11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5130S-EI[HI][SI][EI-R]&S5120V2-SI&S3100V3-EI&E100C&E500C[D] Command References-R63xx-6W10511-Network Management and Monitoring Command Reference
04-PoE commands
04-PoE commands 270.52 KB
PoE commands
Only the PoE models support the PoE feature.
apply poe-profile
Use apply poe-profile to apply a PoE profile to a power interface (PI).
Use undo apply poe-profile to restore the default.
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
No PoE profile is applied to PIs.
PI view
index index: Specifies a PoE profile by its index number in the range of 1 to 100.
name profile-name: Specifies a PoE profile by its name, a case-sensitive string of 1 to 15 characters.
# Apply the PoE profile named forIPphone to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] apply poe-profile name forIPphone
apply poe-profile interface
display poe-profile
Use apply poe-profile interface to apply a PoE profile to PIs.
Use undo apply poe-profile interface to remove the PoE profile application from PIs.
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
No PoE profile is applied to a PI.
interface-range: Specifies a range of Ethernet interfaces in the form of interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number must be smaller than the end interface number. If an interface in the specified range does not support PoE, it is ignored when the PoE profile is applied.
[Sysname] apply poe-profile name forIPphone interface gigabitethernet 1/0/1
# Apply the PoE profile with index number 1 to PIs GigabitEthernet 1/0/2 to GigabitEthernet 1/0/6.
[Sysname] apply poe-profile index 1 interface gigabitethernet 1/0/2 to gigabitethernet 1/0/6
apply poe-profile
display poe-profile interface
display poe device
Use display poe device to display general PSE information.
display poe device [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays general PSE information about all PSEs in the IRF fabric.
# Display general PSE information.
<Sysname> display poe device
Slot  1:
 PSE ID    Slot No.  SSlot No. PortNum   MaxPower(W)    State   Model
 4          1          0           48         600.0           Off      LSPPSE48A
PSE ID
ID of the PSE.
Slot No.
Slot number of the PSE.
SSlot No.
Sub-slot number of the PSE.
PortNum
Number of PIs on the PSE.
MaxPower(W)
Maximum power of the PSE.
PSE status:
·     On—The PSE is supplying power.
·     Off—The PSE is not supplying power.
·     Faulty—The PSE has failed.
Model
PSE model.
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for GigabitEthernet 1/0/1.
<Sysname> display poe interface gigabitethernet 1/0/1
 PoE Status                         : Enabled
 Power Priority                    : Critical
 Oper                                : On
 IEEE Class                         : 1
 Detection Status                  : Delivering power
 Power Mode                         : Signal
 Current Power                      : 11592    mW
 Average Power                      : 11610    mW
 Peak Power                          : 11684    mW
 Max Power                           : 15400    mW
 Electric Current                   : 244      mA
 Voltage                              : 51.7     V
 PD Description                      : IP Phone For Room 101
 Legacy PD Detection                : Disabled
PoE Status
PoE status:
·     Enabled.
·     Disabled.
Power Priority
Power supply priority:
·     Critical (highest).
·     High.
·     Low.
Oper
Operating status:
·     Off—PoE is disabled.
·     On—Power is being supplied to the PI correctly.
·     Power-lack—Remaining guaranteed power is insufficient for a critical PI.
·     Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power.
·     Power-itself—The PD is using another power supply.
·     Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power.
IEEE Class
PD power class by which the PI supplies power to the PD.
If the PI does not support supplying power to the PD, this field displays a hyphen (-).
Detection Status
Power detection status:
·     Disabled—The PoE function is disabled.
·     Searching—The PI is searching for the PD.
·     Delivering power—The PI is supplying power to the PD.
·     Fault—A fault occurred during the test.
·     Test—The PI is undergoing a test.
·     Other fault—A fault has caused the PSE to enter the idle status.
·     PD disconnected—The PD is disconnected.
Power Mode
Power transmission mode:
·     Signal—Power is transmitted over the signal pairs of a twisted pair cable.
·     Spare—Power is transmitted over the spare pairs of a twisted pair cable.
Current Power
Current power, including PD consumption power and transmission loss.
Average Power
Average power.
Peak Power
Peak power.
Max Power
Maximum power.
Electric Current
Current.
Voltage
Voltage.
PD Description
Type and location description for the PD connected to the PI.
# Display power supplying information for all PIs.
 Interface    PoE       Priority  CurPower  Oper    IEEE  Detection
                                     (W)                  Class Status
 GE1/0/1      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/2      Enabled   Low       0.0       Off       0     Searching
 GE1/0/3      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/4      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/5      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/6      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/7      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/8      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/9      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/10     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/11     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/12     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/13     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/14     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/15     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/16     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/17     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/18     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/19     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/20     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/21     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/22     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/23     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/24     Disabled  Low       0.0       Off       0     Disabled
   ---  On State Ports: 0; Used: 0.0(W); Remaining: 600.0(W)  ---
Interface name.
PoE
PoE status:
·     Enabled.
·     Disabled.
Priority
Power priority:
·     High.
·     Low.
CurPower
Current power of a PI.
Oper
Operating status:
IEEE Class
Detection Status
·     Disabled—PoE function is disabled.
·     Delivering Power—The PI is supplying power for the PD.
On State Ports
Number of PIs that are supplying power.
Used
Power consumed by the current PI.
Remaining
(Devices that support dynamic power allocation.) Total remaining power of all PSEs configured with a maximum power. This field displays 0 if no PSE is configured with a maximum power (all PSEs participate in dynamic power allocation).
(Devices that do not support dynamic power allocation.) Total remaining power of all PSEs.
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power information for all PIs.
# Display power information for GigabitEthernet 1/0/1.
<Sysname> display poe interface power gigabitethernet 1/0/1
Interface    Current   Peak      Max       PD Description
               (W)       (W)       (W)
 GE1/0/1        15.0      15.3      30.0      Access Point on Room 509 for Peter
# Display power information for all PIs.
              (W)       (W)       (W)
 GE1/0/1      0.0       0.0       30.0
 GE1/0/2      0.0       0.0       30.0
 GE1/0/3      0.0       0.0       30.0
 GE1/0/4      0.0       0.0       30.0
 GE1/0/5      0.0       0.0       30.0
 GE1/0/6      0.0       0.0       30.0
 GE1/0/7      0.0       0.0       30.0
 GE1/0/8      0.0       0.0       30.0
 GE1/0/9      0.0       0.0       30.0
 GE1/0/10     0.0       0.0       30.0
 GE1/0/11     0.0       0.0       30.0
 GE1/0/12     0.0       0.0       30.0
 GE1/0/13     0.0       0.0       30.0
 GE1/0/14     0.0       0.0       30.0
 GE1/0/15     0.0       0.0       30.0
 GE1/0/16     0.0       0.0       30.0
 GE1/0/17     0.0       0.0       30.0
 GE1/0/18     0.0       0.0       30.0
 GE1/0/19     0.0       0.0       30.0
 GE1/0/20     0.0       0.0       30.0
 GE1/0/21     0.0       0.0       30.0
 GE1/0/22     0.0       0.0       30.0
 GE1/0/23     0.0       0.0       30.0
 GE1/0/24     0.0       0.0       30.0
Interface name.
CurPower
Current power.
PeakPower
Peak power.
MaxPower
Maximum power.
PD Description
Type and location description for the PD connected to a PI.
Ports On
Used
Power consumed by all PIs.
Remaining
display poe pse
Use display poe pse to display detailed PSE information.
display poe pse [ pse-id ]
pse-id: Specifies a PSE by its ID. If you do not specify a PSE, this command displays detailed information about all PSEs.
# Display detailed PSE information.
<Sysname> display poe pse
 PSE ID                            : 4
 Slot No.                          : 1
 SSlot No.                         : 0
 PSE Model                         : LSPPSE48A
 PSE Status                        : Enabled
 Power Priority                   : Low
 Current Power                    : 0.0      W
 Average Power                    : 0.0      W
 Peak Power                        : 0.0      W
 Max Power                         : 600.0    W
 Max Allocable Power             : 600.0    W
 Remaining Guaranteed Power     : 600.0    W
 PSE CPLD Version                 : -
 PSE Software Version             : 172
 PSE Hardware Version             : 0
 Power Utilization Threshold    : 80
 PD Power Policy                  : Priority
 PD Disconnect-Detection Mode   : DC
Table 5 Command output
PSE ID
ID of the PSE.
SSlot No.
Subslot number of the PSE.
PSE Status
PoE status of the PSE:
·     Enabled.
·     Disabled.
PSE Fast Power Supply
PSE fast power supply enabling status:
·     Enabled.
·     Disabled.
Power Priority
Power priority of the PSE.
Current Power
Current power of the PSE.
Average Power
Average power of the PSE.
Peak Power
Peak power of the PSE.
Max Power
Max Allocable Power
Maximum allocable power of the PSE. (This field is supported only in Release 6340 and later.)
The value of this field = Maximum power of the PSE – Sum of maximum powers of all PIs with forced PoE power supply enabled.
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE.
PSE CPLD Version
PSE CPLD version number.
PSE software version number.
PSE hardware version number.
Legacy PD Detection
Nonstandard PD detection status:
·     Enabled.
·     Disabled.
PSE power alarm threshold.
PD Power Policy
PD power management policy mode.
PD disconnection detection mode.
PD High Inrush
Whether PD high inrush is enabled.
·     Enabled.
·     Disabled.
display poe pse interface
Use display poe pse interface to display the PoE status of all PIs on a PSE.
display poe pse pse-id interface
pse pse-id: Specifies a PSE ID. To display PSE ID and slot mappings, use the display poe device command.
# Display the status of all PIs on PSE 4.
<Sysname> display poe pse 4 interface
                                     (W)                  Class Status
Table 6 Command output
Interface name of a PI.
PoE
PoE status of a PI:
·     Enabled.
·     Disabled.
Priority
Priority of a PI:
·     High.
·     Low.
CurPower
Oper
Operating status of a PI:
IEEE Class
Detection Status
Power detection status of a PI:
·     Delivering Power—The PI is supplying power to the PD.
·     Other Fault—A fault has caused the PSE to enter the idle status.
·     PD Disconnected—The PD is disconnected.
On State Ports
Used
Power consumed by PIs on the PSE.
Remaining
Remaining power of the PSE. This field displays 0 for a PSE that participates in dynamic power allocation.
display poe pse interface power
Use display poe pse interface power to display power information for PIs on a PSE.
display poe pse pse-id interface power
pse pse-id: Specifies a PSE by its ID. To display PSE ID and slot mappings, use the display poe device command.
# Display power information for PIs on PSE 4.
<Sysname> display poe pse 4 interface power
              (W)       (W)       (W)
Table 7 Command output
Current
Peak
Peak power of a PI.
Max
Maximum power of a PI.
PD Description
Type and location description for the PD connected with a PI.
Ports On
Used
Remaining
display poe-profile
Use display poe-profile to display information about the PoE profile.
display poe-profile [ index index | name profile-name ]
If you do not specify a profile, the command displays information about all PoE profiles.
# Display information about all PoE profiles.
<Sysname> display poe-profile
 PoE Profile     Index   ApplyNum  Interfaces     Configuration
 forIPphone      1        4           GE1/0/1        poe enable
                                        GE1/0/2           poe priority critical
                                        GE1/0/3
                                        GE1/0/4
 forAP            2        2           GE1/0/5         poe enable
                                        GE1/0/6         poe max-power 14000
   ---  Total PoE profiles: 2, total ports: 6  ---
# Display information about the PoE profile with index number 1.
<Sysname> display poe-profile index 1
 forIPphone      1        6          GE1/0/1         poe enable
                                       GE1/0/3
                                       GE1/0/4
                                       GE1/0/5
                                       GE1/0/6
   ---  Total ports: 6  ---
Table 8 Command output
PoE Profile
Name of the PoE profile.
Index
Index number of the PoE profile.
ApplyNum
Number of PIs to which the PoE profile is applied.
Interfaces
Interface name of the PI to which the PoE configuration is applied.
Configuration
Configurations of the PoE profile.
Total PoE profiles
Number of PoE profiles.
Total ports
Number of PIs to which all PoE profiles are applied.
Use display poe-profile interface to display information about the PoE profile on a PI.
display poe-profile interface interface-type interface-number
# Display information about the PoE profile on GigabitEthernet 1/0/1.
<Sysname> display poe-profile interface gigabitethernet 1/0/1
 PoEProfile     Index   ApplyNum  Interface   Effective configuration
The Effective configuration field displays the configurations that have taken effect. For the descriptions of other fields, see Table 8.
poe ai enable
Use poe ai enable to enable AI-driven PoE.
Use undo ai poe enable to disable AI-driven PoE.
poe ai enable
undo poe ai enable
IMPORTANT
IMPORTANT:
This command is available only in Release 6318P01 and later.
AI-driven PoE is disabled.
With AI-driven PoE enabled, the device automatically recovers a PI when it fails. If more than one PI fails simultaneously, the device recovers the PIs one by one in ascending order of PI number.
AI-driven PoE automatically adjusts the power supply parameters to fit the power needs. If you disable AI-driven PoE, the system reverts the parameters to the settings before the adjustment.
AI-driven PoE takes effect only on PSEs that run firmware V147 or later.
·     Firmware earlier than V147—You must use the poe update command to upgrade the PSE firmware and then enable AI-driven PoE on the PSE.
·     Firmware V147 or later—You do not need to re-enable AI-driven PoE after upgrading the firmware if you have enabled the feature before the upgrade.
# Enable AI-driven PoE.
[Sysname] poe ai enable
poe class-detect ignore
Use poe class-detect ignore to ignore the PD power class.
Use undo poe class-detect to restore the default.
This command is supported only in Release 6351 and later.
The device supplies power to a PD based on the detected power class of the PD.
PI view
By default, before supplying power to a PD, the device detects the power class of the PD and supplies power to the PD based on the detected power class. For example, if the device detects the power class of 1 for a PD, the device can provide a maximum power of 12.95 W to the PD. If the power required by a PD is greater than 12.95 W, the device will stop supplying power to the PD.
After configuring this command, the device will continue to detect the PD power class before supplying power to a PD. As long as the power required by the PD does not exceed the maximum allowed power on the interface (configured by using the poe max power command in interface view), the device can supplies power to the PD.
If you execute the poe class-detect ignore command multiple times, and the most recent configuration will take effect.
# Configure GigabitEthernet 1/0/1 to ignore the PD power class.
[Sysname-GigabitEthernet1/0/1] poe class-detect ignore
poe detection-mode
Use poe detection-mode to configure the PD detection mode.
Use undo poe detection-mode to restore the default.
poe detection-mode { none | simple | strict }
The default differs depending on the software version, as shown below:
Versions
Default setting
Versions earlier than Release 6350
The PD detection mode is strict.
Release 6350 and later
·     If the device starts up with the initial configuration, the PD detection mode is strict.
·     If the device starts up with the factory defaults, the PD detection mode is simple.
PI view
none: Enables the device to supply power to PDs that are correctly connected to the device without causing short circuit.
simple: Enables the device to supply power to PDs that comply with basic requirements of 802.3af or 802.3at.
strict: Enables the device to supply power to PDs that comply with all requirements of 802.3af or 802.3at.
CAUTION
CAUTION:
A non-PD device might be damaged when power is supplied to it. To avoid device damage, do not specify the none keyword when the PI connects to a non-PD device.
This command is available only for a PSE that has a model name ending with a character of B, LSPPSE48B for example. To obtain the model name of a PSE, execute the display poe pse command.
To configure the detection mode for nonstandard PDs, first execute the poe legacy enable command to enable detection for nonstandard PDs.
# Configure the simple detection mode for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] poe detection-mode simple
poe legacy enable
poe disconnect
Use poe disconnect to configure a PD disconnection detection mode.
Use undo poe disconnect to restore the default.
poe disconnect { ac | dc }
undo poe disconnect
The default PD disconnection detection mode is ac.
ac: Specifies the PD disconnection detection mode as ac.
dc: Specifies the PD disconnection detection mode as dc.
If you change the PD disconnection detection mode while the device is running, the connected PDs are powered off.
# Set the PD disconnection detection mode to dc.
[Sysname] poe disconnect dc
display poe pse
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
·     S5130S-HI switch series, S5130S-EI switch series, S3100V3-EI switch series, and E500D switch series:
Versions
Default setting
Versions earlier than Release 6328
PoE is disabled on PIs.
Release 6328 and later
·     If the device starts up with the initial configuration, PoE is disabled on PIs.
·     If the device starts up with the factory defaults, PoE is enabled on PIs.
·     S5130S-SI switch series and S5120V2-SI switch series:
PoE is enabled on PIs if the device starts up with the factory defaults and is disabled on PIs when the device starts up with the initial configuration.
·     S5130S-EI-R switch series:
For more information about the device initial configuration and factory defaults, see configuration file management in Fundamentals Configuration Guide.
PI view
PoE profile view
If a PoE profile has been applied to a PI, remove the application before configuring the PI in PoE profile view.
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname-GigabitEthernet1/0/1] poe enable
# Enable PoE on a PI in PoE profile view.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
poe-profile
poe fast-on enable
Use poe fast-on enable to enable fast PoE for a PSE.
Use undo poe fast-on enable to disable fast PoE for the PSE.
poe fast-on enable pse pse-id
undo poe fast-on enable pse pse-id
IMPORTANT
IMPORTANT:
This command is supported only in Release 6328 and later.
Fast PoE is disabled on a PSE. PIs on the PSE supply power to PDs only after the PSE has started up.
Fast PoE enables a PI on a PSE to supply power to PDs immediately after the PSE is powered on.
You must re-configure this command if you modified other PoE settings after configuring this command.
# Enable fast PoE for PSE 4.
[Sysname] poe fast-on enable pse 4
display poe pse
poe force-power
Use poe force-power to enable forced PoE power supply.
Use undo poe force-power to disable forced PoE power supply.
This command is supported only in Release 6340 and later.
poe force-power
Forced PoE power supply is disabled.
PI view
CAUTION
CAUTION:
This command enables the device to supply power to a PD directly without performing a detection of the PD. To avoid damaging the PD, make sure the power provided by the device meets the PD specifications before executing this command.
Before supplying power to a PD, the device performs a detection of the PD. It supplies power to the PD only after the PD passes the detection. If the PD fails the detection but the power provided by the device meets the PD specifications, you can execute this command to enable forced power supply to the PD.
# Enable forced PoE power supply.
[Sysname-GigabitEthernet1/0/1] poe force-power
The PD might be damaged if the prowded by the device does not meet the PD power specifications. Make sure you are fully aware of the impacts of this command when you use it in a live network. Continue?[Y/N]: y
poe guard-band
Use poe guard-band to set the PoE guard band.
Use undo poe guard-band to restore the default.
poe pse pse-id guard-band power
undo poe pse pse-id guard-band
The PoE guard band is 30 W.
power: Specifies the PoE guard band in the range of 0 to 30, in watts.
Application scenarios
PoE guard band is a specified amount of power reserved to prevent PSE power overload in case of PD power jitter. For example, if the maximum power of the PSE is 200 W and the guard band is 30 W, the PSE can provide a maximum power of 170 W to all PDs. If the total power of PDs reaches 170 W, no power will be supplied to new PDs.
When the PD operates stably with low power jitter (less than the default guard band), you can use the poe pse guard-band command to decrease the guard band and use the released PSE power to power the new PDs.
Before executing this command, execute the display poe interface command to check the value of the Remaining field. If the guard band is greater than the value of Remaining field, some PDs being powered might have a power down. For example, the current guard band is 10 W, and the value of the Remaining field is 10 W. If the network administrator changes the guard band to 30 W, some PDs that are currently being powered might have a power down to make up for the 20 W power gap.
# Set the PoE guard band to 30 W.
[Sysname] poe pse 1 guard-band 30
poe high-inrush enable
Use poe high-inrush enable to allow inrush currents drawn by PDs.
Use undo poe high-inrush enable to restore the default.
This command is supported only in versions earlier than Release 6351.
poe high-inrush enable pse pse-id
undo poe high-inrush enable pse pse-id
Inrush currents drawn by PDs are not allowed.
CAUTION
CAUTION:
Inrush currents might damage the components on the device. Use this command with caution.
Inrush current might occur at PD startup and trigger PSE self-protection, As a result, the PSE stops supplying power to the PDs. To continue power supply to the PDs, configure this feature to allow inrush currents drawn by PDs.
IEEE 802.3af and IEEE 802.3at define specifications for inrush current. Support for the specifications defined by IEEE 802.3af and/or IEEE 802.3at depends on the device model.
# All high inrush currents drawn by PDs.
[Sysname] poe high-inrush enable pse 4
display poe pse
PI view
CAUTION
CAUTION:
display poe pse
poe legacy enable (interface view)
Use poe legacy enable to enable nonstandard PD detection for a PI.
Use undo poe legacy enable to disable nonstandard PD detection for a PI.
poe legacy enable
Nonstandard PD detection is disabled for a PI.
Interface view
The device supports PSE-based and PI-based nonstandard PD detection. If you enable nonstandard PD detection both in system view and interface view, the configuration in system view takes effect.
As a best practice for disabling nonstandard PD detection for all PIs successfully in one operation, disable this feature in both system view and interface view.
# Enable nonstandard PD detection for a PI.
[Sysname-GigabitEthernet1/0/1] poe legacy enable
poe legacy enable (system view)
Use poe legacy enable to enable the PSE to detect nonstandard PDs.
Use undo poe legacy enable to disable the PSE from detecting nonstandard PDs.
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
Nonstandard PD detection is disabled.
# Enable PSE 4 to detect nonstandard PDs.
[Sysname] poe legacy enable pse 4
display poe pse
poe max-power
Use poe max-power to set the maximum PI power.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
The maximum PI power depends on the PoE standard of the PI.
PI view
PoE profile view
max-power: Sets the maximum PI power in milliwatts. The value range depends on the PoE standard of the PI.
# Set the maximum PI power to 12000 milliwatts in PI view.
[Sysname-GigabitEthernet1/0/1] poe max-power 12000
# Set the maximum PI power to 12000 milliwatts in PoE profile view.
[Sysname-poe-profile-abc-1] poe max-power 12000
poe mps
Use poe mps to set the TMPDO for Maintain Power Signature (MPS).
Use undo poe mps to restore the default.
This command is supported only in R6350 and later.
poe mps pse pse-id tmpdo { timer | long |normal }
undo poe mps pse pse-id tmpdo
The normal TMPDO mode is used for the MPS. The TMPDO is 324 milliseconds.
timer: Sets the TMPDO for the MPS. The value is a multiple of 4 in the range of 300 to 400, in milliseconds.
long: Specify the long TMPDO mode. The TMPDO is 360 milliseconds.
normal: Specifies the normal TMPDO mode. The TMPDO is 324 milliseconds.
The MPS is an electronic signature provided by a PD. The PD can use this signature to maintain connection to the PSE in sleep mode. The PD sends a PoE-compliant pulse current to the PSE periodically. If the PSE detects the PoE-compliant pulse current from the PD within the TMPDO, it supplies power to the PD. If the PSE does not detect the PoE-compliant pulse current from the PD within the TMPDO, it will not supply power to the PD.
To send pulse currents at larger intervals for lower standby power, you can use this command to change the TMPDO to be longer.
Only PSE modules that have a model name of LSPPSE**A support this feature. To view the PSE models, execute the display poe pse command.
If you execute the command multiple times, the most recent configuration takes effect.
# Set the TMPDO for the MPS to 350 milliseconds.
[Sysname] poe mps pse 1 tmpdo 350
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is configured for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname-GigabitEthernet1/0/1] poe pd-description IP Phone For Room 101
poe pd-policy priority
Use poe pd-policy priority to enable PI power management.
Use undo poe pd-policy priority to restore the default.
PI power management is disabled.
If PI power management is disabled, the PSE does not supply power to new PDs when PSE power overload occurs.
If PI power management is enabled, when a PSE is overloaded, the PSE allocates power to PDs based on the priority of their PIs.
# Enable PI power management.
[Sysname] poe pd-policy priority
poe priority
poe power-delay
Use poe power-delay to enable PoE delay.
Use undo poe power-delay to disable PoE delay.
poe power-delay time
PoE delay is disabled.
time: Specifies the delay time in the range of 1 to 3600, in seconds.
By default, the device executes the poe enable command and supplies power to an interface immediately when any one of the following conditions is met:
·     The poe enable command is configured.
·     The device reboots with the poe enable command in the configuration file.
·     The interface comes up and the PoE module resumes PoE power supply to the interface.
The poe power-delay command creates a PoE delay timer after the poe enable command is configured and allows the PoE module to supply power to the PI only after the timer expires.
The undo poe enable command is executed immediately upon configuration and is not affected by the poe power-delay command.
# Enable PoE delay and set the delay time to 30 seconds.
[Sysname] poe power-delay 30
poe enable
poe priority (interface view)
Use poe priority to set the power supply priority for a PI.
Use undo poe priority to restore the default.
poe priority { critical | high | low }
undo poe priority
The power supply priority of a PI is low.
PI view
PoE profile view
critical: Sets the power supply priority to critical. The PI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical PI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the PoE power is insufficient, power is first supplied to PIs with higher priority.
For PIs with same power supply priority, the PI with the smallest ID is allocated with power first.
# Set the power supply priority of the PI to critical in PI view.
[Sysname-GigabitEthernet1/0/1] poe priority critical
# Set the power supply priority of the PI to critical in PoE profile view.
[Sysname-poe-profile-abc-1] poe priority critical
[Sysname-poe-profile-abc-1] quit
[Sysname-GigabitEthernet1/0/1] apply poe-profile name abc
poe reset enable
Use poe reset enable to enable PI power cycling upon a system warm reboot.
Use undo poe pse-policy priority to disable PI power cycling upon a system warm reboot.
poe reset enable
undo poe reset enable
PI power cycling upon a system warm reboot is disabled.
During the system warm reboot process (upon execution of the reboot command), the PIs continue supplying power to the PDs but data connections between the PDs and the device are interrupted. After the system reboots, PDs might not re-initiate data connections with the device. Power cycling PIs upon a system warm reboot allows the PDs to re-establish data connections with the device.
# Enable PI power cycling upon a system warm reboot.
[Sysname] poe reset enable
poe standard
Use poe standard { at | bt } to specify a PoE standard.
Use undo poe standard to restore the default.
undo poe standard
IMPORTANT
IMPORTANT:
Only the UPWR switch models support this command. For the specific switch models, see the installation guide for the switch series.
By default, the PoE standard of a PI is IEEE 802.3bt.
PI view
at: Specify the IEEE 802.3at standard.
bt: Specify the IEEE 802.3bt standard.
For this command to take effect, restore the maximum power of the PI to the default before executing the command.
IEEE released 802.3af (PoE), 802.3at (PoE+), and 802.3bt (PoE++) standards in chronological sequence. These standards are backward compatible but forwards incompatible. Before supplying power to a PD, a PI will detect the PD, determine the power class for the PD based on its power requirement, and supplies power to the PD based on the power class.
·     802.3af—Defines four power classes 0 to 3 and provides a maximum power of 12.95 W.
·     802.3at—Adds class 4 in addition to the four power classes defined by 802.3af and provides a maximum power of 25.5 W.
·     802.3bt—Adds classes 5 to 8 in addition to the five power classes defined by 802.3at and provides a maximum power of 71 W.
Specify a PoE standard based on the power requirement of the PD. If the maximum power allowed by the standard is less than that required by the PD, the PI will not supply power to the PD.
CAUTION
CAUTION:
When a PI is operating in 802.3bt mode and providing a power output over 30 W, changing the PoE standard might cause a power cycle of the PD. Before changing the PoE standard, make sure you understand its impact on the live network.
# Specify the IEEE 802.3at standard for GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] poe standard at
poe max-power
poe track
Use poe track to associate a PI to a track entry.
Use undo poe track to restore the default.
This command is supported only in Release R6350 and later.
poe track track-entry-number action { alarm | alarm-reboot-pd }
undo poe track
A PI is not associated with any track entry.
PI view
track-entry-number: Specify a track entry ID in the range of 1 to 1024.
action: Specifies the action to be taken when the track entry state changes from positive to negative.
alarm: Outputs an SNMP notification and log.
alarm-reboot-pd: Outputs an SNMP notification and log and reboots the PD connected to the PI.
This command uses a track entry to monitor the link status between the device and a PD and triggers the specified action when the track entry state changes from positive to negative. For more information about Track, see Track configuration in High Availability Configuration Guide.
If you configure this command multiple times in PI view, the most recent configuration takes effect.
# Associate GigabitEthernet 1/0/1 with track entry 1 and enable the system to output an SNMP notification and log when the track entry state changes from positive to negative.
[Sysname-GigabitEthernet1/0/1] poe track 1 action alarm
poe track-shutdown
Use poe track-shutdown to disable PoE power supply on shutdown interfaces.
Use undo poe track-shutdown to restore the default.
poe track-shutdown
The device continues supplying power to an interface after the interface is shut down.
By default, the device continues supplying power to an interface after the interface is shut down by the shutdown command or by an upper layer module such as monitor link. As a result, the PD connected to the shutdown interface operates continuously but fails to access the network.
This command disables the PoE module from supplying power to an interface after the interface is shut down. After the interface comes up, the PoE module resumes power supply to the interface.
The command does not power off an interface that has been shut down but is supplying power to a PD.
# Disable PoE power supply on interfaces after they shut down.
[Sysname] poe track-shutdown
poe enable
poe update
Use poe update to upgrade the PSE firmware when the device is operating.
poe update { full | refresh } filename [ pse pse-id ]
full: Upgrades the PSE firmware in full mode.
refresh: Upgrades the PSE firmware in refresh mode.
filename: Specifies the name of the upgrade file, a case-insensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
pse pse-id: Specifies a PSE by its ID. If you do not specify a PSE, all PSEs are upgraded.
You can upgrade the PSE firmware in service in either of the following modes:
·     Refresh mode—Updates the PSE firmware without deleting it. You can use the refresh mode in most cases.
·     Full mode—Deletes the current PSE firmware and reloads a new one. Use the full mode if the PSE firmware is damaged and you cannot execute any PoE commands.
# Upgrade the firmware of PSE 4 in service.
[Sysname] poe update refresh POE-168.bin pse 4
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for the PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of the PSE.
poe utilization-threshold value pse pse-id
undo poe utilization-threshold pse pse-id
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power usage crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of PSE 4 to 90%.
[Sysname] poe utilization-threshold 90 pse 4
poe-profile
Use poe-profile to create a PoE profile and enter its view, or enter the view of an existing PoE profile.
Use undo poe-profile to delete a PoE profile.
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
No PoE profiles exist.
profile-name: Specifies a PoE profile name, a case-sensitive string of 1 to 15 characters. A PoE configuration file name begins with a letter and must not contain reserved keywords including undo, all, name, interface, user, poe, disable, max-power, mode, priority, or enable.
index: Specifies the index number of a PoE profile, in the range of 1 to 100.
To configure PIs in batches, use the PoE profile.
If you do not specify a profile index, the system automatically assigns an index (starting from 1) to the PoE profile.
If a PoE profile is applied, use the undo apply poe-profile command to remove the application before deleting the PoE profile.
# Create a PoE profile, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
[Sysname-poe-profile-abc-3]
# Create a PoE profile and name it def. Do not specify the index number.
[Sysname] poe-profile def
[Sysname-poe-profile-def-1]
apply poe-profile
poe enable
poe max-power
poe priority
