11-Network Management and Monitoring Configuration Guide
HomeSupportSecurityH3C SecPath L5000Configure & DeployConfiguration GuidesH3C SecPath L5000-AD9X0 Series Configuration Guides(V7)(R9900)-6W10111-Network Management and Monitoring Configuration Guide
04-Email alerting configuration
04-Email alerting configuration 93.46 KB
Configuring email alerting
About email alerting
The email alerting feature enables sending alert emails to the specified email addresses (typically, the network administrator) when particular events occur. When an event occurs, the device generates log information. This feature collects the log information and sends it to the network administrator in an email.
The device supports sending alert emails for the following events:
·     Node failure—When a real server fails or recovers from a failure, an alert email is sent. For information about real servers, see server load balancing in Load Balancing Configuration Guide.
·     Link failure—When a link fails or recovers from a failure, an alert email is sent. For information about links, see outbound link load balancing in Load Balancing Configuration Guide.
·     Network attack—When a network attack is detected, an alert email is sent. This event type is not supported in the current software version. For information about network attack types, see attack detection and prevention configuration in Security Configuration Guide.
Configuring the email server
Only the SMTP server is supported.
2.     Create an email server and enter email server view.
email-server server-name
3.     Specify the IP address or domain name of the email server.
email-server host { domain domain-name | ip ip-address }
By default, the IP address or domain name of the email server is not specified.
If you specify a domain name, you must configure DNS to obtain the mapping between the domain name and IP address of the email server. For more information about DNS, see Layer 3—IP Services Configuration Guide.
4.     (Optional.) Specify the port number of the email server.
email-server port port
By default, the port number of the email server is 25.
5.     (Optional.) Enable client authentication.
email-server client-authentication enable
By default, client authentication is disabled.
For the email server to authenticate the device, enable client authentication.
6.     (Optional.) Configure the username and password used by the email server to authenticate the device.
email-server username username password { cipher | simple } password
By default, the username and password are not configured.
If you have enabled client authentication, you must configure the username and password.
Testing the email server
After configuring the email server, perform this task to test the availability of the email server.
2.     Enter email server view.
3.     Test the email server.
email-server test
Configuring email alerting settings
2.     Create and enter the email view of the warning type.
send-email type warning
3.     Specify an event type that triggers alerts.
event { link-failure | network-attack | node-failure }
By default, no event trigger is specified.
4.     Specify the SMTP server to send alert emails.
By default, no SMTP server is specified.
5.     Configure the email subject.
email-subject subject-string
By default, the email subject is not configured.
6.     Configure the email addresses to receive alert emails.
email-recipients mail-address
By default, no recipients' email addresses are configured.
Use semicolons to separate multiple email addresses.
7.     Configure the email address to send alert emails.
email-sender mail-address
By default, no sender's email address is configured.
Only one sender's email address can be configured.
8.     Set the frequency at which alert emails are sent.
email-frequency interval
The default setting is 60 seconds.
9.     Enable email sending.
email-sending enable
By default, email sending is disabled.
Display and maintenance commands for email alerting
Display the configuration of email servers.
display email-server [ name server-name ]
Display email sending settings.
display send-email [ type warning ]
Email alert configuration examples
Example: Configuring email alerting
As shown in Figure 1, configure server load balancing on the device to load balance FTP traffic on the three servers. Configure email alerting to send alert emails to the network administrator ([email protected]) when a server fails.
Figure 1 Network diagram
Table 1 Interface label and interface name mappings
Interface label
Interface name
Interface1
Ten-GigabitEthernet2/3/1
1.     Assign an IP address to interface Ten-GigabitEthernet 2/3/1.
[Sysname] sysname Device
[Device] interface ten-gigabitethernet 2/3/1
[Device-Ten-GigabitEthernet2/3/1] ip address 171.1.1.2 255.255.255.0
[Device-Ten-GigabitEthernet2/3/1] quit
2.     Configure settings for routing.
This example configures static routes, and the next hop in the routes is 171.1.1.1.
[Device] ip route-static 0.0.0.0 0.0.0.0 171.1.1.1
3.     Configure server load balancing.
For more information, see server load balancing in Load Balancing Configuration Guide.
4.     Configure the email server:
# Create an email server and enter email server view.
[Device] email-server smtp-server1
# Specify the IPv4 address of the email server as 200.1.1.1.
[Device-email-server-smtp-server1] email-server host ip 200.1.1.1
5.     Test the email server:
# Send a test email to test the availability of the configured email server.
[Device-email-server-smtp-server1] email-server test
Email server is available.
# Return to system view.
[Device-email-server-smtp-server1] quit
6.     Configure email sending settings:
# Create and enter the email view of the warning type.
[Device] send-email type warning
# Configure the node failure event as a trigger for sending alert emails.
[Device-email-warning] event node-failure
# Specify smtp-server1 as the SMTP server for sending alert emails.
[Device-email-warning] email-server smtp-server1
# Configure the email subject as The state of real server.
[Device-email-warning] email-subject The state of real server
# Configure the recipient's email address as [email protected].
[Device-email-warning] email-recipients [email protected]
# Configure the sender's email address as [email protected].
[Device-email-warning] email-sender [email protected]
# Enable email sending.
[Device-email-warning] email-sending enable
[Device-email-warning] quit
# Display the configuration of email server smtp-server1.
[Device] display email-server name smtp-server1
Server name: smtp-server1
  Domain name:
  IPv4 address: 200.1.1.1
  IPv6 address:
  Port number: 25
  Email server client-authentication: Enabled
  Email server username: admin
# Display email sending settings.
<Device> display send-email type warning
Email type: Warning
  Event: node-failure
  Email server: smtp-server1
  Email subject: The state of real server
  Email recipients: [email protected]
  Email sender: [email protected]
  Email sending frequency: 60 sec
  Email sending function state: Enabled
