02-Product introduction
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10202-Product introduction
03-H3C PoE Adapter Introduction
03-H3C PoE Adapter Introduction 106.24 KB
New H3C Technologies Co., Ltd.
http://www.h3c.com
Document version: 6W100-20220630
H3C PoE adapter Introduction· 1
ADP060-55V-PoE-GL· 1
About the ADP060-55V-PoE-GL PoE adapter 1
Technical specifications· 2
Connecting the PoE adapter 2
CAUTION
CAUTION:
The available H3C PoE adapter models vary by country and region. This document is for generic reference only. To avoid damages, contact the local H3C sales agent or engineers when using an H3C PoE adapter.
This document provides the specifications and views for H3C PoE adapters.
ADP060-55V-PoE-GL
The ADP060-55V-PoE-GL (part number: 9801A1PJ) is a two-port PoE adapter. It delivers optimum performance over a wide range of temperatures and can be used indoors and outdoors (because it is not waterproof, waterproof measures must be taken for outdoor use). You can use it to provide PoE power to a network endpoint over a Category 5e cable on a 10/100/1000M network.
IMPORTANT
IMPORTANT:
As a best practice, do not connect it to two APs simultaneously.
Figure 1 ADP060-55V-PoE-GL PoE adapter views
(1) PoE ports
(2) 10/100/1000M Ethernet ports
(13) AC power input receptacle
Table 1 ADP060-55V-PoE-GL PoE adapter ports description
Port type
Compliant standards and protocols
PoE1/PoE2
N/A
Signal & power output port, used for connecting a PD such as AP.
LAN1/LAN2
·     IEEE802.3
·     IEEE802.3u
Signal input port, used for connecting an Ethernet switch.
N/A
Used for connecting the local power source.
Table 2 ADP060-55V-PoE-GL power adapter technical specifications
Item
Specification
Dimensions (H × W × D)
46 × 208 × 85 mm (1.81 × 8.19 × 3.35 in)
Weight
0.437 kg (0.96 lb)
Rated input voltage
100 VAC to 240 VAC @ 50/60 Hz
Max input current
1.5 A (115 VAC, fully loaded)
0.75 A (230 VAC, fully loaded)
Rated output voltage
55 VDC
Rated output current
1.1 A
Total output power
60 W
Temperature
Operating: –30°C to +55°C (–22°F to +131°F)
Storage: –30°C to +70°C (–22°F to +158°F)
Ambient humidity
Operating: 5% RH to 95% RH, noncondensing
Storage: 10% RH to 90% RH, noncondensing
Security compliance
CE/CCC/UL
AC power cord
Removable, C14 connector
Whether the power cord is provided with the PoE adapter varies by region.
The signal input port works in conjunction with the signal & power output port numbered the same. LAN 1 must work in conjunction with PoE 1 and LAN 2 must work in conjunction with PoE 2.
To connect a signal & power output port to an AP, make sure you connect the signal input port numbered the same with the signal & power output port to the Ethernet switch.
Figure 2 Connecting the ADP060-55V-PoE-GL PoE adapter
