H3C S6510 Switch Series Hardware Information and Specifications-6W100
HomeSupportSwitchesS6500 SeriesS6510 SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C S6510 Switch Series Hardware Information and Specifications-6W100
01-Text
01-Text 1.42 MB
1 Product models and technical specifications
Product models
Product series
Product code
Product model
S6510 series
S6510-50QS
LS-6510-50QS
S6510-2C
LS-6510-2C
Technical specifications
Table1-1 Technical specifications
Item
S6510-50QS
S6510-2C
Physical specifications
Dimensions (H × W × D)
44 × 440 × 360 mm (1.73 × 17.32 × 14.17 in)
44 × 440 × 400 mm (1.73 × 17.32 × 15.75 in)
Dimensions (H × W × D, with package materials)
120 × 560 × 485 mm (4.72 × 22.05 × 19.09 in)
180 × 678 × 576 mm (7.09 × 26.69 × 22.68 in)
Weight
≤ 7.0 kg (15.43 lb)
≤ 7.5 kg (16.53 lb)
Memory (RAM)
2 GB
2 GB
Flash
1 GB
1 GB
Port type and quantity
Console port
1 × serial console port
·     1 × serial console port
·     1 × Type-C console port
Only the Type-C console port is available when you connect both ports.
USB port
1
1
Management Ethernet port
1
1
SFP+ port
24
8
QSFP+ port
2
N/A
SFP28 port
N/A
4
10/100/1000BASE-T autosensing Ethernet port
24
N/A
Interface module and power supply slots
Interface module slot
N/A
2
Power supply slot
2
2
Power supply specifications
Power input type
AC input and DC input
Note:
For DC input, you can use a –48 VDC power source in the equipment room or an RPS (H3C RPS1600-A).
See "Removable power supplies"
System power consumption
Power consumption (static)
Data collection standard: no load
Single AC input: 38 W
Dual AC inputs: 45 W
Single DC input: 38 W
Dual DC inputs: 45 W
Single AC input: 28 W
Dual AC inputs: 35 W
Single DC input: 31 W
Dual DC inputs: 37 W
Power consumption (typical)
Data collection standard: fully configured with copper cables or network cables, 30% traffic
Single AC input: 76 W
Dual AC inputs: 82 W
Single DC input: 76 W
Dual DC inputs: 82 W
Single AC input: 72 W
Dual AC inputs: 75 W
Single DC input: 75 W
Dual DC inputs: 80 W
Power consumption (full load)
Data collection standard: fully configured with transceiver modules or network cables, 100% traffic
Single AC input: 85 W
Dual AC inputs: 92 W
Single DC input: 85 W
Dual DC inputs: 92 W
Single AC input: 91 W
Dual AC inputs: 94 W
Single DC input: 95 W
Dual DC inputs: 101 W
System thermal consumption
Thermal consumption (static)
Single AC input: 129.66 BTU/hr
Dual AC inputs: 153.55 BTU/hr
Single DC input: 129.66 BTU/hr
Dual DC inputs: 153.55 BTU/hr
Single AC input: 96 BTU/hr
Dual AC inputs: 119 BTU/hr
Single DC input: 106 BTU/hr
Dual DC inputs: 126 BTU/hr
Thermal consumption (typical)
Single AC input: 259.32 BTU/hr
Dual AC inputs: 279.80 BTU/hr
Single DC input: 259.32 BTU/hr
Dual DC inputs: 279.80 BTU/hr
Single AC input: 246 BTU/hr
Dual AC inputs: 256 BTU/hr
Single DC input: 256 BTU/hr
Dual DC inputs: 273 BTU/hr
Thermal consumption (full load)
Single AC input: 290.03 BTU/hr
Dual AC inputs: 313.92 BTU/hr
Single DC input: 290.03 BTU/hr
Dual DC inputs: 313.92 BTU/hr
Single AC input: 311 BTU/hr
Dual AC inputs: 321 BTU/hr
Single DC input: 324 BTU/hr
Dual DC inputs: 345 BTU/hr
Heat dissipation
Heat dissipation method
Air cooling
Ventilation aisle
From the port side to the power supply side (facing the front panel)
Reliability and availability
Mean Time Between Failures (MTBF) (years)
105.15
66.95
Mean Time To Repair (MTTR) (hours)
1
Availability
99.999891%
99.99983%
Environment specifications
Sound pressure level at 27°C (80.6°F)
45.3 dBA
47.6 dBA
Altitude
0 to 5000 m (0 to 16404.20 ft)
Operating temperature
–5ºC to +45ºC (23°F to 113°F)
The allowed maximum temperature decreases by 0.33°C (0.59°F) as the altitude increases by 100 m (328.08 ft) from 0 m (0 ft).
–5ºC to +50ºC (23°F to 122°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Relative humidity (non-condensing)
5% to 95%
Compliance
Product compliance
·     Safety standards
·     EMC standards
·     Environmental and eco-friendly standards
2 Chassis views
Chassis views
S6510-50QS
Figure2-1 S6510-50QS front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) SFP+ port
(4) SFP+ port LED
(5) QSFP+ port
(6) QSFP+ port LED
(7) Management Ethernet port LED (ACT/LINK)
(8) Power supply 1 status LED (PWR1)
(9) Power supply 2 status LED (PWR2)
(10) System status LED (SYS)
(11) Mode LED (MODE)
(12) Mode button
(13) USB port
(14) Management Ethernet port (MGMT)
(15) Console port (CONSOLE)
Figure2-2 S6510-50QS rear panel
(1) Grounding screw
(2) Power supply 1
(3) Power supply 2
The S6510-50QS switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-2, two PSR180-12A-B AC power supplies are installed in the power supply slots.
S6510-2C
Figure2-3 S6510-2C front panel
(1) Interface module 1
(2) Interface module 2
(3) Serial console port (CONSOLE)
(4) Interface module 2 status LED (SLOT2)
(5) Interface module 1 status LED (SLOT1)
(6) Power supply 1 status LED (PWR1)
(7) Power supply 2 status LED (PWR2)
(8) System status LED (SYS)
(9) ID LED (ID)
(10) Type-C console port (CONSOLE)
(11) Reset button (RESET)
(12) Management Ethernet port LED (ACT/LINK)
(13) Management Ethernet port (MGMT)
The S6510-2C switch came with the two interface module slots each installed with a filler panel. You can install one or two interface modules for the switch as needed. In Figure2-3, two LSWM28T16SFP interface modules are installed in the interface module slots.
Figure2-4 S6510-2C rear panel
(1) Grounding screw
(2) SFP+ port
(3) SFP+ port LED
(4) SFP28 port
(5) SFP28 port LED
(6) Power supply 1
(7) Power supply 2
(8) USB port
The S6510-2C switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-4, two PSR180-12A-B AC power supplies are installed in the power supply slots.
3 FRUs and compatibility matrixes
The switch uses modular design. Table3-1 describes the FRUs available for the switch.
Table3-1 FRUs and compatibility matrix
FRU model
S6510-50QS
S6510-2C
PSR180-12A-B (air exhausted from the power supply faceplate)
Supported
Supported
PSR180-12A-F (air drawn from the power supply faceplate)
Supported
N/A
PSR180-12D-B (air exhausted from the power supply faceplate)
Supported
Supported
Removable interface modules
LSWM224T
N/A
Supported
LSWM224SFP
N/A
Supported
LSWM28T16SFP
N/A
Supported
LSWM216T8SFP
N/A
Supported
·     The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supplies you have installed on the switch.
·     One power supply can meet the power requirement of the switch. You can install two power supplies on the switch for 1+1 redundancy. The switch supports installation of both an AC power supply and a DC power supply.
4 Removable power supplies
180W AC power supplies (PSR180-12A-B and PSR180-12A-F)
View
The PSR180-12A-F and PSR180-12A-B AC power supplies are similar in views except for their marks and airflow directions.
Figure4-1 PSR180-12A-B AC power supply view
Functions
The PSR180-12A-F and PSR180-12A-B are AC-input and DC-output AC power supplies. They provide an output voltage of 12 V and a maximum output of 180 W.
Table4-1 PSR180-12A-F and PSR180-12A-B power supply features
Feature
Protection function
The power supplies provide protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions.
Support for redundancy
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing.
Support for hot swapping
You can remove one of the power supplies in 1+1 redundancy when the switch is operating.
Table4-2 Technical specifications
Item
Specification
Dimensions (H × W × D, including the handle)
41.1 × 101.6 × 207 mm (1.62 × 4.00 × 8.15 in)
Weight
0.8 kg (1.76 lb)
Rated AC input voltage range
100 VAC to 240 VAC @ 50 Hz or 60 Hz
Maximum AC input voltage range
90 VAC to 290 VAC @ 47 Hz to 63 Hz
Rated input current
N/A
Rated output current
15 A
Rated output voltage
12 V
Rated output power
180 W
Melting current of power supply fuse
6.3 A/250 V
180W DC power supply (PSR180-12D-B)
View
Figure4-2 PSR180-12D-B DC power supply view
Functions
The PSR180-12D-B is a DC-input and DC-output power supply. It provides an output voltage of 12 V and a maximum output of 180 W.
Table4-3 PSR180-12D-B power supply features
Feature
Protection function
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions.
Table4-4 Technical specifications
Item
Specification
Weight
1 kg (2.20 lb)
Rated input voltage range
–48 VDC to –60 VDC
Maximum input voltage range
–36 VDC to –72 VDC
Rated input current
N/A
15 A
12 V
Rated output power
180 W
8 A/125 V
5 Interface modules
The S6510-2C switch provides two interface module slots. Install interface modules in the slots as required.
You can install an interface module in any interface module slot on the S6510-2C switch.
You can install or remove an interface module when the switch is operating correctly. Do not install or remove an interface module while the switch is starting up.
Table5-1 Support of SFP ports on an interface module for the autonegotiation feature
Interface module model
Installation slot
Available transceiver module type
Support for autonegotiation
LSWM224SFP
SLOT1
100M
No.
1G
Yes. This feature is enabled by default. You can disable the feature by using the speed 1000 and duplex full commands.
2.5G
No.
SLOT2
1G
2.5G
No.
LSWM28T16SFP
SLOT1
100M
No.
1G
2.5G
No.
SLOT2
1G
2.5G
No.
LSWM216T8SFP
SLOT1
100M
No.
1G
2.5G
No.
SLOT2
1G
2.5G
No.
Table5-2 Support of 10/100/1000Base-T ports on an interface module for the half duplex mode
Installation slot
Support for the half duplex mode
LSWM224T
SLOT1
Yes.
SLOT2
No.
LSWM216T8SFP
SLOT1
Yes.
SLOT2
No.
LSWM28T16SFP
SLOT1
Yes.
SLOT2
No.
LSWM224T
About LSWM224T
The LSWM224T interface module provides twenty-four 10/100/1000Base-T ports.
Figure5-2 LSWM224T front panel
(3) Ejector lever
(4) Latch
Table5-3 Technical specifications
Item
Specification
41 × 190 × 157 mm (1.61 × 7.48 × 6.18 in)
Weight
0.8 kg (1.76 lb)
N/A
N/A
Power consumption (at full load)
8 W
Ports and LEDs
10/100/1000BASE-T port and LED
Table5-4 10/100/1000BASE-T port specifications
Item
Specification
Connector type
RJ-45
Transmission rate, duplex mode, and auto MDI/MDI-X
·     10 Mbps, full/half duplex
·     100 Mbps, full/half duplex
·     1000 Mbps, full duplex
·     MDI/MDI-X autosensing
Max transmission distance
100 m (328.08 ft)
Transmission medium
Category 5 or above twisted pair cable
Compliant standard
IEEE 802.3i, 802.3u, 802.3ab
Table5-5 10/100/1000BASE-T port LED description
Item
Steady green
A link is present on the port and the port is operating at 1000 Mbps.
Flashing green
The port is receiving or sending data at 1000 Mbps.
Steady yellow
A link is present on the port and the port is operating at 10/100 Mbps.
Flashing yellow
The port is receiving or sending data at 10/100 Mbps.
Off
No module is installed or no link is present on the port.
LSWM224SFP
About LSWM224SFP
The LSWM224SFP interface module provides twenty-four 2.5G/1G SFP ports.
Figure5-3 LSWM224SFP front panel
(1) 2.5G/1G SFP port
(2) 2.5G/1G SFP port LED
(3) Ejector lever
(4) Latch
Table5-6 Technical specifications
Item
Specification
Weight
0.8 kg (1.76 lb)
N/A
N/A
22 W
Ports and LEDs
2.5G/1G SFP port and LED
Table5-7 2.5G/1G SFP port specifications
Item
Specification
Port type
SFP port
Available transceiver modules and cables
·     FE SFP transceiver modules described in Table5-9. (FE SFP transceiver modules are supported only when the interface module is installed in SLOT1.)
·     GE SFP transceiver modules and cables described in Table5-10.
·     2.5G SFP transceiver modules described in Table5-11.
·     To use GE SFP copper transceiver modules, make sure the operating temperature does not exceed 40°C (104°F).
·     To use a 2.5G SFP transceiver module to connect to the peer end, use dual-fiber connection. If single-fiber connection is used, only one end of the link is up, which affects normal communication.
Table5-8 2.5G/1G SFP port LED description
Item
Steady green
A link is present on the port and the port is operating at 2.5 Gbps.
Flashing green
The port is receiving or sending data at 2.5 Gbps.
Steady yellow
A link is present on the port and the port is operating at 1 Gbps/100 Mbps.
Flashing yellow
The port is receiving or sending data at 1 Gbps/100 Mbps.
Off
Table5-9 FE SFP transceiver modules available for the SFP ports
Transceiver module type
Transceiver module model
Central wavelength (nm)
Connector type
Cable specifica
-tions (µm)
Mode band-
width (MHz*km)
Maximum trans-
mission distance
SFP-FE-SX-MM1310-A
1310
LC
50/125, MMF
N/A
2 km (1.24 miles)
62.5/125, MMF
SFP-FE-LX-SM1310-A
1310
LC
9/125, SMF
N/A
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
9/125, SMF
N/A
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
9/125, SMF
N/A
80 km (49.71 miles)
Table5-10 GE SFP transceiver modules and cables available for the SFP ports
Transceiver module
/cable type
Transceiver module
/cable model
Central wave-
length (nm)
Connector type
Cable specifica-
tions (µm)
Mode band-
width (MHz*km)
Maximum trans-
mission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850
LC
50/125, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
50/125, MMF
500/400
550 m (1804.46 ft)
62.5/125, MMF
500
550 m (1804.46 ft)
SFP-GE-LX10-SM1310
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
SFP-GE-LH20-SM1310-I
1310
LC
9/125, SMF
N/A
20 km (12.43 miles)
SFP-GE-LH40-SM1310-I
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
9/125, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
9/125, SMF
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-BIDI-I
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI-I
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
SFP-GE-LH70-SM1490-BIDI
Tx: 1490
Rx: 1550
LC
9/125, SMF
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
Tx: 1550
Rx: 1490
LC
9/125, SMF
N/A
70 km (43.50 miles)
SFP-GE-LH40-SM1310-BIDI
Tx: 1310
Rx: 1550
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
Tx: 1550
Rx: 1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP copper cable
SFP-STACK-Kit
N/A
N/A
SFP copper cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LX-SM1310-BIDI-I and SFP-GE-LX-SM1490-BIDI-I transceiver modules, the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules, and the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module.
Table5-11 2.5G SFP transceiver modules available for the SFP ports
Central wave-
length (nm)
Connec-
tor type
Cable specifica-tions (µm)
Mode band-
width (MHz*km)
Maximum transmission distance
SFP-2.5G-LX10-SM1310-DR
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
SFP-2.5G-LX10-SM1310-DR-L
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
SFP-2.5G-LX03-SM1490-BIDI
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
3 km (1.86 miles)
SFP-2.5G-LX03-SM1310-BIDI
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
3 km (1.86 miles)
IMPORTANT
IMPORTANT:
The SFP-2.5G-LX03-SM1490-BIDI and SFP-2.5G-LX03-SM1310-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-2.5G-LX03-SM1490-BIDI transceiver module, the other end must use the SFP-2.5G-LX03-SM1310-BIDI transceiver module.
LSWM28T16SFP
About LSWM28T16SFP
The LSWM28T16SFP interface module provides eight 10/100/1000Base-T ports and sixteen 2.5G/1G SFP ports.
Figure5-4 LSWM28T16SFP front panel
(3) Ejector lever
(4) Latch
(5) 10/100/1000BASE-T autosensing Ethernet port
(6) 10/100/1000BASE-T autosensing Ethernet port LED
Table5-12 Technical specifications
Item
Specification
Weight
0.8 kg (1.76 lb)
N/A
N/A
16 W
Ports and LEDs
Table5-13 10/100/1000BASE-T port specifications
Item
Specification
Connector type
RJ-45
100 m (328.08 ft)
Transmission medium
Compliant standard
Table5-14 10/100/1000BASE-T port LED description
Item
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
Table5-15 2.5G/1G SFP port specifications
Item
Specifications
Port type
SFP port
·     FE SFP transceiver modules described in Table5-17. (FE SFP transceiver modules are supported only when the interface module is installed in SLOT1)
·     GE SFP transceiver modules and cables described in Table5-18.
·     2.5G SFP transceiver modules described in Table5-19.
Table5-16 2.5G/1G SFP port LED description
Item
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
Table5-17 FE SFP transceiver modules available for the SFP ports
Trans-
ceiver module type
Trans-
ceiver module model
Connector type
Cable specifica-
tions (µm)
Mode band-
width (MHz*km)
SFP-FE-SX-MM1310-A
1310
LC
50/125, MMF
N/A
2 km (1.24 miles)
62.5/125, MMF
SFP-FE-LX-SM1310-A
1310
LC
9/125, SMF
N/A
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
9/125, SMF
N/A
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
9/125, SMF
N/A
80 km (49.71 miles)
Table5-18 GE SFP transceiver modules and cables available for the SFP ports
Transceiver module
/cable type
Transceiver module
/cable model
Central wave-
length (nm)
Connec-
tor type
Cable specifica-
tions (µm)
Mode bandwidth (MHz*km)
Maxi-
mum trans-
mission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850
LC
50/125, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
50/125, MMF
500/400
550 m (1804.46 ft)
62.5/125, MMF
500
550 m (1804.46 ft)
SFP-GE-LX10-SM1310
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
1310
LC
9/125, SMF
N/A
20 km (12.43 miles)
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
9/125, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
9/125, SMF
N/A
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1550
LC
9/125, SMF
N/A
70 km (43.50 miles)
Tx: 1550
Rx: 1490
LC
9/125, SMF
N/A
70 km (43.50 miles)
Tx: 1310
Rx: 1550
LC
9/125, SMF
N/A
40 km (24.86 miles)
Tx: 1550
Rx: 1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP copper cable
SFP-STACK-Kit
N/A
N/A
SFP copper cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
Table5-19 2.5G SFP transceiver modules available for the SFP ports
Trans-
ceiver module type
Trans-
ceiver module model
Central wave-
length (nm)
Connec-
tor type
Cable specifications (µm)
Mode band-
width (MHz*km)
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
3 km (1.86 miles)
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
3 km (1.86 miles)
IMPORTANT
IMPORTANT:
LSWM216T8SFP
About LSWM216T8SFP
The LSWM216T8SFP interface module provides sixteen 10/100/1000Base-T ports and eight 2.5G/1G SFP ports.
Figure5-5 LSWM216T8SFP front panel
(3) Ejector lever
(4) Latch
Table5-20 Technical specifications
Item
Specification
Weight
0.8 kg (1.76 lb)
N/A
N/A
13 W
Ports and LEDs
Table5-21 10/100/1000BASE-T port specifications
Item
Specification
Connector type
RJ-45
100 m (328.08 ft)
Transmission medium
Compliant standard
Table5-22 10/100/1000BASE-T port LED description
Item
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
Table5-23 2.5G/1G SFP port specifications
Item
Specification
Port type
SFP port
·     FE SFP transceiver modules described in Table5-25. (FE SFP transceiver modules are supported only when the interface module is installed in SLOT1)
·     GE SFP transceiver modules and cables described in Table5-26.
·     2.5G SFP transceiver modules described in Table5-27.
Table5-24 2.5G/1G SFP port LED description
Item
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
Table5-25 FE SFP transceiver modules available for the SFP ports
Trans-
ceiver module type
Trans-
ceiver module model
Central wave-
length (nm)
Connector type
Cable specifica-
tions (µm)
Maximum trans-
mission distance
SFP-FE-SX-MM1310-A
1310
LC
50/125, MMF
N/A
2 km (1.24 miles)
62.5/125, MMF
SFP-FE-LX-SM1310-A
1310
LC
9/125, SMF
N/A
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
9/125, SMF
N/A
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
9/125, SMF
N/A
80 km (49.71 miles)
Table5-26 GE SFP transceiver modules and cables available for the SFP ports
Transceiver module
/cable type
Transceiver module
/cable model
Central wave-
length (nm)
Connec
-tor type
Cable specifica-
tions (µm)
Mode band-
width (MHz*km)
Maximum trans-
mission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850
LC
50/125, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
50/125, MMF
500/400
550 m (1804.46 ft)
62.5/125, MMF
500
550 m (1804.46 ft)
SFP-GE-LX10-SM1310
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
1310
LC
9/125, SMF
N/A
20 km (12.43 miles)
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
9/125, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
9/125, SMF
N/A
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1550
LC
9/125, SMF
N/A
70 km (43.50 miles)
Tx: 1550
Rx: 1490
LC
9/125, SMF
N/A
70 km (43.50 miles)
Tx: 1310
Rx: 1550
LC
9/125, SMF
N/A
40 km (24.86 miles)
Tx: 1550
Rx: 1310
LC
9/125, SMF
N/A
40 km (24.86 miles)
SFP copper cable
SFP-STACK-Kit
N/A
N/A
SFP copper cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
Table5-27 2.5G SFP transceiver modules available for the SFP ports
Central wave-
length (nm)
Connec-
tor type
Cable specifica
-tions (µm)
Maximum trans-
mission distance
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
1310
LC
9/125, SMF
N/A
10 km (6.21 miles)
Tx: 1490
Rx: 1310
LC
9/125, SMF
N/A
3 km (1.86 miles)
Tx: 1310
Rx: 1490
LC
9/125, SMF
N/A
3 km (1.86 miles)
IMPORTANT
IMPORTANT:
6 Ports and LEDs
Ports
Console port
Table6-1 Console port specifications (1)
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Speed
9600 bps (default) to 115200 bps
Supported services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local terminal (for example, a PC) running a terminal emulation program.
Compatible switch models
All models
Table6-2 Console port specifications (2)
Item
Specification
Connector type
USB Type-C
Compliant standard
USB 2.0
Speed
Supported services
S6510-2C
Table6-3 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Transmission baud rate
Transmission medium
100 m (328.08 ft)
Compliant standard
Functions and services
Used for upgrading and managing applications and Boot ROM
All switch models
USB port
Table6-4 USB port specifications
Item
Specification
Port type
USB 2.0
Compliant standard
OHC
Port transmission rate
Uploads and downloads data at a rate up to 480 Mbps
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files
All switch models
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee the correct operation of USB devices from all vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
SFP+ port
Table6-5 SFP+ port specifications
Item
Specification
Port type
SFP+ port
·     S6510-50QS
¡     GE SFP transceiver modules and cables described in Table6-6
¡     10GE SFP+ transceiver modules and cables described in Table6-9
·     S6510-2C
¡     GE SFP transceiver modules and cables described in Table6-7
¡     2.5GE SFP transceiver modules described in Table6-8
¡     10GE SFP+ transceiver modules and cables described in Table6-10
·     S6510-50QS
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) or GE copper transceiver modules, make sure the operating temperature does not exceed 40°C (104°F). Do not install the transceiver modules in adjacent ports.
·     S6510-2C
¡     To use 10GE SFP+ transceiver modules with a minimum transmission distance of 80 km (49.71 miles) or GE SFP copper transceiver modules, make sure the operating temperature does not exceed 40°C (104°F).
¡     To use 10GE SFP-10GE-T copper transceiver modules, make sure the operating temperature does not exceed 40°C (104°F). Do not install the transceiver modules in adjacent ports.
¡     To use a 2.5G SFP transceiver module to connect to the peer end, make sure the peer end is configured with the speed 2500 and duplex full commands.
¡     To use a 2.5G SFP transceiver module to connect to the peer end, use dual-fiber connection. If single-fiber connection is used, only one end of the link is up, which affects normal communication.
All switch models
Table6-6 GE SFP transceiver modules and cables available for the SFP+ ports (1)
Trans-
ceiver module/
cable model
Transceiver module/
cable model
Central wave-
length
Connec-
tor type
Cable specifica-
tions
Mode band-
width (MHz*km)
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850 nm
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
50/125 µm, MMF
500/400
550 m (1804.46 ft)
62.5/125 µm, MMF
500
550 m (1804.46 ft)
SFP-GE-LX10-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
1310 nm
LC
9/125 µm, SMF
N/A
20 km (12.43 miles)
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
Tx: 1550 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
Tx: 1310 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
Tx: 1550 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP copper cable
SFP-STACK-Kit
N/A
N/A
SFP copper cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
Table6-7 GE SFP transceiver modules and cables available for the SFP+ ports (2)
Trans-
ceiver module/
cable model
Transceiver module/
cable model
Central wavelength
Connec-
tor type
Cable specifica-
tions
Mode band-
width (MHz*km)
Maximum trans-
mission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850 nm
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
50/125 µm, MMF
500/400
550 m (1804.46 ft)
62.5/125 µm, MMF
500
550 m (1804.46 ft)
SFP-GE-LX10-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
1310 nm
LC
9/125 µm, SMF
N/A
20 km (12.43 miles)
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
Tx: 1550 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
Tx: 1310 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
Tx: 1550 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP copper cable
SFP-STACK-Kit
N/A
N/A
SFP copper cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
Table6-8 2.5G transceiver modules available for the SFP+ ports
Central wavelength
Connec
-tor type
Cable specifica-
tions
Mode band-
width (MHz*km)
Maximum trans-
mission distance
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
3 km (1.86 miles)
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
3 km (1.86 miles)
IMPORTANT
IMPORTANT:
Table6-9 10GE SFP+ transceiver modules and cables available for the SFP+ ports (1)
Trans-
ceiver module/
cable model
Transceiver module/
cable model
Central wavelength
Connec-
tor type
Cable specifica-
tions
Mode band-
width (MHz*km)
Maximum trans-
mission distance
SFP-XG-SX-MM850-D
850 nm
LC
50/125 µm, MMF
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-XG-CPRI-IR-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
1.4 km (0.87 miles)
SFP-XG-CPRI-LR-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1270-BIDI
Tx: 1270 nm
Rx: 1330 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
Tx: 1330 nm
Rx: 1270 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
Tx: 1270 nm
Rx: 1330 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
Tx: 1330 nm
Rx: 1270 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1490-BIDI
Tx: 1490 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-BIDI
Tx: 1550 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP+ copper cable
LSWM1STK
N/A
N/A
SFP+ copper cable
N/A
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
N/A
N/A
SFP+ fiber cable
N/A
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, the SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and the SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use the SFP-XG-LX-SM1330-BIDI transceiver module.
Table6-10 10GE SFP+ transceiver modules and cables available for the SFP+ ports (2)
Transceiver module/
cable model
Transceiver module/
cable model
Central wave-
length
Connec
-tor type
Cable specifica
-tions
Maximum trans-
mission distance
SFP+ copper transceiver module
SFP-10GE-T
N/A
RJ-45
Category 6a STP/Category 7 twisted pair cable
N/A
30 m (98.43 ft)
SFP-XG-SX-MM850-D
850 nm
LC
50/125 µm, MMF
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
1310 nm
LC
9/125 µm, SMF
N/A
1.4 km (0.87 miles)
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1270 nm
Rx: 1330 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1330 nm
Rx: 1270 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1270 nm
Rx: 1330 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
Tx: 1330 nm
Rx: 1270 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
Tx: 1490 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
Tx: 1550 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP+ copper cable
LSWM1STK
N/A
N/A
SFP+ copper cable
N/A
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
N/A
N/A
SFP+ fiber cable
N/A
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
IMPORTANT
IMPORTANT:
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For the specifications of H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
H3C provides users with SFP+ cables of different lengths. For more information, see Table6-9. For the cable appearance, see Table6-1.
Figure6-1 SFP+ copper cable
(1) Connector
(2) Pull latch
SFP28 port
Table6-11 SFP port specifications
Item
Specification
Port type
SFP28 port
·     GE SFP transceiver modules and cables described in Table6-12
·     10GE SFP+ transceiver modules and cables described in Table6-13
·     SFP28 transceiver modules and cables described in Table6-14
·     SFP28 ports do not support autonegotiation and operate at 25 Gbps by default. To change the speed to 10 Gbps, use the port-mode slot command to specify the 1/10-Gbps dual-rate mode for the ports. After configuration, all SFP28 ports will operate at 10 Gbps.
·     When an SFP port uses a GE transceiver module to connect to the peer end, make sure the peer end is configured with the speed 1000 and duplex full commands.
·     To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) or GE SFP copper transceiver modules, make sure the operating temperature does not exceed 40°C (104°F).
·     To use 10GE copper transceiver modules, make sure the transceiver modules are not installed in adjacent ports and the operating temperature does not exceed 40°C (104°F).
S6510-2C
Table6-12 GE SFP transceiver modules and cables available for the SFP28 ports
Trans-
ceiver module/cable type
Trans-
ceiver module/
cable model
Central wave-
length
Connec-
tor type
Maximum trans-
mission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850 nm
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
50/125 µm, MMF
500/400
550 m (1804.46 ft)
62.5/125 µm, MMF
500
550 m (1804.46 ft)
SFP-GE-LX10-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
1310 nm
LC
9/125 µm, SMF
N/A
20 km (12.43 miles)
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1310 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1490 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
Tx: 1550 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
Tx: 1310 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
Tx: 1550 nm
Rx: 1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP copper cable
SFP-STACK-Kit
N/A
N/A
SFP copper cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
Table6-13 10GE SFP+ transceiver modules and cables available for the SFP28 ports
Transceiver module/
cable model
Transceiver module/
cable model
Central wave-
length
Connec-
tor type
Cable specifica
-tions
SFP-10GE-T
N/A
RJ-45
N/A
30 m (98.43 ft)
SFP-XG-SX-MM850-D
850 nm
LC
50/125 µm, MMF
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
1310 nm
LC
9/125 µm, SMF
N/A
1.4 km (0.87 miles)
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1270 nm
Rx: 1330 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1330 nm
Rx: 1270 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
Tx: 1270 nm
Rx: 1330 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
Tx: 1330 nm
Rx: 1270 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
Tx: 1490 nm
Rx: 1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
Tx: 1550 nm
Rx: 1490 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP+ copper cable
LSWM1STK
N/A
N/A
SFP+ copper cable
N/A
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
N/A
N/A
SFP+ fiber cable
N/A
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
IMPORTANT
IMPORTANT:
Table6-14 SFP28 transceiver modules and cables available for the SFP28 ports
Transceiver module/cable type
Transceiver module/cable model
Central wavelength
Connector type
SFP-25G-SR-MM850
850 nm
LC
50/125 µm, MMF
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-SR-MM850-H
850 nm
LC
50/125 µm, MMF
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-LR-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-25G-LR-SM1310-I
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-25G-CSR-MM850
850 nm
LC
50/125 µm, MMF
2000
200 m (656.17 ft)
> 3500
300 m (984.25 ft)
> 5500
400 m (1312.34 ft)
SFP28 copper cable
SFP-25G-D-CAB-1M
N/A
N/A
25G SFP28 copper cable
N/A
1 m (3.28 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
SFP28 fiber cable
SFP-25G-D-AOC-3M
N/A
N/A
25G SFP28 fiber cable
N/A
3 m (9.84 ft)
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
QSFP+ port
The S6510-50QS switch provides two QSFP+ ports on its front panel. You can install the QSFP+ transceiver modules and cables in Table6-15 as needed.
Table6-15 QSFP+ transceiver modules and cables available for the QSFP+ ports
Transceiver module/
cable type
Transceiver module/
cable model
Central wave-
length
Connec-
tor type
Cable specifica
-tions
QSFP-40G-SR4-MM850
850 nm
MPO
50/125 µm, MMF
2000
100 m (328.08 ft)
4700
150 m (492.12 ft)
QSFP-40G-CSR4-MM850
850 nm
MPO
50/125 µm, MMF
2000
300 m (984.25 ft)
4700
400 m (1312.33 ft)
QSFP-40G-BIDI-SR-MM850
Two lanes:
·     850 nm
·     900 nm
LC
50/125 µm, MMF
2000
100 m (328.08 ft)
4700
150 m (492.12 ft)
QSFP-40G-BIDI-WDM850
Four lanes:
·     850 nm
·     880 nm
·     910 nm
·     940 nm
LC
50/125 µm, MMF
2000
240 m (787.40ft)
4700
350 m (1148.29 ft)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271 nm
·     1291 nm
·     1311 nm
·     1331 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
QSFP-40G-LR4-PSM1310
1310 nm
MPO
9/125 µm, SMF
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271 nm
·     1291 nm
·     1311 nm
·     1331 nm
LC
9/125 µm, SMF
N/A
2 km (1.24 miles)
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271 nm
·     1291 nm
·     1311 nm
·     1331 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
QSFP+ copper cable
LSWM1QSTK0
N/A
N/A
40G QSFP+ copper cable
N/A
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
QSFP+ fiber cable
QSFP-40G-D-AOC-3M
N/A
N/A
40G QSFP+ fiber cable
N/A
3 m (9.84 ft)
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
Figure6-2 40G QSFP+ copper cable
(1) Connector
(2) Pull latch
Table6-16 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
100 m (328.08 ft)
Transmission medium
Category 5 and above twisted pair cable
Compliant standard
S6510-50QS
LEDs
System status LED
Through the system status LED, you can preliminarily determine the operating state of the switch. For more information, see Table6-17.
Table6-17 System status LED description
LED mark
Status
SYS
Steady green
The switch is operating correctly.
Flashing green (1 Hz)
The switch is performing power-on self test (POST).
Steady red
The switch has failed POST or the switch is faulty.
Off
The switch is powered off.
Power supply status LED
Table6-18 Power supply status LED description
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is operating correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is not operating or has failed.
Off
No power supply is installed in the power supply slot.
Interface module status LED
The S6510-2C switch provides two interface module status LEDs on the front panel to indicate the operating state of the interface modules in slot 1 and slot 2, respectively.
Table6-19 Interface module status LED description
Switch model
LED mark
Status
S6510-2C
SLOT1/SLOT2
Steady green
The interface module is present and is operating correctly.
Flashing yellow
The switch does not support the interface module, or the interface module has failed.
Off
No interface module is installed in the interface module slot.
Port mode LED
To show more information about the switch through the port status LEDs, the S6510-50QS switch provides a mode LED (MODE) to indicate the type of information that the port status LEDs are showing.
You can use the mode button to change the indication of the mode LED (MODE).
Table6-20 Port mode LED description
Switch model
LED mark
LED status
S6510-50QS
MODE
Steady green
The port LEDs are showing the link state of the ports.
Flashing yellow
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4.
Steady yellow
The port LEDs are showing the duplex mode of the ports.
Table6-21 Management Ethernet port LED description
LED mark
LED status
ACT/LINK
Steady green
A link is present on the port.
Flashing green
The port is sending or receiving data.
Off
No link is present on the port.
ID LED
Table6-22 ID LED description
Switch model
LED mark
LED status
S6510-2C
ID
Flashing blue
Helps identifying the switch.
To identify the switch location, execute the locator  blink blink-time command. This LED will flash blue.
The S6510-50QS switch provides a status LED for each 10/100/1000BASE-T autosensing Ethernet port. The port LEDs and the mode LED work in conjunction to indicate the operating status of the 10/100/1000BASE-T autosensing Ethernet ports.
Table6-23 10/100/1000BASE-T autosensing Ethernet port LED description
Switch model
Mode LED status
10/100/1000BASE-T autosensing Ethernet port LED status
S6510-50QS
Steady green (rate mode)
Steady green
A link is present on the port and the port is operating at 10/100/1000 Mbps.
Flashing green
The port is sending or receiving data at 10/100/1000 Mbps.
Off
Flashing yellow (IRF mode)
Steady green
Steady yellow (duplex mode)
Steady green
The port is operating in full/half duplex mode.
Off
SFP+ port LED
Table6-24 SFP+ port LED description
Switch model
LED status
Mode LED status (MODE)
SFP+ port LED status
S6510-50QS
Steady green
A link is present on the port and the port is operating at 1/10 Gbps.
Flashing green
The port is sending or receiving data at 1/10 Gbps.
Off
Off
The mode LED is operating in IRF mode.
Steady green
Off
S6510-2C
Steady green
A link is present on the port and the port is operating at 10 Gbps.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
A link is present on the port and the port is operating at 1/2.5 Gbps.
Flashing yellow
The port is sending or receiving data at 1/2.5 Gbps.
Off
SFP28 port LED
Table6-25 SFP28 port LED description
Switch model
SFP28 port LED status
S6510-2C
Steady green
A link is present on the port and the port is operating at 25 Gbps.
Flashing green
The port is sending or receiving data at 25 Gbps.
Steady yellow
Flashing yellow
Off
QSFP+ port LED
Table6-26 QSFP+ port LED description
Switch model
LED status
QSFP+ port LED status
S6510-50QS
Steady green
A link is present on the port and the port is operating at 40 Gbps.
Flashing green
The port is sending or receiving data at 40 Gbps.
Off
Off
Steady green
Off
7 Buttons
Reset button
The S6510-2C switch provides one reset button on the front panel. For more information, see Table7-1.
Table7-1 Methods for using the reset button
Switch model
Button
Services
S6510-2C
Reset button
·     To restart the switch, press the button for no more than 5 seconds and release the button.
·     To restore the factory default and restart the switch, press and hold the button for over 5 seconds and release the button when the SYS LED flashes red rapidly (8 Hz). This operation only restarts the switch if the switch is an IRF member device. To restore the factory default with the reset button, you must first remove the switch from the IRF fabric.
To enhance switch security and prevent factory default restoration caused by misuse of the reset button, execute the undo push-button reset enable command to disable the reset button.
8 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
Table8-1 Cooling system
Switch model
Fan type
Airflow direction
·     S6510-50QS
·     S6510-2C
Fixed fans
Port side to power supply side (facing the front panel)
