- 11-Network Management and Monitoring Configuration Guide
- 01-Bandwidth management configuration
- 02-BFD configuration
- 03-EAA configuration
- 04-Email alerting configuration
- 05-Event MIB configuration
- 06-Fast log output configuration
- 07-Flow log configuration
- 08-Information center configuration
- 09-NETCONF configuration
- 10-NQA configuration
- 11-NTP configuration
- 13-Process monitoring and maintenance configuration
- 14-Process placement configuration
- 15-RMON configuration
- 16-SNMP configuration
- 17-System maintenance and debugging configuration
- 18-Track configuration
| 00-Preface | 109.79 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures for network management and monitoring features.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
