15-WLAN advanced features
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10515-WLAN advanced features
02-Example for Configuring Multicast Optimization
Example: Configuring multicast optimization
Introduction
The following information provides examples for configuring multicast optimization.
As shown in Figure 1:
·     The AC acts as a DHCP server to assign IP addresses to the AP and clients.
·     The AP provides wireless services service1 and service2 for Client 1 and Client 2, respectively.
·     The AC forwards client traffic.
Configure multicast optimization so that Client 1 can receive video stream for multicast group 224.1.1.1 and Client 2 cannot receive the video stream.
Figure 1 Network diagram
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 2.2.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 2.2.2.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 as a trunk port. Remove the port from VLAN 1, assign the port to VLAN 100 and VLAN 200, and set the PVID to 100.
[AC] interface gigabitethernet1/0/1
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2.     Configure DHCP:
# Enable DHCP.
[AC] dhcp enable
# Configure DHCP address pool vlan100 and specify subnet 112.12.0.0/16 and gateway address 112.12.1.25 in the address pool.
[AC] dhcp server ip-pool vlan100
[AC-dhcp-pool-vlan100] network 112.12.0.0 mask 255.255.0.0
[AC-dhcp-pool-vlan100] gateway-list 112.12.1.25
[AC-dhcp-pool-vlan100] quit
# Configure a DHCP address pool vlan200, specify subnet 112.13.0.0/16 and gateway address 112.13.1.25 in this address pool, and specify the gateway as the DNS server. Configure the DNS server according to the actual network plan.
[AC] dhcp server ip-pool vlan200
[AC-dhcp-pool-vlan200] network 112.13.0.0 mask 255.255.0.0
[AC-dhcp-pool-vlan200] gateway-list 112.13.1.25
[AC-dhcp-pool-vlan200] dns-list 112.13.1.25
[AC-dhcp-pool-vlan200] quit
3.     Configure the AP:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create an AP named ap1, and specify its model and serial ID.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC-wlan-ap-ap1] quit
4.     Configure wireless services:
# Create a service template named service1.
[AC] wlan service-template service1
# Set the SSID to service1.
[AC-wlan-st-service1] ssid service1
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-service1] vlan 200
# Set the AKM mode to PSK, and specify plaintext string 12345678 as the preshared key.
[AC-wlan-st-service1] akm mode psk
[AC-wlan-st-service1] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-service1] cipher-suite ccmp
[AC-wlan-st-service1] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-service1] client forwarding-location ac
# Enable WLAN multicast optimization.
[AC-wlan-st-service1] multicast-optimization enable
# Enable the service template.
[AC-wlan-st-service1] service-template enable
[AC-wlan-st-service1] quit
# Create a service template named service2.
[AC] wlan service-template service2
# Set the SSID to service2.
[AC-wlan-st-service2] ssid service2
[AC-wlan-st-service2] vlan 200
[AC-wlan-st-service2] akm mode psk
[AC-wlan-st-service2] preshared-key pass-phrase simple 12345678
[AC-wlan-st-service2] cipher-suite ccmp
[AC-wlan-st-service2] security-ie rsn
[AC-wlan-st-service2] client forwarding-location ac
[AC-wlan-st-service2] service-template enable
[AC-wlan-st-service2] quit
# Create AP group group1, and add the AP to the AP group, and specify the AP model.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
[AC-wlan-ap-group-group1] ap-model WA6320
# Bind service template service1 to radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template service1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
# Bind service template service2 to radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template service2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
5.     Configure multicast optimization:
# Enable IGMP snooping globally.
[AC] igmp-snooping
[AC-igmp-snooping] quit
# Enable IGMP snooping and then enable dropping unknown multicast data packets for VLAN 200.
[AC] vlan 200
[AC-vlan200] igmp-snooping enable
[AC-vlan200] igmp-snooping drop-unknown
[AC-vlan200] quit
# Set the aging time to 300 seconds for IPv4 multicast optimization entries.
[AC] wlan multicast-optimization aging-time 300
# Configure the AP to receive a maximum of 100 IGMP packets from clients every 60 seconds.
[AC] wlan multicast-optimization packet-rate-limit interval 60 threshold 100
# Set the limit for IPv4 multicast optimization entries to 100.
[AC] wlan multicast-optimization global entry-limit 100
# Set the limit for multicast optimization entries per client to 8.
[AC] wlan multicast-optimization client entry-limit 8
# Set the maximum number of clients that WLAN multicast optimization supports to 10, and configure the AP to drop multicast packets when the number of clients reaches the threshold.
[AC] wlan multicast-optimization entry client-limit 10 drop
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnel between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 as a trunk port. Remove the port form VLAN 1, assign the port to VLAN 100, and set the PVID to VLAN 100.
[Switch] interface gigabitethernet1/0/1
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 as an access port and assign the port to VLAN 100.
# Enable PoE.
1.     Connect Client 1 and Client 2 to wireless services service1 and service2, respectively. (Details not shown.)
2.     Verify that Client 1 can successfully associate with service1.
[AC] display wlan client service-template service1
Total number of clients: 1
MAC address     Username   AP name         RID  IP address      IPv6 address   VLAN
0024-d705-c600  N/A        ap1             1    112.13.1.26     N/A            200
3.     Verify that Client 2 can successfully associate with service2.
[AC] display wlan client service-template service2
0024-d710-18a4  N/A        ap1             2    112.13.1.27     N/A            200
4.     Verify that Client 1 can successfully receive demanded video stream.
# Demand video stream of multicast group 224.1.1.1 from Client 1. (Details not shown.)
# Send video stream from the source to multicast group 224.1.1.1. (Details not shown.)
# Display IGMP snooping group entries on the AC.
[AC] display igmp-snooping group
Total 1 entries.
VLAN 200: Total 1 entries.
  (0.0.0.0, 224.1.1.1)
    Host slots (0 in total):
    Host ports (2 in total):
      WLAN-BSS1/0/1                       (00:02:45)
The output shows that WLAN-BSS 1/0/1 (connected to Client 1) is a member port of multicast group 224.1.1.1.
# Display Layer 2 multicast fast forwarding entries on the AC.
[AC] display l2-multicast fast-forwarding cache
Total 1 entries, 1 matched
 (1.1.1.100,224.1.1.1)
    Status      : Enable                VLAN            : 200
    Source port : 63                    Destination port: 63
    Protocol    : 17                    Flag            : 0x2
    Ingress port: GigabitEthernet1/0/1
    List of 1 egress ports:
        WLAN-BSS1/0/1
          Status: Enable                Flag: 0x10
The output shows that only Client 1 can receive video stream of multicast group 224.1.1.1.
Configuration files
·     AC:
igmp-snooping
dhcp enable
vlan 100
vlan 200
vlan 200
 ssid service1
 vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
 ssid service2
 vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
 ip address 112.12.1.25 255.255.0.0
interface Vlan-interface200
 ip address 112.13.1.25 255.255.0.0
ap ap1
ap-model WA6320
 radio 1
radio enable
radio 2
radio enable
·     Switch:
vlan 100
vlan 200
poe enable
Related documentation
·     Network Connectivity Command Reference in H3C Access Controllers Command References
·     Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Traffic Optimization Command Reference in H3C Access Controllers Command References
·     WLAN Traffic Optimization Configuration Guide in H3C Access Controllers Configuration Guides
