H3C SR8800-X Router Series Hardware Information and Specifications-5W102
HomeSupportRoutersSR8800-X SeriesProduct LiteratureHardware Information & SpecificationsH3C SR8800-X Router Series Hardware Information and Specifications-5W102
01-About the router
01-About the router 582.17 KB
1 About the router
Chassis views
H3C SR8800-X routers include the following models:
·     SR8804-X
·     SR8808-X (one fan tray)
·     SR8808-X (two fan trays)
·     SR8808H-X
·     SR8812-X
·     SR8816-X
·     The chassis views in this section are for illustration only.
·     The available chassis models and accessories vary by country and region. This document describes only the preceding models. For the chassis models and accessories available in your country or region, contact the local H3C marketing personnel.
Figure1-1 SR8804-X front and rear views
(1) MPUs (slots 0 and 1)
(2) Service modules (slots 2 to 5)
(3) Power supplies
(4) Fan tray
(5) Switching fabric modules (slots 6 to 9)
Figure1-2 SR8808-X (one fan tray) front and rear views
(1) Service modules (slots 0 to 3 and slots 6 to 9)
(2) MPUs (slots 4 and 5)
(3) Power supplies
(4) Fan tray
(5) Switching fabric modules (slots 10 to 13)
Figure1-3 SR8808-X (two fan trays) front and rear views
(3) Power supplies
(4) Fan trays
Figure1-4 SR8808H-X front and rear views
(2) Service modules (slots 2 to 9)
(3) Power supplies
(4) Power switches
(5) Air duct
(6) Fan trays
(7) Switching fabric modules (slots 10 to 14) (slot 11 can be used only when five switching fabric modules are required)
Figure1-5 SR8812-X front and rear views
(1) Service modules (slots 0 to 5 and slots 8 to 13)
(2) MPUs (slots 6 and 7)
(3) Power supplies
(4) Fan trays
(5) Switching fabric modules (slots 14 to 17)
Figure1-6 SR8816-X front and rear views
(1) Service modules (slots 0 to 15)
(2) MPUs (slots 16 and 17)
(3) Power supplies
(4) Power switches
(5) Air duct
(6) Fan trays
(7) Switching fabric modules (slots 18 to 22) (slot 19 can be used only when five switching fabric modules are required)
Device slots and slot numbering
Module slot numbering
The slot numbering sequence for all models of SR8800-X follows the principle of front-to-back, top-to-bottom, and left-to-right.
Table1-1 Module slot numbering
MPU location
Model
Numbering
Upper front
SR8804-X and SR8808H-X
See Figure1-7 (SR8804-X is used as an example)
Middle upper
SR8808-X and SR8812-X
See Figure1-8 (SR8812-X is used as an example)
Lower front
SR8816-X
See Figure1-9 (SR8816-X is used as an example)
Figure1-7 Slot numbering on the SR8804-X
Figure1-8 Slot numbering on the SR8812-X
Figure1-9 Slot numbering on the SR8816-X
Interface module slot numbering and interface numbering
The slot numbering sequence for all interface modules follows the principle of top-to-bottom and left-to-right.
For example, as shown in Figure1-10, if you install MIC-GP4L interface modules on the CSPEX-1504X, white-background numbers represent interface numbers, and green-background numbers represent slot numbers. The fiber and copper ports of a combo interface are numbered in pairs.
Figure1-10 Subslot numbering and interface numbering
Power supply slot numbering
The slot numbering sequence for all models of SR8800-X follows the principle of left-to-right and top-to-bottom.
·     For example, on the SR8804-X, the power supply slots are number 0 through 3 from the left to right, as shown by the white-background numbers in Figure1-7.
·     For example, on the SR8812-X, the power supply slots are number 0 through 5 from the left to right, as shown by the white-background numbers in Figure1-8.
·     For example, on the SR8816-X, the power supply slots in the first row are numbered 0 through 7 and the slots in the second row are numbered 8 through 15 from the left to right, as shown by the white-background numbers in Figure1-9.
Module slots
Table1-2 Slots for MPUs, service modules, and switching fabric modules
MPUs
Installation slots
SRPU
SR8804-X: Slot 0 and Slot1
SR8808-X (single fan tray): Slot 4 and Slot 5
SR8808-X (dual fan trays): Slot 4 and Slot 5
SR8808H-X: Slot 0 and Slot 1
SR8812-X: Slot 6 and Slot 7
SR8816-X: Slot 16 and Slot 17
Service modules
SR8804-X: Slot 2 through Slot 5
SR8808-X (single fan tray): Slot 0 through Slot 3, Slot 6 through Slot 9
SR8808-X (dual fan trays): Slot 0 through Slot 3, Slot 6 through Slot 9
SR8808H-X: Slot 2 through Slot 9
SR8812-X: Slot 0 through Slot 5, Slot 8 through Slot 13
SR8816-X: Slot 0 through Slot 15
SR8804-X: Slot 6 through Slot 9
SR8808-X (single fan tray): Slot 10 through Slot 13
SR8808-X (dual fan trays): Slot 10 through Slot 13
SR8808H-X: Slot 10 through Slot 14
SR8812-X: Slot 14 through Slot 17
SR8816-X: Slot 18 through Slot 22
Interface numbering
Interface numbering method
The SR8800-X supports varies types of interfaces, including console ports, USB console ports, GE ports, XGE ports, network management ports, and POS interfaces.
The interfaces are numbered according to the following rules:
The number of an interface is in the interface-type slot/subslot/num format, where:
·     interface-type: Represents the interface type, such as GigabitEthernet and POS.
·     slot: Represents the number of the module slot. For more information, see the green-background numbers in Figure1-7, Figure1-8, and Figure1-9.
·     subslot: Represents the number of the subslot, a slot on an SPEX, CSPEX, MPE, or SPE interface module. For more information, see the green-background numbers in Figure1-10. For an SPC, CSPC, CEPC, or OAA module, the subslot number is 0.
·     num: Specifies the interface number, the number of the interface on an SPC, CSPC, CEPC, or OAA module or on an interface module. For more information, see the white-background numbers in Figure1-10. Note that each combo interface contains one SFP fiber port and one RJ-45 copper port. The fiber port and copper port are numbered in pairs.
Note that:
·     In an IRF fabric, the number of a router is in the chassis/slot/subslot/num format, where chassis represents the member device number in the IRF fabric. For example, on a device with member number 1, interfaces on the device are numbered in the interface-type 1/slot/subslot/num format. For more information about member numbering in IRF, see H3C SR8800-X Routers Configuration Guides.
·     For different interface submodules on the same SPEX, CSPEX, MPE, or SPE module, their slot numbers are the same.
·     For different interfaces on the same interface submodule, their subslot numbers are the same.
·     The interface number for each type of interfaces starts from 1 and is consistent with the interface number on the SPC, CSPC, CEPC, or OAA module or interface sub-module.
·     The management interface number is independent of the installation slot of the MPU on the router, and the slot number, subslot number, and interface number for the management interface are all fixed to 0.
Interface numbering example
·     Two SR05SRP1L1 MPUs are installed on the SR8804-X.
The number of MPU network management interface M-GigabitEthernet is fixed to M-GigabitEthernet 0/0/0.
·     One MIC-GP4L submodule is installed in the CSPEX-1504X module in slot 3 on the router.
¡     If an MIC-GP4L interface submodule is installed in slot 1 on the CSPEX-1504X, GigabitEthernet interfaces on the submodule are numbered as follows:
-     GigabitEthernet 3/1/1
-     GigabitEthernet 3/1/2
-     GigabitEthernet 3/1/3
-     GigabitEthernet 3/1/4
¡     If an MIC-GP4L interface submodule is installed in slot 2 on the CSPEX-1504X, GigabitEthernet interfaces on the submodule are numbered as follows:
-     GigabitEthernet 3/2/1
-     GigabitEthernet 3/2/2
-     GigabitEthernet 3/2/3
-     GigabitEthernet 3/2/4
¡     If an MIC-GP4L interface submodule is installed in slot 3 on the CSPEX-1504X, GigabitEthernet interfaces on the submodule are numbered as follows:
-     GigabitEthernet 3/3/1
-     GigabitEthernet 3/3/2
-     GigabitEthernet 3/3/3
-     GigabitEthernet 3/3/4
¡     If an MIC-GP4L interface submodule is installed in slot 4 on the CSPEX-1504X, GigabitEthernet interfaces on the submodule are numbered as follows:
-     GigabitEthernet 3/4/1
-     GigabitEthernet 3/4/2
-     GigabitEthernet 3/4/3
-     GigabitEthernet 3/4/4
·     One SPC-GP48LB module is installed in slot 3 on the router.
GigabitEthernet interfaces on the SPC-GP48LB are numbered GigabitEthernet 3/0/1 through GigabitEthernet 3/0/48.
Technical specifications
Table1-3 Technical specifications (1)
Item
SR8804-X
Cabinet requirements
19 inches
19 inches
19 inches
Chassis height
8 RU
20 RU
21 RU
Physical dimensions (H × W × D)
353 × 440 × 660 mm (13.90 × 17.32 × 25.98 in)
886 × 440 × 660 mm (34.88 × 17.32 × 25.98 in)
930 × 440 × 660 mm (36.61 × 17.32 × 25.98 in)
Max. weight (fully configured)
≤ 76 kg (167.55 lb)
≤ 120 kg (264.55 lb)
≤ 170 kg (374.78 lb)
Availability
99.999%
99.999%
99.999%
Heat dissipation
Fan cooling
Fan cooling
Fan cooling
Airflow direction
Left-to-right
Front-to-back
Front-to-back
Total number of slots
15
21
22
Number of MPU slots
2
2
2
Number of service modules
4
8
8
Number of switching fabric modules
4
4
4
Number of power module slots
4
6
6
Number of fan tray slots
1
1
2
Noise level
·     Fan noise (room temperature): 62.3 dBA
·     Fan noise (full fan speed): 75.5 dBA
·     Fan noise (room temperature): 61.6 dBA
·     Fan noise (full fan speed): 72.6 dBA
·     Fan noise (room temperature): 65.7 dBA
·     Fan noise (full fan speed): 73.3 dBA
Weight
Chassis (including chassis ears, blanks, and power supply blanks) + modules + power supplies + fan trays + swappable interface modules + other swappable modules
Power consumption
Min router power consumption = Static power consumption of modules + Min fan tray power consumption
Max router power consumption = Dynamic consumption of modules + Max fan tray power consumption
Heat dissipation volume
Heat dissipation volume per hour = 0.9*Total power consumption/0.9*3.4121
Temperature
·     Operating temperature: 0°C to 45°C (32°F to 113°F)
·     Not Operating temperature: –40°C to +70°C (–40°F to +158°F)
Operating temperature change
≤ 30°C (86°F) per hour
Relative humidity
·     Operating humidity: 10% to 95% RH, non-condensing
·     Storage humidity: 5% to 95% RH, non-condensing
Altitude
≤ 5000 m (16404.20 ft)
Table1-4 Technical specifications (2)
Item
SR8808H-X
SR8812-X
SR8816-X
19 inches
19 inches
19 inches
Chassis height
21 RU
18 RU
38 RU
931 × 440 × 640 mm (36.65 × 17.32 × 25.20 in)
797 × 440 × 660 mm (31.38 × 17.32 × 25.20 in)
1687 × 440 × 640 mm (66.42 × 17.32 × 25.20 in)
≤ 245 kg (540.12 lb)
174 kg (383.60 lb)
≤ 440 kg (970.02 lb)
Availability
99.999%
99.999%
99.999%
Heat dissipation
Fan cooling
Fan cooling
Fan cooling
Airflow direction
Front-to-back
Left-to-right
Front-to-back
31
26
54
Number of RPU slots
2
2
2
8
12
16
5
4
5
8
6
16
8
2
15
Noise level
·     Fan noise (room temperature): 66.4 dBA
·     Fan noise (full fan speed): 84.0 dBA
·     Fan noise (room temperature): 66 dBA
·     Fan noise (full fan speed): 79 dBA
·     Fan noise (room temperature): 75.9 dBA
·     Fan noise (full fan speed): 91 dBA
Weight
Power consumption
Temperature
Relative humidity
Altitude
·     Rack Unit (RU) is a measurement unit used to indicate the height of a rack. 1 RU is equal to 44.45 mm (1.75 in).
·     The dimension data refers to the size value of the chassis itself and does not include the dimensions of chassis ears, cable management brackets, modules, power modules, and other installed components and accessories.
·     The heat generated by the device is closely related to its power consumption. It is generally assumed that 90% of the power consumption is converted to heat, and the power module's conversion efficiency is 90%. The unit of heat is generally measured in BTU/h, and 1 watt is equal to 3.4121 BTU/h.
·     The noise value is tested using the bystander sound pressure level test method of ISO 7779.
·     For information about the power consumption of each component, see "Appendix B  FRUs and compatibility matrixes."
