- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-iPerf commands
- 06-NTP commands
- 07-PoE commands
- 08-SNMP commands
- 09-RMON commands
- 10-Event MIB commands
- 11-NETCONF commands
- 12-CWMP commands
- 13-SmartMC commands (self-mesh not supported)
- 14-Quicknet commands
- 15-EAA commands
- 16-Process monitoring and maintenance commands
- 17-Sampler commands
- 18-Mirroring commands
- 19-NetStream commands
- 20-IPv6 NetStream commands
- 21-sFlow commands
- 22-Performance management commands
- 23-Fast log output commands
- 24-Flow log commands
- 25-Information center commands
- 26-Cloud connection commands
- 27-GOLD commands
- 28-Packet capture commands
- 29-SQA commands
- 30-eMDI commands
| 21-sFlow commands | 117.99 KB |
sFlow commands
The following compatibility matrixes show the support of hardware platforms for sFlow:
Hardware |
sFlow compatibility |
Flow sampling compatibility on Layer 3 Ethernet interface switched from Layer 2 Ethernet interface |
MSR610 |
Yes |
No |
Yes |
No |
MSR810-LMS, MSR810-LUS |
No |
No |
MSR810-SI, MSR810-LM-SI |
No |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
No |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL |
Yes |
No |
Yes |
· MSR2600-6-X1: No · MSR2600-15-X1, MSR2600-15-X1-T: Yes |
MSR2600-10-X1 |
Yes |
No |
MSR2630-G-X1 |
Yes |
No |
MSR2630 |
Yes |
No |
MSR3600-28, MSR3600-51 |
Yes |
No |
No |
No |
Yes |
No |
Yes |
No |
MSR3600-28-G-X1-DP, MSR3600-51-G-X1-DP |
Yes |
No |
Yes |
No |
MSR-iMC |
Yes |
No |
Yes |
· MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC: No · MSR3620-X1, MSR3640-X1: Yes |
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660 |
Yes |
No |
MSR3610-G, MSR3620-G |
Yes |
No |
MSR3640-G |
Yes |
Yes |
MSR3640-X1-HI |
Yes |
Yes |
Hardware |
Yes |
No |
MSR830-4LM-WiNet |
Yes |
No |
Yes |
No |
Yes |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2600-10-X1-WiNet |
Yes |
No |
MSR2630-WiNet |
Yes |
No |
MSR3600-28-WiNet |
Yes |
No |
MSR3610-X1-WiNet |
Yes |
No |
MSR3620-X1-WiNet |
Yes |
Yes |
Yes |
No |
Hardware |
MSR860-6EI-XS |
No |
No |
MSR860-6HI-XS |
Yes |
No |
MSR2600-15-X1-XS |
Yes |
Yes |
MSR2630-XS |
No |
No |
MSR3600-28-XS |
Yes |
No |
MSR3610-XS |
Yes |
No |
MSR3620-XS |
Yes |
No |
MSR3610-I-XS |
Yes |
No |
MSR3610-IE-XS |
Yes |
No |
MSR3620-X1-XS |
Yes |
No |
MSR3640-XS |
Yes |
No |
MSR3660-XS |
Yes |
No |
Hardware |
MSR810-LM-GL |
Yes |
No |
MSR810-W-LM-GL |
Yes |
No |
MSR830-6EI-GL |
Yes |
No |
MSR830-10EI-GL |
Yes |
No |
MSR830-6HI-GL |
Yes |
No |
MSR830-10HI-GL |
Yes |
No |
MSR1004S-5G-GL |
Yes |
Yes |
MSR2600-6-X1-GL |
No |
No |
MSR3600-28-SI-GL |
No |
No |
The devices do not support the random sampling mode and supports only the fixed sampling mode.
Layer 2 Ethernet interfaces support counter sampling and do not support flow sampling.
Layer 3 Ethernet interfaces switched from Layer 2 Ethernet interfaces support counter sampling. For whether they support flow sampling, see the following table.
Layer 3 Ethernet interfaces on Layer 3 Ethernet interface cards support counter sampling and flow sampling.
display sflow
Use display sflow to display sFlow configuration and operation information.
display sflow
# Display sFlow configuration and operation information.
<Sysname> display sflow
sFlow datagram version: 5
Global information:
Agent IP: 10.10.10.1(CLI)
Source address: 10.0.0.1 2001::1
Collector information:
ID IP Port Aging Size VPN-instance Description
1 22:2:20::10 6535 N/A 1400 netserver
2 192.168.3.5 6543 500 1400 Office
Port information:
Interface CID Interval(s) FID MaxHLen Rate Mode Status
GE1/0/1 1 100 1 128 1000 Determine Active
GE1/0/2 2 100 2 128 1000 Determine Active
sFlow datagram version |
sFlow version, which can only take the value of 5. The device can send only sFlow packets whose sFlow version is 5. |
Global information |
Global sFlow information. |
Agent IP |
IP address of the sFlow agent: · CLI—Manually configured IP address. · Auto—Automatically configured IP address. |
Source address |
Source IP address of sFlow packets. |
Collector information |
sFlow collector information. |
ID |
sFlow collector ID. |
IP |
sFlow collector IP address. |
Port |
sFlow collector port. |
Aging |
Remaining lifetime of the sFlow collector. If this field displays N/A, the sFlow collector never ages out. |
Size |
Maximum length of the sFlow data portion in an sFlow packet. |
VPN-instance |
Name of the VPN instance to which the sFlow collector belongs. |
Description of the sFlow collector. |
Port information |
Information about interfaces configured with sFlow. |
Interface configured with sFlow. |
CID |
ID of the sFlow collector for receiving counter sampled packets. If no sFlow collector ID is specified, this field displays 0. |
Interval(s) |
Counter sampling interval, in seconds. |
FID |
ID of the sFlow collector for receiving flow sampled packets. If no sFlow collector ID is specified, this field displays 0. |
MaxHLen |
Maximum number of bytes that can be copied in a sampled packet (starting from the packet header). |
Rate |
Number of packets out of which the interface samples a packet by using flow sampling. |
Mode |
Flow sampling mode. The Determine value means sampling a fixed number of packets. |
Status |
sFlow status of the port: · Suspended—The sFlow feature is suspended because the port is down. · Active—The sFlow feature is active because the port is up. |
sflow agent
Use sflow agent to configure an IP address for the sFlow agent.
Use undo sflow agent to restore the default.
sflow agent { ip ipv4-address | ipv6 ipv6-address }
undo sflow agent { ip | ipv6 }
No IP address is configured for the sFlow agent. The device periodically identifies whether the sFlow agent has an IP address. If the sFlow agent does not have an IP address, the device automatically selects an IPv4 address for the sFlow agent. It does not save the IPv4 address in the configuration file.
ip ipv4-address: Specifies an IPv4 address for the sFlow agent.
ipv6 ipv6-address: Specifies an IPv6 address for the sFlow agent.
As a best practice, manually configure an IP address for the sFlow agent.
# Specify IP address 10.10.10.1 for the sFlow agent.
[Sysname] sflow agent ip 10.10.10.1
sflow collector
Use sflow collector to configure parameters for an sFlow collector.
Use undo sflow collector to remove an sFlow collector.
sflow collector collector-id [ vpn-instance vpn-instance-name ] { ip ipv4-address | ipv6 ipv6-address } [ port port-number | datagram-size size | time-out seconds | description string ] *
undo sflow collector collector-id
No sFlow collector information is configured.
collector-id: Specifies an sFlow collector by its ID. The value range for this argument is 1 to 10.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the sFlow collector belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The VPN instance name cannot contain spaces. By default, the sFlow collector belongs to the public network.
ip ipv4-address: Specifies an IPv4 address for the sFlow collector.
ipv6 ipv6-address: Specifies an IPv6 address for the sFlow collector.
port port-number: Specifies the UDP port number of the sFlow collector, in the range of 1 to 65535. The default is 6343.
datagram-size size: Specifies the maximum length of the sFlow data portion in an sFlow packet. The value range for the size argument is 200 to 3000 bytes, and the default value is 1400 bytes.
time-out seconds: Specifies the aging timer of the sFlow collector, in the range of 1 to 2147483647 seconds. When the aging timer expires, the sFlow collector settings are deleted. The sFlow collector settings do not age out by default.
description string: Specifies a description, a case-sensitive string of 1 to 127 characters. The default description is "CLI Collector."
# Configure the following parameters for sFlow collector 2:
· IP address—3.3.3.1.
· Port number—Default.
· Description—netserver.
· Aging timer—1200 seconds.
· Maximum length of the sFlow data portion in the sFlow packet—1000 bytes.
[Sysname] sflow collector 2 ip 3.3.3.1 description netserver time-out 1200 datagram-size 1000
sflow counter collector
Use sflow counter collector to specify an sFlow collector for counter sampling.
Use undo sflow counter collector to restore the default.
sflow counter collector collector-id
No sFlow collector is specified for counter sampling.
# Specify sFlow collector 2 on GigabitEthernet 1/0/1 for counter sampling.
[Sysname-GigabitEthernet1/0/1] sflow counter collector 2
sflow counter interval
Use sflow counter interval to enable counter sampling and set a counter sampling interval.
Use undo sflow counter interval to disable counter sampling.
sflow counter interval interval
Counter sampling is disabled.
interval: Specifies the counter sampling interval in the range of 2 to 86400 seconds.
# Enable counter sampling and set the counter sampling interval to 120 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] sflow counter interval 120
sflow flow collector
Use sflow flow collector to specify an sFlow collector for flow sampling.
Use undo sflow flow collector to restore the default.
sflow flow collector collector-id
No sFlow collector is specified for flow sampling.
# Specify sFlow collector 2 on GigabitEthernet 1/0/1 for flow sampling.
[Sysname-GigabitEthernet1/0/1] sflow flow collector 2
sflow flow max-header
Use sflow flow max-header to set the maximum number of bytes (starting from the packet header) that flow sampling can copy per packet.
Use undo sflow flow max-header to restore the default.
sflow flow max-header length
Flow sampling can copy up to 128 bytes of a packet.
length: Specifies the maximum number of bytes that can be copied, in the range of 18 to 512. As a best practice, use the default value.
# Set the maximum number of bytes to 60 for flow sampling to copy per packet on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] sflow flow max-header 60
sflow sampling-mode determine
Use sflow sampling-mode determine to specify a flow sampling mode.
Use undo sflow sampling-mode to restore the default.
The fixed sampling rate is determined by using the sflow sampling-rate rate command. For example, if the flow sampling interval is set to 4000 (by using the sflow sampling-rate command), the device samples packets as follows:
· The device randomly samples a packet, like the tenth packet, from the first 4000 packets.
· The next time the device samples the 4010th packet, and so on.
# Specify fixed flow sampling mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] sflow sampling-mode determine
sflow sampling-rate
sflow sampling-rate
Use sflow sampling-rate to enable flow sampling and specify the number of packets out of which flow sampling will sample a packet.
Use undo sflow sampling-rate to disable flow sampling.
Flow sampling is disabled.
rate: Specifies the number of packets out of which flow sampling will sample a packet on the interface. The value range for this argument is 1000 to 5000.
# Enable flow sampling to sample a packet out of 1024 packets on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] sflow sampling-rate 1024
sflow sampling-mode
sflow source
Use sflow source to specify the source IP address of sent sFlow packets.
Use undo sflow source to restore the default.
sflow source { ip ipv4-address | ipv6 ipv6-address } *
undo sflow source { ip | ipv6 } *
The source IP address of sent sFlow packets is determined by routing.
ip ipv4-address: Specifies the source IPv4 address of sent sFlow packets.
ipv6 ipv6-address: Specifies the source IPv6 address of sent sFlow packets.
# Specify the source IPv4 address of sent sFlow packets as 10.0.0.1.
[Sysname] sflow source ip 10.0.0.1
