- 13-High availability
- 01-Example for Configuring IRF Setup with LACP MAD
- 02-Example for Configuring IRF Setup with ARP MAD
- 03-Example for Configuring IRF Setup with Indirectly Connected Members
- 04-Example for Configuring IRF Setup with Members in One Chassis
- 05-Example for Configuring IRF Setup with Members in Different Chassis
- 06-Example for Configuring Dual-Link Backup
- 07-Example for Configuring Remote 802.1X in AC Hierarchy with Dual-Link Central AC Backup
- 08-Example for Configuring Remote Portal in AC Hierarchy with Dual-Link Central AC Backup
- 09-Example for Configuring OAuth MAC-Based Portal in Local-Forwarding Dual-Link Backup
- 10-Example for Configuring OAuth Portal in Local-Forwarding Dual-Link Backup
- 11-Example for Configuring Remote MAC-Based Portal in Local-Forwarding Dual-Link Backup
- 12-Example for Configuring Remote Portal and Transparent MAC in Local-Forwarding Dual-Link Backup
- 13-Example for Configuring Remote Portal in Local-Forwarding Dual-Link Backup
- 14-Example for Configuring Remote Portal and Transparent MAC in Central-Forwarding Dual-Link Backup
- 15-Example for Configuring Remote Portal in Central-Forwarding Dual-Link Backup
- 16-Example for Configuring Lightweight Portal in Central-Forwarding Dual-Link Backup
- 17-Example for Configuring OAuth Portal in Central-Forwarding Dual-Link Backup
- 18-Example for Configuring Remote MAC-Based Portal in Central-Forwarding Dual-Link Backup
- 19-Example for Configuring Remote 802.1X in Dual-Link AC Backup
- 20-Example for Configuring Remote MAC in Dual-Link AC Backup
- 21-Example for Configuring Lightweight Dual-Link Hot Backup and AP License Sync
- 22-Example for Configuring N+1 Backup and AP License Sync
| 06-Example for Configuring Dual-Link Backup | 244.93 KB |
Example: Configuring dual-link backup and AP license synchronization
Introduction
The following information provides a dual-link backup and AP license synchronization configuration example.
Network requirements
As shown in Figure 1, configure AC 1 as the master AC and AC 2 as the backup AC. When AC 1 fails and AC 2 takes over, the AP can communicate through AC 2. Configure the master CAPWAP tunnel preemption feature on the two ACs so that the AP reconnects to AC 1 when AC 1 recovers.
Enable AP license synchronization on AC 1 and AC 2 for the two ACs to back up licenses for each other.
When you configure dual-link backup and AP license synchronization, follow these restrictions and guidelines:
· Make sure the device model is compatible with the software version.
· Use the actual serial ID of an AP to uniquely identify that AP.
· If you use a manual AP to establish CAPWAP tunnels with the ACs, make sure the name of the AP is the same on the two ACs and either a serial ID or MAC address is configured for the AP on the two ACs.
· As a best practice, install a license on the master AC before enabling AP license synchronization.
· Before enabling AP license synchronization, you must specify IP addresses and roles for the AC and its member ACs in the AP license synchronization group.
· Configure both AC 1 and AC 2 as the master in the AP license synchronization group.
· When the master AC fails, the backup AC takes over and becomes the new master AC. The licenses synchronized to the new master AC will be valid for a 30-day grace period.
· Dual-link backup is applicable to both centralized forwarding and local forwarding. This example uses centralized forwarding.
Procedures
Configuring AC 1
Installing a license
# Install a license on AC 1. (Details not shown.)
Configuring interfaces on AC 1
# Configure VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. AC 1 will use this IP address to establish CAPWAP tunnels with APs.
<AC1> system-view
[AC1] vlan 100
[AC1-vlan100] quit
[AC1] interface vlan-interface 100
[AC1-Vlan-interface100] ip address 10.1.1.1 16
[AC1-Vlan-interface100] quit
# Configure GigabitEthernet 1/0/1 that connects AC 1 to the switch as a trunk port, and assign it to all VLANs.
[AC1] interface gigabitethernet 1/0/1
[AC1-GigabitEthernet1/0/1] port link-type trunk
[AC1-GigabitEthernet1/0/1] port trunk permit vlan all
[AC1-GigabitEthernet1/0/1] quit
# Create AP group group1, and set the connection priority to 7.
[AC1] wlan ap-group group1
[AC1-wlan-ap-group-group1] priority 7
# Specify a backup AC.
[AC1-wlan-ap-group-group1] backup-ac ip 10.1.1.2
# Enable master CAPWAP tunnel preemption.
[AC1-wlan-ap-group-group1] wlan tunnel-preempt enable
# Create an AP grouping rule by AP names.
[AC1-wlan-ap-group-group1] ap ap1
[AC1-wlan-ap-group-group1] quit
Configuring AP license synchronization
# Enable AP license synchronization on AC 1 and configure AC 1 as the master AC.
[AC1] wlan ap-license-group
[AC1-wlan-als-group] local ip 10.1.1.1
[AC1-wlan-als-group] member ip 10.1.1.2
[AC1-wlan-als-group] ap-license-synchronization enable
[AC1-wlan-als-group] quit
Configuring a manual AP
# Create an AP named ap1, and specify the AP model and serial ID.
[AC1] wlan ap ap1 model WA6320
[AC1-wlan-ap-ap1] serial-id 219801A28N819CE0002T
Configuring AC 2
(Optional.) Installing a license
# Install a license on AC 2. (Details not shown.)
Configuring interfaces on AC 2
# Configure VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. AC 2 will use this IP address to establish CAPWAP tunnels with APs.
<AC2> system-view
[AC2] vlan 100
[AC2-vlan100] quit
[AC2] interface Vlan-interface 100
[AC2-Vlan-interface100] ip address 10.1.1.2 16
[AC2-Vlan-interface100] quit
# Configure GigabitEthernet 1/0/1 that connects AC 2 to the switch as a trunk port, and assign it to all VLANs.
[AC2] interface gigabitethernet 1/0/1
[AC2-GigabitEthernet1/0/1] port link-type trunk
[AC2-GigabitEthernet1/0/1] port trunk permit vlan all
[AC2-GigabitEthernet1/0/1] quit
# Create AP group group1, and specify a backup AC. Use the default setting for the connection priority.
[AC2] wlan ap-group group1
[AC2-wlan-ap-group-group1] backup-ac ip 10.1.1.1
[AC2-wlan-ap-group-group1] ap ap1
[AC2-wlan-ap-group-group1] quit
[AC2] wlan ap-license-group
[AC2-wlan-als-group] local ip 10.1.1.2
[AC2-wlan-als-group] member ip 10.1.1.1
[AC2-wlan-als-group] ap-license-synchronization enable
[AC2-wlan-als-group] quit
[AC2] wlan ap ap1 model WA6320
[AC2-wlan-ap-ap1] serial-id 219801A28N819CE0002T
Configuring the switch
Configuring interfaces on the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnels between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN interface 100, and assign it an IP address.
[Switch-Vlan-interface100] ip address 10.1.1.3 16
# Configure GigabitEthernet 1/0/1 that connects the switch to AC 1 as a trunk port, and assign the trunk port to all VLANs.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan all
# Configure GigabitEthernet 1/0/2 that connects the switch to AC 2 as a trunk port, and assign the port to all VLANs.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan all
# Configure GigabitEthernet 1/0/3 that connects the switch to the AP as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 100
# Enable the PoE feature.
[Switch-GigabitEthernet1/0/3] poe enable
[Switch-GigabitEthernet1/0/3] quit
Configuring DHCP
# Create DHCP address pool 100. Specify the 10.1.0.0/16 subnet for the pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 10.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-100] quit
# Enable DHCP.
[Switch] dhcp enable
# Display AP license synchronization group information on AC 1 to verify that the number of licenses in the group is the sum of licenses installed on AC 1 and AC 2.
<AC1> display wlan ap-license-group
Group total licenses: 256
Group used licenses: 1
AP license synchronization: Enabled
Local IP: 10.1.1.1
Local role: Master
Member information: 1
IP address Total Used Member role State Online duration
10.1.1.2 0 0 Master UP 00hr 1min 51sec
# Verify that the AP state is R/M on AC 1.
<AC1> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 384
Remaining APs: 383
Total AP licenses: 256
Local AP licenses: 256
Server AP licenses: 0
Remaining local AP licenses: 255
Sync AP licenses: 0
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name APID State Model Serial ID
ap1 1 R/M WA6320 219801A28N819CE0002T
# Verify that the AP state is R/M on AC 1 and R/B on AC 2, and the number of licenses is 256.
<AC2> display wlan ap all
Remaining APs: 383
Remaining local AP licenses: 256
Sync AP licenses: 256
AP information
ap1 1 R/B WA6320 219801A28N819CE0002T
# Shut down VLAN-interface 1 on AC 2 and wait for no longer than 30 seconds, during which service interruption occurs. Verify that the AP is in R/M state.
Remaining APs: 383
AP information
# Bring up VLAN-interface 1 on AC 1. Verify that the AP state is R/M on AC 1 and R/B on AC 2. (Details not shown.)
Configuration files
· AC 1:
vlan 100
interface Vlan-interface100
ip address 10.1.1.1 255.255.0.0
priority 7
ap ap1
local ip 10.1.1.1
member ip 10.1.1.2
· AC 2:
vlan 100
ip address 10.1.1.2 255.255.0.0
ap ap1
local ip 10.1.1.2
member ip 10.1.1.1
· Switch
dhcp enable
vlan 100
ip address 10.1.1.3 255.255.0.0
poe enable
Related documentation
· AP License Synchronization Command Reference in H3C Access Controllers Command References
· AP License Synchronization Configuration Guide in H3C Access Controllers Configuration Guides
· AP Management Command Reference in H3C Access Controllers Command References
· AP Management Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN High Availability Command Reference in H3C Access Controllers Command References
· WLAN High Availability Configuration Guide in H3C Access Controllers Configuration Guides
