- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-iFIT commands
- 05-iPerf commands
- 06-NTP commands
- 07-PoE commands
- 08-SNMP commands
- 09-RMON commands
- 10-Event MIB commands
- 11-NETCONF commands
- 12-CWMP commands
- 13-SmartMC commands (self-mesh not supported)
- 14-Quicknet commands
- 15-EAA commands
- 16-Process monitoring and maintenance commands
- 17-Sampler commands
- 18-Mirroring commands
- 19-NetStream commands
- 20-IPv6 NetStream commands
- 21-sFlow commands
- 22-Performance management commands
- 23-Fast log output commands
- 24-Flow log commands
- 25-Information center commands
- 26-Cloud connection commands
- 27-GOLD commands
- 28-Packet capture commands
- 29-SQA commands
- 30-eMDI commands
| 14-Quicknet commands | 89.17 KB |
Quicknet commands
This feature is supported only on the following models and the device roles supported by the models vary:
· Models that support both the TM and TC roles: MSR610 and MSR830-10HI-GL
· Models that support only the TC role: MSR830-6EI-WiNet, MSR830-10BHI-WiNet, MSR3620-X1-WiNet, MSR860-6HI-XS, MSR3620-X1-XS, MSR2600-15-X1-XS, MSR3610-XS, MSR3620-XS, and MSR3640-XS
display quicknet configuration
Use display quicknet configuration to display the Quicknet configuration.
Both the TM and TC devices support this command.
# Display the Quicknet configuration on the TM.
<Sysname> display quicknet configuration
Device role : TM(auto)
FTP server IP : N/A
FTP server username : N/A
Topology-refresh interval : 60(s)
Backup startup-configuration interval : N/A
Sync backup number : 5
Device status : Normal
# Display TM information on a TC.
Device role : TC(auto)
TM IP : 192.168.22.103
TM MAC : 8288-468d-0100
TM sysname : Sysname
Device role |
Current device role. Options include: · TM—The role is manually specified by using a command. · TC—TC role manually specified by using a command. · TM(auto)—The role is determined through election. · TC(auto)—The role is determined through election. |
FTP server IP |
IP address of the FTP server. If no address is configured, this field displays N/A. |
FTP server username |
FTP server username. If no username is configured, this field displays N/A. |
Topology-refresh interval |
Topology refresh interval, in seconds. |
Backup startup-configuration interval |
Interval for automatic configuration file backup, in hours. If no interval is set, this field displays N/A. |
Sync backup number |
Number of TCs that can perform configuration backup at the same time. |
Device status |
TM status. Options include: · Normal. · Lack—Lack of configuration required by Quicknet, such as NETCONF, Telnet, local user, and LLDP. |
TM IP |
IP address of the TM. If the TC failed to obtain the TM IP address, this field displays N/A. |
TM MAC |
MAC address of the TM. If the TC failed to obtain the TM MAC address, this field displays N/A. |
TM sysname |
Name of the TM. If the TC failed to obtain the TM name, this field displays N/A. |
display quicknet tc
Use display quicknet tc to display TC information.
display quicknet tc [ tc-id ] [ verbose ]
tc-id: Specifies the TC ID, in the range of 1 to 255. If you do not specify this argument, the command displays information about all TCs.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
This command is supported only on the TM, and cannot be executed on TCs.
# Display the brief information about all TCs on the TM.
<Sysname> display quicknet tc
TCID DeviceType Sysname IpAddress MacAddress Status Version
1 MSR3600 S1 192.168.22.104 201c-e7c3-0300 Normal COMWAREV700R001
TCID |
TC ID. |
DeviceType |
Device type of the TC. |
Sysname |
TC name. |
IpAddress |
IP address of the TC. |
MacAddress |
MAC address of the TC. |
Status |
Operating status of the TC. Options include: · Normal—The device is operating correctly. · Offline—The device is offline. |
Version |
Software version of the TC. |
# Display detailed information about all TCs.
<Sysname> display quicknet tc verbose
TC ID : 1
Adding method : Manual
Sysname : S1
Model : MSR3620-WiNet
Device type : MSR3600
SYSOID : 1.3.6.1.4.1.25506
MAC address : 0e74-e2fb-0400
IP address : 192.168.56.103
Boot image :
Boot image version :
System image :
System image version :
Current-configuration file :
Uptime : 2 days, 3 hours, 4 minutes
System CPU usage : 0%
System memory usage : 0%
Status : Offline
Boot-loader file :
Startup-configuration file :
TC ID |
TC ID. |
Adding method |
Method through which the TC joined the Quicknet network. Options include: · Manual. · Auto. |
Device role |
Method through which the device obtained the TC role. · TC—TC role manually specified by using a command. · TC(auto)—The role is determined through election. |
Sysname |
TC name. |
Model |
Device model of the TC. |
Device type |
SYSOID |
OID of the TC MIB node, which represents the device manufacturer. |
MAC address |
IP address |
Boot image |
Name of the boot startup software package on the TC. |
Boot image version |
Version of the boot startup software package on the TC. |
System image |
Name of the system startup software package on the TC. |
System image version |
Version of the system startup software package on the TC. |
Current-configuration file |
Configuration file used by the TC currently. |
Uptime |
Uptime of the TC. |
System CPU usage |
CPU usage of the TC. |
System memory usage |
Memory usage of the TC. |
Status |
Boot-loader file |
Software package used by the TC for update. |
Startup-configuration file |
Configuration file used by the TC for update. |
quicknet enable
Use quicknet enable to enable Quicknet and use auto election to determine the device role.
Use undo quicknet enable to disable Quicknet and restore the default settings of Quicknet.
quicknet enable
If the device starts up with the initial configuration, Quicknet is disabled. If the device starts up with the factory defaults, the initial state of Quicknet depends on the factory defaults. To view the factory defaults, use the display default-configuration command in any view. For more information about the initial configuration and the factory defaults, see configuration file management in Fundamentals Configuration Guide.
Application scenarios
Quicknet is primarily used for centralized management and maintenance of a large number of dispersed network devices at the network edge. With Quicknet enabled, the device can establish a Quicknet network with other devices and achieve unified management through the Quicknet management system.
Operating mechanism
In a Quicknet network, the following device roles are available:
· Topology master (TM)—Manages all devices in the Quicknet network.
· Topology client (TC)—Managed by the TM in the Quicknet network.
Quicknet networks can include various models of network method for determining device roles varies by product positioning. This command configures the device to use the auto election mechanism to determine the device role (TC or TM) in a Quicknet network. Devices of different types come with different priorities in role election. The device with a high priority has a high probability to be elected as the TM.
One Quicknet network can have only one TM.
If you switch the device role from TM to TC or disable Quicknet, the system clears all the running configuration related to Quicknet on the device.
Quicknet requires specific ACL resources. If ACL resources are insufficient, Quicknet might fail to be enabled. You can use the display acl command to view the ACL configuration and operation status and use the undo acl command to delete useless ACLs based on the actual conditions. After releasing ACL resources, you can try again to enable Quicknet. For more information about ACL, see ACL and QoS Configuration Guide.
When you enable Quicknet, the device checks whether port 80 and port 443 are occupied, as HTTP and HTTPS services require these ports. If port 80 or port 443 is occupied, Quicknet cannot be enabled.
# Enable Quicknet.
[Sysname] quicknet enable
quicknet tc enable
quicknet password
Use quicknet password to set the network-wide Quicknet password.
Use undo quicknet password to restore the default.
quicknet password [ cipher ] string
The network-wide Quicknet password is not configured, but the device comes with a preset credential: default username admin and a default password. For APs, the default password is h3capadmin. For other devices, the default password is admin.
cipher: Specifies a password in ciphertext format. If you do not specify this keyword, the command sets the password in plaintext format but saves the password in encrypted format.
string: Specifies the password string, a case-sensitive string of 1 to 63 characters in plaintext format or 1 to 117 characters in ciphertext format.
To manage and maintain the Quicknet network, the TM establishes a NETCONF channel with each TC by using the local username (admin) and the default password. To increase device security, you can perform this task to change the password used for NETCONF channel establishment.
Operating mechanism
After you configure the network-wide Quicknet password on TM, the TM deploys the configuration to all TCs, and the password will take effect on all TCs. The TM and TCs will use this password to rebuild the NETCONF channels.
Recommended configuration
As a best practice for security purposes, change the network-wide password on the TM once the Quicknet network is established.
Both the TM and TC devices support the command.
· After you execute this command on the TM, the TM immediately synchronizes the configuration to all TCs. The local stored network password will also be synchronized to all TCs according to a set interval.
· Executing this command on a TC only modifies the NETCONF channel authentication password for that TC. For a TC, the most recent configuration takes effect, whether it is locally configured or synchronized from the TM.
# Change the network-wide Quicknet password to hello123.
[Sysname] quicknet password hello123
quicknet tc enable
Use quicknet tc enable to enable Quicknet and specify the device role as TC.
quicknet tc enable
Operating mechanism
Quicknet networks can include various models of network method for determining device roles varies by product positioning. You can use this command to manually specify the device role as TC.
# Enable Quicknet and specify the device role as TC.
[Sysname] quicknet tc enable
quicknet enable
