01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)(R9900)-6W10001-Fundamentals Command Reference
02-License management commands
02-License management commands 91.77 KB
All commands in this chapter are supported only on the default context. Features licensed to the default context are also licensed to non-default contexts. For information about contexts, see Virtual Technologies Configuration Guide.
display license
Use display license to display detailed license information.
display license [ activation-file ] [ slot slot-number ]
context-admin
context-operator
activation-file: Displays license information about activation files.
slot slot-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices.
If you do not specify any parameters, this command displays detailed information about all licenses.
# Display detailed information about all licenses.
<Sysname> display license
Slot 1:
flash:/license/NGFirewall2017111419524513753.ak
Feature: IPS
Product Description: Trial IPS License, 30 Days
Registered at: 2017-11-14 20:07:06
License Type: Trial (date restricted)
Trial Validity Period: 2017-11-14 to 2017-12-14
Current State: Expired
Feature
Feature name.
Product Description
License description.
Registered at
Time when the license was installed.
License Type
License type by validity period:
·     NA—The system cannot obtain the license type.
·     Permanent—Purchased license that never expires and is always valid.
·     Days restricted—Purchased license that is valid for a period of days, for example, 30 days.
·     Trial (days restricted)—Free trial license that is valid for a period of days.
Time Left (days)
Remaining days of the license. This field is available for a purchased license.
Trial Time Left (days)
Remaining days of the trial period. This field is available for a trial license.
Current State
State of the license:
·     In use—The license is being used.
·     Usable—The license is available for use.
¡     If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state.
¡     A date restricted license is in this state if its start date is not reached.
·     Expired—The license has expired.
·     Uninstalled—The license has been uninstalled.
·     Unusable—The license cannot be used.
·     Invalid—The license is invalid and cannot be used.
Uninstall Key
This field is available for licenses that have been uninstalled.
Uninstall Date
Date when the activation file was uninstalled.
display license device-id
Use display license device-id to display SN and DID information.
display license device-id slot slot-number
context-admin
context-operator
When you register a license for a device, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# Display the SN and DID for the specified slot.
<Sysname> display license device-id slot 1
SN: 210235A1FXH164000026
Device ID: flash:/license/210235A1FXH164000026.did
display license feature
Use display license feature to display brief license information for features.
context-admin
context-operator
# Display brief feature license information.
<Sysname> display license feature
Slot 1:
Total: 32  Usage: 0
Feature                         Licensed        State
ACG                             N               -
AV                              N               -
IPS                             N               -
SLB                             N               -
SSLVPN                          N               -
UFLT                            N               -
Total
Total number of licenses that can be installed.
Usage
Number of licenses stored in the license storage.
Feature
Feature that must be licensed before being used.
Licensed
Licensing state of the feature:
·     N—Not licensed.
·     Y—Licensed.
License type by purchasing state:
·     Formal—Purchased license.
·     Trial—Trial license.
·     Pre-licensed—Preinstalled license.
If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license.
display license preinstalled
Use display license preinstalled to display preinstalled licenses.
The following compatibility matrix shows the support of hardware platforms for this command:
Series
Models
Command compatibility
F5000 series
F5000-AI-160-G, F5000-AI-130-G, F5000-AI-120-G, F5000-AI-110-G, F5000-AI-55-G, F5000-AI-15-G, F5000-CN160-G, F5000-E-G
No
F5000-AI160, F5000-CN160, F5000-CN-G55, F5080, F5030
Yes
F1000 series
F1000-AK9130
Yes
F1000-AI-90, F1000-AI-25, F1000-AI-90-G, F1000-AI-80-G, F1000-AI-75-G, F1000-AI-65-G, F1000-AI-55-G
Yes
context-admin
context-operator
Non-default vSystems do not support this command.
# Display preinstalled licenses.
<Sysname> display license preinstalled
Feature: The standard license of Comware 7
SubFeature: ipv6/mpls
License type: Permanent
Time remaining (days): No limit
Current state: In use
license activation-file install
Use license activation-file install to install an activation file.
license activation-file install license-file slot slot-number
context-admin
license-file: Specifies the path of an activation file, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the device.
Activation files are device locked. A licensed feature can run on the IRF member device where its activation file is installed even after the member device is moved from one IRF fabric to another IRF fabric.
# Install activation file package 20170101.tar.
[Sysname] license activation-file install flash:/license/20170101.tar
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...
Decompress......Done.
Begain to install test01.ak …Done.
Begain to install test02.ak …Done.
Begain to install test03.ak …Done.
Total Num:3
Success Num:3
Failed Num:0
# Install activation file 20170811.ak to the specified slot.
[Sysname] license activation-file install flash:/license/20170811.ak slot 1
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...Done.
display license
license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
license activation-file uninstall license-file slot slot-number
context-admin
license-file: Specifies the file path, a case-sensitive string of 1 to 127 characters.
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# Uninstall activation file flash:/license/20130811.ak from the specified slot.
[Sysname] license activation-file uninstall flash:/license/20130811.ak slot 1
Uninstall file: flash:/license/20130811.uak
display license
license compress
Use license compress to compress the license storage.
license compress slot slot-number
context-admin
The license storage is limited. You can execute this command to clear expired licenses and uninstalled licenses from the license storage.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID or DID file change. Before performing a compression, make sure all licenses registered with the old DID or DID file have been installed. You will be unable to install such licenses after the compression.
# Compress the license storage on the specified slot.
[Sysname] license compress slot 1
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
