11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5560S-EI[SI]&S5500V3-SI&MS4520V2&WS5850-Winet Command References-R63xx-6W10411-Network Management and Monitoring Command Reference
18-EPA commands
18-EPA commands 63.62 KB
EPA commands
This feature is supported only in Release 6328 and later.
display epa monitor-information
Use display epa monitor-information to display endpoint association and disassociation information detected by EPA.
display epa monitor-information [ online | offline ] [ device device-id | mac mac-address [ vlan vlan-id ] ]
online: Displays endpoint association information.
offline: Displays endpoint disassociation information.
device device-id: Specifies a device by its bridge MAC address in the H-H-H format. In a SmartMC (or WiNet) network, you can specify the bridge MAC address of a member to display only information about endpoints connecting to the member.
mac mac-address: Specifies an endpoint by its MAC address in the H-H-H format.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify this option, the command displays information in all VLANs.
In a SmartMC (or WiNet) network, you can execute this command on the commander or on a member.
·     If you execute this command on the commander, you can view information on all devices in the network or information on a specific device.
·     If you execute this command on a member, you can view only association events of endpoints connecting to the member.
In a non-SmartMC (or non-WiNet) network, this command displays information only on the device on which the command is executed.
For more information about SmartMC (or WiNet), see Network Management and Monitoring Configuration Guide.
# In a SmartMC (or WiNet) network, display endpoint association and disassociation information on the member device with bridge MAC address 3cf5-cc97-772f.
<Sysname> display epa monitor-information device 3cf5-cc97-772f
Local device type   : SmartMC TM
Local device ID     : ae05-0607-eaaa
Endpoint information:
  Access device ID    MAC address     VLAN    Interface                  Status
  3cf5-cc97-772f      0e74-e2fb-0400  11      GE1/0/1                    Online
  3cf5-cc97-772f      5caf-2e5f-0100  11      GE1/0/2                    Offline
# In a non-SmartMC (or non-WiNet) network, display endpoint association and disassociation information on the current device.
Local device type   : Self-managed
Local device ID     : 3cf5-cc97-772e
  3cf5-cc97-772e      1cab-34aa-d00e  10      GE1/0/1                    Online
  3cf5-cc97-772e      0000-02b5-ed00  10      GE1/0/2                    Offline
Local device type
Local device type.
For SmartMC, options include:
·     Self-managedIndicates a device in a non-SmartMC network.
·     SmartMC TMIndicates the commander in a SmartMC network.
·     SmartMC TCIndicates a member in a SmartMC network.
For WiNet, options include:
·     Self-managed—Indicates a device in a non-WiNet network.
·     WiNet TM—Indicates the commander in a WiNet network.
·     WiNet TC—Indicates a member in a WiNet network.
Local device ID
Local device ID (bridge MAC address).
Access device ID
ID (bridge MAC address) of the connected device.
MAC address
MAC address of the endpoint.
VLAN
VLAN in which the endpoint resides.
Interface to which the endpoint is connected.
Status
Endpoint status. Options include:
·     Online.
·     Offline.
epa monitor-rule
epa monitor-rule
Use epa monitor-rule to create an endpoint monitor rule.
Use undo epa monitor-rule to remove an endpoint monitor rule.
epa monitor-rule [ monitor-rule-id ] mac mac-address [ mask mac-mask ] [ vlan vlan-id ]
undo epa monitor-rule { monitor-rule-id | mac mac-address [ mask mac-mask ] [ vlan vlan-id ] }
No endpoint monitor rules exist.
monitor-rule-id: Specifies the rule ID in the range of 1 to 1024. If you do not specify this argument, the command assigns the smallest available ID to the rule.
mac mac-address: Specifies the MAC address of the endpoint to monitor, in the H-H-H format.
mask mac-mask: Specifies a MAC address mask, in the H-H-H format.
vlan vlan-id: Specifies the VLAN in which the endpoint will be monitored. The vlan-id argument represents the VLAN ID in the range of 1 to 4094. If you do not specify this option, the command creates a rule that monitors the endpoint in all VLANs.
In a SmartMC (or WiNet) network, you can execute this command only on the commander. The commander will deploy the rule to all members to monitor associations and disassociations of the specified endpoint in the entire network.
In a non-SmartMC (or non-WiNet) network, this command enables the device to monitor associations and disassociations of the specified endpoint only on the device itself.
# Create an endpoint monitor rule to monitor endpoints whose MAC address starts with 0e74 in all VLANs.
[Sysname] epa monitor-rule mac 0e74-e2fb-0400 mask ffff-0000-0000
epa online-offline-log disable
Use epa online-offline-log disable to disable EPA logging.
Use undo epa online-offline-log disable to enable EPA logging.
EPA logging is enabled.
By default, the EPA module logs endpoint associations and disassociations. If a monitored endpoint comes online or goes offline frequently, the device will generate a large number of log entries. In this case, to avoid affecting device performance, disable EPA logging as a best practice.
# Disable EPA logging.
[Sysname] epa online-offline-log disable
epa monitor-rule
