29-WLAN Configuration Guide(Fat AP)
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR610[810][830][1000S][2600][3600] Routers Configuration Guides(V7)-R6749-6W10329-WLAN Configuration Guide(Fat AP)
10-WLAN mesh configuration
10-WLAN mesh configuration 230.52 KB
Configuring WLAN mesh
About WLAN mesh
WLAN mesh allows APs to be wirelessly connected. The APs on a WLAN mesh network can be connected directly or over multiple hops. When one AP fails, the remaining APs can still communicate with each other.
Benefits
WLAN mesh provides the following benefits:
·     Low cost, high performance, and easy deployment.
·     High expansibility without wires.
·     Same good user experience as traditional WLANs.
WLAN mesh network
Figure 1 shows a WLAN mesh network.
APs on a WLAN mesh network are mesh points (MPs). MPs play the following roles:
·     Single-purpose MP—Provides only mesh services.
·     Mesh access point (MAP)—Provides both mesh and access services.
·     Mesh portal point (MPP)—Provides a wired connection to a wired network.
Figure 1 WLAN mesh network diagram
Mesh profile
A mesh profile is a set of mesh protocol processing capabilities for an AP to operate on a mesh network. A mesh profile contains the following attributes:
·     Mesh ID—Identifies a mesh network.
·     Mesh security—Contains settings for neighbor authentication, including an authentication and key management mode, and a preshared key.
·     Keepalive interval—Specifies the interval for sending keepalive packets over a mesh link. The MP with a higher MAC address sends keepalive packets at the keepalive interval to the peer end. The sending MP disconnects the mesh link if it has not received a reply before three consecutive keepalive intervals expire. The receiving MP disconnects the mesh link if it has not received keepalive packets before three consecutive keepalive intervals expire. For correct link status detection, the keepalive interval at the sending end must be equal to or less than three times the keepalive interval at the receiving end.
To form a mesh network, APs must have the same mesh ID and mesh security settings.
Neighbor discovery and mesh link establishment
MPs must operate at the same radio mode and on the same channel to discover each other. MPs can establish a mesh link after they discover each other and establish a peer relationship.
The following are the available discovery methods:
·     Active scanning—The MP sends Probe Request frames to discover neighbors and establish peer relationships.
·     Passive scanning—The MP listens to Beacon frames to collect information about other MPs. If there are neighbors, the AP sends Probe Request frames to request establishing a peer relationship.
This section uses active scanning to describe the neighbor discovery and mesh link establishment process.
As shown in Figure 2, MPs attempt to establish peer relationships by exchanging their mesh profiles in Probe Request and Probe Response frames.
One MP adds another MP as a mesh peer if the following conditions are met:
·     The MPs' mesh profiles match.
·     The Accepting Peer Links bit in the received request or response is set.
The MP peers attempt to establish a mesh link by sending a Link Open request to each other. The mesh link is established after the MP peers acknowledge the Link Open request received from each other.
Figure 2 Neighbor discovery and mesh link establishment on a WLAN mesh network
Two fat APs enabled with auto channel selection cannot establish a mesh link with each other. For more information about auto channel selection, see "Configuring radio management."
Wireless distribution system
Wireless distribution systems (WDSs) are applications of WLAN mesh. A WDS uses the mesh links between APs to connect dispersed LANs. The APs transfer the 802.3 frames that come from the LANs in the form of 802.11s frames over the mesh links.
You can create a WDS in point-to-point or star topology by administratively making sure mesh links are established between selected APs. Alternatively, you can use the topology that is created automatically by APs through automatic neighbor discovery and mesh link establishment without administrative intervention.
Point-to-point topology
As shown in Figure 3, you can set up a mesh link between two APs to connect two LANs.
Figure 3 WDS point to point topology
Star topology
As shown in Figure 4, you can set up mesh links between one central AP and multiple leaf APs to connect multiple LANs. In this topology, all data between LANs must traverse the central AP (AP 4 in this example).
Figure 4 Star topology
Topology created without administrative intervention
Without administrative intervention, the WDS topology depends on the result of automatic neighbor discovery and mesh link establishment between APs.
Figure 5 Automatic topology setup
Mesh peer blacklist or whitelist
You can configure the blacklist or whitelist to control whether an MP neighbor can establish a mesh link with the local MP.
If you configure both the blacklist and whitelist, only the whitelist takes effect and only MP neighbors in the whitelist can establish a mesh link with the local MP. If only the blacklist is configured, MP neighbors in the blacklist cannot establish a mesh link with the local MP.
Restrictions: Hardware compatibility with WLAN mesh
Only the MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-W-5G-CN, and MSR1104S-W-5GGL support this feature.
Protocols and standards
·     Draft P802.11s_D1.06
·     ANSI/IEEE Std 802.11, 1999 Edition
·     IEEE Std 802.11a
·     IEEE Std 802.11b
·     IEEE Std 802.11g
·     IEEE Std 802.11i
·     IEEE Std 802.11s
·     IEEE Std 802.11-2004
·     draft-ohara-capwap-lwapp-03
WLAN mesh tasks at a glance
To configure WLAN mesh, perform the following tasks:
1.     Configuring a mesh profile
2.     Binding a mesh profile to a radio interface
3.     (Optional.) Configuring a mesh policy
4.     (Optional.) Binding a mesh policy to a radio interface
5.     (Optional.) Configuring the mesh peer blacklist or whitelist
6.     (Optional.) Configuring mesh interfaces
7.     (Optional.) Enabling Comware 7 APs to establish mesh connections with Comware 5 APs
MPs on the same mesh network must use the same mesh ID and mesh security settings.
2.     Create a mesh profile and enter mesh profile view.
wlan mesh-profile mesh-profile-number
3.     Specify a mesh ID.
mesh-id mesh-id
4.     (Optional.) Configure mesh security.
¡     Configure a preshared key.
preshared-key { pass-phrase | raw-key } { cipher | simple } string
By default, no preshared key is configured.
¡     Enable SAE authentication and key management mode.
akm mode sae
By default, no authentication and key management mode is configured.
5.     (Optional.) Set the mesh link keepalive interval.
link-keepalive keepalive-interval
The default mesh link keepalive interval is 2 seconds.
6.     Enable the mesh profile.
mesh-profile enable
By default, a mesh profile is disabled.
For the AP to join a mesh network, you must bind a mesh profile to a radio interface on the AP. You can bind different mesh profiles to the radio interfaces on an AP for it to join different mesh networks.
2.     Enter radio interface view.
interface wlan-radio interface-number
3.     Bind a mesh profile to the radio interface.
By default, no mesh profile is bound to a radio interface.
A mesh policy contains a set of mesh link setup and maintenance attributes.
2.     Create a mesh policy and enter mesh policy view.
wlan mesh-policy policy-name
By default, a system-defined mesh policy exists. The policy name is default_mesh_policy.
3.     Enable link initiation.
link-initiation enable
By default, link initiation is enabled.
4.     (Optional.) Set the maximum number of mesh links.
link-maximum-number max-link-number
By default, the maximum number is 2.
5.     (Optional.) Set the probe request interval.
probe-request-interval interval-value
By default, the probe request interval is 1000 ms. As a best practice, set the value to a multiple of 100.
6.     (Optional.) Set the mesh link hold RSSI, the minimum signal strength for a mesh link to be retained.
link-hold-rssi value
By default, the mesh link hold RSSI is 15 dBm.
By default, a system-defined mesh policy is bound to each radio interface. This system-defined mesh policy cannot be deleted or modified. To change the link setup and maintenance settings on a radio interface, you can bind a user-defined mesh policy to the radio interface to replace the system-defined mesh policy.
3.     Bind a mesh policy to the radio interface.
mesh-policy name policy-name
By default, the system-defined mesh policy default_mesh_policy is bound to a radio interface.
3.     Add the MAC address of an MP to the mesh peer blacklist or whitelist.
mesh peer-mac-address [ blacklist ] mac-address
By default, no mesh peer blacklist or whitelist exists.
Tasks at a glance
To configure mesh interfaces, perform the following tasks:
1.     Creating a mesh interface
2.     Binding a mesh interface to a radio
Create mesh interfaces to allow mesh networks in the same VLAN to communicate with each other.
2.     Create a mesh interface and enter its view.
interface wlan-mesh interface-number
Mesh interfaces created in AP view can be bound to a radio only in radio view. Mesh interfaces created in AP group view can be bound to a radio in both radio view and AP group radio view.
You can bind only one mesh interface to a radio.
3.     Bind a mesh interface to the radio interface.
mesh-interface interface-number
By default, no mesh interface is bound to a radio interface.
In a scenario where both Comware 7 and Comware 5 APs are deployed, enable this feature for all Comware 7 APs that require mesh connections.
2.     Enter mesh policy view.
By default, a default mesh policy named default_mesh_policy exists.
3.     Enable Comware 7 APs to establish mesh connections with Comware 5 APs.
comware5-compatibility enable
By default, Comware 7 APs cannot establish mesh connections with Comware 5 APs.
Display and maintenance commands for WLAN mesh
Display mesh link information.
display wlan mesh-link [ mesh-profile mesh-profile-number | interface interface-type interface-number | peer-mac-address mac-address ]
Display mesh policy information.
display wlan mesh-policy [ mesh-policy-name ]
Display mesh profile information.
display wlan mesh-profile [ mesh-profile-number ]
WLAN mesh configuration examples
Example: Configuring WLAN mesh
As shown in Figure 6, establish an 802.11n 5GHz WLAN mesh network to provide network access for the clients. Configure the MP and MAPs to establish mesh links on channel 149.
Figure 6 Network diagram
1.     Configure the MPP:
# Create a mesh profile.
<MPP> system-view
[MPP] wlan mesh-profile 1
# Set the mesh ID to 1.
[MPP-wlan-mesh-profile-1] mesh-id 1
# Enable SAE for authentication and key management.
[MPP-wlan-mesh-profile-1] akm mode sae
# Configure a preshared key.
[MPP-wlan-mesh-profile-1] preshared-key pass-phrase simple 12345678
# Enable the mesh profile.
[MPP-wlan-mesh-profile-1] mesh-profile enable
[MPP-wlan-mesh-profile-1] quit
# Bind the mesh profile to the radio interface WLAN-Radio 0/0.
[MPP] interface wlan-radio 0/0
[MPP-WLAN-Radio0/0] mesh-profile 1
# Set the radio type to 802.11n (5GHz) on the interface.
[MPP-WLAN-Radio0/0] type dot11an
# Set the working channel of the radio to 149.
[MPP-WLAN-Radio0/0] channel 149
# Enable the radio.
[MPP-WLAN-Radio0/0] undo shutdown
[MPP-WLAN-Radio0/0] quit
2.     Configure MAP 1:
<MAP1> system-view
[MAP1] wlan mesh-profile 1
[MAP1-wlan-mesh-profile-1] mesh-id 1
[MAP1-wlan-mesh-profile-1] akm mode sae
# Configure the same preshared key as the MPP.
[MAP1-wlan-mesh-profile-1] preshared-key pass-phrase simple 12345678
[MAP1-wlan-mesh-profile-1] mesh-profile enable
[MAP 1-wlan-mesh-profile-1] quit
# Configure a service template.
[MAP1] wlan service-template service1
[MAP1-wlan-st-service1] ssid mesh-network
[MAP1-wlan-st-service1] service-template enable
[MAP1-wlan-st-service1] quit
[MAP1] interface wlan-radio 0/0
[MAP1-WLAN-Radio0/0] mesh-profile 1
# Bind the service template to the radio interface WLAN-Radio 0/0.
[MAP1-WLAN-Radio0/0] service-template service1
[MAP1-WLAN-Radio0/0] type dot11an
[MAP1-WLAN-Radio0/0] channel 149
# Add the MAC address of a radio on the MPP to the mesh peer whitelist to avoid loops. MAP 1 can set up a mesh link only with the MPP.
[MAP1-WLAN-Radio0/0] mesh peer-mac-address 4a1b-517d-23ff
# Enable the radio.
[MAP1-WLAN-Radio0/0] undo shutdown
[MAP1-WLAN-Radio0/0] quit
[MAP1] quit
3.     Configure MAP 2 in the same way you configure MAP 1. (Details not shown.)
# Verify that the MPP can establish mesh links to the MAPs.
<MPP> display wlan mesh-link
 Peer MAC       RSSI BSSID          Interface        Link state    Online time
 7b2d-23bb-e56f 22   4a1b-517d-23ff WLAN-MeshLink1   Active(an)    00h 08m 31s
 6a3b-cc5a-e215 22   4a1b-517d-23ff WLAN-MeshLink2   Active(an)    00h 40m 56s
# Verify that MAP 1 can establish a mesh link to the MPP.
<MAP1> display wlan mesh-link
 4a1b-517d-23ff 22   7b2d-23bb-e56f WLAN-MeshLink1   Active(an)    00h 08m 31s
# Verify that MAP 2 can establish a mesh link to the MPP.
<MAP2> display wlan mesh-link
 4a1b-517d-23ff 22   6a3b-cc5a-e215 WLAN-MeshLink1   Active(an)    00h 08m 31s
Example: Configuring point-to-point WDS
As shown in Figure 7, deploy a point-to-point WDS of two fat APs to provide Layer 2 wireless connectivity between two LANs. Configure the APs to use 802.11a to establish a WDS link on channel 149.
Figure 7 Network diagram
1.     Configure AP 1:
<AP1> system-view
[AP1] wlan mesh-profile 1
[AP1-wlan-mesh-profile-1] mesh-id 1
[AP1-wlan-mesh-profile-1] akm mode sae
[AP1-wlan-mesh-profile-1] preshared-key pass-phrase simple 12345678
[AP1-wlan-mesh-profile-1] mesh-profile enable
[AP 1-wlan-mesh-profile-1] quit
[AP1] interface wlan-radio 0/0
[AP1-WLAN-Radio0/0] mesh-profile 1
# Set the radio type to 802.11a on the interface.
[AP1-WLAN-Radio0/0] type dot11a
[AP1-WLAN-Radio0/0] channel 149
# Enable the radio.
[AP1-WLAN-Radio0/0] undo shutdown
[AP1-WLAN-Radio0/0] quit
[AP1] quit
2.     Configure AP 2 in the same way you configure AP 1. (Details not shown.)
# Display mesh link information on AP 1.
<AP1> display wlan mesh-link
 482b-c01d-e87f 22   a503-cc9b-418f WLAN-MeshLink1   Active(a)     00:01:10
# Display mesh link information on AP 2.
<AP2> display wlan mesh-link
 a503-cc9b-418f 22   482b-c01d-e87f WLAN-MeshLink1   Active(a)     00:01:10
