07-Layer 3—IP Routing Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command Reference-R8630Pxx-6W10007-Layer 3—IP Routing Command Reference
13-Routing policy commands
13-Routing policy commands 494.53 KB
Routing policy commands· 1
Common routing policy commands· 1
apply additional-paths· 1
apply aigp· 1
apply as-path· 2
apply comm-list delete· 3
apply community· 4
apply cost 5
apply cost-type· 6
apply esi 7
apply extcommunity· 7
apply extcommunity color 9
apply extcommunity soo· 10
apply flex-algo· 11
apply gateway-ip· 13
apply ip-precedence· 13
apply ipv6 gateway-ip· 14
apply isis· 15
apply label-index· 16
apply label-value· 16
apply large-comm-list delete· 17
apply large-community· 18
apply local-preference· 19
apply mpls-label 20
apply origin· 21
apply preference· 21
apply preferred-value· 22
apply prefix-priority· 23
apply qos-local-id· 23
apply tag· 24
apply traffic-index· 25
continue· 26
display ip as-path· 26
display ip community-list 27
display ip extcommunity-list 28
display ip large-community-list 29
display ip rd-list 30
display route-policy· 31
if-match as-path· 32
if-match community· 33
if-match cost 34
if-match extcommunity· 35
if-match interface· 36
if-match large-community· 36
if-match local-preference· 37
if-match mpls-label 38
if-match protocol 38
if-match rd-list 40
if-match route-policy· 40
if-match route-type· 41
if-match rpki 42
if-match tag· 43
ip as-path· 44
ip community-list 45
ip extcommunity-list 46
ip large-community-list 49
ip rd-list 50
reset ip as-path· 51
route-policy· 52
route-policy non-exist-deny· 53
route-policy nonexistent-config-confirm·· 53
route-policy prefix-protocol-check· 54
route-policy-change delay-time· 55
IPv4 routing policy commands· 56
apply fast-reroute· 56
apply ip-address next-hop· 57
display ip prefix-list 58
if-match ip· 59
ip prefix-list 60
reset ip prefix-list 61
IPv6 routing policy commands· 62
apply ipv6 fast-reroute· 62
apply ipv6 next-hop· 63
display ipv6 prefix-list 64
if-match ipv6· 65
ipv6 prefix-list 66
reset ipv6 prefix-list 67
Use apply additional-paths to set the maximum number of BGP Add-Path optimal routes.
Use undo apply additional-paths to remove the configuration.
apply additional-paths best-number
The number of BGP Add-Path optimal routes is not limited.
Routing policy node view
best-number: Specifies the maximum number of BGP Add-Path optimal routes. The value range is 2 to 64.
Use this command to change the effective maximum number of BGP Add-Path optimal routes. The configuration change applies only to BGP routes.
# Configure node 10 in permit mode for routing policy policy1 to set the maximum number of BGP Add-Path optimal routes matching AS path list 1 to 3.
[Sysname-route-policy-policy1-10] if-match as-path 1
[Sysname-route-policy-policy1-10] apply additional-paths 3
apply aigp
Use apply aigp to set the AIGP attribute for BGP routes.
Use undo apply aigp to restore the default.
apply aigp { cost-value | igp-cost }
undo apply aigp
No AIGP attribute is set.
cost-value: Specifies the AIGP attribute for BGP routes, in the range of 0 to 4294967295.
igp-cost: Specifies the cost value of the IGP route to the next hop of BGP routes as the AIGP attribute.
Use this command to add or edit the AIGP attribute for BGP routes.
An Accumulated Interior Gateway Protocol (AIGP) administrative domain is a collection of multiple ASs that run the same IGP under one administrative department. Within the domain, BGP accumulates the IGP metrics all along the forwarding path for a route. Then, it uses the accumulated value as the AIGP attribute for the route to implement metric-based route selection.
For more information about the AS_PATH attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to set the AIGP attribute to 10 for BGP routes.
[Sysname-route-policy-policy1-10] apply aigp 10
peer aigp
apply as-path
Use apply as-path to set the AS_PATH attribute for BGP routes.
Use undo apply as-path to restore the default.
apply as-path { as-number&<1-32> [ delete | replace ] | clear }
undo apply as-path
No AS_PATH attribute is set.
as-number&<1-32>: Specifies an AS by its number. The value range is 1 to 4294967295 for an integer AS number and is 0.1 to 65535.65535 for a dotted AS number. &<1-32> indicates that you can specify a maximum of 32 AS numbers.
delete: Deletes the specified AS numbers from the original AS_PATH attribute.
replace: Replaces the original AS numbers with the specified AS numbers. If you do not specify this keyword, the command adds the specified AS numbers before the original AS_PATH attribute.
clear: Clears the original AS numbers.
Use this command to add or edit the AS_PATH attribute for BGP routes.
The AS_PATH attribute identifies the ASs through which a route has passed. Before advertising a route to another AS, BGP adds the local AS number into the AS_PATH attribute, so the receiver can determine ASs to route the message back.
# Configure node 10 in permit mode for routing policy policy1 to add AS number 200 before the original AS_PATH attribute of BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply as-path 200
display ip as-path
if-match as-path
ip as-path
Use apply comm-list delete to delete the COMMUNITY attributes from BGP routes.
Use undo apply comm-list to restore the default.
No COMMUNITY attributes are deleted from BGP routes.
comm-list-number: Specifies a basic community list by its number in the range of 1 to 99 or an advanced community list by its number in the range of 100 to 199.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters that cannot contain only numbers.
Application scenarios
A BGP community is a group of routes with the same characteristics. The COMMUNITY attribute identifies the community to which a BGP route belongs. After you configure this command, the COMMUNITY attributes in the specified community list will be deleted from BGP routes.
For more information about the COMMUNITY attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
You must specify an existing community list when executing this command. To configure a community list, use the ip community-list command.
# Configure node 10 in permit mode for routing policy policy1 to delete the COMMUNITY attributes specified in community list 1 from BGP routes.
[Sysname-route-policy-policy1-10] apply comm-list 1 delete
ip community-list
apply community
Use apply community to set the COMMUNITY attribute for BGP routes.
Use undo apply community to remove the specified COMMUNITY attribute for BGP routes.
undo apply community [ none | additive | { community-number&<1-32> | aa:nn&<1-32> | internet | no-advertise | no-export | no-export-subconfed } * [ additive ] ]
No COMMUNITY attribute is set for BGP routes.
none: Removes the COMMUNITY attributes of BGP routes.
community-number&<1-32>: Specifies a community sequence number in the range of 1 to 4294967295. &<1-32> indicates that you can specify a maximum of 32 community sequence numbers.
aa:nn&<1-32>: Specifies a community number. Both aa and nn are in the range of 0 to 65535. &<1-32> indicates that you can specify a maximum of 32 community numbers.
internet: Sets the INTERNET community attribute for BGP routes. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Sets the NO_ADVERTISE community attribute for BGP routes. Routes with this attribute cannot be advertised to any peers.
no-export: Sets the NO_EXPORT community attribute for BGP routes. Routes with this attribute cannot be advertised out of the AS or confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Sets the NO_EXPORT_SUBCONFED community attribute for BGP routes. Routes with this attribute cannot be advertised out of the local AS or to other sub-ASs in the confederation.
additive: Adds the specified COMMUNITY attribute to the original COMMUNITY attribute of BGP routes.
A BGP community is a group of routes with the same characteristics. The COMMUNITY attribute identifies the community to which a BGP route belongs. Use this command to set the COMMUNITY attribute for BGP routes.
# Configure node 16 in permit mode for routing policy setcommunity to set the NO_EXPORT community attribute for BGP routes.
[Sysname-route-policy-setcommunity-16] apply community no-export
if-match community
ip community-list
apply cost
Use apply cost to set a cost for routes.
Use undo apply cost to restore the default.
undo apply cost
No cost is set for routes.
+: Increases a cost value.
-: Decreases a cost value.
cost-value: Specifies a cost in the range of 0 to 4294967295.
Use this command to set a cost for routes and control the route selection order. For example, when the next hop of a route is in unfavorable link bandwidth condition, you can use this command to increase the cost value for that route.
# Configure node 10 in permit mode for routing policy policy1 to set a cost of 120 for OSPF external routes.
[Sysname-route-policy-policy1-10] if-match route-type external-type1or2
[Sysname-route-policy-policy1-10] apply cost 120
apply cost-type
Use apply cost-type to set a cost type for routes.
Use undo apply cost-type to restore the default.
apply cost-type { external | internal | type-1 | type-2 }
No cost type is set for routes.
external: Sets the cost type to IS-IS external route.
internal: Sets the cost type to IS-IS internal route, or sets the MED value for a matching BGP route to the IGP metric of the route's next hop.
type-1: Sets the cost type to OSPF Type-1 external route.
type-2: Sets the cost type to OSPF Type-2 external route.
For IS-IS, the apply cost-type internal command sets the cost type for a matching IS-IS route to IS-IS internal route.
For BGP, the apply cost-type internal command sets the MED for a matching BGP route learned from an IBGP peer to the IGP metric of the route's next hop. The MED is modified when BGP advertises the route to an EBGP peer.
# Configure node 10 in permit mode for routing policy policy1 to set the cost type for routes that have a tag of 8 to OSPF Type-1 external route.
[Sysname-route-policy-policy1-10] if-match tag 8
[Sysname-route-policy-policy1-10] apply cost-type type-1
apply esi
Use apply esi to specify the Ethernet segment identifier (ESI) for BGP routes.
Use undo apply esi to remove the configuration.
apply esi esi-id
undo apply esi
No ESI is specified for BGP routes.
esi-id: Specifies an ESI in the format of xxxx.xxxx.xxxx.xxxx.xxxx. Each x is a hexadecimal value. The specified ESI must start with c8 and cannot contain only 0s or Fs.
In iSec scenarios, you can use this command to specify the ESI for IP prefix routes. The ESI is used for associating IP prefix routes with EVPN Ethernet auto-discovery routes that carry the iSec attribute.
For more information about iSec, see iSec configuration in Security Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to add ESI c800.1111.2200.0000.0000 to BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply esi c800.1111.2200.0000.0000
apply extcommunity
Use apply extcommunity to set the extended community attribute for BGP routes.
Use undo apply extcommunity to remove the specified extended community attribute for BGP routes.
apply extcommunity { bandwidth link-bandwidth-value | { rt route-target }&<1-32> } [ additive ]
undo apply extcommunity [ bandwidth link-bandwidth-value | { rt route-target }&<1-32> ]
No extended community attribute is set for BGP routes.
bandwidth link-bandwidth-value: Sets the link bandwidth extended community attribute, a string of 3 to 16 characters. The link-bandwidth-value argument is in the 16-bit AS number:32-bit user-defined number format, for example, 100:3. The AS number is in the range of 0 to 65535, and the user-defined number is in the range of 0 to 4294967295.
{ rt route-target }&<1-32>: Sets the RT extended community attribute, a string of 3 to 24 characters. &<1-32> indicates that you can specify a maximum of 32 RT extended community attributes.
An RT attribute has the following forms:
·     16-bit AS number in integer format:32-bit user-defined number, for example, 101:3. The AS number is in the range of 0 to 65535, and the user-defined number is in the range of 0 to 4294967295.
·     16-bit AS number in dotted format:32-bit user-defined number. For example, 0.1:1. The AS number range is 0.1 to 0.65535.
·     32-bit IP address:16-bit user-defined number, for example, 192.168.122.15:1. The user-defined number is in the range of 0 to 65535.
·     32-bit AS number in integer format:16-bit user-defined number, for example, 70000:3. The AS number is in the range of 65536 to 4294967295, and the user-defined number is in the range of 0 to 65535.
·     32-bit IP address/IPv4 address mask length:16-bit user-defined number, for example, 192.168.122.15/24:1.
·     32-bit AS number in dotted format:16-bit user-defined number, for example, 10.1:1. The minimum AS number is 1.0.
additive: Adds the specified attribute to the original extended community attribute.
Use this command to configure the link bandwidth or RT extended community attribute for BGP routes.
·     The link bandwidth attribute is used for BGP route-based Unequal Cost Multiple Path (UCMP) load balancing. For information about the link bandwidth attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
·     Route target (also called VPN target) attributes are used to control the advertisement of VPN routing information. For more information about the route target attribute, see MPLS L3VPN configuration in MPLS L3VPN Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to add the RT extended community attribute 100:2 to BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply extcommunity rt 100:2 additive
# Configure node 10 in permit mode for routing policy policy1 to add the link bandwidth extended community attribute 100:2 to BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply extcommunity bandwidth 100:2 additive
Use apply extcommunity color to set the color extended community attribute for BGP routes.
Use undo apply extcommunity color to remove the specified color extended community attribute for BGP routes.
apply extcommunity color color [ additive ]
No color extended community attribute is set for BGP routes.
color color: Sets the color extended community attribute, a string of 4 to 13 characters. The value of the color argument is in the Color-Only (CO) bit:color-value format, for example, 10:3. The value of the CO bit must be a binary number in the range of 00 to 11, and the value range for color-value is 0 to 4294967295.
additive: Adds the specified color extended community attribute to the original color extended community attribute of BGP routes. If you do not specify this keyword, the specified color attribute replaces the original color attribute of BGP routes.
Use this command to configure the color extended community attribute for BGP routes. Color attributes are used to distinguish multiple SR-MPLS TE policies or SRv6 TE policies with the same source and destination nodes.
Operating mechanism
When a packet matches a BGP route, the device uses the color value and the next hop address of the BGP route to search for a matching SR-MPLS TE or SRv6 TE policy to forward the packet. The largest one is used for searching if the route contains multiple color values. Whether the next hop address of the route can match the endpoint address of an SR-MPLS TE or SRv6 TE policy depends on the value of CO bit as follows:
·     If the CO bit value is 00 or 11, they can match when they are the same.
·     If the CO bit value is 01, the route searches for a matching SR-MPLS TE or SRv6 TE policy in the following sequence:
a.     The route matches an SR-MPLS TE or SRv6 TE policy whose endpoint address is the same as its next hop address.
b.     The route matches an SR-MPLS TE or SRv6 TE policy based on its next hop address type as follows:
-     If the next hop address type is IPv4 , the route matches an SR-MPLS TE policy whose endpoint address is 0.0.0.0.
-     If the next hop address type is IPv6, the route matches an SRv6 TE policy whose endpoint address is ::.
·     If the CO bit value is 10, the route searches for a matching SR-MPLS TE or SRv6 TE policy in the following sequence:
c.     The route matches an SR-MPLS TE or SRv6 TE policy whose endpoint address is the same as its next hop address.
d.     The route matches an SR-MPLS TE or SRv6 TE policy based on its next hop address type as follows:
-     If the next hop address type is IPv4, the route matches an SR-MPLS TE policy whose endpoint address is 0.0.0.0.
e.     The route matches an SR-MPLS TE or SRv6 TE policy with the lowest endpoint address.
If an SR-MPLS TE or SRv6 TE policy is matched, the device uses the policy to forward packets that matches the route. If no policies are matched, the device uses the route for packet forwarding.
For more information about color attributes, SR-MPLS TE policies, or SRv6 TE policies, see SR-MPLS TE policy configuration or SRv6 TE policy configuration in Segment Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to add color extended community attribute 10:20 to BGP routes.
[Sysname-route-policy-policy1-10] apply extcommunity color 10:20 additive
Use apply extcommunity soo to set the Site of Origin (SoO) extended community attribute for BGP routes.
Use undo apply extcommunity soo to remove the configuration.
No SoO extended community attribute is set for BGP routes.
site-of-origin&<1-32>: Sets the SoO extended community attribute, a string of 3 to 24 characters. &<1-32> indicates that you can specify a maximum of 32 SoO extended community attributes.
An SoO attribute has the following forms:
additive: Adds the specified SoO attribute to the original SoO attribute of BGP routes. If you do not specify this keyword, the specified SoO attribute replaces the original SoO attribute of BGP routes.
Use this command to configure the SoO extended community attribute for BGP routes.
The SoO attribute specifies the site where the route originated. It prevents advertising a route back to the originating site. If the AS-path attribute is lost, the router can use the SoO attribute to avoid routing loops.
For information about the SoO attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to add the SoO extended community attribute 1:100 to BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply extcommunity soo 1:100 additive
apply flex-algo
Use apply flex-algo to set a flexible algorithm ID for routes.
Use undo apply flex-algo to restore the default.
apply flex-algo flex-algo-id
No flexible algorithm ID is configured for routes.
flex-algo-id: Specifies a flexible algorithm ID in the range of 128 to 255.
Flexible algorithms enable users to define separate topologies for path calculation. They are mainly used in SR networks.
In the current software version, flexible algorithm ID configuration is supported only for redistributed IPv6 IS-IS and BGP routes.
When you apply flexible algorithms to an SRv6 network, each flexible algorithm calculates routes independently. To redistribute the routes calculated in a flexible algorithm topology (topology k2) to another (topology k1), perform the following task:
1.     Configure a routing policy that contains an apply flex-algo clause. The flexible algorithm ID specified in that apply clause is the flexible algorithm ID of topology k1.
2.     Enter the IS-IS IPv6 unicast view of the edge nodes in topologies k1 and k2, and then specify the routing policy above in the import-route command to filter redistributed routes.
In this example, you need to configure route redistribution for the IS-IS process that participates in the route calculation of topology k1.
The task above can redistribute only the IPv6 IS-IS routes calculated by topology k2 to topology k1. The IPv6 IS-IS routes not calculated by flexible algorithm will not be redistributed. The algorithm ID range for a flexible algorithm route is 128 to 255. The algorithm ID of a non-flexible algorithm route is fixed at 0.
·     The routing policy sets the algorithm ID of an IPv6 IS-IS route to the flexible algorithm ID of topology k1 if the following conditions exist:
¡     The route passes the routing policy specified in the import-route command.
¡     The algorithm ID of the route is in the range of 128 to 255.
·     If the algorithm ID of an IPv6 IS-IS route is 0, the routing policy does not set the algorithm ID of the route to the flexible algorithm ID of topology k1. As a result, the route cannot be redistributed to topology k1.
When the edge node redistributes the IPv6 BGP routes of topology k2 to topology k1, the routing policy specified in the import-route command filters those routes. The routing policy will add the flexible algorithm ID of topology k1 to the IPv6 BGP routes that pass the routing policy.
For information about flexible algorithms, see IS-IS configuration in Layer 3—IP Routing Configuration Guide.
# Set the flexible algorithm ID to 128 for routes.
[Sysname-route-policy-policy1-10] apply flex-algo 128
import-route (Layer 3IP Routing Command Reference)
apply gateway-ip
Use apply gateway-ip to configure a gateway address for EVPN IP prefix advertisement routes.
Use undo apply gateway-ip to restore the default.
apply gateway-ip { ip-address | origin-nexthop }
No gateway address is configured for EVPN IP prefix advertisement routes.
ip-address: Specifies an IP address in dotted decimal notation.
origin-nexthop: Configures the next hop of the route as the gateway address.
Use this command in EVPN networks to set the Gateway IP Address field (IPv4) of EVPN IP prefix advertisement routes.
# Configure the next hop of the route as the gateway address
[Sysname-route-policy-policy1-10] apply gateway-ip origin-nexthop
apply ip-precedence
Use apply ip-precedence to set an IP precedence for matching routes.
Use undo apply ip-precedence to restore the default.
No IP precedence is set.
value: Specifies an IP precedence in the range of 0 to 7. Each precedence value corresponds to a precedence type, as shown in Table 1. When you specify the value argument, you can enter either a precedence value or a precedence type.
Table 1 IP precedence values and their corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
clear: Clears the IP precedence of matching routes.
# Configure node 10 in permit mode for routing policy policy1 to set an IP precedence of 3 for BGP routes matching extended community list 100.
[Sysname] ip extcommunity-list 100 permit rt 100:100
[Sysname-route-policy-policy1-10] if-match extcommunity 100
[Sysname-route-policy-policy1-10] apply ip-precedence 3
Use apply ipv6 gateway-ip to configure an IPv6 gateway address for EVPN IP prefix advertisement routes.
Use undo apply ipv6 gateway-ip to restore the default.
apply ipv6 gateway-ip { ipv6-address | origin-nexthop }
No IPv6 gateway address is configured for EVPN IP prefix advertisement routes.
ipv6-address: Specifies an IPv6 address.
origin-nexthop: Configures the next hop of the route as the IPv6 gateway address.
Use this command in EVPN networks to set the Gateway IP Address field (IPv6) of EVPN IP prefix advertisement routes.
# Configure the next hop of the route as the IPv6 gateway address.
[Sysname-route-policy-policy1-10] apply ipv6 gateway-ip origin-nexthop
apply gateway-ip
apply isis
Use apply isis to redistribute routes into the specified IS-IS level.
Use undo apply isis to restore the default.
undo apply isis
No IS-IS level is set.
level-1: Redistributes routes into IS-IS Level-1.
level-1-2: Redistributes routes into both IS-IS Level-1 and Level-2.
level-2: Redistributes routes into IS-IS Level-2.
IS-IS adopts a two-level hierarchical architecture to support large-scale networks. A large-scale routing domain is divided into multiple areas. Typically, a Level-1 router is deployed within an area. A Level-2 router is deployed between areas. A Level-1-2 router is deployed between Level-1 and Level-2 routers.
For more information about the two-level hierarchy, see IS-IS configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to redistribute routes that have a tag of 8 to IS-IS level-2.
[Sysname-route-policy-policy1-10] apply isis level-2
apply label-index
Use apply label-index to set a label index value.
Use undo apply label-index to restore the default.
apply label-index index-value
No label index value is set.
index-value: Specifies a label index value in the range of 0 to 1048575.
Use this command in an Segment Routing with MPLS (SR-MPLS) network to set the label index value for the prefix SID of routes. For routes redistributed to BGP, IS-IS, or OSPF, SR nodes calculate the prefix SID for them based on the label index value configured with this command.
For more information about SR-MPLS, see SR-MPLS configuration in Segment Routing Configuration Guide.
The label index value specified by this command takes precedence over the label index value carried by the redistributed routes.
# Configure node 10 in permit mode for routing policy policy1 to set a label index value of 120 for BGP routes.
[Sysname-route-policy-policy1-10] apply label-index 120
apply label-value
Use apply label-value to set an SID value.
Use undo apply label-value to restore the default.
apply label-value label-value
No SID value is set.
label-value: Specifies an SID value in the range of 16 to 1048575.
Use this command to set an SID value for routes in an SR-MPLS network as follows:
·     Set the SID value that BGP Egress Peer Engineering (BGP-EPE) assigns to BGP peers or peer groups. For more information about BGP-EPE, see SR-MPLS configuration in Segment Routing Configuration Guide.
·     Set the SID value for SR labeled routes that advertised from the same local loopback interface to multiple IS-IS or OSPF processes. To achieve this goal, you can redistribute direct routes to IS-IS or OSPF, and configure an apply label-value clause to have the used routing policy set the SID value for those redistributed routes.
The SID value specified by this command takes precedence over the SID value carried by the redistributed routes.
# Configure node 10 in permit mode for routing policy policy1 to set an SID value of 120 for BGP peers or peer groups.
[Sysname-route-policy-policy1-10] apply label-value 120
Use apply large-comm-list delete to delete the large community attributes from BGP routes.
Use undo apply large-comm-list to remove the configuration.
apply large-comm-list { large-comm-list-number | large-comm-list-name } delete
No large community attributes are deleted from BGP routes.
large-comm-list-number: Specifies a large community list by its number. A basic community list number is in the range of 1 to 99, and an advanced community list number is in the range of 100 to 199.
large-comm-list-name: Specifies a large community list by its name. A large community list name is a case-sensitive string of 1 to 63 characters and cannot contain only digits.
The COMMUNITY attribute can denote only two-ocet AS numbers. To use the community attribute flexibly, BGP large community attribute is defined. The 12-ocet large community attribute value is in Administration:LocalData1:LocalData2 format.
The large community attribute contributes to flexible application of routing policies and control over route advertisement and reception because of the following advantages:
·     It can denote two-ocet and four-ocet AS numbers entirely.
·     It contains two four-ocet local data attribute identifiers.
The large community attribute can be used together with the COMMUNITY attribute for better route management.
For more information about the large community attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
You can use this command to delete the large community attributes that match the specified large community list from BGP routes.
You must specify an existing large community list when executing this command. To configure a large community list, use the ip large-community-list command.
# Configure node 10 in permit mode for routing policy policy1 to delete the large community attributes specified in large community list 1 from BGP routes.
[Sysname-route-policy-policy1-10] apply large-comm-list 1 delete
Use apply large-community to set the large community attribute for BGP routes.
Use undo apply large-community to remove the configuration.
apply large-community { aa:bb:cc&<1-8> [ additive ] | additive | none }
undo apply large-community [ aa:bb:cc&<1-8> [ additive ] | additive | none ]
No large community attribute is set for BGP routes.
aa:bb:cc&<1-8>: Specifies a large community number. aa, bb, and cc are all in the range of 0 to 4294967295. &<1-8> indicates that a maximum of 8 numbers can be specified.
additive: Adds the specified large community attribute to the original large community attribute of BGP routes. If you do not specify this keyword, the original large community attribute of BGP routes will be overwritten.
none: Removes the large community attribute from BGP routes.
You can use this command to set the large community attribute for BGP routes.
If you execute this command multiple times, you can set a maximum of 32 large community attributes for BGP routes.
# Configure node 16 in permit mode for routing policy setlargecommunity to set large community attribute 1:1:1 for BGP routes.
[Sysname] route-policy setlargecommunity permit node 10
[Sysname-route-policy-setlargecommunity-10] apply large-community 1:1:1
Use apply local-preference to set a local preference for BGP routes.
Use undo apply local-preference to restore the default.
No local preference is set for BGP routes.
preference: Specifies a local preference in the range of 0 to 4294967295.
The local preference is used to determine the optimal route for traffic leaving the local AS. After a BGP router obtains multiple routes with the same destination and different next hops from several IBGP peers, it preferentially selects the route with the highest local preference as the optimal route.
For more information about the local preference, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to set a local preference of 130 for BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply local-preference 130
apply mpls-label
Use apply mpls-label to assign MPLS labels to routes.
Use undo apply mpls-label to restore the default.
apply mpls-label
No MPLS labels are assigned to routes.
If this command fails to assign an MPLS label to a route, the route will not be advertised.
# Configure node 10 in permit mode for routing policy policy1 to assign MPLS labels to routes.
[Sysname-route-policy-policy1-10] apply mpls-label
apply origin
Use apply origin to set the ORIGIN attribute for BGP routes.
Use undo apply origin to restore the default.
undo apply origin
No ORIGIN attribute is set for BGP routes.
egp as-number: Sets the ORIGIN attribute to EGP. The as-number argument specifies an AS number for EGP routes. The value range is 1 to 4294967295 for an integer AS number and is 0.1 to 65535.65535 for a dotted AS number.
igp: Sets the ORIGIN attribute to IGP.
incomplete: Sets the ORIGIN attribute to UNKNOWN.
The ORIGIN attribute specifies the origin of BGP routes. This attribute has the following types:
·     IGP—Has the highest priority. Routes generated in the local AS have the IGP attribute.
·     EGP—Has the second highest priority. Routes obtained through EGP have the EGP attribute.
·     INCOMPLETE—Has the lowest priority. The source of routes with this attribute is unknown. Routes redistributed from other routing protocols have the INCOMPLETE attribute.
For more information about the ORIGIN attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to set the ORIGIN attribute to IGP for BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply origin igp
apply preference
Use apply preference to set a preference for a routing protocol.
Use undo apply preference to restore the default.
apply preference preference
No preference is set for a routing protocol.
preference: Specifies a preference in the range of 1 to 255.
If you have set preferences for routing protocols by using the preference command, the apply preference command sets a new preference for the matching routing protocol. Unmatched routing protocols still use the preferences set by using the preference command.
# Configure node 10 in permit mode for routing policy policy1 to set the preference for OSPF external routes to 90.
[Sysname-route-policy-policy1-10] apply preference 90
Use apply preferred-value to set a preferred value for BGP routes.
Use undo apply preferred-value to restore the default.
No preferred value is set for BGP routes.
preferred-value: Specifies a preferred value in the range of 0 to 65535.
During route selection, BGP first drops routes with unreachable next hops, and then selects the route with the greatest preferred value. Use this command to set a preferred value for BGP routes to control BGP path selection.
For more information about the preferred value, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to set a preferred value of 66 for BGP routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply preferred-value 66
Use apply prefix-priority to set a prefix priority for routes.
Use undo apply prefix-priority to restore the default.
No prefix priority is set, which means the prefix priority is low.
critical: Sets the critical prefix priority for routes.
high: Sets the high prefix priority for routes.
medium: Sets the medium prefix priority for routes.
A topology change causes routing convergence in protocols such as OSPF and IS-IS. To improve the convergence speed, you can set prefix priorities for routes. Prefix priority levels include critical, high, medium, and low. The higher the convergence priority, the faster the convergence speed.
# Configure node 10 in permit mode for routing policy policy1 to set prefix priority critical for routes matching prefix list abc.
[Sysname-route-policy-policy1-10] if-match ip address prefix-list abc
[Sysname-route-policy-policy1-10] apply prefix-priority critical
apply qos-local-id
Use apply qos-local-id to set a local QoS ID for matching routes.
Use undo apply qos-local-id to restore the default.
apply qos-local-id { local-id-value | clear }
No local QoS ID is set.
local-id-value: Specifies a local QoS ID in the range of 1 to 4095.
clear: Clears the local QoS ID of matching routes.
Use this command on a QoS Policy Propagation Through the Border Gateway Protocol (QPPB) network. QPPB enables you to classify routes based on the BGP community lists, BGP AS paths, ACLs, and prefix lists, and apply different QoS policies.
In a dual-homed network scenario, you must configure the same local QoS ID for the dual-homed routes.
For more information about QPPB, see QoS configuration in ACL and QoS Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to set a local QoS ID of 100 for BGP routes matching extended community list 100.
[Sysname-route-policy-policy1-10] apply qos-local-id 100
apply tag
Use apply tag to set a tag for IGP routes.
Use undo apply tag to restore the default.
apply tag tag-value
undo apply tag
No routing tag is set for IGP routes.
tag-value: Specifies the tag value in the range of 0 to 4294967295.
Use this command to set a tag for IGP routes. To view the tag value, execute the display ip routing table verbose command.
# Configure node 10 in permit mode for routing policy policy1 to set a tag of 100 for IGP routes.
[Sysname-route-policy-policy1-10] apply tag 100
apply traffic-index
Use apply traffic-index to set a traffic index for BGP routes.
Use undo apply traffic-index to restore the default.
No traffic index is set for BGP routes.
value: Specifies the traffic index in the range of 1 to 127.
clear: Clear the traffic index of BGP routes.
BGP policy accounting provides the following functionalities:
·     Classifies IP traffic by BGP path attributes such as NEXT HOP, COMMUNITY, and AS_PATH.
·     Assigns an index to each class of traffic.
·     Collects statistics based on indexes.
For more information about BGP policy accounting, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to set a traffic index of 6 for BGP routes matching extended community list 100.
[Sysname-route-policy-policy1-10] apply traffic-index 6
continue
Use continue to specify the next node to be matched.
Use undo continue to restore the default.
continue [ node-number ]
undo continue
No next node is specified.
node-number: Specifies the routing policy node number in the range of 1 to 65535. The specified next node must have a larger number than the current node.
A route that matches the current node (permit node) must match the specified next node in the same routing policy. The continue clause combines the if-match and apply clauses of the two nodes to improve flexibility of the routing policy. After you configure a continue clause, a route continues to match against the subsequent nodes if it does not match the specified next node. To prevent such a route from matching against other nodes, add a clauseless deny node following the specified next node.
Example
# Specify the next node 20 for node 10 of the routing policy policy1.
[Sysname-route-policy-policy1-10] continue 20
display ip as-path
Use display ip as-path to display BGP AS path list information.
display ip as-path [ as-path-number ]
as-path-number: Specifies an AS path list by its number in the range of 1 to 256. If you do not specify this argument, the command displays information about all BGP AS path lists.
# Display information about BGP AS path list 1.
As-path-number: 1
 Permitted 0
 Denied 0
        Mode: Permit  Regular experssion:10:1
# Display information about all BGP AS path lists.
As-path-number: 12
 Permitted 0
 Denied 0
        Mode: Permit  Regular expression:^10
As-path-name: as1
 Permitted 0
 Denied 0
        Mode: Deny    Regular expression:*200.*300
As-path-number
AS path list number.
As-path-name
AS path list name.
Permitted
Number of times that the policy is applied and matched.
Denied
Number of times that the policy is applied but not matched.
Mode
Match mode:
·     Permit.
·     Deny.
Regular expression
Regular expression used to match routes.
reset ip as-path
Use display ip community-list to display BGP community list information.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
name comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters that cannot contain only numbers.
If no community list is specified, this command displays information about all BGP community lists.
# Display information about all BGP community lists.
<Sysname> display ip community-list
Community List Basic aaa
        Permit
Community List Advanced bbb
        Permit  3333
Basic community list.
Advanced community list.
permit
Match mode:
·     Permit.
·     Deny.
Use display ip extcommunity-list to display BGP extended community list information.
display ip extcommunity-list [ ext-comm-list-number | ext-comm-list-name ]
ext-comm-list-number: Specifies an extended community list by its number in the range of 1 to 65535.
ext-comm-list-name: Specifies an extended community list by its name, a case-sensitive string of 1 to 63 characters. The name cannot contain only digits.
If you do not specify any arguments, this command displays information about all BGP extended community lists.
# Display information about BGP extended community list 1.
         Permit rt: 9:6
         Permit soo: 9:6
         Permit bandwidth: 9:6
Extended Community List Name extlist
        Permit rt: 10:10
        Permit soo: 1:100
Extended community list number.
Extended community list name.
permit
Match mode:
·     Permit.
·     Deny.
rt
Route Target (RT) extended community attribute.
soo
Site of Origin (SoO) extended community attribute.
bandwidth
Link-bandwidth extended community attribute.
Use display ip large-community-list to display BGP large community list information.
display ip large-community-list [ basic-large-comm-list-number | adv-large-comm-list-number | name large-comm-list-name ]
basic-large-community-list-number: Specifies a basic large community list by its number in the range of 1 to 99.
adv-large-community-list-number: Specifies an advanced large community list by its number in the range of 100 to 199.
name large-comm-list-name: Specifies a large community list by its name. A large community list name is a case-sensitive string of 1 to 63 characters and cannot contain only digits.
If no large community list is specified, this command displays information about all BGP large community lists.
# Display information about all BGP large community lists.
<Sysname> display ip large-community-list
Large-community List Basic aaa
        Permit  1:1:1
Large-community List Advanced bbb
        Permit  3333:3333:3333
Large-community List Number 20
        Deny    4:4:4
Table 5 Command output
Large-community Basic
Basic large community list name.
Advanced large community list name.
Large community list number.
Match mode:
·     Permit.
·     Deny.
Permit
The match mode is permit.
Deny
The match mode is deny.
display ip rd-list
Use display ip rd-list to display route distinguisher (RD) list information.
rd-list-number: Displays information about an RD list. The rd-list-number argument represents the number of the RD list, in the range of 1 to 65535. If you do not specify an RD list, this command displays information about all RD lists.
# Display information about all RD lists.
<Sysname> display ip rd-list
Route Distinguisher List Number 1
        index: 1          Permit 1.1.1.1:1 2.2.2.2:* 100:1 200:*
Route Distinguisher List Number 2
        index: 2          Deny   1:1 2:2
Table 6 Command output
RD list number.
index
Index of the RD list item.
Permit
Match mode:
·     Permit.
·     Deny.
ip rd-list
Use display route-policy to display routing policy information.
display route-policy [ name route-policy-name [ node node-number ] ]
name route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all routing policies.
node node-number: Specifies a routing policy node by its index in the range of 0 to 65535. If you do not specify this option, the command displays information about all routing policy nodes.
# Display information about routing policy policy1.
<Sysname> display route-policy name policy1
Route-policy: policy1
  Permit : 1
          if-match cost 10
          continue: next node 11
          apply comm-list a delete
Table 7 Command output
Route-policy
Routing policy name.
Permit : xx
The match mode of node xx is Permit.
Deny   : xx
The match mode of node xx is Deny.
if-match
Match criterion.
continue
Specify the next node to be matched.
apply
Action.
if-match as-path
Use if-match as-path to match BGP routes whose AS_PATH attribute matches a specified AS path list.
Use undo if-match as-path to remove the specified AS path list match criterion.
if-match as-path { as-path-number&<1-32> | as-path-name }
undo if-match as-path [ as-path-number&<1-32> | as-path-name ]
No AS path list match criterion is configured.
as-path-number&<1-32>: Specifies an AS path list by its number in the range of 1 to 256. &<1-32> indicates that you can specify a maximum of 32 AS path lists.
as-path-name: Specifies an AS path list by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
Use this command in conjunction with the ip as-path command to configure AS_PATH-based criteria for route filtering. If the AS path list specified by this command does not exist, first use the ip as-path command to create the AS path list.
# Configure AS path list 2 to permit BGP routes containing AS number 200 or 300 to pass. Configure node 10 in permit mode for routing policy test to match AS path list 2.
[Sysname-route-policy-policy1-10] if-match as-path 2
apply as-path
ip as-path
if-match community
Use if-match community to match BGP routes whose COMMUNITY attribute matches a specified community list.
Use undo if-match community to remove the specified community list match criterion.
if-match community { { basic-community-list-number [ whole-match ] | name comm-list-name [ whole-match | unorder-match ] } | adv-community-list-number [ unorder-match ] }&<1-32>
undo if-match community [ { basic-community-list-number [ whole-match ] | name comm-list-name [ whole-match | unorder-match ] } | adv-community-list-number [ unorder-match ] ]&<1-32>
No community list match criterion is configured.
whole-match: Exactly matches the specified community list. In this match mode, a BGP route can match the specified community list only if it has and only has the communities contained in the specified community list. This keyword takes effect only on basic community lists. If you do not specify this keyword in the if-match community command, a BGP route is matched as long as it contains all of the communities in the specified community list. The undo if-match community command always deletes the configured community list match criterion for BGP routes regardless of whether this keyword is specified.
unorder-match: Specifies unordered matching. In this match mode, regular expressions in an advanced community attribute list does not need to match against a BGP route based on the order of the community attributes carried by the BGP route. For example, if the community attributes carried by a BGP route are 1:1 2:2 3:3 4:4, in ordered matching, advanced community lists with regular expressions 1$, 2$, and 3$ cannot match the BGP route. Only the community list with regular expression 4$ can match the BGP route. Whereas in unordered matching, advanced community lists with regular expressions 1$, 2$, 3$, and 4$ all can match the BGP route. This keyword takes effect only on advanced community lists. If you do not specify this keyword in the if-match community command, ordered matching is used. The undo if-match community command always deletes the configured community list match criterion for BGP routes regardless of whether this keyword is specified.
&<1-32>: Indicates that you can specify a maximum of 32 community lists.
Use this command in conjunction with the ip community-list command to configure COMMUNITY-based criteria for route filtering. If the community list specified by this command does not exist, first use the ip community-list command to create the community list.
# Configure community list 1 to permit BGP routes with community number 100 or 200. Then configure node 10 in permit mode for routing policy test to use community list 1 to match BGP routes.
[Sysname-route-policy-test-10] if-match community 1
apply community
ip community-list
if-match cost
Use if-match cost to match routes that have the specified cost.
Use undo if-match cost to restore the default.
if-match cost cost-value
undo if-match cost
No cost match criterion is configured.
# Configure node 10 in permit mode for routing policy policy1 to permit routes with a cost of 8.
[Sysname-route-policy-policy1-10] if-match cost 8
Use if-match extcommunity to match BGP routes whose extended community attribute matches a specified extended community list.
Use undo if-match extcommunity to remove the specified extended community list match criterion.
undo if-match extcommunity [ ext-comm-list-number ]&<1-32>
if-match extcommunity ext-comm-list-name&<1-32>
undo if-match extcommunity [ ext-comm-list-name ]&<1-32>
No extended community list match criterion is configured.
ext-comm-list-name: Specifies an extended community list by its name, a case sensitive string of 1 to 63 characters. The name cannot contain only digits.
&<1-32>: Indicates that you can specify a maximum of 32 extended community lists.
Use this command in conjunction with the ip extcommunity-list command to configure extended community-based criteria for route filtering. If the extended community list specified by this command does not exist, first use the ip extcommunity-list command to create the extended community list.
For more information about the extended community attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to match BGP routes whose extended community attribute matches extended community lists 100 and 150.
[Sysname] ip extcommunity-list 150 permit rt 150:150
[Sysname-route-policy-policy1-10] if-match extcommunity 100 150
apply extcommunity
if-match interface
Use if-match interface to match routes that have the specified output interfaces.
Use undo if-match interface to remove the specified output interface match criterion.
No output interface match criterion is configured.
&<1-16>: Indicates that you can specify a maximum of 16 interfaces.
BGP does not support criteria for matching the output interfaces of routes.
# Configure node 10 in permit mode for routing policy policy1 to permit routes with the output interface Ten-GigabitEthernet 3/1/1.
[Sysname-route-policy-policy1-10] if-match interface ten-gigabitethernet 3/1/1
Use if-match large-community to match BGP routes by large community list.
Use undo if-match large-community to remove the large community list match criterion.
if-match large-community { { basic-large-comm-list-number | name large-comm-list-name } [ whole-match ] | adv-large-comm-list-number }&<1-32>
undo if-match large-community [ { basic-large-comm-list-number | name large-comm-list-name } [ whole-match ] | adv-large-comm-list-number ]&<1-32>
No large community list match criterion is configured.
whole-match: Exactly matches the specified large community list. If you specify this keyword, this command matches routes with the same large community list as that you have specified.
&<1-32>: Indicates that you can specify a maximum of 32 large community lists.
When you use this command, the specified large community list must have been created. To create a large community list, use the ip large-community-list command.
You can use the ip large-community-list command together with this command to match BGP routes with specific large community attributes.
# Configure large community list 1 to permit BGP routes with large community number 1:0:1 or 2:0:1. Then configure node 10 for routing policy test to use large community list 1 to match BGP routes.
[Sysname] ip large-community-list 1 permit 1:0:1 2:0:1
[Sysname-route-policy-test-10] if-match large-community 1
Use if-match local-preference to match BGP routes that have the specified local preference.
Use undo if-match local-preference to restore the default.
No local preference match criterion is configured.
# Create node 10 in permit mode for routing policy policy1 to match BGP routes that have a local preference of 2.
[Sysname-route-policy-policy1-10] if-match local-preference 2
if-match mpls-label
Use if-match mpls-label to set the MPLS label match criterion.
Use undo if-match mpls-label to restore the default.
if-match mpls-label
No MPLS label match criterion is set.
# Configure node 10 in permit mode for routing policy policy1 to match routes that have MPLS labels.
[Sysname-route-policy-policy1-10] if-match mpls-label
if-match protocol
Use if-match protocol to configure a routing protocol match criterion.
undo if-match protocol to remove a routing protocol match criterion.
if-match protocol { bgp | direct | eigrp | isis | ospf | ospfv3 | rip | ripng | static | unr } *
undo if-match protocol [ bgp | direct | eigrp | isis | ospf | ospfv3 | rip | ripng | static | unr ] *
No routing protocol match criterion is configured.
bgp: Matches BGP routes.
direct: Matches direct routes.
eigrp: Matches EIGRP routes.
isis: Matches IS-IS routes.
ospf: Matches OSPF routes.
ospfv3: Matches OSPFv3 routes.
rip: Matches RIP routes.
ripng: Matches RIPng routes.
static: Matches static routes.
unr: Matches user network routes.
Execute this command to filter routes by routing protocol. If you specify multiple routing protocols, a route matches the criterion as long as it belongs to one of the specified routing protocols.
This command takes effect only in scenarios where BGP uses routing policies for route filtering.
After you create a match criterion by using this command, the match criterion does not take effect if the following conditions exist:
·     You specify a routing policy that contains the match criterion in a command.
·     You specify a routing protocol in the same command.
For example, if the route-policy-name argument in the import-route static route-policy route-policy-name command specifies a routing policy that contains a routing protocol match criterion, the match criterion does not take effect.
# Configure node 10 in permit mode for routing policy policy1 to match direct and static routes.
[Sysname-route-policy-policy1-10] if-match protocol direct static
if-match rd-list
Use if-match rd-list to match routes whose RD matches the specified RD list.
Use undo if-match rd-list to remove the specified RD list match criterion.
No RD list match criterion is configured.
rd-list-number: Specifies an RD list by its number in the range of 1 to 65535.
Use this command in conjunction with the ip rd-list command to configure RD-based criteria for route filtering. If the RD list specified by this command does not exist, first use the ip rd-list command to create the RD list.
For more information about RDs, see MPLS L3VPN configuration in MPLS L3VPN Configuration Guide.
# Configure node 10 in permit mode for routing policy rp1 to match routes whose RD matches RD list 1.
[Sysname] ip rd-list 1 permit 1:1
[Sysname] route-policy rp1 permit node 10
[Sysname-route-policy-rp1-10] if-match rd-list 1
ip rd-list
Use if-match route-policy to specify a routing policy to match routes.
Use undo if-match route-policy to restore the default.
if-match route-policy route-policy-name
No routing policy is specified to match routes.
Operating mechanism
When you use a routing policy as the if-match clause criterion for another routing policy, the if-match clause works as follows:
·     When the match mode of a node is deny, a route is rejected if the route meets all the if-match clauses of the node. The route is not compared with the next node. If the route does not meet all the if-match clauses of the node, it is compared with the next node.
·     When the match mode of a node is permit, a route is handled by the apply clauses of the node if the route meets all the if-match clauses of the node. If the route does not meet all the if-match clauses of the node, it is compared with the next node.
Follow these restrictions and guidelines when you configure a routing policy if-match clause criterion:
·     If the specified routing policy does not exist, all routes match the criterion.
·     If a routing policy has been used as an if-match clause criterion, you cannot specify a routing policy match criterion for the routing policy. For example, if routing policy A uses routing policy B as a match criterion, you cannot specify any routing policy match criterion for routing policy B. In addition, you cannot specify routing policy A as a match criterion for any another routing policies.
·     Reference loops are not allowed. For example, if routing policy A is used as a match criterion of routing policy B, you cannot configure routing policy B as a match criterion of routing policy A any more.
If you execute this command multiple times for a routing policy, the most recent configuration takes effect.
# Configure node 10 in permit mode for routing policy parent to match routes that match routing policy child.
[Sysname] route-policy parent permit node 10
[Sysname-route-policy-parent-10] if-match route-policy child
if-match route-type
Use if-match route-type to set a route-type match criterion.
Use undo if-match route-type to remove the specified route-type match criterion.
if-match route-type { bgp-evpn-ad | bgp-evpn-imet | bgp-evpn-ip-prefix | bgp-evpn-mac-ip | ebgp | eigrp-external | eigrp-internal | external-type1 | external-type1or2 | external-type2 | ibgp | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 } *
undo if-match route-type [ bgp-evpn-ad | bgp-evpn-imet | bgp-evpn-ip-prefix | bgp-evpn-mac-ip | ebgp | eigrp-external | eigrp-internal | external-type1 | external-type1or2 | external-type2 | ibgp | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 ] *
No route-type match criterion is set.
Routing policy node view
bgp-evpn-ad: Matches BGP EVPN Ethernet auto-discovery routes.
bgp-evpn-imet: Matches BGP EVPN inclusive multicast Ethernet tag routes.
bgp-evpn-ip-prefix: Matches BGP EVPN IP prefix routes.
bgp-evpn-mac-ip: Matches BGP EVPN MAC/IP advertisement routes.
ebgp: Matches EBGP routes.
eigrp-external: Matches EIGRP external routes.
eigrp-internal: Matches EIGRP internal routes.
external-type1: Matches OSPF Type 1 external routes.
external-type1or2: Matches OSPF Type 1 and Type 2 external routes.
external-type2: Matches OSPF Type 2 external routes.
ibgp: Matches IBGP routes.
internal: Matches OSPF internal routes (including OSPF intra-area and inter-area routes).
is-is-level-1: Matches IS-IS Level-1 routes.
is-is-level-2: Matches IS-IS Level-2 routes.
nssa-external-type1: Matches OSPF NSSA Type 1 external routes.
nssa-external-type1or2: Matches OSPF NSSA Type 1 and 2 external routes.
nssa-external-type2: Matches OSPF NSSA Type 2 external routes.
# Configure node 10 in permit mode for routing policy policy1 to match OSPF internal routes.
[Sysname-route-policy-policy1-10] if-match route-type internal
if-match rpki
Use if-match rpki to set the BGP RPKI validation state match criterion.
Use undo if-match rpki to restore the default.
undo if-match rpki
No BGP RPKI validation state match criterion is set.
invalid: Matches BGP routes whose BGP RPKI validation state is Invalid.
not-found: Matches BGP routes whose BGP RPKI validation state is Not found.
valid: Matches BGP routes whose BGP RPKI validation state is Valid.
The BGP Resource Public Key Infrastructure (RPKI) feature enables BGP to validate the origin AS of a route and determine whether to use and advertise the route based on the validation state.
For more information about BGP RPKI, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure node 10 in permit mode for routing policy policy1 to match BGP routes whose BGP RPKI validation state is Valid.
[Sysname-route-policy-policy1-10] if-match rpki valid
if-match tag
Use if-match tag to match IGP routes that have the specified tag.
Use undo if-match tag to restore the default.
if-match tag tag-value
undo if-match tag
No tag match criterion is configured.
tag-value: Specifies a tag in the range of 0 to 4294967295.
# Configure node 10 in permit mode for routing policy policy1 to match IGP routes that have a tag of 8.
ip as-path
Use ip as-path to configure an AS path list.
Use undo ip as-path to remove an AS path list.
ip as-path { as-path-number | as-path-name } { deny | permit } regular-expression
undo ip as-path { as-path-number | as-path-name } [ regular-expression | deny | permit ]
No AS path lists exist.
as-path-number: Specifies an AS path list number in the range of 1 to 256.
as-path-name: Specifies an AS path list name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
deny: Specifies the match mode for the AS path list as deny.
permit: Specifies the match mode for the AS path list as permit.
regular-expression: Specifies an AS path regular expression, a string of 1 to 256 characters.
The AS_PATH attribute identifies the ASs through which a route has passed. Before advertising a route to another AS, BGP adds the local AS number into the AS_PATH attribute, so the receiver can determine ASs to route the message back.
You can use this command to specify a regular expression for AS_PATH-based BGP route filtering. An AS path regular expression, for example, ^200.*100$, matches the AS_PATH attribute that starts with AS 200 and ends with AS 100.
For more information about regular expressions, see routing policy configuration in Layer 3—IP Routing Configuration Guide. For more information about the AS_PATH attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure AS path list 1 to permit routes whose AS_PATH attribute starts with 10.
apply as-path
display ip as-path
if-match as-path
ip community-list
Use ip community-list to configure a community list.
Use undo ip community-list to remove a community list.
undo ip community-list { basic-comm-list-num | basic basic-comm-list-name } [ deny | permit ] [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] *
undo ip community-list { adv-comm-list-num | advanced adv-comm-list-name } [ deny | permit ] [ regular-expression ]
No community lists exist.
basic-comm-list-num: Specifies a basic community list number in the range of 1 to 99.
basic basic-comm-list-name: Specifies a basic community list name, a case-sensitive string of 1 to 63 characters that cannot contain only numbers.
advanced adv-comm-list-name: Specifies an advanced community list name, a case-sensitive string of 1 to 63 characters that cannot contain only numbers.
adv-comm-list-num: Specifies an advanced community list number in the range of 100 to 199.
regular-expression: Specifies a regular expression for the advanced community list, a string of 1 to 63 characters. For more information about regular expressions, see Layer 3IP Routing Configuration Guide.
deny: Specifies the match mode for the community list as deny.
permit: Specifies the match mode for the community list as permit.
community-number&<1-32>: Specifies a community sequence number in the range of 1 to 4294967295. &<1-32> indicates that you can specify a maximum of 32 community sequence numbers.
aa:nn&<1-32>: Specifies a community number. Both aa and nn are in the range of 0 to 65535. &<1-32> indicates that you can specify a maximum of 32 community numbers.
internet: Specifies the INTERNET community attribute. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Specifies the NO_ADVERTISE community attribute. Routes with this attribute cannot be advertised to other BGP peers.
no-export: Specifies the NO_EXPORT community attribute. Routes with this attribute cannot be advertised out of the local AS or the local confederation but can be advertised to other ASs in the confederation.
no-export-subconfed: Specifies the NO_EXPORT_SUBCONFED community attribute. Routes with this attribute cannot be advertised out of the local AS, or to other sub-ASs in the local confederation.
A BGP community is a group of routes with the same characteristics. The COMMUNITY attribute identifies the community to which a BGP route belongs. Use this command to configure community lists for flexible control over routing policies.
For more information about the COMMUNITY attribute, see BGP configuration in Layer 3—IP Routing Configuration Guide.
# Configure basic community list 1 to permit routes with the INTERNET community attribute.
# Configure advanced community list 100 to permit routes with the COMMUNITY attribute starting with 10.
apply comm-list delete
apply community
if-match community
Use ip extcommunity-list to configure an extended community list.
Use undo ip extcommunity-list to remove an extended community list.
ip extcommunity-list { ext-comm-list-number | ext-comm-list-name } [ index index-number ] { deny | permit } { bandwidth link-bandwidth-value | rt route-target | soo site-of-origin }&<1-32>
undo ip extcommunity-list { ext-comm-list-number | ext-comm-list-name } [ index index-number ] [ { deny | permit } [ bandwidth link-bandwidth-value | rt route-target | soo site-of-origin ]&<1-32> ]
ip extcommunity-list { ext-comm-list-number | ext-comm-list-name } [ index index-number ] { deny | permit } { rt | soo } advanced regular-expression
undo ip extcommunity-list { ext-comm-list-number | ext-comm-list-name } [ index index-number ] [ { deny | permit } { rt | soo } advanced regular-expression ]
No extended community lists exist.
ext-comm-list-number: Specifies an extended community list number in the range of 1 to 65535.
ext-comm-list-name: Specifies an extended community list name, a case-sensitive string of 1 to 63 characters. The name cannot contain only digits.
index index-number: Specifies an index for the extended community list entry, in the range of 1 to 4294967295. An extended community list entry with a smaller index number is matched first. If you do not specify this option, the index number starts from 1 and increases by 1 for each of the consecutive extended community list entries.
deny: Specifies the match mode for the extended community list as deny.
permit: Specifies the match mode for the extended community list as permit.
bandwidth link-bandwidth-value: Specifies a link bandwidth extended community attribute, a string of 3 to 16 characters. &<1-32> indicates that you can specify a maximum of 32 link bandwidth extended community attributes. The link-bandwidth-value argument is in the 16-bit AS number:32-bit user-defined number format, for example, 100:3. The AS number is in the range of 0 to 65535, and the user-defined number is in the range of 0 to 4294967295.
rt route-target: Specifies a space-separated list of up to 32 RT extended community attribute items. Each item is a string of 3 to 24 characters.
soo site-of-origin: Specifies a space-separated list of up to 32 SoO extended community attribute items. Each item is a string of 3 to 24 characters.
An RT or SoO attribute has the following forms:
·     16-bit AS number in integer format:32-bit user-defined number. For example, 101:3. The AS number is in the range of 0 to 65535, and the user-defined number is in the range of 0 to 4294967295.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1. The user-defined number is in the range of 0 to 65535.
·     32-bit AS number in integer format:16-bit user-defined number. For example, 70000:3. The AS number is in the range of 65536 to 4294967295, and the user-defined number is in the range of 0 to 65535.
·     32-bit IP address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
·     32-bit AS number in dotted format:16-bit user-defined number. For example, 10.1:1. The minimum AS number is 1.0.
advanced regular-expression: Specifies a regular expression to filter extended community attributes. The value for the regular-expression argument is a string of 1 to 63 characters. For more information about regular expressions, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
Application scenarios
Extended community lists are used to filter routes.
Operating mechanism
You can configure multiple entries for an extended community list. The relationship between the entries is logical OR. A route matches the extended community list as long as it matches one entry in the list. A route matches an entry only if it matches all attributes in the entry.
To view detailed extended community list information, use the display ip extcommunity-list command.
You must specify the advanced regular-expression option for all entries in an extended community list, or not specify it at all. If you specify the advanced regular-expression option in the first command for an extended community list, the subsequent commands without this option specified do not take effect. Similarly, if you do not specify this option in the first command, the subsequent commands with this option specified do not take effect.
If you specify an existing extended community list by its number or name when executing this command, you can add a new entry or edit an existing entry:
·     If you do not specify the index index-number option or specify an entry index that does not exist, this command adds a new entry to the list.
·     If you specify an existing entry index, this command edits the specified entry. If you execute this command multiple times for an extended community list entry, the most recent configuration takes effect.
# Configure extended community list 1 to permit routes with RT 200:200 to pass.
# Configure extended community list 2 to permit routes with SoO 100:100 to pass.
# Configure extended community list 3 to permit routes with link bandwidth attribute 100:100 to pass.
[Sysname] ip extcommunity-list 3 permit bandwidth 100:100
# Configure extended community list 4 to permit routes with RT extended community attributes that begin with 10 to pass.
[Sysname] ip extcommunity-list 4 permit rt advanced ^10
apply extcommunity
Use ip large-community-list to create a large community list.
Use undo ip large-community-list to remove a large community list or remove specific communities from a large community list.
ip large-community-list { basic-large-comm-list-num | basic basic-large-comm-list-name } { deny | permit } aa:bb:cc&<1-32>
undo ip large-community-list { basic-large-com-list-num | basic basic-large-comm-list-name } [ deny | permit ] [ aa:bb:cc&<1-32> ]
ip large-community-list { adv-large-comm-list-num | advanced adv-large-comm-list-name } { deny | permit } regular-expression
undo ip large-community-list { adv-large-comm-list-num | advanced adv-large-comm-list-name } [ deny | permit ] [ regular-expression ]
No large community lists exist.
basic-large-comm-list-num: Specifies a basic large community list number in the range of 1 to 99.
basic basic-large-comm-list-name: Specifies a basic large community list name that is a case-sensitive string of 1 to 63 characters and cannot contain only digits.
adv-large-comm-list-num: Specifies an advanced large community list number in the range of 100 to 199.
advanced adv-comm-list-name: Specifies an advanced large community list name that is a case-sensitive string of 1 to 63 characters and cannot contain only digits.
deny: Specifies the match mode for the large community list as deny.
permit: Specifies the match mode for the large community list as permit.
aa:bb:cc&<1-32>: Specifies a large community number. aa, bb, and cc are all in the range of 0 to 4294967295. &<1-32> indicates that a maximum of 32 numbers can be specified.
regular-expression: Specifies a regular expression for the advanced large community list. A regular expression is a string of 1 to 63 characters. For more information about regular expressions, see routing policy configuration in Layer 3IP Routing Configuration Guide.
You can use this command together with the if-match large-community command to match BGP routes with specific large community attributes.
If you specify neither of the deny and permit keywords, the undo command applies to large community lists in permit and deny modes.
# Configure advanced large community list 100 to permit routes with the large community attribute starting with 10.
[Sysname] ip large-community-list 100 permit ^10
# Configure basic large community list 1 to permit routes with large community attribute 1:1:1.
[Sysname] ip large-community-list 1 permit 1:1:1
ip rd-list
Use ip rd-list configure an RD list.
Use undo ip rd-list to remove an RD list.
undo ip rd-list rd-list-number [ index index-number ] [ { deny | permit } route-distinguisher&<1-10> ]
No RD lists exist.
index index-number: Specifies an index number for an RD list item, in the range of 1 to 4294967295. An item with a smaller index number is matched first. If you do not specify this option, the index number starts from 10 and increases by 10 for each of the consecutive RD list items.
deny: Specifies the deny mode. If a route matches the item, the route is denied without being compared with the next item. If a route does not match the item, the route is compared with the next item.
permit: Specifies the permit mode. If a route matches the item, it passes the RD list. If a route does not match the item, the route is compared with the next item.
route-distinguisher&<1-10>: Specifies a list of up to 10 RD list items. Each item is a string of 3 to 21 characters.
An RD has the following forms:
·     16-bit AS number in dotted format:32-bit user-defined number. For example, 0.1:3. The AS number range is 0.1 to 0.65535.
·     16-bit AS number in integer format:wildcard character. For example, 101:*.
·     16-bit AS number in dotted format:wildcard character. For example, 0.1:*. The AS number range is 0.1 to 0.65535.
·     32-bit IP address:wildcard character. For example, 192.168.122.15:*.
·     32-bit AS number in integer format:16-bit user-defined number. For example, 65536:1. The minimum AS number is 65536.
·     32-bit AS number in integer format:wildcard character. For example, 65536:*. The minimum AS number is 65536.
·     32-bit AS number in dotted format:16-bit user-defined number. For example, 65535.65535:1. The minimum AS number is 1.0.
·     32-bit AS number in dotted format:wildcard character. For example, 1.0:*. The minimum AS number is 1.0.
An RD list matches the RDs of BGP routes. An RD list is identified by an RD list number and can contain multiple items that specify RD ranges. The relationship between the items is logical OR. A route matches the RD list if it matches one item in the list. A route does not match the RD list if it does not match any items in the list.
To filter routes by RD, use the ip rd-list command together with the if-match rd-list command. If you specify a nonexistent RD list for the if-match rd-list command, all routes pass the RD match criterion.
# Configure RD list 1 to permit routes with RD 100: 1.
[Sysname] ip rd-list 1 permit 100:1
display ip rd-list
if-match rd-list
reset ip as-path
Use reset ip as-path to clear BGP AS path list statistics.
reset ip as-path [ as-path-number | as-path-name ]
If you do not specify an AS path list number or name, this command clears statistics for all AS path lists.
# Clear statistics for BGP AS path list abc.
<Sysname> reset ip as-path abc
display ip as-path
route-policy
Use route-policy to create a routing policy and a node and enter routing policy node view, or enter the view of an existing routing policy node.
Use undo route-policy to remove a routing policy or a node of it.
No routing policies exist.
route-policy-name: Specifies a routing policy name, a case-sensitive string of 1 to 63 characters.
deny: Specifies the deny match mode for the routing policy node. If a route matches all the if-match clauses of the node, it is denied without being compared with the next node. If a route does not match any if-match clauses of the node, the route is compared with the next node.
permit: Specifies the permit match mode for the routing policy node. If a route matches all the if-match clauses of the node, it is handled by the apply clauses of the node. If a route does not match any if-match clauses of the node, the route is compared with the next node.
node node-number: Specifies a node number in the range of 0 to 65535. A node with a smaller number is matched first.
Use a routing policy to filter routing information.
Operating mechanism
A routing policy can contain several nodes and each node contains a set of if-match and apply clauses. The if-match clauses define the match criteria of the node and the apply clauses define the actions to be taken on packets matching the criteria. The relation between the if-match clauses of different types is logical AND and the relation between the if-match clauses of the same type is logical OR. if-match clauses of all types must be met. The relation between nodes is logical OR. A packet passing a node passes the routing policy. If a packet does not pass any nodes, the packet does not pass the routing policy.
# Create node 10 in permit mode for routing policy policy1 and enter routing policy node view.
route-policy non-exist-deny
Use route-policy non-exist-deny to prevent BGP routes from passing a routing policy that does not exist.
Use undo route-policy non-exist-deny to restore the default.
All routes can pass a routing policy that does not exist.
With this feature enabled, no routes can pass a routing policy that does not exist. The routing policy can filter routes correctly only after you create it.
This command takes effect only on BGP routes. If you enable this feature and use a routing policy that does not exist for route filtering, non-BGP routes can still pass the routing policy.
# Prevent all routes from passing a routing policy that does not exist.
[Sysname] route-policy non-exist-deny
route-policy nonexistent-config-confirm
Use route-policy nonexistent-config-confirm enable to enable interactive notifications about non-existent routing policy settings.
Use undo route-policy nonexistent-config-confirm enable to disable interactive notifications about non-existent routing policy settings.
Interactive notifications about non-existent routing policy settings are enabled.
If a non-existent routing policy is used for route filtering or a non-existent ACL or prefix list is associated with an if-match clause, all routes can match the non-existent routing policy or if-match clause.
For example, if you associate a non-existent prefix list with an if-match clause, all routes might be permitted or denied by the related routing policy.
To avoid the above issue, use this command to enable interactive notifications about non-existent routing policies, ACLs, and prefix lists. When you apply a non-existent routing policy, or associate a non-existent ACL or prefix list to an if-match clause, you must enter Y or N for configuration confirmation.
·     To issue the configuration, enter Y.
·     To cancel the configuration, enter N.
# Enable interactive notifications about non-existent routing policy settings.
[Sysname] route-policy nonexistent-config-confirm enable
route-policy prefix-protocol-check
Use route-policy prefix-protocol-check to enable IP protocol consistency check between routes and the prefix list specified in an if-match clause.
Use undo route-policy prefix-protocol-check to restore the default.
The routing policy does not check the IP protocol consistency between routes and the prefix list specified in an if-match clause:
·     If the if-match clause uses an IPv6 address prefix list, all IPv4 routes can match the clause.
·     If the if-match clause uses an IPv4 address prefix list, all IPv6 routes can match the clause.
This feature functions as follows:
·     If the if-match clause uses an IPv6 prefix list, all IPv4 routes cannot match the clause.
·     If the if-match clause uses an IPv4 prefix list, all IPv6 routes cannot match the clause.
If both of the following conditions exist, a routing protocol (either IGP or BGP) will check the IP protocol consistency between routes and the prefix list specified in an if-match clause:
·     The route-policy prefix-protocol-check command is executed.
·     The routing protocol uses a routing policy for route filtering.
If both of the following conditions exist, a routing protocol (either IGP or BGP) will not check the IP protocol consistency between routes and the prefix list specified in an if-match clause:
·     The undo route-policy prefix-protocol-check command is executed.
# Enable IP protocol consistency check between routes and the prefix list specified in an if-match clause.
[Sysname] route-policy prefix-protocol-check
if-match ip
if-match ipv6
route-policy-change delay-time
Use route-policy-change delay-time to set the routing policy change delay timer.
Use undo route-policy-change delay-time to restore the default.
route-policy-change delay-time { time-value | unlimited }
Routing policy changes immediately take effect, but the routing protocol waits five seconds before processing routes from the new routing policy.
time-value: Specifies the routing policy change delay timer in the range of 60 to 3600 seconds. When this delay timer expires, the routing protocol waits five seconds before processing routes from the new routing policy.
unlimited: Sets an infinite delay timer.
This command makes a routing policy take effect after a delayed time interval, which prevents incomplete routing policy configuration from being issued to cause incorrect route advertisement.
Operating mechanism
A routing policy changes when one of the following events occurs:
·     A routing policy is created.
·     A routing policy node, if-match clause, or apply clause is added, modified, or deleted for a routing policy.
·     An IPv4 prefix list, IPv6 prefix list, AS path list, community list, extended community list, or MAC list is added, modified, or deleted.
·     The ACL used by an if-match clause changes.
After you configure this command, the system automatically starts the timer when a routing policy changes. The changes will not take effect on the routing policy until the change delay timer expires.
To have enough time to complete routing policy configuration, you can specify the unlimited keyword for the command. Then, execute the undo form of the command after you complete the configuration.
If you modify the routing policy change delay timer before it expires, the timer will be reset.
# Set the routing policy change delay timer to 60 seconds.
[Sysname] route-policy-change delay-time 60
IPv4 routing policy commands
apply fast-reroute
Use apply fast-reroute to set a backup link for fast reroute (FRR).
Use undo apply fast-reroute to restore the default.
No backup link for FRR is configured.
backup-interface interface-type interface-number: Specifies a backup output interface by its type and number. If the specified interface is a non-P2P interface, you must also specify a backup next hop. Non-P2P interfaces include NBMA and broadcast interfaces.
backup-nexthop ip-address: Specifies a backup next hop.
This command sets a backup link in the routing policy for FRR.
Using the routing policy, a routing protocol can designate a backup link for specific routes to implement FRR. If the primary link is used as an optimal route, the backup link is issued to the FIB together with the primary link. When the primary link fails, FRR immediately directs packets to the backup link to minimize interruption time.
# Configure node 10 of routing policy policy1 to set the backup output interface Ten-GigabitEthernet 3/1/1 and backup next hop 193.1.1.8 for the route destined for 100.1.1.0/24.
[Sysname-route-policy-policy1-10] apply fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 193.1.1.8
apply ip-address next-hop
Use apply ip-address next-hop to set a next hop for IPv4 routes.
Use undo apply ip-address next-hop to restore the default.
apply ip-address next-hop { ip-address [ public | vpn-instance vpn-instance-name ] | advertiser-address }
No next hop is set for IPv4 routes.
ip-address: Specifies the next hop IP address.
public: Specifies the public network.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the next hop belongs to the public network.
advertiser-address: Specifies the IPv4 address of the BGP route advertiser as the next hop. This keyword functions as follows:
·     Before advertising a route to IPv4 peers and peer groups, BGP sets the local peer address as the next hop of the route.
·     After receiving a route from an IPv4 peer or peer group, BGP sets the source peer address as the next hop of the route.
If you use the ip-address argument to set a next hop, the configuration does not take effect on redistributed routes.
You can use the peer route-policy command to specify a routing policy to set the address of an indirectly connected interface as the next hop for routes from directly connected EBGP peers. In this situation, configuration of the peer ebgp-max-hop command is required. The command allows the establishment of an EBGP session to the indirectly connected peer. If you do not execute the peer ebgp-max-hop command, the next hop will be unreachable and services will be interrupted.
If you execute this command multiple times to set different next hops for IPv4 routes, the most recent configuration takes effect.
# Configure node 10 in permit mode for routing policy policy1 to set next hop 193.1.1.8 for routes matching AS path list 1.
[Sysname-route-policy-policy1-10] if-match as-path 1
[Sysname-route-policy-policy1-10] apply ip-address next-hop 193.1.1.8
display ip prefix-list
Use display ip prefix-list to display IPv4 prefix list statistics.
name prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all IPv4 prefix lists.
# Display the statistics for IPv4 prefix list abc.
<Sysname> display ip prefix-list name abc
Prefix-list: abc
 Permitted 0
 Denied 0
         index: 10        Deny   6.6.6.0/24              ge  26  le  28
Table 8 Command output
Prefix-list
Name of the IPv4 prefix list.
Permitted
Total number of routes that match the criterion and are permitted after the IPv4 prefix list was created. The value for this field is reset to zero after device reboot.
Denied
Total number of routes that match the criterion and are denied after the IPv4 prefix list was created. The value for this field is reset to zero after device reboot.
index
Index of an item.
deny
Match mode of the item:
·     Permit.
·     Deny.
6.6.6.0/24
IP address and mask.
ge
Greater-equal, the lower mask length limit.
le
Less-equal, the upper mask length limit.
ip prefix-list
reset ip prefix-list
if-match ip
Use if-match ip to match IPv4 routes whose destination, next hop, or source address matches an ACL or IPv4 prefix list.
Use undo if-match ip to remove the specified ACL or IPv4 prefix list match criterion.
if-match ip { address | next-hop | route-source } { acl { ipv4-acl-number | name ipv4-acl-name } | prefix-list prefix-list-name }
undo if-match ip { address | next-hop | route-source } [ acl | prefix-list ]
No ACL or IPv4 prefix list match criterion is configured.
address: Matches the destination address of IPv4 routes.
next-hop: Matches the next hop of IPv4 routes.
route-source: Matches the source address of BGP routes. This keyword corresponds to the Neighbor field in the output from the display ip routing-table verbose command.
acl ipv4-acl-number: Specifies an ACL by its number. The value range for the ipv4-acl-number argument is 2000 to 3999 for the address keyword, and 2000 to 2999 for the next-hop and route-source keywords.
acl name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with a letter and cannot be all.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
When you specify an IPv4 ACL, follow these guidelines:
·     If the specified ACL does not exist or does not have any rules, all IPv4 routes can match the ACL.
·     If a rule in the specified ACL is applied to a VPN instance, the rule does not take effect.
Follow these restrictions and guidelines to use an IPv4 advanced ACL rule to configure an ACL match criterion:
·     To match the destination address of IPv4 routes, execute the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to create the rule.
·     To match the destination address mask of IPv4 routes, execute the rule [ rule-id ] { deny | permit } ip destination dest-addr dest-wildcard command to create the rule. Do not use this rule if the next-hop or route-source keyword is specified.
If the specified prefix list does not exist, all IPv4 routes can match the if-match clause.
# Configure node 10 of routing policy policy1 to match IPv4 routes whose next hop matches IP prefix list p1.
[Sysname-route-policy-policy1-10] if-match ip next-hop prefix-list p1
ip prefix-list
Use ip prefix-list to configure an IPv4 prefix list or an item for the list.
Use undo ip prefix-list to remove an IPv4 prefix list or an item of it.
undo ip prefix-list prefix-list-name [ ip-address mask-length [ greater-equal min-mask-length ] [ less-equal max-mask-length ] | index index-number ]
No IPv4 prefix lists exist.
prefix-list-name: Specifies an IPv4 prefix list name, a case-sensitive string of 1 to 63 characters.
index index-number: Specifies an index number for an IPv4 prefix list item, in the range of 1 to 65535. An item with a smaller index number is matched first. If you do not specify this option, the index number starts from 10 and increases by 10 for each of the consecutive prefix list items. This option is required for target configuration. For more information about target configuration, see Fundamentals Configuration Guide.
permit: Specifies the permit mode. If a route matches the item, it passes the IPv4 prefix list. If a route does not match the item, the route is compared with the next item.
ip-address mask-length: Specifies an IPv4 prefix and mask length. The value range for the mask-length argument is 0 to 32.
greater-equal min-mask-length, less-equal max-mask-length: Specifies a prefix length range. The greater-equal keyword means "greater than or equal to" and the less-equal keyword means "less than or equal to." The prefix length range relation is mask-length <= min-mask-length <= max-mask-length <= 32.
·     If only the min-mask-length argument is specified, the prefix length range is [ min-mask-length, 32 ].
·     If only the max-mask-length argument is specified, the prefix length range is [ mask-length, max-mask-length ].
·     If both the min-mask-length and max-mask-length arguments are specified, the prefix length range is [ min-mask-length, max-mask-length ].
An IPv4 prefix list is used to filter IPv4 addresses. It can contain multiple items, each of which specifies a range of IPv4 prefixes. The relation between the items is logical OR. If an item is passed, the IPv4 prefix list is passed. If no item is passed, the IP prefix list cannot be passed.
If the ip-address mask-length argument is specified as 0.0.0.0 0, only the default route will be matched.
To match all routes, use 0.0.0.0 0 less-equal 32.
# Configure IP prefix list p1 to permit routes destined for network 10.0.0.0/8 and with mask length 17 or 18.
[Sysname] ip prefix-list p1 permit 10.0.0.0 8 greater-equal 17 less-equal 18
Use reset ip prefix-list to clear IPv4 prefix list statistics.
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all IPv4 prefix lists.
# Clear the statistics for IPv4 prefix list abc.
<Sysname> reset ip prefix-list abc
ip prefix-list
IPv6 routing policy commands
apply ipv6 fast-reroute
Use apply ipv6 fast-reroute to set a backup link for fast reroute (FRR).
Use undo apply ipv6 fast-reroute to restore the default.
backup-nexthop ipv6-address: Specifies an IPv6 backup next hop.
# Configure node 10 of routing policy policy1 to set the backup next hop 1::1/64 for the route destined for 100::1/64.
[Sysname] ipv6 prefix-list abc index 10 permit 100::1 64
[Sysname-route-policy-policy1-10] if-match ipv6 address prefix-list abc
[Sysname-route-policy-policy1-10] apply ipv6 fast-reroute backup-nexthop 1::1
apply ipv6 next-hop
Use apply ipv6 next-hop to set a next hop for IPv6 routes.
Use undo apply ipv6 next-hop to restore the default.
apply ipv6 next-hop { ipv6-address | advertiser-address }
No next hop is set for IPv6 routes.
ipv6-address: Specifies the next hop IPv6 address.
advertiser-address: Specifies the IPv6 address of the BGP route advertiser as the next hop. This keyword functions as follows:
·     Before advertising a route to IPv6 peers and peer groups, BGP sets the local peer address as the next hop of the route.
·     After receiving a route from an IPv6 peer or peer group, BGP sets the source peer address as the next hop of the route.
If you use the ipv6-address argument to set a next hop, the configuration does not take effect on redistributed routes.
If you execute this command multiple times to set different next hops for IPv6 routes, the most recent configuration takes effect.
# Configure node 10 for routing policy policy1 to set next hop 3ffe:506::1 for IPv6 routes matching AS path list 1.
[Sysname-route-policy-policy1-10] apply ipv6 next-hop 3ffe:506::1
display ipv6 prefix-list
Use display ipv6 prefix-list to display IPv6 prefix list statistics.
name prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all IPv6 prefix lists.
# Display the statistics for all IPv6 prefix lists.
<Sysname> display ipv6 prefix-list
Prefix-list6: 666
 Permitted 0
 Denied 0
         index: 10        Permit 6::/64                  ge  66  le  88
Table 9 Command output
Prefix-list6
Name of the IPv6 prefix list.
Permitted
Total number of routes that match the criterion and are permitted after the IPv6 prefix list was created. The value for this field is reset to zero after device reboot.
Denied
Total number of routes that match the criterion and are denied after the IPv6 prefix list was created. The value for this field is reset to zero after device reboot.
index
Index number of an item.
permit
·     Permit.
·     Deny.
6::/64
IPv6 address and prefix length for matching.
ge
Greater-equal, the lower prefix length limit.
le
Less-equal, the upper prefix length limit.
ipv6 prefix-list
reset ipv6 prefix-list
if-match ipv6
Use if-match ipv6 to match IPv6 routes whose destination, next hop, or source address matches an ACL or IPv6 prefix list.
Use undo if-match ipv6 to remove the specified ACL or IPv6 prefix list match criterion.
if-match ipv6 { address | next-hop | route-source } { acl { ipv6-acl-number  | name ipv6-acl-name } | prefix-list prefix-list-name
undo if-match ipv6 { address | next-hop | route-source } [ acl | prefix-list ]
No ACL or IPv6 prefix list match criterion is configured.
address: Matches the destination address of IPv6 routes.
next-hop: Matches the next hop of IPv6 routes.
route-source: Matches the source address of IPv6 routes.
acl ipv6-acl-number: Specifies an IPv6 ACL by its number. The value range for the ipv6-acl-number argument is 2000 to 3999 for the address keyword, and 2000 to 2999 for the next-hop and route-source keywords.
acl name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with a letter and cannot be all.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
When you specify an IPv6 ACL, follow these guidelines:
·     If the specified ACL does not exist or does not have any rules, all IPv6 routes can match the ACL.
Follow these restrictions and guidelines to use an IPv6 advanced ACL rule to configure an ACL match criterion:
·     To match the destination address of IPv6 routes, execute the rule [ rule-id ] { deny | permit } ipv6 source source-address source-prefix command to create the rule.
·     To match the destination address prefix of IPv6 routes, execute the rule [ rule-id ] { deny | permit } ipv6 destination dest-address dest-prefix command to create the rule. Do not use this rule if the next-hop or route-source keyword is specified.
If the specified IPv6 prefix list does not exist, all IPv6 routes can match the if-match clause.
# Configure node 10 of routing policy policy1 to permit routes whose next hop matches IPv6 prefix list p1.
[Sysname-route-policy-policy1-10] if-match ipv6 next-hop prefix-list p1
ipv6 prefix-list
Use ipv6 prefix-list to configure an IPv6 prefix list or an item for it.
Use undo ipv6 prefix-list to remove an IPv6 prefix list or an item.
ipv6 prefix-list prefix-list-name [ index index-number ] { deny | permit } ipv6-address { prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ] | inverse inverse-prefix-length }
undo ipv6 prefix-list prefix-list-name [ ipv6-address { prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ] | inverse inverse-prefix-length } | index index-number ]
No IPv6 prefix lists exist.
prefix-list-name: Specifies an IPv6 prefix list name, a case-sensitive string of 1 to 63 characters.
index index-number: Specifies an index number for an IPv6 prefix list item, in the range of 1 to 65535. An item with a smaller index number is matched first. If you do not specify this option, the index number starts from 10 and increases by 10 for each of the consecutive IPv6 prefix list items. This option is required for target configuration. For more information about target configuration, see Fundamentals Configuration Guide.
permit: Specifies the permit mode. If a route matches the item, it passes the IPv6 prefix list. If a route does not match the item, the route is compared with the next item.
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies the IPv6 prefix length. The value range for the prefix-length argument is 0 to 128.
The prefix length range relation is mask-length <= min-mask-length <= max-mask-length <= 128.
·     If only the min-prefix-length argument is specified, the prefix length range is [ min-prefix-length, 128 ].
·     If only the max-prefix-length argument is specified, the prefix length range is [ prefix-length, max-prefix-length ].
·     If both the min-prefix-length and max-prefix-length arguments are specified, the prefix length range is [ min-prefix-length, max-prefix-length ].
inverse inverse-prefix-length: Matches IPv6 addresses from the least significant bit to the specified length. The value range for the inverse-prefix-length argument is 1 to 128.
An IPv6 prefix list is used to filter IPv6 addresses. An IPv6 prefix list can have multiple items, and each of them specifies a range of IPv6 prefixes. The relation between the items is logical OR. A route passing an item passes the IPv6 prefix list. A route passing no item does not pass the IPv6 prefix list.
If the ipv6-address prefix-length argument is specified as :: 0, only the default route matches.
To match all routes, configure :: 0 less-equal 128.
# Permit IPv6 addresses with a mask length between 32 bits and 64 bits.
[Sysname] ipv6 prefix-list abc permit :: 0 greater-equal 32 less-equal 64
# Deny IPv6 addresses with a prefix 3FFE:D00::/32 and a prefix length greater than or equal to 32 bits.
[Sysname] ipv6 prefix-list abc deny 3FFE:D00:: 32 less-equal 128
Use reset ipv6 prefix-list to clear IPv6 prefix list statistics.
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all IPv6 prefix lists.
# Clear the statistics for IPv6 prefix list abc.
<Sysname> reset ipv6 prefix-list abc
ipv6 prefix-list
