14-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000] Firewalls Series Configuration Guides(V7)(R9900)-6W10014-Layer 3—IP Services Configuration Guide
01-IP addressing configuration
01-IP addressing configuration 93.54 KB
Configuring IP addressing
About IP addressing
The IP addresses in this chapter refer to IPv4 addresses unless otherwise specified.
IP address representation and classes
IP addressing uses a 32-bit address to identify each host on an IPv4 network. To make addresses easier to read, they are written in dotted decimal notation, each address being four octets in length. For example, address 00001010000000010000000100000001 in binary is written as 10.1.1.1.
Each IP address breaks down into the following sections:
·     Net ID—Identifies a network. The first several bits of a net ID, known as the class field or class bits, identify the class of the IP address.
·     Host ID—Identifies a host on a network.
IP addresses are divided into five classes, as shown in Figure 1. The shaded areas represent the address class. The first three classes are most commonly used.
Figure 1 IP address classes
Table 1 IP address classes and ranges
Class
Address range
Remarks
A
0.0.0.0 to 127.255.255.255
The IP address 0.0.0.0 is used by a host at startup for temporary communication. This address is never a valid destination address.
Addresses starting with 127 are reserved for loopback test. Packets destined to these addresses are processed locally as input packets rather than sent to the link.
B
128.0.0.0 to 191.255.255.255
N/A
C
192.0.0.0 to 223.255.255.255
N/A
D
224.0.0.0 to 239.255.255.255
Multicast addresses.
E
240.0.0.0 to 255.255.255.255
Reserved for future use, except for the broadcast address 255.255.255.255.
Special IP addresses
The following IP addresses are for special use and cannot be used as host IP addresses:
·     IP address with an all-zero net ID—Identifies a host on the local network. For example, IP address 0.0.0.16 indicates the host with a host ID of 16 on the local network.
·     IP address with an all-zero host ID—Identifies a network.
·     IP address with an all-one host ID—Identifies a directed broadcast address. For example, a packet with the destination address of 192.168.1.255 will be broadcast to all the hosts on the network 192.168.1.0.
Subnetting and masking
Subnetting divides a network into smaller networks called subnets by using some bits of the host ID to create a subnet ID.
Masking identifies the boundary between the host ID and the combination of net ID and subnet ID.
Each subnet mask comprises 32 bits that correspond to the bits in an IP address. In a subnet mask, consecutive ones represent the net ID and subnet ID, and consecutive zeros represent the host ID.
Before being subnetted, Class A, B, and C networks use these default masks (also called natural masks): 255.0.0.0, 255.255.0.0, and 255.255.255.0, respectively.
Figure 2 Subnetting a Class B network
Subnetting increases the number of addresses that cannot be assigned to hosts. Therefore, using subnets means accommodating fewer hosts.
For example, a Class B network without subnetting can accommodate 1022 more hosts than the same network subnetted into 512 subnets.
·     Without subnetting—65534 (216 – 2) hosts. (The two deducted addresses are the broadcast address, which has an all-one host ID, and the network address, which has an all-zero host ID.)
·     With subnetting—Using the first nine bits of the host-id for subnetting provides 512 (29) subnets. However, only seven bits remain available for the host ID. This allows 126 (27 – 2) hosts in each subnet, a total of 64512 (512 × 126) hosts.
IP address assignment
The following are methods available for assigning an IP address to an interface:
·     Manual assignment. This chapter describes only manual IP address assignment for interfaces.
·     BOOTP. For information about BOOTP, see "Configuring the BOOTP client."
·     DHCP. For information about DHCP, see "Configuring the DHCP client."
·     PPP address negotiation. For information about PPP, see Layer 2—WAN Access Configuration Guide.
These methods are mutually exclusive. If you change the IP address assignment method, the new IP address will overwrite the previous address.
vSystem support for features
vSystem support for features vSystem supports all IP addressing features. For more information about vSystem, see Virtual Technologies Configuration Guide.
Assigning an IP address to an interface
An interface can have one primary address and multiple secondary addresses.
Typically, you need to configure a primary IP address for an interface. If the interface connects to multiple subnets, configure primary and secondary IP addresses on the interface so the subnets can communicate with each other through the interface.
You can configure floating IP addresses on RBM-based hot backup networks. The floating attribute simplifies the configuration of High Availability (HA). After you configure an floating IP address on the tenant-facing interface of the active device, the floating IP address is automatically synchronized to the standby device. You do not need to configure a Virtual Router Redundancy Protocol (VRRP) virtual address for the active device and the standby device separately. Floating IP address configuration is available only for the active device in active/standby mode. You canot configure, edit, or delete floating IP addresses on the standby devices. For more information about HA and RBM, see RBM-based hot backup configuration in High Availability Configuration Guide.
·     An interface can have only one primary IP address. If you execute the ip address command multiple times to specify different primary IP addresses, the most recent configuration takes effect.
·     You cannot assign secondary IP addresses to an interface that obtains an IP address through BOOTP, DHCP, PPP address negotiation, or IP unnumbered.
·     The primary and secondary IP addresses assigned to the interface can be located on the same network segment. Different interfaces (interface and its subinterface, different subinterfaces of an interface) on your device must reside on different network segments.
·     You can assign interfaces IP addresses that have different masks but the same network address if ANDed with the shortest mask. For example, 1.1.1.1/16 and 1.1.2.1/24 have the same network address 1.1.0.0 if ANDed with 255.255.0.0. You can assign the IP addresses to two interfaces on the device. By default, users connected to the two interfaces cannot communicate with each other. For the users to communicate, you must configure common proxy ARP on the device. For more information, see "Configuring proxy ARP."
2.     Enter interface view.
3.     Assign an IP address to the interface.
ip address ip-address { mask-length | mask } [ sub ] [ float ]
By default, no IP address is assigned to the interface.
Configuring IP unnumbered
You can configure an interface to borrow an IP address from other interfaces. This is called IP unnumbered, and the interface borrowing the IP address is called IP unnumbered interface.
You can use IP unnumbered to save IP addresses when available IP addresses are inadequate or when an interface is used only occasionally.
·     Loopback interfaces cannot borrow IP addresses of other interfaces, but other interfaces can borrow IP addresses of loopback interfaces.
·     An interface cannot borrow an IP address from an unnumbered interface.
·     Multiple interfaces can use the same unnumbered IP address.
·     If an interface has multiple manually configured IP addresses, only the manually configured primary IP address can be borrowed.
·     A dynamic routing protocol cannot be enabled on the interface where IP unnumbered is configured. To enable the interface to communicate with other devices, configure a static route to the peer device on the interface.
·     A Layer 3 Ethernet subinterface or Layer 3 aggregate subinterface cannot learn the ARP entry for the IP address it borrows. As a best practice, do not configure IP unnumbered on Layer 3 Ethernet subinterfaces or Layer 3 aggregate subinterfaces.
Assign an IP address to the interface from which you want to borrow the IP address. Alternatively, you can configure the interface to obtain one through BOOTP, DHCP, or PPP address negotiation.
Do not configure IP unnumbered on an Ethernet subinterface or a Layer-3 aggregate subinterface because they cannot learn the ARP entries for the borrowed IP address.
1.     ‍Enter system view.
3.     Specify the interface to borrow the IP address of the specified interface.
By default, the interface does not borrow IP addresses from other interfaces.
Display and maintenance commands for IP addressing
Display detailed information about the floating IP addresses.
display ip address float [ interface interface-type interface-number | vpn-instance vpn-instance-name [ ip-address ] ]  [ slot slot-number ]
Display brief IP configuration for Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ] brief [ description ]
Display IP configuration and statistics for the specified or all Layer 3 interfaces.
