12-ACL and QoS Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10012-ACL and QoS Command Reference
03-Data buffer commands
03-Data buffer commands 174.58 KB
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to restore the default.
buffer apply
undo buffer apply
For data buffer settings to take effect, you must execute this command after configuring data buffer settings.
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
buffer packet-drop alarm enable
Use buffer packet-drop alarm enable to enable packet-drop alarms.
Use undo buffer packet-drop alarm enable to disable packet-drop alarms.
Packet-drop alarms are disabled.
The device generates and reports packet-drop alarms to a network management system (such as IMC) for displaying the data buffer usage.
This command does not take effect only on the Headroom buffer.
# Enable packet-drop alarms.
[Sysname] buffer packet-drop alarm enable
buffer usage threshold queue (interface view)
buffer usage threshold queue (system view)
buffer packet-drop alarm interval
Use buffer packet-drop alarm interval to set the interval for sending packet-drop alarms.
Use undo buffer packet-drop alarm interval to restore the default.
buffer packet-drop alarm interval interval
The interval for sending packet-drop alarms is 5 seconds.
interval: Specifies the interval for sending packet-drop alarms, in the range of 0 to 60 seconds. The value of 0 indicates that packet-drop alarms are sent immediately after they are generated.
This command takes effect only when packet-drop alarms are enabled.
# Set the interval for sending packet-drop alarms to 20 seconds.
[Sysname] buffer packet-drop alarm interval 20
buffer queue guaranteed (system view)
Use buffer queue guaranteed to set the fixed-area space for a queue.
Use undo buffer queue guaranteed to delete the fixed-area space setting of a queue.
buffer egress [ slot slot-number ] cell queue queue-id guaranteed ratio ratio
undo buffer egress [ slot slot-number ] cell queue queue-id guaranteed
The fixed-area ratio for a queue is 12%.
egress: Specifies the egress buffer.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
cell: Specifies cell resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
ratio ratio: Specifies the fixed-area space ratio, in percentage. The value range for ratio is 1 to 100.
By default, all queues have an equal share of the fixed area. You can set the fixed-area ratio for a queue. The other queues equally share the remaining part.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of fixed-area space configured for all queues cannot exceed the total fixed-area space. Otherwise, the configuration fails.
# Configure queue 0 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 guaranteed ratio 20
buffer queue guaranteed (interface view)
Use buffer queue guaranteed to set the fixed-area ratio or size for a queue.
Use undo buffer queue guaranteed to delete the fixed-area ratio or size setting of a queue.
buffer egress cell queue queue-id guaranteed ratio ratio
undo buffer egress cell queue queue-id guaranteed
Interface view
ratio ratio: Specifies the fixed-area space ratio, in percentage. The value range for ratio is 0 to 100.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of the fixed-area ratios configured for all queues cannot exceed 100%. The queue that causes the sum of the fixed-area ratios to exceed 100% fails to be configured and still uses the default setting.
# Configure queue 0 on HundredGigE 1/0/1 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname-HundredGigE1/0/1] buffer egress cell queue 0 guaranteed ratio 20
buffer queue map-to service-pool
Use buffer queue map-to service-pool to map a queue to a service pool.
Use undo buffer queue map-to service-pool to restore the default.
buffer { egress | ingress } queue queue-id map-to service-pool sp-id
undo buffer { egress | ingress } queue queue-id map-to
All queues are mapped to service pool 0.
Interface view
ingress: Specifies the ingress buffer.
service-pool sp-id: Specifies a service pool by its ID. The value range for the sp-id argument is 1 to 3.
Before configuring this command, use the buffer service-pool shared command to set the maximum shared-area ratio for the service pool.
For the same packet, the queue of the ingress interface receive buffer and the queue of the egress interface transmit buffer must be mapped to the same service pool.
When you modify the service pool mapping of the ingress interface receive buffer and the egress interface transmit buffer queues, make sure no traffic is present on the ingress and egress interfaces, or use the shutdown command to shut down the interfaces. After you modify the service pool mapping, bring up the interfaces. For more information about the command, see common interface commands in Interface Command Reference.
For different interfaces, the device supports a maximum of six mappings between queues and service pools.
For the ingress buffer, the queue ID specified represents the 802.1p priority. The actual queue ID mapped to the service pool is determined by the dot1p-lp priority map.
# Map queue 1 on HundredGigE 1/0/1 to service pool 1.
[Sysname-HundredGigE1/0/1] buffer egress queue 1 map-to service-pool 1
buffer queue shared (system view)
Use buffer queue shared to set the maximum shared-area ratio for a queue.
Use undo buffer queue shared to delete the maximum shared-area ratio setting of a queue.
buffer egress [ slot slot-number ] cell queue queue-id shared { ratio ratio | size }
undo buffer egress [ slot slot-number ] cell queue queue-id shared
The maximum shared-area ratio for a queue is 20%.
queue-id: Specifies a queue by its ID in the range of 0 to 7. If you do not specify a queue, this command sets the maximum shared-area space for each port.
ratio ratio: Specifies the maximum shared-area space ratio, in percentage. The value range for ratio is 0 to 100.
size: Specifies the maximum shared-area space, in the range of 0 to 257862 cell resources. The S9825 switch series supports the range 0 to 216535.
By default, all queues have an equal share of the shared area. You can set the shared-area ratio for a queue. The unconfigured queues use the default setting. The shared-area space for each queue is finally determined by the chip based on your configuration and the number of packets to be received and sent.
# Configure queue 0 to use up to 10% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 shared ratio 10
buffer queue shared (interface view)
Use buffer queue shared to set the maximum shared-area ratio or size for a queue.
Use undo buffer queue shared to delete the maximum shared-area ratio or size setting of a queue.
buffer egress cell queue queue-id shared { ratio ratio | size }
undo buffer egress cell queue queue-id shared
Interface view
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 100.
# Configure queue 0 on HundredGigE 1/0/1 to use 20% shared-area space of cell resources in the egress buffer.
[Sysname-HundredGigE1/0/1] buffer egress cell queue 0 shared ratio 20
Use buffer service-pool shared to set the maximum shared-area ratio or size for a service pool.
Use undo buffer service-pool shared to delete the maximum shared-area ratio or size setting of a service pool.
buffer { egress | ingress } [ slot slot-number ] cell service-pool sp-id shared ratio ratio
undo buffer { egress | ingress } [ slot slot-number ] cell service-pool sp-id shared
All of the shared area is reserved for service pool 0.
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 99.
This command takes effect after you executed the buffer apply command.
When you configure the size of the shared area available to a transmit buffer service pool, the size of the shared area available to the receive buffer service pool with the same number is also adjusted accordingly.
# Configure service pool 1 to use up to 50% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell service-pool 1 shared ratio 50
buffer apply
buffer threshold alarm enable
Use buffer threshold alarm enable to enable threshold-crossing alarms.
Use undo buffer threshold alarm enable to disable threshold-crossing alarms.
buffer threshold alarm { egress | headroom | ingress } enable
undo buffer threshold alarm { egress | headroom | ingress } enable
Threshold-crossing alarms are disabled.
headroom: Specifies the Headroom buffer.
The device generates and reports threshold-crossing alarms to a network management system (such as IMC) for displaying the data buffer usage.
# Enable threshold-crossing alarms.
[Sysname] buffer threshold alarm ingress enable
buffer usage threshold headroom
buffer usage threshold headroom queue
buffer threshold alarm interval
Use buffer threshold alarm interval to set the interval for sending threshold-crossing alarms.
Use undo buffer threshold alarm interval to restore the default.
buffer threshold alarm { egress | headroom | ingress } interval interval
undo buffer threshold alarm { egress | headroom | ingress } interval
The interval for sending threshold-crossing alarms is 5 seconds.
interval: Specifies the interval for sending threshold-crossing alarms, in the range of 0 to 60 seconds. 0 indicates that threshold-crossing alarms are sent immediately after they are generated.
This command takes effect only when threshold-crossing alarms are enabled.
# Set the interval for sending threshold-crossing alarms to 20 seconds.
[Sysname] buffer threshold alarm ingress interval 20
buffer total-shared
Use buffer total-shared to set the total shared-area ratio.
Use undo buffer total-shared to delete the total shared-area ratio setting.
buffer egress [ slot slot-number ] cell total-shared ratio ratio
undo buffer egress [ slot slot-number ] cell total-shared
If this command is not configured, you can display the default value by using the display buffer command.
ratio ratio: Specifies the ratio of the shared area, in percentage. The value range for ratio is 0 to 100.
After you set the shared-area ratio, the remaining buffer space is automatically assigned to the fixed area.
# Configure the shared area to use 50% space of cell resources in the egress buffer.
[Sysname] buffer egress cell total-shared ratio 50
buffer usage peak-interval
Use buffer queue shared to set the monitoring period for data buffer peak usage.
Use undo buffer queue shared to restore the default.
buffer usage peak-interval interval
undo buffer usage peak-interval
The monitoring period for data buffer peak usage is 3600 seconds.
interval: Specifies the monitoring period for data buffer peak usage, in the range of 5 to 3600 seconds.
Operating mechanism
The device collects information on buffer usage per second. It compares the collected information during the monitoring interval to determine the peak buffer usage and the time the peak occurred. When a monitoring period ends, the system clears the peak value for that monitoring period and starts monitoring a new peak in the next monitoring period. The device reports the peak value and the time obtained in the previous monitoring period to the gRPC server via gRPC.
For example, if the monitoring period for buffer usage peak is 600 seconds, after the 600-second monitoring period ends, a peak buffer usage value and its occurrence time are obtained. At this point, gRPC will report the peak data from the previous monitoring period.
This command is effective only for reporting buffer usage peaks via gRPC. As a best practice, configure a long peak usage monitoring period. Otherwise, the peak information reported by gRPC will change frequently and might not accurately reflect the actual peak buffer usage situation.
The peak value records displayed by the display buffer usage interface command are not affected by this command.
# Set the monitoring period for data buffer peak usage to 200 seconds.
[Sysname] buffer usage peak-interval 200
Use buffer usage threshold to set a per-interface buffer usage threshold.
Use undo buffer usage threshold to restore the default.
buffer usage threshold slot slot-number ratio ratio
undo buffer usage threshold slot slot-number
The per-interface buffer usage threshold is 100%.
ratio ratio: Specifies the buffer usage threshold in percentage, in the range of 1 to 100.
After you configure this command, the switch automatically records buffer usage for each interface. When a queue on an interface uses more buffer space than the set threshold, the system counts one threshold violation for the queue.
To display the buffer usage statistics for interfaces, use the display buffer usage interface command.
# Set the per-interface buffer usage threshold to 50% for slot 1.
[Sysname] buffer usage threshold slot 1 ratio 50
Use buffer usage threshold headroom to set the global per-queue alarm threshold for the Headroom buffer.
Use undo buffer usage threshold headroom to restore the default.
buffer usage threshold headroom slot slot-number ratio ratio
undo buffer usage threshold headroom slot-number ratio
The global per-queue alarm threshold for the Headroom buffer is 100%.
ratio ratio: Specifies the alarm threshold in percentage, in the range of 1 to 100.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global alarm threshold for the Headroom buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
#  Set the global per-queue alarm threshold to 50% for slot 1.
[Sysname] buffer usage threshold headroom slot 1 ratio 50
Use buffer usage threshold headroom queue to set the Headroom buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold headroom queue to restore the default.
buffer usage threshold headroom queue queue-id ratio ratio
undo buffer usage threshold headroom queue queue-id ratio
The global per-queue alarm threshold for the Headroom buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the Headroom buffer alarm threshold to 50% for queue 1 on HundredGigE 1/0/1.
[Sysname–HundredGigE1/0/1] buffer usage threshold headroom queue 1 ratio 50
Use buffer usage threshold queue to set the ingress or egress buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold queue to restore the default.
buffer { egress | ingress } usage threshold queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold queue queue-id ratio
The global per-queue alarm threshold for the ingress or egress buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold for the ingress or egress buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the ingress buffer alarm threshold to 50% for queue 1 on HundredGigE 1/0/1.
[Sysname–HundredGigE1/0/1] buffer ingress usage threshold queue 1 ratio 50
Use buffer usage threshold queue to set the global ingress or egress buffer alarm threshold for a queue.
buffer { egress | ingress } usage threshold slot slot-number  queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold slot slot-number queue queue-id ratio
The global ingress or egress buffer alarm threshold for a queue is 100%.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global ingress or egress alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
#  Set the global ingress alarm threshold to 50% for queue 1 in slot 1.
[Sysname] buffer ingress usage threshold slot 1 queue 1 ratio 50
buffer usage threshold service-pool
Use buffer usage threshold service-pool to set the alarm threshold for a service pool.
Use undo buffer usage threshold service-pool to restore the default.
buffer egress usage threshold service-pool sp-id slot slot-number ratio ratio
undo buffer egress usage threshold service-pool sp-id slot slot-number ratio
The alarm threshold for a service pool is 100%.
service-pool sp-id: Specifies a service pool by its ID. The value range for the sp-id argument is 0 to 3.
This command takes effect only when threshold-crossing alarms are enabled. When the usage of a service pool exceeds the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the alarm threshold to 50% for a service pool in slot 1.
[Sysname] buffer egress usage threshold service-pool 0 slot 1 ratio 50
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·     Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·     Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·     Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer
Use display buffer to display buffer size settings.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
queue queue-id: Specifies a queue by its number in the range of 0 to 7. If you specify a queue, this command displays the fixed-area ratio and shared-area ratio for the specified queue. If you specify the queue keyword without the queue-id argument, this command displays the fixed-area ratio and shared-area ratio for each queue. If you do not specify the queue keyword, this command displays the total shared-area ratio.
# Display buffer size settings.
<Sysname> display buffer
Slot  Type    Eg(Total-shared)
1     cell    100
          Eg: Size of the sending buffer
Total-shared: Size of the shared buffer for all ports
        Unit: Ratio
# Display the fixed-area ratio and shared-area ratio for the queues.
<Sysname> display buffer queue
Slot  Queue        Type    Eg(Guaranteed , Shared)
1     0-7          cell    0 , 20
  Guaranteed: Size of the minimum guaranteed buffer per queue
      Shared: Size of the maximum shared buffer per queue
        Unit: Ratio
Resource type: packet or cell.
Queue
Queue ID in the range of 0 to 7.
Eg
Egress buffer.
(Total-shared)
Total-shared indicates the total shared-area ratio.
If the device does not support a resource type, this field displays two hyphens (--).
·     Guaranteed indicates the fixed-area ratio of a queue.
·     Shared indicates the shared-area ratio of a queue.
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
# Display buffer usage.
<Sysname> display buffer usage
Ingress total-shared cell buffer usage on slot 1 :
XPE0
Total:   80078 KB
Used:       0 KB
Free:   80078 KB
Global_headroom_total:    1240 KB
Global_headroom_used:       0 KB
SP0_headroom_total:    1240 KB
SP0_headroom_used:       0 KB
SP0_headroom_peak:       0 KB
SP0_buffer_total:   80078 KB
SP0_buffer_used:       0 KB
SP0_buffer_peak:       0 KB
SP1_headroom_total:       0 KB
SP1_headroom_used:       0 KB
SP1_headroom_peak:       0 KB
SP1_buffer_total:       0 KB
SP1_buffer_used:       0 KB
SP1_buffer_peak:       0 KB
SP2_headroom_total:       0 KB
SP2_headroom_used:       0 KB
SP2_headroom_peak:       0 KB
SP2_buffer_total:       0 KB
SP2_buffer_used:       0 KB
SP2_buffer_peak:       0 KB
SP3_headroom_total:       0 KB
SP3_headroom_used:       0 KB
SP3_headroom_peak:       0 KB
SP3_buffer_total:       0 KB
SP3_buffer_used:       0 KB
SP3_buffer_peak:       0 KB
Egress total-shared cell buffer usage on slot 1 :
XPE0
Total:   80078 KB
Used:       0 KB
Free:   80078 KB
                                 5sec   1min   5min
HundredGigE1/0/1         XPE 0     0%     0%     0%
HundredGigE1/0/2         XPE 0     0%     0%     0%
HundredGigE1/0/3         XPE 0     0%     0%     0%
HundredGigE1/0/4         XPE 0     0%     0%     0%
HundredGigE1/0/5         XPE 0     0%     0%     0%
HundredGigE1/0/6         XPE 0     0%     0%     0%
HundredGigE1/0/7         XPE 0     0%     0%     0%
HundredGigE1/0/8         XPE 0     0%     0%     0%
HundredGigE1/0/9         XPE 0     0%     0%     0%
HundredGigE1/0/10        XPE 0     0%     0%     0%
Usage of cell resources in the shared area on the device.
XPE
Type of the data buffer.
Total
Total size of the data buffer.
Used
Size of used data buffer.
Free
Size of free data buffer.
SP
Service pool.
headroom_used
Headroom area usage in KB for the ingress buffer.
headroom_peak
Peak used Headroom area in KB during the time between two executions of the display buffer usage command.
buffer_total
Total buffer size in KB.
buffer_used
Used buffer size in KB.
buffer_peak
Peak used buffer size in KB during the time between two executions of the display buffer usage command.
5sec
Percentage of the buffer that the port uses for the last 5 seconds.
1min
Percentage of the buffer that the port uses for the last 1 minute.
5min
Percentage of the buffer that the port uses for the last 5 minutes.
Use display buffer usage interface to display buffer usage statistics for interfaces.
display buffer usage interface [ interface-type [ interface-number ] ] [ verbose ]
interface-type [ interface-number ]: Specifies an interface by its type and number. If you do not specify the interface-type argument, this command displays buffer usage statistics for all Ethernet interfaces. If you specify the interface-type argument without the interface-number argument, this command displays buffer usage statistics for all Ethernet interfaces of the specified type.
verbose: Displays detailed buffer usage statistics. If you do not specify this keyword, the command displays brief buffer usage statistics.
# Display brief buffer usage statistics for HundredGigE 1/0/1.
<Sysname> display buffer usage interface hundredgige 1/0/1
Interface   QueueID Total                          Used            Threshold(%) Violations
HGE1/0/1    0       257862 cell 82000116 bytes    0 cell 0 bytes  100         0
            1       257862 cell 82000116 bytes    0 cell 0 bytes  100         0
            2       257862 cell 82000116 bytes    0 cell 0 bytes  100         0
            3       257862 cell 82000116 bytes    0 cell 0 bytes  100         0
            4       257862 cell 82000116 bytes    0 cell 0 bytes  100         0
            5       257862 cell 82000116 bytes    0 cell 0 bytes  100         0
            6       257862 cell 82000116 bytes    0 cell 0 bytes  100         0
            7       257862 cell 82000116 bytes    0 cell 0 bytes  100         0
Total
Data buffer size in cell resources and bytes allowed for a queue.
Used
Data buffer size in cell resources and bytes that has been used by a queue.
Threshold(%)
Buffer usage threshold for a queue, which is configured by using the buffer usage threshold command. The threshold value is the same as the per-interface threshold value.
Violations
Number of threshold violations for a queue.
The value of this field is reset upon a switch reboot.
# Display detailed buffer usage statistics for HundredGigE 1/0/1.
[Sysname] display buffer usage interface hundredgige 1/0/1 verbose
HGE1/0/1
  Ingress:
    QueueID: 0
      Total: 36 cell 55000 bytes                 Used: 0 cell 0 bytes
      Threshold(%): 3                            Violations: 4
      Shared: 1 cell 5 bytes                     Headroom: 6 cell 30 bytes
      Xoff threshold: 36 cell 55000 bytes        Is dynamic: 0
      Used(%): 0                                 Free: 36 cell 55000 bytes
      UsedPeak: 0 cell 0 bytes                   HeadroomUsed(%): 0
      HeadroomFree: 0 cell 0 bytes               HeadroomPeak: 0 cell 0 bytes
      UsedPeakTime: 2022-04-19 20:20:43          HeadroomPeakTime: 2022-04-19 20:20:43
    QueueID: 7
      UsedPeakTime: 2022-04-19 21:20:43          HeadroomPeakTime: 2022-04-19 21:20:43
  Egress:
    QueueID: 0
      Threshold(%): 22                           Violations: 12
      TailDropThreshold: 1 cell 13 bytes         Is dynamic: 0
      DeadlockCount: 0                           DeadlockRecover: 0
      UsedPeak: 0 cell 0 bytes                   UsedPeakTime: -
    QueueID: 7
Ingress
Usage statistics for the ingress buffer.
Egress
Usage statistics for the egress buffer.
Total
Data buffer size allowed for a queue, in the number of cell resources and bytes.
Used
Data buffer size that has been used by a queue, in the number of cell resources and bytes.
Threshold(%)
Buffer usage threshold for a queue. The threshold value is the same as the per-interface threshold value.
Violations
Shared
Number of cell resources and bytes in the shared area used by a queue
Headroom
Number of cell resources and bytes in the Headroom area used by a queue. When a queue on an interface enabled with PFC enters PFC XOFF state, the interface sends XOFF frames to notify the peer interface to stop sending packets to that queue. Packets sent by the peer interface before it receives XOFF frames are stored in the Headroom area.
XoffThres
Back pressure frame triggering threshold.
If a dynamic back pressure frame triggering threshold is configured, this field displays a percentage value. If a static back pressure frame triggering threshold is configured, this field displays an absolute value.
For commands to configure back pressure frame triggering thresholds, see PFC commands in Layer 2—LAN Switching Command Reference
TailDropThresh
Tail drop threshold, in the number of cell resources calculated according to the ratio value set in the buffer queue shared command.
IsDynamic
For the inbound direction, this field can be one of the following values:
·     0—Indicates a static back pressure frame triggering threshold.
·     1—Indicates a dynamic back pressure frame triggering threshold.
For the outbound direction, this field can only be 1, which indicates a dynamic tail drop threshold.
Used(%)
Buffer usage in percentage.
Free
Free buffer in cell resources and bytes.
UsedPeak
Peak used buffer in cell resources and bytes during the time between two executions of the display buffer usage interface command.
HeadroomUsed(%)
Headroom area usage in percentage for the ingress buffer.
HeadroomFree
Free Headroom area in cell resources and bytes for the ingress buffer.
HeadroomPeak
Peak used Headroom area in cell resources and bytes during the time between two executions of the display buffer usage interface command.
UsedPeakTime
Peak time for buffer use. This field displays a hyphen (-) if the buffer is not used.
HeadroomPeakTime
Peak time for Headroom buffer use. This field displays a hyphen (-) if the Headroom buffer is not used.
DeadlockCount
Number of times the device entered the PFC deadlock state in the egress buffer.
DeadlockRecover
Number of times the device released the PFC deadlock state in the egress buffer.
