10-Security Command Reference
HomeSupportSwitchesS5590-EI SeriesReference GuidesCommand ReferencesH3C S5590-HI[S5590-EI][S5500V3-HI] Switch Series Command References-R8336Pxx-6W10010-Security Command Reference
25-CloudSec commands
25-CloudSec commands 114.51 KB
CloudSec commands
cloudsec peer
Use cloudsec peer to create a CloudSec peer and enter its view, or enter the view of an existing CloudSec peer.
Use undo cloudsec peer to delete a CloudSec peer.
cloudsec peer { ipv4-address | ipv6-address }
undo cloudsec peer { ipv4-address | ipv6-address }
No CloudSec peers exist.
ipv4-address: Specifies the IPv4 address of a CloudSec peer.
ipv6-address: Specifies the IPv6 address of a CloudSec peer.
After you create a CloudSec peer, you can specify the CloudSec parameters used for protection of communication with that peer. These parameters include a keychain and CloudSec policy binding, as well as the transmit and receive SCIs. The CloudSec policy contains settings such as the cipher suite and SAK rekey interval.
# Specify the node at 11.1.1.1 as a CloudSec peer and enter CloudSec peer view.
[Sysname] cloudsec peer 11.1.1.1
[Sysname-cloudsec-peer-11.1.1.1]
cloudsec policy
cloudsec policy
Use cloudsec policy to create a CloudSec policy and enter its view, or enter the view of an existing CloudSec policy.
Use undo cloudsec policy to delete a CloudSec policy.
cloudsec policy policy-name
undo cloudsec policy policy-name
The device has a default CloudSec policy named default-policy.
policy-name: Specifies a CloudSec policy by its name, a case-sensitive string of 1 to 16 characters.
To configure CloudSec, you must first create a CloudSec policy, and then configure CloudSec settings such as cipher suites and the SAK update interval in the policy.
To create multiple CloudSec policies, repeat this command.
The default CloudSec policy is named default-policy. You cannot delete or modify it.
# Create a CloudSec policy named abcd and enter its view.
<Syaname> system-view
[Sysname] cloudsec policy abcd
[Sysname-cloudsec-policy-abcd]
cipher-suite
cloudsec source-interface
Use cloudsec source-interface to associate a VXLAN tunnel source interface with CloudSec.
Use undo cloudsec source-interface to disassociate a tunnel source interface from CloudSec.
cloudsec source-interface interface-type interface-number
undo cloudsec source-interface interface-type interface-number
No tunnel source interfaces associate with CloudSec.
interface-type interface-number: Specifies a tunnel source interface by its type and number.
Operating mechanism
To protect the packets transmitted in an EVPN VXLAN tunnel with CloudSec, you must associate its tunnel source interface with CloudSec.
To associate multiple tunnel source interfaces with CloudSecCloudSec, repeat this command. CloudSec is automatically enabled when you execute this command, the cloudsec peer command, or the cloudsec policy command for the first time.
# Associate a tunnel source interface with CloudSec.
[Sysname] cloudsec source-interface loopback 0
cloudsec peer
cloudsec policy
cipher-suite
Use cipher-suite to specify a cipher suite for CloudSec to encrypt data.
Use undo cipher-suite to restore the default.
cipher-suite { gcm-aes-128 | gcm-aes-256 | gcm-aes-xpn-128 | gcm-aes-xpn-256 }
undo cipher-suite
CloudSec uses the GCM-AES-128 cipher suite.
CloudSec policy view
gcm-aes-128: Specifies the GCM-AES-128 cipher suite.
gcm-aes-256: Specifies the GCM-AES-256 cipher suite.
gcm-aes-xpn-128: Specifies the GCM-AES-XPN-128 cipher suite.
gcm-aes-xpn-256: Specifies the GCM-AES-XPN-256 cipher suite.
You must configure the local end and its peer end with the same cipher suite to successfully establish a CloudSec session. If you change the cipher suite at one end, you must ensure that the same change is made at the other end.
# In CloudSec policy abcd, set the cipher suite to GCM-AES-256.
[Sysname-cloudsec-policy-abcd] cipher-suite gcm-aes-256
cloudsec policy
display cloudsec local
Use display cloudsec local to display local CloudSec information.
display cloudsec local [ ipv4-address | ipv6-address ]
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
If you do not specify an IPv4 or IPv6 address, this command displays all local CloudSec information.
# Display local CloudSec information.
<Sysname> display cloudsec local
Local address 1.1.1.1
      Current SA  : AN 1
      Previous SA : AN N/A
Local address 3.3.3.3
      Current SA  : AN 1
# Display CloudSec information for the address at 1.1.1.1 at the local end.
<Sysname> display cloudsec local 1.1.1.1
      Current SA  : AN 1
Local address
Local address.
Current SA
The current SA in use for the security channel.
If this information is unavailable, the AN field displays N/A.
Previous SA
The previous SA used for the secure channel.
AN
SA number.
display cloudsec peer
Use display cloudsec peer to display peer CloudSec information.
display cloudsec peer [ ipv4-address | ipv6-address ] [ verbose ]
ipv4-address: Specifies a peer by its IPv4 address.
ipv6-address: Specifies a peer by its IPv6 address.
verbose: Displays detailed information about CloudSec peers. If you do not specify this keyword, the command displays brief information about CloudSec peers.
If you do not specify an IPv4 or IPv6 address, this command displays all peer CloudSec information.
# Display brief information about the CloudSec peer at 2.2.2.2.
<Sysname> display cloudsec peer 2.2.2.2
Peer address 2.2.2.2
  Active policy       : PL01
  TunnelNo                  : 1
# Display detailed information about the CloudSec peer at 2.2.2.2.
<Sysname> display cloudsec peer 2.2.2.2 verbose
  TunnelNo                     : 1
  Included SCI              : No
  Cipher suite              : GCM-AES-128
  SAK rekey interval        : 1800s
  Tx secure channel:
    SCI         : 000C292179BC0004
    Current SA  : AN 1
Peer address
Address of the peer.
Active policy
The CloudSec policy that has been applied to a peer and is in effect. The command does not display this field if the peer does not have an effective CloudSec policy.
TunnelNo
Number of the VXLAN tunnel protected by the CloudSec peer.
Included SCI
Whether the device sends CloudSec protected packets with the transmit SCI value included in the SecTAG field.
Cipher suite
Cipher suite for packet encryption:
·     GCM-AES-128.
·     GCM-AES-256.
·     GCM-AES-XPN-128.
·     GCM-AES-XPN-256.
SAK rekey interval
SAK rekey interval.
Tx secure channel
Secure channel information for sending packets.
SCI
SCI information.
Current SA
AN
SA number.
cloudsec peer
display cloudsec policy
Use display cloudsec policy to display CloudSec policies.
display cloudsec policy [ name policy-name ]
name policy-name: Specifies a CloudSec policy by its name. The policy-name argument represents the policy name, a case-sensitive string of 1 to 16 characters. If you do not specify a policy, the command displays all CloudSec policies.
# Display all CloudSec policies.
<Sysname> display cloudsec policy
PolicyName     : Policy-1
  Included SCI              : No
PolicyName     : Policy-2
  Included SCI              : No
# Display the CloudSec policy for peer 2.2.2.2.
<Sysname> display cloudsec policy name Policy-1
PolicyName     :Policy-1
  Included SCI              : No
PolicyName
CloudSec policy name.
Included SCI
Inclusion of the transmit SCI value in the encrypted packet.
·     No—SCI is not included.
·     Yes—SCI is included.
Cipher suite
Cipher suite:
·     GCM-AES-128.
·     GCM-AES-256.
·     GCM-AES-XPN-128.
·     GCM-AES-XPN-256.
SAK rekey interval
SAK rekey interval.
cloudsec policy
include sci
Use include sci to enable the device to send CloudSec protected packets with the transmit SCI value included in the SecTAG field.
Use undo include sci to restore the default.
include sci
undo include sci
The device does not send CloudSec protected data packets with the transmit SCI value included in the SecTAG field.
A transmit secure channel identifier (SCI) identifies the source of a packet and is manually configured.
For correct traffic forwarding through a CloudSec protected tunnel, enable or disable inclusion of the transmit SCI value in the SecTAG field on both ends of the tunnel. Do not enable the feature at one end and disable it at the other end.
# In CloudSec policy abcd, configure the device to include the SCI value in the SecTAG field of encrypted packets sent to peers.
[Sysname-cloudsec-policy-abcd] include sci
cloudsec policy
interface-peer/peer advertise-cloudsec
Use peer advertise-cloudsec or interface-peer advertise-cloudsec to configure the device to advertise CloudSec encryption information to a peer or peer group.
Use undo peer advertise-cloudsec or undo interface-peer advertise-cloudsec to remove a peer or peer group from the list of CloudSec encryption information recipients.
In BGP IPv4 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-cloudsec
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-cloudsec
In BGP IPv6 unicast address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-cloudsec
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-cloudsec
In BGP IPv4 unicast address family view or BGP IPv6 unicast address family view:
interface-peer interface-type interface-number advertise-cloudsec
undo interface-peer interface-type interface-number advertise-cloudsec
The device does not advertise CloudSec encryption information to peers or peer groups.
group-name: Specifies a BGP peer group by its name, a case-sensitive string of 1 to 47 characters. The specified BGP peer group must already exist.
ipv4-address: Specifies a peer by its IPv4 address. The specified peer must already exist.
mask-length: Specifies a subnet mask length in the range of 0 to 32. If you specify a subnet, this command applies to all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address. The specified peer must already exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. If you specify a subnet, this command applies to all dynamic peers in the subnet.
link-local-address: Specifies the link-local address of the peer.
interface-type interface-number: Specifies the peer-connected interface by its type and number.
interface-peer interface-type interface-number: Indicates that the link-local address of the peer belongs to the ND entry learned for the peer on the interface specified by its type and number.
Application scenarios
CloudSec uses BGP to transmit encryption information between peers for data packet encryption during communication.
Operating mechanism
BGP conveys CloudSec encryption information in a BGP path called the Tunnel Encapsulation attribute. This attribute has a type value of 23 and contains one or more type-length-value TLV fields. The type value for CloudSec in the Tunnel Encapsulation attribute is 18. It indicates the tunnel encapsulation defined by the IANA for cloud security.
This feature uses BGP to advertise the source addresses of VXLAN tunnels as BGP unicast route prefixes to the specified peers. When BGP advertises this unicast route information, it also advertises the encryption information generated by the device to the specified peers. The peers will encrypt the packets transmitted in the CloudSec protected VXLAN tunnels to the device based on the received encryption information.
The Tunnel Encapsulation attribute is optional transitive. You must make sure the specified peers can identify the Tunnel Encapsulation attribute and the encrypted information contained in this attribute. A peer will be unable to encrypt VXLAN tunneled packets with this information if it cannot identify the Tunnel Attribute or CloudSec encryption information.
# In BGP IPv4 unicast address family view, configure the device to advertise CloudSec encryption information to peer group test.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] peer test advertise-cloudsec
keychain
Use keychain to specify a pair of keychain and CloudSec policy for a CloudSec peer.
Use undo keychain to restore the default.
keychain keychain-name policy policy-name
undo keychain
No keychain and CloudSec policy pairs apply to CloudSec peers.
CloudSec peer view
keychain-name: Specifies a keychain name, a case-sensitive string 1 63 characters.
policy policy-name: Specifies a CloudSec policy by its name. The policy-name argument represents the policy name, a case-sensitive string of 1 to 16 characters.
If the CloudSec policy specified in a keychain and CloudSec policy pair has not been created, the device uses the default CloudSec policy named default-policy for the peer. The specified CloudSec policy applies after it is created.
You can specify only one pair of keychain and CloudSec policy for a peer.
CloudSec only uses keys for a keychain and does not use authentication algorithms for the keys. The keys can be activated only after you configure authentication algorithms for them. You must configure the same key for keychains and specify an authentication algorithm for each key at both ends of the CloudSec protected tunnel. The specified authentication algorithms can be different. To configure a key for a keychain, use the key-string command. To specify an authentication algorithm for a key, use the authentication-algorithm command.
# Apply keychain abcd and CloudSec policy aa to a CloudSec peer.
[Sysname] cloudsec peer-ip 11.1.1.1
[Sysname-cloudsec-peer-11.1.1.1] keychain abcd policy aa
authentication-algorithm (Security Command Reference)
cloudsec policy
key-string (Security Command Reference)
sak-rekey-interval
Use sak-rekey-interval to set the SAK rekey interval.
Use undo sak-rekey-interval to restore the default.
sak-rekey-interval interval
SAKs do not rekey.
interval: Specifies the SAK rekey interval, in seconds. The value range is 1800 to 2592000.
A security association (SA) is an agreement negotiated by CA participants. The agreement includes a cipher suite and keys for integrity check.
A secure channel can contain multiple SAs, each with a unique key called a secure association key (SAK). An SAK is derived from the CAK to encrypt data transmitted in the secure channel. To regularly update the SAKs for enhanced key security, use this command to set a SAK rekey interval.
# Set the SAK rekey interval to 2000 seconds in CloudSec policy abcd.
[Sysname-cloudsec-policy-abcd] sak-rekey-interval 2000
cloudsec policy
sci rx
Use sci rx to set a receive SCI value for CloudSec protected packets.
Use undo sci rx to restore the default.
sci rx sci-value
undo sci rx
No receive SCI value is set for CloudSec protected packets.
CloudSec peer view.
sci-value: Specifies a receive SCI value for CloudSec protected packets. The value range is 1 to 4294967295.
A secure channel identifier (SCI) uniquely identifies a secure channel. It ensures that every pair of communicating nodes correctly identifies and verifies their secure channel, preventing unauthorized nodes from inserting or tampering with data. By using SCIs to identify secure channels, CloudSec provides enhanced data protection and security to ensure secrecy and integrity of data.
The sender inserts the SCI value in a packet based on its configuration and policy. The receiver verifies this SCI value and compares it with the preconfigured policy to determine if the packet comes from the expected secure channel.
When the device receives a CloudSec protected packet from the peer, it compares the SCI value in the packet with the local receive SCI value. If the two SCI values match, the device processes the CloudSec packet.
# In CloudSec peer view, set the receive SCI value to 10000.
[Sysname] cloudsec peer 2.2.2.2
[Sysname-cloudsec-peer-2.2.2.2] sci rx 10000
cloudsec peer
sci tx
Use sci tx to set a transmit SCI value for CloudSec protected packets.
Use undo sci tx to restore the default.
sci tx sci-value
undo sci tx
No transmit SCI value is set for CloudSec protected packets.
CloudSec peer view
sci-value: Specifies a transmit SCI value for CloudSec protected packets. The value range is 1 to 4294967295.
With SCI inclusion enabled, the device sends the specified transmit SCI value in the CloudSec protected packets sent to the peer device. Upon receipt of the packets, the peer device compares the transmit SCI value in the packets with its local receive SCI value. The peer device processes the packets only if the two SCI values match.
# In CloudSec peer view, set the transmit SCI value to 10000.
[Sysname-cloudsec-peer-2.2.2.2] sci tx 10000
cloudsec peer
