- 01-Fundamentals Command Reference
- 01-RBAC commands
- 02-License management commands
- 03-RAID management commands (security devices)
- 04-Software upgrade commands
- 05-ISSU commands
- 06-Automatic configuration commands
- 07-Tcl commands
- 08-Python commands
- 09-Device management commands
- 10-Configuration file management commands
- 11-File system management commands
- 12-Login management commands
- 13-FTP and TFTP commands
- 14-CLI commands
| 00-Preface | 109.74 KB |
Preface
This command reference describes commands that help you get started with the device.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
