12-Security Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6749-6W10212-Security Command Reference
08-Password control commands
08-Password control commands 221.86 KB
display password-control
Use display password-control to display password control configuration.
display password-control [ super ]
super: Displays the password control information for the super passwords. If you do not specify this keyword, the command displays the global password control configuration.
# Display the global password control configuration.
 Password control:                     Enabled (device management users)
                                       Enabled (network access users)
 Password aging:                       Enabled (90 days)
 Password length:                      Enabled (10 characters)
 Password composition:                 Enabled (1 types, 1 characters per type)
 Password history:                     Enabled (max history records:4)
 Early notice on password expiration:  7 days
 Maximum login attempts:               3
 Action for exceeding login attempts:  Lock user for 1 minutes
                                       Autoincrement (max lock time: 3 minutes)
 Password history was last reset:      0 days ago (device management users)
                                       0 days ago (network access users)
 Minimum interval between two updates: 24 hours
 User account idle time:               90 days
 Logins with aged password:            3 times in 30 days
 Password complexity:                  Disabled (username checking)
                                       Disabled (repeated characters checking)
 Password change:                      Enabled (first login)
                                       Enabled (mandatory weak password change)
 User information in blacklist:        Username-only
 All line:                             Disabled (all line blacklist)
# Display the password control configuration for super passwords.
Password control
Whether the password control feature is enabled for device management users or network access users.
Password aging
Whether password expiration is enabled and, if enabled, the aging time.
Password length
Whether the minimum password length restriction feature is enabled and, if enabled, the setting.
Whether the password composition restriction feature is enabled and, if enabled, the settings.
Password history
Whether the password history management feature is enabled and, if enabled, the setting.
Number of days during which the user is notified of the pending password expiration.
Allowed maximum number of consecutive failed login attempts for FTP and VTY users.
Action to be taken after a user fails to log in after the specified number of attempts:
·     Lock—Locks the account permanently.
·     Lock user for x minutes—Locks the account for x minutes. The Autoincrement field indicates that the locking period of the account increments each time the account fails the maximum number of login attempts again after the locking timer expires. The max lock time field indicates the maximum locking period.
·     Unlock—Does not lock the account.
Last time when the password history records of the device management or network access users were deleted.
Minimum password update interval.
Number of times and maximum number of days a user can log in using an expired password.
Password complexity
Whether the following password complexity checking (username checking and repeated characters checking) is enabled.
Password change
Status of the password change at first login feature:
·     Enabled (first login).
·     Disabled (first login).
·     Enabled (mandatory weak password change).
·     Disabled (mandatory weak password change).
User information items added to the password control blacklist:
·     Username-only—Only usernames are added to the password control blacklist.
·     Username and IP—Both usernames and IP addresses are added to the password control blacklist.
All line
Status of the password control blacklist feature for all user line types:
·     Enabled (all line blacklist).
·     Disabled (all line blacklist).
display password-control blacklist
Use display password-control blacklist to display password control blacklist information.
display password-control blacklist [ user-name user-name | ip ipv4-address | ipv6 ipv6-address ]
user-name user-name: Specifies a user by its username, a string of 1 to 55 characters. You can specify a pure username or specify a pure username and its domain name in the format of pure usernname@domain name. The pure username is case sensitive. The domain name is case insensitive.
ip ipv4-address: Specifies the IPv4 address of a user.
ipv6 ipv6-address: Specifies the IPv6 address of a user.
If you do not specify any parameters, this command displays information about all users in the password control blacklist.
When the console AUX, TTY, or USB users fail login, only their user accounts will be added to the password control blacklist. When FTP, Web, or virtual terminal line (VTY) users fail login, both their IP addresses and user accounts will be added to the password control blacklist. The user information items specified by the password-control blacklist user-info command will be added to the password control blacklist.
The device will create a blacklist entry for each IP address for a user account when the following conditions are both met:
·     Both usernames and IP addresses are added to the password control blacklist.
·     A user uses the same user account to log in to the device from different IP addresses and fails the logins.
When the maximum number of blacklist entries for the user account is reached, a blacklist entry for a new IP address of the user account will overwrite the earliest blacklist entry for the user account.
# Display password control blacklist where both usernames and IP addresses are added.
<Sysname> display password-control blacklist
 Per-user blacklist limit: 100.
 Blacklist items matched: 2.
 Username                     IP address           Login failures   Lock flag
 zzz                          -                    3                lock
 abcd                         169::168:34:1        4                lock
 admin                        192.168.34.1         1                unlock
Maximum number of blacklist entries for a user account.
Number of blacklisted users.
IP address
IP address of the user.
Login failures
Number of login failures.
Lock flag
Whether the user account is locked for the user:
·     unlock—Not locked.
·     lock—Locked temporarily or permanently, depending on the password-control login-attempt command.
password-control { composition | history | length } enable
Use password-control { composition | history | length } enable to enable a password restriction feature.
Use undo password-control { aging | composition | history | length } enable to disable a password restriction feature.
undo password-control { composition | history | length } enable
If the device starts up with the initial configuration, the password restriction features are all enabled. If the device starts up with factory defaults, the initial state of each password restriction feature depends on the factory defaults. To obtain the factory defaults of this command, execute the display default-configuration command in any view.
For more information about the initial configuration and factory defaults, see configuration file management in Fundamentals Configuration Guide.
composition: Enables the password composition restriction.
history: Enables the password history management feature.
length: Enables the minimum password length restriction.
The password history management feature takes effect only after the global password control feature is also enabled.
In non-FIPS mode, the password composition restriction and the minimum password length restriction are enabled by default regardless of whether or not the global password control feature is enabled. By default, a password must contain a minimum of four different characters.
In FIPS mode, the password composition restriction or the minimum password length restriction takes effect only after the global password control feature is also enabled. When the password composition restriction takes effect, a password, by default, must contain a minimum of four different characters. When the minimum password length restriction takes effect, a password, by default, must contain a minimum of 15 characters.
If a password of a device management user is in hashed form, a restriction setting does not take effect for the password even when the following requirements are met:
·     The global password control feature is enabled.
·     The specific password restriction feature is enabled.
For more information about configuring a password for a device management user, see "AAA commands."
If the password history management is disabled, the system will not compare the new password with history passwords, but the system will not stop recording history passwords. When the number of history password records of a user reaches the maximum number set by the password-control history command, the newest history record overwrites the earliest one.
# Enable the password control feature globally.
# Enable the password composition restriction.
[Sysname] password-control composition enable
# Enable the minimum password length restriction.
[Sysname] password-control length enable
# Enable the password history management feature.
[Sysname] password-control history enable
password-control aging
Use password-control aging to set the password aging time.
Use undo password-control aging to restore the default.
A password expires after 90 days. The password aging time for a user group equals the global setting. The password aging time for a local user equals that of the user group to which the local user belongs.
User group view
Local user view
aging-time: Specifies the password aging time in days, in the range of 1 to 365.
The aging time depends on the view:
·     The time in system view has global significance and applies to all user groups.
·     The time in user group view applies to all local users in the user group.
·     The time in local user view applies only to the local user.
A password aging time with a smaller application scope has higher priority. The system prefers to use the non-default password aging time in local user view for a local user.
·     If the default password aging time is configured for the local user, the system uses the non-default password aging time for the user group to which the local user belongs.
·     If the default password aging time is configured for the user group, the system uses the global password aging time.
# Globally set the passwords to expire after 80 days.
[Sysname] password-control aging 80
# Set the passwords for user group test to expire after 90 days.
[Sysname] user-group test
[Sysname-ugroup-test] password-control aging 90
[Sysname-ugroup-test] quit
# Set the password for device management user abc to expire after 100 days.
[Sysname] local-user abc class manage
[Sysname-luser-manage-abc] password-control aging 100
display local-user
display user-group
password-control aging enable
Use password-control aging enable to enable the password expiration feature.
Use undo password-control aging enable to disable the password expiration feature.
If the device starts up with the initial configuration, the password expiration feature is enabled. If the device starts up with factory defaults, the initial state of the password expiration feature depends on the factory defaults. To obtain the factory defaults of this command, execute the display default-configuration command in any view.
User group view
Local user view
To enable the password expiration feature for a local user, make sure the feature is enabled in system view, user group view, and local user view.
The password expiration enablement setting depends on the view:
·     The setting in system view has global significance and applies to all user groups.
·     The setting in user group view applies to all local users in the user group.
·     The setting in local user view applies only to the local user.
The password expiration setting with a smaller application scope has higher priority. The system prefers to use the non-default password expiration setting in local user view for a local user.
·     If the default setting is configured for the local user, the system uses the non-default setting for the user group to which the local user belongs.
·     If the default setting is configured for the user group, the system uses the global setting.
# Disable the password expiration feature globally.
[Sysname] undo password-control aging enable
# Disable the password expiration feature for user group test.
[Sysname-ugroup-test] undo password-control aging enable
# Disable the password expiration feature for device management user abc.
[Sysname-luser-manage-abc] undo password-control aging enable
password-control alert-before-expire
Use password-control alert-before-expire to set the number of days before a user's password expires during which the user is notified of the pending password expiration.
Use undo password-control alert-before-expire to restore the default.
The default is 7 days.
alert-time: Specifies the number of days before a user password expires during which the user is notified of the pending password expiration. The value range is 1 to 30.
This command is effective only for non-FTP users. FTP users can only have their passwords changed by the administrator.
# Configure the device to notify a user about pending password expiration 10 days before the user's password expires.
[Sysname] password-control alert-before-expire 10
password-control blacklist all-line
Use password-control blacklist all-line to enable the password control blacklist feature for all user line types.
Use undo password-control blacklist all-line to disable the password control blacklist feature for all user line types.
The password control blacklist feature is disabled for all user line types.
By default, the password control blacklist feature is enabled only for FTP, Web, and VTY users when you enable the global password control feature. To enable the password control blacklist feature for login users on all user lines (console, AUX, TTY, VTY, and USB lines), you must also execute this command. For more information about user lines, see login management configuration in in Fundamentals Configuration Guide.
With this feature enabled, the number of consecutive login failures on the same user account is accumulated for users on console, AUX, TTY, and USB lines. If the number reaches the limit, the system adds the user account to the blacklist and takes corresponding action.
Use password-control login-attempt to configure the maximum number of consecutive login failures and the action to be taken when the maximum number is reached.
# Enable the password control blacklist feature for all user line types.
[Sysname] password-control blacklist all-line
password-control blacklist user-info username-only
Use password-control blacklist user-info username-only to add only usernames of users failing authentication to the password control blacklist.
Use undo password-control blacklist user-info to restore the default.
Both usernames and IP addresses are added to the password control blacklist when users fail authentication.
If the user information items to add to the password control blacklist change, the system will clear the password control blacklist and restart the recording.
# Add only usernames to the password control blacklist when users fail authentication.
[Sysname] password-control blacklist user-info username-only
reset password-control blacklist
password-control change-password first-login enable
Use password-control change-password first-login enable to enable the password change at first login feature.
Use undo password-control change-password first-login enable to disable the password change at first login feature.
The password change at first login feature is enabled.
For the password change at first login feature to take effect, make sure the global password control is enabled.
In FIPS mode, the password change at first login feature cannot be disabled.
# Enable the password change at first login feature.
[Sysname] password-control change-password first-login enable
password-control change-password weak-password enable
Use password-control change-password weak-password enable to enable mandatory weak password change.
Use undo password-control change-password weak-password enable to disable mandatory weak password change.
In non-FIPS mode:
The mandatory weak password change feature is disabled.
In FIPS mode:
The mandatory weak password change feature is enabled.
The system checks for weak login passwords for Telnet, SSH, HTTP, or HTTPS device management users. A password is weak if it does not meet the following requirements:
·     Password composition restriction.
·     Minimum password length restriction.
·     Password complexity checking policy.
In non-FIPS mode: The mandatory weak password change feature is disabled by default. The system displays a message about a weak password but does not force the user to change it. To improve the device security, you can enable the mandatory weak password change feature, which forces the users to change the identified weak passwords. The users can log in to the device only after their passwords meet the password requirements.
In FIPS mode: The mandatory weak password change feature is enabled and cannot be disabled by default. The system checks for weak login passwords for SSH or HTTPS device management users and forces the users to change the identified weak passwords. The users can log in to the device only after their passwords meet the password requirements.
To view the current password control settings, use the display password-control command. To change the password composition restriction, minimum password length, and password complexity checking policy, use the password-control composition, password-control length, and password-control complexity commands, respectively.
# Enable the mandatory weak password change feature.
[Sysname] password-control change-password weak-password enable
Use password-control complexity to configure the password complexity checking policy.
Use undo password-control complexity to remove a password complexity checking item.
undo password-control complexity { same-character | user-name } check
In non-FIPS mode:
The global password complexity checking policy is that username checking is enabled and repeated characters checking is disabled.
The password complexity checking policy for a user group equals the global setting.
The password complexity checking policy for a local user equals that of the user group to which the local user belongs.
In FIPS mode:
The global password complexity checking policy is that both username checking and repeated characters checking are disabled.
User group view
Local user view
same-character: Refuses a password that contains a minimum of three consecutive identical characters. For example, the password aaabc is not complex enough.
user-name: Refuses a password that contains the username, the reverse of the username, or part of the username or the reverse of the username. For example:
·     If the username is 123, a password such as abc123 or 321df is not complex enough.
·     If the username is 12345, a password such as 123 is not complex enough.
The password complexity checking policy depends on the view:
·     The policy in system view has global significance and applies to all user groups.
·     The policy in user group view applies to all local users in the user group.
·     The policy in local user view applies only to the local user.
A password complexity checking policy with a smaller application scope has higher priority. The system prefers to use the non-default password complexity checking policy in local user view for a local user.
·     If the default policy is configured for the local user, the system uses the non-default policy for the user group to which the local user belongs.
·     If the default  policy is configured for the user group, the system uses the global policy.
In non-FIPS mode: Username checking is independent of whether the global password control feature is enabled.
In FIPS mode: The password complexity checking takes effect only after you enable the global password control feature and execute the password-control complexity command.
You can enable both username checking and repeated characters checking.
# Configure the password complexity checking policy, refusing any password that contains the username, the reverse of the username, or part of the username or the reverse of the username.
display local-user
display user-group
Use password-control composition to configure the password composition policy.
Use undo password-control composition to restore the default.
In non-FIPS mode:
The password using the global composition policy must contain a minimum of two character types and a minimum of one character for each type. The password composition policy for a user group is the same as the global policy. The password composition policy for a local user is the same as that of the user group to which the local user belongs.
In FIPS mode:
The password using the global composition policy must contain a minimum of four character types and a minimum of one character for each type. The password composition policy for a user group is the same as the global policy. The password composition policy for a local user is the same as that of the user group to which the local user belongs.
User group view
Local user view
type-number type-number: Specifies the minimum number of character types that a password must contain. The value range for the type-number argument is 1 to 4 in non-FIPS mode and fixed at 4 in FIPS mode.
type-length type-length: Specifies the minimum number of characters that are from each type in the password. The value range for the type-length argument is 1 to 63 in non-FIPS mode, and 1 to 15 in FIPS mode.
The password composition policy depends on the view:
A password composition policy with a smaller application scope has higher priority. The system prefers to use the non-default password composition policy in local user view for a local user.
The product of the minimum number of character types and minimum number of characters for each type cannot be greater than the maximum length of passwords.
# Specify that all passwords must each contain a minimum of four character types and a minimum of five characters for each type.
[Sysname] password-control composition type-number 4 type-length 5
# Specify that passwords in user group test must contain a minimum of four character types and a minimum of five characters for each type.
[Sysname-ugroup-test] password-control composition type-number 4 type-length 5
# Specify that the password of device management user abc must contain a minimum of four character types and a minimum of five characters for each type.
[Sysname-luser-manage-abc] password-control composition type-number 4 type-length 5
display local-user
display user-group
Use password-control enable to enable the password control feature globally.
Use undo password-control enable to disable the password control feature globally.
password-control enable [ network-class ]
 undo password-control enable [ network-class ]
In non-FIPS mode:
If the device starts up with the initial configuration, the password control feature is disabled globally for device management and network access users. If the device starts up with factory defaults, the initial state of the global password control feature for device management and network access users depends on the factory defaults. To obtain the factory defaults of this command, execute the display default-configuration command in any view.
In FIPS mode:
The password control feature is enabled globally and cannot be disabled for device management users.
The password control feature is disabled globally for network access users.
network-class: Enables global password control for network access users. If you do not specify this keyword, the command enables global password control for device management users.
When you enable global password control, the device automatically generates a .dat file and saves the file to the storage media. The file is used to record authentication and login information of local users. Do not manually delete or modify the file.
You can configure all password control features for device management users.
For network access users, you can configure only the following password control features:
·     Password composition policy.
·     Minimum password length.
·     Minimum password update interval.
·     Maximum number of history password records for each user.
For device management users, the password composition restriction, minimum password length restriction, and username checking are independent of the global password control feature. Other password control functions take effect only after the global password control feature is enabled.
For network access users, all password control functions take effect only after the global password control feature is enabled.
After the global password control feature is enabled, the passwords configured for local users must contain a minimum of four different characters.
After the global password control feature is enabled for device management users, you cannot display the password and super password configuration for device management users by using the corresponding display commands.
After the global password control feature is enabled for network access users, you cannot display the password configuration for network access users by using the corresponding display commands.
# Enable the password control feature globally for device management users.
# Enable the password control feature globally for network access users.
[Sysname] password-control enable network-class
password-control update-interval
password-control expired-user-login
Use password-control expired-user-login to set the maximum number of days and maximum number of times that a user can log in after the password expires.
Use undo password-control expired-user-login to restore the defaults.
A user can use an expired password to log in three times within 30 days after the password expires. If all the three attempts fail or the user makes a login attempt after 30 days, the system prompts the user to set a new password.
delay delay: Specifies the maximum number of days during which a user can log in using an expired password. The value range for the delay argument is 1 to 90.
times times: Specifies the maximum number of times a user can log in after the password expires. The value range is 0 to 10. For a user to set a new password at the system prompt immediately after the password expires, set the value to 0.
This command is effective only on non-FTP login users. An FTP user cannot continue to log in after its password expires.
# Allow a user to log in five times within 60 days after the password expires.
Use password-control history to set the maximum number of history password records for each user.
Use undo password-control history to restore the default.
password-control history max-record-number
The maximum number of history password records for each user is 4.
max-record-number: Specifies the maximum number of history password records for each user. The value range is 2 to 15.
The global password control feature enables the system to record history passwords. When the number of history password records of a user reaches the maximum number, the newest history record overwrites the earliest one.
To delete the existing records, use one of the following methods:
·     Use the undo password-control enable command to disable the password control feature globally.
·     Use the reset password-control history-record command to clear the passwords manually.
# Set the maximum number of history password records for each user to 10.
[Sysname] password-control history 10
Use password-control length to set the minimum password length.
Use undo password-control length to restore the default.
In non-FIPS mode:
If the device starts up with the initial configuration, the global minimum password length is 10 characters. The minimum password length for a user group equals the global setting. The minimum password length for a local user equals that of the user group to which the local user belongs. If the device starts up with factory defaults, the global minimum password length depends on the factory defaults. To obtain the factory defaults of this command, execute the display default-configuration command in any view. For more information about the initial configuration and factory defaults, see configuration file management in Fundamentals Configuration Guide.
In FIPS mode:
The global minimum password length is 15 characters. The minimum password length for a user group equals the global setting. The minimum password length for a local user equals that of the user group to which the local user belongs.
User group view
Local user view
length: Specifies the minimum password length in characters. The value range for this argument is 4 to 32 in non-FIPS mode, and 15 to 32 in FIPS mode.
The minimum length setting depends on the view:
A minimum password length with a smaller application scope has higher priority. The system prefers to use the non-default minimum password length in local user view for a local user.
·     If the default minimum password length is configured for the local user, the system uses the non-default minimum password length for the user group to which the local user belongs.
·     If the default minimum password length is configured for the user group, the system uses the global minimum password length.
# Set the global minimum password length to 16 characters.
# Set the minimum password length to 16 characters for the user group test.
[Sysname-ugroup-test] password-control length 16
# Set the minimum password length to 16 characters for the device management user abc.
[Sysname-luser-manage-abc] password-control length 16
display local-user
display user-group
password-control login idle-time
Use password-control login idle-time to set the maximum account idle time.
Use undo password-control login idle-time to restore the default.
If the device starts up with the initial configuration, the maximum account idle time is 90 days globally. The maximum account idle time for a user group equals the global setting. The maximum account idle time for a local user equals that of the user group to which the local user belongs. If the device starts up with factory defaults, the maximum account idle time depends on the factory defaults. To obtain the factory defaults of this command, execute the display default-configuration command in any view.
User group view
Device management user view
idle-time: Specifies the maximum account idle time in days. The value range is 0 to 365. 0 means no restriction for account idle time.
If a user account is idle for this period of time, the account becomes invalid and can no longer be used to log in to the device.
The account might become invalid if the system time changes after your last successful login. You cannot use an invalid account to log in. To disable the account idle time restriction, set the idle time value to 0.
The maximum account idle time depends on the view:
A maximum account idle time with a smaller application scope has higher priority. The system prefers to use the non-default maximum account idle time in local user view for a local user.
·     If the default maximum account idle time is configured for the local user, the system uses the non-default maximum account idle time for the user group to which the local user belongs.
·     If the default maximum account idle time is configured for the user group, the system uses the global maximum account idle time.
This command is available only for device management users.
# Set the maximum account idle time to 30 days.
# Set the maximum account idle time to 30 days for user group test.
[Sysname-ugroup-test] password-control login idle-time 30
# Set the maximum account idle time to 30 days for device management user abc.
[Sysname-luser-manage-abc] password-control login idle-time 30
display local-user
display user-group
Use password-control login-attempt to configure the login attempt limit. The settings include the maximum number of consecutive login failures and the action to be taken when the maximum number is reached.
Use undo password-control login-attempt to restore the default.
password-control login-attempt login-times [ exceed { lock | lock-time time [ autoincrement max-lock-time ] | unlock } ]
If the device starts up with the initial configuration, the global login-attempt settings are as follows:
·     The maximum number of consecutive login failures is 3.
·     The locking period is 1 minute.
The login-attempt settings for a user group equal the global settings.
The login-attempt settings for a local user equal those for the user group to which the local user belongs.
If the device starts up with factory defaults, the login attempt limit depends on the factory defaults. To obtain the factory defaults of this command, execute the display default-configuration command in any view.
User group view
Local user view
login-times: Specifies the maximum number of consecutive login failures. The value range is 2 to 10.
exceed: Specifies an action if the user fails the maximum number of consecutive login attempts.
·     lock: Locks the user permanently.
¡     For FTP, Web, or VTY users, the user account and the user's IP address are both locked. No one can use this user account to log in from this locked IP address.
¡     For console, AUX, TTY, or USB users, the user account is locked. A user cannot use this user account to log in through a console, AUX, TTY, or USB user line.
·     lock-time time: Locks the user for a period of time. The value range for the time argument is 1 to 360 minutes.
¡     When the locking timer expires, the FTP, Web, or VTY user can use this user account to log in from the IP address again.
¡     When the locking timer expires, the console, AUX, TTY, or USB user can use this user account to log in again through a console, AUX, TTY, or USB user line.
·     autoincrement max-lock-time: Enables the locking period of the account to increment each time the account fails the maximum number of login attempts again after the locking timer expires. The max-lock-time argument represents the maximum locking period, in the range of 100 to 360 in minutes. The value for the max-lock-time argument must be equal to or greater than that for the time argument. For example, if the time argument is x and the max-lock-time argument is y, the account is locked for x minutes when the account fails the maximum number of login attempts for the first time. When the account fails the maximum number of login attempts for the nth time, the account is locked for n*x minutes. If the product of n*x is greater than y, the account is locked only for y minutes, and the locking period will not increment for subsequent login failures.
·     unlock: Does not lock the user account.
¡     The FTP, Web, or VTY user can continue using this user account to make login attempts from the current IP address.
¡     The console, AUX, TTY, or USB user can continue using this user account to make login attempts through a console, AUX, TTY, or USB user line.
The login-attempt policy depends on the view:
A login-attempt policy with a smaller application scope has higher priority. The system prefers to use the non-default login-attempt policy in local user view for a local user.
If an FTP, Web, or VTY user fails to log in, the system adds the user account and the user's IP address to the password control blacklist. If a console, AUX, TTY, or USB user fails to log in, the system adds the user account to the password control blacklist. When the maximum number of consecutive login failures is reached, the login attempt limit feature is triggered.
Whether a blacklisted user and user account are locked depends on the locking setting:
·     If a user account is permanently locked for a user, the user cannot use this account unless this account is removed from the password control blacklist. To remove the user account, use the reset password-control blacklist command.
·     To use a temporarily locked user account, the user can perform either of the following tasks:
¡     Wait until the locking timer expires.
¡     Remove the user account from the password control blacklist.
·     If the user account and the user are blacklisted but not locked, the user can continue using this account to log in. The account and the user's IP address are removed from the password control blacklist when the user uses the account to successfully log in to the device.
This account is locked only for the user at the locked IP address. A user from an unlocked IP address can still use this account, and the user at the locked IP address can use other unlocked user accounts.
The password-control login-attempt command takes effect immediately after being executed, and can affect the users already in the password control blacklist.
If a local user is assigned the security-audit user role, this command does not take effect for that user. When the number of login failures exceeds the specified threshold, the security-audit administrator user will not be added to the password control blacklist. For more information about the security-audit user role, see RBAC configuration in Fundamentals Configuration Guide.
# Allow a maximum of four consecutive login failures on a user account, and lock the user account and the user's IP address permanently if the limit is reached.
[Sysname] password-control login-attempt 4 exceed lock
# Use the user account test to log in to the device, and enter incorrect password for four times.
# Display the password control blacklist. The output shows that the user account is on the blacklist, and its status is lock.
[Sysname] display password-control blacklist
 Blacklist items matched: 1.
 test                         192.168.44.1         4                lock
# Verify that the user at 192.168.44.1 cannot use this user account to log in.
# Allow a maximum of two consecutive login failures on a user account, and lock the account for 3 minutes if the limit is reached.
[Sysname] password-control login-attempt 2 exceed lock-time 3
# Use the user account test to log in to the device, and enter incorrect password for two attempts.
# Display the password control blacklist. The output shows that the user account is on the blacklist and its status is lock.
 test                         192.168.44.1         2                lock
# Verify that after 3 minutes, the user account is removed from the password control blacklist and the user at 192.168.44.1 can use this account.
display local-user
display user-group
password-control backlist all-line
password-control per-user blacklist-limit
Use password-control per-user blacklist-limit to set the maximum number of blacklist entries for a user account.
Use undo password-control per-user blacklist-limit to restore the default.
password-control per-user blacklist-limit max-number
The maximum number of blacklist entries for a user account is 32.
max-number: Maximum number of blacklist entries that the device can record for a single user account. The value range is 1 to 4294967295.
For an FTP, a VTY, or a Web user that fails login, the system adds the username and IP address of the user to the password control blacklist.
If such a user uses the same user account to log in to the device from different IP addresses and fails the logins, the device will create a blacklist entry for each IP address for the user account. When the maximum number of blacklist entries for the user account is reached, a blacklist entry for a new IP address of the user account will overwrite the earliest blacklist entry for the user account.
# Set the maximum number of blacklist entries for a user account to 100.
[Sysname] password-control per-user blacklist-limit 100
password-control super aging
Use password-control super aging to set the aging time for super passwords.
Use undo password-control super aging to restore the default.
A super password expires after 90 days.
aging-time: Specifies the super password aging time in days, in the range of 1 to 365.
# Set the super passwords to expire after 10 days.
[Sysname] password-control super aging 10
password-control super composition
Use password-control super composition to configure the composition policy for super passwords.
Use undo password-control super composition to restore the default.
In non-FIPS mode:
A super password must contain a minimum of two character types and a minimum of one character for each type.
In FIPS mode:
A super password must contain a minimum of four character types and a minimum of one character for each type.
type-number type-number: Specifies the minimum number of character types that a super password must contain. The value range for the type-number argument is 1 to 4 in non-FIPS mode and fixed at 4 in FIPS mode.
type-length type-length: Specifies the minimum number of characters that are from each character type. The value range for the type-length argument is 1 to 63 in non-FIPS mode, and 1 to 15 in FIPS mode.
The product of the minimum number of character types and minimum number of characters for each type cannot be greater than the maximum length of the super password.
# Specify that a super password must contain a minimum of four character types and a minimum of five characters for each type.
password-control super length
Use password-control super length to set the minimum length for super passwords.
Use undo password-control super length to restore the default.
In non-FIPS mode:
The minimum super password length is 10 characters.
In FIPS mode:
The minimum super password length is 15 characters.
length: Specifies the minimum length of super passwords in characters. The value range for this argument is 4 to 63 in non-FIPS mode, and 15 to 63 in FIPS mode.
# Set the minimum length of super passwords to 16 characters.
[Sysname] password-control super length 16
Use password-control update-interval to set the minimum password update interval, which is the minimum interval at which users can change their passwords.
Use undo password-control update-interval to restore the default.
password-control update-interval interval
If the device starts up with the initial configuration, the minimum password update interval is 24 hours. If the device starts up with factory defaults, the minimum password update interval depends on the factory defaults. To obtain the factory defaults of this command, execute the display default-configuration command in any view.
interval: Specifies the minimum password update interval in hours, in the range of 0 to 168. 0 means no requirements for password update interval.
The set minimum interval is not effective on a user who is prompted to change the password at the first login or after the password expires.
# Set the minimum password update interval to 36 hours.
Use reset password-control blacklist to remove blacklisted users.
reset password-control blacklist [ user-name user-name ]
user-name user-name: Specifies the username of a user account to be removed from the password control blacklist. The username is a string of 1 to 55 characters. You can specify a pure username or specify a pure username and its domain name in the format of pure usernname@domain name. The pure username is case sensitive. The domain name is case insensitive.
You can use this command to remove a user account that is blacklisted due to excessive login failures.
# Remove the user account named test from the password control blacklist.
<Sysname> reset password-control blacklist user-name test
Are you sure to delete the specified user in blacklist? [Y/N]:
Use reset password-control history-record to delete history password records.
reset password-control history-record [ super [ role role name ] | user-name user-name | network-class [ user-name user-name ] ]
super: Deletes the history records of the specified super password or all super passwords.
role role name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the command deletes the history records of all super passwords.
network-class: Deletes the history password records of network access users. If you do not specify this keyword, the command deletes the history password records of device management users.
user-name user-name: Specifies the username of the user whose password records are to be deleted. The user-name argument is a string of 1 to 55 characters. You can specify a pure username or specify a pure username and its domain name in the format of pure usernname@domain name. The pure username is case sensitive. The domain name is case insensitive. If you do not specify a username, this command deletes all history password records of the specified user type.
If you do not specify any parameters, this command deletes the history password records of all device management users.
# Clear the history password records of all device management users.
<Sysname> reset password-control history-record
Are you sure to delete all local user's history records? [Y/N]:y
# Delete the history password records of all network access users.
<Sysname> reset password-control history-record network-class
Are you sure you want to delete all network access users' history records? [Y/N]:y
