- 14-Layer 3—IP Services Configuration Guide
- 01-IP addressing configuration
- 02-IP forwarding basics configuration
- 03-ARP configuration
- 04-IPv6 fast forwarding configuration
- 05-DHCPv6 configuration
- 06-Multi-CPU packet distribution configuration
- 07-Adjacency table configuration
- 08-Web caching configuration
- 09-DNS configuration
- 10-Fast forwarding configuration
- 11-DHCP configuration
- 12-IPv6 basics configuration
- 13-IP performance optimization configuration
| 10-Fast forwarding configuration | 108.41 KB |
Restrictions and guidelines: Fast forwarding configuration
Configuring the aging time for fast forwarding entries
Configuring fast forwarding load sharing
Configuring hardware fast forwarding
Enabling DSCP-based fast forwarding for GRE and VXLAN packets
Enabling the fast forwarding chip to encapsulate the incremental checksum in outgoing packets
Enabling the fast forwarding chip to do packet integrity check
Specifying the action on altered packets
Enabling single-chip hardware forwarding for upstream packets
Using the CRC hash algorithm for aggregation member port selection
Enabling traffic statistics on hardware fast forwarding
Enabling round-robin forwarding of RBM heartbeat packets on switching fabric modules
Enabling malformed packet detection
Display and maintenance commands for fast forwarding
About fast forwarding
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields: source IP address, source port number, destination IP address, destination port number, and protocol number. After a flow's first packet is forwarded through the routing table, fast forwarding creates an entry and uses the entry to forward subsequent packets of the flow.
vSystem support for features
Non-default vSystems do not support the following features:
· Hardware fast forwarding.
· Enabling/disabling fast forwarding.
For information about the support of non-default vSystems for the commands, see fast forwarding command reference. For information about vSystem, see Virtual Technologies Configuration Guide.
Fast forwarding can process fragmented IP packets, but it does not fragment IP packets.
Fast forwarding can be implemented by software or hardware. Unless otherwise noted, fast forwarding in this chapter refers to software fast forwarding.
The fast forwarding table uses an aging timer for each forwarding entry. If an entry is not updated before the timer expires, the device deletes the entry. If an entry has a hit within the aging time, the aging timer restarts.
1. Enter system view.
2. Configure the aging time for fast forwarding entries.
ip fast-forwarding aging-time aging-time
By default, the aging time is 30 seconds.
Fast forwarding load sharing enables the device to identify a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface.
2. Configure fast forwarding load sharing. Choose one option as needed:
¡ Enable fast forwarding load sharing.
ip fast-forwarding load-sharing
¡ Disable fast forwarding load sharing.
undo ip fast-forwarding load-sharing
By default, fast forwarding load sharing is enabled.
Hardware fast forwarding stores session information during fast forwarding to speed up subsequent traffic forwarding by comparing the traffic with session information.
Disable hardware fast forward when you troubleshoot problems on forwarding chips.
2. Configure hardware fast forwarding.
¡ Enable hardware fast forwarding.
hardware fast-forwarding enable [ slot slot-number ]
¡ Disable hardware fast forwarding.
undo hardware fast-forwarding enable [ slot slot-number ]
By default, hardware fast forwarding is enabled.
This feature uses the DSCP value in the outer header instead of the source port number among the identification criteria to identify GRE and VXLAN traffic flows.
2. Enable DSCP-based fast forwarding for GRE and VXLAN packets.
ip fast-forwarding dscp
By default, DSCP-based fast forwarding for GRE and VXLAN packet is disabled.
3. (Optional.) Specify the destination UDP port number for identifying VXLAN packets
ip fast-forwarding vxlan-port port-number
By default, the destination UDP port number is 4789.
2. Enable the fast forwarding chip to encapsulate the incremental checksum in outgoing packets.
hardware fast-forwarding checksum encap incremental [ slot slot-number cpu cpu-number ]
By default, the fast forwarding chip encapsulates the incremental checksum in outgoing packets.
Support for this command varies by device model. For more information, see the command reference.
2. Enable the fast forwarding chip to check the integrity of outgoing packets.
hardware fast-forwarding checksum inspect [ l3 | l4 [ tcp | udp ] ] enable [ slot slot-number cpu cpu-number ]
By default, the fast forwarding chip checks the integrity of outgoing packets to prevent packet alteration.
2. Specify the action to take on altered packets.
hardware fast-forwarding checksum inspect action { drop-err | log } [ slot slot-number cpu cpu-number ]
By default, the device forwards the altered packet and generates a log message.
This feature enables a dual-chip module to forward upstream packets by using only one of the chips. It does not apply to downstream packets. The module uses both chips to forward downstream packets.
This feature applies only to modules that have more than one hardware forwarding chip.
After you change the hardware forwarding mode for upstream packets, you must restart the module for the change to take effect.
To change the hardware forwarding mode for upstream packets in a security engine group with multiple security engines (multiple modules), perform the following tasks:
1. Execute the hardware fast-forwarding standalone or undo hardware fast-forwarding standalone command on all modules one by one to change their hardware forwarding mode for upstream packets.
2. Restart all modules.
For more information about security engine groups, see context configuration in Virtual Technologies Configuration Guide.
2. Enable single-chip hardware forwarding for upstream packets.
hardware fast-forwarding standalone [ slot slot-number [ cpu cpu-number ] ]
By default, dual-chip hardware forwarding is enabled for upstream packets.
2. Use the CRC hash algorithm to select a link aggregation member port as the output interface for outgoing traffic.
hardware fast-forwarding link-aggregation hash-mode crc
By default, the Exclusive-OR algorithm is used for aggregation member port selection.
3. (Optional.) Set the IPv6 address offset for CRC calculation to select an aggregation member port as the output interface for outgoing traffic.
hardware fast-forwarding link-aggregation hash-mode crc ip-offset offset-vlaue
By default, the IPv6 address offset used in CRC calculation is 0.
If you use the CRC hash algorithm for aggregation member port selection, you can use this command to set a calculation offset for IPv6 addresses to be calculated. CRC takes the bit where the offset-vlaue argument specifies and the following 32 bits for calculation.
With this feature enabled, you can use the display interface blade or display interface blade-aggregation commands to view statistics of all traffic forwarded through software or hardware fast forwarding on the corresponding Blade interface. With this feature disabled, you can use the commands to view only statistics of traffic forwarded by software fast forwarding.
This feature is applicable only to security service modules with hardware fast forwarding chips.
This command is only supported by the default context and not supported by non-default contexts.
2. Enable hardware fast forwarding load sharing.
hardware fast-forwarding statistics enable [ slot slot-number [ cpu cpu-number ]]
By default, hardware fast forwarding load sharing is disabled.
This feature only changes the forwarding mode of RBM heartbeat packets.
When the device is installed with multiple switching fabric modules, you can use this feature to enable those switching fabric modules to forward RBM heartbeat packets in round-robin mode.
2. Enable switching fabric modules to forward RBM heartbeat packets in round-robin mode.
hardware round-robin switch-fabric enable
By default, switching fabric modules forward RBM heartbeat packets in round-robin mode.
2. Enable malformed packet detection.
hardware fast-forwarding malpkt-filter enable [ slot slot-number cpu cpu-number ]
By default, malformed packet detection is enabled.
Task |
Command |
Display the speed statistics on hardware fast forwarding. |
display hardware fast-forwarding packet statistics [ slot slot-number cpu cpu-number ] display hardware fast-forwarding packet statistics [ chassis chassis-number slot slot-number cpu cpu-number ] |
Display the session statistics on hardware fast forwarding. |
display hardware fast-forwarding session statistics [ slot slot-number cpu cpu-number ] display hardware fast-forwarding session statistics [ chassis chassis-number slot slot-number cpu cpu-number ] |
Task |
Command |
Display the aging time of fast forwarding entries. |
display ip fast-forwarding aging-time |
Display fast forwarding entries. |
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ] |
Display fast forwarding entries about fragmented packets. |
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ] |
Clear the fast forwarding table. |
reset ip fast-forwarding cache [ slot slot-number ] |
Standalone mode:
