02-Product introduction
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10202-Product introduction
01-H3C Access Controllers Introduction
01-H3C Access Controllers Introduction 133.99 KB
New H3C Technologies Co., Ltd.
http://www.h3c.com
Document version: 6W102-20251204
WX5800H Series Access Controllers
Item
WX5860H
Operating system
Comware 7
Interfaces
·     One Console port, 9600 bps (default) to 115200 bps
·     8 × 1000BASE-T autosensing Ethernet ports
·     12 × 10GBASE-R SFP+ ports
·     4 × 40GBase-R QSFP+ ports
Supported APs by default
0
Maximum number of supported APs
6144
Supported AP license BOM codes
·     3132A09W (1 AP)
·     3130A1L9 (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
·     3130A1LD (128 APs)
·     3130A1QM (512 APs)
·     3130A1LE (1024 APs)
Maximum number of wireless users
61440
Maximum number of local users that can be configured
61440
IRF
Supported
WX5800X Series Access Controllers
Item
WX5860X
Operating system
Comware 7
Interfaces
·     1 × console port
·     3 × USB ports
·      OOBM port
Support a maximum of two interface cards. An interface card provides:
·     2 × 40G QSFP+ ports
·     8 × 10G SFP+ ports
·     8 × GE combo interfaces
(The 2 × 40G QSFP+ ports and 8 × 10G SFP+ ports are mutually exclusive.)
0
·     One interface card: 6656
·     Two interface cards: 10240 (R5472:8192->10240)
·     3130A1L9(1 AP)
·     3132A09W (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
102400
102400
IRF
Supported
WX3800H Series Access Controllers
Item
WX3820H
WX3840H
Operating system
Comware 7
Comware 7
Interfaces
·     8 × 100/1000 BASE-T autosensing Ethernet copper ports
·     8 × 100BASE-FX/1000BASE-X SFP ports
·     2 × 10GBASE-R SFP+ ports
·     8 × 100/1000BASE-T autosensing Ethernet copper ports
·     1 × 100/1000BASE-T management Ethernet port
0
0
·     512 (Recommended for local forwarding)
·     256 (Recommended for centralized forwarding)
1024
·     3132A09W (1 AP)
·     3130A1L9 (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
·     3132A09W (1 AP)
·     3130A1L9 (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
8192
20480
8192
20480
IRF
Supported
Supported
WX3800X Series Access Controllers
Item
WX3820X
WX3840X
Operating system
Comware 7
Comware 7
Interfaces
Fixed:
·     8 × GE ports
·     8 × SFP ports
·     1 × OOBM port
·     2 × USB ports
Expandable:
·     8 × GE ports
·     2 × SFP+ ports
Fixed:
·     8 × GE ports
·     8 × SFP ports
·     1 × OOBM port
·     2 × USB ports
Expandable:
·     8 × GE ports
·     4 × SFP+ ports
0
0
768
1536, expandable to 2048
·     3130A1L9 (1 AP)
·     3132A09W (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
·     3130A1L9 (1 AP)
·     3132A09W (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
15360
30720
15360
30720
IRF
Not supported
Not supported
Cloud cluster
Supported (R14xx or higher)
WX2800X Series Access Controllers
Item
WX2812X-PWR
WX2860X
WX2880X
Operating system
Comware 7
Comware 7
Comware 7
Interfaces
LAN:
·     2 × SFP+ ports
·     12 × PoE+ ports
WAN:
·     2 × GE ports
·     1 × USB port
WAN:
·     2 × 2.5GE ports
LAN:
·     8 × GE ports
·     2 × SFP+ ports
·     1 × USB port
·     1 × console port
WAN:
·     2 × 2.5GE ports
LAN:
·     8 × GE ports
·     2 × SFP+ ports
·     1 × USB port
·     1 × console port
18
0
0
18
144
288
Not supported
·     3130A1L9 (1 AP)
·     3132A09W (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
·     3130A1L9 (1 AP)
·     3132A09W (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
1024
4096
8192
1024
4096
8192
IRF
Not supported
Not supported
Not supported
WX1800H Series Access Controllers
Item
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
Operating system
Comware 7
Comware 7
Comware 7
Comware 7
Interfaces
·     5 × 100/1000BASE-T autosensing Ethernet copper port, including four LAN ports and one WAN port
·     LAN ports support PoE
·     12 × 100/1000BASE-T autosensing Ethernet copper port, including four LAN ports and one WAN port
·     8 × 100/1000BASE-T autosensing Ethernet copper port, including six LAN ports and two WAN ports
·     1000BASE-X SFP ports 5 and 6 form combo interfaces with 100/1000BASE-T autosensing Ethernet copper ports LAN 5 and LAN 6, respectively.
4
10
20
20
4
10
20
·     128 (Recommended for local forwarding)
·     64 (Recommended for centralized forwarding)
Not supported
Not supported
Not supported
·     3132A09W (1 AP)
·     3130A1L9 (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
128
320
640
1280
128
320
640
1280
IRF
Not supported
Not supported
Not supported
Not supported
WBC Series Access Controllers
Item
WBC580 G2
Operating system
Comware 7
Interfaces
·     2 × embedded 1000 Mbps Ethernet ports
·     2 × 10 Gbps Ethernet fiber ports
·     1 × HDM dedicated network port
0
2048
·     3130A1L9 (1 AP)
·     3130A2HB (4 APs)
·     3130A1LA (8 APs)
·     3130A1LB (16 APs)
·     3130A1LC (32 APs)
·     3130A2HC (64 APs)
32768
32768
IRF
Supported
WSG Series Wireless Integrated Services Gateways
Item
WSG1808X-PWR
WSG1812X-PWR
WSG1840X
Operating system
Comware 7
Comware 7
Comware 7
Interfaces
WAN:
·     1 × GE ports
·     1 × GE PoE+ ports
LAN:
·     1 × SFP+ ports
·     7 × GE PoE+ ports
WAN:
·     2 × GE ports
LAN:
·     2 × SFP+ ports
·     12 × GE PoE+ ports
WAN:
·     2 × GE ports
LAN:
·     1 × SFP+ port
·     1 × 2.5GE port
·     4 × GE ports
12
32(E5622:4->32)
64(E5622:4->64)
24
64(E5622:32->64)
128
3130A5XB (1 AP)
3130A5X9 (4 APs)
3130A5XC (8 APs)
3130A5XB (1 AP)
3130A5X9 (4 APs)
3130A5XC (8 APs)
3130A5XA (16 APs)
3130A5XB (1 AP)
3130A5X9 (4 APs)
3130A5XC (8 APs)
3130A5XA (16 APs)
1024
1024
2048
1024
1024
2048
IRF
Not supported
Not supported
Not supported
VAC1000 Series Access Controllers
Item
VAC1000
Operating system
Comware 7
32 (180-day trial license)
2048
·     3130A1Q9 (8 APs, 1 year)
·     3130A1QA (8 APs, 3 years)
·     3130A1QB (8 APs, permanent)
·     3130A1QC (32 APs, 1 year)
·     3130A1QD (32 APs, 3 years)
·     3130A1QE (32 APs, permanent)
·     3130A1QG (128 APs, 1 year)
·     3130A1QH (128 APs, 3 years)
·     3130A1QF (128 APs, permanent)
102400
102400
IRF
Not supported
