01-Hardware Troubleshooting Guide
HomeSupportRoutersSR6602-I[IE] SeriesDiagnose & MaintainTroubleshootingH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Troubleshooting Guide(V9)-R9160-6W10001-Hardware Troubleshooting Guide
01-System Issues
01-System Issues 58.01 KB
Troubleshooting hardware failures
System failures
No display or garbled display on the configuration terminal
Symptom
The configuration terminal does not have a display or has garbled display when the device is powered on.
Common causes
The following are the common causes for this type of issue:
·     The power system is operating incorrectly.
·     The MPU is operating incorrectly.
·     The console cable is not connected to the console port on the MPU.
·     Configuration terminal parameters are incorrect.
·     The console cable has exceptions.
Troubleshooting flow
Figure 1 shows the troubleshooting flowchart:
Figure 1 Troubleshooting flow
Solution
1.     Verify that the power system is operating correctly.
If the power system is operating incorrectly, see the power failure troubleshooting section to resolve the issue.
2.     Verify that the MPU is operating correctly.
If the MPU is operating incorrectly, see the MPU failure troubleshooting section to resolve the issue.
3.     Verify that the console cable is correctly connected to the console port on the MPU.
4.     Verify that the console cable is correctly connected to the console port and the specified serial port on the configuration terminal. Verify that the following settings are configured for the terminals:
¡     Baud rate—9600.
¡     Data bits—8.
¡     Parity—None.
¡     Stop bits—1.
¡     Flow control—None.
Verify that the terminal is VT100. The serial port settings depend on the device model.
5.     Replace the console cable.
6.     If the issue persists, collect the following information and contact Technical Support:
¡     Results of each step.
¡     The configuration file, log messages, and alarm messages.
Related alarm and log messages
Alarm messages
N/A
Log messages
N/A
Unexpected device reboot
Symptom
The device reboots unexpectedly.
Common causes
This type of issue is typically caused by startup file exceptions.
Figure 2 shows the troubleshooting flowchart:
Figure 2 Flowchart for troubleshooting unexpected reboot of a device
Solution
1.     Identify whether the device can enter command line state after it reboots.
If the device can enter command line mode, execute the display diagnostic-information command to collect diagnostic information. Then, export the device data and send it to H3C technical support for help.
When you execute the display diagnostic-information command, you can specify the key-info keyword to collect only critical diagnostic information and reduce collection time.
2.     Verify that the startup file is normal.
If the device cannot enter command line mode, connect it via the console port and reboot it again. If BootWare reports a CRC error or fails to locate the startup file, use the BootWare menu to reload the startup file and set it as the current startup file. During the BootWare loading process, BootWare automatically sets this file as the current startup file.
3.     If the issue persists, collect the following information and contact Technical Support:
Alarm messages
N/A
Log messages
N/A
Memory anomaly alarm
Symptom
The system outputs an alarm message for abnormal memory usage, for example:
DIAG/1/MEM_EXCEED_THRESHOLD: Memory minor threshold has been exceeded.
Common causes
This type of issue is typically caused by memory leakage.
Figure 3 shows the troubleshooting flowchart:
Figure 3 Flowchart for troubleshooting high memory usage
Solution
1.     Check the usage of each memory module.
2.     Execute the display system internal kernel memory pool command in probe view to check the memory usage. Identify memory modules with abnormal or continuously increasing usage.
[Sysname] probe
[Sysname-probe] display system internal kernel memory pool slot 1
Active    Number  Size     Align Slab Pg/Slab ASlabs  NSlabs Name
9126      9248    64       8     32   1       289     289    kmalloc-64
105       112     16328    0     2    8       54      56     kmalloc-16328
14        14      2097096  0     1    512     14      14     kmalloc-2097096
147       225     2048     8     15   8       12      15     kmalloc-2048
7108      7232    192      8     32   2       226     226    kmalloc-192
22        22      524232   0     1    128     22      22     kmalloc-524232
1288      1344    128      8     21   1       64      64     kmalloc-128
0         0       67108808 0     1    16384   0       0      kmalloc-67108808
630       651     4096     8     7    8       93      93     kmalloc-4096
68        70      131016   0     1    32      68      70     kmalloc-131016
1718      2048    8        8     64   1       31      32     kmalloc-8
1         1       16777160 0     1    4096    1       1      kmalloc-16777160
2         15      2048     0     15   8       1       1      sgpool-64
0         0       40       0     42   1       0       0      inotify_event_cache
325       330     16328    8     2    8       165     165    kmalloc_dma-16328
0         0       72       0     30   1       0       0      LFIB_IlmEntryCache
0         0       1080     0     28   8       0       0      LFIB_IlmEntryCache
0         0       1464     0     21   8       0       0      MFW_FsCache
1         20      136      0     20   1       1       1      L2VFIB_Ac_cache
0         0       240      0     25   2       0       0      CCF_JOBDESC
0         0       88       0     26   1       0       0      NS4_Aggre_TosSrcPre
0         0       128      0     21   1       0       0      IPFS_CacheHash_cachep
---- More ----
View the values in the Number and Size columns. If you find that the memory usage of a block is continuously increasing, it indicates that the block is being constantly used.
¡     An increase in the usage of some memory blocks can be normal, so you must determine whether the increase is truly abnormal. Number*Size represents the amount of memory used by a module. Identifying whether the memory usage is normal might require monitoring the rate of memory growth and the amount of memory used over time.
¡     Some memory leaks might be slow, so a longer period (even several weeks) of observation and comparison might be needed.
3.     Collecting information and contacting Technical Support
As a best practice, contact Technical Support to collect failure information.
For correct failure location, do not restart the device.
Alarm messages
N/A
Log messages
·     MEM_ALERT
·     MEM_EXCEED_THRESHOLD
·     MEM_BELOW_THRESHOLD
