07-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR610[810][830][1000S][2600][3600] Routers Configuration Guides(V7)-R6749-6W10307-Layer 3—IP Services Configuration Guide
22-Lighttpd service configuration
22-Lighttpd service configuration 62.27 KB
Configuring lighttpd Web services
About lighttpd Web services
The device can act as a lighttpd Web server to support lightweight Web access to resources saved on the device. Supported resources include PHP dynamic webpages, pictures, flash files, video files, and advertisements. To access the resources on the lighttpd Web server, users only need to launch a Web browser and enter the IP address of the device in the address bar.
Restrictions: Hardware compatibility with Lighttpd Web service
Hardware
Lighttpd Web service compatibility
MSR610
Yes
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
Yes
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
Yes
MSR1004S-5G, MSR1004S-5G-CN
Yes
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL
Yes
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
No
MSR2630-G-X1
No
MSR 2630
No
MSR3600-28, MSR3600-51
No
MSR3600-28-SI, MSR3600-51-SI
No
No
MSR3600-28-G-DP, MSR3600-51-G-DP
No
MSR3600-28-G-X1-DP, MSR3600-51-G-X1-DP
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
No
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
No
MSR3610-G, MSR3620-G
No
MSR3640-G
No
MSR3640-X1-HI
No
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
No
Hardware
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2600-15-X1-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
No
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
Restrictions and guidelines: lighttpd Web service configuration
For the lighttpd Web server to provide lightweight HTTP or HTTPS access service correctly, make sure it uses different service ports than other services. By default, the lightweight HTTP service port number is 80 and the lightweight HTTPS service port number is 443.
For the lighttpd Web server to provide HTTPS access service, save the required certificate to the lighttpd Web service working directory.
2.     Specify the lighttpd Web service working directory.
light-http server directory directory
By default, no lighttpd Web service working directory is specified.
3.     Save the webpages for users to access to the lighttpd Web service working directory.
4.     Enable the lighttpd Web server.
light-http server enable
By default, the lighttpd Web server is disabled.
5.     (Optional.) Specify the lightweight HTTP service port number.
light-http server http-port port-number
By default, the lightweight HTTP service port number is 80.
6.     (Optional.) Specify the lightweight HTTPS service port number.
light-http server https-port port-number
By default, the lightweight HTTPS service port number is 443.
