08-端口安全命令
本章节下载 (171.82 KB)
1.1.2 display port-security mac-address block
1.1.3 display port-security mac-address security
1.1.4 port-security authorization ignore
1.1.6 port-security intrusion-mode
1.1.7 port-security mac-address security
1.1.8 port-security max-mac-count
1.1.11 port-security port-mode
1.1.12 port-security timer disableport
本章所指的交换机代表了一般意义下的交换设备,以及配置了交换功能的无线控制器设备。为提高可读性,在手册的描述中将不另行说明。
display port-security [ interface interface-list ]
interface interface-list:以太网端口列表,表示多个以太网端口。表示方式为interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>。其中,interface-type为端口类型,interface-number为端口号。&<1-10>表示前面的参数最多可以输入10次。起始端口类型必须和终止端口类型一致,并且终止端口号必须大于起始端口号。
【描述】
display port-security命令用来显示端口安全的配置信息、运行情况和统计信息。
需要注意的是,如果不指定参数interface interface-list则显示所有端口的端口安全信息。
相关配置可参考命令port-security enable、port-security port-mode、port-security ntk-mode、port-security intrusion-mode、port-security max-mac-count、port-security mac-address security、port-security authorization ignore、port-security oui和port-security trap。
# 显示所有端口的端口安全状态。
<Sysname> display port-security
Equipment port-security is enabled
AddressLearn trap is enabled
Intrusion trap is enabled
Dot1x logon trap is enabled
Dot1x logoff trap is enabled
Dot1x logfailure trap is enabled
RALM logon trap is enabled
RALM logoff trap is enabled
RALM logfailure trap is enabled
Disableport Timeout: 20s
OUI value:
Index is 1, OUI value is 000d1a
Index is 2, OUI value is 003c12
GigabitEthernet0/0/1 is link-down
Port mode is UserloginWithOUI
NeedtoKnow mode is needtoknowonly
Intrusion mode is disableport
Max MAC address number is 50
Stored MAC address number is 0
Authorization is ignored
GigabitEthernet0/0/2 is link-down
Port mode is noRestriction
NeedtoKnow mode is disabled
Intrusion mode is no action
Max MAC address number is not configured
Authorization is permitted
表1-1 display port-security命令显示信息描述表
Equipment port-security is enabled |
端口安全已经开启 |
AddressLearn trap is enabled |
端口学习告警已经开启 |
Intrusion trap is enabled |
入侵检测告警已经开启 |
Dot1x logon trap is enabled |
802.1x认证成功告警已经开启 |
Dot1x logoff trap is enabled |
802. 1x认证用户下线告警已经开启 |
Dot1x logfailure is enabled |
802. 1x认证失败告警已经开启 |
RALM logon trap is enabled |
MAC地址认证成功告警已经开启 |
RALM logoff trap is enabled |
MAC地址认证用户下线告警已经开启 |
RALM logfailure trap is enabled |
MAC地址认证失败告警已经开启 |
Disableport Timeout: 20 s |
端口暂时被关闭20秒 |
OUI value |
24位的OUI值 |
Index |
OUI的索引 |
Port mode is UserloginWithOUI |
端口安全模式为UserloginWithOUI |
NeedtoKnow mode is needtoknowonly |
NeedtoKnow模式为needtoknowonly |
Intrusion mode is disableport |
入侵检测特性为disableport |
Max MAC address number |
端口下最大安全MAC地址数 |
Stored MAC address number |
保存的MAC地址数 |
Authorization is ignored |
服务器的授权信息将被忽略 |
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
interface interface-type interface-number:显示指定端口的阻塞MAC地址信息。其中,interface-type interface-number表示端口类型和端口编号。
vlan vlan-id:显示指定VLAN的阻塞MAC地址信息。其中,vlan-id表示VLAN编号,取值范围为1~4094。
count:统计符合条件的阻塞MAC地址个数。
【描述】
display port-security mac-address block命令用来显示阻塞MAC地址信息。
需要注意的是,如果不指定任何参数,则显示所有阻塞MAC地址的信息。
相关配置可参考命令port-security intrusion-mode。
# 显示所有阻塞MAC地址。
<Sysname> display port-security mac-address block
MAC ADDR From Port VLAN ID
0002-0002-0002 GigabitEthernet0/0/1 1
000d-88f8-0577 GigabitEthernet0/0/1 1
--- 2 mac address(es) found ---
# 显示所有阻塞MAC地址计数。
<Sysname> display port-security mac-address block count
# 显示指定VLAN中的阻塞MAC地址。
<Sysname> display port-security mac-address block vlan 1
# 显示指定端口下的阻塞MAC地址。
<Sysname> display port-security mac-address block interface GigabitEthernet0/0/1
--- 1 mac address(es) found ---
# 显示指定端口下的在指定VLAN中的阻塞MAC地址。
<Sysname> display port-security mac-address block interface GigabitEthernet 0/0/1 vlan 1
表1-2 display port-security mac-address block命令显示信息描述表
MAC ADDR |
阻塞MAC地址 |
From Port |
阻塞MAC地址所在端口 |
VLAN ID |
端口所属VLAN |
2 mac address(es) found |
当前阻塞MAC地址数目 |
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
interface interface-type interface-number:显示指定端口的安全MAC地址信息。其中,interface-type interface-number表示端口类型和端口编号。
vlan vlan-id:显示指定VLAN的安全MAC地址信息。其中,vlan-id表示VLAN编号,取值范围为1~4094。
count:统计符合条件的安全MAC地址个数。
【描述】
display port-security mac-address security命令用来显示安全MAC地址信息。
需要注意的是,如果不指定任何参数,则显示所有安全MAC地址的信息。
相关配置可参考命令port-security mac-address security。
# 显示所有安全MAC地址。
<Sysname> display port-security mac-address security
MAC ADDR VLAN ID STATE PORT INDEX AGING TIME(s)
0002-0002-0002 1 Security GigabitEthernet0/0/1 NOAGED
000d-88f8-0577 1 Security GigabitEthernet0/0/1 NOAGED
# 显示所有安全MAC地址计数。
<Sysname> display port-security mac-address count
# 显示指定VLAN中的安全MAC地址。
<Sysname> display port-security mac-address security vlan 1
# 显示指定端口下的安全MAC地址。
<Sysname> display port-security mac-address security interface GigabitEthernet0/0/1
# 显示指定端口下的在指定VLAN中的安全MAC地址。
<Sysname> display port-security mac-address security interface GigabitEthernet 0/0/1 vlan 1
表1-3 display port-security mac-address命令显示信息描述表
MAC ADDR |
安全MAC地址 |
VLAN ID |
端口所属VLAN |
STATE |
添加的MAC地址类型 |
PORT INDEX |
安全MAC地址所在端口 |
AGING TIME(s) |
安全MAC地址的存活时间 |
当前保存的安全MAC地址数目 |
undo port-security authorization ignore
二层以太网端口视图
无
【描述】
port-security authorization ignore命令用来配置端口不应用RADIUS服务器下发的授权信息。undo port-security port-mode ignore命令用来恢复缺省情况。
缺省情况下,端口应用RADIUS服务器下发的授权信息。
相关配置可参考命令display port-security。
# 配置端口GigabitEthernet0/0/1不应用RADIUS服务器下发的授权信息。
[Sysname] interface gigabitethernet 0/0/1
[Sysname-GigabitEthernet0/0/1] port-security authorization ignore
undo port-security enable
无
【描述】
port-security enable命令用来使能端口安全功能。undo port-security enable命令用来关闭端口安全功能。
缺省情况下,端口安全功能处于关闭状态。
(1) 如果已全局开启了802.1x或MAC地址认证功能,则无法使能端口安全功能。
(2) 端口安全功能使能后,端口的如下配置会被自动恢复为(括弧内的)缺省情况,且以下配置不能再进行手动配置,只能随端口安全模式的改变由系统配置:
l 802.1x认证(关闭)、端口接入控制方式(macbased)、端口接入控制模式(auto);
l MAC地址认证(关闭)。
(3) 端口安全功能关闭时,端口的如下配置会被自动恢复为(括弧内的)缺省情况:
l 端口安全模式(noRestrictions);
l MAC地址认证(关闭)。
(4) 端口上有用户在线的情况下,端口安全功能无法关闭。
相关配置可参考命令display port-security、“802.1x-HABP-MAC地址认证命令”中的命令dot1x、dot1x port-method、dot1x port-control和mac-authentication。
# 使能端口安全功能。
[Sysname] port-security enable
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
undo port-security intrusion-mode
二层以太网端口视图
blockmac:表示将非法报文的源MAC地址加入阻塞MAC地址列表中,源MAC地址为阻塞MAC地址的报文将被丢弃。此MAC地址在被阻塞3分钟(系统默认,不可配)后恢复正常。
disableport:表示将收到非法报文的端口永久关闭。
disableport-temporarily:表示将收到非法报文的端口暂时关闭一段时间。关闭时长可通过port-security timer disableport命令配置。
【描述】
port-security intrusion-mode命令用来配置入侵检测特性。undo port-security intrusion-mode命令用来缺省情况。
缺省情况下,不进行入侵检测处理。
相关配置可参考命令display port-security和port-security timer disableport。
# 配置端口GigabitEthernet0/0/1的入侵检测特性被触发后,将非法报文的源MAC地址置为阻塞MAC。
[Sysname-GigabitEthernet0/0/1] port-security intrusion-mode blockmac
在二层以太网端口视图下:
port-security mac-address security mac-address vlan vlan-id
在系统视图下:
port-security mac-address security mac-address interface interface-type interface-number vlan vlan-id
undo port-security mac-address security [ [ mac-address [ interface interface-type interface-number ] ] vlan vlan-id ]
二层以太网端口视图/系统视图
mac-address:安全MAC地址,格式为H-H-H。
interface interface-type interface-number:指定添加安全MAC地址的端口。其中,interface-type interface-number表示端口类型和端口编号。
vlan vlan-id:指定安全MAC地址所属的VLAN。其中,vlan-id表示VLAN编号,取值范围为1~4094。
【描述】
port-security mac-address security命令用来添加安全MAC地址。undo port-security mac-address security命令用来删除匹配的安全MAC地址。
缺省情况下,未配置安全MAC地址。
l 此命令只有在端口安全功能打开且指定端口的端口安全模式为autoLearn的时候才能配置成功。
l 删除安全MAC地址的命令只能在系统视图下执行。
# 在系统视图下为端口GigabitEthernet0/0/1添加一条安全MAC地址:0001-0001-0002,该安全MAC地址属于VLAN10。
[Sysname] port-security mac-address security 0001-0001-0002 interface gigabitethernet 0/0/1 vlan 10
# 在端口视图下为端口GigabitEthernet0/0/1添加一条安全MAC地址:0001-0002-0003,该安全MAC弟子属于VLAN4。
[Sysname-GigabitEthernet0/0/1] port-security mac-address security 0001-0002-0003 vlan 4
port-security max-mac-count count-value
undo port-security max-mac-count
二层以太网端口视图
count-value:端口允许的最大安全MAC地址数,取值范围为1~1024。
【描述】
port-security max-mac-count命令用来设置端口允许的最大安全MAC地址数。undo port-security max-mac-count命令用来恢复缺省情况。
缺省情况下,最大安全MAC地址数不受限制。
l 该值未配置的情况下,不能开启autoLearn模式。
l 端口允许的最大安全MAC地址数不统计手工设置的静态MAC地址,而且手工设置的静态MAC地址也不受此数目限制。
l 端口允许的最大安全MAC地址数不能小于当前端口下已保存的MAC地址数。
# 配置端口GigabitEthernet0/0/1允许的最大安全MAC地址数为100。
[Sysname-GigabitEthernet0/0/1] port-security max-mac-count 100
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkonly }
undo port-security ntk-mode
以太网端口视图
ntk-withbroadcasts:仅发送目的地址为已认证的MAC地址或广播地址的报文。
ntk-withmulticasts:仅发送目的地址为已认证的MAC地址、广播地址或组播地址的报文。
ntkonly:仅发送目的地址为已认证的MAC地址的报文。
【描述】
port-security ntk-mode命令用来配置端口NeedToKnow特性。undo port-security ntk-mode命令用来恢复缺省配置。
缺省情况下,端口没有配置NeedToKnow特性,即所有报文都可成功发送。
# 配置端口GigabitEthernet0/0/1的NeedToKnow特性为ntkonly。
[Sysname-GigabitEthernet0/0/1] port-security ntk-mode ntkonly
port-security oui oui-value index index-value
undo port-security oui index index-value
oui-value:OUI值,输入格式为H-H-H的48位MAC地址。系统会自动取输入的前24位做为OUI值,忽略后24位。
index-value:标识此OUI的索引值,取值范围为1~16。
【描述】
port-security oui命令用来配置用户认证的OUI值,在端口安全模式为UserLoginWithOUI时使用。undo port-security oui命令用来删除指定索引的OUI值。
缺省情况下,没有设置用户认证的OUI值。
需要注意的是,本命令设置的OUI值,只在端口安全模式为userLoginWithOUI时生效。
# 配置OUI值为000d2a,索引为4。
[Sysname] port-security oui 000d-2a10-0033 index 4
port-security port-mode { autolearn | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
端口视图
autolearn:设置端口安全模式为autoLearn模式。
mac-authentication:设置端口安全模式为macAddressWithRadius模式。
mac-else-userlogin-secure:设置端口安全模式为macAddressElseUserLoginSecure模式。
mac-else-userlogin-secure-ext:设置端口安全模式为macAddressElseUserLoginSecureExt模式。
secure:设置端口安全模式为secure模式。
userlogin:设置端口安全模式为userLogin模式。
userlogin-secure:设置端口安全模式为userLoginSecure模式。
userlogin-secure-ext:设置端口安全模式为userLoginSecureExt模式。
userlogin-secure-or-mac:设置端口安全模式为macAddressOrUserLoginSecure模式。
userlogin-secure-or-mac-ext:设置端口安全模式为macAddressOrUserLoginSecureExt模式。
userlogin-withoui:设置端口安全模式为userLoginWithOUI。
【描述】
port-security port-mode命令用来配置端口安全模式。undo port-security port-mode命令用来恢复缺省情况。
缺省情况下,端口处于noRestrictions模式,此时该端口下端口安全特性不生效。
l 端口安全模式与端口下的802.1x认证使能、端口接入控制方式、端口接入控制模式以及端口下的MAC地址认证使能配置互斥。
l 当端口安全已经使能且当前端口安全模式不是noRestrictions时,若要改变端口安全模式,必须首先执行undo port-security port-mode命令恢复端口安全模式为noRestrictions模式。
l 端口上有用户在线的情况下,端口安全模式无法改变。
# 配置端口GigabitEthernet0/0/1的端口安全模式为secure。
[Sysname-GigabitEthernet0/0/1] port-security port-mode secure
# 将端口GigabitEthernet0/0/1的端口安全模式改变为userLogin。
[Sysname-GigabitEthernet0/0/1] undo port-security port-mode
[Sysname-GigabitEthernet0/0/1] port-security port-mode userlogin
port-security timer disableport time-value
undo port-security timer disableport
time-value:端口静默时间,取值范围为20~300,单位为秒。
【描述】
port-security timer disableport命令用来配置系统暂时关闭端口连接的时间。undo port-security timer disableport命令用来恢复缺省情况。
缺省情况下,系统暂时关闭端口连接的时间为20秒。
# 配置系统暂时关闭端口连接的时间为30秒。
[Sysname] port-security timer disableport 30
port-security trap { addresslearned | dot1xlogfailure | dot1xlogoff | dot1xlogon | intrusion | ralmlogfailure | ralmlogoff | ralmlogon }
undo port-security trap { addresslearned | dot1xlogfailure | dot1xlogoff | dot1xlogon | intrusion | ralmlogfailure | ralmlogoff | ralmlogon }
addresslearned:端口学习告警。在端口学习到新MAC地址时发出告警信息。
dot1xlogfailure:802.1x认证失败告警。
dot1xlogon:802.1x认证成功告警。
dot1xlogoff:802.1x认证用户下线告警。
intrusion:发现非法报文告警。
ralmlogfailure:MAC地址认证失败告警。
ralmlogoff:MAC地址认证用户下线告警。
ralmlogon:MAC地址认证成功告警。
【描述】
port-security trap命令用来打开指定告警功能。undo port-security trap命令用来关闭指定告警功能。
缺省情况下,所有告警功能处于关闭状态。
# 打开端口学习告警功能。
[Sysname] port-security trap addresslearned
