14-High Availability Configuration Guide
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-X Routers Configuration Guides-R8630Pxx-6W10014-High Availability Configuration Guide
08-VSRP configuration
08-VSRP configuration 1.39 MB
Configuring VSRP·· 1
About VSRP· 1
Basic concepts· 1
VSRP operating mechanism·· 1
VSRP backup modes· 2
VSRP control channel fast detection· 3
Restrictions and guidelines: Subinterface configuration consistency· 3
VSRP tasks at a glance· 3
Prerequisites for VSRP· 4
Configuring a VSRP group· 4
Configuring a VSRP instance· 5
Specifying a virtual IPv6 address· 6
Enabling VSRP logging· 7
Enabling SNMP notifications for VSRP· 7
Setting up protection tunnels· 7
Configuring VSRP for BRAS services (IPoE/PPPoE) 8
About VSRP for BRAS services· 8
Restrictions and guidelines for configuring VSRP for IPoE· 8
Associating a BRAS service-enabled interface with a VSRP instance· 9
Specifying the TCP port number for establishing BRAS service backup data channels· 9
Associating an interface used for UP backup with a VSRP instance· 10
Configuring VSRP for L2TP· 10
About VSRP for L2TP· 10
Restrictions and guidelines for configuring VSRP for L2TP· 10
Prerequisites for configuring VSRP for L2TP· 11
Associating an L2TP group with a VSRP instance· 11
Specifying the source address for an L2TP tunnel 11
Specifying an L2TP tunnel ID range· 12
Specifying the TCP port number for establishing L2TP service backup data channels· 12
Configuring VSRP for ARP· 13
About VSRP for ARP· 13
Restrictions and guidelines for configuring VSRP for ARP· 13
Enabling VSRP for ARP· 13
Specifying the TCP port number for establishing ARP service backup data channels· 14
Configuring VSRP for ND·· 14
About VSRP for ND·· 14
Restrictions and guidelines for configuring VSRP for ND·· 14
Enabling VSRP for ND·· 15
Specifying the TCP port number for establishing ND service backup data channels· 15
Configuring VSRP for DHCPv4 server 16
About VSRP for DHCPv4 server 16
Restrictions and guidelines for configuring VSRP for DHCPv4 server 16
Associating an IPv4 address pool with a VSRP instance· 16
Associating a client-side interface with a VSRP instance· 16
Specifying the TCP port number for establishing DHCPv4 server service backup data channels· 17
Configuring VSRP for DHCPv6 server 17
About VSRP for DHCPv6 server 17
Restrictions and guidelines for configuring VSRP for an IPv6 address pool 18
Associating an IPv6 address pool with a VSRP instance· 18
Associating a client-side interface with a VSRP instance· 18
Specifying the TCP port number for establishing DHCPv6 server service backup data channels· 19
Configuring VSRP for DHCPv4 relay· 19
About VSRP for DHCPv4 relay agent 19
Restrictions and guidelines for configuring VSRP for DHCPv4 relay agent 19
Associating a DHCPv4 client-side interface with a VSRP instance· 20
Specifying the TCP port number for establishing DHCPv4 relay service backup data channels· 20
Configuring VSRP for DHCPv6 relay· 20
About VSRP for DHCPv6 relay· 20
Restrictions and guidelines for configuring VSRP for DHCPv6 relay agent 21
Associating a DHCPv6 client-side interface with a VSRP instance· 21
Specifying the TCP port number for establishing DHCPv6 relay service backup data channels· 21
Configuring VSRP for IGMP· 21
About VSRP for IGMP· 21
Associating an IGMP-enabled interface with a VSRP instance· 22
Enabling VSRP load sharing on an IGMP-enabled interface· 22
Specifying the TCP port number for establishing IGMP service backup data channels· 23
Enabling IGMP data synchronization· 23
Configuring VSRP for MLD·· 24
About VSRP for MLD·· 24
Associating an MLD-enabled interface with a VSRP instance· 24
Enabling VSRP load sharing on an MLD-enabled interface· 24
Specifying a TCP port number for establishing MLD service backup data channels· 25
Enabling MLD data synchronization· 26
Display and maintenance commands for VSRP· 26
VSRP configuration examples· 26
Example: Configuring VSRP for IPoE (IPv4 address pool) 26
Example: Configuring VSRP for IPoE (IPv6 address pool) 34
Example: Configuring VSRP for dual-stack IPoE (IPv4 and IPv6 address pools) 43
Example: Configuring VSRP for PPPoE (PPP address pool) 56
Example: Configuring VSRP for PPPoE (NDRA one prefix per user) 62
Example: Configuring VSRP for dual-stack PPPoE (IPv4 address pool and NDRA one prefix per user) 71
Example: Configuring VSRP for dual-stack PPPoE (IPv4 address pool and IPv6 address pool for a VPN instance) 83
Example: Configuring VSRP for L2TP· 95
Example: Configuring VSRP and VRRP collaboration for ARP· 101
Example: Configuring VSRP and S-Trunk collaboration for ARP· 107
Example: Configuring VSRP and VRRP collaboration for ND·· 111
Example: Configuring VSRP and S-Trunk collaboration for ND·· 116
Example: Configuring VSRP for IGMP· 120
Example: Configuring VSRP load sharing on an IGMP-enabled interface· 124
Example: Configuring VSRP for MLD·· 128
Example: Configuring VSRP load sharing on an MLD-enabled interface· 132
Configuring VSRP
About VSRP
Virtual Service Redundancy Protocol (VSRP) provides unified device-level backup for multiple user services between two devices operating in master/backup mode.
When the master and backup devices are operating correctly, VSRP backs up user data of service modules from the master device to the backup device. When the master device or its link fails, the user services can be fast switched to the backup device. When the original master device or its link is recovered, the user services fall back to the original master device to ensure service continuity.
Basic concepts
VSRP includes the following components:
·     VSRP group—A VSRP group contains two peer devices that are enabled with VSRP.
·     VSRP peer—The member devices in a VSRP group are the peer of each other, with one as master and the other as backup. You must configure the peer IP address on each device to create a VSRP group.
·     VSRP instance—A VSRP instance is associated with one service to back up service data from the master to the backup for service continuity.
·     VSRP control channel and data channel—The VSRP peers in a VSRP group synchronize VSRP instance state information and service data by establishing TCP control and data channels.
¡     Control channel—The master backs up the status of all VSRP instances on the VSRP group to the backup in real time over the control channel.
¡     Data channel—VSRP establishes a data channel to back up data in real time for each service associated with a VSRP instance on the VSRP group. This backup mechanism ensures that the backup device takes over the services when the master fails.
Both TCP control and data channels are initiated by the peer with lower IP address to the peer with higher IP address.
A VSRP group contains two peer devices that are enabled with VSRP. VSRP collaborates with VRRP or S-Trunk to determine the role of each peer device in a VSRP group as master or backup.
VSRP is typically used on a network that contains broadband remote access servers (BRASs). To ensure service continuity, the master BRAS backs up authentication, accounting, and management information to the backup BRAS in real time.
VRRP collaboration
As shown in Figure 1, VSRP determines the roles of the peer devices in the VSRP group in consistent with their roles in the VRRP group. The master forwards traffic and backs up the services to the backup device either at a regular interval or when traffic reaches the specified threshold. When the master in the VSRP group fails, the backup takes over to ensure service continuity. For more information about VRRP, see "Configuring VRRP."
Figure 1 VSRP-VRRP collaboration
To use S-Trunk together with VSRP, you must configure the same smart trunk on the peers in a VSRP group. As shown in Figure 2, VSRP determines the roles of the peer devices in the VSRP group based on their roles in the S-Trunk system. The VSRP master is the primary S-Trunk member device, and the VSRP backup is the secondary S-Trunk member device. The master forwards traffic and backs up the services to the backup device. When the master in the VSRP group fails, the backup takes over to ensure service continuity. For more information about S-Trunk, see "Configuring S-Trunk."
Figure 2 VSRP-S-Trunk collaboration
VSRP backup modes
A VSRP instance supports the following backup modes:
·     Cold backup mode—In cold backup mode, two devices deployed with VSRP provide only device-level service redundancy. Service data is backed up between the master and backup devices. When a switchover occurs, the new master device might experience a temporary service interruption due to the lack of service data. This mode is applicable to the scenarios that are not sensitive to temporary service interruptions.
·     Hot backup mode (1:1 backup)—The backup device issues backup data to the data plane as soon as it receives the data from the master. In this mode, the backup takes over quickly when the master fails. This mode is applicable to scenarios where a device acts as the backup in only one VSRP group.
VSRP provides the following hot backup modes:
¡     Dual-active hot backup mode—Both the master and backup devices are active to load share traffic.
¡     Single-active hot backup mode—The master device is active to process service traffic, and the backup device takes over when the master device fails.
·     Warm backup mode (N:1 backup)—One backup device backs up multiple master devices. The backup device issues received backup data to the data plane when a master fails. This mode has a longer failover delay than hot backup mode. This mode is applicable to scenarios where a device acts as the backup in more than one VSRP group.
By default, a VSRP group detects the state of the failover link based only on the state of the TCP control channel. To fast detect the state of the failover link, you can perform the following tasks:
1.     Use NQA or BFD to monitor the state of the failover link.
2.     Establish the collaboration between the failover link state and NQA or BFD through the Track function.
A VSRP group operates differently depending on the state of the track entry associated with the VSRP group:
·     When the track entry is in Positive or NotReady state, a device attempts to establish a TCP control channel with its peer.
·     When the track entry changes to Negative state, the device terminates the TCP control channel.
As a best practice to maintain data consistency, make sure the peer devices in a VSRP group have consistent main interface and subinterface configuration, including but not limited to the following settings:
·     Subinterface numbers.
·     VLAN configuration.
·     VPN configuration.
To configure VSRP, perform the following tasks:
1.     Configuring a VSRP group
2.     Configuring a VSRP instance
3.     Specifying a virtual IPv6 address
This task is required if you enable VSRP for IPoE or DHCPv6 on an IPv6 network.
4.     (Optional.) Enabling VSRP logging
5.     (Optional.) Enabling SNMP notifications for VSRP
6.     Setting up protection tunnels
7.     Configuring VSRP for a service module
¡     Configuring VSRP for BRAS services (IPoE/PPPoE)
¡     Configuring VSRP for L2TP
¡     Configuring VSRP for ARP
¡     Configuring VSRP for ND
¡     Configuring VSRP for DHCPv4 server
¡     Configuring VSRP for DHCPv6 server
¡     Configuring VSRP for DHCPv4 relay
¡     Configuring VSRP for DHCPv6 relay
¡     Configuring VSRP for IGMP
¡     Configuring VSRP for MLD
Perform the following tasks on the two peer devices in a VSRP group:
1.     For VSRP to collaborate with VRRP, configure VRRP to operate in standard mode.
2.     For VSRP to collaborate with VRRP, configure a VRRP group on the two peer devices to determine their role in the VSRP group.
3.     For VSRP to collaborate with S-Trunk, configure a smart trunk on the two peer devices to determine their role in the VSRP group. Make sure the primary and secondary member interfaces of the smart trunk are on the desired VSRP master and backup, respectively.
Binding a VSRP group or smart trunk to an existing VRRP group does not affect the functionality of the VRRP group or smart trunk.
2.     Create a VSRP group and enter the VSRP peer view.
vsrp peer peer-name
3.     Configure TCP connection parameters for establishing VSRP channels to the peer.
peer [ ipv6 ] peer-ip-address local local-ip-address [ port port-id ]
By default, no VSRP channels are established to the peer.
The TCP port cannot be in use. To view the TCP port numbers in use, execute the display [ ipv6 ] tcp command.
4.     (Optional.) Associate a VSRP group with a track entry.
track track-entry-number
A VSRP instance backs up data for its associated service.
A VSRP instance can be bound to only one VSRP group. Each VSRP instance on a VSRP group is identified by a unique backup ID.
The master forwards traffic and backs up service data to the backup device at the specified interval or when the specified traffic threshold is reached.
An IPoE or PPPoE network requires an address pool to be created on the master and backup of a VSRP instance and route advertisement for subnets of the address pool. By default, only the master advertises the subnet routes, and network devices reach terminal users only through the master. If the master fails or is disconnected, communication with the terminal users is interrupted before the backup takes over.
You can enable route advertisement for the backup to reduce the service outage. After you configure this feature, the network devices have two routes to reach a terminal user, and the route advertised by the master has a smaller route cost. When both the master and the backup are available, the network devices access terminal users through the master. When the master becomes unavailable, the network devices look up the routing table and use the routes advertised by the backup to reach terminal users.
The NAS parameters (IP address, interface, and host name) on a VSRP instance are shared by the VSRP member devices for the associated service. Configure NAS settings on a VSRP instance if its associated service requires the NAS parameters to remain unchanged after a master/backup switchover. For example, the settings are applicable to the following scenarios:
·     Avoid re-authentication on master/backup switchover by maintaining the same NAS-IP-address, NAS-Port, and host name in packets sent to the RADIUS server.
·     Maintain the same Option 82 values in packets sent to the DHCP server.
2.     Create a VSRP instance and enter VSRP instance view.
vsrp instance instance-name
3.     Specify a backup ID for the VSRP instance.
backup id backup-id peer peer-name
By default, a VSRP instance has no ID.
4.     Configure collaboration of the VSRP instance with a module for VSRP role assignment. Choose one option as needed:
¡     Bind the VSRP instance to a VRRP group. Choose one option as needed:
-     Bind the VSRP instance to an IPv4 VRRP group.
bind vrrp vrid virtual-router-id interface interface-type interface-number
By default, a VSRP instance is not bound to an IPv4 VRRP group.
-     Bind the VSRP instance to an IPv6 VRRP group.
bind vrrp ipv6 vrid virtual-router-id interface interface-type interface-number
By default, a VSRP instance is not bound to an IPv6 VRRP group.
¡     Bind the VSRP instance to a smart trunk member interface.
bind s-trunk s-trunk-id interface route-aggregation interface-number
By default, a VSRP instance is not bound to any smart trunk member interface.
If you execute the following commands multiple times for a VSRP instance, the most recent configuration takes effect:
¡     bind s-trunk
¡     bind vrrp ipv6 vrid
¡     bind vrrp vrid
5.     Set the backup mode of the VSRP instance.
backup mode { cold | hot [ dual-active ] | warm }
By default, a VSRP instance operates in hot backup mode.
6.     (Optional.) Set a traffic backup interval or a traffic threshold that triggers a traffic backup.
traffic backup { interval interval-value | threshold threshold-value } *
By default, a VSRP instance backs up traffic at 10-minute intervals or when the traffic reaches 50 MB.
7.     (Optional.) Enable route advertisement for the backup.
backup route-advertise [ master-cost master-cost backup-cost backup-cost ]
By default, route advertisement is enabled only for the master.
8.     (Optional.) Configure NAS parameters.
nas { id host-name | ip ip-address | port interface-type interface-number }
By default, no NAS parameters are configured.
To enable VSRP for IPv6 services (such as IPoE and DHCPv6), you must specify a virtual IPv6 address for the service-enabled interface. This is applicable to some special networks, such as a network that contains BRAS devices. In a VSRP instance, you must configure the same virtual IPv6 address on the master and the backup. Then, the master advertises the virtual IPv6 address as the gateway address in RA messages to the hosts. In this way, traffic from the hosts can be directed to the master.
2.     Enter interface view.
The following types of interfaces are supported:
¡     Layer 3 Ethernet interface.
¡     Layer 3 Ethernet subinterface.
¡     Layer 3 aggregate interface.
¡     Layer 3 aggregate subinterface.
¡     Layer 3 FlexE logical interface.
3.     Specify a virtual IPv6 address for the interface that is associated with a VSRP instance.
ipv6 virtual-address ipv6-address vsrp vsrp-instance
By default, no virtual IPv6 address is specified for the interface.
If logging is enabled for VSRP, a log messages generated after an important event occurs, such as VSRP connection setup, abnormal VSRP connection, or VSRP instance status switchover.
The VSRP logging feature sends log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about information center, see Network Management and Monitoring Configuration Guide.
2.     Enable VSRP logging.
vsrp log enable
By default, VSRP logging is disabled.
If SNMP notifications are enabled for VSRP, a notification is sent to the SNMP module after an important event occurs, such as VSRP connection setup, abnormal VSRP connection, or VSRP instance status switchover.
For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for VSRP.
snmp-agent trap enable vsrp
By default, SNMP notifications are enabled for VSRP.
To ensure service continuity when the access-side link of the master fails, the master forwards the traffic sent from the external network to users towards the backup over a protection tunnel. The backup then forwards the traffic to the destination.
The master and the backup set up protection tunnels for the public instance and each VPN instance. The protection tunnel for the public instance is set up after you finish protection tunnel configuration, while the protection tunnel for a VPN instance is set up on demand.
VSRP supports the following LSP and SRv6 protection tunnels:
·     SR TE tunnels. For more information, see SR-MPLS TE policy configuration in Segment Routing Configuration Guide.
·     SRv6 BE tunnels. For more information, see SRv6 VPN configuration in Segment Routing Configuration Guide.
2.     Create a VSRP group and enter VSRP peer view.
vsrp peer peer-name
3.     Configure protection tunnels. Choose one of the following methods:
¡     Specify the destination address of LSP protection tunnels.
protect lsp-tunnel for-all-instance peer-ip ip-address [ tunnel-policy policy-name ]
By default, no LSP protection tunnel destination address is configured.
¡     Specify a locator for SRv6 protection tunnels.
protect srv6-tunnel for-all-instance locator locator-name
By default, no SRv6 protection tunnels exist.
To back up BRAS services on an interface, associate that interface with a VSRP instance.
·     This feature applies only to IPoE and PPPoE.
·     You must associate the peer IPoE-enabled interfaces on the master and the backup with the same VSRP instance.
·     If you configure VLAN termination on the subinterfaces on the master and backup, make sure the subinterfaces terminate the same VLAN IDs.
·     On a device, you cannot associate multiple interfaces with the same VSRP instance. You can associate subinterfaces of an interface with the same or different VSRP instances.
·     On an interface, before configuring or removing a VSRP instance association, first clear all online IPoE and PPPoE users to go offline.
·     To modify the VSRP instance association of an interface, first use the undo bras vsrp-instance command to remove the existing VSRP instance association.
·     If BRAS users use address pools, you must associate the address pools with the same VSRP instance used by BRAS services.
·     For static individual users to access the network, make sure you configure the same static IPoE sessions on the master and backup.
·     You must configure the same IP address pool on the master and backup. Make sure the BRAS users obtain the same gateway address after a master and backup switchover.
·     An address pool can belong to only one VSRP instance. VSRP instances cannot share an address pool.
·     For IPoE services to operate correctly, make sure the BRAS settings (for example, IPoE authentication method, authentication domain, and IP address pool) are consistent on the master and backup interfaces.
3.     Associate the interface with a VSRP instance.
bras vsrp-instance instance-name
By default, a BRAS service-enabled interface is not associated with a VSRP instance.
To back up the BRAS services on an interface, the master and the backup must establish a TCP data channel. You can change the TCP port number for establishing the data channel.
To establish BRAS service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
The specified port number cannot be a TCP port number in use.
2.     Specify a TCP port number for VSRP to establish data channels for BRAS service backup.
bras vsrp-port port-number
The default TCP port number is 60045.
If you associate an interface used for UP backup with a VSRP instance, the VSRP device roles are determined based on the role of that interface in the related UP backup profile.
·     If the interface is a master interface, the device that owns the interface is the master in the VSRP instance.
·     If the interface is a backup interface, the device that owns the interface is the backup in the VSRP instance.
For more information about interfaces for UP backup, see BRAS Services Command Reference.
·     bind vrrp ipv6 vrid
·     bind vrrp vrid
3.     Associate an interface used for UP backup with the VSRP instance.
bind interface interface-type interface-number
By default, an interface used for UP backup is not associated with a VSRP instance.
If you specify an interface that is not included in any UP backup profile, the VSRP instance is in down state and cannot operate correctly.
About VSRP for L2TP
You can use VSRP to back up L2TP tunnels and sessions from a master LAC to a backup LAC by associating a LAC-mode L2TP group with a VSRP instance.
When the master LAC fails, the backup takes over the L2TP services to ensure service continuity.
VSRP is available only for LAC that provides access for PPPoE clients in the NAS-Initiated mode. To use VSRP for L2TP, you must also configure VSRP for PPPoE server on the LACs. For more information, see "Configuring VSRP for BRAS services (IPoE/PPPoE) ." For more information about the NAS-Initiated mode, see L2TP in BRAS Service Configuration Guide.
If VSRP is configured for L2TP, a tunnel can be established on an LAC only by creating an L2TP group. The RADIUS server cannot issue tunnel attributes to the LAC directly to create a tunnel.
Before you enable VSRP for L2TP, configure L2TP on the master LAC, the backup LAC, and the LNS for the LACs to establish L2TP tunnels with the LNS. Make sure the LACs have the same L2TP settings. For more information about configuring L2TP, see BRAS Service Configuration Guide.
·     You must associate the peer L2TP groups on the master and backup LACs with the same VSRP instance.
·     Associating an L2TP group with a VSRP instance will remove the existing L2TP tunnels in the L2TP group.
·     You cannot change or remove the association between an L2TP group and a VSRP instance when an L2TP tunnel exists in the L2TP group.
2.     Enter L2TP group view in LAC mode.
l2tp-group group-number [ mode lac ]
3.     Associate the L2TP group with a VSRP instance.
vsrp-instance vsrp-instance-name
By default, an L2TP group is not associated with a VSRP instance.
You must specify the same L2TP tunnel source address on the master and backup LACs. This source address is used as the source address of tunneled packets. With the L2TP tunnel source address specified, the master LAC generates a static route to the source address. The static route has the loopback interface as the output interface.
After a master and backup switchover, the original master deletes the static route and uses a dynamic routing protocol to advertise the route deletion. Meanwhile, the new master generates a static route to the tunnel source address and uses a dynamic routing protocol to advertise the route. In this way, the traffic from the LNS can be automatically switched to the new master LAC. The LNS considers that the original L2TP tunnel remains established.
·     The tunnel source address can be the loopback interface address with a 32-bit mask. However, it cannot be the IP address of any physical port on either device in the VSRP instance. Moreover, the tunnel source address cannot conflict with any IP address on the network.
·     As a best practice, specify different L2TP tunnel source addresses for the L2TP tunnels in different L2TP groups.
·     To specify an L2TP tunnel source address, you must associate the corresponding L2TP group with a VSRP instance first.
·     You cannot change or remove the specified tunnel source address for the existing L2TP tunnel in an L2TP group.
·     When you enable VSRP for L2TP, the tunnel source address specified by the tunnel vsrp source-ip command rather than that specified by the source-ip command takes effect. If you configure the source-ip command but do not configure the tunnel vsrp source-ip command, VSRP for L2TP cannot operate correctly. For more information about the source-ip command, see BRAS Service Command Reference.
3.     Specify the source IP address for the L2TP tunnel.
tunnel vsrp source-ip ip-address
By default, the source IP address of the L2TP tunnel is the IP address of the local tunnel interface.
To avoid tunnel ID conflicts after a master/backup switchover, you must specify different L2TP tunnel ID ranges on the peer LACs in the following scenario:
You assign the peer LACs to two VSRP instances with their roles exchanged for load sharing purposes. For example, use LAC 1 as the master and LAC 2 as the backup in VSRP instance 1. Use LAC 2 as the master and LAC 1 as the backup in VSRP instance 2.
You cannot change the L2TP tunnel ID range for an LAC when it has an L2TP tunnel.
2.     Specify an L2TP tunnel ID range.
l2tp tunnel id low-id high-id
By default, the L2TP tunnel ID range is 1 to 65535.
VSRP uses the data channels for BRAS service backup to back up L2TP services. To back up L2TP services, the master and the backup must first establish a TCP data channel for BRAS services. You can change the TCP port number for establishing the data channel.
To establish L2TP service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
2.     Specify a TCP port number for VSRP to establish data channels for L2TP service backup.
l2tp vsrp-port port-number
The default TCP port number is 60036.
About VSRP for ARP
This feature enables the master to back up the ARP entries to the backup to ensure ARP entry consistency. When the master fails or its links fail, the backup can take over to forward traffic immediately without traffic loss.
·     You must associate the peer interfaces on the master and backup access devices with the same VSRP instance.
·     If you configure VLAN termination on the subinterfaces on the master and backup access devices, make sure the peer subinterfaces terminate the same VLAN IDs.
·     You cannot associate different interfaces on a device with the same VSRP instance.
·     You can associate different subinterfaces of an interface with the same VSRP instance or with different VSRP instances.
·     On a subinterface, the VSRP instance association configured in subinterface view takes precedence over the one configured by using the arp vsrp-instance apply sub-interface command.
To associate a main interface and its subinterfaces with the same VSRP instance, you can use the arp vsrp-instance apply sub-interface command on the main interface to simplify configuration.
¡     Layer 3 FlexE interface.
¡     L3VE interface.
¡     L3VE subinterface.
3.     Associate ARP with a VSRP instance.
arp vsrp-instance vsrp-instance-name [ apply sub-interface ]
By default, ARP is not associated with any VSRP instance on an interface.
To back up ARP entries, the master must establish a TCP data channel with the backup. You can use this command to change the TCP port number for establishing the data channel.
To establish ARP service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
2.     Specify a TCP port number for VSRP to establish ARP service backup data channels.
arp vsrp-port port-number
The default TCP port number is 60043.
About VSRP for ND
This feature enables the master to back up the ND entries of an interface to the backup in real time through the data channel of VSRP. When the master fails or its links fail, the backup can take over to forward traffic immediately without traffic loss.
To associate a main interface and its subinterfaces with the same VSRP instance, you can use the ipv6 nd vsrp-instance apply sub-interface command on the main interface to simplify configuration.
·     Before you execute the ipv6 nd vsrp-instance apply sub-interface command on a main interface, make sure no VSRP instance association exists on the main interface or its subinterfaces. If ND already has a VSRP instance association on a main interface, you cannot associate ND with other VSRP instances on the subinterfaces of the main interface. Before you associate ND with a VSRP instance on a subinterface, make sure no VSRP instance association for ND exists on the main interface.
·     To modify the VSRP instance association for ND on an interface, first remove the existing association.
¡     L3VE interface.
3.     Associate ND with a VSRP instance.
ipv6 nd vsrp-instance vsrp-instance-name [ apply sub-interface ]
By default, ND is not associated with any VSRP instance on an interface.
To back up ND entries, the master must establish a TCP data channel with the backup. You can use this command to change the TCP port number for establishing the data channel.
To establish ND service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
2.     Specify a TCP port number for VSRP to establish ND service backup data channels.
ipv6 nd vsrp-port port-number
The default TCP port number is 60044.
You can use VSRP to back up the address assignment data for an IPv4 address pool by associating that address pool with a VSRP instance.
If the peer client-side interfaces on the master and backup DHCPv4 servers have different interface names, you must also associate the interfaces with the same VSRP instance. The peer client-side interfaces are client-side interfaces that connect the master and backup DHCPv4 servers to the same subnet.
When the VSRP instance state is Master, the DHCPv4 server to which the IPv4 address pool belongs is the master device. When the VSRP instance state is Backup, the DHCPv4 server to which the IPv4 address pool belongs is the backup device.
In a VSRP group, the master DHCPv4 server assigns IP addresses together with other configuration parameters to DHCPv4 clients. The backup DHCPv4 server only receives the address pool data backed up from the master DHCPv4 server. The IPv4 address pool data includes lease bindings and conflicting IP addresses. For more information about DHCPv4, see Layer 3—IP Services Configuration Guide.
VSRP for DHCPv4 server service is typically used in BRAS scenarios in which the master DHCPv4 server assigns IP addresses and other configuration parameters to IPoE or PPPoE users.
VSRP for DHCPv4 server does not support the cold backup mode. If you configure the cold backup mode, VSRP for DHCPv4 server operates in hot backup mode.
2.     Create an IPv4 address pool and enter its view.
ip pool pool-name
3.     Associate the address pool with a VSRP instance.
By default, an IPv4 address pool is not associated with any VSRP instance.
If the peer client-side interfaces on the master and backup DHCPv4 servers have different interface names, you must also associate the interfaces to the same VSRP instance.
This configuration is not required if the peer client-side interfaces have the same interface name.
dhcp vsrp-instance vsrp-instance-name
By default, a DHCPv4 client-side interface is not associated with a VSRP instance.
To back up address assignment data for an IPv4 address pool, the master DHCPv4 server must establish a data channel with the backup DHCPv4 server. You can change the port number for establishing the data channel.
To establish DHCPv4 server service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
2.     Specify a TCP port number for VSRP to establish DHCPv4 server service backup data channels.
dhcp vsrp port port-number
The default TCP port number is 60037.
You can use VSRP to back up the address assignment data for an IPv6 address pool by associating that address pool with a VSRP instance.
If the peer client-side interfaces on the master and backup DHCPv6 servers have different interface names, you must also associate the interfaces with the same VSRP instance. The peer client-side interfaces are client-side interfaces that connect the master and backup DHCPv6 servers to the same subnet.
When the VSRP instance state is Master, the DHCPv6 server to which the IPv6 address pool belongs is the master device. When the VSRP instance state is Backup, the DHCPv6 server to which the IPv6 address pool belongs is the backup device.
In a VSRP group, the master DHCPv6 server assigns IP addresses together with other configuration parameters to DHCPv6 clients. The backup DHCPv6 server only receives the address pool data backed up from the master DHCPv6 server. The IPv6 address pool data includes lease bindings and conflicting IP addresses. For more information about DHCPv6, see Layer 3—IP Services Configuration Guide.
VSRP for DHCPv6 server service is typically used in BRAS scenarios in which the master DHCPv6 server assigns IP addresses and other configuration parameters to IPoE or PPPoE users.
For DHCPv6 clients to correctly renew leases or release IPv6 addresses after a switchover, use the virtual-duid command to generate the same virtual DUID for the master and the backup.
VSRP for DHCPv6 server does not support the cold backup mode. If you configure the cold backup mode, VSRP for DHCPv6 server operates in hot backup mode.
2.     Create an IPv6 address pool and enter its view.
ipv6 pool pool-name
By default, an IPv6 address pool is not associated with a VSRP instance.
4.     Specify a virtual DUID for the DHCPv6 server.
virtual-duid { enterprise-number enterprise-number identifier identifier | hardware-type hardware-type address address }
By default, no virtual DUID is specified for a DHCPv6 server. The DHCPv6 server uses its real DUID.
If the peer client-side interfaces on the master and backup DHCPv6 servers have different interface names, you must also associate the interfaces to the same VSRP instance.
ipv6 dhcp vsrp-instance vsrp-instance-name
By default, a DHCPv6 client-side interface is not associated with a VSRP instance.
To back up address assignment data for an IPv6 address pool, the master DHCPv6 server must establish a data channel with the backup DHCPv6 server. You can change the port number for establishing the data channel.
To establish DHCPv6 server service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
2.     Specify a TCP port number for VSRP to establish DHCPv6 server service backup data channels.
ipv6 dhcp vsrp port port-number
The default TCP port number is 60039.
You can use VSRP to back up the relay entries for a client-side interface on a DHCPv4 relay agent by associating that interface with a VSRP instance. For more information about DHCPv4 relay agent, see Layer 3—IP Services Configuration Guide.
In a VSRP group, the master DHCPv4 relay agent provides DHCP relay services for DHCPv4 clients. The backup DHCPv4 relay agent only receives the relay entries backed up from the master DHCPv4 relay agent.
VSRP for DHCPv4 relay agent is typically used in BRAS scenarios in which the master DHCPv4 relay agent relays IP addresses and other configuration parameters to IPoE or PPPoE users.
VSRP for DHCPv4 relay agent does not support the cold backup mode. If you configure the cold backup mode, VSRP for DHCPv4 relay agent operates in hot backup mode.
dhcp relay vsrp-instance vsrp-instance-name
To back up relay entries for a client-side interface, the master DHCPv4 relay agent must establish a data channel with the backup DHCPv4 relay agent. You can change the port number for establishing the data channel.
To establish DHCPv4 relay service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
2.     Specify a TCP port number for VSRP to establish DHCPv4 relay service backup data channels.
You can use VSRP to back up the relay entries for a client-side interface on a DHCPv6 relay agent by associating that interface with a VSRP instance. For more information about DHCPv6 relay agent, see Layer 3—IP Services Configuration Guide.
In a VSRP group, the master DHCPv6 relay agent provides DHCP relay services for DHCPv6 clients. The backup DHCPv6 relay agent only receives the relay entries backed up from the master DHCPv6 relay agent.
VSRP for DHCPv6 relay agent is typically used in BRAS scenarios in which the master DHCPv6 relay agent relays IP addresses and other configuration parameters to IPoE or PPPoE users.
VSRP for DHCPv6 relay agent does not support the cold backup mode. If you configure the cold backup mode, VSRP for DHCPv6 relay agent operates in hot backup mode.
ipv6 dhcp relay vsrp-instance vsrp-instance-name
To back up relay entries for a client-side interface, the master DHCPv6 relay agent must establish a data channel with the backup DHCPv6 relay agent. You can change the port number for establishing the data channel.
2.     Specify a TCP port number for VSRP to establish DHCPv6 relay service backup data channels.
About VSRP for IGMP
You can use VSRP to back up the multicast service on an IGMP-enabled interface by associating that interface with a VSRP instance. When the master device in the VSRP group fails, the backup device can take over the multicast services to ensure service continuity. For more information about IGMP, see IP Multicast Configuration Guide.
You must associate the peer IGMP-enabled interfaces on the master and the backup with the same VSRP instance. You cannot configure PIM on these interfaces. For more information about PIM, see IP Multicast Configuration Guide.
igmp vsrp-instance vsrp-instance-name
By default, an IGMP-enabled interface is not associated with any VSRP instance.
In a VSRP group, the master device by default forwards all multicast traffic. After you enable VSRP load sharing, the master and backup devices forward multicast traffic for odd multicast group addresses and even multicast group addresses, respectively.
You can disable multicast traffic fallback upon recovery of a failed member device or configure a recovered member device to wait a period of time before it load shares multicast traffic.
You must configure the same VSRP load sharing settings on the two member devices in the same VSRP group.
If you configure VSRP load sharing on a subinterface, follow these restrictions:
·     Make sure the subinterface and its main interface are associated with the same VSRP instance.
·     Configure VSRP load sharing on the main interface. Otherwise, VSRP load sharing does not take effect on the subinterface.
If the member devices in a VSRP group fail simultaneously, the member device that first recovers forwards all multicast traffic. When the other member device also recovers, it loads share multicast traffic immediately, whether you enable VSRP load sharing or not. In this situation, transient multicast traffic loss will occur.
In a VSRP group, if a non-direct uplink fails on a member device, the other member device forwards all multicast traffic. When the non-direct uplink recovers, the downstream VSRP member device loads share multicast traffic immediately, whether you enable VSRP load sharing or not. In this situation, transient multicast traffic loss will occur.
When you set the multicast traffic fallback delay, follow these restrictions and guidelines:
·     To prevent absence of multicast forwarding entries from causing multicast traffic loss, increase this delay.
·     To prevent a recovered member device from being idle, decrease this delay.
·     Make sure this delay is longer than the maximum response time for IGMP general queries (configurable with the igmp max-response-time command).
·     If you do not set the maximum response time for IGMP general queries, set this delay to be longer than 60 seconds.
During multicast traffic fallback, multicast traffic loss or duplication might occur. In an environment that requires high availability of multicast services, disable multicast traffic fallback.
3.     Enable VSRP load sharing on the interface.
igmp vsrp-load-balance [ no-restore | restore-delay delay-time ]
By default, VSRP load sharing is disabled on an IGMP-enabled interface. Only the master device forwards multicast traffic.
To back up the IGMP service on an IGMP-enabled interface, the master and the backup must establish a TCP data channel. You can change the TCP port number for establishing the data channel.
To establish IGMP service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
2.     Specify a TCP port number for VSRP to establish IGMP service backup data channels.
igmp vsrp-port port-number
Enable IGMP data synchronization on an IGMP-enabled interface if you are not sure whether the master and the backup can both receive IGMP packets.
Disable IGMP data synchronization if the master and the backup can both receive IGMP packets. For example, you can disable IGMP data synchronization if you have not configured IPoE, PPP, or portal authentication for multicast users.
The synchronized IGMP data will age out after you disable IGMP data synchronization.
3.     Enable IGMP data synchronization.
igmp vsrp-sync enable
By default, IGMP data synchronization is enabled.
About VSRP for MLD
You can use VSRP to back up the multicast service on an MLD-enabled interface by associating that interface with a VSRP instance. When the master device in the VSRP group fails, the backup device can take over the multicast services to ensure service continuity. For more information about MLD, see IP Multicast Configuration Guide.
You must associate the peer MLD-enabled interfaces on the master and the backup with the same VSRP instance. You cannot configure IPv6 PIM on these interfaces. For more information about IPv6 PIM, see IP Multicast Configuration Guide.
mld vsrp-instance vsrp-instance-name
By default, an MLD-enabled interface is not associated with any VSRP instance.
·     Make sure this delay is longer than the maximum response time for MLD general queries (configurable with the mld max-response-time command).
mld vsrp-load-balance [ no-restore | restore-delay delay-time ]
By default, VSRP load sharing is disabled on an MLD-enabled interface. Only the master device forwards multicast traffic.
To back up the MLD service on an MLD-enabled interface, the master and the backup must establish a TCP data channel. You can change the TCP port number for establishing the data channel.
To establish MLD service backup data channels successfully, you must specify the same TCP port number on the master and backup devices.
2.     Specify a TCP port number for VSRP to establish MLD service backup data channels.
mld vsrp-port port-number
Enable MLD data synchronization on an MLD-enabled interface if you are not sure whether the master and the backup can both receive MLD packets.
Disable MLD data synchronization if the master and the backup can both receive MLD packets. For example, you can disable IGMP data synchronization if you have not configured IPoE, PPP, or portal authentication for multicast users.
The synchronized MLD data will age out after you disable IGMP data synchronization.
3.     Enable MLD data synchronization.
mld vsrp-sync enable
By default, MLD data synchronization is enabled.
Display VSRP instance information.
display vsrp instance [ instance-name ]
Display VSRP group information.
display vsrp peer [ peer-name ]
As shown in Figure 3, the hosts use IPoE to access the BRAS devices (Device A and Device B). The two BRAS devices are in a VSRP group. IPv4 address pool 1 is enabled on the BRAS devices. The hosts obtain IP addresses through DHCP from the master. Perform the following tasks:
·     Enable IPoE and enable the DHCPv4 user on Ten-GigabitEthernet 3/1/1 of both Device A and Device B.
·     Create VRRP group 1 on Ten-GigabitEthernet 3/1/1.10, and configure the subinterface to terminate VLAN-tagged packets whose outermost VLAN ID is 10.
·     Enable OSPF on Device A and Device B to ensure that they can learn and advertise routes on their uplinks.
·     Enable VSRP for IPoE to back up IPoE sessions in real time.
·     Use the RADIUS server for authentication, authorization, and accounting of IPoE users.
Figure 3 Network diagram
Table 1 Interface label and interface name mappings
Interface label
Interface name
Interface1
Ten-GigabitEthernet3/1/1
Interface2
Ten-GigabitEthernet3/1/2
Interface3
Ten-GigabitEthernet3/1/3
1.     Assign IP addresses to interfaces, as shown in Figure 3. (Details not shown.)
2.     Configure the RADIUS server (this example uses a FreeRADIUS server that runs on Linux):
# Add the NAS IP address and shared key configuration to the clients.conf configuration file. (The NAS IP addresses for the two clients are 4.4.4.2 and 5.5.5.2, respectively, and the shared key is radius.)
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=radius
client 5.5.5.2/32 {
ipaddr = 5.5.5.2
netmask=32
secret=radius
# Add the IPoE user configuration to the users file. (The MAC addresses of the three IPoE users are 0010-9400-0001, 0010-9400-0002, and 0010-9400-0003. The password is radius, and the name of the authorized address pool is 1.)
001094000001  Cleartext-Password :="radius"
              Framed-Pool = 1
001094000002  Cleartext-Password :="radius"
              Framed-Pool = 1
001094000003  Cleartext-Password :="radius"
              Framed-Pool = 1
3.     Configure Device A:
a.     Configure a RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter RADIUS scheme view.
[DeviceA] radius scheme rs1
# Specify the primary authentication server and primary accounting server.
[DeviceA-radius-rs1] primary authentication 10.20.30.1
[DeviceA-radius-rs1] primary accounting 10.20.30.1
# Set the shared key for secure RADIUS authentication and accounting communication.
[DeviceA-radius-rs1] key authentication simple radius
[DeviceA-radius-rs1] key accounting simple radius
# Configure Device A to remove the domain name in the username sent to the RADIUS servers for RADIUS scheme rs1.
[DeviceA-radius-rs1] user-name-format without-domain
# Specify the source IP address as 3.3.3.3 (the gateway address for the hosts) for outgoing RADIUS packets.
[DeviceA-radius-rs1] nas-ip 3.3.3.3
[DeviceA-radius-rs1] quit
# Enable the session-control feature.
[DeviceA] radius session-control enable
b.     Configure an authentication domain:
# Create ISP domain dm1 and enter ISP domain view.
[DeviceA] domain name dm1
# Configure the domain to use RADIUS scheme rs1 for authentication, authorization, and accounting for IPoE users.
[DeviceA-isp-dm1] authentication ipoe radius-scheme rs1
[DeviceA-isp-dm1] authorization ipoe radius-scheme rs1
[DeviceA-isp-dm1] accounting ipoe radius-scheme rs1
[DeviceA-isp-dm1] quit
c.     Configure the DHCP server:
# Enable DHCP.
[DeviceA] dhcp enable
[DeviceA] dhcp server request-ip-address check
# Create IPv4 address pool 1 and associate the pool with VSRP instance vs1.
[DeviceA] ip pool 1
[DeviceA-ip-pool-1] vsrp-instance vs1
# Assign gateway address 3.3.3.3 to the hosts, and export the host route destined for the hosts and the route destined for 3.3.3.0/24.
[DeviceA-ip-pool-1] network 3.3.3.0 mask 255.255.255.0 export-route
[DeviceA-ip-pool-1] gateway-list 3.3.3.3 export-route
# Exclude addresses from dynamic allocation.
[DeviceA-ip-pool-1] forbidden-ip 3.3.3.1 3.3.3.2 3.3.3.3
[DeviceA-ip-pool-1] quit
d.     Configure a VRRP group:
# Enter Ten-GigabitEthernet 3/1/1.10 interface view.
[DeviceA] interface ten-gigabitethernet 3/1/1.10
# Create VRRP group 1 and set its virtual IP address to 3.3.3.3.
[DeviceA–Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 virtual-ip 3.3.3.3
# Configure Ten-GigabitEthernet 3/1/1.10 to terminate VLAN 10.
[DeviceA-Ten-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10
# Set the priority of Device A to 250 in VRRP group 1 on Ten-GigabitEthernet 3/1/1.10. Device A is assigned a higher priority than Device B in VRRP group 1, so Device A can become the master.
[DeviceA-Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 priority 250
# Configure Device A to operate in preemptive mode, and set the preemption delay to 90000 centiseconds (15 minutes). When the original master recovers, it has 15 minutes to synchronize data from the new master before switch-back to ensure stability and data consistency of the VRRP group.
[DeviceA–Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 preempt-mode delay 90000
[DeviceA–Ten-GigabitEthernet3/1/1.10] quit
# Create track entry 1 to monitor the link status of uplink interface Ten-GigabitEthernet 3/1/2. When the uplink fails, the track entry transits to Negative state.
[DeviceA] track 1 interface ten-gigabitethernet 3/1/2
# Associate VRRP group 1 on Ten-GigabitEthernet 3/1/1.10 with track entry 1, and decrease the device priority by 200 when the state of track entry 1 changes to Negative.
[DeviceA-Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 track 1 priority reduced 200
[DeviceA-Ten-GigabitEthernet3/1/1.10] quit
e.     Configure VSRP instance vs1:
# Create VSRP group pr1 and enter VSRP peer view.
[DeviceA] vsrp peer pr1
# Specify the local IP address as 4.4.4.2 and the peer IP address as 5.5.5.2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[DeviceA-vsrp-peer-pr1] peer 5.5.5.2 local 4.4.4.2
[DeviceA-vsrp-peer-pr1] quit
# Create VSRP instance vs1 and enter its view.
[DeviceA] vsrp instance vs1
# Associate VSRP instance vs1 with VSRP group pr1 and set its backup ID to 1.
[DeviceA-vsrp-instance-vs1] backup id 1 peer pr1
# Bind VSRP instance vs1 to VRRP group 1 on Ten-GigabitEthernet 3/1/1.10.
[DeviceA-vsrp-instance-vs1] bind vrrp vrid 1 interface ten-gigabitethernet 3/1/1.10
# Specify the logical NAS IP address as 3.3.3.3.
[DeviceA-vsrp-instance-vs1] nas ip 3.3.3.3
# Specify the logical interface as Ten-GigabitEthernet 3/1/2.
[DeviceA-vsrp-instance-vs1] nas port ten-gigabitethernet 3/1/2
[DeviceA-vsrp-instance-vs1] quit
f.     Configure IPoE authentication on Ten-GigabitEthernet 3/1/1:
# Enter Ten-GigabitEthernet 3/1/1 interface view.
# Enable IPoE and specify Layer 2 access mode.
[DeviceA–Ten-GigabitEthernet3/1/1] ip subscriber l2-connected enable
# Configure ISP domain dm1 for DHCPv4 users.
[DeviceA–Ten-GigabitEthernet3/1/1] ip subscriber dhcp domain dm1
# Set the password to radius in plain text for the dynamic IPoE users.
[DeviceA–Ten-GigabitEthernet3/1/1] ip subscriber password plaintext radius
# Associate Ten-GigabitEthernet 3/1/1 with VSRP instance vs1.
[DeviceA–Ten-GigabitEthernet3/1/1] bras vsrp-instance vs1
[DeviceA–Ten-GigabitEthernet3/1/1] dhcp vsrp-instance vs1
[DeviceA–Ten-GigabitEthernet3/1/1] quit
# Specify TCP port 1025 for VSRP to establish data channels for IPoE session backup.
[DeviceA] bras vsrp-port 1025
g.     Configure OSPF:
# Enable OSPF process 1 and set its router ID to 4.4.4.2 (the IP address of Ten-GigabitEthernet 3/1/2).
[DeviceA] ospf 1 router-id 4.4.4.2
# Configure OSPF to redistribute the user network route filtered by routing policy 1. Device A then advertises the user network route destined for the subnet where the hosts reside to Device C. In this way, Device C can select the route to a host based on the state of Device A and Device B in the VSRP instance.
[DeviceA-ospf-1] import-route unr inherit-cost route-policy 1
[DeviceA-ospf-1] quit
# Configure routing policy 1 to permit routes destined for network 3.3.3.0/24.
[DeviceA] ip prefix-list 1 permit 3.3.3.0 24
[DeviceA] route-policy 1 permit node 1
[DeviceA-route-policy-1-1] if-match ip address prefix-list 1
[DeviceA-route-policy-1-1] quit
# Create Area 0 and specify Ten-GigabitEthernet 3/1/2 whose IP address is on network 4.4.4.0/24 to run OSPF in Area 0.
[DeviceA] ospf
[DeviceA-ospf-1] area 0.0.0.0
[DeviceA-ospf-1-area-0.0.0.0] network 4.4.4.0 0.0.0.255
4.     Configure Device B:
[DeviceB] radius scheme rs1
[DeviceB-radius-rs1] primary authentication 10.20.30.1
[DeviceB-radius-rs1] primary accounting 10.20.30.1
[DeviceB-radius-rs1] key authentication simple radius
[DeviceB-radius-rs1] key accounting simple radius
# Configure Device B to remove the domain name in the username sent to the RADIUS servers for RADIUS scheme rs1.
[DeviceB-radius-rs1] user-name-format without-domain
[DeviceB-radius-rs1] nas-ip 3.3.3.3
[DeviceB-radius-rs1] quit
[DeviceB] radius session-control enable
[DeviceB] domain name dm1
[DeviceB-isp-dm1] authentication ipoe radius-scheme rs1
[DeviceB-isp-dm1] authorization ipoe radius-scheme rs1
[DeviceB-isp-dm1] accounting ipoe radius-scheme rs1
[DeviceB-isp-dm1] quit
# Enable DHCP.
[DeviceB] dhcp enable
[DeviceB] dhcp server request-ip-address check
[DeviceB] ip pool 1
[DeviceB-ip-pool-1] vsrp-instance vs1
[DeviceB-ip-pool-1] network 3.3.3.0 mask 255.255.255.0 export-route
[DeviceB-ip-pool-1] gateway-list 3.3.3.3 export-route
[DeviceB-ip-pool-1] forbidden-ip 3.3.3.1 3.3.3.2 3.3.3.3
[DeviceB-ip-pool-1] quit
[DeviceB] interface ten-gigabitethernet 3/1/1.10
[DeviceB–Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 virtual-ip 3.3.3.3
[DeviceB-Ten-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10
# Set the priority of Device B to 200 in VRRP group 1 on Ten-GigabitEthernet 3/1/1.10. Device B is assigned a lower priority than Device A in VRRP group 1, so Device A can become the master.
[DeviceB-Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 priority 200
[DeviceB–Ten-GigabitEthernet3/1/1.10] quit
[DeviceB] vsrp peer pr1
# Specify the local IP address as 5.5.5.2 and the peer IP address as 4.4.4.2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[DeviceB-vsrp-peer-pr1] peer 4.4.4.2 local 5.5.5.2
[DeviceB-vsrp-peer-pr1] quit
[DeviceB] vsrp instance vs1
[DeviceB-vsrp-instance-vs1] backup id 1 peer pr1
[DeviceB-vsrp-instance-vs1] bind vrrp vrid 1 interface ten-gigabitethernet 3/1/1.10
[DeviceB-vsrp-instance-vs1] nas ip 3.3.3.3
[DeviceB-vsrp-instance-vs1] nas port ten-gigabitethernet 3/1/2
[DeviceB-vsrp-instance-vs1] quit
[DeviceB–Ten-GigabitEthernet3/1/1] ip subscriber l2-connected enable
[DeviceB–Ten-GigabitEthernet3/1/1] ip subscriber dhcp domain dm1
[DeviceB–Ten-GigabitEthernet3/1/1] ip subscriber password plaintext radius
[DeviceB–Ten-GigabitEthernet3/1/1] bras vsrp-instance vs1
[DeviceB–Ten-GigabitEthernet3/1/1] dhcp vsrp-instance vs1
[DeviceB–Ten-GigabitEthernet3/1/1] quit
# Specify TCP port number 1025 for VSRP to establish data channels for IPoE session backup.
[DeviceB] bras vsrp-port 1025
g.     Configure OSPF:
# Enable OSPF process 1 and set its router ID to 5.5.5.2 (the IP address of Ten-GigabitEthernet 3/1/2).
[DeviceB] ospf 1 router-id 5.5.5.2
# Configure OSPF to redistribute the user network route filtered by routing policy 1. Device B then advertises the user network route destined for the subnet where the hosts reside to Device C. In this way, Device C can select the route to a host based on the state of Device A and Device B in the VSRP instance.
[DeviceB-ospf-1] import-route unr inherit-cost route-policy 1
[DeviceB-ospf-1] quit
[DeviceB] ip prefix-list 1 permit 3.3.3.0 24
[DeviceB] route-policy 1 permit node 1
[DeviceB-route-policy-1-1] if-match ip address prefix-list 1
[DeviceB-route-policy-1-1] quit
# Create Area 0 and specify Ten-GigabitEthernet 3/1/2 whose IP address is on network 5.5.5.0/24 to run OSPF in Area 0.
[DeviceB] ospf
[DeviceB-ospf-1] area 0.0.0.0
[DeviceB-ospf-1-area-0.0.0.0] network 5.5.5.0 0.0.0.255
5.     Configure Device C:
# Enable OSPF process 1 and set its router ID to 4.4.4.1 (the IP address of Ten-GigabitEthernet 3/1/1).
<DeviceC> system-view
[DeviceC] ospf 1 router-id 4.4.4.1
# Configure OSPF Area 0.
[DeviceC-ospf-1] area 0.0.0.0
[DeviceC-ospf-1-area-0.0.0.0] network 4.4.4.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 5.5.5.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
6.     Configure the L2 Switch:
a.     Create VLAN 10.
<L2Switch> system-view
[L2Switch] vlan 10
[L2Switch-vlan10] quit
b.     Configure VLAN settings on the interfaces that connect to Device A and Device B:
# Assign Ten-GigabitEthernet 3/1/2 to VLAN 10.
[L2Switch] interface ten-gigabitethernet 3/1/2
[L2Switch-Ten-GigabitEthernet3/1/2] port link-type trunk
[L2Switch-Ten-GigabitEthernet3/1/2] port trunk permit vlan 10
[L2Switch-Ten-GigabitEthernet3/1/2] quit
# Assign Ten-GigabitEthernet 3/1/3 to VLAN 10.
[L2Switch] interface ten-gigabitethernet 3/1/3
[L2Switch-Ten-GigabitEthernet3/1/3] port link-type trunk
[L2Switch-Ten-GigabitEthernet3/1/3] port trunk permit vlan 10
[L2Switch-Ten-GigabitEthernet3/1/3] quit
# Verify that Device A and Device B have the same IPoE user information about authenticated IPoE users.
·     On the master:
[DeviceA] display access-user
UserID   Interface                IP address          MAC address    S-/C-VLAN
         Username                 Access type
         IPv6 address
0x1      XGE3/1/1                 3.3.3.4             0010-9400-0001  -/-
         00109400000              L2 IPoE dynamic(D/-)
0x2      XGE3/1/1                 3.3.3.5             0010-9400-0002  -/-
         001094000002             L2 IPoE dynamic(D/-)
0x3      XGE3/1/1                 3.3.3.6             0010-9400-0003  -/-
         001094000003             L2 IPoE dynamic(D/-)
·     On the backup:
[DeviceB] display access-user
         IPv6 address
         001094000001             L2 IPoE dynamic(D/-)
As shown in Figure 4, the hosts use IPoE to access the BRAS devices (Device A and Device B). The two BRAS devices are in a VSRP group. IPv6 address pool 1 is enabled on the BRAS devices. The hosts obtain IP addresses through DHCP from the master. Perform the following tasks:
·     Enable IPoE and enable the DHCPv6 user on Ten-GigabitEthernet 3/1/1 of both Device A and Device B.
Figure 4 Network diagram
Table 2 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
1.     Assign IPv6 addresses to interfaces, as shown in Figure 4. (Details not shown.)
# Add the NAS IP address and shared key configuration to the clients.conf configuration file. (The NAS IP addresses for the two clients are 4::2 and 5::2, respectively, and the shared key is radius.)
client 4::2/64 {
ipaddr = 4::2
netmask=64
secret=radius
client 5::2/64 {
ipaddr = 5::2
netmask=64
secret=radius
              Framed-Pool = 1
              Framed-Pool = 1
              Framed-Pool = 1
[DeviceA-radius-rs1] primary authentication ipv6 100::1
[DeviceA-radius-rs1] primary accounting ipv6 100::1
# Specify the source IPv6 address as 1::1 for outgoing RADIUS packets.
[DeviceA-radius-rs1] nas-ip ipv6 1::1
# Configure authentication, authorization, and accounting methods for IPoE users.
c.     Configure a loopback interface:
# Enable OSPFv3 process 1 and specify Area 0 on Loopback 0.
[DeviceA] interface loopback 0
[DeviceA-LoopBack0] ospfv3 1 area 0
# Set the OSPFv3 cost to 30 for Loopback 0. Make sure this enables the RADIUS server to choose the route to Loopback 0 based on the cost.
[DeviceA-LoopBack0] ospfv3 cost 30
[DeviceA-LoopBack0] quit
d.     Configure the DHCPv6 server:
# Enable DHCP.
# Enable DHCPv6 server on Ten-GigabitEthernet 3/1/1.
[DeviceA–Ten-GigabitEthernet3/1/1] ipv6 dhcp select server
# Disable RA message suppression on Ten-GigabitEthernet 3/1/1.
[DeviceA–Ten-GigabitEthernet3/1/1] undo ipv6 nd ra halt
# Set the M flag to 1 and the O flag to 1 in RA advertisements to be sent. The receiving hosts can obtain IPv6 addresses and other configuration information from the DHCPv6 server.
[DeviceA–Ten-GigabitEthernet3/1/1] ipv6 nd autoconfig managed-address-flag
[DeviceA–Ten-GigabitEthernet3/1/1] ipv6 nd autoconfig other-flag
# Create address pool 1.
[DeviceA] ipv6 pool 1
# Specify subnet 3::/64 in address pool 1 and advertise the subnet.
[DeviceA-ipv6-pool-1] network 3::/64 export-route
[DeviceA-ipv6-pool-1] gateway-list 3::1
# Associate IPv6 address pool 1 with VSRP instance vs1.
[DeviceA-ipv6-pool-1] vsrp-instance vs1
# Configure IPv6 address pool 1 to use the virtual DUID generated based on enterprise number 2 and identifier ff.
[DeviceA-ipv6-pool-1] virtual-duid enterprise-number 2 identifier ff
[DeviceA-ipv6-pool-1] quit
# Exclude IPv6 address 3::1 from dynamic allocation.
[DeviceA] ipv6 dhcp server forbidden-address 3::1
e.     Configure a VRRP group:
[DeviceA–Ten-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10
# Create IPv6 VRRP group 1 and set its virtual IP address to fe80::2.
[DeviceA–Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 virtual-ip fe80::2 link-local
# Configure Ten-GigabitEthernet 3/1/1.10 to automatically generate a link-local address.
[DeviceA–Ten-GigabitEthernet3/1/1.10] ipv6 address auto link-local
[DeviceA-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 priority 250
[DeviceA–Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 preempt-mode delay 90000
# Associate VRRP group 1 on Ten-GigabitEthernet 3/1/1.10 with track entry 1 and decrease the device priority by 200 when the state of track entry 1 changes to Negative.
[DeviceA-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 track 1 priority reduced 200
f.     Configure VSRP instance vs1:
# Specify the local IP address as 4::2 and the peer IP address as 5::2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[DeviceA-vsrp-peer-pr1] peer ipv6 5::2 local 4::2
# Bind VSRP instance vs1 to IPv6 VRRP group 1 on Ten-GigabitEthernet 3/1/1.10.
[DeviceA-vsrp-instance-vs1] bind vrrp ipv6 vrid 1 interface ten-gigabitethernet 3/1/1.10
# Specify the logical host name as abc.
[DeviceA-vsrp-instance-vs1] nas id abc
g.     Specify a virtual IPv6 address for Ten-GigabitEthernet 3/1/1:
# Specify a virtual IPv6 address of fe80::100 for Ten-GigabitEthernet 3/1/1.
[DeviceA–Ten-GigabitEthernet3/1/1] ipv6 virtual-address fe80::100 vsrp vs1
h.     Configure IPoE authentication on Ten-GigabitEthernet 3/1/1:
# Configure ISP domain dm1 for DHCPv6 users.
[DeviceA–Ten-GigabitEthernet3/1/1] ipv6 dhcp vsrp-instance vs1
# Specify TCP port 1026 for VSRP to establish data channels for IPoE session backup.
[DeviceA] bras vsrp-port 1026
i.     Configure OSPFv3:
# Enable OSPFv3 process 1 and set its router ID to 1.1.1.1.
[DeviceA] ospfv3
[DeviceA-ospfv3-1]router-id 1.1.1.1
# Configure OSPFv3 to redistribute the user network route filtered by routing policy 1. Device A then advertises the user network route destined for the subnet where the hosts reside to Device C. In this way, Device C can select the route to a host based on the state of Device A and Device B in the VSRP instance.
[DeviceA-ospfv3-1] import-route unr inherit-cost route-policy 1
[DeviceA-ospfv3-1] quit
# Configure routing policy 1 to permit routes destined for network 3::/32.
[DeviceA] ipv6 prefix-list 1 permit 3:: 32
[DeviceA-route-policy-1-1] if-match ipv6 address prefix-list 1
# Enable OSPFv3 and specify Area 0 on Ten-GigabitEthernet 3/1/2.
[DeviceA] interface ten-gigabitethernet 3/1/2
[DeviceA–Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[DeviceA–Ten-GigabitEthernet3/1/2] quit
[DeviceB-radius-rs1] primary authentication ipv6 100::1
[DeviceB-radius-rs1] primary accounting ipv6 100::1
[DeviceB] interface loopback 0
[DeviceB-LoopBack0] ospfv3 1 area 0
# Set the OSPFv3 cost to 100 for Loopback 0. The RADIUS server can choose the route to Loopback 0 based on the cost.
[DeviceB-LoopBack0] ospfv3 cost 100
[DeviceB-LoopBack0] quit
# Enable DHCP.
[DeviceB–Ten-GigabitEthernet3/1/1] ipv6 dhcp select server
[DeviceB–Ten-GigabitEthernet3/1/1] undo ipv6 nd ra halt
[DeviceB–Ten-GigabitEthernet3/1/1] ipv6 nd autoconfig managed-address-flag
[DeviceB–Ten-GigabitEthernet3/1/1] ipv6 nd autoconfig other-flag
[DeviceB] ipv6 pool 1
[DeviceB-ipv6-pool-1] network 3::/64 export-route
[DeviceB-ipv6-pool-1] gateway-list 3::1
[DeviceB-ipv6-pool-1] vsrp-instance vs1
[DeviceB-ipv6-pool-1] virtual-duid enterprise-number 2 identifier ff
[DeviceB-ipv6-pool-1] quit
[DeviceB] ipv6 dhcp server forbidden-address 3::1
[DeviceB–Ten-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10
[DeviceB–Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 virtual-ip fe80::2 link-local
[DeviceB–Ten-GigabitEthernet3/1/1.10] ipv6 address auto link-local
[DeviceB-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 priority 200
# Specify the local IP address as 5::2 and the peer IP address as 4::2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[DeviceB-vsrp-peer-pr1] peer ipv6 4::2 local 5::2
[DeviceB-vsrp-instance-vs1] bind vrrp ipv6 vrid 1 interface ten-gigabitethernet 3/1/1.10
[DeviceB-vsrp-instance-vs1] nas id abc
g.     Specify a virtual IPv6 address on Ten-GigabitEthernet 3/1/1:
[DeviceB–Ten-GigabitEthernet3/1/1] ipv6 virtual-address fe80::100 vsrp vs1
[DeviceB–Ten-GigabitEthernet3/1/1] ipv6 dhcp vsrp-instance vs1
[DeviceB] bras vsrp-port 1026
# Enable OSPFv3 process 1 and set its router ID to 2.2.2.2.
[DeviceB] ospfv3
[DeviceB-ospfv3-1]router-id 2.2.2.2
# Configure OSPFv3 to redistribute the user network route filtered by routing policy 1. Device B then advertises the user network route destined for the subnet where the hosts reside to Device C. In this way, Device C can select the route to a host based on the state of Device A and Device B in the VSRP instance.
[DeviceB-ospfv3-1] import-route unr inherit-cost route-policy 1
[DeviceB-ospfv3-1] quit
[DeviceB] ipv6 prefix-list 1 permit 3:: 32
[DeviceB-route-policy-1-1] if-match ipv6 address prefix-list 1
[DeviceB] interface ten-gigabitethernet 3/1/2
[DeviceB–Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[DeviceB–Ten-GigabitEthernet3/1/2] quit
# Enable OSPFv3 process 1 and set its router ID to 3.3.3.3.
[DeviceC] ospfv3
[DeviceC-ospfv3-1] router-id 3.3.3.3
# Enable OSPFv3 process 1 and specify Area 0 on Ten-GigabitEthernet 3/1/3.
[DeviceC] interface ten-gigabitethernet 3/1/3
[DeviceC-Ten-GigabitEthernet3/1/3] ospfv3 1 area 0
[DeviceC-Ten-GigabitEthernet3/1/3] quit
# Enable OSPFv3 process 1 and specify Area 0 on Ten-GigabitEthernet 3/1/1.
[DeviceC] interface ten-gigabitethernet 3/1/1
[DeviceC–Ten-GigabitEthernet3/1/1] ospfv3 1 area 0
[DeviceC–Ten-GigabitEthernet3/1/1] quit
# Enable OSPFv3 process 1 and specify Area 0 on Ten-GigabitEthernet 3/1/2.
[DeviceC] interface ten-gigabitethernet 3/1/2
[DeviceC–Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[DeviceC–Ten-GigabitEthernet3/1/2] quit
a.     Create VLAN 10.
[L2Switch] vlan 10
[L2Switch] interface Ten-GigabitEthernet 3/1/3
·     On the master:
         IPv6 address
0x1      XGE3/1/1                 -                   0010-9400-0001  -/-
         001094000001             L2 IPoE dynamic(-/D)
         3::1
0x2      XGE3/1/1                 -                   0010-9400-0002  -/-
         001094000002             L2 IPoE dynamic(-/D)
         3::2
0x3      XGE3/1/1                 -                   0010-9400-0003  -/-
         001094000003             L2 IPoE dynamic(-/D)
         3::3
·     On the backup:
         IPv6 address
         3::1
         3::2
         3::3
Example: Configuring VSRP for dual-stack IPoE (IPv4 and IPv6 address pools)
As shown in Figure 5, the hosts use IPoE to access BRAS A and BRAS B. The two BRAS devices are in a VSRP group. The hosts obtain IP addresses through DHCP from the master. Perform the following tasks:
·     Enable IPoE on Ten-GigabitEthernet 3/1/1 of both BRAS A and BRAS B.
·     Configure an IPv4 address pool and an IPv6 address pool on the BRAS devices.
·     Enable OSPF on BRAS A and BRAS B to ensure that they can learn and advertise routes on their uplinks.
Figure 5 Network diagram
Table 3 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
Interface4
Ten-GigabitEthernet3/1/4
1.     Assign IP addresses to interfaces, as shown in Figure 5. (Details not shown.)
2.     Configure the RADIUS server:
This example uses a FreeRADIUS server that runs on Linux.
# Add the NAS IP address and shared key configuration to the clients.conf configuration file. (The NAS IP addresses for the two clients are 4.4.4.2, and 5.5.5.2, respectively, and the shared key is 123456.)
client 3.3.3.3/32 {
ipaddr = 3.3.3.3
netmask=32
secret=123456
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=123456
client 5.5.5.2/32 {
ipaddr = 5.5.5.2
netmask=24
secret=123456
# Add the IPoE user configuration to the users file. (The MAC addresses of the three IPoE users are 0010-9400-0001, 0010-9400-0002, and 0010-9400-0003. The password is 123456.)
001094000001  Cleartext-Password :="123456"
001094000002  Cleartext-Password :="123456"
001094000003  Cleartext-Password :="123456"
3.     Configure the DHCP server:
This example uses a network device as the DHCP server. As a best practice, use a dedicated DHCP server.
a.     Configure the DHCPv4 server:
# Enable DHCP.
<DHCP> system-view
[DHCP] dhcp enable
# Enable the DHCP server to return a DHCP-NAK message if the client notions of their IP addresses are incorrect.
[DHCP] dhcp server request-ip-address check
# Create IPv4 address pool ipoev4 and enter its view.
[DHCP] ip pool ipoev4
# Assign subnet 3.3.3.0/24 to the hosts, and specify the gateway address and DNS server address.
[DHCP-ip-pool-ipoev4] network 3.3.3.0 24
[DHCP-ip-pool-ipoev4] gateway-list 3.3.3.3 export-route
[DHCP-ip-pool-ipoev4] dns-list 8.8.8.8
# Exclude the gateway address and the IP addresses of host-facing interfaces on the BRAS devices from dynamic allocation.
[DHCP-ip-pool-ipoev4] forbidden-ip 3.3.3.1
[DHCP-ip-pool-ipoev4] forbidden-ip 3.3.3.2
[DHCP-ip-pool-ipoev4] forbidden-ip 3.3.3.3
[DHCP-ip-pool-ipoev4] quit
# Configure a static route for the DHCPv4 server to reach the BRAS devices.
[DHCP] ip route-static 0.0.0.0 0 6.6.6.1
b.     Configure the DHCPv6 server:
[DHCP] interface ten-gigabitethernet 3/1/1
[DHCP–Ten-GigabitEthernet3/1/1] ipv6 dhcp select server
[DHCP–Ten-GigabitEthernet3/1/1] quit
# Create IPv6 address pool ipoev6 and enter its view.
[DHCP] ipv6 pool ipoev6
# Assign subnet 3::/64 to the hosts and specify DNS server address.
[DHCP-ipv6-pool-ipoev6] network 3::/64
[DHCP-ipv6-pool-ipoev6] dns-server 8::8
[DHCP-ipv6-pool-ipoev6] quit
[DHCP] ipv6 dhcp server forbidden-address 3::1
[DHCP] ipv6 dhcp server forbidden-address 3::2
[DHCP] ipv6 dhcp server forbidden-address 3::3
# Configure a static route for the DHCPv6 server to reach the BRAS devices.
[DHCP] ipv6 route-static 0::0 0 6::1
4.     Configure BRAS A:
<BRASA> system-view
[BRASA] radius scheme rs1
[BRASA-radius-rs1] primary authentication 6.6.6.2
[BRASA-radius-rs1] primary accounting 6.6.6.2
[BRASA-radius-rs1] key authentication simple 123456
[BRASA-radius-rs1] key accounting simple 123456
# Enable the accounting-on feature.
[BRASA-radius-rs1] accounting-on enable
[BRASA-radius-rs1] nas-ip 3.3.3.3
[BRASA-radius-rs1] quit
b.     Configure DHCPv4 relay agent:
# Enable DHCP.
[BRASA] dhcp enable
# Enable recording client information in relay entries.
[BRASA] dhcp relay client-information record
# Configure IPv4 address pool ipoev4 and associate the pool with VSRP instance vs1.
[BRASA] ip pool ipoev4
[BRASA-ip-pool-ipoev4] gateway-list 3.3.3.3 export-route
[BRASA-ip-pool-ipoev4] remote-server 6.6.6.3
[BRASA-ip-pool-ipoev4] vsrp-instance vs1
# Configure BRAS A to export the user network route for 3.3.3.0/24 to the routing table for OSPF to redistribute the user network route and advertise it to Device C. Device C uses the route to direct traffic of that subnet to BRAS A.
In this example, BRAS devices also act as DHCPv4 relay agents. The network 3.3.3.0 24 export-route command is used for OSPF route redistribution instead of IP address assignment.
The network 3.3.3.0 24 export-route command is configured on both the master and the backup of a VSRP instance. Only the master exports the route for that subnet. If the master becomes the backup, it deletes the exported route.
[BRASA-ip-pool-ipoev4] network 3.3.3.0 24 export-route
[BRASA-ip-pool-ipoev4] quit
[BRASA] interface ten-gigabitethernet 3/1/1
[BRASA-Ten-GigabitEthernet3/1/1] dhcp relay vsrp-instance vs1
c.     Configure DHCPv6 relay agent:
# Disable RA message suppression on Ten-GigabitEthernet 3/1/1. Set the managed address configuration flag (M) to 1 and set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
[BRASA–Ten-GigabitEthernet3/1/1] undo ipv6 nd ra halt
[BRASA–Ten-GigabitEthernet3/1/1] ipv6 nd autoconfig managed-address-flag
[BRASA–Ten-GigabitEthernet3/1/1] ipv6 nd autoconfig other-flag
# Enable the DHCPv6 relay agent on Ten-GigabitEthernet 3/1/1.
[BRASA–Ten-GigabitEthernet3/1/1] ipv6 dhcp select relay
# Enable recording client information in DHCPv6 relay entries.
[BRASA–Ten-GigabitEthernet3/1/1] ipv6 dhcp relay client-information record
[BRASA–Ten-GigabitEthernet3/1/1] quit
# Configure IPv6 address pool ipoev6 and associate the pool with VSRP instance vs1.
[BRASA] ipv6 pool ipoev6
[BRASA-ipv6-pool-ipoev6] gateway-list 3::3
[BRASA-ipv6-pool-ipoev6] remote-server 6::3
[BRASA-ipv6-pool-ipoev6] vsrp-instance vs1
# Configure BRAS A to export the user network route for 3::/64 to the routing table for OSPFv3 to redistribute the route and advertise it to Device C. Device C uses the route to direct traffic of that subnet to BRAS A.
In this example, BRAS devices also act as DHCPv6 relay agents. The network 3::/64 export-route command is used for OSPFv3 route redistribution instead of IP address assignment.
The network 3::/64 export-route command is configured on both the master and the backup of a VSRP instance. Only the master exports the route for that subnet. If the master becomes the backup, it deletes the exported route.
[BRASA-ipv6-pool-ipoev6] network 3::/64 export-route
[BRASA-ipv6-pool-ipoev6] quit
[BRASA–Ten-GigabitEthernet3/1/1] ipv6 dhcp relay vsrp-instance vs1
d.     Configure an authentication domain:
[BRASA] domain name dm1
[BRASA-isp-dm1] authentication ipoe radius-scheme rs1
[BRASA-isp-dm1] authorization ipoe radius-scheme rs1
[BRASA-isp-dm1] accounting ipoe radius-scheme rs1
# Configure an IPv4 address pool and an IPv6 address pool for users in the ISP domain.
[BRASA-isp-dm1] authorization-attribute ip-pool ipoev4
[BRASA-isp-dm1] authorization-attribute ipv6-pool ipoev6
[BRASA-isp-dm1] quit
e.     Configure OSPF:
# Enable OSPF process 1 and specify its router ID as 3.3.3.1 (the IP address of Ten-GigabitEthernet 3/1/1.10).
[BRASA] ospf 1 router-id 3.3.3.1
# Configure OSPF to redistribute the user network route filtered by routing policy 1. When BRAS A acts as the master and assigns an IP address to a host, it advertises the user network route destined for the subnet where the host resides to Device C. In this way, Device C can select the route to the host based on the state of BRAS A and BRAS B in the VSRP instance.
[BRASA-ospf-1] import-route unr inherit-cost route-policy 1
[BRASA-ospf-1] quit
# Configure routing policy 1 to permit routes destined for 3.3.3.0/24.
[BRASA] ip prefix-list 1 permit 3.3.3.0 24
[BRASA] route-policy 1 permit node 1
[BRASA-route-policy-1-1] if-match ip address prefix-list 1
[BRASA-route-policy-1-1] quit
# Configure Area 0.
[BRASA] ospf
[BRASA-ospf-1] area 0.0.0.0
[BRASA-ospf-1-area-0.0.0.0] network 4.4.4.0 0.0.0.255
[BRASA-ospf-1-area-0.0.0.0] quit
[BRASA-ospf-1] quit
f.     Configure OSPFv3:
# Enable OSPFv3 process 1 and specify its router ID as 3.3.3.1.
[BRASA] ospfv3
[BRASA-ospfv3-1] router-id 3.3.3.1
# Configure OSPFv3 to redistribute the user network route filtered by routing policy 1. BRAS A then advertises the user network route destined for the subnet where the host resides to Device C. In this way, Device C can select the route to the host based on the state of BRAS A and BRAS B in the VSRP instance.
[BRASA-ospfv3-1] import-route unr inherit-cost route-policy 1
[BRASA-ospfv3-1] quit
# Configure routing policy 1 to permit routes destined for 3::/32.
[BRASA] ipv6 prefix-list 1 permit 3:: 32
[BRASA-route-policy-1-1] if-match ipv6 address prefix-list 1
# Configure Area 0 on Ten-GigabitEthernet 3/1/2.
[BRASA] interface ten-gigabitethernet 3/1/2
[BRASA–Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[BRASA–Ten-GigabitEthernet3/1/2] quit
g.     Configure an IPv6 VRRP group:
# Enter the view of Ten-GigabitEthernet 3/1/1.10.
[BRASA] interface ten-gigabitethernet 3/1/1.10
# Create IPv6 VRRP group 1 and set its virtual IP address to fe80::3.
[BRASA–Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 virtual-ip fe80::3 link-local
[BRASA–Ten-GigabitEthernet3/1/1.10] ipv6 address auto link-local
# Set the priority of BRAS A to 250 in VRRP group 1 on Ten-GigabitEthernet 3/1/1.10. BRAS A is assigned a higher priority than BRAS B in VRRP group 1, so BRAS A can become the master.
[BRASA-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 priority 250
# Configure BRAS A to operate in preemptive mode, and set the preemption delay to 90000 centiseconds (15 minutes). When the original master recovers, it has 15 minutes to synchronize data from the new master before switch-back to ensure stability and data consistency of the VRRP group.
[BRASA–Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 preempt-mode delay 90000
[BRASA–Ten-GigabitEthernet3/1/1.10] quit
[BRASA] track 1 interface ten-gigabitethernet 3/1/2
[BRASA-track-1] quit
[BRASA-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 track 1 priority reduced 200
[BRASA-Ten-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10
[BRASA-Ten-GigabitEthernet3/1/1.10] quit
h.     Configure a VSRP instance:
When VSRP is enabled for IPoE, IPv4 and IPv6 users share a data backup channel. You can configure an IPv4 or IPv6 data backup channel for dual-stack IPoE. This example creates an IPv6 data backup channel.
[BRASA] vsrp peer pr1
[BRASA-vsrp-peer-pr1] peer ipv6 5::2 local 4::2
[BRASA-vsrp-peer-pr1] quit
[BRASA] vsrp instance vs1
[BRASA-vsrp-instance-vs1] backup id 1 peer pr1
[BRASA-vsrp-instance-vs1] bind vrrp ipv6 vrid 1 interface ten-gigabitethernet 3/1/1.10
[BRASA-vsrp-instance-vs1] nas id abc
[BRASA-vsrp-instance-vs1] nas port ten-gigabitethernet 3/1/2
# Enable route advertisement for the backup. Set the route costs for the master and the back to 20 and 30, respectively.
[BRASA-vsrp-instance-vs1] backup route-advertise master-cost 20 backup-cost 30
[BRASA-vsrp-instance-vs1] quit
i.     Specify a virtual IPv6 address on Ten-GigabitEthernet 3/1/1:
[BRASA–Ten-GigabitEthernet3/1/1] ipv6 virtual-address fe80::100 vsrp vs1
j.     Configure IPoE authentication on Ten-GigabitEthernet 3/1/1:
[BRASA–Ten-GigabitEthernet3/1/1] ip subscriber l2-connected enable
# Configure ISP domain dm1 for DHCP users.
[BRASA–Ten-GigabitEthernet3/1/1] ip subscriber dhcp domain dm1
# Configure the source MAC addresses as authentication usernames for DHCP users.
[BRASA–Ten-GigabitEthernet3/1/1] ip subscriber dhcp username include source-mac
# Set the password to 123456 in plain text for the dynamic IPoE users.
[BRASA–Ten-GigabitEthernet3/1/1] ip subscriber password plaintext 123456
[BRASA–Ten-GigabitEthernet3/1/1] bras vsrp-instance vs1
5.     Configure BRAS B:
<BRASB> system-view
[BRASB] radius scheme rs1
[BRASB-radius-rs1] primary authentication 6.6.6.2
[BRASB-radius-rs1] primary accounting 6.6.6.2
[BRASB-radius-rs1] key authentication simple 123456
[BRASB-radius-rs1] key accounting simple 123456
[BRASB-radius-rs1] accounting-on enable
# Specify the source IP address as 3.3.3.3 (the gateway address for hosts) for outgoing RADIUS packets.
[BRASB-radius-rs1] nas-ip 3.3.3.3
[BRASB-radius-rs1] quit
# Enable DHCP.
[BRASB] dhcp enable
[BRASB] dhcp relay client-information record
[BRASB] ip pool ipoev4
[BRASB-ip-pool-ipoev4] gateway-list 3.3.3.3 export-route
[BRASB-ip-pool-ipoev4] remote-server 6.6.6.3
[BRASB-ip-pool-ipoev4] vsrp-instance vs1
# Configure BRAS B to export the user network route for 3.3.3.0/24 to the routing table for OSPF to redistribute the user network route and advertise it to Device C. Device C uses the route to direct traffic of that subnet to BRAS B.
[BRASB-ip-pool-ipoev4] network 3.3.3.0 24 export-route
[BRASB-ip-pool-ipoev4] quit
[BRASB] interface ten-gigabitethernet 3/1/1
[BRASB-Ten-GigabitEthernet3/1/1] dhcp relay vsrp-instance vs1
[BRASB–Ten-GigabitEthernet3/1/1] undo ipv6 nd ra halt
[BRASB–Ten-GigabitEthernet3/1/1] ipv6 nd autoconfig managed-address-flag
[BRASB–Ten-GigabitEthernet3/1/1] ipv6 nd autoconfig other-flag
[BRASB–Ten-GigabitEthernet3/1/1] ipv6 dhcp select relay
[BRASB–Ten-GigabitEthernet3/1/1] ipv6 dhcp relay client-information record
[BRASB–Ten-GigabitEthernet3/1/1] quit
[BRASB] ipv6 pool ipoev6
[BRASB-ipv6-pool-ipoev6] gateway-list 3::3
[BRASB-ipv6-pool-ipoev6] remote-server 6::3
[BRASB-ipv6-pool-ipoev6] vsrp-instance vs1
# Configure BRAS B to export the user network route for 3::/64 to the routing table for OSPFv3 to redistribute the route and advertise it to Device C. Device C uses the route to direct traffic of that subnet to BRAS B.
[BRASB-ipv6-pool-ipoev6] network 3::/64 export-route
[BRASB-ipv6-pool-ipoev6] quit
[BRASB–Ten-GigabitEthernet3/1/1] ipv6 dhcp relay vsrp-instance vs1
[BRASB] domain name dm1
[BRASB-isp-dm1] authentication ipoe radius-scheme rs1
[BRASB-isp-dm1] authorization ipoe radius-scheme rs1
[BRASB-isp-dm1] accounting ipoe radius-scheme rs1
[BRASB-isp-dm1] authorization-attribute ip-pool ipoev4
[BRASB-isp-dm1] authorization-attribute ipv6-pool ipoev6
[BRASB-isp-dm1] quit
e.     Configure OSPF:
# Enable OSPF process 1 and specify its router ID as 3.3.3.2 (the IP address of Ten-GigabitEthernet 3/1/1.10).
[BRASB] ospf 1 router-id 3.3.3.2
# Configure OSPF to redistribute the user network route filtered by routing policy 1. When BRAS B acts as the master and assigns an IP address to a host, it advertises the user network route destined for the subnet where the host resides to Device C. In this way, Device C can select the route to the host based on the state of BRAS A and BRAS B in the VSRP instance.
[BRASB-ospf-1] import-route unr inherit-cost route-policy 1
[BRASB-ospf-1] quit
[BRASB] ip prefix-list 1 permit 3.3.3.0 24
[BRASB] route-policy 1 permit node 1
[BRASB-route-policy-1-1] if-match ip address prefix-list 1
[BRASB-route-policy-1-1] quit
# Configure Area 0.
[BRASB] ospf
[BRASB-ospf-1] area 0.0.0.0
[BRASB-ospf-1-area-0.0.0.0] network 5.5.5.0 0.0.0.255
[BRASB-ospf-1-area-0.0.0.0] quit
[BRASB-ospf-1] quit
# Enable OSPFv3 process 1 and specify its router ID as 3.3.3.2.
[BRASB] ospfv3
[BRASB-ospfv3-1] router-id 3.3.3.2
# Configure OSPFv3 to redistribute the user network route filtered by routing policy 1. BRAS B then advertises the user network route destined for the subnet where the host resides to Device C. In this way, Device C can select the route to the host based on the state of BRAS A and BRAS B in the VSRP instance.
[BRASB-ospfv3-1] import-route unr inherit-cost route-policy 1
[BRASB-ospfv3-1] quit
[BRASB] ipv6 prefix-list 1 permit 3:: 32
[BRASB-route-policy-1-1] if-match ipv6 address prefix-list 1
[BRASB] interface ten-gigabitethernet 3/1/2
[BRASB–Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[BRASB–Ten-GigabitEthernet3/1/2] quit
[BRASB] interface ten-gigabitethernet 3/1/1.10
[BRASB–Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 virtual-ip fe80::3 link-local
[BRASB–Ten-GigabitEthernet3/1/1.10] ipv6 address auto link-local
# Set the priority of BRAS B to 200 in VRRP group 1 on Ten-GigabitEthernet 3/1/1.10. BRAS A is assigned a higher priority than BRAS B in VRRP group 1, so BRAS A can become the master.
[BRASB-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 priority 200
[BRASB-Ten-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10
[BRASB–Ten-GigabitEthernet3/1/1.10] quit
h.     Configure the track entry associated with the BFD session on Ten-GigabitEthernet 3/1/1.10:
# Create track entry 2 and associate it with a BFD session.
[BRASB] track 2 bfd echo interface ten-gigabitethernet 3/1/1.10 remote ip 3.3.3.1 local ip 3.3.3.2
[BRASB-track-2] quit
# Associate VRRP group 1 on Ten-GigabitEthernet 3/1/1.10 with track entry 2 and switch the master and the backup when the state of track entry 2 changes to Negative.
[BRASB–Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 track 2 switchover
i.     Configure a VSRP instance:
[BRASB] vsrp peer pr1
[BRASB-vsrp-peer-pr1] peer ipv6 4::2 local 5::2
[BRASB-vsrp-peer-pr1] quit
[BRASB] vsrp instance vs1
[BRASB-vsrp-instance-vs1] backup id 1 peer pr1
[BRASB-vsrp-instance-vs1] bind vrrp ipv6 vrid 1 interface ten-gigabitethernet 3/1/1.10
[BRASB-vsrp-instance-vs1] nas id abc
[BRASB-vsrp-instance-vs1] nas port ten-gigabitethernet 3/1/2
[BRASB-vsrp-instance-vs1] backup route-advertise master-cost 20 backup-cost 30
[BRASB-vsrp-instance-vs1] quit
j.     Specify a virtual IPv6 address on Ten-GigabitEthernet 3/1/1:
[BRASB–Ten-GigabitEthernet3/1/1] ipv6 virtual-address fe80::100 vsrp vs1
k.     Configure IPoE authentication on Ten-GigabitEthernet 3/1/1:
[BRASB–Ten-GigabitEthernet3/1/1] ip subscriber l2-connected enable
[BRASB–Ten-GigabitEthernet3/1/1] ip subscriber dhcp domain dm1
[BRASB–Ten-GigabitEthernet3/1/1] ip subscriber dhcp username include source-mac
[BRASB–Ten-GigabitEthernet3/1/1] ip subscriber password plaintext 123456
[BRASB–Ten-GigabitEthernet3/1/1] bras vsrp-instance vs1
6.     Configure Device C:
a.     Configure OSPF:
# Enable OSPF process 1 and set its router ID to 6.6.6.1 (the IP address of Ten-GigabitEthernet 3/1/3).
[DeviceC] ospf 1 router-id 6.6.6.1
# Configure Area 0.
b.     Configure OSPFv3:
# Enable OSPFv3 process 1 and set its router ID to 6.6.6.1.
[DeviceC] ospfv3
[DeviceC-ospfv3-1] router-id 6.6.6.1
[DeviceC-ospfv3-1] quit
# Configure Area 0.
7.     Configure L2 Switch:
# Create VLAN 10.
[L2Switch] vlan 10
# Verify that BRAS A and BRAS B have the same IPoE user information about authenticated IPoE users.
·     On the master:
[BRASA] display access-user
         IPv6 address
         001094000001             L2 IPoE dynamic(D/D)
         3::4
·     On the backup:
[BRASB] display access-user
         IPv6 address
         3::4
Example: Configuring VSRP for PPPoE (PPP address pool)
As shown in Figure 6, the host runs PPPoE client dialup software. To ensure service availability, enable VSRP for PPPoE on BRAS A (the master PPPoE server) and BRAS B (the backup PPPoE server). When BRAS A fails, BRAS B takes over the PPPoE services to avoid service interruption. Use the RADIUS server for authentication, authorization, and accounting of the PPPoE client.
Figure 6 Network diagram
Table 4 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
1.     Assign IP addresses to interfaces, as shown in Figure 6. Configure routes for the host, the BRASs, the core router, and the RADIUS server to reach one another. (Details not shown.)
# Add the NAS IP address and shared key configuration to the clients.conf configuration file. (The NAS IP addresses for the three clients are 4.4.4.1, 6.6.6.1, and 5.5.5.1, and the shared key is radius.)
client 4.4.4.1/32 {
ipaddr = 4.4.4.1
netmask=24
secret=radius
client 6.6.6.1/32 {
ipaddr = 6.6.6.1
netmask=24
secret=radius
client 5.5.5.1/32 {
ipaddr = 5.5.5.1
netmask=24
secret=radius
# Add the PPPoE client configuration to the users file. (The username of the PPPoE client is user1, and the password is pass1.)
user1  Cleartext-Password :="pass1"
3.     Configure BRAS A:
a.     Configure a VRRP group:
# Assign an IP address to Gigabitethernet 1/0/1.
<BRASA> system-view
[BRASA-Ten-GigabitEthernet3/1/1] ip address 5.5.5.98 255.255.255.0
# Create IPv4 VRRP group 1 and set its virtual IP address to 5.5.5.100.
[BRASA-Ten-GigabitEthernet3/1/1] vrrp vrid 1 virtual-ip 5.5.5.100
# Set the priority of BRAS A to 105 in VRRP group 1 on Ten-GigabitEthernet 3/1/1.
[BRASA-Ten-GigabitEthernet3/1/1] vrrp vrid 1 priority 105
[BRASA-Ten-GigabitEthernet3/1/1] vrrp vrid 1 preempt-mode delay 90000
[BRASA-Ten-GigabitEthernet3/1/1] quit
# Associate VRRP group 1 on Ten-GigabitEthernet 3/1/1 with track entry 1 and decrease the device priority by 100 when the state of track entry 1 changes to Negative.
[BRASA-Ten-GigabitEthernet3/1/1] vrrp vrid 1 track 1 priority reduced 100
b.     Configure a VSRP instance:
# Create interface Loopback 1 and assign the interface an IP address of 1.1.1.1.
[BRASA] interface loopback 1
[BRASA-Loopback1] ip address 1.1.1.1 32
[BRASA-Loopback1] quit
# Create VSRP group 1 and enter VSRP peer view.
[BRASA] vsrp peer 1
# Specify the local address as 1.1.1.1 and the peer address as 2.2.2.2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[BRASA-vsrp-peer-1] peer 2.2.2.2 local 1.1.1.1
[BRASA-vsrp-peer-1] quit
# Create VSRP instance 1 and associate it with VSRP group 1. Set the backup ID of the VSRP instance to 1.
[BRASA] vsrp instance 1
[BRASA-vsrp-instance-1] backup id 1 peer 1
# Bind VSRP instance 1 to VRRP group 1 on Ten-GigabitEthernet 3/1/1 and set VSRP instance 1 to operate in hot backup mode.
[BRASA-vsrp-instance-1] bind vrrp vrid 1 interface ten-gigabitethernet 3/1/1
[BRASA-vsrp-instance-1] backup mode hot
# Specify the logical NAS IP address as 5.5.5.1.
[BRASA-vsrp-instance-1] nas ip 5.5.5.1
[BRASA-vsrp-instance-1] nas port ten-gigabitethernet 3/1/2
[BRASA-vsrp-instance-1] quit
c.     Configure a RADIUS scheme:
[BRASA-radius-rs1] primary authentication 10.20.30.1
[BRASA-radius-rs1] primary accounting 10.20.30.1
[BRASA-radius-rs1] key authentication simple radius
[BRASA-radius-rs1] key accounting simple radius
# Configure BRAS A to remove the domain name in the username sent to the RADIUS servers for RADIUS scheme rs1.
[BRASA-radius-rs1] user-name-format without-domain
# Specify the source IP address as 5.5.5.1 (the gateway address for the host) for outgoing RADIUS packets.
[BRASA-radius-rs1] nas-ip 5.5.5.1
[BRASA] radius session-control enable
# Configure the domain to use RADIUS scheme rs1 for authentication, authorization, and accounting for PPP users.
[BRASA-isp-dm1] authentication ppp radius-scheme rs1
[BRASA-isp-dm1] authorization ppp radius-scheme rs1
[BRASA-isp-dm1] accounting ppp radius-scheme rs1
[BRASA-isp-dm1] authorization-attribute ip-pool pool1
e.     Configure PPPoE authentication:
# Configure local BAS IP pool pool1, and add the IP address range from 5.5.5.2 to 5.5.5.10 to the pool. Specify 5.5.5.1 as a gateway address in the IP pool. Associate the IP pool with VSRP instance 1.
[BRASA] ip pool pool1 bas local
[BRASA-ip-pool-pool1] address range 5.5.5.2 5.5.5.10
[BRASA-ip-pool-pool1] gateway 5.5.5.1 24
[BRASA-ip-pool-pool1] vsrp-instance 1
[BRASA-ip-pool-pool1] quit
# Specify TCP port 10000 as the TCP port for VSRP to establish data channels for PPP and PPPoE session backup.
[BRASA] bras vsrp-port 10000
# Create interface Virtual-Template 10 and assign it an IP address of 5.5.5.1.
[BRASA] interface virtual-template 10
[BRASA-Virtual-Template10] ip address 5.5.5.1 24
# Configure Virtual-Template 10 to use CHAP for authentication and use address pool pool1 to assign IP addresses.
[BRASA-Virtual-Template10] ppp authentication-mode chap domain dm1
[BRASA-Virtual-Template10] remote address pool pool1
[BRASA-Virtual-Template10] quit
# Enable a PPPoE server on Ten-GigabitEthernet 3/1/1 and bind Ten-GigabitEthernet 3/1/1 to interface Virtual-Template 10.
[BRASA-Ten-GigabitEthernet3/1/1] pppoe-server bind virtual-template 10
# Associate Ten-GigabitEthernet 3/1/1 with VSRP instance 1.
[BRASA-Ten-GigabitEthernet3/1/1] bras vsrp-instance 1
4.     Configure BRAS B:
# Assign an IP address to Ten-GigabitEthernet 3/1/1.
<BRASB> system-view
[BRASB-Ten-GigabitEthernet3/1/1] ip address 5.5.5.99 255.255.255.0
[BRASB-Ten-GigabitEthernet3/1/1] vrrp vrid 1 virtual-ip 5.5.5.100
# Create interface Loopback 1 and assign the interface an IP address of 2.2.2.2.
[BRASB] interface loopback 1
[BRASB-Loopback1] ip address 2.2.2.2 32
[BRASB-Loopback1] quit
[BRASB] vsrp peer 1
# Specify the local IP address as 2.2.2.2 and the peer IP address as 1.1.1.1 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[BRASB-vsrp-peer-1] peer 1.1.1.1 local 2.2.2.2
[BRASB-vsrp-peer-1] quit
[BRASB] vsrp instance 1
[BRASB-vsrp-instance-1] backup id 1 peer 1
[BRASB-vsrp-instance-1] bind vrrp vrid 1 interface ten-gigabitethernet 3/1/1
[BRASB-vsrp-instance-1] backup mode hot
[BRASB-vsrp-instance-1] nas ip 5.5.5.1
[BRASB-vsrp-instance-1] nas port ten-gigabitethernet 3/1/2
[BRASB-vsrp-instance-1] quit
[BRASB-radius-rs1] primary authentication 10.20.30.1
[BRASB-radius-rs1] primary accounting 10.20.30.1
[BRASB-radius-rs1] key authentication simple radius
[BRASB-radius-rs1] key accounting simple radius
# Configure BRAS B to remove the domain name in the username sent to the RADIUS servers for RADIUS scheme rs1.
[BRASB-radius-rs1] user-name-format without-domain
[BRASB-radius-rs1] nas-ip 5.5.5.1
[BRASB] radius session-control enable
[BRASB-isp-dm1] authentication ppp radius-scheme rs1
[BRASB-isp-dm1] authorization ppp radius-scheme rs1
[BRASB-isp-dm1] accounting ppp radius-scheme rs1
[BRASB-isp-dm1] authorization-attribute ip-pool pool1
[BRASB] ip pool pool1 bas local
[BRASB-ip-pool-pool1] address range 5.5.5.2 5.5.5.10
[BRASB-ip-pool-pool1] gateway 5.5.5.1 24
[BRASB-ip-pool-pool1] vsrp-instance 1
[BRASB-ip-pool-pool1] quit
[BRASB] bras vsrp-port 10000
[BRASB] interface virtual-template 10
[BRASB-Virtual-Template10] ip address 5.5.5.1 24
[BRASB-Virtual-Template10] ppp authentication-mode chap domain dm1
[BRASB-Virtual-Template10] remote address pool pool1
[BRASB-Virtual-Template10] quit
[BRASB-Ten-GigabitEthernet3/1/1] pppoe-server bind virtual-template 10
[BRASB-Ten-GigabitEthernet3/1/1] bras vsrp-instance 1
[BRASB-Ten-GigabitEthernet3/1/1] quit
1.     Enter username user1 and password pass1 on the PPPoE client software to initiate a connection request to the PPPoE server.
2.     Verify that BRAS A (the master) and BRAS B (the backup) have the same PPP and PPPoE sessions after the client accesses the network.
# Display PPP sessions synchronized by VSRP instances on BRAS A.
         IPv6 address
0x1      XGE3/1/1                 5.5.5.2             00e0-2984-90d2  -/-
         user1                    PPPoE users
# Display PPP sessions synchronized by VSRP instances on BRAS B.
         Username                 IPv6 address        Access type
         IPv6 address
         user1                    PPPoE users
3.     Verify that BRAS B becomes the master and takes over the PPPoE services when BRAS A fails (for example, Ten-GigabitEthernet 3/1/1 is down).
         IPv6 address
         user1                    PPPoE users
Example: Configuring VSRP for PPPoE (NDRA one prefix per user)
As shown in Figure 7, the hosts run PPPoE client dialup software. To ensure service availability, enable VSRP for PPPoE on BRAS A (the master PPPoE server) and BRAS B (the backup PPPoE server). When BRAS A fails, BRAS B takes over the PPPoE services to avoid service interruption. Perform the following tasks:
·     Configure NDRA for IPv6 address assignment on the BRAS devices. With NDRA configured, a host obtains an IPv6 prefix in an RA message. The host then generates an IPv6 global unicast address by combining the IPv6 prefix and the negotiated IPv6 interface identifier. The IPv6 prefix in the RA message is from a prefix pool.
·     Enable VSRP for PPPoE to back up PPPoE sessions in real time.
·     Use the RADIUS server for authentication, authorization, and accounting of PPPoE users.
Figure 7 Network diagram
Table 5 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
1.     Assign IP addresses to interfaces, as shown in Figure 7. (Details not shown.)
# Add the NAS IP address and shared key configuration to the clients.conf configuration file. (The NAS IP addresses for the two clients are 4::2, and 5::2, respectively, and the shared key is 123456.)
client 3::3/64 {
ipaddr = 3::3
netmask=64
secret=123456
client 4::2/64 {
ipaddr = 4::2
netmask=64
secret=123456
client 5::2/64 {
ipaddr = 5::2
netmask=64
secret=123456
# Add the PPPoE client configuration to the users file. (The usernames of the three PPPoE clients are user1, user2, and user3. The password is 123456.)
user1  Cleartext-Password :="123456"
user2  Cleartext-Password :="123456"
user3  Cleartext-Password :="123456"
<BRASA> system-view
[BRASA-radius-rs1] primary authentication ipv6 6::2
[BRASA-radius-rs1] primary accounting ipv6 6::2
# Specify the source IP address as 3::3 (the gateway address for the hosts) for outgoing RADIUS packets.
[BRASA-radius-rs1] nas-ip ipv6 3::3
b.     Configure a prefix pool:
# Create prefix pool 1, and specify the prefix 3::/32 with the assigned prefix length 64. Prefix pool 1 contains 4294967296 prefixes from 3::/64 to 3:0:FFFF:FFFF::/64.
[BRASA] ipv6 dhcp prefix-pool 1 prefix 3::/32 assign-len 64
# Create IPv6 address pool pppoev6.
[BRASA] ipv6 pool pppoev6
# Apply prefix pool 1 to IPv6 address pool pppoev6.
[BRASA-ipv6-pool-pppoev6] prefix-pool 1 export-route
# Associate IPv6 address pool pppoev6 with VSRP instance vs1.
[BRASA-ipv6-pool-pppoev6] vsrp-instance vs1
[BRASA-ipv6-pool-pppoev6] quit
c.     Configure an authentication domain:
# Specify the prefix pool and primary DNS server address for users in the ISP domain.
[BRASA-isp-dm1] authorization-attribute ipv6-nd-prefix-pool pppoev6
[BRASA-isp-dm1] authorization-attribute primary-dns ipv6 8::8
d.     Configure OSPFv3:
[BRASA] interface loopback 0
[BRASA-LoopBack0] ospfv3 1 area 0
# Set the OSPFv3 cost to 30 for Loopback 0 for the RADIUS server to choose the route to Loopback 0 based on the cost.
[BRASA-LoopBack0] ospfv3 cost 30
[BRASA-LoopBack0] quit
[BRASA] ospfv3
[BRASA] ipv6 prefix-list 1 permit permit 3:: 32
e.     Configure an IPv6 VRRP group:
f.     Configure a VSRP instance:
[BRASA-vsrp-instance-vs1] bind vrrp ipv6 vrid 1 interface Ten-GigabitEthernet3/1/1.10
g.     Configure PPPoE:
# Create interface Virtual-Template 1.
# Enable PAP authentication on Virtual-Template 1.
[BRASA-Virtual-Template1] ppp authentication-mode pap domain dm1
# Configure Virtual-Template 1 to automatically generate a link-local address.
[BRASA-Virtual-Template1] ipv6 address auto link-local
# Disable RA message suppression on Virtual-Template 1.
[BRASA-Virtual-Template1] undo ipv6 nd ra halt
# Enable DHCPv6 server on Virtual-Template 1, and associate the interface with VSRP instance vs1.
[BRASA-Virtual-Template1] ipv6 dhcp select server
[BRASA-Virtual-Template1] ipv6 dhcp vsrp-instance vs1
[BRASA-Virtual-Template1] quit
# Enable a PPPoE server on Ten-GigabitEthernet 3/1/1, and bind the interface to Virtual-Template 1.
[BRASA-Ten-GigabitEthernet3/1/1] bras vsrp-instance vs1
<BRASB> system-view
[BRASB-radius-rs1] primary authentication ipv6 6::2
[BRASB-radius-rs1] primary accounting ipv6 6::2
# Specify the source IP address as 3::3 (the gateway address for hosts) for outgoing RADIUS packets.
[BRASB-radius-rs1] nas-ip ipv6 3::3
[BRASB] ipv6 dhcp prefix-pool 1 prefix 3::/32 assign-len 64
[BRASB] ipv6 pool pppoev6
[BRASB-ipv6-pool-pppoev6] prefix-pool 1 export-route
[BRASB-ipv6-pool-pppoev6] vsrp-instance vs1
[BRASB-ipv6-pool-pppoev6] quit
[BRASB-isp-dm1] authorization-attribute ipv6-nd-prefix-pool pppoev6
[BRASB-isp-dm1] authorization-attribute primary-dns ipv6 8::8
[BRASB] interface loopback 0
[BRASB-LoopBack0] ospfv3 1 area 0
[BRASB-LoopBack0] ospfv3 cost 30
[BRASB-LoopBack0] quit
[BRASB] ospfv3
[BRASB-vsrp-instance-vs1] bind vrrp ipv6 vrid 1 interface Ten-GigabitEthernet3/1/1.10
g.     Configure PPPoE:
[BRASB-Virtual-Template1] ppp authentication-mode pap domain dm1
[BRASB-Virtual-Template1] ipv6 address auto link-local
[BRASB-Virtual-Template1] undo ipv6 nd ra halt
[BRASB-Virtual-Template1] ipv6 dhcp select server
[BRASB-Virtual-Template1] ipv6 dhcp vsrp-instance vs1
[BRASB-Virtual-Template1] quit
[BRASB-Ten-GigabitEthernet3/1/1] bras vsrp-instance vs1
[DeviceC] ospfv3
# Configure Area 0.
6.     Configure L2 Switch:
# Create VLAN 10.
[L2Switch] vlan 10
1.     Enter username user1 and password 123456 on the PPPoE client software to initiate a connection request to the PPPoE server.
         IPv6 address
0x1      XGE3/1/1                 -                   001b-21a8-0949  -/-
         user1                    PPPoE users
         3::4C0B:9D77:3D96:F2B
         IPv6 address
         user1                    PPPoE users
3.     Verify that BRAS B becomes the master and takes over the PPPoE services when BRAS A fails (for example, Ten-GigabitEthernet 3/1/2 is down).
         IPv6 address
         user1                    PPPoE users
Example: Configuring VSRP for dual-stack PPPoE (IPv4 address pool and NDRA one prefix per user)
As shown in Figure 8, the hosts run PPPoE client dialup software. To ensure service availability, enable VSRP for PPPoE on BRAS A (the master PPPoE server) and BRAS B (the backup PPPoE server). When BRAS A fails, BRAS B takes over the PPPoE services to avoid service interruption. Perform the following tasks:
·     Configure an IPv4 address pool for IPv4 address assignment on the BRAS devices.
Figure 8 Network diagram
Table 6 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
Interface4
1.     Assign IP addresses to interfaces, as shown in Figure 8. (Details not shown.)
client 3.3.3.3/32 {
ipaddr = 3.3.3.3
netmask=32
secret=123456
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=123456
client 5.5.5.2/32 {
ipaddr = 5.5.5.2
netmask=24
secret=123456
3.     Configure the DHCPv4 server:
This example uses a network device as the DHCPv4 server. As a best practice, use a dedicated DHCPv4 server.
# Enable DHCP.
<DHCP> system-view
[DHCP] dhcp enable
# Create IPv4 address pool pppoev4 and enter its view.
[DHCP] ip pool pppoev4
[DHCP-ip-pool-pppoev4] network 3.3.3.0 24
[DHCP-ip-pool-pppoev4] gateway-list 3.3.3.3 export-route
[DHCP-ip-pool-pppoev4] dns-list 8.8.8.8
[DHCP-ip-pool-pppoev4] forbidden-ip 3.3.3.1
[DHCP-ip-pool-pppoev4] forbidden-ip 3.3.3.2
[DHCP-ip-pool-pppoev4] forbidden-ip 3.3.3.3
[DHCP-ip-pool-pppoev4] quit
<BRASA> system-view
b.     Configure an IPv4 address pool:
# Enable DHCP.
[BRASA] dhcp enable
# Configure IPv4 address pool pppoev4 and associate the pool with VSRP instance vs1.
[BRASA] ip pool pppoev4
[BRASA-ip-pool-pppoev4] gateway-list 3.3.3.3 export-route
[BRASA-ip-pool-pppoev4] remote-server 6.6.6.3
[BRASA-ip-pool-pppoev4] vsrp-instance vs1
[BRASA-ip-pool-pppoev4] network 3.3.3.0 24 export-route
[BRASA-ip-pool-pppoev4] quit
c.     Configure a prefix pool:
# Specify the IPv4 address pool, prefix pool, and primary DNS server address for users in the ISP domain.
[BRASA-isp-dm1] authorization-attribute ip-pool pppoev4
e.     Configure OSPF:
# Configure OSPF to redistribute the static route filtered by routing policy 1. BRAS A then advertises the static route destined for the subnet where the host resides to Device C. In this way, Device C can select the route to the host based on the state of BRAS A and BRAS B in the VSRP instance.
[BRASA-ospf-1] import-route static route-policy 1
[BRASA-ospf-1] quit
# Configure Area 0.
[BRASA] ospf
[BRASA-ospf-1] quit
[BRASA] ospfv3
When VSRP is enabled for PPPoE, IPv4 and IPv6 users share a data backup channel. You can configure an IPv4 or IPv6 data backup channel for dual-stack PPPoE. This example creates an IPv6 data backup channel.
i.     Configure PPPoE:
# Associate Virtual-Template 1 with VSRP instance vs1.
[BRASA-Virtual-Template1] dhcp relay vsrp-instance vs1
<BRASB> system-view
# Enable DHCP.
[BRASB] dhcp enable
[BRASB] ip pool pppoev4
[BRASB-ip-pool-pppoev4] gateway-list 3.3.3.3 export-route
[BRASB-ip-pool-pppoev4] remote-server 6.6.6.3
[BRASB-ip-pool-pppoev4] vsrp-instance vs1
[BRASB-ip-pool-pppoev4] network 3.3.3.0 24 export-route
[BRASB-ip-pool-pppoev4] quit
[BRASB-isp-dm1] authorization-attribute ip-pool pppoev4
e.     Configure OSPF:
# Configure OSPF to redistribute the user network route filtered by routing policy 1. BRAS B then advertises the user network route destined for the subnet where the host resides to Device C. In this way, Device C can select the route to the host based on the state of BRAS A and BRAS B in the VSRP instance.
[BRASB-ospf-1] quit
# Configure Area 0.
[BRASB] ospf
[BRASB-ospf-1] quit
[BRASB] ospfv3
j.     Configure PPPoE:
[BRASB-Virtual-Template1] dhcp relay vsrp-instance vs1
a.     Configure OSPF:
# Configure Area 0.
[DeviceC] ospfv3
# Configure Area 0.
# Create VLAN 10.
[L2Switch] vlan 10
         IPv6 address
0x1      XGE3/1/1                 3.3.3.6             001b-21a8-0949  -/-
         user1                    PPPoE users
         IPv6 address
         user1                    3::4C0B:9D77:3D96:F PPPoE users
                                  2B
         IPv6 address
         user1                    PPPoE users
Example: Configuring VSRP for dual-stack PPPoE (IPv4 address pool and IPv6 address pool for a VPN instance)
As shown in Figure 9, the hosts run PPPoE client dialup software. To ensure service availability, enable VSRP for PPPoE on BRAS A (the master PPPoE server) and BRAS B (the backup PPPoE server). When BRAS A fails, BRAS B takes over the PPPoE services to avoid service interruption. Perform the following tasks:
·     Configure an IPv4 address pool and an IPv6 address pool for IP address assignment for uses in a VPN instance on the BRAS devices.
Figure 9 Network diagram
Table 7 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
Interface4
Configure MPLS L3VPN before you configure PPPoE. Assign matching VPN targets to the sites of VPN 1 for the sites to communicate with each other. This example provides only access authentication configuration on PE 1. For more information about other MPLS L3VPN configuration, see MPLS Configuration Guide.
1.     Assign IP addresses to interfaces, as shown in Figure 9. (Details not shown.)
client 3.3.3.3/32 {
ipaddr = 3.3.3.3
netmask=32
secret=123456
client 4.4.4.2/32 {
ipaddr = 4.4.4.2
netmask=32
secret=123456
client 5.5.5.2/32 {
ipaddr = 5.5.5.2
netmask=24
secret=123456
# Add the PPPoE client configuration to the users file. (The username of the PPPoE client is user1. The password is 123456.)
a.     Create VPN instance vpn1.
<BRASA> system-view
[BRASA] ip vpn-instance vpn1
[BRASA-vpn-instance-vpn1] quit
b.     Configure a RADIUS scheme:
c.     Configure PBR:
Configure static routes and PBR for the RADIUS packets sent by BRAS devices to reach the RADIUS server.
# Configure a static route for users in VPN instance vpn1 to reach the RADIUS server.
[BRASA] ip route-static vpn-instance vpn1 6.6.6.2 32 4.4.4.1 public
# Configure ACL 3030 to match traffic with source address 6.6.6.2/32 and destination address 3.3.3.3/32.
[BRASA] acl advanced 3030
[BRASA-acl-ipv4-adv-3030] rule permit ip source 6.6.6.2 0 destination 3.3.3.3 0
[BRASA-acl-ipv4-adv-3030] quit
# Create PBR policy public_to_vpn1. Configure the policy to permit traffic that matches ACL 3030 in VPN instance vpn1.
[BRASA] policy-based-route public_to_vpn1 permit node 0
[BRASA-pbr-public_to_vpn1-0] if-match acl 3030
[BRASA-pbr-public_to_vpn1-0] apply access-vpn vpn-instance vpn1
[BRASA-pbr-public_to_vpn1-0] quit
# Apply PBR policy public_to_vpn1 to Ten-GigabitEthernet 3/1/2.
[BRASA–Ten-GigabitEthernet3/1/2] ip policy-based-route public_to_vpn1
d.     Configure an IPv4 address pool:
# Enable DHCP.
[BRASA] dhcp enable
[BRASA-ip-pool-pppoev4] dns-list 8.8.8.8
[BRASA-ip-pool-pppoev4] forbidden-ip 3.3.3.1
[BRASA-ip-pool-pppoev4] forbidden-ip 3.3.3.2
[BRASA-ip-pool-pppoev4] forbidden-ip 3.3.3.3
# Associate the address pool with VSRP instance vs1 and VPN instance vpn1.
[BRASA-ip-pool-pppoev4] vpn-instance vpn1
e.     Configure an IPv6 address pool:
# Create IPv6 address pool pppoev6. Assign subnet 3::/64 to the hosts and specify the DNS server address.
[BRASA-ipv6-pool-pppoev6] network 3::/64 export-route
[BRASA-ipv6-pool-pppoev6] dns-server 8::8
[BRASA-ipv6-pool-pppoev6] vpn-instance vpn1
[BRASA] ipv6 dhcp server forbidden-address 3::1 vpn-instance vpn1
[BRASA] ipv6 dhcp server forbidden-address 3::2 vpn-instance vpn1
[BRASA] ipv6 dhcp server forbidden-address 3::3 vpn-instance vpn1
f.     Configure an authentication domain:
# Create ISP domain dm1 and enter ISP domain view.
# Specify the IPv4 address pool, IPv6 address pool, and VPN instance for users in the ISP domain.
[BRASA-isp-dm1] authorization-attribute ipv6-pool pppoev6
[BRASA-isp-dm1] authorization-attribute vpn-instance vpn1
g.     Configure OSPF:
# Configure Area 0.
[BRASA-ospf-1] quit
h.     Configure OSPFv3:
[BRASA] ospfv3
i.     Configure an IPv6 VRRP group:
j.     Configure a VSRP instance:
k.     Configure PPPoE:
# Set the managed address configuration flag (M) to 1 and set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
[BRASA-Virtual-Template1] ipv6 nd autoconfig managed-address-flag
[BRASA-Virtual-Template1] ipv6 nd autoconfig other-flag
[BRASA-Virtual-Template1] dhcp vsrp-instance vs1
# Enable DHCPv6 server on Virtual-Template 1 and associate the interface with VSRP instance vs1.
# Enable a PPPoE server on Ten-GigabitEthernet 3/1/1 and associate the interface with Virtual-Template 1.
<BRASB> system-view
[BRASB] ip vpn-instance vpn1
[BRASB-vpn-instance-vpn1] quit
# Create a RADIUS scheme named rs1 and enter RADIUS scheme view.
# Specify the primary authentication server and primary accounting server.
# Set the shared key for secure RADIUS authentication and accounting communication.
c.     Configure PBR:
[BRASB] ip route-static vpn-instance vpn1 6.6.6.2 32 5.5.5.1 public
[BRASB] acl advanced 3030
[BRASB-acl-ipv4-adv-3030] rule permit ip source 6.6.6.2 0 destination 3.3.3.3 0
[BRASB-acl-ipv4-adv-3030] quit
[BRASB] policy-based-route public_to_vpn1 permit node 0
[BRASB-pbr-public_to_vpn1-0] if-match acl 3030
[BRASB-pbr-public_to_vpn1-0] apply access-vpn vpn-instance vpn1
[BRASB-pbr-public_to_vpn1-0] quit
[BRASB–Ten-GigabitEthernet3/1/2] ip policy-based-route public_to_vpn1
# Enable DHCP.
[BRASB] dhcp enable
[BRASB-ip-pool-pppoev4] dns-list 8.8.8.8
[BRASB-ip-pool-pppoev4] forbidden-ip 3.3.3.1
[BRASB-ip-pool-pppoev4] forbidden-ip 3.3.3.2
[BRASB-ip-pool-pppoev4] forbidden-ip 3.3.3.3
[BRASB-ip-pool-pppoev4] vpn-instance vpn1
# Create IPv6 address pool pppoev6. Assign subnet 3::/64 to the hosts and specify DNS server address.
[BRASB-ipv6-pool-pppoev6] network 3::/64 export-route
[BRASB-ipv6-pool-pppoev6] dns-server 8::8
[BRASB-ipv6-pool-pppoev6] vpn-instance vpn1
[BRASB] ipv6 dhcp server forbidden-address 3::1 vpn-instance vpn1
[BRASB] ipv6 dhcp server forbidden-address 3::2 vpn-instance vpn1
[BRASB] ipv6 dhcp server forbidden-address 3::3 vpn-instance vpn1
[BRASB-isp-dm1] authorization-attribute ipv6-pool pppoev6
[BRASB-isp-dm1] authorization-attribute vpn-instance vpn1
g.     Configure OSPF:
# Configure Area 0.
[BRASB-ospf-1] quit
[BRASB] ospfv3
# Configure Ten-GigabitEthernet 3/1/1.10 to terminate VLAN 10.
j.     Configure the track entry associated with the BFD session on Ten-GigabitEthernet 3/1/1.10:
k.     Configure a VSRP instance:
# Create VSRP group pr1 and enter VSRP peer view.
# Create VSRP instance vs1 and enter its view.
l.     Configure PPPoE:
[BRASB-Virtual-Template1] ipv6 nd autoconfig managed-address-flag
[BRASB-Virtual-Template1] ipv6 nd autoconfig other-flag
[BRASB-Virtual-Template1] dhcp vsrp-instance vs1
5.     Configure P1:
a.     Configure OSPF:
<P1> system-view
[P1] ospf 1 router-id 6.6.6.1
# Configure Area 0.
[P1-ospf-1] area 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 4.4.4.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] network 5.5.5.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] quit
[P1-ospf-1] quit
[P1] ospfv3
[P1-ospfv3-1] router-id 6.6.6.1
[P1-ospfv3-1] quit
# Configure Area 0.
[P1] interface ten-gigabitethernet 3/1/1
[P1–Ten-GigabitEthernet3/1/1] ospfv3 1 area 0
[P1–Ten-GigabitEthernet3/1/1] quit
[P1] interface ten-gigabitethernet 3/1/2
[P1–Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[P1–Ten-GigabitEthernet3/1/2] quit
[P1] interface ten-gigabitethernet 3/1/3
[P1-Ten-GigabitEthernet3/1/3] ospfv3 1 area 0
[P1-Ten-GigabitEthernet3/1/3] quit
c.     Configure static routes for P1 to reach 3.3.3.3:
# Configure a static route with BRAS A as the next hop.
[P1] ip route-static 3.3.3.3 32 4.4.4.2
# Configure a static route with BRAS B as the next hop.
[P1] ip route-static 3.3.3.3 32 5.5.5.2
# Create VLAN 10.
[L2Switch] vlan 10
         IPv6 address
0x1      XGE3/1/1                 3.3.3.4             001b-21a8-0949  -/-
         user1                    PPPoE users
         3::4
         IPv6 address
         user1                    PPPoE users
         3::4
         IPv6 address
         user1                    PPPoE users
         3::4
Example: Configuring VSRP for L2TP
As shown in Figure 10, enable VSRP for L2TP on LAC 1 (the master) and LAC 2 (the backup). When LAC 1 fails, LAC 2 can take over the L2TP services to avoid service interruption.
Figure 10 Network diagram
Table 8 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
1.     Assign IP addresses to interfaces, as shown in Figure 10. Configure routes for the remote user, the LACs, the LNS, and the RADIUS servers to reach one another. (Details not shown.)
2.     Configure RADIUS server 1 and RADIUS server 2. (Details not shown.)
3.     Configure the LNS:
# Create a RADIUS scheme named rad and enter RADIUS scheme view.
<LNS> system-view
[LNS] radius scheme rad
[LNS-radius-rad] primary authentication 7.7.7.2
[LNS-radius-rad] primary accounting 7.7.7.2
[LNS-radius-rad] key authentication simple auth2pass
[LNS-radius-rad] key accounting simple auth2pass
# Specify the source IP address as 7.7.7.1 (the IP address of Ten-GigabitEthernet 3/1/2) for outgoing RADIUS packets.
[LNS-radius-rad] nas-ip 7.7.7.1
[LNS-radius-rad] quit
# Enable DHCP and configure an address pool.
[LNS] dhcp enable
[LNS] ip pool pool1
[LNS-ip-pool-pool1] network 192.168.1.0 mask 255.255.255.0 export-route
[LNS-ip-pool-pool1] gateway-list 192.168.1.1 export-route
[LNS-ip-pool-pool1] forbidden-ip 192.168.1.1
[LNS-ip-pool-pool1] quit
# Create ISP domain bbb and configure the domain to use RADIUS scheme rad for authentication, authorization, and accounting for PPP users.
[LNS] domain name bbb
[LNS-isp-bbb] authentication ppp radius-scheme rad
[LNS-isp-bbb] authorization ppp radius-scheme rad
[LNS-isp-bbb] accounting ppp radius-scheme rad
[LNS-isp-bbb] authorization-attribute ip-pool pool1
[LNS-isp-bbb] quit
# Enable L2TP.
[LNS] l2tp enable
# Create interface Virtual-Template 1, and set the PPP authentication mode to PAP.
[LNS] interface virtual-template 1
[LNS-Virtual-Template1] ppp authentication-mode pap domain bbb
[LNS-Virtual-Template1] quit
# Create L2TP group 1 in LNS mode.
[LNS] l2tp-group 1 mode lns
# Configure the local tunnel name as LNS.
[LNS-l2tp1] tunnel name LNS
# Specify Virtual-Template 1 for receiving calls from the specified LAC.
[LNS-l2tp1] allow l2tp virtual-template 1 remote LAC
# Disable tunnel authentication.
[LNS-l2tp1] undo tunnel authentication
[LNS-l2tp1] quit
4.     Configure LAC 1:
<LAC1> system-view
[LAC1] radius scheme rad
# Specify the primary authentication server with IP address 10.1.1.2 and UDP port number 1812.
[LAC1-radius-rad] primary authentication 10.1.1.2 1812
# Specify the primary accounting server with IP address 10.1.1.2 and UDP port number 1813.
[LAC1-radius-rad] primary accounting 10.1.1.2 1813
[LAC1-radius-rad] key authentication simple auth1pass
[LAC1-radius-rad] key accounting simple auth1pass
# Specify the source IP address as 1.1.1.100 (the virtual IP address of VRRP group 1) for outgoing RADIUS packets.
[LAC1-radius-rad] nas-ip 1.1.1.100
[LAC1-radius-rad] quit
# Create ISP domain bbb and enter ISP domain view.
[LAC1] domain name bbb
# Configure the domain to use RADIUS scheme rad for authentication, authorization, and accounting for PPP users.
[LAC1-isp-bbb] authentication ppp radius-scheme rad
[LAC1-isp-bbb] authorization ppp radius-scheme rad
[LAC1-isp-bbb] accounting ppp radius-scheme rad
[LAC1-isp-bbb] quit
# Create interface Virtual-Template 1 and set the PPP authentication mode to PAP.
[LAC1] interface virtual-template 1
[LAC1-Virtual-Template1] ppp authentication-mode pap domain bbb
[LAC1-Virtual-Template1] quit
# Enable L2TP.
[LAC1] l2tp enable
# Create L2TP group 1 in LAC mode.
[LAC1] l2tp-group 1 mode lac
# Configure the local tunnel name as LAC.
[LAC1-l2tp1] tunnel name LAC
# Specify PPP user user1 as the condition for the LAC to initiate tunneling requests.
[LAC1-l2tp1] user fullusername user1
# Specify the LNS IP address as 5.5.5.1.
[LAC1-l2tp1] lns-ip 5.5.5.1
[LAC1-l2tp1] undo tunnel authentication
# Associate L2TP group 1 with VSRP instance l2tp1.
[LAC1-l2tp1] vsrp-instance l2tp1
# Specify the source IP address for the L2TP tunnel as 6.6.6.1. After successful VSRP master and backup negotiation, only the master LAC generates a static route to the source address with the loopback interface as the output interface. To forward downstream traffic from LNS to the remote end always through the master LAC, use a dynamic routing protocol to advertise this static route. (Details not shown.)
[LAC1-l2tp1] tunnel vsrp source-ip 6.6.6.1
[LAC1-l2tp1] quit
# Configure the PPPoE server.
[LAC1] interface ten-gigabitethernet 3/1/1
[LAC1-Ten-GigabitEthernet3/1/1] pppoe-server bind virtual-template 1
# Associate the PPPoE server-enabled interface with VSRP instance l2tp1.
[LAC1-Ten-GigabitEthernet3/1/1] bras vsrp-instance l2tp1
[LAC1-Ten-GigabitEthernet3/1/1] quit
# Create track entry 2 to monitor the link status of uplink interface Ten-GigabitEthernet 3/1/2.
[LAC1] track 2 interface ten-gigabitethernet 3/1/2
# Create VRRP group 1 and set its virtual IP address to 1.1.1.100.
[LAC1-Ten-GigabitEthernet3/1/1] vrrp vrid 1 virtual-ip 1.1.1.100
# Set the priority of LAC 1 to 120 in VRRP group 1 on Ten-GigabitEthernet 3/1/1.
[LAC1-Ten-GigabitEthernet3/1/1] vrrp vrid 1 priority 120
# Configure LAC 1 to operate in preemptive mode, and set the preemption delay to 90000 centiseconds (15 minutes). When the original master recovers, it has 15 minutes to synchronize data from the new master before switch-back to ensure stability and data consistency of the VRRP group.
[LAC1-Ten-GigabitEthernet3/1/1] vrrp vrid 1 preempt-mode delay 90000
# Associate VRRP group 1 on Ten-GigabitEthernet 3/1/1 with track entry 2 and decrease the device priority by 50 when the state of track entry 2 changes to Negative.
[LAC1-Ten-GigabitEthernet3/1/1] vrrp vrid 1 track 2 priority reduced 50
# Create VSRP group pname, and enter VSRP peer view.
[LAC1] vsrp peer pname
# Specify the local IP address as 2.2.2.2 and the peer IP address as 3.3.3.3 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[LAC1-vsrp-peer-pname] peer 3.3.3.3 local 2.2.2.2
[LAC1-vsrp-peer-pname] quit
# Create VSRP instance l2tp1 and associate it with VSRP group pname. Set the backup ID of the VSRP instance to 1.
[LAC1] vsrp instance l2tp1
[LAC1-vsrp-instance-l2tp1] backup id 1 peer pname
# Bind VSRP instance l2tp1 to VRRP group 1 on Ten-GigabitEthernet 3/1/1.
[LAC1-vsrp-instance-l2tp1] bind vrrp vrid 1 interface ten-gigabitethernet 3/1/1
[LAC1-vsrp-instance-l2tp1] quit
5.     Configure LAC 2:
<LAC2> system-view
[LAC2] radius scheme rad
[LAC2-radius-rad] primary authentication 10.1.1.2 1812
[LAC2-radius-rad] primary accounting 10.1.1.2 1813
[LAC2-radius-rad] key authentication simple auth1pass
[LAC2-radius-rad] key accounting simple auth1pass
[LAC2-radius-rad] nas-ip 1.1.1.100
[LAC2-radius-rad] quit
[LAC2] domain name bbb
[LAC2-isp-bbb] authentication ppp radius-scheme rad
[LAC2-isp-bbb] authorization ppp radius-scheme rad
[LAC2-isp-bbb] accounting ppp radius-scheme rad
[LAC2-isp-bbb] quit
[LAC2] interface virtual-template 1
[LAC2-Virtual-Template1] ppp authentication-mode pap domain bbb
[LAC2-Virtual-Template1] quit
# Enable L2TP.
[LAC2] l2tp enable
[LAC2] l2tp-group 1 mode lac
[LAC2-l2tp1] tunnel name LAC
[LAC2-l2tp1] user fullusername user1
[LAC2-l2tp1] lns-ip 5.5.5.1
[LAC2-l2tp1] undo tunnel authentication
[LAC2-l2tp1] vsrp-instance l2tp1
[LAC2-l2tp1] tunnel vsrp source-ip 6.6.6.1
[LAC2-l2tp1] quit
[LAC2] interface ten-gigabitethernet 3/1/1
[LAC2-Ten-GigabitEthernet3/1/1] pppoe-server bind virtual-template 1
# Associate the PPPoE server with VSRP instance l2tp1.
[LAC2-Ten-GigabitEthernet3/1/1] bras vsrp-instance l2tp1
[LAC2-Ten-GigabitEthernet3/1/1] quit
[LAC2-Ten-GigabitEthernet3/1/1] vrrp vrid 1 virtual-ip 1.1.1.100
# Create VSRP group pname and enter VSRP peer view.
[LAC2] vsrp peer pname
# Specify the local IP address as 3.3.3.3 and the peer address as 2.2.2.2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[LAC2-vsrp-peer-pname] peer 2.2.2.2 local 3.3.3.3
[LAC2-vsrp-peer-pname] quit
[LAC2] vsrp instance l2tp1
[LAC2-vsrp-instance-l2tp1] backup id 1 peer pname
[LAC2-vsrp-instance-l2tp1] bind vrrp vrid 1 interface ten-gigabitethernet 3/1/1
[LAC2-vsrp-instance-l2tp1] quit
¡     # To enable RADIUS server 1 to always interact with the master LAC, configure the following settings. After configuration, when both the master and backup LACs redistribute the direct route of subnet 1.1.1.0/24 (where NAS IP address 1.1.1.100 resides) into the dynamic routing protocol (such as OSPF) and advertise the direct route to the upstream CR, the CR learns the subnet route 1.1.1.0/24 advertised by only the master device.
¡     # Create track entry 1 and associate it with VRRP group 1 on interface Ten-GigabitEthernet 3/1/1. When the device is in master state, the associated track entry changes to Positive state. When the device is in backup state, the associated track entry changes to Negative state.
[LAC2] track 1 vrrp interface ten-gigabitethernet 3/1/1 vrid 1
[LAC2-track-1] quit
¡     # On Ten-GigabitEthernet 3/1/1, associate the direct route with track entry 1 and apply the cost 100 to the direct route when the state of track entry 1 changes to Negative.
[LAC2-Ten-GigabitEthernet3/1/1] route-direct track 1 degrade-cost 100
¡     # Redistibute direct routes into OSPF process 100, and specify to use the original cost of redistributed routes. This ensures that the cost value for the routes advertised by the backup device to the CR is larger than the cost value for the routes advertised by the master device. As a result, the CR device learns the subnet route 1.1.1.0/24 advertised by only the master device. (This example uses OSPF to illustrate only the key configuration for route redistribution.)
[LAC2] ospf 100
[LAC2-ospf-100] import-route direct inherit-cost
[LAC2-ospf-100] quit
6.     Enter the username user1 and password pwd on the PPPoE client dialup software to initiate a connection request on the remote user.
# Verify that LAC 1 (the master) has synchronized L2TP service data to LAC 2 (the backup).
<LAC1> display vsrp instance l2tp1
VSRP instance name: l2tp1
 VSRP peer name: pname
 Backup ID: 1
 Bound VRID: VRRP VRID 1 interface Ten-GigabitEthernet3/1/1
 Instance status: Master
 Local status: Master
 Peer status: Backup
 Backup mode: Hot
 Traffic backup interval: 10(minutes)
 Traffic backup threshold: 50(MB)
 Route advertisement: Master only
# Verify that LAC 1 and LAC 2 have the same L2TP sessions.
<LAC1> display ppp sync-session vsrp-instance l2tp1
VSRP instance: l2tp1
VSRP instance state: Master
PSID        LTID       LSID      RSID      MAC address       IP address
Interface   Username   IPv6 NDPrefix       IPv6 PDPrefix     IPv6 address
1           28532      467       32060     6c5d-5cb3-0106    -
XGE3/1/1    user1      -                   -                 -
<LAC2> display ppp sync-session vsrp-instance l2tp1
VSRP instance state: Backup
# Verify that LAC 1 and LAC 2 have the same L2TP tunnel information.
<LAC1> display l2tp tunnel vsrp l2tp1
Total synchronized L2TP tunnels: 1
LocalTID RemoteTID State        Sessions RemoteAddress   RemotePort RemoteName
28532    4         Established  1        5.5.5.1         1701       LNS
<LAC2> display l2tp tunnel vsrp l2tp1
# Shut down LAC 1.
# Verify that LAC 2 becomes the master and takes over the L2TP services. LAC 1 becomes the backup. The data channel between them is disconnected.
<LAC2> display vsrp instance l2tp1
 Backup ID: 1
 Peer status: Down
 Backup mode: Hot
Example: Configuring VSRP and VRRP collaboration for ARP
As shown in Figure 11, configure VSRP to back up ARP entries between Device A and Device B.
·     Enable VSRP for ARP on Ten-GigabitEthernet 3/1/1 of Device A and Device B.
·     Configure VRRP on Ten-GigabitEthernet 3/1/1.10 of Device A and Device B, and configure these subinterfaces to terminate VLAN 10.
·     Enable OSPF on Device A and Device B to ensure that they can learn and advertise routes on their upstream links.
Figure 11 Network diagram
Table 9 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
1.     Assign IP addresses to the interfaces, as shown in Figure 11. (Details not shown.)
2.     Configure Device A:
# Enter Ten-GigabitEthernet 3/1/1.10 interface view.
[DeviceA] interface ten-gigabitethernet 3/1/1.10
# Create VRRP group 1 and set its virtual IP address to 3.3.3.3.
[DeviceA–Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 virtual-ip 3.3.3.3
[DeviceA-Ten-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10
# Set the priority of Device A to 250 in VRRP group 1 on Ten-GigabitEthernet 3/1/1.10. Device A is assigned a higher priority than Device B in VRRP group 1, so Device A can become the master.
[DeviceA-Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 priority 250
# Configure Device A to operate in preemptive mode, and set the preemption delay to 90000 centiseconds (15 minutes). When the original master recovers, it has 15 minutes to synchronize data from the new master before switch-back to ensure stability and data consistency of the VRRP group.
[DeviceA–Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 preempt-mode delay 90000
[DeviceA–Ten-GigabitEthernet3/1/1.10] quit
# Create track entry 1 to monitor the link status of uplink interface Ten-GigabitEthernet 3/1/2. When the uplink fails, the track entry transits to Negative state.
[DeviceA] track 1 interface ten-gigabitethernet 3/1/2
# Associate VRRP group 1 on Ten-GigabitEthernet 3/1/1.10 with track entry 1, and decrease the device priority by 200 when the state of track entry 1 changes to Negative.
[DeviceA-Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 track 1 priority reduced 200
[DeviceA-Ten-GigabitEthernet3/1/1.10] quit
b.     Configure VSRP instance vs1:
[DeviceA] vsrp peer pr1
# Specify the local IP address as 4.4.4.2 and the peer IP address as 5.5.5.2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[DeviceA-vsrp-peer-pr1] peer 5.5.5.2 local 4.4.4.2
[DeviceA-vsrp-peer-pr1] quit
[DeviceA] vsrp instance vs1
# Associate VSRP instance vs1 with VSRP group pr1 and set its backup ID to 1.
[DeviceA-vsrp-instance-vs1] backup id 1 peer pr1
# Bind VSRP instance vs1 to VRRP group 1 on Ten-GigabitEthernet 3/1/1.10.
[DeviceA-vsrp-instance-vs1] bind vrrp vrid 1 interface ten-gigabitethernet 3/1/1.10
c.     Configure VSRP for ARP.
# Associate ARP with VSRP instance vs1.
[DeviceA–Ten-GigabitEthernet3/1/1.10] arp vsrp-instance vs1
# Specify TCP port 1024 for VSRP to establish data channels for ARP service backup.
[DeviceA] arp vsrp-port 1024
d.     Configure OSPF:
# Enable OSPF process 1 and set its router ID to 4.4.4.2 (the IP address of Ten-GigabitEthernet 3/1/2).
[DeviceA] ospf 1 router-id 4.4.4.2
# Configure OSPF to redistribute the user network route filtered by routing policy 1. Device A then advertises the user network route destined for the subnet where the hosts reside to Device C. In this way, Device C can select the route to a host based on the state of Device A and Device B in the VSRP instance.
[DeviceA-ospf-1] import-route unr inherit-cost route-policy 1
[DeviceA-ospf-1] quit
# Configure routing policy 1 to permit routes destined for network 2.2.2.0/24.
[DeviceA] ip prefix-list 1 permit 2.2.2.0 24
[DeviceA] route-policy 1 permit node 1
[DeviceA-route-policy-1-1] if-match ip address prefix-list 1
[DeviceA-route-policy-1-1] quit
# Configure Area 0.
[DeviceA] ospf
[DeviceA-ospf-1] area 0.0.0.0
[DeviceA-ospf-1-area-0.0.0.0] network 4.4.4.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
3.     Configure Device B:
[DeviceB] interface ten-gigabitethernet 3/1/1.10
[DeviceB–Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 virtual-ip 3.3.3.3
[DeviceB-Ten-GigabitEthernet3/1/1.10] vlan-type dot1q vid 10
# Set the priority of Device B to 200 in VRRP group 1 on Ten-GigabitEthernet 3/1/1.10. Device B is assigned a lower priority than Device A in VRRP group 1, so Device A can become the master.
[DeviceB-Ten-GigabitEthernet3/1/1.10] vrrp vrid 1 priority 200
[DeviceB–Ten-GigabitEthernet3/1/1.10] quit
[DeviceB] vsrp peer pr1
# Specify the local IP address as 5.5.5.2 and the peer IP address as 4.4.4.2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[DeviceB-vsrp-peer-pr1] peer 4.4.4.2 local 5.5.5.2
[DeviceB-vsrp-peer-pr1] quit
[DeviceB] vsrp instance vs1
[DeviceB-vsrp-instance-vs1] backup id 1 peer pr1
[DeviceB-vsrp-instance-vs1] bind vrrp vrid 1 interface ten-gigabitethernet 3/1/1.10
[DeviceB–Ten-GigabitEthernet3/1/1.10] arp vsrp-instance vs1
[DeviceB] arp vsrp-port 1024
d.     Configure OSPF:
# Enable OSPF process 1 and set its router ID to 5.5.5.2 (the IP address of Ten-GigabitEthernet 3/1/2).
[DeviceB] ospf 1 router-id 5.5.5.2
# Configure OSPF to redistribute the user network route filtered by routing policy 1. Device B then advertises the user network route destined for the subnet where the hosts reside to Device C. In this way, Device C can select the route to a host based on the state of Device A and Device B in the VSRP instance.
[DeviceB-ospf-1] import-route unr inherit-cost route-policy 1
[DeviceB-ospf-1] quit
[DeviceB] ip prefix-list 1 permit 2.2.2.0 24
[DeviceB] route-policy 1 permit node 1
[DeviceB-route-policy-1-1] if-match ip address prefix-list 1
[DeviceB-route-policy-1-1] quit
# Configure Area 0.
[DeviceB] ospf
[DeviceB-ospf-1] area 0.0.0.0
[DeviceB-ospf-1-area-0.0.0.0] network 5.5.5.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
4.     Configure Device C:
# Enable OSPF process 1 and set its router ID to 4.4.4.1 (the IP address of Ten-GigabitEthernet 3/1/1).
<DeviceC> system-view
[DeviceC] ospf 1 router-id 4.4.4.1
# Configure OSPF Area 0.
[DeviceC-ospf-1] area 0.0.0.0
[DeviceC-ospf-1-area-0.0.0.0] network 4.4.4.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 5.5.5.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
5.     Configure the L2 Switch:
a.     Create VLAN 10.
<L2Switch> system-view
[L2Switch] vlan 10
[L2Switch-vlan10] quit
b.     Configure VLAN settings on the interfaces that connect to Device A and Device B:
# Assign Ten-GigabitEthernet 3/1/2 to VLAN 10.
[L2Switch] interface ten-gigabitethernet 3/1/2
[L2Switch-Ten-GigabitEthernet3/1/2] port link-type trunk
[L2Switch-Ten-GigabitEthernet3/1/2] port trunk permit vlan 10
[L2Switch-Ten-GigabitEthernet3/1/2] quit
# Assign Ten-GigabitEthernet 3/1/3 to VLAN 10.
[L2Switch] interface ten-gigabitethernet 3/1/3
[L2Switch-Ten-GigabitEthernet3/1/3] port link-type trunk
[L2Switch-Ten-GigabitEthernet3/1/3] port trunk permit vlan 10
[L2Switch-Ten-GigabitEthernet3/1/3] quit
# Verify the VSRP configuration on Device A and Device B.
·     On the master:
[DeviceA] display vsrp instance
VSRP instance name: vs1
VSRP peer name: pr1
Backup ID:1
Bound VRID: VRRP VRID 1 interface GigabitEthernet0/0/1.10
Peer status: Backup
Backup mode: Hot
·     On the backup:
[DeviceB] display vsrp instance
VSRP peer name: pr1
Backup ID:1
Instance status: Backup
Peer status: Master
Backup mode: Hot
# Verify that Device A and Device B have the same ARP information for Ten-GigabitEthernet 3/1/1.
·     On the master:
[DeviceA] display arp all
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address      MAC address    VLAN/VSI name Interface                Aging Type
11.1.1.2        0001-0001-0001 --            XGE3/1/1                 20    D
11.1.1.3        0001-0001-0000 --            XGE3/1/1                 20    D
11.1.1.4        0001-0000-ffff --            XGE3/1/1                 20    D
11.1.1.5        0001-0000-fffe --            XGE3/1/1                 20    D
·     On the backup:
[DeviceB] display arp all
11.1.1.2        0001-0001-0001 --            XGE3/1/1                 --    R
11.1.1.3        0001-0001-0000 --            XGE3/1/1                 --    R
11.1.1.4        0001-0000-ffff --            XGE3/1/1                 --    R
11.1.1.5        0001-0000-fffe --            XGE3/1/1                 --    R
Example: Configuring VSRP and S-Trunk collaboration for ARP
As shown in Figure 12, configure VSRP to back up ARP entries between Device A and Device B.
·     Configure smart trunk 1 on Device A and Device B, and assign Route-Aggregation 1 of Device A and Device B to the smart trunk. Configure Route-Aggregation 1 of Device A as the primary member interface, and configure Route-Aggregation 1 of Device B as the secondary member interface.
·     Enable VSRP for ARP on Route-Aggregation 1 of Device A and Device B.
·     Configure VSRP and S-Trunk collaboration.
Figure 12 Network diagram
Table 10 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Configuring the CE
1.     Assign IP addresses to the interfaces, as shown in Figure 12. (Details not shown.)
2.     Configure link aggregation:
<CE> system-view
[CE] interface route-aggregation 1
[CE-Route-Aggregation1] link-aggregation mode dynamic
[CE-Route-Aggregation1] quit
[CE] interface ten-gigabitethernet 3/1/1
[CE-Ten-GigabitEthernet3/1/1] port link-aggregation group 1
[CE-Ten-GigabitEthernet3/1/1] quit
[CE] interface ten-gigabitethernet 3/1/2
[CE-Ten-GigabitEthernet3/1/2] port link-aggregation group 1
[CE-Ten-GigabitEthernet3/1/2] quit
Configuring PE 1
2.     Configure LACP system settings to set up the S-Trunk system.
<PE1> system-view
[PE1] lacp system-priority 10
[PE1] lacp system-mac 1-1-1
[PE1] lacp system-number 1
3.     Configure S-Trunk protocol packet parameters.
[PE1] s-trunk udp-port 2048
[PE1] s-trunk id 1
[PE1-s-trunk1] s-trunk ip destination 2.1.1.2 source 2.1.1.1
[PE1-s-trunk1] quit
4.     Configure static BFD to monitor link status for S-Trunk.
[PE1] bfd static bfd1 peer-ip 2.1.1.2 source-ip 2.1.1.1 discriminator local 1 remote 2
[PE1-bfd-static-session-bfd1] quit
[PE1] s-trunk id 1
[PE1-s-trunk1] s-trunk bfd-session bfd1
[PE1-s-trunk1] quit
5.     Create smart trunk 1 and assign member interfaces to it.
[PE1] interface route-aggregation 1
[PE1-Route-Aggregation1] link-aggregation mode dynamic
[PE1-Route-Aggregation1] s-trunk 1
[PE1-Route-Aggregation1] quit
[PE1] interface ten-gigabitethernet 3/1/1
[PE1-Ten-GigabitEthernet3/1/1] port link-aggregation group 1
[PE1-Ten-GigabitEthernet3/1/1] quit
6.     Configure a VSRP instance:
[PE1] vsrp peer pr1
# Specify the local IP address 2.1.1.1 and the peer address 2.1.1.2.
[PE1-vsrp-peer-pr1] peer 2.1.1.2 local 2.1.1.1
[PE1-vsrp-peer-pr1] quit
[PE1] vsrp instance vs1
# Specify the backup ID of VSRP instance vs1 as 1 in VSRP group pr1.
[PE1-vsrp-instance-vs1] backup id 1 peer pr1
# Bind VSRP instance vs1 to Route-Aggregation 1 in smart trunk 1.
[PE1-vsrp-instance-vs1] bind s-trunk 1 interface route-aggregation 1
[PE1-vsrp-instance-vs1] quit
7.     Configure VSRP for ARP:
# Enter the view of Router-Aggregation 1.
[PE1–Route-Aggregation1] arp vsrp-instance vs1
[PE1–Route-Aggregation1] quit
[PE1] arp vsrp-port 1024
Configuring PE 2
<PE2> system-view
[PE2] lacp system-priority 10
[PE2] lacp system-mac 1-1-1
[PE2] lacp system-number 2
[PE2] s-trunk udp-port 2048
[PE2] s-trunk id 1
[PE2-s-trunk1] s-trunk ip destination 2.1.1.1 source 2.1.1.2
[PE2-s-trunk1] quit
[PE2] bfd static bfd1 peer-ip 2.1.1.1 source-ip 2.1.1.2 discriminator local 2 remote 1
[PE2-bfd-static-session-bfd1] quit
[PE2] s-trunk id 1
[PE2-s-trunk1] s-trunk bfd-session bfd1
[PE2-s-trunk1] quit
[PE2] interface route-aggregation 1
[PE2-Route-Aggregation1] link-aggregation mode dynamic
[PE2-Route-Aggregation1] s-trunk 1
[PE2-Route-Aggregation1] quit
[PE2] interface ten-gigabitethernet 3/1/1
[PE2-Ten-GigabitEthernet3/1/1] port link-aggregation group 1
[PE2-Ten-GigabitEthernet3/1/1] quit
[PE2] vsrp peer pr1
# Specify the local IP address 2.1.1.2 and the peer address 2.1.1.1.
[PE2-vsrp-peer-pr1]peer 2.1.1.1 local 2.1.1.2
[PE2-vsrp-peer-pr1] quit
[PE2] vsrp instance vs1
[PE2-vsrp-instance-vs1] backup id 1 peer pr1
[PE2-vsrp-instance-vs1] bind s-trunk 1 interface route-aggregation 1
[PE2-vsrp-instance-vs1] quit
[PE2–Route-Aggregation1] arp vsrp-instance vs1
[PE2–Route-Aggregation1] quit
[PE2] arp vsrp-port 1024
# Verify that the PE 1 and PE 2 are the primary and secondary S-Trunk member devices, respectively.
[PE1] display s-trunk verbose 1
                            Trunk-wide info and statistics
S-Trunk ID: 1
Revert: Enabled                       Revert-delay(s): 120
Local bridge MAC: 666d-17c0-0100      Peer bridge MAC: 666d-3a83-0200
Local Priority: 32768                 Peer Priority: 32768
DevRole (Trigger): Primary (PRIORITY)
DestIP: 2.1.1.2                      SrcIP: 2.1.1.1
Local hello interval(100ms): 10       Local hello timeout(100ms): 200
InStrunkPDUs: 2575                    OutStrunkPDUs: 2810
InDrops: 2                            OutDrops: 64
Peer hello interval(100ms): 10        Peer hello timeout(100ms): 200
BFD session: bfd1
                            Trunk member info
Local    LinkState   ConfigRole    OperRole (Trigger)            Peer
RAGG1    Up          Auto          Primary (PEER_MEMBER_DOWN)    RAGG1
[PE2] display s-trunk verbose 1
S-Trunk ID: 1
Local bridge MAC: 666d-3a83-0200      Peer bridge MAC: 666d-17c0-0100
DevRole (Trigger): Secondary (PRIORITY)
DestIP: 2.1.1.1                      SrcIP: 2.1.1.2
InStrunkPDUs: 2634                    OutStrunkPDUs: 2664
InDrops: 0                            OutDrops: 0
BFD session: bfd1
                            Trunk member info
RAGG1    Down        Auto          Secondary (PEER_MEMBER_UP)    RAGG1
# Verify that PE 1 and PE 2 are the VSRP master and backup, respectively.
·     On the master:
[PE1] display vsrp instance
VSRP peer name: pr1
Backup ID:1
Bound S-Trunk: 1   Interface Route-Aggregation1
Peer status: Backup
Backup mode: Hot
·     On the backup:
[PE2] display vsrp instance
VSRP peer name: pr1
Backup ID:1
Local status: Backup
Peer status: Master
Backup mode: Hot
# Verify that both Device A and Device B have the ARP information for Route-Aggregation 1.
·     On the master:
[PE1] display arp all
1.1.1.3         0001-0001-0001 --            RAGG1                    20    D
·     On the backup:
[PE2] display arp all
1.1.1.3         0001-0001-0001 --            RAGG1                    --    R
Example: Configuring VSRP and VRRP collaboration for ND
As shown in Figure 13, configure VSRP to back up ND entries between Device A and Device B.
·     Enable VSRP for ND on Ten-GigabitEthernet 3/1/1 of Device A and Device B.
·     Configure Device A and Device B to set up a VSRP service backup data channel over their upstream links.
Figure 13 Network diagram
Table 11 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
1.     Assign IPv6 addresses to the interfaces and configure routing, as shown in Figure 13. (Details not shown.)
# Create VRRP group 1 and set its virtual IPv6 address to 2::10 and virtual link-local address to FE80::10.
[DeviceA-Ten-GigabitEthernet3/1/1.10]vrrp ipv6 vrid 1 virtual-ip 2::10
[DeviceA-Ten-GigabitEthernet3/1/1.10]vrrp ipv6 vrid 1 virtual-ip FE80::10 link-local
[DeviceA-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 priority 250
[DeviceA–Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 preempt-mode delay 90000
[DeviceA-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 track 1 priority reduced 200
# Specify the local IP address as 3::2 and the peer IP address as 4::2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[DeviceA-vsrp-peer-pr1] peer ipv6 4::2 local 3::2
[DeviceA-vsrp-instance-vs1] bind vrrp ipv6 vrid 1 interface ten-gigabitethernet 3/1/1.10
c.     Configure VSRP for ND.
# Enter Ten-GigabitEthernet 3/1/1 interface view.
# Associate ND with VSRP instance vs1.
[DeviceA–Ten-GigabitEthernet3/1/1] ipv6 nd vsrp-instance vs1
[DeviceA–Ten-GigabitEthernet3/1/1] quit
# Specify TCP port 1024 for VSRP to establish data channels for ND service backup.
[DeviceA] ipv6 nd vsrp-port 1024
[DeviceB-Ten-GigabitEthernet3/1/1.10]vrrp ipv6 vrid 1 virtual-ip 2::10
[DeviceB-Ten-GigabitEthernet3/1/1.10]vrrp ipv6 vrid 1 virtual-ip FE80::10 link-local
[DeviceB-Ten-GigabitEthernet3/1/1.10] vrrp ipv6 vrid 1 priority 200
# Specify the local IP address as 4::2 and the peer IP address as 3::2 for VSRP to establish VSRP channels. The default TCP port number for the control channel is used.
[DeviceB-vsrp-peer-pr1] peer ipv6 3::2 local 4::2
[DeviceB-vsrp-instance-vs1] bind vrrp ipv6 vrid 1 interface ten-gigabitethernet 3/1/1.10
[DeviceB–Ten-GigabitEthernet3/1/1] ipv6 nd vsrp-instance vs1
[DeviceB–Ten-GigabitEthernet3/1/1] quit
[DeviceB] ipv6 nd vsrp-port 1024
4.     Configure the L2 Switch:
a.     Create VLAN 10.
[L2Switch] vlan 10
1.     Verify the VSRP configuration on Device A and Device B.
¡     On the master:
VSRP peer name: pr1
Backup ID:1
Bound VRID: VRRP IPv6 VRID 1 interface Ten-GigabitEthernet3/1/1.10
Peer status: Backup
Backup mode: Hot
¡     On the backup:
VSRP peer name: pr1
Backup ID:1
Peer status: Master
Backup mode: Hot
2.     Verify that Device A and Device B have the same ND information for Ten-GigabitEthernet 3/1/1.
¡     On the master:
[DeviceA]dis ipv6 neighbors all
Type: S-Static    D-Dynamic    O-Openflow     R-Rule    IS-Invalid static
IPv6 address              MAC address    VLAN/VSI   Interface     State T  Aging
1::3                      0010-9400-0001 --         XGE3/1/1      REACH D  6
¡     On the backup:
[DeviceB]dis ipv6 neighbors all
1::3                      0010-9400-0001 --         XGE3/1/1      REACH R  --
Example: Configuring VSRP and S-Trunk collaboration for ND
As shown in Figure 14, configure VSRP to back up ND entries between Device A and Device B.
Enable VSRP for ND on Route-Aggregation 1 of Device A and Device B.
Figure 14 Network diagram
Table 12 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Configuring the CE
1.     Assign IPv6 addresses to the interfaces, as shown in Figure 14. (Details not shown.)
2.     Configure link aggregation.
<CE> system-view
Configuring PE 1
1.     Assign IP addresses to the interfaces, as shown in Figure 14. (Details not shown.)
<PE1> system-view
[PE1] s-trunk id 1
[PE1-s-trunk1] quit
[PE1] s-trunk id 1
[PE1-s-trunk1] quit
[PE1] vsrp peer pr1
7.     Configure VSRP for ND:
[PE1–Route-Aggregation1] ipv6 nd vsrp-instance vs1
Configuring PE 2
<PE2> system-view
[PE2] s-trunk id 1
[PE2-s-trunk1] quit
[PE2] s-trunk id 1
[PE2-s-trunk1] quit
[PE2] vsrp peer pr1
[PE2-vsrp-peer-pr1] peer 2.1.1.1 local 2.1.1.2
[PE2–Route-Aggregation1] ipv6 nd vsrp-instance vs1
1.     Verify that PE 1 and PE 2 are the primary and secondary S-Trunk member devices, respectively.
# Verify that PE 1 is the primary S-Trunk member device.
S-Trunk ID: 1
Local bridge MAC: 46e4-b684-0200      Peer bridge MAC: 46e4-bba4-0300
Local priority: 32768                 Peer priority: 32768
InStrunkPDUs: 1222                    OutStrunkPDUs: 1408
InDrops: 1                            OutDrops: 0
Sequence number check: Disabled
BFD session: -
VPN instance: -
Description: -
                            Trunk member info
# Verify that PE 2 is the secondary S-Trunk member device.
S-Trunk ID: 1
Local bridge MAC: 46e4-bba4-0300      Peer bridge MAC: 46e4-b684-0200
InStrunkPDUs: 1299                    OutStrunkPDUs: 1258
BFD session: -
VPN instance: -
Description: -
                            Trunk member info
2.     Verify that PE 1 and PE 2 are the VSRP master and backup, respectively.
¡     On the master:
 VSRP peer name: pr1
 Backup ID: 1
 Bound S-Trunk ID: 1   Interface Route-Aggregation1
 Peer status: Backup
 Backup mode: Hot
¡     On the backup:
 VSRP peer name: pr1
 Backup ID: 1
 Peer status: Master
 Backup mode: Hot
3.     Verify that both Device A and Device B have the ND information for Route-Aggregation 1.
¡     On the master:
[PE1] display ipv6 neighbors all
1::1                      46e4-afbf-0102 --         RAGG1         REACH D  23
FE80::44E4:AFFF:FEBF:102  46e4-afbf-0102 --         RAGG1         REACH D  13
¡     On the backup:
[PE2] display ipv6 neighbors all
1::1                      46e4-afbf-0102 --         RAGG1         REACH R  --
FE80::44E4:AFFF:FEBF:102  46e4-afbf-0102 --         RAGG1         REACH R  --
Example: Configuring VSRP for IGMP
As shown in Figure 15, configure VSRP to back up IGMP multicast information for IPv4 IPoE users on Ten-GigabitEthernet 3/1/1.10.
·     Configure IPoE, VSRP instance, and VRRP settings as described in "Example: Configuring VSRP for IPoE (IPv4 address pool)."
·     Enable IGMP and per-session multicast forwarding on Ten-GigabitEthernet 3/1/1.10 on both Device A and Device B.
·     Enable PIM-SM on Device A, Device B, and Device C.
·     Configure Device C as the RP.
Figure 15 Network diagram
Table 13 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
1.     Assign IP addresses to interfaces, as shown in Figure 15. Configure routes for the hosts, the BRASs, the RP, and the RADIUS server to reach one another. (Details not shown.)
2.     Configure the RADIUS servers as described in "Example: Configuring VSRP for IPoE (IPv4 address pool)."
3.     Configure Device A:
# Configure IPoE, VRRP group, and VSRP instance settings as described in "Example: Configuring VSRP for IPoE (IPv4 address pool)." In this example, the VSRP instance name is vsrp1.
# Enable IP multicast routing.
[DeviceA] multicast routing
[DeviceA-mrib] quit
# Enable IGMP and per-session multicast forwarding on Ten-GigabitEthernet 3/1/1.10 (the downstream interface). Enable PIM-SM on Ten-GigabitEthernet 3/1/2 (the upstream interface).
[DeviceA-Ten-GigabitEthernet3/1/1.10] igmp enable
[DeviceA-Ten-GigabitEthernet3/1/1.10] igmp join-by-session
[DeviceA] interface ten-gigabitethernet 3/1/2
[DeviceA-Ten-GigabitEthernet3/1/2] pim sm
[DeviceA-Ten-GigabitEthernet3/1/2] quit
# Associate VSRP instance vsrp1 with Ten-GigabitEthernet 3/1/1.10 for IGMP service backup.
[DeviceA-Ten-GigabitEthernet3/1/1.10] igmp vsrp-instance vsrp1
4.     Configure Device B:
[DeviceB] multicast routing
[DeviceB-mrib] quit
[DeviceB-Ten-GigabitEthernet3/1/1.10] igmp enable
[DeviceB-Ten-GigabitEthernet3/1/1.10] igmp join-by-session
[DeviceB-Ten-GigabitEthernet3/1/1.10] quit
[DeviceB] interface ten-gigabitethernet 3/1/2
[DeviceB-Ten-GigabitEthernet3/1/2] pim sm
[DeviceB-Ten-GigabitEthernet3/1/2] quit
[DeviceB-Ten-GigabitEthernet3/1/1.10] igmp vsrp-instance vsrp1
5.     Configure Device C:
[DeviceC] multicast routing
[DeviceC-mrib] quit
# Enable PIM-SM on Ten-GigabitEthernet 3/1/1, Ten-GigabitEthernet 3/1/2, and Ten-GigabitEthernet 3/1/3.
[DeviceC] interface ten-gigabitethernet 3/1/1
[DeviceC-Ten-GigabitEthernet3/1/1] pim sm
[DeviceC-Ten-GigabitEthernet3/1/1] quit
[DeviceC] interface ten-gigabitethernet 3/1/2
[DeviceC-Ten-GigabitEthernet3/1/2] pim sm
[DeviceC-Ten-GigabitEthernet3/1/2] quit
[DeviceC] interface ten-gigabitethernet 3/1/3
[DeviceC-Ten-GigabitEthernet3/1/3] pim sm
[DeviceC-Ten-GigabitEthernet3/1/3] quit
# Configure Device C as the BSR and the RP.
[DeviceC] pim
[DeviceC-pim] c-bsr 10.20.30.2
[DeviceC-pim] c-rp 10.20.30.2
[DeviceC-pim] quit
# Verify that Device A (the master) and Device B (the backup) have the same IGMP interface and group information about IPoE users.
·     On the master:
[DeviceA] display igmp interface verbose
 Multicast-UA0(3.3.3.1):
   IGMP is enabled.
   IGMP version: 2
   Query interval for IGMP: 125s
   Other querier present time for IGMP: 255s
   Maximum query response time for IGMP: 10s
   Last member query interval: 1s
   Last member query count: 2
   Startup query interval: 31s
   Startup query count: 2
   General query timer expiry (hh:mm:ss): 00:01:48
   Querier for IGMP: 3.3.3.1 (This router)
   IGMP activity: 1 join(s), 0 leave(s)
   Multicast routing on this interface: Enabled
   Robustness: 2
   Require-router-alert: Disabled
   Fast-leave: Disabled
   Startup-query: Off
   Other-querier-present-timer-expiry (hh:mm:ss): Off
   Authorization: Disabled
   Join-by-session: Enabled
   User-VLAN-aggregation: Disabled
   Access interface: Ten-GigabitEthernet3/1/1.10
   VSRP instance: vsrp1 (State is master, synchronization is on)
   IGMP groups reported in total: 1
[DeviceA] display igmp group
IGMP groups in total: 1
   Group address   Last reporter   Uptime      Expires
   225.1.1.1       3.3.3.7         00:04:18    00:04:19
·     On the backup:
[DeviceB] display igmp interface verbose
 Multicast-UA1(3.3.3.2):
   IGMP is enabled.
   IGMP version: 2
   General query timer expiry (hh:mm:ss): off
   Querier for IGMP: 3.3.3.2 (This router)
   Robustness: 2
   Startup-query: Off
   VSRP instance: vsrp1 (State is backup)
[DeviceB] display igmp group
Example: Configuring VSRP load sharing on an IGMP-enabled interface
As shown in Figure 16, perform the following tasks:
·     Enable IGMP on the interface of the access device (Device D) connected to the user.
·     Configure PIM and enable PIM-SM on the interfaces connecting the access devices and upstream router (Device C).
·     Configure the upstream router as the RP.
·     Add the downstream interfaces on Device A and Device B to the same Layer 3 aggregation group.
·     Connect Device D to Device A and Device B through a Layer 2 aggregate interface.
·     Configure the source and destination IP addresses for the S-Trunk protocol packets (without OSPF configuration).
Figure 16 Network diagram
Table 14 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
1.     Assign IP addresses to the interfaces, and configure routes for the devices to reach one another. (Details not shown.)
# Set the destination UDP port of IPv4 S-Trunk protocol packets.
[DeviceA] s-trunk udp-port 2048
# Associate track entry 1 with static BFD session bfd2.
[DeviceA] track 1 bfd static bfd2
# Create a monitor link group and specify member interfaces for it.
[DeviceA] monitor-link group 1
[DeviceA-mtlk-group1] port ten-gigabitethernet 3/1/1 downlink
[DeviceA-mtlk-group1] port ten-gigabitethernet 3/1/2 uplink
[DeviceA-mtlk-group1] quit
# Create a Layer 3 aggregate interface operating in dynamic link aggregation mode, and enable PIM and IGMP on the interface.
[DeviceA] interface Route-Aggregation1
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
[DeviceA-Route-Aggregation1] pim sm
[DeviceA-Route-Aggregation1] igmp enable
[DeviceA-Route-Aggregation1] quit
# Specify the local IP address as 1.1.1.1 and the peer IP address as 1.1.1.2 for VSRP to establish VSRP channels, and associate a track entry with VSRP.
[DeviceA] vsrp peer 1
[DeviceA-vsrp-peer-1] peer 1.1.1.2 local 1.1.1.1
[DeviceA-vsrp-peer-1] track 1
[DeviceA-vsrp-peer-1] quit
# Create a VSRP instance.
[DeviceA] vsrp instance 1
[DeviceA-vsrp-instance-1] backup id 1 peer 1
[DeviceA-vsrp-instance-1] bind s-trunk 1 interface Route-Aggregation1
[DeviceA-s-trunk1]quit
# Configure S-Trunk parameters.
[DeviceA] s-trunk id 1
[DeviceA-s-trunk1] s-trunk bfd-session strunk1
[DeviceA-s-trunk1] s-trunk role priority 100
[DeviceA-s-trunk1] s-trunk ip destination 23.0.0.12 source 23.0.0.21
[DeviceA-s-trunk1] quit
# Associate IGMP-enabled interface Route-Aggregation 1 with a VSRP instance, configure the role of the S-Trunk member interface as primary, and enable VSRP load sharing on the interface
[DeviceA-Route-Aggregation1] igmp vsrp-instance 1
[DeviceA-Route-Aggregation1] igmp vsrp-load-balance restore-delay 30
[DeviceA-Route-Aggregation1] s-trunk 1
[DeviceA-Route-Aggregation1] s-trunk port-role primary
# Create a loopback interface to establish VSRP channels.
[DeviceA] interface LoopBack1
[DeviceA-LoopBack1] ip address 1.1.1.1 255.255.255.255
[DeviceA-LoopBack1] ospf 1 area 0.0.0.0
[DeviceA-LoopBack1] pim sm
[DeviceA-LoopBack1] quit
# Configure static BFD to monitor link status for S-Trunk.
[DeviceA] bfd static bfd2 peer-ip 1.1.1.2 source-ip 1.1.1.1 discriminator local 3 remote 4
[DeviceA-bfd-static-session-bfd2] quit
[DeviceA] bfd static strunk1 peer-ip 23.0.0.12 source-ip 23.0.0.21 discriminator local 1 remote 2
[DeviceA-bfd-static-session-strunk1] quit
Configure Device B in the same way Device A is configured. (Details not shown.)
[DeviceC-mrib] quit
# Enable PIM-SM on both the upstream and downstream interfaces.
# Configure Device C as the BSR and RP.
[DeviceC] pim
[DeviceC-pim] c-bsr 10.0.0.12
[DeviceC-pim] c-rp 10.0.0.12
[DeviceC-pim] quit
# Verify that Device A (the master) and Device B (the backup) have the same IGMP interface and group information. The master and backup devices forward multicast traffic for odd multicast group addresses and even multicast group addresses, respectively.
·     On the master:
Route-Aggregation1(31.0.0.2):
   IGMP is enabled.
   IGMP version: 2
   General query timer expiry (hh:mm:ss): 00:01:00
   Querier for IGMP: 31.0.0.2 (This router)
   IGMP activity: 5935 join(s), 1934 leave(s)
   Robustness: 2
   Startup-query: Off
   Join-by-session: Disabled
   VSRP instance: 1 (State is master, synchronization is on)
   VSRP forward mode: odd (Wait to restore is 30s)
  IGMP groups reported in total: 4001
·     On the backup:
Route-Aggregation1(31.0.0.1):
   IGMP is enabled.
   IGMP version: 2
   General query timer expiry (hh:mm:ss): Off
   Querier for IGMP: 31.0.0.1 (This router)
   IGMP activity: 6068 join(s), 2067 leave(s)
   Robustness: 2
   Startup-query: On
   VSRP instance: 1 (State is backup)
   VSRP forward mode: even (Wait to restore is 30s)
Example: Configuring VSRP for MLD
As shown in Figure 17, configure VSRP to back up MLD multicast information for IPv6 IPoE users on Ten-GigabitEthernet 3/1/1.10.
·     Configure IPoE, VSRP instance, and VRRP settings as described in "Example: Configuring VSRP for IPoE (IPv6 address pool)."
·     Enable MLD and per-session multicast forwarding on Ten-GigabitEthernet 3/1/1.10 on both Device A and Device B.
·     Enable IPv6 PIM-SM on Device A, Device B, and Device C.
Figure 17 Network diagram
Table 15 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
1.     Assign IPv6 addresses to interfaces, as shown in Figure 17. Configure routes for the hosts, the BRASs, the RP, and the RADIUS server to reach one another. (Details not shown.)
2.     Configure the RADIUS servers as described in "Example: Configuring VSRP for IPoE (IPv6 address pool)."
# Configure IPoE, VRRP group, and VSRP instance settings as described in "Example: Configuring VSRP for IPoE (IPv6 address pool)." In this example, the VSRP instance name is vsrp1.
# Enable IPv6 multicast routing.
[DeviceA] ipv6 multicast routing
[DeviceA-mrib6] quit
# Enable MLD and per-session multicast forwarding on Ten-GigabitEthernet 3/1/1.10. Enable IPv6 PIM-SM on Ten-GigabitEthernet 3/1/2.
[DeviceA-Ten-GigabitEthernet3/1/1.10] mld enable
[DeviceA-Ten-GigabitEthernet3/1/1.10] mld join-by-session
[DeviceA-Ten-GigabitEthernet3/1/2] ipv6 pim sm
# Associate VSRP instance vsrp1 with Ten-GigabitEthernet 3/1/1.10 for MLD multicast service backup.
[DeviceA-Ten-GigabitEthernet3/1/1.10] mld vsrp-instance vsrp1
# Configure IPv6 IPoE, VRRP group, and VSRP instance settings as described in "Example: Configuring VSRP for IPoE (IPv6 address pool)." In this example, the VSRP instance name is vsrp1.
[DeviceB] ipv6 multicast routing
[DeviceB-mrib6] quit
[DeviceB-Ten-GigabitEthernet3/1/1.10] mld enable
[DeviceB-Ten-GigabitEthernet3/1/1.10] mld join-by-session
[DeviceB-Ten-GigabitEthernet3/1/2] ipv6 pim sm
# Associate VSRP instance vsrp1 with Ten-GigabitEthernet 3/1/1.10 for MLD service backup.
[DeviceB-Ten-GigabitEthernet3/1/1.10] mld vsrp-instance vsrp1
[DeviceC] ipv6 multicast routing
[DeviceC-mrib6] quit
# Enable IPv6 PIM-SM on Ten-GigabitEthernet 3/1/1, Ten-GigabitEthernet 3/1/2, and Ten-GigabitEthernet 3/1/3.
[DeviceC-Ten-GigabitEthernet3/1/1] ipv6 pim sm
[DeviceC-Ten-GigabitEthernet3/1/2] ipv6 pim sm
[DeviceC-Ten-GigabitEthernet3/1/3] ipv6 pim sm
[DeviceC] ipv6 pim
[DeviceC-pim6] c-bsr 100::10
[DeviceC-pim6] c-rp 100::10
[DeviceC-pim6] quit
# Verify that Device A and Device B have the same MLD interface and group information after the IPv6 IPoE users access the network and join multicast groups. The VSRP state of Device A displays master. The VSRP state of Device B displays backup.
·     On the master:
[DeviceA] display mld interface verbose
 Multicast-UA0(FE80::2:2):
   MLD is enabled.
   MLD version: 1
   Query interval for MLD: 125s
   Other querier present time for MLD: 255s
   Maximum query response time for MLD: 10s
   Last listener query interval: 1s
   Last listener query count: 2
   General query timer expiry (hh:mm:ss): 00:00:49
   Querier for MLD: FE80::2:2 (This router)
   MLD activity: 1 join(s), 0 done(s)
   IPv6 multicast routing on this interface: Enabled
   Robustness: 2
   Startup-query: Off
   MLD groups reported in total: 1
[DeviceA] display mld group
MLD groups in total: 1
   Group address: FF1E::1
    Last reporter: 2::7
    Uptime: 00:01:43
    Expires: 00:04:16
·     On the backup:
[DeviceB] display mld interface verbose
 Multicast-UA0(FE80::2:3):
   MLD is enabled.
   MLD version: 1
   Querier for MLD: FE80::2:3 (This router)
   Robustness: 2
   Startup-query: Off
[DeviceB] display mld group
    Last reporter: 2::7
    Uptime: 00:01:43
    Expires: 00:04:16
Example: Configuring VSRP load sharing on an MLD-enabled interface
As shown in Figure 18, perform the following tasks:
·     Enable MLD on the interface of the access device (Device D) connected to the user.
Figure 18 Network diagram
Table 16 Interface label and interface name mappings
Interface label
Interface name
Interface1
Interface2
Interface3
# Create a Layer 3 aggregate interface operating in dynamic link aggregation mode, and enable PIM and MLD on the interface.
[DeviceA-Route-Aggregation1] mld enable
# Associate MLD-enabled interface Route-Aggregation 1 with a VSRP instance, configure the role of the S-Trunk member interface as primary, and enable VSRP load sharing on the interface
[DeviceA-Route-Aggregation1] mld vsrp-instance 1
[DeviceA-Route-Aggregation1] mld vsrp-load-balance restore-delay 30
[DeviceC-mrib] quit
[DeviceC] pim
[DeviceC-pim] quit
# Verify that Device A (the master) and Device B (the backup) have the same MLD interface and group information. The master and backup devices forward multicast traffic for odd multicast group addresses and even multicast group addresses, respectively.
·     On the master:
   MLD is enabled.
   MLD version: 2
   Querier for MLD: 31.0.0.2 (This router)
   MLD activity: 5935 join(s), 1934 leave(s)
   Robustness: 2
   Startup-query: Off
  MLD groups reported in total: 4001
·     On the backup:
   MLD is enabled.
   MLD version: 2
   Querier for MLD: 31.0.0.1 (This router)
   MLD activity: 6068 join(s), 2067 leave(s)
   Robustness: 2
   Startup-query: On
