| 02-RPM application hosting commands | 41.25 KB |
rpm
Use rpm to install an RPM application in Comware.
rpm [ params ]
params: Specifies parameters. The parameter requirements are the same as those in the Linux system. You can enter rpm –-help to view the parameter help information.
The Comware system integrates the RPM functions. After you log in to the Comware CLI interface, you can issue the rpm command as in Linux to install, run, and manage RPM applications.
# Query information about the package nano-2.3.1-10.el7.x86_64.rpm.
[Sysname] rpm -qp --info nano-2.3.1-10.el7.x86_64.rpm
Version : 2.3.1
Release : 10.el7
Architecture: x86_64
Install Date: (not installed)
Group : Applications/Editors
License : GPLv3+
Signature : RSA/SHA256, Fri Jul 4 03:53:43 2019, Key ID 24c6a8a7f4a80eb5
Source RPM : nano-2.3.1-10.el7.src.rpm
Build Date : Tue Jun 10 04:47:54 2019
Build Host : worker1.bsys.centos.org
Relocations : (not relocatable)
Packager : CentOS BuildSystem <http://bugs.centos.org>
Vendor : CentOS
URL : http://www.nano-editor.org
Summary : A small text editor
Description :
GNU nano is a small and friendly text editor.
[Sysname]
run bash
Use run bash to run an RPM application from Bash.
run bash app [ params ]
app: Specifies the application name.
params: Specifies the parameters for the rpm command. You can enter the run bash app –-help command to display the help information.
# Run the nano editor.
[Sysname] run bash nano
GNU nano 2.3.1 New Buffer
^G Get Help ^O WriteOut ^R Read File ^Y Prev Page ^K Cut Text ^C Cur Pos
^X Exit ^J Justify ^W Where Is ^V Next Page ^U UnCut Text^T To Spell
