- 14-High Availability Configuration Guide
- 01-Ethernet OAM configuration
- 02-CFD configuration
- 03-DLDP configuration
- 04-Monitor Link configuration
- 05-S-Trunk configuration
- 06-Error code detection configuration
- 07-VRRP configuration
- 08-VSRP configuration
- 09-Failover group configuration
- 10-Service instance group configuration
- 11-BFD configuration
- 12-Track configuration
- 13-Process placement configuration
| 10-Service instance group configuration | 51.93 KB |
Configuring service instance groups
Restrictions and guidelines: Service instance group configuration
Configuring a service instance group
Display and maintenance commands for service instance groups
About service instance groups
Associated with a failover group, a service instance group helps back up service data for specific service modules (such as NAT), and guarantee correct operation of specific services.
For inter-system service backup, you can associate a service instance group with only one failover group. The nodes in the failover group must belong to different systems.
For intra-system service backup, you can associate a service instance group with one or multiple failover groups. The nodes in the failover groups must belong to the same system.
· If you associate a service instance group with one failover group, the nodes in the failover group perform NAT service backup globally.
· If you associate a service instance group with multiple failover groups, NAT service backup loads are distributed among the failover groups. Each failover group also backs up services between its nodes. You can associate a service instance group with a maximum of four failover groups.
For more information about failover groups, see "Configuring failover groups."
You can associate a service instance group with multiple failover groups. You cannot use a service instance group for both inter-system and intra-system service backup. The failover groups associated with the service instance group must be the same type, default, iSec, or WAAS.
You cannot associate a service instance group with multiple failover groups if the service instance group has been associated with a NAT instance that has one of the following settings:
· Address ranges configured by using the address command for a NAT address group that provides the outbound dynamic NAT service.
· NO-PAT.
· Static NAT.
· Global NAT address group that has multiple NAT instance associations.
· NAT server mapping that maps one public IP address to multiple private IP addresses.
After specifying a service instance group for a service module, you are not allowed to perform the following operations:
· Delete the service instance group.
· Cancel the association between the service instance group and failover group.
1. Enter system view.
2. Create a service instance group and enter its view.
service-instance-group service-instance-group-name [ type { default | isec | waas } ]
3. Associate a failover group with the service instance group.
failover-group failover-group-name
By default, a service instance group is not associated with any failover groups.
Task |
Command |
Display service instance group information. |
display service-instance-group [ service-instance-group-name ] |
