17-BRAS Services Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command Reference-R8630Pxx-6W10017-BRAS Services Command Reference
12-UCM commands
12-UCM commands 1.04 MB
UCM commands· 1
access-limit 1
access-user adjustment access-rate-limit minor severe· 2
access-user adjustment accounting-update enable· 3
access-user adjustment traffic enable· 4
access-user adjustment user-detect enable· 5
access-user authen-and-accounting without-ipv6-prefix· 6
access-user authen-rate· 7
access-user authen-rate minor severe· 8
access-user change nat-instance user-group· 9
access-user cpu-warning log enable· 10
access-user flow-rate-calculate enable· 11
access-user four-dimension-mode enable· 13
access-user interface send gratuitous-arp (on UPs) 13
access-user interface-switchto-backup keep-host-routes· 15
access-user log enable· 16
access-user max-connections· 17
access-user max-connections minor severe· 18
access-user nat-info-change send-accounting-update· 19
access-user online-fail-warning· 20
access-user send gratuitous-arp (on UPs) 21
access-user send gratuitous-arp rate-limit (on UPs) 22
access-user sense cpu-usage enable· 23
access-user session-threshold· 24
access-user url character-transfer‌ 26
access-user user-detect packet-loss-ratio-threshold‌· 28
bras auto-cut-user before-reboot 30
bras compatible old-style-commands enable‌· 30
bras data-backup-mode· 32
cut access-user 34
display access-user 38
display access-user authen-rate status· 80
display access-user max-connections status· 82
display access-user statistics· 83
display access-user backup-state· 88
display access-user offline-reason statistics· 88
display access-user user-detect packet-loss-ratio‌· 90
display access-user user-plane (on UPs) 93
display bras-interface access-user-count 105
display bras-interface configuration· 106
display bras-interface users-by-vlan· 125
display max-user history· 126
display trace access-user 128
flow-statistics frequency· 130
nas-port-type· 130
reset access-user offline-reason statistics· 132
reset access-user user-detect packet-loss-ratio‌· 133
reset max-user history· 134
slot-user-warning-threshold· 135
snmp-agent trap enable slot-user-warning-threshold· 136
snmp-agent trap enable user-warning-threshold· 137
trace access-user 138
user-policy interface-down online· 140
work-mode user-plane (on UPs) 141
UCM commands
On a CUPS network, this device acts only as a UP. When executing operation commands in this chapter (commands except the display commands), follow these restrictions and guidelines:
·     If a command is tagged with (UPs), this command can be executed only on a UP. Before executing this command on a UP, make sure you are fully aware of the impact of this command on the current network and prevent configuration errors from causing network failures.
·     If a command does not have any tag, this command can be executed only on a CP by default. To execute this command on a UP, do that under the guidance of professionals, make sure you are fully aware of the impact of this command on the current network, and prevent configuration errors from causing network failures.
access-limit
Use access-limit to configure the maximum number of access users allowed on an interface.
Use undo access-limit to restore the default.
access-limit user-number [ start-vlan start-vlan [ end-vlan end-vlan ] [ qinq qinq-vlan ] ]
undo access-limit [ start-vlan start-vlan [ end-vlan end-vlan ] [ qinq qinq-vlan ] ]
The maximum number of access users on an interface is not limited.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
L3VE interface/subinterface view
user-number: Specifies the maximum number of access users allowed. The value range is 1 to 64000.
start-vlan start-vlan: Specifies the start VLAN in the range of 1 to 4094. In QinQ applications, this option specifies the start inner VLAN. Only subinterfaces support this option.
end-vlan end-vlan: Specifies the end VLAN in the range of 1 to 4094. In QinQ applications, this option specifies the end inner VLAN. The end VLAN cannot be smaller than the start VLAN. Only subinterfaces support this option.
qinq qinq-vlan: Specifies the outer VLAN of QinQ in the range of 1 to 4094. If you specify start-vlan and do not specify qinq, all outer VLANs 1 through 4094 are each allocated to the specified inner VLAN. Only subinterfaces support this option.
When you execute this command, follow these restrictions and guidelines:
·     If no VLAN is specified, the following rules apply:
¡     For a main interface, the user-number argument specifies the maximum number of access users allowed on the main interface.
¡     For a subinterface, the user-number argument specifies the maximum number of access users allowed on each single VLAN or each inner-outer VLAN pair of the subinterface.
·     If VLANs are specified in this command, this command specifies the maximum number of users in each of the specified VLANs. For example, if you specify the start-vlan start-vlan and end-vlan end-vlan keywords in this command, this command specifies the maximum number of users allowed in each of the VLANs from the start VLAN to the end VLAN.
·     If one access-limit command is configured with VLANs and another access-limit command is not configured with VLANs, the number of users in the specified VLANs is limited by the first command and the number of users in the other VLANs is limited by the second command.
·     For a single VLAN or a single inner-outer VLAN pair, the most recent configuration takes effect. For example, if you first execute the access-limit 50 start-vlan 1 end-vlan 3 command and then the access-limit 100 start-vlan 2 end-vlan 3 command, the maximum number of users allowed is 100 in VLAN 2 or VLAN 3 and 50 in VLAN 1.
If the configured limit is smaller than the number of existing users on an interface (or VLANs on an interface), the configuration succeeds and the existing users are not affected. However, new users cannot access on the interface (or VLANs on the interface).
When this command is executed together with the pppoe-server session-limit per-vlan command and the access-limit command in an ISP domain, the three commands all take effect. The three commands control the number of users on the interface (or VLANs on the interface) in different perspectives, and the number of users is controlled by all the three commands. A new PPPoE user can access only when none of these limits is reached.
When this command is executed together with the access-limit command in an ISP domain, the two commands both take effect. The two commands control the number of BRAS users on the interface (or VLANs on the interface) in different perspectives, and the number of BRAS users is controlled by both commands. A new BRAS user can access only when neither limit is reached.
#Set the maximum number of access users allowed on Ten-GigabitEthernet 3/1/1.1. For packets with a single layer of VLAN tags, set the maximum number of access users to 100 for packets with VLAN tag 2. For packets with two layers of VLAN tags, set the maximum number of access users to 100 for each combination of inner VLAN 2 and any of outer VLANs 1 through 4094.
[Sysname] interface ten-gigabitethernet 3/1/1.1
[Sysname-Ten-GigabitEthernet3/1/1.1] access-limit 100 start-vlan 2
access-limit (BRAS Services Command Reference)
pppoe-server session-limit per-vlan (BRAS Services Command Reference)
Use access-user adjustment access-rate-limit minor severe to configure the user access rates at different CPU usage levels on the device.
Use undo access-user adjustment access-rate-limit minor severe to restore the default.
access-user adjustment access-rate-limit minor access-rate severe access-rate
The device is not enabled to adjust the access rate of online users based on CPU usage.
minor: Specifies the user access rate when the CPU usage reaches the minor level (level-1 alarm).
severe: Specifies the user access rate when the CPU usage reaches the severe level (level-2 alarm).
access-rate: Limits the DHCPv4, DHCPv6, and PPPoE user access rate to the specified percentage of the maximum access rate when the CPU usage reaches the alarm threshold. The value ranges from 1 to 99.
Application scenarios
Use this command when the device CPU usage is high. This feature reduces the device load and frees up CPU resources by adjusting the user access rate.
Operating mechanism
When the CPU usage of the device reaches the minor or severe level, the DHCPv4, DHCPv6, and PPPoE user access rate drops to the specified percentage of the maximum access rate. This prevents excessive CPU resource consumption.
# When the CPU usage reaches the minor level, reduce the DHCPv4, DHCPv6, and PPPoE user access rate to 80% of the maximum access rate.  When the CPU usage reaches the severe level, reduce the access rate to 60% of the maximum access rate.
[Sysname] access-user adjustment access-rate-limit minor 80 severe 60
Use access-user adjustment accounting-update enable to enable the device to adjust the real-time accounting packet sending frequency based on CPU usage.
Use undo access-user adjustment accounting-update enable to restore the default.
The device is not enabled to adjust the real-time accounting packet sending frequency based on CPU usage.
Use this command when the device CPU usage is high. This feature reduces the device load and frees up CPU resources by adjusting the real-time accounting packet sending frequency.
Operating mechanism
By default, the device sends a real-time accounting update packet at each accounting interval. After you enable the device to adjust the real-time accounting packet sending frequency based on CPU usage, the device sends a real-time accounting update packet at double the time interval when the CPU usage reaches the minor level (level-1 alarm). The device sends a real-time accounting update packet at triple the time interval when the CPU usage reaches the severe level (level-2 alarm).
# Enable the device to adjust the real-time accounting packet sending frequency based on CPU usage.
[Sysname] access-user adjustment accounting-update enable
Use access-user adjustment traffic enable to enable the device to adjust the online user traffic statistics collection frequency based on CPU usage.
Use undo access-user adjustment traffic enable to restore the default.
The device is not enabled to adjust the online user traffic statistics collection frequency based on CPU usage.
Use this command when the device CPU usage is high. This feature reduces the device load and frees up CPU resources by adjusting the online user traffic statistics collection frequency.
Operating mechanism
After you enable the device to adjust the online user traffic statistics collection frequency based on CPU usage, the device collects online user traffic statistics at the slowest configurable frequency when the CPU usage reaches the minor level (level-1 alarm). The device collects online user traffic statistics at half the slowest configurable frequency when the CPU usage reaches the severe level (level-2 alarm).
# Enable the device to adjust the online user traffic statistics collection frequency based on CPU usage.
[Sysname] access-user adjustment traffic enable
Use access-user adjustment user-detect enable to enable the device to adjust the user detection frequency based on CPU usage.
Use undo access-user adjustment user-detect enable to restore the default.
The device is not enabled to adjust the user detection frequency based on CPU usage.
Use this command when the device CPU usage is high. This feature reduces the device load and frees up CPU resources by adjusting the user detection packet sending frequency.
Operating mechanism
When you enable the online user detection feature, the device sends a detection packet at each time interval by default. After you enable the device to adjust the user detection frequency based on CPU usage, the device sends a detection packet at double the time interval when the CPU usage reaches the minor level (level-1 alarm). The device sends a detection packet at triple the time interval when the CPU usage reaches the severe level (level-2 alarm).
The ip subscriber adjustment user-detect cpu-usage and access-user adjustment user-detect enable commands are mutually exclusive. Do not execute both commands at the same time.
# Enable the device to adjust the user detection frequency based on CPU usage.
[Sysname] access-user adjustment user-detect enable
Use access-user authen-and-accounting without-ipv6-prefix to configure the BRAS not to carry attribute 97 when sending authentication and accounting packets to the AAA server.
Use undo access-user authen-and-accounting without-ipv6-prefix to restore the default.
The BRAS carries attribute 97 when sending authentication and accounting packets to the AAA server.
Attribute 97 (Framed-IPv6-Prefix) indicates the user's IPv6 prefix information, with a prefix length of 64 bits.
By default, in the IPv6 scenario, the BRAS will fill in the first 64 bits of a user IPv6 address as a prefix in attribute 97 when sending authentication and accounting packets to the AAA server. This facilitates the AAA server to manage and control the user IPv6 addresses. However, for certain ISPs or application scenarios, providing IPv6 prefix information in non-ND user scenarios might not be necessary or secure. In this case, you can use the access-user authen-and-accounting without-ipv6-prefix command to disable carrying attribute 97.
Operating mechanism
After the access-user authen-and-accounting without-ipv6-prefix command is executed, the BRAS no longer carries attribute 97 when sending authentication and accounting packets to the AAA server. This command effectively prevents the transmission of IPv6 prefix information, reduces the risk of user information leakage, enhances network security, and protects user privacy.
·     This feature is only applicable to non-ND user scenarios. For example, IPoE unclassified-IPv6 users, DHCPv6 users, and static users.
·     For ND user scenarios (such as ND prefix sharing scenarios or one ND prefix per user scenarios), the BRAS will always carry attribute 97 when sending authentication and accounting packets to the AAA server, and cannot be configured to not carry attribute 97 through this command.
·     If the AAA server needs to obtain the IPv6 prefix information of the user devices, prohibiting the sending of attribute 97 might cause AAA authentication failure or accounting errors. Configure this feature as needed.
# Configure the BRAS not to carry attribute 97 when sending authentication and accounting packets to the AAA server.
[Sysname] access-user authen-and-accounting without-ipv6-prefix
Use access-user authen-rate to configure the access user authentication rate for the device.
Use undo access-user authen-rate to restore the default.
access-user authen-rate authen-number authen-period [ force ]
The access user authentication rate is not set.
authen-number: Specifies the maximum number of users allowed for access authentication within the specified statistics collection interval. The value range is 1 to 65535.
authen-period: Specifies the statistics collection interval for the user access authentication on the device. The value range is 1 to 65535 seconds.
force: Forces the configuration of this command to take effect. If you do not specify this keyword, the actual access user authentication rate on the device might be affected by other commands.
Use this command when the device CPU usage is high. This feature reduces the device load and frees up CPU resources by adjusting the access user authentication rate.
Operating mechanism
The maximum number of authenticated access users allowed within the specified statistics collection interval is the specified value. The device will reject any users exceeding this upper limit to prevent excessive CPU resource consumption.
When you execute both the access-user authen-rate and access-user authen-rate minor severe commands, the following rules apply:
·     If you specify the force keyword in the access-user authen-rate command, the device uses the authentication rate configured by using the access-user authen-rate command.
·     If you do not specify the force keyword in the access-user authen-rate command, the device uses the authentication rate configured by using the access-user authen-rate command when the CPU usage is below the alarm threshold.  If the CPU usage reaches the alarm threshold, the device uses the smaller authentication rate value configured by the two commands.
# Configure the device to authenticate up to 3333 access users in each 10-second authentication statistics collection interval.
[Sysname] access-user authen-rate 3333 10
Use access-user authen-rate minor severe to configure the access user authentication rate at different CPU usage levels.
Use undo access-user authen-rate minor to restore the default.
access-user authen-rate minor authen-number authen-period severe authen-number authen-period
minor: Specifies the access user authentication rate when the CPU usage reaches the minor level (level-1 alarm).
severe: Specifies the access user authentication rate when the CPU usage reaches the severe level (level-2 alarm).
Operating mechanism
When the device's CPU usage reaches the minor or severe level, the maximum number of authenticated access users allowed within the specified statistics collection interval is the specified value. The device will reject any users exceeding this upper limit to prevent excessive CPU resource consumption.
# When the CPU usage reaches the minor level, the device can authenticate up to 3333 access users within a 10-second authentication statistics collection interval.  When the CPU usage reaches the severe level, the device can authenticate up to 1111 access users within a 10-second authentication statistics collection interval.
[Sysname] access-user authen-rate minor 3333 10 severe 1111 10
Use access-user change nat-instance user-group to manually change the binding between the load-sharing user group and NAT instance for an access user.
access-user change user-id user-id nat-instance nat-instance-name user-group user-group-name
user-id user-id: Specifies an online user by its ID. The user-id argument specifies an online user ID, a hexadecimal number in the range of 1 to FFFF4240.
nat-instance nat-instance-name: Specifies a NAT instance by its name, a case-sensitive string of 1 to 31 characters. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX". To ensure that NAT operates normally, make sure the specified NAT instance name is available.
user-group user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
In the scenario where global NAT is used to collaborate with BRASs, when the user traffic cannot be forwarded, you can execute this command to manually switch the user to another CGN card that is operating normally. Then, you can identify whether the original CGN card hosting the current user fails.
·     If user traffic can be normally forwarded after the switchover, the original CGN card might fail. In this case, identify whether the original CGN card fails.
·     If user traffic cannot be forwarded after the switchover, the NAT configuration might have errors. In this case, identify whether the NAT configuration is correct.
Operating mechanism
When you execute this command, the BRAS will re-allocate the public network IP address and port block to the user according to the binding between the load-sharing user group and NAT instance specified in this command, and refresh the user session information. The whole process is automatically done by the device. During the process, the user online state is not affected, and the user stays online.
You can use the display access-user command to view the user-id information and public network IP address information of an access user.
Before executing this command, make sure the following conditions are met:
·     The NAT instance and user group specified in this command have been bound by using the user-group bind nat-instance command in user authentication domain view. If not, the command will fail to be executed.
·     The NAT instance specified in this command is available, for example, the NAT instance-related configuration is correct, the CGN card is in place, and IP addresses and port block resources are available. If not, executing this command might cause the user to go offline.
This command takes effect only once and is not saved in the configuration file. After you execute this command, the user might go offline and then come online. If you still want to change the binding between the load-sharing user group and NAT instance for the access user after the user comes online, execute this command again.
On a CUPS network, to manually change the binding between the load-sharing user group and NAT instance for an access user, you must configure this feature on a CP.
# Manually change the binding between the load-sharing user group and NAT instance for the user with ID 80000001.
[Sysname] access-user change user-id 80000001 nat-instance 1 user-group 1
user-group bind nat-instance (BRAS Services Command Reference)
Use access-user cpu-warning log enable to enable the CPU usage alarm logs on the device.
Use undo access-user cpu-warning log enable to restore the default.
The CPU usage alarm logs are disabled.
Enable the CPU usage alarm logs to record when the CPU usage enters or exits the specified alarm threshold. The generated log messages by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination.
For more information about the information center, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable the CPU usage alarm logs on the device.
[Sysname] access-user cpu-warning log enable
Use access-user flow-rate-calculate enable to enable flow rate calculation for online users.
Use undo access-user flow-rate-calculate enable command to disable flow rate calculation for online users.
access-user flow-rate-calculate enable [ interval interval ]
Flow rate calculation is disabled for online users.
interval interval: Specifies the interval for calculating the user flow rate, in the range of 1 to 43200 minutes. The default is 5 minutes.
In the live network, you can allocate bandwidth to different users based on their actual requirements to make efficient use of bandwidth resources. To quickly locate users with abnormal bandwidth (such as users with significantly lower or higher Internet access speeds than their allocated bandwidth), you can enable flow rate calculation for online users. With this feature enabled, you can execute the display access-user command with the flow-rate keyword specified to view information of users whose flow rates fall within the specified range.
Operating mechanism
After flow rate calculation for online users is enabled, the device will calculate the flow rate for each online user based on the interval value (5 by default) specified in the access-user flow-rate-calculate enable command and the online user traffic accounting frequency mode (normal mode by default) configured by using the flow-statistics frequency command according to certain principles.
Recommended configuration
In the live network, configure this feature according to the total number of users on the device and the frequency mode set by using the flow-statistics frequency command. For more information, see the following table. For example, when the total number of users on the device is less than 50000 and the frequency mode is fast, configure the interval for calculating user flow rates to be equal to or greater than 3 minutes as a best practice.
Table 1 Recommended intervals for calculating the user flow rates
Frequency mode (right)
Fast mode
(fast)
Normal mode
(normal)
Slow mode
(sflow)
Total number of users on the device (below)
Less than 50000
≥3 minutes
≥6 minutes
≥12 minutes
50000 to 120000
≥7 minutes
≥14 minutes
≥28 minutes
120000 to 250000
≥15 minutes
≥30 minutes
≥60 minutes
250000 to 500000
≥30 minutes
≥60 minutes
≥120 minutes
500000 to 1000000
≥60 minutes
≥120 minutes
≥240 minutes
More than 1000000
≥100 minutes
≥200 minutes
≥400 minutes
Enabling this feature will occupy a certain amount of memory resources. To avoid occupying too many memory resources, enable flow rate calculation for online users only when you need to obtain user rate information. Promptly disable this feature when you do not need to obtain user rate information.
If a user has no service traffic within a certain interval, the device will not use the configured interval as the interval for calculating the user flow rates. Instead, the device will automatically calculate the interval for the user flow rates based on the actual user traffic conditions. To view the interval for automatically calculating the user flow rates and the statistics of the user flow rates within that interval, execute the display access-user verbose command.
In a CPDR or VSRP network, only the master CP or master VSRP device supports recording user flow rate information.
 # Enable flow rate calculation for online users.
[Sysname] access-user flow-rate-calculate enable
display access-user
Use access-user four-dimension-mode enable to configure the device to use four-dimensional interfaces to communicate with AAA servers.
Use undo access-user four-dimension-mode enable to restore the default.
The device uses three-dimensional interfaces to communicate with AAA servers.
In a CUPS network, you only need to execute this command on the CP and do not need to execute this command on UPs. More specifically, the remote interface number on the CP is in the format of UP ID/actual interface number on the UP. For example, Remote-XGE1024/3/1/2, where 1024 is the UP ID and 3/1/2 is a three-dimensional interface number. By default, when the CP communicates with AAA servers, the device uses three-dimensional interface numbers in interface information, for example, NAS-Port-ID. When you need to specify the access UP of a user on the AAA server, use this command to configure the device to use four-dimensional interfaces to communicate with AAA servers. After you execute this command, one dimension of UP ID is added to the original three-dimension interface numbers of the CP, and the interface number format is up-id/original three-dimensional interface number.
By default, in a unified network, when the device communicates with AAA servers, the device uses three-dimensional interface numbers without the chassis information in interface information, for example, NAS-Port-ID. On an IRF fabric, when you need to specify the access IRF member device of a user on the AAA server, use this command to configure the device to use four-dimensional interfaces to communicate with AAA servers.
This command takes effect only on users coming online after this command is executed.
On a unified network, this feature takes effect only on users coming online through physical interfaces, and does not take effect on users coming online through global interfaces such as Layer 3 aggregate interfaces.
# Configure the device to use four-dimensional interfaces to communicate with AAA servers.
[Sysname] access-user four-dimension-mode enable
Use access-user interface send gratuitous-arp command to configure how the UP sends gratuitous ARP packets upon the master/backup UP switchover on a UP backup network.
Use undo access-user interface send gratuitous-arp to restore the default.
access-user interface send gratuitous-arp { by-user-vlan | disable | on-all-vlans }
How the UP sends gratuitous ARP packets depends on the VLAN termination method configured on the new master interface as follows:
·     Dot1q termination—For an interface configured with Dot1q termination, regardless of whether it is also configured with QinQ termination, the interface sends gratuitous ARP packets in the smallest VLAN specified in Dot1q termination.
·     QinQ termination—For an interface configured with QinQ termination, the interface sends gratuitous ARP packets in the smallest outer VLAN specified in QinQ termination.
·     Untagged/default termination—For an interface configured with untagged or default termination, the interface sends gratuitous ARP packets without any VLAN tags.
by-user-vlan: Specifies the new master interface and its subinterfaces to send gratuitous ARP packets as follows.
·     The main interface directly sends gratuitous ARP packets without carrying a VLAN tag.
·     Subinterface:
¡     In 1:1 hot standby mode:
If online users exist on a subinterface upon the master/backup UP switchover, the subinterface sends gratuitous ARP packets in the VLAN of a randomly selected user.
If no users are online on the subinterface upon the master/backup UP switchover, the subinterface does not send a gratuitous ARP packet.
¡     In other UP backup modes, a subinterface will send gratuitous ARP packets in the VLAN of a randomly selected user only when users come online on the subinterface.
disable: Disables the UP from sending gratuitous ARP packets.
on-all-vlans: Specifies the UP to send gratuitous ARP packets in all VLANs terminated on the new master interface.
In an UP backup network, if the master interface, master UP, or master network-side link fails, the CP will notify the backup UP interface to become the master. After the master/backup UP switchover, the new master interface will send gratuitous ARP packets. This allows connected devices to update their MAC address entries and switch service traffic to the new master interface.
By default, the UP only sends gratuitous ARP packets in the specific VLANs based on VLAN termination configuration on the new master interface. To change the VLANs of the gratuitous ARP packets sent by the UP, execute this command.
Select a parameter for this feature as needed.
·     In scenarios where you do not need to send gratuitous ARP packets (for example, when the connected devices support fast convergence of MAC address entries or use other mechanisms to synchronize the outgoing interfaces), specify the disable parameter.
·     When you have service requirements in multiple VLANs and rely on gratuitous ARP packets to update the outgoing interfaces, specify the on-all-vlans parameter, which configures the UP to send gratuitous ARP packets in all VLANs terminated on the new master interface.
·     In scenarios where the connected devices do not distinguish services by VLAN, you can either not execute this command or specify the by-user-vlan parameter.
This command only applies to the master/backup UP switchovers that have not occurred, and does not affect the ongoing switchover process.
# Configure the UP to send gratuitous ARP packets in all VLANs terminated on the new master interface after the master/backup UP switchover.
[Sysname] access-user interface send gratuitous-arp on-all-vlans
Use access-user interface-switchto-backup keep-host-routes to enable the feature of retaining UNR host routes of users when an interface switches to backup.
Use undo access-user interface-switchto-backup keep-host-routes to disable the feature of retaining UNR host routes of users when an interface switches to backup.
The feature of retaining UNR host routes of users when an interface switches to backup is disabled.
On a VSRP network, when the master interface switches to backup, the device automatically deletes the UNR host routes for all online users on that master interface by default. When the interface switches to the master interface, the device regenerates UNR host routes for all users that switch to the new master interface and come online.
·     When users do not need to access each other, you can enable this feature. This feature avoids the impact on switchover efficiency caused by generating UNR host routes for users that switch to the new master interface on the device.
·     When users need to access each other, you must disable this feature to ensure mutual access.
Operating mechanism
With this feature enabled, when the master interface switches to backup, the device will retain the UNR host routes for all online users on that master interface. When the interface switches to master, the device directly uses the retained UNR host routes. This feature avoids regenerating UNR host routes for users that switch to the new master interface and improves switchover efficiency.
·     This feature is only applicable to VSRP networks.
·     When enabling this feature on a VSRP network, you must enable this feature on both the master and backup devices. If you do not do that, the feature might become unavailable.
# Enable the feature of retaining UNR host routes of users when an interface switches to backup.
[Sysname] access-user interface-switchto-backup keep-host-routes
Use access-user log enable to enable logging for access users.
Use undo access-user log enable to disable logging for access users.
access-user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
undo access-user log enable [ abnormal-logout | failed-login | normal-logout | successful-login ] *
Logging is disabled for access users.
abnormal-logout: Specifies abnormal logout logs.
failed-login: Specifies login failure logs.
normal-logout: Specifies normal logout logs.
successful-login: Specifies login success logs.
CAUTION
CAUTION:
As a best practice, disable this feature to prevent excessive log output.
The logging feature enables the device to generate logs and send them to the information center. Logs are generated after a user comes online successfully, fails to come online, normally goes offline, or abnormally goes offline. A log entry contains information such as the username, IP address, interface name, inner VLAN, outer VLAN, MAC address, and failure causes. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
When you configure this command without specifying any keyword, this command enables or disables logging for login successes, login failures, normal logouts, and abnormal logouts.
# Enable logging for access users.
[Sysname] access-user log enable
Use access-user max-connections to configure the maximum number of concurrent online users allowed on the device and the threshold for recovering user access.
Use undo access-user max-connections to restore the default.
access-user max-connections max-number resume-number [ force ]
The maximum number of concurrent online users allowed on the device and the threshold for recovering user access are not set.
max-number: Specifies the maximum number of concurrent online users allowed. The value range is 1 to 65535.
resume-number: Specifies the threshold for recovering user access, in the range of 1 to 65535.
force: Forces the configuration of this command to take effect. If you do not specify this keyword, other commands might affect the maximum number of concurrent online users allowed and the threshold for recovering user access on the device.
Use this command when the device CPU usage is high. This feature reduces the device load and frees up CPU resources by adjusting the maximum number of concurrent online users allowed.
Operating mechanism
The device will reject new user connections once the number of online users reaches the specified maximum number of concurrent users. This prevents excessive CPU resource usage. When the number of online users on the device drops below the specified recovery threshold, the device can accept new users again to ensure normal operation.
When you execute both the access-user max-connections and access-user max-connections minor severe commands, the following rules apply:
·     If you specify the force keyword in the access-user max-connections command, the device uses the configured maximum number of concurrent users and recovery threshold for user access configured by using the access-user max-connections command.
·     If you do not specify the force keyword in the access-user max-connections command, the device uses the configured maximum number of concurrent users and recovery threshold for user access configured by using the access-user max-connections command when the CPU usage is below the alarm threshold.  If the device’s access authentication rate reaches the alarm threshold, the device uses the smaller configured value of the two commands.
# Configure the maximum number of concurrent online users allowed on the device as 3333 and the threshold for recovering user access as 2222.
[Sysname] access-user max-connections 3333 2222
Use access-user max-connections minor severe to configure the maximum number of concurrent online users allowed on the device and the threshold for recovering user access at different CPU usage levels.
Use undo access-user max-connections minor to restore the default.
access-user max-connections minor max-number resume-number severe max-number resume-number
The device does not adjust the maximum number of concurrent online users allowed or the threshold for user access recovery based on CPU usage.
minor: Specifies the maximum number of concurrent online users allowed and the threshold for user access recovery when the CPU usage of the device reaches the minor level (level-1 alarm).
severe: Specifies the maximum number of concurrent online users allowed and the threshold for user access recovery when the CPU usage of the device reaches the severe level (level-1 alarm).
Operating mechanism
When the device's CPU usage reaches the minor or severe level, the device will reject new user connections after the specified maximum number of concurrent users is reached. This prevents excessive CPU resource consumption. When the number of online users on the device drops below the specified recovery threshold, the device can accept new users again to ensure normal operation.
Set the threshold for user access recovery to be smaller than the maximum number of concurrent online users.
# Configure the device to allow a maximum of 3333 concurrent online users and configure the threshold for user access recovery as 2222 when the CPU usage reaches the minor level. Configure the device to allow a maximum of 1111 concurrent online users and configure the threshold for user access recovery as 111 when the CPU usage reaches the severe level.
[Sysname] access-user max-connections minor 3333 2222 severe 1111 111
Use access-user nat-info-change send-accounting-update to configure the BRAS to send an accounting-update message to the AAA server when the NAT information of an access user changes.
Use undo access-user nat-info-change send-accounting-update to restore the default.
When the NAT information of an access user changes, the BRAS first sends a stop-accounting message and then a start-accounting message to the AAA server.
To meet the NAT source tracking requirements in the NAT-BRAS collaboration scenario, when the NAT information (including only the public network IP address and port blocks, and excluding extended port blocks) of an access user changes (for example, because the CGN card fails), the BRAS will first send a stop-accounting message and then send a start-accounting message to notify the AAA server of the user information change by default. Then, the AAA server can timely record and refresh the user information. For the BRAS to directly send an accounting-update message to notify the AAA server of the user information change when the NAT information of a user changes, you can configure this feature.
Operating mechanism
With this feature enabled, when the NAT information (including only the public network IP address and port blocks, and excluding incremental port blocks) of a user changes, the BRAS directly sends an accounting-update message to notify the AAA server of the user information change. The sent accounting-update message carries the H3C private attribute H3C-Nat-Port-Range-Update with value 3, which represents the public network IP address and port block change.
Before configuring this feature, make sure the BRAS and the connected AAA server can recognize the support the H3C private attribute H3C-Nat-Port-Range-Update. If you cannot do that, use the default settings.
To configure this feature on a CUPS network, configure this feature on a CP.
# Configure the BRAS to send an accounting-update message to the AAA server when the NAT information of an access user changes.
[Sysname] access-user nat-info-change send-accounting-update
Use access-user online-fail-warning to enable the user online failure threshold alarm function.
Use undo access-user online-fail-warning to disable the user online failure threshold alarm function.
access-user online-fail-warning threshold threshold-value period period-value
The user online failure threshold alarm function is disabled.
threshold threshold-value: Specifies a percentage of the number of user online failures to the total number of user online events, in the range of 1 to 100.
period period-value: Specifies the alarm detection interval in the range of 1 to 1440 minutes.
With the user online failure threshold alarm function enabled, when the number of user online failures within an alarm detection interval exceeds the specified threshold, an alarm is automatically triggered. Then, the administrator can promptly learn the user online failure conditions on the live network. An administrator can execute the display aaa online-fail-record command to view user online failure records.
The alarm information output contains logs and traps.
·     The generated log messages by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
·     To send the traps to an NMS correctly, you must also configure SNMP correctly as described in Network Management and Monitoring Configuration Guide. For more information about SNMP alarms, see SNMP configuration in Network Management and Monitoring Guide.
In standalone mode:
The total number of access user online failures refers to the sum of IPoE user, PPPoE user, and L2TP user online failures on the whole device.
The total number of access user online events refers to the sum of IPoE user, PPPoE user, and L2TP user online failures and online successes on the whole device.
In IRF mode:
The total number of access user online failures refers to the sum of IPoE user, PPPoE user, and L2TP user online failures on the whole IRF system.
The total number of access user online events refers to the sum of IPoE user, PPPoE user, and L2TP user online failures and online successes on the whole IRF system.
If a single user comes online successfully or fails to come online for multiple times, each online success or failure is counted in the total number of online successes or failure.
When the device calculates the number of online events of a user, the device uniquely identifies a user by the MAC address, inner VLAN, and outer VLAN.
·     For a dual-stack user, only if the user successfully comes online in one protocol stack, the user is considered as coming online successfully. A dual-stack user is considered failing to come online only when the user fails to come online in both protocol stacks.
·     For an IPoE leased user, the online events of the main user and the online events of the subusers are separately counted.
# Configure the device to generate an alarm when the percentage of user online failures to user online events exceeds 50% within 10 minutes.
[Sysname] access-user online-fail-warning threshold 50 period 10
Use access-user send gratuitous-arp command to configure the times and intervals for sending gratuitous ARP packets on the UP.
Use undo access-user send gratuitous-arp to restore the default.
access-user send gratuitous-arp retry retry-count interval interval
In 1:1 hot standby mode, the UP sends gratuitous ARP packets for three times at intervals of one second after the master/backup UP switchover.
In both N:1 warm standby mode and 1:N warm load balancing mode, the UP send gratuitous ARP packets for 15 times after the master/backup UP switchover: sends the packets at intervals of one second for the first five times and at intervals of three seconds for the next 10 times.
retry retry-count: Specifies the times for sending gratuitous ARP packets, in the range of 1 to 255.
interval interval: Specifies the intervals for sending gratuitous ARP packets, in the range of 1 to 120 seconds.
Gratuitous ARP packets will be sent multiple times. When a large number of ARP gratuitous ARP packets are sent, use this command to decrease the times for sending gratuitous ARP packets and increase the sending interval to avoid congestion caused by insufficient performance of the UP or its connected devices.
Operating mechanism
This command specifies the times and intervals for sending gratuitous ARP packets in the same VLAN on an interface, rather than for the total packets sent by the interface. For example, if an interface on a UP needs to send gratuitous ARP packets in 100 VLANs, it must send 100 packets each time and repeatedly send them at the specified intervals.
# Configure the UP to send gratuitous ARP packets for up to 10 times at the intervals of one second.
[Sysname] access-user send gratuitous-arp retry 10 interval 1
Use access-user send gratuitous-arp rate-limit to set the maximum number of gratuitous ARP packets that a UP can send per second.
Use undo access-user send gratuitous-arp rate-limit to restore the default.
access-user send gratuitous-arp rate-limit rate
The maximum number of gratuitous ARP packets that a UP can send per second is not limited.
rate: Specifies the maximum number of gratuitous ARP packets sent per second, in the range of 1 to 500000000.
When multiple interfaces on the UP need to send gratuitous ARP packets in multiple VLANs, a large number of packets will be sent each time. To avoid congestion caused by a high packet sending rate, use this command to limit the maximum number of gratuitous ARP packets sent per second by the UP.
Operating mechanism
The limit set by using this command applies to each individual slot. In each slot, the total number of gratuitous ARP packets sent per second on all interfaces is limited, and any packets exceeding the limit will be dropped. The device uses a single-rate single-bucket token bucket algorithm to determine whether the number of packets exceeds the limit. As a result, the actual number of packets the device can send might slightly differ from the number set by using this command.
When you execute the access-user interface send gratuitous-arp on-all-vlans command, if the gratuitous ARP packets in some VLANs exceed the limit in one send operation, these packets will be preferentially sent in the next send operation. For example, an interface on a UP terminates VLANs 1 through 4000, and gratuitous ARP packets in VLANs 2001 through 4000 are dropped due to exceeding the limit during one send operation. Then, the device will preferentially send packets in VLANs 2001 through 4000 before sending packets in VLANs 1 through 2000 in the next send operation.
# Configure the UP to send up to 1000 gratuitous ARP packets per second.
[Sysname] access-user send gratuitous-arp rate-limit 1000
Use access-user sense cpu-usage enable to enable CPU usage awareness on the device.
Use undo access-user sense cpu-usage enable to restore the default.
The CPU usage awareness feature is not enabled on the device.
This command is a prerequisite for the following commands:
·     access-user adjustment user-detect enable
·     access-user adjustment accounting-update enable
·     access-user adjustment traffic enable
·     access-user max-connections minor
·     access-user authen-rate minor
·     access-user adjustment access-rate-limit minor
·     access-user cpu-warning log enable
After you enable the CPU usage awareness feature on the device, the device can adjust functions based on CPU usage to reduce device resource consumption and improve device performance.
# Enable the CPU usage awareness feature on the device.
[Sysname] access-user sense cpu-usage enable
Use access-user session-threshold to configure the online access user session count alarm thresholds on the device.
Use undo access-user session-threshold to restore the default.
access-user session-threshold { lower-limit lower-limit-value | upper-limit upper-limit-value }
undo access-user session-threshold { lower-limit | upper-limit }
On the device, the upper online access user session count alarm threshold is 100, and the lower online access user session count alarm threshold is 0.
lower-limit lower-limit-value: Specifies the lower online access user session count alarm threshold in the range of 0 to 99. The configured value is a percentage of the maximum number of online access user sessions allowed.
upper-limit upper-limit-value: Specifies the upper online access user session count alarm threshold in the range of 1 to 100. The configured value is a percentage of the maximum number of online access user sessions allowed.
(In standalone mode.) The online access user session count on the device is the total number of online IPoE sessions, PPPoE sessions, and L2TP sessions on the device.
(In IRF mode.) The online access user session count on the device is the total number of online IPoE sessions, PPPoE sessions, and L2TP sessions on the IRF system.
You can use this command to set the upper alarm threshold and lower alarm threshold for the online access user session count. When the online access user session count exceeds the upper alarm threshold or drops below the lower threshold, an alarm is triggered automatically. Then, the administrator can promptly know the online user conditions of the network. To view the total number of access users, use the display access-user command.
The user session count alarm function counts only user sessions that occupy session resources. In the current software version, only the following sessions occupy session resources:
·     The following IPoE sessions:
¡     Sessions of individual access users
¡     Sessions of interface-leased users
¡     Sessions of interface-leased subusers
¡     Sessions of subnet-leased users
¡     Sessions of subnet-leased subusers
¡     Sessions of L2VPN-leased users
·     PPPoE sessions
·     L2TP sessions
Either a single-stack user or dual-stack user occupies one session resource.
Suppose the maximum number of online access user sessions allowed on the device is a, the upper alarm threshold is b, and the lower alarm threshold is c. The following rules apply:
·     When the online access user session count exceeds a×b or drops below a×c, the corresponding alarm information is output.
·     When the online access user session count returns between the upper alarm threshold and lower alarm threshold, the alarm clearing information is output.
In some special cases, the online access user session count frequently changes in the critical range, which causes frequent output of alarm information and alarm clearing information. To avoid this problem, the system introduces a buffer area when the online access user session count recovers from the upper or lower threshold. The buffer area size is 10% of the difference between the upper threshold and the lower threshold. Suppose the buffer area size is d. Then, d=a×(b-c)÷10. When the online access user session count drops below a×b-d or exceeds a×c+d, the alarm information is output.
For example, suppose a is 1000, b is 80%, and c is 20%. Then, d= a×(b-c)÷10=1000×(80%-20%)÷10=1000×60%÷10=600÷10=60.
·     When the online access user session count exceeds the upper threshold a×b=1000×80%=800, the upper threshold alarm is output. When the online access user session count restores to be smaller than a×b-d=800-60=740, the alarm clearing information is output.
·     When the online access user session count drops below the lower threshold a×c=1000×20%=200, the lower threshold alarm is output. When the online access user session count restores to be greater than a×c+d=200+60=260, the alarm clearing information is output.
The upper threshold alarm information output and the alarm clearing information output both contain logs and traps.
·     For traps to be correctly sent to the NMS host, you must execute the snmp-agent trap enable user-warning-threshold command in addition to configuring the SNMP alarm feature correctly. For more information about SNMP alarms, see SNMP configuration in Network Management and Monitoring Guide.
# Set the upper online access user session count threshold to 80% on the device.
[Sysname] access-user session-threshold upper-limit 80
Use access-user url character-transfer to configure the escape rules for parameters in the web server URL redirected by the device to users.
Use undo access-user url character-transfer to restore the default or delete the specified characters to be escaped.
access-user url character-transfer { none | reserve | unsafe | user-defined-characters character }
undo access-user url character-transfer [ user-defined-characters character ]
The device uses the rules in the following table to escape characters in the web URL parameters (specified by the web-server url-parameter command):
Web URL parameter
Escape rules
param-name
Letters, digits, ampersand signs (&), and equal signs (=) remain unescaped. Other characters are processed using the percent sign (%) followed by their hexadecimal ASCII code.
value expression
ssid
nas-id
Letters and digits remain unescaped. Other characters are processed using the percent sign (%) followed by their hexadecimal ASCII code.
remote-id
nas-port-id
Letters, digits, colons (:), forward slashes (/), equal signs (=), semi-colons (;), and dots (.) remain unescaped. Other characters are processed using the percent sign (%) followed by their hexadecimal ASCII code.
user-location
source-mac
Not escaped and assembled according to the configuration.
original-url
Letters, digits, percent signs (%), ampersand signs (&), equal signs (=), forward slashes (/), dots (.), and colons (:) remain unescaped. Other characters are processed using the percent sign (%) followed by their hexadecimal ASCII code.
source-address
none: Does not escape any characters.
reserve: Escapes only characters recommended to be reserved in RFC 1738, including semi-colons (;), forward slashes (/), question marks (?), colons (:), at signs (@), equal signs (=), and ampersand signs (&).
unsafe: Escape only characters defined as unsafe in RFC 1738, including left angle brackets (<), right angle bracket (>), quotation marks ("), pound signs (#), percent signs (%), left braces ({), and right braces (}), vertical bars (|), backslashes (\), carets (^), tildes (~), left brackets ([), right brackets (]), back quotes (`), and spaces.
user-defined-characters character: Escapes only user-specified characters. The character argument represents the list of hexadecimal values for ASCII characters requiring escaping, separated by spaces. The range of each value is 0 to ff, case-insensitive. For example, to escape the ASCII character A in the URL parameters, specify user-defined-characters 41 when executing this command, where 41 is the hexadecimal value of character A.
In scenarios using URL redirection, such as web authentication or ad pushing, if URL parameters with special characters are not properly escaped, browsers might fail to recognize them, leading to webpage display issues. To resolve the issue, you can configure the escape rules for characters in the URL parameters. This ensures that the redirect URL generated by the device is correctly translated in different browsers.
Operating mechanism
In a URL, question marks (?) are used to separate the path and parameter sections. For example, in an IPoE web authentication network, the URL path is configured by using the web-server { ip | ipv6 } command, and the URL parameters are configured by using the web-server url-parameter command.
With escape rules configured, the system translates characters in the URL parameters (after the question mark) as instructed by the escape rules.
During the escaping process, the system does not differentiate between parameter fields but escapes all matching characters in the entire parameter section. The principle of escaping is to replace matching characters with a percent sign (%) followed by the hex ASCII code of that character. For example,
to escape ASCII characters A, B, and C in URL parameters, execute access-user url character-transfer user-defined-characters 41 42 43, where 41, 42, and 43 represent the hex codes of characters A, B, and C, respectively. This guides the system to escape the characters to %41, %42, %43, ensuring proper URL translation in all browsers. Other characters will not be escaped.
·     Before configuring the escape rules for URL parameters, make sure that all the browsers used in the network support the escape result. Support for escape characters might differ by browser, which might affect the display and functions of URL redirection.
·     You can use the access-user url character-transfer user-defined-characters command to configure up to 145 custom escape rules.
¡     You can execute this command once to specify up to 145 characters to be escaped, or
¡     execute this command multiple times to specify up to 145 characters.
·     When you execute the undo access-user url character-transfer command:
¡     If you do not specify the user-defined-characters keyword, the default escape rules take effect.
¡     If you specify the user-defined-characters character keyword, the device only deletes the specified user-defined escape rules. Other configured escape rules, if any, are not affected.
·     As a best practice, do not execute the access-user url character-transfer or undo access-user url character-transfer command when online users are present. If you do so, online users might fail to process URLs based on the rule changes, causing the web authentication page to fail to be displayed properly. If configuration changes are required when users are online, modify the configuration during periods with fewer users to minimize impact. After you change the escape rules, if the web authentication page cannot open for an online user, make the user go offline and then come online again.
# Configure the system to escape unsafe characters in parameters of the web server URL redirected by the device to users.
[Sysname] access-user url character-transfer unsafe
Use access-user user-detect packet-loss-ratio-threshold to enable the packet loss ratio alarm for access user detection packets.
Use undo access-user user-detect packet-loss-ratio-threshold to disable the packet loss ratio alarm for access user detection packets.
access-user user-detect packet-loss-ratio-threshold threshold-value
The packet loss ratio alarm is disabled for access user detection packets.
threshold-value: Specifies the alarm threshold for the packet loss ratio of access user detection packets (the ratio of dropped detection packets to all detection packets). The value range is 20 to 100.
After the online user detection feature is enabled, the device will automatically create a 30-second timer. The timer will be reset after expiration. After the packet loss ratio alarm is enabled for access user detection packets, an alarm will be automatically triggered in either of the following conditions:
·     The packet loss ratio calculated exceeds the specified alarm threshold when the 30-second timer expires continuously for three times, and the number of packets sent within each 30-second timer exceeds 50.
·     The packet loss ratio calculated within the last 30 seconds when the 30-second timer expires restores to the normal range (equal to or less than the specified alarm threshold) after an alarm is output.
In this way, the administrator can timely learn the packet loss conditions of user detection packets on the live network.
In this function, the packet loss ratio of detection packets refers to the ratio of dropped packets (sent packets - received packets) to all detection packets within the 30-second timer on a detected interface. The formula is as follows: the packet loss ratio = (sent packets - received packet)/sent packets. If you execute the display access-user user-detect packet-loss-ratio or display ppp keepalive packet-loss-ratio command at a time point within a 30-second timer, this command displays the packet loss ratio statistics collected at the specified time point within the 30-second timer. For example, if you execute this display command at the 10th second within a 30-second timer, this command displays the packet loss ratio statistics collected within the 10 seconds.
The alarm information output contains only logs. The generated log messages by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
On a CUPS network, detection packets are sent and received on UPs. Therefore, this command takes effect only when it is executed on UPs. L2TP users do not have interface information on UPs. Therefore, the packet loss ratio statistics for L2TP users are collected on a per-slot basis.
This feature applies to only IPoE users, PPPoE users, and L2TP users.
# Enable the packet loss ratio alarm for access user detection packets, and set the alarm threshold to 25%.
[Sysname] access-user user-detect packet-loss-ratio-threshold 25
display ppp keepalive packet-loss-ratio (BRAS Services Command Reference)
reset access-user user-detect packet-loss-ratio
reset ppp keepalive packet-loss-ratio (BRAS Services Command Reference)
bras auto-cut-user before-reboot
Use bras auto-cut-user before-reboot to enable auto user logout before BRAS reboot.
Use undo bras auto-cut-user before-reboot to disable auto user logout before BRAS reboot.
Auto user logout before BRAS reboot is disabled.
By default, if devices are rebooted as planned or slots are separately rebooted when devices are upgraded, the devices or slots will not actively send accounting stop packets to the AAA server during the reboot process. During the reboot process, the devices will log out users, but the AAA server cannot sense the logout events and still considers the users online.  Within a short period of time after the devices or slots are rebooted, the online users before reboot cannot log in again because the AAA server still considers them as online.
To resolve this issue, enable the feature of auto user logout before BRAS reboot. With this feature enabled, when the reboot command is executed each time to reboot a device or slot, the device first forbids new users from coming online, and logs out all online users or online users on the slot to be rebooted. When users are logged out, the device will actively send accounting stop packets to the AAA server. After these users are logged out, the device or slot will be rebooted.
When a slot is restarted, this feature takes effect only on users coming online through physical interfaces in the slot.
If you execute the reboot command with the force keyword specified, the feature of auto user logout before BRAS reboot does not take effect.
On a CUPS network, this command takes effect only when it is executed on CPs.
# Enable auto user logout before BRAS reboot.
[Sysname] bras auto-cut-user before-reboot
reboot (Fundamentals Command Reference)
bras compatible old-style-commands enable
Use bras compatible old-style-commands enable to enable BRAS device compatibility with old-style commands.
Use undo bras compatible old-style-commands enable to disable BRAS device compatibility with old-style commands.
BRAS device compatibility with old-style commands is disabled.
A software upgrade might change the command style on the BRAS device. To manage the BRAS device without upgrading its NMS software, enable BRAS device compatibility with old-style commands.
Operating mechanism
BRAS device compatibility with old-style commands enables the device to recognize old-style commands.
Enable this feature only when the NMS software does not recognize the new-style commands and you want to use old-style commands for BRAS device management.
·     The following are the old-style commands:
¡     ip subscriber nas-port-type cable
¡     dhcp server ip-pool
¡     ipv6 dhcp pool
¡     dhcp pool-group
¡     ipv6 dhcp pool-group
·     The following are the new-style commands:
¡     nas-port-type
¡     ip pool
¡     ipv6 pool
¡     ip pool-group
¡     ipv6 pool-group
You cannot disable BRAS device compatibility with old-style commands if any old-style command is effective. You cannot enable BRAS device compatibility with old-style commands if any new-style command is effective. An exception is that you can enable BRAS device compatibility with old-style commands regardless of whether you have executed the new-style nas-port-type command unless the command includes the cable keyword. After you enable this feature, you can still execute the nas-port-type command except for specifying the cable keyword.
If BRAS device compatibility with old-style commands has already been enabled and old-style commands have been executed, but the network management system requires support for new-style commands due to version upgrades, first remove all old-style command configurations and disable the old-style command compatibility feature. Then, execute new-style commands.
If you have executed new-style commands but the network management system does not support them after the device accesses the network management system and requires old-style commands, remove all configurations except the nas-port-type command. Also remove the nas-port-type cable command configuration, if any. Then, enable the compatibility with old-style commands on the device.
# Enable BRAS device compatibility with old-style commands.
[Sysname] bras compatible old-style-commands enable
dhcp pool-group (BRAS Services Command Reference)
dhcp server ip-pool (BRAS Services Command Reference)
ip pool (BRAS Services Command Reference)
ip pool-group (BRAS Services Command Reference)
ip subscriber nas-port-type cable (old style) (BRAS Services Command Reference)
ipv6 dhcp pool (BRAS Services Command Reference)
ipv6 dhcp pool-group (BRAS Services Command Reference)
ipv6 pool (BRAS Services Command Reference)
ipv6 pool-group (BRAS Services Command Reference)
nas-port-type
bras data-backup-mode
Use bras data-backup-mode to configure the data backup mode for the BRAS service module.
Use undo bras data-backup-mode to restore the default.
bras data-backup-mode { non-realtime [ auto-reboot-board ] | realtime }
The data backup mode is realtime for the BRAS service module.
non-realtime: Specifies the BRAS service module not to back up the running data (for example, user session information) to the lightning memory-mapped database (LMDB) in real time.
·     auto-reboot-board: Specifies the device to automatically forcibly reboot the active MPU and complete active/standby switchover when the BRAS service module process on the active MPU is abnormal. If you do not specify this keyword, the device does not automatically forcibly reboot the active MPU when the BRAS service module process is abnormal. (In standalone mode.)
·     auto-reboot-board: Specifies the device to automatically reboot the global active MPU and complete active/standby MPU switchover when the BRAS service module process on the active MPU is abnormal. If you do not specify this keyword, the device does not automatically forcibly reboot the global active MPU when the BRAS service module process is abnormal. (In IRF mode.)
realtime: Specifies the BRAS service module to back up the running data to the LMDB in real time. For traffic data in the UCM module, if user traffic changes, the backup user information in the LMDB will be frequently updated, which will increase the processing load of the LMDB. To avoid this issue, the system triggers backup user information updates in the LMDB according to the following principles:
·     If the traffic of a user does not change within 5 minutes or the traffic change of a user reaches the update threshold 50 MB, UCM will back up information of the user again to the LMDB to update backup information of the user in the LMDB.
·     If the traffic of a user does not change within 5 minutes, UCM does not update the backup information of the user in the LMDB.
Operating mechanism
In non-realtime mode, the BRAS service module does not back up the running data to the LMDB in real time and the following rules apply:
·     To avoid data loss when the BRAS service module process is normally restarted (for example, by using the process restart command), the BRAS service module will back up the running data of the module to the LMDB before the process is restarted. The LMDB is shipped with the device for storing important information such as backup module running data.
·     When the BRAS service module process on the active MPU is abnormal, the data of the BRAS service module on the current active MPU will be lost. The device determines whether to forcibly reboot the active MPU according to whether the auto-reboot-board keyword is specified. (In standalone mode.)
·     When the BRAS service module process on the global active MPU is abnormal, the data of the BRAS service module on the current global active MPU will be lost. The device determines whether to forcibly reboot the global active MPU according to whether the auto-reboot-board keyword is specified. (In IRF mode.)
In realtime mode, the BRAS service module will back up the running data to the LMDB in real time to avoid data loss. For traffic data in the UCM module, if user traffic changes, the backup user information in the LMDB will be frequently updated, which will increase the processing load of the LMDB. To avoid this issue, the system triggers backup user information updates in the LMDB according to the following principles:
Active/standby MPU switchover is automatically performed only when the auto-reboot-board keyword is specified in the dual-MPU environment and the BRAS service module process is abnormal.
In the current software version, this feature takes effect only on the UCM, PPP, and DHCP modules.
When you execute this command, follow these restrictions and guidelines:
·     As a best practice to ensure device performance when a large number of users are online, do not frequently execute this command to switch the data backup mode for the BRAS service module.
·     When you switch the backup mode from non-realtime to realtime, the device will immediately back up the running data of the BRAS service module to the LMDB. Then, the data will be updated in real time.
·     When you switch the data backup mode from realtime to non-realtime, the device will delete the data that has been backed up to the LMDB for the BRAS service module. Then, the device will process the data according to whether the auto-reboot-board keyword is specified.
On a CUPS network, the command executed on a CP takes effect only on the CP, the command executed on a UP takes effect only on the UP, and they do not affect each other. Execute this command on a CP or UP as needed.
# Configure the data backup mode as real time for the BRAS service module.
[Sysname] bras data-backup-mode realtime
display access-user (BRAS Services Command Reference)
cut access-user
Use cut access-user to forcibly log out users.
In standalone mode:
cut access-user [ { graceful-offline | auth-type { admin | bind | dot1x [ with-address | without-address ] | ppp | pre-auth | web-auth [ inherit-pppoe | non-inherit-pppoe ] } | domain domain-name [ authentication | authorization ] | interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] | ip-pool pool-name | ip-type { dual-stack | ipv4 | ipv6 } | ipv6-pool pool-name | mac-address mac-address | nat-instance nat-instance-name | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-profile profile-name [ both | inbound | outbound ] | user-type { l2vpn-leased | lac | layer2-dynamic | layer2-interface-leased | layer2-static | layer2-subnet-leased | layer3-dynamic | layer3-interface-leased | layer3-static | layer3-subnet-leased | leased | leased-subuser | lns | pppoe | pppoea } | username user-name | vpn-instance vpn-instance-name | vxlan vxlan-id [ vxlan-id-max ] | slot slot-number [ cpu cpu-number ] } * | { { ip-address ipv4-address | ipv6-address ipv6-address | ipv6-prefix prefix-address/prefix-length } [ vpn-instance vpn-instance-name ] | user-id user-id } ]
cut access-user user-type pppoegw [ { username user-name | ip-address ipv4-address | vpn-instance vpn-instance-name | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number [ cpu cpu-number ] } * | user-id user-id ]
In IRF mode:
cut access-user [ { graceful-offline | auth-type { admin | bind | dot1x [ with-address | without-address ] | ppp | pre-auth | web-auth [ inherit-pppoe | non-inherit-pppoe ] } | domain domain-name [ authentication | authorization ] | interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] | ip-pool pool-name | ip-type { dual-stack | ipv4 | ipv6 } | ipv6-pool pool-name | mac-address mac-address | nat-instance nat-instance-name | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-profile profile-name [ both | inbound | outbound ] | user-type { l2vpn-leased | lac | layer2-dynamic | layer2-family-leased | layer2-interface-leased | layer2-static | layer2-subnet-leased | layer3-dynamic | layer3-interface-leased | layer3-static | layer3-subnet-leased | leased | leased-subuser | lns | pppoe | pppoea } | username user-name | vpn-instance vpn-instance-name | vxlan vxlan-id [ vxlan-id-max ] | chassis chassis-number slot slot-number [ cpu cpu-number ] } * | { { ip-address ipv4-address | ipv6-address ipv6-address | ipv6-prefix prefix-address/prefix-length } [ vpn-instance vpn-instance-name ] | user-id user-id } ]
cut access-user user-type pppoegw [ { username user-name | ip-address ipv4-address | vpn-instance vpn-instance-name | s-vlan svlan-id [ c-vlan cvlan-id ] | chassis chassis-number slot slot-number [ cpu cpu-number ] } * | user-id user-id ]
auth-type: Specifies an authentication type for access users.
·     admin: Specifies device management users.
·     bind: Specifies IPoE users using bind authentication.
·     dot1x: Specifies 802.1X users. If you specify the dot1x keyword but do not specify the with-address or without-address keyword, this command forcibly logs out all matching 802.1X users.
¡     with-address: Specifies IPoE users that come online in the postauthentication domain in the 802.1X authentication method. Session information about this type of users has IP address information.
¡     without-address: Specifies IPoE users that have not come online in the preauthentication domain in the 802.1X authentication method but whose 802.1X clients have come online. Session information about this type of users does not have IP address information.
·     ppp: Specifies PPP users.
·     pre-auth: Specifies IPoE users in the preauthentication phase.
·     web-auth: Specifies IPoE users using Web authentication in the Web authentication phase.
¡     inherit-pppoe: Specifies IPoE Web users that inherit the PPPoE user information.
¡     non-inherit-pppoe: Specifies IPoE Web users except those that inherit PPPoE user information.
domain domain-name: Forcibly logs out users in an authorization or authentication domain specified by its name, a case-insensitive string of 1 to 255 characters. If you specify the domain keyword but do not specify the authorization or authentication keyword, this command forcibly logs out all users in the specified authentication domain and authorization domain.
·     authorization: Forcibly logs out users that access through the specified authorization domain.
·     authentication: Forcibly logs out users that access through the specified authentication domain.
interface interface-type interface-number: Logs out users on an interface specified by its type and number. Only network access users support this keyword.
·     s-vlan svlan-id: Logs out users in an SVLAN specified by its ID. The value range is 1 to 4094.
·     c-vlan cvlan-id: Logs out users in a CVLAN specified by its ID. The value range is 1 to 4094.
ip-pool pool-name: Logs out users in an IPv4 address pool specified by its name, a case-insensitive string of 1 to 63 characters.
ip-type: Logs out users of the specified IP type.
·     dual-stack: Specifies dual-stack users.
·     ipv4: Specifies IPv4 users.
·     ipv6: Specifies IPv6 users.
ipv6-pool pool-name: Logs out users in an IPv6 address pool specified by its name, a case-insensitive string of 1 to 63 characters. On an NDRA network, if the IPv6 prefix of a user is from the ND prefix pool, the pool-name argument represents the name of the AAA-authorized ND prefix pool.
mac-address mac-address: Logs out a user with the specified MAC address in the form of H-H-H, case-insensitive. Only network access users support this keyword.
nat-instance nat-instance-name: Logs out users of a NAT instance specified by its name.
user-address-type: Logs out users with the specified IP address type.
·     ds-lite: Specifies lite dual-stack addresses.
·     ipv6: Specifies IPv6 addresses.
·     nat64: Specifies NAT64 addresses.
·     private-ds: Specifies private dual-stack addresses.
·     private-ipv4: Specifies private IPv4 addresses.
·     public-ds: Specifies public dual-stack addresses.
·     public-ipv4: Specifies public IPv4 addresses.
user-profile profile-name: Logs out users of a user profile specified by its name, a case-sensitive string of 1 to 31 characters. Valid characters include letters, digits, underlines (_), minus sings (-), and periods (.). A user profile name must start with a letter or digit, and cannot be all digits. If you do not specify a user profile direction, a user is logged out only if the user’s user profile matches the specified user profile in any direction.
·     both: Logs a user whose profile matches the specified profile in both directions.
·     inbound: Logs a user whose profile matches the specified profile in the inbound direction.
·     outbound: Logs a user whose profile matches the specified profile in the outbound direction.
user-type: Specifies a user type.
·     l2vpn-leased: Specifies IPoE L2VPN-leased users.
·     lac: Specifies users on the device acting as an LAC.
·     layer2-dynamic: Specifies Layer 2 IPoE dynamic users.
·     layer2-family-leased: Specifies Layer 2 IPoE family-leased users.
·     layer2-interface-leased: Specifies Layer 2 IPoE interface-leased users.
·     layer2-static: Specifies Layer 2 IPoE static users.
·     layer2-subnet-leased: Specifies Layer 2 IPoE subnet-leased users.
·     layer3-dynamic: Specifies Layer 3 IPoE dynamic users.
·     layer3-interface-leased: Specifies Layer 3 IPoE interface-leased users.
·     layer3-static: Specifies Layer 3 IPoE static users.
·     layer3-subnet-leased: Specifies Layer 3 IPoE subnet-leased users.
·     leased: Specifies IPoE leased users.
·     leased-subuser: Specifies Layer 2 IPoE leased subusers.
·     lns: Specifies users on the device acting as an LNS.
·     pppoe: Specifies PPPoE users, including PPPoE users that trigger the LAC to set up L2TP tunnels.
·     pppoea: Specifies PPPoE agency users.
·     pppoegw: Specifies PPPoE gateway access users.
username user-name: Logs out a user specified by its username, a case-sensitive string of 1 to 253 characters.
vpn-instance vpn-instance-name: Logs out users in a VPN instance specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command logs out users in the public network.
vxlan vxlan-id [ vxlan-id-max ]: Logs out users in a VXLAN specified by the vxlan-id argument or VXLAN range specified by the vxlan-id vxlan-id-max arguments The vxlan-id and vxlan-id-max arguments are both in the range of 0 to 16777215.
ip-address ipv4-address: Logs out a user with the specified IPv4 address.
ipv6-address ipv6-address: Logs out a user with the specified IPv6 address.
ipv6-prefix prefix-address/prefix-length: Logs out users with the specified IPv6 prefix. The prefix-address argument specifies the IPv6 prefix, and the prefix-length argument specifies the IPv6 prefix length.
user-id user-id: Logs out a user specified by its online index. The value range is 1 to FFFF4240 (hexadecimal).
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed.(In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed.(In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
graceful-offline: Forcibly logs off users at the rate specified by using the access-user graceful-offline speed command. This keyword takes effect on all types of users except for DHCP-based Layer 2 IPoE users.
This command takes effect only on online IPoE, PPPoE, and L2TP users.
After this command is executed, the system will print the number of users affected by this operation and prompt the user to confirm whether to continue. This operation affects users who directly and completely match the execution conditions of the command, excluding users who go offline indirectly as a result of executing this command.
# Forcibly log out the user with IP address 10.10.10.10.
<Sysname> cut access-user ip-address 10.10.10.10
This command will cut off 1 user totally.Continue?[Y/N]: y
# Forcibly log out the users in ISP domain dm1.
<Sysname> cut access-user domain dm1
This command will cut off 100 user totally.Continue?[Y/N]: y
# Forcibly log out the user named user1.
<Sysname> cut access-user username user1
display access-user
display access-user
Use display access-user to display access user information.
In standalone mode:
display access-user [ [ { { accounting-state { accounting | idle | leaving-flow-query | ready | wait-acct-start | wait-acct-stop } | [ all-vpn-instance | public-instance | vpn-instance vpn-instance-name ] | auth-method { hwtacacs | local | none | radius | radius-proxy } | auth-type { admin | bind | dot1x [ with-address | without-address ] | ppp | pre-auth | web-auth [ inherit-pppoe | non-inherit-pppoe | web-mac-auth | web-mac-trigger | web-normal ] } | car cir cir-value [ pir pir-value ] [ inactive ] [ both | inbound | outbound ] | domain domain-name [ authorization | authentication ] | flow-rate [ ip | ipv6 ] { inbound { above rate-inbound-above-value | below rate-inbound-below-value } * | outbound { above rate-outbound-above-value | below rate-outbound-below-value } * } * | initiator-method { arp | dhcpv4 | dhcpv6 | ndrs | nsna | unclassified-ip | unclassified-ipv6 } | [ interface interface-type interface-number [ all | s-vlan svlan-id [ c-vlan cvlan-id ] | s-vlan svlan-id [ c-vlan cvlan-id ] ] ] | ip-pool pool-name | ip-pool-group ip-pool-groupname | ip-type { dual-stack | ipv4 | ipv6 } | { ipv4 multicast-user-profile profile-name | ipv6 multicast-user-profile profile-name } * | ipv6-address-protocol { dhcpv6 | dhcpv6-pd | nd } | ipv6-cpe-mode { ipv6 | ipv6-pd } | ipv6-pool pool-name | ipv6-pool-group ipv6-pool-groupname | lac-ip lac-ip-address | lns-ip lns-ip-address | { { { local-access | remote-access } | { backup | master } } * | normal } | mac-address mac-address | nat-instance nat-instance-name | pppoe-agency-state no-online | quota-out-redirect | radius-attribute-inexistence user-profile | remote-name tunnel-name | session-group-profile { session-group-profile-name | [ session-group-profile-name ] inactive } | start-time start-time start-date end-time end-time end-date | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-group { user-group-name | [ user-group-name ] inactive } | user-traffic [ ip | ipv6 ] { inbound { above traffic-inbound-above-value { byte | giga-byte | kilo-byte | mega-byte } | below traffic-inbound-below-value { byte | giga-byte | kilo-byte | mega-byte } } * | outbound { above traffic-outbound-above-value { byte | giga-byte | kilo-byte | mega-byte } | below traffic-outbound-below-value { byte | giga-byte | kilo-byte | mega-byte } } * } * | user-priority { user-priority | [ user-priority ] inactive } [ both | inbound | outbound ] | user-profile { user-profile-name | [ user-profile-name ] inactive } [ both | inbound | outbound ] | user-type { l2vpn-leased | lac | layer2-dynamic | layer2-interface-leased | layer2-static | layer2-subnet-leased | layer3-dynamic | layer3-interface-leased | layer3-static | layer3-subnet-leased | leased | leased-subuser | lns | pppoe | pppoea } | username user-name | vxlan vxlan-id [ vxlan-id-max ] | slot slot-number [ cpu cpu-number ] } * | time time [ slot slot-number [ cpu cpu-number ] ] } [ count | verbose ] | { { ip-address ipv4-address | ipv6-address ipv6-address | ipv6-prefix ipv6-prefix/prefix-length | public-ip-address public-ip-address } [ all-vpn-instance | public-instance | vpn-instance vpn-instance-name ] | user-id user-id } [ slot slot-number [ cpu cpu-number ] ] [ verbose ] ] | { count | verbose } ]
display access-user user-type pppoegw [ { username user-name | ip-address ipv4-address | vpn-instance vpn-instance-name | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number [ cpu cpu-number ] } * | user-id user-id ] [ count | verbose ]
In IRF mode:
display access-user [ [ { { accounting-state { accounting | idle | leaving-flow-query | ready | wait-acct-start | wait-acct-stop } | [ all-vpn-instance | public-instance | vpn-instance vpn-instance-name ] | auth-method { hwtacacs | local | none | radius | radius-proxy } | auth-type { admin | bind | dot1x [ with-address | without-address ] | ppp | pre-auth | web-auth [ inherit-pppoe | non-inherit-pppoe | web-mac-auth | web-mac-trigger | web-normal ] } | car cir cir-value [ pir pir-value ] [ inactive ] [ both | inbound | outbound ] | domain domain-name [ authorization | authentication ] | flow-rate [ ip | ipv6 ] { inbound { above rate-inbound-above-value | below rate-inbound-below-value } * | outbound { above rate-outbound-above-value | below rate-outbound-below-value } * } * | initiator-method { arp | dhcpv4 | dhcpv6 | ndrs | nsna | unclassified-ip | unclassified-ipv6 } | [ interface interface-type interface-number [ all | s-vlan svlan-id [ c-vlan cvlan-id ] ] |  s-vlan svlan-id [ c-vlan cvlan-id ] ] | ip-pool pool-name | ip-pool-group ip-pool-groupname | ip-type { dual-stack | ipv4 | ipv6 } | { ipv4 multicast-user-profile profile-name | ipv6 multicast-user-profile profile-name } * | ipv6-address-protocol { dhcpv6 | dhcpv6-pd | nd } | ipv6-cpe-mode { ipv6 | ipv6-pd } | ipv6-pool pool-name | ipv6-pool-group ipv6-pool-groupname | lac-ip lac-ip-address | lns-ip lns-ip-address | { { { local-access | remote-access } | { backup | master } } * | normal } | mac-address mac-address | nat-instance nat-instance-name | pppoe-agency-state no-online | quota-out-redirect | radius-attribute-inexistence user-profile | remote-name tunnel-name | session-group-profile { session-group-profile-name | [ session-group-profile-name ] inactive } | start-time start-time start-date end-time end-time end-date | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-group { user-group-name | [ user-group-name ] inactive } | user-traffic [ ip | ipv6 ] { inbound { above traffic-inbound-above-value { byte | giga-byte | kilo-byte | mega-byte } | below traffic-inbound-below-value { byte | giga-byte | kilo-byte | mega-byte } } * | outbound { above traffic-outbound-above-value { byte | giga-byte | kilo-byte | mega-byte } | below traffic-outbound-below-value { byte | giga-byte | kilo-byte | mega-byte } } * } * | user-priority { user-priority | [ user-priority ] inactive } [ both | inbound | outbound ] | user-profile { user-profile-name | [ user-profile-name ] inactive } [ both | inbound | outbound ] | user-type { l2vpn-leased | lac | layer2-dynamic | layer2-interface-leased | layer2-static | layer2-subnet-leased | layer3-dynamic | layer3-interface-leased | layer3-static | layer3-subnet-leased | leased | leased-subuser | lns | pppoe | pppoea } | username user-name | vxlan vxlan-id [ vxlan-id-max ] | chassis chassis-number slot slot-number [ cpu cpu-number ] } * | time time [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] } [ count | verbose ] | { { ip-address ipv4-address | ipv6-address ipv6-address | ipv6-prefix ipv6-prefix/prefix-length | public-ip-address public-ip-address } [ all-vpn-instance | public-instance | vpn-instance vpn-instance-name ] | user-id user-id } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ verbose ] ] | { count | verbose } ]
display access-user user-type pppoegw [ { username user-name | ip-address ipv4-address | vpn-instance vpn-instance-name | s-vlan svlan-id [ c-vlan cvlan-id ] | chassis chassis-number slot slot-number [ cpu cpu-number ] } * | user-id user-id ] [ count | verbose ]
In standalone mode:In IRF mode:
display access-user all-slot [ { { accounting-state { accounting | idle | leaving-flow-query | ready | wait-acct-start | wait-acct-stop } | auth-method { hwtacacs | local | none | radius | radius-proxy } | auth-type { admin | bind | dot1x [ with-address | without-address ] | ppp | pre-auth | web-auth [ web-mac-auth | web-mac-trigger | web-normal ] } | car cir cir-value [ pir pir-value ] [ inactive ] [ both | inbound | outbound ] | domain domain-name [ authorization | authentication ] | flow-rate [ ip | ipv6 ] { inbound { above rate-inbound-above-value | below rate-inbound-below-value } * | outbound { above rate-outbound-above-value | below rate-outbound-below-value } * } * | initiator-method { arp | dhcpv4 | dhcpv6 | ndrs | nsna | unclassified-ip | unclassified-ipv6 } | [ interface interface-type interface-number [ all | s-vlan svlan-id [ c-vlan cvlan-id ] ] |  s-vlan svlan-id [ c-vlan cvlan-id ] ] | ip-pool pool-name | ip-pool-group ip-pool-groupname | ip-type { dual-stack | ipv4 | ipv6 } | { ipv4 multicast-user-profile profile-name | ipv6 multicast-user-profile profile-name } * | ipv6-address-protocol { dhcpv6 | nd } | ipv6-cpe-mode { ipv6 | ipv6-pd } | ipv6-pool pool-name | ipv6-pool-group ipv6-pool-groupname | lac-ip lac-ip-address | lns-ip lns-ip-address | { { { local-access | remote-access } | { backup | master } } * | normal } | mac-address mac-address | nat-instance nat-instance-name | pppoe-agency-state no-online | quota-out-redirect | radius-attribute-inexistence user-profile | remote-name tunnel-name | session-group-profile { session-group-profile-name | [ session-group-profile-name ] inactive } | start-time start-time start-date end-time end-time end-date | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-group { user-group-name | [ user-group-name ] inactive } | user-traffic [ ip | ipv6 ] { inbound { above traffic-inbound-above-value { byte | giga-byte | kilo-byte | mega-byte } | below traffic-inbound-below-value { byte | giga-byte | kilo-byte | mega-byte } } * | outbound { above traffic-outbound-above-value { byte | giga-byte | kilo-byte | mega-byte } | below traffic-outbound-below-value { byte | giga-byte | kilo-byte | mega-byte } } * } * | user-priority { user-priority | [ user-priority ] inactive } [ both | inbound | outbound ] | user-profile { user-profile-name | [ user-profile-name ] inactive } [ both | inbound | outbound ] | user-type { l2vpn-leased | lac | layer2-dynamic | layer2-interface-leased | layer2-static | layer2-subnet-leased | layer3-dynamic | layer3-interface-leased | layer3-static | layer3-subnet-leased | leased | leased-subuser | lns | pppoe } | username user-name | vpn-instance vpn-instance-name | vxlan vxlan-id [ vxlan-id-max ] } * | time time } ] count
accounting-state: Specifies users in the specified accounting state.
·     accounting: Specifies the accounting state.
·     idle: Specifies the idle state. A user is in this state when the user is online but the BRAS does not send accounting messages for the user to the AAA server. For example, a user that fails to start accounting or a user that does not support accounting (for example, FTP user) is in this state.
·     leaving-flow-query: Specifies the leaving flow query state. A user is in this state when the user is going offline and the BRAS is collecting traffic statistics of the user.
·     ready: Specifies the ready state. A user is in this state from the time when the user comes online until the BRAS sends the Accounting-Start messages for the user to the AAA server.
·     wait-acct-start: Specifies the wait-acct-start state. A user is in this state from the time when the BRAS sends the Accounting Start messages for the user to the AAA server until the accounting response messages are received.
·     wait-acct-stop: Specifies the wait-acct-stop state. A user is in this state from the time when the BRAS sends Accounting-Stop messages for the user to the AAA server until the BRAS receiving the Accounting-Stop response messages.
all-slot: Displays the number of all access users in each slot.
all-vpn-instance: Specifies all VPN instances.
public-instance: Specifies the public network instance.
vpn-instance vpn-instance-name: Specifies users in an MPLS L3VPN instance specified by its name, a case-sensitive string of 1 to 31 characters.
auth-method: Specifies online users that come online by using the specified authentication method.
·     hwtacacs: Specifies the HWTACACS authentication method.
·     local: Specifies the local authentication method.
·     none: Specifies no authentication method.
·     radius: Specifies the RADIUS authentication method.
·     radius-proxy: Specifies the RADIUS proxy authentication method.
·     dot1x: Specifies 802.1X users. If you specify the dot1x keyword but do not specify the with-address or without-address keyword, this command displays all matching 802.1X users.
·     pre-auth: Specifies IPoE in the preauthentication phase.
¡     inherit-pppoe:  Specifies IPoE Web users that inherit PPPoE user information.
¡     web-mac-auth: Specifies IPoE Web users that come online through transparent MAC authentication.
¡     web-mac-trigger: Specifies IPoE Web users that come online through transparent MAC trigger authentication.
¡     web-normal: Specifies IPoE Web users that come online through common Web authentication (non-transparent authentication).
car: Displays information of users with the specified CAR parameters authorized.
·     cir cir-value: Specifies the committed information rate in the range of 1 to 4294967295 kbps.
·     pir pir-value: Specifies the peak information rate in the range of 1 to 4294967295 kbps.
·     inactive: Displays information of users for which CAR authorization failed. If this keyword is not specified, this command displays information of users with CAR authorized in the inbound or outbound direction.
·     both: Matches in both inbound and outbound directions. If none of the both, inbound, and outbound keywords is specified, the user CAR directions are not restricted, as long as the CAR parameters in either the inbound or outbound direction match the criteria.
·     inbound: Matches only in the inbound direction.
·     outbound: Matches only in the outbound direction.
domain domain-name: Specifies users accessing through an authorization or authentication domain specified by its name, a case-insensitive string of 1 to 255 characters. If you specify the domain keyword but do not specify the authorization or authentication keyword, this command displays information about all matching users accessing through the specified authentication domain and authorization domain.
·     authorization: Specifies users that access through the specified authorization domain.
·     authentication: Specifies users that access through the specified authentication domain.
flow-rate: Displays information of online users with the flow rates in the specified range. To filter user information through this parameter, you must first execute the access-user flow-rate-calculate enable command. In the CPDR or VSRP network, only the master CP or master VSRP device supports recording user flow rate information. Therefore, this parameter can only be used on the master CP or master VSRP device to filter user information.
·     ip: Matches users based on the sum of the specified IPv4 flow rate and IPv6 flow rate in merge accounting mode, or matches users based on the specified IPv4 flow rate in separate accounting mode.
·     ipv6: Match users based on the specified IPv6 flow rate. If neither of the ip and ipv6 parameters is specified, the system matches users based on the sum of the specified IPv4 flow rate and IPv6 flow rate.
·     inbound: Displays information of users with the specified uplink flow rates.
¡     above rate-inbound-above-value: Displays information of users with the uplink flow rate greater than or equal to the specified value. The value for the rate-inbound-above-value argument ranges from 0 to 4294967294 bps.
¡     below rate-inbound-below-value: Displays information of users with the uplink flow rate lower than the specified value. The value for the rate-inbound-below-value argument ranges from 0 to 4294967294 bps.
·     outbound: Displays information of users with the specified downlink flow rates.
¡     above rate-outbound-above-value: Displays information of users with the downlink flow rate greater than or equal to the specified value. The value for the rate-outbound-above-value argument ranges from 0 to 4294967294 bps.
¡     below rate-outbound-below-value: Displays information of users with the downlink flow rate lower than the specified value. The value for the rate-outbound-below-value argument ranges from 0 to 4294967294 bps.
initiator-method: Specifies online users that come online by using the specified packet initiation method.
·     arp: Specifies ARP packet initiation.
·     dhcpv4: Specifies DHCPv4 packet initiation.
·     dhcpv6: Specifies DHCPv6 packet initiation.
·     ndrs: Specifies IPv6 ND RS packet initiation.
·     nsna: Specifies NS/NA packet initiation.
·     unclassified-ip: Specifies unclassified-IP packet initiation.
·     unclassified-ipv6: Specifies unclassified-IPv6 packet initiation.
interface interface-type interface-number: Specifies users accessing through an interface specified by its type and number. Only network access users support this option.
all: Displays user information on the current main interface and all its subinterfaces. To specify this keyword, make sure the interface specified by using the interface keyword is a main interface and you must also specify the count keyword.
s-vlan svlan-id: Specifies an SVLAN by its ID. The value range is 1 to 4094.
c-vlan cvlan-id: Specifies a CVLAN by its ID. The value range is 1 to 4094.
ip-pool pool-name: Specifies users in an IPv4 address pool specified by its name, a case-insensitive string of 1 to 63 characters.
ip-pool-group ip-pool-groupname: Specifies users in an IPv4 address pool group specified by its name, a case-insensitive string of 1 to 63 characters.
ip-type: Specifies users of an IP type.
ipv4: Specifies IPv4 multicast user profiles.
ipv6: Specifies IPv6 multicast user profiles.
multicast-user-profile profile-name: Specifies a multicast user profile by its name, a case-sensitive string of 1 to 31 characters.
ipv6-address-protocol: Specifies users whose IPv6 addresses or prefixes are assigned by the specified IPv6 protocol.
·     dhcpv6: Specifies users whose IPv6 addresses are assigned by DHCPv6.
·     dhcpv6-pd: Specifies users whose IPv6 PD prefixes are assigned by DHCPv6.
·     nd: Specifies users whose addresses are assigned by IPv6 NDRA.
ipv6-cpe-mode: Specifies CPE users. In an NDRA+IA_PD or IA_NA+IA_PD hybrid network, you cannot specify the ipv6-cpe-mode keyword to search for access users.
·     ipv6: Specifies access users that obtain IPv6 addresses through NDRA or IA_NA.
·     ipv6-pd: Specifies access users that obtain IPv6 PD prefixes through IA_PD.
ipv6-pool pool-name: Specifies users in an IPv6 address pool specified by its name, a case-insensitive string of 1 to 63 characters. If you specify this parameter, only information of users whose addresses are successfully allocated from the specified IPv6 address pool will be displayed.
ipv6-pool-group ipv6-pool-groupname: Specifies users in an IPv6 address pool group by its name, a case-insensitive string of 1 to 63 characters. If you specify this parameter, information of all users with the specified IPv6 address pool group authorized will be displayed, regardless of whether these users have actually obtained addresses from that pool group.
lac-ip lac-ip-address: Specifies the LNS to display users on the LAC specified by its IP address. Only the LNS supports this option.
lns-ip lns-ip-address: Specifies the LAC to display users on the LNS specified by its IP address. Only the LAC supports this option.
local-access: Specifies users who initially come online from the local device in a CPDR or VSRP network, as well as all users on the local device in a non-CPDR and non-VSRP network.
remote-access: Specifies users who initially come online from the peer device in a CPDR or VSRP network.
backup: Specifies users with the backup role as Backup in a CPDR or VSRP network.
master: Specifies users with the backup role as Master in a CPDR or VSRP network.
normal: Specifies users in a non-CPDR and non-VSRP network.
mac-address mac-address: Specifies a user by its MAC address in H-H-H format, case-insensitive. Only network access users support this option.
nat-instance nat-instance-name: Specifies users in a NAT instance specified by its name.
pppoe-agency-state: Specifies internal campus access authentication users (for example, IPoE users) in the specified PPPoE agency state.
no-online: Specifies internal campus access authentication users with the PPPoE agency state as not online.
quota-out-redirect: Specifies users who are in Redirect state after their traffic quota has been exhausted.
radius-attribute-inexistence user-profile: Displays information of users without user profiles authorized.
remote-name tunnel-name: Specifies an L2TP user of the LAC or LNS specified by its tunnel name, a string of 1 to 31 characters.
session-group-profile: Displays information of users with a session group profile authorized.
·     session-group-profile-name: Specifies a session group profile by its name, a case-sensitive string of 1 to 31 characters.
·     inactive: Displays information of users for which session group profiles failed to be authorized. If this keyword is not specified, this command displays information of users with the specified session group profile authorized. If this keyword is specified, the following rules apply:
¡     When the session-group-profile-name argument is not specified, this command displays information of users for which any session group profile failed to be authorized.
¡     When the session-group-profile-name argument is specified, this command only displays information of users for which the specified session group profile failed to be authorized.
start-time start-time start-date end-time end-time end-date: Specifies users within the specified time range. The start-time start-time start-date option specifies the start time and date. The end-time start-time start-date option specifies the end time and date.
·     The start-time and end-time arguments are in the HH:MM:SS format. HH specifies an hour in the range of 0 to 23. MM specifies a minute in the range of 0 to 59. SS specifies a second in the range of 0 to 59. To specify an integer hour, you do not need to specify the minute or second. To specify an integer minute, you do not need to specify the second. For example, if you enter 0 or 0:0, the time is hour 0 minute 0 second 0.
·     The start-date and end-date arguments are in the MM/DD/YYYY or YYYY/MM/DD format. MM specifies a month in the range of 1 to 12. DD specifies a day and its value range varies by month. YYYY specifies a year in the range of 2000 to 2035.
user-address-type: Specifies users with addresses of the specified type.
user-group: Displays information of users in the specified user group.
·     user-group-name: Specifies the name of an authorized user group, a case-insensitive string of 1 to 32 characters.
·     inactive: Displays information of users for which the user groups failed to be authorized. If this keyword is not specified, this command displays information of users with the specified user group authorized. If this keyword is specified, the following rules apply:
¡     When the user-group-name argument is not specified, this command displays information of users for which any user group failed to be authorized.
¡     When the user-group-name argument is specified, this command only displays information of users for which the specified user group failed to be authorized.
user-traffic: Displays information of online users in the specified user traffic range.
·     ip: Matches users based on the sum of the specified IPv4 traffic and IPv6 traffic in merge accounting mode, or matches users based on the specified IPv4 traffic in separate accounting mode.
·     ipv6: Match users based on the specified IPv6 traffic. If neither of the ip and ipv6 parameters is specified, the system matches users based on the sum of the specified IPv4 traffic and IPv6 traffic.
·     inbound: Displays information of users with the specified uplink traffic.
¡     above traffic-inbound-above-value: Displays information of users with the uplink traffic greater than or equal to the specified value. The value for the traffic-inbound-above-value argument ranges from 0 to 4294967294 bytes, kilobytes, megabytes, or gigabytes.
¡     below traffic-inbound-below-value: Displays information of users with the uplink traffic lower than the specified value. The value for the traffic-inbound-below-value argument ranges from 0 to 4294967294 bytes, kilobytes, megabytes, or gigabytes.
·     outbound: Displays information of users with the specified downlink traffic.
¡     above traffic-outbound-above-value: Displays information of users with the downlink traffic greater than or equal to the specified value. The value for the traffic-outbound-above-value argument ranges from 0 to 4294967294 bytes, kilobytes, megabytes, or gigabytes.
¡     below traffic-outbound-below-value: Displays information of users with the downlink traffic lower than the specified value. The value for the traffic-outbound-below-value argument ranges from 0 to 4294967294 bytes, kilobytes, megabytes, or gigabytes.
·     byte: Specifies traffic in bytes.
·     giga-byte: Specifies traffic in gigabytes.
·     kilo-byte: Specifies traffic in kilobytes.
·     mega-byte: Specifies traffic in megabytes.
user-priority: Displays information of users with user priority values authorized.
·     user-priority: Specifies traffic with an authorized priority in the range of 0 to 7.
·     inactive: Displays information of users for which the user priority failed to be authorized. If this keyword is not specified, this command displays information of users with the specified user priority authorized.  If this keyword is specified, the following rules apply:
¡     When the user-priority argument is not specified, this command displays information of users for which any user priority failed to be authorized.
¡     When the user-priority argument is specified, this command only displays information of the users for which the specified user priority failed to be authorized.
·     both: Matches in both inbound and outbound directions. If none of the  both, inbound, and outbound keywords is specified, the user priority directions are not restricted, as long as the user priority in either the inbound or outbound direction matches the criteria.
·     inbound: Matches only in the inbound direction. If neither of the inbound and outbound keywords is specified, the direction is ignored in a match.
user-profile: Displays information of users with user profiles authorized.
·     user-profile-name: Specifies an authorized user profile by its name, a case-sensitive string of 1 to 31 characters.
·     inactive: Displays information of users for which user profiles failed to be authorized. If this keyword is not specified, this command displays information of users with the specified user profile authorized. If this keyword is specified, the following rules apply:
When the user-profile-name argument is not specified, this command displays information of all users for which any user profile failed to be authorized.
When the user-profile-name argument is specified, this command only displays information of users for which the specified user profile failed to be authorized.
·     both: Matches in both inbound and outbound directions. If none of the both, inbound, and outbound keywords is specified, the user profile directions are not restricted, as long as the user profile in either the inbound or outbound direction matches the criteria.
user-type: Specifies users of the specified type.
·     lac: Specifies users on the device acting as a LAC.
username user-name: Specifies a user by its name, a case-sensitive string of 1 to 253 characters.
vxlan vxlan-id [ vxlan-id-max ]: Specifies users in the specified VXLANs. The vxlan-id argument and the vxlan-id-max argument specify the start VXLAN ID and end VXLAN ID, respectively, each in the range of 1 to 16777215.
time time: Specifies users accessing with the specified time range. The time argument specifies a duration in the range of 1 to 7200 seconds. For example, if you set the time argument to 2000, this command displays users coming online with the latest 2000 seconds.
ip-address ipv4-address: Specifies the user with the specified IPv4 address.
ipv6-address ipv6-address: Specifies the user with the specified IPv6 address.
ipv6-prefix ipv6-prefix: Specifies users with the specified IPv6 prefix (IPv6 ND prefix or IPv6 PD prefix). The ipv6-prefix argument specifies an IPv6 prefix. The prefix-length argument specifies an IPv6 prefix length.
public-ip-address public-ip-address: Specifies a NAT user by the public IP address assigned to the user in the NAT network.
user-id user-id: Specifies an online user by its index, a hexadecimal number in the range of 1 to FFFF4240.
count: Displays the number of users.
verbose: Displays detailed user information. This keyword is supported only by IPoE, PPPoE, and L2TP users.
If you do not specify the count or verbose keyword, this command displays brief user information.
If you do not specify the all-vpn-instance, public-instance, or vpn-instance keyword, this command displays user information of the public network instance and all VPN instances.
In an L2TP network, this command is supported on an LAC only if a remote system dials in to the LAC through a PPPoE network. For more information about L2TP, see L2TP configuration in BRAS Services Configuration Guide .
# Display the number of all access users.
<Sysname> display access-user count
Total users                      : 5
PPPoE users                      : 0
PPPoEA users                     : 0
PPPoA users                      : 0
PPPoFR users                     : 0
PPPoPhy users                    : 0
LNS users                        : 0
LAC users                        : 0
VPPP users                       : 0
L2 IPoE dynamic users            : 1
L2 IPoE static users             : 0
L2 IPoE interface leased users   : 0
L2 IPoE subnet leased users      : 0
L2 IPoE family leased users      : 0
L2 IPoE leased subusers          : 0
IPoE L2VPN leased users          : 0
L3 IPoE dynamic users            : 0
L3 IPoE static users             : 0
L3 IPoE interface leased users   : 0
L3 IPoE subnet leased users      : 0
Web auth users                   : 0
Portal users                     : 0
Telnet users                     : 1
SSH users                        : 0
HTTP users                       : 1
HTTPS users                      : 1
FTP users                        : 1
Command users                    : 0
PAD users                        : 0
Terminal users                   : 0
MAC auth users                   : 0
Dot1X users                      : 0
IKE users                        : 0
SSLVPN users                     : 0
DVPN users                       : 0
PPPoEGW users                    : 5
Total users
Total number of users (excluding LAC users).
PPPoE users
Number of PPPoE users (including PPPoE users that trigger the LAC to set up L2TP tunnels).
PPPoEA users
Number of PPPoE agency users.
PPPoA users
This field is not supported in the current software version.  Number of PPPoA users.
PPPoFR users
This field is not supported in the current software version. Number of PPPoFR users.
PPPoPhy users
Number of PPP access users directly carried on physical links.
LNS users
Number of L2TP users on the LNS.
LAC users
Number of L2TP users on the LAC. For example, PPPoE users that trigger the LAC to set up L2TP tunnels in NAS-initiated mode and LNS users on the LTS.
VPPP users
Number of L2TP users automatically dialing on the LAC.
Number of Layer 2 IPoE dynamic users, including IPoE users using 802.1X authentication in the postauthentication phase.
The access type that initiates the user in the corresponding protocol stack will be displayed after this field only in the summary information. The type is represented in the form of (IPv4 protocol stack access type/IPv6 protocol stack access type). Options include:
·     D—DHCP user.
·     S—Static user.
·     U—Unclassified-IP user.
·     N—IPv6 ND RS user.
·     Hyphen (-)—Indicates that the access type for the user in the corresponding protocol stack does not exist.
Number of Layer 2 IPoE static users, including static individual users, static leased users, and IPoE users using 802.1X authentication in the postauthentication phase.
Number of Layer 2 IPoE interface-leased users.
Number of Layer 2 IPoE subnet-leased users.
Number of Layer 2 IPoE family-leased users.
Number of Layer 2 IPoE leased subusers.
Number of IPoE L2VPN-leased users.
Number of Layer 3 IPoE dynamic users.
Number of Layer 3 IPoE static users, including static individual users and static leased users.
·     D—DHCP user.
Number of Layer 3 IPoE interface-leased users.
Number of Layer 3 IPoE subnet-leased users.
Web auth users
Number of Web authentication users.
·     D—DHCP user.
·     S—Static user.
When re-authentication for IPoE users in the specified IP address range is enabled by using the ip subscriber reauth command in system view, IPoE users in that IP address range that come online through an interface with IPoE Web authentication enabled and complete re-authentication will be counted in the Web auth users field.
Portal users
This field is not supported in the current software version. Number of portal users.
Telnet users
Number of Telnet users.
SSH users
Number of SSH users.
HTTP users
Number of HTTP users.
HTTPS users
Number of HTTPS users.
FTP users
Number of FTP users.
Command users
Number of command authorization and accounting users.
PAD users
This field is not supported in the current software version.  Number of PAD users.
Terminal users
Number of uses logging in through the Console port.
MAC auth users
This field is not supported in the current software version. Number of MAC authentication users.
Dot1X users
This field is not supported in the current software version. Number of Layer 2 802.1X users.
IKE users
This field is not supported in the current software version. Number of IKE users.
SSLVPN users
This field is not supported in the current software version. Number of SSL VPN users.
DVPN users
This field is not supported in the current software version. Number of DVPN users.
PPPoEGW users
Number of PPPoE gateway access users.
#Display brief information about all access users.
UserID   Username                Access type                         MAC address
         IP address              IPv6 address
         Interface                                                   S-/C-VLAN
0x33d    user1                   LNS                                 -
         192.168.0.2             -
         BAS0                                                        -/-
0x33e    user2                   L2 IPoE dynamic(D/-)                001b-21a8-0949
         3.3.3.3                 -
         XGE3/1/1                                                    -/-
0x33f    user3                   PPPoE                               001b-21a8-0949
         192.168.0.3             -
         XGE3/1/1                                                    -/-
0x400005 user4                   Telnet                              -
         3.3.3.3                 -
0x400006 user5                   FTP                                 -
         3.3.3.3                 -
UserID
Online index of a user.
Access interface of a user. If the user does not have an access interface, this field displays a hyphen (-).
Username
Username for authentication. If the username contains more than 20 characters, the username is displayed in the format of “the first 20 characters in the username+...” in the brief information.
IP address
IPv4 address of a user. If the user does not have an IPv4 address, this field displays a hyphen (-).
For a PPPoE agency user, this field indicates the IPv4 address assigned by an ISP to the user.
IPv6 address
IPv6 address of a user. If the user does not have an IPv6 address, this field displays a hyphen (-).
MAC address
MAC address of a user. If the user does not have a MAC address, this field displays a hyphen (-).
For a PPPoE agency user, this field indicates the MAC address of the BRAS user.
S-/C-VLAN
SVLAN and CVLAN of a user. If the user does not have a SVLAN or CVLAN, this field displays -/-.
Access type
Access type of a user. For more information, see Table 2.
#(Individual users.) Display detailed information about IPoE users using bind authentication.
<Sysname> display access-user auth-type bind verbose
Basic:
  State: Online
  Description: N/A
  User ID: 0x33e
  Username: user1
  Backup role: N/A
  Authorization domain: dm1
  Authentication domain: dm1
  Interface: XGE3/1/1
  Service-VLAN/Customer-VLAN: -/-
  VXLAN ID: -
  MAC address: 001b-21a8-0949
  IP address: 3.3.3.3
  IP pool: pool1
  Primary DNS server: -
  Secondary DNS server: -
  IPv6 address: -
  IPv6 pool: N/A
  Primary IPv6 DNS server: -
  Secondary IPv6 DNS server: -
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  IPv6 ND prefix pool: N/A
  DHCP lease: -
  DHCP remaining lease: -
  DHCPv6 lease: -
  DHCPv6 remaining lease: -
  User address type: N/A
  VPN instance: N/A
  Access type: L2 IPoE dynamic
  Authentication type: Bind
  Static leased user: No
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
  NAS-Port-Id: slot=3;subslot=1;port=1;vlanid=0;
  User IPv6CP interface ID: -
  IP gateway address: 3.3.3.1
  IPv6 link-local address: -
  IPv6 address protocol: N/A
  User basic service IP type: IPv4
AAA:
  Authentication state: Authenticated
  Authorization state: Authorized
  Realtime accounting switch: Closed
  Realtime accounting interval: -
  Login time: 2019-09-21  13:55:57
  Accounting start time: 2019-09-21  13:55:57
  Online time (hh:mm:ss): 0:02:19
  Accounting state: Accounting
  Acct start-fail action: Online
  Acct update-fail action: Online
  Acct quota-out action: Offline
  Dual-stack accounting mode: Merge
  Dual-stack rate mode: Merge
  Idle cut: 0 seconds  0 bytes, direction: Both
  Session timeout: Unlimited
  Time remained: Unlimited
  Traffic quota: Unlimited
  Traffic remained: Unlimited
  IPv6CP interface ID assignment: Disabled
  Redirect WebURL: -
  ITA policy name: N/A
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
  Inbound netstream sampler: Not set
  Outbound netstream sampler: Not set
  IPv4 multicast user profile: N/A
  IPv6 multicast user profile: N/A
  User session: limit 2, online 1
  Account ID: 0x2
  Authorized IPv4 address: N/A
  Authorized IPv6 address: N/A
  Current authen method: RADIUS
  Accounting session ID: 400033e-0-0-202205070936120000000012
  Max IPv4 multicast addresses: 1
  IPv4 multicast address list : 225.0.0.11
  Max IPv6 multicast addresses: 1
  IPv6 multicast address list : ff1e::31
  Radius-proxy client IP address: 200.0.0.1
  Radius-proxy client VPN instance: N/A
ACL&QoS:
  Inbound user profile: N/A
  Outbound user profile: N/A
  Session group profile: N/A
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
  Inbound subscriber group CAR: -
  Outbound subscriber group CAR: -
  Inbound user priority: -
  Outbound user priority: -
Flow rate statistics:
  Flow rate calculation time: 2019-09-21  13:49:50 - 2019-09-21  13:55:57
  Flow rate: 0 bits/sec
    Inbound  flow rate: 0 bits/sec
    Outbound flow rate: 0 bits/sec
  IPv6 flow rate: 0 bits/sec
    IPv6 inbound  flow rate: 0 bits/sec
    IPv6 outbound flow rate: 0 bits/sec
Flow statistics:
  Uplink   packets/bytes: 389/50005
  Downlink packets/bytes: 23/1362
  IPv6 uplink   packets/bytes: 0/0
  IPv6 downlink packets/bytes: 0/0
ITA:
  Level-1 Uplink packets/bytes        : 4/392
          Downlink packets/bytes      : 4/392
          IPv6 uplink packets/bytes   : 0/0
          IPv6 downlink packets/bytes : 0/0
  Level-2 Uplink packets/bytes        : 0/0
          Downlink packets/bytes      : 0/0
#(Static leased users.) Display detailed information about IPoE users using bind authentication.
Basic:
  State: Online
  Description: N/A
  User ID: 0x33e
  Username: user1
  Backup role: N/A
  Interface: XGE3/1/1
  VXLAN ID: -
  IP address: 3.3.3.3
  IP pool: pool1
  IPv6 address: -
  IPv6 pool: N/A
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: L3 IPoE static
  Static leased user: Yes
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
AAA:
  Redirect WebURL: -
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
  Account ID: 0x2
ACL&QoS:
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow statistics:
#(Leased users.) Display detailed information about IPoE users using bind authentication.
Basic:
  State: Online
  Description: N/A
  User ID: 0x1
  Username: user1
  Backup role: N/A
  Authorization domain : dm1
  Interface: XGE3/1/1
  VXLAN ID: -
  MAC address: -
  IP address: -
  IP pool: N/A
  IPv6 address: -
  IPv6 pool: N/A
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: L2 IPoE interface leased
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
  IP gateway address: -
AAA:
  Login time: 2019-11-19  10:15:40
  Accounting start time: 2019-11-19  10:15:40
  Online time(hh:mm:ss): 0:33:54
  Redirect WebURL: -
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
  Accounting session ID: 4000001-0-0-202205070936120000000012
ACL&QoS:
  User group ACL: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow statistics:
  Uplink   packets/bytes: 4/392
  Downlink packets/bytes: 4/392
Total subusers: 1
  UserID   IP address          MAC address     S-/C-VLAN
           IPv6 address
  0xc      1.1.1.2             6c45-4eea-0206  -/-
Basic:
  State: Online
  Description: N/A
  User ID: 0xc
  Username: user1
  Backup role: N/A
  Authentication domain: N/A
  Interface: XGE3/1/1
  VXLAN ID: -
  MAC address: 6c45-4eea-0206
  IP address: 1.1.1.2
  IP pool: N/A
  IPv6 address: -
  IPv6 pool: N/A
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: L2 IPoE leased subusers
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
  IP gateway address: 1.1.1.1
AAA:
  Authentication state: -
  Authorization state: -
  Login time: 2019-11-19  10:32:09
  Accounting start time: -
  Online time(hh:mm:ss): 0:00:00
  Accounting state: Stop
  Dual-stack accounting mode: N/A
  Redirect WebURL: -
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
ACL&QoS:
  User group ACL: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow statistics:
  Uplink   packets/bytes: 0/0
  Downlink packets/bytes: 0/0
#Display detailed information about PPP access users.
<Sysname> display access-user auth-type ppp verbose
Basic:
  State: Online
  Description: N/A
  PPP index: 0x22d0a92580000105
  User ID: 0x33d
  Username: user1
  Backup role: N/A
  Interface: BAS0
  VXLAN ID: -
  MAC address: -
  IP address: 192.168.0.2
  IP pool: pool1
  Primary DNS server: 8.8.8.8
  IPv6 address: 8::8
  IPv6 pool: pool1
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: LNS
  Authentication type: PPP
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
  User IPv6CP interface ID: 1e2f:c3e4:3333:1234
  IP gateway address: 192.168.0.1
L2TP LNS:
  Group ID: 1
  Local tunnel ID: 8912
  Remote tunnel ID: 2
  Local session ID: 43301
  Remote session ID: 1
  Local IP: 3.3.3.1
  Remote IP: 3.3.3.3
  Local port: 1701
  Remote port: 1701
  Vrf index: 0
  Calling station: 9a4d-e968-0116 XGE3/1/1:ffff.ffff
AAA:
  Login time: 2019-09-21  13:54:52
  Accounting start time: 2019-09-21  13:54:52
  Online time (hh:mm:ss): 0:03:24
  IPv6CP interface ID assignment: Enabled
  Redirect WebURL: -
  MRU: 1400 bytes
  IPv4 MTU: 1400 bytes
  IPv6 MTU: 1400 bytes
  Subscriber ID: -
  Accounting session ID: 400033d-0-0-202205070936120000000012
ACL&QoS:
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow statistics:
  Uplink   packets/bytes: 691/57955
Basic:
  State: Online
  Description: N/A
  PPP index: 0x140000002
  User ID: 0x33f
  Username: user2
  Backup role: N/A
  Authorization domain: dm2
  Authentication domain: dm2
  Interface: XGE3/1/1
  VXLAN ID: -
  IP address: 192.168.0.3
  IP pool: pool1
  IPv6 address: 192::1
  IPv6 pool: pool1
  Primary IPv6 DNS server: 8::8
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Access type: PPPoE
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
PPPoE:
  Session ID: 1
AAA:
  Login time: 2019-09-21  13:57:07
  Accounting start time: 2019-09-21  13:57:07
  Online time (hh:mm:ss): 0:01:09
  Redirect WebURL: -
  MRU: 1480 bytes
  IPv4 MTU: 1480 bytes
  IPv6 MTU: 1480 bytes
  Subscriber ID: -
  Accounting session ID: 400033f-0-0-202205070936120000000012
  NAT instance: cgn
ACL&QoS:
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
NAT:
  Global IP address: 111.8.0.200
  Port block: 28744-28748
  Extended port block: 2024-2033-111.8.0.201/3024-3033-111.8.0.202/4024-4033-111.8.0.203/5024-5033-111.8.0.214/6024-6033-11.8.0.222
Flow statistics:
  Uplink   packets/bytes: 28/4736
EDSG:
  Service ID                    : 1
  Service ID                    : 2
# Display detailed information about temporary Layer 2 IPoE users.
<Sysname> display access-user temporary  user-type layer2-dynamic verbose
Slot 97:
Basic:
  State: Online (Temporary)
  Description: N/A
  User ID: 0x80002e64
  Username: -
  Backup role: Master
  Authorization domain: N/A
  Interface: R-XGE1025/2/2/2.2
  Service-VLAN/Customer-VLAN: 3002/100
  VXLAN ID: -
  MAC address: 0010-9400-0001
  IP address: 6.13.0.0
  IP pool: N/A
  IPv6 address: -
  IPv6 pool: N/A
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  DHCP lease: -
  DHCPv6 lease: -
  VPN instance: N/A
  Static Lease user: No
  Agent-Circuit-Id: -
  Agent-Remote-Id: -
  NAS-Port-Id: -
  User switchover time: -
  IP gateway address: 6.0.0.1
  User basic service IP type: -
AAA:
  Login time: 2025-03-11  09:26:59
  Accounting state: Ready
  Acct start-fail action: Offline
  Acct update-fail action: Offline
  Redirect WebURL: -
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
  Accounting session ID: N/A
ACL&QoS:
  User group ACL: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow statistics:
Basic
Basic information of a user.
Session state of a user. Options include:
·     Init—Initializing.
·     Authing—Authentication in progress.
·     Authed—Authentication completed.
·     Reauth—Reauthentication in progress.
·     Logout—Exiting the current authentication phase.
·     Online—Online.
·     Offline—Going offline.
Description of a user. If the user does not have a description, this field displays N/A.
PPP index
PPP session index. This field is displayed only for PPPoE users and L2TP users.
Username
Backup role
Role of the user in the CPDR or VSRP network:
·     Master—In the CPDR network, the user belongs to the master CPDR group. In the VSRP network, the user belongs to the master device.
·     Backup—In the CPDR network, the user belongs to the backup CPDR group, and the user information is synchronized from the master CP. In the VSRP network, the user belongs to the backup device, and the user information is synchronized from the master device.
·     N/A—The user is not in a CPDR or VSRP network.
Authorization domain, which specifies the ISP domain that the AAA server authorizes to the user through the H3C-ISP-ID attribute. The authorization domain is the actual ISP domain that the user uses after coming online.
Authentication domain, which specifies the domain used by the user for authentication on the AAA server. For Layer 2 IPoE leased subusers, who do not need authentication, this field displays N/A.
Backup interface
UP backup access interface of a user. If the user does not have a UP backup access interface, this field is not displayed.
PPPoEA relay interface
Name of the access interface of the PPPoE agency gateway bound to a PPPoE agency group. This interface is on the PPPoE agency gateway for connecting to the campus BRAS. This field is displayed only on a PPPoE agency gateway network.
VXLAN ID
VXLAN ID. If the user does not have a VXLAN ID, this field displays a hyphen (-).
MAC address
MAC address. If the user does not have a MAC address, this field displays a hyphen (-).
IP address
IPv4 address of the user. If the user does not have an IPv4 address, this field displays a hyphen (-).
IP pool
Name of the IP address pool actually used by the user (this field displays N/A if the user does not use an IP address pool). The value displayed for this field depends on the origins of the IP address pool as follows:
·     If AAA authorizes an IP address pool but does not authorize an IP address pool group, the field displays the name of the AAA-authorized IP address pool.
·     If AAA does not authorize an IP address pool but authorizes an IP address pool group, the field displays the name of the IP address pool that actually allocated an IP address to the user in the AAA-authorized IP address pool group.
·     If AAA authorizes both an IP address pool and an IP address pool group, the field displays the name of the AAA-authorized IP address pool.
·     If AAA does not authorize an IP address pool or IP address pool group, the field displays the name of the IP address pool selected through DHCP. For more information about how DHCP selects an IP address pool, see DHCP configuration in BRAS Services Configuration Guide.
IP pool group
AAA-authorized IP address pool group name. This field is displayed when AAA authorizes an IP address pool group.
Primary DNS server
Primary IPv4 DNS server address. This field displays a hyphen (-) when no primary IPv4 DNS server address is allocated to the user.
Secondary IPv4 DNS server address. This field displays a hyphen (-) when no secondary IPv4 DNS server address is allocated to the user.
IPv6 address
IPv6 address of the user. If the user does not have an IPv6 address, this field displays a hyphen (-).
IPv6 pool
Name of the IPv6 address pool actually used by the user (this field displays N/A if the user does not use an IPv6 address pool). The value displayed for this field depends on the origins of the IPv6 address pool as follows:
·     If AAA authorizes an IPv6 address pool but does not authorize an IPv6 address pool group, the field displays the name of the AAA-authorized IPv6 address pool.
·     If AAA does not authorize an IPv6 address pool but authorizes an IPv6 address pool group, the field displays the name of the IPv6 address pool that actually allocated an IPv6 address to the user in the AAA-authorized IPv6 address pool group.
·     If AAA authorizes both an IPv6 address pool and an IPv6 address pool group, the field displays the name of the AAA-authorized IPv6 address pool.
·     If AAA does not authorize an IPv6 address pool or IPv6 address pool group, the field displays the name of the IPv6 address pool selected through DHCP. For more information about how DHCP selects an IPv6 address pool, see DHCPv6 configuration in BRAS Services Configuration Guide.
IPv6 pool group
AAA-authorized IPv6 address pool group name. This field is displayed when AAA authorizes an IPv6 address pool group.
Primary IPv6 DNS server address. This field displays a hyphen (-) when no primary IPv6 DNS server address is allocated to the user.
Secondary IPv6 DNS server address. This field displays a hyphen (-) when no secondary IPv6 DNS server address is allocated to the user.
IPv6 PD prefix
IPv6 PD prefix of the user. If the user does not have an IPv6 PD prefix, this field displays a hyphen (-).
IPv6 ND prefix
IPv6 ND prefix of the user. If the user does not have an IPv6 ND prefix, this field displays a hyphen (-).
IPv6 ND prefix pool
Name of the AAA-authorized IPv6 ND prefix pool. (This field displays N/A if no IPv6 ND prefix pool is authorized). The value displayed for this field depends on the origins of the IPv6 ND prefix pool:
·     If AAA authorizes an IPv6 ND prefix pool but does not authorize an IPv6 ND prefix pool group, the field displays the name of the AAA-authorized IPv6 ND prefix pool.
·     If AAA does not authorize an IPv6 ND prefix pool but authorizes an IPv6 ND prefix pool group, the field displays the name of the IPv6 ND prefix pool that actually allocated a prefix to the user in the AAA-authorized IPv6 ND prefix pool group.
·     If AAA authorizes both an IPv6 ND prefix pool and an IPv6 ND prefix pool group, the field displays the name of the AAA-authorized IPv6 ND prefix pool.
Name of the AAA-authorized IPv6 ND prefix pool group. This field is displayed only when AAA authorizes an IPv6 ND prefix pool group.
DHCP lease
DHCP-authorized IP lease in seconds (This field is displayed only in common mode or in control plane mode of the CUPS mode):
·     Hyphen (-)—No IP lease is authorized.
·     Unlimited—The IP lease is unlimited.
Remaining DHCP-authorized IP lease in seconds. This field is displayed only in common mode or in control plane mode of the CUPS mode.
This field is displayed only on the service node. On the other nodes, this field displays a hyphen (-).
DHCPv6 lease
DHCPv6-authorized IPv6 lease in seconds (this field is displayed only in common mode or in control plane mode of the CUPS mode and when IPv6 users are online):
·     Hyphen (-)—No IPv6 lease is authorized.
·     Unlimited—The IPv6 lease is unlimited.
Remaining DHCPv6-authorized IPv6 lease in seconds. This field is displayed only in common mode or in control plane mode of the CUPS mode and when IPv6 users are online.
User address type
AAA-authorized user address type:
·     private-ds—Private dual-stack address.
·     private-ipv4—Private IPv4 address.
·     public-ds—Public dual-stack address.
·     public-ipv4—Public IPv4 address.
·     ds-lite—Lite dual-stack address.
·     ipv6—IPv6 address.
·     nat64—NAT64 address.
·     N/A—If no IPv4 user address type is authorized, this field displays N/A.
VPN instance
VPN instance of the user. If the user belongs to a public network, this field displays N/A.
Access type
Access type of the user. For more information, see Table 2.
Authentication type
Authentication type of the user:
·     AdminDevice management users.
·     BindIPoE users using bind authentication.
·     PPPPPP users.
·     Pre-authIPoE users in preauthentication phase.
·     SSLVPNSSL VPN users.
·     Web-authIPoE users in Web authentication phase and users performing authentication through a Web interface on a Layer 2 Ethernet interface.
¡     mac-auth: IPoE Web users that come online through transparent MAC authentication.
¡     mac-trigger: IPoE Web users that come online through transparent MAC trigger authentication.
Inherit-PPPoE user: Yes
The current IPoE Web user directly inherits the PPPoE user information in the preauthentication domain and comes online in the postauthentication domain. This field is displayed only when the IPoE Web user inherits the PPPoE user information and comes online in the postauthentication domain.
Static leased user
Whether the user is an IPoE static leased user. This field displays Yes for static leased users and No for the other users.
(Static leased sessions are supported only when the bind authentication mode is used on a non-CUPS network.)
Agent-Circuit-Id
Circuit ID. If no circuit ID exists, this field displays a hyphen (-).
Agent-Remote-Id
Remote ID. If no remote ID exists, this field displays a hyphen (-).
NAS-Port-Id
Information encapsulated in the NAS-Port-ID attribute. If no circuit ID NAS-Port-ID attribute information exists, this field displays a hyphen (-). For a leased user or subuser, this field always displays the NAS-Port-ID of the leased user.
This field displays the NAS-Port-ID encapsulation format defined by each service module and is not affected by the attribute 87 format command configuration. For more information about this command, see AAA commands.
In a non-CPDR network or on the master CP in a CPDR network, this field will display a hyphen (-) during the master/backup UP switchover, and it will display the correct NAS-PORT-ID attribute encapsulation information after the next accounting packet is generated for the user or the user roams.
Interface ID used by a PPP user after the IPv6CP negotiation succeeds. If the user does not have an interface ID, this field displays a hyphen (-). The interface IDs used by PPP users include the following types, in descending order of priority:
1.     ‍Interface ID authorized by the RADIUS server through the Framed-Interface-Id attribute.
1.     The lowest 64 bits of the authorized IPv6 address if an IPv6 address is authorized to the user but no IPv6 prefix is authorized to the user when NDRA is used to allocate IPv6 addresses to PPP users.
2.     Interface ID automatically assigned by the device when the ipv6cp assign-interface-id command is executed in the ISP domain of the user.
If the ipv6cp assign-interface-id command is not executed in the ISP domain of the user, the following rules apply:
·     If the user carries a non-zero interface ID that does not conflict with any other interface ID, the interface carried by the user is used.
·     Otherwise, the interface ID assigned by the device is used.
IP gateway address
IPv4 gateway address of the user. If the user does not have an IPv6 gateway address, this field displays a hyphen (-).
IPv6 link-local address of the user. If the user does not have an IPv6 link-local address, this field displays a hyphen (-).
IPv6 address protocol types. If there are multiple IPv6 address protocol types, they are separated by spaces. Options include:
·     DHCPv6— DHCPv6 is used to allocate IPv6 addresses to users.
·     DHCPv6-PD—DHCPv6 is used to allocate IPv6 PD prefixes to users.
·     ND—IPv6 NDRA is used to allocate IPv6 addresses to users.
·     N/A—IPv6 addresses are allocated in a non-dynamic method.
IP address types on which the main service of the user depends. If multiple IP address types are configured, they are separated by spaces. If no IP address types are configured, this field displays a hyphen (-). Options include:
·     IPv4—IPv4 address type.
·     IPv6—IPv6 address type.
·     IPv6-PD—IPv6 PD prefix.
AAA
AAA information. In session mode of the CUPS mode, only the Redirect WebURL, Redirect IPv6 WebURL, MRU, IPv4 MTU, and IPv6 MTU fields are displayed for AAA information on a UP.
Authentication state of the user:
·     Idle—The user is not authenticated.
·     Authenticating—The user is being authenticated.
·     Authenticated—The user has been authenticated.
Authorization state
Authorization state of the user:
·     Idle—The user is not authorized.
·     Authorizing—The user is being authorized.
·     Authorized—The user has been authorized.
·     Open.
·     Closed.
Realtime accounting interval in seconds. If the device does not send accounting information of online users to the AAA server, this field displays a hyphen (-).
Login time
Time when the user logged in.
Time when accounting started for the user. For a leased subuser, this field always displays a hyphen (-).
Online duration of the user in the current login. For a leased subuser, this field always displays 0:00:00.
Accounting state
Accounting state of a user:
·     Idle.
·     Ready.
·     Accounting—Accounting in progress.
·     Leaving-flow-query—Waiting for offline flow responses.
·     Wait-acct-start—Waiting for Accounting-Start responses.
·     Wait-acct-stop—Waiting for the Accounting-Stop responses.
·     Stop—Accounting stopped.
Actions to take after accounting fails to start:
·     Online—Keeps the user online.
·     Offline—Forces the user offline.
Actions to take after accounting fails to update:
Actions to take after the traffic quota is exhausted:
·     Redirect—Pushes a redirect Web page to the user.
Accounting mode of dual-stack users:
·     MergeReports the IPv4 and IPv6 traffic of dual-stack users as a whole to the accounting server.
·     SeparateReports the IPv4 and IPv6 traffic of dual-stack users to the accounting server separately.
Rate limiting mode for dual-stack users:
·     Merge—Unified rate limiting, which calculates the rate for both the IPv4 and IPv6 traffic of dual-stack users.
·     Separate—Separate rate limiting, which calculates the IPv4 and IPv6 traffic rates of dual-stack users separately.
Idle cut
Parameters for idle cut. If traffic does not reach the specified threshold in bytes within the specified period, the user is considered as offline and is logged out.
direction
The device determines whether to idle cut (forcibly log out) a user based on whether the inbound, outbound, or total traffic of the user reaches the specified threshold in bytes within the specified period.
Direction of traffic to be used by idle cut:
·     Both—Sum of inbound and outbound traffic.
·     Inbound—Inbound traffic.
·     Outbound—Outbound traffic.
Session timeout
AAA-authorized session timeout in seconds.
·     Unlimited—The online duration of the user is not limited in either of the following conditions:
¡     The action to take on a user after the accounting quota (traffic or duration) is exhausted is to keep the user online.
¡     No session timeout is authorized to the user.
·     Hyphen (-)—After the authorized online duration times out, a redirect Web page is pushed to the user.
This field is displayed only when the remaining AAA-authorized session timeout is not 0.
Time remained
Remaining AAA-authorized session timeout in seconds.
Traffic quota
AAA-authorized traffic quota in bytes.
·     Unlimited—The traffic quota of the user is not limited in either of the following conditions:
¡     No traffic quota is authorized to the user.
·     Hyphen (-)—After the authorized traffic quota is exhausted, a redirect Web page is pushed to the user.
This field is displayed only when the remaining AAA-authorized traffic quota is not 0.
Traffic remained
Remaining AAA-authorized traffic quota in bytes.
Whether the ipv6cp assign-interface-id command is executed to enable the device to forcibly assign interface IDs to PPP users during IPv6CP negotiation and not to accept non-zero interface IDs that are carried in user packets and do not conflict with other interface IDs.
·     Enabled.
·     Disabled.
Redirect WebURL
URL address of the Web page pushed to the user. Options include:
·     Authorized reachable redirect URL—For IPoE Web preauthentication, this field displays the URL of the IPv4 Web authentication page pushed to the user. In other cases, this field displays the URL of the redirect IPv4 or IPv6 Web page pushed to the user.
·     Redirect URL after the user traffic quota is used up—URL of the IPv4 or IPv6 Web page pushed to the user after the user traffic quota is used up.
For the preceding URLs, follow these restrictions and guidelines:
·     If you use the web-server url-parameter userip source-address command to configure the redirect URL to carry the user IP address, this parameter will be displayed as %c here.
·     If you use the web-server url-parameter userurl original-url command to configure the redirect URL to carry the URL of the Web page that the user initially accesses, this parameter will be displayed as %o here.
·     If the user does not have the redirect Web URL, this field displays a hyphen (-).
This field applies only to the IPoE Web preauthentication domain, and indicates the IPv6 URL of the reachable Web authentication page pushed to the user.
·     If there is no IPv6 URL for a Web authentication page pushed to the user, this field will not be displayed.
ITA policy name
AAA-authorized ITA policy name. If no ITA policy name is authorized, this field displays N/A.
MRU
MRU in bytes negotiated by both ends of a link in the PPP LCP phase. This field is applicable to only PPPoE and L2TP users, and displays N/A for other users.
IPv4 MTU
MTU used for guiding IPv4 packet forwarding, in bytes. This field is applicable to only PPPoE and L2TP users, and displays N/A for other users.
IPv6 MTU
MTU used for guiding IPv6 packet forwarding, in bytes. This field is applicable to only PPPoE and L2TP users, and displays N/A for other users.
Subscriber ID
Subscriber ID authorized to the user. If no subscriber ID is authorized, this field displays a hyphen (-).
Name of the inbound NetStream sampler authorized to the user. If no inbound NetStream sampler is authorized to the user, this field displays Not set.
Name of the outbound NetStream sampler authorized to the user. If no outbound NetStream sampler is authorized to the user, this field displays Not set.
Name of the IPv4 multicast user profile authorized to the user. If no IPv4 multicast user profile is authorized to the user, this field displays N/A.
Name of the IPv6 multicast user profile authorized to the user. If no IPv6 multicast user profile is authorized to the user, this field displays N/A.
Current authentication method:
·     None—Does not authenticate users.
·     Local—Local authentication.
·     RADIUS—RADIUS authentication.
·     RADIUS proxy—RADIUS proxy authentication.
·     HWTACACS—HWTACACS authentication.
Accounting session ID.
NAT instance
NAT instance name. If the user does not have a NAT instance, this field is not displayed.
Maximum number of AAA-authorized IPv4 multicast groups that a user can join. This field is displayed only when the number of addresses in the list is greater than 0.
List of AAA-authorized IPv4 multicast group addresses. If no IPv4 multicast group is authorized, this field displays an ellipsis (...).
Maximum number of AAA-authorized IPv6 multicast groups that a user can join. This field is displayed only when the number of addresses in the list is greater than 0.
IPv4/IPv6 address of the RADIUS client when the RADIUS proxy feature is enabled.
Name of the VPN instance to which the RADIUS client belongs when the RADIUS proxy feature is enabled. This field displays N/A if the RADIUS client belongs to the public network instance.
User session: limit n, online m
Statistics about users using a shared account. This field is displayed only when the users-per-account command has been executed in the ISP domain to which users belongs or the RADIUS server has authorized attribute 62 (port-limit) to users.
·     limit—Maximum number of concurrent users allowed for a shared account.
·     online—Actual number of access users.
Account ID
Account ID automatically allocated by the system to the user. This field is not displayed if no account ID is allocated.
IPv4 address authorized to the user by AAA. If no IPv4 address is authorized, this field displays N/A.
IPv6 address authorized to the user by AAA. If no IPv6 address is authorized, this field displays N/A.
PPPoE agency user: Yes
Indicates that the user supports PPPoE agency. This field appears only if PPPoE agency is supported.
PPPoEA state
Online state of the PPPoE agency user. The field is displayed only when the PPPoE agency feature is supported. Possible values for the PPPoE agency state include:
·     Request—PPPoE agency requests are initiated.
·     Succeeded—PPPoE agency succeeds, but the user has not come online.
·     Online—The PPPoEA user has come online.
·     Start redial timer—The redial timer is started after the PPPoE agency fails or the PPPoE agency user goes offline, and the redial timer has not timed out. After the redial timer times out, PPPoE agency will be performed again.
PPPoEA user ID
User ID of a PPPoEA user. This field is displayed only when the PPPoE agency feature is supported.
PPPoEA user IP
IP address of a PPPoEA user. This field is displayed only when the PPPoE agency feature is supported.
PPPoEA online failure or offline reason
Online or offline failure reason of a PPPoEA user. This field is displayed only when the PPPoE agency feature is supported.
PPPoEA redial times
Redial times of a PPPoEA user. This field is displayed only when the PPPoE agency feature is supported.
PPPoEA user name
Username used by a PPPoEA user for coming online. This field is displayed only when the PPPoE agency feature is supported.
PPPoEA user group
User group to which a PPPoEA user belongs. This field is displayed only when the PPPoE agency feature is supported.
ACL&QoS
ACL and QoS information.
Name of the AAA-authorized inbound user profile. N/A means that no inbound user profile is authorized.
The user profile has the following states:
·     active—The inbound user profile is authorized successfully.
·     inactive—Inbound user profile authorization failed or the inbound user profile does not exist on the BRAS.
·     N/A—The authorization state is insignificant. The device does not need the authorized attribute.
Name of the AAA-authorized outbound user profile. N/A means that no outbound user profile is authorized.
·     active—The outbound user profile is authorized successfully.
·     inactive—Outbound user profile authorization failed or the outbound user profile does not exist on the BRAS.
Name of the AAA-authorized session group profile. N/A means that no session group profile is authorized.
The session group profile has the following states:
·     inactive—Session group profile authorization failed or the session group profile does not exist on the BRAS.
·     active—The session group profile is authorized successfully.
If the authorization result has not been updated, nothing is displayed.
User group acl
Name of the AAA-authorized user group ACL. N/A means that no user group ACL is authorized.
The user group ACL has the following states:
·     active—The user group ACL is authorized successfully.
·     inactive—User group ACL authorization failed or the user group ACL does not exist on the BRAS.
Inbound CAR
AAA-authorized inbound CIR and PIR in kbps, and CBS in bytes. A hyphen (-) means that no inbound CAR is authorized.
The inbound CAR has the following states:
·     inactive—Inbound CAR is not authorized successfully.
·     active—Inbound CAR is authorized successfully.
·     from-firewall—Indicates that the rate limit is deployed by the firewall to the BRAS.
Outbound CAR
AAA-authorized outbound CIR and PIR in kbps, and CBS in bytes. A hyphen (-) means that no outbound CAR is authorized.
The outbound CAR has the following states:
·     inactive—Outbound CAR is not authorized successfully.
·     active—Outbound CAR is authorized successfully.
AAA-authorized inbound subscriber group CAR parameters:
·     Committed information rate (CIR) in kbps.
·     Peak information rate (PIR) in kbps.
·     Committed burst size (CBS) in bytes.
If no CAR parameters have been authorized, this field displays a hyphen (-). Authorization status options include:
·     active—Inbound subscriber group CAR parameters have been authorized successfully.
·     inactive—Inbound subscriber group CAR parameters have failed to be authorized.
·     N/A—Indicates insignificant authorization status (the current device does not need this authorization attribute).
AAA-authorized outbound subscriber group CAR parameters:
·     active—Outbound subscriber group CAR parameters have been authorized successfully.
·     inactive—Outbound subscriber group CAR parameters have failed to be authorized.
AAA-authorized inbound user priority, which can be a number in the range of 0 to 7, 15, and a hyphen (-). A hyphen (-) or 15 means that no inbound user priority is authorized.
The inbound user priority has the following states:
·     inactive—Inbound user priority is not authorized successfully.
·     active—Inbound user priority is authorized successfully.
AAA-authorized outbound user priority, which can be a number in the range of 0 to 7, 15, and a hyphen (-). A hyphen (-) or 15 means that no outbound user priority is authorized.
The outbound user priority has the following states:
·     inactive—Outbound user priority is not authorized successfully.
·     active—Outbound user priority is authorized successfully.
NAT
NAT information.
Global IP address
Public network IP address. This field is displayed after NAT444 translation.
Port block
Port block, from the start port to the end port. This field is displayed after NAT444 translation.
Extended port block
Extended port block, in the form of start port-end port-public network IP address. This field is displayed only when extended port blocks are configured in dynamic port block mapping mode.
Flow statistics
Flow statistics. This field is not displayed on UPs in session mode of the CUPS mode.
Total number and size of uplink packets. This field displays the total number and size of uplink IPv4 and IPv6 packets in Merge accounting mode. Otherwise, this field displays the total number and size of uplink IPv4 packets.
Total number and size of downlink packets. This field displays the total number and size of downlink IPv4 and IPv6 packets in Merge accounting mode. Otherwise, this field displays the total number and size of downlink IPv4 packets.
Total number and size of uplink IPv6 packets.
Total number and size of downlink IPv6 packets.
Flow rate statistics (displayed only when the access-user flow-rate-calculate enable command is executed).
User flow rate information within the specified time period.
Flow rate
In merge accounting mode, this field displays the sum of the user's IPv4 uplink and downlink flow rates and IPv6 uplink and downlink flow rates. In any other cases, this field displays the sum of the user's uplink IPv4 flow rate and downlink IPv4 uplink flow rate. The unit of measurement is bps.
Inbound flow rate
In merge accounting mode, this field displays the sum of the user's IPv4 uplink flow rate and IPv6 uplink flow rate. In any other cases, this field displays the sum of the user's IPv4 uplink flow rate. The unit of measurement is bps.
Outbound flow rate
In merge accounting mode, this field displays the sum of the user's IPv4 downlink flow rate and IPv6 downlink flow rate. In any other cases, this field displays the sum of the user's IPv4 downlink flow rate. The unit of measurement is bps.
IPv6 flow rate
Sum of the user's IPv6 uplink flow rate and downlink flow rate. The unit of measurement is bps.
User's IPv6 uplink flow rate, in bps.
User's IPv6 downlink flow rate, in bps.
PPPoE
PPPoE information.
Session ID
PPPoE session ID.
L2TP LAC
L2TP LAC information.
L2TP LNS
L2TP LNS information.
Group ID
L2TP group number.
Local tunnel ID
Tunnel ID of the local L2TP end.
Remote tunnel ID
Tunnel ID of the L2TP peer.
Local session ID
Session ID of the local L2TP end.
Remote session ID
Session ID of the L2TP peer.
Local IP
IP address of the local L2TP end.
Remote IP
IP address of the L2TP peer.
Local port
UDP port number used by the local L2TP end.
Remote port
UDP port number used by the L2TP peer.
Vrf index
VPN index of an L2TP session.
Calling station
L2TP calling number. If the calling number does not exist, this field displays a hyphen (-).
ITA
ITA information.
Level-n
ITA accounting level n, in the range of 1 to 8.
EDSG
EDSG information.
Service ID
EDSG service ID.
·     Uplink IPv4 and IPv6 ITA or EDSG traffic in packets and bytes when the dual-stack accounting mode is merge.
·     Uplink IPv4 ITA or EDSG traffic in packets and bytes in any other case.
·     Downlink IPv4 and IPv6 ITA or EDSG traffic in packets and bytes when the dual-stack accounting mode is merge.
·     Downlink IPv4 ITA or EDSG traffic in packets and bytes in any other case.
Uplink IPv6 ITA or EDSG traffic in packets and bytes.
Downlink IPv6 ITA or EDSG traffic in packets and bytes.
Total subusers
Number of Layer 2 IPoE leased subusers and brief information about these subusers (the brief information is displayed only when subusers exist).
cut access-user
display access-user authen-rate status
Use display access-user authen-rate status to display the configuration and status of the access user authentication rate on the device.
display access-user authen-rate status [ history ]
history: Displays historical configuration and status information of the access user authentication rate of the device. Up to 1000 entries can be displayed. If you do not specify this keyword, the system displays the current information.
# Display the current configuration and status of the user authentication rate of the device.
<Sysname> display access-user authen-rate status
Authentication number : 500
Authentication period : 1
Global                : Yes
Authentication status : no-limit
Table 5 Command output
Current effective maximum number of users allowed for access authentication within the specified statistics collection interval.
This field displays a hyphen (-) if the corresponding parameter is not configured.
Current effective user access authentication statistics collection interval, in seconds.
Global
Whether the effective value comes from the access-user authen-rate command in system view. Options include:
·     Yes.
·     No.
·     Hyphen (-)—Not configured.
Whether access user authentication is limited. Options include:
·     no-limit—Not limited.
·     limited—Limited.
# Display historical information that the configured user authentication rates were exceeded.
<Sysname> display access-user authen-rate status history
status                time                      authen-number     authen-period
limited               2024-10-21 12:24:56       500               10
limited               2024-10-21  09:12:12      500               1
Table 6 Command output
status
Whether the access user authentication rate is limited.
time
Time when the access user authentication rate reached the upper limit.
authen-number
Maximum effective access user authentication rate on the device.
authen-period
Effective access user authentication statistics collection interval on the device.
access-user authen-rate minor severe
display access-user max-connections status
Use display access-user max-connections status to display the configuration and status information related to the maximum number of concurrent online users.
display access-user max-connections status [ history ]
history: Displays historical configuration and status information for the maximum number of concurrent online users. Up to 1000 entries can be displayed. If you do not specify this parameter, this command displays the current configuration status of the maximum number of concurrent online users.
# Display the current configuration and status information related to the maximum number of concurrent online users on the device.
<Sysname> display access-user max-connections status
Max connections number : 10000
Resume number          : 8000
Global                 : Yes
Connection number      : 5000
Max connections status : no-limit
Table 7 Command output
Current effective maximum number of concurrent online users.
Resume number
Current active threshold for user access recovery.
Global
Whether the effective value comes from the access-user max-connections command in system view. Options include:
·     Yes.
·     No.
Connection number
Current number of concurrent online users.
Whether user access is limited currently. Options include:
·     limited—Limited.
# Display the historical configuration and status information related to the maximum number of concurrent online users on the device.
<Sysname> display access-user max-connections status history
status         time                         max-connect-users    recover-users
limited        2024-10-21 12:24:56          10000                8000
no-limit       2024-10-21 10:12:12          10000                8000
limited        2024-10-21 09:12:12          8000                 6000
Table 8 Command output
status
Whether the number of concurrent online users reaches the limit. Options include:
·     no-limit—The number of concurrent online users is not limited.
·     limited—The number of concurrent online user has reached the upper limit.
time
Time when the number of concurrent online users reached the maximum number or dropped to the recovery threshold.
max-connect-users
Effective maximum number of concurrent online users on the device.
recover-users
Effective threshold for user access recovery on the device.
access-user max-connections minor severe
display access-user statistics
Use display access-user statistics to display accounting state statistics of access users by accounting state, backup role, or session state.
display access-user { accounting-state | backup-role | session-state } statistics [ [ all-vpn-instance | public-instance | vpn-instance vpn-instance-name ] | domain domain-name [ authorization | authentication ] | interface interface-type interface-number [ all | s-vlan svlan-id [ c-vlan cvlan-id ] ] | ip-pool pool-name | ip-pool-group ip-pool-groupname | ip-type { dual-stack | ipv4 | ipv6 } | ipv6-address-protocol { dhcpv6 | dhcpv6-pd | nd } | ipv6-pool pool-name | ipv6-pool-group ipv6-pool-groupname | lac-ip lac-ip-address | lns-ip lns-ip-address | nat-instance nat-instance-name | remote-name tunnel-name | user-group { user-group-name | [ user-group-name ] inactive } | user-type { l2vpn-leased | lac | layer2-dynamic | layer2-family-leased | layer2-interface-leased | layer2-static | layer2-subnet-leased | layer3-dynamic | layer3-interface-leased | layer3-static | layer3-subnet-leased | leased | leased-subuser | lns | pppoe | pppoea } ] *
accounting-state: Displays statistics of access users based on accounting state.
backup-role: Displays statistics of access users based on backup role.
session-state: Displays statistics of access users based on session state.
all-vpn-instance: Specifies all VPN instances, excluding the public network instance.
public-instance: Specifies the public network instance.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name. The vpn-instance-name argument specifies an MPLS L3VPN name, a case-sensitive string of 1 to 31 characters.
domain domain-name: Specifies an ISP domain by its name. The domain-name argument represents the name of an authorization or authentication domain, a case-insensitive string of 1 to 255 characters. If you specify the domain keyword but do not specify the authorization or authentication keyword, this command displays statistics of users who access through all authentication and authorization domains that meet the criteria.
·     authorization: Specifies users that access through the specified authorization domain.
·     authentication: Specifies users that access through the specified authentication domain.
interface interface-type interface-number: Specifies users that access an interface specified by its type and number. This parameter is supported only on network access users.
·     all: Specifies users on the current main interface and all its subinterfaces. To specify this keyword, make sure the interface specified by using the interface keyword is a main interface.
·     s-vlan svlan-id: Specifies an SVLAN by its ID. The value range for the svlan-id argument is 1 to 4094.
·     c-vlan cvlan-id: Specifies a CVLAN by its ID. The value range for the cvlan-id argument is 1 to 4094.
ip-pool pool-name: Specifies an IPv4 address pool by its name, a case-insensitive string of 1 to 63 characters.
ip-pool-group ip-pool-groupname: Specifies an IPv4 address pool group by its name, a case-insensitive string of 1 to 63 characters.
ip-type: Specifies an IP version of users.
·     dual-stack: Specifies dual-stack users.
·     ipv4: Specifies IPv4 users.
·     ipv6: Specifies IPv6 users.
ipv6-address-protocol: Specifies users whose IPv6 addresses or prefixes are assigned by the specified IPv6 protocol.
·     dhcpv6: Specifies users whose IPv6 addresses are assigned by DHCPv6.
·     dhcpv6-pd: Specifies users whose IPv6 PD prefixes are assigned by DHCPv6.
·     nd: Specifies users whose addresses are assigned by IPv6 NDRA.
ipv6-pool pool-name: Specifies an IPv6 address pool by its name, a case-insensitive string of 1 to 63 characters. On an NDRA network, if the IPv6 prefix of a user is from an ND prefix pool, the pool-name argument represents the name of the AAA-authorized ND prefix pool.
ipv6-pool-group ipv6-pool-groupname: Specifies an IPv6 address pool group by its name, a case-insensitive string of 1 to 63 characters.
lac-ip lac-ip-address: Specifies the LNS to display users on the LAC specified by its IP address. Only the LNS supports this option.
lns-ip lns-ip-address: Specifies the LAC to display users on the LNS specified by its IP address. Only the LAC supports this option.
nat-instance nat-instance-name: Specifies a NAT instance by its name, a case-sensitive string of 1 to 31 characters. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX". To ensure that NAT operates normally, make sure the specified NAT instance name is available.
remote-name tunnel-name: Displays statistics of L2TP users for the specified LAC or LNS. The tunnel-name argument represents the tunnel name on the LAC or LNS, and is a case-sensitive string of 1 to 31 characters.
user-group: Displays statistics for users in the specified user group.
user-type: Specifies a user type.
·     l2vpn-leased: Specifies IPoE L2VPN-leased users.
·     lac: Specifies online users on the device acting as an LAC.
·     layer2-dynamic: Specifies Layer 2 IPoE dynamic users.
·     layer2-family-leased: Specifies Layer 2 IPoE family-leased users.
·     layer2-interface-leased: Specifies Layer 2 IPoE interface-leased users.
·     layer2-static: Specifies Layer 2 IPoE static users.
·     layer2-subnet-leased: Specifies Layer 2 IPoE subnet-leased users.
·     layer3-dynamic: Specifies Layer 3 IPoE dynamic users.
·     layer3-interface-leased: Specifies Layer 3 IPoE interface-leased users.
·     layer3-static: Specifies Layer 3 IPoE static users.
·     layer3-subnet-leased: Specifies Layer 3 IPoE subnet-leased users.
·     leased: Specifies IPoE leased users (including main users and subusers).
·     leased-subuser: Specifies Layer 2 IPoE leased subusers.
·     lns: Specifies online users on the device acting as an LNS.
·     pppoe: Specifies online PPPoE users.
·     pppoea: Specifies online PPPoE agency users.
·     Display the statistics of the access users by accounting state.
# Display the statistics of the access users by accounting state.
<Sysname> display access-user accounting-state statistics
Total users                       : 3
Idle                              : 0
Ready                             : 0
Wait-acct-start                   : 0
Accounting                        : 3
Leaving-flow-query                : 0
Wait-acct-stop                    : 0
Stop                              : 0
Table 9 Command output
Total users
Total users.
Idle
Number of users in Idle state.
Ready
Number of users in Ready state.
Wait-acct-start
Number of users in Wait-acct-start state.
Accounting
Number of users in Accounting state
Leaving-flow-query
Number of users in Leaving-flow-query state.
Wait-acct-stop
Number of users in Wait-acct-stop state.
Stop
Number of users in Stop state.
·     Display the statistics of the access users by backup role.
# Display the statistics of the access users by backup role.
<Sysname> display access-user backup-role statistics
Total users                       : 3
Normal users                      : 3
Master users                      : 0
Backup users                      : 0
Local-access users                : 3
Remote-access users               : 0
Table 10 Command output
Total users
Total number of users, which is the sum of the following types of users:
·     Normal users.
·     Master users.
·     Backup users.
Normal users
Number of users in a non-CPDR and non-VSRP network.
Master users
Number of users with the backup role as Master in a CPDR or VSRP network.
Backup users
Number of users with the backup role as Backup in a CPDR or VSRP network.
Local-access users
Number of users who initially come online from the local device in a CPDR or VSRP network, as well as all users on the local device in a non-CPDR and non-VSRP network.
Remote-access users
Number of users who initially come online from the remote device in a CPDR or VSRP network.
·     Display the statistics of the access users by session state
# Display the statistics of the access users by session state.
<Sysname> display access-user session-state statistics
Total users                       : 3
Init                              : 0
Authing                           : 0
Authed                            : 0
Reauth                            : 0
Logout                            : 0
Online                            : 3
Offline                           : 0
Table 11 Command output
Total users
Total number of users.
Init
Number of users in initialization state.
Authing
Number of users in authenticating state.
Authed
Number of users in authenticated state.
Reauth
Number of users in reauthentication phase.
Logout
Number of users exiting the current authentication.
Online
Number of users in online state.
Offline
Number of users going offline.
display access-user backup-state
Use display access-user backup-state to display the access user backup state on each slot.
The active MPU will synchronize the online user information to the standby MPUs and interface cards. You can use this command to view the progress of synchronizing online user information to the standby MPUs and interface cards.(In standalone mode.)
The global active MPU will synchronize the online user information to the standby MPUs and interface cards. You can use this command to view the progress of synchronizing online user information to the standby MPUs and interface cards. (In IRF mode.)
For example, when locating faults, you might need to manually trigger active/standby switchover. To ensure data consistency after the switchover, use this command to verify that the data has been synchronized completely before triggering the switchover.
# Display the access user backup state on each slot.
<Sysname> display access-user backup-state
Slot 3: Ready for smoothing
Slot 4: Smoothing
Slot 5: Smoothing finished
Table 12 Command output
Ready for smoothing
Data synchronization has not started.
Smoothing
Data synchronization is in progress.
Smoothing finished
Data synchronization has finished.
display access-user offline-reason statistics
Use display access-user offline-reason statistics to display offline reason and online reason statistics of access users.
display access-user offline-reason statistics [ verbose ]
verbose: Displays the sub-reason codes and related statistics for each main reason code. If you do not specify this keyword, this command displays each main reason code and related statistics.
This command displays offline reason and online reason statistics of access users.
When the access module is busy processing services, the system might fail to display the related statistics temporarily. In this case, wait a moment and display the statistics later.
This command can display the offline reason statistics for PPPoE, L2TP, and IPoE users.
If the count for a reason code is 0, the reason code field is not displayed.
The offline reasons vary by network environment. Table 13 only list some common offline reasons. For more offline reasons, see the actual output the device.
# Display statistics for the main offline reasons.
<Sysname> display access-user offline-reason statistics
Administrator is resetting service on the NAS: 1
NAS detected an error on the port which required ending the session: 1
NAS error: 5
NAS ended session for a non-error unknown reason: 2
# Display statistics for the offline sub-reasons.
<Sysname> display access-user offline-reason statistics verbose
cut command: 1
Interface down: 1
Service-type mismatch with local-user's: 5
TERM with Ifnet down: 2
Table 13 Command output
User request
Number of users who proactively request to go offline.
Physical down
Number of users that go offline because of data interruption. For example, keepalive detection fails for PPP users.
Service can no longer be provided
Number of users that go offline because of service server interruption. For example, the LNS requests users to go offline.
Idle cut
Number of users that go offline because the idle timer expires.
Session timeout
Number of users that go offline because sessions time out. For example, the AAA-authorized session duration times out.
Number of users that go offline because the administrator resets the service. For example, the administrator executes the cut access-user command.
Administrator is ending service on the NAS
Number of users that go offline because the administrator stops the service. For example, the process exits abnormally.
Number of users that go offline because of interface failures. For example, an access interface goes down.
Number of users that go offline because the sessions are ended by the NAS due to non-error unknown reasons.
NAS error
Number of users that go offline because of NAS failures. For example, UCM failed to apply for memory resources.
NAS request
Number of users that the NAS requests to go offline. For example, the maximum number of online users is reached.
NAS ended session for reboot
Number of users that go offline because the NAS is rebooted.
Port not needed
Number of users that go offline because interfaces are disabled.
Port preempted
Number of users that go offline because interfaces are preempted.
Port suspended
Number of users that go offline because interfaces are suspended.
Service unavailable
Number of users that go offline because services are not supported. For example, the PPPoE server failed to send PADS packets.
Callback user
Number of users that go offline because of callback services. For example, PPP authentication failed.
cut command
Number of users that go offline because the administrator executes the cut access-user command.
Interface down
Number of users that go offline because the access interfaces go down or flap.
Number of users that go offline because the access types of users do not match the service type in the local user configuration on the device.
Number of users that go offline because the access interfaces go down on the network layer
User info error
Number of users that go offline because of incorrect user information. For example, the authentication username is empty.
Host logoff
Number of users that the client requests to go offline.
Restart of the 802.1X supplicant
Number of users that go offline because the 802.1X service is restarted.
802.1X supplicant failed to re-authenticate
Number of users that go offline because 802.1X re-authentication failed.
802.1X port's MAC is reinitialized
Number of users that go offline because the 802.1X access control method is reset to MAC-based.
802.1X port is administratively disabled
Number of users that go offline because 802.1x authentication is disabled.
display access-user user-detect packet-loss-ratio
Use display access-user user-detect packet-loss-ratio to display the packet loss ratio statistics for the access user detection packets.
In standalone mode:
display access-user user-detect packet-loss-ratio [ interface interface-type interface-number [ s-vlan svlan-id ] ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display access-user user-detect packet-loss-ratio [ interface interface-type interface-number [ s-vlan svlan-id ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays entries of all interfaces.
s-vlan svlan-id: Specifies a SVLAN by its ID. The value range for the svlan-id argument is 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
After online user detection is enabled on an interface, the device will automatically record the number of sent detection packets and received packets. You can use this command to view the packet loss ratio statistics for detection packets.
If you execute the display access-user user-detect packet-loss-ratio command at a time point within a 30-second timer, this command displays the packet loss ratio statistics collected at the specified time point within the 30-second timer. For example, if you execute this display command at the 10th second within a 30-second timer, this command displays the packet loss ratio statistics collected within the 10 seconds.
On a unified network, this command displays only the packet loss ratio statistics for IPoE user detection packets. To view the packet loss ratio statistics for PPPoE and L2TP user detection packets on a unified network, use the display ppp keepalive packet-loss-ratio command.
On a CUPS network, this command displays only the packet loss ratio statistics for IPoE, PPPoE, and L2TP user detection packets.
On a CUPS network, detection packets are sent and received on UPs. Therefore, this command can be executed only when it is executed on UPs.
# Display the packet loss ratio statistics for access user detection packets on all interfaces.
<Sysname> display access-user user-detect packet-loss-ratio
Slot 3:
L2TP keepalive   : 50%
Interface Ten-GigabitEthernet3/1/1:
ARP              : 10%
ND               : 15%
PPPoE keepalive  : 18%
Interface Ten-GigabitEthernet3/1/2:
ICMPv4           : 20%
ICMPv6           : 15%
Slot 4:
Interface Ten-GigabitEthernet4/1/1:
ARP              : 10%
ICMPv6           : 15%
# Display the packet loss ratio statistics for access user detection packets on the specified interface.
<Sysname> display access-user user-detect packet-loss-ratio interface ten-gigabitethernet 3/1/1.1
Slot 3:
Interface Ten-GigabitEthernet3/1/1.1:
ND               : 15%
ICMPv4           : 15%
S-VLAN: 100
ND               : 15%
ICMPv4           : 13%
S-VLAN: 200
ND               : 15%
ICMPv4           : 17%
Table 14 Command output
L2TP keepalive
Packet loss ratio of L2TP user keepalive detection packets.
Detected interface.
S-VLAN
Service provider VLAN.
ARP
Packet loss ratio of IPoE user ARP detection packets.
ND
Packet loss ratio of IPoE user ND detection packets.
ICMPv4
Packet loss ratio of IPoE user ICMPv4 detection packets.
ICMPv6
Packet loss ratio of IPoE user ICMPv6 detection packets.
PPPoE keepalive
Packet loss ratio of PPPoE user keepalive detection packets.
access-user user-detect packet-loss-ratio-threshold
display ppp keepalive packet-loss-ratio (BRAS Services Command Reference)
ip subscriber user-detect ip
ip subscriber user-detect ipv6
reset access-user user-detect packet-loss-ratio
display access-user user-plane (on UPs)
Use display access-user user-plane to display access user information on an UP.
Syntax I:
display access-user user-plane [ [ all-vpn-instance | public-instance | vpn-instance vpn-instance-name ] | auth-type { bind | ppp | pre-auth | web-auth } | interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] | { ip-address ipv4-address | ipv6-address ipv6-address } | ip-type { dual-stack | ipv4 | ipv6 } | lac-ip lac-ip-address | lns-ip lns-ip-address | nat-instance nat-instance-name | mac-address mac-address | slot slot-number [ cpu cpu-number ] | user-type { l2vpn-leased | lac | layer2-dynamic | layer2-interface-leased | layer2-static | layer2-subnet-leased | layer3-dynamic | layer3-interface-leased | layer3-static | layer3-subnet-leased | leased | leased-subuser | lns | pppoe } | user-id user-id | up-escape | up-not-escape ] * [ count | verbose ]
Syntax II:
display access-user user-plane all-slot [ auth-type { bind | mac-auth | ppp | pre-auth | web-auth } | interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] | { ip-address ipv4-address | ipv6-address ipv6-address } [ vpn-instance vpn-instance-name ] | ip-type { dual-stack | ipv4 | ipv6 } | lac-ip lac-ip-address | lns-ip lns-ip-address | nat-instance nat-instance-name | mac-address mac-address | user-type { l2vpn-leased | lac | layer2-dynamic | layer2-interface-leased | layer2-static | layer2-subnet-leased | layer3-dynamic | layer3-interface-leased | layer3-static | layer3-subnet-leased | leased | leased-subuser | lns | pppoe } | user-id user-id | vpn-instance vpn-instance-name | up-escape | up-not-escape ] * count
all-slot: Displays the number of all access users in each slot.
vpn-instance vpn-instance-name: Specifies users in an MPLS L3VPN instance specified by its name, a case-sensitive string of 1 to 31 characters.
auth-type: Specifies an authentication type for access users.
·     bind: Specifies IPoE users using bind authentication.
·     ppp: Specifies PPP users.
·     pre-auth: Specifies IPoE users using Web authentication in the preauthentication phase.
·     web-auth: Specifies IPoE users using Web authentication in the Web authentication phase.
interface interface-type interface-number: Specifies users accessing through an interface specified by its type and number. Only network access users support this option.
·     s-vlan svlan-id: Specifies an SVLAN by its ID. The value range is 1 to 4094.
·     c-vlan cvlan-id: Specifies a CVLAN by its ID. The value range is 1 to 4094.
ip-address ipv4-address: Specifies the user with the specified IPv4 address.
ipv6-address ipv6-address: Specifies the user with the specified IPv6 address.
ip-type: Specifies users of an IP type.
mac-address mac-address: Specifies a user by its MAC address in H-H-H format, case-insensitive. Only network access users support this option.
nat-instance nat-instance-name: Specifies users of a NAT instance specified by its name.
user-type: Specifies users of the specified type.
·     lac: Specifies users on the device acting as a LAC.
·     leased: Specifies IPoE leased users.
·     lns: Specifies users on the device acting as an LNS.
·     pppoe: Specifies PPPoE users, including PPPoE users that trigger the LAC to set up L2TP tunnels.
user-id user-id: Specifies an online user by its index.
up-escape: Displays users who come online during the UP fail-permit period.
up-not-escape: Displays users who come online during non-UP fail-permit periods.
count: Displays the number of users.
verbose: Displays detailed user information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
This command is used to display the PPPoE, L2TP, and IPoE access user information synchronized from the CP to an UP. If you do not specify the count or verbose keyword, this command displays brief user information.
If you do not specify the all-vpn-instance, public-instance, or vpn-instance keyword, this command displays user information of the public network instance and all VPN instances.
In an L2TP network, this command is supported on an LAC only if a remote system dials in to the LAC through a PPPoE network. For more information about L2TP, see L2TP configuration in BRAS Services Configuration Guide.
# Display the number of all access users on the UP.
<Sysname> display access-user user-plane count
Total users                      : 3
PPPoE users                      : 1
VPPP users                       : 0
LNS users                        : 1
L2 IPoE dynamic users            : 1
L2 IPoE static users             : 0
L2 IPoE interface leased users   : 0
L2 IPoE subnet leased users      : 0
L2 IPoE leased subusers          : 0
IPoE L2VPN leased users          : 0
L3 IPoE dynamic users            : 0
L3 IPoE static users             : 0
L3 IPoE interface leased users   : 0
L3 IPoE subnet leased users      : 0
Web auth users                   : 0
Table 15 Command output
Total users
PPPoE users
Number of PPPoE users.
VPPP users
Number of L2TP users automatically dialing on the LAC.
LNS users
Number of L2TP users on the LNS.
Number of Layer 2 IPoE dynamic users.
The access type that initiates the user in the corresponding protocol stack will be displayed after this field only in the summary information. The type is represented in the form of (IPv4 protocol stack access type/IPv6 protocol stack access type). On a CUPS network, this field is supported only on the CP, and this field is insignificant and always displays (-/-) on UPs.
Number of Layer 2 IPoE static users.
Number of Layer 2 IPoE interface-leased users.
Number of Layer 2 IPoE subnet-leased users.
Number of Layer 2 IPoE leased subusers.
Number of IPoE L2VPN-leased users.
Number of Layer 3 IPoE dynamic users.
Number of Layer 3 IPoE static users.
Number of Layer 3 IPoE interface-leased users.
Number of Layer 3 IPoE subnet-leased users.
Web auth users
Number of Web authentication users.
The access type that initiates the user in the corresponding protocol stack will be displayed after this field only in the summary information. The type is represented in the form of (IPv4 protocol stack access type/IPv6 protocol stack access type). In a CUPS network, this field is supported only on the CP, and this field is insignificant and always displays (-/-) on UPs.
# Display brief information about all access users on the UP.
UserID      Interface            IP address              MAC address     S-/C-VLAN
            Username             Access type
            IPv6 address
0x33d       XGE3/1/1             192.168.0.2             -               -/-
            -                    LNS
0x33e       XGE3/1/1             3.3.3.3                 001b-21a8-0949  -/-
            -                    L2 IPoE dynamic(-/-)
0x33f       XGE3/1/1             192.168.0.3             001b-21a8-0949  -/-
            -                    PPPoE
Table 16 Command output
UserID
Online index of a user.
Access interface of a user.
Username
Username for authentication. If the user does not have a username, this field displays a hyphen (-).
IP address
IPv4 address of a user. If the user does not have an IPv4 address, this field displays a hyphen (-).
IPv6 address
IPv6 address of a user. If the user does not have an IPv6 address, this field displays a hyphen (-).
MAC address
MAC address of a user. If the user does not have a MAC address, this field displays a hyphen (-).
S-/C-VLAN
SVLAN and CVLAN of a user. If the user does not have a SVLAN or CVLAN, this field displays a hyphen (-).
Access type
Access type of a user. For more information, see Table 15.
# Display detailed information about IPoE users on the UP.
<Sysname> display access-user user-plane auth-type bind verbose
Basic:
  User ID: 0x33e
  Interface: XGE3/1/1
  Service-VLAN/Customer-VLAN: -/-
  MAC address: 001b-21a8-0949
  IP address: 3.3.3.3
  IPv6 address: -
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  VPN instance: N/A
  Access type: L2 IPoE dynamic
  UP backup state: Master, Resource ID: 65537
  IP gateway address: 3.3.3.1
  IPv6 link-local address: -
AAA:
  Dual-stack accounting mode: Merge
  Redirect WebURL: -
  MRU: N/A
  IPv4 MTU: N/A
  IPv6 MTU: N/A
  Subscriber ID: -
  IPv4 multicast user profile: N/A
  IPv6 multicast user profile: N/A
  Max IPv4 multicast addresses: 1
  IPv4 multicast address list : 225.0.0.11
  Max IPv6 multicast addresses: 1
  IPv6 multicast address list : ff1e::31
ACL&QoS:
  Inbound user profile: N/A
  Outbound user profile: N/A
  Session group profile: N/A
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
  Inbound subscriber group CAR: -
  Outbound subscriber group CAR: -
  Inbound user priority: -
  Outbound user priority: -
Flow statistics:
  Uplink   packets/bytes: 389/50005
  Downlink packets/bytes: 23/1362
  IPv6 uplink   packets/bytes: 0/0
  IPv6 downlink packets/bytes: 0/0
Basic:
  PPP index: 0x22d0a92580000105
  User ID: 0x33d
  Interface: XGE3/1/1
  MAC address: -
  IP address: 192.168.0.2
  IPv6 address: -
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  VPN instance: N/A
  Access type: LNS
  IP gateway address: 192.168.0.1
L2TP LAC:
  Local tunnel ID: 8912
  Remote tunnel ID: 2
  Local session ID: 43301
  Remote session ID: 1
  Local IP: 4.1.1.1
  Remote IP: 5.1.1.5
  Local port: 1701
  Remote port: 1701
  Vrf index: 0
AAA:
  Redirect WebURL: -
  MRU: 1400 bytes
  IPv4 MTU: 1400 bytes
  IPv6 MTU: 1400 bytes
  Subscriber ID: -
ACL&QoS:
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow statistics:
  Uplink   packets/bytes: 691/57955
  Downlink packets/bytes: 0/0
ITA:
  Level-1 Uplink packets/bytes        : 4/392
          Downlink packets/bytes      : 4/392
          IPv6 uplink packets/bytes   : 0/0
          IPv6 downlink packets/bytes : 0/0
  Level-2 Uplink packets/bytes        : 0/0
          Downlink packets/bytes      : 0/0
# Display detailed information about PPP users on the UP.
<Sysname> display access-user user-plane auth-type ppp verbose
Basic:
  Interface: XGE3/1/1
  PPP index: 0x140000002
  User ID: 0x33f
  Interface: XGE3/1/1
  VXLAN ID: 10
  IP address: 192.168.0.3
  IPv6 address: -
  IPv6 PD prefix: -
  IPv6 ND prefix: -
  VPN instance: N/A
  Access type: PPPoE
PPPoE:
  Session ID: 1
AAA:
  Redirect WebURL: -
  MRU: 1480 bytes
  IPv4 MTU: 1480 bytes
  IPv6 MTU: 1480 bytes
  Subscriber ID: -
ACL&QoS:
  User group acl: N/A
  Inbound CAR: -
  Outbound CAR: -
Flow statistics:
  Uplink   packets/bytes: 28/4736
EDSG:
  Service ID                    : 1
  Service ID                    : 2
Table 17 Command output
Basic
Basic information of a user.
PPP index
PPP session index. This field is displayed only for PPPoE users and L2TP users.
VXLAN ID
VXLAN ID. If the user does not have a VXLAN ID, this field displays a hyphen (-).
MAC address
MAC address. If the user does not have a MAC address, this field displays a hyphen (-).
IP address
IPv4 address of the user. If the user does not have an IPv4 address, this field displays a hyphen (-).
IPv6 address
IPv6 PD prefix
IPv6 ND prefix
VPN instance
Access type
This field displays (UP escape) on the right of the access type if the user comes online during the UP fail-permit period.
UP backup state
Role of the user access interface (corresponding to the remote interface on the CP) in the UP backup group:
·     Master.
·     Backup.
Resource ID
Resource ID of a master/backup interface pair in the UP backup group.
IP gateway address
AAA
AAA information.
Redirect WebURL
·     Authorized redirect URL—For IPoE Web preauthentication, this field displays the URL of the IPv4 Web authentication page pushed to the user. In other cases, this field displays the URL of the redirect IPv4 or IPv6 Web page pushed to the user.
·     If the preceding URL does not exist, this field displays a hyphen (-).
This field applies only to the IPoE Web preauthentication domain, and indicates the IPv6 URL of the Web authentication page pushed to the user.
MRU
IPv4 MTU
IPv6 MTU
Subscriber ID
NAT instance
ACL&QoS
User group acl
Inbound CAR
Outbound CAR
NAT
NAT information.
Global IP address
Port block
Extended port block
PPPoE
PPPoE information.
Session ID
PPPoE session ID.
L2TP LAC
L2TP LNS
Local tunnel ID
Remote tunnel ID
Local session ID
Remote session ID
Local IP
Remote IP
Local port
Remote port
Vrf index
ITA
ITA information.
Level-n
EDSG
EDSG information.
Service ID
EDSG service ID.
display bras-interface access-user-count
Use display bras-interface access-user-count to display BRAS configuration and the number of users of an interface.
display bras-interface [ interface-type interface-number ] access-user-count
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays BRAS configuration and the number of users of all interfaces.
You can use this command to view configuration and user counts only on interfaces configured with IPoE or PPPoE.
#Display BRAS configuration and the number of users on Ten-GigabitEthernet 3/1/1.
<Sysname> display bras-interface ten-gigabitethernet 3/1/1 access-user-count
Interface              IPoE            PPPoE            Users
XGE3/1/1               L2-connected    Bind             100
Table 18 Command output
IPoE
Whether IPoE is enabled on the interface:
·     L2-connected—IPoE in Layer 2 access mode is enabled on the interface.
·     Routed—IPoE in Layer 3 access mode is enabled on the interface.
·     N/A—IPoE is not enabled on the interface.
PPPoE
Whether the interface has the PPPoE server protocol enabled and is bound to a VT interface:
·     Bind—The interface has the PPPoE server protocol enabled and is bound to a VT interface.
·     N/A—The PPPoE server protocol is not enabled on the interface.
Users
Number of current users on the interface.
display bras-interface configuration
Use display bras-interface configuration to display BRAS configuration and running information of an interface.
In standalone mode:
display bras-interface [ interface-type interface-number ] configuration [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display bras-interface [ interface-type interface-number ] configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays BRAS configuration and running information of all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
You can use this command to view BRAS configuration and running information only on interfaces configured with IPoE or PPPoE.
The command output and the sequence of information in the command output vary by device type, device configuration, networking mode, and device role on the network.
#Display configuration and running information of interface Route-Aggregation 1.
<Sysname> display bras-interface route-aggregation 1 configuration
Interface configuration:
  Interface name            : RAGG1
  MAC address               : 6eb9-84e6-0102
  Authentication type       : Bind
  BRAS mode                 : Normal
  UP status                 : None
  Blocking                  : No
  PPPoEA relay interface    : No
  Global interface          : Yes
  Interface deleting        : No
  Link layer status         : Down
  IPv4 network layer status : Down
  IPv6 network layer status : Down
  IPv4 MTU                  : 1500 bytes
  IPv6 MTU                  : 1500 bytes
IPoE configuration:
  IPoE access mode                            : L2-connected
  IPoE protocol type                          : Dual-stack
  IPv4 unclassified-IP trigger                : Enable
  IPv4 unclassified-IP matching-user          : Disable
  IPv6 unclassified-IP trigger                : Enable
  IPv6 unclassified-IP matching-user          : Disable
  IPoE MAC-auth                               : Enable
  IPoE inherit-PPPoE                          : Disable
  IPoE dot1x                                  : Enable
  IPoE dot1x dot1x-retrigger packet           : N/A
  IPoE dot1x dot1x-retrigger interval         : 60 seconds
  IPoE dhcp-release-ip dot1x-offline          : Disable
  IPoE dot1x-offline user-offline             : Disable
  IPoE static-dot1x-user                      : Disable
  Access-out                                  : Disable
  Service identify type                       : N/A
  Lease-end-time original                     : Disable
  Web basic-service-IPv4                      : Disable
  Web support-authorized-vpn                  : Disable
  Web or 802.1X support-unclassified-IP       : Disable
  IPoE basic-service-ip-type                  : Disable
  IPoE user name type                         : MAC-address
  IPoE user name MAC separator                : N/A
  IPoE user name MAC case                     : Uppercase
  IPoE password type                          : String
  IPoE pre-auth domain name                   : N/A
  IPoE web-auth domain name                   : N/A
  IPoE MAC-auth domain name                   : N/A
  DHCP user name type                         : Sysname
  DHCP user name separator                    : N/A
  DHCP domain name                            : N/A
  DHCP domain name force                      : No
  NDRS domain name                            : N/A
  Unclassified-IP domain name                 : dm1
  IPv4 user detect mode                       : ARP
  IPv4 user detect retry times                : 5
  IPv4 user detect interval                   : 120 seconds
  IPv4 user detect NoDataCheck                : Disable
  IPv6 user detect mode                       : ND
  IPv6 user detect retry times                : 5
  IPv6 user detect interval                   : 120 seconds
  IPv6 user detect NoDataCheck                : Disable
  IPoE pre-auth user track number             : N/A
  IPoE pre-auth user fail-permit user-group   : N/A
  IPoE pre-auth user track status             : N/A
  IPoE captive-bypass type                    : N/A
  IPoE web redhcp                             : Enable
  IPoE http-fast-relay                        : Disable
  IPoE roam                                   : Enable
  IPoE roam group name                        : roam
  QoS session-group identify                  : N/A
  IPoE unclassified-ip-defense                : Disable
  IPoE unclassified-ip-defense period         : 600
  IPoE unclassified-ip-defense threshold      : 6000
  IPoE unclassified-ip-defense interval       : 300
  HTTP-X-Header                               : Disable
Max session configuration:
  Interface max session number            : 1000
  NDRS max session number                 : N/A
  DHCPv4 max session number               : 500
  DHCPv6 max session number               : N/A
  IPv4 unclassified-IP max session number : N/A
  IPv6 unclassified-IP max session number : N/A
Access limit configuration:
  Access delay type                     : Even-mac and odd-mac
  Even-MAC user delay time              : 100 milliseconds
  Odd-MAC user delay time               : 100 milliseconds
  User-policy interface-down online     : No
  User-policy interface-down keepalive  : No
Nas-Port-ID configuration:
  NAS port type                          : 802.11
  IPoE circuit-id format                 : ASCII
  IPoE remote-id format                  : ASCII
  IPoE nas-port-id cn-telecom format     : Version3.0
  IPoE nas-port-id nasinfo-insert        : Yes
  PPPoE remote-id format                 : ASCII
  PPPoE circuit-id format                : ASCII
  PPPoE circuit-id mode                  : TR-101
  PPPoE nas-port-id insert BasInfo       : Disable
  PPPoE nas-port-id insert BasInfo type  : N/A
  PPPoE trust access-line-id             : No
  PPPoE access-line-id insert VxlanInfo  : Disable
  PPPoE access-line-id content           : Circuit-id
  PPPoE access-line-id separator         :
PPPoE configuration:
  PPPoE bind                    : Disable
  PPPoE agency bind             : Disable
# (On UPs.) Display configuration and running information on interface Ten-GigabitEthernet 3/1/1 on the UP.
<Sysname> display bras-interface ten-gigabitethernet 3/1/1 configuration
  Interface name            : XGE3/1/1
  MAC address               : 7c1e-0620-98cd
  BRAS mode                 : UP
  Global interface          : No
  Link layer status         : Up
  IPv4 network layer status : Up
  IPv6 network layer status : Up
UP backup configuration:
  Interface configure role      : Master
  Interface backup status       : Master
  Backup mode                   : Warm Load Balance
  Virtual MAC address           : 0000-5e00-01cb
    Backup relation ID          : 655563
    Blocking                    : NO
    Virtual MAC backup status   : Master
    Local UP IP address         : N/A
    Peer UP IP address          : N/A
  Virtual MAC address           : 0000-5e00-01ad
    Backup relation ID          : 655533
    Blocking                    : NO
    Local UP IP address         : 2.2.17.2
    Peer UP IP address          : 2.2.13.2
UP running configuration:
  ARP trigger                   : Enable
  NSNA trigger                  : Enable
  NDRS trigger                  : Enable
  MAC trigger                   : Disable
  PPPoE bind                    : Enable
  ARP proxy                     : Enable
  ND proxy                      : Enable
  IPoE MAC-auth                 : Disable
  IPoE http-fast-reply          : Disable
  IPv4 user detect NoDataCheck  : Enable
  IPv6 user detect NoDataCheck  : Enable
  PPPoE detect NoDataCheck      : Disable
Table 19 Command output
MAC address
MAC address of a local interface.
Authentication type
Authentication mode:
·     Bind—Bind authentication.
·     Web—Web authentication.
·     PPP— PPP authentication.
·     Admin— Device admin user authentication.
·     Dot1x—802.1X authentication.
BRAS mode
BRAS mode:
·     Normal—Normal mode (the device is not a UP).
·     UP—Forwarding mode (the device is a UP).
UP status
UP state:
·     None—The device is not a UP.
·     Main UP—The device is the master UP.
·     Hot-standby backup UP—The device is a backup UP in hot UP standby.
·     Warm-standby backup UP—The device is a backup UP in warm UP standby.
Blocking
Blocking state of the interface or virtual MAC address:
·     Yes—The interface or virtual MAC address is blocked, and does not allow new users to access.
·     No—The interface or virtual MAC address is in normal state, and allows new users to access.
Whether this interface an agency gateway access interface bound to an agency group:
·     Yes—This interface is bound to an agency group and is an agency gateway access interface.
·     No—This interface is not bound to an agency group and is not an agency gateway access interface.
Global interface
Whether the interface is a global interface.
·     Yes—The interface a global interface (for example, a Layer 3 aggregate interface).
·     No—The interface a physical interface.
Interface deleting
Interface deletion state:
·     Yes—The interface is being deleted.
·     No—The interface is in normal state.
Link layer status
Link layer state of the interface:
·     Up—The link layer state of the interface is up.
·     Down—The link layer state of the interface is down.
IPv4 network layer state of the interface:
·     Up—The network layer state of the interface is up.
·     Down—The network layer state of the interface is down.
IPv6 network layer state of the interface:
Temp block remaining time
When you use the cut access-user command to forcibly log out a user, this field displays the remaining time in seconds for temporarily blocking the interface. If interface blocking is not configured, this field displays a hyphen (-).
IPv4 MTU
MTU limit on IPv4 IPoE user packets, in bytes.
IPv6 MTU
MTU limit on IPv6 IPoE user packets, in bytes.
IPoE configuration
IPoE-related configuration.
IPoE access mode
IPoE access mode:
·     L2-connected—Layer 2 access mode.
·     Routed—Layer 3 access mode.
·     N/A—IPoE is not enabled.
IPoE protocol type
Protocol stack for which IPoE is enabled:
·     IPv4—IPoE is enabled for the IPv4 protocol stack.
·     IPv6—IPoE is enabled for the IPv6 protocol stack.
·     Dual-stack—IPoE is enabled for both the IPv4 protocol stack and the IPv6 protocol stack.
Unclassified-IPv4 packet initiation state:
·     Enable.
·     Disable.
Unclassified-IPv4 packets allow only the specified types of users to come online:
·     Enable—Unclassified-IPv4 packets allow only the matching static users, abnormally logged out DHCP users, roaming users, and users in loose mode to come online.
·     Disable—Unclassified-IPv4 packets allow dynamic users in addition to the matching static users, abnormally logged out DHCP users, roaming users, and users in loose mode to come online.
Unclassified-IPv6 packet initiation state:
·     Enable.
·     Disable.
Unclassified-IPv6 packets allow only the specified types of users to come online:
·     Enable—Unclassified-IPv6 packets allow only the matching static users, abnormally logged out DHCP users, and roaming users to come online.
·     Disable—Unclassified-IPv6 packets allow dynamic users in addition to the matching static users, abnormally logged out DHCP users, and roaming users to come online.
IPoE MAC-auth
IPoE Web MAC authentication state:
·     Enable.
·     Disable.
IPoE inherit-PPPoE
State of inherit-PPPoE for IPoE.
·     Enable.
·     Disable.
IPoE dot1x
State of 802.1X authentication for IPoE.
·     Enable.
·     Disable.
IPoE dot1x high-priority
State of 802.1X authentication prioritization for IPoE. This information is not displayed if the IPoE 802.1X authentication feature is not enabled.
·     Enable.
·     Disable.
IPoE dot1x high-priority strict
State of 802.1X authentication prioritization in strict mode. This information is not displayed if the IPoE 802.1X authentication feature is not enabled.
·     Enable.
·     Disable.
Types of packets that the BRAS can use to retrigger 802.1X authentication when an IPoE user fails to come online through 802.1X authentication. If multiple packet types are specified, they are separated by spaces. Options include:
·     ARP—Represents ARP packets.
·     ND—Represents ND packets.
·     DHCPv4—Represents DHCPv4 packets.
·     DHCPv6—Represents DHCPv6 packets.
N/A—Represents no packets are configured.
Suppression interval for retriggering 802.1X authentication based on ARP and ND packets, in seconds.
State of logging out the 802.1X client of an IPoE user when the IP address of the IPoE user is released.
·     Enable.
·     Disable.
State of logging out an IPoE user when the 802.1X client of the IPoE user goes offline.
·     Enable.
·     Disable.
State of static 802.1X user authentication.
·     Enable.
·     Disable.
Access-out
IPoE access-out authentication state:
·     Enable.
·     Disable.
Service identification type of an access user.
·     8021p second-vlan—Identifies a service by the 802.1p priority value in the inner VLAN tag of a packet in QinQ mode.
·     8021p vlan—Identifies a service by the 802.1p priority value in the VLAN tag of a packet (the 802.1p priority value in the outer VLAN tag of a packet in QinQ mode).
·     DSCP—Identifies a service by the DSCP value in a packet.
·     Second-vlan—Identifies a service by the inner VLAN ID of a packet in QinQ mode.
·     Vlan—Identifies a service by the VLAN ID of a packet (the outer VLAN ID of a packet in QinQ mode).
State of using the lease expiration time when an IPoE user went offline as the lease expiration time when the IPoE comes online again.
·     Enable.
·     Disable.
State of IPv6 protocol stack dependency of IPoE Web users on IPv4 protocol stack:
·     Enable.
·     Disable.
State of the VPN authorization feature in the Web postauthentication domain:
·     Enable.
·     Disable.
State of support of unclassified-IP users for Web authentication or 802.1X authentication:
·     Enable.
·     Disable.
Protocol stack on which the main service of IPoE users depends:
·     IPv4—The main service of IPoE users depends on the IPv4 protocol stack.
·     IPv6—The main service of IPoE users depends on the IPv6 protocol stack.
·     Disable—The protocol stack on which the main service of IPoE users depends is not set.
IPoE user name type
Authentication username type of an individual IPoE user:
·     MAC-address—Uses the MAC address as the username.
·     String—Uses the specified string as the username.
·     N/A—No authentication username is configured for an individual IPoE user.
IPoE user name string
String specified as the authentication username of an IPoE user.
MAC address separator when IPoE uses MAC addresses as authentication usernames.
Case of MAC addresses when IPoE uses MAC addresses as authentication usernames.
·     Lowercase—Letters in MAC addresses are lower case.
·     Uppercase—Letters in MAC addresses are upper case.
IPoE password type
Authentication password type of an individual IPoE user:
·     String—Uses the specified string as the password.
·     MAC-address—Uses the MAC address as the password.
·     N/A—No authentication password is configured for IPoE.
IPoE password address-separator
MAC address separator when IPoE uses MAC addresses as passwords.
IPoE password MAC case
Case of MAC addresses when IPoE uses MAC addresses as passwords:
Preauthentication domain name for IPoE Web authentication.
Authentication domain name for IPoE Web authentication.
Authentication domain name for MAC authentication users.
DHCP user name type
Authentication username type of DHCP users:
·     Sysname—Uses the access device name as the username.
·     Source-IP—Uses the source IP address in packets as the username.
·     Source-MAC—Uses the source MAC address in packets as the username.
·     Client-id—Uses the DHCPv4 Option61 or DHCPv6 Option1 in DHCP packets as the username.
·     Vendor-class—Uses the DHCPv4 Option60 or DHCPv6 Option16 in DHCP packets as the username.
·     Circuit-id—Uses the DHCPv4 Option82 sub-option1 or DHCPv6 Option18 in DHCP packets as the username.
·     Remote-id—Uses the DHCPv4 Option82 sub-option2 or DHCPv6 Option37 in DHCP packets as the username.
·     Vendor-specific—Uses the DHCPv4 Option82 sub-option9 or DHCPv6 Option17 in DHCP packets as the username.
·     Nas-port-id—Uses the NAS-PORT-ID attribute in the authentication packets as the username.
·     Vlan—Uses the outer VLAN in the authentication packets as the username.
·     Second-vlan—Uses the inner VLAN in the authentication packets as the username.
·     Slot—Uses the slot number of a user as the username.
·     Subslot—Uses the subslot of a user as the username.
·     Port—Uses the access port number of a user as the username.
·     Circuit-id MAC—Uses the MAC address in the Circuit-ID (Option82 sub-option1) as the username.
·     Hostname—Uses the DHCPv4 Option12 in DHCP packets as the username.
·     N/A—No authentication username is configured for a DHCP user.
Separator used for the field used as the authentication username of a DHCP user.
DHCP user name address-separator
MAC address separator when MAC addresses are used as authentication usernames of DHCP users.
DHCP user name keep original
Directly use the information in the DHCPv4 Option12, DHCPv4 Option60, or DHCPv6 Option16 field in DHCP packets as the username and transmit it to the authentication server for authentication:
·     Yes—The device directly transmits information above to the authentication server for authentication.
·     No—The device converts non-printable characters into printable characters and then transmits the information to the authentication server for authentication.
DHCP user name absent replace
Processing when the DHCPv4 Option60 or DHCPv6 Option16 field does not exist in DHCP packets:
·     Yes—Replaces an inexistent option with the domain name of the user authentication domain as the username when condition above exists.
·     No—Leaves the option part in the username empty when the condition above exists.
DHCP user name string
String specified as the authentication username of a DHCP user.
DHCPv4 password type
An individual DHCPv4 user uses the specified information in the DHCPv4 packets as the authentication password:
·     Circuit-id—Uses the DHCPv4 Option82 sub-option1 field in DHCP packets as the authentication password.
·     Option60—Uses the Option60 field in DHCPv4 packets as the authentication password.
·     User-class—Uses the Option77 field in DHCPv4 packets as the authentication password.
·     N/A—No field in the DHCPv4 packets is specified as the authentication password.
DHCPv4 password length
Password length when a DHCPv4 user uses the specified information in the DHCPv4 packets as the authentication password. N/A indicates that the password length is not configured.
DHCPv4 password offset length
Offset length when a DHCPv4 user uses the specified information in the DHCPv4 packets as the authentication password. N/A indicates that the offset length is not configured.
Original mode of DHCPv4 password option 60
Whether to directly use the information selected from Option60 according to the specified rule as the authentication password without performing validity check:
·     Yes.
·     No.
DHCPv6 password type
An individual DHCPv6 user uses the specified information in the DHCPv6 packets as the authentication password:
·     Option16—Uses the Option16 or Option17 field in DHCPv6 packets as the authentication password.
·     N/A—No field in the DHCPv6 packets is specified as the authentication password.
Original mode of DHCPv6 password option 16 or option 17
Whether to directly use the information selected from Option16 or Option17 according to the specified rule as the authentication password without performing validity check:
·     Yes.
·     No.
DHCPv6 password length
Password length when a DHCPv6 user uses the specified information in the DHCPv6 packets as the authentication password. N/A indicates that the password length is not configured.
DHCPv6 password offset length
Offset length when a DHCPv6 user uses the specified information in the DHCPv6 packets as the authentication password. N/A indicates that the offset length is not configured.
DHCP domain name
Authentication domain name for DHCP users.
Whether the authentication domain name configured for DHCP users is forced:
·     Yes—The authentication domain name configured for DHCP users is forced.
·     No—The authentication domain name configured for DHCP users is not forced.
DHCP domain type
Sub-option type when a DHCP user uses the vendor class as the authentication domain name:
·     Vlan—Uses the outer VLAN in authentication packets as the  authentication domain name.
DHCP domain separator
Separator when a DHCP user uses the vendor class as the authentication domain name.
DHCP domain string
String specified as the authentication domain name of a DHCP user.
NDRS user name type
Authentication username type of NDRS users:
·     Nas-port-id—Uses the NAS-Port-ID attribute in the authentication packets as the username.
·     Subslot—Uses the subslot number of a user as the username.
·     N/A—No authentication username is configured for NDRS users.
NDRS user name separator
Separator for the field used as the authentication username of an NDRS user.
NDRS user name address-separator
MAC address separator when MAC addresses are used as authentication usernames of NDRS users.
NDRS user name string
String specified as the authentication username of an NDRS user.
NDRS domain name
Authentication domain name for NDRS users.
Unclassified-IP user name type
Authentication username type of unclassified-IP access users:
·     N/A—No authentication username is configured for unclassified-IP users.
Unclassified-IP user name separator
Separator for the field used as the authentication username of an unclassified-IP user.
Unclassified-IP user name address-separator
MAC address separator when MAC addresses are used as authentication usernames of unclassified-IP users.
Unclassified-IP user name string
String specified as the authentication username of an unclassified-IP access user.
Authentication domain name for an unclassified-IP user.
Online detection type for IPv4 access users:
·     ARP—Uses ARP packets as the detection packets.
·     ICMP—Uses ICMP packets as the detection packets.
·     N/A—Online detection is not enabled for the IPv4 protocol stack.
Maximum number of online detection retries for the IPv4 access users.
Online detection interval for IPv4 access users in seconds.
Ignore data traffic update in online detection for IPv4 access users:
·     Enable—Detection packets are sent after the detection timer expires no matter whether user uplink traffic is updated within a detection timer.
·     Disable—No detection packets are sent within one detection timer period after the detection timer expires if user uplink traffic is updated within a detection timer period.
Online detection type for IPv6 access users:
·     ND—Uses ND packets as the detection packets.
·     ICMP—Uses ICMPv6 packets as the detection packets.
·     N/A—Online detection is not enabled for the IPv6 protocol stack.
Maximum number of online detection retries for the IPv6 access users.
Online detection interval for IPv6 access users in seconds.
Ignore data traffic update in online detection for IPv6 access users:
ID of the track entry associated with a fail-permit user group.
Fail-permit user group.
Current state of the track entry associated with the fail-permit user group:
·     NotReady—The monitored object is not ready.
·     Positive—The monitored object is operating normally.
·     Negative—The monitored object is operating abnormally.
·     N/A—No track entry is associated with the fail-permit user group.
IPoE captive-bypass feature type:
·     Android—Specifies Android users.
·     IOS—Specifies IOS users.
·     Android and IOS—Specifies Android and IOS users.
·     N/A—The IPoE captive-bypass feature is not configured.
IPoE web redhcp
Re-DHCP for IPoE Web authentication:
·     Enable—Re-DHCP for IPoE Web authentication is enabled.
·     Disable—Re-DHCP for IPoE Web authentication is disabled.
HTTP packet fast reply state:
·     Enable—HTTP packet fast reply is enabled.
·     Disable—HTTP packet fast reply is disabled.
IPoE roam
IPoE individual user roaming state:
·     Enable—IPoE individual user roaming is enabled.
·     Disable—IPoE individual user roaming is disabled.
Roaming group to which the interface belongs.
Session group recognition method:
·     Customer-vlan—Recognizes a session group by inner VLAN (private network VLAN of the user).
·     Service-vlan—Recognizes a session group by outer VLAN (public network VLAN that the service provider allocates to the user).
·     Customer-service-vlan—Recognizes a session group by inner VLAN and outer VLAN.
·     Subscriber-id—Recognizes a session group by subscriber ID. For more information about subscriber IDs, see BRAS Services Command Reference.
·     N/A—No session group recognition method is configured.
Enabling status of attack prevention against packets with unknown source IP address:
·     Enable
·     Disable
Blocking duration for attack prevention against packets with unknown source IP packets, in seconds.
Blocking threshold for attack prevention against packets with unknown source IP packets.
Statistics collection period for attack prevention against packets with unknown source IP packets, in seconds.
HTTP-X-Header
Enabling status of HTTP enhanced header authentication:
·     Enable.
·     Disable.
X-Header name
Name of the field in the HTTP-X header that require decoding by the BRAS device. If HTTP enhanced header authentication is disabled, this field is not displayed.
Configuration related to the maximum numbers of sessions.
Maximum number of individual IPoE sessions and leased subuser sessions that can be created on an interface.
Maximum number of IPoE sessions that can be triggered by RS packets on an interface.
Maximum number of IPoE sessions that can be triggered by DHCPv4 packets on an interface.
Maximum number of IPoE sessions that can be triggered by DHCPv6 packets on an interface.
Maximum number of IPoE dynamic sessions that can be triggered by unclassified-IPv4 packets on an interface.
Maximum number of IPoE dynamic sessions that can be triggered by unclassified-IPv6 packets on an interface.
Access limit configuration.
Access delay type
Response delay time for IPoE users on an interface:
·     Even-MAC—Specifies the response delay time for IPoE users with even MAC addresses.
·     Odd-MAC—Specifies the response delay time for IPoE users with odd MAC addresses.
·     Even-MAC and odd-MAC—Specifies the response delay time for all users on the interface.
·     N/A—The response delay time for IPoE users is not configuration on the interface.
Response delay time for IPoE users with even MAC addresses in milliseconds.
Response delay time for IPoE users with odd MAC addresses in milliseconds.
Keep BRAS users online when an interface goes down:
·     Yes—Keep BRAS users online when an interface goes down.
·     No—Log out BRAS users when an interface goes down.
Online detection state if users are kept online when the interface goes down. (This function takes effect only when the function of keeping users online when the interface goes down is configured.)
·     Yes—Online detection does not take effect  if users are kept online when the interface goes down.
·     No—Online detection still takes effect if users are kept online when the interface goes down.
IPoE chasten configuration
IPoE blocking configuration.
IPoE chasten quiet time
IPoE user blocking period in seconds. The value of 0 indicates that blocking is not enabled.
IPoE chasten period time
Detection period of consecutive IPoE user authentication failures, in seconds.
IPoE chasten check times
Maximum number of consecutive IPoE user authentication failures allowed within a detection period.
NAS-Port-ID configuration.
NAS port type
NAS-Port-Type attribute type of an interface, which is Ethernet by default:
·     802.11—Interface type compliant with the Wireless-IEEE 802.11 standard. The corresponding code is 19.
·     Adsl-cap—Asymmetric DSL, Carrierless Amplitude Phase Modulation (ADSL-CAP) interface type. The corresponding code is 12.
·     Adsl-dmt—Asymmetric DSL, Discrete Multi-Tone (ADSL-DMT) interface type. The corresponding code is 13.
·     Async—Async interface type. The corresponding code is 0.
·     Cable—Cable interface type. The corresponding code is 17.
·     Ethernet—Ethernet interface type. The corresponding code is 15.
·     G.3-fax—G.3 fax interface type. The corresponding code is 10.
·     HDLC—HDLC interface type. The corresponding code is 7.
·     IDSL—ISDN Digital Subscriber Line (IDSL) interface type. The corresponding code is 14.
·     ISDN-async-v110—ISDN-async-v110 interface type. The corresponding code is 4.
·     ISDN-async-v120—ISDN-async-v120 interface type. The corresponding code is 3.
·     ISDN-sync—ISDN sync interface type. The corresponding code is 2.
·     Piafs—Interface type compliant with the Personal Handyphone System (PHS) Internet Access Forum Standard (PIAFS) standard. The corresponding code is 6.
·     SDSL—Symmetric DSL (SDSL) interface type. The corresponding code is 11.
·     Sync—Sync interface type. The corresponding code is 1.
·     Virtual—Virtual interface type. The corresponding code is 5.
·     Wireless-other— Wireless-other interface type. The corresponding code is 18.
·     X.25—X.25 interface type. The corresponding code is 8.
·     X.75—X.75 interface type. The corresponding code is 9.
·     XDSL—Digital Subscriber Line of unknown type (XDSL) interface type. The corresponding code is 16.
Parsing format for the circuit-id in DHCP Option by IPoE. The default is ascii.
·     ASCII—Parses in string format.
·     Hex—Parses in hexadecimal format.
Parsing format for the remote-id in DHCP Option by IPoE. The default is ascii.
IPoE nas-port-id bind interface type
Interface type when IPoE uses the specified interface information to fill in the NAS-Port-ID attribute of RADIUS.
IPoE nas-port-id bind interface number
Interface number when IPoE uses the specified interface information to fill in the NAS-Port-ID attribute of RADIUS.
Encapsulation format of the NAS-Port-ID attribute that the access device sends to the RADIUS server when IPoE users perform authentication. The default is version 1.0.
·     Version1.0—Specifies the version 1.0 format. The NAS-Port-ID attribute sent to the RADIUS server is filled in the China-Telecom 163 format.
·     Version2.0—Specifies the version 2.0 format. The NAS-Port-ID attribute sent to the RADIUS server is filled according to the YDT 2275-2011 subscriber access loop (port) identification requirements.
·     Version3.0—Specifies the version 3.0 format.
·     Version4.0—Specifies the version 4.0 format.
·     Version5.0—Specifies the version 5.0 format.
The device extracts the content in Option 82 Circuit-ID from DHCPv4 packets or Option18 from DHCPv6 packets, and uses it together with the NAS information as the NAS-Port-ID attribute string.
·     Yes—This feature is enabled on the interface
·     No—This feature is disabled on the interface.
Transmission format of the remote-id in the PPPoE access line ID. The default is string.
·     ASCII—String format, which transmits the remote-id information in the form of characters.
·     Hex—Hexadecimal format, which transmits the remote-id information in the form of hexadecimal digits.
Transmission format of the circuit-id in the PPPoE access line ID. The default is string.
·     ASCII—String format, which transmits the circuit-id information in the form of characters.
·     Hex—Hexadecimal format, which transmits the circuit-id information in the form of hexadecimal digits.
Parsing format of the circuit-id in the PPPoE access line ID. The default is TR-101.
·     CN-telecom—China Telecom format.
·     TR-101—TR-101 format.
PPPoE nas-port-id interface type
Interface type when PPPoE uses the specified interface information to fill in the NAS-Port-ID attribute of RADIUS.
PPPoE nas-port-id interface number
Interface number when PPPoE uses the specified interface information to fill in the NAS-Port-ID attribute of RADIUS.
Function of automatically inserting BAS information into the NAS-Port-ID attribute by PPPoE:
·     Enable—The function of automatically inserting BAS information into the NAS-Port-ID attribute by PPPoE is enabled.
·     Disable—The function of automatically inserting BAS information into the NAS-Port-ID attribute by PPPoE is disabled.
Format for the BAS information automatically inserted into the NAS-Port-ID attribute by PPPoE:
·     CN-163—Inserts BAS information in the China Telecom 163 format.
·     CN-163.redback—Inserts BAS information in the China Telecom 163 redback format.
·     bas-info-redback—Inserts BAS information in the China Telecom redback format. This mode swaps the inner and outer VLAN positions compared to the China Telecom format.
·     N/A—Does not automatically insert BAS information.
Whether PPPoE trusts the contents in the access line ID in the received packets.
·     Yes—Sets the trust mode.
·     No—Does not set the trust mode.
Function of inserting VXLAN information into the NAS-Port-ID attribute by PPPoE:
·     Enable—The function of inserting VXLAN information into the NAS-Port-ID attribute by PPPoE is enabled.
·     Disable—The function of inserting VXLAN information into the NAS-Port-ID attribute by PPPoE is disabled.
Type of the content in the NAS-Port-ID attribute sent to the RADIUS server by PPPoE. By default is, only the circuit-ID is included.
·     All—Uploads both the circuit-id and remote-id.
·     Circuit-id—Uploads only the Circuit-id.
·     Remote-id—Uploads only the Remote-id.
Separator for the content in the NAS-Port-ID attribute sent to the RADIUS server by PPPoE. The length is one character. The default is a space.
VSRP configuration
VSRP configuration
VSRP instance name
VSRP instance name.
UP backup profile ID
UP backup profile ID.
Configured interface role:
·     Master—The interface is the master interface in the UP backup profile.
·     Backup—The interface is the backup interface in the UP backup profile.
·     N/A—The interface is not an interface in the UP backup profile.
Interface backup state:
·     Master—The interface is the master interface.
·     Backup—The interface is the backup interface.
·     Unbind—The master/backup relationship of the interface is removed.
·     Failed—The interface is in failed state.
·     N/A—The interface is not a UP backup interface.
Backup mode
Backup mode:
·     Hot—Hot backup.
·     Warm—Warm backup.
·     Load Balance—Load balancing backup.
·     Warm Load Balance—Warm load balancing backup.
·     N/A—UP backup is not set.
Interface backup mode
Interface backup mode of the UP backup profile to which the interface belongs:
·     Inherit-main—Inherits the main interface state.
·     No-inherit—Does not inherit the main interface state.
Virtual MAC address
Virtual MAC address of the interface.
Backup relation ID
Backup relationship ID.
Configured master UP ID
Configured master UP ID corresponding to the virtual MAC address.
Backup status of the virtual MAC address:
·     Master—Indicates the virtual MAC address is in running master state.
·     Backup—Indicates the virtual MAC address is in running backup state.
·     Failed—Indicates the virtual MAC address is in interface failed state.
·     N/A—Indicates the virtual MAC address is in invalid value state.
Configured main interface
Configured master interface. N/A indicate that no master interface is configured.
Configured backup interface
Configured backup interface. N/A indicate that no backup interface is configured.
Master UP ID
ID of the UP to which the configured master interface belongs.
Local UP IP address
Local IP address on the UP backup network.
Peer UP IP address
Remote IP address on the UP backup network.
UP running configuration.
ARP trigger
ARP packet initiation state:
·     Enable.
·     Disable.
NSNA trigger
IPv6 NS/NA packet initiation state:
·     Enable.
·     Disable.
NDRS trigger
IPv6 NDRS packet initiation state:
·     Enable.
·     Disable.
MAC trigger
MAC trigger authentication state:
·     Enable.
·     Disable.
PPPoE bind
PPPoE server protocol state on the interface:
·     Enable—The interface has the PPPoE server protocol enabled and is bound to a VT interface.
·     Disable—The PPPoE server protocol is not enabled on the interface.
ARP proxy
ARP proxy state on the interface:
·     Enable.
·     Disable.
ND proxy
ND proxy state on the interface:
·     Enable.
·     Disable.
UP ID
UP ID.
Interface online
Online state of the interface:
·     Yes—The interface is in online state.
·     No—The interface is in offline state.
IPoE protocol type
IPoE access protocol stack. This feature takes effect only when IPoE is enabled.
PPPoE detect retry times
Maximum number of PPPoE user keepalive detection retries.
PPPoE detect interval
PPPoE user keepalive detection interval, in seconds.
Ignore data traffic update in keepalive detection for PPPoE users:
PPPoE configuration
PPPoE related configuration.
PPPoE agency bind
State of PPPoE agency on an interface.
·     Enable—The interface has the PPPoE agency protocol enabled and is bound to a VT interface.
·     Disable—The PPPoE agency protocol is not enabled on the interface.
display bras-interface users-by-vlan
Use display bras-interface users-by-vlan to display the number of BRAS users by VLAN on an interface.
display bras-interface interface-type interface-number users-by-vlan [ s-vlan s-vlan-id [ c-vlan c-vlan-id ] ]
s-vlan svlan-id: Specifies a SVLAN by its ID. The value range for the svlan-id argument is 1 to 4094.  If you do not specify this option, the command displays the number of BRAS users for each SVLAN and CVLAN combination on an interface.
c-vlan cvlan-id: Specifies a CVLAN by its ID. The value range for the cvlan-id argument is 1 to 4094.  If you specify the s-vlan keyword but do not specify the c-vlan keyword, this command displays the number of BRAS users for the combination of the fixed SVLAN and each CVLAN on an interface.
#Display the number of BRAS users by VLAN on Ten-GigabitEthernet 3/1/1.1.
<Sysname> display bras-interface ten-gigabitethernet 3/1/1.1 users-by-vlan
Slot 1:
Interface                  S-VLAN/C-VLAN            Users
XGE3/1/1.1                 100/200                  200
XGE3/1/1.1                 100/201                  160
XGE3/1/1.1                 111/105                  100
Total users : 460
  Single VLAN-tagged users : 0
  QinQ VLAN-tagged users   : 460
Table 20 Command output
User access interface name.
S-VLAN
SVLAN. This field displays a hyphen (-) if no SVLAN exists.
C-VLAN
CVLAN. This field displays a hyphen (-) if no CVLAN exists.
Users
Total number of users.
Total users
Total number of users in all VLANs on the interface.
Total number of users with a single layer of VLAN tags on the interface.
Total number of users with two layers of VLAN tags on the interface.
display max-user history
Use display max-user history to display history information about the peak user counts.
In standalone mode:
display max-user history [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display max-user history [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
This command displays the following peak user counts and the time when each peak user count was reached:
·     Maximum number of users initiating authentication concurrently.
·     Maximum number of users passing authentication concurrently.
·     Maximum number of sessions set to the driver concurrently.
·     Maximum number of users being accounted concurrently.
When the access module is busy processing services, the history information might not be displayed. In this case, wait for several minutes and then try again.
In the current software version, the history information about the peak user counts can be displayed for PPPoE, L2TP, and IPoE users.
Users authenticated on logical interfaces such as aggregate interfaces are processed in the same way as users authenticated on physical interfaces. The history information of the peak online user counts issued to the driver is displayed only on the slot of the physical interface where users actually come online.
When an online user roams or experiences a master/backup UP switchover, the system records information of the user on the most recent slot or UP where the user is online.
Users who went online before the reset max-user history command was executed will no longer be counted in the peak user count in the display max-user history command output after the reset max-user history command is executed.
# (In standalone mode.) Display history information about the peak user counts.
<Sysname> display max-user history slot 3
Slot 3:
PPPoE:
Max concurrent users initiating authentication: 2      Time: 2019-01-08 19:48:23
Max concurrent users passing authentication: 2         Time: 2019-01-08 19:48:23
Max concurrent sessions set to driver: 2               Time: 2019-01-08 19:48:23
Max concurrent users in accounting: 2                  Time: 2019-01-08 19:48:23
L2TP:
Max concurrent users initiating authentication: 5      Time: 2019-01-08 19:48:23
Max concurrent users passing authentication: 5         Time: 2019-01-08 19:48:23
Max concurrent sessions set to driver: 5               Time: 2019-01-08 19:48:23
Max concurrent users in accounting: 5                  Time: 2019-01-08 19:48:23
IPoE:
Max concurrent users initiating authentication: 6      Time: 2019-01-08 19:48:23
Max concurrent users passing authentication: 6         Time: 2019-01-08 19:48:23
Max concurrent sessions set to driver: 6               Time: 2019-01-08 19:48:23
Max concurrent users in accounting: 6                  Time: 2019-01-08 19:48:23
Table 21 Command output
Maximum number of users initiating authentication concurrently after the system starts up.
This field is not displayed if the user count is 0.
Maximum number of online users passing authentication concurrently after the system starts up.
Maximum number of online sessions set to the driver concurrently after the system starts up.
Maximum number of online users being accounted concurrently after the system starts up.
Time
Time when the peak user count was reached.
display trace access-user
Use display trace access-user to display service tracing object configuration information.
display trace access-user [ object object-id ]
object object-id: Specifies a service tracing object by its ID, in the range of 1 to 5. If you do not specify a tracing object, this command displays configuration information for all service tracing objects.
This command displays configuration information for only service tracing objects whose tracing time has not expired.
#Display configuration information for all service tracing objects.
<Sysname> display trace access-user
Object ID: 1
Access mode: IPoE
User name: aaa
Access interface: Ten-GigabitEthernet3/1/1.1
IP address: 1.1.1.2
MAC address: 0001-0002-0003
Service VLAN: 3
Customer VLAN: 2
Output direction: VTY
Aging time: 0 min
Object ID: 2
Access mode: LNS
User name: aaa
Access interface: Ten-GigabitEthernet3/1/1.2
IP address: 1.1.1.3
Service VLAN: 3
Customer VLAN: 2
Tunnel ID: 12345
Calling station ID: 7425-8a23-23d5 XGE3/1/1.2:0003.0002
Aging time: 0 min
Table 22 Command output
Object ID
ID of the service tracing object.
Access mode
Access mode of the service tracing object:
IPoE.
PPPoE.
LNS.
User name
Username of the access user.
Access interface
Access interface of the access user.
IP address
IP address of the access user.
MAC address
MAC address of the access user.
Service VLAN
Outer VLAN ID of the access user.
Customer VLAN
Inner VLAN ID of the access user.
Tunnel ID
L2TP tunnel ID of the access user. This field is displayed only for L2TP users.
Calling station ID
L2TP calling number. If a user comes online without carrying a calling station, this field displays a hyphen (-).
Output direction
Location to which the service tracing object information is output.
Aging time
Tracing time of the service tracing object.
trace access-user
flow-statistics frequency
Use flow-statistics frequency to set the traffic accounting frequency mode for online users.
Use undo flow-statistics frequency to restore the default.
flow-statistics frequency { fast | normal | slow }
The traffic accounting frequency mode for online users is normal.
fast: Specifies the fast mode. For high accuracy of the BRAS user traffic statistics, specify this keyword.
normal: Specifies the normal mode. For medium accuracy of the BRAS user traffic statistics, specify this keyword.
slow: Specifies the slow mode. For low accuracy of the BRAS user traffic statistics, specify this keyword.
# Set the traffic accounting frequency mode for online users to fast.
[Sysname] flow-statistics frequency fast
nas-port-type
Use nas-port-type to configure the NAS-Port-Type for an interface.
Use undo nas-port-type to restore the default.
nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
undo nas-port-type
The NAS-Port-Type for an interface is Ethernet.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
L3VE interface/subinterface view
802.11: Specifies the port type complying with Wireless-IEEE 802.11. The type ID is 19.
adsl-cap: Specifies the ADSL-CAP port type, including Asymmetric DSL and Carrierless Amplitude Phase Modulation. The type ID is 12.
adsl-dmt: Specifies the ADSL-DMT port type, including Asymmetric DSL and Discrete Multi-Tone. The type ID is 13.
async: Specifies the Async port type with a type ID of 0.
cable: Specifies the Cable port type with a type ID of 17.
ethernet: Specifies the Ethernet port type with a type ID of 15.
g.3-fax: Specifies the G.3 Fax port type with a type ID of 10.
hdlc: Specifies the HDLC port type with a type ID of 7.
idsl: Specifies the IDSL port type with a type ID of 14.
isdn-async-v110: Specifies the ISDN Async V.110 port type with a type ID of 4.
isdn-async-v120: Specifies the ISDN Async V.120 port type with a type ID of 3.
isdn-sync: Specifies the ISDN Sync port type with a type ID of 2.
piafs: Specifies the port type complying with PIAFS. The type ID is 6.
sdsl: Specifies the SDSL port type with a type ID of 11.
sync: Specifies the Sync port type with a type ID of 1.
virtual: Specifies the Virtual port type with a type ID of 5.
wireless-other: Specifies the Wireless-other port type with a type ID of 18.
x.25: Specifies the X.25 port type with a type ID of 8.
x.75: Specifies the X.75 port type with a type ID of 9.
xdsl: Specifies the XDSL port type with a type ID of 16.
Operating mechanism
The nas-port-type attribute is used for RADIUS authentication and accounting. For more information about the nas-port-type attribute, see RFC 2865.
This command does not affect existing users.
If you execute this command multiple times on the same interface, the most recent configuration takes effect.
If you do not execute the bras compatible old-style-commands enable command to enable BRAS device compatibility with old-style commands, this command has no configuration restrictions.
After you execute this command, it does not affect enabling or disabling BRAS device compatibility with old-style commands unless you specify the cable keyword.
After you execute the nas-port-type cable command, you cannot enable BRAS device compatibility with old-style commands.
After you execute the bras compatible old-style-commands enable command to enable BRAS device compatibility with old-style commands, follow these restrictions:
·     You can use only the old-style ip subscriber nas-port-type cable command to set the Cable port type for an interface. To use the new-style nas-port-type cable command to set the Cable port type for an interface, first execute the undo bras compatible old-style-commands enable command to disable BRAS device compatibility with old-style commands, and then execute the nas-port-type cable command.
·     To set a port type other than the Cable port type, you can use the new-style nas-port-type command. If you execute the nas-port-type (except with the cable keyword) and ip subscriber nas-port-type cable commands multiple times, the most recent configuration takes effect.
#Configure the NAS-Port-Type as sdsl for Ten-GigabitEthernet 3/1/1.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] nas-port-type sdsl
ip subscriber nas-port-type cable (old style) (BRAS Services Command Reference)
reset access-user offline-reason statistics
Use reset access-user offline-reason statistics to clear offline reason statistics of access users.
# Clear statistics for the offline reasons.
<Sysname> reset access-user offline-reason statistics
display access-user offline-reason statistics
reset access-user user-detect packet-loss-ratio
Use reset access-user user-detect packet-loss-ratio to clear the packet loss ratio statistics for the access user detection packets.
In standalone mode:
reset  access-user user-detect packet-loss-ratio [ interface interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset  access-user user-detect packet-loss-ratio [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears entries of all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
On a unified network, this command clears only the packet loss ratio statistics for IPoE user detection packets. To clear the packet loss ratio statistics for PPPoE and L2TP user detection packets on a unified network, use the reset ppp keepalive packet-loss-ratio command.
On a CUPS network, this command clears only the packet loss ratio statistics for IPoE, PPPoE, and L2TP user detection packets. L2TP users do not have interface information on UPs. To clear the packet loss ratio statistics for L2TP users, specify the slot parameter or do not specify any parameter.
On a CUPS network, detection packets are sent and received on UPs. Therefore, this command can be executed only when it is executed on UPs.
After you execute the reset access-user user-detect packet-loss-ratio command to clear the packet loss ratio statistics for detection packets, the device will re-calculate the packet loss ratio and the continuous intervals. When the packet loss ratio meets the alarm conditions continuously for three intervals, an alarm will be output. For more information, see the access-user user-detect packet-loss-ratio-threshold command.
After you execute the reset system internal ucm statistics command to clear the detection packet statistics, the device will also clear the packet loss ratio statistics and re-calculate the packet loss ratio and continuous intervals. When the alarm conditions are met, an alarm will be output.
# Clear the packet loss ratio statistics for access user detection packets on all interfaces.
<Sysname> reset access-user user-detect packet-loss-ratio
display access-user user-detect packet-loss-ratio
reset ppp keepalive packet-loss-ratio (BRAS Services Command Reference)
Use reset max-user history to clear history information about the peak user counts.
In standalone mode:
reset max-user history [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset max-user history [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a slot, this command clears entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
This command clears the following peak user counts and the time when each peak user count was reached:
# (In standalone mode.) Clear history information about the peak user counts for slot 1.
<Sysname> reset max-user history slot 1
slot-user-warning-threshold
Use slot-user-warning-threshold to configure the per-slot user count alarm threshold.
Use undo slot-user-warning-threshold to restore the default.
slot-user-warning-threshold threshold-value
The per-slot user count alarm threshold is 100.
threshold-value: Specifies the per-slot user count alarm threshold in percentage (the percentage of the user count on a slot to the per-slot maximum user count allowed), in the range of 1 to 100. When you set the upper-limit-value argument to 100 (the default) in this command, the result is the same as when this command is not executed.
You can use this command to set the per-slot user count alarm threshold. When the user count on a slot exceeds the threshold, an alarm is triggered automatically. Then, the administrator can promptly know the online user conditions of the network.
This feature counts only the number of IPoE users, PPPoE users, and L2TP users.
·     A dual-stack PPPoE user is counted as one user.
·     A dual-stack IPoE user is counted as one user.
·     For IPoE leased users, one interface-leased user is counted as one user, and one subnet-leased user is counted as one user.
·     For IPoE leased subusers, one subuser is counted as one user.
·     L2TP users on LACs are counted in the same way as PPPoE users are counted. L2TP users on LNSs are not counted.
Suppose the per-slot maximum user count allowed is a and the per-slot user count alarm threshold is b. The following rules apply:
·     When the user count on a slot exceeds a×b, the alarm information is output.
·     When the user count on a slot drops within the normal range, the alarm clearing information is output.
In some special cases, the user count on a slot frequently changes in the critical range, which causes frequent output of alarm information and alarm clearing information. To avoid this problem, the system introduces a buffer area when the user count on a slot drops below the threshold. The buffer area size is 10% of the threshold set. Suppose the buffer area size is c. Then, c=a×b÷10. When the user count on a slot drops below a×b-c, the alarm clearing information is output.
For example, suppose a is 1000 and b is 80%. Then, c= a×b÷10=1000×80%÷10=80.
·     When the user count on a slot exceeds a×b=1000×80%=800, the alarm information is output.
·     When the user count on a slot drops below a×b-c=800-80=720, the alarm clearing information is output.
The upper threshold alarm information output and the alarm clearing information output both contain logs and traps.
·     The generated log messages by the device will be sent to the information center. The information center configuration specifies the log message sending rule and destination. For more information about the information center, see Network Management and Monitoring Configuration Guide.
·     For traps to be correctly sent to the NMS host, you must execute the snmp-agent trap enable slot-user-warning-threshold command in addition to configuring the SNMP alarm feature correctly. For more information about SNMP alarms, see SNMP configuration in Network Management and Monitoring Guide.
# Set the per-slot user count threshold to 80.
[Sysname] slot-user-warning-threshold 80
Use snmp-agent trap enable slot-user-warning-threshold to enable the per-slot user count trap feature.
Use undo snmp-agent trap enable slot-user-warning-threshold to disable the per-slot user count trap feature.
The per-slot user count trap feature is disabled.
With the per-slot user count trap feature enabled, when the user count on a slot exceeds the set threshold or drops within the normal range, a trap is generated. The generated trap will be sent to the SNMP module of the device. You can set the trap sending parameters in SNMP to determine how the traps are output. For more information about traps, see Network Management and Monitoring Configuration Guide.
This feature takes effect only when the per-slot user count alarm threshold is set.
# Enable the per-slot user count trap feature.
[Sysname] snmp-agent trap enable slot-user-warning-threshold
snmp-agent trap enable user-warning-threshold
Use snmp-agent trap enable user-warning-threshold to enable SNMP notifications for the device-level access user count.
Use undo snmp-agent trap enable user-warning-threshold to disable SNMP notifications for the device-level access user count.
SNMP notifications are disabled for the device-level access user count trap feature.
(In standalone mode.) The number of access user sessions on the whole device refers to the total number of IPoE sessions, PPPoE sessions, and L2TP sessions on the device.
(In IRF mode.) The number of access user sessions on the whole device refers to the total number of IPoE sessions, PPPoE sessions, and L2TP sessions on the whole IRF fabric.
With SNMP notifications enabled for the device-level access user count, when the access user session count ratio on the device exceeds the threshold or restores to the normal range, the corresponding alarm is generated. The generated alarms are sent to the SNMP module of the device. You can specify how the alarms are output through setting the alarm output parameters in SNMP. For more information about alarms, see SNMP configuration in Network Management and Monitoring Guide.
For this feature to take effect, you must first configure the device-level access user count alarm threshold. Use one of the following commands to configure the device-level user count alarm threshold:
·     access-user session-threshold (Applicable to IPoE, PPPoE, and L2TP users.)
·     l2tp session-threshold (Applicable to only L2TP users.)
·     ppp session-threshold (Applicable to only PPPoE users.)
If all of the preceding commands are executed, all of them take effect. An alarm is output when any threshold is reached.
# Enable SNMP notifications for the device-level access user count.
[Sysname] snmp-agent trap enable user-warning-threshold
l2tp session-threshold (BRAS Services Command Reference)
ppp session-threshold (BRAS Services Command Reference)
trace access-user
Use trace access-user to create a service tracing object.
Use undo trace access-user to delete a service tracing object.
trace access-user object object-id { access-mode { ipoe | lns | pppoe } | c-vlan vlan-id | interface interface-type interface-number | ip-address ip-address | mac-address mac-address | s-vlan vlan-id | tunnel-id tunnel-id | username user-name } * [ aging time | output { file file-name | syslog-server server-ip-address | vty } ] *
trace access-user object object-id [ access-mode { ipoe | lns | pppoe } | c-vlan vlan-id | interface interface-type interface-number | ip-address ip-address | mac-address mac-address | s-vlan vlan-id | tunnel-id tunnel-id | username user-name ] * calling-station-id calling-station-id
undo trace access-user { all | object object-id }
No service tracing object exists.
object object-id: Specifies a service tracing object ID, in the range of 1 to 5.
access-mode: Creates a service tracing object based on an access mode.
·     ipoe: Creates a service tracing object based on the IPoE access mode.
·     lns: Creates a service tracing object based on the LNS device in L2TP access mode.
·     pppoe: Creates a service tracing object based on the PPPoE access mode.
calling-station-id calling-station-id: Creates a service tracing object based on an L2TP calling number. The calling-station-id argument specifies an L2TP calling number, a case-insensitive string of 1 to 64 characters. The L2TP calling number format is H-H-H IFNAME:SVLAN.CVLAN, where H-H-H represents the user MAC address, IFNAME represents the abbreviated name of the user access interface on the LAC, and SVLAN.CVLAN represents the outer VLAN ID and inner VLAN ID of the user. When the user does not have VLAN information, the SVLAN.CVLAN field is padded with ffff.ffff. For example, if the MAC address of a user is 000f-e235-dc71, the user access interface on the LAC is RAGG1.1, and the outer VLAN ID and inner VLAN ID of the user are 1 and 2, respectively, the L2TP calling number is 000f-e235-dc71 RAGG1.1:0001.0002.
c-vlan vlan-id: Creates a service tracing object based on an inner VLAN ID in the range of 1 to 4094.
interface interface-type interface-number: Creates a service tracing object based on the specified interface. With this option specified, the service tracing object becomes ineffective when the slot or subslot that hosts the specified interface is rebooted. Only network access users support this option.
ip-address ip-address: Creates a service tracing object based an IP address.
mac-address mac-address: Creates a service tracing object based on a MAC address in the format of H-H-H, case-insensitive. Only network access users support this option.
s-vlan vlan-id: Creates a service tracing object based on an outer VLAN ID in the range of 1 to 4094.
tunnel-id tunnel-id: Creates a service tracing object based on an L2TP tunnel ID in the range of 1 to 65535. This option does not take effect on IPoE users.
username user-name: Creates a service tracing object based on a username, a case-sensitive string of 1 to 253 characters.
aging time: Specifies the maximum length of the tracing time in the range of 0 to 60 minutes. The default is 15. The tracing time is calculated from the time when this command is configured. The service object is no longer traced after the tracing time expires. The value of 0 indicates that the tracing time never expires and the device will always trace the service object. To stop tracing a service object, delete the service tracing object by using the undo form or shut down the VTY where the command is executed.
output: Specifies the location to which the service tracing object information is output. By default, the service tracing object information is output to the VTY monitor terminal.
·     file file-name: Outputs the service tracing information to the storage medium on the device. For the specific storage location, execute the display trace access-user command. The file-name argument represents the name of the file storing the service tracing information in the storage medium, a case-sensitive string of 1 to 63 characters. For the configuration to take effect, make sure the file-name argument does not contain the working directory.
·     syslog-server server-ip-address: Outputs the service tracing information to the log server specified by its IP address.
·     vty: Outputs the service tracing information to the current VTY monitor terminal.
all: Specifies all service tracing objects.
You can create service tracing objects to trace access user information, such as login and logout information. By specifying match parameters, you can trace the specific access users.
This command is resource intensive. As a best practice, use this command only when troubleshooting devices.
When the syslog-server server-ip-address option is specified, make sure the device and the specified log server can reach each other and the log server configuration is correct.
(In standalone mode.) Active/standby MPU switchover causes the command to be ineffective.
(In IRF mode.) Active/standby global MPU switchover causes the command to be ineffective.
An LNS cannot obtain the MAC address or inner/outer VLAN information of access users, the mac-address, c-vlan, or s-vlan keyword in this command does not take effect. For example, when the access-mode lns and the mac-address, c-vlan, or s-vlan keyword are configured in this command, only the access-mode lns configuration takes effect.
#Create service tracing object 1.
[Sysname] trace access-user object 1 access-mode ipoe interface ten-gigabitethernet 3/1/1.1 ip-address 1.1.1.2 mac-address 1-2-3 c-vlan 2 s-vlan 3
user-policy interface-down online
Use user-policy interface-down online to keep the users online after the interface goes down.
Use undo user-policy interface-down to restore the default.
user-policy interface-down online [ no-user-detect ]
Users on an interface are forced to go offline after the interface goes down.
online: Keeps users online after the interface goes down.
no-user-detect: Does not perform online detection on users after the interface goes down. If you do not specify this keyword, online detection is still performed for users on the interface after the interface goes down, and forcibly logs out users that fail online detection.
Application scenarios
To prevent users from frequently coming online and going offline because the interface frequently comes up and goes down, you can use this command to keep users online after the interface goes down.
When you configure an interface to keep the users online after the interface goes down, to prevent users from being logged out because the users fail online detection during the period the interface recovers from down to up, specify the no-user-detect keyword.
·     This command takes effect only on PPPoE and IPoE access users.
·     When the interface goes down after this command is executed, if you execute this command again to modify the parameter settings, the new settings do not take effect immediately, and the old settings before the interface goes down still take effect. The new settings take effect only when the down interface comes up and then goes down. For example, if you first execute the user-policy interface-down online command, and then execute the user-policy interface-down online no-user-detect command after the interface goes down, the user-policy interface-down online command executed before the interface goes down still takes effect. The user-policy interface-down online no-user-detect command configuration takes effect only when the down interface comes up and then goes down.
·     After you execute this command on a unified network, if you execute the undo form after the interface goes down, users on the interface will be forcibly logged out.
·     On a CUPS network, the following rules apply:
¡     In the UP backup scenario, users on an interface will not be forcibly logged out when the interface goes down, independent of the configuration of this command.
¡     After you execute this command in a scenario where UP backup is not configured, if you execute the undo form after the interface goes down, users on the interface will be forcibly logged out.
·     As a best practice, do not execute the user-policy interface-down online command in a VSRP network, because this command does not take effect in a VSRP network. Whether users on a primary/secondary interface will be forcibly logged out when the interface goes down depends on the VSRP state and is independent of the configuration of this command. If you execute the undo user-policy interface-down online command when the interface goes down, users might be logged out abnormally.
#Allow users on Ten-GigabitEthernet 3/1/1 to keep online after the interface goes down.
[Sysname-Ten-GigabitEthernet3/1/1] user-policy interface-down online
ip subscriber user-detect ip (BRAS Services Command Reference)
ip subscriber user-detect ipv6 (BRAS Services Command Reference)
timer-hold (BRAS Services Command Reference)
timer-hold retry (BRAS Services Command Reference)
work-mode user-plane (on UPs)
Use work-mode user-plane to configure the device to operate in user plane mode.
Use undo work-mode user-plane to restore the default.
The device operates in common mode.
In a CUPS network, you must use this command to configure the device acting as an UP to operate in user plane mode. In this mode, the device performs only the data forwarding service.
You cannot configure the device to operate in user plane mode in any of the following cases:
·     IPoE is enabled on any interface of the device by using the ip subscriber enable command.
·     PPPoE is enabled on any interface of the device by using the pppoe-server bind command.
·     The default configuration of one of the following commands has been changed in system view or on any interface:
¡     pppoe-server connection chasten
¡     pppoe-server connection chasten option105
¡     pppoe-server connection chasten per-interface
·     L2TP is enabled on any interface of the device by using the l2tp enable command.
If an interface has the preceding features (such as IPoE) enabled and the card where the interface resides has been removed, you cannot configure the device to operate in user plane mode. In this scenario, you can configure the device to operate in user plane mode in one of the following methods:
·     Reinsert the removed card into the device, and remove the configured features from the corresponding interface view. Then, execute the work-mode user-plane command to configure the device to operate in user plane mode.
·     Restore the device to factory default settings or empty configuration, and then execute the work-mode user-plane command to configure the device to operate in user plane mode.
You cannot cancel the user plane mode for a device that is operating user plane mode and being managed by a CP.
The user plane mode requires port 1701. If the port is used by another service on the device, you cannot configure the device to operate in user plane mode.
# Configure the device to operate in user plane mode.
<Sysname> system
[Sysname] work-mode user-plane
cut access-user
ip subscriber enable (BRAS Services Command Reference)
l2tp enable (BRAS Services Command Reference)
pppoe-server bind (BRAS Services Command Reference)
pppoe-server connection chasten (BRAS Services Command Reference)
pppoe-server connection chasten option105 (BRAS Services Command Reference)
pppoe-server connection chasten per-interface (BRAS Services Command Reference)
reset pppoe-server all (BRAS Services Command Reference)
