| 00-Preface | 59.77 KB |
Preface
This document describes hardware information and specifications for S6510 switch series, covering the product models and technical specifications, chassis views, removable components and their compatibilities, ports and LEDs, and cooling system.
Audience
· Network planners.
· Technical support and servicing engineers.
· Network administrators.
Conventions
Symbols
Convention |
NOTE: |
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Examples in this document might use devices that differ from your device in hardware model, configuration, or software version. It is normal that the physical port numbers, sample output, screenshots, and other information in the examples differ from what you have on your device.
Documentation feedback
We appreciate your comments.
