| 02-FRUs and compatibility matrixes | 16.79 MB |
2 FRUs and compatibility matrixes
SPC/CSPC LPUs (interface modules)
SPEX-1204/CSPEX-1104-E/CSPEX-1304X/CSPEX-1404X/CSPEX-1504X
CSPEX-1512X/CSPEX-1612X/CSPEX-1812X/CSPEX-1812X-E/CSPEX-1802X/CSPEX-1802XB/CSPEX-2612X-E
IM modules (Universal line processing unit)
IM modules (Security monitor line processing unit)
IM modules (Network data encryption service processing unit)
IM modules (Universal open application platform)
SFC-04-1/SFC-04-2/SFC-04-3/SFC-04-4
SR8808-X (one fan tray) fan tray
SR8808-X (dual fan trays) fan tray
For compatibility between the cards and the software release, see the release notes.
For compatibility between the cards and transceiver modules, see the cards and transceiver modules compatibility matrixes for the device.
NOTE: This document uses the identifier printed on a card or subcard as its model name. |
IMPORTANT: · All cards are hot swappable except for the MIC-SM network data encryption interface card. · Only fiber-to-copper transceiver modules can be used to switch the port speed from 1000 Mbps to 100 Mbps. To configure a GE port to operate at 100 Mbps, first install a compatible fiber-to-copper transceiver module and then execute the speed 100 command. |
MPUs
You can install one MPU, or two MPUs for redundancy for the router. To install two MPUs for the router, make sure they are the same model.
CSR05SRP1P1
View
Figure2-1 CSR05SRP1P1 view
(1) USB console port |
(2) USB 2.0 port |
(3) 10/100/1000BASE-T management Ethernet ports (port 1 reserved for future use) |
(4) Console port |
(5) System reset button |
(6) MPU active/standby LED. For the LED description, see Table2-1. |
(7) Card status LEDs. For the LED description, see Table2-2. |
(8) Power supply status LEDs. For the LED description, see Table2-3. |
(9) Fan tray status LEDs. For the LED description, see Table2-4. |
(10) Management Ethernet port LED. For the LED description, see Table2-5. |
LEDs
Table2-1 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
The MPU is in active state. |
Off |
· The MPU is in standby state. · The MPU is faulty. To further determine the MPU status, see the card status LED description for the MPU. |
Table2-2 Card status LED description
LED status |
RUN (green) |
ALM (red) |
Flashing green (once every 2 seconds) |
Off |
The card in the corresponding slot is operating correctly. |
Fast flashing green (once every 4 seconds) |
Steady on |
The card in the corresponding slot is loading software. If the card keeps in this state, the software version of the card is not compatible with that of the device. |
Flashing red (once every 4 seconds) |
The temperature of the card in the corresponding slot is abnormal. The temperature has exceeded the upper warning temperature threshold or dropped below the lower temperature threshold. |
Steady on |
Steady on |
The card in the corresponding slot is starting or faulty. |
Off |
Off |
No card is available in the corresponding slot. |
NOTE: The ALM LED being on for a while at the system startup does not mean that the card is faulty. |
Table2-3 Power supply status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
All power supplies in the chassis are operating correctly. |
Off |
Steady on |
A minimum of one power supply in the chassis does not have power output. Possible reasons include: · The power supply is faulty. · The power switch for the power supply has not been turned on. · Power cord connection failure. · Power outage of the external power supply system. |
Off |
Off |
· No power supplies are present in the chassis. · No power supply in the chassis has power output. Possible reasons include: ¡ The power supplies are faulty. ¡ The power switches for the power supplies have not been turned on. ¡ Power cord connection failure. ¡ Power outage of the external power supply system. |
Table2-4 Fan tray status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
The fan tray is operating correctly. |
Off |
Steady on |
One or multiple fans in the fan tray are faulty or the fan tray is installed incorrectly. |
Off |
Off |
The router is not powered on. |
Table2-5 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
The port is in sending or receiving data. |
Steady green |
A link is present on the port. |
Off |
No link is present on the port. |
Ports
Console port
The console port can be connected to a computer for system debugging, configuration, maintenance, management, and host software loading.
Table2-6 Console port specifications
Item |
Connector type |
RJ-45 |
Compliant standard |
Asynchronous EIA/TIA-232 |
Transmission baud rate |
≤ 115200 bps. The default value is 9600 bps. |
Transmission medium and max transmission distance |
Common asynchronous serial interface cable, with a maximum transmission distance of 15 m (49.21 ft) |
Services |
Connects to the serial port on a local PC running a terminal emulation program. |
Table2-7 USB console port specifications
Item |
Connector type |
USB-AB |
USB 2.0, full speed |
USB-AB cable, with a maximum transmission distance of 2 m (6.56 ft) |
Services |
Connects to the USB port on a local PC running a terminal emulation program to provide a command-line interface for the router. A generic USB to serial port driver is required on the PC. Connects routers to PCs or similar terminals that do not have a serial port. |
The management Ethernet port can be connected to a computer for router program loading and router debugging, or connects to a remote NMS for remote management.
Table2-8 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
2 (port 1 reserved for future use) |
10/100/1000 Mbps |
Category-5 or above twisted pair cable, with a transmission distance of 100 m (328.08 ft) |
Services |
For router software upgrade and network management |
USB port
USB ports can connect multiple types of devices and provide a higher data transfer rate than common parallel interfaces and serial interfaces.
Table2-9 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
External storage media |
NOTE: The USB port does not support an extension cable. |
Technical specifications
Table2-10 Technical specifications
Item |
Dimensions (H × W × D) |
52.2 × 399 × 352 mm (2.06 × 15.71 × 13.86 in) |
Weight |
4.30 kg (9.48 lb) |
Maximum power consumption |
64 W |
Typical power consumption |
60 W |
Minimum power consumption |
58 W |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
SDRAM |
8 GB |
CSR05SRP1P3-G
View
Figure2-2 CSR05SRP1P3-G view
(1) High-precision time synchronization ports (Both are input ports by default. When both ports are input ports, only port 1 is valid.) |
(2) SMB coaxial clock ports (2 input ports and 2 output ports) |
(3) USB console port |
(4) USB 2.0 port |
(5) 1000BASE-T management Ethernet ports |
(6) Console port |
(7) System reset button |
(8) MPU active/standby LED. For the LED description, see Table2-11. |
(9) Card status LEDs. For the LED description, see Table2-12. |
(10) Power supply status LED. For the LED description, see Table2-13. |
(11) Fan tray status LED. For the LED description, see Table2-14. |
(12) Management Ethernet port LED. For the LED description, see Table2-15. |
LEDs
Table2-11 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-12 Card status LED description
LED status |
Flashing green |
Flashing green (4 Hz) |
Steady red |
Flashing red |
Off |
Table2-13 Power supply status LED description
LED mark |
Status |
PWR (red or green) |
Green |
Steady red |
Off |
Table2-14 Fan tray status LED description
LED mark |
Status |
FAN |
Steady green |
Steady red |
Off |
Table2-15 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
Steady on |
Off |
Ports
Console port
Table2-16 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-17 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-18 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
2 |
1000 Mbps, full duplex |
Services |
USB port
Table2-19 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
SMB coaxial clock input/output port
SMB coaxial clock ports provide input or output clock references at 2.048 Mbps (2.048 MHz). You can set the data rate mode or frequency mode through CLI. Two of them are input ports and two are output ports.
Table2-20 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Transmission medium |
75 ohm coaxial cable |
Services |
Sends and receives 2.048 MHz clocks and 2.048 Mbps signals to synchronize the clocks of the router and other devices, such as routers and the terminals. |
Table2-21 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Category-5 or above twisted pair cable |
Services |
You can configure the port as an input port or output port at the CLI. Synchronizes the clocks of the router and other devices, such as GPS receivers and terminals. |
Table2-22 Technical specifications
Item |
Weight |
4.50 kg (9.92 lb) |
65 W |
50 W |
40 W |
SDRAM |
16 GB |
CSR05SRP1R3
View
Figure2-3 CSR05SRP1R3 view
(4) USB 2.0 port |
(5) 1000BASE-T Management Ethernet ports (port 1 reserved for future use) |
(6) Console port |
(8) MPU active/standby LED. For the LED description, see Table2-23. |
(9) Card status LEDs. For the LED description, see Table2-24. |
(10) Power supply status LEDs. For the LED description, see Table2-25. |
(11) Fan tray status LEDs. For the LED description, see Table2-26. |
(12) Management Ethernet port LED. For the LED description, see Table2-27. |
LEDs
Table2-23 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-24 Card status LED description
LED status |
RUN (green) |
ALM (red) |
Off |
Steady on |
Steady on |
Steady on |
Off |
Off |
Table2-25 Power supply status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-26 Fan tray status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-27 Management Ethernet port LED description
LED mark |
LED |
LINK/ACT |
Flashing green |
Steady on |
Off |
Ports
Console port
Table2-28 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-29 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-30 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
Services |
USB port
Table2-31 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
Table2-32 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Services |
Table2-33 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-34 Technical specifications
Item |
Weight |
4.90 kg (10.80 lb) |
130 W |
95 W |
89 W |
SDRAM |
2 × 16 GB |
CSR05SRP1R3-G
View
Figure2-4 CSR05SRP1R3-G view
(2) SMB coaxial clock output ports (2 in total) |
(3) SMB coaxial clock input ports (2 in total) |
(4) USB 2.0 port |
(6) Console port |
(8) MPU active/standby LED. For the LED description, see Table2-35. |
(9) Card status LEDs. For the LED description, see Table2-36. |
(10) Power supply status LED. For the LED description, see Table2-37. |
(11) Fan tray status LED. For the LED description, see Table2-38. |
(12) Management Ethernet port LED. For the LED description, see Table2-39. |
LEDs
Table2-35 MPU active/standby LED description
LED mark |
Status |
ACTIVE |
Steady green |
Off |
Table2-36 Card status LED description
LED status |
Flashing green |
Fast flashing green (4 Hz) |
The card in the corresponding slot is loading software. If the card keeps in this state, the current software version of the device is not running the software version compatible with the card. |
Steady red |
Flashing red |
Off |
Table2-37 Power supply status LED description
Power supply status LED |
Status |
Steady green |
Steady red |
A minimum of one power supply in the chassis does not have power output. Possible reasons include: · The power supply is faulty. · The power switch for the power supply has not been turned on. · Power cord connection failure. Power outage of the external power supply system. |
Off |
Table2-38 Fan tray status LED description
Fan tray status LED |
Status |
FAN (Red or green) |
Steady green |
Steady red |
One or more fans in the fan tray have failed or the fan tray is installed incorrectly. |
Off |
Table2-39 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
Steady green |
Off |
Ports
Console port
Table2-40 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-41 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
2 |
Services |
USB port
Table2-42 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
SMB coaxial clock ports provide input or output clock references at 2.048 Mbps (2.048 MHz). You can set the data rate mode or frequency mode through the CLI. Two of them are input ports and two are output ports.
Table2-43 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
75-ohm coaxial cable |
Services |
Table2-44 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-45 Technical specifications
Item |
Weight |
4.55 kg (10.03 lb) |
130 W |
117 W |
55 W |
SDRAM |
16 GB or 32 GB (subject to the card specifications) |
SR05SRP1L1
View
Figure2-5 SR05SRP1L1 view
(1) CF card |
(2) Console port |
(4) 10/100/1000BASE-T Management Ethernet port |
(5) USB 2.0 port |
(6) System reset button |
(7) MPU active/standby LED. For the LED description, see Table2-46. |
(8) Card status LEDs. For the LED description, see Table2-47. |
(9) Fan tray status LEDs. For the LED description, see Table2-48. |
(10) Management Ethernet port LEDs. For the LED description, see Table2-49. |
(11) CF card LED. For the LED description, see Table2-50. |
LEDs
Table2-46 MPU active/standby LED description
LED mark |
LED |
ACTIVE |
Steady green |
Off |
Table2-47 Card status LED description
LED status |
RUN (green) |
ALM (red) |
Off |
Steady on |
The card in the corresponding slot is loading software. If the card keeps in this state, the software version of the card is not compatible with that of the card. |
Steady on |
Steady on |
Off |
Off |
Table2-48 Fan tray status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-49 Management Ethernet port LED description
Status |
LINK (green) |
ACT (yellow) |
Steady on |
Flashing green |
Steady on |
Off |
Off |
Off |
Table2-50 CF card LED description
LED |
Status |
CF card (green) |
Steady on |
The CF card is present and idle. Do not hot swap it. |
Flashing green |
The CF card is present and the system is reading/writing the card. Do not hot swap it. |
Off |
The CF card is not present, or the CF card is in offline state. You can hot swap it. |
Ports
Console port
Table2-51 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-52 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-53 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
USB port
Table2-54 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
CF card slot
A CF card is a mobile storage device that features fast speed, large capacity, small size, light weight, and low power consumption.
Table2-55 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
You can use a CF card to store logs, application program files, and configuration files. |
NOTE: Before you use a CF card, insert the CF card into the card slot and fasten the card cover. |
Table2-56 Technical specifications
Item |
40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in) |
Weight |
3.05 kg (6.72 lb) |
53 W |
47 W |
46 W |
SDRAM |
8 GB or 16 GB (subject to the card specifications) |
SR05SRP1L3
View
Figure2-6 SR05SRP1L3 view
(2) CF card |
(3) SMB coaxial clock ports (2 input ports and 2 output ports) |
(4) Console port |
(5) USB console port |
(6) 10/100/1000BASE-T management Ethernet port |
(7) USB 2.0 port |
(8) System reset button |
(9) MPU active/standby LED. For the LED description, see Table2-57. |
(10) Card status LEDs. For the LED description, see Table2-58. |
(11) Fan tray status LEDs. For the LED description, see Table2-59. |
(12) Management Ethernet port LEDs. For the LED description, see Table2-60. |
(13) Card status LED. For the LED description, see Table2-61. |
LEDs
Table2-57 MPU active/standby LED description
LED mark |
LED |
ACTIVE |
Steady green |
Off |
Table2-58 Card status LED description
LED status |
RUN (green) |
ALM (red) |
Off |
Steady on |
Steady on |
Steady on |
Off |
Off |
Table2-59 Fan tray status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-60 Management Ethernet port LED description
Status |
LINK (green) |
ACT (yellow) |
Steady on |
Flashing green |
Steady on |
Off |
Off |
Off |
Table2-61 CF card LED description
LED |
Status |
CF card (green) |
Steady on |
Flashing green |
Off |
Ports
Console port
Table2-62 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-63 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-64 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
USB port
Table2-65 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
CF card slot
Table2-66 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
Table2-67 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048Mbps |
Services |
Table2-68 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-69 Technical specifications
Item |
Weight |
3.18 kg (7.01 lb) |
53 W |
52 W |
50 W |
SDRAM |
SR05SRP1P3
View
Figure2-7 SR05SRP1P3 view
(2) CF card |
(4) SMB coaxial clock ports (2 input ports and 2 output ports) |
(5) USB 2.0 port |
(6) 10/100/1000BASE-T management Ethernet ports (port 1 reserved for future use) |
(7) Console port |
(9) MPU active/standby LED. For the LED description, see Table2-70. |
(10) Card status LEDs. For the LED description, see Table2-71. |
(11) Power supply status LEDs. For the LED description, see Table2-72. |
(12) Fan tray status LEDs. For the LED description, see Table2-73. |
(13) Management Ethernet port LED. For the LED description, see Table2-74. |
(14) CF card LED. For the LED description, see Table2-75. |
LED
Table2-70 MPU active/standby LED description
LED mark |
LED |
ACTIVE |
Steady green |
Off |
Table2-71 Card status LED description
LED status |
RUN (green) |
ALM (red) |
Off |
Steady on |
Steady on |
Steady on |
Off |
Off |
Table2-72 Power supply status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
A power supply in the chassis does not have power output. Possible reasons include: · The power supply is faulty. · The power switch for the power supply has not been turned on. · Power cord connection failure. · Power outage of the external power supply system. |
Off |
Off |
Table2-73 Fan tray status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-74 Management Ethernet port LED description
LED mark |
LED |
LINK/ACT |
Flashing green |
Steady on |
Off |
Table2-75 CF card LED description
LED |
Status |
CF card (green) |
Steady on |
Flashing green |
Off |
Ports
Console port
Table2-76 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-77 USB console port specifications
Item |
Connector type |
USB-AB |
Services |
Table2-78 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
10/100/1000 Mbps |
Services |
USB port
Table2-79 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
CF card slot
Table2-80 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
Table2-81 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048Mbps |
Services |
Table2-82 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Services |
Table2-83 Technical specifications
Item |
Weight |
4.80 kg (10.58 lb) |
64 W |
60 W |
58 W |
SDRAM |
16 GB |
Compatibility information
Table2-84 Compatibility matrix between MPUs and routers
Card model |
Applicable router models |
SR05SRP1L1 |
SR8804-X, SR8808-X, SR8812-X |
SR05SRP1L3 |
CSR05SRP1P1 |
SR8808H-X, SR8816-X |
SR05SRP1P3 |
CSR05SRP1P3-G |
CSR05SRP1R3 |
CSR05SRP1R3-G |
A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time.
CSPC-GE16XP4L-E
View
Figure2-8 CSPC-GE16XP4L-E view
(1) 10GBASE-R-SFP+ fiber ports (4 in total) (10GE SFP+ modules supported) |
(2) Combo interfaces (16 in total) (10GE SFP+ modules supported in 1000BASE-X-SFP fiber ports) |
(3) SFP port LED. For the LED description, see Table2-86. |
(4) RJ-45 Ethernet Interface LED. For the LED description, see Table2-85. |
(5) SFP+ port LED. For the LED description, see Table2-87. |
LEDs
Table2-85 RJ-45 Ethernet port LED description
LED |
Status |
RJ-45 Ethernet port LED |
Flashing |
The port is sending or receiving data. |
Steady on |
Off |
Table2-86 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-87 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of an SFP+ port by observing the color of its LED. Green indicates a speed of 10 Gbps, and yellow indicates a speed of 1000 Mbps. |
Ports
Table2-88 Port specifications
Card model |
Connector type |
Port quantity |
Port transmission speed |
CSPC-GE16XP4L-E |
16-port GE combo interface + 4-port 10GE optical interface module |
RJ-45 |
16 |
10/100/1000 Mbps |
LC |
16 |
1000 Mbps |
4 |
10 Gbps |
Table2-89 Technical specifications
Item |
Weight |
4.35 kg (9.59 lb) |
127 W |
114 W |
107 W |
CSPC-GE24L-E
View
Figure2-9 CSPC-GE24L-E view
(1) Combo interfaces (24 in total) (10GE SFP+ modules supported in 1000BASE-X-SFP fiber ports) |
(2) SFP port LED. For the LED description, see Table2-91. |
(3) RJ-45 Ethernet Interface LED. For the LED description, see Table2-90. |
LEDs
Table2-90 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-91 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-92 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GE24L-E |
24-port GE Combo interface service module |
RJ-45 |
24 |
10/100/1000 Mbps |
LC |
24 |
1000 Mbps |
Table2-93 Technical specifications
Item |
Weight |
4.45 kg (9.81 lb) |
114 W |
110 W |
108 W |
CSPC-GP24GE8XP2L-E
View
Figure2-10 CSPC-GP24GE8XP2L-E view
(1) 10GBASE-R-SFP+ fiber ports (2 in total) (10GE SFP+ modules supported) |
(2) 1000BASE-X-SFP fiber ports (24 in total) (GE SFP modules supported) |
(3) Combo interfaces (8 in total) (10GE SFP+ modules supported in 1000BASE-X-SFP fiber ports) |
(4) RJ-45 Ethernet Interface LED. For the LED description, see Table2-94. |
(5) SFP port LED. For the LED description, see Table2-95. |
(6) SFP+ port LED. For the LED description, see Table2-96. |
LEDs
Table2-94 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-95 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-96 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-97 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP24GE8XP2L-E |
24-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port 1000BASE-X Ethernet combo interface + 2-port 10GBASE-R/W Ethernet optical interface line processing unit (SFP+, LC) (E Type) |
RJ45 |
8 |
10/100/1000 Mbps |
LC |
32 |
1000 Mbps |
2 |
10 Gbps |
Table2-98 Technical specifications
Item |
Weight |
4.45 kg (9.81 lb) |
126 W |
113 W |
101 W |
SPC-CP1LAX/SPC-CP1LCX
View
Figure2-11 SPC-CP1LCX view
(1) 100GBASE-R-CFP fiber port (1 in total) |
(2) CFP port LED. For the LED description, see Table2-99. |
The views of the SPC-CP1LAX and SPC-CP1LCX are similar. This figure uses the SPC-CP1LCX as an example.
LEDs
Table2-99 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
The CFP port is sending or receiving data. |
Steady on |
A link is present on the CFP port. |
Off |
No link is present on the CFP port. |
Ports
Table2-100 Port specifications
Card model |
Connector type |
Port quantity |
SPC-CP1LAX |
1-port 100GBASE Ethernet optical interface module (CFP, LC) (A Type) |
LC |
1 |
100 Gbps |
SPC-CP1LCX |
1-port 100GBASE Ethernet optical interface module (CFP, LC) (C Type) |
LC |
1 |
100 Gbps |
Table2-101 Technical specifications
Item |
Weight |
3.50 kg (7.72 lb) |
173 W |
156 W |
115 W |
SPC-CP2LA/SPC-CP2LB
View
Figure2-12 SPC-CP2LA view
(1) 100GBASE-R-CFP fiber ports (2 in total) |
(2) CFP port LED. For the LED description, see Table2-102. |
The views of the SPC-CP2LA and SPC-CP2LB are similar. This figure uses the SPC-CP2LA as an example.
LEDs
Table2-102 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-103 Port specifications
Card model |
Connector type |
Port quantity |
SPC-CP2LA |
2-port 100GBASE Ethernet optical interface module (CFP, LC) (A Type) |
LC |
2 |
100 Gbps |
SPC-CP2LB |
2-port 100GBASE Ethernet optical interface module (CFP, LC) (B Type) |
LC |
2 |
100 Gbps |
Table2-104 Technical specifications
Item |
Weight |
4.06 kg (8.96 lb) |
197 W |
178 W |
150 W |
SPC-GP24LA1
View
Figure2-13 SPC-GP24LA1 view
(1) 1000BASE-X-SFP fiber ports (16 in total) |
(2) Combo interfaces (8 in total) |
(3) SFP port LED. For the LED description, see Table2-106. |
(4) RJ-45 Ethernet port LED. For the LED description, see Table2-105. |
NOTE: · A combo interface is a logical interface that contains an SFP fiber port and an RJ-45 copper port. The two ports share one forwarding channel. As a result, they cannot work simultaneously. When you activate one port, the other port is automatically disabled. You can activate the fiber or copper port as needed. By default, the copper port is activated. · Use a category 5 or above twisted pair cable to connect a 1000BASE-T RJ-45 copper port. The maximum transmission distance is 100 m (328.08 ft). |
LEDs
Table2-105 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-106 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-107 Port specifications
Card model |
Connector type |
Port quantity |
SPC-GP24LA1 |
16-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port combo interface module (A Type) |
RJ45 |
8 |
10/100/1000 Mbps |
LC |
24 |
100 Mbps |
155 Mbps |
1000 Mbps |
Table2-108 Technical specifications
Item |
Weight |
3.01 kg (6.64 lb) |
75 W |
68 W |
47 W |
SPC-GP24XP2LA/SPC-GP24XP2LB
Figure2-14 SPC-GP24XP2LB view
(3) 10GBASE-R-XFP fiber ports (2 in total) |
(4) SFP port LED. For the LED description, see Table2-110. |
(5) RJ-45 Ethernet port LED. For the LED description, see Table2-109. |
(6) XFP port LED. For the LED description, see Table2-111. |
The views of the SPC-GP24XP2LA and SPC-GP24XP2LB are similar. This figure uses the SPC-GP24XP2LB as an example.
LEDs
Table2-109 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-110 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-111 XFP port LED description
XFP port LED status |
LINK |
ACT |
Steady on |
Flashing green |
A link is present, and the XFP port is sending or receiving data. |
Steady on |
Off |
A link is present, but the XFP port is not sending or receiving data. |
Off |
Off |
No link is present on the XFP port. |
Ports
Table2-112 Port specifications
Card model |
Connector type |
Port quantity |
SPC-GP24XP2LA |
16-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port combo interface + 2-port 10GE optical interface module (XFP, LC) (A Type) |
RJ45 |
8 |
10/100/1000 Mbps |
LC |
24 |
100 Mbps |
155 Mbps |
1000 Mbps |
LC |
2 |
10 Gbps |
SPC-GP24XP2LB |
16-port 1000BASE-X optical interface (SFP, LC) + 8-port combo interface + 2-port 10GE optical interface module (XFP, LC) (B Type) |
RJ45 |
8 |
10/100/1000 Mbps |
LC |
24 |
100 Mbps |
155 Mbps |
1000 Mbps |
LC |
2 |
10 Gbps |
Table2-113 Technical specifications
Item |
Weight |
3.08 kg (6.79 lb) |
100 W |
90 W |
51 W |
SPC-GP44XP4LAX/SPC-GP44XP4LCX
View
Figure2-15 SPC-GP44XP4LCX view
(1) 1000BASE-X-SFP fiber ports (44 in total) |
(2) 10GBASE-R-SFP+ fiber ports (4 in total) |
(3) SFP port LED. For the LED description, see Table2-114. |
(4) SFP+ port LED. For the LED description, see Table2-115. |
The views of the SPC-GP44XP4LAX and SPC-GP44XP4LCX are similar. This figure uses the SPC-GP44XP4LCX as an example.
LEDs
Table2-114 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-115 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-116 Port specifications
Card model |
Connector type |
Port quantity |
SPC-GP44XP4LAX |
44-port 1000BASE-X Ethernet optical interface module (SFP, LC) + 4-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
LC |
44 |
100 Mbps |
155 Mbps |
1000 Mbps |
4 |
10 Gbps |
1000 Mbps |
SPC-GP44XP4LCX |
44-port 1000BASE-X Ethernet optical interface module (SFP, LC) + 4-port 10GBASE Ethernet optical interface module (SFP+, LC) (C Type) |
LC |
44 |
100 Mbps |
155 Mbps |
1000 Mbps |
4 |
10 Gbps |
1000 Mbps |
Table2-117 Technical specifications
Item |
Weight |
3.60 kg (7.94 lb) |
142 W |
128 W |
118 W |
SPC-GP48LA1/SPC-GP48LB
View
Figure2-16 SPC-GP48LA1 view
(1) 1000BASE-X-SFP fiber ports (48 in total) |
(2) SFP port LED. For the LED description, see Table2-118. |
The views of the SPC-GP48LB and SPC-GP48LA1 are similar. This figure uses the SPC-GP48LA1 as an example.
LEDs
Table2-118 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-119 Port specifications
Card model |
Connector type |
Port quantity |
SPC-GP48LA1 |
48-port 1000BASE-X Ethernet optical interface module (SFP, LC) (A Type) |
LC |
48 |
100 Mbps |
155 Mbps |
1000 Mbps |
SPC-GP48LB |
48-port enhanced 1000BASE-X Ethernet optical interface module (SFP, LC) (B Type) |
LC |
48 |
100 Mbps |
155 Mbps |
1000 Mbps |
Table2-120 Technical specifications
Item |
Weight |
3.25 kg (7.17 lb) |
110 W |
99 W |
43 W |
SPC-GT48LA1
View
Figure2-17 SPC-GT48LA1 view
(1) 10/100/1000BASE-T copper ports (48 in total) |
(2) RJ-45 Ethernet port LED. For the LED description, see Table2-121. |
LEDs
Table2-121 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Ports
Table2-122 Port specifications
Card model |
Connector type |
Port quantity |
SPC-GT48LA1 |
48-port 10/100/1000BASE-T Ethernet interface module (RJ45) (A Type) |
RJ45 |
48 |
10/100/1000 Mbps |
Table2-123 Technical specifications
Item |
Weight |
3.31 kg (7.30 lb) |
95 W |
86 W |
67 W |
SPC-XLP6LAX/SPC-XLP6LCX
View
Figure2-18 SPC-XLP6LCX view
(1) 40GBASE-R-QSFP+ fiber ports (6 in total) |
(2) QSFP+ port LED. For the LED description, see Table2-124. |
The views of the SPC-XLP6LAX and SPC-XLP6LCX are similar. This figure uses the SPC-XLP6LCX as an example.
LEDs
Table2-124 QSFP + port LED description
LED |
Status |
QSFP + port LED |
Flashing |
The QSFP+ port is sending or receiving data. |
Steady on |
A link is present on the QSFP+ port. |
Off |
No link is present on the QSFP+ port. |
Ports
Table2-125 Port specifications
Card model |
Connector type |
Port quantity |
SPC-XLP6LAX |
6-port 40GBASE Ethernet optical interface module (QSFP+, MPO) (A Type) |
LC/MPO |
6 |
40 Gbps |
SPC-XLP6LCX |
6-port 40GBASE Ethernet optical interface module (QSFP+, MPO) (C Type) |
LC/MPO |
6 |
40 Gbps |
Table2-126 Technical specifications
Item |
Weight |
3.95 kg (8.71 lb) |
290 W |
261 W |
181 W |
SPC-XP12LAX/SPC-XP12LCX
View
Figure2-19 SPC-XP12LCX view
(1) 10GBASE-R-SFP+ fiber ports (12 in total) |
(2) SFP+ port LED. For the LED description, see Table2-127. |
The views of the SPC-XP12LAX and SPC-XP12LCX are similar. This figure uses the SPC-XP12LCX as an example.
LEDs
Table2-127 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-128 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP12LAX |
12-port 10GE optical interface module |
LC |
12 |
10 Gbps |
1000 Mbps |
CSPC-XP12LCX |
LC |
12 |
10 Gbps |
1000 Mbps |
Table2-129 Technical specifications
Item |
Weight |
3.65 kg (8.05 lb) |
· SPC-XP12LAX: 130 W · SPC-XP12LCX: 173 W |
· SPC-XP12LAX: 117 W · SPC-XP12LCX: 156 W |
· SPC-XP12LAX: 107 W · SPC-XP12LCX: 122 W |
SPC-XP24LAX/SPC-XP24LCX
View
Figure2-20 SPC-XP24LCX view
(1) 10GBASE-R-SFP+ fiber ports (24 in total) |
(2) SFP+ port LED. For the LED description, see Table2-130. |
The views of the SPC-XP24LAX and SPC-XP24LCX are similar. This figure uses the SPC-XP24LCX as an example.
LEDs
Table2-130 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-131 Port specifications
Card model |
Connector type |
Port quantity |
SPC-XP24LAX |
24-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
LC |
24 |
10 Gbps |
1000 Mbps |
SPC-XP24LCX |
LC |
24 |
10 Gbps |
1000 Mbps |
Table2-132 Technical specifications
Item |
Weight |
4.15 kg (9.15 lb) |
· SPC-XP24LAX: 209 W · SPC-XP24LCX: 294 W |
· SPC-XP24LAX: 189 W · SPC-XP24LCX: 265 W |
· SPC-XP24LAX: 153 W · SPC-XP24LCX: 178 W |
SPC-XP2LA1
View
Figure2-21 SPC-XP2LA1 view
(1) 10GBASE-R-XFP fiber ports (2 in total) |
(2) XFP port LED. For the LED description, see Table2-133. |
LEDs
Table2-133 XFP port LED description
LINK |
ACT |
Steady on |
Flashing green |
Steady on |
Off |
Off |
Off |
Ports
Table2-134 Port specifications
Card model |
Connector type |
Port quantity |
SPC-XP2LA1 |
2-port 10GBASE Ethernet optical interface module (XFP, LC) (A Type) |
LC |
2 |
10 Gbps |
Table2-135 Technical specifications
Item |
40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in)) |
Weight |
2.93 kg (6.46 lb) |
55 W |
50 W |
43 W |
SPC-XP4LA1/SPC-XP4LB
View
Figure2-22 SPC-XP4LA1 view
(2) XFP port LED. For the LED description, see Table2-136. |
The views of the SPC-XP4LB and SPC-XP4LA1 are similar. This figure uses the SPC-XP4LA1 as an example.
LEDs
Table2-136 XFP port LED description
LINK |
ACT |
Steady on |
Flashing green |
Steady on |
Off |
Off |
Off |
Ports
Table2-137 Port specifications
Card model |
Connector type |
Port quantity |
SPC-XP4LA1 |
4-port 10GBASE Ethernet optical interface module (XFP, LC) (A Type) |
LC |
4 |
10 Gbps |
SPC-XP4LB |
4-port Enhanced 10GBASE Ethernet optical interface module (XFP, LC) (B Type) |
LC |
4 |
10 Gbps |
Table2-138 Technical specifications
Item |
Weight |
2.93 kg (6.46 lb) |
80 W |
72 W |
53 W |
SPC-XP8LA/SPC-XP8LB
View
Figure2-23 SPC-XP8LA view
(1) 10GBASE-R-SFP+ fiber ports (8 in total) |
(2) SFP+ port LED. For the LED description, see Table2-139. |
The views of the SPC-XP8LB and SPC-XP8LA are similar. This figure uses the SPC-XP8LA as an example.
LED
Table2-139 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-140 Port specifications
Card model |
Connector type |
Port quantity |
SPC-XP8LA |
8-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
LC |
8 |
100 Mbps |
1000 Mbps |
10 Gbps |
SPC-XP8LB |
8-port Enhanced 10GBASE Ethernet optical interface module (SFP+, LC) (B Type) |
LC |
8 |
10 Gbps |
1000 Mbps |
Table2-141 Technical specifications
Item |
Weight |
3.44 kg (7.58 lb) |
170 W |
153 W |
117 W |
Table2-142 Compatibility matrix between SPC/CSPC cards and routers
Card model |
SPC-GT48LA1 |
Supported |
Not supported |
CSPC-GE24L-E |
Supported |
Not supported |
SPC-GP24LA1 |
Supported |
Not supported |
SPC-GP24XP2LA |
Supported |
Not supported |
SPC-GP24XP2LB |
Supported |
Not supported |
Supported |
Not supported |
CSPC-GE16XP4L-E |
Supported |
Not supported |
SPC-XP2LA1 |
Supported |
Not supported |
SPC-XP4LA1 |
Supported |
Not supported |
SPC-XP4LB |
Supported |
Not supported |
SPC-XP8LA |
Supported |
Not supported |
SPC-XP8LB |
Supported |
Not supported |
SPC-GP48LA1 |
Supported |
Not supported |
SPC-GP48LB |
Supported |
Not supported |
SPC-GP44XP4LCX |
Supported |
Not supported |
SPC-GP44XP4LAX |
Supported |
Not supported |
SPC-XP24LCX |
Supported |
Not supported |
SPC-XP24LAX |
Supported |
Not supported |
SPC-XP12LCX |
Supported |
Not supported |
SPC-XP12LAX |
Supported |
Not supported |
SPC-XLP6LCX |
Supported |
Not supported |
SPC-XLP6LAX |
Supported |
Not supported |
SPC-CP1LCX |
Supported |
Not supported |
SPC-CP1LAX |
Supported |
Not supported |
SPC-CP2LB |
Supported |
Not supported |
SPC-CP2LA |
Supported |
Not supported |
CEPC LPUs (interface modules)
CEPC-CP4RX
View
Figure2-24 CEPC-CP4RX view
(1) 100GBASE-R-CFP2 fiber ports (4 in total) |
(2) CFP2 port LED. For the LED description, see Table2-143. |
LEDs
Table2-143 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
The CFP2 port is sending or receiving data at 100 Gbps. |
Steady on |
A 100 Gbps link is present on the CFP2 port. |
Off |
No link is present on the CFP2 port. |
Ports
Table2-144 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-CP4RX |
4-port 100GBASE Ethernet optical interface module (CFP2) |
LC |
4 |
100 Gbps |
Table2-145 Technical specifications
Item |
Weight |
4.20 kg (9.26 lb) |
368 W |
331 W |
228.5 W |
CEPC-CP4RX-L
Figure2-25 CEPC-CP4RX-L view
(1) 100GBASE-QSFP28 fiber ports (4 in total) (100G QSFP 28 modules supported) |
(2) QSFP 28 port LED. For the LED description, see Table2-146. |
LEDs
Table2-146 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
The QSFP28 port is sending or receiving data at 100 Gbps. |
Steady on |
A 100 Gbps link is present on the QSFP28 port. |
Off |
No link is present on the QSFP28 port. |
Ports
Table2-147 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-CP4RX-L |
4-port 100G Ethernet optical interface line processing unit (QSFP28, LC) |
LC |
4 |
100 Gbps |
40 Gbps |
Table2-148 Technical specifications
Item |
Weight |
8.30 kg (18.30 lb) |
354 W |
252 W |
191 W |
CEPC-CQ16L1
View
Figure2-26 CEPC-CQ16L1 view
(1) 100GBASE-QSFP28 fiber ports (16 in total) |
(2) QSFP 28 port LED. For the LED description, see Table2-149. |
LEDs
Table2-149 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
IMPORTANT: Only ports 1, 2, 7, 8, 9, 10, 15, and 16 support switching the speed between 100 Gbps and 40 Gbps. |
Table2-150 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-CQ16L1 |
16-port 100G Ethernet optical interface line processing unit (QSFP28,LC) |
LC |
16 |
100 Gbps |
40 Gbps |
Table2-151 Technical specifications
Item |
52.5 mm × 399 mm × 370 mm (2.07 in × 15.71 in × 14.57 in) |
Weight |
8.25 kg (18.19 lb) |
1240 W |
970 W |
760 W |
CEPC-CQ8L
View
Figure2-27 CEPC-CQ8L view
(1) 100GBASE-QSFP28 fiber ports (8 in total) (100G QSFP 28 modules supported) |
(2) QSFP 28 port LED. For the LED description, see Table2-152. |
LEDs
Table2-152 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-153 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-CQ8L |
8-port 100G Ethernet optical interface line processing unit (QSFP28, LC) |
LC |
8 |
100 Gbps |
Table2-154 Technical specifications
Item |
Weight |
8.00 kg (17.64 lb) |
CEPC-CQ8L: 1100 W |
CEPC-CQ8L: 880 W |
CEPC-CQ8L: 653 W |
CEPC-DQ2L1-G
View
Figure2-28 CEPC-DQ2L1-G view
(1) QSFP-DD port LED. For the LED description, see Table2-155. |
(2) 400GBASE-R-QSFP-DD fiber ports (2 in total) (400G QSFP-DD transceiver modules supported) |
(3) Card status LED. For the LED description, see Table2-156. |
LEDs
Table2-155 QSFP-DD port LED description
LED |
Status |
QSFP-DD port LED |
Flashing |
The QSFP-DD port is sending or receiving data. |
On |
A link is present on the QSFP-DD port. |
Off |
No link is present on the QSFP-DD port. |
Table2-156 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
The card is faulty. |
Off |
The card is faulty or is not present. |
Flashing (about once per second) |
The card is operating correctly. |
Fast flashing (about eight times per second) |
The card is starting up. If the LED keeps fast flashing, card registration has failed. |
Ports
Table2-157 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-DQ2L1-G |
2-port 400G Ethernet optical interface line processing unit (QSFP-DD,LC) |
LC |
2 |
400 Gbps |
Table2-158 Technical specifications
Item |
52.5 × 399 × 370 mm (2.07 × 15.71 × 14.57 in) |
Weight |
6.96 kg (15.34 lb) |
540 W |
510 W |
450 W |
CEPC-XP24LX
View
Figure2-29 CEPC-XP24LX view
(1) 10GBASE-R/W-SFP+ fiber ports (24 in total) (10GE SFP+ modules supported) |
(2) SFP+ port LED. For the LED description, see Table2-159. |
LEDs
Table2-159 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
The SFP+ port is sending or receiving data. |
Steady on |
A link is present on the SFP+ port. |
Off |
No link is present on the SFP+ port. |
Ports
Table2-160 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-XP24LX |
24-port 10GBASE-R/W Ethernet optical interface line processing unit (SFP+, LC) |
LC |
24 |
10 Gbps |
Table2-161 Technical specifications
Item |
Weight |
4.70 kg (10.36 lb) |
321 W |
289 W |
237.6 W |
CEPC-XP48RX
View
Figure2-30 CEPC-XP48RX view
(1) 10GBASE-R-SFP+ fiber ports (48 in total) |
(2) SFP+ port LED. For the LED description, see Table2-162. |
LEDs
Table2-162 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-163 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-XP48RX |
48-port 10GBASE-R/W Ethernet optical interface module (SFP+, LC) |
LC |
48 |
10 Gbps |
Table2-164 Technical specifications
Item |
Weight |
4.75 kg (10.47 lb) |
407 W |
336 W |
234.8 W |
CEPC-XP4LX
View
Figure2-31 CEPC-XP4LX view
(1) 10GBASE-R/W-SFP+ fiber ports (4 in total) (10GE SFP+ modules supported) |
(2) SFP+ port LED. For the LED description, see Table2-165. |
LEDs
Table2-165 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-166 Port specifications
Card model |
Connector type |
Port quantity |
CEPC-XP4LX |
4-port 10GBASE-R/W Ethernet optical interface line processing unit module (SFP+, LC) |
LC |
4 |
10 Gbps |
Table2-167 Technical specifications
Item |
Weight |
184 W |
117 W |
102 W |
For adequate ventilation and cooling, you can install the CEPC-CP4RX, CEPC-XP48RX, and CEPC-XP24LX cards in the following slots only when the other slots are not available.
· SR8808-X router—Slots 0, 8 and 9.
· SR8812-X router—Slots 0 and 13.
Table2-168 Compatibility matrix between CEPC cards and routers
Card model |
SR8804-X |
CEPC-CP4RX |
Not supported |
Supported |
Supported |
CEPC-CP4RX-L |
Not supported |
Supported |
Supported |
CEPC-XP48RX |
Not supported |
Supported |
Supported |
CEPC-XP24LX |
Not supported |
Supported |
Supported |
CEPC-XP4LX |
Supported |
Supported |
Supported |
CEPC-CQ8L |
Not supported |
Not supported |
Supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Supported |
CEPC-DQ2L1-G |
Not supported |
Not supported |
Supported |
SPEX/CSPEX base cards
IMPORTANT: A CSPEX-1104-E card supports a maximum of three MIC-XP4L1 and MIC-GP4L subcards in total. |
View
Figure2-32 SPEX-1204 view
(1) Card status LED. For the LED description, see Table2-169. |
The views of SPEX-1204, CSPEX-1304X, CSPEX-1404X, CSPEX-1504X, CSPEX-1504XA, and CSPEX-1104-E are similar. This figure uses the SPEX-1204 as an example.
LEDs
LED |
Status |
RUN (green) |
Steady on |
Off |
Subcard slots
Table2-170 Subcard slots
Card model |
Number of subcard slots |
CSPEX-1104-E |
4 |
SPEX-1204 |
4 |
CSPEX-1304X |
4 |
CSPEX-1404X |
4 |
CSPEX-1504X |
4 |
Table2-171 Technical specifications
Item |
Weight |
· CSPEX-1104-E: 3.45 kg (7.61 lb) · SPEX-1204: 3.50 kg (7.72 lb) · CSPEX-1304X: 3.75 kg (8.27 lb) · CSPEX-1404X: 7.20 kg (15.87 lb) · CSPEX-1504X: 7.20 kg (15.87 lb) |
· CSPEX-1104-E: 164 W · SPEX-1204: 190 W · CSPEX-1304X: 184 W · CSPEX-1404X: 230 W · CSPEX-1504X: 261 W |
· CSPEX-1104-E: 88 W · SPEX-1204: 104 W · CSPEX-1304X: 101 W · CSPEX-1404X: 138 W · CSPEX-1504X: 154 W |
· CSPEX-1104-E: 79 W · SPEX-1204: 88 W · CSPEX-1304X: 90 W · CSPEX-1404X: 111.6 W · CSPEX-1504X: 112.1 W |
· 0°C to 45°C (32°F to 113°F) |
CSPEX-1502X/CSPEX-1602X
View
Figure2-33 CSPEX-1602X view
(1) Card status LED. For the LED description, see Table2-172. |
The views of the CSPEX-1602X and CSPEX-1502X are similar. This figure uses the CSPEX-1602X as an example.
LEDs
LED |
Status |
RUN (green) |
Steady on |
Off |
Subcard slots
Table2-173 Subcard slots
Card model |
CSPEX-1502X |
2 |
CSPEX-1602X |
2 |
Table2-174 Technical specifications
Item |
· 40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in) |
Weight |
· CSPEX-1502X: 3.95 kg (8.71 lb) · CSPEX-1602X: 7.50 kg (16.53 lb) |
· CSPEX-1502X: 270 W · CSPEX-1602X: 354 W |
· CSPEX-1502X: 135 W · CSPEX-1602X: 222 W |
· CSPEX-1502X: 120 W · CSPEX-1602X: 174.6 W |
View
Figure2-34 CSPEX-1512X view
(1) Card status LED. For the LED description, see Table2-175. |
The views of the CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XB, and CSPEX-2612X-E are similar. This figure uses the CSPEX-1512X as an example.
LEDs
LED |
Status |
RUN (green) |
Steady on |
Off |
Subcard slots
Table2-176 Subcard slots
Card model |
CSPEX-1512X |
2 |
CSPEX-1612X |
2 |
CSPEX-1812X |
2 |
CSPEX-1812X-E |
2 |
CSPEX-1802X |
2 |
CSPEX-1802XB |
2 |
CSPEX-2612X-E |
2 |
Table2-177 Technical specifications
Item |
52.5 mm × 399 mm × 352 mm (2.07 in × 15.71 in × 13.86 in) |
Weight |
· CSPEX-1512X: 5.40 kg (11.90 lb) · CSPEX-1612X: 8.75 kg (19.29 lb) · CSPEX-1812X: 5.95 kg (13.12 lb) · CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XB: 9.00 kg (19.84 lb) · CSPEX-2612X-E: 6.00 kg (13.23 lb) |
· CSPEX-1512X: 281 W · CSPEX-1612X: 320 W · CSPEX-1812X: 657 W · CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XB: 486 W · CSPEX-2612X-E: 538 W |
· CSPEX-1512X: 202 W · CSPEX-1612X: 238 W · CSPEX-1812X: 426 W · CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XB: 333 W · CSPEX-2612X-E: 457 W |
· CSPEX-1512X: 185 W · CSPEX-1612X: 200 W · CSPEX-1812X: 413 W · CSPEX-1812X-E, CSPEX-1802X, CSPEX-1802XB: 275 W · CSPEX-2612X-E: 330 W |
CSPEX-1804X
View
Figure2-35 CSPEX-1804X view
(1) Card status LED. For the LED description, see Table2-178. |
LEDs
LED |
Status |
RUN (green) |
Steady on |
Off |
Subcard slots
Table2-179 Subcard slots
Card model |
CSPEX-1804X |
4 |
Table2-180 Technical specifications
Item |
Weight |
6.30 kg (13.89 lb) |
625 W |
510 |
460 W |
CSPEX-2304X-G
View
Figure2-36 CSPEX-2304X-G view
(1) Card status LED. For the LED description, see Table2-181. |
LEDs
LED |
Status |
RUN (green) |
Steady on |
Off |
Subcard slots
Table2-182 Subcard slots
Card model |
CSPEX-2304X-G |
4 |
Table2-183 Technical specifications
Item |
Weight |
4.65 kg (10.25 lb) |
280 W |
242 W |
200 W |
CSPEX-2304X-G2
View
Figure2-37 CSPEX-2304X-G2 view
(1) Card status LED. For the LED description, see Table2-184. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
The card is faulty or is not in position. |
Subcard slots
Table2-185 Subcard slots
Card model |
CSPEX-2304X-G2 |
4 |
Table2-186 Technical specifications
Item |
Weight |
3.80 kg (8.38 lb) |
261 W |
Power consumption (with typical configuration) |
154 W |
112 W |
CSPEX-2304X-LG
View
Figure2-38 CSPEX-2304X-LG view
(1) Card status LED. For the LED description, see Table2-187. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-188 Subcard slots
Card model |
CSPEX-2304X-LG |
4 |
Table2-189 Technical specifications
Item |
Weight |
280 W |
242 W |
200 W |
CSPEX-2314X-G
View
Figure2-39 CSPEX-2314X-G view
(1) Card status LED. For the LED description, see Table2-190. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-191 CSPEX-2314X-G subcard slots
Card model |
CSPEX-2314X-G |
4 |
Table2-192 Technical specifications
Item |
52.5 × 399 × 352 mm (2.07 × 15.71 × 13.86 in) |
Weight |
11.57 kg (25.51 lb) |
385 W |
333 W |
185 W |
CSPEX-2314X-G1
View
Figure2-40 CSPEX-2314X-G1 view
(1) Card status LED. For the LED description, see Table2-193. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-194 Subcard slots
Card model |
CSPEX-2314X-G1 |
4 |
Table2-195 Technical specifications
Item |
Weight |
5.15 kg (11.35 lb) |
320 W |
268 W |
120 W |
CSPEX-2314X-G2
View
Figure2-41 CSPEX-2314X-G2 view
(1) Card status LED. For the LED description, see Table2-196. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-197 Subcard slots
Card model |
CSPEX-2314X-G2 |
4 |
Table2-198 Technical specifications
Item |
Weight |
320 W |
268 W |
120 W |
CSPEX-2612X3-E
View
Figure2-42 CSPEX-2612X3-E view
(1) Card status LED. For the LED description, see Table2-199. |
LEDs
LED |
Status |
RUN (Green) |
Steady on |
Off |
Subcard slots
Table2-200 Subcard slots
Card model |
CSPEX-2612X3-E |
2 |
Table2-201 Technical specifications
Item |
Weight |
9.00 kg (19.84 lb) |
610 W |
410 W |
317 W |
An SR8804-X router installed with Type-A switching fabric modules does not support the CSPEX-1304X, CSPEX-1404X, or CSPEX-1504X cards.
For adequate ventilation and cooling, you can install the CSPEX-1602X cards in the following slots only when the other slots are not available.
Table2-202 Compatibility matrix between SPEX/CSPEX cards and routers
Card model |
SR8804-X |
SR8808-X |
SR8812-X |
SPEX-1204 |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1104-E |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
Supported |
Supported |
CSPEX-1404X |
Supported |
Supported |
Supported |
Supported |
CSPEX-1502X |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1504X |
Supported |
Supported |
Supported |
Supported |
CSPEX-1602X |
Not supported |
Supported |
Supported |
Supported |
CSPEX-1802X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1802XB |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1804X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1512X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1612X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1812X |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-1812X-E |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-2304X-G |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2304X-G2 |
Supported |
Supported |
Supported |
Supported |
CSPEX-2304X-LG |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2314X-G |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-2314X-G1 |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-2314X-G2 |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-2612X-E |
Not supported |
Not supported |
Not supported |
Supported |
CSPEX-2612X3-E |
Not supported |
Not supported |
Not supported |
Supported |
Table2-203 Compatibility matrixes between SPEX/CSPEX cards and subcards (1)
Subcard model |
SPEX/CSPEX card |
SPEX-1204 |
CSPEX-1304X |
CSPEX-1504X/CSPEX-1404X/CSPEX-2304X-G2 |
CSPEX-1502X |
CSPEX-1602X |
CSPEX-1804X |
GIC-CLP2L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-CQ1L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-ET16L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-GP12L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-GT10L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-MSC-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-PSP4L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-SP4L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-SP8L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-TCP8L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-XP4L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-XP6L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-XP12LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-XP12L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-GP10L |
Subcard slots 1 and 2: Supported. Subcard slots 3 and 4: Not supported. |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L1 |
Not supported |
Not supported |
Supported only by CSPEX-1504X and CSPEX-2304X-G2 |
Not supported |
Not supported |
Not supported |
MIC-ET16L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-CLP2L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-CLP4L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-SP4L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-SP8L |
Supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-GP4L |
Subcard slots 1 and 2: Not supported. Subcard slots 3 and 4: Supported. |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Subcard slots 1, 2, and 3: Supported. Subcard slot 4: Not supported. |
Supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-XP2L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L-LAN |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-XP4L1 |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L2 |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-XP8L |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
MIC-XP10LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP10L-LAN |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-QP1L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CP2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
Not supported. |
Not supported |
Not supported |
Not supported |
MIC-CQ1LF |
Not supported |
Not supported |
Not supported. |
Not supported |
Not supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
MIC-PSP4L |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-TCP8L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
MIC-SEC |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-QP3L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L1B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-XP20L1B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CC2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ2LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-YGS4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CC1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CC2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Table2-204 Compatibility matrixes between SPEX/CSPEX cards and subcards (2)
Subcard model |
SPEX/CSPEX card |
CSPEX-1104-E |
CSPEX-1512X |
CSPEX-1612X |
CSPEX-1812X |
CSPEX-1812X-E |
CSPEX-1802X |
GIC-CLP2L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-CQ1L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-ET16L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-GP12L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-GT10L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-MSC-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-PSP4L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-SP4L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-SP8L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-TCP8L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-XP4L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-XP6L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-XP12LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
GIC-XP12L-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-GP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP4L |
Supported, a maximum of 3. |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L2 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP4L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CLP2L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CLP4L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP8L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-ET16L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L1 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L-LAN |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP4L1 |
Supported, a maximum of 3 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP10LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP10L-LAN |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-PSP4L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-TCP8L |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SEC |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GT20L |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-QP3L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-GP20L |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-GP24L |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
NIC-GP24L1B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-XP5L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
NIC-XP10L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
NIC-XP20L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
NIC-XP20L1 |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
NIC-XP20L1B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Supported |
NIC-CC2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
NIC-CQ1L |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Supported |
NIC-CQ2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
NIC-CQ2LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-GP20L |
Not supported |
Supported |
Supported |
Supported |
Not supported |
Not supported |
RX-NIC-XP5L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
RX-NIC-XP10L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
RX-NIC-XP20L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
RX-NIC-YGS4L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
RX-NIC-LGQ2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
Supported |
RX-NIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
RX-NIC-CC1L |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
RX-NIC-CC2L |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
Supported |
Table2-205 Compatibility matrixes between SPEX/CSPEX cards and subcards (3)
Subcard model |
SPEX/CSPEX card |
CSPEX-1802XB |
CSPEX-2304X-G CSPEX-2304X-LG |
CSPEX-2314X-G |
CSPEX-2314X-G1 CSPEX-2314X-G2 |
CSPEX-2612X-E |
CSPEX-2612X3-E |
GIC-CLP2L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-CQ1LF |
Not supported |
Not supported |
Supported |
Supported (only in subcard slots 1 and 2) |
Not supported |
Not supported |
GIC-CQ1L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-ET16L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-GP12L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-GT10L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-MSC-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-PSP4L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-SP4L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-SP8L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-TCP8L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-XP4L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-XP6L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
GIC-XP12LF |
Not supported |
Not supported |
Supported |
Not supported |
Not supported |
GIC-XP12L-G |
Not supported |
Not supported |
Supported |
Supported |
Not supported |
Not supported |
PIC-GP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP4L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L2 |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP4L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CLP2L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CLP4L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SP8L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-ET16L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GT20L1 |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP2L-LAN |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP4L1 |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP10LF |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP10L-LAN |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP5L2 |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ1LF |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-PSP4L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-TCP8L |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
MIC-SEC |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GT20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-QP3L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-GP24L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
NIC-GP24L1B |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
NIC-XP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
NIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-XP20L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
NIC-XP20L1B |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
NIC-CC1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CC2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
NIC-CQ1L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Supported |
NIC-CQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
NIC-CQ2LB |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
RX-NIC-GP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-XP5L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
RX-NIC-XP10L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
RX-NIC-XP20L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
RX-NIC-YGS4L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
RX-NIC-LGQ2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
RX-NIC-CQ1LF |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
RX-NIC-CC1L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-NIC-CC2L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MPE base cards
MPE-1104
View
Figure2-43 MPE-1104 view
(1) Card status LED. For the LED description, see Table2-206. |
LEDs
LED |
Status |
RUN (green) |
Steady on |
Off |
Subcard slots
Table2-207 Subcard slots
Card model |
MPE-1104 |
4 |
Table2-208 Technical specifications
Item |
Dimensions (H × W × D) |
Weight |
3.52 kg (7.76 lb) |
Maximum power consumption |
158 W |
Typical power consumption |
94 W |
Minimum power consumption |
91 W |
Operating temperature |
The subslot restrictions of an MPE card depend on the subslot mode. For more information about subslot modes, see H3C SR8800-X Routers Configuration Guides.
Compatibility information
Table2-209 Compatibility matrix between MPE cards and routers
Card model |
SR8804-X |
SR8808-X, SR8812-X |
SR8808H-X, SR8816-X |
MPE-1104 |
Supported |
Supported |
Not supported |
Table2-210 Compatibility matrix between MPE cards and subcards
Subcard model |
MPE cards |
GIC-CLP2L-G |
Not supported |
GIC-CQ1LF |
Not supported |
GIC-CQ1L-G |
Not supported |
GIC-ET16L-G |
Not supported |
GIC-GP12L-G |
Not supported |
GIC-GT10L-G |
Not supported |
GIC-MSC-G |
Not supported |
GIC-PSP4L-G |
Not supported |
GIC-SP4L-G |
Not supported |
GIC-SP8L-G |
Not supported |
GIC-TCP8L-G |
Not supported |
GIC-XP4L-G |
Not supported |
GIC-XP6L-G |
Not supported |
GIC-XP12LF |
Not supported |
GIC-XP12L-G |
Not supported |
PIC-GP10L |
Not supported |
PIC-TCP8L |
Not supported |
PIC-PSP4L |
Not supported |
PIC-PS2G4L |
Not supported |
PIC-PUP1L |
Not supported |
PIC-XP1L |
Not supported |
MIC-GT20L |
Not supported |
MIC-GT20L1 |
Not supported |
MIC-CLP4L |
Supported |
MIC-ET16L |
Supported |
MIC-CLP2L |
Supported |
MIC-SP8L |
Only one is supported. Can be installed only slot 1 or slot 2. |
MIC-SP4L |
Supported |
MIC-GP4L |
Supported |
MIC-GP8L |
Not supported in slot 3 or slot 4 |
MIC-GP10L1 |
Not supported |
MIC-GP10L2 |
Not supported |
MIC-GP10L-V2 |
Not supported |
MIC-GP20L |
Not supported |
MIC-GP20L1 |
Not supported |
MIC-XP2L |
Not supported |
MIC-XP2L-LAN |
Not supported |
MIC-XP4L1 |
Not supported |
MIC-XP5L |
Not supported |
MIC-XP5L1 |
Not supported |
MIC-XP5L2 |
Not supported |
MIC-XP8L |
Not supported |
MIC-XP10LF |
Not supported |
MIC-XP10L-LAN |
Not supported |
MIC-XP20L |
Not supported |
MIC-QP1L |
Not supported |
MIC-CP1L |
Not supported |
MIC-CP1L-V2 |
Not supported |
MIC-CP2L |
Not supported |
MIC-CP2L-V2 |
Not supported |
MIC-CQ1L1 |
Not supported |
MIC-CQ1L2 |
Not supported |
MIC-CQ1LF |
Not supported |
MIC-CQ2L |
Not supported |
MIC-PSP4L |
Not supported |
MIC-TCP8L |
Not supported |
MIC-SEC |
Not supported |
NIC-GT20L |
Not supported |
NIC-QP3L |
Not supported |
NIC-GP20L |
Not supported |
NIC-GP24L |
Not supported |
NIC-GP24L1 |
Not supported |
NIC-GP24L1B |
Not supported |
NIC-XP5L |
Not supported |
NIC-XP10L |
Not supported |
NIC-XP20L |
Not supported |
NIC-XP20L1 |
Not supported |
NIC-XP20L1B |
Not supported |
NIC-CC1L |
Not supported |
NIC-CC2L |
Not supported |
NIC-CQ1L |
Not supported |
NIC-CQ2L |
Not supported |
NIC-CQ2LB |
Not supported |
RX-NIC-GP20L |
Not supported |
RX-NIC-XP5L |
Not supported |
RX-NIC-XP10L |
Not supported |
RX-NIC-XP20L |
Not supported |
RX-NIC-YGS4L |
Not supported |
RX-NIC-LGQ2L |
Not supported |
RX-NIC-LGQ4L |
Not supported |
RX-NIC-CQ1LF |
Not supported |
RX-NIC-CQ2LF |
Not supported |
RX-NIC-CC1L |
Not supported |
RX-NIC-CC2L |
Not supported |
SPE base cards
RX-SPE200/RX-SPE200-E
View
Figure2-44 RX-SPE200 view
(1) Card status LED. For the LED description, see Table2-211. |
The views of the RX-SPE200 and RX-SPE200-E are similar. This figure uses the RX-SPE200 as an example.
LEDs
LED |
Status |
RUN (green) |
Steady on |
Off |
Subcard slots
Table2-212 Subcard slots
Card model |
RX-SPE200 |
2 |
RX-SPE200-E |
2 |
Table2-213 Technical specifications
Item |
Weight |
· RX-SPE200: 5.35 kg (11.79 lb) · RX-SPE200-E: 5.00 kg (11.02 lb) |
· RX-SPE200: 530 W · RX-SPE200-E: 270 W |
· RX-SPE200: 300 W · RX-SPE200-E: 135 W |
· RX-SPE200: 280 W · RX-SPE200-E: 120 W |
Table2-214 Compatibility matrix between SPE cards and routers
Card model |
SR8804-X |
RX-SPE200 |
Not supported |
Not supported |
Supported |
RX-SPE200-E |
Not supported |
Not supported |
Supported |
Table2-215 Compatibility matrix between SPE cards and subcards
Subcard model |
RX-SPE200 |
RX-SPE200-E |
GIC-CLP2L-G |
Not supported |
Not supported |
GIC-CQ1LF |
Not supported |
Not supported |
GIC-CQ1L-G |
Not supported |
Not supported |
GIC-ET16L-G |
Not supported |
Not supported |
GIC-GP12L-G |
Not supported |
Not supported |
GIC-GT10L-G |
Not supported |
Not supported |
GIC-MSC-G |
Not supported |
Not supported |
GIC-PSP4L-G |
Not supported |
Not supported |
GIC-SP4L-G |
Not supported |
Not supported |
GIC-SP8L-G |
Not supported |
Not supported |
GIC-TCP8L-G |
Not supported |
Not supported |
GIC-XP4L-G |
Not supported |
Not supported |
GIC-XP6L-G |
Not supported |
Not supported |
GIC-XP12LF |
Not supported |
Not supported |
GIC-XP12L-G |
Not supported |
Not supported |
PIC-GP10L |
Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
Not supported |
MIC-GT20L1 |
Not supported |
Not supported |
MIC-CLP4L |
Not supported |
Not supported |
MIC-ET16L |
Not supported |
Not supported |
MIC-CLP2L |
Not supported |
Not supported |
MIC-SP8L |
Not supported |
Not supported |
MIC-SP4L |
Not supported |
Not supported |
MIC-GP4L |
Not supported |
Not supported |
MIC-GP8L |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
MIC-GP10L2 |
Not supported |
Not supported |
MIC-GP10L-V2 |
Not supported |
Not supported |
MIC-GP20L |
Not supported |
Not supported |
MIC-GP20L1 |
Not supported |
Not supported |
MIC-XP2L |
Not supported |
Not supported |
MIC-XP2L-LAN |
Not supported |
Not supported |
MIC-XP4L1 |
Not supported |
Not supported |
MIC-XP5L |
Not supported |
Not supported |
MIC-XP5L1 |
Not supported |
Not supported |
MIC-XP5L2 |
Not supported |
Not supported |
MIC-XP8L |
Not supported |
Not supported |
MIC-XP10LF |
Not supported |
Not supported |
MIC-XP10L-LAN |
Not supported |
Not supported |
MIC-XP20L |
Not supported |
Not supported |
MIC-QP1L |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
MIC-CP1L-V2 |
Not supported |
Not supported |
MIC-CP2L |
Not supported |
Not supported |
MIC-CP2L-V2 |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
MIC-CQ2L |
Not supported |
Not supported |
MIC-PSP4L |
Not supported |
Not supported |
MIC-TCP8L |
Not supported |
Not supported |
MIC-SEC |
Not supported |
Not supported |
NIC-GT20L |
Supported |
Not supported |
NIC-QP3L |
Supported |
Supported |
NIC-GP20L |
Supported |
Not supported |
NIC-GP24L |
Supported |
Not supported |
NIC-GP24L1 |
Not supported |
Supported |
NIC-GP24L1B |
Not supported |
Not supported |
NIC-XP5L |
Not supported |
Not supported |
NIC-XP10L |
Supported |
Not supported |
NIC-XP20L |
Not supported |
Not supported |
NIC-XP20L1 |
Not supported |
Not supported |
NIC-XP20L1B |
Not supported |
Not supported |
NIC-CC1L |
Not supported |
Not supported |
NIC-CC2L |
Not supported |
Not supported |
NIC-CQ1L |
Supported |
Not supported |
MIC-CQ1L2 |
Not supported |
Not supported |
MIC-CQ1LF |
Not supported |
Not supported |
NIC-CQ2L |
Not supported |
Not supported |
NIC-CQ2LB |
Not supported |
Not supported |
RX-NIC-GP20L |
Supported |
Not supported |
RX-NIC-XP5L |
Supported |
Supported |
RX-NIC-XP10L |
Supported |
Supported |
RX-NIC-XP20L |
Not supported |
Not supported |
RX-NIC-YGS4L |
Supported |
Supported |
RX-NIC-LGQ2L |
Supported |
Supported |
RX-NIC-LGQ4L |
Not supported |
Not supported |
RX-NIC-CQ1LF |
Supported |
Supported |
RX-NIC-CQ2LF |
Not supported |
Not supported |
RX-NIC-CC1L |
Supported |
Supported |
RX-NIC-CC2L |
Not supported |
Not supported |
GIC subcards
IMPORTANT: · To use a GIC interface card, you must install it on a CSPEX base card. You cannot install it directly on the router. · For the compatibility between GIC interface cards and CSPEX base cards, see the compatibility information for the base cards. · Some GIC subcards support changing the speed and operating mode. For more information, see H3C SR8800-X Routers Configuration Guides. |
GIC-CLP2L-G
View
Figure2-45 GIC-CLP2L-G view
(1) OC-3/STM-1 SFP fiber ports (2 in total) |
(2) Port LED. For the LED description, see Table2-216. |
LEDs
Table2-216 WAN port LED description
LED |
Status |
WAN port LED (ACT/ALM) |
Steady green |
A link is present on the WAN port. |
Flashing green |
The WAN port is receiving or sending data correctly. |
Steady yellow |
A transceiver module has been installed in the WAN port, but an alarm has occurred. |
Off |
No transceiver module is installed in the WAN port. |
Ports
Table2-217 Port specifications
Card model |
Connector type |
Port quantity |
Port transmission speed |
GIC-CLP2L-G |
2-port OC-3/STM-1 (155M) channelized POS optical interface card |
LC |
2 |
155 Mbps (OC-3/STM-1) |
Table2-218 Technical specifications
Item |
22.3 × 190 × 154 mm (0.88 × 7.48 × 6.06 in) |
Weight |
1.05 kg (2.31 lb) |
18 W |
16 W |
GIC-CQ1LF
View
Figure2-46 GIC-CQ1LF view
(1) 100G/50G/40G fiber port (1 in total) |
(2) 50G/40G fiber port (1 in total) |
(3) 50G/40G fiber port LED. For the LED description, see Table2-219. |
(4) 100G/50G/40G fiber port LED. For the LED description, see Table2-219. |
LEDs
Table2-219 Fiber port LED description
LED |
Status |
Fiber port LED (LINK/ACT) |
Flashing |
The port is receiving or sending data. |
On |
A link is present on the port. |
Off |
No link is present on the port. |
NOTE: You can identify the speed of a QSFP28 port by observing the color of its LED. Green indicates a speed of 100 Gbps, and yellow indicates a speed of 50 Gbps or 40 Gbps. |
Ports
Table2-220 Port specifications
Card model |
Connector type |
Port quantity |
GIC-CQ1LF |
2-port 50G/1-port 100G flexible Ethernet optical interface card |
LC |
1 |
100 Gbps |
2 |
40 Gbps |
50 Gbps |
NOTE: You can change the speed of only port 1 to 100 Gbps. After the change, port 2 is unavailable. For more information about the commands used for changing the speed of ports on the subcard, see H3C SR8800-X Routers Command Reference. |
Table2-221 Technical specifications
Item |
Weight |
0.75 kg (1.65 lb) |
50 W |
27 W |
GIC-CQ1L-G
View
Figure2-47 GIC-CQ1L-G view
(1) 100GBASE-R QSFP28 fiber port (1 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-222. |
LEDs
Table2-222 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
The QSFP28 port is receiving or sending data. |
On |
A link is present on the QSFP28 port. |
Off |
NOTE: You can identify the speed of a QSFP28 port by observing the color of its LED. Green indicates a speed of 100 Gbps, and yellow indicates a speed of 10 Gbps. |
Ports
Table2-223 Port specifications
Card model |
Connector type |
Port quantity |
GIC-CQ1L-G |
1-port 100G Ethernet optical interface card |
LC |
1 |
100 Gbps |
10 Gbps |
Table2-224 Technical specifications
Item |
Weight |
1.00 kg (2.20 lb) |
15 W |
13 W |
GIC-ET16L-G
View
Figure2-48 GIC-ET16L-G view
(1) E1-HM96 copper ports (16 in total) |
(2) Port LED. For the LED description, see Table2-225. |
LEDs
Table2-225 WAN port LED description
LED |
Status |
ACT/ALM |
Steady green |
Flashing green |
The port is receiving or sending data correctly. |
Steady yellow |
An E1 cable is has been connected to the port, but an alarm has occurred. |
Off |
No E1 cable is connected to the port. |
Ports
Table2-226 Port specifications
Card model |
Connector type |
Port quantity |
GIC-ET16L-G |
16-port E1 copper interface card |
HM96 male connector |
16 |
E1 |
Table2-227 Technical specifications
Item |
Weight |
1.00 kg (2.20 lb) |
14 W |
12 W |
GIC-GP12L-G
View
Figure2-49 GIC-GP12L-G view
(1) 1000BASE-X SFP fiber ports (12 in total) |
(2) SFP port LED. For the LED description, see Table2-228. |
LEDs
Table2-228 GE SFP port LED description
LED |
Status |
GE SFP port LED (LINK/ACT) |
Flashing |
The SFP port is receiving or sending data. |
On |
A link is present on the SFP port. |
Off |
No link is present on the SFP port. |
NOTE: You can identify the speed of an SFP port by observing the color of its LED. Green indicates a speed of 1000 Mbps, and yellow indicates a speed of 10/100 Mbps. |
Ports
Table2-229 Port specifications
Card model |
Connector type |
Port quantity |
GIC-GP12L-G |
12-port 1000BASE-X Ethernet optical interface card |
LC |
12 |
10/100/1000 Mbps |
Table2-230 Technical specifications
Item |
Weight |
1.05 kg (2.31 lb) |
26 W |
15 W |
GIC-GT10L-G
View
Figure2-50 GIC-GT10L-G view
(1) RJ45 Ethernet port LEDs. For the LED description, see Table2-231. |
(2) 10/100/1000BASE-T copper ports (10 in total) |
LEDs
Table2-231 RJ45 Ethernet port LED description
LED |
Status |
RJ45 Ethernet port LED |
LINK: Steady green |
A 1000 Mbps link is present on the port. |
LINK: Flashing green |
The port is receiving or sending data at 1000 Mbps. |
ACT: Steady yellow |
A 10/100 Mbps link is present on the port. |
ACT: Flashing yellow |
The port is receiving or sending data at 10/100 Mbps. |
Off |
NOTE: You can identify the speed of an RJ45 Ethernet port by observing the color of its LEDs. A green LINK LED indicates a speed of 1000 Mbps, and a yellow ACT LED indicates a speed of 10/100 Mbps. |
Ports
Table2-232 Port specifications
Card model |
Connector type |
Port quantity |
GIC-GT10L-G |
10-port 1000BASE-T Ethernet copper interface card |
RJ45 |
10 |
10/100/1000 Mbps |
Table2-233 Technical specifications
Item |
Weight |
0.77 kg (1.70 lb) |
20 W |
17 W |
GIC-MSC-G
View
Figure2-51 GIC-MSC-G view
Ports
Table2-234 Port specifications
Card model |
Connector type |
Port quantity |
GIC-MSC-G |
Network data mutiservice processing interface card (GIC) |
N/A |
N/A |
N/A |
Table2-235 Technical specifications
Item |
Weight |
0.70 kg (1.54 lb) |
13 W |
11 W |
GIC-PSP4L-G
View
Figure2-52 GIC-PSP4L-G view
(1) OC-48c/STM-16c POS fiber ports (4 in total) |
(2) Port LED. For the LED description, see Table2-236. |
LEDs
Table2-236 WAN port LED description
LED |
Status |
Steady green |
Flashing green |
Steady yellow |
Off |
Ports
Table2-237 Port specifications
Card model |
Connector type |
Port quantity |
GIC-PSP4L-G |
4-port OC-48c/STM-16c (2.5G) POS optical interface card |
LC |
4 |
2.5 Gbps |
Table2-238 Technical specifications
Item |
Weight |
0.74 kg (1.63 lb) |
20 W |
16 W |
GIC-SP4L-G
View
Figure2-53 GIC-SP4L-G view
(1) Four OC-3/STM-1c POS/ATM fiber ports or one OC-12c/STM-4c POS/ATM fiber port (only port 1 supports OC-12c/STM-4c) |
(2) Port LED. For the LED description, see Table2-239. |
LEDs
Table2-239 WAN port LED description
LED |
Status |
Steady green |
Flashing green |
Steady yellow |
Off |
Ports
Table2-240 Port specifications
Card model |
Connector type |
Port quantity |
GIC-SP4L-G |
4-port OC-3c/STM-1c (155M) POS/ATM or 1-port OC-12c/STM-4c (622M) POS/ATM optical interface card The card does not support switching to ATM mode. |
LC |
4 |
1 |
622 Mbps (OC-12/STM-4) |
NOTE: You can change the speed of only port 1 to 622 Mbps. After the change, other ports are unavailable. For more information about the command used for changing the operating mode of the subcard, see H3C SR8800-X Routers Command Reference. |
Table2-241 Technical specifications
Item |
Weight |
0.74 kg (1.63 lb) |
20 W |
16 W |
GIC-SP8L-G
View
Figure2-54 GIC-SP8L-G view
(1) OC-3c/STM-1c POS fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-242. |
LEDs
Table2-242 WAN port LED description
LED |
Status |
Steady green |
Flashing green |
Steady yellow |
Off |
Ports
Table2-243 Port specifications
Card model |
Connector type |
Port quantity |
GIC-SP8L-G |
8-port OC-3c/STM-1c (155M) POS optical interface card |
LC |
8 |
Table2-244 Technical specifications
Item |
Weight |
0.75 kg (1.65 lb) |
24 W |
16 W |
GIC-TCP8L-G
View
Figure2-55 GIC-TCP8L-G view
(1) OC-3c/OC-12c POS/GE fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-245. |
LEDs
Table2-245 WAN port LED description
LED |
Status |
Steady green |
Flashing green |
Steady yellow |
Off |
Ports
Table2-246 Port specifications
Card model |
Connector type |
Port quantity |
GIC-TCP8L-G |
8-port OC-3c/OC-12c (622M/155M) POS/GE optical interface card |
LC |
8 |
10/100/1000 Mbps |
Table2-247 Technical specifications
Item |
Weight |
1.05 kg (2.31 lb) |
24 W |
16 W |
GIC-XP4L-G
View
Figure2-56 GIC-XP4L-G view
(1) 10GBASE-R/W SFP+ fiber ports (4 in total) |
(2) SFP+ port LED. For the LED description, see Table2-248. |
LEDs
Table2-248 SFP+ port LED description
LED |
Status |
10GE SFP+ port LED (LINK/ACT) |
Flashing |
The SFP+ port is receiving or sending data. |
On |
Off |
NOTE: You can identify the speed of an SFP+ port by observing the color of its LED. Green indicates a speed of 10 Gbps, and yellow indicates a speed of 10/100/1000 Mbps. |
Ports
Table2-249 Port specifications
Card model |
Connector type |
Port quantity |
GIC-XP4L-G |
4-port 10GBASE-R/W Ethernet optical interface card |
LC |
4 |
10/100/1000 Mbps |
10 Gbps |
Table2-250 Technical specifications
Item |
Weight |
1.05 kg (2.31 lb) |
23 W |
15 W |
GIC-XP6L-G
View
Figure2-57 GIC-XP6L-G view
(1) 10GBASE-R/W SFP+ fiber ports (6 in total) |
(2) SFP+ port LED. For the LED description, see Table2-251. |
LEDs
Table2-251 SFP+ port LED description
LED |
Status |
Flashing |
On |
Off |
Ports
Table2-252 Port specifications
Card model |
Connector type |
Port quantity |
GIC-XP6L-G |
6-port 10GBASE-R/W Ethernet optical interface card |
LC |
6 |
10/100/1000 Mbps |
10 Gbps |
Table2-253 Technical specifications
Item |
Weight |
1.05 kg (2.31 lb) |
24 W |
15 W |
GIC-XP12LF
View
Figure2-58 GIC-XP12LF view
(1) 10GBASE-R/W SFP+ fiber ports (12 in total) |
(2) SFP+ port LED. For the LED description, see Table2-254. |
LEDs
Table2-254 SFP+ port LED description
LED |
Status |
Flashing |
On |
Off |
NOTE: You can identify the speed of an SFP+ port by observing the color of its LED. Green indicates a speed of 25 Gbps, and yellow indicates a speed of 10 Gbps or 1000 Mbps. |
Ports
Table2-255 Port specifications
Card model |
Connector type |
Port quantity |
GIC-XP12LF |
12-port 10GBASE-R flexible Ethernet optical interface card |
LC |
12 |
1000 Mbps |
10 Gbps |
4 |
25 Gbps |
NOTE: You can change the speed of only ports 1 to 4 to 25 Gbps. When any of these ports operates at 25 Gbps, ports 11 and 12 are unavailable. Follow these restrictions and guidelines when you change the port speed: · Ports 1 and 7 form a group. After you change port 1 to a 25GE interface, port 7 is unavailable. · Ports 2 and 8 form a group. After you change port 2 to a 25GE interface, port 8 is unavailable. · Ports 3 and 9 form a group. After you change port 3 to a 25GE interface, port 9 is unavailable. · Ports 4 and 10 form a group. After you change port 4 to a 25GE interface, port 10 is unavailable. · Ports 5 and 6 cannot be changed to 25GE interfaces, and they are not affected by any speed change of other ports. For more information about the commands used for changing the speed of ports on the subcard, see H3C SR8800-X Routers Command Reference. |
Table2-256 Technical specifications
Item |
Weight |
0.75 kg (1.65 lb) |
46 W |
24 W |
GIC-XP12L-G
View
Figure2-59 GIC-XP12L-G view
(2) SFP+ port LED. For the LED description, see Table2-257. |
LEDs
Table2-257 SFP+ port LED description
LED |
Status |
Flashing |
On |
Off |
Ports
Table2-258 Port specifications
Card model |
Connector type |
Port quantity |
GIC-XP12L-G |
12-port 10GBASE-R/W Ethernet optical interface card |
LC |
12 |
10/100/1000 Mbps |
10 Gbps |
Table2-259 Technical specifications
Item |
Weight |
1.05 kg (2.31 lb) |
28 W |
15 W |
MIC subcards
IMPORTANT: · To use a MIC interface card, you must install it on a CMPE, SPE, or SPEX/CSPEX base card. You cannot install it directly on the router. · For the compatibility between MIC interface cards and CMPE, SPE, or SPEX/CSPEX base cards, see the compatibility information for the base cards. · A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time. · Some MIC subcards support changing the speed and operating mode. For more information, see H3C SR8800-X Routers Configuration Guides. |
MIC-CLP2L
View
Figure2-60 MIC-CLP2L view
(1) CPOS-OC3/STM1-SFP port (2 in total) |
(2) Port LED. For the LED description, see Table2-260. |
LEDs
Table2-260 WAN port LED description
LED |
Status |
Flashing green |
The port is up and is receiving or sending data correctly. |
Steady green |
The port is up and no services are running on the port. |
Steady red |
An alarm has occurred. |
Off |
The port is down. |
Ports
Table2-261 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CLP2L |
2-port OC-3/STM-1 CPOS optical interface card |
LC |
2 |
Table2-262 Technical specifications
Item |
18 × 171 × 157 mm (0.71 × 6.73 × 6.18 in) |
Weight |
0.32 kg (0.71 lb) |
10.9 W |
9.8 W |
MIC-CLP4L
View
Figure2-61 MIC-CLP4L view
(1) CPOS-OC3/STM1-SFP port (4 in total) |
(2) Port LED. For the LED description, see Table2-263. |
LEDs
Table2-263 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-264 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CLP4L |
4-port OC-3/STM-1 CPOS optical interface card |
LC |
4 |
Table2-265 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
12.9 W |
9.8 W |
MIC-CP1L
View
Figure2-62 MIC-CP1L view
(1) 100GBASE-R-CFP fiber ports (1 in total) |
(2) CFP port LED. For the LED description, see Table2-266 |
LEDs
Table2-266 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
The CFP port is sending or receiving data. |
Steady on |
A link is present on the CFP port. |
Off |
No link is present on the CFP port. |
Ports
Table2-267 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP1L |
1-port 100G optical interface card (CFP, LC) |
LC |
1 |
100 Gbps |
Table2-268 Technical specifications
Item |
37 mm × 171 mm × 157 mm (1.46 in × 6.73 in × 6.18 in) |
Weight |
0.55 kg (1.21 lb) |
11.8 W |
3.3 W |
MIC-CP1L-V2
View
Figure2-63 MIC-CP1L-V2 view
(1) CFP2 port LED. For the LED description, see Table2-269. |
(2) 100GBASE-R-CFP2 fiber ports (1 in total) |
LEDs
Table2-269 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
The CFP2 port is sending or receiving data at 100 Gbps. |
Steady on |
A 100 Gbps link is present on the CFP2 port. |
Off |
No link is present on the CFP2 port. |
Ports
Table2-270 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP1L-V2 |
1-port 100G Ethernet optical interface card (CFP2, LC) |
LC |
1 |
100 Gbps |
Table2-271 Technical specifications
Item |
23 mm × 137 mm × 119 mm (0.91 in × 5.39 in × 4.69 in) |
Weight |
0.45 kg (0.99 lb) |
8.7 W |
6 W |
MIC-CP2L
View
Figure2-64 MIC-CP2L view
(1) 100GBASE-R-CFP2 fiber ports (2 in total) (100G CFP2 modules supported) |
(2) CFP2 port LED. For the LED description, see Table2-272. |
LEDs
Table2-272 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-273 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP2L |
2-port 100G Ethernet optical interface card (CFP2, LC) |
LC |
2 |
100 Gbps |
Table2-274 Technical specifications
Item |
38 mm × 179 mm × 149 mm (1.50 in × 7.05 in × 5.87 in) |
Weight |
0.80 kg (1.76 lb) |
18.1 W |
8.6 W |
MIC-CP2L-V2
View
Figure2-65 MIC-CP2L-V2 view
(1) QSFP28 port LED. For the LED description, see Table2-275. |
(2) 100GBASE-R-QSFP28 fiber ports (2 in total) |
LEDs
Table2-275 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
The QSFP28 port is sending or receiving data at 100 Gbps. |
Steady on |
A 100 Gbps link is present on the QSFP28 port. |
Off |
No link is present on the QSFP28 port. |
Ports
Table2-276 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP2L-V2 |
2-port 100G Ethernet optical interface card (QSFP28) |
LC |
2 |
100 Gbps |
Table2-277 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
15 W |
9.3 W |
MIC-CQ1L1
View
Figure2-66 MIC-CQ1L1 view
(1) 100GBASE-R-QSFP28 port (1 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-278 |
LEDs
Table2-278 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-279 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ1L1 |
LC |
1 |
100 Gbps |
40 Gbps |
Table2-280 Technical specifications
Item |
Weight |
0.50 kg (1.10 lb) |
15 W |
9 W |
MIC-CQ1L2
View
Figure2-67 MIC-CQ1L2 view
(1) QSFP28 port LED. For the LED description, see Table2-281. |
(2) 100GBASE-R-QSFP28 fiber ports (1 in total) |
LEDs
Table2-281 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-282 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ1L2 |
LC |
1 |
· 100 Gbps |
· 40 Gbps |
Table2-283 Technical specifications
Item |
Weight |
0.45 kg (0.99 lb) |
15 W |
9 W |
0°C to 45°C (32°F to 113°F) |
MIC-CQ1LF
View
Figure2-68 MIC-CQ1LF view
(1) 100G/50G/40G fiber port LED. For the LED description, see Table2-284. |
(2) 100G/50G/40G fiber port (1 in total) |
(3) 50G/40G fiber port (1 in total) |
(4) 50G/40G fiber port LED. For the LED description, see Table2-284. |
LEDs
Table2-284 Fiber port LED description
LED |
Status |
Fiber port LED |
Flashing |
The port is sending or receiving data. |
Steady on |
Off |
NOTE: You can identify the speed of a port by observing the color of its LED. Green indicates a speed of 100 Gbps, and yellow indicates a speed of 50 Gbps or 40 Gbps. |
Ports
Table2-285 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ1LF |
2-port 50G/1-port 100G flexible Ethernet optical interface card (QSFP28,LC) |
LC |
1 |
100 Gbps |
2 |
50 Gbps |
40 Gbps |
Table2-286 Technical specifications
Item |
36 × 171 × 157 mm (1.42 × 6.73 × 6.18 in) |
Weight |
0.58 kg (1.28 lb) |
27 W |
21 W |
MIC-CQ2L
View
Figure2-69 MIC-CQ2L view
(1) QSFP28 port LED. For the LED description, see Table2-287. |
LEDs
Table2-287 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-288 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ2L |
LC |
2 |
100 Gbps |
40 Gbps |
Table2-289 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
16 W |
8 W |
MIC-ET16L
View
Figure2-70 MIC-ET16L view
(2) Port LED. For the LED description, see Table2-290. |
LED
LED |
Status |
ACT/ALM |
Flashing green |
Steady green |
A link is present, but the port is not receiving or sending data. |
Steady red |
Off |
Ports
Table2-291 Port specifications
Card model |
Connector type |
Port quantity |
MIC-ET16L |
16-port E1 electrical interface card (HM96 male connector) |
HM96 male |
16 |
E1 |
Table2-292 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
8.7W |
8.6 W |
MIC-GP10L1/MIC-GP10L2
View
Figure2-71 MIC-GP10L1 view
(1) 1000BASE-X-SFP fiber ports (10 in total) |
(2) SFP port LED. For the LED description, see Table2-293. |
The views of the MIC-GP10L1 and MIC-GP10L2 are similar. This figure uses the MIC-GP10L1 as an example.
LEDs
Table2-293 GE SFP port LED description
LED |
Status |
Flashing green |
The SFP port is sending or receiving data. |
Green |
Off |
Ports
Table2-294 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP10L1 |
10-port 1000BASE-X optical interface card (SFP, LC) |
LC |
10 |
100 Mbps |
1000 Mbps |
MIC-GP10L2 |
10-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
10 |
100 Mbps |
1000 Mbps |
Table2-295 Technical specifications
Item |
Weight |
· MIC-GP10L1: 0.30 kg (0.66 lb) · MIC-GP10L2: 0.48 kg (1.06 lb) |
· MIC-GP10L1: 7.9 W · MIC-GP10L2: 30 W |
· MIC-GP10L1: 2.1 W · MIC-GP10L2: 20 W |
MIC-GP10L-V2
View
Figure2-72 MIC-GP10L-V2 view
(2) SFP port LED. For the LED description, see Table2-296. |
LEDs
Table2-296 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-297 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP10L-V2 |
LC |
10 |
100 Mbps |
1000 Mbps |
Table2-298 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
9.4 W |
9.3 W |
MIC-GP20L
View
Figure2-73 MIC-GP20L view
(1) 1000BASE-X-SFP fiber ports (20 in total) |
(2) SFP port LED. For the LED description, see Table2-299. |
LEDs
Table2-299 GE SFP port LED description
LED |
Status |
Flashing green |
Steady green |
Off |
Ports
Table2-300 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP20L |
20-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
20 |
100 Mbps |
1000 Mbps |
Table2-301 Technical specifications
Item |
Weight |
0.55 kg (1.21 lb) |
23 W |
7.6 W |
MIC-GP20L1
View
Figure2-74 MIC-GP20L1 view
(2) SFP port LED. For the LED description, see Table2-302. |
LEDs
Table2-302 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-303 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP20L1 |
LC |
20 |
100 Mbps |
1000 Mbps |
Table2-304 Technical specifications
Item |
Weight |
0.80 kg (1.76 lb) |
18 W |
7 W |
MIC-GP4L
View
Table2-305 MIC-GP4L view
(1) Combo interfaces (4 in total) |
(2) Combo fiber port LINK/ACT LED. For the LED description, see Table2-306. |
(3) Combo copper LINK LED. For the LED description, see Table2-306. |
(4) Combo copper ACT LED. For the LED description, see Table2-306. |
LEDs
Table2-306 Combo ports LED description
Port type |
LED |
Status |
Combo fiber port |
LINK/ACT |
Steady on |
The port is up. |
Flashing green |
Off |
The port is down. |
Combo copper port |
LINK (Green) |
Steady on |
The port is up. |
Off |
The port is down. |
ACT (Orange) |
Flashing green |
Off |
The port is not receiving or sending data. |
Ports
Table2-307 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP4L |
4-port 1000BASE-X/1000BASE-T combo interface card |
RJ45 |
4 |
10/100/1000 Mbps |
LC |
4 |
100 Mbps |
1000 Mbps |
Table2-308 Technical specifications
Item |
Weight |
0.31 kg (0.68 lb) |
5.5 W |
0.8 W |
MIC-GP8L
View
Figure2-75 MIC-GP8L view
(1) 1000BASE-X-SFP fiber ports (8 in total) |
(2) SFP port LED. For the LED description, see Table2-309. |
LEDs
Table2-309 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-310 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP8L |
8-port 1000BASE-X optical interface card (SFP, LC) |
LC |
8 |
100 Mbps |
1000 Mbps |
Table2-311 Technical specifications
Item |
Weight |
0.29 kg (0.64 lb) |
4.7 W |
0.6 W |
MIC-GT20L/MIC-GT20L1
View
Figure2-76 MIC-GT20L view
(1) 10/100/1000BASE-T copper ports (20 in total) |
(2) RJ45 Ethernet port LED. For the description for the RJ45 port LEDs on the MIC-GT20L, see Table2-312. For the description for the RJ45 port LEDs on the MIC-GT20L1, see Table2-313. |
The views of the MIC-GT20L and MIC-GT20L1 are similar. This figure uses the MIC-GT20L as an example.
LEDs
Table2-312 RJ45 Ethernet port LED description (1)
LED |
Status |
RJ-45 Ethernet port LED |
Flashing |
Steady on |
Off |
Table2-313 RJ45 Ethernet port LED description (2)
LED |
Status |
Off |
NOTE: You can identify the speed of an RJ-45 Ethernet port by observing the color of its LEDs. A green LINK LED indicates a speed of 1000 Mbps, and a yellow ACT LED indicates a speed of 10/100 Mbps. |
Ports
Table2-314 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GT20L |
20-port 1000BASE-X Ethernet electrical interface card (RJ45) |
RJ45 |
20 |
10/100/1000 Mbps |
MIC-GT20L1 |
20-port 1000BASE-T Ethernet copper interface card (RJ45) |
RJ45 |
20 |
10/100/1000 Mbps |
Table2-315 Technical specifications
Item |
Weight |
· MIC-GT20L: 0.50 kg (1.10 lb) · MIC-GT20L1: 0.40 kg (0.88 lb) |
· MIC-GT20L: 11.9 W · MIC-GT20L1: 39 W |
· MIC-GT20L: 9.2 W · MIC-GT20L1: 28 W |
MIC-PSP4L
View
Figure2-77 MIC-PSP4L view
(2) Port LED. For the LED description, see Table2-316. |
LEDs
Table2-316 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-317 Port specifications
Card model |
Connector type |
Port quantity |
MIC-PSP4L |
4-port OC-48c/STM-16c POS optical interface card (SFP, LC) |
LC |
4 |
2.5 Gbps |
Table2-318 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
33 W |
29 W |
MIC-QP1L
View
Figure2-78 MIC-QP1L view
(1) 40GBASE-R-QSFP+ fiber port (1 in total) |
(2) QSFP+ port LED. For the LED description, see Table2-319. |
LEDs
Table2-319 QSFP + port LED description
LED |
Status |
QSFP + port LED |
Flashing |
The QSFP+ port is sending or receiving data. |
Steady on |
A link is present on the QSFP+ port. |
Off |
No link is present on the QSFP+ port. |
Ports
Table2-320 Port specifications
Card model |
Connector type |
Port quantity |
MIC-QP1L |
1-port 40G Ethernet optical interface card (QSFP+, LC) |
LC |
1 |
40 Gbps |
4 (after splitting) |
10 Gbps |
NOTE: You can execute a command to split the 40G port into four 10G breakout interfaces. For more information about the command, see H3C SR8800-X Routers Command Reference. |
Table2-321 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
7 W |
3 W |
MIC-SP4L
View
Figure2-79 MIC-SP4L view
(1) OC-3c/STM-1c POS/ATM fiber ports (4 in total) or OC-12c/STM-4c POS/ATM fiber port (port 1) |
(2) Port LED. For the LED description, see Table2-322. |
LEDs
Table2-322 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-323 Port specifications
Card model |
Connector type |
Port quantity |
MIC-SP4L |
4-port OC-3c/STM-1c POS/ATM or 1-port OC-12c/STM-4c POS/ATM optical interface card (SFP, LC) |
LC |
4 |
1 |
Table2-324 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
13.5 W |
9.6 W |
MIC-SP8L
View
Figure2-80 MIC-SP8L view
(2) Port LED. For the LED description, see Table2-325. |
LEDs
Table2-325 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-326 Port specifications
Card model |
Connector type |
Port quantity |
MIC-SP8L |
8-port OC-3c/STM-1c POS optical interface card (SFP, LC) |
LC |
8 |
Table2-327 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
16.3 W |
14 W |
MIC-TCP8L
View
Figure2-81 MIC-TCP8L view
(2) Port LED. For the LED description, see Table2-328. |
LEDs
Table2-328 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-329 Port specifications
Card model |
Connector type |
Port quantity |
MIC-TCP8L |
8-port OC-3c/OC-12c POS/GE optical interface card (SFP, LC) |
LC |
8 |
100 Mbps |
1000 Mbps |
Table2-330 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
30 W |
28 W |
MIC-XP10LF
View
Figure2-82 MIC-XP10LF view
(1) Port LED. For the LED description, see Table2-331. |
(2) 25GBASE-R-SFP28 fiber ports (ports 1 to 4) or 10GBASE-R-SFP+ fiber ports |
LEDs
Table2-331 Port LED description
LED |
Status |
Port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of an SFP28 port by observing the color of its LED. Green indicates a speed of 25 Gbps, and yellow indicates a speed of 10 Gbps or 1000 Mbps. |
Ports
Table2-332 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP10LF |
10-port 10GBASE-R flexible Ethernet optical interface card (SFP+,LC) |
LC |
10 |
1000 Mbps |
10 Gbps |
4 |
25 Gbps |
NOTE: You can change the speed of only ports 1 to 4 to 25 Gbps. Follow these restrictions and guidelines when you change the port speed: · Ports 1 and 7 form a group. After you change port 1 to a 25GE interface, port 7 is unavailable. · Ports 2 and 8 form a group. After you change port 2 to a 25GE interface, port 8 is unavailable. · Ports 3 and 9 form a group. After you change port 3 to a 25GE interface, port 9 is unavailable. · Ports 4 and 10 form a group. After you change port 4 to a 25GE interface, port 10 is unavailable. · Ports 5 and 6 cannot be changed to 25GE interfaces, and they are not affected by any speed change of other ports. For more information about the commands used for changing the speed of ports on the subcard, see H3C SR8800-X Routers Command Reference. |
Table2-333 Technical specifications
Item |
Weight |
0.61 kg (1.34 lb) |
37 W |
30 W |
MIC-XP10L-LAN
View
Figure2-83 MIC-XP10L-LAN view
(1) 10GBASE-R-SFP+ fiber ports or 1000BASE-X-SFP fiber ports (10 in total) |
(2) SFP+ port LED. For the LED description, see Table2-334. |
LEDs
Table2-334 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of an SFP+ port by observing the color of its LED. Green indicates a speed of 10 Gbps, and yellow indicates a speed of 1000 Mbps. |
Ports
Table2-335 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP10L-LAN |
10-port 10GBASE-R Ethernet optical interface card (SFP+, LC)-LAN |
LC |
10 |
10 Gbps |
1000 Mbps |
Table2-336 Technical specifications
Item |
Weight |
0.46 kg (1.01 lb) |
20 W |
12 W |
MIC-XP20L
View
Figure2-84 MIC-XP20L view
(1) 10GBASE-R/W-SFP+ fiber ports (20 in total) (10GE SFP+ modules supported) |
(2) SFP+ port LED. For the LED description, see Table2-337. |
LEDs
Table2-337 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of an SFP+ port by observing the color of its LED. Green indicates a speed of 10 Gbps, and yellow indicates a speed of 100/1000 Mbps. |
Ports
Table2-338 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP20L |
20-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
20 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-339 Technical specifications
Item |
Weight |
0.95 kg (2.09 lb) |
53 W |
38.3 W |
MIC-XP2L
View
Figure2-85 MIC-XP2L view
(1) 10GBASE-R/W-SFP+ fiber ports (2 in total) |
(2) SFP+ port LED. For the LED description, see Table2-340. |
LEDs
Table2-340 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-341 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP2L |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC) |
LC |
2 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-342 Technical specifications
Item |
Weight |
0.29 kg (0.64 lb) |
13 W |
10 W |
MIC-XP2L-LAN
View
Figure2-86 MIC-XP2L-LAN view
(1) 10GBASE-R-SFP+ fiber ports (2 in total) |
(2) SFP+ port LED. For the LED description, see Table2-343. |
LEDs
Table2-343 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-344 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP2L-LAN |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC)-LAN |
LC |
2 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-345 Technical specifications
Item |
Weight |
0.28 kg (0.62 lb) |
9 W |
6 W |
MIC-XP4L1
View
Figure2-87 MIC-XP4L1 view
(1) 10GBASE-R/W-SFP+ fiber ports (4 in total) |
(2) SFP+ port LED. For the LED description, see Table2-346. |
LEDs
Table2-346 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-347 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP4L1 |
4-port 10GBASE-R/W Ethernet optical interface card 1 (SFP+, LC) |
LC |
4 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-348 MIC-XP4L1
Item |
Weight |
0.30 kg (0.66 lb) |
13 W |
11 W |
MIC-XP5L
View
Figure2-88 MIC-XP5L view
(1) 10GBASE-R/W-SFP+ fiber ports (5 in total) |
(2) SFP+ port LED. For the LED description, see Table2-349. |
LEDs
Table2-349 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-350 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP5L |
5-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
5 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-351 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
14.2 W |
10.4 W |
MIC-XP5L1/MIC-XP5L2
View
Figure2-89 MIC-XP5L1 view
(2) SFP+ port LED. For the LED description, see Table2-352. |
The views of the MIC-XP5L1 and MIC-XP5L2 are similar. This figure uses the MIC-XP5L1 as an example.
LEDs
Table2-352 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-353 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP5L1 |
5-port 10GBASE-R/W Ethernet optical interface card |
LC |
5 |
100 Mbps |
1000 Mbps |
10 Gbps |
MIC-XP5L2 |
5-port 10GBASE-R Ethernet optical interface card |
LC |
5 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-354 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
· MIC-XP5L1: 13 W · MIC-XP5L2: 6.4 W |
· MIC-XP5L1: 11 W · MIC-XP5L2: 2.3 W |
MIC-XP8L
View
Figure2-90 MIC-XP8L view
(1) 10GBASE-R/W-SFP+ fiber ports (8 in total) |
(2) SFP+ port LED. For the LED description, see Table2-355. |
LEDs
Table2-355 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-356 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP8L |
8-port 10GBASE-R/W Ethernet optical interface card (SFP+, LC) |
LC |
8 |
10 Gbps |
1000 Mbps |
Table2-357 Technical specifications
Item |
Weight |
0.70 kg (1.54 lb) |
22 W |
16 W |
NIC subcards
IMPORTANT: · To use a NIC interface card, you must install it on a CMPE, SPE, or SPEX/CSPEX base card. You cannot install it directly on the router. · For the compatibility between NIC interface cards and CMPE, SPE, or SPEX/CSPEX base cards, see the compatibility information for the base cards. · Some NIC subcards support changing the speed and operating mode. For more information, see H3C SR8800-X Routers Configuration Guides. |
NIC-CC1L
View
Figure2-91 NIC-CC1L view
(1) 100GBASE-R-CFP2 fiber ports (1 in total) |
(2) CFP2 port LED. For the LED description, see Table2-358. |
LEDs
Table2-358 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-359 Port specifications
Card model |
Connector type |
Port quantity |
NIC-CC1L |
LC |
1 |
100 Gbps |
Table2-360 Technical specifications
Item |
47.5 mm × 179 mm × 118 mm (1.87 in × 7.05 in × 4.65 in) |
Weight |
0.60 kg (1.32 lb) |
9.7 W |
9.6 W |
NIC-CC2L
View
Figure2-92 NIC-CC2L view
(1) 100GBASE-R-CFP2 fiber ports (2 in total) |
(2) CFP2 port LED. For the LED description, see Table2-361. |
LEDs
Table2-361 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-362 Port specifications
Card model |
Connector type |
Port quantity |
NIC-CC2L |
2-port 100G Ethernet optical interface card |
LC |
2 |
100 Gbps |
Table2-363 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
21 W |
19.2 W |
NIC-CQ1L
View
Figure2-93 NIC-CQ1L view
(1) 100GBASE-R-QSFP28 fiber ports (1 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-364. |
LEDs
Table2-364 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-365 Port specifications
Card model |
Connector type |
Port quantity |
NIC-CQ1L |
LC |
1 |
100 Gbps |
Table2-366 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
13 W |
8 W |
NIC-CQ2L/NIC-CQ2LB
View
Figure2-94 NIC-CQ2L view
(1) 100GBASE-R-QSFP28 fiber ports (2 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-367. |
The views of NIC-CQ2L and NIC-CQ2LB are similar. This figure uses the NIC-CQ2L as an example.
LEDs
Table2-367 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-368 Port specifications
Card model |
Connector type |
Port quantity |
NIC-CQ2L |
LC |
2 |
100 Gbps |
NIC-CQ2LB |
2-port 100G Ethernet optical interface card B |
LC |
2 |
100 Gbps |
Table2-369 Technical specifications
Item |
Weight |
· NIC-CQ2L: 0.35 kg (0.77 lb) · NIC-CQ2LB: 0.75 kg (1.65 lb) |
26 W |
16 W |
NIC-GP20L
View
Figure2-95 NIC-GP20L view
(2) SFP port LED. For the LED description, see Table2-370. |
LEDs
Table2-370 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-371 Port specifications
Card model |
Connector type |
Port quantity |
NIC-GP20L |
20-port 1000BASE-X Ethernet optical interface card |
LC |
20 |
100 Mbps |
1000 Mbps |
Table2-372 Technical specifications
Item |
Weight |
0.65 kg (1.43 lb) |
13.8 W |
12 W |
NIC-GP24L
View
Figure2-96 NIC-GP24L view
(1) 1000BASE-X-SFP fiber ports (24 in total) |
(2) SFP port LED. For the LED description, see Table2-373. |
LEDs
Table2-373 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-374 Port specifications
Card model |
Connector type |
Port quantity |
NIC-GP24L |
24-port 1000BASE-X Ethernet optical interface card |
LC |
24 |
100 Mbps |
1000 Mbps |
Table2-375 Technical specifications
Item |
Weight |
0.50 kg (1.10 lb) |
28 W |
20 W |
NIC-GP24L1/NIC-GP24L1B
View
Figure2-97 NIC-GP24L1 view
(2) SFP port LED. For the LED description, see Table2-376. |
The views of the NIC-GP24L1 and NIC-GP24L1B are similar. This figure uses the NIC-GP24L1 as an example.
LEDs
Table2-376 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-377 Port specifications
Card model |
Connector type |
Port quantity |
NIC-GP24L1 |
LC |
24 |
100 Mbps |
1000 Mbps |
NIC-GP24L1B |
24-port 1000BASE-X Ethernet optical interface card B |
LC |
24 |
1000 Mbps |
Table2-378 Technical specifications
Item |
Weight |
1.00 kg (2.20 lb) |
47 W |
41 W |
NIC-GT20L
View
Figure2-98 NIC-GT20L view
(2) RJ-45 Ethernet port LED. For the LED description, see Table2-379. |
LEDs
Table2-379 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Ports
Table2-380 Port specifications
Card model |
Connector type |
Port quantity |
NIC-GT20L |
20-port 1000BASE-T Ethernet copper interface card |
RJ45 |
20 |
10/100/1000 Mbps |
Table2-381 Technical specifications
Item |
Weight |
0.75 kg (1.65 lb) |
16.5 W |
14.6 W |
NIC-QP3L
View
Figure2-99 NIC-QP3L view
(1) 40GBASE-R-QSFP+ fiber ports (3 in total) |
(2) QSFP+ port LED. For the LED description, see Table2-382. |
LEDs
Table2-382 QSFP+ port LED description
LED |
Status |
QSFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-383 Port specifications
Card model |
Connector type |
Port quantity |
NIC-QP3L |
3-port 40G Ethernet optical interface card (QSFP+,LC) |
LC |
3 |
40 Gbps |
Table2-384 Technical specifications
Item |
47.5 × 179 × 118 mm (1.87 × 7.05 × 4.65 in) |
Weight |
0.75 kg (1.65 lb) |
34 W |
33 W |
NIC-XP10L
View
Figure2-100 NIC-XP10L view
(1) 10GBASE-R/W-SFP+ fiber ports (10 in total) |
(2) SFP+ port LED. For the LED description, see Table2-385. |
LEDs
Table2-385 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-386 Port specifications
Card model |
Connector type |
Port quantity |
NIC-XP10L |
10-port 10GBASE-R/W Ethernet optical interface card |
LC |
10 |
10 Gbps |
1000 Mbps |
Table2-387 Technical specifications
Item |
Weight |
0.65 kg (1.43 lb) |
27.4 W |
26.9 W |
NIC-XP20L
View
Figure2-101 NIC-XP20L view
(1) 10GBASE-R/W-SFP+ fiber ports (20 in total) |
(2) SFP+ port LED. For the LED description, see Table2-388. |
LEDs
Table2-388 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-389 Port specifications
Card model |
Connector type |
Port quantity |
NIC-XP20L |
20-port 10GBASE-R/W Ethernet optical interface card |
LC |
20 |
10 Gbps |
1000 Mbps |
Table2-390 Technical specifications
Item |
Weight |
0.90 kg (1.98 lb) |
58 W |
39 W |
NIC-XP20L1/NIC-XP20L1B
View
Figure2-102 NIC-XP20L1 view
(1) 10GBASE-R/W-SFP+ fiber ports or 1000BASE-X-SFP fiber ports (20 in total) |
(2) SFP+ port/SFP port LED. For the SFP+ port LED description, see Table2-391. For the SFP port LED description, see Table2-392 |
The views of the NIC-XP20L1 and NIC-XP20L1B are similar. This figure uses the NIC-XP20L1 as an example.
LEDs
Table2-391 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Table2-392 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-393 Port specifications
Card model |
Connector type |
Port quantity |
NIC-XP20L1 |
LC |
20 |
10 Gbps |
1000 Mbps |
NIC-XP20L1B |
20-port 10GBASE-R/W Ethernet optical interface card B |
LC |
20 |
10 Gbps |
1000 Mbps |
Table2-394 Technical specifications
Item |
Weight |
· NIC-XP20L1: 1.00 kg (2.20 lb) · NIC-XP20L1B: 0.90 kg (1.98 lb) |
60 W |
50 W |
NIC-XP5L
View
Figure2-103 NIC-XP5L view
(2) SFP+ port LED. For the LED description, see Table2-395. |
LEDs
Table2-395 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-396 Port specifications
Card model |
Connector type |
Port quantity |
NIC-XP5L |
LC |
5 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-397 Technical specifications
Item |
Weight |
0.60 kg (1.32 lb) |
14.9 W |
11 W |
RX-NIC-CC1L
View
Figure2-104 RX-NIC-CC1L view
(2) CFP2 port LED. For the LED description, see Table2-398. |
LEDs
Table2-398 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-399 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-CC1L |
LC |
1 |
100 Gbps |
Table2-400 Technical specifications
Item |
Weight |
0.60 kg (1.32 lb) |
9.7 W |
9.6 W |
RX-NIC-CC2L
View
Figure2-105 RX-NIC-CC2L view
(2) CFP2 port LED. For the LED description, see Table2-401. |
LEDs
Table2-401 CFP2 port LED description
LED |
Status |
CFP2 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-402 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-CC2L |
LC |
2 |
100 Gbps |
Table2-403 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
21 W |
19.2 W |
RX-NIC-CQ1LF
View
Figure2-106 RX-NIC-CQ1LF view
(2) QSFP28 port LED. For the description, see Table2-404. |
LEDs
Table2-404 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the speed of a QSFP28 port by observing the color of its LED. Green indicates a speed of 100 Gbps, and yellow indicates a speed of 50 Mbps. |
Ports
Table2-405 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-CQ1LF |
LC |
1 |
100 Gbps |
50 Gbps |
Table2-406 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
53 W |
35 W |
RX-NIC-CQ2LF
View
Figure2-107 RX-NIC-CQ1LF view
(1) 100GBASE-R-QSFP28 fiber ports (2 in total). |
(2) QSFP28 port LED. For the description, see Table2-407. |
LEDs
Table2-407 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-408 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-CQ2LF |
2-port 100G flexible Ethernet optical interface card |
LC |
2 |
100 Gbps |
50 Gbps |
Table2-409 Technical specifications
Item |
Weight |
1.00 kg (2.20 lb) |
61 W |
38 W |
RX-NIC-GP20L
View
Figure2-108 RX-NIC-GP20L view
(2) SFP port LED. For the LED description, see Table2-410. |
LEDs
Table2-410 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-411 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-GP20L |
LC |
20 |
100 Mbps |
1000 Mbps |
Table2-412 Technical specifications
Item |
Weight |
0.65 kg (1.43 lb) |
13.8 W |
12 W |
RX-NIC-LGQ2L
View
Figure2-109 RX-NIC-LGQ2L view
(1) 50GBASE-R-QSFP28 fiber ports (2 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-413. |
LEDs
Table2-413 QSFP28 port LED description
LED |
Status |
QSFP28 port LEDs |
Flashing |
Steady on |
Off |
Ports
Table2-414 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-LGQ2L |
2-port 50G Ethernet optical interface card |
LC |
2 |
Standard Ethernet mode: 50 Gbps Flexible Ethernet mode: 50 Gbps |
Table2-415 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
61 W |
38 W |
0 °C to 45 °C (32 °F to 113 °F) |
RX-NIC-LGQ4L
View
Figure2-110 RX-NIC-LGQ4L view
(1) 50GBASE-R-QSFP28 fiber ports (4 in total) |
(2) QSFP28 port LED. For the description, see Table2-416. |
LEDs
Table2-416 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-417 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-LGQ4L |
4-port 50G Ethernet optical interface card |
LC |
4 |
Table2-418 Technical specifications
Item |
Weight |
0.90 kg (1.98 lb) |
92 W |
55 W |
RX-NIC-XP10L
View
Figure2-111 RX-NIC-XP10L view
(2) SFP+ port LED. For the LED description, see Table2-419. |
LEDs
Table2-419 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-420 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-XP10L |
LC |
10 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-421 Technical specifications
Item |
Weight |
0.65 kg (1.43 lb) |
27.4 W |
26.9 W |
RX-NIC-XP20L
View
Figure2-112 RX-NIC-XP20L view
(2) SFP+ port LED. For the LED description, see Table2-422. |
LEDs
Table2-422 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-423 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-XP20L |
LC |
20 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-424 Technical specifications
Item |
Weight |
1.00 kg (2.20 lb) |
58 W |
39 W |
RX-NIC-XP5L
View
Figure2-113 RX-NIC-XP5L view
(2) SFP+ port LED. For the LED description, see Table2-425. |
LEDs
Table2-425 SFP + port LED description
LED |
Status |
SFP + port LED |
Flashing |
Steady on |
Off |
Ports
Table2-426 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-XP5L |
LC |
5 |
100 Mbps |
1000 Mbps |
10 Gbps |
Table2-427 Technical specifications
Item |
Weight |
0.60 kg (1.32 lb) |
14.9 W |
11 W |
RX-NIC-YGS4L
View
Figure2-114 RX-NIC-YGS4L view
(1) 10GBASE-R-SFP+ port or 25GBASE-R-SFP28 port (4 in total) |
(2) SFP28 port LED. For the LED description, see Table2-428. |
LEDs
Table2-428 SFP28 port LED description
LED |
Status |
SFP28 port LED |
Flashing |
Steady on |
Off |
Ports
Table2-429 Port specifications
Card model |
Connector type |
Port quantity |
RX-NIC-YGS4L |
4-port 25G Ethernet optical interface card |
LC |
4 |
10 Gbps |
25 Gbps |
Table2-430 Technical specifications
Item |
Weight |
0.80 kg (1.76 lb) |
38 W |
25 W |
PIC subcards
IMPORTANT: · To use a PIC interface card, you must install it on a CMPE, SPE, or SPEX/CSPEX base card. You cannot install it directly on the router. · For the compatibility between PIC interface cards and CMPE, SPE, or SPEX/CSPEX base cards, see the compatibility information for the base cards. |
PIC-GP10L
View
Figure2-115 PIC-GP10L view
(1) 1000BASE-X-SFP Ethernet fiber port (10 in total) |
(2) SFP port LED. For the LED description, see Table2-431. |
LEDs
Table2-431 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-432 Port specifications
Card model |
Connector type |
Port quantity |
PIC-GP10L |
LC |
10 |
100 Mbps |
1000 Mbps |
Table2-433 PIC-GP10L
Item |
Weight |
0.45 kg (0.99 lb) |
21 W |
9.5 W |
PIC-PS2G4L
View
Figure2-116 PIC-PS2G4L view
(1) OC48c/STM16c-SFP POS fiber ports (2 in total) |
(2) 1000BASE-X-SFP GE fiber ports (4 in total) |
(3) POS port LED. For the LED description, see Table2-434. |
(4) GE port LED. For the LED description, see Table2-435. |
LEDs
Table2-434 WAN port LED description
LED |
Status |
Green |
Steady red |
Off |
The port is down. |
Table2-435 GE SFP port LED description
LED |
Status |
Flashing green |
Green |
Off |
Ports
Table2-436 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PS2G4L |
2-port OC-48c/STM-16c POS optical interface (SFP, LC) + 4-port 1000BASE-X optical interface card (SFP, LC) |
LC |
2 |
2.5 Gbps (OC-48/STM-16) |
4 |
100 Mbps |
1000 Mbps |
Table2-437 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
16 W |
9.3 W |
PIC-PSP4L
View
Figure2-117 PIC-PSP4L view
(1) OC48c/STM16c-SFP POS fiber ports (4 in total) |
(2) Port LED. For the LED description, see Table2-438. |
LEDs
Table2-438 WAN port LED description
LED |
Status |
Green |
Steady red |
Off |
The port is down. |
Ports
Table2-439 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PSP4L |
LC |
4 |
Table2-440 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
18 W |
9.7 W |
PIC-PUP1L
View
Figure2-118 PIC-PUP1L view
(1) OC192c/STM64c-XFP POS fiber port (1 in total) |
(2) Port LED. For the LED description, see Table2-441. |
LEDs
Table2-441 WAN port LED description
LED |
Status |
Green |
Steady red |
Off |
The port is down. |
Ports
Table2-442 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PUP1L |
1-port OC-192c/STM-64c POS optical interface card (XFP, LC) |
LC |
1 |
10 Gbps (OC-192/STM-64) |
Table2-443 Technical specifications
Item |
Weight |
0.50 kg (1.10 lb) |
19 W |
14.3 W |
PIC-TCP8L
View
Figure2-119 PIC-TCP8L view
(1) OC3c/OC12c/1000BASE-X-SFP POS/GE fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-444. |
LEDs
Table2-444 WAN port LED description
LED |
Status |
Green |
Steady red |
Off |
The port is down. |
Ports
Table2-445 Port specifications
Card model |
Connector type |
Port quantity |
PIC-TCP8L |
LC |
8 |
100 Mbps |
1000 Mbps |
Table2-446 Technical specifications
Item |
Dimensions (H × W × D) |
Weight |
0.40 kg (0.88 lb) |
Maximum power consumption |
17 W |
Minimum power consumption |
9.7 W |
Operating temperature |
PIC-XP1L
View
Figure2-120 PIC-XP1L view
(1) 10GBASE-R/W-XFP Ethernet fiber port (1 in total) |
(2) XFP port LED. For the LED description, see Table2-447. |
LEDs
Table2-447 10GE XFP port LED description
LED |
Status |
10GE XFP port LED (LINK/ACT) |
Flashing green |
The XFP port is sending or receiving data. |
Green |
A link is present on the XFP port. |
Off |
No link is present on the XFP port. |
Ports
Table2-448 Port specifications
Card model |
Connector type |
Port quantity |
PIC-XP1L |
1-port 10GBASE-R/W Ethernet optical interface card (XFP, LC) |
LC |
1 |
10 Gbps |
Table2-449 Technical specifications
Item |
Weight |
0.45 kg (0.99 lb) |
23.7 W |
12.5 W |
OAA modules
LSU1ADECEA0
View
Figure2-121 LSU1ADECEA0 view
(1) Console port (CONSOLE) |
(2) USB port (reserved for future use) |
(3) Combo copper port (10/100/1000BASE-T) |
(4) Combo copper port LED (LINK/ACT) |
(5) Combo fiber port (1000BASE-X) |
(6) Combo fiber port LED (LINK/ACT) |
(7) Alarm LED (ALM) |
(8) System LED (RUN) |
(9) Ejector lever |
(10) Captive screw |
LEDs
Table2-450 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
The system is operating correctly. |
Steady red |
A critical fault is present on the system and the fault must be handled immediately. |
System LED |
RUN |
Off |
No power is input or the service module has failed. |
Steady green |
The system is running incorrectly. |
Slow flashing green (1 Hz) |
Fast flashing green (8 Hz) |
The system is loading software or has not started. |
Combo interface LED |
LINK/ACT |
Off |
No link is present. |
Steady green |
A link is present. |
Flashing green |
The interface is sending or receiving data. |
Ports
Table2-451 Port specifications
Card model |
Connector type |
Port quantity |
LSU1ADECEA0 |
Application delivery service module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-452 Technical specifications
Item |
40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in) |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
IM-ACG1000X-IV
View
Figure2-122 IM-ACG1000X-IV view
(1) Captive screw |
(2) Ejector lever |
(3) Drive slot |
(4) Console port (CONSOLE) |
(5) GE Ethernet copper interface (10/100/1000BASE-T) |
(6) USB port |
(7) Drive LED (HD) |
(8) System LED (SYS) |
LEDs
Table2-453 LED description
LED |
Mark |
Status |
Drive LED |
HD |
Fast flashing green |
Data is being read from or written to the drive. |
Steady green |
The drive is running correctly. |
Off |
The drive is absent. |
System LED |
SYS |
Off |
Slow flashing green |
The system is loading software. |
Ports
Table2-454 Port specifications
Card model |
Connector type |
Port quantity |
IM-ACG1000X-IV |
Application control gateway module |
RJ45 |
1 |
10/100/1000 Mbps |
Table2-455 Technical specifications
Item |
Weight |
4.80 kg (10.60 lb) |
235 W |
175 W |
IM-IPSX-IV
View
Figure2-123 IM-IPSX-IV view
(1) Captive screw |
(2) Ejector lever |
(3) Drive slot |
(6) USB port |
LEDs
Figure2-124 LED description
LED |
Mark |
Status |
Drive LED |
HD |
Steady green |
Off |
System LED |
SYS |
Off |
Ports
Table2-456 Port specifications
Card model |
Connector type |
Port quantity |
IM-IPSX-IV |
Intrusion prevention system module |
RJ45 |
1 |
10/100/1000 Mbps |
Table2-457 Technical specifications
Item |
Weight |
4.80 kg (10.58 lb) |
235 W |
175 W |
IM-NGFWX-IV
View
Figure2-125 IM-NGFWX-IV view
(1) Captive screw |
(2) Ejector lever |
(3) Drive slot |
(6) USB port |
LEDs
Table2-458 LED description
LED |
Mark |
Status |
Drive LED |
HD |
Steady green |
Off |
System LED |
SYS |
Off |
Ports
Table2-459 Port specifications
Card model |
Connector type |
Port quantity |
IM-NGFWX-IV |
Firewall module |
RJ45 |
1 |
10/100/1000 Mbps |
Table2-460 Technical specifications
Item |
40 mm × 399 mm × 352 mm (1.57 in × 15.71 in × 13.86 in) |
Weight |
235 W |
175 W |
LSU1FWCEA0
View
Figure2-126 LSU1FWCEA0 view
(9) Ejector lever |
LEDs
Table2-461 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
A critical fault has occurred to the system and the fault must be handled immediately. |
System LED |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-462 Port specifications
Card model |
Connector type |
Port quantity |
LSU1FWCEA0 |
Firewall module |
RJ45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-463 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
LSU1IPSBEA0
View
Figure2-127 LSU1IPSBEA0 view
(2) USB port ( Control power supply of the external PFC power fail safeguard module) |
(9) Ejector lever |
LEDs
Table2-464 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
System LED |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-465 Port specifications
Card model |
Connector type |
Port quantity |
LSU1IPSBEA0 |
RJ45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-466 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
LSU3FWCEA0
View
Figure2-128 LSU3FWCEA0 view
(9) Ejector lever |
LEDs
Table2-467 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
System LED |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-468 Port specifications
Card model |
Connector type |
Port quantity |
LSU3FWCEA0 |
Firewall module |
RJ45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-469 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
For adequate ventilation and cooling, install the IM-NGFWX-IV, IM-IPSX-IV, and IM-ACG1000X-IV cards in the following slots only when the other slots are not available.
· SR8808-X router—Slots 0, 8 and 9.
· SR8812-X router—Slots 0 and 13.
Compatibility information
Table2-470 Compatibility matrix between OAA cards and routers
Card model |
SR8804-X, SR8808-X, SR8812-X |
SR8808H-X, SR8816-X |
IM-NGFWX-IV |
Supported |
Supported |
LSU1FWCEA0 |
Supported |
Not supported |
LSU3FWCEA0 |
Supported |
Not supported |
IM-IPSX-IV |
Supported |
Supported |
LSU1IPSBEA0 |
Supported |
Not supported |
IM-ACG1000X-IV |
Supported |
Supported |
LSU1ADECEA0 |
Supported |
Not supported |
IM modules (Universal line processing unit)
IM-APA-I
NOTE: The IM-APA-I provides one subcard slot. You can use it with an IM-SP-B subcard for double iBRAS packet processing rate. |
View
Figure2-129 IM-APA-I view
(1) Card status LED. For the LED description, see Table2-471. |
LEDs
Table2-471 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
The card is faulty. |
Off |
The card is faulty or is not in position. |
Flashing (once per second) |
The card is operating correctly. |
Fast flashing |
The card is starting up. If the LED keeps fast flashing, card registration has failed. |
Ports
Table2-472 Port specifications
Card model |
IM-APA-I |
iBRAS application-aware line processing unit |
Table2-473 Technical specifications
Item |
52.5 × 399 × 352 mm (2.07 × 15.71 × 13.86 in) |
Weight |
3.12 kg (6.88 lb) |
400 W |
Power consumption (with typical configuration) |
260 W |
248 W |
IM-APA-I3
NOTE: The IM-APA-I3 provides one subcard slot. You can use it with an IM-SP-B3 subcard for double iBRAS packet processing rate. |
View
Figure2-130 IM-APA-I3 view
(1) Card status LED. For the LED description, see Table2-474. |
LED
Table2-474 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Fast flashing (four times per second) |
Ports
Table2-475 Port specifications
Card model |
IM-APA-I3 |
Table2-476 Technical specifications
Item |
52.5 × 399 × 361 mm (2.07 × 15.71 × 14.21 in) |
Weight |
8.93 kg (19.69 lb) |
516 W |
274 W |
265 W |
IM-MSUX (1 U)
View
Figure2-131 IM-MSUX (1 U) view
(1) Card status LED. For the LED description, see Table2-477. |
LED
Table2-477 Card status LED description
LED |
Status |
RUN (green) |
Steady on |
Off |
The card is faulty or is not present. |
Fast flashing |
Ports
Table2-478 Port specifications
Card model |
IM-MSUX (1 U) |
Universal line processing unit |
Table2-479 Technical specifications
Item |
Weight |
4.95 kg (10.91 lb) |
186 W |
Typical power consumption |
175 W |
158.2 W |
IM-MSUX (1.2 U)
View
Figure2-132 IM-MSUX (1.2 U) view
(1) Card status LED. For the LED description, see Table2-480. |
LEDs
Table2-480 Card status LED description
LED |
Status |
RUN (green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-481 Port specifications
Card model |
IM-MSUX (1.2 U) |
Table2-482 Technical specifications
Item |
Weight |
4.85 kg (10.69 lb) |
186 W |
175 W |
158.2 W |
IM-MSEX-B
NOTE: The IM-MSEX-B provides one subcard slot. You can use it without a subcard, or use it with an IM-SP-B subcard for double CGN packet processing rate. |
View
Figure2-133 IM-MSEX-B view
(1) Card status LED. For the LED description, see Table2-483. |
LEDs
Table2-483 Card status LED description
LED |
Status |
RUN (green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-484 Port specifications
Card model |
IM-MSEX-B |
Service processing unit |
Table2-485 Technical specifications
Item |
Weight |
3.12 kg (6.88 lb) |
400 W |
260 W |
248 W |
IM-MSEX-B3
NOTE: The IM-MSEX-B3 provides one subcard slot. You can use it without a subcard, or use it with an IM-SP-B3 subcard for double CGN packet processing rate. |
View
Figure2-134 IM-MSEX-B3 view
(1) Card status LED. For the LED description, see Table2-486. |
LEDs
Table2-486 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Ports
Table2-487 Port specifications
Card model |
IM-MSEX-B3 |
Table2-488 Technical specifications
Item |
Weight |
516 W |
274 W |
265 W |
IM-SP-B
NOTE: The IM-SP-B subcard must be installed on an IM-APA-I or IM-MSEX-B for use. It occupies one subcard slot and does not provide ports. |
View
Figure2-135 IM-SP-B view
(1) Card status LED. For the LED description, see Table2-489. |
LEDs
Table2-489 Card status LED description
LED |
Status |
RUN (green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-490 Port specifications
Card model |
IM-SP-B |
Universal expansion service processing module |
Table2-491 Technical specifications
Item |
47.5 × 170 × 192 mm (1.87 × 6.69 × 7.56 in) |
Weight |
1.20 kg (2.65 lb) |
130 W |
95 W |
IM-SP-B3
NOTE: The IM-SP-B3 subcard must be installed on an IM-APA-I3 or IM-MSEX-B3 for use. It occupies one subcard slot and does not provide ports. |
View
Figure2-136 IM-SP-B3 view
(1) Card status LED. For the LED description, see Table2-492. |
LEDs
Table2-492 Card status LED description
LED |
Status |
RUN (Green) |
Steady on |
Off |
Ports
Table2-493 Port specifications
Card model |
IM-SP-B3 |
Table2-494 Technical specifications
Item |
47.5 × 190 × 154 mm (1.87 × 7.48 × 6.06 in) |
Weight |
1.26 kg (2.78 lb) |
127 W |
124 W |
For adequate ventilation and cooling, install the IM-MSUX cards in the following slots only when the other slots are not available:
Table2-495 Compatibility matrix between universal line processing units and routers
Card model |
SR8804-X |
IM-APA-I |
Not supported |
Not supported |
Supported |
IM-APA-I3 |
Not supported |
Not supported |
Supported |
IM-MSUX (1 U) |
Supported |
Supported |
Supported |
IM-MSUX (1.2 U) |
Not supported |
Not supported |
Supported |
IM-MSEX-B |
Not supported |
Not supported |
Supported |
IM-MSEX-B3 |
Not supported |
Not supported |
Supported |
IM modules (Security monitor line processing unit)
IM-SMUX
View
Figure2-137 IM-SMUX view
(1) Card status LED. For the LED description, see Table2-496. |
LEDs
Table2-496 Card status LED description
LED |
Status |
RUN (green) |
Steady on |
Off |
Flashing (about once per second) |
Fast flashing |
The card is starting up. If the LED keeps fast flashing, the card fails registration. |
Ports
Table2-497 Port specifications
Card model |
IM-SMUX |
Security monitor line processing unit |
Table2-498 Technical specifications
Item |
Weight |
186 W |
175 W |
159 W |
Table2-499 Compatibility matrix between security monitor line processing units and routers
Card model |
SR8804-X |
IM-SMUX |
Not supported |
Not supported |
Supported |
IM modules (Network data encryption service processing unit)
IM-SFMX
NOTE: The IM-SFMX provides one subcard slot. When used without a subcard, it uses non-SM algorithms to encrypt and decrypt network data. When used with an MIC-SM, it uses SM algorithms to encrypt and decrypt network data. |
View
Figure2-138 IM-SFMX view
(1) Card status LED. For the LED description, see Table2-500. |
LEDs
Table2-500 Card status LED description
LED |
Status |
RUN (green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-501 Port specifications
Card model |
IM-SFMX |
Network data encryption service processing unit |
Table2-502 Technical specifications
Item |
40 × 399 × 355 mm (1.57 × 15.71 × 13.86 in) |
Weight |
4.05 kg (8.93 lb) |
165 W |
113 W |
90 W |
MIC-SEC
NOTE: The MIC-SEC occupies one subcard slot. It must be installed on a base card for use. For compatibilities between the MIC-SEC subcard and MPE, SPE, or SPEX/CSPEX base cards, see compatibility information for the base cards. |
View
Figure2-139 MIC-SEC view
Ports
Table2-503 Port specifications
Card model |
Connector type |
Port quantity |
Port transmission speed |
MIC-SEC |
Network data encryption service processing interface card |
N/A |
N/A |
N/A |
Table2-504 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
31 W |
29 W |
MIC-SM
NOTE: · The MIC-SM is not hot swappable. · The MIC-SM must be installed on an IM-SFMX for use. It occupies one subcard slot. · The MIC-SM is provided with six USB keys for you to obtain user roles to manage the card. To obtain a user role, first insert a USB key into USB port AUTH. For more information about the encryption card configuration, see H3C SR8800-X Routers Configuration Guides. |
View
Figure2-140 MIC-SM view
(1) Card status LED. For the LED description, see Table2-505. |
(2) USB port KEY (reserved for future use) |
(3) USB port AUTH |
LEDs
Table2-505 Card status LED description
LED |
Status |
RUN (green) |
Steady on |
Off |
Fast flashing |
Ports
Table2-506 Port specifications
Card model |
MIC-SM |
Network data encryption interface card |
Table2-507 Technical specifications
Item |
37 × 179 × 149 mm (1.46 in × 7.05 in × 5.87 in) |
Weight |
0.90 kg (1.98 lb) |
40 W |
25 W |
Table2-508 Compatibility matrix between security monitor line processing units and routers
Card model |
SR8804-X |
IM-SMUX |
Not supported |
Not supported |
Supported |
IM modules (Universal open application platform)
IM-OAPX
View
Figure2-141 IM-OAPX view
No. |
(1) |
Power on/standby button and system power LED |
(2) |
2.5 in SATA drive slot |
(3) |
Drive Present/Active LED |
(4) |
Drive Fault/UID LED |
(5) |
BMC network port (1 Gb, RJ45) with default IP 192.168.1.2/24 |
(6) |
Shared network port, which can be used as the following: · Ethernet port (1Gb, RJ45) · BMC network port (1Gb, RJ45), with default IP automatically obtained through DHCP) |
(7) |
BMC network port status LED |
(8) |
Shared network port status LED |
(9) |
VGA connector |
(10) |
USB 2.0 port |
(11) |
USB 3.0 port |
(12) |
Console port |
(13) |
UID LED |
(14) |
RUN LED |
(15) |
Health LED |
LEDs
Table2-509 System power LED description
LED |
Status |
Steady green |
The system has started up. |
Flashing green (1 Hz) |
The system is starting up. |
Steady amber |
The system is in standby mode. |
Off |
The system is powered off. |
Table2-510 Health LED description
LED |
Status |
Health LED |
Steady green |
Flashing green (4 Hz) |
The BMC is currently resetting and initializing. |
Flashing yellow and green (1 Hz) |
A minor alarm occurs in the system, including an alarm on an error monitored by BMC or an alarm on hardware. |
Flashing yellow (1 Hz) |
A major alarm occurs in the system, including an alarm on an error monitored by BMC, an alarm on hardware or CPU. |
Table2-511 RUN LED description
LED |
Status |
RUN LED |
Steady on |
Off |
Flashing (1 Hz) |
Fast flashing |
Table2-512 UID LED description
LED |
Status |
UID LED |
Steady blue |
The UID LED is activated. You can activate the UID LED in the following methods: · Press down the UID LED. · Power on the UID LED from BMC. |
Flashing blue |
· 1 Hz: The system is being remote managed by BMC or performing software update. · 4Hz: BMC is restarting by pressing the UID button or LED for 8 seconds. |
Off |
The UID LED is not activated. |
Table2-513 Drive LED description
Fault/UID LED (orange/blue) |
Present/Active LED (green) |
Flashing orange (0.5 Hz) |
Steady green/flashing green (4 Hz) |
A predictive alarm occurs on the drive. Replace the drive in time.* |
Steady orange |
An error occurs on the drive. Replace the drive immediately. |
Steady blue |
The drive is operating correctly and has been selected by the array management tool. |
Off |
Flashing (4 Hz) |
The drive is present. Data is being read from or written to the drive, or the drive is being used for array migration or rebuilding. |
Off |
Steady on |
The drive is present but no data being read from or written to the drive. |
Off |
Off |
The drive is not installed properly. |
Table2-514 BMC network port LED description
LED |
Status |
BMC network port LED |
Steady green |
The network port is being activated. |
The network port is receiving or sending data. |
Off |
The network port is disconnected. |
Table2-515 Shared network port LED description
LED |
Status |
Shared network port LED |
Steady green |
Off |
Ports
Table2-516 Port specifications
Card model |
IM-OAPX |
Universal open application platform |
Table2-517 Technical specifications
Item |
Weight |
6.25 kg (13.78 lb) |
320 W |
310 W |
295 W |
Processor |
Intel Skylake Xeon CPU · A maximum power consumption of 205 W · A maximum of 2.6 GHz CPU clock speed · 38.5 MB cache |
Memory |
Support six DDR4 memory modules · Single DIMM capacity: 32 GB · Total memory capacity: 192 GB |
Storage |
Maximum storage capacity: 2 × 960 GB |
Chipset |
Intel C62x Lewisburg chipset compatible with LBG-T SKU |
User port |
· 2 × console ports · 1 × BMC network port · 1 × shared network port (used as an Ethernet port or a BMC network port) · 1 × VGA connector · 1 × USB port (USB 3.0) · 2 × USB ports (USB 2.0) |
Table2-518 Drive specifications
Model |
Capacity |
Interface type |
Interface rate |
UIS-SSD-960GB-SATA-6G-SFF-EV |
960 G |
SATA |
6 Gbps |
UN-SSD-960G-SATA-6G-SFF-EV-1 |
960 G |
SATA |
6 Gbps |
To avoid data loss on drives, you must shut down the universal open application platform before performing the following operations:
· Reboot or hot swap the universal open application platform.
· Reboot or shut down the router.
Do not install the universal open application platform in slot 6 of the SR8808-X router or slot 8 of the SR8812-X router.
The console port on the panel of the universal open application platform is only for users. The internal console port of the universal open application platform is only for H3C Support to perform maintenance and updates. Operations without permission are not allowed. H3C will not be liable for any consequences caused thereby.
The shared network interface can operate only at 1000 Mbps and can be connected only with a GE Ethernet port.
USB ports on the universal open application platform do not support extension cable connection.
Table2-519 Compatibility matrix between the universal open application platform and routers
Card model |
SR8804-X |
IM-OAPX |
Supported |
Supported |
Supported |
Switching fabric modules
SFC-04-1/SFC-04-2/SFC-04-3/SFC-04-4
View
Figure2-142 SFC-04-1 view
NOTE: The views of the SFC-04-1, SFC-04-2, SFC-04-3, and SFC-04-4 are similar. This figure uses the SFC-04-1 as an example. |
Table2-520 Technical specifications
Item |
40 × 256 × 298 mm (1.57 × 10.08 × 11.73 in) |
Weight |
1.00 kg (2.20 lb) |
N/A |
N/A |
SFC-04B/SFC-04D
View
Figure2-143 SFC-04B view
(1) Switching fabric module status LED. For the LED description, see Table2-521. |
(2) Console port |
NOTE: The views of the SFC-04B and SFC-04D are similar. This figure uses the SFC-04B as an example. |
LEDs
Table2-521 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
The switching fabric module is operating correctly. |
Off |
Steady on |
The switching fabric module is faulty. |
Flashing (0.5 Hz) |
Steady on |
The temperature of the switching fabric module has exceeded the upper limit or dropped below the lower limit. |
Off |
Off |
The switching fabric module has not started up. |
Steady on |
Off |
The switching fabric module is starting up. |
Table2-522 Technical specifications
Item |
Weight |
· SFC-04B: 1.75 kg (3.86 lb) · SFC-04D: 1.71 kg (3.77 lb) |
· SFC-04B: 65 W · SFC-04D: 80 W |
· SFC-04B: 59 W · SFC-04D: 72 W |
· SFC-04B: 48 W · SFC-04D: 60 W |
SFC-08B/SFC-08D
View
Figure2-144 SFC-08B view
(1) Console port |
(2) Switching fabric module status LED. For the LED description, see Table2-523. |
NOTE: The views of the SFC-08B and SFC-08D are similar. This figure uses the SFC-08B as an example. |
LEDs
Table2-523 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
Off |
Steady on |
Flashing (0.5 Hz) |
Steady on |
Off |
Off |
Steady on |
Off |
Table2-524 Technical specifications
Item |
40 × 426 × 298 mm (1.57 × 16.77 × 11.73 in) |
Weight |
· SFC-08B: 2.50 kg (5.51 lb) · SFC-08D: 2.77 kg (6.11 lb) |
· SFC-08B: 60 W · SFC-08D: 135 W |
· SFC-08B: 54 W · SFC-08D: 122 W |
· SFC-08B: 44 W · SFC-08D: 101 W |
SFC-08E
View
Figure2-145 SFC-08E view
(1) Switching fabric module status LED. For the LED description, see Table2-525. |
LEDs
Table2-525 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
Off |
Steady on |
Flashing (0.5 Hz) |
Steady on |
Off |
Off |
Steady on |
Off |
Table2-526 Technical specifications
Item |
Weight |
3.55 kg (7.83 lb) |
140 W |
130 W |
73 W |
SFC-08E1/SFC-08T
View
Figure2-146 SFC-08T view
(1) Switching fabric module status LED. For the LED description, see Table2-527. |
NOTE: The views of the SFC-08E1 and SFC-08T are similar. This figure uses the SFC-08T as an example. |
LEDs
Table2-527 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-528 Technical specifications
Item |
40 × 562 × 298 mm (1.57 × 22.13 × 11.73 in) |
Weight |
· CSFC-08E1: 5.20 kg (11.46 lb) · CSFC-08T: 5.15 kg (11.35 lb) |
· CSFC-08E1: 125 W · CSFC-08T: 129 W |
· CSFC-08E1: 112 W · CSFC-08T: 116 W |
· CSFC-08E1: 75 W · CSFC-08T: 100 W |
CSFC-08T-G
View
Figure2-147 CSFC-08T-G view
(1) Switching fabric module status LED. For the LED description, see Table2-529. |
LEDs
Table2-529 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-530 Technical specifications
Item |
Weight |
5.30 kg (11.68 lb) |
130 W |
110 W |
100 W |
SFC-12B/SFC-12D
View
Figure2-148 SFC-12B view
(1) Console port |
(2) Switching fabric module status LED. For the LED description, see Table2-531. |
NOTE: The views of the SFC-12B and SFC-12D are similar. This figure uses the SFC-12B as an example. |
LEDs
Table2-531 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
Off |
Steady on |
Flashing (0.5 Hz) |
Steady on |
Off |
Off |
Steady on |
Off |
Table2-532 Technical specifications
Item |
40 × 602 × 298 mm (1.57 × 23.70 × 11.73 in) |
Weight |
· SFC-12B: 3.89 kg (8.58 lb) · SFC-12D: 4.51 kg (9.94 lb) |
· SFC-12B: 140 W · SFC-12D: 255 W |
· SFC-12B: 126 W · SFC-12D: 230 W |
· SFC-12B: 107 W · SFC-12D: 195 W |
SFC-12E
View
Figure2-149 SFC-12E view
(1) Console port |
(2) Air inlet vents |
(3) Switching fabric module status LED. For the LED description, see Table2-533. |
LEDs
Table2-533 Switching fabric module status LED description
LED status |
RUN |
ALM |
Flashing (0.5 Hz) |
Off |
Off |
Steady on |
Flashing (0.5 Hz) |
Steady on |
Off |
Off |
Steady on |
Off |
Table2-534 Technical specifications
Item |
Weight |
178 W |
161 W |
146 W |
SFC-16T/SFC-16E
View
Figure2-150 SFC-16E view
(1) Switching fabric module status LED. For the LED description, see Table2-535. |
NOTE: The views of the SFC-16T and SFC-16E are similar. This figure uses the SFC-16E as an example. |
LEDs
Table2-535 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-536 Technical specifications
Item |
40 × 961 × 298 mm (1.57 × 37.83 × 11.73 in) |
Weight |
· CSFC-16T: 10.25 kg (22.60 lb) · CSFC-16E: 10.50 kg (23.15 lb) |
· CSFC-16T: 402 W · CSFC-16E: 248 W |
· CSFC-16T: 361 W · CSFC-16E: 220 W |
· CSFC-16T: 267 W · CSFC-16E: 159 W |
CSFC-16T3
View
Figure2-151 CSFC-16T3 view
(1) Switching fabric module status LED. For the LED description, see Table2-537. |
LEDs
Table2-537 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-538 Technical specifications
Item |
Weight |
10.35 kg (22.82 lb) |
600 W |
380 W |
256 W |
0°C to 45°C (32°F to 113°F) |
CSFC-16T-G
View
Figure2-152 CSFC-16T-G view
(1) Switching fabric module status LED. For the LED description, see Table2-539. |
LEDs
Table2-539 Switching fabric module status LED description
RUN LED status |
Flashing (0.5 Hz) |
Flashing (8 Hz) |
Off |
Table2-540 Technical specifications
Item |
Weight |
10.30 kg (22.71 lb) |
120 W |
110 W |
100 W |
Do not mix Type-B, Type-D, Type-E, Type-T, and Type-TG switching fabric modules in any combinations on the same router.
If you use Type-B, Type-D, Type-E, Type-T, or Type-TG switching fabric modules for the router, a minimum of two are required. For an SR8808H-X router, you must install switching fabric modules in slots 10 and 12. Slot 11 can be used only when five switching fabric modules are required. For an SR8816-X router, you must install switching fabric modules in slots 18 and 20. Slot 19 can be used only when five switching fabric modules are required. For other routers, slots 1, 3, and 4 take precedence over the other slots for switching fabric module installation.
The console port on a switching fabric module is only for H3C Support to perform maintenance and updates. Operations without permission are not allowed. H3C will not be liable for any consequences caused thereby.
If Type-A switching fabric modules are used, use the four together and install each into the specified slot. Each Type-A switching fabric module has a mark specifying the slot for installation. For example, the SFC-04-1 has the mark Notes:Please insert to Slot 6.
After you change a Type-B or Type-D switching fabric module to a Type-A switching fabric module on the SR8804-X router, you must restart the router.
Table2-541 Compatibility matrix between switching fabric modules and routers
Chassis model |
Available switching fabric module model |
Number |
SR8804-X |
Type-A: SFC-04-1, SFC-04-2, SFC-04-3, and SFC-04-4 |
4 (1 for each switching fabric module model) |
· Type-B: SFC-04B · Type-D: SFC-04D |
2 to 4 |
SR8808-X |
· Type-B: SFC-08B · Type-D: SFC-08D · Type-E: SFC-08E |
2 to 4 |
SR8808H-X |
· Type-E: SFC-08E1 · Type-T: SFC-08T · Type-TG: CSFC-08T-G |
2 to 5 |
SR8812-X |
· Type-B: SFC-12B · Type-D: SFC-12D · Type-E: SFC-12E |
2 to 4 |
SR8816-X |
· Type-E: SFC-16E · Type-T: SFC-16T, CSFC-16T3 · Type-TG: CSFC-16T-G |
2 to 5 |
Table2-542 Compatibility matrix between switching fabric modules and service modules (1)
Service module |
Type-A switching fabric module |
SFC-04B |
SFC-04D |
SFC-08B |
SFC-08D |
SFC-12B SFC-12D |
SPC-GT48LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GE24L-E |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP24LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP48LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP48LB |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP24XP2LA |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP24XP2LB |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GP24GE8XP2L-E |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPC-GE16XP4L-E |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP44XP4LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-GP44XP4LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP2LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP4LA1 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP4LB |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP8LA |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP8LB |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP12LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP12LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP24LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XP24LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XLP6LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-XLP6LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-CP1LAX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-CP1LCX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-CP2LA |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
SPC-CP2LB |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CEPC-XP4LX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CEPC-XP24LX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-XP48RX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CP4RX-L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-DQ2L1-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPEX-1204 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1104-E |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1304X |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1404X |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1502X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1504X |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1602X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1802X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1802XB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1804X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1512X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1612X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1812X |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1812X-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2304X-G |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-2304X-G2 |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-2304X-LG |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-2314X-G |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2314X-G1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2314X-G2 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2612X-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-2612X3-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
MPE-1104 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
RX-SPE200 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-SPE200-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-NGFWX-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1FWCEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU3FWCEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-IPSX-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1IPSBEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-ACG1000X-IV |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1ADECEA0 |
Supported |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-APA-I |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-APA-I3 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-MSUX (1 U) |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1.2 U) |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-MSEX-B |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-MSEX-B3 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-SMUX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Not supported |
IM-SFMX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-OAPX |
Not supported |
Supported |
Supported |
Supported |
Supported |
Supported |
Table2-543 Compatibility matrix between switching fabric modules and service modules (2)
Service module |
SFC-08E |
SFC-08E1 |
SFC-12E |
SFC-08T |
CSFC-08T-G |
SPC-GT48LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE24L-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP48LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP48LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24XP2LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24XP2LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE16XP4L-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP44XP4LAX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP44XP4LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP2LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP4LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP4LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP8LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP8LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP12LAX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP12LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP24LAX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP24LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XLP6LAX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XLP6LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP1LAX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP1LCX |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP2LA |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP2LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-XP4LX |
Supported |
Supported |
Supported |
Supported |
Supported |
CEPC-XP24LX |
Supported |
Supported |
Supported |
Supported |
Not supported |
CEPC-XP48RX |
Supported |
Supported |
Supported |
Supported |
Not supported |
CEPC-CP4RX |
Supported |
Supported |
Supported |
Supported |
Not supported |
CEPC-CP4RX-L |
Supported |
Supported |
Supported |
Supported |
Not supported |
CEPC-CQ8L |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
CEPC-CQ16L1 |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
CEPC-DQ2L1-G |
Not supported |
Not supported |
Not supported |
Supported |
Not supported |
SPEX-1204 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1104-E |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1404X |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1502X |
Supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1504X |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-1602X |
Supported |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1802X |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-1802XB |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
CSPEX-1804X |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-1512X |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-1612X |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-1812X |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-1812X-E |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-2304X-G |
Supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-2304X-G2 |
Supported |
Supported |
Supported |
Supported |
Supported |
CSPEX-2304X-LG |
Supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-2314X-G |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-2314X-G1 |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-2314X-G2 |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-2612X-E |
Not supported |
Supported |
Not supported |
Supported |
Supported |
CSPEX-2612X3-E |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
MPE-1104 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
RX-SPE200 |
Not supported |
Supported |
Not supported |
Supported |
Supported |
RX-SPE200-E |
Not supported |
Supported |
Not supported |
Supported |
Supported |
IM-NGFWX-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1FWCEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
LSU3FWCEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-IPSX-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1IPSBEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-ACG1000X-IV |
Supported |
Supported |
Supported |
Supported |
Supported |
LSU1ADECEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
IM-APA-I |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
IM-APA-I3 |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
IM-MSUX (1 U) |
Supported |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1.2 U) |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
IM-MSEX-B |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
IM-MSEX-B3 |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
IM-SMUX |
Not supported |
Supported |
Not supported |
Supported |
Supported |
IM-SFMX |
Supported |
Supported |
Supported |
Not supported |
Not supported |
IM-OAPX |
Supported |
Supported |
Supported |
Supported |
Supported |
Table2-544 Compatibility matrix between switching fabric modules and service modules (3)
Service module |
SFC-16E |
SFC-16T |
CSFC-16T3 |
CSFC-16T-G |
SPC-GT48LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE24L-E |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP48LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP48LB |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24XP2LA |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP24XP2LB |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
CSPC-GE16XP4L-E |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP44XP4LAX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-GP44XP4LCX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP2LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP4LA1 |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP4LB |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP8LA |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP8LB |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP12LAX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP12LCX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP24LAX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XP24LCX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XLP6LAX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-XLP6LCX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP1LAX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP1LCX |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP2LA |
Not supported |
Not supported |
Not supported |
Not supported |
SPC-CP2LB |
Not supported |
Not supported |
Not supported |
Not supported |
CEPC-XP4LX |
Supported |
Supported |
Not supported |
Supported |
CEPC-XP24LX |
Supported |
Supported |
Not supported |
Not supported |
CEPC-XP48RX |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CP4RX |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CP4RX-L |
Supported |
Supported |
Not supported |
Not supported |
CEPC-CQ8L |
Not supported |
Supported |
Not supported |
Not supported |
CEPC-CQ16L1 |
Not supported |
Supported |
Not supported |
Not supported |
CEPC-DQ2L1-G |
Not supported |
Supported |
Not supported |
Not supported |
SPEX-1204 |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1104-E |
Not supported |
Not supported |
Not supported |
Not supported |
CSPEX-1304X |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1404X |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1502X |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1504X |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1602X |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1802X |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-1802XB |
Supported |
Supported |
Supported |
Not supported |
CSPEX-1804X |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1512X |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1612X |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1812X |
Supported |
Supported |
Not supported |
Supported |
CSPEX-1812X-E |
Supported |
Supported |
Supported |
Supported |
CSPEX-2304X-G |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2304X-G2 |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2304X-LG |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2314X-G |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2314X-G1 |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2314X-G2 |
Supported |
Supported |
Not supported |
Supported |
CSPEX-2612X-E |
Supported |
Supported |
Not supported |
Not supported |
CSPEX-2612X3-E |
Supported |
Supported |
Supported |
Not supported |
MPE-1104 |
Not supported |
Not supported |
Not supported |
Not supported |
RX-SPE200 |
Supported |
Supported |
Not supported |
Supported |
RX-SPE200-E |
Supported |
Supported |
Not supported |
Not supported |
IM-NGFWX-IV |
Supported |
Supported |
Not supported |
Supported |
LSU1FWCEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
LSU3FWCEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
IM-IPSX-IV |
Supported |
Supported |
Not supported |
Supported |
LSU1IPSBEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
IM-ACG1000X-IV |
Supported |
Supported |
Not supported |
Supported |
LSU1ADECEA0 |
Not supported |
Not supported |
Not supported |
Not supported |
IM-APA-I |
Supported |
Supported |
Supported |
Not supported |
IM-APA-I3 |
Supported |
Supported |
Supported |
Not supported |
IM-MSUX (1 U) |
Supported |
Supported |
Supported |
Supported |
IM-MSUX (1.2 U) |
Supported |
Supported |
Supported |
Not supported |
IM-MSEX-B |
Supported |
Supported |
Supported |
Not supported |
IM-MSEX-B3 |
Supported |
Supported |
Supported |
Not supported |
IM-SMUX |
Supported |
Supported |
Supported |
Supported |
IM-SFMX |
Supported |
Not supported |
Not supported |
Not supported |
IM-OAPX |
Supported |
Supported |
Not supported |
Supported |
Power supplies
The router supports the PSR1200B-12A, PSR1200B-12A1-F, LSUM1AC1200, LSUM1AC2500, PSR2500-12A, LSUM1DC2400, PSR2400-12D, PSR2400-D, and PSR2500B-12AHD-F power supplies.
PSR1200B-12A/LSUM1AC1200
View
(1) Captive screw |
(2) Power supply handle |
(3) Power input receptacle |
(4) Air inlet vent |
(5) Power output status LED |
(6) Power input status LED |
NOTE: The views of the PSR1200B-12A and LSUM1AC1200 power supplies are similar. This figure uses the PSR1200B-12A as an example. |
LEDs
Table2-545 PSR1200B-12A/LSUM1AC1200 LED description
LED mark |
Status |
AC |
Steady green |
The power supply is operating correctly. |
Off |
No power input. |
The input voltage is too low and the power supply has entered self-protection state. |
DC |
Steady green |
Power output of the power supply is normal. |
Steady red |
Power output of the power supply is abnormal. The power supply has an output short circuit, output overcurrent, output overvoltage, input undervoltage, or remote shutdown alarm and has entered self-protection state. |
Steady amber |
An overtemperature alarm is present. |
Table2-546 Technical specifications
Item |
41 × 102 × 410 mm (1.61 × 4.02 × 16.14 in) |
Weight |
2.27 kg (5.00 lb) |
Inputs |
1 |
Rated input voltage range |
100 VAC to 240 VAC @ 50 Hz or 60 Hz |
Input voltage range |
90 VAC to 290 VAC |
Maximum input current |
16 A |
Rated output voltage |
12 VDC |
Rated output current |
100 A |
Rated output power |
1200 W |
Front-level circuit breaker/fuse |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cable |
Standard C19 cable (3*1.5mm²) |
PSR1200B-12A1-F
View
Figure2-154 PSR1200B-12A1-F power supply view
(1) Captive screw |
LEDs
Table2-547 PSR1200B-12A1-F LED description
LED mark |
Status |
AC |
Steady green |
Off |
No power input. |
DC |
Steady green |
Normal power output. |
Steady red |
Steady amber |
Table2-548 Technical specifications
Item |
Weight |
2.27 kg (5.00 lb) |
Inputs |
1 |
· 200 VAC to 240 VAC @ 50 Hz or 60 Hz · 240 VDC |
· 180 VAC to 264 VAC · 192 VDC to 320 VDC |
10 A |
12 VDC |
100 A |
1200 W |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cable |
Standard C13 cable (3*1.0mm²) |
PSR2500-12A/LSUM1AC2500
View
Figure2-155 PSR2500-12A view
(1) Captive screw |
NOTE: The views of the PSR2500-12A and LSUM1AC2500 power supplies are similar. This figure uses the PSR2500-12A as an example. |
LEDs
Table2-549 PSR2500-12A/LSUM1AC2500 LED description
LED mark |
Status |
AC |
Steady green |
Off |
No power input. |
DC |
Steady green |
Steady red |
Steady amber |
Table2-550 Technical specifications
Item |
Weight |
2.50 kg (5.51 lb) |
Inputs |
1 |
· 100 VAC to 240 VAC @ 50 Hz or 60 Hz · 240 VDC |
· 90 VAC to 264 VAC · 190 VDC to 290 VDC |
16 A |
12 VDC |
· 100 A (100 VAC to 180 VAC input) · 208 A (180 VAC to 240 VAC or 240 VDC input) |
· 1200 W (100 VAC to 180 VAC input) · 2500 W (180 VAC to 240 VAC or 240 VDC input) |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cable |
PSR2400-12D/LSUM1DC2400
View
Figure2-156 PSR2400-12D view
(1) Captive screw |
(3) Power input status LED |
(4) Power output status LED |
(5) DC input negative terminal (–) |
(6) DC input positive terminal (+) |
NOTE: The views of the PSR2400-12D and LSUM1DC2400 power supplies are similar. This figure uses the PSR2400-12D as an example. |
LEDs
Table2-551 PSR2400-12D/LSUM1DC2400 LED description
LED mark |
Status |
INP OK |
Steady green |
Off |
No power input. |
DC/FLT |
Steady green |
Steady red |
Steady amber |
Table2-552 Technical specifications
Item |
Weight |
2.40 kg (5.29 lb) |
Inputs |
1 |
–48 VDC to –60 VDC |
–36 VDC to –72 VDC |
78 A |
12 VDC |
200 A |
2400 W |
≥ 100 A |
Heat dissipation |
Built-in fans |
Power cable |
PWC01 2P cable |
PSR2400-D
View
Figure2-157 PSR2400-D view
(1) Captive screw |
LEDs
Table2-553 PSR2400-D LED description
LED mark |
Status |
INP OK |
Steady green |
Off |
No power input. |
DC/FLT |
Steady green |
Steady red |
Steady amber |
Table2-554 Technical specifications
Item |
Weight |
2.40 kg (5.29 lb) |
Inputs |
1 |
78 A |
12 VDC |
200 A |
2400 W |
≥ 100 A |
Heat dissipation |
Built-in fans |
Power cable |
ST M5 cable |
PSR2500B-12AHD-F
View
Figure2-158 PSR2500B-12AHD-F view
(1) Captive screw |
(5) Power input status LED |
(6) Air inlet vent |
LEDs
Table2-555 PSR2500B-12AHD-F LED description
LED mark |
Status |
IN |
Steady green |
Off |
No power input. |
OUT |
Steady green |
Steady red |
Steady amber |
Table2-556 Technical specifications
Item |
Weight |
2.75 kg (6.06 lb) |
Inputs |
1 |
· 100 VAC to 240 VAC @ 50 Hz or 60 Hz · 240 VDC to 380 VDC |
· 90 VAC to 290 VAC · 180 VDC to 400 VDC |
16 A |
12 VDC |
· 100 A (100 VAC to 180 VAC input) · 208 A (180 VAC to 240 VAC or 240 VDC to 380 VDC input) |
· 1200 W (100 VAC to 180 VAC input) · 2500 W (180 VAC to 240 VAC or 240 VDC to 380 VDC input) |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cable |
Standard HVDCB cable (3*1.5mm²) |
PSR2200-12D-F
View
Figure2-159 PSR2200-12D-F power supply view
(1) Captive screw |
(5) DC input positive terminal (+) |
(6) DC input negative terminal (–) |
(7) Air inlet vent |
LEDs
Table2-557 PSR2200-12D-F LED description
LED mark |
Status |
INP OK |
Steady green |
The power supply system is operating correctly. |
Off |
No power input. |
DC/FLT |
Steady green |
Power output of the power supply system is normal. |
Steady red |
Power output of the power supply system is abnormal. The power supply has an output short circuit, output overcurrent, output overvoltage, input undervoltage, or remote shutdown alarm and has entered self-protection state. |
Steady amber |
An overtemperature alarm was triggered. |
Table2-558 Technical specifications
Item |
Weight |
1.78 kg (3.92 lb) |
Inputs |
1 |
–38.4 VDC to –72 VDC |
70 A |
12 VDC |
184 A |
2200 W |
≥ 100 A |
Heat dissipation |
Built-in fans |
Power cable |
ST M5 cable |
PSR2400-12A-F
View
Figure2-160 PSR2400-12A-F power supply view
(1) Captive screw |
LEDs
Table2-559 PSR2400-12A-F LED description
LED mark |
Status |
AC |
Steady green |
Off |
No power input. |
DC |
Steady green |
Steady red |
Steady amber |
Table2-560 Technical specifications
Item |
Weight |
2.20 kg (4.85 lb) |
Inputs |
1 |
· 90 VAC to 290 VAC · 180 VDC to 320 VDC |
16 A |
12 VDC |
· 100 A (100 VAC to 175 VAC input) · 200 A (175 VAC to 240 VAC or 240 VDC input) |
· 1200 W (100 VAC to 175 VAC input) · 2400 W (175 VAC to 240 VAC or 240 VDC input) |
≥ 32 A |
Heat dissipation |
Built-in fans |
Power cable |
PSR2400-12AHD-F
View
Figure2-161 PSR2400-12AHD-F power supply view
(1) Captive screw |
LEDs
Table2-561 PSR2400-12AHD-F LED description
LED mark |
Status |
IN |
Steady green |
Off |
No power input. |
OUT |
Steady green |
Steady red |
Steady amber |
Table2-562 Technical specifications
Item |
Weight |
2.20 kg (4.85 lb) |
Inputs |
1 |
· 90 VAC to 290 VAC · 180 VDC to 410 VDC |
16 A |
12 VDC |
· 100 A (100 VAC to 175 VAC input) · 200 A (175 VAC to 240 VAC or 240 VDC to 380 VDC input) |
· 1200 W (100 VAC to 175 VAC input) · 2400 W (175 VAC to 240 VAC or 240 VDC to 380 VDC input) |
≥ 32 A |
Heat dissipation |
Built-in fans |
Power cable |
As a best practice, make sure the rated current of a single circuit breaker is not less than 1.2 times the maximum input current of the power supply.
You can select a certain number of power supplies according to the power supply conditions at the installation site and actual power consumption of your router. Make sure the total maximum output power of the installed power supplies is greater than the system power consumption. As a best practice, reserve 20% of the maximum output power.
Do not install power supplies of different models on the same router.
When the temperature of a power supply exceeds the upper limit or drops below the lower limit, the power supply shuts down automatically. When the temperature returns into the normal range, the power supply starts up automatically.
Table2-563 Compatibility matrix between power supplies and routers
Power supply model |
SR8804-X |
SR8808-X (one fan tray)/SR8808-X (dual fan trays) |
SR8808H-X |
SR8812-X |
SR8816-X |
LSUM1AC1200 |
PSR1200B-12A |
PSR1200B-12A1-F |
LSUM1AC2500 |
PSR2500-12A |
LSUM1DC2400 |
PSR2400-12D |
PSR2400-D |
PSR2500B-12AHD-F |
PSR2200-12D-F |
PSR2400-12A-F |
PSR2400-12AHD-F |
NOTE: · "●" indicates that the power supply is compatible with the chassis. · "—" indicates that the power supply is not compatible with the chassis. |
Fan trays
The router came with fan trays installed. To replace a fan tray, make sure the new fan tray is compatible with the router.
SR8804-X fan tray
View
Figure2-162 SR8804-X fan tray view
(1) Captive screw |
(2) Status LED |
(3) Fan tray handle |
(4) Fan tray handle pivot |
(5) Fan |
LEDs
Table2-564 Fan tray LED description
LED status |
OK |
FAIL |
Steady on |
Off |
The fan tray is operating correctly. |
Off |
Steady on |
The fan tray is faulty. |
Off |
Off |
The fan tray has not been powered on. |
Table2-565 Technical specifications
Item |
106 × 255 × 643 mm (4.17 × 10.04 × 25.32 in) |
Weight |
4.70 kg (10.36 lb) |
240 W |
190 W |
12 W |
Number of fans |
8 |
Fan diameter |
92 mm (3.62 in) |
Max fan speed |
6000 RPM |
Maximum air flow rate |
960 CFM (27.18 m3/min) |
SR8808-X (one fan tray) fan tray
View
Figure2-163 SR8808-X (one fan tray) fan tray view
(1) Fan |
(2) Status LED |
(3) Captive screw |
(4) Fan tray handle |
(5) Fan tray handle pivot |
LEDs
Table2-566 Fan tray LED description
LED status |
OK |
FAIL |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-567 Technical specifications
Item |
80 × 440 × 654 mm (3.15 × 17.32 × 25.75 in) |
Weight |
8.30 kg (18.30 lb) |
300 W |
260 W |
13 W |
Number of fans |
12 |
Fan diameter |
120 mm (4.72 in) |
Max fan speed |
5200 RPM |
1152 CFM (32.62 m3/min) |
SR8808-X (dual fan trays) fan tray
View
Figure2-164 SR8808-X (dual fan trays) fan tray view
(1) Fan |
(2) Status LED |
(3) Captive screw |
LEDs
Table2-568 Fan tray LED description
LED status |
OK |
FAIL |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
The SR8808-X (dual fan trays) has two fan trays, which are the same in technical specifications. Table2-569 describes the specifications for a single SR8808-X (dual fan trays) fan tray.
Table2-569 Single SR8808-X (dual fan trays) fan tray specifications
Item |
49 × 440 × 654 mm (1.93 × 17.32 × 25.75 in) |
Weight |
7.40 kg (16.31 lb) |
320 W |
63 W |
18 W |
Number of fans |
12 |
Fan diameter |
120 mm (4.72 in) |
Max fan speed |
5200 RPM |
SR8808H-X/SR8816-X fan tray
View
Figure2-165 SR8808H-X fan tray view
(1) Captive screw |
(2) Status LED |
(4) Fan |
NOTE: The views of the SR8808H-X fan tray and SR8816-X fan tray are similar. This figure uses the SR8808H-X fan tray as an example. |
LEDs
Table2-570 Fan tray LED description
LED mark |
Status |
RUN |
Steady green |
Steady red |
· The fan tray is faulty. · The fan tray is installed incorrectly. |
Off |
The SR8808H-X router has eight fan trays, and the SR8816-X router has fifteen fan trays, which are the same in technical specifications. Table2-571 describes the technical specifications of a single SR8808H-X router fan tray.
Table2-571 Single SR8808H-X router fan tray technical specifications
Item |
191 × 81 × 159 mm (7.52 × 3.19 × 6.26 in) |
Weight |
1.35 kg (2.98 lb) |
143 W |
114 W |
18 W |
Number of fans |
2 |
Fan diameter |
80 mm (3.15 in) |
Max fan speed |
12800 RPM |
350 CFM (9.91 m3/min) |
SR8812-X fan tray
View
Figure2-166 SR8812-X fan tray view
(1) Captive screw |
(2) Status LED |
(5) Fan |
LEDs
Table2-572 Fan tray LED description
LED status |
OK |
FAIL |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-573 Technical specifications
Item |
Dimensions (H × W × D) |
84 × 301 × 646 mm (3.31 × 11.85 × 25.43 in) |
Weight |
· Upper fan tray: 4.49 kg (9.90 lb) · Lower fan tray: 3.61 kg (7.96 lb) |
Maximum power consumption |
· Upper fan tray: 190 W · Lower fan tray: 110 W |
· Upper fan tray: 160 W · Lower fan tray: 100 W |
Minimum power consumption |
· Upper fan tray: 9 W · Lower fan tray: 7 W |
Number of fans |
· Upper fan tray: 8 · Lower fan tray: 4 |
Fan diameter |
120 mm (4.72 in) |
Max fan speed |
5200 RPM |
· Upper fan tray: 1040 CFM (29.45 m3/min) · Lower fan tray: 720 CFM (20.39 m3/min) |
Air filters
CAUTION: Clean air filters periodically (once or more times every three months) to guarantee adequate ventilation and to avoid overtemperature. |
To prevent dusts from entering the chassis, you can configure air filters for the router as needed and install them at the air intakes.
H3C SR8800-X air filters include the SR8804-X air filter, SR8808-X air filter, and SR8812-X air filter. Order air filters compatible with your router.
Slide rails
Before rack-mounting the router, install slide rails on the rack.
LSXM1BSR
Figure2-167 LSXM1BSR view
(1) Positioning tongue |
(2) Slide rail installation hole |
(3) Front plate installation hole |
(4) Sign |
(5) Guide rail |
Figure2-168 Front plate
(1) Installation hole |
Table2-574 Technical specifications
Item |
Maximum loading capacity |
650 kg (1432.98 lb) |
Adjustment range |
630 to 900 mm (24.80 to 35.43 in) |
Occupied rack space |
1 RU |
LSTM1KSGD0
Figure2-169 LSTM1KSGD0 view
(2) Sign |
(3) Guide rail |
Table2-575 Technical specifications
Item |
280 kg (617.28 lb) |
Adjustment range |
300 to 500 mm (11.81 to 19.69 in) |
2 RU |
LSTM2KSGD0
Figure2-170 LSTM2KSGD0 view
(2) Sign |
(3) Guide rail |
Table2-576 Technical specifications
Item |
400 kg (881.83 lb) |
Adjustment range |
500 to 800 mm (19.69 to 31.50 in) |
2 RU |
Select slide rails for the router based on the chassis weight.
To rack-mount an SR8816-X router, reserve a 2 RU space between the router (including slide rails) and the rack bottom.
Table2-577 Chassis weights and applicable slide rails
Model |
Chassis weight (fully configured) |
Applicable slide rails |
SR8804-X |
76 kg (167.55 lb) |
LSXM1BSR LSTM1KSGD0 LSTM2KSGD0 |
SR8808-X (one fan tray) |
120 kg (264.55 lb) |
170 kg (374.78 lb) |
SR8808H-X |
245 kg (540.12 lb) |
SR8812-X |
174 kg (383.60 lb) |
SR8816-X |
440 kg (970.02 lb) |
LSXM1BSR LSTM2KSGD0 |
DC power cords
DC power cords are used for connecting the DC power supplies of an SR8800-X router to the external DC power supply system.
Table2-578 DC power cord specifications
DC power cord |
Cable length |
0404A0E1 |
3 m (9.84 ft) |
Used for connecting the LSUM1DC2400/PSR2400-12D power supply |
0404A0H8 |
3 m (9.84 ft) |
0404A0E2 |
15 m (49.21 ft) |
0404A0H9 |
15 m (49.21 ft) |
0404A1BE |
20 m (65.62 ft) |
0404A1BF |
20 m (65.62 ft) |
0404A0J5 |
30 m (98.43 ft) |
0404A1BD |
40 m (131.23 ft) |
0404A1M7 |
10 m (32.81 ft) |
Used for connecting the PSR2400-D power supply |
0404A1M6 |
15 m (49.21 ft) |
0404A1M5 |
20 m (65.62 ft) |
0404A1MD |
30 m (98.43 ft) |
AC power cords
AC power cords are used for connecting the AC power supplies of an SR8800-X router to the external AC power supply system.
To select an AC power cord for an AC power supply, consider the following items:
· Power capacity of the power supply.
· Current-carrying capacity of the power cord.
· Region-and country-specific plug type.
The AC power supplies available for the router require a 16A or 10A AC power cord. Table2-579 and Table2-580 describe the region-and country-specific plug types for 10A and 16A AC power cords, respectively.
Table2-579 10A AC power cords used in different countries or regions
1 |
Plug type |
Code (Length) |
Countries or regions where the type of power cords conforms to local safety regulations and can be used legally |
Other countries or regions using this type of power cords |
Countries or regions seldom using this type of power cords |
I type |
04041104: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Power cord outline |
Connector outline |
2 |
Plug type |
Code (Length) |
B type |
04020728: 3 m (9.8 ft) |
Canada and U.S.A |
Mexico, Argentina, Brazil, Columbia, Venezuela, Thailand, Peru, Philippine, and A6 countries or regions |
N/A |
Plug outline |
Connector outline |
3 |
Plug type |
Code (Length) |
F type |
04041056: 3 m (9.8 ft) |
Holland, Denmark, Sweden, Finland, Norway, Germany, France, Austria, Belgium, and Italy |
Indonesia, Türkiye, Russia, and CIS |
N/A |
Plug outline |
Connector outline |
4 |
Plug type |
Code (Length) |
G type |
04040890: 3 m (9.8 ft) |
United Kingdom |
Malaysia, Hong Kong, and Egypt |
N/A |
Connector outline |
Connector outline |
5 |
Plug type |
Code (Length) |
B type |
04040887: 3 m (9.8 ft) |
Japan |
N/A |
N/A |
Plug outline |
Connector outline |
6 |
Plug type |
Code (Length) |
I type |
04040888: 3 m (9.8 ft) |
Australia |
N/A |
N/A |
Plug outline |
Connector outline |
7 |
Plug type |
Code (Length) |
J type |
04041119: 3 m (9.8 ft) |
Switzerland |
N/A |
N/A |
Plug outline |
Connector outline |
8 |
Plug type |
Code (Length) |
L type |
04041120: 3 m (9.8 ft) |
Italy |
N/A |
N/A |
Plug outline |
Connector outline |
9 |
Plug type |
Code (Length) |
D type |
0404A0Q0: 3 m (9.8 ft) |
India |
N/A |
N/A |
Plug outline |
Connector outline |
Table2-580 16A AC power cords used in different countries or regions
1 |
Plug type |
Code (Length) |
I type |
04043396: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
2 |
Plug type |
Code (Length) |
C20 type |
0404A0C2: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
3 |
Plug type |
Code (Length) |
B type |
0404A063: 3 m (9.8 ft) |
Canada and U.S.A |
N/A |
Plug outline |
Connector outline |
4 |
Plug type |
Code (Length) |
F type |
0404A061: 3 m (9.8 ft) |
N/A |
Plug outline |
Connector outline |
5 |
Plug type |
Code (Length) |
B type |
0404A062: 3 m (9.8 ft) |
Japan |
N/A |
N/A |
Connector outline |
Connector outline |
6 |
Plug type |
Code (Length) |
I type |
0404A01A: 3 m (9.8 ft) |
Australia |
N/A |
N/A |
Plug outline |
Connector outline |
7 |
Plug type |
Code (Length) |
I type |
0404A0RQ: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
