19-Application Hosting Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10019-Application Hosting Command Reference
01-Container application hosting commands
01-Container application hosting commands 60.12 KB
docker
Use docker to manage Docker containers.
docker [ params ]
params: Specifies parameters for the command. The available parameters are the same as the parameters for the standard Linux docker command. For more information, execute the docker –-help command.
CAUTION
CAUTION:
Before you execute the docker load command, use the display memory command to check the remaining memory in the Free field. To avoid device reboot because of memory exhaustion during image file loading, you must make sure the remaining memory is greater than the image file size.
The Comware system is integrated with a modified version of the Docker daemon and can resolve standard Linux docker commands. At the Comware CLI, you can use standard Linux docker commands to create, run, and monitor containers and construct and store images.
As a best practice, do not configure open application containers to share the network namespace for Comware containers. If an open application container shares the network space for Comware containers, that open application container cannot persist through a Comware system reboot. When the Comware system reboots, you must create that container again if you need to use it.
To prevent overuse of resources from degrading Comware performance, a system-defined limit is set on the CPU and memory resources assignable to open application containers. If the CPU or memory size specified for an open application container exceeds the system-defined limit when you run it by using the docker run command with the --cpuset-cpus, --cpuset-shared, or --memory option, the system-defined limit takes effect.
# List containers.
[Sysname] docker ps
CONTAINER ID        IMAGE               COMMAND             CREATED             STATUS              PORTS
NAMES
d160d5ddab1f      comware: MPU      "/bin/v9.sh"   17 years ago     Up 17 years
comware
# Use image file flash:/tftpd.tar.gz to create a TFTP server container that uses the same network namespace as Comware.
[Sysname] docker run --network container:comware --name tftpserver tftpd.tar.gz
docker-config reload
Use docker-config reload to reload the Docker daemon configuration.
This command loads the configuration file and certificate in the flash:/third-party/autocopy/etc/docker/ directory to memory and triggers the Docker daemon process to reload the configuration file.
If you modify the Docker daemon configuration file, verify that the modified configuration commands do not have errors. If the Docker daemon configuration file has errors, the Docker process might not be able to start up, causing the Comware system unable to start up correctly. If this symptom occurs, perform the following tasks:
1.     Reboot the device and enter the BootWare menu.
2.     Delete the erroneous Docker daemon configuration file and reboot the device.
3.     If the symptom persists, reboot the device and enter the BootWare menu again.
4.     Delete the flash: /third-party directory and reboot the device again.
# Reload the Docker daemon configuration.
[Sysname] docker-config reload
Reloading docker configuration...
Done.
[Sysname]
kubelet enable
Use kubelet enable to enable the kubelet service.
Use undo kubelet enable to disable the kubelet service.
kubelet enable
undo kubelet enable
The kubelet service is disabled.
When you enable the kubelet service, the system automatically synchronize the files listed in Table 1 to the file system in memory. To enable the kubelet service successfully, make sure the files exist in the specified directory.
Table 1 Files required for enabling the kubelet service
File description
Storage location
File name (extension not allowed)
Kubernetes public configuration file
flash: /third-party/autocopy/etc/kubernetes
kubeconfig
Kubelet configuration file
kubeletconfig
Environment variable file for Kubelet command line parameters
kubelet
The following are the sample content of the files. You can modify the files as required.
/* Kubernetes public configuration file flash:/third-party/autocopy/etc/kubernetes/kubeconfig */
apiVersion:  v1
clusters:
- cluster:
    insecure-skip-tls-verify:  true
    server:  http: //192.168.111.62: 8080
contexts:
- context:
    cluster:  TestCluster
    user:  comwarev9
current-context:  Comware
kind:  Config
preferences:  {}
users:  []
/* Kubelet configuration file flash:/third-party/autocopy/etc/kubernetes/kubeletconfig */
kind:  KubeletConfiguration
apiVersion:  kubelet.config.k8s.io/v1beta1
failSwapOn:  false
address:  0.0.0.0
port:  10250
/* Environment variable file for Kubelet command line parameters: flash:/third-party/autocopy/etc/kubernetes/kubelet */
KUBELET_ARGS=”--hostname-override 6890-A  --pod-infra-container-image=192.168.111.62: 5000/pause: 3.1“
# Enable the kubelet service.
[Sysname] kubelet enable
Starting kubelet...
OK.
# Disable the kubelet service.
[Sysname] undo kubelet enable
Stopping kubelet...
OK.
tpa container enable
Use tpa container enable to enable the container feature.
Use undo tpa container enable to disable the container feature.
The container feature is enabled.
To install Docker containers on the device, you must enable the container feature.
Disabling the container feature stops and deletes all running Docker containers.
# Enable the container feature.
[Sysname] tpa container enable
# Disable the container feature.
[Sysname] undo tpa container enable
This operation will disable the third-party container feature and all third-party containers will be stopped and deleted. Continue? [Y/N]: y
Stopping kubelet...
OK.
Done.
