11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5560S-EI[SI]&S5500V3-SI&MS4520V2&WS5850-Winet Command References-R63xx-6W10411-Network Management and Monitoring Command Reference
17-WiNet commands
17-WiNet commands 302.83 KB
WiNet commands
boot-loader file
Use boot-loader file to specify the upgrade startup software files for a WiNet group.
Use undo boot-loader to restore the default.
boot-loader file { ipe-filename | boot boot-filename system system-filename }
undo boot-loader
No upgrade startup software files are specified for a WiNet group.
WiNet group view
ipe-filename: Specifies an IPE software file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .ipe extension.
boot boot-filename: Specifies a boot image file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .bin extension.
system system-filename: Specifies a system image file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .bin extension.
# Specify IPE software file device.ipe for WiNet group testgroup.
[Sysname] winet group testgroup
[Sysname-winet-group-testgroup] boot-loader file device.ipe
winet group
winet upgrade boot-loader
create batch-file
Use create batch-file to create a batch file.
create batch-file batch-file-name
No batch files exist.
batch-file-name: Specifies the name of the batch file, a case-insensitive string of 1 to 255 characters. If you do not specify a file extension when specifying a file name, the default extension .cmdset is used.
After executing this command, you will enter the batch edit mode. In this mode, each command occupies a line. When you finish editing all command lines, enter a percent sign (%) to return to user view.
Make sure the command lines that you enter are correct because the system does not verify whether the command lines are correct.
# Create a batch file named test.cmdset, and enter the command lines for specifying the device name as Sysname and enabling Telnet.
<Sysname> create batch-file test.cmdset
Begin to edit batch commands, and quit with the character '%'.
sysname Sysname
telnet server enable%
<Sysname>
display winet batch-file status
winet batch-file deploy
display winet backup configuration status
Use display winet backup configuration status to display the backup status on members.
This command displays the status of the ongoing backup task or the most recent backup task if the member is not performing backup.
# Display the backup status on members.
<Sysname> display winet backup configuration status
ID     IpAddress        MacAddress          Status       Time
1      192.168.56.30    08d2-38ff-0300      Finished     2017-04-05 11:30:35
2      192.168.56.40    62d2-c21c-0400      Finished     2017-04-05 11:30:40
ID
ID of the member.
IpAddress
IP address of the member.
MacAddress
MAC address of the member.
Status
Backup status:
·     Waiting—The member is waiting for configuration backup.
·     Processing—The member is backing up the configuration.
·     Finished—The member has finished backing up the configuration.
·     Timeout—Configuration backup times out.
·     Failed—The member failed to back up the configuration.
Time
Time when the member finished backing up the configuration. If the member has not finished backing up the configuration, this field displays a hyphen (-).
winet backup configuration interval
winet backup configuration max-number
Use display winet batch-file status to display the batch file deployment result.
display winet batch-file status [ ap | last number | phone ]
ap: Displays the result of the most recent batch file deployment for ports connected to APs.
last number: Specifies a batch file deployment (performed by using the winet batch-file deploy command) by its number counting from the most recent batch file deployment. The value range for the number argument is 1 to 5.
phone: Displays the result of the most recent batch file deployment for ports connected to IP phones.
If you do not specify any parameters, this command displays the result of the most recent batch file deployment performed by using the winet batch-file deploy command.
# Display the result of the most recent batch file deployment. In this example, the batch file contains the display winet configuration command.
<Sysname> display winet batch-file status last 1
TC ID 1
Device MAC : 8a73-60c3-0200
Start Time : 2018-12-24 14:55:39
End   Time : 2018-12-24 14:55:43
Result     :
<Sysname>display winet configuration
Device role              : TC
TM IP                    : 192.168.22.103
TM MAC                   : 8a73-4faa-0100
TM sysname               : Sysname
<Sysname>
TC ID 2
Device MAC : 8a73-6b31-0300
Start Time : 2018-12-24 14:55:43
End   Time : 2018-12-24 14:55:48
Result     :
Device role              : TC
<Sysname>
TC ID
ID of the member.
Device MAC
Start Time
Batch file deployment start time.
End Time
Batch file deployment end time.
Result
Batch file deployment result in details.
create batch-file
winet batch-file apply
Use display winet configuration to display the WiNet configuration.
# Display the WiNet configuration on the commander.
Release 6318P01 and earlier:
<Sysname> display winet configuration
Device role                           : TM
FTP server IP                         : 192.168.22.103
FTP server username                   : admin
Topology-refresh interval             : 60(s)
Backup startup-configuration interval : N/A
Sync backup number                    : 5
Device status                         : Lack
Some configurations are absent on the TM, such as Telnet or LLDP configuration.
Release 6328 and later:
Device role                           : TM
File server:
  Type: FTP
  IP address: 192.168.22.103
  Username: admin
  Port: 21
  VPN instance: N/A
  Directory: /FTP
# Display the commander information on a member.
Device role       : TC
TM MAC            : 8288-468d-0100
Device role
Role of the device.
FTP server IP
This field is supported only in Release 6318P01 and earlier.
IP address of the FTP server. If no FTP server IP address is configured, this field displays N/A.
FTP server username
FTP server username. If no username is configured, this field displays N/A.
File server
This field is supported only in Release 6328 and later.
File server configuration.
File server type. If no file server is specified, this field displays N/A.
IP address
File server IP address. If no file server is specified, this field displays N/A.
Username
File server username. If no file server is specified, this field displays N/A.
Port
File server port. If no file server is specified, this field displays N/A.
VPN instance
VPN instance to which the file server belongs. If no file server is specified, this field displays N/A.
Directory
Storage directory of files on the file server. If no file server is specified, this field displays N/A.
Topology refresh interval, in seconds.
Automatic configuration file backup interval, in hours. If no interval is set, this field displays N/A.
Sync backup number
Number of members that can perform configuration backup at the same time.
Device status
Commander status:
·     Normal.
·     Lack—Lack of configuration, such as NETCONF, Telnet, local user, and LLDP.
TM IP
IP address of the commander. If the member failed to obtain the commander IP address, this field displays N/A.
TM MAC
MAC address of the commander, If the member failed to obtain the commander MAC address, this field displays N/A.
TM sysname
Name of the commander. If the member failed to obtain the commander name, this field displays N/A.
Some configurations are absent on the TM, such as XXX.
This field is available only when the Device status field displays Lack. Lack of configuration will affect WiNet functions. Please follow the prompt to complete the configuration.
smartmc backup configuration interval
smartmc backup configuration max-number
smartmc enable
smartmc { ftp-server | sftp-server }
smartmc topology-refresh interval
display winet device-link
Use display winet device-link to display connections between devices in the WiNet network.
# Display connections between devices in the WiNet network.
<Sysname> display winet device-link
(TM IP)[192.168.56.20]
ID    Hop  LocalPort            LocalIP           PeerPort               PeerIP
0     0    GigabitEthernet1/0/2  192.168.56.20     GigabitEthernet1/0/1   192.168.56.30
1     1    GigabitEthernet1/0/1  192.168.56.30     GigabitEthernet1/0/2   192.168.56.20
1     2    GigabitEthernet1/0/2  192.168.56.30     GigabitEthernet1/0/1   192.168.56.40
2     3    GigabitEthernet1/0/1  192.168.56.40     GigabitEthernet1/0/2   192.168.56.30
TM IP
ID
ID of the commander or member.
Hop
Number of hops between the commander and member.
LocalPort
Local port.
LocalIP
IP address of the local device.
PeerPort
Peer port.
PeerIP
IP address of the peer port.
winet topology-refresh
winet topology-refresh interval
display winet group
Use display winet group to display WiNet group information.
display winet group [ group-name ] [ verbose ]
group-name: Specifies a WiNet group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this argument, the command displays information about all WiNet groups.
Verbose: Displays detailed WiNet group information. If you do not specify this keyword, the command displays brief WiNet group information.
# Display detailed WiNet group information.
<Sysname> display winet group verbose
Group name                   : test
TC count                     : 3
Boot-loader file             :
Startup-configuration file   :
Rule:
 Match Device-type WS5850-WiNet
TCID DeviceType Sysname  IpAddress       MacAddress     Status   Version
1    WS5850     S1       192.168.56.103  0e74-e2fb-0400 Normal   COMWAREV700R001
2    WS5850     S2       192.168.56.102  0e74-ea13-0500 Normal   COMWAREV700R001
3    WS5850     S3       192.168.56.104  0e74-db54-0300 Normal   COMWAREV700R001
Table 5 Command output
GroupName
Name of the WiNet group.
TC count
Number of members in the WiNet group.
Boot-loader file
Names of the upgrade startup software files for upgrading the WiNet group. If no upgrade startup software files are specified, this field displays null.
Name of the configuration file for upgrading the WiNet group. If no configuration file is specified, this field displays null.
Rule
Match criteria of the WiNet group.
Match
Match type and its value. The match types include the following:
·     Device-type—Matches members by device type.
·     IP-address—Matches members by IP address.
·     MAC-address—Matches members by MAC address.
TCID
ID of the member.
DeviceType
Device type of the member.
Sysname
Device name of the member.
IpAddress
MacAddress
Version
Software version of the member.
Status
Operating status of the member:
·     Offline—The member is offline.
·     Normal—The member is online.
match
winet group
display winet replace status
Use display winet replace status to display faulty member replacement status.
# Display faulty member replacement status.
<Sysname> display winet replace status
Faulty ID      : 2
Faulty MAC     : 94e2-cdcb-0600
Replacement ID : 3
Replacement MAC: 2443-5f8c-0200
Mode           : Manual
Status         : Successful
Start time     : 2017-03-21 15:01:31
End time       : 2017-03-21 15:01:40
Table 6 Command output
Faulty ID
ID of the faulty member.
Faulty MAC
MAC address of the faulty member.
Replacement ID
ID of the new member.
Replacement MAC
MAC address of the new member.
Mode
Replacement method, which can be Manual or Auto.
Status
Replacement status:
·     Successful.
·     Failed.
·     Replacing.
·     Timeout.
Start time
Replacement start time
End time
Replacement end time.
winet auto-replace enable
winet replace
display winet resource-monitor
Use display winet resource-monitor to display resource monitoring information.
display winet resource-monitor [ cpu | memory | temperature ] * [ tc tc-id | tm ]
cpu: Displays CPU usage.
memory: Displays memory usage.
temperature: Displays temperature information.
tc tc-id: Specify a member by its ID in the range of 1 to 255.
tm: Specify the commander.
This command displays CPU usage, memory usage, and temperature information of the commander and members on the commander. For packet dropping information, log in to the Web interface of the commander and access the WiNet > Intelligent O&M > Resource monitoring page. Packet dropping information can be viewed only in Release 6328 and later.
If you do not specify a resource type, this command displays the resource monitoring information of all types.
If you do not specify a member or the commander, this command displays the resource monitoring information for the commander and all members.
# Display the resource monitoring information for member 1.
<Sysname> display winet resource-monitor tc 1
TC 1
  Collection time : 2017-07-25 18:02:30
  Slot 1:
    CPU 0 CPU usage: 1%
    Memory usage   : 587076/903332
    Temperature    : 30
Table 7 Command output
Collection time
Time when the resource monitoring information was collected.
display winet resource-monitor configuration
Use display winet resource-monitor configuration to display resource monitoring configuration.
This command displays CPU usage, memory usage, and temperature monitoring configuration of the commander. In Release 6328 and later, you can view the status of packet dropping monitoring by using the display current-configuration | include smartmc command.
# Display resource monitoring configuration.
<Sysname> display winet resource-monitor configuration
ID  MacAddress      CPU  Memory  Temperature
1   1234-2222-3333  Y    N       N
2   1234-2222-3334  Y    N       N
3   1234-2222-3335  Y    N       N
Table 8 Command output
ID
Device ID.
MacAddress
MAC address of the device.
CPU
CPU usage monitoring status:
·     Y—CPU usage monitoring is enabled.
·     N—CPU usage monitoring is disabled.
·     -—The device does not support CPU usage monitoring.
Memory
Memory usage monitoring status:
·     Y—Memory usage monitoring is enabled.
·     N—Memory usage monitoring is disabled.
·     -—The device does not support memory usage monitoring.
Temperature
Temperature monitoring status:
·     Y—Temperature monitoring is enabled.
·     N—Temperature monitoring is disabled.
·     -—The device does not support temperature monitoring.
display winet tc
Use display winet tc to display member information.
display winet tc [ tc-id ] [ verbose ]
tc-id: Specifies a member by its ID in the range of 1 to 255. If you do not specify a member, this command displays information about all members.
verbose: Displays detailed member information. If you do not specify this keyword, the command displays brief member information.
# Display brief information about all members.
<Sysname> display winet tc
1    WS5850     S1       192.168.22.104  201c-e7c3-0300 Normal   COMWAREV700R001
Table 9 Command output
TCID
ID of the member.
DeviceType
Sysname
IpAddress
MacAddress
Status
·     Normal—The member is operating correctly.
Version
# Display detailed information about all members.
<Sysname> display winet tc verbose
TC ID                        : 1
Adding method                : Manual
Sysname                      : S1
Model                        : WS5850-WiNet
Device type                  : WS5850-WiNet
SYSOID                       : 1.3.6.1.4.1.25506
MAC address                  : 0e74-e2fb-0400
IP address                   : 192.168.56.103
Boot image                   :
Boot image version           :
System image                 :
System image version         :
Current-configuration file   :
Uptime                       : 2 days, 3 hours, 4 minutes
System CPU usage             : 0%
System memory usage          : 0%
Status                       : Offline
Boot-loader file             :
Table 10 Command output
TC ID
ID of the member.
Adding method
Method through which the member is added to the WiNet network:
·     Manual.
·     Auto.
Sysname
Model
Device model of the member.
Device type
SYSOID
SYSOID of the member.
MAC address
IP address
Boot image
Boot image file that the member runs.
Boot image version
Version of the boot image file.
System image
System image file that the member runs.
Version of the system image file.
Current startup configuration file used by the member.
Uptime
Operation duration of the member.
System CPU usage
CPU usage on the member.
System memory usage
Memory usage on the member.
Status
Boot-loader file
Upgrade startup software files.
Upgrade configuration file.
display winet tc log buffer
Use display winet tc log buffer to display log information in the log buffer on a member.
display winet tc tc-id log buffer [ module module-name [ mnemonic mnemonic-value ] ]
module module-name: Specifies a module by its name, a case-insensitive string of 1 to 8 characters. To display module names, use the info-center source command (see information center commands in Network Management and Monitoring Command Reference).
mnemonic mnemonic-value: Specifies a mnemonic, a case-insensitive string of 1 to 32 characters.
# Display the log information for the SHELL module with the SHELL_CMD mnemonic for member 1.
<Sysname> display winet tc 1 log buffer module SHELL mnemonic SHELL_CMD
Time     : 2017-07-15 13:51:46
Level    : Informational
Module   : SHELL
Mnemonic : SHELL_CMD
Content  : -Line=con0-IPAddr=**-User=**; Command is qu
Time     : 2017-07-15 13:51:39
Module   : SHELL
Content  : -Line=con0-IPAddr=**-User=**; Command is local-user admin
Table 11 Command output
Time
Time when the log was generated.
Level
Log level.
display winet tc log restart
Use display winet tc log restart to display the restart log information for a member.
display winet tc tc-id log restart
In addition to saving the logs generated by modules to the log buffer, a member sends restart logs to the commander. The commander creates a restart log buffer for each member to store their restart logs.
The commander stores a maximum of 10 restart logs for each member. The most recent restart log overwrites the oldest one when there are more than 10 restart logs for a member.
You can also use the display winet tc tc-id log buffer module SYSLOG mnemonic SYSLOG_RESTART command to display the restart log information.
# Display the restart log information for member 1.
<Sysname> display winet tc 1 log restart
Module   : SYSLOG
Mnemonic : SYSLOG_RESTART
Content  : System restarted -- H3C Comware Software.
Table 12 Command output
Time
Level
Log level.
display winet upgrade status
Use display winet upgrade status to display member upgrade status.
# Display member upgrade status.
<Sysname> display winet upgrade status
ID    IpAddress         MacAddress      Status      UpdateTime        UpdateFile
1     192.168.56.1      82dd-a434-0200  Finished    Immediately       bootloader.ipe
2     192.168.56.103    5caf-2e5f-0100  Finished    Immediately       bootloader.ipe
Table 13 Command output
ID
ID of the member.
MacAddress
IpAddress
Status
Upgrade status:
·     Waiting—The member is waiting for downloading the upgrade file.
·     Download-failed—The member failed to download the upgrade file.
·     Download-finished—The member has downloaded the upgrade file.
·     Downloading—The member is downloading the upgrade file.
·     Updating—The member is upgrading.
·     Finished—The member has finished upgrading.
·     Failed—The member failed to upgrade.
·     Unknown—The upgrade status of the member is unknown.
Updated File
Name of the upgrade file.
UpdateTime
Upgrade time:
·     Immediately—Upgrade at once.
·     Delay(m)—Upgrade after the specified delay.
·     Time(HH:MM)—Upgrade at the specified time.
winet upgrade group
winet upgrade tc
display winet vlan
Use display winet vlan to display VLAN creation results for members.
display winet vlan
# Display VLAN creation results.
<Sysname> display winet vlan
ID     IpAddress         MacAddress        Vlan      Status
1      192.168.22.222    703d-15ad-cd02    2         Success
2      192.168.22.3      24ff-2264-0100    2         Success
3      192.168.22.4      24ff-2f74-0200    2         Success
4      192.168.22.223    487a-dac8-29ba    2         Success
Table 14 Command output
ID
Member ID.
IpAddress
MacAddress
Vlan
VLAN created for the member.
Status
VLAN creation status:
·     Processing—The VLAN is being created.
·     Success—The VLAN has been created successfully.
·     Failure. The port xxx is not an access port—The VLAN fails to be created, because ports connected to non-WiNet devices are not access ports.
·     Failure. xxx not exist—The VLAN fails to be created, because all access ports are connected to WiNet devices.
winet vlan
match
Use match to set a match criterion to add all matching members to a WiNet group.
Use undo match to delete a match criterion.
match { device-type device-type | ip-address ip-address { ip-mask-length | ip-mask } | mac-address mac-address mac-mask-length }
undo match { device-type device-type | ip-address ip-address { ip-mask-length | ip-mask } | mac-address mac-address mac-mask-length }
No match criterion is set.
WiNet group view
device-type device-type: Sets a device type match criterion.
ip-address ip-address { ip-mask-length | ip-mask }: Sets an IP address match criterion. The ip-address argument specifies an IP address in dotted decimal notation. The ip-mask argument specifies the subnet mask in dotted decimal notation. The ip-mask-length argument specifies the subnet mask length in the range of 1 to 32.
mac-address mac-address mac-mask-length: Sets a MAC address match criterion. The mac-address argument specifies a MAC address in the format of H-H-H. The mac-mask-length argument specifies the mask length in the range of 1 to 48.
# Create a WiNet group named a and add members in subnet 192.168.1.0/24 to the group.
[Sysname] winet group a
[Sysname-winet-group-a] match ip-address 192.168.1.0 24
winet group
display winet group
winet auto-link-aggregation enable
Use winet auto-link-aggregation enable to enable automatic Ethernet link aggregation.
Use undo winet auto-link-aggregation enable to disable automatic Ethernet link aggregation.
Automatic Ethernet link aggregation is disabled.
Automatic Ethernet link aggregation is not performed between the commander and a member.
Enabling or disabling automatic Ethernet link aggregation might cause network flapping, and the members might go offline for a short period of time.
# Enable automatic Ethernet link aggregation.
[Sysname] winet auto-link-aggregation enable
Use winet auto-replace enable to enable the automatic faulty member replacement feature.
Use undo winet auto-replace enable to disable the automatic faulty member replacement feature.
The automatic faulty member replacement feature is disabled.
To perform an automatic fault replacement, first enable this feature on the commander, and then perform the following tasks:
1.     Install the new member at the location where the faulty member was installed.
2.     Connect all cables to the new member.
Make sure the new member and the faulty member have the same neighbor relationship, device model, and IRF member ID.
# Enable the automatic faulty member replacement feature.
[Sysname] winet auto-replace enable
winet replace
Use winet backup configuration to manually back up the configuration file on members.
winet backup configuration { group group-name-list | tc [ tc-id-list ] }
group group-name-list: Specifies a space-separated list of up to 10 WiNet groups. The group name is a case-sensitive string of 1 to 31 characters.
tc tc-id-list: Specifies a space-separated list of up to 10 member items. Each item specifies a device or a range of devices in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 0 to 255, with 0 representing the commander and 1 to 255 representing members. If you do not specify the commander or any members, all devices will perform configuration backup.
After you execute this command, the members immediately save the running configuration to the next-startup configuration files and upload the configuration files to the file server.
The backup configuration files are named in the format of bridge MAC address_backup.cfg.
# Back up the configuration file on member 1, member 2, member 3, and member 4.
[Sysname] winet backup configuration tc 1 to 4
# Back up the configuration file on all members in WiNet groups test1, test2, and test3.
[Sysname] winet backup configuration group test1 test2 test3
Use winet backup configuration max-number to set the maximum number of members that can perform automatic configuration backup at the same time.
Use undo winet backup configuration max-number to restore the default.
winet backup configuration max-number max-number
A maximum of five members can perform automatic configuration backup at the same time.
max-number: Specifies the maximum number of members that can perform automatic configuration backup at the same time, in the range of 2 to 20.
The maximum number of members that can perform automatic configuration at the same time is limited by the performance of the file server. If automatic configuration backup fails, set the maximum number of members to a smaller value.
# Specify that a maximum of 10 members can perform automatic configuration backup at the same time.
[Sysname] winet backup configuration max-number 10
Use winet backup configuration interval to enable the automatic configuration file backup feature and set the automatic backup interval.
Use undo winet backup configuration interval to restore the default.
winet backup configuration interval interval
The automatic configuration file backup feature is disabled.
interval: Specifies the automatic configuration file backup interval in the range of 1 to 720 hours.
This command enables the commander and members to back up their configuration files by saving the running configuration to the files and then uploading them to the file server. When you execute this command, the commander and members immediately perform a backup. After that, they back up the configuration files at the specified interval. The backup configuration files are named in the format of bridge MAC address_backup.cfg.
# Enable the automatic configuration file backup feature and set the backup interval to 24 hours.
[Sysname] winet backup configuration interval 24
Use winet batch-file apply to specify a batch file to deploy to ports connecting APs or IP phones.
Use undo winet batch-file apply to remove a batch file specified for ports connecting APs or IP phones.
winet batch-file batch-file-name apply { ap | phone }
undo winet batch-file apply { ap | phone }
No batch file is specified for ports connecting APs or IP phones.
batch-file-name: Specifies a batch file by its name, a case-insensitive string of 1 to 255 characters.
ap: Specifies ports connecting APs.
phone: Specifies ports connecting IP phones.
With batch file deployment enabled, the commander automatically deploys configurations in the specified batch file to a port connecting an AP or IP phone, simplifying access port configuration.
When the commander first detects the association of an AP or IP phone on a port through LLDP, it deploys the command lines in the specified batch file to the port. If no batch file is specified for the device type, the configurations on the port remain unchanged.
If the AP or IP phone disconnects from the port, the configurations on the port remain. When a new device comes online from the port, configurations used by the port depend on the new device type.
·     If the new device is an AP or IP phone and has the same type as the disconnected device, the configurations on the port remain unchanged.
·     If the new device is an AP or IP phone but has a different type as the disconnected device, the commander deploys the command lines in the specified batch file to the port. If no batch file is specified for the device type, the configurations on the port remain unchanged.
·     If the new device is neither an AP nor an IP phone, the configurations on the port remain unchanged.
To disable the commander from deploying a batch file to ports, remove the specified batch file or execute the undo winet batch-file-apply enable command to disable batch file deployment. The undo winet batch-file-apply enable command is supported only in Release 6328 and later.
# Specify batch file ap.cmdset for ports connecting APs or IP phones.
[Sysname] winet batch-file ap.cmdset apply ap
create batch-file
Use winet batch-file deploy to deploy bulk command lines to a list of members or WiNet groups.
winet batch-file batch-file-name deploy { group group-name-list | tc tc-id-list }
batch-file-name: Specifies the name of a batch file, a case-insensitive string of 1 to 255 characters.
tc tc-id-list: Specifies a space-separated list of up to 10 member items. Each item specifies a member or a range of members in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 1 to 255.
# Deploy batch file startup.cmdset to WiNet group testgroup.
[Sysname] winet batch-file startup.cmdset deploy group testgroup
create batch-file
Use winet batch-file-apply enable to enable batch file deployment.
Use undo winet batch-file-apply enable to disable batch file deployment.
This command is supported only in Release 6328 and later.
Batch file deployment is enabled.
With batch file deployment enabled, the commander automatically deploys configurations in the specified batch file to a port connecting an AP or IP phone, simplifying access port configuration. To disable the commander from deploying a batch file to ports, remove the specified batch file or disable batch file deployment.
# Disable batch file deployment.
[Sysname] undo winet batch-file-apply enable
winet enable
Use winet enable to enable WiNet and set the device role.
Use undo winet enable to disable WiNet.
winet { tc | tm username username password { cipher | simple } string } enable
undo winet enable
WiNet is disabled.
tc: Enables WiNet and sets the device role to member.
tm: Enables WiNet and sets the device role to commander.
username username: Specifies a username for the local user, a case-sensitive string of 1 to 55 characters.
password: Specifies a password for the local user.
simple: Specifies a password in plaintext form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
A WiNet network must have one and only one commander.
To enable WiNet, execute this command on both the commander and members. To configure the other WiNet features, execute associated commands only on the commander.
If you change the role of the commander to member or disable WiNet on the commander, all WiNet settings in its running configuration will be cleared.
WiNet fails to be enabled if ACL resources are insufficient. If ACL resources are insufficient, use the undo acl command to delete unnecessary ACLs and then enable WiNet. You can execute the display acl command to view ACL configuration and match statistics. For more information about ACLs, see ACL and QoS Configuration Guide.
WiNet fails to be enabled if ports 80 and 443 have been used.
If you execute this command multiple times, the most recent configuration takes effect. You can execute the command to change the device role or the password.
# Enable WiNet and set the device role to member.
[Sysname] winet tc enable
winet { ftp-server| sftp-server }
Use winet { ftp-server | sftp-server } to configure the file server information.
Use undo winet { ftp-server | sftp-server } to delete the file server information.
winet ftp-server server-address username username password { cipher | simple } string
undo winet ftp-server
winet { ftp-server | sftp-server } { ipv4-address | ipv6 ipv6-address } [ port port ] [ vpn-instance vpn-instance-name ] [ directory directory ] username username password { cipher | simple } string
No file server information is configured.
ftp-server: Specifies an FTP server.
sftp-server: Specifies an SFTP server.
ipv4-address: Specifies the IPv4 address of the file server.
ipv6 ipv6-address: Specifies the IPv6 address of the file server.
port port: Specifies the port number of the file server, in the range of 1 to 65535. The default pot for an FTP server and an SFTP server is 21 and 22, respectively.
vpn-instance vpn-instance-name: Specifies the name of the MPLS L3VPN instance to which the file server belongs, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command considers that the file server is in the public network.
directory directory: Specifies the working directory of the file server, a case-insensitive string. By default, the root directory is used.
username username: Specifies the file server username, a case-sensitive string of 1 to 55 characters.
password: Specifies the file server password.
# Set the file server to FTP, and specify the server IP address, username, and password as 192.168.22.19, admin, and hello12345, respectively.
[Sysname] winet ftp-server 192.168.22.19 username admin password simple hello12345
winet group
Use winet group to create a WiNet group and enter its view, or enter the view of an existing WiNet group.
Use undo winet group to delete a WiNet group.
winet group group-name
undo winet group group-name
No WiNet groups exist.
group-name: Specifies the name of the WiNet group, a case-sensitive string of 1 to 31 characters.
When you perform the following operations, you can specify a WiNet group to apply the operations to all members in the group:
·     Startup software upgrade.
·     Configuration file upgrade.
·     Configuration deployment.
# Create WiNet group testgroup.
match
winet outbound
Use winet outbound to configure an outgoing interface for the WiNet network.
Use undo winet outbound to restore the default.
winet outbound
undo winet outbound
No interface is used as an outgoing interface, and the WiNet network cannot communicate with outside networks.
VLAN interface view
VLAN interface 1 cannot be used as an outgoing interface, because the WiNet network is established in VLAN 1.
# Configure GigabitEthernet 1/0/1 as an outgoing interface for the WiNet network.
[Sysname-GigabitEthernet1/0/1] winet outbound
Use winet resource-monitor to enable resource monitoring.
Use undo winet resource-monitor to disable resource monitoring.
winet resource-monitor [ cpu | memory | packet-drop | temperature ] * [ group group-name-list | tc { tc-id-list | mac-address mac-address } | tm ]
undo winet resource-monitor [ cpu | memory | packet-drop | temperature ] * [ group group-name-list | tc { tc-id-list | mac-address mac-address } | tm ]
Resource monitoring is disabled.
cpu: Enables CPU usage monitoring.
memory: Enables memory usage monitoring.
packet-drop: Enables packet dropping monitoring.
The packet-drop keyword is supported only in Release 6328 and later.
temperature: Enables temperature monitoring.
group group-name-list: Specifies the WiNet groups to monitor. You can specify a space-separated list of up to 10 WiNet groups. The group name is a case-sensitive string of 1 to 31 characters.
tc: Specifies the members to monitor.
mac-address mac-address: Specifies a member by its MAC address in the format of H-H-H.
tm: Enables resource monitoring on the commander.
Packet dropping monitoring monitors packet dropping on members and on interfaces.
If you do not specify a resource type, this command enables resource monitoring for all resource types.
If you do not specify a device to monitor (member or the commander), this command enables resource monitoring on the commander and all members.
# Enable resource monitoring for all resource types on member 1 through member 3.
[Sysname] winet resource-monitor tc 1 to 3
winet resource-monitor interval
winet resource-monitor max-age
Use winet resource-monitor interval to set the interval for the commander to obtain resource monitoring information.
Use undo winet resource-monitor interval to restore the default.
winet resource-monitor interval interval
The interval for the commander to obtain resource monitoring information is 1 minute.
interval: Specifies the interval for the commander to obtain resource monitoring information, in the range of 1 to 60 minutes.
For packet dropping monitoring, the specified interval applies only to obtaining of member packet dropping information. Because of the great amount of interface information, the commander obtains interface packet dropping information from members only when Web displaying is requested.
# Set the interval for the commander to obtain resource monitoring information to 5 minutes.
[Sysname] winet resource-monitor interval 5
Use winet resource-monitor max-age to set the aging time for resource monitoring information.
Use undo winet resource-monitor max-age to restore the default.
winet resource-monitor max-age max-age
The aging time for resource monitoring information is 24 hours.
max-age: Specifies the aging time for resource monitoring information, in the range of 1 to 168 hours.
For packet dropping monitoring, the specified aging time applies only to member packet dropping information. Each member saves its interface packet dropping information for as long as 30 days.
To view interface packet dropping information, log in to the Web interface of the commander and access the WiNet > Intelligent O&M > Resource monitoring page. You can view information in the past 1 hour, 1 day, or 30 days.
# Set the aging time for resource monitoring information to 1 hour.
[Sysname] winet resource-monitor max-age 1
winet replace
Use winet replace to manually replace a faulty member.
winet replace tc tc-id1 faulty-tc tc-id2
tc tc-id1: Specifies the ID of the new member, in the range of 1 to 255.
faulty-tc tc-id2: Specifies the ID of the faulty member, in the range of 1 to 255.
Before you execute this command, perform the following tasks:
# Replace faulty member 5 with new member 10.
[Sysname] winet replace tc 10 faulty-tc 5
winet tc boot-loader
Use winet tc boot-loader to specify the upgrade startup software files for a member.
Use undo winet tc boot-loader to remove the configuration.
winet tc tc-id boot-loader { ipe-filename | boot boot-filename system system-filename }
undo winet tc tc-id boot-loader
tc tc-id: Specifies a member by its ID in the range of 1 to 255.
# Specify upgrade boot image boot.bin and upgrade system image system.bin for member 1.
[Sysname] winet tc 1 boot-loader boot boot.bin system system.bin
display winet tc
winet tc device-type
Use winet tc device-type to define a member type on the commander.
Use undo winet tc device-type to delete a member type.
winet tc sysoid sysoid device-type device-type
undo winet tc sysoid sysoid device-type device-type
sysoid sysoid: Specifies the SYSOID of a member.
device-type device-type: Specifies a member type.
A device type can correspond to multiple device models. You can identify different device models with different SYSOIDs by specifying a SYSOID for each device model. The commander identifies member types by SYSOID.
The system predefines the device types for some device models based on SYSOIDs. For device models without predefined device types, you must define their member types by SYSOID manually. If you do not do so, the commander cannot identify the types of such devices.
You cannot modify the predefined device types.
Before defining a device type for a member, you can use the display winet tc command to determine whether the member has a predefined one.
·     If the member has been predefined with one device type, the DeviceType field displays the actual predefined device type.
·     If the member does not have a predefined device type, the DeviceType field displays unknown.
To obtain the SYSOID of a member, use the display winet tc verbose command.
# Define a member type by specifying the SYSOID as 1.3.6.1.4.1.25506.1.1588 and the member type as SW.
[Sysname] winet tc sysoid 1.3.6.1.4.1.25506.1.1588 device-type SW
winet tc password
Use winet tc password to modify the password for the default user (admin) on members.
Use undo winet tc password to restore the default.
winet tc password [ cipher ] string
The password for the default user on members is admin.
cipher: Specifies a password in encrypted form. If you do not specify this keyword, the command creates a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
The cipher keyword is supported only in Release 6328 and later.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 33 to 117 characters.
During WiNet network establishment, the commander establishes NETCONF sessions to members and adds them to the network. The default username and password on the members for NETCONF session establishment are admin and admin. To enhance security, you can perform this task to change the password for the default user admin of the members after the commander adds the members to the network.
If the default password cannot meet the password complexity requirements on members, you cannot execute the undo smartmc tc password command to restore the default.
Do not modify the password for members that are manually added to the WiNet network. If you modify the password for a manually added member, you will not be able to manage that member from the commander.
# Configure default user admin on members to use plaintext password hello12345.
[Sysname] smartmc tc password hello12345
winet tc startup-configuration
Use winet tc startup-configuration to specify the upgrade configuration file for a member.
Use undo winet tc startup-configuration to remove the configuration.
winet tc tc-id startup-configuration cfg-filename
undo winet tc tc-id startup-configuration
cfg-filename: Specifies a configuration file by its name, a case-insensitive string of 5 to 45 characters. The file name must include the .cfg extension.
# Specify upgrade configuration file startup.cfg for member 1.
[Sysname] winet tc 1 startup-configuration startup.cfg
display winet tc
Use winet topology-refresh to manually refresh the network topology.
To display topology changes, use this command to manually refresh the topology.
# Manually refresh the network topology.
<Sysname> winet topology-refresh
Use winet topology-refresh interval to set the automatic network topology refresh interval.
Use undo winet topology-refresh interval to restore the default.
winet topology-refresh interval interval
The automatic network topology refresh interval is 60 seconds.
interval: Specifies the automatic network topology refresh interval in the range of 60 to 300 seconds.
# Set the automatic network topology refresh interval to 100 seconds.
[Sysname] winet topology-refresh interval 100
winet topology-save
Use winet topology-save to save the current network topology.
winet topology-save
This task allows you to save the current network topology to the topology.dba file in the flash memory. After the commander reboots, it uses the topology.dba file to restore the network topology.
# Save the current network topology
[Sysname] winet topology-save
Use winet upgrade boot-loader to upgrade the startup software on a list of members or WiNet groups.
Use undo winet upgrade delete the startup software upgrade task.
winet upgrade boot-loader { group | tc } list [ delay minutes | time time ]
winet upgrade boot-loader { group | tc } { list { boot boot-filename system system-filename | file ipe-filename } }&<1-40> [ delay delay-time | time time ]
undo winet upgrade
group: Specifies the WiNet groups to be upgraded.
tc: Specifies the members to be upgraded.
list: Specifies a space-separated list of up to 10 member items or WiNet group items.
·     WiNet group—Each item specifies a WiNet group name, a case-sensitive string of 1 to 31 characters.
·     Member—Each item specifies a member ID or a range of member IDs in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 1 to 255.
boot boot-filename: Specifies a boot image by its name.
system system-filename: Specifies a system image by its name.
file ipe-filename: Specifies an IPE file by its name, a case-insensitive string of 5 to 45 characters.
delay delay-time: Specifies the upgrade delay time in the range of 1 to 1440 minutes.
time in-time: Specifies the upgrade time in the format of hh:mm. The value range for the hh argument is 0 to 23 hours. The value range for the mm argument is 0 to 59 minutes.
CAUTION
CAUTION:
Upgrading the startup software might interrupt services. Before upgrading the startup software, make sure no services will be interrupted.
To use this command to upgrade the startup software on members without specifying the upgrade files, you must first perform one of the following tasks:
·     Execute the winet tc boot-loader command to specify the upgrade files for members.
·     Execute the boot-loader command to specify the upgrade files for a WiNet group.
A member can perform only one upgrade task at a time.
If you execute this command without specifying the delay time or update time, the members or WiNet group immediately upgrades the startup software and the upgrade operation cannot be cancelled. If you specify a delay time or upgrade time to perform a scheduled upgrade, the upgrade operation can be cancelled by using the undo winet upgrade command before it starts.
# Upgrade startup software images boot.bin and sys.bin on all members in WiNet groups test1 and test2.
[Sysname] winet upgrade boot-loader group test1 test2 boot boot.bin system sys.bin
boot-loader
winet upgrade startup-configuration
Use winet upgrade startup-configuration to upgrade the configuration file on a list of members or on all members in WiNet groups.
Use undo winet upgrade delete the configuration file upgrade task.
winet upgrade startup-configuration { group | tc } list [ delay minutes | time time ]
winet upgrade startup-configuration group { list file cfg-filename }&<1-40> [ delay delay-time | time time ]
winet upgrade startup-configuration tc { list cfg-filename }&<1-40> [ delay delay-time | time time ]
undo winet upgrade
file cfg-filename: Specifies a configuration file by its name.
The file keyword needs to be entered only in Release 6328 and later.
CAUTION
CAUTION:
After you update the configuration file, the configuration in the new configuration file will become the running configuration. Before upgrading the configuration file, make sure the contents of the new configuration file are correct.
To use this command to upgrade the configuration file on members without specifying the upgrade file, you must first perform one of the following tasks:
·     Execute the winet tc startup-configuration command to specify the upgrade file for members.
·     Execute the startup-configuration command to specify the upgrade file for a WiNet group.
If you execute this command without specifying the delay time or update time, the members or WiNet group immediately upgrades the configuration file and the upgrade operation cannot be cancelled. If you specify a delay time or upgrade time to perform a scheduled upgrade, the upgrade operation can be cancelled by using the undo winet upgrade command before it starts.
# Upgrade configuration file startup.cfg on all members in WiNet groups test1 and test2.
[Sysname] winet upgrade boot-loader group test1 test2 startup.cfg
boot-loader
winet vlan
Use winet vlan to create a VLAN for members.
winet vlan vlan-id { group group-name-list | tc tc-id-list }
vlan-id: Specifies the VLAN ID in the range of 1 to 4094.
group group-name-list: Specifies the WiNet groups for which the VLAN is created. You can specify a space-separated list of up to 10 WiNet groups. The group name is a case-sensitive string of 1 to 31 characters.
tc tc-id-list: Specifies the members for which the VLAN is created. You can specify a space-separated list of up to 10 member items. Each item specifies a member or a range of members in the form of tc-id1 to tc-id2. The value for tc-id2 must be greater than or equal to the value for tc-id1. The value range for the tc-id argument is 1 to 255.
Execute this command when the network topology is stable. As a best practice, use the winet topology-refresh command to refresh the network topology before executing this command.
After you execute this command, all access ports on members except the following access ports are assigned to the VLAN:
·     Access ports connecting to the commander.
·     Access ports connecting to other members.
·     Access ports connecting to offline devices. Remove offline devices before configuring this command.
If the VLAN is successfully created but some access ports of a member cannot be assigned to the VLAN, the VLAN memberships of the member is restored to the state before the VLAN is created.
The failure to assign an access port of a member to the created VLAN does not affect the VLAN assignment for other members.
After command execution, you can use the display winet vlan command to examine the VLAN creation result.
# Create a VLAN for member 1 and member 2.
[Sysname] winet vlan 2 tc 1 to 2
As a best practice, execute the display winet vlan command to verify that the VLAN has been created successfully.
Use startup-configuration to specify an upgrade configuration file for a WiNet group .
Use undo startup-configuration to restore the default.
startup-configuration cfgfile
No upgrade configuration file is specified for the WiNet group.
WiNet group view
cfgfile: Specifies a configuration file by its name, a string of 5 to 45 characters. The file name must include the .cfg extension.
# Specify configuration file startup.cfg for WiNet group testgroup.
[Sysname-winet-group-testgroup] startup-configuration startup.cfg
winet group
