11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5130S-EI[HI][SI][EI-R]&S5120V2-SI&S3100V3-EI&E100C&E500C[D] Command References-R63xx-6W10511-Network Management and Monitoring Command Reference
14-VCF fabric commands
14-VCF fabric commands 71.01 KB
VCF fabric commands
The S5130S-SI and S5120V2-SI switch series do not support VCF fabric.
display vcf-fabric role
Use display vcf-fabric role to display the role of the device in the VCF fabric.
Use this command to display the default role and the current role of the device in the VCF fabric. To change the current role of the device, use the vcf-fabric role command.
# Display the role of the device in the VCF fabric.
<System> display vcf-fabric role
Default role: access
Current role: access
Default role
Default role of the device.
Current role
Current role of the device.
vcf-fabric role
display vcf-fabric underlay autoconfigure
Use display vcf-fabric underlay autoconfigure to display information about automated underlay network deployment.
Before you execute this command, make sure automated underlay network deployment is enabled.
# Display information about automated underlay network deployment.
<Sysname> display vcf-fabric underlay autoconfigure
success command:
          system
          clock timezone beijing add 08:00:00
          system
          lldp global enable
          system
          stp global enable
          system
          interface Vlan-interface1
          ip address dhcp-alloc
          system
          telnet server enable
          system
          ssh server enable
          system
          info-center loghost 110.0.0.111
          system
          local-user aaa
          password ******
          service-type telnet http https ssh
          system
          line vty 0 63
          authentication-mode scheme
          system
          vcf-fabric topology enable
          system
          snmp-agent
          snmp-agent community read public
          snmp-agent community write private
          snmp-agent sys-info version all
          system
          vlan 4093
          system
          vlan 4094
          system
          interface Vlan-interface4094
          system
          ntp-service enable
          ntp-service unicast-server 110.0.0.111
          system
          snmp-agent
          snmp-agent packet max-size 4096
          snmp-agent target-host trap address udp-domain 110.0.0.111 params securityname public v2c
          system
          local-user 2
          password ******
          system
          ssh server enable
          local-user 3
          password ******
          service-type ssh http https
          system
          netconf soap http enable
          netconf soap https enable
          local-user 1
          password ******
          service-type http https
IRF allocation:
        Self Bridge Mac: 00e0-fc00-510a
        IRF Status: No
        Member List: [1]
success command
Commands that have been successfully executed during automated underlay network deployment.
Uplink interface
Uplink interfaces of the device.
Downlink interface
Downlink interfaces of the device.
Aggregation configuration
Information about Layer 2 aggregation groups.
IRF allocation
IRF configurations, including IRF bridge MAC address of the IRF fabric, IRF status, and the IRF member ID of the device.
display vcf-fabric underlay template-version
Use display vcf-fabric underlay template-version to display the supported version and the current version of the template file for automated VCF fabric deployment.
The version format of a template file for automated VCF fabric deployment is x.y. Only the x part is examined during a version compatibility check. For successful automated deployment, make sure x in the version of the template file to be used is not greater than x in the supported version.
# Display the supported version and the current version of the template file for automated VCF fabric deployment when automated deployment is not started.
<Sysname> display vcf-fabric underlay template-version
Supported template version: 6.0
Current template version: Not available
# Display the supported version and the current version of the template file for automated VCF fabric deployment when automated deployment has finished.
Current template version: 6.0
Supported version of the template file for automated VCF fabric deployment.
Current version of the template file for automated VCF fabric deployment.
This field displays Not available if automated VCF fabric deployment has not started.
This field displays None if automated VCF fabric deployment has finished but the template file does not contain a version number.
Use vcf-fabric topology enable to enable VCF fabric topology discovery.
Use undo vcf-fabric topology enable to disable VCF fabric topology discovery.
VCF fabric topology discovery is disabled.
# Enable VCF fabric topology discovery.
[Sysname] vcf-fabric topology enable
Use vcf-fabric underlay autoconfigure to specify the template file for automated underlay network deployment.
Use undo vcf-fabric underlay autoconfigure to restore the default.
vcf-fabric underlay autoconfigure template
No template file is specified for automated underlay network deployment.
template: Specifies a template file by its name, a case-insensitive string of 1 to 127 characters. A template file is a file ending with the .template file extension.
After this command is executed, the device uses the specified template file to deploy the underlay network.
# Specify template file 1_access.template for automated underlay network deployment.
[Sysname] vcf-fabric underlay autoconfigure 1_access.template
vcf-fabric underlay pause
Use vcf-fabric underlay pause to pause automated underlay network deployment.
Use undo vcf-fabric underlay pause to continue automated underlay network deployment.
Automated underlay network deployment is not paused.
You can use this command to pause automated underlay network deployment if the device is in the process of automated underlay network deployment.
# Pause automated underlay network deployment.
[Sysname] vcf-fabric underlay pause
