- 15-WLAN advanced features
- 01-Example for Configuring WLAN Probe
- 02-Example for Configuring Multicast Optimization
- 03-Example for Configuring Client Rate Limiting
- 04-Example for Configuring WLAN Load Balancing
- 05-Example for Configuring the WLAN Static Blacklist
- 06-Example for Configuring Client Quantity Control
- 07-Example for Configuring iBeacon Transmission for a BLE Module
- 08-Example for Configuring Medical RFID Tag Management
- 09-Example for Configuring iBeacon Management
- 10-Example for Configuring a Mesh Link Between a Fit AP and a Fat AP
- 11-Example for Configuring a Mesh Link Between Fit APs
- 12-Example for Configuring Auto-DFS and Auto-TPC
- 13-Example for Configuring Dual-Uplink Interfaces
- 14-Example for Configuring AP Image Downloading
- 15-Examples for Configuring Centralized Management of Cloud-Managed APs
- 16-Example for Configuring AeroScout Wi-Fi Tag Location
- 17-Example for Configuring the WLAN-based E-Schoolbag service
- 18-Example for Configuring AP Name-based Filtering and Control for the Bonjour Gateway
- 19-Example for Configuring AP Position-based Filtering and Control for the Bonjour Gateway
- 20-Example for Configuring AP Group-based Filtering and Control for the Bonjour Gateway
| 10-Example for Configuring a Mesh Link Between a Fit AP and a Fat AP | 202.53 KB |
Example: Configuring a mesh link between a fit AP and a fat AP
Introduction
The following information provides an example of configuring a mesh link between a fit AP and a fat AP.
As shown in Figure 1, in centralized forwarding mode, the AC in LAN 1 is connected to Switch 1, and Switch 1 assigns an IP address to the AP and client in LAN 1 as a DHCP server. Switch 2 assigns an IP address to the client in LAN 2 as a DHCP server. Configure the devices to meet the following requirements:
· AP 1 obtains an IP address from the address pool on VLAN 10 configured on Switch 1 and comes online from the AC.
· The clients in LAN 1 and LAN 2 are assigned to different VLANs and are reachable to each other at Layer 3.
· Use the actual serial ID of an AP to uniquely identify that AP.
· Configure GE 1/0/4 that connects Switch 1 to the AP as a trunk port, and remove the port from VLAN 1.
· To avoid mesh link errors, do not configure WLAN mesh and auto bandwidth adjustment of WLAN RRM at the same time.
Procedures
Configuring Switch 1
1. Configure interfaces on Switch 1:
# Create VLAN 10 and VLAN-interface 10, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<Switch1> system-view
[Switch1] vlan 10
[Switch1-vlan10] quit
[Switch1] interface vlan-interface 10
[Switch1-Vlan-interface10] ip address 172.16.1.1 255.255.255.0
[Switch1-Vlan-interface10] quit
# Create VLAN 20 and VLAN-interface 20, and assign an IP address to the VLAN interface. This VLAN will use be used as the gateway for the clients.
[Switch1] vlan 20
[Switch1-vlan20] quit
[Switch1] interface vlan-interface 20
[Switch1-Vlan-interface20] ip address 192.168.10.1 255.255.255.0
[Switch1-Vlan-interface20] quit
# Create VLAN 30 and VLAN-interface 30, and assign an IP address to the VLAN interface. The switch will use this VLAN to communicate with the AP.
[Switch1] vlan 30
[Switch1-vlan30] quit
[Switch1] interface vlan-interface 30
[Switch1-Vlan-interface30] ip address 10.12.12.1 255.255.255.0
[Switch1-Vlan-interface30] quit
# Configure GigabitEthernet 1/0/1 that connects Switch 1 to the AC as a trunk port, and assign the port to all VLANs.
[Switch1] interface gigabitEthernet 1/0/1
[Switch1-GigabitEthernet1/0/1] port link-type trunk
[Switch1-GigabitEthernet1/0/1] port trunk permit vlan all
[Switch1-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/4 that connects Switch 1 to AP 1 as a trunk port, remove the port from VLAN 1, and assign the port to all the other VLANs.
[Switch1] interface gigabitEthernet 1/0/4
[Switch1-GigabitEthernet1/0/4] port link-type trunk
[Switch1-GigabitEthernet1/0/4] port trunk permit vlan all
[Switch1-GigabitEthernet1/0/4] undo port trunk permit vlan 1
# Set the PVID of GigabitEthernet 1/0/4 to VLAN 10.
[Switch1-GigabitEthernet1/0/4] port trunk pvid vlan 10
[Switch1-GigabitEthernet1/0/4] quit
# Assign GigabitEthernet 1/0/2 that connects Switch 1 to Client 1 to VLAN 20.
[Switch1] interface gigabitEthernet 1/0/2
[Switch1-GigabitEthernet1/0/2] port access vlan 20
[Switch1-GigabitEthernet1/0/2] quit
[Switch1] quit
2. Configure the DHCP server:
# Enable DHCP.
[Switch1] dhcp enable
# Specify 172.16.1.0/24 as the address range for dynamic allocation in DHCP address pool 1, and specify 172.16.1.1 as the gateway address.
[Switch1] dhcp server ip-pool 1
[Switch1-dhcp-pool-1] network 172.16.1.0 mask 255.255.255.0
[Switch1-dhcp-pool-1] gateway-list 172.16.1.1
# Exclude 172.16.1.2 from dynamic allocation.
[Switch1-dhcp-pool-1] forbidden-ip 172.16.1.2
[Switch1-dhcp-pool-1] quit
# Configure DHCP address pool 2. In the address pool, specify 192.168.10.1 as the gateway IP address, 192.168.10.0/24 as the subnet for dynamic allocation, and 192.168.10.1 as the DNS server address.
[Switch1] dhcp server ip-pool 2
[Switch1-dhcp-pool-2] network 192.168.10.0 mask 255.255.255.0
[Switch1-dhcp-pool-2] gateway-list 192.168.10.1
[Switch1-dhcp-pool-2] dns-list 192.168.10.1
[Switch1-dhcp-pool-2] quit
3. # Configure a route to the network where Client 2 resides.
[Switch1] ip route-static 192.168.20.0 255.255.255.0 10.12.12.2
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 10 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
[AC] vlan 10
[AC-vlan10] quit
[AC] interface vlan-interface 10
[AC-Vlan-interface10] ip address 172.16.1.2 255.255.255.0
[AC-Vlan-interface10] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to Switch 1 as a trunk port, and assign the port to all VLANs.
[AC-GigabitEthernet1/0/1] port trunk permit vlan all
2. Configure a fit AP:
NOTE: In a large-scale network, configure AP settings in AP group view instead of AP view as a best practice. |
# Create a manual AP named ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6330
[AC-wlan-ap-ap1] serial-id 219801A23V8192E00021
[AC-wlan-ap-ap1] quit
# Create AP group group1, and configure a grouping rule by AP name to add AP ap1 to the group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
[AC-wlan-ap-group-group1] ap-model WA6330
[AC-wlan-ap-group-group1-ap-model-WA6330] radio 1
# Enter the view of radio 1, specify the radio type as dot11an, and specify the channel as 36.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] type dot11an
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] channel 36
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] quit
[AC-wlan-ap-group-group1] quit
3. Configure a mesh profile:
# Create mesh profile 1.
[AC] wlan mesh-profile 1
# Set the mesh ID to 1.
[AC-wlan-mesh-profile-1] mesh-id 1
# Set the authentication and key management (AKM) mode to sae.
[AC-wlan-mesh-profile-1] akm mode sae
# Configure simple character string meshlink as the PSK.
[AC-wlan-mesh-profile-1] preshared-key pass-phrase simple meshlink
# Enable the mesh profile.
[AC-wlan-mesh-profile-1] mesh-profile enable
[AC-wlan-mesh-profile-1] quit
# Bind radio 1 to the mesh profile.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh-profile 1
4. Add the MAC address of AP 2 to the mesh peer whitelist for AP ap1.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh peer-mac-address 90e7-1066-e060
[AC-wlan-ap-group-group1-ap-model-WA6330] quit
5. Configure a WLAN-mesh interface:
# Create a WLAN-mesh interface.
[AC-wlan-ap-group-group1] interface wlan-mesh 1
# Configure WLAN-mesh interface 1 as a trunk port, and assign the port to all VLANs.
[AC-wlan-ap-group-group1-wlan-mesh-1] mesh-port link-type trunk
[AC-wlan-ap-group-group1-wlan-mesh-1] mesh-port trunk permit vlan all
[AC-wlan-ap-group-group1-wlan-mesh-1] quit
# Bind WLAN-mesh interface 1 to radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh-interface 1
6. Editing the AP’s configuration file
# Edit the AP’s configuration file, name it map.txt.
vlan 30
7. Upload the configuration file to the AC.
[AC-wlan-ap-group-group1-ap-model-WA6330] map-configuration map.txt
Configuring Switch 2
1. Configure interfaces on Switch 2:
# Create VLAN 40 and VLAN-interface 40, and assign an IP address to the VLAN interface. This VLAN will be used for client access.
<Switch2> system-view
[Switch2] vlan 40
[Switch2-vlan40] quit
[Switch2] interface vlan-interface 40
[Switch2-Vlan-interface40] ip address 192.168.20.2 255.255.255.0
[Switch2-Vlan-interface40] quit
# Configure GigabitEthernet 1/0/1 that connects Switch 2 to the AC as a trunk port, and assign the port to all VLANs.
[Switch2] interface gigabitEthernet 1/0/1
[Switch2-GigabitEthernet1/0/1] port link-type trunk
[Switch2-GigabitEthernet1/0/1] port trunk permit vlan all
[Switch2-GigabitEthernet1/0/1] quit
# Assign GigabitEthernet1/0/2 that connects Switch 2 to Client 2 to VLAN 40.
[Switch2] interface gigabitEthernet 1/0/2
[Switch2-GigabitEthernet1/0/2] port access vlan 40
[Switch2-GigabitEthernet1/0/2] quit
# Enable DHCP.
[Switch2] dhcp enable
# Specify 192.168.20.0/24 as the address range for dynamic allocation in DHCP address pool 1, and specify 192.168.20.1 as the gateway address.
[Switch2] dhcp server ip-pool 1
[Switch2-dhcp-pool-1] network 192.168.20.0 mask 255.255.255.0
[Switch2-dhcp-pool-1] gateway-list 192.168.20.1
# Exclude 192.168.20.1 from dynamic allocation.
[Switch2-dhcp-pool-1] forbidden-ip 192.168.20.1
[Switch2-dhcp-pool-1] quit
Configuring AP 2
1. Configure interfaces on AP 2:
# Create VLAN 30 and VLAN-interface 30, and assign an IP address to the VLAN interface. The AP will use this VLAN to communicate with Switch 1.
<AP2> system-view
[AP2] vlan 30
[AP2-vlan30] quit
[AP2] interface vlan-interface 30
[AP2-Vlan-interface30] ip address 10.12.12.2 255.255.255.0
[AP2-Vlan-interface30] quit
# Create VLAN 40 and VLAN-interface 20, and assign an IP address to the VLAN interface. This VLAN will be used as the gateway for the clients.
[AP2] vlan 40
[AP2-vlan40] quit
[AP2] interface vlan-interface 40
[AP2-Vlan-interface40] ip address 192.168.20.1 255.255.255.0
[AP2-Vlan-interface40] quit
2. Configure a radio interface:
# Enter the view of WLAN-Radio 1/0/1, specify the radio type as dot11an, and specify the channel as 36.
[AP2] interface wlan-radio 1/0/1
[AP2-WLAN-Radio1/0/1] type dot11an
[AP2-WLAN-Radio1/0/1] channel 36
[AP2-WLAN-Radio1/0/1] quit
[AP2] wlan mesh-profile 1
[AP2-wlan-mesh-profile-1] mesh-id 1
[AP2-wlan-mesh-profile-1] akm mode sae
[AP2-wlan-mesh-profile-1] preshared-key pass-phrase simple meshlink
[AP2-wlan-mesh-profile-1] mesh-profile enable
[AP2-wlan-mesh-profile-1] quit
# Bind WLAN-Radio 1/0/1 to the mesh profile.
[AP2-WLAN-Radio1/0/1] mesh-profile 1
4. Add the MAC address of AP 1 to the mesh peer whitelist for the fat AP.
[AP2-WLAN-Radio1/0/1] mesh peer-mac-address 542b-dea7-a8c0
[AP2] interface wlan-mesh 1
[AP2-WLAN-Mesh1] port link-type trunk
[AP2-WLAN-Mesh1] port trunk permit vlan all
[AP2-WLAN-Mesh1] quit
# Bind WLAN-mesh interface 1 to WLAN-Radio 1/0/1.
[AP2-WLAN-Radio1/0/1] mesh-interface 1
6. Configure a route to the network where Client 1 resides.
[AP2] ip route-static 192.168.10.0 255.255.255.0 10.12.12.1
1. Verify that AP 1 has been associated with the AC. If the AP is in R/M state, the AP has been associated with the AC.
<AC> display wlan ap name ap1
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name APID State Model Serial ID
ap1 1 R/M WA6330 219801A23V8192E00021
2. Display mesh link information on the fat AP:
<AP2> display wlan mesh-link
Peer MAC RSSI BSSID Interface Link state Online time
542b-dea7-a8c0 81 d461-fe59-4d20 WLAN-MeshLink2 Active(an) 20h 00m 49s
3. Ping Client 2 from Client 1 to verify that they are reachable to each other.
C:\Users\system32> ping 192.168.20.3
Pinging 192.168.20.3 with 32 bytes of data:
Reply from 192.168.20.3: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.20.3:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Configuration files
· Switch 1:
dhcp enable
vlan 10
vlan 20
vlan 30
interface Vlan-interface10
interface Vlan-interface20
interface Vlan-interface30
port access vlan 20
interface GigabitEthernet1/0/4
port trunk permit vlan 2 to 4094
· AC:
wlan mesh-profile 1
mesh-id 1
akm mode sae
preshared-key pass-phrase cipher $c$3$qVXx1KuNn4FeEi3nMUkQ7A8jcIMrN8JH2AOv
mesh-profile enable
vlan 10
map-configuration flash:/map.txt
vlan 1
ap ap1
ap-model WA6330
radio 1
type dot11an
channel 36
radio enable
mesh-interface 1
mesh-profile 1
· Switch 2:
dhcp enable
vlan 40
interface Vlan-interface40
port access vlan 40
· AP 2:
wlan mesh-profile 1
mesh-id 1
akm mode sae
mesh-profile enable
vlan 30
vlan 40
interface WLAN-Radio1/0/1
mesh-profile 1
mesh-interface 1
type dot11an
channel 36
interface WLAN-Mesh1
Related documentation
· AP Management Command Reference in H3C Access Controllers Command References
· AP Management Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Mesh Command Reference in H3C Access Controllers Command References
· WLAN Mesh Configuration Guide in H3C Access Controllers Configuration Guides
