06-Interface
HomeSupportReference GuidesMIB CompanionH3C S9850-G&S6530X Switch Series MIB References-R8307Pxx-6W10006-Interface
03-HH3C-STORM-CONSTRAIN-MIB
03-HH3C-STORM-CONSTRAIN-MIB 92.86 KB
About this MIB
Use this MIB to obtain the interface status, configure traffic constrain, and define corresponding alarm thresholds.
MIB file name
hh3c-storm-constrain.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cStormConstrain(66)
Scalar objects
hh3cStormTrapType
Object (OID)
Access
Value range
Implementation
hh3cStormTrapType (1.3.6.1.4.1.25506.2.66.1.1)
accessible-for-notify
INTEGER
{ broadcast(1), multicast(2), unicast(3),knownUnicast(4) }
Reason why a trap message is generated on an interface.
·     broadcast—Trap message generated when broadcast traffic exceeds the upper limit or drops below the lower limit on the interface.
·     multicast—Trap message generated when multicast traffic exceeds the upper limit or drops below the lower limit on the interface.
·     unicast—Trap message generated when unknown unicast traffic exceeds the upper limit or drops below the lower limit on the interface.
·     knownUnicast—Trap message generated when known unicast traffic exceeds the upper limit or drops below the lower limit on the interface.
As per the MIB.
hh3cStormTrapThreshold
Object (OID)
Access
Value range
Implementation
hh3cStormTrapThreshold (1.3.6.1.4.1.25506.2.66.1.2)
Integer32
Integer32
Threshold value for which a trap message was generated.
For example, this value indicates the upper limit value for a trap generated because broadcast traffic exceeds the upper limit.
As per the MIB.
Tabular objects
hh3cStormCtrlTable
About this table
This table contain storm control settings.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cStormCtrlPortStatus (1.3.6.1.4.1.25506.2.66.2.1.1.1)
read-only
IH3cStormConstrainUnit
Status of an interface.
·     controlled—The interface is in controlled status.
·     normal—The interface is in normal status.
As per the MIB.
hh3cStormCtrlBroadcastUnit (1.3.6.1.4.1.25506.2.66.2.1.1.2)
read-create
INTEGER
INTEGER{ pps(1), per(2), bps(3)}
Unit for the upper or lower broadcast traffic limit.
You must specify hh3cStormCtrlBroadcastUnit, hh3cStormCtrlBroadcastUpper, and hh3cStormCtrlBroadcastLower in an SNMP request.
This object does not support value bytePerSecond or none.
hh3cStormCtrlBroadcastUpper (1.3.6.1.4.1.25506.2.66.2.1.1.3)
read-create
Integer32
Integer32
Upper limit for broadcast traffic. The unit depends on h3cStormCtrlBroadcastUnit.
Value 0 indicates invalid configuration.
hh3cStormCtrlBroadcastLower (1.3.6.1.4.1.25506.2.66.2.1.1.4)
read-create
Integer32
Integer32
Lower limit for broadcast traffic. The unit depends on h3cStormCtrlBroadcastUnit.
hh3cStormCtrlMulticastUnit (1.3.6.1.4.1.25506.2.66.2.1.1.5)
read-create
Unit for the upper or lower multicast traffic limit.
You must specify hh3cStormCtrlMulticastUnit, hh3cStormCtrlMulticastUpper, and hh3cStormCtrlMulticastLower in an SNMP notification.
hh3cStormCtrlMulticastUpper (1.3.6.1.4.1.25506.2.66.2.1.1.6)
read-create
Integer32
Integer32
Upper limit for multicast traffic. The unit depends on h3cStormCtrlMulticastUnit.
hh3cStormCtrlMulticastLower (1.3.6.1.4.1.25506.2.66.2.1.1.7)
read-create
Integer32
Integer32
Lower limit for multicast traffic. The unit depends on h3cStormCtrlMulticastUnit.
You must specify hh3cStormCtrlMulticastUnit, hh3cStormCtrlMulticastUpper, and hh3cStormCtrlMulticastLowe in an SNMP notification.
The value of this object must be smaller than hh3cStormCtrlMulticastUpper.
hh3cStormCtrlUnicastUnit (1.3.6.1.4.1.25506.2.66.2.1.1.8)
read-create
Unit for the upper or lower unicast traffic limit.
You must specify hh3cStormCtrlUnicastUnit, hh3cStormCtrlUnicastUpper, and hh3cStormCtrlUnicastLower in an SNMP notification.
hh3cStormCtrlUnicastUpper (1.3.6.1.4.1.25506.2.66.2.1.1.9)
read-create
Integer32
Integer32
Upper limit for unicast traffic. The unit depends on h3cStormCtrlUnicastUnit.
hh3cStormCtrlUnicastLower (1.3.6.1.4.1.25506.2.66.2.1.1.10)
read-create
Integer32
Integer32
Lower limit for multicast traffic. The unit depends on h3cStormCtrlUnicastUnit.
The value of this object must be smaller than hh3cStormCtrlUnicastUpper.
hh3cStormCtrlRowStatus (1.3.6.1.4.1.25506.2.66.2.1.1.11)
read-create
RowStatus
RowStatus
Row status.
Supports only the following values: active, create, and destroy.
hh3cStormCtrlPortMode (1.3.6.1.4.1.25506.2.66.2.1.1.12)
read-create
INTEGER
INTEGER{ none(1), block(2), shutdown(3) }
Storm control mode of the interface.
As per the MIB.
Notifications
This section contains HH3C-STORM-CONSTRAIN-MIB notifications.
hh3cStormRising
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.66.3.1
Traffic of a type on an interface exceeded the upper limit.
Error
Warning
1.3.6.1.4.1.25506.2.66.3.2 (hh3cStormFalling)
ON
Notification triggers
This notification is generated when traffic control is enabled and traffic of any type on an interface exceeds the upper limit of this traffic type.
System impact
Traffic of this type might be dropped.
Status control
ON
CLI: Use the storm-constrain enable trap command.
OFF
CLI: Use the undo storm-constrain enable trap command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of an interface.
ifIndex
InterfaceIndex
Integer32 (1..2147483647)
1.3.6.1.4.1.25506.2.66.1.1 (hh3cStormTrapType)
Type of the notification.
ifIndex
INTEGER
broadcast(1)
multicast(2)
unicast(3)
1.3.6.1.4.1.25506.2.66.1.2 (hh3cStormTrapThreshold)
Alarm threshold.
ifIndex
Integer32
Same as the standard MIB.
1.3.6.1.4.1.25506.2.66.2.1.1.1 (hh3cStormCtrlPortStatus)
Status of the interface.
ifIndex
INTEGER
controlled(1)
normal(2)
Recommended action
To resolve the issue:
1.     Verify traffic of this type on the interface does not exceed the upper limit of this traffic type. If the threshold is too low, adjust it as needed.
2.     If the issue persists, contact H3C Support.
hh3cStormFalling
Basic information
OID
Event
Severity
Default status
Traffic of a type on an interface dropped below the lower limit.
Recovery
Warning
N/A
ON
This notification is generated when traffic control is enabled and traffic of any type on an interface dropped below the upper limit of this traffic type.
System impact
The services are not impacted.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
ifIndex
InterfaceIndex
ifIndex
INTEGER
broadcast(1)
multicast(2)
unicast(3)
Alarm threshold.
ifIndex
Integer32
ifIndex
INTEGER
controlled(1)
normal(2)
Recommended action
No action is required.
