- 10-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-SSH commands
- 14-SSL commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-MFF commands
- 22-FIPS commands
- 23-MACsec commands
- 24-802.1X client commands
- 25-CloudSec commands
- 26-Microsegmentation commands
- 27-SAVI commands
- 28-Object group commands
| 01-AAA commands | 1.68 MB |
aaa authorization-cache enable
aaa authorization-cache expiry
aaa authorization-cache max-number
aaa abnormal-offline-record enable
aaa normal-offline-record enable
authen-radius-unavailable online domain
authorization lan-access radius-cache enable
authorization-attribute (ISP domain view)
display aaa authorization-cache
display aaa normal-offline-record
display aaa online-fail-record
display aaa abnormal-offline-record
if-match vpn-instance critical-microsegment
if-match vpn-instance microsegment
local-server log change-password-prompt
redirect move-temporarily enable
reset aaa abnormal-offline-record
reset aaa normal-offline-record
session-time include-idle-time
authorization-attribute (local user view/user group view)
display local-guest waiting-approval
password (device management user view)
password (network access user view)
reset local-guest waiting-approval
service-type (local user view)
snmp-agent trap enable local-server
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
data-flow-format (RADIUS scheme view)
display radius server-load statistics
display stop-accounting-buffer (for RADIUS)
include-attribute 218 vendor-id 25506
primary accounting (RADIUS scheme view)
primary authentication (RADIUS scheme view)
radius authentication-request first
radius-server authen-state-check interval
reauthentication server-select
reset radius server-load statistics
reset stop-accounting-buffer (for RADIUS)
retry stop-accounting (RADIUS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (RADIUS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
stop-accounting-packet send-force
timer quiet (RADIUS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (RADIUS scheme view)
timer tls-idle-timeout (RADIUS scheme view)
timer tls-idle-timeout (RADIUS DAE server view)
user-name-format (RADIUS scheme view)
vpn-instance (RADIUS scheme view)
data-flow-format (HWTACACS scheme view)
display stop-accounting-buffer (for HWTACACS)
primary accounting (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
reset stop-accounting-buffer (for HWTACACS)
retry stop-accounting (HWTACACS scheme view)
secondary accounting (HWTACACS scheme view)
secondary authentication (HWTACACS scheme view)
snmp-agent trap enable hwtacacs
stop-accounting-buffer enable (HWTACACS scheme view)
timer quiet (HWTACACS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer response-timeout (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
vpn-instance (HWTACACS scheme view)
display radius-server active-client
display radius-server active-user
Connection recording policy commands
AAA commands
General AAA commands
aaa author-profile
Use aaa author-profile to create an authorization profile and enter its view, or enter the view of an existing authorization profile.
Use undo aaa author-profile to delete an authorization profile.
aaa author-profile profile-name
undo aaa author-profile profile-name
No authorization profiles exist.
profile-name: Specifies the name of the authorization profile, a case-insensitive string of 1 to 31 characters.
Application scenarios
A user in an ISP domain can use the following authorization attributes:
· Attributes assigned by the server.
· Attributes configured in the authentication domain.
· Attributes defined in the authorization profile applied to the authentication domain.
The priorities of the attributes are in descending order.
An authorization profile defines a set of authorization attributes and can be used to authorize network resources on a VPN basis, for example, assigning different microsegments to different VPN users. If you apply an authorization profile to an authentication domain, all users in the domain can obtain network resources defined in the profile.
You can configure a maximum of 16 authorization profiles.
Deleting or changing an authorization profile does not affect users that are using the profile. The configuration change takes effect only on new clients that come online afterward.
# Create authorization profile abc and enter its view.
[Sysname] aaa author-profile abc
[Sysname-author-profile-abc]
display aaa author-profile
aaa authorization-cache acl
Use aaa authorization-cache acl to specify the aging time of authorization information cache entries for AAA users matching the specified ACL.
Use undo aaa authorization-cache acl to restore the default.
aaa authorization-cache acl acl-number expiry expiry-time
The aging time is determined by the configuration of the aaa authorization-cache expiry command.
acl-number: Specifies an ACL by its number in the range of 4000 to 4999.
expiry expiry-time: Specifies the aging time in the range of 0 to 2147483647 in hours. Setting this value to 0 indicates that the authorization information cache entries never age.
Operating mechanism
When a user goes offline, the device starts an aging timer for the cached authorization information. If the user's MAC address is allowed in the configured ACL rules, the timer uses the aging time set by this command. If the MAC address is not allowed in the ACL, the device's aging timer uses the value configured by the aaa authorization-cache expiry command.
If a user goes offline and does not reconnect, and the configured aging time is 0, the user's authorization cache information might remain stale. In this case, you can use the display aaa authorization-cache command to check the residual cache entries and the reset aaa authorization-cache command to clear them.
The configuring aging time does not affect existing authorization information cache entries.
You can execute this command multiple times to configure up to 16 ACLs.
In an M-LAG network, make sure the configurations on both devices are consistent.
# Specify the aging time of authorization information cache entries to 10 hours for AAA users matching ACL 4000.
[Sysname] aaa authorization-cache acl 4000 expiry 10
Use aaa authorization-cache enable to enable authorization information cache for AAA users.
Use undo authorization-cache enable to disable authorization information cache for AAA users.
undo aaa authorization-cache enable
Authorization information cache is disabled for AAA users.
This feature enables the system to record and query specific authorization information cache of users during the authentication process in each ISP domain. After you disable this feature, the system stops recording and querying user authorization information cache and deletes existing authorization information cache entries.
To view the authorization information cache for AAA users, execute the display aaa authorization-cache command.
# Enable authorization information cache for AAA users.
[Sysname] aaa authorization-cache enable
Use aaa authorization-cache expiry to specify the aging time of authorization information cache entries.
Use undo aaa authorization-cache expiry to restore the default.
aaa authorization-cache expiry expiry-time
The aging time of authorization information cache entries is 336 hours.
expiry expiry-time: Specifies the aging time in the range of 0 to 2147483647 hours.
When a user goes offline, the device starts the aging timer for the corresponding authorization information cache entry. If the user does not come online again through RADIUS authentication before the timer expires, the device deletes the entry.
# Set the aging time of authorization information cache entries to 10 hours.
[Sysname] aaa authorization-cache expiry 10
Use aaa authorization-cache max-number to specify the maximum number of authorization information cache entries for AAA users.
Use undo authorization-cache max-number to restore the default.
aaa authorization-cache max-number max-number
undo aaa authorization-cache max-number
The system can record a maximum of 8000 authorization information cache entries for AAA users.
max-number: Specifies the maximum number of cache entries in the range of 1 to 4294967295.
With authorization information cache enabled for AAA users, the system records user authorization information generated during the authentication process in each ISP domain. You can use this command to modify the maximum number of cache entries that can be recorded on the device. The maximum supported value is 4294967295.
If the maximum number is reached, the device stops recording new authorization information and discards the excessive information. This configuration takes effect only when authorization information cache is enabled for AAA users globally.
# Specify the maximum number of authorization information cache entries for AAA users as 10000.
[Sysname] aaa authorization-cache max-number 10000
aaa nas-id profile
Use aaa nas-id profile to create a NAS-ID profile and enter its view, or enter the view of an existing NAS-ID profile.
Use undo aaa nas-id profile to delete a NAS-ID profile.
undo aaa nas-id profile profile-name
No NAS-ID profiles exist.
profile-name: Specifies the NAS-ID profile name, a case-insensitive string of 1 to 31 characters.
Configure a NAS-ID profile to maintain NAS-ID and VLAN bindings on the device.
During RADIUS authentication, the device uses a NAS-ID to set the NAS-Identifier attribute of RADIUS packets so that the RADIUS server can identify the access location of users.
By default, the device uses the device name as the NAS-ID.
# Create a NAS-ID profile named aaa and enter its view.
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa]
nas-id bind vlan
port-security nas-id-profile
portal nas-id-profile
aaa realtime-backup enable
Use aaa realtime-backup enable to enable real-time recording of AAA user associations and disassociations.
Use undo aaa realtime-backup enable to disable real-time recording of AAA user associations and disassociations.
aaa { abnormal-offline-record | normal-offline-record | online-fail-record } * realtime-backup enable
undo aaa { abnormal-offline-record | normal-offline-record | online-fail-record } * realtime-backup enable
Real-time recording of AAA user associations and disassociations is disabled.
abnormal-offline-record: Specifies recording abnormal disassociations.
normal-offline-record: Specifies recording normal disassociations.
online-fail-record: Specifies recording association failures.
In non-real-time backup mode, the AAA service module does not back up the AAA user association and disassociation records to the device.
In real-time backup mode, to avoid data loss due to process abnormalities, restarts, or master/backup switchover, the AAA service module backs up the AAA user association and disassociation records to the device in real-time.
In non-real-time backup mode, enabling real-time backup of specific AAA user association and disassociation records immediately triggers a backup of the records in the memory. Conversely, in real-time backup mode, disabling real-time backup of specific AAA user association and disassociation records deletes the corresponding backup records on the device. Therefore, if a large number of AAA user association and disassociation records exist, do not use this command to frequently switch the record backup mode as a best practice. If you do so, it may affect the device performance.
For this feature to take effect, you must first enable recording of user associations and disassociations.
# Enable real-time recording of AAA user associations and disassociations.
[Sysname] aaa online-fail-record realtime-backup enable
aaa offline-record enable
aaa online-fail-record enable
reset aaa online-fail-record
Use aaa abnormal-offline-record enable to enable user abnormal offline recording.
Use undo aaa abnormal-offline-record enable to disable user abnormal offline recording.
User abnormal offline recording is disabled.
This feature enables the system to record information about users that go offline abnormally. These records help the administrator analyze the causes and resolve the issues for abnormal user offline events. To display user abnormal offline records, use the display aaa abnormal-offline-record command.
This feature takes effect only when user offline recording is enabled.
The device can store a maximum of 32768 user abnormal offline records.
To reduce the memory usage, you can disable this feature.
# Enable user abnormal offline recording.
[Sysname] aaa abnormal-offline-record enable
Use aaa normal-offline-record enable to enable user normal offline recording.
Use undo aaa normal-offline-record enable to disable user normal offline recording.
User normal offline recording is disabled.
This feature enables the system to record information about users that go offline normally. These records help the administrator analyze causes of user offline events. To display user normal offline records, use the display aaa normal-offline-record command.
The device can store a maximum of 32768 user normal offline records.
# Enable user normal offline recording.
[Sysname] aaa normal-offline-record enable
Use aaa offline-record enable to enable user offline recording.
Use undo aaa offline-record enable to disable user offline recording.
User offline recording is disabled.
You must enable this feature so that user abnormal offline recording and user normal offline recording can take effect. Then, the system can record information about users that go offline normally and abnormally. To display user offline records, use the display aaa offline-record command.
The device can store a maximum of 65536 user offline records.
# Enable user offline recording.
[Sysname] aaa offline-record enable
Use aaa online-fail-record enable to enable user online failure recording.
Use undo aaa online-fail-record enable to disable user online failure recording.
User online failure recording is disabled.
This feature enables the system to record information about users that fail to come online. These records help the administrator identify causes of user online failures and check for malicious users. To display user online failure records, use the display aaa online-fail-record command.
The device can store a maximum of 32768 user online failure records.
# Enable user online failure recording.
[Sysname] aaa online-fail-record enable
aaa session-limit
Use aaa session-limit to set the maximum number of concurrent users that can log on to the device through the specified method.
Use undo aaa session-limit to restore the default maximum number of concurrent users for the specified login method.
In non-FIPS mode:
aaa session-limit { ftp | http | https | ssh | telnet } max-sessions
undo aaa session-limit { ftp | http | https | ssh | telnet }
In FIPS mode:
aaa session-limit { https | ssh } max-sessions
undo aaa session-limit { https | ssh }
The maximum number of concurrent users is 32 for each user type.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
telnet: Telnet users.
max-sessions: Specifies the maximum number of concurrent login users. The value range is 1 to 32 for FTP, SSH, and Telnet services, and is 1 to 64 for HTTP and HTTPS services.
After the maximum number of concurrent login users for a user type exceeds the upper limit, the system denies the subsequent users of this type.
For HTTP and HTTPS services, the number of concurrent users of an application is separately limited. For example, if the maximum number of concurrent HTTP users is 20, a maximum of 20 concurrent users are allowed for each HTTP-based application, such as RESTful, Web, and NETCONF.
# Set the maximum number of concurrent FTP users to 4.
[Sysname] aaa session-limit ftp 4
accounting command
Use accounting command to specify the command line accounting method.
Use undo accounting command to restore the default.
accounting command hwtacacs-scheme hwtacacs-scheme-name
The default accounting methods of the ISP domain are used for command line accounting.
ISP domain view
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
The command line accounting feature works with the accounting server to record valid commands that have been successfully executed on the device.
· When the command line authorization feature is disabled, the accounting server records all valid commands that have been successfully executed.
· When the command line authorization feature is enabled, the accounting server records only authorized commands that have been successfully executed.
Command line accounting can use only a remote HWTACACS server.
# In ISP domain test, perform command line accounting based on HWTACACS scheme hwtac.
[Sysname] domain test
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
accounting default
command accounting (Fundamentals Command Reference)
hwtacacs scheme
accounting default
Use accounting default to specify default accounting methods for an ISP domain.
Use undo accounting default to restore the default.
In non-FIPS mode:
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
In FIPS mode:
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
The default accounting method of an ISP domain is local.
ISP domain view
local: Performs local accounting.
none: Does not perform accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
The default accounting method is used for all users that support this method and do not have an accounting method configured.
Local accounting is only used for monitoring and controlling the number of local user connections. It does not provide the statistics function that the accounting feature generally provides.
You can specify one primary default accounting method and multiple backup default accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting default radius-scheme radius-scheme-name local none command specifies the primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
The remote accounting method is invalid in the following situations:
· The specified accounting scheme does not exist.
· The device fails to send accounting request packets.
· The device does not receive any accounting response packets from an accounting server.
The local accounting method is invalid if the device fails to find the matching local user configuration.
When the primary accounting method is local, the following rules apply:
· The device uses the backup accounting methods in sequence only if local accounting is invalid for one of the following reasons:
¡ An exception occurs in the local accounting process.
¡ The device connection is terminated or the user account is not configured on the device.
· The device does not turn to the backup accounting methods if local accounting is invalid because of any other reason. Accounting fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default accounting method and use local accounting as the backup.
[Sysname-isp-test] accounting default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
accounting lan-access
Use accounting lan-access to specify accounting methods for LAN users.
Use undo accounting lan-access to restore the default.
In non-FIPS mode:
accounting lan-access { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
accounting lan-access { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] | local [ radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
The default accounting methods of the ISP domain are used for LAN users.
ISP domain view
broadcast: Broadcasts accounting requests to servers in RADIUS schemes.
radius-scheme radius-scheme-name1: Specifies the primary broadcast RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
radius-scheme radius-scheme-name2: Specifies the backup broadcast RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
You can specify one primary accounting method and multiple backup accounting methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
The following guidelines apply to broadcast accounting:
· The device sends start-accounting, update-accounting, and stop-accounting requests to the primary accounting servers in the specified broadcast RADIUS schemes at the real-time accounting interval set in the primary broadcast RADIUS scheme. If the primary server is unavailable in a scheme, the device sends the accounting requests to the secondary servers of the scheme in the order the servers are configured.
· The accounting result is determined by the primary broadcast RADIUS scheme. The accounting result from the backup scheme is used as reference only. If the primary scheme does not return any result, the device considers the accounting as a failure.
When the primary accounting method is local, the following rules apply to the accounting of a user:
# In ISP domain test, perform local accounting for LAN users.
[Sysname-isp-test] accounting lan-access local
# In ISP domain test, perform RADIUS accounting for LAN users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting lan-access radius-scheme rd local
# In ISP domain test, broadcast accounting requests of LAN users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting lan-access broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting login
Use accounting login to specify accounting methods for login users.
Use undo accounting login to restore the default.
In non-FIPS mode:
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
In FIPS mode:
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
The default accounting methods of the ISP domain are used for login users.
ISP domain view
Accounting is not supported for FTP, SFTP, and SCP users.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting login radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
# In ISP domain test, perform local accounting for login users.
[Sysname-isp-test] accounting login local
# In ISP domain test, perform RADIUS accounting for login users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting login radius-scheme rd local
accounting default
hwtacacs scheme
local-user
radius scheme
accounting portal
Use accounting portal to specify accounting methods for portal users.
Use undo accounting portal to restore the default.
In non-FIPS mode:
accounting portal { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
accounting portal { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] | local [ radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
The default accounting methods of the ISP domain are used for portal users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the accounting portal radius-scheme radius-scheme-name local none command specifies a primary default RADIUS accounting method and two backup methods (local accounting and no accounting). The device performs RADIUS accounting by default and performs local accounting when the RADIUS server is invalid. The device does not perform accounting when both of the previous methods are invalid.
# In ISP domain test, perform local accounting for portal users.
[Sysname-isp-test] accounting portal local
# In ISP domain test, perform RADIUS accounting for portal users based on scheme rd and use local accounting as the backup.
[Sysname-isp-test] accounting portal radius-scheme rd local
# In ISP domain test, broadcast accounting requests of portal users to RADIUS servers in schemes rd1 and rd2, and use local accounting as the backup.
[Sysname-isp-test] accounting portal broadcast radius-scheme rd1 radius-scheme rd2 local
accounting default
local-user
radius scheme
accounting quota-out
Use accounting quota-out to configure access control for users that have used up their data or time accounting quotas.
Use undo accounting quota-out to restore the default.
accounting quota-out { offline | online }
The device logs off users that have used up their accounting quotas.
ISP domain view
offline: Logs off users that have used up their accounting quotas.
online: Allows users that have used up their accounting quotas to stay online.
If the server notifies the device of portal users' remaining accounting quotas, the time that the device logs out portal users that have used up their accounting quotas might be inaccurate.
# In ISP domain test, configure the device to allow users that have used up their accounting quotas to stay online.
[Sysname-isp-test] accounting quota-out online
accounting start-fail
Use accounting start-fail to configure access control for users that encounter accounting-start failures.
Use undo accounting start-fail to restore the default.
accounting start-fail { offline | online }
The device allows users that encounter accounting-start failures to stay online.
ISP domain view
offline: Logs off users that encounter accounting-start failures.
online: Allows users that encounter accounting-start failures to stay online.
# In ISP domain test, configure the device to allow users that encounter accounting-start failures to stay online.
[Sysname-isp-test] accounting start-fail online
accounting update-fail
Use accounting update-fail to configure the action to take on users after they have made the specified number of consecutive failed accounting-update attempts.
Use undo accounting update-fail to restore the default.
accounting update-fail { [ max-times max-times ] offline | online }
The device allows users to stay online after the accounting update for them has failed.
ISP domain view
max-times max-times: Specifies the maximum number of consecutive accounting-update failures allowed by the device for each user. The value range for the times argument is 1 to 255, and the default value is 1. The setting for this parameter takes effect only on portal users. Its value is fixed at 1 for other users, regardless of the setting for this parameter.
offline: Logs off users when the number of consecutive failed accounting-update attempts for them reaches the limit.
online: Allows users to stay online after the number of consecutive failed accounting-update attempts reaches the limit.
The device determines the failure of an accounting-update attempt based on the following factors:
· Maximum number of transmission attempts for a RADIUS packet (set by using the retry command).
· Real-time accounting interval (set by using the timer realtime-accounting command).
· Maximum number of real-time accounting request attempts (set by using the retry realtime-accounting command).
The following information describes the process that the device uses to determine the failure of an accounting-update failure:
Table 1 The device sends accounting request packets at real-time accounting intervals set by using the timer realtime-accounting command.
2. If the device has not received a response to a request packet when the response timeout timer expires, the device resends the request packet.
3. When the number of consecutive transmission attempts for the request reaches the limit set by using the retry command, the device determines that the real-time accounting request fails.
4. When the number of consecutive real-time accounting request failures reaches the limit set by using the retry realtime-accounting command, the device determines that an accounting-update fails.
5. The system determines the action to take upon an accounting-update failure depending on the user type:
¡ For portal users:
The system will count the failure. If the number of consecutive accounting-update failures reaches the limit set by using the accounting update-fail command, it takes the action specified by using the same command.
¡ For the other users:
The system immediately takes the action specified by using the accounting update-fail command.
# In ISP domain test, configure the device to allow users that have failed all their accounting-update attempts to stay online.
[Sysname-isp-test] accounting update-fail online
retry
authen-fail
Use authen-fail to configure the authentication failure policy for users in an ISP domain.
Use undo authen-fail to restore the default.
authen-fail { offline | online domain new-isp-name no-authen }
undo authen-fail
The device logs out users in an ISP domain if the users fail authentication.
ISP domain view
offline: Logs out users that fail authentication.
online: Enables the authen-fail online feature to allow users that fail authentication to stay online.
domain new-isp-name: Specifies an authentication-fail (auth-fail) domain to accommodate users that fail authentication. The new-isp-name argument represents the name of the auth-fail domain, a case-insensitive string of 1 to 255 characters. The specified domain must already exist. The domain name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
no-authen: Enables the user to join the auth-fail domain without reauthentication. The system will only do reauthorization and accounting for them.
By default, users cannot come online if they fail authentication. To have authentication-failed users in an authentication domain stay online and access a limited set of network resources, specify an auth-fail domain to accommodate them. In the auth-fail domain, you can specify a set of authorization and accounting schemes to assign resources to the authentication-failed users.
You cannot delete an ISP domain if it is used as the auth-fail domain for an authentication domain. To delete it, you must first execute the undo authen-fail command to remove its binding with the authentication domain.
The authen-fail online feature is available only for wired port security users.
The authen-fail online feature does not apply to users that fail authentication for one of the following reasons:
· Authentication times out, for example, because no authentication servers respond.
· The authentication ISP domain is in blocked state or is a denied domain.
# Specify ISP domain dm1 as the auth-fail domain to accommodate users that fail authentication in ISP domain test.
[Sysname-isp-test] authen-fail online domain dm1 no-authen
display domain
authen-radius-recover
Use authen-radius-recover to specify an action to take on users in the critical domain when a RADIUS server becomes available.
Use undo authen-radius-recover to restore the default.
authen-radius-recover { offline | online domain new-isp-name | re-authen }
No action is specified to take on users in the critical domain when a RADIUS server becomes available.
ISP domain view
offline: Logs off users in the critical domain.
online: Allows users in the critical domain to stay online and assigns the users to the recovery domain.
domain new-isp-name: Specifies a recovery domain to accommodate users in the critical domain when a RADIUS server becomes available. The new-isp-name argument represents the domain name, a case-insensitive string of 1 to 255 characters. The name must exist and cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
re-authen: Reauthenticates the users in the original authentication domain. This keyword is applicable only to 802.1X and MAC authentication users.
This command takes effect only on 802.1X authentication, Web authentication, and MAC authentication users.
Depending on the network requirements, specify the action to take on users in the critical domain when a RADIUS server in the users' original authentication domain becomes available.
· To perform authentication, authorization, and accounting for the users, log off the users.
· To allow the users to stay online without being authenticated, specify a recovery domain. When a RADIUS server becomes available, the users are assigned to the recovery domain from the critical domain.
· To reauthenticate users in the original authentication domain without users being aware of the process, specify the reauthentication action.
When you use the online domain new-isp-name option to specify a recovery domain, the device does not immediately assign users in the critical domain to the specified recovery domain. The device assigns these users to the recovery domain when a RADIUS server becomes available.
When you specify a recovery domain for an ISP domain, follow these restrictions and guidelines:
· If the none method is configured as the backup authentication method in the original authentication domain before the users are assigned to the critical domain, the users are still assigned to the recovery domain when a RADIUS server becomes available.
· As a best practice to accurately identify whether a RADIUS authentication server is available and the recovery configuration can take effect in time, configure RADIUS server status detection.
· To delete the ISP domain that has been specified as a recovery domain, you must first use the undo authen-radius-recover command to remove the recovery domain setting from the ISP domain.
· In the current software version, you can specify only an ISP domain as its own recovery domain in the view of the ISP domain.
# In ISP domain test, log off users in the critical domain when a RADIUS server becomes available.
[Sysname-isp-test] authen-radius-recover offline
display domain
radius-server test-profile
Use authen-radius-unavailable online domain to specify a critical domain (also known as fail-permit domain) for an ISP domain to accommodate users that access the ISP domain when all RADIUS servers are unavailable.
Use undo authen-radius-unavailable online domain to restore the default.
authen-radius-unavailable online domain new-isp-name
No critical domain is specified for an ISP domain to accommodate users that access the ISP domain when all RADIUS servers are unavailable.
ISP domain view
new-isp-name: Specifies an ISP domain name, a case-insensitive string of 1 to 255 characters. The name must exist and cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
Users in an ISP domain cannot come online correctly if no responses are received for the RADIUS authentication requests sent by the device when all RADIUS authentication servers are unavailable. To resolve this issue, specify a critical domain for this ISP domain to accommodate users that access this ISP domain when all RADIUS servers are unavailable. The users can come online in the critical domain without being authenticated when all RADIUS servers are unavailable.
Users assigned to the critical domain are removed from the critical domain only when the following requirements are met:
· A RADIUS authentication server in the original authentication domain becomes available.
· A recovery domain is specified for the original authentication domain.
When you specify a critical domain for an ISP domain, follow these restrictions and guidelines:
· If an ISP domain has been specified as a critical domain, do not specify a critical domain for that ISP domain. If you do so, the critical domain specified for that ISP domain cannot take effect.
· If a critical domain has been specified for an ISP domain, do not specify that ISP domain as a critical domain. If you do so, that ISP domain cannot act as a critical domain.
· To delete the ISP domain that has been specified as a critical domain, you must first use the undo authen-radius-unavailable online domain command to remove the critical domain setting from the ISP domain.
· If non-none authentication, authorization, or accounting methods are configured in the critical domain for an ISP domain, the non-none authentication or authorization methods cannot take effect on users. However, the non-none accounting methods in the critical domain can take effect on users. As a best practice to reduce user management cost, do not configure non-none authentication, authorization, or accounting methods in the critical domain.
# Specify critical domain dm1 to accommodate users that access ISP domain test when all RADIUS servers are unavailable.
[Sysname-isp-test] authen-radius-unavailable online domain dm1
display domain
authentication default
Use authentication default to specify default authentication methods for an ISP domain.
Use undo authentication default to restore the default.
In non-FIPS mode:
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
In FIPS mode:
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | ldap-scheme ldap-scheme-name [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | local [ ldap-scheme ldap-scheme-name ] | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
The default authentication method of an ISP domain is local.
ISP domain view
ldap-scheme ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters.
local: Performs local authentication.
none: Does not perform authentication.
The default authentication method is used for all users that support this method and do not have an authentication method configured.
You can specify one primary default authentication method and multiple backup default authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication default radius-scheme radius-scheme-name local none command specifies a primary default RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
The remote authentication method is invalid in the following situations:
· The specified authentication scheme does not exist.
· The device fails to send authentication request packets.
· The device does not receive any authentication response packets from an authentication server.
The local authentication method is invalid if the device fails to find the matching local user configuration.
When the primary authentication method is local, the following rules apply to the authentication of a user:
· The device uses the backup authentication methods in sequence only if local authentication is invalid for one of the following reasons:
¡ An exception occurs in the local authentication process.
· The device does not turn to the backup authentication methods if local authentication is invalid because of any other reason. Authentication fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default authentication method and use local authentication as the backup.
[Sysname-isp-test] authentication default radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authentication lan-access
Use authentication lan-access to specify authentication methods for LAN users.
Use undo authentication lan-access to restore the default.
In non-FIPS mode:
authentication lan-access { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
authentication lan-access { ldap-scheme ldap-scheme-name [ local ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
The default authentication methods of the ISP domain are used for LAN users.
ISP domain view
You can specify one primary authentication method and multiple backup authentication methods.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for LAN users.
[Sysname-isp-test] authentication lan-access local
# In ISP domain test, perform RADIUS authentication for LAN users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication lan-access radius-scheme rd local
ldap scheme
local-user
radius scheme
authentication login
Use authentication login to specify authentication methods for login users.
Use undo authentication login to restore the default.
In non-FIPS mode:
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
In FIPS mode:
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | ldap-scheme ldap-scheme-name [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | local [ ldap-scheme ldap-scheme-name ] | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
The default authentication methods of the ISP domain are used for login users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication login radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for login users.
[Sysname-isp-test] authentication login local
# In ISP domain test, perform RADIUS authentication for login users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication login radius-scheme rd local
hwtacacs scheme
ldap scheme
local-user
radius scheme
authentication portal
Use authentication portal to specify authentication methods for portal users.
Use undo authentication portal to restore the default.
In non-FIPS mode:
authentication portal { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
authentication portal { ldap-scheme ldap-scheme-name [ local ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
The default authentication methods of the ISP domain are used for portal users.
ISP domain view
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authentication portal radius-scheme radius-scheme-name local none command specifies the default primary RADIUS authentication method and two backup methods (local authentication and no authentication). The device performs RADIUS authentication by default and performs local authentication when the RADIUS server is invalid. The device does not perform authentication when both of the previous methods are invalid.
# In ISP domain test, perform local authentication for portal users.
[Sysname-isp-test] authentication portal local
# In ISP domain test, perform RADIUS authentication for portal users based on scheme rd and use local authentication as the backup.
[Sysname-isp-test] authentication portal radius-scheme rd local
ldap scheme
local-user
radius scheme
authentication super
Use authentication super to specify a method for user role authentication.
Use undo authentication super to restore the default.
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
The default authentication methods of the ISP domain are used for user role authentication.
ISP domain view
To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication. The device supports local and remote methods for user role authentication. For more information about user role authentication, see RBAC configuration in Fundamentals Configuration Guide.
You can specify one authentication method and one backup authentication method to use in case that the previous authentication method is invalid.
# In ISP domain test, perform user role authentication based on HWTACACS scheme tac.
[Sysname] super authentication-mode scheme
[Sysname-isp-test] authentication super hwtacacs-scheme tac
hwtacacs scheme
radius scheme
authorization command
Use authorization command to specify command authorization methods.
Use undo authorization command to restore the default.
In non-FIPS mode:
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
In FIPS mode:
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local }
The default authorization methods of the ISP domain are used for command authorization.
ISP domain view
local: Performs local authorization.
none: Does not perform authorization. The authorization server does not verify whether the entered commands are permitted by the user role. The commands are executed successfully if the user role has permission to the commands.
Command authorization restricts login users to execute only authorized commands by employing an authorization server to verify whether each entered command is permitted.
When local command authorization is configured, the device compares each entered command with the user's configuration on the device. The command is executed only when it is permitted by the authorized user role.
The commands that can be executed are controlled by both the access permission of user roles and command authorization of the authorization server. Access permission only controls whether the authorized user roles have access to the entered commands, but it does not control whether the user roles have obtained authorization to these commands. If a command is permitted by the access permission but denied by command authorization, this command cannot be executed.
You can specify one primary command authorization method and multiple backup command authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization command hwtacacs-scheme hwtacacs-scheme-name local none command specifies the default HWTACACS authorization method and two backup methods (local authorization and no authorization). The device performs HWTACACS authorization by default and performs local authorization when the HWTACACS server is invalid. The device does not perform command authorization when both of the previous methods are invalid.
The remote authorization method is invalid in the following situations:
· The specified authorization scheme does not exist.
· The device fails to send authorization request packets.
· The device does not receive any authorization response packets from an authorization server.
The local authorization method is invalid if the device fails to find the matching local user configuration.
# In ISP domain test, configure the device to perform local command authorization.
[Sysname-isp-test] authorization command local
# In ISP domain test, perform command authorization based on HWTACACS scheme hwtac and use local authorization as the backup.
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
command authorization (Fundamentals Command Reference)
hwtacacs scheme
local-user
authorization default
Use authorization default to specify default authorization methods for an ISP domain.
Use undo authorization default to restore the default.
In non-FIPS mode:
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
In FIPS mode:
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
The default authorization method of an ISP domain is local.
ISP domain view
none: Does not perform authorization. The following default authorization information applies after users pass authentication:
· Login users obtain the level-0 user role. Login users include the Telnet, FTP, SFTP, SCP, and terminal users. Terminal users can access the device through the console port. For more information about the level-0 user role, see RBAC configuration in Fundamentals Configuration Guide.
· The working directory for FTP, SFTP, and SCP login users is the root directory of the NAS. However, the users do not have permission to access the root directory.
· Non-login users can access the network.
The default authorization method is used for all users that support this method and do not have an authorization method configured.
The RADIUS authorization configuration takes effect only when the authentication method and authorization method of the ISP domain use the same RADIUS scheme.
You can specify one primary authorization method and multiple backup authorization methods.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization default radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
When the primary authorization method is local, the following rules apply to the authorization of a user:
· The device uses the backup authorization methods in sequence only if local authorization is invalid for one of the following reasons:
¡ An exception occurs in the local authorization process.
· The device does not turn to the backup authorization methods if local authorization is invalid because of any other reason. Authorization fails for the user.
# In ISP domain test, use RADIUS scheme rd as the primary default authorization method and use local authorization as the backup.
[Sysname-isp-test] authorization default radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
Use authorization lan-access to specify authorization methods for LAN users.
Use undo authorization lan-access to restore the default.
In non-FIPS mode:
authorization lan-access { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
authorization lan-access { local | radius-scheme radius-scheme-name } *
The default authorization methods of the ISP domain are used for LAN users.
ISP domain view
none: Does not perform authorization. An authenticated LAN user directly accesses the network.
The RADIUS authorization configuration takes effect only when authentication and authorization methods of the ISP domain use the same RADIUS scheme.
When the primary method is invalid, the device attempts to use the backup methods in sequence. For example, the authorization lan-access radius-scheme radius-scheme-name local none command specifies a primary RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for LAN users.
[Sysname-isp-test] authorization lan-access local
# In ISP domain test, perform RADIUS authorization for LAN users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization lan-access radius-scheme rd local
local-user
radius scheme
Use authorization lan-access radius-cache enable to enable RADIUS authorization information cache for LAN users.
Use undo authorization lan-access radius-cache enable to disable RADIUS authorization information cache for LAN users.
RADIUS authorization information cache is disabled for LAN users.
ISP domain view
Operating mechanism
With this feature enabled, when a LAN user passes RADIUS authentication and comes online in an ISP domain, the system records the authorization information returned by the RADIUS server in the authorization information cache. When the user tries to perform RADIUS authentication and come online in the same ISP domain again, if no server is available, the system queries the cached authorization information for the user. If a match is found, the system uses the cached information to perform authentication and authorization and returns authentication success to the user.
With this feature disabled, the system does not record the authorization information returned by the RADIS server for users.
For this feature to take effect, you must also enable authorization information cache for AAA users (aaa authorization-cache enable).
To use this feature, if the accounting scheme and authentication scheme are the same in the ISP domain, configure RADIUS-based remote authentication as the primary accounting method and configure no authentication as the backup accounting method, or allow users that have failed all their accounting-update attempts to stay online.
# Enable RADIUS authorization information cache for LAN users.
[Sysname-isp-test] authorization lan-access radius-cache enable
authorization login
Use authorization login to specify authorization methods for login users.
Use undo authorization login to restore the default.
In non-FIPS mode:
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
In FIPS mode:
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
The default authorization methods of the ISP domain are used for login users.
ISP domain view
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization login radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for login users.
[Sysname-isp-test] authorization login local
# In ISP domain test, perform RADIUS authorization for login users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization login radius-scheme rd local
hwtacacs scheme
local-user
radius scheme
authorization portal
Use authorization portal to specify authorization methods for portal users.
Use undo authorization portal to restore the default.
In non-FIPS mode:
authorization portal { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
In FIPS mode:
authorization portal { local | radius-scheme radius-scheme-name } *
The default authorization methods of the ISP domain are used for portal users.
ISP domain view
none: Does not perform authorization. An authenticated portal user directly accesses the network.
When the default authorization method is invalid, the device attempts to use the backup authorization methods in sequence. For example, the authorization portal radius-scheme radius-scheme-name local none command specifies the default RADIUS authorization method and two backup methods (local authorization and no authorization). The device performs RADIUS authorization by default and performs local authorization when the RADIUS server is invalid. The device does not perform authorization when both of the previous methods are invalid.
# In ISP domain test, perform local authorization for portal users.
[Sysname-isp-test] authorization portal local
# In ISP domain test, perform RADIUS authorization for portal users based on scheme rd and use local authorization as the backup.
[Sysname-isp-test] authorization portal radius-scheme rd local
local-user
radius scheme
authorization-attribute (ISP domain view)
Use authorization-attribute to configure authorization attributes for users in an ISP domain.
Use undo authorization-attribute to restore the default of an authorization attribute.
authorization-attribute { acl acl-number | author-profile profile-name | idle-cut minutes [ flow ] [ traffic { both | inbound | outbound } ] | igmp max-access-number max-access-number | ip-pool ipv4-pool-name | ipv6-pool ipv6-pool-name | microsegment microsegment-id | mld max-access-number max-access-number | redirect { deny | permit } user-agent match match-string | url url-string | user-group user-group-name | vlan vlan-id | vsi vsi-name }
undo authorization-attribute { acl | author-profile | idle-cut | igmp | ip-pool | ipv6-pool | microsegment | mld | redirect | url | user-group | vlan | vsi }
The idle cut feature is disabled.
An IPv4 user can concurrently join a maximum of four IGMP multicast groups.
An IPv6 user can concurrently join a maximum of four MLD multicast groups.
No other authorization attributes exist.
ISP domain view
acl acl-number: Specifies an ACL to filter traffic for users. The value range for the acl-number argument is 2000 to 4999. This option is applicable only to portal and LAN users. The device processes the traffic that matches the rules in the authorization ACL based on the permit or deny statement in the rules.
author-profile profile-name: Specifies the name of an authorization profile, a case-insensitive string of 1 to 31 characters. An authorization profile defines a set of authorization attributes and can be used to authorize network resources on a VPN basis. This option takes effect only on 802.1X, MAC, and Web authentication users. For Web authorization users, only the microsegments and the VPN instances defined in an authorization profile takes effect, and the VSI configuration is not supported.
idle-cut minutes: Specifies an idle timeout period in minutes. The value range for the minutes argument is 1 to 600. This option is applicable only to portal users.
flow: Specifies the minimum traffic that must be generated in the idle timeout period in bytes. The value range is 1 to 10240000, and the default value is 10240.
traffic: Specifies the traffic direction for the idle cut feature. If you do not specify this keyword, the idle cut feature applies to both traffic directions.
both: Specifies both traffic directions.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
igmp max-access-number max-access-number: Specifies the maximum number of IGMP groups that an IPv4 user can join concurrently. The value range for the max-access-number argument is 1 to 64. This option is applicable only to portal users.
ip-pool ipv4-pool-name: Specifies an IPv4 address pool for users. The ipv4-pool-name argument is a case-sensitive string of 1 to 63 characters. This option is applicable only to portal users.
ipv6-pool ipv6-pool-name: Specifies an IPv6 address pool for users. The ipv6-pool-name argument is a case-insensitive string of 1 to 63 characters. This option is applicable only to portal users.
microsegment microsegment-id: Specifies an authorization microsegment for users. The microsegment-id argument represents a microsegment ID in the range of 1 to 65535. This attribute takes effect only on 802.1X and MAC authentication users.
mld max-access-number max-access-number: Specifies the maximum number of MLD groups that an IPv6 user can join concurrently. The value range for the max-access-number argument is 1 to 64. This option is applicable only to portal users.
redirect deny: Prohibits terminals meeting the matching rules from accessing the redirect URL.
redirect permit: Allows terminals meeting the matching rules to access the redirect URL.
user-agent: Uses the user-agent field in HTTP or HTTPS requests to match the configured user terminal types.
match match-string: Specifies the rules for matching user terminal types when a user first accesses the network. The match-string argument is a case-insensitive string of 1-255 characters. Different matching rules can be separated by a vertical bar (|), where a vertical bar (|) indicates an "or" relationship between the matching rules. For example, aa|bb means either aa or bb. This option is available only for users authenticated by MAC address.
url url-string: Specifies a redirect URL for users. The url-string argument is a case-sensitive string of 1 to 255 characters. The URL must start with http:// or https://. You can configure the redirect URL attribute to push advertisements or notifications to users after the users pass authentication or push bill overdue notifications to users. This option is applicable only to LAN users.
user-group user-group-name: Specifies a user group for users. The user-group-name argument is a case-insensitive string of 1 to 32 characters. Authenticated users obtain all attributes of the user group.
vlan vlan-id: Specifies an authorization VLAN for users. The vlan-id argument represents a VLAN ID in the range of 1 to 4094. This attribute takes effect only on wired 802.1X, Web authentication, and MAC authentication users.
vsi vsi-name: Specifies an authorization VSI for users. The vsi-name represents a VSI name, a case-sensitive string of 1 to 31 characters. This attribute takes effect only on wired 802.1X and MAC authentication users.
Operating mechanism
A user in an ISP domain can use the following authorization attributes:
· Attributes assigned by the server.
· Attributes configured in the authentication domain.
The priorities of the attributes are in descending order.
When the idle cut feature is configured, the device periodically detects the traffic of each online user. The device logs out users that do not meet the minimum traffic requirement in the idle timeout period. When the idle cut feature is disabled on the device, the idle cut feature of the server takes effect. The server considers a user idle if the user's traffic is less than 10240 bytes in a configurable idle timeout period.
You can configure multiple authorization attributes for users in an ISP domain. If you execute the command multiple times with the same attribute specified, the most recent configuration takes effect.
When you specify an authorization ACL, the following restrictions apply:
· The authorization ACL is invalid if it does not exist or does not contain rules. If strict checking on authorization ACLs is enabled for portal users in this situation, portal users will be forced offline.
· Support for the VPN instance parameter in the ACL rules for LAN users depends on the device model.
· Support for the VPN instance parameter in the ACL rules for portal users depends on the device model.
· For portal users to come online after passing authentication, make sure ACLs assigned to portal users do not have rules specified with a source IP or MAC address.
To avoid user logoff caused by authorization attribute conflicts, do not assign an authorization VSI and an authorization VLAN at the same time. The conflict occurs in the following cases:
· The server authorizes a VSI through session control or CoA messages to an online user that is authorized with a VLAN at association.
· The server authorizes a VLAN through session control or CoA messages to an online user that is authorized with a VSI at association.
· The server authorizes a VSI through session control or CoA messages to an online user that uses the default authorization VLAN because no VLAN or VSI is authorized at association.
When you specify matching rules for user terminals, follow these restrictions and guidelines:
· Vertical bars (|) are used as the delimiter in matching rules and cannot be input as part of a rule.
· Do not input vertical bars (|) consecutively, such as ||, |||, or | |.
· Matching rules can include spaces, but spaces do not participate in the match and will occupy string length.
# Specify user group abc as the authorization user group for users in ISP domain test.
[Sysname-isp-test] authorization-attribute user-group abc
# Specify user group abc as the authorization user group to prohibit users using iPhone or Android terminals from accessing the redirect URL in ISP domain test.
[Sysname-isp-test] authorization-attribute redirect deny user-agent match iPhone|Andriod
display domain
default critical-microsegment
Use default critical-microsegment to specify the default critical microsegment for a critical profile.
Use undo default critical-microsegment to restore the default.
default critical-microsegment microsegment-id [ vsi vsi-name ] [ url-user-logoff ]
No default critical microsegment is specified for a critical profile.
Critical profile view
microsegment-id: Specifies a microsegment by its ID in the range of 1 to 65535.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. This option is applicable only to VXLAN networks. You can specify this option as needed.
url-user-logoff: Forcibly logs off all MAC authentication users that have been assigned with a redirect URL before accommodating users to the critical microsegment. If you do not specify this keyword, the device allows the MAC authentication users to stay online until the MAC authentication offline detection feature logs off the users. This option is applicable only to MAC authentication users.
During authentication, if all authentication servers in the ISP domain are unreachable, the device will accommodate users on a port to the critical microsegment for the critical profile applied to the port.
For users in a VPN instance, the device preferentially accommodates the users to the critical microsegment specified for the VPN instance. If no critical microsegment is specified for the VPN instance, the device accommodates the users to the default critical microsegment in the critical profile.
You can specify only one default critical microsegment for a critical profile. If you execute this command multiple times, the most recent configuration takes effect.
# Specify microsegment with ID 66 as the default critical microsegment for critical profile abc.
[Sysname] aaa critical-profile abc
[Sysname-critical-profile-abc] default critical-microsegment 66
if-match vpn-instance critical-microsegment
default microsegment
Use default microsegment to specify the default microsegment for an authorization profile.
Use undo default microsegment to restore the default.
default microsegment microsegment-id [ vsi vsi-name ]
No default microsegment is specified for an authorization profile.
Authorization profile view
The system authorizes the default microsegment to non-VPN users and VPN users that do not match any VPN instance specified by the if-match vpn-instance microsegment command.
You can specify only one default microsegment for an authorization profile. If you execute this command multiple times, the most recent configuration takes effect.
# Specify microsegment with ID 66 as the default microsegment for authorization profile abc.
[Sysname] aaa author-profile abc
[Sysname-author-profile-abc] default microsegment 66
display aaa author-profile
Use display aaa author-profile to display authorization profile information.
display aaa author-profile [ name profile-name ]
name profile-name: Specifies an authorization profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, this command displays information about all authorization profiles.
# Display information about all authorization profiles.
<Sysname> display aaa author-profile
Total 2 aaa author-profiles
aaa author-profile: a
default microsegment 1 vsi 1
Total 3 match criteria.
if match vpn-instance 2 microsegment 2 vsi 2
if match vpn-instance 3 microsegment 3 vsi 3
if match vpn-instance 4 microsegment 3 vsi 4
aaa author-profile: b
Total 2 match criteria.
# Display information about authorization profile a.
<Sysname> display aaa author-profile name a
aaa author-profile |
Authorization profile name. |
default microsegment xxx vsi xxx |
Default microsegment and the corresponding VSI. |
Total xx match criteria. |
Number of VPN and microsegment bindings in the profile. |
if match vpn-instance xxx microsegment xxx vsi xxx |
VPN instance, the corresponding microsegment, and the corresponding VSI. |
aaa author-profile
display aaa authorization-cache
Use display aaa authorization-cache to display the recorded authorization information cache entries.
display aaa authorization-cache [ dot1x | mac-auth | static | web-auth ] [ mac mac-address ]
dot1x: Specifies 802.1X authentication users.
mac-auth: Specifies MAC address authentication users.
static: Specifies static users.
web-auth: Specifies web authentication users.
mac mac-address: Specifies a MAC address. The mac-address argument represents the MAC address in the H-H-H format. If you do not specify this keyword, the command displays information about all users of the specified type.
If you do not specify any parameters, the command displays all the recorded authorization information cache entries.
# Display all the recorded authorization information cache entries.
<Sysname> display aaa authorization-cache
Total cache entries: 2
Username: ias
Access type: MAC authentication
UUID: ff ff ff ff
Remaining time: 335:58:16 (hh:mm:ss)
AAA authentication method: RADIUS
Authorization VSI: N/A
Authorization microsegment ID: N/A
Authorization microsegment name: N/A
Authorization VLAN ID: 6
Authorization VLAN name: N/A
Egress VLAN ID: N/A
Egress VLAN Name(untagged): 1 5 7 9 11 13 15
Authorization ACL number: 3001
Authorization ACL name: N/A
Authorization ACL version: N/A
User MAC address: 0015-e9a6-abcd
Username: luser
Access type: 802.1X authentication
UUID: 41 41 41 41 42 42 42
Authorization VLAN ID: 2
Egress VLAN ID(tagged): 17
Egress VLAN Name: N/A
Authorization ACL number: N/A
Authorization ACL name: DACL
Authorization ACL version: IPV4
Total cache entries |
Total number of recorded authorization information cache entries. |
User MAC address |
MAC address of the user. |
Username |
Username. |
Access type |
Access type. Options include: · 802.1X authentication. · MAC authentication. · Web authentication. · Static user access. |
Remaining time |
Remaining time of the aging timer. This field displays Not expire if the entry never ages. xx:xx:xx (hh:mm:ss) represents the aging time. |
Remaining time |
Remaining time of the aging timer. This field displays Not expire if the entry never ages. xx:xx:xx (hh:mm:ss) represents the expiry time. |
UUID |
UUID information. |
AAA authentication method |
AAA authentication method used by the user to come online. Options include: · Local. · RADIUS. · TACACS. |
Authorization VSI |
Authorization VSI. If no VSI is authorized, this field displays N/A. |
Authorization microsegment ID |
Authorization microsegment ID. If no microsegment is authorized, this field displays N/A. |
Authorization microsegment name |
Name of the authorization microsegment. If no microsegment is authorized, this field displays N/A. |
Authorization VLAN ID |
Authorization VLAN ID. If no VLAN is authorized, this field displays N/A. |
Authorization VLAN name |
Name of the authorization VLAN. |
Egress VLAN ID |
ID of the authorization egress VLAN. If no egress VLAN is authorized, this field displays N/A. |
Egress VLAN Name |
Name of the authorization egress VLAN. If no egress VLAN is authorized, this field displays N/A. |
Authorization ACL number |
Number of the authorization static ACL. If no static ACL is authorized, this field displays N/A. |
Authorization ACL name |
Name of the authorization static ACL. |
Authorization ACL version |
Version of the authorization ACL. Options include IPV4, IPV6, MAC, USER, and WLAN. |
Authorization dynamic ACL name |
Name of the authorization dynamic ACL. If no dynamic ACL is authorized, this field displays N/A. |
Authorization user profile |
User profile authorized to the user. |
display aaa normal-offline-record
Use display aaa normal-offline-record to display user normal offline records.
display aaa normal-offline-record { access-type { lan-access | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] | reason-code code } * [ time begin-time end-time [ date begin-date end-date ] ] [ brief | count count ]
display aaa normal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type: Specifies users by the access type.
lan-access: Specifies LAN users, such as 802.1X users and MAC authentication users.
login: Specifies login users, such as SSH users, Telnet users, and FTP users.
portal: Specifies portal users.
domain domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters.
interface interface-type interface-number: Specifies an interface by its interface type and interface number.
ip ipv4-address: Specifies a user by its IPv4 address.
ipv6 ipv6-address: Specifies a user by its IPv6 address.
mac-address mac-address: Specifies a user by its MAC address in the format of H-H-H.
slot slot-number: Specifies an IRF member device by its member ID.
s-vlan svlan-id: Specifies an SVLAN by its VLAN ID in the range of 1 to 4094.
c-vlan cvlan-id: Specifies a CVLAN by its VLAN ID in the range of 1 to 4094.
username user-name: Specifies users using the specified username, a case-sensitive string of 1 to 253 characters.
reason-code code: Specifies a reason code. The minimum value is 1. For the detailed value range, enter a question mark (?).
fuzzy-match: Matches the username in fuzzy mode. In fuzzy mode, a user matches if the user's username includes the specified username. If you do not specify this keyword, the device matches the username in exact mode. In exact mode, a user matches if the user's username is the same as the specified username.
time: Specifies user normal offline records generated in a time range.
begin-time: Specifies the start time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59.
end-time: Specifies the end time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59.
date: Specifies a date range. If you do not specify a date range, this command displays user abnormal offline records on the current day.
begin-date: Specifies the start date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
end-date: Specifies the end date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
brief: Displays brief information about user normal offline records. If you do not specify this keyword, the command displays detailed information about user normal offline records.
count count: Specifies the number of user normal offline records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user normal offline records. This command displays the most recent user normal offline records that match the specified criteria in reverse chronological order.
If user normal offline records exist in the system, you can use this command to display the records regardless of whether user normal offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user normal offline records for all users.
The usernames that the server sends to the device might include invisible characters. For the device to display the records for users with such usernames, you must specify the fuzzy-match keyword in this command.
# Display detailed information about normal offline records for all users.
<Sysname> display aaa normal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IP address: 19.19.0.2
IPv6 address: -
User ID: 0x8000004a
User state: AUTHED
Accounting state: Accounting
Online request time: 2019/01/02 15:20:33
Offline time: 2019/02/28 15:20:56
Offline reason: User request.
Offline reason code: 1
# Display brief information about normal offline records for login users.
<Sysname> display aaa normal-offline-record access-type login brief
Username: jay
MAC address: -
IP address: 11.2.2.41
IPv6 address: -
UP IDs |
UP ID list. This field is available only when the administrator account you use has management permissions to the UPs. |
Total count |
Total number of matching user normal offline records. |
Username |
Name of a user. This field does not display anything if the system failed to obtain the username. |
Domain |
Name of the ISP domain to which the user belongs. This field does not display anything if the system failed to obtain the ISP domain. |
MAC address |
MAC address of the user. This filed displays a hyphen (-) if the system failed to obtain the MAC address. |
Access type |
Access type of the user: · MAC authentication—Access based on MAC authentication. · 802.1X—Access based on 802.1X authentication. · Web authentication—Access based on Web authentication. · Telnet—Telnet access. · FTP—FTP access. · SSH—SSH access. · Portal—Access based on portal authentication. · NETCONF over SOAP—Access through NETCONF over SOAP sessions. · NETCONF over RESTful—Access through NETCONF over RESTful sessions. · Web—Web login. · Terminal—Terminal login such as console login. |
Access UP ID |
ID of the UP through which the user accesses the network. |
Access interface |
Interface through which the user accesses the network. This field displays a hyphen (-) if the system failed to obtain the access interface. |
SVLAN/CVLAN |
SVLAN and CVLAN to which the user belongs. This field displays a hyphen (-) for the SVLAN or CVLAN in the following situations: · The user does not belong to an SVLAN. · The system failed to obtain the SVLAN or CVLAN of the user. |
IP address |
IPv4 address of the user. This field displays a hyphen (-) if the system failed to obtain the IPv4 address. |
IPv6 address |
IPv6 address of the user. This field displays a hyphen (-) if the system failed to obtain the IPv6 address. |
User ID |
Unique identifier of the user in UCM. |
User state |
User state at user disassociation: · INIT—Initialization in progress. · AUTHING—Authentication in progress. · ALLOC—Intermediate state between authentication failure and user logout. · AUTHED—Authenticated. · USER-ADDING—Result waiting, intermediate state between deploying to kernel and notifying standby interface module. · UP—Association success. · DELETING—Deletion in progress. · DELETED—Deleted. · BINDING—Binding in progress (available only for PPP MP). · REAUTH—Re-authentication process (IPoE Web user is performing authentication at Web authentication phase). · LOGOUT—Exiting the current authentication phase (IPoE Web user returns to authentication pre-domain phase from the Web authentication phase). · MODIFY—Updating user information (such as COA). |
Accounting state |
User accounting state at user disassociation: · -—No accounting configuration exists or the user has not entered accounting state. · Accounting—Accounting in progress. |
Online request time |
Time when the user requested to come online. This field is available only in normal mode. |
Offline time |
Time when the user went offline. This field is available only in normal mode. |
Offline reason |
Reason that the user went offline. This field is available only in normal mode. For more information about the reasons, see display aaa abnormal-offline-record. |
Offline reason code |
Reason code for the user offline event. This field is available only in normal mode. |
Frist online request time |
Time at which the user first initiated an online request. This field is available only in compress mode. |
Frist offline time |
Time at which the user went offline for the first time. This field is available only in compress mode. |
Frist offline reason |
Reason for the first user offline. For more information, see display aaa abnormal-offline-record. This field is available only in compress mode. |
Frist offline reason code |
Reason code for the first user offline event. This field is available only in compress mode. |
Last online request time |
Time at which the user last initiated an online request. This field is available only in compress mode. |
Last offline time |
Time at which the user last went offline. This field is available only in compress mode. |
Last offline reason |
Reason for the last user offline. For more information, see display aaa abnormal-offline-record. This field is available only in compress mode. |
Last offline reason code |
Reason code for the last user offline event. This field is available only in compress mode. |
Offline attempts from the first to the last |
Number of user offline events triggered between the first and last records. This field is available only in compress mode. |
Calling station ID |
L2TP call number. This field displays - if the number does not exist. This field is available only in PPPoL2TP scenarios. |
reset aaa normal-offline-record
display aaa online-fail-record
Use display aaa online-fail-record to display user online failure records.
display aaa online-fail-record { access-type { lan-access | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] | reason-code code } * [ time begin-time end-time [ date begin-date end-date ] ] [ brief | count count ]
display aaa online-fail-record time begin-time end-time [ date begin-date end-date ] [ brief ]
time: Specifies user online failure records generated in a time range.
brief: Displays brief information about user online failure records. If you do not specify this keyword, the command displays detailed information about user online failure records.
count count: Specifies the number of user online failure records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user online failure records. This command displays the most recent user online failure records that match the specified criteria in reverse chronological order.
If user online failure records exist in the system, you can use this command to display the records regardless of whether user online failure recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user online failure records for all users.
# Display detailed information about the most recent two online failure records for login users that use the username aaa.
<Sysname> display aaa online-fail-record username aaa access-type login count 2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: 100/-
IP address: 19.19.0.1
IPv6 address: -
User ID: 0x8000004b
User state: AUTHED
Online request time: 2019/01/02 15:20:37
Online failure reason: Authentication failed.
Online failure reason code: 17
Reply message: no user exists.
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
User ID: 0x8000004b
User state: AUTHED
# Display brief information about user online failure records generated from 2019-03-01 13:20:50 to 2019-03-02 17:20:30.
<Sysname> display aaa online-fail-record time 13:20:50 10:20:30 date 2019/3/1 2019/3/2 brief
Username: aaa
MAC address: -
IPv6 address: -
User ID: 0x8000004b
User state: Authened
Accounting state: AcctStart
# Display detailed information about user online failure records generated from 2019-03-01 13:20:50 to 2019-03-02 17:20:30.
<Sysname> display aaa online-fail-record time 13:20:50 17:20:30 date 2019/3/1 2019/3/2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
User ID: 0x8000004b
User state: AUTHED
Online request time: 2019/03/02 16:20:33
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
User ID: 0x8000004c
User state: AUTHED
Online request time: 2019/03/01 15:20:51
Online failure reason code: 135
Table 5 Command output
UP IDs |
Total count |
Total number of matching user online failure records. |
Username |
Domain |
MAC address |
MAC address of the user. This filed displays a hyphen (-) if the system failed to obtain the user's MAC address. |
Access type |
Access UP ID |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
User ID |
User state |
Accounting state |
Time when the user requested to come online. |
Online failure reason |
Reason that the user failed to come online. For more information about the reasons, see display aaa abnormal-offline-record. |
Reason code for the user disassociation. |
Online failure reason code |
Reason code for the user online failure. This field is available only in normal mode. |
Frist online failure reason |
Reason for the first user online failure. For more information, see display aaa abnormal-offline-record. This field is available only in compress mode. |
Frist online failure reason code |
Reason code for the first user online failure. This field is available only in compress mode. |
Last online failure reason |
Reason for the last user online failure. For more information, see display aaa abnormal-offline-record. This field is available only in compress mode. |
Last online failure reason code |
Reason code for the last user online failure. This field is available only in compress mode. |
Online failures from the first to the last |
Number of user online failures triggered between the first and last records. This field is available only in compress mode. |
reset aaa online-fail-record
Use display aaa abnormal-offline-record to display user abnormal offline records.
display aaa abnormal-offline-record { access-type { lan-access | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] | reason-code code } * [ time begin-time end-time [ date begin-date end-date ] ] [ brief | count count ]
display aaa abnormal-offline-record offline-reason { idle-cut | quota-out | realtime-acct-fail | session-timeout | user-detect-fail } [ brief ]
display aaa abnormal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
offline-reason: Specifies a user offline reason.
idle-cut: Specifies the reason as session idle timeout.
quota-out: Specifies the reason as data quota out.
realtime-acct-fail: Specifies the reason as realtime accounting failure.
session-timeout: Specifies the reason as session timeout.
user-detect-fail: Specifies the reason as 802.1X user online detection failure.
time: Specifies user abnormal offline records generated in a time range.
brief: Displays brief information about user abnormal offline records. If you do not specify this keyword, the command displays detailed information about user abnormal offline records.
count count: Specifies the number of user abnormal offline records to be displayed. The value range for the count argument is 1 to 32768.
You can specify multiple query criteria to filter user abnormal offline records. This command displays the most recent user abnormal offline records that match the specified criteria in reverse chronological order.
If user abnormal offline records exist in the system, you can use this command to display the records regardless of whether user abnormal offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user abnormal offline records for all users.
# Display detailed information about abnormal offline records for all users.
<Sysname> display aaa abnormal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: SSH
SVLAN/CVLAN: -/-
IPv6 address: -
User ID: 0x8000004a
User state: AUTHED
Offline reason: User disconnected from the server.
Offline reason code: 763
# Display brief information about abnormal offline records for login users.
<Sysname> display aaa abnormal-offline-record access-type login brief
Username: jay
MAC address: -
IPv6 address: -
Table 6 Command output
UP IDs |
Total count |
Total number of matching user abnormal offline records. |
Username |
Domain |
MAC address |
Access type |
Access type of the user: · MAC authentication—Access based on MAC authentication. · 802.1X—Access based on 802.1X authentication. · Web authentication. · Telnet—Telnet access. · FTP—FTP access. · SSH—SSH access. · Portal—Access based on portal authentication. · NETCONF over SOAP—Access through NETCONF over SOAP sessions. · NETCONF over RESTful—Access through NETCONF over RESTful sessions. · Web—Web login. · Terminal—Terminal login such as console login. |
Access UP ID |
Access interface |
SVLAN/CVLAN |
IP address |
User ID |
User state |
Accounting state |
IPv6 address |
Offline time |
Time when the user went offline. |
Offline reason |
Reason that the user went offline. For more information about the reasons, see Table 7. |
Reason for the first user offline. For more information, see Table 7. This field is available only in compress mode. |
Last offline time |
Reason for the last user offline. For more information, see Table 7. This field is available only in compress mode. |
Table 7 shows user online failure reasons and user offline reasons. Support for the reasons depends on the device model.
Table 7 User online failure reasons and user offline reasons
Reason |
Lost carrier. |
The physical link went down. |
Lost service. |
The service that the user requested is not supported. |
NAS error. |
An error occurred on the device. |
NAS reboot. |
The device rebooted. |
Admin reboot. |
The administrator rebooted the device. |
Process exit. |
The access process exited. |
NAS request. |
The device requested to log out the user. |
Cut command. |
The administrator manually logged out the user at the CLI. |
Logged off by the RADIUS server. |
The RADIUS server logged out the user. |
User request. |
The user requested to go offline. |
Authentication failed |
Authentication failed. |
Authorization failed. |
Start accounting failed. |
The device failed to start accounting for the user. |
No AAA response during authentication. |
The device did not receive a response from the remote authentication server within the authentication timeout time. |
RADIUS authentication rejected. |
The user failed RADIUS authentication because the username or password was inconsistent with that on the RADIUS server. |
AAA authorization information invalid. |
The authorization information was invalid or the device did not have configuration of the authorized items. |
No AAA response for accounting start. |
The device did not receive a response for the start-accounting request sent to the remote server within the start-accounting timeout time. |
Authentication request to AAA failed. |
The device failed to send the authentication request to the RADIUS server because the route between the device and the RADIUS server is unreachable. |
Accounting request to AAA failed. |
The device failed to send the accounting request to the RADIUS server because the route between the device and the RADIUS server is unreachable. |
TACACS authentication rejected. |
The user failed HWTACACS authentication because the username or password was inconsistent with that on the HWTACACS server. |
Authentication method error. |
The authentication method of the user was inconsistent with the authentication method configured on the access interface. |
No AAA response for accounting stop. |
The device did not receive a response for the stop-accounting request sent to the server. |
The local user doesn't exist. |
The local user does not exist on the device. |
Local authentication request was rejected. |
The user failed local authentication because of incorrect password. |
IP assignment failed. |
IP address assignment for the user failed. |
Concurrent user login limit reached. |
Maximum number of concurrent local users that use the username already reached. |
NAS interface access limit reached. |
Maximum number of online users on the interface already reached. |
Maximum number of concurrent users that use this account already reached. |
Maximum number of concurrent users that use the username already reached. |
PPP negotiation terminated. |
PPP negotiation for the user failed. |
Insufficient hardware resources. |
Hardware resources were insufficient. |
Failed to obtain IPv6 prefix. |
No IPv6 prefix was available to be assigned to the user. |
No response from DHCP server. |
The device did not receive a response for the request sent to the DHCP server to apply an IP address for the user. |
DHCP IP address allocation failure. |
DHCPv6 address assignment for the user failed. Possible reasons include: · No authorization IPv6 pool is configured in the ISP domain. · The IPv6 pool is being locked. |
DHCP session conflict. |
The DHCP session to be created conflicted with an existing DHCP session. |
DHCP user request. |
The DHCP user requested to go offline. |
DHCP lease timeout. |
The allocated IP address lease of the DHCP user expired. |
DHCP declined. |
The device received a DHCP-decline packet from the DHCP user because the allocated IP address was being used by another DHCP user. |
DHCP configuration changed. |
The DHCP configuration changed. |
NAK from the DHCP server or tenant duration is 0. |
The IP address that the DHCP user requested was not on the network segment specified for IP assignment on the device or the lease duration of the address was not extended. |
IP conflict on DHCP server. |
The device detected an IP address conflict. |
DHCP server notified. |
The DHCP server instructed the device to log off the user. |
DHCP server notified, and the device deleted the user. |
The DHCP server instructed the device to log off the user and the device deleted the user. |
DHCPv6 requests with DUID mismatch. |
After the ipv6 dhcp duid-mismatch offline command is executed, the DHCPv6 server receives a DHCPv6 request message with a matching MAC but a different DUID and deletes the online user's lease. |
DHCP with dhcp user offline configured. |
After the dhcp user offline command is executed, the DHCP device receives a DHCP-DISCOVER or REBOOT-REQUEST message with the same MAC address and deletes the online user's lease. |
DHCP with the fast-renew method specified for roaming users. |
After the (ipv6)dhcp session-mismatch action fast-renew command is executed, the DHCP device receives DHCP or DHCPv6 request messages from a user whose physical location has changed but MAC address remains the same, and deletes the online user's lease. |
DHCP with dhcp conflict-ip-address offline configured. |
After the dhcp conflict-ip-address offline command is executed, the device detects a conflict between the assigned address and an online user's address and deletes the online user. |
DHCP request interface address. |
The address requested by the DHCP user is the device's interface address. |
DHCP lease release with ICMP. |
If an ICMP message detects a user address conflict, the lease is released. |
DHCP request IP is used. |
The address requested by the user is already in use. |
DHCP request info mismatch. |
The PPP user already exists in DHCP, and the user information (such as VLAN) does not match. |
DHCP request IP conflict of NDRA relogin user. |
The address requested by the NDRA user for reconnection is a conflicting address. |
DHCP reserve IP in detect subnet table. |
The placeholder address requested is already in the detect subnet table. |
DHCP reserve prefix failed due to share type conflict. |
The user's requested placeholder prefix type does not match the actual shared type of the prefix, resulting in a failed placeholder prefix request. |
DHCP reserve unshare prefix is used. |
The requested non-shared placeholder prefix is already in use. |
DHCP reserve share prefix already used by another type user. |
The requested shared placeholder prefix is already in use by another type of user. |
DHCP reserve subnet is used. |
The requested placeholder subnet segment is already in use. |
DHCP reserve subnet in detect IP table. |
The requested placeholder subnet segment is already in the detect IP table. |
DHCP reserve subnet is used by unknown source. |
The requested placeholder subnet segment is already in use by an unknown source user. |
Invalid DHCP request info, pool-group not exist. |
The address pool group requested by the user does not exist. |
DHCP temporarily not process the user request. |
The user's request has not been processed yet. |
Invalid DHCP request info, pool VPN not exist. |
The VPN configured under the address pool does not exist. |
Invalid DHCP request info, VPN mismatch. |
The VPN to which the user belongs does not match the VPN configured under the address pool. |
Invalid DHCP request info, network not exist. |
The network is not configured under the address pool requested by the user. |
Invalid DHCP request info, pool not exist. |
The address pool requested by the user does not exist. |
DHCP smooth failed, lease not exist. |
The PPP user lease smoothing failed because the DHCP module does not have the user's lease. |
DHCP reserve subnet not exist. |
The requested placeholder subnet does not exist. |
DHCP lease initialization failed. |
Lease initialization failed. |
DHCP reserve IP failed, invalid reserved ip. |
The requested placeholder address is invalid. |
DHCP PPP online failed, request lease failed. |
The PPP user's lease application failed, resulting in a failure to come online. |
DHCP delete user, VT interface deactive. |
Upon receiving the deactive event from the virtual template interface, DHCP deletes users under that interface. |
DHCP proxy entry timeout. |
Proxy entry aged out and is deleted. |
DHCP delete proxy entry upon NAK. |
Upon receiving a DHCP-NAK packet, the relay deletes the proxy entry. |
DHCP delete proxy entry. |
The proxy entry is deleted. |
DHCP delete MAC-port entry. |
The MAC-port entry is deleted. |
DHCP delete timeout MAC-port entry. |
The MAC-port entry aged out and is deleted. |
DHCP pool-group delete. |
The address pool group to which the online address pool belongs is deleted. |
DHCP delete pool from pool-group. |
The online address pool is removed from the address pool group. |
DHCP delete pool. |
The online address pool is deleted. |
DHCP start ICMP failed. |
DHCP failed to initiate ICMP detection. |
DHCP NDRS request exceed maximum. |
NDRS has reached its maximum number of pending requests and is not accepting new ones for now. |
DHCP NDRS online timeout. |
NDRS user login timed out. |
DHCP pool locked. |
The address pool is locked. |
DHCP reserve subnet failed, subnet mask lower than network mask. |
The application for a placeholder subnet failed because the requested subnet mask is lower than the network segment's mask. |
DHCP reserve subnet failed, unusable network. |
The subnet availability check failed, causing the placeholder subnet application to be unsuccessful. |
DHCP reserve prefix failed, unusable prefix. |
The prefix pool availability check failed, leading to the unsuccessful application for a placeholder prefix. |
DHCP NDRA relogin failed, no available pool in pool-group. |
The address pool was not matched in the address pool group, causing the NDRA user's re-login to fail. |
DHCP NDRA relogin failed, lease pool not found. |
The lease's associated address pool does not exist, resulting in the NDRA user's re-login failure. |
DHCP NDRA relogin failed. |
The NDRA user failed to re-login. |
DHCP NDRA smooth failed, another address lease already exist. |
NDRA user smoothing failed: the user has a lease with inconsistent addresses. |
DHCP prefix lease initialization failed. |
Failed to initialize prefix lease. |
DHCP delete lease after another module notify. |
Other modules have instructed DHCP to delete the lease. |
DHCP NDRA smooth failed. |
NDRA user smoothing failed. |
DHCP dual NDRS backup request failed. |
For dual-active NDRS users, the backup device failed to send the address request message to the master device. |
DHCP static reserve IP failed, unsable IP. |
The application for a static placeholder address failed due to an unsuccessful address availability check. |
DHCP alloc mode error. |
The allocation mode is incorrect. |
DHCP request timeout in pool-group. |
When the PPPOE address pool group is online, a delay in processing login requests results in a login failure. |
DHCP request timeout in pool. |
If the PPPOE address pool is online and the login request is not processed in time, the login will fail. |
DHCP Cinfo refresh by detecting lease released. |
The same lease is assigned to a new user, Cinfo information is refreshed, and the original user is logged off. |
DHCPv6 REPLY packet info invalid. |
Invalid information in the DHCPv6 REPLY message leads to a failure in logging on or renewing the lease (an error code in lease time or status code). |
DHCP inform request has no response. |
Delete the temporary user created for processing the INFORM message if no INFORM reply is received. |
DHCP inform request process successfully. |
After the INFORM message is processed, the temporary user that was created is deleted. |
AM configuration error. |
The static session already exists. |
The dynamic IPoE session to be created conflicted with an existing static IPoE session. |
NAT444 failed. |
IPoE failed to collaborate with NAT444. |
The ND RS session is updated. |
The device received a new ND RS session request for the user when the user was online. |
L2TP tunnel terminated by the peer. |
The peer device terminated the L2TP tunnel. It might because the peer device determined that the user had gone offline. |
The peer did not respond to control packets. |
The peer device did not respond to the PPP control packet from the device. |
Failed to set up an L2TP session. |
An L2TP session was failed to be created. |
Repeated LCP negotiation packets. |
The device received a duplicated LCP negotiation packet. It might because the user terminated the connection and then initiated a connection again. |
Failed to assign a user rule. |
The device failed to issue a portal user rule to the user. |
COA failure. |
The device failed to process a CoA message for the user. |
Failed to update authorization information. |
The device failed to update the authorization information for the user. |
Realtime accounting request to AAA failed. |
The real-time accounting request for the user failed. |
Session timeout. |
The session of the user timed out. |
Data quota limit reached. |
The data quotas of the user were used up. |
Session idle cut. |
The device logged out of the user because the user's traffic in the idle timeout period at the specified direction is less than the specified minimum traffic. |
User online detection failure. |
The user failed online detection. |
Port was removed from VLAN. |
The access interface of the user was removed from the VLAN. |
Port error. |
A port error occurred. |
Interface down or deactive. |
The protocol of the interface went down, the link on the interface went down, or the interface was deactivated. |
VSRP status changed. |
Backup device deleted user data that is inconsistent with data on the master device. |
The backup device in the VSRP group deleted user data inconsistent with data on the master device. |
MAC address change. |
The MAC address of the user changed. |
Failed to recover AAA resources. |
The device failed to recover AAA resources for the user. |
Deleted users because of inter-card session conflict. |
The device deleted the user because sessions on different cards conflict. |
User aged out before coming online. |
The online wait timer for the user expired. |
MPU-LPU data synchronization failure. |
Inter-card data smoothing failed. |
Failed to synchronize data with DHCP server. |
The device failed to synchronize data with the DHCP server. |
Failed to synchronize data with portal server. |
The device failed to synchronize data with the portal server. |
Failed to synchronize user information with the server. |
The device failed to synchronize user data with the DHCP server. |
User recovery failure. |
User data recovery failed. |
Failed to obtain physical information. |
The device failed to obtain physical information of the user. |
Authorization ACL for the online user changed. |
The authorization ACL for the user changed. |
Authorization user profile for the online user changed. |
The authorization user profile for the user changed. |
Magic number check failed. |
Reauthentication failed. |
Reauthentication for the user failed. |
No AAA response during realtime accounting. |
The device did not receive a response for the real-time accounting request sent to the server. |
Portal notified. |
Portal instructed the device to log out the user. |
Invalid username or password. |
No VTY line available. |
No available VTY line because the maximum number of users that use VTY lines already reached. |
SSH server received a packet with an incorrect message authentication code. |
The message authentication code in the packet from the SSH client was incorrect. |
User disconnected from the server. |
The SSH or FTP user disconnected from the server. |
No working directory available. |
No working directory is available. |
PTY allocation failed. |
FTP server error. |
The user failed to log in to the FTP server because an error existed on the FTP server. |
Server is disabled. |
The service was disabled. |
Service type not supported. |
The type of the service that the user requested was not supported. |
RBAC denied file management operations in the login command. |
Failed to issue RBAC access permissions to the login user. |
The device failed to issue RBAC access permissions to the login user. |
NETCONF inner error. |
An internal NETCONF error occurred. |
NETCONF session was terminated by another NETCONF session. |
The NETCONF session of the user was terminated by another NETCONF session. |
Failed to allocate public network ports in a CGN network. |
Public network port allocation failed on the CGN network. |
Failed to obtain an IP address of the type specified for basic services of users. |
The user failed to obtain an IP address of the type specified for the basic services of the user. |
UserGroup configuration changed. |
The configuration of the user group changed. |
MAC conflict. |
MAC address conflict occurred. |
RedisDBM clear. |
A RedisDBM session clear operation was executed on the migration source device. |
RedisDBM conflict. |
Data conflict occurred on the migration destination device during RedisDBM data recovery. |
RedisDBM block. |
A RedisDBM session block operation was executed on the migration source device. |
Logged out by the RADIUS proxy |
The user was logged out by the RADIUS proxy. |
Logged out by the RADIUS proxy because of username change |
The user was logged out by the RADIUS proxy because the username changed. |
NAT failed to issue the user port block info to the driver. |
The port block issues information to the driver after a user comes online. If the port block fails to issue information, the user will be logged out. |
Failed to match NAT configuration. |
The device fails to find a matching NAT configuration for the user when the user was coming online or the user information was being smoothed. |
Failed to come online by using CGN because the matching NAT doesn't support port block-based NAT. |
The matching NAT configured for the user does not support port block-based NAT. |
Failover group failure. |
The failover group failed. |
Failed to get NAT instance or NAT instance configuration is not correct. |
The device failed to get NAT instance for the load-sharing user group or the NAT instance obtained is incorrect. |
The NAT address was released. |
The NAT address of the user was reclaimed. |
NAT configured with flow-triggered port block assignment doesn't support CGN. |
In the current software version, only port block-based NAT is supported for CGN. If a NAT instance is configured with flow-triggered port block assignment, the user redirected to the NAT instance will fail to come online. |
The port block will issue information to the driver after a user comes online. If the port block fails to issue information, the user will be logged out. |
Failed to come online by using CGN because of session service-location configuration matching failure. |
The device failed to find a matching failover group for processing session-based services for the user. |
Failed to obtain user group information. |
User authentication and NAT unification failed due to nat instance is sub type. |
User authentication and NAT unification failed because the NAT instance in the message is a subinstance. |
Login time beyond validity period. |
The login time is beyond the validity period of the local user. |
Maximum number of concurrent SSH users already reached. |
The number of concurrent online SSH users has reached the maximum number supported. |
Fail to add to RADIUS buffer queue |
Failed to add to the RADIUS buffer queue. |
Service-type mismatch |
Mismatching service type. |
The local user is blocked |
The local user is blocked. |
The lock flag of the local user is lock in the password control blacklist |
The lock flag of the local user is locked in the password control blacklist. |
Binding attributes mismatch |
Mismatching binding attributes. |
The ISP domain does not exist |
The ISP domain does not exist. |
The ISP domain is blocked |
The ISP domain is blocked. |
HWTACACS authorization server is unreachable or the server configuration does not exist |
The HWTACACS authorization server is unreachable or the server configuration does not exist. |
Username is empty |
The username is empty. |
No password set for the virtual terminal |
No password is set for the virtual terminal. |
User validity time expired |
The user validity period expired. |
System Error |
System error. |
Client response timed out |
Client response timed out. |
reset aaa abnormal-offline-record
display aaa offline-record
Use display aaa offline-record to display user offline records.
display aaa offline-record { access-type { lan-access | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] | reason-code code } * [ time begin-time end-time [ date begin-date end-date ] ] [ brief | count count ]
display aaa offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
time: Specifies user offline records generated in a time range.
brief: Displays brief information about user offline records. If you do not specify this keyword, the command displays detailed information about user offline records.
count count: Specifies the number of user offline records to be displayed. The value range for the count argument is 1 to 65536.
You can specify multiple query criteria to filter user offline records. This command displays the most recent user offline records that match the specified criteria in reverse chronological order.
If user offline records exist in the system, you can use this command to display the records regardless of whether user offline recording is enabled or not.
If you do not specify any parameters, this command displays detailed information about user offline records for all users.
# Display detailed information about offline records for all users.
<Sysname> display aaa offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
IPv6PD: -
User ID: 0x8000004a
User state: AUTHED
# Display brief information about offline records for login users.
<Sysname> display aaa offline-record access-type login brief
Username: jay
MAC address: -
IP address: 20.20.20.1
IPv6 address: -
IPv6 PD: -
Username: test
MAC address: -
IP address: 20.20.20.3
IPv6 address: -
IPv6 PD: -
Table 8 Command output
UP IDs |
Total count |
Total number of matching user offline records. |
Username |
Domain |
MAC address |
Access type |
Access UP ID |
Access interface |
SVLAN/CVLAN |
IP address |
IPv4 address of the user, including the disassociation time, disassociation reason, and error code. This field displays a hyphen (-) if the system failed to obtain the IPv4 address. |
IPv6 address |
IPv6 address of the user, including the disassociation time, disassociation reason, and error code. This field displays a hyphen (-) if the system failed to obtain the IPv6 address. |
Ipv6 PD |
IPv6 address prefix of the user, including the disassociation time, disassociation reason, and error code. This field displays a hyphen (-) if the system failed to obtain the IPv6 address prefix. |
User ID |
User state |
Accounting state |
Offline time |
Offline reason |
Reason code for the user disassociation. This field is available only in normal mode. |
First online request time |
First offline time |
First offline reason |
First offline reason code |
Last offline time |
reset aaa offline-record
display domain
Use display domain to display ISP domain configuration.
display domain [ isp-name ]
isp-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. If you do not specify an ISP domain, this command displays the configuration of all ISP domains.
# Display the configuration of all ISP domains.
<Sysname> display domain
Total 2 domains
Domain: system
State: Active
Default authentication scheme: Local
Default authorization scheme: Local
Default accounting scheme: Local
Accounting start failure action: Online
Accounting update failure action: Online
Accounting quota out policy: Offline
Service type: HSI
Session time: Exclude idle time
Dual-stack accounting method: Merge
Authorization attributes:
Idle cut: Disabled
IGMP access limit: 4
MLD access limit: 4
Redirect match terminal rule:
Rule: iphone|ipad
Action: permit
Authen-fail action: Offline
Authen-radius-unavailable: Not configured
Authen-radius-recover: Not configured
Temporary redirect: Disabled
Domain: dm
State: Active
Login authentication scheme: RADIUS=rad
Login authorization scheme: HWTACACS=hw
Super authentication scheme: RADIUS=rad
Command authorization scheme: HWTACACS=hw
LAN access authentication scheme: RADIUS=r4
Portal authentication scheme: LDAP=ldp
Default authentication scheme: RADIUS=rad, Local, None
Default accounting scheme: None
Service type: HSI
Session time: Include idle time
Idle cut : Enabled
Idle timeout: 2 minutes
Flow: 10240 bytes
Traffic direction: Both
IP pool: appy
ACL number: 3000
User group: ugg
IPv6 pool: ipv6pool
URL: http://test
MLD access limit: 4
Rule: iphone|ipad
Action: permit
Authen-fail action: Online in domain dm1 without authentication
Authen-radius-unavailable: Online domain dm2
Authen-radius-recover: Offline
LAN access radius cache: Enabled
Default domain name: system
Table 9 Command output
Domain |
ISP domain name. |
State |
Status of the ISP domain. |
Default authentication scheme |
Default authentication methods. |
Default authorization scheme |
Default authorization methods. |
Default accounting scheme |
Default accounting methods. |
Login authentication scheme |
Authentication methods for login users. |
Login authorization scheme |
Authorization methods for login users. |
Login accounting scheme |
Accounting methods for login users. |
Super authentication scheme |
Authentication methods for obtaining another user role without reconnecting to the device. |
Command authorization scheme |
Command line authorization methods. |
Command accounting scheme |
Command line accounting method. |
LAN access authentication scheme |
Authentication methods for LAN users. |
LAN access authorization scheme |
Authorization methods for LAN users. |
LAN access accounting scheme |
Accounting methods for LAN users. |
Portal authentication scheme |
Authentication methods for portal users. |
Portal authorization scheme |
Authorization methods for portal users. |
Portal accounting scheme |
Accounting methods for portal users. |
RADIUS |
RADIUS scheme. |
HWTACACS |
HWTACACS scheme. |
LDAP |
LDAP scheme. |
Local |
Local scheme. |
None |
No authentication, no authorization, or no accounting. |
Accounting start failure action |
Access control for users that encounter accounting-start failures: · Online—Allows the users to stay online. · Offline—Logs off the users. |
Accounting update failure max-times |
Maximum number of consecutive accounting-update failures allowed by the device for each user in the domain. |
Accounting update failure action |
Access control for users that have failed all their accounting-update attempts: · Online—Allows the users to stay online. · Offline—Logs off the users. |
Accounting quota out policy |
Access control for users that have used up their accounting quotas: · Online—Allows the users to stay online. · Offline—Logs off the users. |
Service type |
Service type of the ISP domain, including HSI, STB, and VoIP. |
Session time |
Online duration sent to the server for users that went offline due to connection failure or malfunction: · Include idle time—The online duration includes the idle timeout period. · Exclude idle time—The online duration does not include the idle timeout period. |
Dual-stack accounting method |
This field is not supported in the current software version. Accounting method for dual-stack users: · Merge—Merges IPv4 data with IPv6 data for accounting. · Separate—Separates IPv4 data from IPv6 data for accounting. |
Authorization attributes |
Authorization attributes for users in the ISP domain. |
Idle cut |
Idle cut feature status: · Enabled—The feature is enabled. The device logs off users that do not meet the minimum traffic requirements in an idle timeout period. · Disabled—The feature is disabled. It is the default idle cut state. |
Idle timeout |
Idle timeout period, in minutes. |
Flow |
Minimum traffic that a login user must generate in an idle timeout period, in bytes. |
Traffic direction |
Traffic direction for the idle cut feature: · Both. · Inbound. · Outbound. |
IP pool |
Name of the authorization IPv4 address pool. |
ACL number |
Authorization ACL for users. |
User group |
Authorization user group for users. |
IPv6 pool |
Name of the authorization IPv6 address pool for users. |
URL |
Authorization redirect URL for users. |
IGMP access limit |
Maximum number of IGMP groups that an IPv4 user is authorized to join concurrently. |
MLD access limit |
Maximum number of MLD groups that an IPv6 user is authorized to join concurrently. |
VSI name |
Authorization VSI name. |
VLAN ID |
Authorization VLAN ID. |
Microsegment ID |
Authorization microsegment ID. |
Redirect match terminal rule |
Rules for matching user terminals when authorizing a redirect URL. If the redirect parameter is not configured in the authorization-attribute command under the ISP domain, this field is not displayed. |
Rule |
Matching rule. |
Action |
The execution actions for authorization attributes include: · deny—Prohibits terminals that meet the matching rules from accessing the redirect URL. · permit—Allows terminals that meet the matching rules to access the redirect URL. |
Authen-fail action |
Authentication failure policy for users that fail authentication in the ISP domain: · Offline—Logs out the users. · Online in domain isp-name without authentication—Allows the users to stay online and assigns the users to the auth-fail domain (represented by the isp-domain argument) without reauthentication. The system will only do reauthorization and accounting for them. |
Authen-radius-unavailable |
Critical domain to accommodate users when all RADIUS authentication servers are unavailable. |
Authen-radius-recover |
Action to take on users in the critical domain when a RADIUS authentication server becomes available. · Offline—Logs off the users. · Online in domain isp-name—Allows the users to stay online in the recovery domain. · Reauthen—Reauthenticate the users in the original authentication ISP domain. |
Temporary redirect |
Status of temporary redirection. · Enabled—Temporary redirection is enabled. The HTTP/HTTPS redirection packets sent to users carry status code 302. · Disabled—Temporary redirection is enabled. The HTTP/HTTPS redirection packets sent to users carry status code 200. |
LAN access radius cache |
Enabling status of RADIUS authorization information cache for LAN users. · Enabled. · Disabled. |
display mubm record
Use display mubm record to display user MAC and UUID binding entries.
display mubm record [ mac mac-address ] [ interface interface-type interface-number | slot slot-number ] [ access-type { dot1x | mac-auth } ]
mac mac-address: Specifies a user MAC address in the format of H-H-H. If you do not specify a user MAC address, this command displays MAC and UUID binding entries for all user MAC addresses.
interface interface-type interface-number: Specifies the user's access interface by its type and number. If you do not specify an interface, this command displays MAC and UUID binding entries on all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays MAC and UUID binding entries on the master device.
access-type: Specifies the user access type. If you do not specify a user access type, this command displays MAC and UUID binding entries for all user access types.
dot1x: Specifies 802.1X authentication access.
mac-auth: Specifies MAC authentication access.
If you do not specify any parameters, this command displays all user MAC and UUID binding entries.
To help administrators identify whether a universally unique identifier (UUID) has been assigned to a user and maintain the MAC and UUID binding entries for users, use this command.
In some scenarios, administrators configure and manage MAC address and UUID binding entries for users on the authentication server, depending on the user access control policies. The binding entries will be assigned to the users after they pass authentication. The device automatically generates the MAC and UUID binding entry of a user when the user comes online and automatically deletes the binding entry when the user goes offline.
When a user's client requests the DHCP server to assign or release an IP address, the DHCP snooping module first searches for the UUID bound to the client MAC address. Then, the device replaces the value of Option 61 (client ID) in the client's DHCP packets with the UUID and forwards the DHCP packets to the DHCP server. The DHCP server will assign or reclaim an IP address based on the UUID in the received DHCP packets. UUID-based IP address assignment flexibly meets the IP address requirements of different scenarios.
# Display UUID information bound to user MAC address 0C-DA-41-1D-1E-EF.
<Sysname> display mubm record mac 0C-DA-41-1D-1E-EF
Mac Address Access Type Interface UUID
0CDA-411D-1EEF Dot1x GE1/0/1 ff ff ff ff
0CDA-411D-1EEF MAC-auth GE1/0/2 41 41 41 41 42 42 42
Table 10 Command output
Mac Address |
User MAC address. |
Access Type |
User access type: · Dot1x—802.1X authentication. · MAC-auth—MAC authentication. |
Interface through which the user accesses the device. |
UUID |
UUID bound to the user MAC address. The UUID value and format subject to the actual situation. |
domain
Use domain to create an ISP domain and enter its view, or enter the view of an existing ISP domain.
Use undo domain to delete an ISP domain.
domain isp-name
undo domain isp-name
A system-defined ISP domain exists. The domain name is system.
isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The name must meet the following requirements:
· The name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
· The name cannot be d, de, def, defa, defau, defaul, default, i, if, if-, if-u, if-un, if-unk, if-unkn, if-unkno, if-unknow, or if-unknown.
All ISP domains are in active state when they are created.
You can modify settings for the system-defined ISP domain system, but you cannot delete this domain.
An ISP domain cannot be deleted when it is the default ISP domain. Before you use the undo domain command, change the domain to a non-default ISP domain by using the undo domain default enable command.
Use short domain names to ensure that user names containing a domain name do not exceed the maximum name length required by different types of users.
# Create an ISP domain named test and enter ISP domain view.
[Sysname] domain test
display domain
domain if-unknown
state (ISP domain view)
Use domain default enable to specify the default ISP domain. Users without any domain name included in the usernames are considered in the default domain.
Use undo domain default enable to restore the default.
domain default enable isp-name
The default ISP domain is the system-defined ISP domain system.
isp-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The ISP domain must already exist.
The system has only one default ISP domain.
# Create an ISP domain named test, and configure the domain as the default ISP domain.
[Sysname-isp-test] quit
[Sysname] domain default enable test
display domain
domain
domain if-unknown
Use domain if-unknown to specify an ISP domain to accommodate users that are assigned to nonexistent domains.
Use undo domain if-unknown to restore the default.
domain if-unknown isp-name
No ISP domain is specified to accommodate users that are assigned to nonexistent domains.
The device chooses an authentication domain for each user in the following order:
1. The authentication domain specified for the access module.
2. The ISP domain in the username.
3. The default ISP domain of the device.
If the chosen domain does not exist on the device, the device searches for the ISP domain that accommodates users assigned to nonexistent domains. If no such ISP domain is configured, user authentication fails.
NOTE: Support for the authentication domain configuration depends on the access module. |
# Specify ISP domain test to accommodate users that are assigned to nonexistent domains.
[Sysname] domain if-unknown test
display domain
if-match vpn-instance critical-microsegment
Use if-match vpn-instance critical-microsegment to specify a critical microsegment for a VPN instance.
Use undo if-match vpn-instance critical-microsegment to restore the default.
if-match vpn-instance vpn-instance-name critical-microsegment microsegment-id [ vsi vsi-name ] [ url-user-logoff ]
undo if-match vpn-instance vpn-instance-name critical-microsegment
No critical microsegment is specified for a VPN instance.
Critical profile view
vpn-instance-name: Specifies an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
microsegment-id: Specifies a microsegment by its ID in the range of 1 to 65535.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. This option is applicable only to VXLAN networks. You can specify this option as needed.
url-user-logoff: Forcibly logs off all MAC authentication users that have been assigned with a redirect URL before accommodating users to the critical microsegment. If you do not specify this keyword, the device allows the MAC authentication users to stay online until MAC authentication offline detection logs off the users. This option is applicable only to MAC authentication users.
During authentication, if all authentication servers in the ISP domain are unreachable, the device will accommodate users on a port to the critical microsegment for the critical profile applied to the port.
For users in a VPN instance, the device preferentially accommodates the users to the critical microsegment specified for the VPN instance. If no critical microsegment is specified for the VPN instance, the device accommodates the users to the default critical microsegment in the critical profile.
In a critical profile, you can configure a maximum of 128 bindings of critical microsegments to VPN instances.
If you specify multiple critical microsegments for the same VPN instance, the most recent configuration takes effect.
# Specify microsegment with ID 123 for VPN instance test in critical profile abc.
[Sysname] aaa critical-profile abc
[Sysname-critical-profile-abc] if-match vpn-instance test critical-microsegment 123
default critical-microsegment
if-match vpn-instance microsegment
Use if-match vpn-instance microsegment to specify a VPN instance and microsegment binding for an authorization profile.
Use undo if-match vpn-instance microsegment to delete the specified VPN instance and microsegment binding for an authorization profile.
if-match vpn-instance vpn-instance-name microsegment microsegment-id [ vsi vsi-name ]
undo if-match vpn-instance vpn-instance-name microsegment
No VPN instance and microsegment binding exists for an authorization profile.
Authorization profile view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
If an authentication domain is applied with an authorization profile, the system assigns the default microsegment to non-VPN users in the domain, and the microsegment of the matching VPN to VPN users. If no matching VPN exists for a VPN user, the default microsegment is authorized.
For an authorization profile, you can configure a maximum of 128 VPN instance and microsegment bindings.
You can bind a VPN instance only to one microsegment but a microsegment to multiple VPN instances.
If you specify multiple authorization microsegments for the same VPN instance, the most recent configuration takes effect.
# Specify microsegment with ID 123 for VPN instance test in authorization profile abc.
[Sysname] aaa author-profile abc
[Sysname-author-profile-abc] if-match vpn-instance test microsegment 123
display aaa author-profile
local-server log change-password-prompt
Use local-server log change-password-prompt to enable password change prompt logging.
Use undo local-server log change-password-prompt to disable password change prompt logging.
Password change prompt logging is enabled.
Use this feature to enhance the protection of passwords for Telnet, SSH, HTTP, HTTPS, NETCONF over SSH, and NETCONF over SOAP users and improve the system security.
This feature enables the device to generate logs to prompt users to change their weak passwords at an interval of 24 hours and at the users' login.
A password is a weak password if it does not meet the following requirements:
· Password composition restriction configured by using the password-control composition command.
· Minimum password length restriction set by using the password-control length command.
· Password complexity checking policy configured by using the password-control complexity command.
For a NETCONF over SSH or NETCONF over SOAP user, the device also generates a password change prompt log if any of the following conditions exists:
· The current password of the user is the default password or has expired.
· The user logs in to the device for the first time or uses a new password to log in after global password control is enabled.
The device will no longer generate password change prompt logs for a user when one of the following conditions exists:
· The password change prompt logging feature is disabled.
· The user has changed the password and the new password meets the password control requirements.
· The enabling status of a related password control feature has changed so the current password of the user meets the password control requirements.
· The password composition policy or the minimum password length has changed.
You can use the display password-control command to display password control configuration. For more information about password control commands, see "Password control commands."
# Enable password change prompt logging.
[Sysname] local-server log change-password-prompt
nas-id bind vlan
Use nas-id bind vlan to bind a NAS-ID with a VLAN.
Use undo nas-id bind vlan to remove a NAS-ID and VLAN binding.
nas-id nas-identifier bind vlan vlan-id
undo nas-id nas-identifier bind vlan vlan-id
No NAS-ID and VLAN bindings exist.
NAS-ID profile view
nas-identifier: Specifies a NAS-ID, a case-sensitive string of 1 to 31 characters.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
You can configure multiple NAS-ID and VLAN bindings in a NAS-ID profile.
A NAS-ID can be bound with more than one VLAN, but a VLAN can be bound with only one NAS-ID. If you configure multiple bindings for the same VLAN, the most recent configuration takes effect.
# Bind NAS-ID 222 with VLAN 2 in NAS-ID profile aaa.
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa] nas-id 222 bind vlan 2
aaa nas-id profile
redirect move-temporarily enable
Use redirect move-temporarily enable to enable the temporary redirect feature.
Use undo redirect move-temporarily enable to disable the temporary redirect feature.
The temporary redirect feature is disabled.
ISP domain view
Typically, the device carries the redirect URL coded in JavaScript in HTTP or HTTPS responses sent to users, and the status code in the responses is 200. The users obtain the redirect URL by parsing the JavaScript codes. If the endpoint of a user (application, for example) does not support JavaScript, the user will fail to be redirected.
To resolve this issue, enable the temporary redirect feature. This feature enables the device to send HTTP or HTTPS responses with status code 302 to users so that the users can obtain the redirect URL.
This feature takes effect only on wired 802.1X and MAC authentication users authorized with a redirection URL.
If you change the temporary redirect setting, the change takes effect only on users that come online afterwards or users that are reauthorized.
# In ISP domain test, enable the temporary redirect feature.
[Sysname] domain name test
[Sysname-isp-test] redirect move-temporarily enable
display domain
Use reset aaa abnormal-offline-record to clear user abnormal offline records.
Use this command with caution. Cleared records cannot be recovered.
# Clear all user abnormal offline records.
<Sysname> reset aaa abnormal-offline-record
reset aaa authorization-cache
Use reset aaa authorization-cache to clear the recorded authorization information cache entries.
reset aaa authorization-cache [ dot1x | mac-auth | static | web-auth ] [ mac mac-address ] [ username username ]
dot1x: Specifies 802.1X authentication users.
mac-auth: Specifies MAC address authentication users.
static: Specifies static users.
web-auth: Specifies web authentication users.
mac mac-address: Specifies a MAC address. The mac-address argument represents the MAC address in the H-H-H format. If you do not specify this keyword, the command clears information about all users of the specified type.
username username: Specifies a username, a case-sensitive string of 1 to 255 characters. If you do not specify this option, the command clears the recorded authorization information cache entries for all usernames.
If you do not specify any parameters, the command clears all the recorded authorization information cache entries.
In an M-LAG network, to clear the recorded authorization information cache entries, you must execute this command on both devices.
# Clear all the recorded authorization information cache entries.
<Sysname> reset aaa authorization-cache
aaa authorization-cache enable
display aaa authorization-cache
Use reset aaa normal-offline-record to clear user normal offline records.
# Clear all user normal offline records.
<Sysname> reset aaa normal-offline-record
display aaa normal-offline-record
Use reset aaa offline-record to clear user offline records.
# Clear all user offline records.
<Sysname> reset aaa offline-record
Use reset aaa online-fail-record to clear user online failure records.
# Clear all user online failure records.
<Sysname> reset aaa online-fail-record
session-time include-idle-time
Use session-time include-idle-time to configure the device to include the idle timeout period in the user online duration sent to the server.
Use undo session-time include-idle-time to restore the default.
The device does not include the idle timeout period in the user online duration sent to the server.
ISP domain view
Whether to configure the device to include the idle timeout period in the user online duration sent to the server, depending on the accounting policy in your network. The idle timeout period is assigned to users by the authorization server after the users pass authentication. For portal users, the device includes the idle timeout period set for the online portal user detection feature in the user online duration. For more information about online detection for portal users, see portal authentication configuration in Security Configuration Guide.
If the user goes offline due to connection failure or malfunction, the user online duration sent to the server is not the same as the actual online duration.
· If the session-time include-idle-time command is used, the user's online duration sent to the server includes the idle timeout period. The online duration that is generated on the server is longer than the actual online duration of the user.
· If the undo session-time include-idle-time command is used, the user's online duration sent to the server excludes the idle timeout period. The online duration that is generated on the server is shorter than the actual online duration of the user.
# Configure the device to include the idle timeout period in the online duration sent to the server for users in ISP domain test.
[Sysname-isp-test] session-time include-idle-time
display domain
Use state to set the status of an ISP domain.
Use undo state to restore the default.
state { active | block }
undo state
An ISP domain is in active state.
ISP domain view
active: Places the ISP domain in active state to allow the users in the ISP domain to request network services.
block: Places the ISP domain in blocked state to prevent users in the ISP domain from requesting network services.
By blocking an ISP domain, you disable offline users of the domain from requesting network services. However, the online users are not affected.
# Place ISP domain test in blocked state.
[Sysname-isp-test] state block
display domain
user-address-type
Use user-address-type to specify the user address type in the ISP domain.
Use undo user-address-type to restore the default.
user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 }
No user address type is specified for the ISP domain.
ISP domain view
ds-lite: Specifies the DS-Lite address type.
ipv6: Specifies the IPv6 address type.
nat64: Specifies the NAT64 address type.
private-ds: Specifies the private-DS address type.
private-ipv4: Specifies the private IPv4 address type.
public-ds: Specifies the public-DS address type.
public-ipv4: Specifies the public IPv4 address type.
Any change to the user address type does not affect online users.
# Specify the private IPv4 address type for users in ISP domain test.
[Sysname-isp-test] user-address-type private-ipv4
display domain
Local user commands
access-limit
Use access-limit to set the maximum number of concurrent logins using the local user name.
Use undo access-limit to restore the default.
access-limit max-user-number
undo access-limit
The number of concurrent logins using the local user name is not limited.
Local user view
max-user-number: Specifies the maximum number of concurrent logins, in the range of 1 to 1024.
This command takes effect only when local accounting is configured for the local user. The command does not apply to FTP, SFTP, or SCP users. These users do not support accounting.
For this command to take effect on network access users, you also need to execute the accounting start-fail offline command in the ISP domain view.
# Set the maximum number of concurrent logins to 5 for users using the local user name abc.
[Sysname] local-user abc
[Sysname-luser-manage-abc] access-limit 5
display local-user
authorization-attribute (local user view/user group view)
Use authorization-attribute to configure authorization attributes for a local user or user group. After the local user or a local user in the user group passes authentication, the device assigns these attributes to the user.
Use undo authorization-attribute to restore the default of an authorization attribute.
authorization-attribute { acl acl-number | idle-cut minutes | ip-pool ipv4-pool-name | ipv6-pool ipv6-pool-name | session-timeout minutes | url url-string | user-role role-name | vlan vlan-id | work-directory directory-name } *
undo authorization-attribute { acl | idle-cut | ip-pool | ipv6-pool | session-timeout | url | user-role role-name | vlan | work-directory } *
The working directory for FTP, SFTP, and SCP users is the root directory of the NAS. However, the users do not have permission to access the root directory.
The device management local users created by a network-admin, system-admin, or level-15 user are assigned the network-operator user role.
Local user view
User group view
acl acl-number: Specifies an authorization ACL. The value range for the acl-number argument is 2000 to 4999. The device processes the traffic that matches the rules in the authorization ACL based on the permit or deny statement in the rules.
idle-cut minutes: Specifies an idle timeout period in minutes. The value range for the minutes argument is 1 to 120. An online user is logged out if its idle period exceeds the specified idle timeout period.
ip-pool ipv4-pool-name: Specifies an IPv4 address pool for the user. The ipv4-pool-name argument is a case-sensitive string of 1 to 63 characters.
ipv6-pool ipv6-pool-name: Specifies an IPv6 address pool for the user. The ipv6-pool-name argument is a case-insensitive string of 1 to 63 characters.
session-timeout minutes: Specifies the session timeout timer for the user, in minutes. The value range for the minutes argument is 1 to 1440. The device logs off the user after the timer expires.
url url-string: Specifies a redirect URL. The url-string argument is a case-sensitive string of 1 to 255 characters. The URL must start with http:// or https://. You can configure the redirect URL attribute to push advertisements or notifications to users after the users pass authentication or push bill overdue notifications to users. This option is applicable only to LAN users.
user-role role-name: Specifies an authorized user role. The role-name argument is a case-sensitive string of 1 to 63 characters. A maximum of 64 user roles can be specified for a user. For user role-related commands, see Fundamentals Command Reference for RBAC commands. This option is available only in local user view and is applicable only to device management users. It is not available in user group view.
vlan vlan-id: Specifies an authorized VLAN. The value range for the vlan-id argument is 1 to 4094. After passing authentication and being authorized a VLAN, a local user can access only the resources in this VLAN.
work-directory directory-name: Specifies the working directory for FTP, SFTP, or SCP users. The directory-name argument is a case-insensitive string of 1 to 255 characters. The directory must already exist.
Configure authorization attributes according to the application environments and purposes. Support for authorization attributes depends on the service types of users.
For portal users, only the following authorization attributes take effect: acl, ip-pool, ipv6-pool, and session-timeout.
For LAN users, only the following authorization attributes take effect: acl, session-timeout, url, and vlan.
For SSH, Telnet, and terminal users, only the authorization attributes idle-cut and user-role take effect.
For HTTP and HTTPS users, only the authorization attribute user-role takes effect.
For FTP users, only the authorization attributes user-role and work-directory take effect.
For other types of local users, no authorization attribute takes effect.
Authorization attributes configured for a user group are intended for all local users in the group. You can group local users to improve configuration and management efficiency. An authorization attribute configured in local user view takes precedence over the same attribute configured in user group view.
When you specify an authorization ACL, the following restrictions apply:
· The authorization ACL is invalid if it does not exist or does not contain rules. If strict checking on authorization ACLs is enabled for portal users in this situation, portal users will be forced offline.
· For LAN users, if an assigned ACL rule contains a VPN instance, the ACL rule does not take effect. If no VPN instance is specified, the ACL rule applies to both VPN and public traffic.
· For portal users, if an assigned ACL rule contains a VPN instance, the ACL rule does not take effect. If no VPN instance is specified, the ACL rule applies to both VPN and public traffic.
· For portal users to come online after passing authentication, make sure ACLs assigned to portal users do not have rules specified with a source IP or MAC address.
To make sure FTP, SFTP, and SCP users can access the directory after an IRF master/subordinate switchover, do not specify slot information for the working directory.
To make sure the user have only the user roles authorized by using this command, use the undo authorization-attribute user-role command to remove the default user role.
The security-audit user role has access to the commands for managing security log files and security log file system. To display all the accessible commands of the security-audit user role, use the display role name security-audit command. For more information about security log management, see Network Management and Monitoring Configuration Guide. For more information about file system management, see Fundamentals Configuration Guide.
You cannot delete a local user if the local user is the only user that has the security-audit user role.
The security-audit user role is mutually exclusive with other user roles.
· When you assign the security-audit user role to a local user, the system requests confirmation for deleting all the other user roles of the user.
· When you assign other user roles to a local user that has the security-audit user role, the system requests confirmation for deleting the security-audit user role for the local user.
The system-admin, security-admin, and audit-admin user roles are mutually exclusive in a user account. In addition, these user roles are mutually exclusive with other user roles in a user account.
When you assign user roles to a user, the system prompts you to confirm the deletion of the user roles that are mutually exclusive with the new user roles.
# Configure the authorized VLAN of network access user abc as VLAN 2.
[Sysname] local-user abc class network
[Sysname-luser-network-abc] authorization-attribute vlan 2
# Configure the authorized VLAN of user group abc as VLAN 3.
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
# Assign the security-audit user role to device management user xyz as the authorized user role.
[Sysname] local-user xyz class manage
[Sysname-luser-manage-xyz] authorization-attribute user-role security-audit
This operation will delete all other roles of the user. Are you sure? [Y/N]:y
display local-user
display user-group
bind-attribute
Use bind-attribute to configure binding attributes for a local user.
Use undo bind-attribute to remove binding attributes of a local user.
bind-attribute { ip ip-address | location interface interface-type interface-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { ip | location | mac | vlan } *
No binding attributes are configured for a local user.
Local user view
ip ip-address: Specifies the IP address to which the user is bound. This option applies only to 802.1X users.
location interface interface-type interface-number: Specifies the interface to which the user is bound. The interface-type argument represents the interface type, and the interface-number argument represents the interface number. To pass authentication, the user must access the network through the bound interface. This option applies only to device management, LAN, and portal users.
mac mac-address: Specifies the MAC address of the user in the format H-H-H. This option applies only to LAN and portal users.
vlan vlan-id: Specifies the VLAN to which the user belongs. The vlan-id argument is in the range of 1 to 4094. This option applies only to LAN and portal users.
To perform local authentication of a user, the device matches the actual user attributes with the configured binding attributes. If the user has a non-matching attribute or lacks a required attribute, the user will fail authentication.
Binding attribute check takes effect on all access services. Configure the binding attributes for a user based on the access services and make sure the device can obtain all attributes to be checked from the user's packet. For example, you can configure an IP address binding for an 802.1X user, because 802.1X authentication can include the user's IP address in the packet. However, you cannot configure IP address bindings for MAC authentication users, because MAC authentication does not use IP addresses.
The binding interface type must meet the requirements of the local user. Configure the binding interface based on the service type of the user.
· If the user is an 802.1X user, specify the 802.1X-enabled Layer 2 Ethernet interface or Layer 2 aggregate interface.
· If the user is a MAC authentication user, specify the MAC authentication-enabled Layer 2 Ethernet interface or Layer 2 aggregate interface.
· If the user is a Web authentication user, specify the Web authentication-enabled Layer 2 Ethernet interface.
· If the user is a portal user, specify the portal-enabled interface. Specify the user-attached Layer 2 Ethernet interface if portal is enabled on a VLAN interface and the portal roaming enable command is not configured.
# Bind MAC address 11-11-11 with network access user abc.
[Sysname-luser-network-abc] bind-attribute mac 11-11-11
display local-user
company
Use company to specify the company of a local guest.
Use undo company to restore the default.
company company-name
undo company
No company is specified for a local guest.
Local guest view
company-name: Specifies the company name, a case-sensitive string of 1 to 255 characters.
# Specify company yyy for local guest abc.
[Sysname] local-user abc class network guest
[Sysname-luser-network(guest)-abc] company yyy
display local-user
description
Use description to configure a description for a network access user.
No description is configured for a network access user.
Network access user view
text: Configures a description, case-sensitive string of 1 to 255 characters.
# Configure a description for network access user 123.
[Sysname] local-user 123 class network
[Sysname-luser-network-123] description Manager of MSC company
display local-user
display local-guest waiting-approval
Use display local-guest waiting-approval to display pending registration requests for local guests.
display local-guest waiting-approval [ user-name user-name ]
user-name user-name: Specifies a local guest by the user name, a case-sensitive string of 1 to 55 characters. The user name must meet the following requirements:
· Cannot contain a domain name.
· Cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
· Cannot be a, al, or all.
If you do not specify a guest, this command displays pending registration requests for all local guests.
On the Web registration page, users submit local guest registration requests for approval. The guest manager can add supplementary information to the guest accounts and approves the requests. The device then creates local guest accounts based on the approved requests.
# Display all pending registration requests for local guests.
<Sysname> display local-guest waiting-approval
Total 1 guest entries matched.
Guest user Smith:
Full name : Smith Li
Company : YYY
Email : [email protected]
Phone : 139189301033
Description: The employee of YYY company
Table 11 Command output
Total 1 guest entries matched. |
Number of local guests that have pending registration requests. |
Full name |
Full name of the local guest. |
Company |
Company name of the local guest. |
Email address of the local guest. |
Phone |
Phone number of the local guest. |
Description of the local guest. |
reset local-guest waiting-approval
display local-user
Use display local-user to display the local user configuration and online user statistics.
display local-user [ class { manage | network [ guest ] } | idle-cut { disable | enable } | service-type { ftp |http | https | lan-access | portal | ssh | telnet | terminal } | state { active | block } | user-name user-name class { manage | network [ guest ] } | vlan vlan-id ]
class: Specifies the local user type.
manage: Device management user.
network: Network access user.
guest: Guest user account.
idle-cut { disable | enable }: Specifies local users by the status of the idle cut feature.
service-type: Specifies the local users that use a specific type of service.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
lan-access: LAN users that typically access the network through an Ethernet, such as 802.1X users.
portal: Portal users.
ssh: SSH users.
telnet: Telnet users.
terminal: Terminal users that log in through console ports.
state { active | block }: Specifies local users in active or blocked state. A local user in active state can access network services, but a local user in blocked state cannot.
user-name user-name: Specifies all local users using the specified username. The username must be a case-sensitive string of 1 to 55 characters. The name must meet the following requirements:
· Cannot contain the domain name.
vlan vlan-id: Specifies all local users in a VLAN. The vlan-id argument is in the range of 1 to 4094.
If you do not specify any parameters, this command displays information about all local users.
# Display information about all local users.
<Sysname> display local-user
Total 2 local users matched.
Device management user root:
State: Active
Service type: SSH/Telnet/Terminal
Access limit: Enabled Max access number: 3
Current access number: 1
User group: system
Bind attributes:
Work directory: flash:
User role list: network-admin
Password aging: 3 days
Password complexity: username checking
repeated characters checking
adjacent characters checking
Password history was last reset: 0 days ago
Network access user jj:
State: Active
Service type: LAN-access
User group: system
Bind attributes:
IP address: 2.2.2.2
Location bound: GigabitEthernet1/0/1
MAC address: 0001-0001-0001
VLAN ID: 2
Idle timeout: 33 minutes
ACL number: 2000
User role list: network-operator, level-0, level-3
Description: A network access user from company cc
Validity period:
Start date and time: 2016/01/01-00:01:01
Expiration date and time: 2017/01/01-01:01:01
Password length: 4 characters
Network access guest user1:
State: Active
Service type: LAN-access/Portal
User group: guest1
Full name: Jack
Company: cc
Email: [email protected]
Phone: 131129237
Sponsor full name: Sam
Sponsor department: security
Sponsor email: [email protected]
Description: A guest from company cc
Validity period:
Start date and time: 2016/04/01-08:00:00
Expiration date and time: 2017/04/03-18:00:00
Table 12 Command output
State |
Status of the local user: active or blocked. |
Service type |
Service types that the local user can use. |
Access limit |
Whether the concurrent login limit is enabled. |
Max access number |
Maximum number of concurrent logins using the local user name. |
Current access number |
Current number of concurrent logins using the local user name. |
User group |
Group to which the local user belongs. |
Bind attributes |
Binding attributes of the local user. |
IP address |
IP address of the local user. |
Location bound |
Binding port of the local user. |
MAC address |
MAC address of the local user. |
VLAN ID |
Binding VLAN of the local user. |
Authorization attributes of the local user. |
Idle timeout |
Idle timeout period of the user, in minutes. |
Session-timeout |
Session timeout timer for the user, in minutes. |
Work directory |
Directory that the FTP, SFTP, or SCP user can access. |
ACL number |
Authorization ACL of the local user. |
VLAN ID |
Authorized VLAN of the local user. |
User role list |
Authorized roles of the local user. |
IP pool |
IPv4 address pool authorized to the local user. |
IPv6 pool |
IPv6 address pool authorized to the local user. |
URL |
Authorization redirect URL for the local user. |
Password control configurations |
Password control attributes that are configured for the local user. |
Password aging |
Password expiration time. |
Password length |
Minimum number of characters that a password must contain. |
Password composition |
Password composition policy: · Minimum number of character types that a password must contain. · Minimum number of characters from each type in a password. |
Password complexity |
Password complexity checking policy: · Reject a password that contains the username or the reverse of the username. · Reject a password that contains any character repeated consecutively three or more times. · Reject a password that contains multiple characters that are horizontally adjacent on the keyboard. |
Maximum login attempts |
Maximum number of consecutive failed login attempts. |
Action for exceeding login attempts |
Action to take on the user that failed to log in after using up all login attempts. |
Password history was last reset |
The most recent time that the history password records were cleared. |
Full name |
Name of the local guest. |
Company |
Phone |
Sponsor full name |
Name of the guest sponsor. |
Sponsor department |
Department of the guest sponsor. |
Sponsor email |
Email address of the guest sponsor. |
Description of the network access user. |
Validity period |
Validity period of the network access user. |
Start date and time |
Date and time from which the network access user begins to take effect. |
Expiration date and time |
Date and time at which the network access user expires. |
display user-group
Use display user-group to display user group configuration.
display user-group { all | name group-name }
all: Specifies all user groups.
name group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
# Display the configuration of all user groups.
<Sysname> display user-group all
Total 2 user groups matched.
User group: system
BYOD authorization attributes: Not configured
User group: jj
Work directory: flash:/
ACL number: 2000
VLAN ID: 2
Password aging: 2 days
Table 13 Command output
User group |
User group name. |
Authorization attributes of the user group. |
Idle timeout |
Session-timeout |
Session timeout timer, in minutes. |
Work directory |
Directory that FTP, SFTP, or SCP users in the group can access. |
ACL number |
Authorization ACL. |
VLAN ID |
Authorized VLAN. |
IP pool |
IPv4 address pool authorized to the user group. |
IPv6 pool |
IPv6 address pool authorized to the user group. |
URL |
Authorization redirect URL for the user group. |
BYOD authorization attributes |
This field is not supported in the current software version. BYOD authorization attributes of the user group. |
Password control attributes that are configured for the user group. |
Password aging |
Password length |
Use email to configure an email address for a local guest.
Use undo email to restore the default.
email email-string
undo email
No email address is configured for a local guest.
Local guest view
email-string: Specifies the email address for the local guest, a case-sensitive string of 1 to 255 characters. For example, [email protected]. The address must comply with RFC 822.
The local guest uses the email address to receive notifications from the device.
# Configure the email address as [email protected] for local guest abc.
[Sysname-luser-network(guest)-abc] email [email protected]
display local-user
full-name
Use full-name to configure the name of a local guest.
Use undo full-name to restore the default.
full-name name-string
undo full-name
No name is configured for a local guest.
Local guest view
name-string: Specifies the local guest name, a case-sensitive string of 1 to 255 characters.
# Configure the name as abc Snow for local guest abc.
[Sysname-luser-network(guest)-abc] full-name abc Snow
display local-user
group
Use group to assign a local user to a user group.
Use undo group to restore the default.
group group-name
undo group
A local user belongs to user group system.
Local user view
group-name: Specifies the user group name, a case-insensitive string of 1 to 32 characters.
# Assign device management user 111 to user group abc.
[Sysname] local-user 111 class manage
[Sysname-luser-manage-111] group abc
display local-user
local-guest email format
Use local-guest email format to configure the subject and body for the email notifications of local guest information.
Use undo local-guest email format to delete the configured subject or body for the email notifications of local guest information.
local-guest email format to { guest | manager | sponsor } { body body-string | subject sub-string }
undo local-guest email format to { guest | manager | sponsor } { body | subject }
No subject or body is configured for the email notifications of local guest information.
to: Specifies the email recipient.
guest: Specifies the local guest.
manager: Specifies the guest manager.
sponsor: Specifies the guest sponsor.
body body-string: Configures the body content. The body-string argument is a case-sensitive string of 1 to 255 characters.
subject sub-string: Configures the email subject. The sub-string argument is a case-sensitive string of 1 to 127 characters.
Email notifications need to be sent to notify the local guests, guest sponsors, or guest managers of the guest account information or guest registration requests. Use this command to configure the subject and body for the email notifications to be sent by the device.
You can configure one subject and one body for each email recipient. If you configure the subject or body content multiple times for the same recipient, the most recent configuration takes effect.
You must configure both the subject and body for each recipient.
# Configure the subject and body for the email notifications to send to the local guest.
[Sysname] local-guest email format to guest subject Guest account information
[Sysname] local-guest email format to guest body A guest account has been created for you. The username, password, and validity period of the account are given below.
local-guest email sender
local-guest email smtp-server
local-guest manager-email
local-guest send-email
Use local-guest email sender to configure the email sender address in email notifications of local guests sent by the device.
Use undo local-guest email sender to restore the default.
local-guest email sender email-address
No email sender address is configured for the email notifications of local guests sent by the device.
email-address: Specifies the email sender address, a case-sensitive string of 1 to 255 characters.
If you do not specify the email sender address, the device cannot send email notifications.
The device supports only one email sender address. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the email sender address as [email protected] for email notifications of local guests.
[Sysname] local-guest email sender [email protected]
Use local-guest email smtp-server to specify an SMTP server to send email notifications of local guests.
Use undo local-guest email smtp-server to restore the default.
local-guest email smtp-server url-string
No SMTP server is specified to send email notifications of local guests.
url-string: Specifies the path of the SMTP server, a case-sensitive string of 1 to 255 characters. The path must comply with the standard SMTP protocol and start with smtp://.
# Specify the SMTP server at smtp://www.test.com/smtp to send local guest email notifications.
[Sysname] local-guest email smtp-server smtp://www.test.com/smtp
local-guest generate
Use local-guest generate to create local guests in batch.
local-guest generate username-prefix name-prefix [ password-prefix password-prefix ] suffix suffix-number [ group group-name ] count user-count validity-datetime start-date start-time to expiration-date expiration-time
username-prefix name-prefix: Specifies the name prefix. The name-prefix argument is a case-sensitive string of 1 to 45 characters. The prefix cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
password-prefix password-prefix: Specifies a prefix for the plaintext password. The password-prefix argument is a case-sensitive string of 1 to 53 characters. If you do not specify a password prefix, the device randomly generates passwords for the local guests.
suffix suffix-number: Specifies the start suffix number of the username and password. The suffix-number argument is a numeric string of 1 to 10 digits.
group group-name: Specifies a user group by the name. The group-name argument is a case-sensitive string of 1 to 32 characters. If you do not specify a user group, the guests are assigned to the system-defined user group system.
count user-count: Specifies the number of local guests to be created. The value range for the user-count argument is 1 to 256.
validity-datetime: Specifies the validity period of the local guests.
start-date: Specifies the start date of the validity period, in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the start time of the validity period, in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
to: Specifies the end date and time of the validity period.
expiration-date: Specifies the expiration date in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
expiration-time: Specifies the expiration time in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
Account names of batch created local guests start with the same string specified by the name prefix, and end with a different number as the suffix. The system increases the start suffix number by 1 for each new local guest created in the batch.
The device generates plaintext passwords by using the password prefix and suffix number in the same way it batch creates the local guest names.
Consider the system resources when you specify the number of local guests to create. The device might fail to create all accounts for a large batch of local guests because of insufficient resources.
If a local guest to be created has the same name as an existing local guest on the device, the new guest overrides the existing guest.
# Create 20 local guests in batch with user names abc01 through abc20 for user group visit. The user accounts are effective from 2014/10/01 00:00:00 to 2015/10/02 12:00:00.
[Sysname] local-guest generate username-prefix abc suffix 01 group visit count 20 validity-datetime 2014/10/01 00:00:00 to 2015/10/02 12:00:00
local-user
display local-user
Use local-guest manager-email to configure the email address of the guest manager.
Use undo local-guest manager-email to restore the default.
local-guest manager-email email-address
No email address is configured for the guest manager.
email-address: Specifies the email address, a case-sensitive string of 1 to 255 characters. For example, [email protected]. The address must comply with RFC 822.
Use this command to specify the email address to which the device sends the local guest registration requests for approval.
# Configure the email address of the guest manager as [email protected].
[Sysname] local-guest manager-email [email protected]
Use local-guest send-email to send emails to a local guest or guest sponsor.
local-guest send-email user-name user-name to { guest | sponsor }
user-name user-name: Specifies a local guest by user name, a case-sensitive string of 1 to 55 characters. The name must meet the following requirements:
Device managers can use this command to inform local guests or guest sponsors of the guest password and validity period information.
# Send an email to notify local guest abc of the guest password and validity period information.
<Sysname> local-guest send-email user-name abc to guest
sponsor-email
local-guest timer
Use local-guest timer to set the waiting-approval timeout timer for local guests.
local-guest timer waiting-approval time-value
undo local-guest timer waiting-approval
The setting is 24 hours.
time-value: Specifies the waiting-approval timeout timer in the range of 1 to 720, in hours.
The waiting-approval timeout timer starts when the registration request of a local guest is sent for approval. If the request is not approved within the timer, the device deletes the registration request.
# Set the waiting-approval timeout timer to 12 hours.
[Sysname] local-guest timer waiting-approval 12
local-user
Use local-user to add a local user and enter its view, or enter the view of an existing local user.
Use undo local-user to delete local users.
local-user user-name [ class { manage | network [ guest ] } ]
undo local-user { user-name class { manage | network [ guest ] } | all [ service-type { ftp | http | https | lan-access | portal | ssh | telnet | terminal } | class { manage | network [ guest ] } ] }
No local users exist.
user-name: Specifies the local user name, a case-sensitive string of 1 to 55 characters. The name must meet the following requirements:
· Cannot be a, al, all, au, aut, auto, auto-, auto-d, auto-de, auto-del, auto-dele, auto-delet, or auto-delete.
class: Specifies the local user type. If you do not specify this keyword, the command adds a device management user.
manage: Device management user that can configure and monitor the device after login. Device management users can use FTP, HTTP, HTTPS, Telnet, SSH, and terminal services.
network: Network access user that accesses network resources through the device. Network access users can use LAN access and portal services.
guest: Guest that can access network resources through the device during a specific validity period. Guests can use LAN access and portal services.
all: Specifies all users.
ftp: FTP users.
http: HTTP users.
https: HTTPS users.
ssh: SSH users.
The device supports a maximum of 1024 device management users and a maximum of 4294967295 network access users.
If the local username contains Chinese characters, make sure the endpoint software used at device login uses the same character set encoding format as the encoding format (GB18030) used by the device to save local user configuration. If they use different encoding formats, the username cannot be correctly decoded on the device, which might cause local authentication failure.
# Add a device management user named user1 and enter local user view.
[Sysname-luser-manage-user1]
# Add a network access user named user2 and enter local user view.
[Sysname] local-user user2 class network
[Sysname-luser-network-user2]
# Add a local guest named user3 and enter local guest view.
[Sysname] local-user user3 class network guest
[Sysname-luser-network(guest)-user3]
display local-user
service-type (local user view)
local-user auto-delete enable
Use local-user auto-delete enable to enable the local user auto-delete feature.
Use undo local-user auto-delete enable to restore the default.
The local user auto-delete feature is disabled.
This feature enables the device to examine the validity of local users at fixed time periods of 10 minutes and automatically delete expired local users.
# Enable the local user auto-delete feature.
[Sysname] local-user auto-delete enable
validity-datetime
local-user-export
Use local-user-export to export local guest account information to a .csv file in the specified path.
local-user-export class network guest url url-string
network: Specifies the network access user.
url url-string: Specifies the URL of the destination file, a case-insensitive string of 1 to 255 characters.
You can import the user account information back to the device or to other devices that support the local-user-import command. Before the import, you can edit the .csv file as needed. However, you must follow the restrictions in "local-user-import."
The device supports TFTP and FTP file transfer modes. Table 14 describes the valid URL formats of the .csv file.
Protocol |
URL format |
TFTP |
tftp://server/path/filename |
Specify a TFTP server. The server argument represents the IP address or host name of the TFTP server. The path argument represents the relative directory of the TFTP working directory. For example, specify the file path as tftp://1.1.1.1/user/user.csv. |
FTP |
· With FTP user name and password: · Without FTP user name and password: |
Specify an FTP server. The server argument represents the IP address or host name of the FTP server. The path argument represents the relative directory of the FTP working directory. The device ignores the domain name in the FTP user name. For example, specify the file path as ftp://1:[email protected]/user/user.csv or ftp://1.1.1.1/user/user.csv. |
# Export local guest account information to the guest.csv file in the ftp://1.1.1.1/user/ path.
[Sysname] local-user-export class network guest url ftp://1.1.1.1/user/guest.csv
local-user-import
local-user-import
Use local-user-import to import local guest account information from a .csv file in the specified path to the device to create local guests based on the imported information.
local-user-import class network guest url url-string validity-datetime start-date start-time to expiration-date expiration-time [ auto-create-group | override | start-line line-number ] *
url url-string: Specifies the source file path. The url-string argument is a case-insensitive string of 1 to 255 characters.
validity-datetime: Specifies the guest validity period of the local guests.
auto-create-group: Enables the device to automatically create user groups for the imported local guests if the groups in the imported information do not exist on the device. If you do not specify this keyword, the device adds all imported local guests to the system-defined user group named system.
override: Enables the device to override the existing account with the same name as an imported guest account. If you do not specify this keyword, the device retains the existing account and does not import the local guest with the same name.
start-line line-number: Specifies the number of the line at which the account import begins. If you do not specify a line number, this command imports all accounts in the .csv file.
The .csv file contains multiple parameters for each account and the parameters must be strictly arranged in the following order:
· Username—User name of the guest account. The user name cannot be empty.
· Password—Password of the guest account in plaintext form. If the password is empty, the device generates a random password in encrypted form for the guest.
· User group—User group to which the guest belongs. If the user group is empty, the device assigns the guest to the system-defined user group named system.
· Guest full name—Name of the guest.
· Guest company—Company of the guest.
· Guest email—Email address of the guest.
· Guest phone—Phone number of the guest.
· Guest description—Description of the guest.
· Sponsor full name—Name of the guest sponsor.
· Sponsor department—Department of the guest sponsor.
· Sponsor email—Email address of the guest sponsor.
The value of each parameter in the file must meet the requirements of the local user attributes on the device. Any violation results in account import failure and interruption. The system displays the number of the line where the account import is interrupted.
Separate different account entries by a carriage return and separate each parameter value in an account entry by a comma (,). If the value of a parameter contains a comma (,), you must enclose the value within a pair of quotation marks ("") to avoid ambiguity. For example,
Jack,abc,visit,Jack Chen,ETP,[email protected],1399899,"The manager of ETP, come from TP.",Sam Wang,Ministry of personnel,[email protected]
The device supports TFTP and FTP file transfer modes. Table 15 describes the valid URL formats of the .csv file.
Protocol |
URL format |
TFTP |
FTP |
# Import guest account information from the ftp://1.1.1.1/user/guest.csv file and specify a validity period for the imported guests.
[Sysname] local-user-import class network guest url ftp://1.1.1.1/user/guest.csv validity-datetime 2014/10/01 00:00:00 to 2014/10/02 12:00:00
display local-user
local-user-export
password (device management user view)
Use password to configure a password for a device management user.
Use undo password to restore the default.
In non-FIPS mode:
password [ { hash | simple } string ]
undo password
In FIPS mode:
password
In non-FIPS mode:
A device management user does not have a password and can pass authentication after entering the correct username and passing attribute checks.
In FIPS mode:
A device management user does not have a password and cannot pass authentication.
Device management user view
hash: Specifies a password encrypted by the hash algorithm.
simple: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in hashed form using hash encryption algorithm SHA-512.
string: Specifies the password string. This argument is case sensitive. In non-FIPS mode, the hashed form of the password is a string of 1 to 110 characters. The plaintext form of the password is a string of 1 to 63 characters. In FIPS mode, the password is in plaintext form and is a string of 15 to 63 characters. The string must contain digits, uppercase letters, lowercase letters, and special characters.
If you do not specify any parameters, you enter the interactive mode to set a plaintext password.
In non-FIPS mode, a device management user for which no password is specified can pass authentication after entering the correct username and passing attribute checks. To enhance security, configure a password for each device management user.
In FIPS mode, a password is required for a device management user to pass authentication. You must set the password in interactive mode.
When global password control is enabled, the device handles passwords of device management users as follows:
· All passwords are saved in the history records in hashed form.
· If a user changes its own password in plaintext form, the system requests the user to enter the current password in plaintext form. If the current password is empty, the user does not need to enter the password. The new password must be different from all passwords of the user in the history records and the current password. In addition, the new password must have a minimum of four characters different from the current password.
· If a user changes the password for another user in plaintext form, the new password must be different from the target user's all passwords in the history records and current password.
· If a user deletes its own password, the system requests the user to enter the current password in plaintext form. If the current password is empty, the user does not need to enter the password.
· Except the above listed situations, the system does not request a user to enter the current plaintext password or compare the new password with passwords in the history records and the current password.
# Set the password to 123456TESTplat&! in plaintext form for device management user user1.
# Configure the password in interactive mode for device management user test.
[Sysname-luser-manage-test] password
Password:
confirm :
display local-user
password (network access user view)
Use password to configure a password for a network access user.
undo password
A network access user does not have a password and can pass authentication after entering the correct username and passing attribute checks.
simple: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form using hash encryption algorithm SHA-512.
string: Specifies the password string. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
As a best practice to enhance security, configure a password for each network access user.
# Set the password to 123456TESTuser&! in plaintext form for network access user user1.
[Sysname] local-user user1 class network
[Sysname-luser-network-user1] password simple 123456TESTuser&!
display local-user
phone
Use phone to specify the phone number of a local guest.
Use undo phone to restore the default.
phone phone-number
undo phone
No phone number is specified for a local guest.
Local guest view
phone-number: Specifies the phone number, a string of 1 to 32 characters.
# Specify the phone number as 13813723920 for local guest abc.
[Sysname-luser-network(guest)-abc] phone 13813723920
display local-user
Use reset local-guest waiting-approval to clear pending registration requests for local guests.
reset local-guest waiting-approval [ user-name user-name ]
If you do not specify a guest, this command clears information about all registration requests for local guests.
# Clear information about all registration requests for local guests.
<Sysname> reset local-guest waiting-approval
Use service-type to specify the service types that a local user can use.
Use undo service-type to remove service types configured for a local user.
In non-FIPS mode:
service-type { ftp | lan-access | { http | https | ssh | telnet | terminal } * | portal }
undo service-type { ftp | lan-access | { http | https | ssh | telnet | terminal } * | portal }
In FIPS mode:
service-type { lan-access | { https | ssh | terminal } * | portal }
undo service-type { lan-access | { https | ssh | terminal } * | portal }
A local user is not authorized to use any service.
Local user view
ftp: Authorizes the user to use the FTP service. The authorized directory can be modified by using the authorization-attribute work-directory command.
http: Authorizes the user to use the HTTP service.
https: Authorizes the user to use the HTTPS service.
lan-access: Authorizes the user to use the LAN access service. The users are typically Ethernet users, for example, 802.1X users.
ssh: Authorizes the user to use the SSH service.
telnet: Authorizes the user to use the Telnet service.
terminal: Authorizes the user to use the terminal service and log in from a console port.
portal: Authorizes the user to use the portal service.
You can assign multiple service types to a user.
# Authorize device management user user1 to use the Telnet and FTP services.
[Sysname-luser-manage-user1] service-type telnet
[Sysname-luser-manage-user1] service-type ftp
display local-user
snmp-agent trap enable local-server
Use snmp-agent trap enable local-server to enable SNMP notifications for password changes of local users.
Use undo snmp-agent trap enable local-server to disable SNMP notifications for password changes of local users.
snmp-agent trap enable local-server [ manage-password-change | network-password-change ] *
undo snmp-agent trap enable local-server [ manage-password-change | network-password-change ] *
All SNMP notifications are disabled for password changes of local users.
manage-password-change: Specifies password changes of device management users.
network-password-change: Specifies password changes of network access users.
With SNMP notifications enabled for password changes of local users, the system generates alarms when one of the following cases occurs:
· The password of a local user is configured or changed from the CLI.
· The password of a local user is changed through NETCONF or MIB, or from the Web interface.
· The password of a portal user is changed online on the login page.
For RADIUS SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
If you do not specify any keywords, the command enables SNMP notifications for password changes of both device management users and network access users.
# Enable SNMP notifications for password changes of local users.
[Sysname] snmp-agent trap enable local-server manage-password-change
sponsor-department
Use sponsor-department to specify the department of the guest sponsor for a local guest.
Use undo sponsor-department to restore the default.
sponsor-department department-string
No department is specified for the guest sponsor of a local guest.
Local guest view
department-string: Specifies the department name, a case-sensitive string of 1 to 127 characters.
# Specify the department as test for the guest sponsor of local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-department test
display local-user
sponsor-email
Use sponsor-email to specify the email address of the guest sponsor for a local guest.
Use undo sponsor-email to restore the default.
sponsor-email email-string
undo sponsor-email
No email address is specified for the guest sponsor.
Local guest view
email-string: Specifies the email address, a case-sensitive string of 1 to 255 characters. The address must comply with RFC 822.
# Specify the email address as [email protected] for the guest sponsor of local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-email [email protected]
display local-user
sponsor-full-name
Use sponsor-full-name to specify the guest sponsor name for a local guest.
Use undo sponsor-full-name to restore the default.
sponsor-full-name name-string
No guest sponsor name is specified for a local guest.
Local guest view
name-string: Specifies the guest sponsor name, a case-sensitive string of 1 to 255 characters.
# Specify the guest sponsor name as Sam Li for local guest abc.
[Sysname-luser-network(guest)-abc] sponsor-full-name Sam Li
display local-user
state (local user view)
Use state to set the status of a local user.
undo state
A local user is in active state.
Local user view
active: Places the local user in active state to allow the local user to request network services.
block: Places the local user in blocked state to prevent the local user from requesting network services.
# Place device management user user1 in blocked state.
[Sysname-luser-manage-user1] state block
display local-user
user-group
Use user-group to create a user group and enter its view, or enter the view of an existing user group.
Use undo user-group to delete a user group.
user-group group-name
undo user-group group-name
A system-defined user group exists. The group name is system.
A user group consists of a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized management of user attributes for the local users in the group.
A user group that has local users cannot be deleted.
You can modify settings for the system-defined user group named system, but you cannot delete the user group.
# Create a user group named abc and enter user group view.
display user-group
validity-datetime
Use validity-datetime to specify the validity period for a network access user.
Use undo validity-datetime to restore the default.
In network access user view (except in local guest view):
validity-datetime { from start-date start-time to expiration-date expiration-time | from start-date start-time | to expiration-date expiration-time }
In local guest view:
validity-datetime from start-date start-time to expiration-date expiration-time
The validity period for a local user does not expire.
Local guest view
from: Specifies the validity start date and time for the user. If you do not specify this option, the command defines only the expiration date and time of the user.
start-date: Specifies the date on which the user becomes effective. The date is in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for the MM argument is 1 to 12. The value range for the DD argument varies with the specified month. The value range for the YYYY argument is 2000 to 2035.
start-time: Specifies the time on the day when the user becomes effective. The time is in the format of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is 0 to 59. The mm and ss arguments are optional. For example, enter 1 to indicate 1:00:00. A value of 0 indicates 00:00:00.
to: Specifies the expiration date and time for the user. If you do not specify this option, the command defines only the validity start date and time of the user.
Expired network access user accounts cannot be used for authentication.
When both from and to options are specified, the expiration date and time must be later than the validity start date and time.
When only the from option is specified, the user is valid since the specified date and time. When only the to option is specified, the user is valid until the specified date and time.
When the RADIUS server feature is enabled on the device, the RADIUS user data for authentication is automatically generated from the network access user configuration. The device ignores the validity start date and time of the RADIUS users.
# Specify the validity period for network access user 123.
[Sysname-luser-network-123] validity-datetime from 2015/10/01 00:00:00 to 2016/10/02 12:00:00
display local-user
RADIUS commands
aaa device-id
Use aaa device-id to configure the device ID.
Use undo aaa device-id to restore the default.
aaa device-id device-id
undo aaa device-id
The device ID is 0.
device-id: Specifies a device ID in the range of 1 to 255.
RADIUS uses the value of the Acct-Session-ID attribute as the accounting ID for a user. The device generates an Acct-Session-ID value for each online user based on the system time, random digits, and device ID.
If you modify the device ID, the new device ID does not take effect on users that have been online during the change.
# Configure the device ID as 1.
[Sysname] aaa device-id 1
accounting-on enable
Use accounting-on enable to configure the accounting-on feature.
Use undo accounting-on enable to disable the accounting-on feature.
accounting-on enable [ interval interval | send send-times ] *
The accounting-on feature is disabled.
RADIUS scheme view
interval interval: Specifies the time interval for retransmitting an accounting-on packet in seconds. The value range for the interval argument is 1 to 15, and the default setting is 3.
send send-times: Specifies the maximum number of accounting-on packet transmission attempts. The value range for the send-times argument is 1 to 255, and the default setting is 50.
The accounting-on feature enables the device to automatically send an accounting-on packet to the RADIUS server after a device reboot. Upon receiving the accounting-on packet, the RADIUS server logs out all online users so they can log in again through the device.
Execute the save command to ensure that the accounting-on enable command takes effect at the next device reboot. For information about the save command, see Fundamentals Command Reference.
Parameters set by using the accounting-on enable command take effect immediately.
# Enable the accounting-on feature for RADIUS scheme radius1, and set the retransmission interval to 5 seconds and the transmission attempts to 15.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
display radius scheme
accounting-on extended
Use accounting-on extended to enable the extended accounting-on feature.
Use undo accounting-on extended to disable the extended accounting-on feature.
The extended accounting-on feature is disabled.
RADIUS scheme view
The extended accounting-on feature enhances the accounting-on feature by applying to a distributed architecture. For the extended accounting-on feature to take effect, the RADIUS server must run on IMC and the accounting-on feature must be enabled.
The extended accounting-on feature is applicable to LAN users. The user data is saved to the member devices through which the users access the IRF fabric.
When this feature is enabled, the IRF fabric automatically sends an accounting-on packet to the RADIUS server after a member device reboots (IRF fabric not reboot). The packet contains the member device identifier. Upon receiving the accounting-on packet, the RADIUS server logs out all online users that access the IRF fabric through the member device. If no users have come online through the member device, the IRF fabric does not send an accounting-on packet after the member device reboots.
The IRF fabric uses the packet retransmission interval and maximum transmission attempts set by using the accounting-on enable command for this feature.
Execute the save command to ensure that the accounting-on extended command takes effect at the next member device reboot. For information about the save command, see Fundamentals Command Reference.
# Enable the extended accounting-on feature for RADIUS scheme radius1.
[Sysname-radius-radius1] accounting-on extended
attribute 5 format
Use attribute 5 format to configure the format of the RADIUS NAS-Port attribute.
Use undo attribute 5 format to restore the default.
attribute 5 format port
The NAS-Port attribute contains the following portions:
· 8-bit IRF member ID.
· 4-bit slot number.
· 8-bit interface index.
· 12-bit VLAN ID.
RADIUS scheme view
port: Specifies the port format.
RADIUS servers of different types might have different requirements for the format of the NAS-Port attribute. To ensure correct RADIUS packet exchange, make sure the format of the NAS-Port attribute meets the requirements of the RADIUS servers.
If you specify the port format, the NAS-Port attribute contains the last segment for the interface number of the interface through which a user accesses the device. For example, if a user accesses the device through GigabitEthernet 1/0/2, 2 is used as the value for the RADIUS NAS-Port attribute.
This command does not distinguish user access types and takes effect on RADIUS packets for all users.
# Configure the format of the RADIUS NAS-Port attribute as the port format in RADIUS scheme radius1.
[Sysname-radius-radius1] attribute 5 format port
attribute 15 check-mode
Use attribute 15 check-mode to configure the Login-Service attribute check method.
Use undo attribute 15 check-mode to restore the default.
attribute 15 check-mode { loose | strict }
Strict Login-Service attribute check applies.
RADIUS scheme view
loose: Matches the standard Login-Service attribute value 0 for SSH, FTP, HTTP, HTTPS, and terminal services.
strict: Matches the extended Login-Service attribute values for the following types of users:
· 50—SSH.
· 51—FTP.
· 52—Terminal.
· 53—HTTP.
· 54—HTTPS.
Use the loose check method if the server does not issue the extended Login-Service attribute values for SSH, FTP, HTTP, HTTPS, or terminal users.
# Configure the Login-Service attribute check method as loose for SSH, FTP, and terminal users in RADIUS scheme radius1.
[Sysname-radius-radius1] attribute 15 check-mode loose
attribute 25 car
Use attribute 25 car to configure the device to interpret the RADIUS class attribute (attribute 25) as CAR parameters.
Use undo attribute 25 car to restore the default.
attribute 25 car
The RADIUS class attribute is not interpreted as CAR parameters.
RADIUS scheme view
Configure the device to interpret the RADIUS class attribute if the RADIUS server uses the attribute to deliver CAR parameters for user-based traffic monitoring and control.
# In RADIUS scheme radius1, configure the device to interpret the RADIUS class attribute as CAR parameters.
[Sysname-radius-radius1] attribute 25 car
attribute 30 mac-format
Use attribute 30 mac-format to configure the format of the MAC address in the RADIUS Called-Station-Id attribute.
Use undo attribute 30 mac-format to restore the default.
attribute 30 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
The MAC address in the RADIUS Called-Station-Id attribute is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphens (-) into six sections with letters in upper case.
RADIUS scheme view
section: Specifies the number of sections that a MAC address contains.
one: Specifies the one-section format HHHHHHHHHHHH.
six: Specifies the six-section format HH-HH-HH-HH-HH-HH.
three: Specifies the three-section format HHHH-HHHH-HHHH.
separator separator-character: Specifies a case-sensitive character that separates the sections.
lowercase: Specifies the letters in a MAC address to be in lower case.
uppercase: Specifies the letters in a MAC address to be in upper case.
Configure the format of the MAC address in the RADIUS Called-Station-Id attribute to meet the requirements of the RADIUS servers.
# In RADIUS scheme radius1, specify hhhhhhhhhhhh as the format of the MAC address in the RADIUS Called-Station-Id attribute.
[Sysname-radius-radius1] attribute 30 mac-format section one lowercase
attribute 31 mac-format
Use attribute 31 mac-format to configure the format of the MAC address in the RADIUS Calling-Station-Id attribute.
Use undo attribute 31 mac-format to restore the default.
attribute 31 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
The MAC address in the RADIUS Calling-Station-Id attribute (attribute 31) is in the format of HH-HH-HH-HH-HH-HH. The MAC address is separated by hyphens (-) into six sections with letters in upper case.
RADIUS scheme view
Configure the format of the MAC address in the RADIUS Calling-Station-Id attribute to meet the requirements of the RADIUS servers.
# In RADIUS scheme radius1, specify hh:hh:hh:hh:hh:hh as the format of the MAC address in the RADIUS Calling-Station-Id attribute.
[Sysname-radius-radius1] attribute 31 mac-format section six separator : lowercase
attribute 87 format
Use attribute 87 format to configure the format of the RADIUS NAS-Port-Id attribute (attribute 87).
Use undo attribute 87 format to restore the default.
attribute 87 format interface-name
The default format varies by user access type.
· For portal users, the NAS-Port-Id attribute contains the following portions:
¡ 2-bit member device ID. .
¡ 2-bit 0s.
¡ 3-bit interface index.
¡ 9-bit VLAN ID.
· For 802.1X and MAC authentication users, the NAS-Port-Id attribute is in the format of slot=xx;subslot=xx;port=xx;vlanid=xx.
¡ slot—IRF member ID.
¡ subslot—Slot number.
¡ port—Interface index.
¡ vlanid—VLAN ID.
· For login users, the NAS-Port-Id attribute is not included in RADIUS packets.
RADIUS scheme view
interface-name: Specifies the interface name format.
RADIUS servers of different types might have different requirements for the format of the NAS-Port-Id attribute. To ensure correct RADIUS packet exchange, configure the format of the NAS-Port-Id attribute to meet the requirements of the RADIUS servers.
If you specify the interface name format, the NAS-Port-Id attribute contains the name of the interface through which a user accesses the device. For example, if a user accesses the device through GigabitEthernet 1/0/1, GigabitEthernet 1/0/1 is used as the value for the RADIUS NAS-Port-Id attribute.
# Configure the format of the RADIUS NAS-Port-Id attribute as the interface name format in RADIUS scheme radius1.
[Sysname-radius-radius1] attribute 87 format interface-name
attribute convert (RADIUS DAS view)
Use attribute convert to configure a RADIUS attribute conversion rule.
Use undo attribute convert to delete RADIUS attribute conversion rules.
attribute convert src-attr-name to dest-attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute convert [ src-attr-name ]
No RADIUS attribute conversion rules exist. The system processes RADIUS attributes according to the principles of the standard RADIUS protocol.
RADIUS DAS view
src-attr-name: Specifies the source RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
dest-attr-name: Specifies the destination RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
coa-ack: Specifies the CoA acknowledgment packets.
coa-request: Specifies the CoA request packets.
received: Specifies the received DAE packets.
sent: Specifies the sent DAE packets.
The device replaces the attribute in packets that match a RADIUS attribute conversion rule with the destination RADIUS attribute in the rule.
The conversion rules take effect only when the RADIUS attribute translation feature is enabled.
When you configure RADIUS attribute conversion rules, follow these restrictions and guidelines:
· The source and destination RADIUS attributes in a rule must use the same data type.
· The source and destination RADIUS attributes in a rule cannot use the same name.
· A source RADIUS attribute can be converted only by one criterion, packet type or direction.
· One source RADIUS attribute cannot be converted to multiple destination attributes.
If you do not specify a source RADIUS attribute, the undo attribute convert command deletes all RADIUS attribute conversion rules.
# In RADIUS DAS view, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute in the received DAE packets with the Connect-Info attribute.
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] attribute convert Hw-Server-String to Connect-Info received
attribute translate
attribute convert (RADIUS scheme view)
attribute convert src-attr-name to dest-attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS scheme view
access-accept: Specifies the RADIUS Access-Accept packets.
access-request: Specifies the RADIUS Access-Request packets.
accounting: Specifies the RADIUS accounting packets.
received: Specifies the received RADIUS packets.
sent: Specifies the sent RADIUS packets.
# In RADIUS scheme radius1, configure a RADIUS attribute conversion rule to replace the Hw-Server-String attribute of received RADIUS packets with the Connect-Info attribute.
[Sysname-radius-radius1] attribute convert Hw-Server-String to Connect-Info received
attribute translate
attribute reject (RADIUS DAS view)
Use attribute reject to configure a RADIUS attribute rejection rule.
Use undo attribute reject to delete RADIUS attribute rejection rules.
attribute reject attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute reject [ attr-name ]
No RADIUS attribute rejection rules exist.
RADIUS DAS view
attr-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The attribute must be supported by the system.
Configure RADIUS attribute rejection rules for the following purposes:
· Delete attributes from the RADIUS packets to be sent if the destination RADIUS server does not identify the attributes.
· Ignore unwanted attributes in the RADIUS packets received from a RADIUS server.
The RADIUS attribute rejection rules take effect only when the RADIUS attribute translation feature is enabled.
A RADIUS attribute can be rejected only by one criterion, packet type or direction.
If you do not specify a RADIUS attribute, the undo attribute reject command deletes all RADIUS attribute rejection rules.
# In RADIUS DAS view, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the DAE packets to be sent.
[Sysname-radius-da-server] attribute reject Connect-Info sent
attribute translate
attribute reject (RADIUS scheme view)
attribute reject attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS scheme view
# In RADIUS scheme radius1, configure a RADIUS attribute rejection rule to delete the Connect-Info attribute from the RADIUS packets to be sent.
[Sysname-radius-radius1] attribute reject Connect-Info sent
attribute translate
attribute remanent-volume
Use attribute remanent-volume to set the data measurement unit for the Remanent_Volume attribute.
Use undo attribute remanent-volume to restore the default.
attribute remanent-volume unit { byte | giga-byte | kilo-byte | mega-byte }
undo attribute remanent-volume unit
The data measurement unit is kilobyte for the Remanent_Volume attribute.
RADIUS scheme view
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
Make sure the measurement unit is the same as the user data measurement unit on the RADIUS server.
# In RADIUS scheme radius1, set the data measurement unit to kilobyte for the Remanent_Volume attribute.
[Sysname-radius-radius1] attribute remanent-volume unit kilo-byte
attribute translate
Use attribute translate to enable the RADIUS attribute translation feature.
Use undo attribute translate to disable the RADIUS attribute translation feature.
attribute translate
The RADIUS attribute translation feature is disabled.
RADIUS DAS view
RADIUS scheme view
To cooperate with RADIUS servers of different vendors, enable the RADIUS attribute translation feature. Configure RADIUS attribute conversion rules and rejection rules to ensure that RADIUS attributes in the packets exchanged between the device and the server are supported by both sides.
# Enable the RADIUS attribute translation feature for RADIUS scheme radius1.
[Sysname-radius-radius1] attribute translate
ca-file
Use ca-file to specify a CA certificate file for EAP authentication.
Use undo ca-file to restore the default.
ca-file file-name
undo ca-file
No CA certificate file is specified for EAP authentication. The device does not verify the RADIUS server certificate during EAP authentication.
EAP profile view
file-name: Specifies a CA certificate file by its name, a case-sensitive string of 1 to 91 characters.
You must specify a CA certificate file to verify the RADIUS server certificate if the EAP authentication method is PEAP-GTC, PEAP-MSCHAPv2, TTLS-GTC, or TTLS-MSCHAPv2.
Before you specify a CA certificate file, you must use FTP or TFTP to transfer the CA certificate file to the root directory of the default storage medium on the device.
In an IRF fabric, make sure a CA certificate file already exists in the root directory of the default storage medium on the master device before you specify the file.
You can specify only one CA certificate file in an EAP profile. If you execute this command multiple times, the most recent configuration takes effect.
If you change the CA certificate file, the new CA certificate file takes effect at the next server status detection.
# In EAP profile eap1, specify CA certificate file CA.der for EAP authentication.
[Sysname] eap-profile eap1
[Sysname-eap-profile-eap1] ca-file CA.der
client
Use client to specify a RADIUS DAC.
Use undo client to remove a RADIUS DAC.
client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | ssl-server-policy policy-name | vpn-instance vpn-instance-name ] *
undo client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ ssl-server-policy ]
No RADIUS DACs are specified.
RADIUS DAS view
ip ipv4-address: Specifies a DAC by its IPv4 address.
ipv6 ipv6-address: Specifies a DAC by its IPv6 address.
key: Specifies the shared key for secure communication between the RADIUS DAC and server. Make sure the shared key is the same as the key configured on the RADIUS DAC. If the RADIUS DAC does not have any shared key, do not specify this option.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. In non-FIPS mode, the encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters. In FIPS mode, the encrypted form of the key is a string of 15 to 117 characters. The plaintext form of the key is a string of 15 to 64 characters. The plaintext string must contain characters from digits, uppercase letters, lowercase letters, and special characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the RADIUS DAC belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
ssl-server-policy: Specifies the SSL server policy for the RADIUS DAE server. With a policy specified, the system uses the RADIUS over TLS method to communicate with the DAE client. With no policy specified, the system uses the RADIUS over UDP method to communicate with the DAE client.
policy-name: Specifies the SSL server policy name, a case-insensitive string of 1 to 31 characters.
With the RADIUS DAS feature, the device listens to the default or specified UDP port to receive DAE requests from the specified DACs. The device processes the requests and sends DAE responses to the DACs.
The device discards any DAE packets sent from DACs that are not specified for the DAS.
You can execute the client command multiple times to specify multiple DACs for the DAS.
RADIUS DACs using UDP and RADIUS DACs using TLS can exist simultaneously. You can specify the SSL server policy for each client, so that each client can use its own certificate.
If the DAS and DACs use the RADIUS over TLS method to communicate, the default shared key is radsec.
# Specify the DAC as 10.110.1.2. Set the shared key to 123456 in plaintext form for secure communication between the DAS and DAC.
[Sysname-radius-da-server] client ip 10.110.1.2 key simple 123456
# Specify the DAC as 10.110.1.2 and specify SSL server policy policy1.
[Sysname-radius-da-server] client ip 10.110.1.2 ssl-server-policy policy1
port
data-flow-format (RADIUS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
RADIUS scheme view
data: Specifies the unit for data flows.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the RADIUS accounting servers. Otherwise, accounting results might be incorrect.
# In RADIUS scheme radius1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
display radius buffer
Use display radius buffer to display information about globally cached RADIUS packets.
This command displays the number of RADIUS cached packets on the master device, allowing administrators to monitor the congestion level of RADIUS cached packets in real time.
# Display information about globally cached RADIUS packets.
<Sysname> display radius buffer
Access type : lan-access
Slot Packets
1 10
2 12
Table 16 Command output
Access type |
Access type. This field is fixed to lan-access. |
Slot |
Slot number of the master device. |
Packets |
Number of packets. |
Use display radius scheme to display RADIUS scheme configuration.
display radius scheme [ radius-scheme-name ]
radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify a RADIUS scheme, this command displays the configuration of all RADIUS schemes.
When displaying configuration only for one scheme or for all RADIUS schemes, this command also displays the active state duration for each active server and the most recent five state changes for all servers in the scheme.
# Display the configuration of all RADIUS schemes.
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: radius1
Index : 0
Primary authentication server:
Host name: Not configured
IP : 2.2.2.2 Port: 2083
VPN : vpn1
SSL client policy : policy1
State: Active (duration: 1 weeks, 2 days, 1 hours, 32 minutes, 34 seconds)
Most recent state changes:
2021/08/15 20:38:45 Changed to active state
2021/08/15 20:33:45 Changed to blocked state
2021/08/15 20:31:19 Changed to active state
2021/08/15 20:26:19 Changed to blocked state
2021/08/15 20:26:00 Changed to active state
Test profile: 132
Probe username: test
Probe interval: 60 minutes
Confirm function: Enabled
Probe state: Detection
Confirm interval: 3
Confirm left count: 3
Weight: 40
Primary accounting server:
IP : 1.1.1.1 Port: 2083
VPN : Not configured
Weight: 40
Second authentication server:
IP : 3.3.3.3 Port: 1812
SSL client policy : Not configured
State: Blocked
Test profile: Not configured
Weight: 40
Second accounting server:
IP : 3.3.3.3 Port: 1813
State: Blocked (mandatory)
Weight: 0
Accounting-On function : Enabled
extended function : Disabled
retransmission times : 5
retransmission interval(seconds) : 2
Timeout Interval(seconds) : 3
TLS idle timeout(seconds) : 60
Retransmission Times : 3
Retransmission Times for Accounting Update : 5
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(seconds) : 22
Stop-accounting packets buffering : Enabled
Retransmission times : 500
NAS IP Address : 1.1.1.1
Local NAS IP Address : Not configured
Peer NAS IP Address : Not configured
User Name Format : with-domain
Data flow unit : Megabyte
Packet unit : One
Attribute 5 format : Port
Attribute 15 check-mode : Strict
Attribute 25 : CAR
Attribute 87 format : Interface name
Attribute Remanent-Volume unit : Mega
server-parallel-auth : Disabled
server-load-sharing : Enabled
Attribute 30 format : hh:hh:hh:hh:hh:hh:SSID
Attribute 30 MAC format : hh:hh:hh:hh:hh:hh
Attribute 31 MAC format : hh:hh:hh:hh:hh:hh
Stop-accounting-packet send-force : Disabled
Reauthentication server selection : Reselect
Attribute 218 of vendor ID 25506 : DHCP-Option 61
Format 1 (1-byte Type field)
# Display the configuration of RADIUS scheme radius1.
<Sysname> display radius scheme radius1
Index: 0
Host name: Not Configured
VPN : vpn1
2019/12/08 20:38:45 Changed to active state
2019/12/08 20:33:45 Changed to blocked state
2019/12/08 20:31:19 Changed to active state
2019/12/08 20:26:19 Changed to blocked state
2019/12/08 20:26:00 Changed to active state
Test profile: 132
Confirm interval: 3
Weight: 40
IP : 1.1.1.1 Port: 1813
Weight: 40
2019/12/08 20:56:22 Changed to blocked state
2019/12/08 20:48:45 Changed to active state
2019/12/08 20:43:45 Changed to blocked state
2019/12/08 20:41:19 Changed to active state
2019/12/08 20:46:19 Changed to blocked state
Weight: 40
Weight: 0
Packet unit : One
Attribute 25 : CAR
Stop-accounting packets send-force : Disabled
Table 17 Command output
Index |
Index number of the RADIUS scheme. |
Primary authentication server |
Information about the primary authentication server. |
Primary accounting server |
Information about the primary accounting server. |
Second authentication server |
Information about the secondary authentication server. |
Second accounting server |
Information about the secondary accounting server. |
Host name |
Host name of the server. This field displays Not configured in the following situations: · The server is not configured. · The server is specified by IP address. |
IP |
IP address of the server. This field displays Not configured in the following situations: · The server is not configured. · The server is specified by hostname, and the hostname is not resolved. |
Port |
Service port number of the server. If no port number is specified, this field displays the default port number. |
SSL client policy |
Name of the SSL client policy used by the TLS connection. |
VPN |
MPLS L3VPN instance to which the server or the RADIUS scheme belongs. If no VPN instance is specified for the server, this field displays Not configured. |
State |
Status of the server: · Active—The server is in active state. · Blocked—The server is changed to blocked state automatically. · Blocked (mandatory)—The server is set to blocked state manually. |
duration |
The duration of the current active state for the server. This field is displayed only when the server is in active state. |
Most recent blocked period |
Most recent blocking start time and end time when the server stayed in blocked state. If the server still remains in blocked state, now is displayed for the end time. |
Most recent state changes |
Most recent five state changes of the server. |
Test profile |
Test profile used for RADIUS server status detection. |
Probe username |
Username used for RADIUS server status detection. |
Probe interval |
Server status detection interval, in minutes. |
Probe eap-profile |
EAP profile specified for RADIUS server status detection. This field is not available if no EAP profile is specified in the test profile for RADIUS server status detection. |
Confirm function |
Enabling status of RADIUS server detection confirmation. Options include: · Disabled. · Enabled. |
Probe state |
Status of server reachability detection. Options include: · Confirmation. · Detection. This field is available only when RADIUS server detection confirmation is enabled. |
Confirm interval |
Interval for sending the confirmation packets for RADIUS server detection. This field is available only when RADIUS server detection confirmation is enabled. |
Confirm left count |
Remaining number of confirmation packets to be sent for RADIUS server detection. This field is available only when RADIUS server detection confirmation is enabled. |
Weight |
Weight value of the RADIUS server. |
Accounting-On function |
Whether the accounting-on feature is enabled. |
extended function |
Whether the extended accounting-on feature is enabled. |
retransmission times |
Number of accounting-on packet transmission attempts. |
retransmission interval(seconds) |
Interval at which the device retransmits accounting-on packets, in seconds. |
Timeout Interval(seconds) |
RADIUS server response timeout period, in seconds. |
TLS idle timeout(seconds) |
Idle timeout of TLS connections, in seconds. |
Retransmission times |
Maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server. |
Retransmission Times for Accounting Update |
Maximum number of accounting attempts. |
Server Quiet Period(minutes) |
Quiet period for the servers, in minutes. |
Realtime Accounting Interval(seconds) |
Interval for sending real-time accounting updates, in seconds. |
Stop-accounting packets buffering |
Whether buffering of nonresponded RADIUS stop-accounting requests is enabled. |
Maximum number of transmission attempts for individual RADIUS stop-accounting requests. |
NAS IP Address |
Source interface or source IP addresses for outgoing RADIUS packets. This field displays Not configured if no source interface or source IP addresses are specified for outgoing RADIUS packets. |
Local NAS IP Address |
NAS IP address of RADIUS packets sent for users that access the network through M-LAG interfaces on the local M-LAG member device. If a source interface is specified to provide the NAS IP address, this field displays Provided by local interface xxx. This field displays Not configured if no local NAS IP address is configured. |
Peer NAS IP Address |
NAS IP address of RADIUS packets sent for users that access the network through M-LAG interfaces on the peer M-LAG member device. If a source interface is specified to provide the NAS IP address, this field displays Provided by peer interface xxx. This field displays Not configured if no peer NAS IP address is configured. |
User Name Format |
Format for the usernames sent to the RADIUS server: · with-domain—Includes the domain name. · without-domain—Excludes the domain name. · keep-original—Forwards the username as the username is entered. |
Data flow unit |
Measurement unit for data flow. |
Packet unit |
Measurement unit for packets. |
Attribute 5 format |
Format of the RADIUS NAS-Port attribute, port or default. |
Attribute 15 check-mode |
RADIUS Login-Service attribute check method for SSH, FTP, and terminal users: · Strict—Matches Login-Service attribute values 50, 51, and 52 for SSH, FTP, and terminal services, respectively. · Loose—Matches the standard Login-Service attribute value 0 for SSH, FTP, and terminal services. |
Attribute 25 |
RADIUS attribute 25 interpretation status: · Standard—The attribute is not interpreted as CAR parameters. · CAR—The attribute is interpreted as CAR parameters. |
Attribute 87 format |
Format of the RADIUS NAS-Port-Id attribute, interface name or default. |
Attribute Remanent-Volume unit |
Data measurement unit for the RADIUS Remanent_Volume attribute. |
server-parallel-auth |
Enabling status of RADIUS server parallel authentication. Options include: · Disabled. · Enabled. |
server-load-sharing |
Status of the RADIUS server load sharing feature: · Disabled—The feature is disabled. The device forwards traffic to the server selected based on primary and secondary server roles. · Enabled—The feature is enabled. The device distributes traffic among multiple servers for load sharing. |
Attribute 30 format |
This field is not supported in the current software version. Format of the RADIUS Called-Station-Id attribute. |
Attribute 30 MAC format |
Format of the MAC address in the RADIUS Called-Station-Id attribute. |
Attribute 31 MAC format |
Format of the MAC address in the RADIUS Calling-Station-Id attribute. |
Stop-accounting-packet send-force |
Whether the device is enabled to forcibly send stop-accounting packets when users for which no start-accounting packets are sent go offline. |
Reauthentication server selection |
RADIUS server selection mode in reauthentication: · Inherit—The device uses the RADIUS server that performed authentication for a user to reauthenticate that user. · Reselect—The device searches for a reachable RADIUS server to reauthenticate a user. |
Attribute 218 vendor ID 25506 |
DHCP options encapsulated in subattribute 218 of vendor 25506 in RADIUS packets and the encapsulation format. · Format 1 (1-byte Type field)—The Type field of the encapsulated TLV is 1 byte long. Use this format when the device cooperates with most RADIUS servers. · Format 2 (2-byte Type field)—The Type field of the encapsulated TLV is 2 bytes long. Use this format when the device cooperates with HUAWEI RADIUS servers. This field is not displayed if the device is not configured to add subattribute 218 of vendor 25506 in RADIUS packets. |
display radius server-load statistics
Use display radius server-load statistics to display authentication and accounting load statistics for all RADIUS servers.
This command displays the following statistics:
· Last-5-second statistics—Total number of authentication or accounting requests sent to each RADIUS server in the last 5 seconds.
· History statistics—Total number of authentication or accounting requests sent to each RADIUS server since the device starts up.
The device collects the statistics as follows:
· Last-5-second statistics—From the device sends the first authentication or accounting request to a RADIUS server, the device counts the number of authentication or accounting requests sent to the server every 5 seconds. Then, the device updates the last-5-second authentication and accounting statistics for the server.
· History statistics—The device increases the history statistics for a RADIUS server by 1 every time it sends an authentication or accounting request to the server. The device does not decrease the history statistics even though users go offline or the server fails to response to a request within the timeout time.
Based on the statistics, you can adjust the load on RADIUS servers by changing the sequence in which the servers are configured or the weight values of the servers.
This command displays statistics only for RADIUS servers whose IP addresses are available or can be resolved from their hostnames.
The device deletes all statistics for a RADIUS server if the server is removed from a RADIUS scheme or the server's IP address, VPN instance, or service port number changes.
If an active/standby switchover occurs, the last-5-second statistics are deleted. However, the history statistics are not deleted. The history statistics might be inaccurate.
If the device reboots, both the last-5-seconds statistics and the history statistics are deleted.
# Display authentication and accounting load statistics for all RADIUS servers.
<Sysname> display radius server-load statistics
Authentication servers: 2
IP VPN Port Last 5 sec History
1.1.1.1 N/A 1812 20 100
2.2.2.2 ABC 1812 0 20
Accounting servers: 2
1.1.1.1 N/A 1813 20 100
2.2.2.2 ABC 1813 0 20
Table 18 Command output
Authentication servers |
Total number of RADIUS authentication servers. |
Accounting servers |
Total number of RADIUS accounting servers. |
IP |
IP address of a RADIUS server. |
VPN |
MPLS L3VPN instance to which the RADIUS server belongs. This field displays N/A if no VPN instance is specified for the server. |
Port |
Service port number of the RADIUS server. |
Last 5 sec |
Total number of RADIUS authentication or accounting requests sent to the RADIUS server within the last 5 seconds. |
History |
Total number of RADIUS authentication or accounting requests sent to the RADIUS server since the device starts up. |
reset radius server-load statistics
display radius statistics
Use display radius statistics to display RADIUS packet statistics.
# Display RADIUS packet statistics.
<Sysname> display radius statistics
Auth. Acct. SessCtrl.
Request Packet: 0 0 0
Retry Packet: 0 0 -
Timeout Packet: 0 0 -
Access Challenge: 0 - -
Account Start: - 0 -
Account Update: - 0 -
Account Stop: - 0 -
Terminate Request: - - 0
Set Policy: - - 0
Packet With Response: 0 0 0
Packet Without Response: 0 0 -
Access Rejects: 0 - -
Dropped Packet: 0 0 0
Check Failures: 0 0 0
TCP Connections: 2 2 0
TCP Connect Failures: 1 0 0
SSL Connections: 1 2 0
SSL Connect Failures: 1 0 0
Cache Search Requests : 3
Search Successes: 2 Search Failures: 1
Authentication servers: 1
IP: 1.1.1.1 Port: 1812
VPN:
Authentication packets:
Requests : 8 Retransmissions : 0
Pending requests : 0 Packet timeouts : 0
Challenge packets : 0 Accept responses : 0
Reject responses : 8 Unknown-type responses : 0
Malformed responses : 0 Bad authenticators : 0
Dropped responses : 0 TCP Connections : 2
TCP Connect Failures : 1 SSL Connections : 1
SSL Connect Failures : 1
Accounting servers: 1
VPN:
Accounting packets:
Start requests : 8 Realtime requests : 0
Stop requests : 0 Pending requests : 0
Packet timeouts : 0 Unknown-type responses : 0
Dropped responses : 0 Accept responses : 8
TCP Connections : 2 TCP Connect Failures : 0
SSL Connections : 2 SSL Connect Failures : 0
Table 19 Command output
Auth. |
Authentication packets. |
Acct. |
Accounting packets. |
SessCtrl. |
Session-control packets. |
Request Packet |
Number of request packets. |
Retry Packet |
Number of retransmitted request packets. |
Timeout Packet |
Number of request packets timed out. |
Access Challenge |
Number of access challenge packets. |
Account Start |
Number of start-accounting packets. |
Account Update |
Number of accounting update packets. |
Account Stop |
Number of stop-accounting packets. |
Terminate Request |
Number of packets for logging off users forcibly. |
Set Policy |
Number of packets for updating user authorization information. |
Packet With Response |
Number of packets for which responses were received. |
Packet Without Response |
Number of packets for which no responses were received. |
Access Rejects |
Number of Access-Reject packets. |
Dropped Packet |
Number of discarded packets. |
Check Failures |
Number of packets with checksum errors. |
Cache Search Requests |
Total number of cache search requests. |
Search Successes |
Number of successful cache searches. |
Search Failures |
Number of cache searches that fail to find matching data. |
TCP Connections |
Number of TCP connection establishments. Authentication and accounting share links. The system performs authentication and accounting based on the server type used at link creation. |
TCP Connect Failures |
Number of TCP connection establishment failures. Authentication and accounting share links. The system performs authentication and accounting based on the server type used at link creation. |
SSL Connection |
Number of SSL connection establishments. Authentication and accounting share links. The system performs authentication and accounting based on the server type used at link creation. |
SSL Connect Failures |
Number of SSL connection establishment failures. Authentication and accounting share links. The system performs authentication and accounting based on the server type used at link creation. |
Number of authentication servers. |
Number of accounting servers. |
IP |
IP address of the IoT server. |
Port |
Port number of the IoT server. |
VPN |
VPN to which the server belongs. If the server resides on the public network, this field is empty. |
Authentication packets |
Authentication server packet statistics. |
Accounting packets |
Accounting server packet statistics. |
Requests |
Number of authentication or accounting requests. Packet retransmissions are not counted, but the Pending Requests value also increases when this field value increases. |
Retransmissions |
Number of retransmitted authentication or accounting requests. The value is not included in the Requests field. |
Pending requests |
Authentication or accounting requests that have not timed out and for which the server responses have not been received. |
Packet timeouts |
Number of authentication or accounting requests that have timed out. |
Challenge packets |
Number of authentication challenge packets. |
Accept responses |
Number of received authentication successes or accounting responses. |
Reject responses |
Number of authentication rejections. |
Unknown-type responses |
Number of non-standard authentication or accounting responses. |
Malformed responses |
Number of authentication or accounting responses with an invalid length. |
Bad authenticators |
Number of authentication or accounting responses with verification errors. Responses with verification errors also belong to invalid responses. |
Dropped responses |
Number of authentication or accounting responses discarded due to other reasons. |
Start requests |
Number of accounting-start requests. |
Realtime requests |
Number of real-time accounting requests. |
Stop requests |
Number of accounting-stop packets. |
reset radius statistics
display stop-accounting-buffer (for RADIUS)
Use display stop-accounting-buffer to display information about buffered RADIUS stop-accounting requests to which no responses have been received.
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
session-id session-id: Specifies a session by its ID. The session-id argument is a string of 1 to 64 characters and cannot contain a letter. A session ID uniquely identifies an online user for a RADIUS scheme.
time-range start-time end-time: Specifies a time range. The start time and end time must be in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd.
user-name user-name: Specifies a user by its name, a case-sensitive string of 1 to 255 characters. Whether the user-name argument should include the domain name depends on the setting configured by using the user-name-format command for the RADIUS scheme.
# Display information about nonresponded RADIUS stop-accounting requests buffered for user abc.
<Sysname> display stop-accounting-buffer user-name abc
Total entries: 2
Scheme Session ID Username First sending time Attempts
rad1 1000326232325010 abc 23:27:16-08/31/2015 19
aaa 1000326232326010 abc 23:33:01-08/31/2015 20
Table 20 Command output
Session ID |
Session ID, which is the value of attribute Acct-Session-Id. |
First sending time |
Time when the stop-accounting request was first sent. |
Attempts |
Number of attempts that were made to send the stop-accounting request. |
reset stop-accounting-buffer (for RADIUS)
retry
retry stop-accounting (RADIUS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
user-name-format (RADIUS scheme view)
eap-profile
Use eap-profile to create an EAP profile and enter its view, or enter the view of an existing EAP profile.
Use undo eap-profile to delete an EAP profile.
eap-profile eap-profile-name
undo eap-profile eap-profile-name
No EAP profiles exist.
eap-profile-name: Specifies the EAP profile name, a case-sensitive string of 1 to 32 characters.
An EAP profile is a collection of EAP authentication settings, including the EAP authentication method and the CA certificate file to be used for some EAP authentication methods. You can use an EAP profile in a test profile for RADIUS server status detection.
You can specify an EAP profile in multiple test profiles. When a test profile uses a EAP authentication scheme, RADIUS over TLS is not supported for communication with the server.
You can configure a maximum of 16 EAP profiles.
# Create an EAP profile named eap1 and enter its view.
radius-server test-profile
exclude
Use exclude to exclude an attribute from RADIUS requests.
Use undo exclude to cancel the configuration of excluding an attribute from RADIUS requests.
exclude { accounting | authentication } name attribute-name
undo exclude { accounting | authentication } name attribute-name
No attributes are configured to be excluded from RADIUS requests.
RADIUS attribute test group view
accounting: Specifies RADIUS accounting requests.
authentication: Specifies RADIUS authentication requests.
name attribute-name: Specifies a RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters. The specified attribute must be an attribute that RADIUS requests carry by default. Attributes that you can exclude from RADIUS authentication requests include Service-Type, Framed-Protocol, NAS-Identifier, Acct-Session-Id, and NAS-Port-Type. Attributes that you can exclude from RADIUS accounting requests include NAS-Identifier, Acct-Delay-Time, Acct-Session-Id, and Acct-Terminate-Cause.
Use this command to exclude an attribute from RADIUS requests sent during an AAA test to help troubleshoot authentication or accounting failures.
Before you exclude an attribute that is already configured to be included in RADIUS requests, you must cancel the inclusion configuration by using the undo include command.
# In RADIUS attribute test group t1, exclude Service-Type attribute from RADIUS authentication requests.
[Sysname] radius attribute-test-group t1
[Sysname-radius-attr-test-grp-t1] exclude authentication name Service-Type
include
test-aaa
include
Use include to include an attribute in RADIUS requests.
Use undo include to cancel the configuration of including an attribute in RADIUS requests.
include { accounting | authentication } { name attribute-name | [ vendor vendor-id ] code attribute-code } type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string } value attribute-value
undo include { accounting | authentication} { name attribute-name | [ vendor vendor-id ] code attribute-code }
No attributes are configured to be included in RADIUS authentication or accounting requests.
name attribute-name: Specifies a standard RADIUS attribute by its name, a case-insensitive string of 1 to 63 characters.
vendor vendor-id: Specifies a vendor by its ID in the range of 1 to 65535. If the attribute is a standard RADIUS attribute, do not specify this option.
code attribute-code: Specifies a RADIUS attribute by its code in the range of 1 to 255.
type: Specifies a data type for the attribute content.
binary: Binary type.
date: Date type.
integer: Integer type.
interface-id: Interface ID type.
ip: IPv4 address type.
ipv6: IPv6 address type.
ipv6-prefix: IPv6 address prefix type.
octets: Octet type.
string: String type.
value attribute-value: Specifies the value for the attribute of the data type. The value range of the attribute-value argument varies by data type.
· For the binary type, the value is a string of 1 to 256 hexadecimal characters, which represents a binary number with a maximum of 128 bytes.
· For the date type, the value range is 0 to 4294967295.
· For the integer type, the value range is 0 to 4294967295.
· For the interface ID type, the value range is 1 to ffffffffffffffff.
· For the IPv6 address prefix type, the value is in the format of prefix/prefix-length.
· For the octet type, the value is a string of 1 to 256 hexadecimal characters, which represents an octet number with a maximum of 128 bytes.
· For the string type, the value of this argument is a string of 1 to 253 characters.
Use this command to add an attribute that RADIUS requests do not carry by default to the RADIUS requests. The undo form of this command removes the attribute from the RADIUS requests.
For an attribute that RADIUS requests carry by default, you can use this command to change its value. The undo form of this command restores the attribute value to the default.
Table 21 shows the attributes that RADIUS requests carry by default.
Table 21 Attributes that RADIUS requests carry by default
Packet type |
Attributes that the type of packets carry by default |
RADIUS authentication request |
User-Name, CHAP-Password (or User-Password), CHAP-Challenge, NAS-IP-Address (or NAS-IPv6-Address), Service-Type, Framed-Protocol, NAS-Identifier, NAS-Port-Type, and Acct-Session-Id. |
RADIUS accounting request |
User-Name, Acct-Status-Type, NAS-IP-Address (or NAS-IPv6-Address), NAS-Identifier, Acct-Session-Id, Acct-Delay-Time, and Acct-Terminate-Cause. |
For the accuracy of AAA tests, the value of an attribute must be of the data type specified for that attribute.
The attribute names of standard attributes saved in the configuration file will be converted to attribute codes.
Before you include an attribute that is already configured to be excluded from RADIUS requests, you must cancel the exclusion configuration by using the undo exclude command.
Plan the RADIUS attributes to be included in RADIUS requests. Besides the attributes carried by default, the device adds the specified attributes to RADIUS packets in the order that they are specified by using the include command. Additional attributes cannot be added to a RADIUS request if the length of the RADIUS request reaches 4096 bytes.
# In RADIUS attribute test group t1, include Calling-Station-Id attribute with value 08-00-27-00-34-D8 in RADIUS authentication requests.
[Sysname-radius-attr-test-grp-t1] include authentication name Calling-Station-Id type string value 08-00-27-00-34-d8
exclude
test-aaa
include-attribute 218 vendor-id 25506
Use include-attribute 218 vendor-id 25506 to include subattribute 218 of vendor 25506 in RADIUS packets.
Use undo include-attribute 218 vendor-id 25506 to not include subattribute 218 of vendor 25506 in RADIUS packets.
Use undo include-attribute 218 vendor-id 25506 dhcp-option to restore the default.
include-attribute 218 vendor-id 25506 dhcp-option { 55 | 61 } * { format1 | format2 }
undo include-attribute 218 vendor-id 25506 [ dhcp-option ]
The device uses format 1 to encapsulate DHCP Option 61 in subattribute 218 of vendor 25506 in RADIUS packets.
RADIUS scheme view
dhcp-option: Specifies a DHCP option to be encapsulated in subattribute 218.
· 55: Specifies DHCP Option 55.
· 61: Specifies DHCP Option 61.
format1: Specifies encapsulation format 1 for the subattribute, in which the Type field is 1 byte long. Use this format when the device cooperates with most RADIUS servers.
format2: Specifies encapsulation format 2 for the subattribute, in which the Type field is 2 bytes long. Use this format when the device cooperates with HUAWEI RADIUS servers.
The RADIUS Vendor-Specific attribute (attribute 26) allows vendors to define extended attributes to implement functions that the standard RADIUS protocol does not provide. Vendor 25506 defines subattribute 218 to carry user DHCP option information.
To send user DHCP option information to RADIUS servers, perform this task to include subattribute 218 of vendor 25506 in outgoing RADIUS start-accounting and update-accounting requests.
In the current software version, only DHCP Option 55 and DHCP Option 61 can be carried in the subattribute.
You can repeat this command to encapsulate both DHCP Option 55 and DHCP Option 61 in the subattribute. The length of each option is limited to 246 bytes.
If you repeat this command multiple times with the same DHCP option specified, the most recent configuration takes effect.
# In RADIUS scheme rad, configure the device to use format 2 to encapsulate DHCP Option 55 in subattribute 218 of vendor 25506 in RADIUS packets.
[Sysname-radius-rad] include-attribute 218 vendor-id 25506 dhcp-option 55 format2
key (RADIUS scheme view)
Use key to set the shared key for secure RADIUS authentication or accounting communication.
Use undo key to delete the shared key for secure RADIUS authentication or accounting communication.
key { accounting | authentication } { cipher | simple } string
undo key { accounting | authentication }
No shared key is configured for secure RADIUS authentication or accounting communication.
RADIUS scheme view
accounting: Specifies the shared key for secure RADIUS accounting communication.
authentication: Specifies the shared key for secure RADIUS authentication communication.
string: Specifies the key. This argument is case sensitive. In non-FIPS mode, the encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters. In FIPS mode, the encrypted form of the key is a string of 15 to 117 characters. The plaintext form of the key is a string of 15 to 64 characters. The plaintext string must contain digits, uppercase letters, lowercase letters, and special characters.
The shared keys configured by using this command apply to all servers in the scheme. Make sure the settings match the shared keys configured on the RADIUS servers.
The shared keys specified for specific RADIUS servers take precedence over the shared key specified with this command.
# In RADIUS scheme radius1, set the shared key to ok in plaintext form for secure accounting communication.
[Sysname-radius-radius1] key accounting simple ok
method
Use method to specify the EAP authentication method.
Use undo method to restore the default.
method { md5 | peap-gtc | peap-mschapv2 | ttls-gtc | ttls-mschapv2 }
undo method
MD5-challenge authentication is used.
EAP profile view
md5: Specifies the MD5-challenge method.
peap-gtc: Specifies the PEAP-GTC method.
peap-mschapv2: Specifies the PEAP-MSCHAPv2 method.
ttls-gtc: Specifies the TTLS-GTC method.
ttls-mschapv2: Specifies the TTLS-MSCHAPv2 method.
You must specify an EAP authentication method that is supported by the RADIUS server to be detected.
You can specify only one EAP authentication method in an EAP profile. If you execute this command multiple times, the most recent configuration takes effect.
If you change the EAP authentication method, the new method takes effect in the next server status detection.
# In EAP profile eap1, specify PEAP-GTC as the EAP authentication method.
[Sysname-eap-profile-eap1] method peap-gtc
microsegment associate
Use microsegment associate to associate a microsegment with a VSI.
Use undo microsegment to remove the association between a microsegment and a VSI.
microsegment microsegment-id associate vsi vsi-name
undo microsegment { microsegment-id | all }
No VSI is associated with a microsegment.
RADIUS scheme view
microsegment-id: Specifies a microsegment by its ID in the range of 1 to 65535.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
all: Specifies all microsegments associated with VSIs.
Use this command when microsegment-based access control is deployed on a VXLAN network.
When the RADIUS server assigns the microsegment and VSI attributes to a user, the device directly assigns the microsegment and VSI to the user so the user can access the related VXLAN resources.
When the RADIUS server assigns only the microsegment attribute but no VSI attribute to a user, the device will search for a VSI associated with the microsegment.
· If the device finds an associated VSI, it assigns the microsegment and the VSI to the user.
· If the device does not find an associated VSI, it assigns only the microsegment to the user.
You can repeat this command to create multiple microsegment-VSI associations. The number of supported maximum number of associations varies by device model.The system supports a maximum of 1024 microsegment-VSI associations.
In a RADIUS scheme, a microsegment can be associated with only one VSI. Multiple microsegments can be associated with the same VSI. If you repeat this command to associate a microsegment with different VSIs, the most recent configuration takes effect.
This command takes effect only on new users that come online after this command is executed.
Make sure the device can interpret microsegment IDs assigned by the RADIUS server. If the device cannot directly interpret microsegment IDs, use the attribute translation feature so the device can translate the server-assigned microsegment ID attribute to the H3C-Microsegment-Id attribute.
# In RADIUS scheme radius1, associate microsegment 123 with VSI test.
[Sysname-radius-radius1] microsegment 123 associate vsi test
attribute convert
nas-ip (RADIUS scheme view)
Use nas-ip to specify a source interface or source IP address for outgoing RADIUS packets.
Use undo nas-ip to delete the specified source interface or source IP address for outgoing RADIUS packets.
nas-ip [ m-lag { local | peer } ] { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo nas-ip [ m-lag { local | peer } ] [ interface | ipv6 ]
The source IP address of an outgoing RADIUS packet is that specified by using the radius nas-ip command in system view.
If the radius nas-ip command is not used, the source IP address is the primary IP address of the outbound interface.
RADIUS scheme view
m-lag: Specifies the source IP address for outgoing RADIUS packets sent for users that access the network through M-LAG interfaces on an M-LAG system.
local: Specifies the local source IP address (the source IP address for outgoing RADIUS packets sent for users that access the network through local M-LAG interfaces).
peer: Specifies the peer source IP address (the source IP address for outgoing RADIUS packets sent for users that access the network through remote M-LAG interfaces). This source IP address is a backup source IP address on the local M-LAG member device.
interface interface-type interface-number: Specifies a source interface by its type and number. The device uses the primary IPv4 address or the IPv6 address of the interface as the source IP address of an outgoing RADIUS packet.
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
The source IP address of RADIUS packets that a NAS sends must match the IP address of the NAS that is configured on the RADIUS server. A RADIUS server identifies a NAS by its IP address. Upon receiving a RADIUS packet, the RADIUS server checks the source IP address of the packet.
· If the source IP address of the packet is the IP address of a managed NAS, the server processes the packet.
· If the source IP address of the packet is not the IP address of a managed NAS, the server drops the packet.
As a best practice, specify a loopback interface address as the source IP address for outgoing RADIUS packets to avoid RADIUS packet loss caused by physical port errors.
On an M-LAG system, to make user traffic switchover caused by primary/secondary M-LAG member device switchover transparent to the RADIUS server, the source IP address of outgoing RADIUS packets must remain unchanged after switchover. You must specify the source IP address depending on the load sharing mode for user authentication on M-LAG interfaces:
· In centralized mode, you must specify the same source IP address on both the M-LAG member devices.
When an M-LAG member device fails, the active M-LAG member device uses the source IP address for outgoing RADIUS packets sent for users authenticated on the failed M-LAG member device.
· In distributed mode, use either of the following methods to specify source IP addresses for outgoing RADIUS packets:
¡ Specify different source addresses on the M-LAG member devices. The M-LAG member devices will automatically advertise their source addresses to each other.
¡ Specify a local and peer source IP address pair on both of the M-LAG member devices. Make sure the peer source IP address on one M-LAG member device is the local IP address on the other M-LAG member device.
When one M-LAG member device fails, the other member device uses the automatically obtained or manually configured peer source IP address to send RADIUS packets for users authenticated on the failed member device.
If you use both the nas-ip command and radius nas-ip command, the following guidelines apply:
· The setting configured by using the nas-ip command in RADIUS scheme view applies only to the RADIUS scheme.
· The setting configured by using the radius nas-ip command in system view applies to all RADIUS schemes.
· The setting in RADIUS scheme view takes precedence over the setting in system view.
For a RADIUS scheme, the following restrictions apply:
· You can specify only one source IPv4 address and one source IPv6 address for outgoing RADIUS packets.
· You can specify only one source interface to provide the source IP address for outgoing RADIUS packets. Make sure the route between the source interface and the RADIUS server is reachable.
· The source interface configuration and the source IP address configuration overwrite each other.
If you do not specify any parameter for the undo nas-ip command, the command deletes the specified source IPv4 address for outgoing RADIUS packets.
On an M-LAG system, you must use this command to specify a virtual IP address for the M-LAG system as the source IP address specified for outgoing RADIUS packets. For more information about virtual IP addresses for the M-LAG system, see M-LAG configuration in Layer 2—LAN Switching Configuration Guide.
The m-lag { local | peer } parameters are applicable only to an M-LAG system. Specify a source IP address for outgoing RADIUS packets on each M-LAG member device as follows, depending on the load sharing mode for user authentication on M-LAG interfaces:
· In centralized mode, execute the nas-ip command with or without the m-lag local parameters to specify the local source IP address. The two methods have the same result except that you must use the same method on both devices.
· In distributed mode, execute the nas-ip command with the m-lag local parameters and with the m-lag peer parameters to specify the local and peer source IP addresses, respectively. Alternatively, execute the nas-ip command with or without the m-lag local parameters to specify the local source IP address. These methods have the same result, except that you must use the same method on both devices.
If you do not specify the keywords, the system does not send accounting-on packets when the device restarts.
# In RADIUS scheme radius1, specify IP address 10.1.1.1 as the source IP address for outgoing RADIUS packets.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] nas-ip 10.1.1.1
radius nas-ip
port
Use port to specify the RADIUS DAS port.
Use undo port to restore the default.
port port-number
undo port
The RADIUS DAS port number is 3799.
RADIUS DAS view
port-number: Specifies a UDP port number in the range of 1 to 65535.
The destination port in DAE packets on the DAC must be the same as the RADIUS DAS port on the DAS.
# Enable the RADIUS DAS to listen to UDP port 3790 for DAE requests.
[Sysname-radius-da-server] port 3790
client
primary accounting (RADIUS scheme view)
Use primary accounting to specify the primary RADIUS accounting server.
Use undo primary accounting to restore the default.
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | ssl-client-policy policy-name | vpn-instance vpn-instance-name | weight weight-value ] *
The primary RADIUS accounting server is not specified.
RADIUS scheme view
host-name: Specifies the host name of the primary RADIUS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS accounting server.
port-number: Specifies the service port number of the primary RADIUS accounting server. The value range for the port number is 1 to 65535. The default value is 1813 when UDP is used, and 2083 when TLS is used.
key: Specifies the shared key for secure communication with the primary RADIUS accounting server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary RADIUS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
weight weight-value: Specifies a weight value for the RADIUS server. The value range for the weight-value argument is 0 to 100, and the default value is 0. The value 0 indicates that the RADIUS server will not be used for load sharing. This option takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme. A larger weight value represents a higher capacity to process accounting requests.
ssl-client-policy policy-name: Specifies an SSL client policy by its name for the primary accounting server, a case-insensitive string of 1 to 31 characters. With a policy specified, the system uses the RADIUS over TLS method to communicate with the server. With no policy specified, the system uses the RADIUS over UDP method to communicate with the server.
Make sure the port number and shared key settings of the primary RADIUS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
The shared key configured by using this command takes precedence over the shared key configured with the key accounting command. If the key accounting command is not configured and the server type is RADIUS over TLS, the default preshared key radsec is used.
If the specified server resides on an MPLS L3VPN, specify the VPN instance by using the vpn-instance vpn-instance-name option. The VPN instance specified by this command takes precedence over the VPN instance specified for the RADIUS scheme.
If you use the primary accounting command to modify or delete the primary accounting server to which the device is sending a start-accounting request, communication with the primary server times out.
· When the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for accounting.
· When the RADIUS server load sharing feature is enabled, the device returns an accounting failure message rather than searching for another active accounting server.
If you remove an actively used accounting server, the device no longer sends users' real-time accounting requests and stop-accounting requests. It does not buffer the stop-accounting requests. The device can generate incorrect accounting results.
For accounting servers with the same IP address (or host name), port number, and VPN, you can specify only the RADIUS over UDP or RADIUS over TLS method. If you specify the RADIUS over TLS method, make sure the SSL client policies specified for each RADIUS scheme have the same name. If you specify the RADIUS over UDP method, you cannot specify SSL client policies for any RADIUS scheme.
# In RADIUS scheme radius1, specify the primary accounting server with IP address 10.110.1.2, UDP port number 1813, and plaintext shared key 123456TESTacct&!.
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple 123456TESTacct&!
# In RADIUS scheme radius1, specify the IP address of the primary accounting server as 10.110.1.2, and specify the SSL client policy as policy1.
[Sysname-radius-radius1] primary accounting 10.110.1.1 ssl-client-policy policy1
secondary accounting (RADIUS scheme view)
server-load-sharing enable
vpn-instance (RADIUS scheme view)
primary authentication (RADIUS scheme view)
Use primary authentication to specify the primary RADIUS authentication server.
Use undo primary authentication to restore the default.
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | ssl-client-policy policy-name | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
The primary RADIUS authentication server is not specified.
RADIUS scheme view
host-name: Specifies the host name of the primary RADIUS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary RADIUS authentication server.
port-number: Specifies the service port number of the primary RADIUS authentication server. The value range for the port number is 1 to 65535. The default value is 1812 when UDP is used, and 2083 when TLS is used.
key: Specifies the shared key for secure communication with the primary RADIUS authentication server.
test-profile profile-name: Specifies a test profile for detecting the RADIUS server status. The profile-name argument is a case-sensitive string of 1 to 31 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary RADIUS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
weight weight-value: Specifies a weight value for the RADIUS server. The value range for the weight-value argument is 0 to 100, and the default value is 0. The value 0 indicates that the RADIUS server will not be used for load sharing. This option takes effect only when the RADIUS server load sharing feature is enabled for the RADIUS scheme. A larger weight value represents a higher capacity to process authentication requests.
ssl-client-policy policy-name: Specifies an SSL client policy by its name for the primary authentication server, a case-insensitive string of 1 to 31 characters. With a policy specified, the system uses the RADIUS over TLS method to communicate with the server. With no policy specified, the system uses the RADIUS over UDP method to communicate with the server.
Make sure the service port and shared key settings of the primary RADIUS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
The shared key configured by this command takes precedence over the shared key configured with the key authentication command. If the key authentication command is not configured and the server type is RADIUS over TLS, the default preshared key radsec is used.
The server status detection is triggered for the server if the specified test profile exists on the device.
If you use the primary authentication command to modify or delete the primary authentication server during an authentication process, communication with the primary server times out.
· When the RADIUS server load sharing feature is disabled, the device tries to communicate with an active server that has the highest priority for authentication.
· When the RADIUS server load sharing feature is enabled, the device performs the following operations:
a. Checks the weight value and number of currently served users for each active server.
b. Determines the most appropriate server in performance to receive an AAA request.
For authentication servers with the same IP address (or host name), port number, and VPN, you can specify only the RADIUS over UDP or RADIUS over TLS method. If you specify the RADIUS over TLS method, make sure the SSL client policies specified for each RADIUS scheme have the same name. If you specify the RADIUS over UDP method, you cannot specify SSL client policies for any RADIUS scheme.
# In RADIUS scheme radius1, specify the primary authentication server with IP address 10.110.1.1, UDP port number 1812, and plaintext shared key 123456TESTauth&!.
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key simple 123456TESTauth&!
# In RADIUS scheme radius1, specify the IP address of the primary authentication server as 10.110.1.1, and specify the SSL client policy as policy1.
[Sysname-radius-radius1] primary authentication 10.110.1.1 ssl-client-policy policy1
secondary authentication (RADIUS scheme view)
radius attribute extended
Use radius attribute extended to define an extended RADIUS attribute.
Use undo radius attribute extended to delete user-defined extended RADIUS attributes.
radius attribute extended attribute-name [ vendor vendor-id ] code attribute-code type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string }
undo radius attribute extended [ attribute-name ]
No user-defined extended RADIUS attributes exist.
attribute-name: Specifies the RADIUS attribute name, a case-insensitive string of 1 to 63 characters. The name must be unique among all RADIUS attributes, including the standard and extended RADIUS attributes.
vendor vendor-id: Specifies a vendor ID in the range of 1 to 65535. If you do not specify a vendor ID, the device processes the RADIUS attribute as a standard RADIUS attribute.
code attribute-code: Specifies the ID of the RADIUS attribute in the attribute set. The value range for the attribute-code argument is 1 to 255.
date: Date type.
octets: Octet type.
To support the proprietary RADIUS attributes of other vendors, perform the following tasks:
1. Use this command to define the attributes as extended RADIUS attributes.
2. Use the attribute convert command to map the extended RADIUS attributes to attributes supported by the system.
3. Use the attribute translate command to enable the RADIUS attribute translation feature for the mappings to take effect.
To cooperate with RADIUS servers of a third-party vendor, map attributes that cannot be identified by the server to server-supported attributes.
Two RADIUS attributes cannot have the same combination of attribute name, vendor ID, and attribute ID.
If you do not specify a RADIUS attribute name, the undo radius attribute extended command deletes all user-defined extended RADIUS attributes.
# Define a string-type extended RADIUS attribute with attribute name Owner-Password, vendor ID 122, and attribute ID 80.
[Sysname] radius attribute extended Owner-Password vendor 122 code 80 type string
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
attribute translate
Use radius attribute-test-group to create a RADIUS attribute test group and enter its view, or enter the view of an existing RADIUS attribute test group.
Use undo radius attribute-test-group to remove a RADIUS attribute test group.
radius attribute-test-group attr-test-group-name
undo radius attribute-test-group attr-test-group-name
No RADIUS attribute test groups exist.
attr-test-group-name: Specifies the name of a RADIUS attribute test group, a case-insensitive string of 1 to 31 characters.
A RADIUS attribute test group is a collection of RADIUS attributes that will be included in or excluded from RADIUS requests.
The system can have multiple RADIUS attribute test groups.
# Create a RADIUS attribute test group named t1 and enter its view.
exclude
include
test-aaa
radius authentication-request first
Use radius authentication-request first to preferentially process RADIUS authentication requests.
Use undo radius authentication-request first to restore the default.
The device processes RADIUS requests in the sequence that the requests are initiated.
RADIUS requests include RADIUS authentication requests, RADIUS accounting-start requests, RADIUS accounting-update requests, and RADIUS accounting-stop requests.
When a large number of users go offline and then try to come online immediately, authentication might fail for these users because of authentication request timeout. To resolve this issue, configure the device to preferentially process authentication requests.
Do not perform this task if the RADIUS server identifies users by the username and does not allow repeated authentication for the same username. A violation might cause authentication failure for users that try to come online immediately after going offline.
As a best practice, do not perform this task when the device has online users.
# Configure the device to preferentially process RADIUS authentication requests.
[Sysname] radius authentication-request first
radius dscp
Use radius dscp to change the DSCP priority of RADIUS packets.
Use undo radius dscp to restore the default.
radius [ ipv6 ] dscp dscp-value
undo radius [ ipv6 ] dscp
The DSCP priority of RADIUS packets is 0.
ipv6: Specifies IPv6 RADIUS packets. If you do not specify this keyword, the command sets the DSCP priority for IPv4 RADIUS packets.
dscp-value: Specifies the DSCP priority of RADIUS packets, in the range of 0 to 63. A larger value represents a higher priority.
To change the transmission priority of RADIUS packets, change the DSCP priority for them.
DSCP priority is contained in the ToS field of the IPv4 header and in the Traffic Class field of the IPv6 header.
# Set the DSCP priority of IPv4 RADIUS packets to 10.
[Sysname] radius dscp 10
radius dynamic-author server
Use radius dynamic-author server to enable the RADIUS DAS feature and enter RADIUS DAS view.
Use undo radius dynamic-author server to disable the RADIUS DAS feature.
The RADIUS DAS feature is disabled.
After you enable the RADIUS DAS feature, the device listens to the RADIUS DAS port to receive DAE packets from specified DACs. Based on the DAE packet type and contents, the device performs one of the following operations:
· Log off online users.
· Change online user authorization information.
· Shut down or reboot online users' access ports.
· Reauthenticate online users.
# Enable the RADIUS DAS feature and enter RADIUS DAS view.
[Sysname] radius dynamic-author server
client
port
radius enable
Use radius enable to enable the RADIUS service.
Use undo radius enable to disable the RADIUS service.
radius enable
undo radius enable
The RADIUS service is enabled.
By default, the RADIUS service is enabled. The device can send and receive RADIUS packets. Attackers might use RADIUS session-control and DAE ports to attack the device. To protect the device when such an attack occurs, disable the RADIUS service temporarily on the device. After the network is secure, re-enable the RADIUS service.
If settings on the RADIUS servers require modification or the RADIUS servers cannot provide services temporarily, you can temporarily disable the RADIUS service on the device.
When the RADIUS service is disabled, the device stops sending and receiving RADIUS packets. If a new user comes online, the device uses the backup authentication, authorization, or accounting method to process that user. If the device has not finished requesting authentication or accounting for a user before the RADIUS service is disabled, it uses the following rules to process that user:
· If the device has sent RADIUS authentication requests for that user to a RADIUS server, the device processes that user depending on whether it receives a response from the RADIUS server.
¡ If the device receives a response from the RADIUS server, it uses the response to determine whether that user has passed authentication. If that user has passed authentication, the device assigns authorization information to that user according to the response.
¡ If the device does not receive any response from the RADIUS server, it attempts to use the backup authentication method to authenticate that user.
· If the device has sent RADIUS start-accounting requests for that user to a RADIUS server, the device processes that user depending on whether it receives a response from the RADIUS server.
¡ If the device receives a response from the RADIUS server, it allows that user to come online. However, the device cannot send out accounting-update or stop-accounting requests to the RADIUS server. It cannot buffer the accounting requests, either. When that user goes offline, the RADIUS server cannot log off that user in time. The accounting result might be inaccurate.
¡ If the device does not receive any response from the RADIUS server, it attempts to use the backup accounting method.
Disabling the RADIUS service does not affect the RADIUS server feature of the device.
The authentication, authorization, and accounting processes undertaken by other methods are not switched to RADIUS when you re-enable the RADIUS service.
# Enable the RADIUS service.
[Sysname] radius enable
radius nas-ip
Use radius nas-ip to specify a source interface or source IP address for outgoing RADIUS packets.
Use undo radius nas-ip to delete the specified source interface or source IP address for outgoing RADIUS packets.
radius nas-ip { interface interface-type interface-number | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
undo radius nas-ip { interface | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
The source IP address of an outgoing RADIUS packet is the primary IPv4 address or the IPv6 address of the outbound interface.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the source IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To configure a public-network source IP address, do not specify this option.
You can specify a maximum of 16 source IP addresses in system view, including:
· Zero or one public-network source IPv4 address.
· Zero or one public-network source IPv6 address.
· Private-network source IP addresses.
Each VPN instance can have only one private-network source IPv4 address and one private-network source IPv6 address in system view.
# Specify IP address 129.10.10.1 as the source IP address for outgoing RADIUS packets.
[Sysname] radius nas-ip 129.10.10.1
radius scheme
Use radius scheme to create a RADIUS scheme and enter its view, or enter the view of an existing RADIUS scheme.
Use undo radius scheme to delete a RADIUS scheme.
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
No RADIUS schemes exist.
radius-scheme-name: Specifies the RADIUS scheme name, a case-insensitive string of 1 to 32 characters.
A RADIUS scheme can be used by more than one ISP domain at the same time.
The device supports a maximum of 16 RADIUS schemes.
# Create a RADIUS scheme named radius1 and enter RADIUS scheme view.
radius session-control client
Use radius session-control client to specify a RADIUS session-control client.
Use undo radius session-control client to remove the specified RADIUS session-control clients.
radius session-control client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo radius session-control client { all | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
No RADIUS session-control clients are specified.
ip ipv4-address: Specifies a session-control client by its IPv4 address.
ipv6 ipv6-address: Specifies a session-control client by its IPv6 address.
key: Specifies the shared key for secure communication with the session-control client.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the RADIUS session-control client belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the client is on the public network, do not specify this option.
all: Specifies all session-control clients.
To verify the session-control packets sent from a RADIUS server running on IMC, specify the RADIUS server as a session-control client to the device. The device matches a session-control packet to a session-control client based on the IP address and VPN instance, and then uses the shared key of the matched client to validate the packet.
The device searches the session-control client settings prior to searching all RADIUS scheme settings for a server with matching settings. This process narrows the search scope for finding the matched RADIUS server.
The session-control client settings take effect only when the RADIUS session-control feature is enabled.
The session-control client settings must be the same as the corresponding settings of the RADIUS server.
You can specify multiple session-control clients on the device.
# Specify a session-control client with IP address 10.110.1.2 and shared key 12345 in plaintext form.
[Sysname] radius session-control client ip 10.110.1.2 key simple 12345
radius session-control enable
Use radius session-control enable to enable the RADIUS session-control feature.
Use undo radius session-control enable to disable the RADIUS session-control feature.
The RADIUS session-control feature is disabled.
An IMC RADIUS server uses session-control packets to deliver dynamic authorization change requests (for example, authorization ACL, VLAN, user group, VSI, and blackhole MAC change requests) or disconnection requests to the device. The session-control feature enables the device to receive the RADIUS session-control packets on UDP port 1812.
This feature must work with IMC servers.
# Enable the RADIUS session-control feature.
[Sysname] radius session-control enable
radius trap-version
Use radius trap-version to set the version of RADIUS server status change MIB nodes.
Use undo radius trap-version to restore the default.
radius trap-version { v1 | v2 } [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up ] *
undo radius trap-version { v1 | v2 } [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up ] *
The device sends notifications about RADIUS server status change MIB nodes over SNMPv1.
v1: Specifies SNMPv1.
v2: Specifies SNMPv2.
accounting-server-down: Specifies the MIB node of RADIUS accounting server down notifications.
accounting-server-up: Specifies the MIB node of RADIUS accounting server up notifications.
authentication-server-down: Specifies the MIB node of RADIUS authentication server down notifications.
authentication-server-up: Specifies the MIB node of RADIUS authentication server up notifications.
Make sure the RADIUS server status change notifications sent by the device can be recognized by the NMS. Choose a MIB node version depending on the NMS requirements.
Table 22 RADIUS server status change MIB nodes (SNMPv1)
MIB node |
OID |
hh3cRadiusAuthServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.1 |
hh3cRadiusAccServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.2 |
hh3cRadiusAuthServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.1 |
hh3cRadiusAccServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.2 |
Table 23 RADIUS server status change MIB nodes (SNMPv2)
MIB node |
OID |
hh3cRadiusAuthenticationServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.4 |
hh3cRadiusAccountingServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.5 |
hh3cRadiusAuthenticationServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.0.6 |
hh3cRadiusAccountingServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.0.7 |
If you do not specify any RADIUS server status change MIB nodes, this command sets a version for all types of RADIUS server status change MIB nodes.
# Set the MIB node version to SNMPv2 for the MIB node of RADIUS accounting server down notifications.
[Sysname] radius trap-version v2 accounting-server-down
snmp-agent trap enable radius
radius-server authen-state-check interval
Use radius-server authen-state-check interval to set the interval at which the device detects the status of RADIUS authentication servers.
Use undo radius-server authen-state-check interval to restore the default.
radius-server authen-state-check interval interval
The device detects the status of RADIUS authentication servers at intervals of 10 minutes.
interval: Sets the detection interval, in minutes. The value range is 1 to 120.
This command takes effect only on 802.1X authentication, Web authentication, and MAC authentication users.
The device detects the status of RADIUS authentication servers in each RADIUS scheme at intervals as configured. It notifies access modules to remove users that use a RADIUS scheme from the critical domain when that RADIUS scheme has reachable RADIUS servers.
If the device cannot detect the status changes of RADIUS authentication servers in time, it cannot timely change server status or handle users. The following situations exist:
· When RADIUS server status detection is enabled, a too long detection interval might cause the device to falsely record a RADIUS server active after the server becomes unavailable. However, users are assigned to the critical domain.
· When RADIUS server status detection is disabled, the device assigns a user to the critical domain if it has not received any responses from a RADIUS server for the user before the server response timeout time expires. However, if the device has received authentication responses from that server for other users during the server response timeout period, the device does not set the state of that server to blocked. If the server is always available for subsequent users, the device always records that server active.
In the above situations, the device cannot remove users in the critical domain from the critical domain after the RADIUS server becomes available. To resolve the issue, use this command to set an appropriate interval for the device to detect the status of RADIUS authentication servers.
A too short detection interval consumes too many system resources for access services. A too long detection interval cannot detect server status changes in time.
As a best practice, consider the processing efficiency for access services and the accuracy for fail-permit and recovery when a large number of users come online in a short time.
# Configure the device to detect the status of RADIUS authentication servers at intervals of 2 minutes.
[Sysname] radius-server authen-state-check interval 2
authen-radius-unavailable online domain
Use radius-server test-profile to configure a test profile for detecting the RADIUS server status.
Use undo radius-server test-profile to delete a RADIUS test profile.
radius-server test-profile profile-name username name [ password { cipher | simple } string ] [ interval interval ] [ confirm | eap-profile eap-profile-name ]
undo radius-server test-profile profile-name
No RADIUS test profiles exist.
profile-name: Specifies the name of the test profile, which is a case-sensitive string of 1 to 31 characters.
username name: Specifies the username in the detection packets. The name argument is a case-sensitive string of 1 to 253 characters.
password: Specifies the user password in the detection packets. If you do not specify a user password, the device randomly generates a user password for each detection packet. As a best practice, specify a user password. RADIUS server might mistake detection packets that contain randomly generated passwords as attack packets.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
interval interval: Specifies the interval for sending a detection packet, in minutes. The value range for the interval argument is 1 to 3600, and the default value is 60.
confirm: Enables the device to send detection confirmation packets to confirm the server status.
eap-profile eap-profile-name: Specifies an EAP profile by its name, a case-sensitive string of 1 to 32 characters.
About this feature
The device starts detecting the status of a RADIUS server only if the test profile specified for the server exists. If you specify a nonexistent test profile for a RADIUS server, the device does not detect the status of the server until you create the test profile on the device.
If you do not specify an EAP profile, the system uses the simple detection method. In this mode, the device uses the test username and password configured in the test profile to construct an authentication request, and sends the request to the RADIUS server referencing the test profile at random time points within the test cycle. If the device receives an authentication response from the server during the current test cycle, the device considers that the server is reachable. With the confirm keyword configured, when the device detects a change in the server's reachability status, it sends three consecutive detection confirmation packets in a short period to reconfirm the actual status of the server. If any of the detection confirmation packets are inconsistent with the detection results, the device will not update its stored server status information. You can use the timer response-timeout command to set the timeout for detection confirmation packets.
To perform EAP-based status detection for a RADIUS server, you must specify a test profile that contains an EAP profile for the RADIUS server.
EAP-based detection provides more reliable detection results than simple detection. As a best practice, configure EAP-based detection on a network environment where EAP authentication is configured.
If you specify a nonexistent EAP profile in a test profile, the device performs simple detection for the RADIUS servers that use the test profile. After the EAP profile is configured, the device will start EAP-based detection at the next detection interval.
When you delete a test profile, the device stops detecting the status of RADIUS servers that use the test profile.
You can execute this command multiple times to configure multiple test profiles.
# Configure a test profile named abc for RADIUS server status detection. A detection packet that uses username admin and plaintext password abc123 is sent every 10 minutes.
[Sysname] radius-server test-profile abc username admin password simple abc123 interval 10
eap-profile
timer response-timeout (RADIUS scheme view)
reauthentication server-select
Use reauthentication server-select to specify a RADIUS server selection mode for reauthentication.
Use undo reauthentication server-select to restore the default.
reauthentication server-select { inherit | reselect }
The inherit mode is used.
RADIUS scheme view
inherit: Uses the RADIUS server that performed authentication for reauthentication.
reselect: Reselects a RADIUS server for reauthentication.
Use this command to configure the RADIUS server selection mechanism in reauthentication. Use one of the following modes depending on the network condition:
· Inherit—The device uses the RADIUS server that performed authentication for a user to reauthenticate that user. This mode reduces the amount of time used in reauthentication. However, if the RADIUS server is unreachable, the reauthentication will fail.
· Reselect—The device searches for a reachable RADIUS server to reauthenticate a user. This mode requires more time than the inherit mode. However, this mode ensures that the device uses the optimal reachable RADIUS server for reauthentication. The following factors affect the RADIUS server selection:
¡ Server configuration in the RADIUS scheme, including the configuration order.
¡ Enabling status of the RADIUS server load sharing feature.
¡ Status of the RADIUS servers in the RADIUS scheme.
If you enable this feature together with RADIUS server parallel authentication (server-parallel-auth enable), this feature does not take effect.
# In RADIUS scheme radius1, set the RADIUS server selection mode to reselect for reauthentication.
[Sysname-radius-radius1] reauthentication server-select reselect
display radius scheme
reset radius server-load statistics
Use reset radius server-load statistics to clear history authentication and accounting load statistics for all RADIUS servers.
This command does not clear authentication and accounting load statistics in the last 5 seconds.
# Clear history authentication and accounting load statistics for all RADIUS servers.
<Sysname> reset radius server-load statistics
display radius server-load statistics
Use reset radius statistics to clear RADIUS statistics.
# Clear RADIUS statistics.
<Sysname> reset radius statistics
display radius statistics
Use reset stop-accounting-buffer to clear buffered RADIUS stop-accounting requests to which no responses have been received.
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
# Clear nonresponded RADIUS stop-accounting requests buffered for user user0001@test.
<Sysname> reset stop-accounting-buffer user-name user0001@test
# Clear nonresponded RADIUS stop-accounting requests buffered from 0:0:0 to 23:59:59 on August 31, 2015.
<Sysname> reset stop-accounting-buffer time-range 0:0:0-08/31/2015 23:59:59-08/31/2015
retry
Use retry to set the maximum number of attempts for transmitting a RADIUS packet to a single RADIUS server.
Use undo retry to restore the default.
retry retries
undo retry
The maximum number of RADIUS packet transmission attempts is 3.
RADIUS scheme view
retries: Specifies the maximum number of RADIUS packet transmission attempts, in the range of 1 to 20.
Because RADIUS uses UDP packets to transmit data, the communication is not reliable.
If the device does not receive a response to its request from the RADIUS server within the response timeout period, the device retransmits the RADIUS request. To set the response timeout period, use the timer response-timeout command.
If the device does not receive a response from the RADIUS server after the maximum number of transmission attempts is reached, the device considers the request a failure.
If the client times out during the authentication process, the user is immediately logged off. To avoid user logoffs, the value multiplied by the following items cannot be larger than the client timeout period defined by the access module:
· The maximum number of RADIUS packet transmission attempts.
· The RADIUS server response timeout period.
· The number of RADIUS authentication servers in the RADIUS scheme.
When the device sends a RADIUS request to a new RADIUS server, it checks the total amount of time it has taken to transmit the RADIUS packet. If the amount of time has reached 300 seconds, the device stops sending the RADIUS request to the next RADIUS server. As a best practice, consider the number of RADIUS servers when you configure the maximum number of packet transmission attempts and the RADIUS server response timeout period.
# In RADIUS scheme radius1, set the maximum number of RADIUS packet transmission attempts to 5.
[Sysname-radius-radius1] retry 5
radius scheme
retry realtime-accounting
Use retry realtime-accounting to set the maximum number of real-time accounting request attempts.
Use undo retry realtime-accounting to restore the default.
retry realtime-accounting retries
The maximum number of real-time accounting request attempts is 5.
RADIUS scheme view
retries: Specifies the allowed maximum number of real-time accounting request attempts, in the range of 1 to 255.
Typically, a RADIUS accounting server determines the online status of a user by using a session timeout timer. If the server has not received a real-time accounting request from the NAS for a user before the session timeout timer expires, the server determines that a link or device failure has occurred. Then, the server stops accounting for the user.
For accurate accounting, configure the NAS with the commands in Table 24 to have it keep pace with the server in disconnecting or retaining the user connection as long as possible:
Table 24 Commands for tuning accounting session parameters
Command |
Sample setting |
timer response-timeout |
Sets the RADIUS server response timeout timer. |
3 seconds |
retry |
Sets the maximum number of transmission attempts for a RADIUS packet. |
3 attempts |
timer realtime-accounting |
Sets the real-time accounting interval. |
12 minutes |
retry realtime-accounting |
Sets the maximum number of real-time accounting request attempts. |
5 |
accounting update-fail |
Sets the action to take when the maximum number of consecutive accounting-update failures is reached. |
N/A |
With the sample settings in Table 24, the device sends an accounting request every 12 minutes, and it retransmits a request if it does not receive a response within 3 seconds after it has sent that request. If the device receives no response after transmitting the request three times, it determines that the real-time accounting request fails and makes another accounting request attempt. If five consecutive accounting request attempts fail, the device determines that an accounting-update failure occurs. For LAN (LAN-access) users, the maximum number of consecutive failed accounting-update attempts is fixed at 1. The device takes the action configured by using the accounting update-fail command to disconnect the user or retain the user's online status.
For more information about how the device determines the action to take upon an accounting-update failure, see the usage guidelines on the accounting update-fail command.
# In RADIUS scheme radius1, set the maximum number of consecutive real-time accounting request attempts to 10.
[Sysname-radius-radius1] retry realtime-accounting 10
retry
timer realtime-accounting (RADIUS scheme view)
retry stop-accounting (RADIUS scheme view)
Use retry stop-accounting to set the maximum number of transmission attempts for individual RADIUS stop-accounting requests.
Use undo retry stop-accounting to restore the default.
retry stop-accounting retries
The maximum number of transmission attempts is 500 for individual RADIUS stop-accounting requests.
RADIUS scheme view
retries: Specifies the maximum number of transmission attempts. The value range is 10 to 65535.
The maximum number of stop-accounting request transmission attempts controls the transmission of stop-accounting requests together with the following parameters:
· RADIUS server response timeout timer (set by using the timer response-timeout command).
· Maximum number of times to transmit a RADIUS packet per round (set by using the retry command).
For example, the following settings exist:
· The RADIUS server response timeout timer is 3 seconds.
· The maximum number of times to transmit a RADIUS packet per round is five.
· The maximum number of stop-accounting request transmission attempts is 20.
A stop-accounting request is retransmitted if the device does not receive a response within 3 seconds. When all five transmission attempts in this round are used, the device buffers the request and starts another round of retransmission. If 20 consecutive rounds of attempts fail, the device discards the request.
# Set the maximum number of stop-accounting request transmission attempts to 1000 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry stop-accounting 1000
display stop-accounting-buffer (for RADIUS)
retry
Use secondary accounting to specify a secondary RADIUS accounting server.
Use undo secondary accounting to remove a secondary RADIUS accounting server.
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | ssl-client-policy policy-name | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary accounting [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name | ssl-client-policy ] * ]
No secondary RADIUS accounting servers are specified.
RADIUS scheme view
host-name: Specifies the host name of a secondary RADIUS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS accounting server.
port-number: Specifies the service port number of the secondary RADIUS accounting server. The value range for the port number is 1 to 65535. The default value is 1813 when UDP is used, and 2083 when TLS is used.
key: Specifies the shared key for secure communication with the secondary RADIUS accounting server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
ssl-client-policy: Specifies the SSL client policy for the secondary accounting server. With a policy specified, the system uses the RADIUS over TLS method to communicate with the server. With no policy specified, the system uses the RADIUS over UDP method to communicate with the server.
policy-name: Specifies the SSL client policy name, a case-insensitive string of 1 to 31 characters.
Make sure the port number and shared key settings of each secondary RADIUS accounting server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The shared key configured by this command takes precedence over the shared key configured with the key accounting command. If the key accounting command is not configured and the server type is RADIUS over TLS, the default preshared key radsec is used.
If you use the secondary accounting command to modify or delete a secondary accounting server to which the device is sending a start-accounting request, communication with the secondary server times out.
If you remove an actively used accounting server, the device no longer sends users' real-time accounting requests and stop-accounting requests. The device does not buffer the stop-accounting requests, either.
# In RADIUS scheme radius1, specify a secondary accounting server with IP address 10.110.1.1 and UDP port 1813.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
# In RADIUS scheme radius2, specify two secondary accounting servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1813.
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813
# In RADIUS scheme radius1, specify the IP address of the secondary accounting server as 10.110.1.1, and specify the SSL client policy as policy1.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 ssl-client-policy policy1
Use secondary authentication to specify a secondary RADIUS authentication server.
Use undo secondary authentication to remove a secondary RADIUS authentication server.
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | ssl-client-policy policy-name | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary authentication [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name | ssl-client-policy ] * ]
No secondary RADIUS authentication servers are specified.
RADIUS scheme view
host-name: Specifies the host name of a secondary RADIUS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS authentication server.
port-number: Specifies the service port number of the secondary RADIUS authentication server. The value range for the port number is 1 to 65535. The default setting is 1812. The default value is 1812 when UDP is used, and 2083 when TLS is used.
key: Specifies the shared key for secure communication with the secondary RADIUS authentication server.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
policy-name: Specifies the name of the SSL client policy, a case-insensitive string of 1 to 31 characters.
Make sure the port number and shared key settings of each secondary RADIUS authentication server are the same as those configured on the corresponding server.
A RADIUS scheme supports a maximum of 16 secondary RADIUS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
The server status detection is triggered for a server if the specified test profile exists on the device.
If you use the secondary authentication command to modify or delete a secondary authentication server during an authentication process, communication with the secondary server times out.
# In RADIUS scheme radius1, specify a secondary authentication server with IP address 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
# In RADIUS scheme radius2, specify two secondary authentication servers with IP addresses 10.110.1.1 and 10.110.1.2 and UDP port 1812.
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812
# In RADIUS scheme radius1, specify the IP address of the secondary authentication server as 10.110.1.2, and specify the SSL client policy as policy1.
[Sysname-radius-radius1] secondary authentication 10.110.1.2 ssl-client-policy policy1
key (RADIUS scheme view)
Use server-load-sharing enable to enable the RADIUS server load sharing feature.
Use undo server-load-sharing enable to disable the RADIUS server load sharing feature.
The RADIUS server load sharing feature is disabled.
RADIUS scheme view
About this feature
Use the RADIUS server load sharing feature to dynamically distribute the workload over multiple servers regardless of their server roles. The device forwards an AAA request to the most appropriate server of all active servers in the scheme after it compares the weight values and numbers of currently served users. Specify a weight value for each RADIUS server based on the AAA capacity of the server. A larger weight value indicates a higher AAA capacity.
In RADIUS server load sharing, once the device sends a start-accounting request to a server for a user, it forwards all subsequent accounting requests of the user to the same server. If the accounting server is unreachable, the device returns an accounting failure message rather than searching for another active accounting server.
# Enable the RADIUS server load sharing feature for RADIUS scheme radius1.
[Sysname-radius-radius1] server-load-sharing enable
Use server-parallel-auth enable to enable RADIUS server parallel authentication.
Use undo server-parallel-auth enable to disable RADIUS server parallel authentication.
RADIUS server parallel authentication is disabled.
RADIUS scheme view
About this feature
The implementation mechanism of this feature varies by authentication method as follows:
· For 802.1X EAP termination authentication or MAC authentication, the device simultaneously sends authentication requests to all servers in Active state, without distinguishing between primary and secondary servers. If any one of the servers responds with successful authentication, the user authentication is considered successful. In the case where user authentication fails on all servers, authentication fail-permit is triggered for the user. User authentication is considered failed if no server responds or if all servers respond with a failure result at least once.
· For 802.1X EAP relay authentication, the device uses the primary and secondary server mode for authentication. If the primary server responds with a failure result, the device checks whether any other servers are in Active state. If an active server is detected, the system notifies the device to send an authentication request to the server for re-authentication. If no active server exists, the device considers that the user authentication fails. In the authentication process, an authentication request is sent to the next active server only when the previous authentication server responds with a fail or does not respond. If any one of the servers responds with successful authentication, the user authentication is considered successful. In the case where user authentication fails on all servers, authentication fail-permit is triggered for the user. User authentication is considered failed if no server responds or if all servers respond with a failure result at least once.
If you enable both this feature and RADIUS server load sharing (server-load-sharing enable), RADIUS server load sharing does not take effect.
If you enable this feature and specify a RADIUS server selection mode for authentication (reauthentication server-select), the specified selection mode does not take effect.
# Enable RADIUS server parallel authentication in RADIUS scheme radius1.
[Sysname-radius-radius1] server-parallel-auth enable
Use snmp-agent trap enable radius to enable SNMP notifications for RADIUS.
Use undo snmp-agent trap enable radius to disable SNMP notifications for RADIUS.
snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
undo snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
All RADIUS SNMP notifications are disabled.
accounting-server-down: Specifies notifications to be sent when the RADIUS accounting server becomes unreachable.
accounting-server-up: Specifies notifications to be sent when the RADIUS accounting server becomes reachable.
authentication-error-threshold: Specifies notifications to be sent when the number of authentication failures exceeds the specified threshold. The threshold is represented by the ratio of the authentication failures to the total number of authentication attempts. The value range is 1 to 100, and the default value is 30. This threshold can only be configured through the MIB.
authentication-server-down: Specifies notifications to be sent when the RADIUS authentication server becomes unreachable.
authentication-server-up: Specifies notifications to be sent when the RADIUS authentication server becomes reachable.
If you do not specify any keywords, this command enables or disables all types of notifications for RADIUS.
When SNMP notifications for RADIUS are enabled, the device supports the following notifications generated by RADIUS:
· RADIUS server unreachable notification—The RADIUS server cannot be reached. RADIUS generates this notification if it cannot receive any response to an accounting or authentication request within the specified RADIUS request transmission attempts.
· RADIUS server reachable notification—The RADIUS server can be reached. RADIUS generates this notification for a previously blocked RADIUS server after the quiet timer expires.
· Excessive authentication failures notification—RADIUS generates this notification when the number of authentication failures to the total number of authentication attempts exceeds the specified threshold.
# Enable the device to send RADIUS accounting server unreachable notifications.
[Sysname] snmp-agent trap enable radius accounting-server-down
state primary
Use state primary to set the status of a primary RADIUS server.
state primary { accounting | authentication } { active | block }
A primary RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies the primary RADIUS accounting server.
authentication: Specifies the primary RADIUS authentication server.
active: Specifies the active state, the normal operation state.
block: Specifies the blocked state, the out-of-service state.
When the RADIUS server load sharing feature is disabled, the device first tries to communicate with the primary server if the primary server is in active state. If the primary server is unavailable, the device performs the following operations:
· Changes the status of the primary server to blocked.
· Starts a quiet timer for the server.
· Tries to communicate with a secondary server in active state.
When the quiet timer of the primary server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active.
When the RADIUS server load sharing feature is enabled, the device checks the weight value and number of currently served users only for servers in active state. The most appropriate active server is selected for communication.
When the primary server and all secondary servers are in blocked state, the device tries to communicate with the primary server.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a primary RADIUS authentication server.
· If you set the status of the server to blocked, the device stops detecting the status of the server.
· If you set the status of the server to active, the device starts to detect the status of the server.
# In RADIUS scheme radius1, set the status of the primary authentication server to blocked.
[Sysname-radius-radius1] state primary authentication block
state secondary
state secondary
Use state secondary to set the status of a secondary RADIUS server.
state secondary { accounting | authentication } [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
A secondary RADIUS server is in active state.
RADIUS scheme view
accounting: Specifies a secondary RADIUS accounting server.
authentication: Specifies a secondary RADIUS authentication server.
host-name: Specifies the host name of the secondary RADIUS server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary RADIUS server.
port-number: Specifies the service port number of a secondary RADIUS server. The value range for the UDP port number is 1 to 65535. The default port numbers for authentication and accounting are 1812 and 1813, respectively.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary RADIUS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
If you do not specify an IP address, this command changes the status of all configured secondary RADIUS servers.
If the device finds that a secondary server in active state is unreachable, the device performs the following operations:
· Changes the status of the secondary server to blocked.
· Tries to communicate with another secondary server in active state.
When the quiet timer of a server times out, the status of the server automatically changes to active. If you set the server status to blocked before the quiet timer times out, the server status cannot change back to active unless you manually set the status to active. If all configured secondary servers are unreachable, the device considers the authentication or accounting attempt a failure.
This command can affect the RADIUS server status detection feature when a valid test profile is specified for a secondary RADIUS authentication server.
# In RADIUS scheme radius1, set the status of all the secondary authentication servers to blocked.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] state secondary authentication block
state primary
stop-accounting-buffer enable (RADIUS scheme view)
Use stop-accounting-buffer enable to enable buffering of RADIUS stop-accounting requests to which no responses have been received.
Use undo stop-accounting-buffer enable to disable the buffering feature.
The device buffers the RADIUS stop-accounting requests to which no responses have been received.
RADIUS scheme view
This command enables the device to buffer a RADIUS stop-accounting request that has no response after the maximum transmission attempts (set by using the retry command) have been made. The device resends the buffered request until it receives a server response or when the number of stop-accounting request transmission attempts reaches the upper limit. If no more attempts are available, the device discards the request. However, if you have removed an accounting server, stop-accounting requests destined for the server are not buffered.
# Enable buffering of RADIUS stop-accounting requests to which no responses have been received.
[Sysname-radius-radius1] stop-accounting-buffer enable
reset stop-accounting-buffer (for RADIUS)
stop-accounting-packet send-force
Use stop-accounting-packet send-force to enable forcibly sending stop-accounting packets. The device will send stop-accounting packets when users for which no start-accounting packets are sent go offline.
Use undo stop-accounting-packet send-force to disable forcibly sending stop-accounting packets.
Forcibly sending stop-accounting packets is disabled. The device does not send stop-accounting packets when users for which no start-accounting packets are sent go offline.
RADIUS scheme view
Typically, if the device does not send a start-accounting packet to the RADIUS server for an authenticated user, it does not send a stop-accounting packet when the user goes offline. If the server has generated a user entry for the user without start-accounting packets, it does not release the user entry when the user goes offline. This feature forces the device to send stop-accounting packets to the RADIUS server when the user goes offline for timely releasing the user entry on the server.
# In RADIUS scheme radius1, enable forcibly sending stop-accounting packets.
[Sysname-radius-radius1] stop-accounting-packet send-force
test-aaa
Use test-aaa to perform an AAA test.
test-aaa user user-name password password radius-scheme radius-scheme-name [ radius-server { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] ] [ chap | pap ] [ attribute-test-group attr-test-group-name ] [ trace ]
user user-name: Specifies the test username, a string of 1 to 80 characters. The username can be a pure username or contain a domain name. The format for a username containing a domain name is pure-username@domain-name. The pure username is case sensitive and the domain name is case insensitive.
password password: Specifies the password of the test user, a case-sensitive string of 1 to 63 characters.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a case-insensitive string of 1 to 32 characters.
radius-server: Specifies a RADIUS server.
ipv4-address: Specifies the IPv4 address of the RADIUS server.
ipv6 ipv6-address: Specifies the IPv6 address of the RADIUS server.
port-number: Specifies the UDP port number of the RADIUS server, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the RADIUS server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
chap: Specifies the CHAP authentication method (the default).
pap: Specifies the PAP authentication method.
attribute-test-group attr-test-group-name: Specifies a RADIUS attribute test group by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a RADIUS attribute test group or the specified RADIUS attribute test group does not exist, the device does not change the attributes carried in authentication or accounting requests.
trace: Displays detailed information about RADIUS packets exchanged during the AAA test. If you do not specify this keyword, the command displays brief information about the AAA test, including the sent and received packets and the test result.
Use this command to identify the reasons for the failure of interaction between the device and the AAA servers.
The device might communicate with the AAA servers incorrectly during an AAA test. Make sure no users come online or go offline during an AAA text.
If the configuration of the specified RADIUS scheme changes, the new configuration does not affect the current AAA test. The modification will take effect in the next test.
The system can have only one AAA test at a time. Another AAA test can be performed only after the current test finishes.
# Perform an AAA test and display detailed information about the test. The test uses username user1, password 123456, the CHAP authentication method, and RADIUS scheme test.
<Sysname> test-aaa user user1 password 123456 radius-scheme test chap trace
Sent a RADIUS authentication request.
Server IP : 192.168.1.110
Source IP : 192.168.1.166
VPN instance : N/A
Server port : 1812
Packet type : Authentication request
Packet length: 118 bytes
Packet ID : 0
Attribute list:
[User-Name(1)] [6] [user1]
[CHAP-Password(3)] [19] [******]
[NAS-IP-Address(4)] [6] [192.168.1.166]
[Service-Type(6)] [6] [2] [Framed]
[Framed-Protocol(7)] [6] [1] [PPP]
[NAS-Identifier(32)] [5] [Sysname]
[Acct-Session-Id(44)] [40] [00000008201707241008280000000c16100171]
[CHAP-Challenge(60)] [18] [******]
[NAS-Port-Type(61)] [6] [15] [Ethernet]
Received a RADIUS authentication response.
VPN instance : N/A
Server port : 1812
Packet type : Access-Reject
Packet length: 20 bytes
Packet ID : 0
Reply-Message: "E63032: Incorrect password. You can retry 9 times."
Sent a RADIUS start-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting request
Packet length: 63 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [1] [Start]
Received a RADIUS start-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting response
Packet ID : 1
Sent a RADIUS stop-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting request
Packet length: 91 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [2] [Stop]
[Acct-Delay-Time(41)] [6] [0]
[Acct-Terminate-Cause(49)] [6] [1] [User Request]
Received a RADIUS stop-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting response
Packet ID : 1
Test result: Failed
# Perform an AAA test and display brief information about the test. The test uses username user1, password 123456 and the CHAP authentication method to test RADIUS server at 192.168.1.110 in RADIUS scheme test.
<Sysname> test-aaa user user1 password 123456 radius-scheme test radius-server 192.168.1.110 1812
Test result: Successful
# Perform an AAA test and do not display detailed information about RADIUS packet exchanges. The test uses username user1, password 123456 and RADIUS scheme rs1.
< Sysname >test-aaa user user1 password 123456 radius-scheme rs1
Waiting to create a connection with the RADIUS over TLS server.
Failed to create a connection with the RADIUS over TLS server for packet, Server IP: 1.1.2.1, VPN instance: N/A, Server port: 2083, SSL client policy: s1, Packet type : Authentication request.
Failed to create a connection with the RADIUS over TLS server for packet, Server IP: 1.1.2.1, VPN instance: N/A, Server port: 2083, SSL client policy: s1, Packet type : Start-accounting request.
Test result: Successful.
Table 25 Command output
Server IP |
IP address of the server. |
Source IP |
Source IP address of the RADIUS packet. |
VPN instance |
MPLS L3VPN instance to which the server belongs. This field displays N/A if the server belongs to the public network. |
Server port |
UDP port number of the server. |
SSL client policy |
SSL client policy configured on the server. |
Packet type |
Type of the RADIUS packet: · Authentication request. · Access-Accept. · Access-Reject. · Start-accounting request. · Start-accounting response. · Stop-accounting request. · Stop-accounting response. |
Packet length |
Total length of the RADIUS packet, in bytes. |
Packet ID |
ID of the RADIUS packet. This field is used to identity a pair of request and response packets. |
[attribute-name (code)] [length] [value] [description] |
Information about a RADIUS attribute: · attribute-name—Name of the attribute. · code—Code of the attribute. · length—Length of the attribute, in bytes. · value—Value of the attribute. · description—Description of the attribute. |
Reply-Message: |
The RADIUS server rejected the authentication request and replied a message. |
Test result |
Result of the AAA test: · Successful—The test has succeeded. · Failed—The test has failed. If any request is rejected, the test fails. |
radius scheme
timer quiet (RADIUS scheme view)
Use timer quiet to set the quiet timer for the servers specified in a RADIUS scheme.
Use undo timer quiet to restore the default.
timer quiet minutes
undo timer quiet
The server quiet timer period is 5 minutes in a RADIUS scheme.
RADIUS scheme view
minutes: Specifies the server quiet period in minutes, in the range of 0 to 255. If you set this argument to 0, the device does not change the state of an unreachable server to blocked after it attempts to send an authentication or accounting request of a user to that server. As a result, when the device attempts to send an authentication or accounting request for a subsequent user, it still tries to send the request to that server because the server is still in active state.
Make sure the server quiet timer is set correctly.
A timer that is too short might result in frequent authentication or accounting failures. This is because the device will continue to attempt to communicate with an unreachable server that is in active state.
A timer that is too long might temporarily block a reachable server that has recovered from a failure. This is because the server will remain in blocked state until the timer expires.
# In RADIUS scheme radius1, set the quiet timer to 10 minutes for the servers.
[Sysname-radius-radius1] timer quiet 10
Use timer realtime-accounting to set the real-time accounting interval.
Use undo timer realtime-accounting to restore the default.
timer realtime-accounting interval [ second ]
The real-time accounting interval is 12 minutes.
RADIUS scheme view
interval: Specifies the real-time accounting interval in the range of 0 to 71582.
second: Specifies the measurement unit as second. If you do not specify this keyword, the real-time accounting interval is measured in minutes.
When the real-time accounting interval on the device is not zero, the device sends online user accounting information to the RADIUS accounting server at the configured interval.
When the real-time accounting interval on the device is zero, the device sends online user accounting information to the RADIUS accounting server at the real-time accounting interval configured on the server. If the real-time accounting interval is not configured on the server, the device does not send online user accounting information.
A short interval helps improve accounting precision but requires many system resources.
Table 26 Recommended real-time accounting intervals
Number of users |
Real-time accounting interval |
1 to 99 |
3 minutes |
100 to 499 |
6 minutes |
500 to 999 |
12 minutes |
1000 or more |
15 minutes or longer |
When you modify the real-time accounting interval, the following rules apply to users that have been online before the modification:
· If you modify the real-time accounting interval from a non-zero value to zero or from zero to a non-zero value, the modification does not take effect on these users. These users still use the old real-time accounting interval.
· If you modify the real-time accounting interval from a non-zero value to another non-zero value, the modification takes effect immediately on these users.
If the device performs RADIUS accounting for a user but not RADIUS authentication or authorization, only the real-time accounting interval set in the user's RADIUS accounting scheme takes effect. The real-time accounting interval assigned by the RADIUS accounting server does not take effect.
# In RADIUS scheme radius1, set the real-time accounting interval to 51 minutes.
[Sysname-radius-radius1] timer realtime-accounting 51
Use timer response-timeout to set the RADIUS server response timeout timer.
Use undo timer response-timeout to restore the default.
timer response-timeout seconds
The RADIUS server response timeout period is 3 seconds.
RADIUS scheme view
seconds: Specifies the RADIUS server response timeout period, in the range of 1 to 10 seconds.
If a NAS receives no response from the RADIUS server in a period of time after sending a RADIUS request, it resends the request so that the user has more opportunity to obtain the RADIUS service. The NAS uses the RADIUS server response timeout timer to control the transmission interval.
· The number of RADIUS servers in the RADIUS scheme.
# In RADIUS scheme radius1, set the RADIUS server response timeout timer to 5 seconds.
[Sysname-radius-radius1] timer response-timeout 5
retry
timer tls-idle-timeout (RADIUS scheme view)
Use timer tls-idle-timeout to set the idle timeout for TLS connections in RADIUS authentication.
Use undo timer tls-idle-timeout to restore the default.
timer tls-idle-timeout timeout-value
The idle timeout is 60 seconds for TLS connections in RADIUS authentication.
RADIUS scheme view
timeout-value: Specifies the idle timeout in the range of 0 to 3600 seconds.
After the device processes the last authentication or accounting request, it uses the idle timeout configured for TLS connections in the RADIUS scheme of the last request to update the idle timeout timer. If the timer expires but no authentication or accounting request is received, the system disconnects the TLS connection. Setting the idle timeout to 0 disables the system from disconnecting TLS connections due to timeout.
If you change the idle timeout under a RADIUS scheme from 0 to a non-zero value, the system traverses the connections of the servers under the scheme and updates the idle timeout to the new value.
# Set the idle timeout for TLS connections in RADIUS scheme radius1 to 30 seconds.
[Sysname-radius-radius1] timer tls-idle-timeout 30
timer tls-idle-timeout (RADIUS DAE server view)
Use timer tls-idle-timeout to set the idle timeout for TLS connections of the RADIUS DAE service.
The idle timeout is 60 seconds for TLS connections.
RADIUS DAS view
timeout-value: Specifies the idle timeout for TLS connections in the range of 0 to 3600 seconds.
When the device sends a RADIUS DAE response or receives a RADIUS DAE request, it updates the idle timeout timer based on the idle timeout configured for the TLS connections in RADIUS DAS view. When the idle timeout is reached, if no response is sent or no request is received, the TLS connection is automatically disconnected. Setting the idle timeout to 0 disables the system from disconnecting TLS connections due to timeout.
# Set the idle timeout for TLS connections of the RADIUS DAE service to 30 seconds.
[Sysname] radius dynamic-author server
tls-port
Use tls-port to specify the TLS connection listening port for the RADIUS DAE service.
Use undo tls-port to restore the default.
tls-port port-number
undo tls-port
The TLS connection listening port for the RADIUS DAE service is 2083.
RADIUS DAS view
port-number: Specifies the TLS connection listening port for the RADIUS DAE service, in the range of 1 to 65535.
Make sure the port number specified in this command is consistent with the TLS port number used by RADIUS DACs to send requests.
# Specify the TLS port number for the DAE service as 3790.
[Sysname-radius-da-server] tls-port 3790
user-name-format (RADIUS scheme view)
Use user-name-format to specify the format of the username to be sent to a RADIUS server.
Use undo user-name-format to restore the default.
user-name-format { keep-original | with-domain | without-domain }
The ISP domain name is included in the usernames sent to a RADIUS server.
RADIUS scheme view
keep-original: Sends the username to the RADIUS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the RADIUS server.
without-domain: Excludes the ISP domain name from the username sent to the RADIUS server.
A username is generally in the userid@isp-name format, of which the isp-name argument is used by the device to determine the ISP domain to which a user belongs. Some earlier RADIUS servers, however, cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such a RADIUS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username sent to a RADIUS server.
If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the RADIUS server will consider two users in different ISP domains but with the same userid as one user.
For 802.1X users using EAP authentication, the user-name-format command configured for a RADIUS scheme does not take effect. The device does not change the usernames from clients before forwarding them to the RADIUS server.
# In RADIUS scheme radius1, configure the device to remove the domain name from the usernames sent to the RADIUS servers.
[Sysname-radius-radius1] user-name-format without-domain
vpn-instance (RADIUS scheme view)
Use vpn-instance to specify an MPLS L3VPN instance for a RADIUS scheme.
Use undo vpn-instance to restore the default.
undo vpn-instance
The RADIUS scheme belongs to the public network.
RADIUS scheme view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
The VPN instance specified for a RADIUS scheme applies to all authentication and accounting servers in that scheme. If a VPN instance is also configured for an individual RADIUS server, the VPN instance specified for the RADIUS scheme does not take effect on that server.
# Specify VPN instance test for RADIUS scheme radius1.
[Sysname-radius-radius1] vpn-instance test
HWTACACS commands
data-flow-format (HWTACACS scheme view)
Use data-flow-format to set the data flow and packet measurement units for traffic statistics.
Use undo data-flow-format to restore the default.
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
Traffic is counted in bytes and packets.
data: Specifies the unit for data flows.
byte: Specifies the unit as byte.
giga-byte: Specifies the unit as gigabyte.
kilo-byte: Specifies the unit as kilobyte.
mega-byte: Specifies the unit as megabyte.
packet: Specifies the unit for data packets.
giga-packet: Specifies the unit as giga-packet.
kilo-packet: Specifies the unit as kilo-packet.
mega-packet: Specifies the unit as mega-packet.
one-packet: Specifies the unit as one-packet.
The data flow and packet measurement units for traffic statistics must be the same as configured on the HWTACACS accounting servers. Otherwise, accounting results might be incorrect.
# In HWTACACS scheme hwt1, set the data flow and packet measurement units for traffic statistics to kilobyte and kilo-packet, respectively.
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
display hwtacacs scheme
Use display hwtacacs scheme to display the configuration or statistics of HWTACACS schemes.
display hwtacacs scheme [ hwtacacs-scheme-name [ statistics ] ]
hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an HWTACACS scheme, this command displays the configuration of all HWTACACS schemes.
statistics: Displays the HWTACACS service statistics. If you do not specify this keyword, the command displays the configuration of the specified HWTACACS scheme.
When displaying configuration only for one scheme or for all schemes, this command also displays the active state duration for each active server and the most recent five state changes for all servers in the scheme.
# Displays the configuration of all HWTACACS schemes.
<Sysname> display hwtacacs scheme
Total 1 HWTACACS schemes
HWTACACS Scheme Name : hwtac
Index : 0
Primary Auth Server:
Host name: Not configured
IP : 2.2.2.2 Port: 49 State: Active
VPN Instance: 2
State: Active (duration: 1 weeks, 2 days, 1 hours, 32 minutes, 34 seconds)
Most recent state changes:
2021/08/15 21:01:23 Changed to active state
2021/08/15 20:56:22 Changed to blocked stat
Single-connection: Enabled
Primary Author Server:
VPN Instance: 2
Single-connection: Disabled
Primary Acct Server:
IP : Not Configured Port: 49 State: Block
VPN Instance: Not configured
State: Blocked
VPN Instance : 2
NAS IP Address : 2.2.2.3
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(minutes) : 12
Stop-accounting packets buffering : Enabled
Retransmission times : 100
Response Timeout Interval(seconds) : 5
Username Format : with-domain
Data flow unit : Byte
Packet unit : one
# Display the configuration of HWTACACS scheme hwtac.
<Sysname> display hwtacacs scheme hwtac
Index : 0
VPN Instance: 2
2019/12/08 21:01:23 Changed to active state
2019/12/08 20:56:22 Changed to blocked state
VPN Instance: 2
State: Blocked
2019/12/08 22:16:52 Changed to blocked state
2019/12/08 22:01:25 Changed to active state
2019/12/08 21:56:22 Changed to blocked state
VPN Instance : 2
Packet unit : one
Table 27 Command output
Index |
Index number of the HWTACACS scheme. |
Primary Auth Server |
Primary HWTACACS authentication server. |
Primary Author Server |
Primary HWTACACS authorization server. |
Primary Acct Server |
Primary HWTACACS accounting server. |
Secondary Auth Server |
Secondary HWTACACS authentication server. |
Secondary Author Server |
Secondary HWTACACS authorization server. |
Secondary Acct Server |
Secondary HWTACACS accounting server. |
Host name |
Host name of the server. This field displays Not configured in the following situations: · The server is not configured. · The server is specified by IP address. |
IP |
IP address of the server. This field displays Not configured in the following situations: · The server is not configured. · The server is specified by hostname, and the hostname is not resolved. |
Port |
Service port of the HWTACACS server. If no port configuration is performed, this field displays the default port number. |
State |
Status of the HWTACACS server: active or blocked. |
VPN Instance |
MPLS L3VPN instance to which the HWTACACS server or scheme belongs. If no VPN instance is specified for the server or scheme, this field displays Not configured. |
State |
Status of the server: · Active—The server is in active state. · Blocked—The server is in blocked state. |
duration |
The duration of the current active state for the server. This field is displayed only when the server is in active state. |
Most recent blocked period |
Most recent blocking start time and end time when the server stayed in blocked state. If the server still remains in blocked state, now is displayed for the end time. |
Most recent state changes |
Most recent five state changes of the server. |
Single-connection |
Single connection status: · Enabled—Establish only one TCP connection for all users to communicate with the server. · Disabled—Establish a TCP connection for each user to communicate with the server. |
NAS IP Address |
Source interface or source IP addresses for outgoing HWTACACS packets. This field displays Not configured if no source interface or source IP addresses are specified for outgoing HWTACACS packets. |
Server Quiet Period(minutes) |
Quiet period for the primary servers, in minutes. |
Realtime Accounting Interval(minutes) |
Real-time accounting interval, in minutes. |
Stop-accounting packets buffering |
Whether buffering of nonresponded HWTACACS stop-accounting requests is enabled. |
Retransmission times |
Maximum number of transmission attempts for individual HWTACACS stop-accounting requests. |
Response Timeout Interval(seconds) |
HWTACACS server response timeout period, in seconds. |
Username Format |
Format for the usernames sent to the HWTACACS server: · with-domain—Includes the domain name. · without-domain—Excludes the domain name. · keep-original—Forwards the username as the username is entered. |
Data flow unit |
Measurement unit for data flows. |
Packet unit |
Measurement unit for packets. |
# Display statistics for HWTACACS scheme tac.
<Sysname> display hwtacacs scheme tac statistics
Primary authentication server : 111.8.0.244
Round trip time: 20 seconds
Request packets: 1
Login request packets: 1
Change-password request packets: 0
Request packets including plaintext passwords: 0
Request packets including ciphertext passwords: 0
Response packets: 2
Pass response packets: 1
Failure response packets: 0
Get-data response packets: 0
Get-username response packets: 0
Get-password response packets: 1
Restart response packets: 0
Error response packets: 0
Follow response packets: 0
Malformed response packets: 0
Continue packets: 1
Continue-abort packets: 0
Pending request packets: 0
Connection failure packets: 0
Connection timeout packets: 0
Response timeout packets: 0
Tx failure packets: 0
Unknown type response packets: 0
Dropped response packets: 0
Primary authorization server :111.8.0.244
Round trip time: 1 seconds
Request packets: 1
Response packets: 1
PassAdd response packets: 1
PassReply response packets: 0
Primary accounting server :111.8.0.244
Round trip time: 0 seconds
Request packets: 2
Accounting start request packets: 1
Accounting stop request packets: 1
Accounting update request packets: 0
Response packets: 2
Success response packets: 2
Table 28 Command output
Primary authentication server |
Primary authorization server |
Primary accounting server |
Secondary authentication server |
Secondary authorization server |
Secondary accounting server |
Round trip time |
The time interval during which the device processed a pair of request and response. The unit is second. |
Request packets |
Total number of sent request packets. |
Login request packets |
Number of sent login request packets. |
Change-password request packets |
Number of sent request packets for changing passwords. |
Request packets including plaintext passwords |
Number of request packets that include plaintext passwords. |
Request packets including ciphertext passwords |
Number of request packets that include ciphertext passwords. |
Response packets |
Total number of received response packets. |
Pass response packets |
Number of response packets indicating successful authentication. |
Failure response packets |
Number of response packets indicating authentication or authorization failure. |
Get-data response packets |
Number of response packets for obtaining user data. |
Get-username response packets |
Number of response packets for obtaining usernames. |
Get-password response packets |
Number of response packets for obtaining passwords. |
Restart response packets |
Number of response packets for reauthentication. |
Error response packets |
Number of error-type response packets. |
Follow response packets |
Number of follow-type response packets. |
Malformed response packets |
Number of malformed response packets. |
Continue packets |
Number of sent Continue packets. |
Continue-abort packets |
Number of sent Continue-abort packets. |
Pending request packets |
Number of request packets waiting for a response. |
Connection failure packets |
Number of TCP connection establishment failures. |
Connection timeout packets |
Number of TCP connection establishment timeouts. |
Response timeout packets |
Number of server response timeouts. |
Tx failure packets |
Number of packets that failed to be transmitted. |
Unknown type response packets |
Number of unknown-type response packets. |
Dropped response packets |
Number of dropped response packets. |
PassAdd response packets |
Number of received PassAdd response packets. The packets indicate that all requested authorization attributes are assigned and additional authorization attributes are added. |
PassReply response packets |
Number of received PassReply response packets. The device uses the specified authorization attributes in the packets to replace the requested authorization attributes. |
Accounting start request packets |
Number of accounting start request packets. |
Accounting stop request packets |
Number of accounting stop request packets. |
Accounting update request packets |
Number of accounting update request packets. |
Success response packets |
Number of accounting success response packets. |
reset hwtacacs statistics
display hwtacacs statistics
Use display hwtacacs statistics to display HWTACACS packet statistics.
# Display HWTACACS packet statistics.
<Sysname> display hwtacacs statistics
Auth. Author. Acct.
Request Packet: 0 0 0
Response Packet: 0 0 0
Login Request: 0 - -
ChangePass Request: 0 - -
Account Start: - - 0
Account Update: - - 0
Account Stop: - - 0
Pass Response: 0 0 -
Failure Response: 0 0 -
Account Success: - - 0
Connection Failure: 0 0 0
Connection Timeout: 0 0 0
Response Timeout: 0 0 0
Send Failure: 0 0 0
Unknown Type: 0 0 0
Dropped Packet: 0 0 0
Table 29 Command output
Auth. |
Statistics for authentication packets. |
Author. |
Statistics for authorization packets. |
Acct. |
Statistics for accounting packets. |
Request Packet |
Number of sent requests. |
Response Packet |
Number of received responses. |
Login Request |
Number of sent login authentication requests. |
ChangePass Request |
Number of sent password change requests. |
Account Start |
Number of sent accounting-start requests. |
Account Update |
Number of sent accounting-update requests. |
Account Stop |
Number of sent accounting-stop requests. |
Pass Response |
Number of received responses that indicate a successful authentication or authorization. |
Failure Response |
Number of received responses that indicate an authentication or authorization failure. |
Account Success |
Number of received responses that indicate a successful accounting. |
Connection Failure |
Connection Timeout |
Response Timeout |
Number of request timeouts. |
Send Failure |
Number of packet transmission failures. |
Unknown Type |
Number of packet-type-unknown responses. |
Dropped Packet |
Number of dropped responses. |
display stop-accounting-buffer (for HWTACACS)
Use display stop-accounting-buffer to display information about buffered HWTACACS stop-accounting requests to which no responses have been received.
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, a case-insensitive string of 1 to 32 characters.
# Display information about nonresponded stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
Total entries: 2
Scheme IP address Username First sending time Attempts
hwt1 192.168.100.1 abc 23:27:16-08/31/2015 19
hwt1 192.168.90.6 bob 23:33:01-08/31/2015 20
Table 30 Command output
First sending time |
Time when the stop-accounting request was first sent. |
Attempts |
Number of attempts that were made to send the stop-accounting request. |
reset stop-accounting-buffer (for HWTACACS)
retry stop-accounting (HWTACACS scheme view)
stop-accounting-buffer enable (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
hwtacacs dscp
Use hwtacacs dscp to change the DSCP priority of HWTACACS packets.
Use undo hwtacacs dscp to restore the default.
hwtacacs [ ipv6 ] dscp dscp-value
undo hwtacacs [ ipv6 ] dscp
The DSCP priority of HWTACACS packets is 0.
ipv6: Specifies IPv6 HWTACACS packets. If you do not specify this keyword, the command sets the DSCP priority for IPv4 HWTACACS packets.
dscp-value: Specifies the DSCP priority of HWTACACS packets, in the range of 0 to 63. A larger value represents a higher priority.
To change the transmission priority of HWTACACS packets, change the DSCP priority for them.
DSCP priority is contained in the ToS field of the IPv4 header and in the Traffic Class field of the IPv6 header.
# Set the DSCP priority of IPv4 HWTACACS packets to 10.
[Sysname] hwtacacs dscp 10
hwtacacs nas-ip
Use hwtacacs nas-ip to specify a source interface or source IP address for outgoing HWTACACS packets.
Use undo hwtacacs nas-ip to delete the specified source interface or source IP address for outgoing HWTACACS packets.
hwtacacs nas-ip { interface interface-type interface-number | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
undo hwtacacs nas-ip { interface | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
The source IP address of an HWTACACS packet sent to the server is the primary IPv4 address or the IPv6 address of the outbound interface.
interface interface-type interface-number: Specifies a source interface by its type and number. The device uses the primary IPv4 address or the IPv6 address of the interface as the source IP address of an outgoing HWTACACS packet.
ipv4-address: Specifies an IPv4 address, which must be an address of the device. The IP address cannot be 0.0.0.0, 255.255.255.255, a class D address, a class E address, or a loopback address.
ipv6 ipv6-address: Specifies an IPv6 address, which must be a unicast address of the device and cannot be a loopback address or a link-local address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the source IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To configure a public-network source IP address, do not specify this option.
The source IP address of HWTACACS packets that a NAS sends must match the IP address of the NAS that is configured on the HWTACACS server. An HWTACACS server identifies a NAS by IP address. Upon receiving an HWTACACS packet, the HWTACACS server checks the source IP address of the packet.
· If the source IP address of the packet is the IP address of a managed NAS, the server processes the packet.
· If the source IP address of the packet is not the IP address of a managed NAS, the server drops the packet.
As a best practice, specify a loopback interface address as the source IP address for outgoing HWTACACS packets to avoid HWTACACS packet loss caused by physical port errors.
If you use both the nas-ip command and hwtacacs nas-ip command, the following guidelines apply:
· The setting configured by using the nas-ip command in HWTACACS scheme view applies only to the HWTACACS scheme.
· The setting configured by using the hwtacacs nas-ip command in system view applies to all HWTACACS schemes.
· The setting in HWTACACS scheme view takes precedence over the setting in system view.
You can specify a maximum of 16 source IP addresses in system view, including:
· Zero or one public-network source IPv4 address.
· Zero or one public-network source IPv6 address.
· Private-network source IP addresses.
Each VPN instance can have only one private-network source IPv4 address and one private-network source IPv6 address in system view.
You can specify only one source interface to provide the source IP address for outgoing HWTACACS packets. Make sure the route between the source interface and the HWTACACS server is reachable.
The source interface configuration and the source IP address configuration overwrite each other.
# Specify IP address 129.10.10.1 as the source IP address for HWTACACS packets.
[Sysname] hwtacacs nas-ip 129.10.10.1
nas-ip (HWTACACS scheme view)
hwtacacs scheme
Use hwtacacs scheme to create an HWTACACS scheme and enter its view, or enter the view of an existing HWTACACS scheme.
Use undo hwtacacs scheme to delete an HWTACACS scheme.
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
No HWTACACS schemes exist.
hwtacacs-scheme-name: Specifies the HWTACACS scheme name, a case-insensitive string of 1 to 32 characters.
An HWTACACS scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 HWTACACS schemes.
# Create an HWTACACS scheme named hwt1 and enter HWTACACS scheme view.
key (HWTACACS scheme view)
Use key to set the shared key for secure HWTACACS authentication, authorization, or accounting communication.
Use undo key to delete the shared key for secure HWTACACS authentication, authorization, or accounting communication.
key { accounting | authentication | authorization } { cipher | simple } string
undo key { accounting | authentication | authorization }
No shared key is configured for secure HWTACACS authentication, authorization, or accounting communication.
accounting: Specifies the shared key for secure HWTACACS accounting communication.
authentication: Specifies the shared key for secure HWTACACS authentication communication.
authorization: Specifies the shared key for secure HWTACACS authorization communication.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. In non-FIPS mode, the encrypted form of the key is a string of 1 to 373 characters. The plaintext form of the key is a string of 1 to 255 characters. In FIPS mode, the encrypted form of the key is a string of 15 to 373 characters. The plaintext form of the key is a string of 15 to 255 characters. The plaintext string must contain digits, uppercase letters, lowercase letters, and special characters.
The shared keys configured on the device must match those configured on the HWTACACS servers.
# In HWTACACS scheme hwt1, set the shared key to 123456TESTauth&! in plaintext form for secure HWTACACS authentication communication.
[Sysname-hwtacacs-hwt1] key authentication simple 123456TESTauth&!
# Set the shared key to 123456TESTautr&! in plaintext form for secure HWTACACS authorization communication.
[Sysname-hwtacacs-hwt1] key authorization simple 123456TESTautr&!
# Set the shared key to 123456TESTacct&! in plaintext form for secure HWTACACS accounting communication.
[Sysname-hwtacacs-hwt1] key accounting simple 123456TESTacct&!
Use nas-ip to specify a source interface or source IP address for outgoing HWTACACS packets.
Use undo nas-ip to delete the specified source interface or source IP address for outgoing HWTACACS packets.
nas-ip { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo nas-ip [ interface | ipv6 ]
The source IP address of an outgoing HWTACACS packet is that configured by using the hwtacacs nas-ip command in system view.
If the hwtacacs nas-ip command is not used, the source IP address is the primary IP address of the outbound interface.
For an HWTACACS scheme, the following restrictions apply:
· You can specify only one source IPv4 address and one source IPv6 address for outgoing HWTACACS packets.
· You can specify only one source interface to provide the source IP address for outgoing HWTACACS packets. Make sure the route between the source interface and the HWTACACS server is reachable.
· The source interface configuration and the source IP address configuration overwrite each other.
If you do not specify any parameter for the undo nas-ip command, the command deletes the configured source IPv4 address for outgoing HWTACACS packets.
# In HWTACACS scheme hwt1, specify IP address 10.1.1.1 as the source address for outgoing HWTACACS packets.
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
hwtacacs nas-ip
primary accounting (HWTACACS scheme view)
Use primary accounting to specify the primary HWTACACS accounting server.
Use undo primary accounting to restore the default.
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS accounting server is not specified.
host-name: Specifies the host name of the primary HWTACACS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies an IPv4 address of the primary HWTACACS accounting server.
ipv6 ipv6-address: Specifies an IPv6 address of the primary HWTACACS accounting server.
port-number: Specifies the service port number of the primary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS accounting server.
single-connection: The device and the primary HWTACACS accounting server use the same TCP connection to exchange accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection every time it exchanges accounting packets with the primary accounting server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS accounting server are the same as those configured on the server.
Two accounting servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
As a best practice, specify the single-connection keyword to reduce TCP connections for improving system performance if the HWTACACS server supports the single-connection method.
If the specified server resides on an MPLS L3VPN, specify the VPN instance by using the vpn-instance vpn-instance-name option. The VPN instance specified by this command takes precedence over the VPN instance specified for the HWTACACS scheme.
You can remove an accounting server only when it is not used for user accounting. Removing an accounting server affects only accounting processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] primary accounting 10.163.155.12 49 key simple 123456TESTacct&!
secondary accounting (HWTACACS scheme view)
vpn-instance (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
Use primary authentication to specify the primary HWTACACS authentication server.
Use undo primary authentication to restore the default.
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS authentication server is not specified.
host-name: Specifies the host name of the primary HWTACACS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authentication server.
port-number: Specifies the service port number of the primary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authentication server.
single-connection: The device and the primary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection every time it exchanges authentication packets with the primary authentication server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS authentication server are the same as those configured on the server.
Two authentication servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
You can remove an authentication server only when it is not used for user authentication. Removing an authentication server affects only authentication processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49 key simple 123456TESTauth&!
secondary authentication (HWTACACS scheme view)
primary authorization
Use primary authorization to specify the primary HWTACACS authorization server.
Use undo primary authorization to restore the default.
primary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
The primary HWTACACS authorization server is not specified.
host-name: Specifies the host name of the primary HWTACACS authorization server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of the primary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of the primary HWTACACS authorization server.
port-number: Specifies the service port number of the primary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the primary HWTACACS authorization server.
single-connection: The device and the primary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection every time it exchanges authorization packets with the primary authorization server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the primary HWTACACS authorization server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the primary HWTACACS authorization server are the same as those configured on the server.
Two authorization servers specified for a scheme, primary or secondary, cannot have identical VPN instance, host name, IP address, and port number settings.
You can remove an authorization server only when it is not used for user authorization. Removing an authorization server affects only authorization processes that occur after the remove operation.
# In HWTACACS scheme hwt1, specify the primary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49 key simple 123456TESTautr&!
secondary authorization (HWTACACS scheme view)
Use reset hwtacacs statistics to clear HWTACACS statistics.
reset hwtacacs statistics { accounting | all | authentication | authorization }
accounting: Clears the HWTACACS accounting statistics.
all: Clears all HWTACACS statistics.
authentication: Clears the HWTACACS authentication statistics.
authorization: Clears the HWTACACS authorization statistics.
# Clear all HWTACACS statistics.
<Sysname> reset hwtacacs statistics all
Use reset stop-accounting-buffer to clear buffered HWTACACS stop-accounting requests to which no responses have been received.
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
# Clear nonresponded stop-accounting requests buffered for HWTACACS scheme hwt1.
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
Use retry stop-accounting to set the maximum number of transmission attempts for individual HWTACACS stop-accounting requests.
Use undo retry stop-accounting to restore the default.
retry stop-accounting retries
The maximum number of transmission attempts for individual HWTACACS stop-accounting requests is 100.
retries: Specifies the maximum number of transmission attempts for HWTACACS stop-accounting requests. The value range is 1 to 300.
# In HWTACACS scheme hwt1, set the maximum number of HWTACACS stop-accounting attempts to 300.
[Sysname-hwtacacs-hwt1] retry stop-accounting 300
timer response-timeout (HWTACACS scheme view)
Use secondary accounting to specify a secondary HWTACACS accounting server.
Use undo secondary accounting to remove a secondary HWTACACS accounting server.
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary accounting [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary HWTACACS accounting servers are specified.
host-name: Specifies the host name of a secondary HWTACACS accounting server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS accounting server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS accounting server.
port-number: Specifies the service port number of the secondary HWTACACS accounting server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS accounting server.
single-connection: The device and the secondary HWTACACS accounting server use the same TCP connection to exchange all accounting packets for all users. If you do not specify this keyword, the device establishes a new TCP connection every time it exchanges accounting packets with the secondary accounting server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS accounting server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the secondary HWTACACS accounting server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS accounting servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary accounting command, the command removes all secondary accounting servers.
# In HWTACACS scheme hwt1, specify a secondary accounting server with IP address 10.163.155.12, TCP port number 49, and plaintext shared key 123456TESTacct&!.
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49 key simple 123456TESTacct&!
Use secondary authentication to specify a secondary HWTACACS authentication server.
Use undo secondary authentication to remove a secondary HWTACACS authentication server.
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authentication [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary HWTACACS authentication servers are specified.
host-name: Specifies the host name of a secondary HWTACACS authentication server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS authentication server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS authentication server.
port-number: Specifies the service port number of the secondary HWTACACS authentication server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authentication server.
single-connection: The device and the secondary HWTACACS authentication server use the same TCP connection to exchange all authentication packets for all users. If you do not specify this keyword, the device establishes a new TCP connection every time it exchanges authentication packets with the secondary authentication server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS authentication server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of each secondary HWTACACS authentication server are the same as those configured on the corresponding server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authentication servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authentication command, the command removes all secondary authentication servers.
# In HWTACACS scheme hwt1, specify a secondary authentication server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTauth&!.
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49 key simple 123456TESTauth&!
Use secondary authorization to specify a secondary HWTACACS authorization server.
Use undo secondary authorization to remove a secondary HWTACACS authorization server.
secondary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authorization [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
No secondary HWTACACS authorization servers are specified.
host-name: Specifies the host name of a secondary HWTACACS authorization server, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies the IPv4 address of a secondary HWTACACS authorization server.
ipv6 ipv6-address: Specifies the IPv6 address of a secondary HWTACACS authorization server.
port-number: Specifies the service port number of the secondary HWTACACS authorization server. The value range for the TCP port number is 1 to 65535. The default setting is 49.
key: Specifies the shared key for secure communication with the secondary HWTACACS authorization server.
single-connection: The device and the secondary HWTACACS authorization server use the same TCP connection to exchange all authorization packets for all users. If you do not specify this keyword, the device establishes a new TCP connection every time it exchanges authorization packets with the secondary authorization server for a user.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the secondary HWTACACS authorization server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Make sure the port number and shared key settings of the secondary HWTACACS authorization server are the same as those configured on the server.
An HWTACACS scheme supports a maximum of 16 secondary HWTACACS authorization servers. If the primary server fails, the device tries to communicate with a secondary server in active state. The device connects to the secondary servers in the order they are configured.
If you do not specify any parameters for the undo secondary authorization command, the command removes all secondary authorization servers.
# In HWTACACS scheme hwt1, specify a secondary authorization server with IP address 10.163.155.13, TCP port number 49, and plaintext shared key 123456TESTautr&!.
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49 key simple 123456TESTautr&!
primary authorization (HWTACACS scheme view)
snmp-agent trap enable hwtacacs
Use snmp-agent trap enable hwtacacs to enable SNMP notifications for HWTACACS.
Use undo snmp-agent trap enable hwtacacs to disable SNMP notifications for HWTACACS.
snmp-agent trap enable hwtacacs [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up | authorization-server-down | authorization-server-up ] *
undo snmp-agent trap enable hwtacacs [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up | authorization-server-down | authorization-server-up ] *
All types of SNMP notifications for HWTACACS are disabled.
accounting-server-down: Specifies notifications to be sent when the HWTACACS accounting server becomes unreachable.
accounting-server-up: Specifies notifications to be sent when the HWTACACS accounting server becomes reachable.
authentication-server-down: Specifies notifications to be sent when the HWTACACS authentication server becomes unreachable.
authentication-server-up: Specifies notifications to be sent when the HWTACACS authentication server becomes reachable.
authorization-server-down: Specifies notifications to be sent when the HWTACACS authorization server becomes unreachable.
authorization-server-up: Specifies notifications to be sent when the HWTACACS authorization server becomes reachable.
If you do not specify any keywords, this command enables or disables all types of notifications for RADIUS.
When SNMP notifications for HWTACACS are enabled, the device supports the following notifications generated by HWTACACS:
· HWTACACS server unreachable notification—The HWTACACS server cannot be reached. The NAS generates this notification if it cannot receive any response to an accounting, authentication, or authorization request within the specified HWTACACS request transmission attempts.
· HWTACACS server reachable notification—The HWTACACS server can be reached. The NAS generates this notification for a previously blocked HWTACACS server after the quiet timer expires and sets the server state to active.
# Enable the device to send HWTACACS accounting server unreachable notifications.
[Sysname] snmp-agent trap enable hwtacacs accounting-server-down
Use stop-accounting-buffer enable to enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
Use undo stop-accounting-buffer enable to disable buffering of HWTACACS stop-accounting requests to which no responses have been received.
The device buffers HWTACACS stop-accounting requests to which no responses have been received.
This command enables the device to buffer an HWTACACS stop-accounting request to which no response has been received. The device resends the buffered request until it receives a server response or when the number of transmission attempts reaches the maximum (set by using the retry stop-accounting command). If no more attempts are available, the device discards the request. However, if you have removed an accounting server, stop-accounting requests destined for the server are not buffered.
# Enable buffering of HWTACACS stop-accounting requests to which no responses have been received.
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
timer quiet (HWTACACS scheme view)
Use timer quiet to set the quiet timer for the servers specified in an HWTACACS scheme.
timer quiet minutes
undo timer quiet
The server quiet period is 5 minutes.
minutes: Specifies the server quiet period in minutes, in the range of 1 to 255.
# In HWTACACS scheme hwt1, set the server quiet timer to 10 minutes.
[Sysname-hwtacacs-hwt1] timer quiet 10
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting minutes
minutes: Specifies the real-time accounting interval in minutes, in the range of 0 to 60. Setting this interval to 0 disables the device from sending online user accounting information to the HWTACACS accounting server.
For real-time accounting, a NAS must transmit the accounting information of online users to the HWTACACS accounting server periodically. This command is used to set the interval.
Table 31 Recommended real-time accounting intervals
Number of users |
1 to 99 |
3 minutes |
100 to 499 |
6 minutes |
500 to 999 |
12 minutes |
1000 or more |
The device sends a start-accounting packet for a dual-stack user after the user obtains an IP address of one stack. No matter how long the real-time accounting interval is, the device sends an update-accounting packet for the user immediately after the user obtains an IP address of another stack.
# In HWTACACS scheme hwt1, set the real-time accounting interval to 51 minutes.
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
Use timer response-timeout to set the HWTACACS server response timeout timer.
The HWTACACS server response timeout time is 5 seconds.
seconds: Specifies the HWTACACS server response timeout time, in the range of 1 to 300 seconds.
HWTACACS is based on TCP. When the server response timeout timer or the TCP timeout timer times out, the device is disconnected from the HWTACACS server.
The client timeout period of the associated access module cannot be shorter than the total response timeout timer of all HWTACACS servers in the scheme. Any violation will result in user logoffs before the authentication, authorization, or accounting process is complete.
# In HWTACACS scheme hwt1, set the HWTACACS server response timeout timer to 30 seconds.
[Sysname-hwtacacs-hwt1] timer response-timeout 30
Use user-name-format to specify the format of the username to be sent to an HWTACACS server.
The ISP domain name is included in the usernames sent to an HWTACACS server.
keep-original: Sends the username to the HWTACACS server as the username is entered.
with-domain: Includes the ISP domain name in the username sent to the HWTACACS server.
without-domain: Excludes the ISP domain name from the username sent to the HWTACACS server.
A username is generally in the userid@isp-name format, of which the isp-name argument is used by the device to determine the ISP domain to which a user belongs. However, some HWTACACS servers cannot recognize a username containing an ISP domain name. Before sending a username including a domain name to such an HWTACACS server, the device must remove the domain name. This command allows you to specify whether to include a domain name in a username to be sent to an HWTACACS server.
If an HWTACACS scheme defines that the username is sent without the ISP domain name, do not apply the scheme to more than one ISP domain. Otherwise, the HWTACACS server will consider two users in different ISP domains but with the same userid as one user.
# In HWTACACS scheme hwt1, configure the device to remove the ISP domain name from the usernames sent to the HWTACACS servers.
[Sysname-hwtacacs-hwt1] user-name-format without-domain
Use vpn-instance to specify an MPLS L3VPN instance for an HWTACACS scheme.
undo vpn-instance
The HWTACACS scheme belongs to the public network.
The VPN instance specified for an HWTACACS scheme applies to all servers in that scheme. If a VPN instance is also configured for an individual HWTACACS server, the VPN instance specified for the HWTACACS scheme does not take effect on that server.
# Specify VPN instance test for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] vpn-instance test
LDAP commands
attribute-map
Use attribute-map to specify the LDAP attribute map in an LDAP scheme.
Use undo attribute-map to restore the default.
attribute-map map-name
undo attribute-map
An LDAP scheme does not use an LDAP attribute map.
LDAP scheme view
map-name: Specifies an LDAP attribute map by its name, a case-insensitive string of 1 to 31 characters.
When the LDAP scheme used for authorization contains an LDAP attribute map, the device converts server-assigned LDAP attributes to device-recognizable AAA attributes based on the mapping entries.
You can specify only one LDAP attribute map in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
If you specify another attribute map or change the mapping entries, the new settings take effect only on the LDAP authorization that occurs after your operation.
# Specify LDAP attribute map map1 in LDAP scheme ldap1.
[Sysname] ldap scheme ldap1
[Sysname-ldap-ldap1] attribute-map map1
display ldap scheme
ldap attribute-map
Use authentication-server to specify the LDAP authentication server for an LDAP scheme.
Use undo authentication-server to restore the default.
authentication-server server-name
No LDAP authentication server is specified for an LDAP scheme.
LDAP scheme view
server-name: Specifies the name of an LDAP server, a case-insensitive string of 1 to 64 characters.
You can specify only one LDAP authentication server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authentication server as ccc.
[Sysname-ldap-ldap1] authentication-server ccc
display ldap scheme
ldap server
Use authorization-server to specify the LDAP authorization server for an LDAP scheme.
Use undo authorization-server to restore the default.
authorization-server server-name
No LDAP authorization server is specified for an LDAP scheme.
LDAP scheme view
You can specify only one LDAP authorization server in an LDAP scheme. If you execute this command multiple times, the most recent configuration takes effect.
# In LDAP scheme ldap1, specify the LDAP authorization server as ccc.
[Sysname-ldap-ldap1] authorization-server ccc
display ldap scheme
ldap server
display ldap scheme
Use display ldap scheme to display LDAP scheme configuration.
display ldap scheme [ ldap-scheme-name ]
ldap-scheme-name: Specifies an LDAP scheme by its name, a case-insensitive string of 1 to 32 characters. If you do not specify an LDAP scheme, this command displays the configuration of all LDAP schemes.
# Display the configuration of all LDAP schemes.
<Sysname> display ldap scheme
Total 1 LDAP schemes
LDAP scheme name : aaa
Authentication server : aaa
IP : 1.1.1.1
Port : 111
VPN instance : Not configured
LDAP protocol version : LDAPv3
Server timeout interval : 10 seconds
Login account DN : Not configured
Base DN : Not configured
Search scope : all-level
User searching parameters:
User object class : Not configured
Username attribute : cn
Username format : with-domain
Authorization server : aaa
IP : 1.1.1.1
Port : 111
Attribute map : map1
Table 32 Command output
Authentication server |
Name of the LDAP authentication server. If no server is configured, this field displays Not configured. |
Authorization server |
Name of the LDAP authorization server. If no server is configured, this field displays Not configured. |
IP |
IP address of the LDAP server. If no server is specified, this field displays Not configured. |
Port |
Port number of the server. If no port number is specified, this field displays the default port number. |
VPN instance |
MPLS L3VPN instance to which the LDAP server belongs. If no VPN instance is specified, this field displays Not configured. |
LDAP protocol version |
LDAP version, LDAPv2 or LDAPv3. |
Server timeout interval |
LDAP server timeout period, in seconds. |
Login account DN |
DN of the administrator. |
Base DN |
Base DN for user search. |
Search scope |
User DN search scope, including: · all-level—All subdirectories. · single-level—Next lower level of subdirectories under the base DN. |
User searching parameters |
User search parameters. |
User object class |
User object class for user DN search. If no user object class is configured, this field displays Not configured. |
Username attribute |
User account attribute for login. |
Username format |
Format for the username sent to the server. |
Attribute map |
LDAP attribute map used by the scheme. If no LDAP attribute map is used, this field displays Not configured. |
ip
Use ip to configure the IP address of the LDAP server.
Use undo ip to restore the default.
ip ip-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ip
An LDAP server does not have an IP address.
LDAP server view
ip-address: Specifies the IP address of the LDAP server.
port port-number: Specifies the TCP port number of the LDAP server. The value range for the port-number argument is 1 to 65535, and the default value is 389.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the LDAP server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
The LDAP service port configured on the device must be consistent with the service port of the LDAP server.
If you change the IP address and port number of the LDAP server, the change takes effect only on the LDAP authentication that occurs after the change.
# Specify the IP address and port number as 192.168.0.10 and 4300 for LDAP server ccc.
[Sysname] ldap server ccc
[Sysname-ldap-server-ccc] ip 192.168.0.10 port 4300
ldap server
ipv6
Use ipv6 to configure the IPv6 address of the LDAP server.
Use undo ipv6 to restore the default.
ipv6 ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6
An LDAP server does not have an IPv6 address.
LDAP server view
ipv6-address: Specifies the IPv6 address of the LDAP server.
# Specify the IPv6 address and port number as 1:2::3:4 and 4300 for LDAP server ccc.
[Sysname-ldap-server-ccc] ipv6 1:2::3:4 port 4300
ldap server
ldap attribute-map
Use ldap attribute-map to create an LDAP attribute map and enter its view, or enter the view of an existing LDAP attribute map.
Use undo ldap attribute-map to delete an LDAP attribute map.
ldap attribute-map map-name
undo ldap attribute-map map-name
No LDAP attribute maps exist.
map-name: Specifies the name of the LDAP attribute map, a case-insensitive string of 1 to 31 characters.
Execute this command multiple times to create multiple LDAP attribute maps. You can add multiple mapping entries to an LDAP attribute map. Each entry defines the mapping between an LDAP attribute and an AAA attribute.
# Create an LDAP attribute map named map1 and enter LDAP attribute map view.
[Sysname] ldap attribute-map map1
[Sysname-ldap-map-map1]
attribute-map
ldap scheme
map
ldap scheme
Use ldap scheme to create an LDAP scheme and enter its view, or enter the view of an existing LDAP scheme.
Use undo ldap scheme to delete an LDAP scheme.
ldap scheme ldap-scheme-name
undo ldap scheme ldap-scheme-name
No LDAP schemes exist.
ldap-scheme-name: Specifies the LDAP scheme name, a case-insensitive string of 1 to 32 characters.
An LDAP scheme can be used by more than one ISP domain at the same time.
You can configure a maximum of 16 LDAP schemes.
# Create an LDAP scheme named ldap1 and enter LDAP scheme view.
display ldap scheme
ldap server
Use ldap server to create an LDAP server and enter its view, or enter the view of an existing LDAP server.
Use undo ldap server to delete an LDAP server.
ldap server server-name
undo ldap server server-name
No LDAP servers exist.
server-name: Specifies the LDAP server name, a case-insensitive string of 1 to 64 characters.
# Create an LDAP server named ccc and enter LDAP server view.
display ldap scheme
login-dn
Use login-dn to specify the administrator DN.
Use undo login-dn to restore the default.
login-dn dn-string
undo login-dn
No administrator DN is specified.
LDAP server view
dn-string: Specifies the administrator DN for binding with the server, a case-insensitive string of 1 to 255 characters.
The administrator DN specified on the device must be consistent with the administrator DN configured on the LDAP server.
If you change the administrator DN, the change takes effect only on the LDAP authentication that occurs after the change.
# Specify the administrator DN as uid=test, ou=people, o=example, c=city for LDAP server ccc.
[Sysname-ldap-server-ccc] login-dn uid=test,ou=people,o=example,c=city
display ldap scheme
login-password
Use login-password to configure the administrator password for binding with the LDAP server during LDAP authentication.
Use undo login-password to restore the default.
login-password { cipher | simple } string
undo login-password
No administrator password is configured.
LDAP server view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 128 characters. Its encrypted form is a case-sensitive string of 1 to 201 characters.
This command takes effect only after the login-dn command is used.
# Specify the administrator password as abcdefg in plaintext form for LDAP server ccc.
[Sysname-ldap-server-ccc] login-password simple abcdefg
display ldap scheme
login-dn
map
Use map to configure a mapping entry in an LDAP attribute map.
Use undo map to delete the specified mapping entries from the LDAP attribute map.
map ldap-attribute ldap-attribute-name [ prefix prefix-value delimiter delimiter-value ] aaa-attribute user-group
undo map [ ldap-attribute ldap-attribute-name ]
An LDAP attribute map does not contain mapping entries.
ldap-attribute ldap-attribute-name: Specifies an LDAP attribute by its name. The ldap-attribute-name argument is a case-insensitive string of 1 to 63 characters.
prefix prefix-value delimiter delimiter-value: Specifies a partial value string of the LDAP attribute for attribute mapping. The prefix-value argument represents the position where the partial string starts. The prefix is a case-insensitive string of 1 to 7 characters, such as cn=. The delimiter-value argument represents the position where the partial string ends, such as a comma (,). If you do not specify the prefix prefix-value delimiter delimiter-value option, the mapping entry uses the entire value string of the LDAP attribute.
aaa-attribute: Specifies an AAA attribute.
user-group: Specifies the user group attribute.
Because the device ignores unrecognized LDAP attributes, configure the mapping entries to include important LDAP attributes that should not be ignored.
An LDAP attribute can be mapped only to one AAA attribute. Different LDAP attributes can be mapped to the same AAA attribute.
If you do not specify an LDAP attribute for the undo map command, the command deletes all mapping entries from the LDAP attribute map.
# In LDAP attribute map map1, map a partial value string of the LDAP attribute named memberof to AAA attribute named user-group.
[Sysname-ldap-map-map1] map ldap-attribute memberof prefix cn= delimiter , aaa-attribute user-group
ldap attribute-map
user-group
protocol-version
Use protocol-version to specify the LDAP version.
Use undo protocol-version to restore the default.
protocol-version { v2 | v3 }
The LDAP version is LDAPv3.
LDAP server view
v2: Specifies the LDAP version LDAPv2.
v3: Specifies the LDAP version LDAPv3.
For successful LDAP authentication, the LDAP version used by the device must be consistent with the version used by the LDAP server.
If you change the LDAP version, the change takes effect only on the LDAP authentication that occurs after the change.
A Microsoft LDAP server supports only LDAPv3.
# Specify the LDAP version as LDAPv2 for LDAP server ccc.
[Sysname-ldap-server-ccc] protocol-version v2
display ldap scheme
search-base-dn
Use search-base-dn to specify the base DN for user search.
Use undo search-base-dn to restore the default.
search-base-dn base-dn
undo search-base-dn
No base DN is specified for user search.
LDAP server view
base-dn: Specifies the base DN for user search, a case-insensitive string of 1 to 255 characters.
# Specify the base DN for user search as dc=ldap,dc=com for LDAP server ccc.
[Sysname-ldap-server-ccc] search-base-dn dc=ldap,dc=com
display ldap scheme
ldap server
search-scope
Use search-scope to specify the user search scope.
Use undo search-scope to restore the default.
search-scope { all-level | single-level }
undo search-scope
The user search scope is all-level.
LDAP server view
all-level: Specifies that the search goes through all subdirectories of the base DN.
single-level: Specifies that the search goes through only the next lower level of subdirectories under the base DN.
# Specify the search scope for the LDAP authentication as all subdirectories of the base DN for LDAP server ccc.
[Sysname-ldap-server-ccc] search-scope all-level
display ldap scheme
ldap server
server-timeout
Use server-timeout to set the LDAP server timeout period, the maximum time that the device waits for an LDAP response.
Use undo server-timeout to restore the default.
server-timeout time-interval
undo server-timeout
The LDAP server timeout period is 10 seconds.
LDAP server view
time-interval: Specifies the LDAP server timeout period in the range of 5 to 20 seconds.
If you change the LDAP server timeout period, the change takes effect only on the LDAP authentication that occurs after the change.
# Set the LDAP server timeout period to 15 seconds for LDAP server ccc.
[Sysname-ldap-server-ccc] server-timeout 15
display ldap scheme
user-parameters
Use user-parameters to configure LDAP user attributes, including the username attribute, username format, and user-defined user object class.
Use undo user-parameters to restore the default of an LDAP user attribute.
user-parameters { user-name-attribute { name-attribute | cn | uid } | user-name-format { with-domain | without-domain } | user-object-class object-class-name }
undo user-parameters { user-name-attribute | user-name-format | user-object-class }
The LDAP username attribute is cn and the username format is without-domain. No user object class is specified and the default user object class of the LDAP server is used.
LDAP server view
user-name-attribute { name-attribute | cn | uid }: Specifies the username attribute. The name-attribute argument represents an attribute value, a case-insensitive string of 1 to 64 characters. The cn keyword represents the user account attribute of common name, and the uid keyword represents the user account attribute of user ID.
user-name-format { with-domain | without-domain }: Specifies the format of the username to be sent to the server. The with-domain keyword means that the username contains the domain name, and the without-domain keyword means that the username does not contain the domain name.
user-object-class object-class-name: Specifies the user object class for user search. The object-class-name argument represents a class value, a case-insensitive string of 1 to 64 characters.
If the username on the LDAP server does not contain the domain name, specify the without-domain keyword. If the username contains the domain name, specify the with-domain keyword.
# Set the user object class to person for LDAP server ccc.
[Sysname-ldap-server-ccc] user-parameters user-object-class person
display ldap scheme
login-dn
RADIUS server commands
display radius-server active-client
Use display radius-server active-client to display information about activated RADIUS clients.
# Display information about all activated RADIUS clients.
<Sysname> display radius-server active-client
Total 2 RADIUS clients.
Client IP: 2.2.2.2
Client IP: 3.3.3.3
radius-server client
display radius-server active-user
Use display radius-server active-user to display information about activated RADIUS users.
display radius-server active-user [ user-name ]
user-name: Specifies a RADIUS user name, a case-sensitive string of 1 to 55 characters. The name must meet the following requirements:
· Cannot contain a domain name.
· Cannot contain any of the following characters: forward slash (/), backslash (\), vertical bar (|), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
· Cannot be a, al, or all.
If you do not specify a RADIUS user name, this command displays information about all RADIUS users.
# Display information about the activated RADIUS user named test.
<Sysname> display radius-server active-user test
Total 1 RADIUS users matched.
Username: test
Description: A network access user from company cc
Authorization attributes:
VLAN ID: 2
ACL number: 2000
Validity period:
Expiration time: 2015/04/03-18:00:00
# Display information about all activated RADIUS users.
Total 2 RADIUS users matched.
Username: 123
VLAN ID: 2
ACL number: 3000
Validity period:
Expiration time: 2016/04/03-18:00:00
Username: 456
VLAN ID: 2
ACL number: 3000
Validity period:
Table 33 Command output
Username |
RADIUS user name. |
Description of the RADIUS user. |
Authorization attributes |
Authorization attributes of the RADIUS user. |
VLAN ID |
Authorization VLAN. |
ACL number |
Authorization ACL. |
Validity period |
Validity time period of the RADIUS user. |
Expiration time |
Expiration date and time. |
local-user
radius-server activate
Use radius-server activate to activate the RADIUS server configuration, including RADIUS clients and users.
Use this command to immediately activate the most recent RADIUS server configuration after you have added, modified, or deleted RADIUS clients and network access users from which RADIUS user data is generated.
Executing this command restarts the RADIUS server process and an authentication service interruption will occur during the restart.
# Activate the RADIUS server configuration.
[Sysname] radius-server activate
Use radius-server client to configure a RADIUS client.
Use undo radius-server client to delete a RADIUS client.
radius-server client ip ipv4-address key { cipher | simple } string
undo radius-server client { all | ip ipv4-address }
No RADIUS clients are specified.
ip ipv4-address: Specifies the IPv4 address of the RADIUS client, which must be a Class A, B, or C address and the first octet cannot be 0 or 127.
key: Specifies the shared key to communicate with the RADIUS client.
string: Specifies a case-sensitive key string. The encrypted form of the key is a string of 1 to 117 characters. The plaintext form of the key is a string of 1 to 64 characters.
all: Specifies all RADIUS clients.
The IP address of a RADIUS client must be the same as the source IP address for outgoing RADIUS packets specified on the RADIUS client.
The shared key of a RADIUS client must be the same as the setting on the RADIUS client.
Execute this command multiple times to configure multiple RADIUS clients.
# Configure a RADIUS client whose IP address is 2.2.2.2 and shared key is test in plaintext.
[Sysname] radius-server client ip 2.2.2.2 key simple test
Connection recording policy commands
aaa connection-recording policy
Use aaa connection-recording policy to create a connection recording policy and enter its view, or enter the view of an existing connection recording policy.
Use aaa connection-recording policy to delete the connection recording policy.
undo aaa connection-recording policy
The connection recording policy does not exist.
Use this feature on scenarios where the device acts as an FTP, SSH, SFTP, or Telnet login client to establish a connection with a login server. This feature enables the device to provide an accounting server with the connection start and termination information. When the login client establishes a connection with the login server, the system sends a start-accounting request to the accounting server. When the connection is terminated, the system sends a stop-accounting request to the accounting server.
# Create a connection recording policy and enter its view.
[Sysname] aaa connection-recording policy
[sysname-connection-recording-policy]
accounting hwtacacs-scheme
display aaa connection-recording policy
Use accounting hwtacacs-scheme to specify the accounting method for the connection recording policy.
Use undo accounting to restore the default.
accounting hwtacacs-scheme hwtacacs-scheme-name
undo accounting
No accounting method is specified for the connection recording policy. No accounting is performed on the connections initiated by the device as a login client.
Connection recording policy view
If the accounting method is changed, the new method takes effect only on subsequent connections initiated by the device as a login client.
For a connection, once the device sends the start-accounting request to an HWTACACS server, it sends the connection's stop-accounting packet to the same server.
The device includes the username entered by a user in the accounting packets to be sent to the AAA server for connection recording. The username format configured by using the user-name-format command in the accounting scheme does not take effect.
# Create a connection recording policy, and specify HWTACACS scheme tac as the accounting method.
[sysname-connection-recording-policy] accounting hwtacacs-scheme tac
Use display aaa connection-recording policy to display the connection recording policy configuration.
# Display the connection recording policy configuration.
<Sysname> display aaa connection-recording policy
Connection-recording policy:
Accounting scheme: HWTACACS=tac1
