- 07-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-NAT configuration
- 06-NAT66 configuration
- 07-IP forwarding basics configuration
- 08-Fast forwarding configuration
- 09-Multi-CPU packet distribution configuration
- 10-Adjacency table configuration
- 11-IRDP configuration
- 12-IP performance optimization configuration
- 13-UDP helper configuration
- 14-IPv6 basics configuration
- 15-DHCPv6 configuration
- 16-IPv6 fast forwarding configuration
- 17-AFT configuration
- 18-Tunneling configuration
- 19-GRE configuration
- 20-ADVPN configuration
- 21-WAAS configuration
- 22-Lighttpd service configuration
- 23-Web caching configuration
- 24-HTTP proxy configuration
- 25-STUN configuration
| 09-Multi-CPU packet distribution configuration | 65.67 KB |
Configuring multi-CPU packet distribution
About multi-CPU packet distribution
Restrictions: Hardware compatibility with multi-CPU packet distribution
Restrictions and guidelines: Multi-CPU packet distribution configuration
Specifying a packet distribution policy
On a multi-CPU device, packets can be distributed among CPUs based on one of the following policies:
· Flow-based policy—Forwards packets of a flow to one CPU or multiple CPUs. The CPU processes flow packets by following the first-in first-out rule. A data flow can be identified by the five-tuple: Source IP address, destination IP address, source port number, destination port number, and protocol number.
· Packet-based policy—Forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
Hardware |
Multi-CPU packet distribution compatibility |
MSR610 |
No |
No |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
No |
MSR1004S-5G, MSR1004S-5G-CN |
No |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL |
No |
No |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
MSR2630-G-X1 |
No |
MSR3600-28, MSR3600-51 |
No |
No |
No |
No |
MSR3600-28-G-X1-DP, MSR3600-51-G-X1-DP |
No |
Yes |
MSR-iMC |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
No |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
No |
MSR2600-10-X1-WiNet |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
MSR3620-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2600-15-X1-XS |
No |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
If a service requires packets of a flow to be received by the same CPU, you must use the flow-based policy.
1. Enter system view.
2. Specify a packet distribution policy.
forwarding policy { per-flow [ enhance ] | per-packet }
By default, the flow-based policy is used.
Support for the enhance keyword depends on the device model. For more information, see the command reference.
