29-WLAN Configuration Guide(Fat AP)
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR610[810][830][1000S][2600][3600] Routers Configuration Guides(V7)-R6749-6W10329-WLAN Configuration Guide(Fat AP)
07-WLAN load balancing configuration
07-WLAN load balancing configuration 242.11 KB
Configuring WLAN load balancing
About WLAN load balancing
WLAN load balancing dynamically loads balance clients across radios to ensure wireless service quality and adequate bandwidth for clients in high-density WLANs.
The term "AP" in this document refers to MSR routers that offer WLAN services as fat APs. For more information, see "Compatibility of hardware and AP functionality."
Networking scheme
Load balancing can be performed only among radios that can be detected by the same client. As shown in Figure 1, Radio 1 and Radio 2 of the AP are enabled. Client 1, Client 2, and Client 3 are associated with radio 1, and Client 4 is associated with Radio 2. Load balancing is enabled on the AP. Radio 1 has reached its maximum load. When Client 5 tries to associate with Radio 1, the AP rejects the association request and directs Client 5 to Radio 2.
Figure 1 Network diagram
Work mechanism
The device performs load balancing when the following conditions are met:
·     The load of a radio reaches the threshold.
·     The load gap between the radio and the radio that has the lightest load reaches the load gap threshold.
When the load and load gap for the radio reach their respective threshold, the radio rejects the association request of a client. If the number of times that the radio rejects the client reaches the specified maximum number of denials for association requests, the radio accepts the client's association request.
Load balancing modes
The device supports session-mode load balancing. It performs session-mode load balancing when the following conditions are met:
·     The specified session threshold is reached.
·     The specified session gap threshold is reached.
As shown in Figure 2, Radio 1 and Radio 2 are enabled on the AP. Client 1 associates with Radio 1, and Client 2 through Client 4 associate with Radio 2. The session threshold and session gap threshold are set to 3 and 2, respectively. When Client 5 tries to associate with Radio 2, Radio 2 rejects the request because both the session threshold and session gap threshold are reached.
Figure 2 Session-mode load balancing
Load balancing types
The device supports the following load balancing types:
·     Radio based—The device determines the radios that will participate in load balancing based on the collected neighbor reports. The neighbor report of a radio records the MAC address and RSSI value of each client that is detected by the radio. The device determines that a radio will participate in load balancing when either of the following conditions is met:
¡     A client requests to associate with the radio.
¡     The radio detects that a client's RSSI has reached the RSSI threshold but the client does not request to associate with the radio.
·     Load balancing group based—You add the radios to a load balancing group. The device performs load balancing only on radios in this load balancing group.
Restrictions: Hardware compatibility with WLAN load balancing
For information about MSR routers that can offer WLAN services as fat APs, see "Compatibility of hardware and AP functionality."
Restrictions and guidelines: WLAN load balancing configuration
When a client requests to access the WLAN, the system performs load balancing only among radios that belong to the same AP and can be detected by the client.
WLAN load balancing tasks at a glance
To configure WLAN load balancing, perform the following tasks:
·     Enabling WLAN load balancing
·     Configuring session-mode load balancing
·     (Optional.) Configuring a load balancing group
Configure this feature to enable the fat AP to perform load balancing based on a load balancing group instead of radios.
·     (Optional.) Configuring load balancing parameters
·     (Optional.) Enabling SNMP notifications for WLAN load balancing
Prerequisites for WLAN load balancing
Before you configure load balancing, make sure the quick association function is disabled. For more information about quick association, see "Enabling quick association."
2.     Enable WLAN load balancing.
wlan load-balance enable
By default, WLAN load balancing is disabled.
2.     Configure session-mode load balancing.
wlan load-balance mode session value [ gap gap-value ]
By default, the session threshold is 20 and the session gap is 4 for session-mode load balancing.
2.     Create a load balancing group and enter its view.
wlan load-balance group group-id
3.     Add a radio to the load balancing group.
radio radio-id
4.     (Optional.) Set a description for the load balancing group.
By default, no description is set for the load balancing group.
The following parameters affect load balancing calculation:
·     Load balancing RSSI threshold—If a radio detects that the RSSI of a client is lower than the specified RSSI threshold, the radio performs either of the following operations:
¡     If multiple radios can detect the client, the radio participates in load balancing only when the client requests to associate with the radio.
¡     If only this radio can detect the client, the radio decreases the maximum number of denials to one so that the client has more chances to associate with the radio.
·     Maximum number of denials for association requests—If the number of times that a radio rejects a client reaches the specified maximum number of denials for association requests, the radio accepts the association request of the client.
2.     Set the RSSI threshold.
wlan load-balance rssi-threshold rssi-threshold
By default, the RSSI threshold is 25.
3.     Set the maximum number of denials for association requests.
wlan load-balance access-denial access-denial
By default, the maximum number of denials is 10 for association requests.
To report critical WLAN load balancing events to an NMS, enable SNMP notifications for WLAN load balancing. For WLAN load balancing event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for WLAN load balancing.
snmp-agent trap enable wlan load-balance
By default, SNMP notifications for WLAN load balancing are disabled.
Display and maintenance commands for WLAN load balancing
Display load balancing group information.
display wlan load-balance group { group-id | all }
Display load balancing information for radios that are bound to a service template.
display wlan load-balance status service-template template-name { client mac-address | group group-id }
Radio-based WLAN load balancing configuration examples
Example: Configuring session-mode load balancing
As shown in Figure 3, radio 1 and radio 2 are enabled on the AP and the clients can discover the radios. Client 1 associates with radio 1, and Client 2 through Client 4 associate with radio 2.
Configure the AP to perform session-mode load balancing on radio 1 and radio 2 when the following conditions are met:
·     The number of sessions on one radio reaches 3.
·     The session gap between the radios reaches 2.
Figure 3 Network diagram
# Create wireless service template 1, and set its SSID to session-balance.
<AP> system-view
[AP] wlan service-template 1
[AP-wlan-st-1] ssid session-balance
[AP-wlan-st-1] service-template enable
[AP-wlan-st-1] quit
# Bind wireless service template 1 to radio interface WLAN-Radio 0/0.
[AP] interface wlan-radio 0/0
[AP-WLAN-Radio0/0] undo shutdown
[AP-WLAN-Radio0/0] service-template 1
[AP-WLAN-Radio0/0] quit
# Bind wireless service template 1 to radio interface WLAN-Radio 0/1.
[AP] interface wlan-radio 0/1
[AP-WLAN-Radio0/1] undo shutdown
[AP-WLAN-Radio0/1] service-template 1
[AP-WLAN-Radio0/1] quit
# Set the load balancing mode to session mode, and set the session threshold and session gap threshold to 3 and 2, respectively.
[AP] wlan load-balance mode session 3 gap 2
# Enable WLAN load balancing.
[AP] wlan load-balance enable
# Verify that the AP performs session-mode load balancing for radio 1 and radio 2 when the following conditions are met:
·     The number of sessions on radio 2 reaches 3.
·     The session gap between the radios reaches 2. (Details not shown.)
# Verify that radio 1 and radio 2 are load balanced by using the display wlan client command. (Details not shown.)
Load balancing group-based WLAN load balancing configuration examples
As shown in Figure 4, radio 1 and radio 2 are enabled on the AP and the clients can discover the radios.
Figure 4 Network diagram
<AP> system-view
[AP-wlan-st-1] quit
# Create load balancing group 1.
[AP] wlan load-balance group 1
# Add radio 1 and radio 2 to load balancing group 1.
[AP-wlan-lb-group-1] radio 1
[AP-wlan-lb-group-1] radio 2
·     The number of sessions on either radio reaches 3.
