H3C MSR5680-X3 Router Hardware Information and Specifications-6W103
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Product LiteratureHardware Information & SpecificationsH3C MSR5680-X3 Router Hardware Information and Specifications-6W103
02-Removable Components
02-Removable Components 5.80 MB
2 Removable components
MSUs
MSU-100
View
Figure2-1 MSU-100 view
(1) Captive screw
(2) DIAG button
(3) USB port
(4) Management Ethernet port
(5) Reset button (RESET)
(6) Console port
(7) Ejector lever
LEDs
Figure2-2 MSU-100 LEDs
(1) Management Ethernet copper port LED
(1) System status LED (SYS)
(3) MSU active/standby status LED (ACT)
(4) Fan tray status LED (FAN)
Table2-1 LED description
LED
Status
System LED (SYS)
Flashing green (eight times per second)
The device is in BootWare stage or is collecting diagnosis information in Comware stage.
Steady green
The device is in Kernel stage, including Eshell stage.
Flashing green (once per second)
The Comware system is starting up or is operating correctly.
Flashing yellow (once per second)
Memory test failed in BootWare stage.
Flashing yellow (eight times per second)
The extended BootWare segment does not exist.
Steady yellow
The boot.bin file does not exist.
Off
No power input, or an exception has occurred.
Steady green
The MSU is in active mode.
The router is performing an active/standby MSU switchover.
Off
The MSU is in standby mode or initialization state.
Steady green
Both fan trays are operating correctly.
One fan tray is operating correctly and the other one is not present.
Steady yellow
A minimum of one fan try is faulty.
Off
Both fan trays are not present.
Steady green
A 1000 Mbps link is present on the port.
Flashing green
The port is sending or receiving data at 1000 Mbps.
Steady yellow
A 10 or 100 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 10 or 100 Mbps.
Off
No link is present on the port.
Ports
Table2-2 Port specifications
Port type
Specification
Console port
1
GE management port
1
USB port
1
DIAG button
1
Technical specifications
Table2-3 Technical specifications
Item
Specification
Net weight
1.54 kg (3.40 lb)
Dimensions (H × W × D)
42.6 × 375 × 227 mm (1.68 × 14.76 × 8.94 in)
Max power consumption
24.60 W
Memory
4 GB DDR4
Flash
4 GB
Link mode of interfaces
All interfaces can operate only as Layer 3 interfaces
MSU-200
View
Figure2-3 MSU-200 view
(1) Captive screw
(2) SIC slot
(3) DIAG button
(4) SFP+ port SFP+10
(5) SFP+ port SFP+11
(6) GE copper ports GE2 to GE9
(7) GE copper port GE1
(8) GE fiber port SFP0
(9) GE fiber port SFP1
(10) USB port
(11) Management Ethernet port
(12) Reset button (RESET)
(13) Console port
(14) Ejector lever
(15) GE copper port GE0
LEDs
Figure2-4 MSU-200 LEDs
(1) SFP+ fiber port LED
(2) GE port LED
(3) SFP fiber port LED
(4) Management Ethernet copper port LED
(5) System status LED (SYS)
(6) MSU active/standby status LED (ACT)
(7) Fan tray status LED (FAN)
Table2-4 LED description
LED
Status
System LED (SYS)
Steady green
Steady yellow
Off
Steady green
Off
Steady green
Steady yellow
Off
SFP+ fiber port LED
Steady green
A 10 Gbps link is present on the port.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
Flashing yellow
Off
SFP fiber port LED
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 100 Mbps.
Off
GE port LED/Management Ethernet copper port LED
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
Ports
Table2-5 Port specifications
Port type
Specification
Console port
1
GE management port
1
GE copper port
8
Combo interface
2 (SFP0/GE0, SFP1/GE1)
SFP+ fiber port
2
USB port
1
DIAG button
1
SIC slot
1
Table2-6 Technical specifications
Item
Specification
Net weight
1.72 kg (3.79 lb)
45.00 W
Memory
4 GB DDR4
Flash
4 GB
MSU-400-G
View
Figure2-5 MSU-400-G view
(1) Captive screw
(2) Management Ethernet port
(3) SFP+ ports SFP+8 to SFP+17
(4) GE copper ports GE0 to GE7
(5) Cloud cluster management SFP+ fiber port
(6) USB port
(7) Reset button (RESET)
(8) Locking clip
(9) Ejector lever
(10) Console port
(11) DIAG button
LEDs
Figure2-6 MSU-400-G LEDs
(2) SFP+ fiber port LED
(3) GE port LED
(4) Cloud cluster management SFP+ fiber port LED
Table2-7 LED description
LED
Status
System LED (SYS)
Steady green
Steady yellow
Off
Steady green
Off
Steady green
Steady yellow
Off
SFP+ fiber port LED
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
Ports
Table2-8 Port specifications
Port type
Specification
Console port
1
GE management port
1
GE copper port
8
SFP+ fiber port
11 (including one cloud cluster management port)
USB port
1
DIAG button
1
Table2-9 Technical specifications
Item
Specification
Net weight
2.2 kg (4.85 lb)
121.30 W
Memory
8 GB DDR4
Flash
4 GB
·     Interfaces that can operate only as Layer 3 interfaces:
¡     Management Ethernet port
¡     Cloud cluster management SFP+ fiber port
·     Interfaces that support link mode change:
¡     Ports SFP+8 to SFP+17
¡     GE copper ports GE0 to GE7
Interface modules
Weights, dimensions, and power consumptions
Table2-10 Weights, dimensions, and power consumptions
Module model
Net weight
RT-SIC-5G
0.25 kg (0.55 lb)
7.60 W
19.8 × 80 × 138 mm (0.78 × 3.15 × 5.43 in)
RT-XMIM-8GEE
0.72 kg (1.59 lb)
12.00 W
19.8 × 186 × 228 mm (0.78 × 7.32 × 8.98 in)
RT-XMIM-8GEE-R
0.65 kg (1.43 lb)
8.80 W
RT-XMIM-8GEF
0.72 kg (1.59 lb)
14.00 W
RT-XMIM-8GEF-R
0.65 kg (1.43 lb)
13.00 W
RT-XMIM-4XP
0.75 kg (1.65 lb)
20.00 W
RT-XMIM-2XPF
0.76 kg (1.68 lb)
15.00 W
RT-XMIM-1POS
0.60 kg (1.32 lb)
9.70 W
RT-XMIM-2POS
0.60 kg (1.32 lb)
10.30 W
RT-XMIM-1CPOS
0.64 kg (1.41 lb)
11 W
RT-XMIM-2E1
0.60 kg (1.32 lb)
5.00 W
RT-XMIM-4E1
0.65 kg (1.43 lb)
5.40 W
RT-XMIM-8E1
0.65 kg (1.43 lb)
6.80 W
RT-SSD-960G
0.50 kg (1.10 lb)
11.00 W
Interface modules
The device supports SIC interface modules, XMIM interface modules, and SSD modules. For more information about the views, LEDs, and specifications of the interface modules, see H3C MSR Router Series Interface Module Guide (V9).
Power supplies
The device supports AC power supplies, DC power supplies, and mix of AC and DC power supplies. The power supplies can be hot swapped and configured in redundancy. In AC or DC power supply mode, you can install only one power supply, or two or three power supplies for 1+1 or 1+2 power supply redundancy respectively. In mixed power supply mode, you can install two power supplies, or three power supplies for 2+1 power supply redundancy.
The device supports only mix of 450 W AC and DC power supplies.
PSR250-12A
View
Figure2-7 PSR250-12A power supply view
(1) Latch
(2) Handle
(3) Power receptacle
LEDs
Figure2-8 PSR250-12A AC power supply LEDs
(1) Status LED
Table2-11 LED description
LED
Status
Status LED
Steady green
The power supply is operating correctly.
Flashing green
The power supply has normal power input but has not been turned on.
Steady red
The power supply is faulty or has entered protection state.
Alternating between red and green
An alarm is present on the power supply.
Flashing red
This power supply does not have power input but the other power supply has power input.
Off
No power is present.
Table2-12 Technical specifications
Item
Specification
Net weight
0.64 kg (1.41 lb)
40 × 51 × 221 mm (1.57 × 2.01 × 8.70 in)
Rated input voltage
·     100 to 240 VAC @ 50 or 60 Hz
·     240 VDC
Input voltage range
·     90 VAC to 290 VAC @ 50 or 60Hz
·     180 VDC to 320 VDC
Max input current
·     4 A (AC input)
·     2 A (DC input)
Max power
250 W
PSR450-12A
View
Figure2-9 PSR450-12A power supply view
(1) Latch
(2) Handle
LEDs
Figure2-10 PSR450-12A AC power supply LEDs
(1) Status LED
Table2-13 LED description
LED
Status
Status LED
Steady green
Flashing green
Steady red
Flashing red
Off
Table2-14 Technical specifications
Item
Specification
Net weight
0.65 kg (1.43 lb)
Rated input voltage
·     240 VDC
Input voltage range
Max input current
·     6 A (AC input)
·     3 A (DC input)
Max power
450 W
PSR450-12A2-F
View
Figure2-11 PSR450-12A2-F power supply view
(1) Latch
(2) Handle
LEDs
Figure2-12 PSR450-12A2-F AC power supply LEDs
(1) Status LED
Table2-15 LED description
LED
Status
Status LED
Steady green
Flashing green
Steady red
An alarm has occurred when one of the following conditions exists on the power supply but the power supply does not enter protection state:
·     Output overcurrent.
·     Output power overload.
·     Overtemperature.
Flashing red
·     The power supply does not have power input. If two power supplies are installed and only one power supply has power input, the status LED of the power supply that does not have power input flashes red.
·     The power supply is in input undervoltage protection state.
Off
Table2-16 Technical specifications
Item
Specification
Net weight
0.66 kg (1.46 lb)
Rated input voltage
·     240 VDC
Input voltage range
Max input current
·     6 A (AC input)
·     3 A (DC input)
Max power
450 W
PSR450-12D-F
View
Figure2-13 PSR450-12D-F power supply view
(1) Latch
(2) Handle
LEDs
Figure2-14 PSR450-12D-F DC power supply LEDs
(1) Status LED
Table2-17 LED description
LED
Status
Status LED
Steady green
Flashing green
Steady red
Flashing red
Off
Table2-18 Technical specifications
Item
Specification
Net weight
0.68 kg (1.50 lb)
Rated input voltage
–48 VDC to –60 VDC
Input voltage range
–36 VDC to –72 VDC
Max input current
12 A to 10 A
Max power
450 W
PSR450-12D1-F
View
Figure2-15 PSR450-12D1-F power supply view
(1) Latch
(2) Handle
LEDs
Figure2-16 PSR450-12D1-F DC power supply LEDs
(1) Status LED
Table2-19 LED description
LED
Status
Status LED
Steady green
Flashing green
Steady red
·     Overtemperature.
Flashing red
Off
Table2-20 Technical specifications
Item
Specification
Net weight
0.64 kg (1.41 lb)
Rated input voltage
–48 VDC to –60 VDC
Input voltage range
–36 VDC to –72 VDC
Max input current
12 A to 10 A
Max power
450 W
Fan trays
FAN-80B-2-C
View
Figure2-17 FAN-80B-2-C fan tray view
(1) Handle
LEDs
Figure2-18 FAN-80B-2-C fan tray LEDs
(1) Status LED
Table2-21 LED description
LED
LED status
RUN
Steady green
The fan tray is operating correctly.
Steady yellow
The fan tray is faulty.
Off
The fan tray is not present or has no power input.
Table2-22 Technical specifications
Item
Specification
Net weight
1.06 kg (2.34 lb)
171 × 136 × 93 mm (6.73 × 5.35 × 3.66 in)
55 W
Number of fans
2
Automatic speed adjustment
Supported
Anti-misinsertion
Supported
Hot swapping
Supported
