| 02-Power Module Issues | 44.85 KB |
Troubleshoot hardware
Power module issues
Abnormal power module state
Symptom
The LED for the power module is abnormal or a fault occurs during the power module operation.
Common causes
The following are the common causes of this type of issue:
· The power module model does not match the host.
· The power module is not correctly installed.
· The power cord is not securely connected.
· The temperature of the power module is too high.
· The power module is faulty.
Troubleshooting flow
Figure 1 shows the troubleshooting flowchart.
Figure 1 Flowchart for troubleshooting power modules
Solution
1. Identify whether the power module model matches the host model.
2. Check the power supply system of the device to ensure that the power supply system can provide power correctly to the device.
3. Identify the LED for the power module to preliminarily determine whether the power module has output short circuit, output overcurrent, output overvoltage, input undervoltage, overheating, and other issues. The power LED status varies by device model. For details, see the hardware manual for the corresponding device.
4. Check the power module state.
5. Use the display power-supply command to check power module status. Identify whether any power modules are in Fault or Absent status.
<Sysname> display power-supply
PWR No. State
0 Normal
1 Absent
You can also use the display alarm command to check power module alarm information.
<Sysname> display alarm
Slot CPU Level Info
- - INFO Power 1 is absent
6. If the state of a power module is Absent, follow these steps for troubleshooting:
a. Re-install the power module. Before you re-install the power module, verify that the power connector is intact.
b. If the state of the power module fails to recover to Normal, install the power module to another slot with a power module that is operating correctly.
c. If the state of the power module still shows Absent, replace it with a new power module.
d. If the issue persists, proceed to step 8.
7. If the power supply state is Fault or Error, follow these steps for troubleshooting:
a. Identify whether the power cord is loose or properly connected.
b. If the power cord is connected properly, identify whether power cord is faulty.
c. If the power cord is normal, the power module itself may be overheating. Check the dust buildup on the power module. If there is excessive dust, clear the dust, and then reinstall the power module.
d. If the state of the power module fails to recover to Normal, install the power module to another slot with a power module that is operating correctly.
e. If the state of the power module still shows Fault, replace it with a new power module.
f. If the issue persists, proceed to step 8.
8. If the issue persists, collect the following information and contact Technical Support:
¡ Results of each step.
¡ The configuration files, log messages, and alarm messages.
Related alarm and log messages
Alarm messages
N/A
Log messages
· DEV/2/POWER_FAILED
· DEV/3/POWER_ABSENT
