06-Interface
HomeSupportReference GuidesMIB CompanionH3C S9850-G&S6530X Switch Series MIB References-R8307Pxx-6W10006-Interface
01-ADSL-LINE-MIB
01-ADSL-LINE-MIB 85.60 KB
ADSL-LINE-MIB
About this MIB
Use this MIB to obtain ADSL line information.
MIB file name
rfc2662-adsl-line.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).adslMIB(94).adslLineMib(1)
Tabular objects
adslLineTable
About this table
This table contains common attributes of ADSL physical interface at the ends of an ADSL line.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslLineCoding.
Object (OID)
Access
Value range
Implementation
adslLineCoding (1.3.6.1.2.1.10.94.1.1.1.1.1)
read-only
AdslLineCodingType
other(1),
dmt (2),
cap (3),
qam (4)
ADSL coding type used on an ADSL line.
As per the MIB.
adslLineType (1.3.6.1.2.1.10.94.1.1.1.1.2)
read-only
INTEGER
noChannel (1), fastOnly (2), interleavedOnly (3), fastOrInterleaved (4), fastAndInterleaved (5)
Type of the ADSL physical line.
As per the MIB.
adslLineSpecific (1.3.6.1.2.1.10.94.1.1.1.1.3)
read-only
OBJECT IDENTIFIER
Standard MIB values.
OID instance in vendor-specific MIB.
As per the MIB.
adslLineConfProfile (1.3.6.1.2.1.10.94.1.1.1.1.4)
read-write
SnmpAdminString
OCTETSTRING  (1..32)
Name of a profile in the adslLineConfProfileTable.
Supports only the read operation.
adslLineAlarmConfProfile (1.3.6.1.2.1.10.94.1.1.1.1.5)
read-write
SnmpAdminString
 OCTETSTRING  (1..32)
Name of a profile in the acLineAlarmConfProfileTable.
adslAtucPhysTable
About this table
This table contains physical layer parameters for an ATUC.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslAtucInvSerialNumber.
Object (OID)
Access
Value range
Implementation
adslAtucInvSerialNumber (1.3.6.1.2.1.10.94.1.1.2.1.1)
read-only
SnmpAdminString
 OCTETSTRING  (0..32)
Serial number of an ATU.
As per the MIB.
adslAtucInvVendorID (1.3.6.1.2.1.10.94.1.1.2.1.2)
read-only
SnmpAdminString
 OCTETSTRING  (0..16)
Vendor ID of the ATU.
As per the MIB.
adslAtucInvVersionNumber (1.3.6.1.2.1.10.94.1.1.2.1.3)
read-only
SnmpAdminString
 OCTETSTRING  (0..16)
Version number of the ATU.
As per the MIB.
adslAtucCurrSnrMgn (1.3.6.1.2.1.10.94.1.1.2.1.4)
read-only
INTEGER
INTEGER (-640..640)
Noise margin of the ATU, in tenth dB.
As per the MIB.
adslAtucCurrAtn (1.3.6.1.2.1.10.94.1.1.2.1.5)
read-only
Gauge32
Gauge32(0..630)
Attenuation of the ATUC line, in tenth dB.
As per the MIB.
adslAtucCurrStatus (1.3.6.1.2.1.10.94.1.1.2.1.6)
read-only
BITS
BITS {
                               noDefect(0),
                               lossOfFraming(1),
                               lossOfSignal(2),
                               lossOfPower(3),
                               lossOfSignalQuality(4),
                               lossOfLink(5),
                               dataInitFailure(6),
                               configInitFailure(7),
                               protocolInitFailure(8),
                               noPeerAtuPresent(9)
Current state of the ATUC line.
As per the MIB.
adslAtucCurrOutputPwr (1.3.6.1.2.1.10.94.1.1.2.1.7)
read-only
INTEGER
INTEGER (-310..310)
Output power of the ATUC line, in tenth dBm.
As per the MIB.
adslAtucCurrAttainableRate (1.3.6.1.2.1.10.94.1.1.2.1.8)
read-only
Gauge32
Maximum currently attainable data rate by the ATU, in bps.
As per the MIB.
adslAturPhysTable
About this table
This table contains physical layer parameters for an ATUR.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslAturInvSerialNumber.
Object (OID)
Access
Value range
Implementation
adslAturInvSerialNumber (1.3.6.1.2.1.10.94.1.1.3.1.1)
read-only
SnmpAdminString
OCTETSTRING (0..32)
As per the MIB.
adslAturInvVendorID (1.3.6.1.2.1.10.94.1.1.3.1.2)
read-only
SnmpAdminString
OCTETSTRING (0..16)
As per the MIB.
adslAturInvVersionNumber (1.3.6.1.2.1.10.94.1.1.3.1.3)
read-only
SnmpAdminString
OCTETSTRING (0..16)
As per the MIB.
adslAturCurrSnrMgn (1.3.6.1.2.1.10.94.1.1.3.1.4)
read-only
INTEGER
INTEGER (-640..640)
Noise margin of the ATUR line, in tenth dB.
As per the MIB.
adslAturCurrAtn (1.3.6.1.2.1.10.94.1.1.3.1.5)
read-only
Gauge32
Gauge32(0..630)
Attenuation of the ATUR line, in tenth dB.
As per the MIB.
adslAturCurrStatus (1.3.6.1.2.1.10.94.1.1.3.1.6)
read-only
BITS
BITS {
                               noDefect(0),
                               lossOfFraming(1),
                               lossOfSignal(2),
                               lossOfPower(3),
Current state of the ATUR line.
As per the MIB.
adslAturCurrOutputPwr (1.3.6.1.2.1.10.94.1.1.3.1.7)
read-only
INTEGER
INTEGER (-310..310)
Output power transmitted by the ATU, in tenth dBm.
As per the MIB.
adslAturCurrAttainableRate (1.3.6.1.2.1.10.94.1.1.3.1.8)
read-only
Gauge32
As per the MIB.
adslAtucChanTable
About this table
This table contains parameters of an ATUC channel.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslAtucChanInterleaveDelay.
Object (OID)
Access
Value range
Implementation
adslAtucChanInterleaveDelay (1.3.6.1.2.1.10.94.1.1.4.1.1)
read-only
Gauge32
Interleave delay for an ATUC channel.
As per the MIB.
adslAtucChanCurrTxRate (1.3.6.1.2.1.10.94.1.1.4.1.2)
read-only
Gauge32
Actual transmit rate on the  channel.
As per the MIB.
adslAtucChanPrevTxRate (1.3.6.1.2.1.10.94.1.1.4.1.3)
read-only
Gauge32
Rate at the time of the last adslAtucRateChangeTrap event.
As per the MIB.
adslAtucChanCrcBlockLength (1.3.6.1.2.1.10.94.1.1.4.1.4)
read-only
Gauge32
Length of the channel data-block on which the CRC operates.
As per the MIB.
adslAturChanTable
About this table
This table contains parameters of an ATUR channel.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is adslAturChanInterleaveDelay.
Object (OID)
Access
Value range
Implementation
adslAturChanInterleaveDelay (1.3.6.1.2.1.10.94.1.1.5.1.1)
read-only
Gauge32
Interleave delay for an ATUR channel.
As per the MIB.
adslAturChanCurrTxRate (1.3.6.1.2.1.10.94.1.1.5.1.2)
read-only
Gauge32
As per the MIB.
adslAturChanPrevTxRate (1.3.6.1.2.1.10.94.1.1.5.1.3)
read-only
Gauge32
As per the MIB.
adslAturChanCrcBlockLength (1.3.6.1.2.1.10.94.1.1.5.1.4)
read-only
Gauge32
As per the MIB.
