12-Security Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6749-6W10212-Security Command Reference
31-Crypto engine commands
31-Crypto engine commands 73.67 KB
crypto-engine accelerator enable gm-algorithm
Use crypto-engine accelerator enable gm-algorithm to enable the GM-capable hardware crypto engine for GM algorithms.
Use undo crypto-engine accelerator enable gm-algorithm to disable the GM-capable hardware crypto engine for GM algorithms.
crypto-engine accelerator enable gm-algorithm { sm2 | sm3 | sm4 } *
undo crypto-engine accelerator enable gm-algorithm { sm2 | sm3 | sm4 } *
The GM-capable hardware crypto engine is disabled for GM algorithms.
sm2: Specifies the SM2 algorithm.
sm3: Specifies the SM3 algorithm.
sm4: Specifies the SM4 algorithm.
Before you execute this command, make sure the device is installed with the GM-capable hardware crypto engine. If you fail to do so, data encryption/decryption by GM algorithms might terminates due to lack of the corresponding hardware crypto engine, which will interrupts the services related with GM algorithms. To identify whether a GM-capable hardware crypto engine is available, execute the display crypto-engine accelerator gm-algorithm status command. As a best practice, do not use the GM-capable hardware crypto engine for device management services. If you fail to do so, you will fail to log in to the device when the GM-capable hardware crypto engine is faulty.
Compatibility description
Only the devices with GM-capable hardware crypto engines support this command.
Application scenarios
By default, the device uses software crypto engines for data encryption/decryption by GM algorithms, including SM2, SM3, and SM4 algorithms. That is, the system uses its own software algorithms for data encryption/decryption. This consumes system resources and is less efficient. When the device is installed with the GM-capable hardware crypto engine, you can execute this command to enable the hardware crypto engine for a specific GM algorithm. Then, data encryption/decryption by that GM algorithm will not consume system resources, which improves device processing efficiency.
You can execute this command multiple times to specify multiple GM algorithms.
# Enable the GM-capable hardware crypto engine for SM2 algorithm.
[Sysname] crypto-engine accelerator enable gm-algorithm sm2
Use display crypto-engine to display crypto engine information.
If the device does not have hardware crypto engines, this command displays information only about software crypto engines.
# Display crypto engine information.
<Sysname> display crypto-engine
  Crypto engine name: Cavium crypto driver
  Crypto engine state: Enabled
  Crypto engine type: Hardware
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 0
  Crypto device name: cavium crypto
  Crypto device serial number:
  Symmetric algorithms: des-cbc des-ecb 3des-cbc 3des-ecb aes-cbc aes-ecb aes-ctr md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc-hmac
  Asymmetric algorithms: dh-group1 dh-group2 dh-group5 dh-group14
  Random number generation function: Supported
  Crypto engine name: Software crypto engine
  Crypto engine type: Software
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 1
  Crypto device name: Software
  Symmetric algorithms:  des-cbc des-ecb 3des-cbc aes-cbc aes-ecb aes-ctr camellia_cbc md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc aes-xcbc-hmac sm3 sm3-hmac sm4-cbc
  Slot ID: 2
  CPU ID: 0
  Crypto engine ID: 0
  Slot ID: 2
  CPU ID: 0
  Crypto engine ID: 1
Crypto engine state
Hardware crypto engine state:
·     Enabled.
·     Disabled.
This field always displays Enabled for software crypto engines.
Crypto engine type
Crypto engine type:
·     Hardware.
·     Software.
Crypto device name
Name of the crypto device.
This field displays Software for software crypto engines.
This field displays cavium crypto for hardware crypto engines.
Serial number of the crypto device.
This field is always empty for software crypto engines.
This field is always empty for hardware crypto engines.
Supported symmetric algorithms.
Supported asymmetric algorithms.
Whether random number generation function is supported:
·     Supported.
·     Not supported.
Use display crypto-engine accelerator gm-algorithm status to display the enabling status of the GM-capable hardware crypto engine for GM algorithms.
You can install a GM-capable hardware crypto engine to the device and execute the crypto-engine accelerator enable gm-algorithm command to enable the GM-capable hardware crypto engine for GM algorithms. In this case, you can execute the display crypto-engine accelerator gm-algorithm status command to obtain whether the GM-capable hardware crypto engine is available and enabled for the specified GM algorithms.
# Display crypto engine acceleration status for GM algorithms when a GM-capable hardware crypto engine is installed.
<Sysname> display crypto-engine accelerator gm-algorithm status
   sm2:  Accelerating
   sm3:  Accelerating
   sm4:  Disable
sm2
Status of the GM-capable hardware crypto engine for SM2 algorithm:
·     Accelerating—The GM-capable hardware crypto engine is enabled for SM2 algorithm.
·     Not accelerating (no available hardware engine)—No GM-capable hardware crypto engine is available.
·     Disable—The GM-capable hardware crypto engine is disabled for SM2 algorithm.
sm3
Status of the GM-capable hardware crypto engine for SM3 algorithm:
·     Disable—The GM-capable hardware crypto engine is disabled for SM3 algorithm.
sm4
Status of the GM-capable hardware crypto engine for SM4 algorithm:
·     Accelerating—The GM-capable hardware crypto engine is enabled for SM4 algorithm.
·     Disable—The GM-capable hardware crypto engine is disabled for SM4 algorithm.
display crypto-engine statistics
Use display crypto-engine statistics to display crypto engine statistics.
In standalone mode:
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
In IRF mode:
display crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ]
engine-id engine-id: Specifies a crypto engine by its ID.The value range for the engine-id argument is 0 to 4294967295.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
If hardware crypto engines are not enabled or the device does not have hardware crypto engines, this command displays statistics only for software crypto engines.
(In standalone mode.) If you do not specify any parameters, this command displays crypto engine statistics for all cards.
(In IRF mode.) If you do not specify any parameters, this command displays crypto engine statistics for all cards.
# (In standalone mode.) Display all crypto engine statistics.
<Sysname> display crypto-engine statistics
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 0
  Submitted sessions: 0
  Failed sessions: 0
  Symmetric operations: 0
  Symmetric errors: 0
  Asymmetric operations: 0
  Asymmetric errors: 0
  Get-random operations: 0
  Get-random errors: 0
# (In standalone mode.) Display statistics for crypto engine 1 on the specified slot.
<Sysname> display crypto-engine statistics engine-id 1 slot 1
  Failed sessions: 0
  Symmetric errors: 0
Submitted sessions
Number of established sessions.
Failed sessions
Number of failed sessions.
Number of operations using symmetric algorithms.
Symmetric errors
Number of failed operations using symmetric algorithms.
Number of operations using asymmetric algorithms.
Asymmetric errors
Number of failed operations using asymmetric algorithms.
Number of operations for obtaining random numbers.
Get-random errors
Number of failed operations for obtaining random numbers.
reset crypto-engine statistics
Use reset crypto-engine statistics to clear crypto engine statistics.
In standalone mode:
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
In IRF mode:
reset crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ]
(In standalone mode.) If you do not specify any parameters, this command clears crypto engine statistics for all cards.
(In IRF mode.) If you do not specify any parameters, this command clears crypto engine statistics for all cards.
# Clear statistics for all crypto engines.
<Sysname> reset crypto-engine statistics
# Clear statistics for crypto engine 1 on the specified slot.
<Sysname> reset crypto-engine statistics engine-id 1 slot 1
