12-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS9850-G SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S6850-G&S6805-G&S9850-G Switch Series Configuration Guides-R8336Pxx-6W10012-Network Management and Monitoring Configuration Guide
23-Performance management configuration
23-Performance management configuration 130.08 KB
Managing device performance
About performance management
The performance management feature samples device performance and collects performance statistics, such as packet drop statistics in the inbound and outbound directions on an interface. You can use commands on the device to display the statistics or configure the device to transfer the statistics to a network management server through gRPC or NETCONF.
For more information about gRPC, see gRPC configuration in Telemetry Configuration Guide.
Figure 1 Performance management diagram
Restrictions and guidelines: Performance management
This feature supports collecting only statistics for traffic on interfaces in the current software version.
Performance management tasks at a glance
To manage device performance, perform the following tasks:
1.     Configuring performance statistics tasks
2.     Enabling performance statistics
A performance statistics task periodically samples performance and collects performance statistics.
A performance statistics task contains the following parameters:
·     Instance—Object for which you want to collect performance statistics. The current software version supports only physical interfaces and tunnel interfaces.
·     Performance sampling interval—Intervals at which the device samples performance data.
·     Performance statistics interval—Intervals at which the device collects performance statistics, including the peak values, valley values, and average values.
Changing the sampling interval or statistics interval for a performance statistics task deletes all performance statistics for the task and recollects the performance statistics.
Changing the statistics interval also changes the sampling interval to the default corresponding to the new statistics interval.
Deleting a performance statistics task terminates the task and deletes all performance statistics for the task.
Table 1 ‍Enter system view.
2.     Enter performance management view.
performance-management
3.     Create a performance statistics task and enter its view.
statistics task task-name
By default, no performance statistics tasks exist in the system.
The device supports a maximum of 16 performance statistics task.
4.     Bind a performance management instance to the performance statistics task.
binding instance-type instance-type { all { physical | tunnel } | instance { instance-name } &<1-8> }
By default, no performance management instances are bound to a performance statistics task.
5.     Set the performance statistics interval.
statistics interval interval
The default statistics interval is 15 minutes.
6.     Set the performance sampling interval.
sample interval interval
The default sampling interval and the possible sampling interval values vary by statistics interval, as shown in the following table:
Statistics interval (minutes)
Default sampling interval (seconds)
Available sampling interval values (seconds)
5
5
5, 10, 15, and 30
10
5
5, 10, 15, 30, and 60
15
5
30
60
60
300
5, 10, 15, 30, 60, and 300
1440
900
300, 600, 900, 1800, and 3600
3.     Enable performance statistics.
statistics enable
By default, performance statistics is disabled.
Display and maintenance commands for performance management configuration
Display the performance statistics for a performance statistics task.
display performance-management statistics task-name data index [ instance-type instance-type-name [ measure measure-name | instance { instance-name } &<1-8> ] * ]
Display performance statistics task information.
display performance-management task [ task-name ]
Performance management configuration examples
Example: Configuring performance management (gRPC)
As shown in Figure 2, configure Device B as a gRPC client to report performance statistics for Ten-GigabitEthernet 1/0/1 to the gRPC server. Set the sampling interval to 5 seconds and the statistics interval to 15 minutes.
Figure 2 Network diagram
Table 2 Interface label and interface name mappings
Interface label
Interface name
Interface1
Ten-GigabitEthernet1/0/1
Interface2
Ten-GigabitEthernet1/0/2
1.     Assign IP addresses to interfaces and configure routes. Make sure the network connection is available between the device and the server. (Details not shown.)
2.     Configure Device B as a gRPC client:
# Enable the gRPC service.
[DeviceB] grpc enable
# Create a sensor group named test, and add sensor path ifmgr/devicecapabilities/.
[DeviceB] telemetry
[DeviceB-telemetry] sensor-group test
[DeviceB-telemetry-sensor-group-test] sensor path ifmgr/devicecapabilities
[DeviceB-telemetry-sensor-group-test] quit
# Create a destination group named collector1. Specify a collector that uses IPv4 address 10.1.1.2 and port number 50050.
[DeviceB-telemetry] destination-group collector1
[DeviceB-telemetry-destination-group-collector1] ipv4-address 10.1.1.2 port 50050
[DeviceB-telemetry-destination-group-collector1] quit
# Configure a subscription named A to bind sensor group test with destination group collector1. Set the sampling interval to 900 seconds.
[DeviceB-telemetry] subscription A
[DeviceB-telemetry-subscription-A] sensor-group test sample-interval 900
[DeviceB-telemetry-subscription-A] destination-group collector1
[DeviceB-telemetry-subscription-A] quit
[DeviceB-telemetry] quit
3.     Configure performance management for interface Ten-GigabitEthernet 1/0/1.
# Enter performance management view.
[DeviceB] performance-management
# Create a performance statistics task named task1 and enter its view.
[DeviceB-pm] statistics task task1
# Bind instance Ten-GigabitEthernet 1/0/1 to the task.
[DeviceB-pm-task-task1] binding instance-type interface instance ten-gigabitethernet 1/0/1
# Set the statistics interval to 15 minutes.
[DeviceB-pm-task-task1] statistics interval 15
# Set the sampling interval to 5 seconds.
[DeviceB-pm-task-task1] sample interval 5
[DeviceB-pm-task-task1] quit
# Enable performance statistics.
[DeviceB-pm] statistics enable
# Verify that the gRPC server receives performance statistics for Ten-GigabitEthernet 1/0/1 from Device B at 900-second intervals. (Details not shown.)
Example: Configuring performance management (NETCONF)
As shown in Figure 3, configure Device B as a NETCONF server to report performance statistics for Ten-GigabitEthernet 1/0/1 to the NETCONF client. Set the sampling interval to 5 seconds and the statistics interval to 15 minutes.
Figure 3 Network diagram
Table 3 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
2.     Configure performance management for interface Ten-GigabitEthernet 1/0/1.
3.     Configure the NETCONF settings on Device B. (Details not shown.) For more information, see "Configuring NETCONF."
# Verify that the NETCONF client receives performance statistics for Ten-GigabitEthernet 1/0/1 from Device B at intervals. (Details not shown.)
