| 03-Flow group commands | 89.37 KB |
Flow group commands
display telemetry flow-group
Use display telemetry flow-group to display the configuration and application status of flow groups.
display telemetry flow-group [ group-id | name group-name ] [ slot slot-number ]
group-id: Specifies a flow group by its ID. The value range for this argument is 1 to 7.
name group-name: Specifies a flow group by its name, a case-sensitive string of 1 to 63 characters.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
If you do not specify the group-id or name group-name option, this command displays the configuration and application status of all flow groups.
# Display the configuration of flow group 1 and its application status in slot 1.
<Sysname> display telemetry flow-group 1 slot 1
Flow group 1 (Failed)
ACL : 2001 (The ACL doesn't exist.)
Template:
destination-ip
destination-port
source-ip
source-port
vxlan
inner-destination-ip
inner-source-ip
Mode : Common-MOD
Configured aging time: 100 milliseconds
Flow group 1 (Failed) |
Name of the flow group. Values for the application status include: · Successful—The flow group is applied successfully. · Failed—The flow group fails to be applied for some reasons other than incomplete flow group configuration. · Inactive—The flow group has not been administratively applied. · Incomplete—The flow group fails to be applied because its configuration is incomplete. |
Mode |
The mode specified when a flow group is applied: · Common-MOD · Mice-elephant-flow |
Apply mode |
The mode specified when a flow group is applied: · Common-MOD Values for the application status include: · Successful—The flow group is applied successfully. · Failed—The flow group fails to be applied for some reasons other than incomplete flow group configuration. · Inactive—The flow group has not been administratively applied. |
Active aging time |
Aging time that actually takes effect. |
display telemetry flow-group flow-table
Use display telemetry flow-group flow-table to display the flow entries generated by flow groups.
display telemetry flow-group flow-table [ [ group-id | name group-name ] | mod ] [ destination-ip { dst-ipv4 | dst-ipv6 } | destination-port dst-port | protocol protocol | source-ip { src-ipv4 | src-ipv6 } | source-port src-port ] * { slot slot-number }
group-id: Specifies a flow group by its ID. The value range for this argument varies by device model.
mod: Specifies flow groups in MOD mode and flow groups in simple MOD mode.
destination-ip { dst-ipv4 | dst-ipv6 }: Specifies the destination IPv4 or IPv6 address.
destination-port dst-port: Specifies the destination port number.
protocol protocol: Specifies the network layer protocol.
source-ip { src-ipv4 | src-ipv6 }: Specifies the source IPv4 or IPv6 address.
source-port src-port: Specifies the source port number.
If you do not specify flow groups, this command displays the flow entries generated by each flow group.
# Display the flow entries generated by flow group 1 for slot 1.
<Sysname> display telemetry flow-group flow-table 1 slot 1
Slot: 1
Flow group 1 (name: abc)
Mode: Mice elephant flow
Src IP Dst IP Pro SPort DPort Aging Packets
In Src IP In Dst IP InP InSP InDP VXLAN ID Bytes
Drop Reason
192.168.1.86 192.168.10.2 6 20 30 12m10s 10
- - - - - - 12400
unknown-vlan
Mode |
Flow group mode: · Mice elephant flow—Elephant/mice flow mode. |
Packet |
Packet count. |
In Src IP |
Inner source IP address of VXLAN packets. |
In Dst IP |
Inner destination IP address of VXLAN packets. |
InP |
Inner network layer protocol. |
InSP |
Inner source port number. |
InDP |
Inner destination port number. |
VXLAN ID |
VXLAN ID. |
Bytes |
Byte count. |
Drop Reason |
Packet drop reason: · car-exceeded—Packet rate exceeded CAR. · higig-header-error—HiGig header error. · invalid-tpid—Invalid TPID. · ip-multicast-error—IP multicast packet error. · ipv4-dip-miss—The destination IPv4 address of a packet does not match a route or matches the default route. · ipv4-l3-header-error—IPv4 header error. · ipv6-dip-miss—The destination IPv6 address of a packet does not match a route or matches the default route. · parity-error—Parity error. · tunnel-header-error—Tunnel packet header error. · unknown-vlan—Unknown VLAN. |
if-match acl
Use if-match acl to specify an ACL for a flow group.
Use undo if-match acl to remove an ACL from a flow group.
if-match acl [ ipv6 | mac ] { acl-number | name acl-name }
undo if-match acl
No ACL is specified for a flow group.
Flow group view
ipv6: Specifies the IPv6 ACL type.
mac: Specifies the Layer 2 ACL type.
acl-number: Specifies the ACL number. The following are available value ranges:
· 2000 to 2999 for basic ACLs.
· 3000 to 3999 for advanced ACLs.
· 4000 to 4999 for Layer 2 ACLs.
name acl-name: Specifies the ACL name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter.
When specifying an ACL, follow these restrictions and guidelines:
· If the specified ACL does not exist or does not have any rules, no traffic will match the ACL.
· In the specified ACL, whether an ACL rule supports the vpn-instance keyword and how the vpn-instance keyword takes effect vary by device model.
When specifying an ACL by its number, follow these rules:
· To specify an IPv4 ACL, specify only its number.
· To specify an IPv6 ACL or Layer 2 ACL, you must specify both its type and number.
When specifying an ACL by its name, follow these rules:
· To specify an IPv4 ACL, specify only its name.
· To specify an IPv6 ACL or Layer 2 ACL, you must specify both its type and name.
A flow group takes effect only on the traffic that matches the specified ACL.
Only one ACL can be specified for a flow group.
# Specify ACL 3000 in flow group 1.
[Sysname] telemetry flow-group 1
[Sysname-telemetry-flow-group-1] if-match acl 3000
acl (ACL and QoS Command Reference)
telemetry apply flow-group
Use telemetry apply flow-group to apply a flow group.
Use undo telemetry apply flow-group to remove the application of a flow group.
telemetry apply flow-group { group-id | name group-name }
undo telemetry apply flow-group { group-id | name group-name | system-defined ip mode mice-elephant-flow }
No flow group is applied.
mode: Specifies an application mode for a system-defined flow group..
· mice-elephant-flow: Specifies the mice-elephant-flow application mode.
The device has a system-defined flow group named system-defined-ip, which is not configurable.
The system-defined flow group generates flow entries based on the 5-tuple and takes effect on all traffic.
# Apply flow group 1.
[Sysname] telemetry apply flow-group 1
# Apply the system-defined IP flow group with the mice/elephant flow mode.
[Sysname] telemetry apply flow-group system-defined ip mode mice-elephant-flow
Use telemetry flow-group to create a flow group and enter its view, or enter the view of an existing flow group.
Use undo telemetry flow-group to delete a flow group.
telemetry flow-group group-id [ name group-name ]
undo telemetry flow-group { group-id | name group-name }
No flow groups exist.
group-id: Specifies a flow group ID. The value range for this argument is 1 to 7.
name group-name: Specifies a flow group name, a case-sensitive string of 1 to 63 characters. The name must be globally unique and cannot start with system-defined-.
You cannot name or rename an existing flow group.
To delete an applied flow group, first remove the application and then delete the flow group.
# Create flow group 1 and enter its view.
telemetry flow-group aging-time
Use telemetry flow-group aging-time to set the aging time for flow entries.
Use undo telemetry flow-group aging-time to restore the default.
telemetry flow-group aging-time msec aging-time
The aging time for flow entries is 10 milliseconds.
msec aging-time: Specifies the aging time for flow entries, in milliseconds. Valid values are 1, 2, 5, and 10.
# Set the aging time for flow entries to 5 milliseconds.
[Sysname] telemetry flow-group aging-time 5
template
Use template to configure a flow entry generation rule.
Use undo template to delete a flow entry generation rule.
template { destination-ip | destination-port | protocol | source-ip | source-port } *
undo template
No flow entry generation rule is configured.
destination-ip: Generates flow entries based on the destination IP address.
destination-port: Generates flow entries based on the destination port number.
protocol: Generates flow entries based on the Layer 3 protocol type.
source-ip: Generates flow entries based on the source IP address.
source-port: Generates flow entries based on the source port number.
This command enables the device to identify traffic and generate flow entries based on the specified header fields.
# Configure flow group 1 to generated flow entries based on the source IP address, destination IP address, source port number, and destination port number.
[Sysname-telemetry-flow-group-1] template destination-ip destination-port source-ip source-port
