- 09-MPLS Configuration Guide
- 01-Basic MPLS configuration
- 02-IPv6 MPLS L3VPN configuration examples
- 03-IPv6 MPLS L3VPN configuration
- 04-L2VPN access to L3VPN or IP backbone configuration
- 05-LDP configuration
- 06-MCE configuration
- 07-MPLS L2VPN configuration examples
- 08-MPLS L2VPN configuration
- 09-MPLS L3VPN configuration examples
- 10-MPLS L3VPN configuration
- 11-MPLS OAM configuration
- 12-MPLS TE configuration
- 13-RSVP configuration
- 14-Static CRLSP configuration
- 15-Static LSP configuration
- 16-Tunnel policy configuration
- 17-VPLS configuration examples
- 18-VPLS configuration
| 02-IPv6 MPLS L3VPN configuration examples | 1.05 MB |
Configuring IPv6 MPLS L3VPN
Example: Configuring IPv6 MPLS L3VPNs
CE 1 and CE 3 belong to VPN 1. CE 2 and CE 4 belong to VPN 2.
VPN 1 uses route target attributes 111:1. VPN 2 uses route target attributes 222:2. Users of different VPNs cannot access each other.
Run EBGP between CEs and PEs to exchange VPN routing information.
PEs use OSPF to communicate with each other and use MP-IBGP to exchange VPN routing information.
Table 1 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Ten-GigabitEthernet3/0/1 |
Interface2 |
Ten-GigabitEthernet3/0/2 |
Interface4 |
Ten-GigabitEthernet3/0/4 |
Interface5 |
Ten-GigabitEthernet3/0/5 |
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
2001:1::1/96 |
P |
Loop0 |
2.2.2.9/32 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/4 |
172.1.1.2/24 |
XGE3/0/1 |
2001:1::2/96 |
XGE3/0/5 |
172.2.1.1/24 |
XGE3/0/2 |
2001:2::2/96 |
PE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/1 |
2001:3::2/96 |
CE 2 |
XGE3/0/1 |
2001:2::1/96 |
XGE3/0/2 |
2001:4::2/96 |
CE 3 |
XGE3/0/1 |
2001:3::1/96 |
XGE3/0/4 |
172.2.1.2/24 |
CE 4 |
XGE3/0/1 |
2001:4::1/96 |
1. Configure OSPF on the MPLS backbone to ensure IP connectivity among the PEs and the P router:
# Configure PE 1.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] interface ten-gigabitethernet 3/0/4
[PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/4] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure the P router.
[Sysname] sysname P
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface ten-gigabitethernet 3/0/4
[P-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[P-Ten-GigabitEthernet3/0/4] quit
[P] interface ten-gigabitethernet 3/0/5
[P-Ten-GigabitEthernet3/0/5] ip address 172.2.1.1 24
[P-Ten-GigabitEthernet3/0/5] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] interface ten-gigabitethernet 3/0/4
[PE2-Ten-GigabitEthernet3/0/4] ip address 172.2.1.2 24
[PE2-Ten-GigabitEthernet3/0/4] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that OSPF adjacencies in Full state have been established between PE 1, P, and PE 2. Execute the display ip routing-table command to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2. Configure basic MPLS and enable MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/4] mpls enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/4] mpls enable
[P-Ten-GigabitEthernet3/0/4] mpls ldp enable
[P-Ten-GigabitEthernet3/0/5] mpls enable
[P-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/4] mpls enable
[PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Execute the display mpls ldp peer command to verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2. Execute the display mpls ldp lsp command to verify that the LSPs have been established by LDP. (Details not shown.)
3. Configure IPv6 VPN instances on the PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::2 96
[PE1-Ten-GigabitEthernet3/0/1] quit
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[PE1-Ten-GigabitEthernet3/0/2] ipv6 address 2001:2::2 96
[PE1-Ten-GigabitEthernet3/0/2] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 2001:3::2 96
[PE2-Ten-GigabitEthernet3/0/1] quit
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[PE2-Ten-GigabitEthernet3/0/2] ipv6 address 2001:4::2 96
[PE2-Ten-GigabitEthernet3/0/2] quit
# Configure CE 1.
[Sysname] sysname CE1
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::1 96
[CE1-Ten-GigabitEthernet3/0/1] quit
# Configure CE 2.
[Sysname] sysname CE2
[CE2] interface ten-gigabitethernet 3/0/1
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::1 96
[CE2-Ten-GigabitEthernet3/0/1] quit
# Configure CE 3.
[Sysname] sysname CE3
[CE3] interface ten-gigabitethernet 3/0/1
[CE3-Ten-GigabitEthernet3/0/1] ipv6 address 2001:3::1 96
[CE3-Ten-GigabitEthernet3/0/1] quit
# Configure CE 4.
[Sysname] sysname CE4
[CE4] interface ten-gigabitethernet 3/0/1
[CE4-Ten-GigabitEthernet3/0/1] ipv6 address 2001:4::1 96
[CE4-Ten-GigabitEthernet3/0/1] quit
# Execute the display ip vpn-instance command on the PEs to display information about the VPN instances. Use the ping command on the PEs to verify that the PEs can ping their attached CEs. (Details not shown.)
4. Establish EBGP peer relationships between the PEs and CEs to allow them to exchange VPN routes:
# Configure CE 1.
[CE1] bgp 65410
[CE1-bgp-default] router-id 4.4.4.4
[CE1-bgp-default] peer 2001:1::2 as-number 100
[CE1-bgp-default] address-family ipv6 unicast
[CE1-bgp-default-ipv6] peer 2001:1::2 enable
[CE1-bgp-default-ipv6] import-route direct
[CE1-bgp-default-ipv6] quit
[CE1-bgp-default] quit
# Configure CE 2.
[CE2] bgp 65420
[CE2-bgp-default] router-id 5.5.5.5
[CE2-bgp-default] peer 2001:2::2 as-number 100
[CE2-bgp-default] address-family ipv6 unicast
[CE2-bgp-default-ipv6] peer 2001:2::2 enable
[CE2-bgp-default-ipv6] import-route direct
[CE2-bgp-default-ipv6] quit
[CE2-bgp-default] quit
# Configure CE 3.
[CE3] bgp 65430
[CE3-bgp-default] router-id 6.6.6.6
[CE3-bgp-default] peer 2001:3::2 as-number 100
[CE3-bgp-default] address-family ipv6 unicast
[CE3-bgp-default-ipv6] peer 2001:3::2 enable
[CE3-bgp-default-ipv6] import-route direct
[CE3-bgp-default-ipv6] quit
[CE3-bgp-default] quit
# Configure CE 4.
[CE4] bgp 65440
[CE4-bgp-default] router-id 7.7.7.7
[CE4-bgp-default] peer 2001:4::2 as-number 100
[CE4-bgp-default] address-family ipv6 unicast
[CE4-bgp-default-ipv6] peer 2001:4::2 enable
[CE4-bgp-default-ipv6] import-route direct
[CE4-bgp-default-ipv6] quit
[CE4-bgp-default] quit
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[PE1-bgp-default-vpn1] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[PE1-bgp-default-ipv6-vpn1] quit
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] peer 2001:2::1 as-number 65420
[PE1-bgp-default-vpn2] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn2] peer 2001:2::1 enable
[PE1-bgp-default-ipv6-vpn2] quit
[PE1-bgp-default-vpn2] quit
[PE1-bgp-default] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 2001:3::1 as-number 65430
[PE2-bgp-default-vpn1] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn1] peer 2001:3::1 enable
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] ip vpn-instance vpn2
[PE2-bgp-default-vpn2] peer 2001:4::1 as-number 65440
[PE2-bgp-default-vpn2] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn2] peer 2001:4::1 enable
[PE2-bgp-default-ipv6-vpn2] quit
[PE2-bgp-default-vpn2] quit
[PE2-bgp-default] quit
# Execute the display bgp peer ipv6 vpn-instance command on the PEs to verify that a BGP peer relationship in Established state has been established between a PE and a CE. (Details not shown.)
5. Configure an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] address-family vpnv6
[PE1-bgp-default-vpnv6] peer 3.3.3.9 enable
[PE1-bgp-default-vpnv6] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] address-family vpnv6
[PE2-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv6] quit
# Execute the display bgp peer vpnv6 command on the PEs to verify that a BGP peer relationship in Established state has been established between the PEs. (Details not shown.)
# Execute the display ipv6 routing-table vpn-instance command on the PEs.
[PE1] display ipv6 routing-table vpn-instance vpn1
Destinations : 5 Routes : 5
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 2001:1::/96 Protocol : Direct
NextHop : :: Preference: 0
Interface : XGE3/0/1 Cost : 0
Destination: 2001:1::2/128 Protocol : Direct
Destination: 2001:3::/96 Protocol : BGP4+
NextHop : ::FFFF:3.3.3.9 Preference: 255
Interface : XGE3/0/4 Cost : 0
Destination: FE80::/10 Protocol : Direct
[PE1] display ipv6 routing-table vpn-instance vpn2
Destination: 2001:2::/96 Protocol : Direct
Interface : XGE3/0/2 Cost : 0
Destination: 2001:2::2/128 Protocol : Direct
Destination: 2001:4::/96 Protocol : BGP4+
The output shows that PE 1 has routes to the remote CEs. Output on PE 2 is similar.
# Verify that CEs of the same VPN can ping each other, whereas those of different VPNs cannot. For example, CE 1 can ping CE 3 (2001:3::1), but cannot ping CE 4 (2001:4::1). (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 111:1 import-extcommunity
vpn-target 111:1 export-extcommunity
vpn-target 222:2 import-extcommunity
vpn-target 222:2 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
interface Ten-GigabitEthernet3/0/1
ipv6 address 2001:1::2/96
interface Ten-GigabitEthernet3/0/2
ipv6 address 2001:2::2/96
interface Ten-GigabitEthernet3/0/4
ip address 172.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
ip address 172.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/5
ip address 172.2.1.1 255.255.255.0
mpls enable
mpls ldp enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ipv6 address 2001:3::2/96
ipv6 address 2001:4::2/96
ip address 172.2.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
return
· CE 1:
sysname CE1
ipv6 address 2001:1::1/96
bgp 65410
router-id 4.4.4.4
import-route direct
return
· CE 2:
sysname CE2
ipv6 address 2001:2::1/96
bgp 65420
router-id 5.5.5.5
import-route direct
return
· CE 3:
sysname CE3
ipv6 address 2001:3::1/96
bgp 65430
router-id 6.6.6.6
import-route direct
return
· CE 4:
sysname CE4
ipv6 address 2001:4::1/96
bgp 65440
router-id 7.7.7.7
import-route direct
return
Example: Configuring an IPv6 MPLS L3VPN over a GRE tunnel
CE 1 and CE 2 belong to VPN 1. The PEs support MPLS, while the P router does not support MPLS and provides only IP features.
On the backbone, use a GRE tunnel to encapsulate and forward packets for IPv6 MPLS L3VPN.
Configure tunnel policies on the PEs, and specify the tunnel type for VPN traffic as GRE.
Table 3 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface4 |
Interface5 |
Table 4 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
2001:1::1/96 |
P |
XGE3/0/4 |
172.1.1.2/24 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/5 |
172.2.1.1/24 |
XGE3/0/1 |
2001:1::2/96 |
PE 2 |
Loop0 |
2.2.2.9/32 |
XGE3/0/5 |
172.1.1.1/24 |
XGE3/0/1 |
2001:2::2/96 |
Tunnel0 |
20.1.1.1/24 |
XGE3/0/4 |
172.2.1.2/24 |
CE 2 |
XGE3/0/1 |
2001:2::1/96 |
Tunnel0 |
20.1.1.2/24 |
1. Configure an IGP on the MPLS backbone to ensure IP connectivity among the PEs and the P router.
# Configure PE 1.
[PE1] interface ten-gigabitethernet 3/0/5
[PE1-Ten-GigabitEthernet3/0/5] ip address 172.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/5] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
[Sysname] sysname P
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
2. Configure basic MPLS on the PEs:
# Configure PE 1.
# Configure PE 2.
[PE2] mpls lsr-id 2.2.2.9
3. Configure VPN instances on the PEs to allow CE access, and apply tunnel policies to the VPN instances to use a GRE tunnel for VPN packet forwarding:
# Configure PE 1.
[PE1] tunnel-policy gre1
[PE1-tunnel-policy-gre1] tunnel select-seq gre load-balance-number 1
[PE1-tunnel-policy-gre1] quit
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
[PE1-vpn-instance-vpn1] tnl-policy gre1
# Configure PE 2.
[PE2] tunnel-policy gre1
[PE2-tunnel-policy-gre1] tunnel select-seq gre load-balance-number 1
[PE2-tunnel-policy-gre1] quit
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] vpn-target 100:1 both
[PE2-vpn-instance-vpn1] tnl-policy gre1
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::2 96
# Configure CE 1.
# Configure CE 2.
# Execute the display ip vpn-instance command on the PEs to display information about the VPN instance. Use the ping command on the PEs to verify that the PEs can ping their attached CEs. (Details not shown.)
4. Establish EBGP peer relationships between PEs and CEs to allow them to exchange VPN routes:
# Configure CE 1.
[CE1] bgp 65410
# Configure PE 1.
[PE1] bgp 100
# Configure CE 2.
[CE2] bgp 65420
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 2001:2::1 as-number 65420
[PE2-bgp-default-ipv6-vpn1] peer 2001:2::1 enable
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
# Configure PE 2.
[PE2] bgp 100
6. Configure a GRE tunnel:
# Configure PE 1.
[PE1] interface tunnel 0 mode gre
[PE1-Tunnel0] source loopback 0
[PE1-Tunnel0] destination 2.2.2.9
[PE1-Tunnel0] ip address 20.1.1.1 24
[PE1-Tunnel0] mpls enable
[PE1-Tunnel0] quit
# Configure PE 2.
[PE2] interface tunnel 0 mode gre
[PE2-Tunnel0] source loopback 0
[PE2-Tunnel0] destination 1.1.1.9
[PE2-Tunnel0] ip address 20.1.1.2 24
[PE2-Tunnel0] mpls enable
[PE2-Tunnel0] quit
# Verify that the CEs have learned the route to each other and can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
tnl-policy gre1
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
tunnel-policy gre1
interface LoopBack0
interface Tunnel0 mode gre
ip address 20.1.1.1 255.255.255.0
mpls enable
source LoopBack0
destination 2.2.2.9
bgp 100
peer 2.2.2.9 connect-interface LoopBack0
peer 2.2.2.9 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
return
· PE 2:
sysname PE2
tnl-policy gre1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
tunnel-policy gre1
interface LoopBack0
ip address 20.1.1.2 255.255.255.0
mpls enable
source LoopBack0
destination 1.1.1.9
bgp 100
peer 1.1.1.9 enable
return
· CE 1:
sysname CE1
bgp 65410
router-id 4.4.4.4
import-route direct
return
· CE 2:
sysname CE2
bgp 65420
router-id 5.5.5.5
import-route direct
return
Example: Configuring a hub-spoke network
The Spoke-CEs cannot communicate directly. They can communicate only through the Hub-CE.
Configure EBGP between the Spoke-CEs and Spoke-PEs and between the Hub-CE and Hub-PE to exchange VPN routing information.
Configure OSPF between the Spoke-PEs and Hub-PE to implement communication between the PEs. Configure MP-IBGP between the Spoke-PEs and Hub-PE to exchange VPN routing information.
Table 5 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Interface4 |
Interface5 |
Device |
IP address |
Device |
IP address |
Spoke-CE 1 |
XGE3/0/1 |
11::1/64 |
Hub-CE |
XGE3/0/1 |
13::1/64 |
Spoke-PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/2 |
14::1/64 |
XGE3/0/1 |
11::2/64 |
Hub-PE |
Loop0 |
2.2.2.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/4 |
172.1.1.2/24 |
Spoke-CE 2 |
XGE3/0/1 |
12::1/64 |
XGE3/0/5 |
172.2.1.2/24 |
Spoke-PE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
13::2/64 |
XGE3/0/1 |
12::2/64 |
XGE3/0/2 |
14::2/64 |
XGE3/0/4 |
172.2.1.1/24 |
1. Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone:
# Configure Spoke-PE 1.
[Sysname] sysname Spoke-PE1
[Spoke-PE1] interface loopback 0
[Spoke-PE1-LoopBack0] ip address 1.1.1.9 32
[Spoke-PE1-LoopBack0] quit
[Spoke-PE1] interface ten-gigabitethernet 3/0/4
[Spoke-PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[Spoke-PE1-Ten-GigabitEthernet3/0/4] quit
[Spoke-PE1] ospf
[Spoke-PE1-ospf-1] area 0
[Spoke-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Spoke-PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[Spoke-PE1-ospf-1-area-0.0.0.0] quit
[Spoke-PE1-ospf-1] quit
# Configure Spoke-PE 2.
[Sysname] sysname Spoke-PE2
[Spoke-PE2] interface loopback 0
[Spoke-PE2-LoopBack0] ip address 3.3.3.9 32
[Spoke-PE2-LoopBack0] quit
[Spoke-PE2] interface ten-gigabitethernet 3/0/4
[Spoke-PE2-Ten-GigabitEthernet3/0/4] ip address 172.2.1.1 24
[Spoke-PE2-Ten-GigabitEthernet3/0/4] quit
[Spoke-PE2] ospf
[Spoke-PE2-ospf-1] area 0
[Spoke-PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Spoke-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[Spoke-PE2-ospf-1-area-0.0.0.0] quit
[Spoke-PE2-ospf-1] quit
# Configure Hub-PE.
[Sysname] sysname Hub-PE
[Hub-PE] interface loopback 0
[Hub-PE-LoopBack0] ip address 2.2.2.9 32
[Hub-PE-LoopBack0] quit
[Hub-PE] interface ten-gigabitethernet 3/0/4
[Hub-PE-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/4] quit
[Hub-PE] interface ten-gigabitethernet 3/0/5
[Hub-PE-Ten-GigabitEthernet3/0/5] ip address 172.2.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/5] quit
[Hub-PE] ospf
[Hub-PE-ospf-1] area 0
[Hub-PE-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[Hub-PE-ospf-1-area-0.0.0.0] quit
[Hub-PE-ospf-1] quit
# Execute the display ospf peer command on the PEs to verify that OSPF adjacencies in Full state have been established between the PEs. Execute the display ip routing-table command on the PEs to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2. Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
[Spoke-PE1] mpls lsr-id 1.1.1.9
[Spoke-PE1] mpls ldp
[Spoke-PE1-ldp] quit
[Spoke-PE1-Ten-GigabitEthernet3/0/4] mpls enable
[Spoke-PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[Spoke-PE2] mpls lsr-id 3.3.3.9
[Spoke-PE2] mpls ldp
[Spoke-PE2-ldp] quit
[Spoke-PE2-Ten-GigabitEthernet3/0/4] mpls enable
[Spoke-PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure Hub-PE.
[Hub-PE] mpls lsr-id 2.2.2.9
[Hub-PE] mpls ldp
[Hub-PE-ldp] quit
[Hub-PE-Ten-GigabitEthernet3/0/4] mpls enable
[Hub-PE-Ten-GigabitEthernet3/0/4] mpls ldp enable
[Hub-PE-Ten-GigabitEthernet3/0/5] mpls enable
[Hub-PE-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Execute the display mpls ldp peer command on the PEs to verify that LDP sessions in Operational state have been established between the PEs. Execute the display mpls ldp lsp command on the PEs to verify that the LSPs have been established by LDP. (Details not shown.)
3. Configure VPN instances on the Spoke-PEs and Hub-PE:
[Spoke-PE1] ip vpn-instance vpn1
[Spoke-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[Spoke-PE1-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE1-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE1-vpn-instance-vpn1] quit
[Spoke-PE1] interface ten-gigabitethernet 3/0/1
[Spoke-PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[Spoke-PE1-Ten-GigabitEthernet3/0/1] ipv6 address 11::2 24
[Spoke-PE1-Ten-GigabitEthernet3/0/1] quit
[Spoke-PE2] ip vpn-instance vpn1
[Spoke-PE2-vpn-instance-vpn1] route-distinguisher 100:2
[Spoke-PE2-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE2-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE2-vpn-instance-vpn1] quit
[Spoke-PE2] interface ten-gigabitethernet 3/0/1
[Spoke-PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[Spoke-PE2-Ten-GigabitEthernet3/0/1] ipv6 address 12::2 24
[Spoke-PE2-Ten-GigabitEthernet3/0/1] quit
# Configure Hub-PE.
[Hub-PE] ip vpn-instance vpn1-in
[Hub-PE-vpn-instance-vpn1-in] route-distinguisher 100:3
[Hub-PE-vpn-instance-vpn1-in] vpn-target 222:2 import-extcommunity
[Hub-PE-vpn-instance-vpn1-in] quit
[Hub-PE] ip vpn-instance vpn1-out
[Hub-PE-vpn-instance-vpn1-out] route-distinguisher 100:4
[Hub-PE-vpn-instance-vpn1-out] vpn-target 111:1 export-extcommunity
[Hub-PE-vpn-instance-vpn1-out] quit
[Hub-PE] interface ten-gigabitethernet 3/0/1
[Hub-PE-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1-in
[Hub-PE-Ten-GigabitEthernet3/0/1] ipv6 address 13::2 24
[Hub-PE-Ten-GigabitEthernet3/0/1] quit
[Hub-PE] interface ten-gigabitethernet 3/0/2
[Hub-PE-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn1-out
[Hub-PE-Ten-GigabitEthernet3/0/2] ipv6 address 14::2 24
[Hub-PE-Ten-GigabitEthernet3/0/2] quit
# Configure Spoke-CE 1.
[Sysname] sysname Spoke-CE1
[Spoke-CE1] interface ten-gigabitethernet 3/0/1
[Spoke-CE1-Ten-GigabitEthernet3/0/1] ipv6 address 11::1 64
[Spoke-CE1-Ten-GigabitEthernet3/0/1] quit
# Configure Spoke-CE 2.
[Sysname] sysname Spoke-CE2
[Spoke-CE2] interface ten-gigabitethernet 3/0/1
[Spoke-CE2-Ten-GigabitEthernet3/0/1] ipv6 address 12::1 64
[Spoke-CE2-Ten-GigabitEthernet3/0/1] quit
# Configure Hub-CE.
[Sysname] sysname Hub-CE
[Hub-CE] interface ten-gigabitethernet 3/0/1
[Hub-CE-Ten-GigabitEthernet3/0/1] ipv6 address 13::1 64
[Hub-CE-Ten-GigabitEthernet3/0/1] quit
[Hub-CE] interface ten-gigabitethernet 3/0/2
[Hub-CE-Ten-GigabitEthernet3/0/2] ipv6 address 14::1 64
[Hub-CE-Ten-GigabitEthernet3/0/2] quit
# Execute the display ip vpn-instance command on the PEs to display the VPN instance configuration. Use the ping command on the PEs to verify that the PEs can ping their attached CEs. (Details not shown.)
4. Establish EBGP peer relationships between the PEs and CEs, and redistribute VPN routes into BGP:
[Spoke-CE1] bgp 65410
[Spoke-CE1-bgp-default] router-id 4.4.4.4
[Spoke-CE1-bgp-default] peer 11::2 as-number 100
[Spoke-CE1-bgp-default] address-family ipv6
[Spoke-CE1-bgp-default-ipv6] peer 11::2 enable
[Spoke-CE1-bgp-default-ipv6] import-route direct
[Spoke-CE1-bgp-default-ipv6] quit
[Spoke-CE1-bgp-default] quit
[Spoke-CE2] bgp 65420
[Spoke-CE2-bgp-default] router-id 5.5.5.5
[Spoke-CE2-bgp-default] peer 12::2 as-number 100
[Spoke-CE2-bgp-default] address-family ipv6
[Spoke-CE2-bgp-default-ipv6] peer 12::2 enable
[Spoke-CE2-bgp-default-ipv6] import-route direct
[Spoke-CE2-bgp-default-ipv6] quit
[Spoke-CE2-bgp-default] quit
# Configure Hub-CE.
[Hub-CE] bgp 65430
[Hub-CE-bgp-default] router-id 6.6.6.6
[Hub-CE-bgp-default] peer 13::2 as-number 100
[Hub-CE-bgp-default] peer 14::2 as-number 100
[Hub-CE-bgp-default] address-family ipv6
[Hub-CE-bgp-default-ipv6] peer 13::2 enable
[Hub-CE-bgp-default-ipv6] peer 14::2 enable
[Hub-CE-bgp-default-ipv6] import-route direct
[Hub-CE-bgp-default-ipv6] quit
[Hub-CE-bgp-default] quit
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] ip vpn-instance vpn1
[Spoke-PE1-bgp-default-vpn1] peer 11::1 as-number 65410
[Spoke-PE1-bgp-default-vpn1] address-family ipv6
[Spoke-PE1-bgp-default-ipv6-vpn1] peer 11::1 enable
[Spoke-PE1-bgp-default-ipv6-vpn1] quit
[Spoke-PE1-bgp-default-vpn1] quit
[Spoke-PE1-bgp-default] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] ip vpn-instance vpn1
[Spoke-PE2-bgp-default-vpn1] peer 12::1 as-number 65420
[Spoke-PE2-bgp-default-vpn1] address-family ipv6
[Spoke-PE2-bgp-default-ipv6-vpn1] peer 12::1 enable
[Spoke-PE2-bgp-default-ipv6-vpn1] quit
[Spoke-PE2-bgp-default-vpn1] quit
[Spoke-PE2-bgp-default] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] ip vpn-instance vpn1-in
[Hub-PE-bgp-default-vpn1-in] peer 13::1 as-number 65430
[Hub-PE-bgp-default-vpn1-in] address-family ipv6
[Hub-PE-bgp-default-ipv6-vpn1-in] peer 13::1 enable
[Hub-PE-bgp-default-ipv6-vpn1-in] quit
[Hub-PE-bgp-default-vpn1-in] quit
[Hub-PE-bgp-default] ip vpn-instance vpn1-out
[Hub-PE-bgp-default-vpn1-out] peer 14::1 as-number 65430
[Hub-PE-bgp-default-vpn1-out] address-family ipv6
[Hub-PE-bgp-default-ipv6-vpn1-out] peer 14::1 enable
[Hub-PE-bgp-default-ipv6-vpn1-out] peer 14::1 allow-as-loop 2
[Hub-PE-bgp-default-ipv6-vpn1-out] quit
[Hub-PE-bgp-default-vpn1-out] quit
[Hub-PE-bgp-default] quit
5. Establish an MP-IBGP peer relationship between the Spoke-PEs and Hub-PE:
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE1-bgp-default] address-family vpnv6
[Spoke-PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
[Spoke-PE1-bgp-default-vpnv6] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE2-bgp-default] address-family vpnv6
[Spoke-PE2-bgp-default-vpnv6] peer 2.2.2.9 enable
[Spoke-PE2-bgp-default-vpnv6] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] peer 1.1.1.9 as-number 100
[Hub-PE-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[Hub-PE-bgp-default] peer 3.3.3.9 as-number 100
[Hub-PE-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[Hub-PE-bgp-default] address-family vpnv6
[Hub-PE-bgp-default-vpnv6] peer 1.1.1.9 enable
[Hub-PE-bgp-default-vpnv6] peer 3.3.3.9 enable
[Hub-PE-bgp-default-vpnv6] quit
# Verify that Spoke-CE 1 and Spoke-CE 2 can ping each other. The TTL value indicates that traffic from Spoke-CE 1 to Spoke-CE 2 passes six hops (64-59+1) and is forwarded through Hub-CE. This example uses Spoke-CE 1.
[Spoke-CE1] ping ipv6 12::1
Ping6(56 bytes) 11::1 --> 12::1, press CTRL_C to break
56 bytes from 12::1, icmp_seq=0 hlim=59 time=0.000 ms
56 bytes from 12::1, icmp_seq=1 hlim=59 time=1.000 ms
56 bytes from 12::1, icmp_seq=2 hlim=59 time=0.000 ms
56 bytes from 12::1, icmp_seq=3 hlim=59 time=1.000 ms
56 bytes from 12::1, icmp_seq=4 hlim=59 time=0.000 ms
--- Ping6 statistics for 12::1 ---
round-trip min/avg/max/std-dev = 0.000/0.400/1.000/0.490 ms
Configuration files
· Spoke-PE 1:
sysname Spoke-PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ipv6 address 11::2/24
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
peer 11::1 enable
return
· Spoke-PE 2:
sysname Spoke-PE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ipv6 address 12::2/24
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
peer 12::1 enable
return
· Hub-PE:
sysname Hub-PE
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ipv6 address 13::2/24
ipv6 address 14::2/24
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 3.3.3.9 enable
peer 13::1 enable
peer 14::1 enable
return
· Spoke-CE 1:
sysname Spoke-CE1
ipv6 address 11::1/64
bgp 65410
router-id 4.4.4.4
import-route direct
peer 11::2 enable
return
· Spoke-CE 2:
sysname Spoke-CE2
ipv6 address 12::1/64
bgp 65420
router-id 5.5.5.5
import-route direct
peer 12::2 enable
return
· Hub-CE:
sysname Hub-CE
ipv6 address 13::1/64
ipv6 address 14::1/64
bgp 65430
router-id 6.6.6.6
import-route direct
peer 13::2 enable
peer 14::2 enable
return
Example: Configuring IPv6 MPLS L3VPN inter-AS option A
CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100 and CE 2 accesses the network through PE 2 in AS 200.
Configure IPv6 MPLS L3VPN inter-AS option A, and use VRF-to-VRF method to manage VPN routes.
Run OSPF on the MPLS backbone of each AS.
Table 7 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface4 |
Interface5 |
Table 8 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
2001:1::1/96 |
CE 2 |
XGE3/0/1 |
2001:2::1/96 |
PE 1 |
Loop0 |
1.1.1.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
2001:1::2/96 |
XGE3/0/1 |
2001:2::2/96 |
XGE3/0/4 |
172.1.1.2/24 |
XGE3/0/4 |
162.1.1.2/24 |
ASBR-PE1 |
Loop0 |
2.2.2.9/32 |
ASBR-PE2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/4 |
162.1.1.1/24 |
XGE3/0/5 |
2002:1::1/96 |
XGE3/0/5 |
2002:1::2/96 |
For the same VPN, the route targets for the VPN instance on the PE must match those for the VPN instance on the ASBR-PE in the same AS. This is not required for PEs in different ASs.
1. Configure an IGP on each MPLS backbone to ensure IP connectivity within the backbone.
# Configure PE 1.
[PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure ASBR-PE 1.
[Sysname] sysname ASBR-PE1
[ASBR-PE1-LoopBack0] ip address 2.2.2.9 32
[ASBR-PE1-LoopBack0] quit
[ASBR-PE1] interface ten-gigabitethernet 3/0/4
[ASBR-PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[ASBR-PE1-Ten-GigabitEthernet3/0/4] quit
[ASBR-PE1] ospf
[ASBR-PE1-ospf-1] area 0
[ASBR-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[ASBR-PE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[ASBR-PE1-ospf-1-area-0.0.0.0] quit
[ASBR-PE1-ospf-1] quit
# Configure ASBR-PE 2.
[Sysname] sysname ASBR-PE2
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE2-LoopBack0] quit
[ASBR-PE2] interface ten-gigabitethernet 3/0/4
[ASBR-PE2-Ten-GigabitEthernet3/0/4] ip address 162.1.1.1 24
[ASBR-PE2-Ten-GigabitEthernet3/0/4] quit
[ASBR-PE2] ospf
[ASBR-PE2-ospf-1] area 0
[ASBR-PE2-ospf-1-area-0.0.0.0] network 162.1.1.0 0.0.0.255
[ASBR-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[ASBR-PE2-ospf-1-area-0.0.0.0] quit
[ASBR-PE2-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 4.4.4.9 32
[PE2-Ten-GigabitEthernet3/0/4] ip address 162.1.1.2 24
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 162.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that each ASBR-PE has established an OSPF adjacency in Full state with the PE in the same AS, and that the PEs and ASBR-PEs in the same AS have learned the routes to the loopback interfaces of each other. Execute the ping command to verify that the PEs and ASBR-PEs in the same AS can ping each other. (Details not shown.)
2. Configure basic MPLS and enable MPLS LDP on each MPLS backbone to establish LDP LSPs:
# Configure basic MPLS on PE 1, and enable MPLS LDP for both PE 1 and the interface connected to ASBR-PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure basic MPLS on ASBR-PE 1, and enable MPLS LDP for both ASBR-PE 1 and the interface connected to PE 1.
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1-Ten-GigabitEthernet3/0/4] mpls enable
[ASBR-PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure basic MPLS on ASBR-PE 2, and enable MPLS LDP for both ASBR-PE 2 and the interface connected to PE 2.
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-Ten-GigabitEthernet3/0/4] mpls enable
[ASBR-PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure basic MPLS on PE 2, and enable MPLS LDP for both PE 2 and the interface connected to ASBR-PE 2.
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls ldp
[PE2-ldp] quit
# Execute the display mpls ldp session command on the routers to verify that the session status is Operational, and that each PE and the ASBR-PE in the same AS have established an LDP neighbor relationship. (Details not shown.)
3. Configure a VPN instance on the PEs:
# Configure CE 1.
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 100:2
# Configure CE 2.
# Configure PE 2.
[PE2-vpn-instance-vpn1] vpn-target 200:1 both
# On ASBR-PE 1, create a VPN instance, and bind the VPN instance to the interface connected to ASBR-PE 2. ASBR-PE 1 considers ASBR-PE 2 to be its attached CE.
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-vpn1] quit
[ASBR-PE1] interface ten-gigabitethernet 3/0/5
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ipv6 address 2002:1::1 96
[ASBR-PE1-Ten-GigabitEthernet3/0/5] quit
# On ASBR-PE 2, create a VPN instance, and bind the VPN instance to the interface connected to ASBR-PE 1. ASBR-PE 2 considers ASBR-PE 1 to be its attached CE.
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-instance-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-instance-vpn1] vpn-target 200:1 both
[ASBR-PE2-vpn-instance-vpn1] quit
[ASBR-PE2] interface ten-gigabitethernet 3/0/5
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ipv6 address 2002:1::2 96
[ASBR-PE2-Ten-GigabitEthernet3/0/5] quit
# Execute the display ip vpn-instance command to display VPN instance information. Verify that each PE can ping its attached CE, and that ASBR-PE 1 and ASBR-PE 2 can ping each other. (Details not shown.)
# Configure CE 1.
[CE1] bgp 65001
[CE1-bgp-default] router-id 5.5.5.5
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 2001:1::1 as-number 65001
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp-default] router-id 6.6.6.6
[CE2-bgp-default] peer 2001:2::2 as-number 200
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 2001:2::1 as-number 65002
5. Establish an IBGP peer relationship between each PE and the ASBR-PE in the same AS and an EBGP peer relationship between the ASBR-PEs:
# Configure PE 1.
[PE1] bgp 100
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] ip vpn-instance vpn1
[ASBR-PE1-bgp-default-vpn1] peer 2002:1::2 as-number 200
[ASBR-PE1-bgp-default-vpn1] address-family ipv6 unicast
[ASBR-PE1-bgp-default-ipv6-vpn1] peer 2002:1::2 enable
[ASBR-PE1-bgp-default-ipv6-vpn1] quit
[ASBR-PE1-bgp-default-vpn1] quit
[ASBR-PE1-bgp-default] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] address-family vpnv6
[ASBR-PE1-bgp-default-vpnv6] peer 1.1.1.9 enable
[ASBR-PE1-bgp-default-vpnv6] quit
[ASBR-PE1-bgp-default] quit
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp-default] ip vpn-instance vpn1
[ASBR-PE2-bgp-default-vpn1] peer 2002:1::1 as-number 100
[ASBR-PE2-bgp-default-vpn1] address-family ipv6 unicast
[ASBR-PE2-bgp-default-ipv6-vpn1] peer 2002:1::1 enable
[ASBR-PE2-bgp-default-ipv6-vpn1] quit
[ASBR-PE2-bgp-default-vpn1] quit
[ASBR-PE2-bgp-default] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp-default] address-family vpnv6
[ASBR-PE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[ASBR-PE2-bgp-default-vpnv6] quit
[ASBR-PE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default] peer 3.3.3.9 as-number 200
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default-vpnv6] peer 3.3.3.9 enable
# Verify that the CEs can learn the route to each other and can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
ipv6 address 2002:1::1/96
bgp 100
peer 1.1.1.9 enable
return
· ASBR-PE 2:
sysname ASBR-PE2
vpn-target 200:1 import-extcommunity
vpn-target 200:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 162.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
ipv6 address 2002:1::2/96
bgp 200
peer 4.4.4.9 connect-interface LoopBack0
peer 4.4.4.9 enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 4.4.4.9 255.255.255.255
ip address 162.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 200
peer 3.3.3.9 enable
return
· CE 1:
sysname CE1
bgp 65001
router-id 5.5.5.5
import-route direct
return
· CE 2:
sysname CE2
bgp 65002
router-id 6.6.6.6
import-route direct
return
Example: Configuring IPv6 MPLS L3VPN inter-AS option B
Site 1 and Site 2 belong to the same VPN. CE 1 of Site 1 accesses the network through PE 1 in AS 100, and CE 2 of Site 2 accesses the network through PE 2 in AS 600.
PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange VPNv6 routes through MP-IBGP. PE 2 and ASBR-PE 2 exchange VPNv6 routes through MP-IBGP. ASBR-PE 1 and ASBR-PE 2 exchange VPNv6 routes through MP-EBGP.
ASBRs do not perform route target filtering of received VPNv6 routes.
Figure 5 Network diagram
Table 9 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface4 |
Interface5 |
Table 10 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
30::1/64 |
XGE3/0/1 |
20::1/64 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
30::2/64 |
CE 2 |
XGE3/0/1 |
20::2/64 |
1. Configure PE 1:
# Configure IS-IS on PE 1.
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0001.00
[PE1-isis-1] quit
# Configure LSR ID, and enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls ldp
[PE1-ldp] quit
# Configure interface Ten-GigabitEthernet 3/0/5, and enable IS-IS, MPLS, and LDP on the interface.
[PE1-Ten-GigabitEthernet3/0/5] ip address 1.1.1.2 255.0.0.0
[PE1-Ten-GigabitEthernet3/0/5] isis enable 1
[PE1-Ten-GigabitEthernet3/0/5] mpls enable
[PE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure interface Loopback 0, and enable IS-IS on it.
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
# Create VPN instance vpn1, and configure the RD and route target attributes.
[PE1-vpn-instance-vpn1] vpn-target 1:1 2:2 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
# Bind the interface connected to CE 1 to the created VPN instance.
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 30::1 64
# Enable BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a VPNv6 peer.
# Establish an EBGP peer relationship between the PE and its attached CE.
[PE1-bgp-default-vpn1] peer 30::2 as-number 65001
[PE1-bgp-default-ipv6-vpn1] peer 30::2 enable
2. Configure ASBR-PE 1:
# Enable IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.0000.0000.0000.0002.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-Ten-GigabitEthernet3/0/5] isis enable 1
[ASBR-PE1-Ten-GigabitEthernet3/0/5] mpls enable
[ASBR-PE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure interface Ten-GigabitEthernet 3/0/4, and enable MPLS.
[ASBR-PE1-Ten-GigabitEthernet3/0/4] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
# Enable BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] peer 11.0.0.1 connect-interface ten-gigabitethernet 3/0/4
# Disable route target based filtering of received VPNv6 routes.
[ASBR-PE1-bgp-default-vpnv6] undo policy vpn-target
# Configure IBGP peer 2.2.2.9 and EBGP peer 11.0.0.1 as VPNv6 peers.
[ASBR-PE1-bgp-default-vpnv6] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
3. Configure ASBR-PE 2:
# Enable IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.0000.0000.0000.0003.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-Ten-GigabitEthernet3/0/5] isis enable 1
[ASBR-PE2-Ten-GigabitEthernet3/0/5] mpls enable
[ASBR-PE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[ASBR-PE2-Ten-GigabitEthernet3/0/4] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
# Enable BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] peer 11.0.0.2 connect-interface ten-gigabitethernet 3/0/4
[ASBR-PE2-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[ASBR-PE2-bgp-default-vpnv6] undo policy vpn-target
# Configure IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as VPNv6 peers.
[ASBR-PE2-bgp-default-vpnv6] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-vpnv6] peer 5.5.5.9 enable
4. Configure PE 2:
# Enable IS-IS on PE 2.
[PE2] isis 1
[PE2-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE2-isis-1] quit
# Configure the LSR ID, and enable MPLS and LDP.
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface ten-gigabitethernet 3/0/5
[PE2-Ten-GigabitEthernet3/0/5] ip address 9.1.1.2 255.0.0.0
[PE2-Ten-GigabitEthernet3/0/5] isis enable 1
[PE2-Ten-GigabitEthernet3/0/5] mpls enable
[PE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/5] quit
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 12:12
[PE2-vpn-instance-vpn1] vpn-target 1:1 2:2 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 2:2 export-extcommunity
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 20::1 64
# Enable BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv6 peer.
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[PE2-bgp-default-vpn1] peer 20::2 as-number 65002
[PE2-bgp-default-ipv6-vpn1] peer 20::2 enable
5. Configure CE 1.
# Assign IP addresses to interfaces.
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 30::2 64
# Establish an EBGP peer relationship between the CE and its connected PE and redistribute direct routes.
[CE1] bgp 65001
[CE1-bgp-default] router-id 6.6.6.6
[CE1-bgp-default] peer 30::1 as-number 100
[CE1-bgp-default-ipv6] peer 30::1 enable
6. Configure CE 2.
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 20::2 64
[CE2] bgp 65002
[CE2-bgp-default] router-id 7.7.7.7
[CE2-bgp-default] peer 20::1 as-number 600
[CE2-bgp-default-ipv6] peer 20::1 enable
# Verify that the CEs can learn each other's interface routes and can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
ipv6 address 30::1/64
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 enable
peer 30::2 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 11.0.0.1 connect-interface Ten-GigabitEthernet3/0/4
peer 2.2.2.9 enable
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 5.5.5.9 connect-interface LoopBack0
peer 11.0.0.2 connect-interface Ten-GigabitEthernet3/0/4
peer 5.5.5.9 enable
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
ip address 5.5.5.9 255.255.255.255
isis enable 1
ipv6 address 20::1/64
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 4.4.4.9 enable
peer 20::2 enable
return
· CE 1:
sysname CE1
ipv6 address 30::2/64
bgp 65001
router-id 6.6.6.6
import-route direct
peer 30::1 enable
return
· CE 2:
sysname CE2
ipv6 address 20::2/64
bgp 65002
router-id 7.7.7.7
import-route direct
peer 20::1 enable
returns
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 1)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100. Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange labeled IPv4 routes by IBGP. PE 2 and ASBR-PE 2 exchange labeled IPv4 routes by IBGP. PE 1 and PE 2 are MP-EBGP peers to exchange VPNv6 routes.
ASBR-PE 1 and ASBR-PE 2 use their respective routing policies and label the routes received from each other.
ASBR-PE 1 and ASBR-PE 2 use EBGP to exchange labeled IPv4 routes.
Table 11 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface4 |
Interface5 |
Table 12 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
2001::1/64 |
XGE3/0/1 |
2002::1/64 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
2001::2/64 |
CE 1 |
XGE3/0/1 |
2002::2/64 |
1. Configure CE 1:
# Configure an IPv6 address for Ten-GigabitEthernet 3/0/1.
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001::2 64
# Establish an EBGP peer relationship with PE 1, and redistribute VPN routes.
[CE1] bgp 65001
[CE1-bgp-default] peer 2001::1 as-number 100
[CE1-bgp-default-ipv6] peer 2001::1 enable
2. Configure PE 1:
[PE1] isis 1
[PE1-isis-1] quit
# Configure an LSR ID, and enable MPLS and LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/5, and enable IS-IS, MPLS, and LDP on the interface.
# Configure Loopback 0 and enable IS-IS on it.
# Create VPN instance vpn1, and configure the RD and route target attributes for it.
[PE1-vpn-instance-vpn1] vpn-target 3:3 import-extcommunity
# Associate Ten-GigabitEthernet 3/0/1 with VPN instance vpn1, and specify the IPv6 address for the interface.
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001::1 64
[PE1] bgp 100
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 3.3.3.9.
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-ipv4] peer 3.3.3.9 label-route-capability
[PE1-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp-default] peer 5.5.5.9 as-number 600
[PE1-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp-default] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv6 peer.
[PE1-bgp-default-af-vpnv6] peer 5.5.5.9 enable
[PE1-bgp-default-af-vpnv6] quit
# Establish an EBGP peer relationship with CE 1, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE1-bgp-default-vpn1] peer 2001::2 as-number 65001
[PE1-bgp-default-ipv6-vpn1] peer 2001::2 enable
3. Configure ASBR-PE 1:
[ASBR-PE1] isis 1
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/4, and enable MPLS on it.
# Configure Loopback 0, and enable IS-IS on it.
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] apply mpls-label
[ASBR-PE1-route-policy-policy1-1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy-policy2-1] if-match mpls-label
[ASBR-PE1-route-policy-policy2-1] apply mpls-label
[ASBR-PE1-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 1, and apply routing policy policy2 to routes advertised to IBGP peer 2.2.2.9.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 route-policy policy2 export
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 2.2.2.9.
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 label-route-capability
# Redistribute routes from IS-IS process 1
[ASBR-PE1-bgp-default-ipv4] import-route isis 1
[ASBR-PE1-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 route-policy policy1 export
# Enable the capability to advertise labeled routes to and receive labeled routes from EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 label-route-capability
4. Configure ASBR-PE 2:
[ASBR-PE2] isis 1
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy-policy1-1] apply mpls-label
[ASBR-PE2-route-policy-policy1-1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy-policy2-1] if-match mpls-label
[ASBR-PE2-route-policy-policy2-1] apply mpls-label
[ASBR-PE2-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 2, and enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 5.5.5.9.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 label-route-capability
# Apply routing policy policy2 to routes advertised to IBGP peer 5.5.5.9.
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 route-policy policy2 export
# Redistribute routes from IS-IS process 1.
[ASBR-PE2-bgp-default-ipv4] import-route isis 1
[ASBR-PE2-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 route-policy policy1 export
# Enable the capability to advertise labeled routes to and receive labeled routes from EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 label-route-capability
5. Configure PE 2:
[Sysname] sysname PE2[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2-vpn-instance-vpn1] vpn-target 3:3 import-extcommunity
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 2002::1 64
# Enable BGP.
[PE2] bgp 600
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 4.4.4.9.
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-ipv4] peer 4.4.4.9 label-route-capability
[PE2-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp-default] peer 2.2.2.9 as-number 100
[PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE2-bgp-default] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv6 peer.
[PE2-bgp-default-af-vpnv6] peer 2.2.2.9 enable
[PE2-bgp-default-af-vpnv6] quit
# Establish an EBGP peer relationship with CE 2, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE2-bgp-default-vpn1] peer 2002::2 as-number 65002
[PE2-bgp-default-ipv6-vpn1] peer 2002::2 enable
6. Configure CE 2:
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 2002::2 64
# Establish an EBGP peer relationship with PE 2, and redistribute VPN routes.
[CE2] bgp 65002
[CE2-bgp-default] peer 2002::1 as-number 600
[CE2-bgp-default-ipv6] peer 2002::1 enable
# Execute the display ipv6 routing table command on CE 1 and CE 2 to verify that CE 1 and CE 2 have a route to each other. Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
ipv6 address 2001::1/64
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 enable
peer 5.5.5.9 enable
peer 2001::2 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
import-route isis 1
peer 2.2.2.9 enable
apply mpls-label
if-match mpls-label
apply mpls-label
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
import-route isis 1
peer 5.5.5.9 enable
apply mpls-label
if-match mpls-label
apply mpls-label
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 1
ipv6 address 2002::1/64
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 4.4.4.9 enable
peer 2.2.2.9 enable
peer 2002::2 enable
return
· CE 1:
sysname CE1
ipv6 address 2001::2/64
bgp 65001
router-id 6.6.6.6
import-route direct
peer 2001::1 enable
return
· CE 2:
sysname CE2
ipv6 address 2002::2/64
bgp 65002
router-id 7.7.7.7
import-route direct
peer 2002::1 enable
return
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 2)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100, and Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and PE 2 are MP-EBGP peers and exchange VPNv6 routes.
ASBR-PE 1 and ASBR-PE 2 label the routes received from each other, use EBGP to exchange labeled IPv4 routes, and redistribute IGP and BGP routes from each other.
Figure 7 Network diagram
Table 13 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface4 |
Interface5 |
Table 14 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
2001::1/64 |
XGE3/0/1 |
2002::1/64 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
2001::2/64 |
CE 1 |
XGE3/0/1 |
2002::2/64 |
1. Configure CE 1:
[CE1] bgp 65001
2. Configure PE 1:
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
# Configure interface Loopback 0 and enable IS-IS on it.
# Associate Ten-GigabitEthernet 3/0/1 with VPN instance vpn1, and specify an IPv6 address for the interface.
[PE1] bgp 100
[PE1-bgp-default-vpnv6] peer 5.5.5.9 enable
[ASBR-PE1] isis 1
# Redistribute BGP routes.
[ASBR-PE1-isis-1] address-family ipv4 unicast
[ASBR-PE1-isis-1-ipv4] import-route bgp
[ASBR-PE1-isis-1-ipv4] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Create routing policy policy1.
# Enable BGP on ASBR-PE 1, and redistribute routes from IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] address-family ipv4 unicast
[ASBR-PE2-isis-1-ipv4] import-route bgp
[ASBR-PE2-isis-1-ipv4] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Enable BGP on ASBR-PE 2, and redistribute routes from IS-IS process 1.
[ASBR-PE2] bgp 600
5. Configure PE 2:
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] bgp 600
[PE2-bgp-default-vpnv6] peer 2.2.2.9 enable
6. Configure CE 2:
[CE2] bgp 65002
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 5.5.5.9 enable
peer 2001::2 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
import-route bgp
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
import-route isis 1
apply mpls-label
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
import-route bgp
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
import-route isis 1
apply mpls-label
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 2.2.2.9 enable
peer 2002::2 enable
return
· CE 1:
sysname CE1
bgp 65001
router-id 6.6.6.6
import-route direct
peer 2001::1 enable
return
· CE 2:
sysname CE2
bgp 65002
router-id 7.7.7.7
import-route direct
peer 2002::1 enable
return
Example: Configuring IPv6 MPLS L3VPN carrier's carrier in the same AS
Configure carrier's carrier for the scenario shown in Figure 8. In this scenario:
· PE 1 and PE 2 are the provider carrier's PE routers. They provide VPN services to the customer carrier.
· CE 1 and CE 2 are the customer carrier's routers. They are connected to the provider carrier's backbone as CE routers.
· PE 3 and PE 4 are the customer carrier's PE routers. They provide IPv6 MPLS L3VPN services to end customers.
· CE 3 and CE 4 are customers of the customer carrier.
· The customer carrier and the provider carrier reside in the same AS.
The key to the carrier's carrier deployment is to configure exchange of two kinds of routes:
· Exchange of the customer carrier's internal routes on the provider carrier's backbone.
· Exchange of the end customers' internal routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-IBGP peer relationship must be established between PE 3 and PE 4.
Table 15 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface4 |
Interface5 |
Table 16 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 3 |
XGE3/0/1 |
2001:1::1/96 |
CE 4 |
XGE3/0/1 |
2001:2::1/96 |
PE 3 |
Loop0 |
1.1.1.9/32 |
PE 4 |
Loop0 |
6.6.6.9/32 |
XGE3/0/1 |
2001:1::2/96 |
XGE3/0/1 |
2001:2::2/96 |
XGE3/0/5 |
10.1.1.1/24 |
XGE3/0/5 |
20.1.1.2/24 |
CE 1 |
Loop0 |
2.2.2.9/32 |
CE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/4 |
10.1.1.2/24 |
XGE3/0/4 |
21.1.1.2/24 |
XGE3/0/5 |
11.1.1.1/24 |
XGE3/0/5 |
20.1.1.1/24 |
PE 1 |
Loop0 |
3.3.3.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/4 |
11.1.1.2/24 |
XGE3/0/4 |
30.1.1.2/24 |
XGE3/0/5 |
30.1.1.1/24 |
XGE3/0/5 |
21.1.1.1/24 |
1. Configure MPLS L3VPN on the provider carrier backbone. Configure IS-IS as the IGP, enable LDP on PE 1 and PE 2, and establish an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1-Ten-GigabitEthernet3/0/5] ip address 30.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 4.4.4.9 enable
[PE1-bgp-default-vpnv4] quit
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] isis 1
[PE2-isis-1] network-entity 10.0000.0000.0000.0005.00
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/0/4] ip address 30.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/4] isis enable 1
[PE2-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[PE2] bgp 100
[PE2-bgp-default] peer 3.3.3.9 as-number 100
[PE2-bgp-default-vpnv4] peer 3.3.3.9 enable
[PE2-bgp-default-vpnv4] quit
# On PE 1 or PE 2, execute the following commands:
¡ Execute the display mpls ldp peer command to verify that an LDP session in Operational state has been established between PE 1 and PE 2. (Details not shown.)
¡ Execute the display bgp peer vpnv4 command to verify that a BGP peer relationship in Established state has been established between PE 1 and PE 2. (Details not shown.)
¡ Execute the display isis peer command to verify that the IS-IS neighbor relationship has been established between PE 1 and PE 2. (Details not shown.)
2. Configure the customer carrier network. Configure IS-IS as the IGP, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
[Sysname] sysname PE3
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] import-route isis 2
[PE3] interface ten-gigabitethernet 3/0/5
[PE3-Ten-GigabitEthernet3/0/5] ip address 10.1.1.1 24
[PE3-Ten-GigabitEthernet3/0/5] isis enable 2
[PE3-Ten-GigabitEthernet3/0/5] mpls enable
[PE3-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE3-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE3-Ten-GigabitEthernet3/0/5] quit
# Configure CE 1.
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1] interface ten-gigabitethernet 3/0/4
[CE1-Ten-GigabitEthernet3/0/4] ip address 10.1.1.2 24
[CE1-Ten-GigabitEthernet3/0/4] isis enable 2
[CE1-Ten-GigabitEthernet3/0/4] mpls enable
[CE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[CE1-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[CE1-Ten-GigabitEthernet3/0/4] quit
# Configure PE 4.
[Sysname] sysname PE4
[PE4] interface loopback 0
[PE4-LoopBack0] ip address 6.6.6.9 32
[PE4-LoopBack0] quit
[PE4] mpls lsr-id 6.6.6.9
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] isis 2
[PE4-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE4-isis-2] quit
[PE4-LoopBack0] isis enable 2
[PE4] interface ten-gigabitethernet 3/0/5
[PE4-Ten-GigabitEthernet3/0/5] ip address 20.1.1.2 24
[PE4-Ten-GigabitEthernet3/0/5] isis enable 2
[PE4-Ten-GigabitEthernet3/0/5] mpls enable
[PE4-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE4-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE4-Ten-GigabitEthernet3/0/5] quit
# Configure CE 2.
[CE2] interface loopback 0
[CE2-LoopBack0] ip address 5.5.5.9 32
[CE2-LoopBack0] quit
[CE2] mpls lsr-id 5.5.5.9
[CE2] mpls ldp
[CE2-ldp] quit
[CE2] isis 2
[CE2-isis-2] network-entity 10.0000.0000.0000.0004.00
[CE2-isis-2] quit
[CE2-LoopBack0] isis enable 2
[CE2] interface ten-gigabitethernet 3/0/5
[CE2-Ten-GigabitEthernet3/0/5] ip address 20.1.1.1 24
[CE2-Ten-GigabitEthernet3/0/5] isis enable 2
[CE2-Ten-GigabitEthernet3/0/5] mpls enable
[CE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[CE2-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[CE2-Ten-GigabitEthernet3/0/5] quit
PE 3 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them. PE 4 and CE 2 can establish an LDP session and IS-IS neighbor relationship between them.
3. Connect the customer carrier and the provider carrier:
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1] mpls ldp
[PE1-ldp] vpn-instance vpn1
[PE1-ldp-vpn-instance-vpn1] quit
[PE1-ldp] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] address-family ipv4
[PE1-isis-2-ipv4] import-route bgp allow-ibgp
[PE1-isis-2-ipv4] quit
[PE1-isis-2] quit
[PE1] interface ten-gigabitethernet 3/0/4
[PE1-Ten-GigabitEthernet3/0/4] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/4] ip address 11.1.1.2 24
[PE1-Ten-GigabitEthernet3/0/4] isis enable 2
[PE1-Ten-GigabitEthernet3/0/4] mpls enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[PE1-Ten-GigabitEthernet3/0/4] quit
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] import-route isis 2
# Configure CE 1.
[CE1] interface ten-gigabitethernet 3/0/5
[CE1-Ten-GigabitEthernet3/0/5] ip address 11.1.1.1 24
[CE1-Ten-GigabitEthernet3/0/5] isis enable 2
[CE1-Ten-GigabitEthernet3/0/5] mpls enable
[CE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
[CE1-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[CE1-Ten-GigabitEthernet3/0/5] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:2
[PE2-vpn-instance-vpn1] quit
[PE2] mpls ldp
[PE2-ldp] vpn-instance vpn1
[PE2-ldp-vpn-instance-vpn1] quit
[PE2-ldp] quit
[PE2] isis 2 vpn-instance vpn1
[PE2-isis-2] network-entity 10.0000.0000.0000.0006.00
[PE2-isis-2] address-family ipv4
[PE2-isis-2-ipv4] import-route bgp
[PE2-isis-2-ipv4] quit
[PE2-isis-2] quit
[PE2-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/5] ip address 21.1.1.1 24
[PE2-Ten-GigabitEthernet3/0/5] isis enable 2
[PE2-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] import-route isis 2
# Configure CE 2.
[CE2] interface ten-gigabitethernet 3/0/4
[CE2-Ten-GigabitEthernet3/0/4] ip address 21.1.1.2 24
[CE2-Ten-GigabitEthernet3/0/4] isis enable 2
[CE2-Ten-GigabitEthernet3/0/4] mpls enable
[CE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
[CE2-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[CE2-Ten-GigabitEthernet3/0/4] quit
PE 1 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them. PE 2 and CE 2 can establish an LDP session and IS-IS neighbor relationship between them.
4. Connect end customers and the customer carrier:
# Configure CE 3.
[Sysname] sysname CE3
[CE3] interface ten-gigabitethernet 3/0/1
[CE3-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::1 96
[CE3-Ten-GigabitEthernet3/0/1] quit
[CE3] bgp 65410
[CE3-bgp-default] router-id 7.7.7.7
[CE3-bgp-default] peer 2001:1::2 as-number 100
[CE3-bgp-default-ipv6] peer 2001:1::2 enable
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface ten-gigabitethernet 3/0/1
[PE3-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE3-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::2 96
[PE3-Ten-GigabitEthernet3/0/1] quit
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[PE3-bgp-default-vpn1] address-family ipv6 unicast
[PE3-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[PE3-bgp-default-ipv6-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3-bgp-default] quit
# Configure CE 4.
[Sysname] sysname CE4
[CE4] interface ten-gigabitethernet 3/0/1
[CE4-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::1 96
[CE4-Ten-GigabitEthernet3/0/1] quit
[CE4] bgp 65420
[CE4-bgp-default] router-id 8.8.8.8
[CE4-bgp-default] peer 2001:2::2 as-number 100
[CE4-bgp-default] address-family ipv6 unicast
[CE4-bgp-default-ipv6] peer 2001:2::2 enable
[CE4-bgp-default-ipv6] import-route direct
[CE4-bgp-default-ipv6] quit
[CE4-bgp-default] quit
# Configure PE 4.
[PE4] ip vpn-instance vpn1
[PE4-vpn-instance-vpn1] route-distinguisher 100:2
[PE4-vpn-instance-vpn1] vpn-target 1:1
[PE4-vpn-instance-vpn1] quit
[PE4] interface ten-gigabitethernet 3/0/1
[PE4-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE4-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::2 96
[PE4-Ten-GigabitEthernet3/0/1] quit
[PE4] bgp 100
[PE4-bgp-default] ip vpn-instance vpn1
[PE4-bgp-default-vpn1] peer 2001:2::1 as-number 65420
[PE4-bgp-default-vpn1] address-family ipv6 unicast
[PE4-bgp-default-ipv6-vpn1] peer 2001:2::1 enable
[PE4-bgp-default-ipv6-vpn1] quit
[PE4-bgp-default-vpn1] quit
[PE4-bgp-default] quit
5. Configure an MP-IBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 100
[PE3-bgp-default] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv6
[PE3-bgp-default-af-vpnv6] peer 6.6.6.9 enable
[PE3-bgp-default-af-vpnv6] quit
# Configure PE 4.
[PE4] bgp 100
[PE4-bgp-default] peer 1.1.1.9 as-number 100
[PE4-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE4-bgp-default] address-family vpnv6
[PE4-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE4-bgp-default-vpnv6] quit
1. Display the public network routing table and VPN routing table on the provider carrier PEs, for example, on PE 1:
# Verify that the public network routing table contains only routes of the provider carrier network.
[PE1] display ip routing-table
Destinations : 9 Routes : 9
3.3.3.9/32 Direct 0 0 127.0.0.1 Loop0
4.4.4.9/32 IS_L1 15 10 30.1.1.2 XGE3/0/5
30.1.1.0/24 Direct 0 0 30.1.1.1 XGE3/0/5
30.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
30.1.1.255/32 Direct 0 0 30.1.1.1 XGE3/0/5
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that the VPN routing table contains the internal routes of the customer carrier network.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11 Routes : 11
1.1.1.9/32 IS_L1 15 20 11.1.1.1 XGE3/0/4
2.2.2.9/32 IS_L1 15 10 11.1.1.1 XGE3/0/4
5.5.5.9/32 BGP 255 10 4.4.4.9 XGE3/0/5
6.6.6.9/32 BGP 255 20 4.4.4.9 XGE3/0/5
10.1.1.0/24 IS_L1 15 20 11.1.1.1 XGE3/0/4
11.1.1.0/24 Direct 0 0 11.1.1.2 XGE3/0/4
11.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/4
11.1.1.255/32 Direct 0 0 11.1.1.2 XGE3/0/4
20.1.1.0/24 BGP 255 20 4.4.4.9 XGE3/0/5
2. Display the routing table on the customer carrier CEs, for example, on CE 1:
# Verify that the routing table contains the internal routes of the customer carrier network.
[CE1] display ip routing-table
Destinations : 15 Routes : 15
1.1.1.9/32 IS_L1 15 10 10.1.1.1 XGE3/0/4
2.2.2.9/32 Direct 0 0 127.0.0.1 Loop0
5.5.5.9/32 IS_L2 15 74 11.1.1.2 XGE3/0/5
6.6.6.9/32 IS_L2 15 74 11.1.1.2 XGE3/0/5
10.1.1.0/24 Direct 0 0 10.1.1.2 XGE3/0/4
10.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/4
10.1.1.255/32 Direct 0 0 10.1.1.2 XGE3/0/4
11.1.1.0/24 Direct 0 0 11.1.1.1 XGE3/0/5
11.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
11.1.1.255/32 Direct 0 0 11.1.1.1 XGE3/0/5
20.1.1.0/24 IS_L2 15 74 11.1.1.2 XGE3/0/5
3. Display the public network routing table and VPN routing table on the customer carrier PEs, for example, on PE 3:
# Verify that the public network routing table contains the internal routes of the customer carrier network.
[PE3] display ip routing-table
Destinations : 13 Routes : 13
1.1.1.9/32 Direct 0 0 127.0.0.1 Loop0
2.2.2.9/32 IS_L1 15 10 10.1.1.2 XGE3/0/5
5.5.5.9/32 IS_L2 15 84 10.1.1.2 XGE3/0/5
6.6.6.9/32 IS_L2 15 84 10.1.1.2 XGE3/0/5
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE3/0/5
10.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
10.1.1.255/32 Direct 0 0 10.1.1.1 XGE3/0/5
11.1.1.0/24 IS_L1 15 20 10.1.1.2 XGE3/0/5
20.1.1.0/24 IS_L2 15 84 10.1.1.2 XGE3/0/5
# Verify that the VPN routing table has the remote VPN route.
[PE3] display ipv6 routing-table vpn-instance vpn1
Destinations : 5 Routes : 5
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 2001:1::/96 Protocol : Direct
NextHop : :: Preference: 0
Interface : XGE3/0/1 Cost : 0
Destination: 2001:1::2/128 Protocol : Direct
Destination: 2001:2::/96 Protocol : BGP4+
NextHop : ::FFFF:6.6.6.9 Preference: 255
Interface : XGE3/0/5 Cost : 0
Destination: FE80::/10 Protocol : Direct
4. Verify that PE 3 and PE 4 can ping each other. (Details not shown.)
5. Verify that CE 3 and CE 4 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 1:1 import-extcommunity
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
vpn-instance vpn1
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
isis enable 1
ip address 11.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/5
ip address 30.1.1.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 4.4.4.9 enable
import-route isis 2
return
· PE 2:
sysname PE2
isis 1
import-route bgp
mpls lsr-id 4.4.4.9
mpls ldp
vpn-instance vpn1
interface LoopBack0
isis enable 1
ip address 30.1.1.2 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
ip address 21.1.1.1 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
import-route isis 2
return
· CE 1:
sysname CE1
isis 2
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
ip address 11.1.1.1 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
return
· CE 2:
sysname CE2
isis 2
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 2
ip address 21.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
isis enable 2
mpls enable
mpls ldp enable
return
· PE 3:
sysname PE3
isis 2
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
isis enable 2
interface Ten-GigabitEthernet3/0/1
ipv6 address 2001:1::2/96
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 6.6.6.9 connect-interface LoopBack0
peer 6.6.6.9 enable
return
· PE 4:
sysname PE4
isis 2
mpls lsr-id 6.6.6.9
mpls ldp
interface LoopBack0
ip address 6.6.6.9 255.255.255.255
isis enable 2
ipv6 address 2001:2::2/96
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
return
· CE 3:
sysname CE3
ipv6 address 2001:1::1/96
bgp 65410
router-id 7.7.7.7
import-route direct
return
· CE 4:
sysname CE4
ipv6 address 2001:2::1/96
bgp 65420
router-id 8.8.8.8
import-route direct
return
Example: Configuring HoVPN
There are two levels of networks, the backbone and the MPLS VPN networks, as shown in Figure 9.
· SPEs act as PEs to allow MPLS VPNs to access the backbone.
· UPEs act as PEs of the MPLS VPNs to allow end users to access the VPNs.
· Performance requirements for the UPEs are lower than those for the SPEs.
· SPEs advertise routes permitted by the routing policies to UPEs, permitting CE 1 and CE 3 in VPN 1 to communicate with each other, and forbidding CE 2 and CE 4 in VPN 2 from communicating with each other.
Table 17 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Ten-GigabitEthernet3/0/1 |
Interface2 |
Ten-GigabitEthernet3/0/2 |
Interface3 |
Ten-GigabitEthernet3/0/3 |
Table 18 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
2001:1::1/96 |
CE 3 |
XGE3/0/1 |
2001:3::1/96 |
CE 2 |
XGE3/0/1 |
2001:2::1/96 |
CE 4 |
XGE3/0/1 |
2001:4::1/96 |
UPE 1 |
Loop0 |
1.1.1.9/32 |
UPE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
2001:1::2/96 |
XGE3/0/1 |
172.2.1.1/24 |
XGE3/0/2 |
2001:2::2/96 |
XGE3/0/2 |
2001:3::2/96 |
XGE3/0/3 |
172.1.1.1/24 |
XGE3/0/3 |
2001:4::2/96 |
SPE 1 |
Loop0 |
2.2.2.9/32 |
SPE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
172.1.1.2/24 |
XGE3/0/1 |
180.1.1.2/24 |
XGE3/0/2 |
180.1.1.1/24 |
XGE3/0/2 |
172.2.1.2/24 |
1. Configure UPE 1:
# Configure basic MPLS and MPLS LDP to establish LDP LSPs.
[Sysname] sysname UPE1
[UPE1] interface loopback 0
[UPE1-LoopBack0] ip address 1.1.1.9 32
[UPE1-LoopBack0] quit
[UPE1] mpls lsr-id 1.1.1.9
[UPE1] mpls ldp
[UPE1-ldp] quit
[UPE1] interface ten-gigabitethernet 3/0/3
[UPE1-Ten-GigabitEthernet3/0/3] ip address 172.1.1.1 24
[UPE1-Ten-GigabitEthernet3/0/3] mpls enable
[UPE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
[UPE1-Ten-GigabitEthernet3/0/3] quit
# Configure the IGP protocol (OSPF, in this example).
[UPE1] ospf
[UPE1-ospf-1] area 0
[UPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[UPE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[UPE1-ospf-1-area-0.0.0.0] quit
[UPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 1 and CE 2 to access UPE 1.
[UPE1] ip vpn-instance vpn1
[UPE1-vpn-instance-vpn1] route-distinguisher 100:1
[UPE1-vpn-instance-vpn1] vpn-target 100:1 both
[UPE1-vpn-instance-vpn1] quit
[UPE1] ip vpn-instance vpn2
[UPE1-vpn-instance-vpn2] route-distinguisher 100:2
[UPE1-vpn-instance-vpn2] vpn-target 100:2 both
[UPE1-vpn-instance-vpn2] quit
[UPE1] interface ten-gigabitethernet 3/0/1
[UPE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[UPE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::2 96
[UPE1-Ten-GigabitEthernet3/0/1] quit
[UPE1] interface ten-gigabitethernet 3/0/2
[UPE1-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[UPE1-Ten-GigabitEthernet3/0/2] ipv6 address 2001:2::2 96
[UPE1-Ten-GigabitEthernet3/0/2] quit
# Establish an MP-IBGP peer relationship with SPE 1.
[UPE1] bgp 100
[UPE1-bgp-default] peer 2.2.2.9 as-number 100
[UPE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[UPE1-bgp-default] address-family vpnv6
[UPE1-bgp-default-vpnv6] peer 2.2.2.9 enable
[UPE1-bgp-default-vpnv6] quit
# Establish an EBGP peer relationship with CE 1.
[UPE1-bgp-default] ip vpn-instance vpn1
[UPE1-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[UPE1-bgp-default-vpn1] address-family ipv6 unicast
[UPE1-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[UPE1-bgp-default-ipv6-vpn1] quit
[UPE1-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 2.
[UPE1-bgp-default] ip vpn-instance vpn2
[UPE1-bgp-default-vpn2] peer 2001:2::1 as-number 65420
[UPE1-bgp-default-vpn2] address-family ipv6 unicast
[UPE1-bgp-default-ipv6-vpn2] peer 2001:2::1 enable
[UPE1-bgp-default-ipv6-vpn2] quit
[UPE1-bgp-default-vpn2] quit
[UPE1-bgp-default] quit
2. Configure CE 1.
[Sysname] sysname CE1
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::1 96
[CE1-Ten-GigabitEthernet3/0/1] quit
[CE1] bgp 65410
[CE1-bgp-default] address-family ipv6 unicast
[CE1-bgp-default-ipv6] peer 2001:1::2 enable
[CE1-bgp-default-ipv6] import-route direct
[CE1-bgp-default-ipv6] quit
[CE1-bgp-default] quit
3. Configure CE 2.
[Sysname] sysname CE2
[CE2] interface ten-gigabitethernet 3/0/1
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::1 96
[CE2-Ten-GigabitEthernet3/0/1] quit
[CE2] bgp 65420
[CE2-bgp-default] peer 2001:2::2 as-number 100
[CE2-bgp-default] address-family ipv6 unicast
[CE2-bgp-default-ipv6] peer 2001:2::2 enable
[CE2-bgp-default-ipv6] import-route direct
[CE2-bgp-default-ipv6] quit
[CE2-bgp-default] quit
4. Configure UPE 2:
[Sysname] sysname UPE2
[UPE2] interface loopback 0
[UPE2-LoopBack0] ip address 4.4.4.9 32
[UPE2-LoopBack0] quit
[UPE2] mpls lsr-id 4.4.4.9
[UPE2] mpls ldp
[UPE2-ldp] quit
[UPE2] interface ten-gigabitethernet 3/0/1
[UPE2-Ten-GigabitEthernet3/0/1] ip address 172.2.1.1 24
[UPE2-Ten-GigabitEthernet3/0/1] mpls enable
[UPE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
[UPE2-Ten-GigabitEthernet3/0/1] quit
[UPE2] ospf
[UPE2-ospf-1] area 0
[UPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[UPE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[UPE2-ospf-1-area-0.0.0.0] quit
[UPE2-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 3 and CE 4 to access UPE 2.
[UPE2] ip vpn-instance vpn1
[UPE2-vpn-instance-vpn1] route-distinguisher 300:1
[UPE2-vpn-instance-vpn1] vpn-target 100:1 both
[UPE2-vpn-instance-vpn1] quit
[UPE2] ip vpn-instance vpn2
[UPE2-vpn-instance-vpn2] route-distinguisher 400:2
[UPE2-vpn-instance-vpn2] vpn-target 100:2 both
[UPE2-vpn-instance-vpn2] quit
[UPE2] interface ten-gigabitethernet 3/0/2
[UPE2-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn1
[UPE2-Ten-GigabitEthernet3/0/2] ipv6 address 2001:3::2 96
[UPE2-Ten-GigabitEthernet3/0/2] quit
[UPE2] interface ten-gigabitethernet 3/0/3
[UPE2-Ten-GigabitEthernet3/0/3] ip binding vpn-instance vpn2
[UPE2-Ten-GigabitEthernet3/0/3] ipv6 address 2001:4::2 96
[UPE2-Ten-GigabitEthernet3/0/3] quit
# Establish an MP-IBGP peer relationship with SPE 2.
[UPE2] bgp 100
[UPE2-bgp-default] peer 3.3.3.9 as-number 100
[UPE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[UPE2-bgp-default] address-family vpnv6
[UPE2-bgp-default-vpnv6] peer 3.3.3.9 enable
[UPE2-bgp-default-vpnv6] quit
# Establish an EBGP peer relationship with CE 3.
[UPE2-bgp-default] ip vpn-instance vpn1
[UPE2-bgp-default-vpn1] peer 2001:3::1 as-number 65430
[UPE2-bgp-default-vpn1] address-family ipv6 unicast
[UPE2-bgp-default-ipv6-vpn1] peer 2001:3::1 enable
[UPE2-bgp-default-ipv6-vpn1] quit
[UPE2-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 4.
[UPE2-bgp-default] ip vpn-instance vpn2
[UPE2-bgp-default-vpn2] peer 2001:4::1 as-number 65440
[UPE2-bgp-default-vpn2] address-family ipv6 unicast
[UPE2-bgp-default-ipv6-vpn2] peer 2001:4::1 enable
[UPE2-bgp-default-ipv6-vpn2] quit
[UPE2-bgp-default-vpn2] quit
[UPE2-bgp-default] quit
5. Configure CE 3.
[CE3-Ten-GigabitEthernet3/0/1] ipv6 address 2001:3::1 96
[CE3] bgp 65430
[CE3-bgp-default] peer 2001:3::2 as-number 100
[CE3-bgp-default] address-family ipv6 unicast
[CE3-bgp-default-ipv6] peer 2001:3::2 enable
[CE3-bgp-default-ipv6] import-route direct
[CE3-bgp-default-ipv6] quit
[CE3-bgp-default] quit
6. Configure CE 4.
[CE4-Ten-GigabitEthernet3/0/1] ipv6 address 2001:4::1 96
[CE4] bgp 65440
[CE4-bgp-default] peer 2001:4::2 as-number 100
[CE4-bgp-default-ipv6] peer 2001:4::2 enable
7. Configure SPE 1:
[Sysname] sysname SPE1
[SPE1] interface loopback 0
[SPE1-LoopBack0] ip address 2.2.2.9 32
[SPE1-LoopBack0] quit
[SPE1] mpls lsr-id 2.2.2.9
[SPE1] mpls ldp
[SPE1-ldp] quit
[SPE1] interface ten-gigabitethernet 3/0/1
[SPE1-Ten-GigabitEthernet3/0/1] ip address 172.1.1.2 24
[SPE1-Ten-GigabitEthernet3/0/1] mpls enable
[SPE1-Ten-GigabitEthernet3/0/1] mpls ldp enable
[SPE1-Ten-GigabitEthernet3/0/1] quit
[SPE1] interface ten-gigabitethernet 3/0/2
[SPE1-Ten-GigabitEthernet3/0/2] ip address 180.1.1.1 24
[SPE1-Ten-GigabitEthernet3/0/2] mpls enable
[SPE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[SPE1-Ten-GigabitEthernet3/0/2] quit
[SPE1] ospf
[SPE1-ospf-1] area 0
[SPE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] quit
[SPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2.
[SPE1] ip vpn-instance vpn1
[SPE1-vpn-instance-vpn1] route-distinguisher 500:1
[SPE1-vpn-instance-vpn1] vpn-target 100:1 both
[SPE1-vpn-instance-vpn1] quit
[SPE1] ip vpn-instance vpn2
[SPE1-vpn-instance-vpn2] route-distinguisher 700:1
[SPE1-vpn-instance-vpn2] vpn-target 100:2 both
[SPE1-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 2 and UPE 1, and specify UPE 1 as a UPE.
[SPE1] bgp 100
[SPE1-bgp-default] peer 1.1.1.9 as-number 100
[SPE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[SPE1-bgp-default] peer 3.3.3.9 as-number 100
[SPE1-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[SPE1-bgp-default] address-family vpnv6
[SPE1-bgp-default-vpnv6] peer 3.3.3.9 enable
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 enable
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 upe
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 next-hop-local
[SPE1-bgp-default-vpnv6] quit
# Create BGP-VPN instances for VPN instances vpn1 and vpn2, so the VPNv6 routes learned according to the RT attributes can be added into the BGP routing tables of the corresponding VPN instances.
[SPE1-bgp-default] ip vpn-instance vpn1
[SPE1-bgp-default-vpn1] quit
[SPE1-bgp-default] ip vpn-instance vpn2
[SPE1-bgp-default-vpn2] quit
[SPE1-bgp-default] quit
# Advertise to UPE 1 the routes permitted by a routing policy (the routes of CE 3).
[SPE1] ipv6 prefix-list hope index 10 permit 2001:3::1 96
[SPE1] route-policy hope permit node 0
[SPE1-route-policy-hope-0] if-match ipv6 address prefix-list hope
[SPE1-route-policy-hope-0] quit
[SPE1] bgp 100
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 upe route-policy hope export
8. Configure SPE 2:
[Sysname] sysname SPE2
[SPE2] interface loopback 0
[SPE2-LoopBack0] ip address 3.3.3.9 32
[SPE2-LoopBack0] quit
[SPE2] mpls lsr-id 3.3.3.9
[SPE2] mpls ldp
[SPE2-ldp] quit
[SPE2] interface ten-gigabitethernet 3/0/1
[SPE2-Ten-GigabitEthernet3/0/1] ip address 180.1.1.2 24
[SPE2-Ten-GigabitEthernet3/0/1] mpls enable
[SPE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
[SPE2-Ten-GigabitEthernet3/0/1] quit
[SPE2] interface ten-gigabitethernet 3/0/2
[SPE2-Ten-GigabitEthernet3/0/2] ip address 172.2.1.2 24
[SPE2-Ten-GigabitEthernet3/0/2] mpls enable
[SPE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
[SPE2-Ten-GigabitEthernet3/0/2] quit
[SPE2] ospf
[SPE2-ospf-1] area 0
[SPE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] quit
[SPE2-ospf-1] quit
[SPE2] ip vpn-instance vpn1
[SPE2-vpn-instance-vpn1] route-distinguisher 600:1
[SPE2-vpn-instance-vpn1] vpn-target 100:1 both
[SPE2-vpn-instance-vpn1] quit
[SPE2] ip vpn-instance vpn2
[SPE2-vpn-instance-vpn2] route-distinguisher 800:1
[SPE2-vpn-instance-vpn2] vpn-target 100:2 both
[SPE2-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 1 and UPE 2, and specify UPE 2 as a UPE.
[SPE2] bgp 100
[SPE2-bgp-default] peer 4.4.4.9 as-number 100
[SPE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[SPE2-bgp-default] peer 2.2.2.9 as-number 100
[SPE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[SPE2-bgp-default] address-family vpnv6
[SPE2-bgp-default-vpnv6] peer 2.2.2.9 enable
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 upe
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 next-hop-local
[SPE2-bgp-default-vpnv6] quit
[SPE2-bgp-default] ip vpn-instance vpn1
[SPE2-bgp-default-vpn1] quit
[SPE2-bgp-default] ip vpn-instance vpn2
[SPE2-bgp-default-vpn2] quit
[SPE2-bgp-default] quit
# Advertise to UPE 2 the routes permitted by a routing policy (the routes of CE 1).
[SPE2] ipv6 prefix-list hope index 10 permit 2001:1::1 96
[SPE2] route-policy hope permit node 0
[SPE2-route-policy-hope-0] if-match ipv6 address prefix-list hope
[SPE2-route-policy-hope-0] quit
[SPE2] bgp 100
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 upe route-policy hope export
# Verify that CE 1 and CE3 can learn each other's interface routes and can ping each other. CE 2 and CE 4 cannot learn each other's interface routes and cannot ping each other. (Details not shown.)
Configuration files
· UPE 1:
sysname UPE1
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
vpn-target 100:2 import-extcommunity
vpn-target 100:2 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
interface Ten-GigabitEthernet3/0/2
interface Ten-GigabitEthernet3/0/3
ip address 172.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 connect-interface LoopBack0
peer 2.2.2.9 enable
return
· CE 1:
sysname CE1
bgp 65410
router-id 5.5.5.5
import-route direct
return
· CE 2:
sysname CE2
bgp 65420
router-id 6.6.6.6
import-route direct
return
· UPE 2:
sysname UPE2
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 172.2.1.1 255.255.255.0
mpls enable
mpls ldp enable
ipv6 address 2001:3::2/96
ipv6 address 2001:4::2/96
bgp 100
peer 3.3.3.9 enable
return
· CE 3:
sysname CE3
ipv6 address 2001:3::1/96
bgp 65430
router-id 7.7.7.7
import-route direct
return
· CE 4:
sysname CE4
ipv6 address 2001:4::1/96
bgp 65440
router-id 8.8.8.8
import-route direct
return
· SPE 1:
sysname SPE1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 172.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 180.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 1.1.1.9 upe
peer 3.3.3.9 enable
ipv6 prefix-list hope index 10 permit 2001:3:: 96
return
· SPE 2:
sysname SPE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 180.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 172.2.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
peer 4.4.4.9 enable
peer 4.4.4.9 upe
ipv6 prefix-list hope index 10 permit 2001:1:: 96
return
Example: Configuring an OSPFv3 sham link
As shown in Figure 10, CE 1 and CE 2 belong to VPN 1. Configure an OSPFv3 sham link between PE 1 and PE 2 so traffic between the CEs is forwarded through the MPLS backbone instead of the backdoor link.
Table 19 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface4 |
Ten-GigabitEthernet3/0/4 |
Interface5 |
Ten-GigabitEthernet3/0/5 |
Table 20 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
100::1/64 |
CE 2 |
XGE3/0/1 |
120::1/64 |
XGE3/0/4 |
20::1/64 |
XGE3/0/4 |
30::2/64 |
PE 1 |
Loop0 |
1.1.1.9/32 |
PE 2 |
Loop0 |
2.2.2.9/32 |
Loop1 |
3::3/128 |
Loop1 |
5::5/128 |
XGE3/0/1 |
100::2/64 |
XGE3/0/1 |
120::2/64 |
XGE3/0/4 |
10.1.1.1/24 |
XGE3/0/5 |
10.1.1.2/24 |
Router A |
XGE3/0/5 |
30::1/64 |
XGE3/0/4 |
20::2/64 |
1. Configure OSPFv3 on the customer networks:
# Configure OSPFv3 on CE 1 and set the cost of the link between CE 1 and Router A to 2.
[CE1] ospfv3
[CE1-ospfv3-1] router-id 6.6.6.6
[CE1-ospfv3-1] area 1
[CE1-ospfv3-1-area-0.0.0.1] quit
[CE1-ospfv3-1] quit
[CE1]interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 100::1 64
[CE1-Ten-GigabitEthernet3/0/1] ospfv3 1 area 1
[CE1-Ten-GigabitEthernet3/0/4] ipv6 address 20::1 64
[CE1-Ten-GigabitEthernet3/0/4] ospfv3 cost 2
[CE1-Ten-GigabitEthernet3/0/4] ospfv3 1 area 1
[CE1] commit
# Configure OSPFv3 on CE 2 and set the cost of the link between CE 2 and Router A to 2.
[CE2] ospfv3
[CE2-ospfv3-1] router-id 8.8.8.8
[CE2-ospfv3-1] area 1
[CE2-ospfv3-1-area-0.0.0.1] quit
[CE2-ospfv3-1] quit
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 120::1 64
[CE2-Ten-GigabitEthernet3/0/1] ospfv3 1 area 1
[CE2-Ten-GigabitEthernet3/0/4] ipv6 address 30::2 64
[CE2-Ten-GigabitEthernet3/0/4] ospfv3 cost 2
[CE2-Ten-GigabitEthernet3/0/4] ospfv3 1 area 1
[CE2] commit
# Configure OSPFv3 on Router A.
[Sysname] sysname RouterA
[RouterA] ospfv3
[RouterA-ospfv3-1] router-id 7.7.7.7
[RouterA-ospfv3-1] area 1
[RouterA-ospfv3-1-area-0.0.0.1] quit
[RouterA-ospfv3-1] quit
[RouterA] interface ten-gigabitethernet 3/0/4
[RouterA-Ten-GigabitEthernet3/0/4] ipv6 address 20::2 64
[RouterA-Ten-GigabitEthernet3/0/4] ospfv3 1 area 1
[RouterA-Ten-GigabitEthernet3/0/4] quit
[RouterA] interface ten-gigabitethernet 3/0/5
[RouterA-Ten-GigabitEthernet3/0/5] ipv6 address 30::1 64
[RouterA-Ten-GigabitEthernet3/0/5] ospfv3 1 area 1
[RouterA-Ten-GigabitEthernet3/0/5] quit
[RouterA] commit
# Execute the display ipv6 routing-table command to verify that CE 1 and CE 2 have learned the route to each other. (Details not shown.)
2. Configure IPv6 MPLS L3VPN on the backbone:
# Configure basic MPLS and MPLS LDP on PE 1 to establish LDP LSPs.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/4] ip address 10.1.1.1 24
# Configure PE 1 to take PE 2 as an MP-IBGP peer.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default] address-family vpnv6
[PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
[PE1-bgp-default-vpnv6] quit
[PE1-bgp-default] quit
# Configure OSPF on PE 1.
[PE1] ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure basic MPLS and MPLS LDP on PE 2 to establish LDP LSPs.
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/5] ip address 10.1.1.2 24
# Configure PE 2 to take PE 1 as an MP-IBGP peer.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] address-family vpnv6
[PE2-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv6] quit
[PE2-bgp-default] quit
# Configure OSPF on PE 2.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE2-ospf-1] quit
3. Configure PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 100::2 64
[PE1-Ten-GigabitEthernet3/0/1] ospfv3 100 area 1
[PE1-Ten-GigabitEthernet3/0/1] quit
[PE1] ospfv3 100
[PE1-ospfv3-100] router-id 100.1.1.1
[PE1-ospfv3-100] domain-id 10
[PE1-ospfv3-100] quit
[PE1] bgp 100
[PE1-bgp-default-vpn1] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn1] import-route ospfv3 100
[PE1-bgp-default-ipv6-vpn1] import-route direct
[PE1-bgp-default-ipv6-vpn1] quit
[PE1-bgp-default-vpn1] quit
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 120::2 64
[PE2-Ten-GigabitEthernet3/0/1] ospfv3 100 area 1
[PE2-Ten-GigabitEthernet3/0/1] quit
[PE2] ospfv3 100
[PE2-ospfv3-100] router-id 120.1.1.1
[PE2-ospfv3-100] domain-id 10
[PE2-ospfv3-100] quit
[PE2] bgp 100
[PE2-bgp-default-vpn1] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn1] import-route ospfv3 100
[PE2-bgp-default-ipv6-vpn1] import-route direct
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
# Execute the display ipv6 routing-table vpn-instance command on the PEs. Verify that the path to the peer CE is along the OSPFv3 route across the customer networks, instead of the IPv6 BGP route across the backbone. (Details not shown.)
4. Configure a sham link:
# Configure PE 1.
[PE1] interface loopback 1
[PE1-LoopBack1] ip binding vpn-instance vpn1
[PE1-LoopBack1] ipv6 address 3::3 128
[PE1-LoopBack1] quit
[PE1] ospfv3 100
[PE1-ospfv3-100] area 1
[PE1-ospfv3-100-area-0.0.0.1] sham-link 3::3 5::5
[PE1-ospfv3-100-area-0.0.0.1] quit
# Configure PE 2.
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance vpn1
[PE2-LoopBack1] ipv6 address 5::5 128
[PE2-LoopBack1] quit
[PE2] ospfv3 100
[PE2-ospfv3-100] area 1
[PE2-ospfv3-100-area-0.0.0.1] sham-link 5::5 3::3
[PE2-ospfv3-100-area-0.0.0.1] quit
# Execute the display ipv6 routing-table vpn-instance command on the PEs to verify the following results (details not shown):
· The path to the peer CE is now along the IPv6 BGP route across the backbone.
· A route to the sham link destination address exists.
The following is the sample output from the command on PE 1:
[PE1] display ipv6 routing-table vpn-instance vpn1
Destination: 3::3/128 Protocol : Direct
Interface : Loop1 Cost : 0
Destination: 5::5/128 Protocol : BGP4+
NextHop : ::FFFF:2.2.2.9 Preference: 255
Interface : XGE3/0/4 Cost : 0
Destination: 20::/64 Protocol : O_INTRA
NextHop : FE80::8824:DAFF:FEF0:306 Preference: 10
Interface : XGE3/0/1 Cost : 3
Destination: 30::/64 Protocol : O_INTRA
Interface : XGE3/0/1 Cost : 4
Destination: 100::/64 Protocol : Direct
Destination: 100::2/128 Protocol : Direct
Destination: 120::/64 Protocol : BGP4+
# Execute the display ipv6 routing-table command on the CEs. Verify that the next hop of the OSPFv3 route to the peer CE is the interface connected to the PE (Ten-GigabitEthernet 3/0/1). This means that the VPN traffic to the peer CE is forwarded over the backbone.
[CE1] display ipv6 routing-table
Destinations : 8 Routes : 8
Destination: 20::/64 Protocol : Direct
Destination: 20::1/128 Protocol : Direct
NextHop : FE80::8824:DDFF:FE48:409 Preference: 10
Interface : XGE3/0/4 Cost : 3
Destination: 100::1/128 Protocol : Direct
Destination: 120::/64 Protocol : O_INTRA
NextHop : FE80::8816:C4FF:FE9D:106 Preference: 10
# Verify that a sham link has been established on PEs, for example, on PE 1.
[PE1] display ospfv3 sham-link
OSPFv3 Process 100 with Router ID 100.1.1.1
Sham-link (Area: 0.0.0.1)
Neighbor ID State Instance ID Destination address
120.1.1.1 P-2-P 0 5::5
# Verify that the peer state is Full on PE 1.
[PE1] display ospfv3 sham-link verbose
Source : 3::3
Destination : 5::5
Interface ID: 2147483649
Neighbor ID : 120.1.1.1, Neighbor state: Full
Cost: 1 State: P-2-P Type: Sham Instance ID: 0
Timers: Hello 10, Dead 40, Retransmit 5, Transmit delay 1
Request list: 0 Retransmit list: 0
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
ospfv3 100 vpn-instance vpn1
router-id 100.1.1.1
domain-id 0.0.0.10
area 0.0.0.1
sham-link 3::3 5::5
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
interface LoopBack1
ipv6 address 3::3/128
ospfv3 100 area 0.0.0.1
ipv6 address 100::2/64
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
import-route direct
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
router-id 120.1.1.1
domain-id 0.0.0.10
area 0.0.0.1
sham-link 5::5 3::3
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
interface LoopBack1
ipv6 address 5::5/128
ipv6 address 120::2/64
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
import-route direct
return
· CE 1:
sysname CE1
ospfv3 1
router-id 6.6.6.6
area 0.0.0.1
ospfv3 1 area 0.0.0.1
ipv6 address 100::1/64
ospfv3 cost 2
return
· CE 2:
sysname CE2
ospfv3 1
router-id 8.8.8.8
area 0.0.0.1
ipv6 address 120::1/64
ospfv3 cost 2
return
· Router A:
sysname RouterA
ospfv3 1
router-id 7.7.7.7
area 0.0.0.1
return
Example: Configuring BGP AS number substitution
As shown in Figure 11, CE 1 and CE 2 belong to VPN 1, and are connected to PE 1 and PE 2. The two CEs have the same AS number, 600. Configure BGP AS number substitution on the PEs to avoid route loss.
Table 21 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Table 22 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10:1::2/96 |
P |
Loop0 |
2.2.2.9/32 |
XGE3/0/2 |
100::1/96 |
XGE3/0/1 |
20.1.1.2/24 |
PE 1 |
Loop0 |
10.1.1.1/32 |
XGE3/0/2 |
30.1.1.1/24 |
XGE3/0/1 |
10:1::1/96 |
PE 2 |
Loop0 |
10.1.1.2/32 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/1 |
10:2::1/96 |
CE 2 |
XGE3/0/1 |
10:2::2/96 |
XGE3/0/2 |
30.1.1.2/24 |
XGE3/0/2 |
200::1/96 |
1. Configure an IGP (OSPF in this example) on the MPLS backbone to establish connectivity between the PEs and the P device.
# Configure PE 1.
[PE1-LoopBack0] ip address 10.1.1.1 32
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip address 20.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/2] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.1 0.0.0.0
[PE1-ospf-1] quit
# Configure the P device.
[Sysname] sysname P
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface ten-gigabitethernet 3/0/1
[P-Ten-GigabitEthernet3/0/1] ip address 20.1.1.2 24
[P-Ten-GigabitEthernet3/0/1] quit
[P] interface ten-gigabitethernet 3/0/2
[P-Ten-GigabitEthernet3/0/2] ip address 30.1.1.1 24
[P-Ten-GigabitEthernet3/0/2] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 10.1.1.2 32
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip address 30.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/2] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 10.1.1.2 0.0.0.0
[PE2-ospf-1] quit
# Verify that OSPF neighbor relationships can be established between PE 1, the P device, and PE 2:
¡ Execute the display ospf peer command on each device to verify that their OSPF neighbors have reached the FULL state.
¡ Execute the display ip routing-table command to verify that the PEs can learn the routes to the Loopback interfaces on the remote PEs.
2. Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls lsr-id 10.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/2] mpls enable
[PE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/1] mpls enable
[P-Ten-GigabitEthernet3/0/1] mpls ldp enable
[P-Ten-GigabitEthernet3/0/2] mpls enable
[P-Ten-GigabitEthernet3/0/2] mpls ldp enable
[P] commit
# Configure PE 2.
[PE2] mpls lsr-id 10.1.1.2
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/2] mpls enable
[PE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
# Verify that LDP sessions can be established between PE 1, the P device, and PE 2:
¡ Execute the display mpls ldp peer command on each device to verify that their LDP sessions are in operational state.
¡ Execute the display mpls ldp lsp command to verify establishment of LDP LSPs.
3. Configure VPN instances on PEs to provide network access for CEs:
# Configure PE 1.
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 10:1::1 96
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 10:2::1 96
# Configure CE 1.
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 10:1::2 96
[CE1] interface ten-gigabitethernet 3/0/2
[CE1-Ten-GigabitEthernet3/0/2] ipv6 address 100::1 96
[CE1-Ten-GigabitEthernet3/0/2] quit
# Configure CE 2.
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 10:2::2 96
[CE2] interface ten-gigabitethernet 3/0/2
[CE2-Ten-GigabitEthernet3/0/2] ipv6 address 200::1 96
[CE2-Ten-GigabitEthernet3/0/2] quit
# Execute the display ip vpn-instance command on the PEs to verify the VPN instance configuration. Make sure the PEs can ping the CEs attached to them.
4. Establish EBGP peer relationships between each PE and the CE attached to them, and import VPN IPv4 routes.
# Configure CE 1.
[CE1] bgp 600
[CE1-bgp-default] router-id 4.4.4.4
[CE1-bgp-default] peer 10:1::1 as-number 100
[CE1-bgp-default-ipv6] peer 10:1::1 enable
# Configure CE 2.
[CE2] bgp 600
[CE2-bgp-default] router-id 5.5.5.5
[CE2-bgp-default] peer 10:2::1 as-number 100
[CE2-bgp-default-ipv6] peer 10:2::1 enable
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10:1::2 as-number 600
[PE1-bgp-default-ipv6-vpn1] peer 10:1::2 enable
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10:2::2 as-number 600
[PE2-bgp-default-ipv6-vpn1] peer 10:2::2 enable
# Execute the display bgp peer ipv6 vpn-instance command on the PEs to verify that they have established BGP peer relationships with their CEs and the peer relationships are in Established state.
5. Establish MP-IBGP peer relationships between PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 10.1.1.2 as-number 100
[PE1-bgp-default] peer 10.1.1.2 connect-interface loopback 0
[PE1-bgp-default-vpnv6] peer 10.1.1.2 enable
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 10.1.1.1 as-number 100
[PE2-bgp-default] peer 10.1.1.1 connect-interface loopback 0
[PE2-bgp-default-vpnv6] peer 10.1.1.1 enable
# Execute the display ipv6 routing-table command on CE 2 to verify that CE 2 has not learned the route to the VPN (100::/96) behind CE 1.
[CE2] display ipv6 routing-table
Destinations : 6 Routes : 6
Destination: 10:2::/96 Protocol : Direct
Destination: 10:2::2/128 Protocol : Direct
Destination: 200::/96 Protocol : Direct
Interface : XGE3/0/2 Cost : 0
Destination: 200::1/128 Protocol : Direct
# Execute the display ipv6 routing-table vpn-instance command on the PEs. The output shows the route to the VPN behind the peer CE. This example uses PE 2.
[PE2] display ipv6 routing-table vpn-instance vpn1
Destinations : 7 Routes : 7
Destination: 10:1::/96 Protocol : BGP4+
NextHop : ::FFFF:10.1.1.1 Preference: 255
Destination: 10:2::1/128 Protocol : Direct
Destination: 100::/96 Protocol : BGP4+
Destination: 200::/96 Protocol : BGP4+
NextHop : 10:2::2 Preference: 255
# Enable BGP update packet debugging on CE 2.
<CE2> terminal monitor
<CE2> terminal logging level 7
<CE2> debugging bgp update 10:2::1 ipv6
# Soft-reset all BGP sessions on PE 2.
<PE2> refresh bgp all export ipv6 vpn-instance vpn1
# View the debugging messages on CE 2. The messages show that CE 2 received the route towards CE 1 from PE 2, with an AS path list of 100 600. Because AS number 600 in the AS path list is the local AS number of CE 2, CE 2 determined that a loop exists and ignored the route.
<CE2>*Apr 27 14:24:34:235 2025 CE2 BGP/7/DEBUG:
BGP_IPV6.: Recv UPDATE from peer 10:2::1 with following destinations:
Update message length : 107
Origin : Incomplete
AS path : 100 600
Next hop : 10:2::1
BGP.: Error identified while receiving UPDATE message from the peer 10:2::1 and ignored
Reason: Looping in ASPATH value.
10:1::/96 PathID 0 ,
100::/96 PathID 0 ,
6. Configure BGP AS number substitution:
# Configure BGP AS number substitution on PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10:1::2 substitute-as
# Configure BGP AS number substitution on PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10:2::2 substitute-as
# On CE 2, verify that among the routes advertised by PE 2 to CE 2, the AS path lists in the routes for 10:1::/96 and 100::/96 have changed from 100 600 to 100 100.
<CE2>*Apr 27 14:26:19:224 2025 CE2 BGP/7/DEBUG:
Origin : Incomplete
AS path : 100 100
Next hop : 10:2::1
*Apr 27 14:26:19:224 2025 CE2 BGP/7/DEBUG: -MDC=1;
100::/96 PathID 0 ,
# Verify that CEs have learned routes to each other. Take CE 2 for example:
<CE2> display ipv6 routing-table
NextHop : 10:2::1 Preference: 255
# Verify that CE 1 and CE 2 can ping the interface addresses of each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 111:1 import-extcommunity
vpn-target 111:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls ldp
interface LoopBack0
ip address 10.1.1.1 255.255.255.255
ipv6 address 10:1::1/96
ip address 20.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 10.1.1.2 connect-interface LoopBack0
peer 10:1::2 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 20.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls ldp
interface LoopBack0
ip address 10.1.1.2 255.255.255.255
ipv6 address 10:2::1/96
mpls enable
mpls ldp enable
bgp 100
peer 10.1.1.1 connect-interface LoopBack0
peer 10:2::2 enable
return
· CE 1:
sysname CE1
ipv6 address 10:1::2/96
ipv6 address 100::1/96
bgp 600
router-id 4.4.4.4
import-route direct
peer 10:1::1 enable
return
· CE 2:
sysname CE2
ipv6 address 10:2::2/96
ipv6 address 200::1/96
bgp 600
router-id 5.5.5.5
import-route direct
peer 10:2::1 enable
return
Example: Configuring BGP AS number substitution and SoO attribute
CE 1, CE 2, and CE 3 belong to VPN 1, and are connected to PE1, PE 2, and PE 3. CE 1 and CE 2 reside in the same site. CE1, CE2, and CE 3 all use AS number 600.
To avoid route loss, configure BGP AS number substitution on PEs.
To avoid routing loops, configure the same SoO attribute on PE 1 and PE 2 for CE 1 and CE 2.
Figure 12 Network diagram
Table 23 Interface label and interface name mappings
Interface label |
Interface name |
Interface1 |
Interface2 |
Interface3 |
Table 24 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
Loop0 |
100::1/96 |
CE 3 |
Loop0 |
200::1/96 |
XGE3/0/1 |
10:1::1/96 |
XGE3/0/1 |
10:3::1/96 |
CE 2 |
XGE3/0/1 |
10:2::1/96 |
PE 2 |
Loop0 |
2.2.2.9/32 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/1 |
10:2::2/96 |
XGE3/0/1 |
10:1::2/96 |
XGE3/0/2 |
40.1.1.1/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/3 |
20.1.1.2/24 |
XGE3/0/3 |
30.1.1.1/24 |
P |
Loop0 |
3.3.3.9/32 |
PE 3 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/1 |
10:3::2/96 |
XGE3/0/2 |
40.1.1.2/24 |
XGE3/0/2 |
50.1.1.2/24 |
XGE3/0/3 |
50.1.1.1/24 |
1. Configure an IGP (OSPF in this example) on the MPLS backbone to establish connectivity between the PEs and the P device:
# Configure PE 1.
[PE1] interface ten-gigabitethernet 3/0/3
[PE1-Ten-GigabitEthernet3/0/3] ip address 30.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/3] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure PE 2.
[PE2-Ten-GigabitEthernet3/0/2] ip address 40.1.1.1 24
[PE2] interface ten-gigabitethernet 3/0/3
[PE2-Ten-GigabitEthernet3/0/3] ip address 20.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE2-ospf-1] quit
[Sysname] sysname P
[P-LoopBack0] ip address 3.3.3.9 32
[P-LoopBack0] quit
[P-Ten-GigabitEthernet3/0/1] ip address 30.1.1.2 24
[P-Ten-GigabitEthernet3/0/2] ip address 40.1.1.2 24
[P] interface ten-gigabitethernet 3/0/3
[P-Ten-GigabitEthernet3/0/3] ip address 50.1.1.1 24
[P-Ten-GigabitEthernet3/0/3] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[P-ospf-1] quit
# Configure PE 3.
[PE3-LoopBack0] ip address 4.4.4.9 32
[PE3] interface ten-gigabitethernet 3/0/2
[PE3-Ten-GigabitEthernet3/0/2] ip address 50.1.1.2 24
[PE3-Ten-GigabitEthernet3/0/2] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[PE3-ospf-1] quit
# Verify that OSPF neighbor relationships can be established between PE 1, PE 2, the P device, and PE 3:
¡ Execute the display ip routing-table command to verify that the PEs can learn the routes to the loopback interfaces on the remote PEs.
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/3] mpls enable
[PE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/3] mpls enable
[PE2-Ten-GigabitEthernet3/0/3] mpls ldp enable
[P] mpls lsr-id 3.3.3.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/3] mpls enable
[P-Ten-GigabitEthernet3/0/3] mpls ldp enable
# Configure PE 3.
[PE3] mpls lsr-id 4.4.4.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-Ten-GigabitEthernet3/0/2] mpls enable
[PE3-Ten-GigabitEthernet3/0/2] mpls ldp enable
# Verify that LDP sessions can be established between PE 1, PE 2, the P device, and PE 3:
# Configure PE 1.
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 10:1::2 96
# Configure PE 2.
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 10:2::2 96
# Configure PE 3.
[PE3-vpn-instance-vpn1] route-distinguisher 300:1
[PE3-vpn-instance-vpn1] vpn-target 111:1
[PE3-Ten-GigabitEthernet3/0/1] ipv6 address 10:3::2 96
# Configure CE 1.
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 10:1::1 96
[CE1-LoopBack0] ipv6 address 100::1 96
# Configure CE 2.
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 10:2::1 96
# Configure CE 3.
[CE3-Ten-GigabitEthernet3/0/1] ipv6 address 10:3::1 96
[CE3] interface loopback 0
[CE3-LoopBack0] ipv6 address 200::1 96
[CE3-LoopBack0] quit
4. Establish EBGP peer relationships between each PE and the CE attached to them, and redistribute VPN routes:
# Configure CE 1.
[CE1] bgp 600
[CE1-bgp-default] router-id 5.5.5.5
[CE1-bgp-default] peer 10:1::2 as-number 100
[CE1-bgp-default-ipv6] peer 10:1::2 enable
# Configure CE 2.
[CE2] bgp 600
[CE2-bgp-default] router-id 6.6.6.6
[CE2-bgp-default] peer 10:2::2 as-number 100
[CE2-bgp-default-ipv6] peer 10:2::2 enable
# Configure CE 3.
[CE3] bgp 600
[CE3-bgp-default] peer 10:3::2 as-number 100
[CE3-bgp-default-ipv6] peer 10:3::2 enable
5. Configure BGP AS number substitution:
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10:1::1 as-number 600
[PE1-bgp-default-vpn1] peer 10:1::1 substitute-as
[PE1-bgp-default-ipv6-vpn1] peer 10:1::1 enable
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10:2::1 as-number 600
[PE2-bgp-default-vpn1] peer 10:2::1 substitute-as
[PE2-bgp-default-ipv6-vpn1] peer 10:2::1 enable
# Configure BGP AS number substitution on PE 3.
[PE3] bgp 100
[PE3-bgp-default-vpn1] peer 10:3::1 as-number 600
[PE3-bgp-default-vpn1] peer 10:3::1 substitute-as
[PE3-bgp-default-ipv6-vpn1] peer 10:3::1 enable
# Execute the display bgp peer ipv4 vpn-instance command on the PEs to verify that they have established BGP peer relationships with their CEs and the peer relationships are in Established state.
6. Establish MP-IBGP peer relationships between PEs and specify PE 1 as the RR:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv6] peer 2.2.2.9 reflect-client
[PE1-bgp-default-vpnv6] peer 4.4.4.9 enable
[PE1-bgp-default-vpnv6] peer 4.4.4.9 reflect-client
# Configure PE 2.
[PE2] bgp 100
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE3-bgp-default-vpnv6] quit
[PE3] commit
7. Configure BGP SoO attributes:
# Display routing information on CE 2. The output shows that CE 2 has learned the route for 100::/96 from CE 1. Routing loop occurs when the route advertised by CE 1 is re-advertised back to the site where CE 1 and CE 2 reside via PE 1, PE 2, and CE 2.
Destination: 10:3::/96 Protocol : BGP4+
# On PE 1, configure the SoO attribute as 1:100 for CE 1.
<PE1> system-view
[PE1] bgp 100
[PE1-bgp-default-ipv6-vpn1] peer 10:1::1 soo 1:100
# On PE 2, configure the SoO attribute as 1:100 for CE 2.
<PE2> system-view
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] peer 10:2::1 soo 1:100
# PE 2 does not advertise routes received from CE 1 to CE 2 because the same SoO attribute has been configured. Display the routing table of CE 2. The output shows that the route 100::/96 has been removed.
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 4.4.4.9 connect-interface LoopBack0
peer 2.2.2.9 enable
peer 4.4.4.9 enable
peer 10:1::1 enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 40.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 10:2::1 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
ip address 40.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 50.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
return
· PE 3:
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 4.4.4.9 255.255.255.255
ipv6 address 10:3::2/96
ip address 50.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 10:3::1 enable
return
· CE 1:
sysname CE1
interface LoopBack0
bgp 600
router-id 5.5.5.5
import-route direct
peer 10:1::2 enable
return
· CE 2:
sysname CE2
bgp 600
router-id 6.6.6.6
import-route direct
peer 10:2::2 enable
return
· CE 3:
sysname CE3
interface LoopBack0
ipv6 address 10:3::1/96
bgp 600
router-id 7.7.7.7
import-route direct
peer 10:3::2 enable
return
