17-BRAS Services Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command Reference-R8630Pxx-6W10017-BRAS Services Command Reference
08-L2TP commands
08-L2TP commands 503.17 KB
L2TP commands
On a CUPS network, this device acts only as a UP. When executing operation commands in this chapter (commands except the display commands), follow these restrictions and guidelines:
·     If a command is tagged with (on UPs), this command can be executed only on a UP. Before executing this command on a UP, make sure you are fully aware of the impact of this command on the current network and prevent configuration errors from causing network failures.
·     If a command does not have any tag, this command can be executed only on a CP by default. To execute this command on a UP, do that under the guidance of professionals, make sure you are fully aware of the impact of this command on the current network, and prevent configuration errors from causing network failures.
allow l2tp
Use allow l2tp to configure an L2TP network server (LNS) to accept Layer 2 Tunneling Protocol (L2TP) tunneling requests from an L2TP access concentrator (LAC), and to specify a VT interface for tunnel setup.
Use undo allow to prevent setting up sessions with users with the specified domain name or users without domain names on an LAC.
In the view of L2TP group 1:
allow l2tp virtual-template virtual-template-number [ local ip-address | remote remote-name ] [ domain domain-name ]
undo allow [ domain domain-name ]
In the view of an L2TP group except group 1:
allow l2tp virtual-template virtual-template-number { local ip-address | remote remote-name } [ domain domain-name ]
An LNS denies L2TP tunneling requests from any LACs.
L2TP group (LNS mode) view
virtual-template virtual-template-number: Specifies a VT interface by its number. The value range for the virtual-template-number argument is 0 to 1023.   An LNS dynamically creates PPP sessions based on the configuration of a VT interface. Each PPP session is used to carry data for a different L2TP session.
local ip-address: Specifies the IP address of the local tunnel.
remote remote-name: Specifies the name of the tunnel peer (LAC) initiating tunneling requests, a case-sensitive string of 1 to 31 characters.
domain domain-name: Allows users with the specified domain name to set up L2TP sessions. The domain-name argument represents the domain name of the user and is a case-sensitive string of 1 to 255 characters. The ISP domain in the username is transmitted to the LNS through PPP proxy information carried in the Incoming-Call-Connection (ICCN) message. ICCN messages are a type of L2TP session setup request.
In NAS-initiated mode, ICCN messages carry PPP proxy information. In this mode, when receiving L2TP session setup requests from the LAC, the LNS compares the following domain names:
·     The ISP domain name in the username.
·     The domain name specified in an allow l2tp command configured in the L2TP group of the tunnel.
Then LNS performs the following operations depending on the comparison result:
·     If a match is found, an L2TP session is set up based on the allow l2tp command configuration.
·     If no match is found, the LNS continues to check whether an allow l2tp command without the domain keyword is executed in the L2TP group view.
¡     If the allow l2tp command exists, an L2TP session is set up based on the allow l2tp command configuration.
¡     If the allow l2tp command does not exist, the L2TP session cannot be set up.
In client-initiated mode or LAC-auto-initiated mode, the ICCN messages do not carry PPP proxy information. As a result, the LNS cannot obtain the ISP domain information in usernames. When receiving L2TP session setup requests, the LNS checks for an allow l2tp command without the domain keyword in the L2TP group of the tunnel.
·     If a match is found, an L2TP session is set up based on the command configuration.
·     If no match is found, the L2TP session cannot be set up.
Application scenarios
The allow l2tp command is available only on LNSs.
Operating mechanism
·     With the local keyword specified, the LNS checks whether the destination address in the received requests is the same as the local tunnel address. The LNS accepts the requests only when the two IP addresses are the same. When specifying the local tunnel address, make sure it is the same as a minimum one of the LNS IP addresses specified on the LAC.
·     If the remote keyword is specified, the LNS checks whether the LAC name in the received requests is the same as the specified LAC name. The LNS accepts the requests only when the two names are the same. When specifying the LAC name, make sure the specified LAC name is the same as the local tunnel name configured on the LAC.
·     If neither local nor remote is specified, L2TP group 1 is the default L2TP group. In this case, the LNS can accept requests from any LAC.
When receiving a request, the LNS compares the destination address or LAC name in the request with that configured in an L2TP group except group 1.
·     If a match is found, the LNS uses the tunnel parameters configured in the L2TP group to set up L2TP tunnels with the LAC. Tunnel parameters include tunnel authentication.
·     If no match is found, the LNS checks whether the default L2TP group exists.
¡     If the default L2TP group exists, the LNS uses its tunnel parameters to set up L2TP tunnels with the LAC.
¡     If the default L2TP group does not exist, the LNS cannot set up L2TP tunnels with the LAC.
When the undo form is executed without the domain keyword, the command prevents setting up sessions with users without domain names.
When the undo form is executed with the domain domain-name option, the command prevents setting up sessions with users with the specified domain name.
Recommended configuration
As a best practice, configure a default L2TP group on the LNS in the following cases:
·     LACs (such as hosts with Windows 2000 Beta 2 installed) include blank local names in their tunneling requests.
·     The LNS sets up tunnels with multiple LACs by using the same tunnel parameters.
When the command is executed in the same L2TP group, the following rules apply:
·     If the first command has the remote remote-name and domain domain-name options specified, all the following commands must have the same remote remote-name option specified.
·     If the first command has the local ip-address and domain domain-name options specified, all the following commands must have the same local ip-address option specified.
·     (Applicable to only L2TP group 1.) If the first command has the domain domain-name option specified but does not have the local ip-address or remote remote-name option specified, all the following commands cannot have the local ip-address or remote remote-name option specified.
·     (Applicable to only L2TP group 1.) If the command is executed with the domain domain-name option multiple times to specify multiple domain names but does not have the local ip-address or remote remote-name option specified, all these configurations take effect.
·     If the command is executed without the domain domain-name option multiple times, the most recent configuration takes effect.
·     If the command is executed with the domain domain-name option multiple times to specify the same domain name, the most recent configuration takes effect.
# Specify L2TP group 1 as the default L2TP group, and specify Virtual-Template 1 for tunnel setup. For L2TP group 2, configure the LNS to accept the L2TP tunneling request initiated by the LAC named aaa, and specify Virtual-Template 2 for tunnel setup.
[Sysname] l2tp-group 1 mode lns
[Sysname-l2tp1] allow l2tp virtual-template 1
[Sysname-l2tp1] quit
[Sysname] l2tp-group 2 mode lns
[Sysname-l2tp2] allow l2tp virtual-template 2 remote aaa
lns-ip
tunnel name
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) is interface baudrate divided by 1000.
Virtual PPP interface view
The expected bandwidth of an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth of Virtual-PPP 10 to 100 kbps.
[Sysname] interface virtual-ppp 10
[Sysname-Virtual-PPP10] bandwidth 100
default
Use default to restore the default settings for a virtual PPP interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use the undo forms of these commands or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Virtual-PPP 10.
[Sysname-Virtual-PPP10] default
default-lac-group enable
Use default-lac-group enable to configure an L2TP group as the default L2TP group.
Use undo default-lac-group enable to remove the default L2TP group configuration.
An L2TP group is not the default L2TP group.
L2TP group (LAC mode) view
Operating mechanism
The default L2TP group matches the users that do not match any other L2TP groups on the device. The default L2TP group has the same functions as non-default L2TP groups.
·     If the RADIUS server issues tunnel attributes to the LAC directly to create a tunnel, the default L2TP group role takes effect.
·     If L2TP tunnels are established in any other method, the default L2TP group role does not take effect.
If the RADIUS server issues tunnel attributes to the LAC directly to create a tunnel, use the default L2TP group for the following purposes:
·     Supplement tunnel attributes for the users that do not match any other L2TP groups if the RADIUS server does not issue all required tunnel attributes.
·     Supplement tunnel attributes for users in different authentication domains or authorization domains to simplify configuration.
You can configure one default L2TP group on the device.
# Configure L2TP group 1 as the default L2TP group.
[Sysname] l2tp-group 1 mode lac
[Sysname-l2tp1] default-lac-group enable
description
The description of an interface is the interface-name plus Interface. For example, the default description of Virtual-PPP254 is Virtual-PPP254 Interface.
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of Virtual-PPP 10 to virtual-interface.
[Sysname-Virtual-PPP10] description virtual-interface
display interface bas-interface
Use display interface bas-interface to display information about a BAS interface.
display interface [ bas-interface [ interface-number ] ] [ brief [ description | down ] ]
bas-interface [ interface-number ]: Specifies a BAS interface. The interface-number argument represents the number of a BAS interface. If you do not specify the bas-interface keyword, this command displays information about all interfaces supported by the device. If you specify the bas-interface keyword without specifying an interface number, this command displays information about all existing BAS interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays physically down interfaces and their down causes. If you do not specify this keyword, the command displays information about interfaces in all states.
BAS interfaces are supported only on LNSs and are not supported on LACs. When you execute the allow l2tp command on an LNS, the device will create the corresponding BAS interface.
# Display information about BAS-interface 0.
<Sysname> display interface bas-interface 0
Bas-interface0
Interface index: 17803
Current state: UP
Line protocol state: UP
Description: Bas-interface0 Interface
Bandwidth: 1000000 kbps
Hold timer: 10 seconds, retry times: 5
Internet protocol processing: Enabled
Link layer protocol: PPP
Physical: L2TP, baudrate: 1000000 kbps
# Display brief information about BAS-interface 0.
<Sysname> display interface bas-interface 0 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
BAS0                 UP   UP       4.1.1.1
# Display brief information about all BAS interfaces in down state and the causes.
<Sysname> display interface bas-interface brief down
Interface             Link Cause
BAS0                  DOWN Not connected
Current state
Physical link state and management state of the interface:
·     DOWN—The interface is administratively up, but its physical state is down.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface, which is determined through automatic parameter negotiation at the data link layer.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
Hold timer
Interval at which the interface sends keepalive packets.
retry times
Maximum number of keepalive retransmission attempts. A link is removed after the maximum number of retransmission attempts is reached.
The interface can process IP packets.
Link layer protocol of the interface.
Physical
Physical type of the interface.
baudrate
Baudrate of the interface.
Last time when the reset counters interface async command was executed. This field displays Never if this command has not been executed since the device startup.
Brief information about Layer 3 interfaces.
Physical link state of the interface:
·     ADM—The interface has been manually shut down. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
The (s) attribute means that the data link protocol of the interface is up but the link is an on-demand link or does not exist. Typically, null and loopback interfaces have this attribute.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. Typically, null and loopback interfaces have this attribute.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN. Not connected indicates no physical connection exists (possibly because the network cable is disconnected or faulty).
display interface virtual-ppp
Use display interface virtual-ppp to display information about virtual PPP interfaces.
display interface [ virtual-ppp [ interface-number ] ] [ brief [ description | down ] ]
virtual-ppp [ interface-number ]: Specifies an existing virtual PPP interface by its number in the range of 0 to 255. If you do not specify the virtual-ppp keyword, this command displays information about all interfaces. If you specify the virtual-ppp keyword but you do not specify an interface, this command displays information about all virtual PPP interfaces.
down: Displays information about the interfaces in physically down state and the causes. If you do not specify this keyword, the command displays information about interfaces in any state.
# Display detailed information about Virtual-PPP 10.
<Sysname> display interface virtual-ppp 10
Virtual-PPP10
Interface index: 17805
Line protocol state: DOWN
Description: Virtual-PPP10 Interface
Bandwidth: 100000 kbps
Internet address: 10.0.0.1/24 (primary)
LCP: initial
Physical: L2TP, baudrate: 100000000 bps
Input: 154 packets, 1880 bytes, 0 drops
Output: 155 packets, 1875 bytes, 0 drops
Current state
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is up both administratively and physically.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Bandwidth
Hold timer
Interval in seconds for the interface to send keepalive packets.
retry times
The interface is not assigned an IP address and cannot process IP packets.
Link layer protocol
Link layer protocol of the interface: PPP.
Physical
Physical type of the interface: L2TP.
baudrate
Baud rate of the interface.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Average rate of inbound traffic in the last 300 seconds.
Average rate of outbound traffic in the last 300 seconds.
Total number of inbound packets, total number of inbound bytes, and total number of dropped inbound packets.
Total number of outbound packets, total number of outbound bytes, and total number of dropped outbound packets.
# Display brief information about virtual PPP interface Virtual-PPP 10.
<Sysname> display interface virtual-ppp 10 brief
VPPP10               ADM  DOWN     10.0.0.1
# Display information about the virtual PPP interfaces in physically down state and the causes.
<Sysname> display interface virtual-ppp brief down
VPPP9                ADM  Administratively
VPPP10               ADM  Administratively
VPPP12               ADM  Administratively
# Display brief information about virtual PPP interface Virtual-PPP 10, including the complete interface description.
<Sysname> display interface Virtual-PPP 10 brief description
Link
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
Protocol
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
display l2tp aging
Use display l2tp aging to display information about locked LNSs.
display l2tp aging
Execute this command to view LNS locking configuration and information about locked LNSs.
# Display LNS locking information.
<Sysname> display l2tp aging
LNS IP     Aging(S)   VPN
1.1.1.1    128        Not set
2.2.2.2    200        Not set
LNS IP
IP address of the locked LNS.
Aging(S)
Remaining locking time (in seconds).
VPN
VPN instance to which the peer end of the L2TP tunnel belongs. If the tunnel peer belongs to the public network, this field displays Not set.
l2tp aging
lns-ip
display l2tp control-packet statistics
Use display l2tp control-packet statistics to display L2TP protocol packet statistics.
display l2tp control-packet statistics [ summary | tunnel [ tunnel-id ] ]
summary: Specifies summary L2TP protocol packet statistics for all L2TP tunnels.
tunnel [ tunnel-id ]: Specifies L2TP tunnels. The value range for the tunnel-id argument is 1 to 65535. If you specify an L2TP tunnel, this command displays L2TP protocol packet statistics for the specified L2TP tunnel. If you specify only the tunnel keyword, this command displays detailed L2TP protocol packet statistics for all L2TP tunnels.
If you do not specify any keyword or argument, the command displays both summary and detailed L2TP protocol packet statistics for all L2TP tunnels.
# Display both summary and detailed L2TP protocol packet statistics for all L2TP tunnels.
<Sysname> display l2tp control-packet statistics
Summary packet statistics:
Recv SCCRQ  : 2           Sent SCCRQ  : 0           Rsnt SCCRQ  : 4
Recv SCCRP  : 0           Sent SCCRP  : 0           Rsnt SCCRP  : 0
Recv SCCCN  : 0           Sent SCCCN  : 0           Rsnt SCCCN  : 0
Recv STOPCCN: 2           Sent STOPCCN: 0           Rsnt STOPCCN: 0
Recv HELLO  : 0           Sent HELLO  : 0           Rsnt HELLO  : 0
Recv ICRQ   : 0           Sent ICRQ   : 0           Rsnt ICRQ   : 0
Recv ICRP   : 0           Sent ICRP   : 0           Rsnt ICRP   : 0
Recv ICCN   : 0           Sent ICCN   : 0           Rsnt ICCN   : 0
Recv CDN    : 0           Sent CDN    : 0           Rsnt CDN    : 0
Tunnel packet statistics: (LocalAddr 1.2.1.1, LocalTID 10567)
Recv SCCRQ  : 1           Sent SCCRQ  : 0           Rsnt SCCRQ  : 2
Recv STOPCCN: 1           Sent STOPCCN: 0           Rsnt STOPCCN: 0
Tunnel packet statistics: (LocalAddr 1.2.1.1, LocalTID 8956)
# Display detailed L2TP protocol packet statistics for all L2TP tunnels.
<Sysname> display l2tp control-packet statistics tunnel
# Display L2TP protocol packet statistics for L2TP tunnel 10567.
<Sysname> display l2tp control-packet statistics tunnel 10567
Table 5 Command output
Summary L2TP protocol packet statistics for all L2TP tunnels.
L2TP protocol packet statistics for an L2TP tunnel.
LocalAddr
Local L2TP tunnel IP address.
LocalTID
Local L2TP tunnel ID.
Recv SCCRQ
Number of received SCCRQ packets.
Recv SCCRP
Number of received SCCRP packets.
Recv SCCCN
Number of received SCCCN packets.
Recv STOPCCN
Number of received STOPCCN packets.
Recv HELLO
Number of received HELLO packets.
Recv ICRQ
Number of received ICRQ packets.
Recv ICRP
Number of received ICRP packets.
Recv ICCN
Number of received ICCN packets.
Recv CDN
Number of received CDN packets.
Sent SCCRQ
Number of transmitted SCCRQ packets.
Sent SCCRP
Number of transmitted SCCRP packets.
Sent SCCCN
Number of transmitted SCCCN packets.
Sent STOPCCN
Number of transmitted STOPCCN packets.
Sent HELLO
Number of transmitted HELLO packets.
Sent ICRQ
Number of transmitted ICRQ packets.
Sent ICRP
Number of transmitted ICRP packets.
Sent ICCN
Number of transmitted ICCN packets.
Sent CDN
Number of transmitted CDN packets.
Rsnt SCCRQ
Number of retransmitted SCCRQ packets.
Rsnt SCCRP
Number of retransmitted SCCRP packets.
Rsnt SCCCN
Number of retransmitted SCCCN packets.
Rsnt STOPCCN
Number of retransmitted STOPCCN packets.
Rsnt HELLO
Number of retransmitted HELLO packets.
Rsnt ICRQ
Number of retransmitted ICRQ packets.
Rsnt ICRP
Number of retransmitted ICRP packets.
Rsnt ICCN
Number of retransmitted ICCN packets.
Rsnt CDN
Number of retransmitted CDN packets.
reset l2tp control-packet statistics
display l2tp packet-limit configuration
Use display l2tp packet-limit configuration to display the packet rate limit configuration on the LNS.
You can use this command to view the l2tp sccrq-limit and l2tp icrq-limit command configuration on the LNS.
# Display the packet rate limit configuration on the LNS.
<Sysname> display l2tp packet-limit configuration
ICRQ limit: 1000 packets/sec
SCCRQ limit: 500 packets/sec minlimit: 200 packets/sec
Table 6 Command output
ICRQ limit
Maximum number of ICRQ packets that the LNS can process per second.
SCCRQ limit
Maximum and minimum numbers of SCCRQ packets that the LNS can process per second.
l2tp icrq-limit
l2tp sccrq-limit
display l2tp packet-limit statistics
Use display l2tp packet-limit statistics to display the packet rate limit statistics on the LNS.
# Display the packet rate limit statistics on the LNS.
<Sysname> display l2tp packet-limit statistics
Dropped ICRQ : 0
Dropped SCCRQ: 0
Peak dropped ICRQ : 0
Peak dropped SCCRQ: 0
Table 7 Command output
Dropped ICRQ
Number of ICRQ packets dropped on the LNS.
Dropped SCCRQ
Number of SCCRQ packets dropped on the LNS.
Peak dropped ICRQ
Peak number of ICRQ packets dropped.
Peak dropped SCCRQ
Peak number of SCCRQ packets dropped.
reset l2tp packet-limit statistics
display l2tp session
Use display l2tp session to display information about L2TP sessions.
display l2tp session [ [ lac | lns ] [ [ local-address local-address | tunnel-id tunnel-id [ session-id session-id ] ] * | remote-address remote-address | username username ] ] [ statistics | verbose ]
lac: Specifies LACs.
lns: Specifies LNSs.
local-address local-address: Specifies a local tunnel IP address.
tunnel-id tunnel-id: Specifies a local tunnel ID in the range of 1 to 65535.
session-id session-id: Specifies a local session ID in the range of 1 to 65535.
remote-address remote-address: Specifies a remote tunnel IP address.
username username: Specifies a username, a case sensitive string of 1 to 80 characters.
statistics: Displays statistics for L2TP sessions.
verbose: Displays detailed information about L2TP sessions.
If you do not specify the statistics or verbose keyword, this command displays brief information about L2TP sessions.
# Display statistics for L2TP sessions.
<Sysname> display l2tp session statistics
Total number of sessions: 1
#Display brief information about all L2TP sessions.
LocalSID      RemoteSID      LocalTID      State
              Username
89            36245          10878         Established
              user1@d1
Table 8 Command output
LocalSID
Local session ID.
RemoteSID
Remote session ID.
LocalTID
Local tunnel ID.
Session state:
·     Idle.
·     Wait-tunnel—Waits for the tunnel to be established.
·     Wait-reply—Waits for an Incoming-Call-Reply (ICRP) message indicating the call is accepted.
·     Wait-connect—Waits for an Incoming-Call-Connected (ICCN) message.
·     Established.
Username
PPP username. This field is insignificant and always displays N/A in client-initiated mode or LAC-auto-initiated mode.
#Display detailed information about an L2TP session with session ID 32502 and tunnel ID 45277.
<Sysname> display l2tp session tunnel-id 45277 session-id 32502 verbose
Local tunnel ID    : 45277
Local session ID   : 32502
Remote session ID  : 14670
PPP index          : 0xb0dd7ef6800001c1
User name          : N/A
Call serial number : 32502
LIP address        : 32768
Session mode       : LAC
Session state      : Established
Flow control       : Disabled
LAC-Auto-Initiated : Yes
Age flag           : 0
Phy interface      : N/A
Bas interface      : N/A
User trace switch  : Disabled
Table 9 Command output
User name
Call serial number
Call number for an L2TP session.
LIP address
The system uses this address to record the location of an L2TP session.
Session mode
L2TP session modes:
·     LAC—L2TP sessions on LACs.
·     LNS—L2TP sessions on LNSs.
Session state
Session state:
·     Idle.
·     Established.
Flow control
This field is not supported in the current software version. L2TP session flow control status:
·     Enabled.
·     Disabled.
LAC-Auto-Initiated
Whether the LAC-Auto-Initiated tunneling mode is used:
·     Yes.
·     No.
Age flag
Flag for a session that ages out due to negotiation failure.
When the session does not age out, this field displays 0.
Phy interface
Physical interface that is the incoming interface for the LNS. This field is insignificant and always displays N/A on an LAC.
Bas interface
BAS interface. This field is insignificant and always displays N/A on an LAC.
User trace switch
Service tracing object status (whether the trace access-user command is used to create a service tracing object):
·     Enabled.
·     Disabled.
display l2tp session temporary
Use display l2tp session temporary to display information about temporary L2TP sessions.
#Display information about temporary L2TP sessions.
<Sysname> display l2tp session temporary
Total number of temporary sessions: 6
LocalSID    RemoteSID    LocalTID     LocalAddress    State
2298        0            19699        20.1.1.2        Wait-tunnel
42805       0            19699        20.1.1.2        Wait-tunnel
17777       0            19699        20.1.1.2        Wait-tunnel
58284       0            19699        20.1.1.2        Wait-tunnel
33256       0            19699        20.1.1.2        Wait-tunnel
8228        0            19699        20.1.1.2        Wait-tunnel
Table 10 Command output
LocalSID
Local session ID.
RemoteSID
Remote session ID.
LocalTID
Local tunnel ID.
LocalAddress
Local tunnel IP address.
Session state:
·     Idle.
·     Wait-reply—Waits for an ICRP message indicating the call is accepted.
·     Wait-connect—Waits for an ICCN message.
display l2tp statistics
Use display l2tp statistics to display L2TP statistics.
In standalone mode:
display l2tp statistics { { all | failure-reason | vsrp [ vsrp-instance vsrp-instance-name ] } [ slot slot-number [ cpu cpu-number ] ] }
In IRF mode:
display l2tp statistics { { all | failure-reason | vsrp [ vsrp-instance vsrp-instance-name ] } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] }
all: Specifies all L2TP statistics.
failure-reason: Specifies statistics about L2TP online failure reasons and offline reasons.
vsrp [ vsrp-instance vsrp-instance-name ]: Specifies a VSRP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSRP instance, this command displays statistics for all VSRP instances.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
In a VSRP network, you can display the L2TP VSRP statistics on both the master and backup devices.
# Display statistics about L2TP online failure reasons and offline reasons.
<Sysname> display l2tp statistics failure-reason slot 0
L2TP failure reason statistics in slot 0:
  L2TP disabled:                                               1
  Online with RADIUS authorization while configured with VSRP: 0
  Failed to get tunnel source IP:                              0
  Failed to get L2TP group:                                    0
  Tunnel creation failed:                                      0
  Session creation failed:                                     1
  SCCRQ check success but not accept:                          1
  SCCRQ check failed:                                          0
  SCCRP check success but not accept:                          0
  Insufficient resources when process SCCRP:                   0
  SCCRP check failed:                                          0
  SCCRN check success but not accept:                          0
  Insufficient resources when process SCCRN:                   0
  SCCRN check failed:                                          0
  ICRQ check success but not accept:                           0
  ICRQ check failed:                                           0
  ICRP check success but not accept:                           0
  Insufficient resources when process ICRP:                    0
  ICRP check failed:                                           0
  ICCN check success but not accept:                           0
  Insufficient resources when process ICCN:                    0
  ICCN check failed:                                           0
  AVP message check failed:                                    0
  AVP header check failed:                                     0
  Received CDN:                                                1
  Received StopCCN:                                            0
  NS sequence number larger than expected:                     0
  NS sequence number smaller than expected:                    0
  Tunnel ACK timeout:                                          0
  Tunnel keep alive timeout:                                   1
  ICRQ limit exceeded:                                         0
  Packet illegal:                                              0
  Smoothing failed:                                            1
Table 11 Command output
L2TP disabled
L2TP is not enabled.
A user comes online through RADIUS authorization when VSRP is configured.
Failed to obtain the L2TP tunnel source IP.
Failed to obtain the L2TP group.
Failed to create the L2TP tunnel.
Failed to create the L2TP session.
SCCRQ message check succeeded but the message cannot be accepted (for example, because the message carries an AVP attribute that does not meet the requirements).
SCCRQ check failed
SCCRQ message check failed.
The SCCRP message check succeeded but the message cannot be accepted.
Insufficient resources for processing SCCRP messages.
SCCRP check failed
SCCRP message check failed.
The SCCRN message check succeeded but the message cannot be accepted.
Insufficient resources for processing SCCRN messages.
SCCRN check failed
SCCRN message check failed.
The ICRQ message check succeeded but the message cannot be accepted.
ICRQ check failed
ICRQ message check failed.
The ICRP message check succeeded but the message cannot be accepted.
Insufficient resources for processing ICRP messages.
ICRP check failed
ICRP message check failed.
The ICCN message check succeeded but the message cannot be accepted.
Insufficient resources for processing ICCN messages.
ICCN check failed
ICCN message check failed.
AVP message field check failed.
AVP header check failed.
Received CDN
A user goes offline because a CDN message was received.
Received StopCCN
A user goes offline because a StopCCN message was received.
The NS of a received message was greater than expected.
The NS of a received message was smaller than expected.
Tunnel ACK timeout
A user goes offline because the tunnel acknowledgment message timed out.
A user goes offline because the tunnel keepalive timer timed out.
ICRQ limit exceeded
The ICRQ message exceeded the limit.
Packet illegal
Invalid message, for example, the L2TP message length is invalid.
Smoothing failed
A user goes offline because L2TP smoothing failed.
# Display L2TP VSRP statistics.
<Sysname> display l2tp statistics vsrp slot 0
L2TP VSRP statistics in slot 0:
VSRP instance: 1
  Sent smooth request messages:            0
  Received smooth request messages:        0
  Sent smooth start messages:              0
  Received smooth start messages:          0
  Sent smooth end messages:                0
  Received smooth end messages:            0
  Sent channel messages:                   0
  Received channel messages:               0
  Sent flow control messages:              0
  Received flow control messages:          0
  Sent master end messages:                0
  Received master end messages:            0
  Sent add tunnel messages:                0
  Received add tunnel messages:            0
  Sent delete tunnel messages:             0
  Received delete tunnel messages:         0
  Sent add session messages:               0
  Received add session messages:           0
  Sent delete session messages:            0
  Received delete session messages:        0
  VSRP binding events notified to PPP:     0
  VSRP unbinding events notified to PPP:   0
  Received VSRP events:                    0
  Received TCP events:                     0
  Created temporary tunnels:               0
  Master aged tunnels:                     0
Table 12 Command output
Number of sent smooth request messages.
Number of received smooth request messages.
Number of sent smooth start messages.
Number of received smooth start messages.
Number of sent smooth end messages.
Number of received smooth end messages.
Number of sent TCP channel messages.
Number of received TCP channel messages.
Number of sent flow control messages.
Number of received flow control messages.
Number of sent master end messages.
Number of received master end messages.
Number of sent Add Tunnel messages.
Number of received Add Tunnel messages.
Number of sent Delete Tunnel messages.
Number of received Delete Tunnel messages.
Number of sent Add Session messages.
Number of received Add Session messages.
Number of sent Delete Session messages.
Number of received Delete Session messages.
Number of VSRP binding events notified to PPP.
Number of VSRP unbinding events notified to PPP.
Number of received VSRP events.
Received TCP events
Number of received TCP events.
Number of temporary tunnel created on the backup device.
Master aged tunnels
Number of aged tunnels when the backup device changes to the master device.
reset l2tp statistics
display l2tp tunnel
Use display l2tp tunnel to display information about L2TP tunnels.
display l2tp tunnel [ [ lac | lns ] [ group-name group-name | group-number group-number | [ local-address local-address | tunnel-id tunnel-id ] * | remote-address remote-address | tunnel-name remote-name ] ] [ statistics | verbose ]
group-name group-name: Specifies an L2TP group by its name, a case insensitive string of 1 to 32 characters.
group-number group-number: Specifies an L2TP group by its number in the range of 1 to 65535.
tunnel-id tunnel-id: Specifies a local L2TP tunnel ID in the range of 1 to 65535.
tunnel-name remote-name: Specifies a remote L2TP tunnel name, a case sensitive string of 1 to 31 characters.
statistics: Displays statistics for L2TP tunnels.
verbose: Displays detailed L2TP tunnel information.
If you do not specify the statistics or verbose keyword, this command displays brief information of L2TP tunnels.
# Display statistics for L2TP tunnels.
<Sysname> display l2tp tunnel statistics
Total number of tunnels: 1
#Display brief information about all L2TP tunnels.
LocalTID  RemoteTID   State         Sessions RemoteAddress    RemotePort
          RemoteName
10878     21          Established   1        20.1.1.2         1701
          lns
Table 13 Command output
LocalTID
Local tunnel ID.
RemoteTID
Remote tunnel ID.
Tunnel state:
·     Idle.
·     Wait-reply.
·     Wait-connect.
·     Established.
·     Stopping.
Sessions
Number of sessions within the tunnel.
RemoteAddress
IP address of the peer.
RemotePort
UDP port number of the peer.
RemoteName
Name of the tunnel peer.
#Display detailed information about an L2TP tunnel with tunnel ID 10878.
<Sysname> display l2tp tunnel tunnel-id 10878 verbose
Group number          : 1
Group mode            : LNS
Tunnel state          : Established
Tunnel type           : Group
Local tunnel ID       : 10878
Remote tunnel ID      : 28143
Local IP address      : 20.1.1.1 (Dynamic)
Remote IP address     : 20.1.1.2
Sessions              : 1
Send window size      : 1024
Send win lower-limit  : 5922
Send win upper-limit  : 5921
Recv window size      : 1024
Control message Nr    : 5924
Latest hello packet Ns: 5923
Recv same hello times : 0
Ack timeout times     : 0
Remote framing cap    : Both
Remote bearer cap     : Both
Remote protocol ver   : 1
Remote port           : 1701
Remote tunnel name    : LAC
Remote vendor name    : Sysname
Tunnel auth           : Disabled
Assignment ID         : N/A
Table 14 Command output
Group number
L2TP group number.
Group mode
L2TP group mode:
·     LAC—The device acts as the LAC to initiates tunneling requests to the LNS.
·     LNS—The device acts as the LNS to receive tunneling requests from the LAC.
Tunnel state
Tunnel state:
·     Idle.
·     Wait-reply—Waits for an SCCRP message.
·     Wait-connect—Waits for an SCCCN message.
·     Established.
·     Stopping—Coming offline.
Tunnel type
Tunnel establishment methods:
·     Group—A tunnel can be established by creating an L2TP group.
·     Radius—The RADIUS server issues tunnel attributes to the LAC directly to create a tunnel.
Disconnection cause
L2TP tunnel disconnection causes (this field is displayed only when a tunnel is disconnected):
·     L2TP fail—L2TP negotiation fails. For example, error packets are received in L2TP negotiation.
·     L2TP cut command—The tunnel is locally disconnected. For example, the administrator executes the reset l2tp tunnel command.
·     L2TP peer clear—Tunnel disconnection is triggered by the peer. For example, STOPCCN packets are received from the peer.
·     L2TP no response—No response is received from the peer. For example, local packets are retransmitted multiple times, but no correct response packet is received.
·     N/A—Unknown causes.
Local IP address
Local tunnel IP address. (The Dynamic field is supported only on a UP backup network. This field is displayed only when the source IP address of the L2TP tunnel on the LAC is dynamically obtained from an IP address pool of the L2TP tunnel type.)
In an LAC CUPS network, this field displayed on the LAC CP is the source IP address used by the peer LAC UP for establishing a tunnel and the peer LAC UP ID; this field displayed on the LNS CP is the source IP address used by the peer LNS UP for establishing a tunnel and the peer LNS UP ID.
Sessions
Number of sessions in this tunnel.
Send window size
Sending window size for an L2TP tunnel.
Lower limit of the sending window size.
Upper limit of the sending window size.
Recv window size
Receiving window size for an L2TP tunnel.
Control message Nr
Sequence number expected in the next control message to be received.
Sequence number of the most recent Hello packet received.
Times for receiving Hello packets with the same sequence number.
Ack timeout times
Times of ACK timer timeout.
Remote framing cap
Frame types supported, accepted, or required by the peer end:
·     Sync—Synchronous.
·     Async—Asynchronous.
·     Both—Synchronous and asynchronous.
This field is displayed only on LNSs.
Remote bearer cap
Channels used by the peer end to send L2TP packets:
·     Digital—Digital channel.
·     Analog—Analogue channel.
·     Both—Digital and analogue channels.
Remote protocol ver
Remote L2TP version number.
Tunnel auth
L2TP tunnel authentication status:
·     Enabled.
·     Disabled.
Assignment ID
Assignment ID issued by AAA to identify tunnels on which sessions are carried.
If AAA does not issue an assignment ID, this field displays N/A.
reset l2tp tunnel
display l2tp-group
Use display l2tp-group to display information about L2TP groups.
display l2tp-group [ group-number | group-name group-name ] [ verbose ]
verbose: Displays detailed L2TP group information. If you do not specify this keyword, this command displays brief L2TP group information.
If you do not specify any keyword or argument, this command displays brief information for all L2TP groups.
#Display brief information about all L2TP groups.
<Sysname> display l2tp-group
Total number of L2TP groups: 3
Group-Number   Group-Mode     Group-Name   Tunnels    Sessions
1              LNS            group1       2          20
2              LAC            N/A          3          120
3              LAC (default)  N/A          4          60
Table 15 Command output
Total number of L2TP groups. This field is displayed only when you execute the display l2tp-group command without specifying any parameters.
Group-Number
L2TP group number.
Group-Mode
L2TP group mode:
·     LAC.
·     LAC (default).
·     LNS.
Group-Name
L2TP group name.
When the L2TP group name is null, this field displays N/A.
Tunnels
Number of tunnels in an L2TP group.
Sessions
Number of sessions in an L2TP group.
#Display detailed information about L2TP group 1.
<Sysname> display l2tp-group 1 verbose
Group number      : 1
Group name        : lac1
Group mode        : LAC
Tunnels           : 2
Sessions          : 20
Local tunnel name : lac
Tunnel recv window: 1024
Tunnel send window: 0
AVP hidden        : No
Hello interval(s) : 60
IP DSCP           : 0
VPN instance      : N/A
Working mode      : Master-backup
LNS IP            : 190.1.1.5 (weight 1)
                    190.1.1.6 (weight 2)
Source IP         : 0.0.0.0
Tunnel per user   : No
Trigger           : Fullusername (user1)
VSRP source IP    : 0.0.0.0
VSRP instance     : N/A
# Display detailed information about L2TP group 2.
<Sysname> display l2tp-group 2 verbose
Group number      : 2
Group name        : lns1
Group mode        : LNS
Tunnels           : 2
Sessions          : 20
Local tunnel name : lns
AVP hidden        : No
IP DSCP           : 0
VPN instance      : N/A
Local IP address  : 190.1.1.2
Remote tunnel name: N/A
Mandatory CHAP    : No
Mandatory LCP     : No
Table 16 Command output
Group number
L2TP group number.
Group-Name
L2TP group name.
Group mode
L2TP group mode:
·     LAC (default).
Tunnel auth
·     Enabled.
·     Disabled.
Local tunnel name
Local L2TP tunnel name. By default, the local L2TP tunnel name is the device name.
Tunnel recv window
Receiving window size for L2TP tunnels.
Tunnel send window
Sending window size for L2TP tunnels.
AVP hidden
Whether transferring AVP data in hidden mode is enabled:
·     Yes.
·     No.
Hello interval(s)
Hello intervals, in seconds.
IP DSCP
DSCP value of L2TP packets.
Flow control
·     Enabled.
·     Disabled.
VPN instance
VPN to which a tunnel peer belongs.
If a tunnel peer belongs to the public network, this field displays N/A.
Working mode
LAC operating mode:
·     Master-backup.
·     Load-sharing.
LNS IP
LNS IP address and weight configured on the LAC. The weight information is displayed only when the LAC operates in load sharing mode.
Source IP
L2TP tunnel source IP address, which is used as the source IP address of L2TP tunnel packets.
Tunnel per user
Whether each L2TP user can use an L2TP tunnel exclusively:
·     Yes.
·     No.
Trigger
Conditions that trigger the LAC to initiate tunneling requests to the LNS:
·     Domain (domain-name)—The domain name of a user matches a configured domain name. The domain-name parameter represents the configured domain name.
·     Fullusername (user-name)—The username of a user matches a configured full username. The user-name parameter represents the configured full username.
VSRP source IP
L2TP tunnel source address when VSRP is enabled. The source address is used as the source IP address of L2TP tunnel packets. If the source address does not exist, this field displays 0.0.0.0.
VSRP instance
VSRP instance with which the L2TP group is associated.
If the L2TP group is not associated with any VSRP instance, this field displays N/A.
Local IP address
Local tunnel IP address. This field displays 0.0.0.0 if no local tunnel IP address is specified.
Remote tunnel name
Name of the tunnel peer that initiates tunneling requests.
If you do not configure a name of the tunnel peer that initiates tunneling requests, this field displays N/A.
Mandatory CHAP
Whether the LNS is forced to perform CHAP authentication for users:
·     Yes.
·     No.
Mandatory LCP
Whether the LNS is forced to perform LCP negotiation with users:
·     Yes.
·     No.
l2tp group
iccn max-connect-speed
Use iccn max-connect-speed to configure the maximum value supported by the Connect Speed field in the Incoming Call Connected (ICCN) messages transmitted by an LAC.
Use undo iccn max-connect-speed to restore the default.
iccn max-connect-speed max-connect-speed-value
The Connect Speed field in ICCN messages supports a maximum value of 4294967295 bps.
max-connect-speed-value: Specifies the maximum value supported by the Connect Speed field in ICCN messages, in the range of 1 to 4294967294 bps.
By default, when an L2TP user access interface (for example, a Layer 3 Ethernet interface through which the user comes online) has bandwidth less than 4 Gbps, the Connect Speed field in the ICCN messages sent by the LAC will take the value of the L2TP user access interface bandwidth. When an L2TP user access interface has bandwidth of 4 Gbps or higher, the Connect Speed field in the ICCN messages will be fixed at 4294967295 bps.
When an H3C device acts as an LAC and a third-party device acts as an LNS, the maximum value of the Connect Speed field supported by the third-party LNS might be less than a certain value. To ensure successful interoperation between the third-party LNS and the H3C LAC, you must configure the maximum value supported by the Connect Speed field in the ICCN messages on the H3C LAC as the maximum value supported by the LNS.
Operating mechanism
When you use this command to configure the maximum value supported by the Connect Speed field in ICCN messages, the device follows these processing principles:
·     If the bandwidth of the L2TP user access interface is less than or equal to the value specified for the max-connect-speed-value argument, the Connect Speed field in the ICCN messages will be set to the bandwidth value of the L2TP user access interface.
·     If the bandwidth of the L2TP user access interface exceeds the value specified for the max-connect-speed-value argument, the Connect Speed field in the ICCN message will be set to the value specified for the max-connect-speed-value argument.
# Set the maximum value of the Connect Speed field to 8000 bps in the ICCN messages sent by the LAC.
[Sysname-l2tp1] iccn max-connect-speed 8000
Use interface virtual-ppp to create a virtual PPP interface and enter its view, or enter the view of an existing virtual PPP interface.
Use undo interface virtual-ppp to delete a virtual PPP interface.
interface virtual-ppp interface-number
undo interface virtual-ppp interface-number
No virtual PPP interface exists.
interface-number: Specifies a virtual PPP interface by its number in the range of 0 to 255.
A virtual PPP interface is required on the LAC for establishing an LAC-auto-initiated L2TP tunnel.
# Create Virtual-PPP 10 and enter its view.
ip dscp
Use ip dscp to set the DSCP value of L2TP packets.
Use undo ip dscp to restore the default.
ip dscp dscp-value
undo ip dscp
The DSCP value of L2TP packets is 0.
L2TP group view
dscp-value: Specifies the DSCP value of L2TP packets, in the range of 0 to 63.
The DSCP field is the first 6 bits of the IP ToS byte. This field marks the priority of IP packets for forwarding. This command sets the DSCP value for the IP packet when L2TP encapsulates a PPP frame into an IP packet.
# Set the DSCP value of L2TP packets to 50.
[Sysname-l2tp1] ip dscp 50
l2tp aging
Use l2tp aging to configure the time for which a LAC locks LNSs.
Use undo l2tp aging to restore the default.
l2tp aging seconds
undo l2tp aging
A LAC locks LNSs for 300 seconds.
seconds: Specifies the time for which a LAC locks LNSs, in the range of 1 to 3600 seconds.
Operating mechanism
If a LAC fails to establish an L2TP tunnel to an LNS, the LAC will lock the LNS for a period of time. Within the locking period, the LAC will not try to establish an L2TP tunnel to the LNS. After the locking period times out, the LAC will try to establish an L2TP tunnel to the LNS again.
This command takes effect only on newly locked LNSs and does not affect LNSs that have already been locked.
# Configure the LAC to lock LNSs for 20 seconds.
[Sysname] l2tp aging 20
display l2tp aging
lns-ip
reset l2tp aging
l2tp calling-number-avp encapsulate-format version1
Use l2tp calling-number-avp encapsulate-format version1 to configure the LAC to encapsulate information in the calling-number-avp attribute in version1 format.
Use undo l2tp calling-number-avp encapsulate-format version1 to restore the default.
The LAC encapsulates the information in the calling-number-avp attribute in the following formats:
·     Encapsulate the MAC address information in hexadecimal format.
·     Encapsulate the interface information in string format.
·     Encapsulate the VLAN information in hexadecimal format.
In an L2TP network, the calling-number-avp attribute contains the user MAC address, the user access interface on the LAC, and the user VLAN. Sometimes, the LNS needs to perform user authentication or generate DHCP client IDs based on the user VLAN information. Use this feature on the LAC to ensure successful L2TP user access to the network by encapsulating VLAN information in ASCII format, which is supported by third-party LNSs, rather than in hexadecimal format. This feature is required for interconnecting with third-party devices that only support parsing the VLAN information in the calling-number in ASCII format.
Operating mechanism
With this feature configured, when the LAC sends an ICRQ packet to the LNS, the LAC will change the encapsulation format of VLAN information from hexadecimal to ASCII. The encapsulation formats for the MAC address information and interface information remain unchanged, as detailed below:
·     Encapsulate the VLAN information in ASCII format.
·     Before configuring this feature to encapsulate VLAN information in ASCII format, confirm the specific format that the LNS uses to parse VLAN information. You must configure this feature on the LAC only if the LNS actually parses VLAN information in ASCII format.
·     If a user has no actual VLAN information on the LAC (for example, the user comes online through the main interface), the LAC will encapsulate the VLAN information by using the value of 4096.
# Configure the LAC to encapsulate information in the calling-number-avp attribute in version1 format.
[Sysname-l2tp1] l2tp calling-number-avp encapsulate-format version1
l2tp lns calling-number-avp parse-vlan-format ascii
l2tp enable
Use l2tp enable to enable L2TP.
Use undo l2tp enable to disable L2TP.
l2tp enable
undo l2tp enable
L2TP is disabled.
For L2TP configurations to take effect, you must enable L2TP.
When UDP port number 1701 for L2TP is used by other services on the device, L2TP will fail to enabled. To view the UDP port usage information, execute the display udp command. For more information about the display udp command, see IP performance optimization commands in Layer 3—IP Services Command Reference.
You cannot enable L2TP on a device configured to operate in user plane mode by using the work-mode user-plane command.
# Enable L2TP.
[Sysname] l2tp enable
work-mode user-plane (BRAS Services Command Reference)
l2tp icrq-limit
Use l2tp icrq-limit to set the maximum number of incoming call request (ICRQ) packets that the LNS can process per second.
Use undo l2tp icrq-limit to restore the default.
l2tp icrq-limit number
The maximum number of ICRQ packets that the LNS can process per second is not limited on a device.
number: Specifies the ICRQ packet processing limit in the range of 1 to 60000.
To avoid device performance degradation and make sure the LNS can process ICRQ requests correctly, use this command to adjust the ICRQ packet processing rate limit.
# Set the maximum number of ICRQ packets that the LNS can process per second to 200.
[Sysname] l2tp icrq-limit 200
Use l2tp lns calling-number-avp parse-vlan-format ascii to configure the LNS to parse the VLAN information in the received calling-number-avp attribute in ASCII format.
Use undo l2tp lns calling-number-avp parse-vlan-format ascii to restore the default.
The LNS parses the VLAN information in the received calling-number-avp attribute in hexadecimal format.
In an L2TP network, the LNS sometimes needs to perform user authentication or generate DHCP client IDs based on the user VLAN information. Enable this feature on the LNS to ensure that the VLAN information from third-party LACs that only support sending the calling-number-avp attribute in ASCII format rather than hexadecimal format can be correctly parsed. This feature allows L2TP users to access the network smoothly.
Operating mechanism
With this feature configured, when the LNS receives an ICRQ packet from the LAC, the LNS will parse the VLAN information in the calling-number-avp attribute of the received ICRQ packet in ASCII format.
·     Before configuring this feature, confirm the specific format of the VLAN information that the LAC sends. Configure this feature only when the LAC actually sends VLAN information in ASCII format.
·     Executing this command to change the parsing format affects the values of certain attributes in the packets sent from the LNS to the AAA server, such as NAS-PORT-ID. If the AAA server has deployed policies (such as authentication and accounting) based on these attribute values, you must update the AAA server configuration after changing the parsing format on the LNS to avoid authentication failures or accounting mistakes.
# Configure the LNS to parse the VLAN information in the calling-number-avp attribute in ASCII format.
[Sysname] l2tp lns calling-number-avp parse-vlan-format ascii
l2tp lns-link-adjustment
Use l2tp lns-link-adjustment to enable link compensation on an L2TP LNS.
Use undo l2tp lns-link-adjustment to disable link compensation on an L2TP LNS.
l2tp lns-link-adjustment { downlink downlink-adjust-value | uplink uplink-adjust-value }
undo l2tp lns-link-adjustment { downlink | uplink }
Link compensation is disabled on an L2TP LNS.
downlink downlink-adjust-value: Specifies the adjusted value for the downlink packets, in the range of 1 to 64 bytes.
uplink uplink-adjust-value: Specifies the adjusted value for the uplink packets, in the range of 1 to 64 bytes.
By default, the device collects L2TP packet statistics based on the actual length of L2TP packets.
To exclude certain fields in packets from statistics for accounting in some scenarios, configure this feature.
Operating mechanism
With this feature configured, the device will subtract a specified number of bytes from each L2TP packet before collecting statistics.
This command takes effect only after it is executed on an L2TP LNS.
# Enable L2TP link compensation and subtract 10 bytes from each uplink L2TP packet before collecting statistics.
[Sysname] l2tp lns-link-adjustment uplink 10
l2tp enable
l2tp sccrq-limit
Use l2tp sccrq-limit to set the maximum number and minimum number of start control connection request (SCCRQ) packets that the LNS can process per second.
Use undo l2tp sccrq-limit to restore the default.
l2tp sccrq-limit max-number [ minimum min-number ]
The maximum number and minimum number of SCCRQ packets that the LNS can process per second are not limited.
max-number: Specifies the maximum number of SCCRQ packets that can be processed per second, in the range of 1 to 10000. The maximum number cannot be smaller than the minimum number.
minimum min-number: Specifies the minimum number of SCCRQ packets that can be processed per second, in the range of 1 to 10000. The default is 1.
If multiple LACs are connected to one LNS, the LACs might send L2TP tunnel establishment requests at the same time. A large number of session establishment requests are also sent through each tunnel. In this case, you can specify the maximum number and minimum number of SCCRQ packets that the LNS can process per second.
·     If the maximum number is too large, the LNS device performance is affected, and users cannot come online because the LNS fails to process request packets timely.
·     If the minimum number is too small, users cannot come online because a large number of request packets cannot be processed timely.
To avoid device performance degradation and ensure that the LNS can process SCCRQ requests correctly, set the maximum number and minimum number according to the actual conditions.
Operating mechanism
With this command executed, the device increase the number of SCCRQ packets processed per second gradually from the minimum number to the maximum number through a certain algorithm rather than immediately uses the maximum number for rate limiting. Before the number of SCCRQ packets processed per second reaches the maximum number, SCCRQ packets might be dropped even when the number of SCCRQ packets received per second is smaller than the maximum number.
# Set the maximum number and minimum number of SCCRQ packets that the LNS can process per second to 500 and 200, respectively.
[Sysname] l2tp sccrq-limit 500 minimum 200
l2tp session-threshold
Use l2tp session-threshold to configure the online L2TP session count alarm thresholds on the device.
Use undo l2tp session-threshold to restore the default.
l2tp session-threshold { lower-limit lower-limit-value | upper-limit upper-limit-value }
undo l2tp session-threshold { lower-limit | upper-limit }
The upper online L2TP session count alarm threshold is 100, and the lower online L2TP session count alarm threshold is 0.
lower-limit lower-limit-value: Specifies the lower online L2TP session count alarm threshold in the range of 0 to 99. The configured value is a percentage of the maximum number of online L2TP sessions allowed.
upper-limit upper-limit-value: Specifies the upper online L2TP session count alarm threshold in the range of 1 to 100. The configured value is a percentage of the maximum number of online L2TP sessions allowed.
(In standalone mode.) The online L2TP session count on the device refers to the total number of online L2TP sessions on the device.
(In IRF mode.) The online L2TP session count on the device refers to the total number of online L2TP sessions on the whole IRF system.
You can use this command to set the upper alarm threshold and lower alarm threshold for the online L2TP session count. When the online L2TP session count exceeds the upper alarm threshold or drops below the lower threshold, an alarm is triggered automatically. Then, the administrator can promptly know the online user conditions of the network. Additionally, the administrator can use the display l2tp session statistics command to view the total number of online L2TP sessions.
Operating mechanism
Suppose the maximum number of online L2TP sessions allowed on the device is a, the upper alarm threshold is b, and the lower alarm threshold is c. The following rules apply:
·     When the online L2TP session count exceeds a×b or drops below a×c, the corresponding alarm information is output.
·     When the online L2TP session count returns between the upper alarm threshold and lower alarm threshold, the alarm clearing information is output.
In some special cases, the online L2TP session count frequently changes in the critical range, which causes frequently output of alarm information and alarm clearing information. To avoid this problem, the system introduces a buffer area when the online L2TP session count recovers from the upper or lower threshold. The buffer area size is 10% of the difference between the upper threshold and the lower threshold. Suppose the buffer area size is d. Then, d=a×(b-c)÷10. When the online L2TP session count drops below a×b-d or exceeds a×c+d, the alarm information is output.
For example, suppose a is 1000, b is 80%, and c is 20%. Then, d= a×(b-c)÷10=1000×(80%-20%)÷10=1000×60%÷10=600÷10=60.
·     When the online L2TP session count exceeds the upper threshold a×b=1000×80%=800, the upper threshold alarm is output. When the online L2TP session count restores to be smaller than a×b-d=800-60=740, the alarm clearing information is output.
·     When the online L2TP session count drops below the lower threshold a×c=1000×20%=200, the lower threshold alarm is output. When the online L2TP session count restores to be greater than a×c+d=200+60=260, the alarm clearing information is output.
The upper threshold alarm information output and the alarm clearing information output both contain logs and traps.
For traps to be correctly sent to the NMS host, you must execute the snmp-agent trap enable user-warning-threshold command in addition to configuring the SNMP alarm feature correctly.
# Set the upper online L2TP session count threshold to 80% on the device.
[Sysname] l2tp session-threshold upper-limit 80
snmp-agent trap enable user-warning-threshold (BRAS Services Command Reference)
l2tp tsa-id
Use l2tp tsa-id to set the TSA ID for the L2TP tunnel switching (LTS) device and enable L2TP loop detection on the LTS device.
Use undo l2tp tsa-id to restore the default.
l2tp tsa-id tsa-id
undo l2tp tsa-id
The TSA ID of the LTS device is not set, and L2TP loop detection is disabled on the LTS device.
tsa-id: Specifies a TSA ID that uniquely identifies the LTS device. This argument is a case-sensitive string of 1 to 64 characters.
Application scenarios
The LTS device compares the configured TSA ID with each TSA ID Attribute Value Pair (AVP) in a received ICRQ packet for loop detection.
Operating mechanism
The LTS device compares the configured TSA ID with each TSA ID Attribute Value Pair (AVP) in a received ICRQ packet:
·     If a match is found, a loop exists. The LTS immediately tears down the session.
·     If no match is found, the LTS performs the following operations:
a.     Encapsulates the configured TSA ID into a new TSA ID AVP.
b.     Appends the new TSA ID AVP to the packet.
c.     Sends the packet to the next hop LTS.
To avoid loop detection errors, make sure the TSA ID of each LTS device is unique.
# Set the TSA ID of the LTS device to lts0, and enable L2TP loop detection on the LTS device.
[Sysname] l2tp tsa-id lts0
l2tp tunnel-id
Use l2tp tunnel-id to specify an L2TP tunnel ID range.
Use undo l2tp tunnel-id to restore the default.
l2tp tunnel-id low-id high-id
undo l2tp tunnel-id
The L2TP tunnel ID is in the range of 1 to 65535.
low-id: Specifies the lower limit of the L2TP tunnel ID. The value range is 1 to 65535.
high-id: Specifies the upper limit of the L2TP tunnel ID. The value range is 1 to 65535. The upper limit must be greater than or equal to the lower limit.
You cannot change the L2TP tunnel ID range for an LAC when it has an L2TP tunnel.
On a UP backup network in 1:N warm load balancing mode, if you disable the free virtual MAC address switchover feature, make sure the tunnel ID ranges configured for the two UP IDs corresponding to the virtual MAC address overlap. If you cannot do that, the virtual MAC address might fail to obtain a tunnel ID. If you enable the free virtual MAC address switchover feature, this restriction does not apply.
# Specify a L2TP tunnel ID range from 20 to 100 on the LAC.
[Sysname] l2tp tunnel-id 1 200
l2tp-auto-client
Use l2tp-auto-client to trigger an LAC to automatically establish an L2TP tunnel.
Use undo l2tp-auto-client to delete the automatically established L2TP tunnel.
l2tp-auto-client l2tp-group group-number
An LAC does not automatically establish an L2TP tunnel.
l2tp-group group-number: Specifies an L2TP group by its number in the range of 1 to 65535. The LAC uses tunnel parameters of the L2TP group to establish the tunnel.
Operating mechanism
After this command is executed, the LAC will immediately start L2TP tunnel establishment.
·     If L2TP tunnel establishment fails but the LNS locking conditions are not meet, the LAC will periodically send L2TP tunnel establishment requests to the LNS until the L2TP tunnel is successfully established.
·     If the LNS locking conditions are met when the L2TP tunnel is still not established, the LAC will lock the LNS for a period of time. Within the locking period, the LAC will not try to establish an L2TP tunnel to the LNS. After the LNS locking period times out, the LAC will repeat the steps above to try to establish L2TP tunnel to the LNS again.
For this command to take effect, make sure the L2TP group is an existing one in LAC mode.
An L2TP tunnel automatically established in LAC-auto-initiated mode exists until you delete the tunnel by using the undo l2tp-auto-client or reset l2tp tunnel command.
# Trigger the LAC to automatically establish an L2TP tunnel by using the tunnel parameters of L2TP group 10.
[Sysname] interface virtual-ppp 1
[Sysname-Virtual-PPP1] l2tp-auto-client l2tp-group 10
l2tp aging
l2tp-group
l2tp-group
Use l2tp-group to create an L2TP group and enter its view, or enter the view of an existing L2TP group.
Use undo l2tp-group to delete an L2TP group.
l2tp-group group-number [ group-name group-name ] [ mode { lac | lns } ]
undo l2tp-group group-number
No L2TP group exists.
group-name group-name: Specifies an L2TP group name, a case insensitive string of 1 to 32 characters. If you do not specify this option, the created L2TP group does not have a name.
mode: Specifies a mode for the L2TP group.
lac: Specifies the LAC mode.
lns: Specifies the LNS mode.
Operating mechanism
To create a new L2TP group, you must specify the mode keyword. To enter the view of an existing L2TP group, you do not need to specify this keyword.
In L2TP group view, you can configure L2TP tunnel parameters, such as tunnel authentication.
A device can have L2TP groups in both LAC and LNS modes at the same time.
# Create L2TP group 2 with group name g1 in LAC mode, and enter its view.
[Sysname] l2tp-group 2 group-name g1 mode lac
[Sysname-l2tp2]
allow l2tp
lns-ip
user
lns-ip
Use lns-ip to specify LNS IP addresses on an LAC.
Use undo lns-ip to remove the specified LNS IP addresses on an LAC.
lns-ip { ip-address [ weight lns-weight ] }&<1-8>
undo lns-ip
No LNS IP addresses are specified on an LAC.
L2TP group (LAC mode) view
ip-address: Specifies the LNS IP address.
weight lns-weight: Specifies the LNS weight in the range of 1 to 10. The default is 5. A greater value indicates a higher priority. The parameter configuration takes effect only when the LAC operates in load sharing mode.
&<1-8> indicates that you can enter the ip-address [ weight lns-weight ] parameter for a maximum of eight times.
A LAC supports the following operating modes:
·     In master/backup mode, when the lns-ip command is executed to configure multiple LNS addresses, the LAC tries to establish a connection to an LNS in the LNS address configuration order until a connection to an LNS is successfully established. The LNS that successfully establishes a connection is called the master LNS, and the other LNSs are backup LNSs. A LAC tries to establish a connection to a backup LNS until the master LNS fails.
·     In load sharing mode, when the lns-ip command is executed to configure multiple LNS addresses, the LAC distributes the L2TP services among the specified LNSs according to their weights.
If you execute this command multiple times for an L2TP group, the most recent configuration takes effect.
# Specify the LNS IP address as 202.1.1.1.
[Sysname] l2tp-group 1 mode lac
[Sysname-l2tp1] lns-ip 202.1.1.1
tunnel load-sharing
mandatory-chap
Use mandatory-chap to force the LNS to perform CHAP authentication for users.
Use undo mandatory-chap to restore the default.
mandatory-chap
undo mandatory-chap
An LNS does not perform CHAP authentication for users.
L2TP group (LNS mode) view
The LNS uses the LAC as an authentication proxy. The LAC sends the LNS all user authentication information from users and the authentication method configured on the LAC itself. The LNS then checks the user validity according to the received information and the locally configured authentication method.
Operating mechanism
When mandatory CHAP authentication is configured, a user who depends on an LAC to initiate tunneling requests is authenticated by both the LAC and the LNS for increased security. Some users might not support the authentication on the LNS. In this situation, do not configure this command, because CHAP authentication on the LNS will fail.
This command takes effect only on NAS-initiated L2TP tunnels.
The mandatory-lcp command takes precedence over this command. If both commands are configured for an L2TP group, the LNS performs LCP renegotiation with the user.
# Force the LNS to perform CHAP authentication for users.
[Sysname] l2tp-group 1 mode lns
[Sysname-l2tp1] mandatory-chap
mandatory-lcp
mandatory-lcp
Use mandatory-lcp to force an LNS to perform LCP negotiation with users.
Use undo mandatory-lcp to restore the default.
mandatory-lcp
undo mandatory-lcp
An LNS does not perform LCP negotiation with users.
By default, to establish a NAS-initiated tunnel, the user performs LCP negotiation with the LAC. If the negotiation succeeds, the LAC initiates a tunneling request and sends the negotiation results (including authentication information) to the LNS. Then, the LNS determines whether the user is valid based on the information received instead of performing LCP renegotiation with the user.
If you do not expect the LNS to accept LCP negotiation parameters, configure this command to perform an LCP negotiation between the LNS and the user. In this case, the information sent by the LAC will be ignored.
Some users might not support LCP negotiation. In this case, do not configure this command because LCP negotiation will fail.
This command takes precedence over the mandatory-chap command. If both commands are configured for an L2TP group, the LNS performs LCP negotiation with the user.
# Force an LNS to perform LCP negotiation with users.
[Sysname-l2tp1] mandatory-lcp
mandatory-chap
mtu
Use mtu to set the MTU size of an interface.
mtu size
undo mtu
The MTU size of a virtual PPP interface is 1500 bytes.
Virtual PPP interface view
size: Specifies the MTU size in bytes. The value range is 128 to 1500.
The MTU size of an interface affects the fragmentation and reassembly of IP packets on the interface.
For the configured MTU size to take effect, you must execute the shutdown command and then the undo shutdown command on the interface.
# Set the MTU size of Virtual-PPP 10 to 1400 bytes.
[Sysname] interface virtual-ppp 10
[Sysname-Virtual-PPP10] mtu 1400
reset counters interface virtual-ppp
Use reset counters interface virtual-ppp to clear the statistics for virtual PPP interfaces.
reset counters interface [ virtual-ppp [ interface-number ] ]
virtual-ppp [ interface-number ]: Specifies a virtual PPP interface by its number in the range of 0 to 255. If you specify neither virtual-ppp nor interface-number, this command clears the statistics for all interfaces. If you specify virtual-ppp but not interface-number, this command clears the statistics for all virtual PPP interfaces. If you specify both virtual-ppp and interface-number, this command clears the statistics for the specified virtual PPP interface.
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
# Clear the statistics for Virtual-PPP 10.
<Sysname> reset counters interface virtual-ppp 10
reset l2tp aging
Use reset l2tp aging to clear the locking state of LNSs.
reset l2tp aging [ ip-address [ vpn-instance vpn-instance-name ] ]
ip-address: Specifies an LNS by its IP address. If you do not specify this option, the command clears the locking state of all LNSs.
vpn-instance vpn-instance-name: Specifies a VPN instance to which the specified LNS belongs. The vpn-instance-name argument specifies an MPLS L3VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the L2TP tunnel peer belongs to the public network.
By default, once an LNS is locked after the locking conditions are met, the LNS can be unlocked until the locking period times out. During the locking period, the LAC does not try to establish an L2TP tunnel to the LNS.
Execute this command to manually clear the locking state of an LNS. Then, the LAC can try to establish an L2TP tunnel to this LNS when necessary.
# Clear the locking state of LNS at IP address 1.1.1.2.
<Sysname> reset l2tp aging 1.1.1.2
display l2tp aging
l2tp aging
Use reset l2tp control-packet statistics to clear L2TP protocol packet statistics.
reset l2tp control-packet statistics [ summary | tunnel [ tunnel-id ] ]
summary: Clears summary L2TP protocol packet statistics for all L2TP tunnels.
tunnel [ tunnel-id ]: Specifies L2TP tunnels. The value range for the tunnel-id argument is 1 to 65535. If you specify an L2TP tunnel, this command clears L2TP protocol packet statistics for the specified L2TP tunnel. If you specify only the tunnel keyword, this command clears detailed L2TP protocol packet statistics for all L2TP tunnels.
If you do not specify any keyword or argument, the command clears both summary and detailed L2TP protocol packet statistics for all L2TP tunnels.
# Clear both summary and detailed L2TP protocol packet statistics for all L2TP tunnels.
<Sysname> reset l2tp control-packet statistics
Use reset l2tp packet-limit statistics to clear packet rate limit statistics on the LNS.
# Clear packet rate limit statistics on the LNS.
<Sysname> reset l2tp packet-limit statistics
Use reset l2tp statistics to clear L2TP statistics.
In standalone mode:
reset l2tp statistics { { all | failure-reason | vsrp [ vsrp-instance vsrp-instance-name ] } [ slot slot-number [ cpu cpu-number ] ] }
In IRF mode:
reset l2tp statistics { { all | failure-reason | vsrp [ vsrp-instance vsrp-instance-name ] } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] }
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears entries on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
In a VSRP network, you can clear the L2TP VSRP statistics on both the master and backup devices.
# Clear all L2TP statistics.
<Sysname> reset l2tp statistics all
reset l2tp tunnel
Use reset l2tp tunnel to disconnect tunnels and all sessions within the tunnels.
reset l2tp tunnel [ [ local-address local-address | tunnel-id tunnel-id ] * | tunnel-name remote-name ]
tunnel-id tunnel-id: Specifies a tunnel by its local ID in the range of 1 to 65535.
tunnel-name remote-name: Specifies L2TP tunnels by the tunnel peer name, a case-sensitive string of 1 to 31 characters.
When the number of user connections is 0 or a network fault occurs, you can disconnect the L2TP tunnel by using this command on either the LAC or LNS.
Operating mechanism
After the tunnel is disconnected, all sessions within it are disconnected. A tunnel disconnected by force can be re-established when a client makes a call.
If you specify a tunnel peer name, all tunnels with the tunnel peer name will be disconnected. If no tunnel with the tunnel peer name exists, nothing happens.
If you do not specify any parameter, this command disconnects all L2TP tunnels on the device.
# Disconnect all tunnels with the tunnel peer name of aaa.
<Sysname> reset l2tp tunnel tunnel-name aaa
display l2tp tunnel
shutdown
Use shutdown to shut down a virtual PPP interface.
Use undo shutdown to bring up a virtual PPP interface.
shutdown
A virtual PPP interface is up.
Using this command to shut down a virtual PPP interface will invalidate the L2TP  functions based on the current virtual PPP interface. As a best practice, make sure you know the impact on the network before using this command.
# Shut down Virtual-PPP 10.
[Sysname-Virtual-PPP10] shutdown
snmp-agent trap enable l2tp
Use snmp-agent trap enable l2tp to enable SNMP notifications for L2TP session addition failure.
Use undo snmp-agent trap enable l2tp to disable SNMP notifications for L2TP session addition failure.
snmp-agent trap enable l2tp [ add-session-failed ]
undo snmp-agent trap enable l2tp [ add-session-failed ]
SNMP notifications are disabled for L2TP session addition failure.
add-session-failed: Enables SNMP notifications for L2TP session addition failure.
Operating mechanism
With SNMP notifications enabled for L2TP session addition failure, when an L2TP session fails to be added on the device (for example, because the number of existing L2TP sessions has exceeded the maximum value allowed), traps will be generated. The generated traps are sent to the SNMP module of the device. You can specify how the traps are output through setting the trap output parameters in SNMP. For more information about traps, see SNMP configuration in Network Management and Monitoring Configuration Guide.
Both the snmp-agent trap l2tp command and the snmp-agent trap enable l2tp add-session-failed command can enable SNMP notifications for L2TP session addition failure.
# Enables SNMP notifications for L2TP session addition failure.
[Sysname] snmp-agent trap enable l2tp add-session-failed
source-ip
Use source-ip to configure the source IP address of L2TP tunnel packets.
Use undo source-ip to restore the default.
source-ip ip-address
undo source-ip
The source IP address of L2TP tunnel packets is the IP address of the egress interface.
ip-address: Specifies the source IP address of L2TP tunnel packets.
For high availability, as a best practice, use the IP address of a loopback interface as the source IP address of L2TP tunnel packets.
When L2TP is enabled for a VSRP group, the following rules apply:
·     If both tunnel vsrp source-ip and source-ip commands are configured in L2TP group view, the tunnel vsrp source-ip command takes effect.
·     If only the source-ip command is configured in L2TP group view, an L2TP VSRP failure occurs.
For more information about L2TP VSRP, see High Availability Configuration Guide.
# Configure the source IP address of L2TP tunnel packets as 2.2.2.2.
[Sysname-l2tp1] source-ip 2.2.2.2
tunnel vsrp source-ip (High Availability Command Reference)
Use tunnel authentication to enable L2TP tunnel authentication.
Use undo tunnel authentication to disable L2TP tunnel authentication.
L2TP tunnel authentication is enabled.
Tunnel authentication prevents the local end from establishing L2TP tunnels with illegal remote ends.
Operating mechanism
·     You can enable tunnel authentication on both sides or either side.
·     To ensure a successful tunnel establishment when tunnel authentication is enabled on both sides or either side, set the same non-null key on the LAC and the LNS. To set the tunnel authentication key, use the tunnel password command.
·     When neither side is enabled with tunnel authentication, the key settings of the LAC and the LNS do not affect the tunnel establishment.
Recommended configuration
For tunnel security, enable tunnel authentication.
# Enable L2TP tunnel authentication.
[Sysname-l2tp1] tunnel authentication
tunnel password
tunnel avp-hidden
Use tunnel avp-hidden to enable transferring AVP data in hidden mode.
Use undo tunnel avp-hidden to restore the default.
tunnel avp-hidden
AVP data is transferred over the tunnel in plaintext mode.
L2TP uses AVPs to transmit tunnel negotiation parameters, session negotiation parameters, and user authentication information. This feature can hide sensitive AVP data, such as user passwords. This feature encrypts AVP data with the key configured by using the tunnel password command before transmission.
·     The tunnel avp-hidden command does not take effect on L2TP groups in LNS mode in the current software version.
·     For this command to take effect, you must enable tunnel authentication by using the tunnel authentication command.
# Enable transferring AVP data in hidden mode.
[Sysname-l2tp1] tunnel avp-hidden
tunnel password
tunnel load-sharing
Use tunnel load-sharing to configure a LAC to operate in load sharing mode.
Use undo tunnel load-sharing to restore the default.
tunnel load-sharing
A LAC operates in master/backup mode.
A LAC can operates in master/backup mode or load sharing mode.
·     Master/backup mode—In master/backup mode, when the lns-ip command is executed to configure multiple LNS addresses, the LAC tries to establish a connection to an LNS in the LNS address configuration order until a connection to an LNS is successfully established. The LNS that successfully establishes a connection is called the master LNS, and the other LNSs are backup LNSs. A LAC tries to establish a connection to a backup LNS until the master LNS fails.
·     Load sharing mode—When a single LNS cannot meet large L2TP service requirements, you can configure the LAC to operate in load sharing mode for performance and reliability. In this mode, the LAC distributes the L2TP services among the specified LNSs according to their weights. To configure the LNS weight, specify the weight keyword in the lns-ip command.
# Configure a LAC to operate in load sharing mode.
[Sysname-l2tp1] tunnel load-sharing
lns-ip
tunnel name
Use tunnel name to specify the local tunnel name.
Use undo tunnel name to restore the default.
tunnel name name
undo tunnel name
The local tunnel name is the device name. For more information about the device name, see Fundamentals Configuration Guide.
name: Specifies the local tunnel name, a case-sensitive string of 1 to 31 characters.
# Specify the local tunnel name as itsme.
[Sysname-l2tp1] tunnel name lac
sysname (Fundamentals Command Reference)
tunnel password
Use tunnel password to configure the key for tunnel authentication.
Use undo tunnel password to restore the default.
tunnel password { cipher | simple } string
No key is configured for tunnel authentication.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters.
For the tunnel authentication key change to take effect, change the tunnel authentication key before tunnel negotiation is performed.
# Configure the key for tunnel authentication to a plaintext key yougotit.
[Sysname-l2tp1] tunnel password simple yougotit
tunnel timer hello
Use tunnel timer hello to set the Hello interval.
Use undo tunnel timer hello to restore the default.
tunnel timer hello hello-interval
The Hello interval is 60 seconds.
hello-interval: Specifies the interval at which the LAC or the LNS sends Hello packets, in the range of 60 to 1000 seconds.
The device sends Hello packets at the set interval. This prevents the L2TP tunnels and sessions from being removed due to timeouts.
You can set different Hello intervals for the LNS and LAC.
# Set the Hello interval to 90 seconds.
[Sysname-l2tp1] tunnel timer hello 90
tunnel window receive
Use tunnel window receive to set the receiving window size for an L2TP tunnel.
Use undo tunnel window receive to restore the default.
tunnel window receive size
The receiving window size for an L2TP tunnel is 1024.
size: Specifies the receiving window size in the range of 1 to 5000. It is the number of packets that can be buffered at the local end.
To enable the device to process a larger number of disordered packets, use this command to enlarge the receiving window size for an L2TP tunnel.
The device uses a receiving window to reorder disordered packets based on packet sequence numbers.
If the sequence number of a packet is within the receiving window but does not equal the minimum value of the window, the device performs the following operations:
1.     The device buffers the packet.
2.     The minimum value and maximum value of the receiving window increment by one.
3.     The device continues to check the next arriving packet.
If the sequence number of a packet equals the minimum value of the receiving window, the device performs the following operations:
4.     The device processes the packet.
5.     The minimum value and maximum value of the receiving window increment by one.
6.     The device checks buffered packets for a packet with the sequence number equal to the new minimum value of the receiving window.
7.     If no required packet is found, the device checks the next arriving packet.
If the sequence number of a packet is not within the receiving window, the device drops the packet.
In the L2TP tunnel establishment process, the device uses the value specified in L2TP group view as the receiving window size.
Changing the receiving window size after an L2TP tunnel is established does not affect the established L2TP tunnel.
# Set the receiving window size for L2TP group 1 to 128.
[Sysname-l2tp1] tunnel window receive 128
tunnel window send
tunnel window send
Use tunnel window send to set the sending window size for an L2TP tunnel.
Use undo tunnel window send to restore the default.
tunnel window send size
The sending window size for an L2TP tunnel is 0, which means using the value of the receiving window size carried in messages sent by the peer end in the tunnel establishment process.
size: Specifies the sending window size for an L2TP tunnel, in the range of 0 to 1024. It is the maximum number of packets the device can send to a peer end when the device receives no response from the peer end. If the messages from the peer end carry no receiving window size in the tunnel establishment process, the sending window size for the device is 4.
The packet processing capability of a peer end might mismatch the receiving window size of the peer end in some networks. For example, the actual packet processing capability of the peer end is 10, but the receiving window size of the peer end is 20. To ensure stable L2TP services, you can adjust the sending window size for the device to match the actual packet processing capability of the peer end.
Operating mechanism
The sending window size set in L2TP group view is obtained in the L2TP tunnel establishment process.
·     If the sending window size is 0, the device uses the default sending window size.
·     If the sending window size is not 0, the device uses the specified value as the sending window size.
Changing the sending window size after an L2TP tunnel is established does not affect the established L2TP tunnel.
# Set the sending window size for L2TP group 1 to 128.
[Sysname-l2tp1] tunnel window send 128
tunnel-alarm enable
Use tunnel-alarm enable to enable the L2TP tunnel alarms.
Use undo tunnel-alarm enable to disable L2TP tunnel alarms.
tunnel-alarm enable
L2TP tunnel alarms are enabled.
Operating mechanism
With L2TP tunnel alarms enabled, the device outputs traps when L2TP tunnels come up or go down.
L2TP tunnel alarms are resource-intensive. Before you set up or delete L2TP tunnels, disable L2TP tunnel alarms as a best practice to ensure device performance.
To send the traps to an NMS correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable L2TP tunnel alarms.
[Sysname-l2tp1] tunnel-alarm enable
tunnel-per-user
Use tunnel-per-user to configure each L2TP user to use an L2TP tunnel exclusively.
Use undo tunnel-per-user to restore the default.
tunnel-per-user
An L2TP tunnel can be used by multiple L2TP users.
# Configure each L2TP user to use an L2TP tunnel exclusively on the LAC.
[Sysname] l2tp-group 2 mode lac
[Sysname-l2tp2] tunnel-per-user
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
seconds: Specifies the interval at which the LAC or the LNS sends keepalive packets, in the range of 0 to 32767 seconds.
A virtual PPP interface sends keepalive packets at keepalive intervals to detect the availability of the peer. If the interface fails to receive keepalive packets when the keepalive retry limit is reached, it determines that the link fails and reports a link layer down event.
To set the keepalive retry limit, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 20 seconds for Virtual-PPP 10.
[Sysname-Virtual-PPP10] timer-hold 20
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5.
retries: Specifies the maximum number of keepalive attempts in the range of 1 to 255.
To set the keepalive interval, use the timer-hold command.
On a slow link, increase the keepalive retry limit to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive retry limit to 10 for Virtual-PPP 10.
[Sysname-Virtual-PPP10] timer-hold retry 10
timer-hold
user
Use user to configure the condition for the LAC to initiate tunneling requests.
Use undo user to restore the default.
user { domain domain-name | fullusername user-name }
undo user
No condition is configured for the LAC to initiate tunneling requests.
domain domain-name: Configures the LAC to initiate tunneling requests to the LNS when the domain name of a user matches a configured domain name. The domain-name argument represents the configured domain name and is an case-insensitive string of 1 to 255 characters.
fullusername user-name: Configures the LAC to initiate tunneling requests to the LNS when the username of a user matches a configured full username. The user-name argument represents the configured full username and is a case-sensitive string of 1 to 255 characters.
Operating mechanism
When a user dials to a LAC and passes authentication, the LAC processes the user as follows:
·     If the ISP domain of the dialup user has been configured with an L2TP group by using the l2tp-group command, all users in the ISP domain are considered as L2TP users. After a user passes authentication, the user initiates tunneling requests to the LNS.
·     If the ISP domain of the dialup user is not configured with an L2TP group by using the l2tp-group command, the following rules apply:
¡     The LAC compares the username of the dialup user with the full usernames configured by using the fullusername user-name command for all L2TP groups on the LAC. If the username matches the full username of an L2TP group, the user uses the L2TP group to initiate tunneling requests.
¡     If the username does not match the full username of any L2TP group, the LAC compares the ISP domain name of the dialup user with the domain names configured by using the domain domain-name command for all L2TP groups on the LAC. If the ISP domain name matches the domain name of an L2TP group, the user uses the L2TP group to initiate tunneling requests. If no matching domain name is found, the user cannot initiate tunneling requests.
The ISP domain name is selected in the following order for a dialup user:
1.     AAA-authorized ISP domain name. If the AAA-authorized ISP domain name does not match the domain name of any L2TP group on the LAC, proceed with the following steps.
2.     ISP domain name used in PPP authentication. For how an ISP domain is selected in PPP authentication, see BRAS Services Command Reference.
¡     If the domain name used in PPP authentication is a forced PPP authentication domain name but the domain name does not match the domain name of any L2TP group on the LAC, the following rules apply:
-     If the username carries a domain name, the LAC compares the domain name in the username with the domain names of all L2TP groups on the LAC. If the domain name of an L2TP group is matched, the user uses the L2TP group to initiate tunneling requests.
-     If no match is found, the user cannot initiate tunneling requests.
-     If the username does not carry a domain name, the user cannot initiate tunneling requests.
¡     If the domain name used in PPP authentication is the domain name carried in the username, non-forced PPP authentication domain name, or AAA-authorized domain name, the LAC compares the used domain name with the domain names of all L2TP groups on the LAC.
-     If the used domain name matches the domain name of an L2TP group, the user users the L2TP group to initiate tunneling requests.
-     If the used domain does not match the domain name of any L2TP group, the user cannot initiate tunneling requests.
The domain name and full username of an L2TP group must be unique among all L2TP groups.
If the l2tp-user radius-force command has been executed in the ISP domain of users, a PPP user is considered an L2TP user and processed only when the RADIUS server issues attribute 64 (tunnel-type) to the user and the tunnel type is L2TP. For more information about the l2tp-user radius-force command, see BRAS Services Command Reference. .
If the current device acts as both LAC and LNS, and LNS users need to come online on the current device, make sure the user domain name specified by using the domain domain-name option in the user command is different from the PPP authentication domain name configured for the LNS role. If you cannot do that, for users in the domain specified by using the domain domain-name option, the current device can only act as an LTS, and these users come online on the remote LNS through the LTS. For users in the user domain to come online on the current device, make sure the PPP authentication domain is different from the user domain specified by using the domain domain-name option in the user command.
# Configure the LAC to initiate tunneling requests to the LNS when the username of the user is test@dm1.
[Sysname-l2tp1] user fullusername test@dm1
l2tp-user radius-force (BRAS Services Command Reference)
ppp authentication-mode (BRAS Services Command Reference)
vpn-instance
Use vpn-instance to assign a tunnel peer to a VPN.
Use undo vpn-instance to restore the default.
undo vpn-instance
A tunnel peer belongs to the public network.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
Operating mechanism
This command enables the device to transmit L2TP control messages and data messages in the specified VPN by searching the routing table in that VPN.
When one L2TP endpoint is in a VPN, assign the peer endpoint to the VPN for correct packet forwarding between the two endpoints.
The tunnel peer and the physical port connecting to the tunnel peer should belong to the same VPN. The VPN to which this physical port belongs is configured by using the ip binding vpn-instance command.
The specified VPN must already exist.
# Assign the tunnel peer to VPN vpn1.
<Sysname>system-view
[Sysname-l2tp1] vpn-instance vpn1
ip vpn-instance (MPLS Command Reference)
ip binding vpn-instance (MPLS Command Reference)
