- 09-MPLS Configuration Guide
- 01-Basic MPLS configuration
- 02-IPv6 MPLS L3VPN configuration examples
- 03-IPv6 MPLS L3VPN configuration
- 04-L2VPN access to L3VPN or IP backbone configuration
- 05-LDP configuration
- 06-MCE configuration
- 07-MPLS L2VPN configuration examples
- 08-MPLS L2VPN configuration
- 09-MPLS L3VPN configuration examples
- 10-MPLS L3VPN configuration
- 11-MPLS OAM configuration
- 12-MPLS TE configuration
- 13-RSVP configuration
- 14-Static CRLSP configuration
- 15-Static LSP configuration
- 16-Tunnel policy configuration
- 17-VPLS configuration examples
- 18-VPLS configuration
| 17-VPLS configuration examples | 467.26 KB |
Configuring VPLS
Example: Configuring static PWs
Configure a VSI on each PE, and establish static PWs between the PEs to interconnect the CEs.
Figure 1 Network diagram
Table 1 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Ten-GigabitEthernet3/0/1 |
Interface2 |
Ten-GigabitEthernet3/0/2 |
Interface3 |
Ten-GigabitEthernet3/0/3 |
1. Configure PE 1:
# Configure an LSR ID.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
# Enable L2VPN.
[PE1] l2vpn enable
# Enable global LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to PE 2), and enable LDP on the interface.
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip address 20.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/2] mpls enable
[PE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[PE1-Ten-GigabitEthernet3/0/2] quit
# Configure Ten-GigabitEthernet 3/0/3 (the interface connected to PE 3), and enable LDP on the interface.
[PE1] interface ten-gigabitethernet 3/0/3
[PE1-Ten-GigabitEthernet3/0/3] ip address 30.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/3] mpls enable
[PE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
[PE1-Ten-GigabitEthernet3/0/3] quit
# Configure OSPF for LDP to create LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Create a VSI, specify the peer PEs, and establish static PWs to the peer PEs.
[PE1] vsi svc
[PE1-vsi-svc] pwsignaling static
[PE1-vsi-svc-static] peer 2.2.2.9 pw-id 3 in-label 100 out-label 100
[PE1-vsi-svc-static-2.2.2.9-3] quit
[PE1-vsi-svc-static] peer 3.3.3.9 pw-id 3 in-label 200 out-label 200
[PE1-vsi-svc-static-3.3.3.9-3] quit
[PE1-vsi-svc-static] quit
[PE1-vsi-svc] quit
# Bind interface Ten-GigabitEthernet 3/0/1 to VSI svc.
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] xconnect vsi svc
[PE1-Ten-GigabitEthernet3/0/1] quit
2. Configure PE 2:
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
# Configure Ten-GigabitEthernet 3/0/2 (the interface connected to PE 1), and enable LDP on the interface.
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip address 20.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/2] mpls enable
[PE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/2] quit
[PE2] interface ten-gigabitethernet 3/0/3
[PE2-Ten-GigabitEthernet3/0/3] ip address 40.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/3] mpls enable
[PE2-Ten-GigabitEthernet3/0/3] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
[PE2] vsi svc
[PE2-vsi-svc] pwsignaling static
[PE2-vsi-svc-static] peer 1.1.1.9 pw-id 3 in-label 100 out-label 100
[PE2-vsi-svc-static-1.1.1.9-3] quit
[PE2-vsi-svc-static] peer 3.3.3.9 pw-id 3 in-label 300 out-label 300
[PE2-vsi-svc-static-3.3.3.9-3] quit
[PE2-vsi-svc-static] quit
[PE2-vsi-svc] quit
# Bind interface Ten-GigabitEthernet 3/0/1 toVSI svc.
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] xconnect vsi svc
[PE2-Ten-GigabitEthernet3/0/1] quit
3. Configure PE 3:
[Sysname] sysname PE3
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 3.3.3.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 3.3.3.9
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] interface ten-gigabitethernet 3/0/2
[PE3-Ten-GigabitEthernet3/0/2] ip address 30.1.1.3 24
[PE3-Ten-GigabitEthernet3/0/2] mpls enable
[PE3-Ten-GigabitEthernet3/0/2] mpls ldp enable
[PE3-Ten-GigabitEthernet3/0/2] quit
# Configure Ten-GigabitEthernet 3/0/3 (the interface connected to PE 2), and enable LDP on the interface.
[PE3] interface ten-gigabitethernet 3/0/3
[PE3-Ten-GigabitEthernet3/0/3] ip address 40.1.1.3 24
[PE3-Ten-GigabitEthernet3/0/3] mpls enable
[PE3-Ten-GigabitEthernet3/0/3] mpls ldp enable
[PE3-Ten-GigabitEthernet3/0/3] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE3-ospf-1] quit
[PE3] vsi svc
[PE3-vsi-svc] pwsignaling static
[PE3-vsi-svc-static] peer 1.1.1.9 pw-id 3 in-label 200 out-label 200
[PE3-vsi-svc-static-1.1.1.9-3] quit
[PE3-vsi-svc-static] peer 2.2.2.9 pw-id 3 in-label 300 out-label 300
[PE3-vsi-svc-static-2.2.2.9-3] quit
[PE3-vsi-svc-static] quit
[PE3-vsi-svc] quit
[PE3] interface ten-gigabitethernet 3/0/1
[PE3-Ten-GigabitEthernet3/0/1] xconnect vsi svc
[PE3-Ten-GigabitEthernet3/0/1] quit
# Verify that two static PWs in up state have been established on PE 1.
[PE1] display l2vpn pw verbose
VSI Name: svc
Peer: 2.2.2.9 PW ID: 3
Signaling Protocol : Static
Link ID : 8 PW State : Up
In Label : 100 Out Label: 100
MTU : 1500
PW Attributes : Main
VCCV CC : -
VCCV BFD : -
Flow Label : -
Control Word : Disabled
Tunnel Group ID : 0x160000001
Tunnel NHLFE IDs : 1027
Admin PW : -
Peer: 3.3.3.9 PW ID: 3
Link ID : 9 PW State : Up
In Label : 200 Out Label: 200
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x260000002
Tunnel NHLFE IDs : 1028
Admin PW : -
Configuration files
· PE 1
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
l2vpn enable
vsi svc
pwsignaling static
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
interface Ten-GigabitEthernet3/0/2
ip address 20.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/3
ip address 30.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/1
port link-mode route
xconnect vsi svc
return
· PE 2
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
l2vpn enable
vsi svc
pwsignaling static
controller E1 0013
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
ip address 20.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 40.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
xconnect vsi svc
return
· PE 3
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
l2vpn enable
vsi svc
pwsignaling static
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ip address 30.1.1.3 255.255.255.0
mpls enable
mpls ldp enable
ip address 40.1.1.3 255.255.255.0
mpls enable
mpls ldp enable
xconnect vsi svc
return
Example: Configuring LDP PWs
Configure a VSI on each PE, and establish LDP PWs between the PEs to interconnect the CEs.
Figure 2 Network diagram
Table 2 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Interface3 |
1. Configure an IGP and public tunnels. (Details not shown.)
2. Configure PE 1:
# Configure basic MPLS.
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure Ten-GigabitEthernet3/0/2 (the interface connected to PE 2), and enable LDP on the interface.
# Configure Ten-GigabitEthernet3/0/3 (the interface connected to PE 3), and enable LDP on the interface.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa] pwsignaling ldp
[PE1-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[PE1-vsi-aaa-ldp-2.2.2.9-500] quit
[PE1-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[PE1-vsi-aaa-ldp-3.3.3.9-500] quit
[PE1-vsi-aaa-ldp] quit
[PE1-vsi-aaa] quit
# Bind interface Ten-GigabitEthernet 3/0/1 to VSI aaa.
[PE1-Ten-GigabitEthernet3/0/1] xconnect vsi aaa
3. Configure PE 2:
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Configure Ten-GigabitEthernet3/0/2 (the interface connected to PE 1), and enable LDP on the interface.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa] pwsignaling ldp
[PE2-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500
[PE2-vsi-aaa-ldp-1.1.1.9-500] quit
[PE2-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[PE2-vsi-aaa-ldp-3.3.3.9-500] quit
[PE2-vsi-aaa-ldp] quit
[PE2-vsi-aaa] quit
[PE2-Ten-GigabitEthernet3/0/1] xconnect vsi aaa
4. Configure PE 3:
[PE3] mpls ldp
[PE3-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
# Configure Ten-GigabitEthernet3/0/3 (the interface connected to PE 2), and enable LDP on the interface.
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa] pwsignaling ldp
[PE3-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500
[PE3-vsi-aaa-ldp-1.1.1.9-500] quit
[PE3-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[PE3-vsi-aaa-ldp-2.2.2.9-500] quit
[PE3-vsi-aaa-ldp] quit
[PE3-vsi-aaa] quit
[PE3-Ten-GigabitEthernet3/0/1] xconnect vsi aaa
# Verify that two LDP PWs in up state have been established on PE 1.
VSI Name: aaa
Peer: 2.2.2.9 PW ID: 500
Signaling Protocol : LDP
In Label : 1279 Out Label: 1279
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x260000000
Admin PW : -
Peer: 3.3.3.9 PW ID: 500
In Label : 1278 Out Label: 1277
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x360000001
Tunnel NHLFE IDs : 1029
Admin PW : -
Configuration files
· PE 1
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
return
· PE 2
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
return
· PE 3
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
return
Example: Configuring BGP PWs
Configure a VSI on each PE, and establish BGP PWs between the PEs to interconnect CEs.
Figure 3 Network diagram
Table 3 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Interface3 |
1. Configure PE 1:
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Establish IBGP connections to PE 2 and PE 3, and use BGP to advertise VPLS label block information.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default] address-family l2vpn
[PE1-bgp-default-l2vpn] peer 2.2.2.9 enable
[PE1-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-default-l2vpn] quit
[PE1-bgp-default] quit
# Configure VSI aaa to use BGP to establish BGP PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa] auto-discovery bgp
[PE1-vsi-aaa-auto] route-distinguisher 1:1
[PE1-vsi-aaa-auto] vpn-target 1:1
[PE1-vsi-aaa-auto] signaling-protocol bgp
[PE1-vsi-aaa-auto-bgp] site 1 range 10 default-offset 0
[PE1-vsi-aaa-auto-bgp] quit
[PE1-vsi-aaa-auto] quit
[PE1-vsi-aaa] quit
2. Configure PE 2:
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Establish IBGP connections to PE 1 and PE 3, and use BGP to advertise VPLS label block information.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] peer 3.3.3.9 as-number 100
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn
[PE2-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE2-bgp-default-l2vpn] quit
[PE2-bgp-default] quit
# Configure VSI aaa to use BGP to establish BGP PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa] auto-discovery bgp
[PE2-vsi-aaa-auto] route-distinguisher 1:1
[PE2-vsi-aaa-auto] vpn-target 1:1
[PE2-vsi-aaa-auto] signaling-protocol bgp
[PE2-vsi-aaa-auto-bgp] site 2 range 10 default-offset 0
[PE2-vsi-aaa-auto-bgp] quit
[PE2-vsi-aaa-auto] quit
[PE2-vsi-aaa] quit
3. Configure PE 3:
[PE3] mpls ldp
[PE3-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
# Establish IBGP connections to PE 1 and PE 2, and use BGP to advertise VPLS label block information.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default] peer 2.2.2.9 as-number 100
[PE3-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-default] address-family l2vpn
[PE3-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE3-bgp-default-l2vpn] peer 2.2.2.9 enable
[PE3-bgp-default-l2vpn] quit
[PE3-bgp-default] quit
# Configure VSI aaa to use BGP to establish BGP PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa] auto-discovery bgp
[PE3-vsi-aaa-auto] route-distinguisher 1:1
[PE3-vsi-aaa-auto] vpn-target 1:1
[PE3-vsi-aaa-auto] signaling-protocol bgp
[PE3-vsi-aaa-auto-bgp] site 3 range 10 default-offset 0
[PE3-vsi-aaa-auto-bgp] quit
[PE3-vsi-aaa-auto] quit
[PE3-vsi-aaa] quit
# Verify that two BGP PWs in up state have been established on PE 1.
VSI Name: aaa
Peer: 2.2.2.9 Remote Site: 2
Signaling Protocol : BGP
In Label : 1295 Out Label: 1025
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x800000160000001
Admin PW : -
Peer: 3.3.3.9 Remote Site: 3
Link ID : 10 PW State : Up
In Label : 1296 Out Label: 1025
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x800000060000000
Tunnel NHLFE IDs : 1026
Admin PW : -
# Display VPLS label block information received from PE 2 and PE 3 on PE 1.
[PE1] display l2vpn bgp verbose
VSI Name: aaa
Remote Site ID : 2
Offset : 0
RD : 1:1
PW State : Up
Encapsulation : BGP-VPLS
MTU : 1500
Nexthop : 2.2.2.9
Local VC Label : 1295
Remote VC Label : 1025
Local Control Word : Disabled
Remote Control Word: Disabled
Link ID : 9
Local Label Block : 1293/10/0
Remote Label Block : 1024/10/0
Local Flow Label : -
Reomote Flow Label : -
Export Route Target: 1:1
Remote Site ID : 3
Offset : 0
RD : 1:1
PW State : Up
MTU : 1500
Nexthop : 3.3.3.9
Local VC Label : 1296
Link ID : 10
Configuration files
· PE 1
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
l2vpn enable
vsi aaa
auto-discovery bgp
vpn-target 1:1 export-extcommunity
vpn-target 1:1 import-extcommunity
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
bgp 100
peer 2.2.2.9 connect-interface LoopBack0
peer 3.3.3.9 connect-interface LoopBack0
peer 2.2.2.9 enable
peer 3.3.3.9 enable
return
· PE 2
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
l2vpn enable
vsi aaa
auto-discovery bgp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
peer 3.3.3.9 enable
return
· PE 3
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
l2vpn enable
vsi aaa
auto-discovery bgp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
bgp 100
peer 1.1.1.9 enable
peer 2.2.2.9 enable
return
Example: Configuring BGP auto-discovery LDP PWs
Configure a VSI on each PE. Use BGP to discover remote PEs and use LDP to create PWs among PEs so CEs in different sites of VPN 1 can communicate with each other.
Figure 4 Network diagram
Table 4 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Interface3 |
1. Configure PE 1:
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Establish IBGP connections to PE 1 and PE 2, and use BGP to advertise VPLS PE information.
[PE1] bgp 100
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa-auto] signaling-protocol ldp
[PE1-vsi-aaa-auto-ldp] vpls-id 100:100
[PE1-vsi-aaa-auto-ldp] quit
[PE1-vsi-aaa] quit
2. Configure PE 2:
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Establish IBGP connections to PE 1 and PE 3, and use BGP to advertise VPLS PE information.
[PE2] bgp 100
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa-auto] signaling-protocol ldp
[PE2-vsi-aaa-auto-ldp] vpls-id 100:100
[PE2-vsi-aaa-auto-ldp] quit
[PE2-vsi-aaa] quit
3. Configure PE 3:
[PE3] mpls ldp
[PE3-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
[PE3] bgp 100
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa-auto] signaling-protocol ldp
[PE3-vsi-aaa-auto-ldp] vpls-id 100:100
[PE3-vsi-aaa-auto-ldp] quit
[PE3-vsi-aaa] quit
# Verify that two PWs in up state have been established on PE 1.
VSI Name: aaa
Peer: 2.2.2.9 VPLS ID: 100:100
In Label : 1555 Out Label: 1555
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
Peer: 3.3.3.9 VPLS ID: 100:100
In Label : 1554 Out Label: 1416
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel NHLFE IDs : 1030
Admin PW : -
# Display LDP PW label information on PE 1.
[PE1] display l2vpn ldp verbose
VSI Name: aaa
PW State: Up
PW Status Communication: Notification method
PW ID FEC (Local/Remote):
Local AII : (1.1.1.9, 2.2.2.9)
Remote AII : (2.2.2.9, 1.1.1.9)
PW Type : VLAN/VLAN
Group ID : 0/0
Label : 1555/1555
Control Word: Disabled/Disabled
VCCV CV Type: -/-
VCCV CC Type: -/-
Flow Label : -/-
MTU : 1500/1500
PW Status : PW forwarding/PW forwarding
VSI Name: aaa
PW State: Up
Local AII : (1.1.1.9, 3.3.3.9)
Remote AII : (3.3.3.9, 1.1.1.9)
PW Type : VLAN/VLAN
Group ID : 0/0
Label : 1554/1416
VCCV CV Type: -/-
VCCV CC Type: -/-
Flow Label : -/-
MTU : 1500/1500
Configuration files
· PE 1
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
l2vpn enable
vsi aaa
auto-discovery bgp
vpls-id 100:100
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
bgp 100
peer 2.2.2.9 enable
peer 3.3.3.9 enable
return
· PE 2
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
l2vpn enable
vsi aaa
auto-discovery bgp
vpls-id 100:100
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
bgp 100
peer 1.1.1.9 enable
peer 3.3.3.9 enable
return
· PE 3
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
l2vpn enable
vsi aaa
auto-discovery bgp
vpls-id 100:100
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
bgp 100
peer 1.1.1.9 enable
peer 2.2.2.9 enable
return
Example: Configuring H-VPLS using MPLS access
Configure an H-VPLS network using MPLS access to avoid full-mesh PW configuration. The H-VPLS uses LDP as the PW signaling protocol.
Figure 5 Network diagram
Table 5 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Interface3 |
1. Configure UPE:
[Sysname] sysname UPE
[UPE] interface loopback 0
[UPE-LoopBack0] ip address 1.1.1.9 32
[UPE-LoopBack0] quit
[UPE] mpls lsr-id 1.1.1.9
[UPE] mpls ldp
[UPE-ldp] quit
# Enable L2VPN.
[UPE] l2vpn enable
# Configure Ten-GigabitEthernet3/0/2 (the interface connected to NPE 1), and enable LDP on the interface.
[UPE] interface ten-gigabitethernet 3/0/2
[UPE-Ten-GigabitEthernet3/0/2] ip address 10.1.1.1 24
[UPE-Ten-GigabitEthernet3/0/2] mpls enable
[UPE-Ten-GigabitEthernet3/0/2] mpls ldp enable
[UPE-Ten-GigabitEthernet3/0/2] quit
[UPE] ospf
[UPE-ospf-1] area 0
[UPE-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[UPE-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[UPE-ospf-1-area-0.0.0.0] quit
[UPE-ospf-1] quit
# Configure VSI aaa to use LDP to establish a U-PW to NPE 1.
[UPE] vsi aaa
[UPE-vsi-aaa] pwsignaling ldp
[UPE-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[UPE-vsi-aaa-ldp-2.2.2.9-500] quit
[UPE-vsi-aaa-ldp] quit
[UPE-vsi-aaa] quit
[UPE] interface ten-gigabitethernet 3/0/1
[UPE-Ten-GigabitEthernet3/0/1] xconnect vsi aaa
[UPE-Ten-GigabitEthernet3/0/1] quit
2. Configure NPE 1:
# Configure IS-IS for LDP to create LSPs.
[Sysname] sysname NPE1
[NPE1] isis 1
[NPE1-isis-1] is-level level-1
[NPE1-isis-1] network-entity 10.0000.0000.0001.00
[NPE1-isis-1] quit
[NPE1] interface loopback 0
[NPE1-LoopBack0] ip address 2.2.2.9 32
[NPE1-LoopBack0] isis enable 1
[NPE1-LoopBack0] quit
[NPE1] mpls lsr-id 2.2.2.9
[NPE1] mpls ldp
[NPE1–ldp] quit
# Enable L2VPN.
[NPE1] l2vpn enable
[NPE1] ospf
[NPE1-ospf-1] area 0
[NPE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[NPE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[NPE1-ospf-1-area-0.0.0.0] quit
[NPE1-ospf-1] quit
# Configure Ten-GigabitEthernet3/0/1 (the interface connected to the UPE), and enable LDP on the interface.
[NPE1] interface ten-gigabitethernet 3/0/1
[NPE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.2 24
[NPE1-Ten-GigabitEthernet3/0/1] mpls enable
[NPE1-Ten-GigabitEthernet3/0/1] mpls ldp enable
[NPE1-Ten-GigabitEthernet3/0/2] quit
# Configure Ten-GigabitEthernet3/0/2 (the interface connected to the NPE 3), and enable LDP on the interface.
[NPE1] interface ten-gigabitethernet 3/0/2
[NPE1-Ten-GigabitEthernet3/0/2] ip address 30.1.1.1 24
[NPE1-Ten-GigabitEthernet3/0/2] mpls enable
[NPE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[NPE1-Ten-GigabitEthernet3/0/2] isis enable 1
# Configure Ten-GigabitEthernet3/0/3 (the interface connected to the NPE 2), and enable LDP on the interface.
[NPE1] interface ten-gigabitethernet 3/0/3
[NPE1-Ten-GigabitEthernet3/0/3] ip address 20.1.1.1 24
[NPE1-Ten-GigabitEthernet3/0/3] mpls enable
[NPE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
[NPE1-Ten-GigabitEthernet3/0/3] isis enable 1
[NPE1-Ten-GigabitEthernet3/0/3] quit
# Configure VSI aaa that uses LDP as the PW signaling protocol, establish a U-PW to the UPE, and establish N-PWs to NPE 2 and NPE 3.
[NPE1] vsi aaa
[NPE1-vsi-aaa] pwsignaling ldp
[NPE1-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500 no-split-horizon
[NPE1-vsi-aaa-ldp-1.1.1.9-500] quit
[NPE1-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[NPE1-vsi-aaa-ldp-3.3.3.9-500] quit
[NPE1-vsi-aaa-ldp] peer 4.4.4.9 pw-id 500
[NPE1-vsi-aaa-ldp-4.4.4.9-500] quit
[NPE1-vsi-aaa-ldp] quit
[NPE1-vsi-aaa] quit
3. Configure NPE 2:
[Sysname] sysname NPE2
[NPE2] isis 1
[NPE2-isis-1] is-level level-1
[NPE2-isis-1] network-entity 10.0000.0000.0002.00
[NPE2-isis-1] quit
[NPE2] interface loopback 0
[NPE2-LoopBack0] ip address 3.3.3.9 32
[NPE2-LoopBack0] isis enable 1
[NPE2-LoopBack0] quit
[NPE2] mpls lsr-id 3.3.3.9
[NPE2] mpls ldp
[NPE2–ldp] quit
# Enable L2VPN.
[NPE2] l2vpn enable
# Configure Ten-GigabitEthernet3/0/2 (the interface connected to the NPE 1), and enable LDP on the interface.
[NPE2] interface ten-gigabitethernet 3/0/2
[NPE2-Ten-GigabitEthernet3/0/2] ip address 20.1.1.2 24
[NPE2-Ten-GigabitEthernet3/0/2] mpls enable
[NPE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
[NPE2-Ten-GigabitEthernet3/0/2] isis enable 1
[NPE2-Ten-GigabitEthernet3/0/2] quit
# Configure Ten-GigabitEthernet3/0/3 (the interface connected to the NPE 3), and enable LDP on the interface.
[NPE2] interface ten-gigabitethernet 3/0/3
[NPE2-Ten-GigabitEthernet3/0/3] ip address 40.1.1.1 24
[NPE2-Ten-GigabitEthernet3/0/3] mpls enable
[NPE2-Ten-GigabitEthernet3/0/3] mpls ldp enable
[NPE2-Ten-GigabitEthernet3/0/3] isis enable 1
[NPE2-Ten-GigabitEthernet3/0/3] quit
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish N-PWs to NPE 1 and NPE 3.
[NPE2] vsi aaa
[NPE2-vsi-aaa] pwsignal ldp
[NPE2-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[NPE2-vsi-aaa-ldp-2.2.2.9-500] quit
[NPE2-vsi-aaa-ldp] peer 4.4.4.9 pw-id 500
[NPE2-vsi-aaa-ldp-4.4.4.9-500] quit
[NPE2-vsi-aaa-ldp] quit
[NPE2-vsi-aaa] quit
[NPE2] interface ten-gigabitethernet 3/0/1
[NPE2-Ten-GigabitEthernet3/0/1] xconnect vsi aaa
[NPE2-Ten-GigabitEthernet3/0/1] quit
4. Configure NPE 3:
[Sysname] sysname NPE3
[NPE3] isis 1
[NPE3-isis-1] is-level level-1
[NPE3-isis-1] network-entity 10.0000.0000.0003.00
[NPE3-isis-1] quit
<NPE3> system-view
[NPE3] interface loopback 0
[NPE3-LoopBack0] ip address 4.4.4.9 32
[NPE3-LoopBack0] isis enable 1
[NPE3-LoopBack0] quit
[NPE3] mpls lsr-id 4.4.4.9
[NPE3] mpls ldp
[NPE3–ldp] quit
# Enable L2VPN.
[NPE3] l2vpn enable
[NPE3] interface ten-gigabitethernet 3/0/2
[NPE3-Ten-GigabitEthernet3/0/2] ip address 30.1.1.2 24
[NPE3-Ten-GigabitEthernet3/0/2] mpls enable
[NPE3-Ten-GigabitEthernet3/0/2] mpls ldp enable
[NPE3-Ten-GigabitEthernet3/0/2] isis enable 1
[NPE3-Ten-GigabitEthernet3/0/2] quit
[NPE3] interface ten-gigabitethernet 3/0/3
[NPE3-Ten-GigabitEthernet3/0/3] ip address 40.1.1.2 24
[NPE3-Ten-GigabitEthernet3/0/3] mpls enable
[NPE3-Ten-GigabitEthernet3/0/3] mpls ldp enable
[NPE3-Ten-GigabitEthernet3/0/3] isis enable 1
[NPE3-Ten-GigabitEthernet3/0/3] quit
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish N-PWs to NPE 1 and NPE 2.
[NPE3] vsi aaa
[NPE3-vsi-aaa] pwsignal ldp
[NPE3-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[NPE3-vsi-aaa-ldp-2.2.2.9-500] quit
[NPE3-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[NPE3-vsi-aaa-ldp-3.3.3.9-500] quit
[NPE3-vsi-aaa-ldp] quit
[NPE3-vsi-aaa] quit
[NPE3] interface ten-gigabitethernet 3/0/1
[NPE3-Ten-GigabitEthernet3/0/1] xconnect vsi aaa
[NPE3-Ten-GigabitEthernet3/0/1] quit
# Verify that PWs in up state have been established on each PE.
[UPE] display l2vpn pw verbose
VSI Name: aaa
In Label : 1277 Out Label: 1277
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x460000000
Admin PW : -
[NPE1] display l2vpn pw verbose
VSI Name: aaa
Peer: 1.1.1.9 PW ID: 500
MTU : 1500
PW Attributes : Main, No-split-horizon
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
In Label : 1276 Out Label: 1275
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x560000001
Tunnel NHLFE IDs : 1031
Admin PW : -
Peer: 4.4.4.9 PW ID: 500
In Label : 1278 Out Label: 1279
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x570000001
Tunnel NHLFE IDs : 1032
Admin PW : -
[NPE2] display l2vpn pw verbose
VSI Name: aaa
In Label : 1275 Out Label: 1276
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x660000000
Admin PW : -
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x670000000
Admin PW : -
[NPE3] display l2vpn pw verbose
VSI Name: aaa
In Label : 1279 Out Label: 1278
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
Configuration files
· NPE 1
sysname NPE1
isis 1
is-level level-1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
isis enable 1
mpls enable
mpls ldp enable
isis enable 1
mpls enable
mpls ldp enable
isis enable 1
mpls enable
mpls ldp enable
return
· NPE 2
sysname NPE2
isis 1
is-level level-1
mpls lsr-id 3.3.3.9
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
ip address 40.1.1.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
xconnect vsi aaa
return
· NPE 3
sysname NPE3
isis 1
is-level level-1
mpls lsr-id 4.4.4.9
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
ip address 4.4.4.9 255.255.255.255
isis enable 1
ip address 30.1.1.2 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
isis enable 1
mpls enable
mpls ldp enable
xconnect vsi aaa
return
· UPE
sysname UPE
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
mpls enable
mpls ldp enable
xconnect vsi aaa
return
Example: Configuring hub-spoke VPLS
Configure a hub-spoke VPLS network to centralize management of the traffic from each site. The VPLS uses LDP as the PW signaling protocol.
Figure 6 Network diagram
Table 6 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Interface3 |
1. Configure Spoke-PE 1:
[Sysname] sysname Spoke-PE1
[Spoke-PE1] interface loopback 0
[Spoke-PE1-LoopBack0] ip address 1.1.1.9 32
[Spoke-PE1-LoopBack0] quit
[Spoke-PE1] mpls lsr-id 1.1.1.9
[Spoke-PE1] mpls ldp
[Spoke-PE1-ldp] quit
# Enable L2VPN.
[Spoke-PE1] l2vpn enable
# Configure Ten-GigabitEthernet3/0/2 (the interface connected to Hub-PE), and enable LDP on the interface.
[Spoke-PE1] interface ten-gigabitethernet 3/0/2
[Spoke-PE1-Ten-GigabitEthernet3/0/2] ip address 10.1.1.1 24
[Spoke-PE1-Ten-GigabitEthernet3/0/2] mpls enable
[Spoke-PE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[Spoke-PE1-Ten-GigabitEthernet3/0/2] quit
[Spoke-PE1] ospf
[Spoke-PE1-ospf-1] area 0
[Spoke-PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[Spoke-PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[Spoke-PE1-ospf-1-area-0.0.0.0] quit
[Spoke-PE1-ospf-1] quit
# Create VSI aaa, enable hub-spoke capability for the VSI, specify the PW signaling protocol as LDP, establish a PW to Hub-PE, and specify the PW as the hub link.
[Spoke-PE1] vsi aaa hub-spoke
[Spoke-PE1-vsi-aaa] pwsignaling ldp
[Spoke-PE1-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500 hub
[Spoke-PE1-vsi-aaa-ldp-3.3.3.9-500] quit
[Spoke-PE1-vsi-aaa-ldp] quit
[Spoke-PE1-vsi-aaa] quit
[Spoke-PE1] interface ten-gigabitethernet 3/0/1
[Spoke-PE1-Ten-GigabitEthernet3/0/1] xconnect vsi aaa
[Spoke-PE1-Ten-GigabitEthernet3/0/1] quit
2. Configure Spoke-PE 2:
[Sysname] sysname Spoke-PE2
[Spoke-PE2] interface loopback 0
[Spoke-PE2-LoopBack0] ip address 2.2.2.9 32
[Spoke-PE2-LoopBack0] quit
[Spoke-PE2] mpls lsr-id 2.2.2.9
[Spoke-PE2] mpls ldp
[Spoke-PE2–ldp] quit
# Enable L2VPN.
[Spoke-PE2] l2vpn enable
[Spoke-PE2] interface ten-gigabitethernet 3/0/2
[Spoke-PE2-Ten-GigabitEthernet3/0/2] ip address 20.1.1.2 24
[Spoke-PE2-Ten-GigabitEthernet3/0/2] mpls enable
[Spoke-PE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
[Spoke-PE2-Ten-GigabitEthernet3/0/2] quit
[Spoke-PE2] ospf
[Spoke-PE2-ospf-1] area 0
[Spoke-PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[Spoke-PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[Spoke-PE2-ospf-1-area-0.0.0.0] quit
[Spoke-PE2-ospf-1] quit
[Spoke-PE2] vsi aaa hub-spoke
[Spoke-PE2-vsi-aaa] pwsignaling ldp
[Spoke-PE2-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500 hub
[Spoke-PE2-vsi-aaa-ldp-3.3.3.9-500] quit
[Spoke-PE2-vsi-aaa-ldp] quit
[Spoke-PE2-vsi-aaa] quit
[Spoke-PE2] interface ten-gigabitethernet 3/0/1
[Spoke-PE2-Ten-GigabitEthernet3/0/1] xconnect vsi aaa
[Spoke-PE2-Ten-GigabitEthernet3/0/1] quit
3. Configure Hub-PE:
[Sysname] sysname Hub-PE
[Hub-PE] interface loopback 0
[Hub-PE-LoopBack0] ip address 3.3.3.9 32
[Hub-PE-LoopBack0] quit
[Hub-PE] mpls lsr-id 3.3.3.9
[Hub-PE] mpls ldp
[Hub-PE–ldp] quit
# Enable L2VPN.
[Hub-PE] l2vpn enable
# Configure Ten-GigabitEthernet3/0/2 (the interface connected to Spoke-PE 1), and enable LDP on the interface.
[Hub-PE] interface ten-gigabitethernet 3/0/2
[Hub-PE-Ten-GigabitEthernet3/0/2] ip address 10.1.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/2] mpls enable
[Hub-PE-Ten-GigabitEthernet3/0/2] mpls ldp enable
[Hub-PE-Ten-GigabitEthernet3/0/2] quit
# Configure Ten-GigabitEthernet3/0/3 (the interface connected to Spoke-PE 2), and enable LDP on the interface.
[Hub-PE] interface ten-gigabitethernet 3/0/3
[Hub-PE-Ten-GigabitEthernet3/0/3] ip address 20.1.1.1 24
[Hub-PE-Ten-GigabitEthernet3/0/3] mpls enable
[Hub-PE-Ten-GigabitEthernet3/0/3] mpls ldp enable
[Hub-PE-Ten-GigabitEthernet3/0/3] quit
[Hub-PE] ospf
[Hub-PE-ospf-1] area 0
[Hub-PE-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[Hub-PE-ospf-1-area-0.0.0.0] quit
[Hub-PE-ospf-1] quit
# Create VSI aaa, enable hub-spoke capability for the VSI, specify the PW signaling protocol as LDP, and establish PWs to Spoke-PE 1 and Spoke-PE 2.
[Hub-PE] vsi aaa hub-spoke
[Hub-PE-vsi-aaa] pwsignaling ldp
[Hub-PE-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500
[Hub-PE-vsi-aaa-ldp-1.1.1.9-500] quit
[Hub-PE-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[Hub-PE-vsi-aaa-ldp-2.2.2.9-500] quit
[Hub-PE-vsi-aaa-ldp] quit
[Hub-PE-vsi-aaa] quit
# Bind interface Ten-GigabitEthernet 3/0/1 to VSI aaa, and specify the AC connected to the CE as a hub link.
[Hub-PE] interface ten-gigabitethernet 3/0/1
[Hub-PE-Ten-GigabitEthernet3/0/1] xconnect vsi aaa hub
[Hub-PE-Ten-GigabitEthernet3/0/1] quit
[Spoke-PE1] display l2vpn pw verbose
VSI Name: aaa
In Label : 1276 Out Label: 1274
MTU : 1500
PW Attributes : Main, Hub link
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x560000000
Admin PW : -
[Spoke-PE2] display l2vpn pw verbose
VSI Name: aaa
In Label : 1275 Out Label: 1273
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
[Hub-PE] display l2vpn pw verbose
VSI Name: aaa
In Label : 1274 Out Label: 1276
MTU : 1500
PW Attributes : Main, Spoke link
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x760000000
Admin PW : -
In Label : 1273 Out Label: 1275
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x860000001
Tunnel NHLFE IDs : 1033
Admin PW : -
Configuration files
· Hub-PE
sysname Hub-PE
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
l2vpn enable
vsi aaa hub-spoke
pwsignaling ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
xconnect vsi aaa
return
· Spoke-PE 1
sysname Spoke-PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
l2vpn enable
vsi aaa hub-spoke
pwsignaling ldp
interface LoopBack0
mpls enable
mpls ldp enable
xconnect vsi aaa
return
· Spoke-PE 2
sysname Spoke-PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
l2vpn enable
vsi aaa hub-spoke
pwsignaling ldp
interface LoopBack0
mpls enable
mpls ldp enable
xconnect vsi aaa
return
Example: Configuring H-VPLS UPE dual homing
To improve reliability of the H-VPLS network, the UPE establishes a U-PW with NPE 1 and NPE 2. The U-PW between UPE and NPE 1 is the primary PW and that between UPE and NPE 2 is the backup PW. The backup PW works only when the primary PW fails.
Figure 7 Network diagram
Table 7 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Interface3 |
Interface4 |
Ten-GigabitEthernet3/0/4 |
1. Configure UPE:
[UPE-LoopBack0] ip address 1.1.1.1 32
[UPE] mpls lsr-id 1.1.1.1
[UPE] mpls ldp
[UPE-ldp] quit
# Enable L2VPN.
[UPE] l2vpn enable
# Configure Ten-GigabitEthernet3/0/3 (the interface connected to NPE 2), and enable LDP on the interface.
[UPE] interface ten-gigabitethernet 3/0/3
[UPE-Ten-GigabitEthernet3/0/3] ip address 13.1.1.1 24
[UPE-Ten-GigabitEthernet3/0/3] mpls enable
[UPE-Ten-GigabitEthernet3/0/3] mpls ldp enable
[UPE-Ten-GigabitEthernet3/0/3] quit
# Configure Ten-GigabitEthernet3/0/4 (the interface connected to NPE 1), and enable LDP on the interface.
[UPE] interface ten-gigabitethernet 3/0/4
[UPE-Ten-GigabitEthernet3/0/4] ip address 12.1.1.1 24
[UPE-Ten-GigabitEthernet3/0/4] mpls enable
[UPE-Ten-GigabitEthernet3/0/4] mpls ldp enable
[UPE-Ten-GigabitEthernet3/0/4] quit
[UPE] ospf
[UPE-ospf-1] area 0
[UPE-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[UPE-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[UPE-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[UPE-ospf-1] quit
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish the primary PW to NPE 1 and the backup PW to NPE 2.
[UPE] vsi aaa
[UPE-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[UPE-vsi-aaa-ldp-2.2.2.2-500] backup-peer 3.3.3.3 pw-id 500
[UPE-vsi-aaa-ldp-2.2.2.2-500-backup] quit
[UPE-vsi-aaa-ldp-2.2.2.2-500] quit
[UPE-vsi-aaa] quit
# Bind interface GigabitEthernet 1/0/2 to VSI aaa.
[UPE] interface gigabitethernet 1/0/2
[UPE-GigabitEthernet1/0/2] xconnect vsi aaa
[UPE-GigabitEthernet1/0/2] quit
2. Configure NPE 1:
[NPE1] isis 1
[NPE1-isis-1] quit
[NPE1-LoopBack0] ip address 2.2.2.2 32
[NPE1] mpls lsr-id 2.2.2.2
[NPE1] mpls ldp
[NPE1–ldp] quit
# Enable L2VPN.
[NPE1] l2vpn enable
[NPE1] ospf
[NPE1-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[NPE1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[NPE1-ospf-1] quit
[NPE1-Ten-GigabitEthernet3/0/1] ip address 12.1.1.2 24
# Configure Ten-GigabitEthernet3/0/2 (the interface connected to NPE 2), and enable LDP on the interface.
[NPE1-Ten-GigabitEthernet3/0/2] ip address 17.1.1.1 24
# Configure Ten-GigabitEthernet3/0/3 (the interface connected to NPE 3), and enable LDP on the interface.
[NPE1-Ten-GigabitEthernet3/0/3] ip address 15.1.1.1 24
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to UPE, NPE 2, and NPE 3.
[NPE1] vsi aaa
[NPE1-vsi-aaa-ldp] peer 1.1.1.1 pw-id 500 no-split-horizon
[NPE1-vsi-aaa-ldp-1.1.1.1-500] quit
[NPE1-vsi-aaa-ldp] peer 3.3.3.3 pw-id 500
[NPE1-vsi-aaa-ldp-3.3.3.3-500] quit
[NPE1-vsi-aaa-ldp] peer 4.4.4.4 pw-id 500
[NPE1-vsi-aaa-ldp-4.4.4.4-500] quit
[NPE1-vsi-aaa] quit
3. Configure NPE 2:
[NPE2] isis 1
[NPE2-isis-1] quit
[NPE2-LoopBack0] ip address 3.3.3.3 32
[NPE2] mpls lsr-id 3.3.3.3
[NPE2] mpls ldp
[NPE2–ldp] quit
# Enable L2VPN.
[NPE2] l2vpn enable
[NPE2] ospf
[NPE2-ospf-1] area 0
[NPE2-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[NPE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[NPE2-ospf-1-area-0.0.0.0] quit
[NPE2-ospf-1] quit
[NPE2-Ten-GigabitEthernet3/0/1] ip address 13.1.1.2 24
[NPE2-Ten-GigabitEthernet3/0/1] mpls enable
[NPE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
[NPE2-Ten-GigabitEthernet3/0/2] ip address 17.1.1.2 24
[NPE2-Ten-GigabitEthernet3/0/3] ip address 16.1.1.1 24
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to UPE, NPE 1, and NPE 3.
[NPE2] vsi aaa
[NPE2-vsi-aaa] pwsignaling ldp
[NPE2-vsi-aaa-ldp] peer 1.1.1.1 pw-id 500 no-split-horizon
[NPE2-vsi-aaa-ldp-1.1.1.1-500] quit
[NPE2-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[NPE2-vsi-aaa-ldp-2.2.2.2-500] quit
[NPE2-vsi-aaa-ldp] peer 4.4.4.4 pw-id 500
[NPE2-vsi-aaa-ldp-4.4.4.4-500] quit
[NPE2-vsi-aaa] quit
4. Configure NPE 3:
[NPE3] isis 1
[NPE3-isis-1] quit
[NPE3-LoopBack0] ip address 4.4.4.4 32
[NPE3] mpls lsr-id 4.4.4.4
[NPE3] mpls ldp
[NPE3–ldp] quit
# Enable L2VPN.
[NPE3] l2vpn enable
[NPE3-Ten-GigabitEthernet3/0/2] ip address 15.1.1.2 24
[NPE3-Ten-GigabitEthernet3/0/3] ip address 16.1.1.2 24
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to NPE 1 and NPE 2.
[NPE3] vsi aaa
[NPE3-vsi-aaa] pwsignaling ldp
[NPE3-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[NPE3-vsi-aaa-ldp-2.2.2.2-500] quit
[NPE3-vsi-aaa-ldp] peer 3.3.3.3 pw-id 500
[NPE3-vsi-aaa-ldp-3.3.3.3-500] quit
[NPE3-vsi-aaa] quit
VSI Name: aaa
Peer: 2.2.2.2 PW ID: 500
In Label : 1151 Out Label: 1279
Wait to Restore Time: 0 sec
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
Peer: 3.3.3.3 PW ID: 500
Link ID : 8 PW State : Blocked
In Label : 1150 Out Label: 1279
MTU : 1500
PW Attributes : Backup
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x360000003
Tunnel NHLFE IDs : 1025
Admin PW : -
VSI Name: aaa
Peer: 1.1.1.1 PW ID: 500
In Label : 1279 Out Label: 1151
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x60000000
Admin PW : -
In Label : 1280 Out Label: 1290
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x160000005
Admin PW : -
Peer: 4.4.4.4 PW ID: 500
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
VSI Name: aaa
In Label : 1279 Out Label: 1150
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
In Label : 1290 Out Label: 1280
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Tunnel Group ID : 0x160000008
Admin PW : -
In Label : 1278 Out Label: 1278
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
VSI Name: aaa
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
MTU : 1500
VCCV CC : -
VCCV BFD : -
Flow Label : -
Admin PW : -
Configuration files
· NPE 1
sysname NPE1
isis 1
is-level level-1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.2
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
isis enable 1
ip address 12.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 17.1.1.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
ip address 15.1.1.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
return
· NPE 2
sysname NPE2
isis 1
is-level level-1
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.3
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
isis enable 1
ip address 13.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 17.1.1.2 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
ip address 16.1.1.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
return
· NPE 3
sysname NPE3
isis 1
is-level level-1
mpls lsr-id 4.4.4.4
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
isis enable 1
ip address 15.1.1.2 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
ip address 16.1.1.2 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
xconnect vsi aaa
return
· UPE
sysname UPE
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.1
mpls ldp
l2vpn enable
vsi aaa
pwsignaling ldp
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
ip address 13.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/4
ip address 12.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
xconnect vsi aaa
xconnect vsi aaa
return
