18-Telemetry Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10018-Telemetry Command Reference
04-MOD commands
04-MOD commands 76.07 KB
MOD commands
collector
Use collector to configure the encapsulation information for packets sent to the collector by MOD.
Use undo collector to restore the default.
collector source-ip source-address destination-ip destination-address source-port source-port destination-port destination-port [ vlan vlan-id ]
undo collector
Defaults
The encapsulation information for packets sent to the collector by MOD is not configured.
MOD view
source-ip source-address: Specifies the source IP address for packets sent to the collector by MOD.
destination-ip destination-address: Specifies the destination IP address for packets sent to the collector by MOD.
source-port source-port: Specifies the source port number for packets sent to the collector by MOD.
destination-port destination-port: Specifies the destination port number for packets sent to the collector by MOD.
vlan vlan-id: Specifies the VLAN for packets sent to the collector by MOD.
The packets are encapsulated with the information specified by using this command and then routed to the remote collector.
# Encapsulate the packets sent to the collector by MOD with the following information: source IP address 10.10.10.10, destination IP address 20.20.20.20, source port number 10, and destination port number 20.
[Sysname] telemetry mod
[Sysname-telemetry-mod] collector source-ip 10.10.10.10 destination-ip 20.20.20.20 source-port 10 destination-port 20
telemetry mod
device-id
Use device-id to configure the device ID for MOD.
Use undo device-id to restore the default.
device-id address
undo device-id
Defaults
No device ID is configured for MOD.
MOD view
address: Specifies the device ID for MOD. This argument can be any IPv4 address except 0.0.0.0. The device ID will be padded in the packets sent to the collector, so that the collector can identify the source of packets.
# Configure the device ID for MOD as 10.10.10.10.
[Sysname-telemetry-mod] device-id 10.10.10.10
telemetry mod
display telemetry mod
Use display telemetry mod to display MOD configuration information.
display telemetry mod [ slot slot-number ]
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display MOD configuration information.
[Sysname] display telemetry mod
Status             : Successful
Drop reason list   :
  invalid-tpid
  unknown-vlan
Sampler            : test1
Device ID          : 192.168.56.2
Transport protocol : UDP
Collector
  Source IP        : 1.1.1.1
  Destination IP   : 1.1.1.2
  Source port      : 80
  Destination port : 90
  VLAN ID          : 20
  Output interface : HundredGigE1/0/1
  Destination MAC  : 0011-0200-0211
Status
MOD configuration deployment state:
·     Successful.
·     Failed.
·     Inactive—The reason-list command is not executed.
Drop reason list
Packet drop reasons (see Table 2).
None indicates that no packet drop reason is configured.
Drop group list
Packet drop reason groups:
·     drop-precedence-drop—Drop reason group related to drop precedence.
·     invalid-queue-drop—Drop reason group related to invalid queues.
·     multicast-replication-fail—Drop reason group related to multicast replication failures.
·     pfc-fc-drop—Drop reason group related to PFC flow control.
·     tail-or-wred-drop—Drop reason group related to tail drop or WRED drop.
·     traffic-management-fail—Drop reason group related to traffic management failures.
·     user-defined—User-defined drop reason group.
·     voq-ram-drop—Drop reason group related to VOQ RAM drop.
Transport protocol
Transport protocol that MOD uses to send packets to the collector.
In the current software version, only UDP is supported.
Collector
Encapsulation information for packets sent to the collector by MOD.
·     Source IP.
·     Destination IP.
·     Source port.
·     Destination port.
·     VLAN ID.
reason-list
Use reason-list to configure a list of packet drop reasons monitored by MOD.
Use undo reason-list to remove a list of packet drop reasons monitored by MOD.
reason-list { reason-list | all }
undo reason-list { reason-list | all }
Defaults
No packet drop reasons monitored by MOD are configured. The device does not monitor packet drops.
MOD view
reason-list: Specifies a list of packet drop reasons. You can specify a space-separated list of up to eight reasons one time. Table 2 shows the possible packet drop reasons.
Table 2 Packet drop reasons
Value
denied-vlan
The VLAN carried in the packet is not an allowed VLAN on the port.
dip-miss
The destination IPv4 or IPv6 address of a packet does not match a route.
inbound-ttl
TTL-related packet drop on the input interface.
invalid-tpid
Invalid TPID.
ip-multicast-error
This value is not supported in the current software version.
IP multicast packet error.
l3-header-error
IPv4 or IPv6 header error.
mmu-drop
MMU-related packet drop.
parity-error
Parity error.
smac-zero
The source MAC address is all zeros.
source-miss
The source IPv4 or IPv6 address of a packet does not match a route.
tunnel-header-error
Tunnel packet header error.
all: Specifies all packet drop reasons.
If you execute the reason-list reason-list command multiple times, the added packet drop reasons accumulate.
If you execute the undo reason-list reason-list command multiple times, the deleted packet drop reasons accumulated.
# Configure MOD to monitor all packet drop reasons.
[Sysname-telemetry-mod] reason-list all
telemetry mod
sampler
Use sampler to enable sampling for MOD.
Use undo sampler to disable sampling for MOD.
sampler sampler-name
undo sampler
Defaults
Sampling is disabled for MOD.
MOD view
sampler-name: Specifies a sampler by its name, a case-sensitive string of 1 to 31 characters.
# Enable sampling for MOD, and use the sampler named sampler1.
[Sysname-telemetry-mod] sampler sampler1
sampler (Network Management and Monitoring Command Reference)
telemetry mod
telemetry mod
Use telemetry mod to enter MOD view.
telemetry mod
# Enter MOD view.
