- 07-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-EIGRP commands
- 07-BGP commands
- 08-Policy-based routing commands
- 09-IPv6 static routing commands
- 10-RIPng commands
- 11-OSPFv3 commands
- 12-IPv6 policy-based routing commands
- 13-Routing policy commands
- 14-DCN commands
| 02-Static routing commands | 253.99 KB |
display route-static routing-table
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd
ip route-static recursive-lookup segment-routing-ipv6
ip route-static recursive-lookup tunnel
delete static-routes all
Use delete static-routes all to delete all static routes.
delete [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes all static routes for the public network.
CAUTION: This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network. |
When you use this command, the system will prompt you to confirm the operation before deleting all the static routes.
To delete one static route, use the undo ip route-static command. To delete all static routes, including the default route, use the delete static-routes all command.
# Delete all static routes.
[Sysname] delete static-routes all
This will erase all IPv4 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ip route-static
display route-static nib
Use display route-static nib to display static route next hop information.
display route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string of 1 to ffffffff. If you do not specify this argument, the command displays all static route next hop information.
verbose: Displays detailed static route next hop information. If you do not specify this keyword, the command displays brief static route next hop information.
# Displays brief static route next hop information.
<Sysname> display route-static nib
Total number of nexthop(s): 44
NibID: 0x11000000 Sequence: 0
Type: 0x21 Flushed: Yes
Age: 00h01m50s
UserKey0: 0x111 VrfNthp: 0
UserKey1: 0x0 Nexthop: 0.0.0.0
IFIndex: 0x111 LocalAddr: 0.0.0.0
MemberPort: 0x0
TopoNthp: 0 ExtType1: 0x0
ExtType2: 0x0
Color: 0 COFlag: 0x0
SIDIndex: 0x0 SRPName:
OriNexthop: 0.0.0.0
NibID: 0x11000001 Sequence: 1
Type: 0x41 Flushed: Yes
Age: 00h01m50s
UserKey0: 0x0 VrfNthp: 5
UserKey1: 0x0 Nexthop: 2.2.2.2
IFIndex: 0x0 LocalAddr: 0.0.0.0
MemberPort: 0x0
ExtType2: 0x0
OriNexthop: 0.0.0.0
NibID |
ID of the NIB. |
NibSeq |
Sequence number of the NIB. |
Type |
Type of the NIB. |
Flushed |
Indicates whether the route with the NIB has been flushed to the FIB. |
Age |
Time when the next hop information was updated most recently. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
VrfNthp |
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network. |
Nexthop |
Next hop address. |
IFIndex |
Interface index |
LocalAddr |
Local interface address. |
MemberPort |
Index of a member port in an aggregation group. |
NewUK0 |
New reserved data 1. This field is not displayed if this attribute is not available. |
NewUK1 |
New reserved data 2. This field is not displayed if this attribute is not available. |
NewUK2 |
New reserved data 3. This field is not displayed if this attribute is not available. |
NewUK3 |
New reserved data 4. This field is not displayed if this attribute is not available. |
NewUK4 |
New reserved data 5. This field is not displayed if this attribute is not available. |
NewUK5 |
New reserved data 6. This field is not displayed if this attribute is not available. |
NewUK6 |
New reserved data 7. This field is not displayed if this attribute is not available. |
NewUK7 |
New reserved data 8. This field is not displayed if this attribute is not available. |
NewUK8 |
New reserved data 9. This field is not displayed if this attribute is not available. |
NewUK9 |
New reserved data 10. This field is not displayed if this attribute is not available. |
NewUK10 |
New reserved data 11. This field is not displayed if this attribute is not available. |
NewUK11 |
New reserved data 12. This field is not displayed if this attribute is not available. |
NewUK12 |
New reserved data 13. This field is not displayed if this attribute is not available. |
TopoNthp |
This field is not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network. |
ExtType1 |
The first NIB extension type. |
ExtType2 |
The second NIB extension type. |
Color |
Color extended community attribute. |
COFlag |
Flag of the color extended community attribute. |
SIDIndex |
SID index value. |
SRPName |
SR-MPLS TE policy name. |
OriNexthop |
Original next hop address of the route. If the route is obtained from a BGP UPDATE message, the address is the next hop IP address in the BGP UPDATE message. |
# Displays detailed static route next hop information.
<Sysname> display route-static nib verbose
Age: 00h01m50s
MemberPort: 0x0
ExtType2: 0x0
OriNexthop: 0.0.0.0
RefCnt: 2 FlushRefCnt: 0
Flag: 0x2 Version: 1
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 0.0.0.0
RelyDepth: 0 RealNexthop: 0.0.0.0
Interface: NULL0 LocalAddr: 0.0.0.0
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology: base
Weight: 1000000 Flags: 0x0
SRPolicyNID: 4294967295 SRInterface:
ColorWeight: 0 Locator: N/A
MemberPort: N/A uiFlags: 0x0
SliceId: 0
Age: 00h01m50s
MemberPort: 0x0
ExtType2: 0x0
OriNexthop: 0.0.0.0
RefCnt: 1 FlushRefCnt: 0
Flag: 0x12 Version: 1
ExtFlag: 0x0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 2.2.2.2
RelyDepth: 9 RealNexthop: 0.0.0.0
SliceId: 0
NibID |
ID of the NIB. |
Sequence |
Type |
Type of the NIB. |
Flushed |
Age |
UserKey0 |
Reserved data 1. |
VrfNthp |
Index of the VPN instance that the next hop belongs to. This field displays 0 if the next hop is on the public network. |
UserKey1 |
Reserved data 2. |
Nexthop |
Next hop address. |
IFIndex |
Interface index |
LocalAddr |
MemberPort |
NewUK0 |
NewUK1 |
NewUK2 |
NewUK3 |
NewUK4 |
NewUK5 |
NewUK6 |
NewUK7 |
NewUK8 |
NewUK9 |
NewUK10 |
NewUK11 |
NewUK12 |
TopoNthp |
ExtType1 |
ExtType2 |
Color |
COFlag |
SIDIndex |
SID index value. |
SRPName |
OriNexthop |
RefCnt |
Reference count of the next hop. |
FlushRefCnt |
Reference count of the next hop that is flushed to the FIB. |
Flag |
Flag of the next hop. |
Version |
Version of the next hop. |
ExtFlag |
Extended flag of the next hop. |
x nexthop(s) |
Number of next hops. |
PrefixIndex |
Prefix index of the next hop for an ECMP route. |
OrigNexthop |
Original next hop. |
RelyDepth |
Recursion depth. |
RealNexthop |
Real next hop. |
Output interface. |
localAddr |
TunnelCnt |
Number of tunnels after route recursion. |
Vrf |
VPN instance name. For the public network, this field displays default-vrf. |
TunnelID |
ID of the tunnel after route recursion. |
Topology |
This field is not supported in the current software version. Topology name. The topology name for the public network is base. |
Weight |
ECMP route weight. This field displays 0 for non-ECMP routes. |
Flags |
Flags of the detailed next hop. |
SRPolicyNID |
NIB ID of the route obtained from an SR-MPLS TE policy through route recursion. |
SRInterface |
Output interface of the route obtained from the SR-MPLS TE policy through route recursion. |
ColorWeight |
Weight value of the color attribute in the SR-MPLS TE policy. |
Locator |
IPv6 prefix of the locator to which the SID belongs. If no locator is available, this field displays N/A. |
MemberPort |
Number of a member port in an aggregation group. If this attribute is not available, this field displays N/A. |
uiFlags |
Extention of the current next hop flag. Options include: · 0x00000001—SRv6 multilevel primary/backup NIDs established by the SRv6 TE policy protocol. · 0x00000002—NID obtained through recursion reported by route management. · 0x00000004—SRv6 forwarding flag. · 0x00000008—The forwarding path is preferentially selected through the SRv6 TE mode. · 0x00000010—SRv6 multilevel FRR. The primary path is an SRv6 TE path, and the backup path is an SRv6 BE path. Value 0x0 indicates that the next hop does not contain any previous flags. |
SliceId |
Network slice instance ID. |
Use display route-static routing-table to display static routing table information.
display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays static routing table information for the public network.
ip-address: Specifies the destination IP address in dotted decimal notation. If you do not specify this argument, the command displays all static routing table information.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
# Display static routing table information.
<Sysname> display route-static routing-table
Total number of routes: 24
Status: * - valid
*Destination: 0.0.0.0/0
NibID: 0x1100000a NextHop: 2.2.2.10
MainNibID: N/A BkNextHop: N/A
BkNibID: N/A Interface: Ten-GigabitEthernet3/1/1
TableID: 0x2 BkInterface: Ten-GigabitEthernet3/1/2
Flag: 0x82d01 BfdSrcIp: N/A
DbIndex: 0xd BfdIfIndex: 0x0
Type: Normal BfdVrfIndex: 0
TrackIndex: 0xffffffff Label: NULL
Preference: 60 vrfIndexDst: 0
BfdMode: N/A vrfIndexNH: 0
Permanent: 0 Tag: 0
UCMIndex: 0x0 UserVLAN: 65535
UCMMTU: 0 BrasHash: 0
SessionID: 0
Cost: 120 EffectiveCost: 120
BfdStatic: bfd01
NibID: 0x1100000b NextHop: 2.2.2.11
BkNibID: N/A Interface: Ten-GigabitEthernet3/1/3
TableID: 0x2 BkInterface: Ten-GigabitEthernet3/1/4
Permanent: 0 Tag: 0
SessionID: 0
destination |
Destination address/prefix. |
NibID |
ID of the NIB. |
MainNibID |
ID of the primary next hop for static route FRR. |
BkNibID |
ID of the backup next hop for static route FRR. |
NextHop |
Next hop address. |
BkNextHop |
Backup next hop address. |
Output interface of the route. |
BkInterface |
Backup output interface. |
TableID |
ID of the table to which the route belongs. |
Flag |
Flag of the route. |
DbIndex |
Index of the database to which the route belongs. |
Type |
Route type: · Normal. · DHCP. · NAT. · IPsec. |
BfdSrcIp |
Source IP address of the indirect BFD session. |
BfdIfIndex |
Index of the interface where BFD is enabled. |
BfdVrfIndex |
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network. |
BfdMode |
BFD session mode: · N/A—No BFD session is configured. · Ctrl—Control packet mode · Echo—Echo packet mode. |
TrackIndex |
NQA Track index. |
vrfIndexDst |
Index of VPN instance to which the destination belongs. For the public network, this field displays 0. |
vrfIndexNH |
Index of the VPN instance to which the next hop belongs. For the public network, this field displays 0. |
Permanent |
Permanent static route flag. 1 indicates a permanent static route. |
UCMIndex |
UCM system resource index. |
UserVLAN |
This field is not supported in the current software version. UCM user outer VLAN. |
UCMMTU |
This field is not supported in the current software version. UCM MTU. |
BrasHash |
This field is not supported in the current software version. Hash value for the UCM load sharing algorithm. |
SessionID |
PPPoE user session ID. |
Cost |
Configured cost value for the static route. |
EffectiveCost |
Cost value for the static route that actually takes effect. |
BfdStatic |
Name of the static BFD session associated with the route. This field is not displayed if no static BFD session has been associated with the route. |
ip route-static
Use ip route-static to configure a static route.
Use undo ip route-static to delete a static route.
ip route-static dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address | dhcp ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet | static session-name } | permanent | track track-entry-number ] [ cost cost-value ] | next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ cost cost-value | inherit-cost ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ cost cost-value | inherit-cost ] } [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ip route-static group group-name { interface-type interface-number [ next-hop-address | dhcp ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet | static session-name } | permanent | track track-entry-number ] [ cost cost-value ] | next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ cost cost-value | inherit-cost ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ cost cost-value | inherit-cost ] } [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
undo ip route-static { dest-address { mask-length | mask } | group group-name } [ interface-type interface-number [ next-hop-address | dhcp ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
ip route-static dest-address { mask-length | mask } vpn-instance d-vpn-instance-name [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ip route-static group group-name vpn-instance d-vpn-instance-name [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
undo ip route-static { dest-address { mask-length | mask } | group group-name } [ vpn-instance d-vpn-instance-name ]
ip route-static dest-address { mask-length | mask } sr-policy policy-name [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
undo ip route-static dest-address { mask-length | mask } [ sr-policy policy-name ] [ preference preference ]
ip route-static dest-address { mask-length | mask } { remote-sid remote-sid locator-prefix-len [ recursive-lookup longest-match ] | srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } [ sid sid ] } * [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
undo ip route-static dest-address { mask-length | mask } [ remote-sid remote-sid locator-prefix-len | srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } ] * [ preference preference ]
No static route is configured.
dest-address: Specifies the destination IP address of the static route, in dotted decimal notation. If the destination IP address and the mask are both 0.0.0.0 (or 0), the configured route is a default route. The default route is used for forwarding a packet matching no entry in the routing table.
group group-name: Specifies a static route group by its name, a case-sensitive string of 1 to 31 characters. If you specify a static route group, all prefixes in the static route group will be assigned the next hop and output interface. If the static route group does not exist or does not contain any prefixes, no static routes will be created.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the next-hop-address argument following this option, the device searches for the output interface in the specified destination VPN instance for packets matching the static route. If you specify the next-hop-address argument and this option, the device searches for the output interface in the specified destination VPN instance based on the specified next hop address for packets matching the static route.
interface-type interface-number: Specifies an output interface by its type and number. For more information, see Layer 3—IP Routing Configuration Guide.
next-hop-address: Specifies the IP address of the next hop, in dotted decimal notation. For more information, see Layer 3—IP Routing Configuration Guide.
dhcp: Specifies the default router designated by the DHCP server for the output interface as the next hop of the static route.
recursive-lookup host-route: Specifies only host routes for static route recursion. If you specify this keyword, you must configure the arp route-direct advertise command on the next hop-associated output interface to enable ARP direct route advertisement for advertising 32-bit host routes.
recursive-lookup longest-match: Specifies routes with the longest matching mask for static route recursion.
backup-interface interface-type interface-number: Specifies a backup output interface by its type and number. If the backup output interface is an NBMA interface or broadcast interface and not a P2P interface, you must specify the backup next hop address.
backup-nexthop backup-nexthop-address: Specifies a backup next hop address.
bfd: Enables BFD to detect reachability of the static route's next hop. When the next hop is unreachable, the system immediately switches to the backup route. For more information about BFD, see High Availability Configuration Guide.
control-packet: Specifies the BFD control packet mode.
bfd-source ip-address: Specifies the source IP address of BFD packets. As a best practice, specify the loopback interface address.
echo-packet: Specifies the BFD echo packet mode.
static session-name: Associates the static route with a static BFD session. The session-name argument represents the static BFD session name, a case-sensitive string of 1 to 64 characters. If you specify a nonexistent static BFD session, you must create the static BFD session to have the association take effect. To use a static BFD session to detect next hop reachability of the static route, you must use the output interface IP address of the static route as the source address of the static BFD session, and use the next hop IP address of the static route as the peer address of the static BFD session.
permanent: Specifies the route as a permanent static route. After you specify this keyword, an active static route will always be active and stay in the routing table, regardless of whether the output interface is up or down. If the static route has not been activated, it will not appear in the routing table, even if the permanent keyword is specified.
track track-entry-number: Associates the static route with a track entry specified by its number in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
sr-policy policy-name: Specifies an SR-MPLS TE policy for static route recursion. The policy-name argument represents the SR-MPLS TE policy name, a case-sensitive string of 1 to 59 characters. For more information about SR-MPLS TE policies, see Segment Routing Configuration Guide.
remote-sid remote-sid locator-prefix-len: Enables the static route to forward packets in SRv6 BE mode. The remote-sid argument specifies the SRv6 SID of the SRv6 BE destination node. The locator-prefix-len argument specifies the locator length for the SRv6 SID. The remote-sid and locator-prefix-len arguments uniquely identifies a locator. The device will perform SRv6 encapsulation for packets and forward the packets according to the IGP routes associated with the locator.
srv6-policy name policy-name: Specifies an SRv6 TE policy by its name for static route recursion. The policy-name argument represents the SRv6 TE policy name, a case-sensitive string of 1 to 59 characters. For more information about SRv6 TE policies, see Segment Routing Configuration Guide.
srv6-policy color color-value end-point ipv6 ipv6-address: Specifies an SRv6 TE policy by its color and endpoint attributes for static route recursion. The color-value argument represents the color attribute value of the SRv6 TE policy, in the range of 0 to 4294967295. The ipv6-address argument represents the endpoint IPv6 address of the SRv6 TE policy.
sid sid: Specifies the SRv6 SID of the endpoint. Packets forwarded through the SRv6 TE policy will be further forwarded based on the SRv6 SID.
cost cost-value: Specifies the cost value for the static route, in the range of 1 to 4294967295. If you do not specify this option, the cost value for the static route is 0.
inherit-cost: Enables the static route to inherit the cost value of the next hop route obtained through the first recursive lookup. If you do not specify this keyword, the static route does not inherit the cost value of the next hop route obtained through recursive lookup, and it uses the default cost value 0.
preference preference: Specifies a preference for the static route, in the range of 1 to 255. The default is 60. The smaller the value, the higher the preference. To enable load sharing for multiple routes to the same destination, assign the same preference to the routes. To enable the routes to back up one another, assign different preferences to them.
tag tag-value: Sets a tag value for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
no-advertise: Disables advertisement for the static route. With this keyword, the static route can be imported to the IGP or BGP routing table, but cannot be advertised to neighbors. If multiple next hops are configured for the same static route prefix, the device flushes only the optimal static routes to the IP routing table. If the optimal static routes are imported to the IGP or BGP routing table, the following conditions exist:
· If only one optimal route exists, you must specify this keyword for the optimal static route. If you do not specify this keyword, the device still can advertise that route to neighbors.
· If multiple optimal routes exist, you must specify this keyword for each optimal static route. For the optimal static routes not specified with the keyword, the device still can advertise them to neighbors.
description text: Configures a description of 1 to 150 characters for the static route. The description can include special characters, such as the space, except the question mark (?).
Application scenarios
Use this command to configure static routes in the public network.
If a network's topology is simple, you only need to configure static routes for the network to work correctly. You can also configure static routes when the device cannot use dynamic routing protocols or cannot establish routes to the destination network.
Follow these guidelines when you specify the output interface or the next hop address of the static route:
· If the output interface is a Null 0 interface, no next hop address is required.
· If the output interface is a point-to-point interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
· NBMA or P2MP interfaces need IP address-to-link layer address mappings for successful packet delivery. As a best practice, specify the next hop address for the route if the output interface is an NBMA or P2MP interface.
· If the output interface is a broadcast interface, the device uses the next hop IP address to obtain the MAC address of the next hop. Therefore, you must specify both the output interface and next hop IP address.
Follow these guidelines when you configure BFD for a static route:
· To use a static BFD session to detect next hop reachability for a static route, you must perform the following tasks:
¡ Specify the IP address of the output interface of the static route as the source address of the static BFD session.
¡ Specify the IP address of the next hop of the static route as the peer address of the static BFD session.
· Enabling BFD for a flapping route could worsen the route flapping situation. Therefore, use it with caution.
Follow these guidelines when you associate a static route with a track entry:
· For static routing-Track-NQA collaboration, you must configure the same VPN instance ID for the next hop to be detected and the NQA operation.
· If the static route needs route recursion, the associated track entry must monitor the next hop of the related route instead of that of the recursive static route. Otherwise, a valid route might be mistakenly considered invalid.
After an interface obtains an IP address and gateway address through DHCP, the device automatically generates a static route with the interface as the output interface. The destination address of the static route is 0.0.0.0/0 and the next hop of the static route is the default router (the gateway address designated by the DHCP server). This static route cannot form ECMP routes with manually configured static routes. The device uses this static route to guide traffic forwarding only after the manually configured static routes become invalid.
Specify the dhcp keyword to use both the automatically generated static route and the manually configured static routes to guide traffic forwarding. This keyword is applicable when the device has dual egress WAN links.
The dhcp keyword enables the device to automatically generate a static route destined for the specified network with the DHCP-designated default router of the output interface as the next hop. This static route takes effect only after the output interface obtains an IP address and gateway address through DHCP, and becomes invalid upon the DHCP lease expiration. The next hop of this static route changes as the gateway address of the output interface changes. In addition, this static route can form ECMP routes with manually configured static routes.
To specify the dhcp keyword, make sure the output interface of the static route is a broadcast interface.
If you do not specify the recursive-lookup longest-match or recursive-lookup host-route keyword, the static route preferentially recurses to a direct route. The static route recurses to the route with the longest matching mask only when no matching direct route is found. If the destination network address of the direct route contains the next hop address of the static route, the following conditions might exist:
· The static route recurses the next hop to the direct route.
· The device determines that the next hop address of the static route is locally connected.
However, the next hop might be incorrect, which results in failure to forward packets matching the static route. If you specify the recursive-lookup longest-match keyword, the static route recurses to the route with the longest matching mask to ensure correct next hop recursion. If you specify the recursive-lookup host-route keyword, the static route recurses to only a host route with a 32-bit mask, and the static route can be activated only when the host route is reachable.
If you specify both the remote-sid remote-sid locator-prefix-len option and srv6-policy keyword, the static route is preferentially recursed to the SRv6 TE policy. When the SRv6 TE policy becomes unavailable, the static route will forward packets in SRv6 BE mode.
You cannot specify both the remote-sid and sid keywords in one command.
The cost value specified with the cost cost-value option or inherit-cost keyword for the static route has the following effects:
· When the static route is redistributed into another routing protocol, its cost value is also redistributed. This affects the optimal route selection result with the static route for the routing protocol.
· The optimal route selection result is affected by the static route in the IP routing table: For multiple static routes with the same destination IP address, the route with smaller preference value is the optimal route. For routes with the same preference value, the one with smaller cost value is the optimal route.
# Configure a static route, whose destination address is 1.1.1.1/24, next hop address is 2.2.2.2, tag value is 45, and description information is for internet.
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet
arp route-direct advertise (Layer 3—IP Services Command Reference)
bfd static (High Availability Command Reference)
display ip routing-table protocol
ip route-static-group
prefix
ip route-static bfd
Use ip route-static bfd to configure BFD session parameters for a static route.
Use undo ip route-static bfd to restore the default.
BFD control packet mode for single-hop detection and BFD echo packet mode:
ip route-static bfd interface-type interface-number next-hop-address { detect-multiplier detect-multiplier | min-echo-receive-interval min-echo-receive-interval | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
undo ip route-static bfd interface-type interface-number next-hop-address
BFD control packet mode for multihop detection:
ip route-static bfd [ vpn-instance d-vpn-instance-name ] next-hop-address source-ip ip-address { detect-multiplier detect-multiplier | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
undo ip route-static bfd [ vpn-instance d-vpn-instance-name ] next-hop-address
No BFD session parameters are specifically configured for a static route. The static route uses the session parameters configured for the BFD module (common BFD session parameters).
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the next hop of the static route belongs to the public network, do not specify this option.
source-ip ip-address: Specifies a source IPv4 address for BFD packets, in dotted decimal notation.
detect-multiplier detect-multiplier: Sets the BFD detection time multiplier. The value range for the detect-multiplier argument is 3 to 50. The default value is 5.
min-echo-receive-interval min-echo-receive-interval: Sets the minimum interval for receiving BFD echo packets, in milliseconds. The value range for the min-echo-receive-interval argument is 3 to 10000.
min-receive-interval min-receive-interval: Sets the minimum interval for receiving BFD control packets, in milliseconds. The value range for the min-receive-interval argument is 3 to 10000.
min-transmit-interval min-transmit-interval: Sets the minimum interval for transmitting BFD control packets, in milliseconds. The value range for the min-transmit-interval argument is 3 to 10000.
To associate a static route with BFD, you can use this command to configure BFD session parameters for a single static route.
Operating mechanism
Use this command to configure BFD session parameters for a static route, including parameters that determine the BFD detection time. The BFD detection time = detect-multiplier × max (min-echo-receive-interval, min-receive-interval, min-transmit-interval). For more information about the calculation method of BFD detection time, see BFD in High Availability Command Reference.
To apply the configured BFD session parameters, use one of the following combinations of parameters to specify a static route:
· In control packet mode for single-hop detection and in echo packet mode, use the output interface and next hop address.
· In control packet mode for multihop detection, use the next hop address and BFD packet source address. If the next hop belongs to a VPN instance, use the destination VPN instance, next hop address, and BFD packet source address to specify the static route.
For an unspecified BFD session parameter, the static route uses the value of the corresponding common BFD session parameter.
If you specify the output interface when executing this command, support for the BFD session parameters varies by BFD session mode.
· Echo-mode BFD sessions support only the min-echo-receive-interval and detect-multiplier parameters.
· Control-mode BFD sessions for single-hop detection support only the min-receive-interval, min-transmit-interval, and detect-multiplier parameters.
# Configure BFD session parameters for the static route with output interface Ten-GigabitEthernet 3/1/1 and next hop 1.2.3.4. The BFD detection time multiplier is 20 and the minimum interval for receiving BFD echo packets is 1000 milliseconds.
[Sysname] ip route-static bfd ten-gigabitethernet 3/1/1 1.2.3.4 detect-multiplier 20 min-echo-receive-interval 1000
Use ip route-static default-preference to configure a default preference for static routes.
Use undo ip route-static default-preference to restore the default.
ip route-static default-preference default-preference
The default preference of static routes is 60.
default-preference: Specifies a default preference for static routes, in the range of 1 to 255.
If no preference is specified for a static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added static routes.
# Set a default preference of 120 for static routes.
[Sysname] ip route-static default-preference 120
Use ip route-static fast-reroute auto to configure static route FRR to automatically select a backup next hop.
Use undo ip route-static fast-reroute auto to disable static route FRR from automatically selecting a backup next hop.
Static route FRR is disabled from automatically selecting a backup next hop.
If multiple static routes to the same destination address with different priorities exist on the device, you can use this command to enable the device to automatically obtain backup routes. The route with higher priority is the primary route, and the route with lower priority is the backup route. Both primary and backup routes are issued to the forwarding table (which can be displayed with the display fib command). If the primary route fails, traffic can immediately switch over to the backup route for forwarding.
# Configure static route FRR to automatically select a backup next hop.
[Sysname] ip route-static fast-reroute auto
Use ip route-static primary-path-detect bfd to configure BFD to detect next hop reachability for the primary link of static route FRR.
Use undo ip route-static primary-path-detect bfd to restore the default.
ip route-static primary-path-detect bfd { ctrl | echo }
BFD is not configured to detect next hop reachability for the primary link of static route FRR. The static route uses ARP to detect next hop reachability of the primary route.
ctrl: Enables BFD control packet mode to detect next hop reachability for the primary link of static route FRR.
echo: Enables BFD echo packet mode to detect next hop reachability for the primary link of static route FRR.
With this command configured, the device automatically creates a BFD session of the IP FRR protocol type, and uses this BFD session to detect next hop reachability of the primary route. This can reduce the convergence time upon traffic switchover to the backup route next hop when the primary route next hop becomes unavailable.
If you do not configure static route FRR, or no reachable backup next hops are available for FRR, the device cannot establish a BFD session to detect the primary route next hop.
To use the BFD session in echo packet mode to detect next hop reachability of the primary route, you only need to configure the BFD echo packet mode on the local end.
The BFD session in control packet mode can be successfully established only through negotiation between the two ends. To use the BFD session in control packet mode to detect next hop reachability of the primary route, perform one of the following tasks:
· Configure the ip route-static primary-path-detect bfd command on the peer device of the primary link. This method applies when FRR is configured for both ends of the primary link.
· Manually create a static BFD session on the peer device of the primary link, and configure the following settings for the static BFD session:
¡ Specify the source IP address for the static BFD session as the destination IP address of the BFD session automatically created on the local end.
¡ Specify the destination IP address for the static BFD session as the source IP address of the BFD session automatically created on the local end.
¡ Specify the remote discriminator for the static BFD session as the local discriminator of the BFD session automatically created on the local end.
# Enable BFD echo packet mode to detect next hop reachability for the primary link of static route FRR.
[Sysname] ip route-static 1.1.1.1 32 ten-gigabitethernet 3/1/1 2.2.2.2 backup-interface ten-gigabitethernet 3/1/2 backup-nexthop 3.3.3.3
[Sysname] ip route-static primary-path-detect bfd echo
# Enable BFD control packet mode to detect next hop reachability for the primary link of static route FRR.
[Sysname] ip route-static primary-path-detect bfd control
Use ip route-static recursive-lookup segment-routing-ipv6 to allow IPv4 static routes to inherit the SRv6 SID information of related routes in route recursion.
Use undo ip route-static recursive-lookup segment-routing-ipv6 to restore the default.
IPv4 static routes are not allowed to inherit the SRv6 SID information of related routes in route recursion.
A static route requires route recursion if its next hop is not directly connected. If the next hop recurses to an SRv6 BE or SRv6 TE policy path, the static route does not inherit the SRv6 SID information of the related route by default. The device does not add SRv6 SID information to the packets matching this static route.
After you configure this command, if the next hop of the static route recurses to an SRv6 BE or SRv6 TE policy path, the static route inherits the SRv6 SID information of related route. The device will add SRv6 SID information and SRv6 encapsulation to the packets matching this static route, and then forward the encapsulated packets in SRv6 BE mode or through the SRv6 TE policy.
For more information about SRv6 BE, see IP L3VPN over SRv6 configuration or public network IP over SRv6 configuration in Segment Routing Configuration Guide. For more information about SRv6 TE policies, see SRv6 TE policy configuration in Segment Routing Configuration Guide.
# Allow IPv4 static routes to inherit the SRv6 SID information of related routes in route recursion.
[Sysname] ip route-static recursive-lookup segment-routing-ipv6
Use ip route-static recursive-lookup tunnel to allow static routes to recurse to LSP tunnels.
Use undo ip route-static recursive-lookup tunnel to restore the default.
ip route-static recursive-lookup tunnel [ prefix-list ipv4-prefix-list-name ] [ tunnel-policy tunnel-policy-name ]
Static routes cannot recurse to LSP tunnels.
prefix-list ipv4-prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters. Only static routes filtered by the specified IPv4 prefix list can recurse to LSP tunnels. If you do not specify an IPv4 prefix list, this command allows all static routes to recurse to LSP tunnels.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 126 characters. Static routes can recurse only to LSP tunnels that match the specified tunnel policy. If you do not specify a tunnel policy, this command allows static routes to recurse to any LSP tunnels.
When packets are forwarded with the IP forwarding method during network access, devices in the ISP network need to learn a large number of routes. This feature enables a static route on an access device to recurse to an LSP tunnel. User packets can then be forwarded through label switching within the ISP network, and the ISP devices do not need to maintain routes for the user network. This reduces the burden on the ISP devices and saves route resources on the devices.
Operating mechanism
The device performs route recursion for a static route if the next hop of the static route is not directly connected. By default, the static route recurses to only an output interface or next hop, and does not recurse to an LSP tunnel. After you configure this command, the static route will preferentially recurse to an LSP tunnel. If recursion to the LSP tunnel succeeds, packets matching this static route will be forwarded through label switching over the LSP tunnel. If recursion to the LSP tunnel fails, the static route continues to perform route recursion until it finds a directly connected output interface to reach the next hop. Packets matching this static route will be forwarded based on IP forwarding.
# Enable the device to recurse static routes to LSP tunnels.
[Sysname] ip route-static recursive-lookup tunnel
ip route-static vpn-instance
Use ip route-static vpn-instance to configure a static route in a VPN instance.
Use undo ip route-static vpn-instance to delete a static route from a VPN instance.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ next-hop-address | dhcp ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet | static session-name } | permanent | track track-entry-number ] [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ cost cost-value | inherit-cost ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } next-hop-address [ recursive-lookup { host-route | longest-match } ] [ public ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] ] [ cost cost-value | inherit-cost ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number [ next-hop-address | dhcp ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet | static session-name } | permanent | track track-entry-number ] [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ public ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ cost cost-value | inherit-cost ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ bfd { control-packet bfd-source ip-address | static session-name } | permanent | track track-entry-number ] [ cost cost-value | inherit-cost ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
undo ip route-static vpn-instance s-vpn-instance-name { dest-address { mask-length | mask } | group group-name } [ interface-type interface-number [ next-hop-address | dhcp ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { public | vpn-instance d-vpn-instance-name } [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name { public | vpn-instance d-vpn-instance-name } [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
undo ip route-static vpn-instance s-vpn-instance-name { dest-address { mask-length | mask } | group group-name } [ public | vpn-instance d-vpn-instance-name ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } sr-policy policy-name [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
undo ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } [ sr-policy policy-name ] [ preference preference ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { remote-sid remote-sid locator-prefix-len [ recursive-lookup longest-match ] | srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } [ sid sid ] } * [ cost cost-value ] [ preference preference ] [ tag tag-value ] [ no-advertise ] [ description text ]
undo ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } [ remote-sid remote-sid locator-prefix-len | srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } ] * [ preference preference ]
No static route is configured in a VPN instance.
s-vpn-instance-name: Specifies a source MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Each VPN instance has its own routing table, and the configured static route is installed in the routing tables of the specified VPN instances.
backup-interface interface-type interface-number: Specifies a backup output interface by its type and number. If the backup output interface is a non-P2P interface (for example, an NBMA interface or broadcast interface), you must specify the backup next hop address.
public: Specifies the public network. If you specify this keyword following the next-hop-address argument, the next hop is on the public network. The device searches for the output interface in the public network based on the next hop address for packets matching the static route. If you specify the next-hop-address argument without specifying the public keyword, the device searches for the output interface in the source VPN instance based on the next hop address for packets matching the static route. If you specify the public keyword without specifying the next-hop-address argument, the device searches for the output interface in the public network for packets matching the static route.
no-advertise: Disables advertisement for the static route. With this keyword, the static route can be imported to the IGP or BGP routing table, but cannot be advertised to neighbors. If multiple next hops are configured for the same static route prefix, the device flushes only the optimal static routes to the IP routing table. If the optimal static routes are imported to the IGP or BGP routing table, you must specify this keyword for each optimal static route. If you do not specify this keyword for an optimal static route, the device still can advertise that route to neighbors.
Use this command to configure a static route for a VPN instance. After configuration, the device will forward packets matching this route in the VPN instance to the next hop, output interface, and VPN instance specified for the static route.
If you specify a destination VPN instance but do not specify a next hop address, the source and destination VPN instances cannot be the same one.
· NBMA or P2MP interfaces need IP address-to-link layer address mappings for successful packet delivery. As a best practice, specify the next hop address for the route at the same time if the output interface is an NBMA or P2MP interface.
· If the output interface is a broadcast interface (for example, an Ethernet interface or VLAN interface), the device uses the next hop IP address to obtain the MAC address of the next hop. Therefore, you must specify both the output interface and next hop IP address.
· To use a static BFD session to detect next hop reachability for a static route, the static BFD session and the next hop of the static route must belong to the same VPN instance. In addition, you must perform the following tasks:
If a VPN instance has been specified as the destination VPN instance, you cannot specify the vpn-instance d-vpn-instance-name option when configuring a static route for the VPN instance by using this command.
A static route with a destination VPN instance specified supports only VXLAN tunnels.
If the action of a PBR node specifies only the default next hop and default SRv6 TE policy for packets, follow these restrictions and guidelines when executing this command:
¡ You cannot configure static routes for the VPN instance in the match criteria of the PBR node.
¡ The dest-address argument cannot specify the destination IP address in the match criteria of the PBR node.
For more information about PBR, see policy-based routing configuration in Layer 3—IP Routing Configuration Guide.
# Configure a static route in VPN instance vpn1, whose destination address is 1.1.1.1/24, next hop address is 2.2.2.2 in VPN instance vpn2, tag value is 45, and description information is for internet.
[Sysname] ip route-static vpn-instance vpn1 1.1.1.1 24 vpn-instance vpn2 2.2.2.2 tag 45 description for internet
prefix
Use ip route-static-group to create a static route group and enter its view, or enter the view of an existing static route group.
Use undo ip route-static-group to delete a static route group.
ip route-static-group group-name
undo ip route-static-group group-name
No static route groups exist.
group-name: Specifies the static route group name, a case-sensitive string of 1 to 31 characters.
To configure multiple static routes with different prefixes, you must execute the command for each static route. To facilitate you configuration, you can create a static route group to configure the static routes in bulk.
Operating mechanism
To configure a static route group:
1. Create a static route group.
2. Execute the prefix to add prefixes to the static route group.
3. Execute the ip route-static group command to create static routes in bulk.
# Create static route group test and enter its view.
[Sysname] ip route-static-group test
[Sysname-route-static-group-test]
ip route-static
prefix
prefix
Use prefix to add a static route prefix to a static route group.
Use undo prefix to delete a static route prefix from a static route group.
prefix dest-address { mask-length | mask }
undo prefix dest-address { mask-length | mask }
No static route prefix is added to a static route group.
Static route group view
Using a static route group to bulk configure static routes can reduce your configuration workload. You can execute this command multiple times to add multiple prefixes to a static route group. Executing the ip route-static group command can bulk create static routes based on these prefixes.
If you have executed the ip route-static group command to bulk create static routes, deleting or adding prefixes in static route group view will delete or add the prefix-associated static routes.
# Add static route prefix 1.1.1.1/32 to static route group test.
[Sysname-route-static-group-test] prefix 1.1.1.1 32
ip route-static
