12-ACL and QoS Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R932x-6W10012-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 663.59 KB
QoS policy commands· 1
Traffic class commands· 1
description· 1
display traffic classifier 1
if-match· 2
traffic classifier 8
Traffic behavior commands· 9
accounting· 9
car 10
display traffic behavior 11
filter 12
redirect 13
remark dot1p· 14
remark dscp· 14
remark ip-precedence· 15
remark local-precedence· 16
remark qos-local-id· 17
remark tunnel-dscp· 17
traffic behavior 18
QoS policy commands· 19
classifier behavior 19
control-plane· 20
display qos policy· 21
display qos policy control-plane· 23
display qos policy control-plane pre-defined· 24
display qos policy global 25
display qos policy interface· 28
display qos policy l2vpn-ac· 32
display qos vlan-policy· 33
qos apply policy (Ethernet service instance view, interface view, control plane view) 35
qos apply policy global 36
qos policy· 37
qos vlan-policy· 39
reset qos policy control-plane· 39
reset qos policy global 40
reset qos vlan-policy· 40
QoS and ACL resource usage displaying commands· 41
display qos-acl resource· 41
Priority mapping commands· 45
Priority map commands· 45
display qos map-table· 45
import (priority map view) 46
qos map-table· 46
Priority trust mode commands· 47
display qos trust interface· 47
qos trust 48
qos trust (system view) 49
Port priority commands· 49
qos priority· 49
Global priority commands· 50
qos mirroring local-precedence· 50
Traffic policing, GTS, and rate limit commands· 52
Traffic policing commands· 52
display qos overhead compensation-length· 52
GTS commands· 54
display qos gts interface· 54
qos gts· 54
Rate limit commands· 55
display qos lr interface· 55
qos lr 56
Congestion management commands· 58
SP commands· 58
display qos queue sp interface· 58
qos sp· 58
WRR commands· 59
display qos queue wrr interface· 59
qos wrr 60
qos wrr  { byte-count | weight } 61
qos wrr group sp· 62
WFQ commands· 63
display qos queue wfq interface· 63
qos bandwidth queue· 64
qos wfq· 64
qos wfq { byte-count | weight } 65
qos wfq group sp· 66
Queue scheduling profile commands· 67
bandwidth queue· 67
display qos qmprofile configuration· 68
display qos qmprofile interface· 69
qos apply qmprofile· 69
qos qmprofile· 70
queue· 71
Congestion avoidance commands· 73
WRED commands· 73
ai-ecn· 73
ai ai-ecn enable· 73
ai-service· 74
display qos wred ecn interface· 74
display qos wred interface· 76
display qos wred table· 77
qos wred apply· 78
qos wred queue· 79
qos wred queue ecn· 80
qos wred queue table· 81
qos wred queue weighting-constant 82
queue (AI ECN view) 82
queue (WRED table view) 83
queue ecn· 84
queue weighting-constant 85
Traffic Matrix commands· 87
display traffic-matrix· 87
ip source destination· 89
ipv6 source destination· 90
traffic-matrix· 91
Elephant and mice flows distinguishing commands· 93
elephant-flow action· 93
elephant-flow rate· 93
agile-buffer enable· 94
qos mice-elephant-flow· 96
Queue-based accounting commands· 97
display qos queue-statistics interface outbound· 97
reset qos queue-statistics interface outbound· 98
QoS policy commands
description
Use description to configure a description for a traffic class.
Use undo description to delete the description of a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ inner ]
Matches an ACL.
The value range for the acl-number argument is as follows:
·     2000 to 3999 for IPv4 ACLs.
·     2000 to 3999 for IPv6 ACLs.
·     4000 to 4999 for Layer 2 MAC ACLs.
·     5000 to 5999 for user-defined ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
If you use the rule [ rule-id ] { deny | permit } command to match packets, the inner keyword matches the inner header information of VXLAN packets. If you do not specify this keyword, the ACL matches the header information of non-encapsulated packets or the outer header information of VXLAN packets.
If you use the rule [ rule-id ] { deny | permit } vxlan command to match inner header information of VXLAN packets, you cannot specify the inner keyword in the if-match acl command.
On the S9855 switch series, to successfully match VXLAN packets by inner IPv6 address, make sure the prefix length is not greater than 120.
If you do not specify a VPN instance, whether the rule applies to VPN packets varies by feature. See the description for the feature that uses ACLs.
any
Matches all packets.
control-plane protocol protocol-name&<1-8>
Matches control plane protocols.
The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3.
control-plane protocol-group protocol-group-name
Matches a control plane protocol group.
The protocol-group-name argument can be critical, exception, important, management, monitor, normal, or redirect.
customer-dot1p dot1p-value
Matches 802.1p priority values in inner VLAN tags of double-tagged packets.
The value range for the dot1p-value argument is 0 to 7.
customer-vlan-id vlan-id-list
Matches VLAN IDs in inner VLAN tags of double-tagged packets.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
Only the S9855 switch series supports this option in the inbound direction.
destination-mac mac-address
Matches a destination MAC address.
This option takes effect only on Ethernet interfaces.
dscp dscp-value
Matches DSCP values.
The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5.
forwarding-layer route
Matches Layer 3 forwarded packets.
inbound-interface interface-type interface-number
Matches an input interface specified by its type and number.
This option is supported only when a QoS policy is applied to the control plane.
The following interface types are supported:
·     Physical interfaces.
·     Layer 3 Ethernet interfaces and subinterfaces.
·     Layer 2 aggregate interfaces.
·     Layer 3 aggregate interfaces and subinterfaces.
ip-precedence ip-precedence-value
Matches IP precedence values.
The value range for the ip-precedence-value argument is 0 to 7.
Matches a protocol.
The protocol-name argument can be ip or ipv6.
qos-local-id local-id-value
Matches a local QoS ID in the range of 1 to 1000.
rocev2 { opcode opcode-value | dst-qpair dst-qpair-value | src-qpair src-qpair-value | nack nack-value } *
Matches an RoCEv2 protocol:
·     opcode opcode-value: Matches the OpCode field in the BTH header. The opcode-value argument specifies an OpCode value in the range of 0 to 255.
·     dst-qpair dst-qpair-value: Matches the Destination QP field in the BTH header. The dst-qpair-value argument specifies a destination QP value in the range of 0 to 16777215.
·     src-qpair src-qpair-value: Matches the Source QP field in the DETH header. The src-qpair-value argument specifies a source QP value in the range of 0 to 16777215.
·     nack nack-value: Matches the lowest five bits in the Syndrome field in the NACK packets. The nack-value argument specifies a value for the lowest five bits in the Syndrome field, in the range of 0 to 31.
service-dot1p dot1p-value
Matches 802.1p priority values in outer VLAN tags.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
You can use this option to match single-tagged packets.
source-mac mac-address
Matches a source MAC address.
tunnel-id tunnel-id
Matches a VXLAN tunnel ID. For the traffic class to take effect, the tunnel must be a VXLAN tunnel.
vxlan { any | vxlan-id }
This option is supported only in the inbound direction.
Table 3 Available system-defined control plane protocols
Protocol
arp
ARP packets
arp-snooping
ARP snooping packets
bfd
BFD packets
bgp
BGP packets
bgp4+
IPv6 BGP packets
bpdu-tunnel
BPDU tunnel packets
cdp
CDP packets
cfd
CFD packets
dhcp
DHCP packets
dhcp-snooping
DHCP snooping packets
dhcp6
IPv6 DHCP packets
dldp
DLDP packets
dot1x
802.1X packets
icmp
ICMP packets
icmp6
ICMPv6 packets
igmp
IGMP packets
ip-option
IPv4 packets with the Options field
ipv6-option
IPv6 packets with the Options field
isis
IS-IS packets
lacp
LACP packets
lldp
LLDP packets
mvrp
MVRP packets (including GVRP packets)
oam
OAM packets
ospf-multicast
OSPF multicast packets
ospf-unicast
OSPF unicast packets
ospf3-multicast
OSPFv3 multicast packets
ospf3-unicast
OSPFv3 unicast packets
pvst
PVST packets
snmp
SNMP packets
ssh
SSH packets
stp
STP packets
telnet
Telnet packets
vrrp
VRRP packets
vrrp6
IPv6 VRRP packets
In a traffic class with the logical OR operator, you can configure multiple if-match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
·     You can specify up to eight values for any of the following match criteria in one if-match command:
¡     802.1p priority.
¡     DSCP.
¡     IP precedence.
¡     VLAN ID.
·     If a packet matches one of the specified values, it matches the if-match command.
·     To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
To use an ACL match criterion, the ACL must already exist.
The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
To match outgoing IPv6 packets in a QoS policy on an S9825 series switch, you must additionally configure the traffic class to match the IPv6 protocol.
The S9825 switch series does not support match the information after the Layer 2 header of packets with double VLAN tags.
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 6.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 6
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 6.
[Sysname-classifier-class1] if-match ip-precedence 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 6 in the inner VLAN tag.
[Sysname-classifier-class1] if-match customer-vlan-id 6
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 7 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 7
# Define a match criterion for traffic class class1 to match the packets of the application 3link.
[Sysname-classifier-class1] if-match application 3link
# Define a match criterion for traffic class class1 to match the VXLAN packets with tunnel ID 2.
[Sysname-classifier-class1] if-match tunnel-id 2
# Define a match criterion for traffic class class1 to match the packets with VXLAN 10.
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting [ byte | packet ] *
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
If you do not specify the byte or packet keyword, traffic is counted in both packets and bytes.
The accounting action does not take effect if the QoS policy is applied globally.
In the outbound direction of an interface on an S9855 switch, if both Layer 3 packet statistics collection and class-based accounting are configured, only Layer 3 packets are counted. For more information about Layer 3 packet statistics collection, see IP performance optimization in Layer 3—IP Services Configuration Guide.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 8 to 4294967288 kbps, in increments of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 8 to 4294967288 kbps, in increments of 8.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Specifies the action to take on the packet:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database: Set the CIR to 200 kbps and CBS to 51200 bytes.
[Sysname-behavior-database] car cir 200 cbs 51200
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Redirecting:
        Redirect to the CPU
    Behavior: 3 (ID 102)
      -none-
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
Accounting enable
Class-based accounting action.
Filter enable
Traffic filtering action.
Redirecting
Information about traffic redirecting.
Mirroring
Information about traffic mirroring.
none
No other traffic behavior is configured.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny  | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
The keywords in the command have different meanings:
·     deny—If a packet matches a traffic class, it is directly dropped and will no longer be affected by actions from lower-priority features.
·     permit—If a packet matches a traffic class, the QoS policy does not affect the packet. If the packet is processed by other lower-priority features, whether it is dropped will depend on the actions of those lower-priority features.
# Configure a traffic filtering action as deny in traffic behavior database.
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number.
sr-policy endpoint color: Redirects traffic to an SR-MPLS TE policy. The endpoint argument represents the endpoint IPv4 or IPv6 address of the SR-MPLS TE policy. The color argument represents the color attribute value of the SR-MPLS TE policy, in the range of 0 to 4294967295.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
The S9855 switch series does not support redirecting traffic to an aggregate interface.
# Configure redirecting traffic to HundredGigE 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface hundredgige 1/0/1
classifier behavior
qos policy
traffic behavior
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark dot1p dot1p-value
undo remark dot1p
No 802.1p priority marking action is configured.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
The S9855 switch series does not support marking the 802.1p priority in the outbound direction.
If you do not specify a color, packets of all colors are marked.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to delete the action.
remark dscp dscp-value
undo remark dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to delete the action.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
When the device marks the IP precedence of packets, it also sets the last three bits of the DSCP field as 000.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to delete the action.
remark local-precedence local-precedence-value
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id [ egress-active ] local-id-value
undo remark qos-local-id [ egress-active ]
No local QoS ID marking action is configured.
egress-active: Specifies that the local QoS ID marking action takes effect only in the outbound direction.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 1000. If the egress-active keyword is specified, the value range is 1 to 128.
You can use one QoS policy to mark the local QoS ID for packets in the inbound direction. Then, you can use another QoS policy to apply other QoS features in the outbound direction based on the marked local QoS ID.
A local QoS ID marking action applied to the inbound direction takes effect only in the inbound direction. For such a local QoS ID marking action to also take effect only in the outbound direction, specify the egress-active keyword.
If you execute the remark qos-local-id command multiple times in the same traffic behavior, the most recent configuration takes effect.
To match the outer DSCP in the VXLAN decapsulation direction after the remark qos-local-id command is executed, you must also match the IPv4 or IPv6 protocol or use an ACL to match it.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
remark tunnel-dscp
Use remark tunnel-dscp to configure an outer DSCP marking action in a traffic behavior.
Use undo remark tunnel-dscp to restore the default.
remark tunnel-dscp dscp-value
The S9825 switch series does not support this command.
No outer DSCP marking action is configured.
dscp-value: Specifies the DSCP value to be set for the outer IP header of tunneled packets. The DSCP value can be a number from 0 to 63 or a keyword in Table 5.
This command takes effect on the following packets:
·     GRE packets.
·     VXLAN packets.
·     IPv4 over IPv4 tunneled packets.
·     IPv6 over IPv4 tunneled packets.
·     IPv6 tunneled packets.
·     MPLS TE tunneled packets.
The outer DSCP value marking action takes effect only when the QoS policy is applied to an interface.
The remark tunnel-dscp command is mutually exclusive with the remark dscp or remark ip-precedence command in one traffic behavior.
If you execute the remark tunnel-dscp command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior data to mark matching packets with DSCP value 2 in the outer IP header of tunneled packets.
[Sysname-behavior-data] remark tunnel-dscp 2
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ mode { dcbx | loose } | insert-before before-classifier-name ] *
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode dcbx: Specifies that the class-behavior association applies only to the DCBX. For more information about DCBX, see Layer 2—LAN Switching Configuration Guide.
mode loose: Specifies that a class-behavior association applies only to a QoS policy applied to a control plane.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
A QoS policy can contain multiple class-behavior associations. The device matches a packet against the class-behavior associations in their configuration order. When a match is found, the device stops the match process and takes the actions in the matching class-behavior association.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
Use a class-behavior association in loose mode (with the mode loose keyword specified) to rate-limit packets of the specified protocol received on the specified interface and sent to a control plane as follows:
1.     Create an ACL, and configure an ACL rule to match packets of the specified protocol in the ACL.
2.     Create a traffic class with the operator AND, and configure the if-match acl and if-match inbound-interface match criteria in the traffic class.
3.     Create a traffic behavior, and configure actions in the traffic behavior.
4.     Create a QoS policy, and associate the traffic class with the traffic behavior with the mode loose keyword specified.
5.     Apply the QoS policy to a control plane.
When packets of the specified protocol are received on the other interface and sent to the control plane, the packets are rate-limited by the protocol packet rate limiting action applied to the control plane.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
# Enter the control plane view of slot 3.
[Sysname] control-plane slot 1
[Sysname-cp-slot1]
display qos policy
Use display qos policy to display QoS policies.
display qos policy user-defined [ accounting | mirroring | remarking ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
user-defined: Specifies user-defined QoS policies.
accounting: Specifies accounting-type QoS policies.
mirroring: Specifies mirroring-type QoS policies.
remarking: Specifies marking-type QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
If you do not specify the accounting, mirroring, or remarking keyword, this command displays generic QoS policies.
# Display all user-defined generic QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
# Display user-defined accounting-type QoS policies.
<Sysname> display qos policy user-defined accounting
  Accounting policy: 1 (ID 100)
     Behavior: 1
# Display user-defined mirroring-type QoS policies.
<Sysname> display qos policy user-defined mirroring
  Mirroring policy: 1 (ID 100)
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# Display user-defined marking-type QoS policies.
<Sysname> display qos policy user-defined remarking
  Marking policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
Table 6 Command output
Information about a user-defined QoS policy.
System-defined QoS policy information
Information about a system-defined QoS policy.
Policy
User-defined generic QoS policy name or system-defined QoS policy name.
Accounting policy
User-defined accounting-type QoS policy name.
Mirroring policy
User-defined mirroring-type QoS policy name.
Marking policy
User-defined marking-type QoS policy name.
For the output description, see Table 1 and Table 4.
Use display qos policy control-plane to display QoS policies applied to a control plane.
# Display the QoS policy applied to the control plane of slot 1.
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Yellow packets: 0 (Packets) 0 (Bytes)
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 7 Command output
Direction
Direction in which the QoS policy is applied.
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies.
# Display the predefined control plane QoS policy of slot 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
  Protocol          Priority   Bandwidth          Group
  ARP               15         2560 (kbps)        normal
  ARP Snooping      15         256 (kbps)         redirect
  BGP               35         256 (pps)          critical
  BGPv6             35         256 (pps)          critical
  DHCP              23         1536 (kbps)        normal
  DHCP Snooping     23         1536 (kbps)        redirect
  DHCPv6            23         1536 (kbps)        normal
  DLDP              41         64 (kbps)          critical
  802.1x            18         128 (kbps)         important
  MVRP              41         256 (kbps)         critical
  ICMP              22         512 (pps)          monitor
  ICMPv6            22         512 (pps)          monitor
  IGMP              30         512 (pps)          important
  IS-IS             37         12000 (kbps)       critical
  LACP              42         64 (kbps)          critical
  LLDP              41         64 (kbps)          important
  OSPF Multicast    36         2048 (kbps)        critical
  OSPF Unicast      36         2048 (kbps)        critical
  OSPFv3 Multicast  36         2048 (kbps)        critical
  OSPFv3 Unicast    36         2048 (kbps)        critical
  PVST              43         2560 (kbps)        critical
  SNMP              26         512 (kbps)         N/A
  STP               43         256 (kbps)         critical
  VRRP              38         512 (kbps)         important
  VRRPv6            38         512 (kbps)         important
  IPOPTION          16         384 (kbps)         normal
  IPOPTIONv6        16         64 (kbps)          normal
  SSH               27         512 (kbps)         management
  TELNET            27         512 (kbps)         management
  BFD               32         12800 (kbps)       critical
Table 8 Command output
Pre-defined control plane policy
Contents of the predefined control plane QoS policy.
Group
Protocol group of the protocol.
For descriptions of other fields, see Table 3.
Use display qos policy global to display QoS policies applied globally.
display qos [ accounting | mirroring | remarking ] policy global [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
If you do not specify the accounting, mirroring, or remarking keyword, this command displays information about generic QoS policies.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display generic QoS policies applied globally.
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about accounting-type QoS policies applied globally.
<Sysname> display qos accounting policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
# Display information about mirroring-type QoS policies applied globally.
<Sysname> display qos mirroring policy global
  Direction: Inbound
  Mirroring policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# Display information about marking-type QoS policies applied globally.
<Sysname> display qos remarking policy global
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
Table 9 Command output
Direction
Accounting policy
Mirroring policy
Marking policy
Green packets
Statistics about green packets.
Yellow packets
Statistics about yellow packets.
Red packets
Statistics about red packets.
Use display qos policy interface to display the QoS policies applied to interfaces.
display qos [ accounting | mirroring | remarking ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify the accounting, mirroring, or remarking keyword, this command displays generic QoS policies applied.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display the generic QoS policy applied to the incoming traffic of HundredGigE 1/0/1.
<Sysname> display qos policy interface hundredgige 1/0/1 inbound
Interface: HundredGigE1/0/1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Matched : 0 (Packets) 0 (Bytes)
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about the accounting-type QoS policy applied to the incoming traffic of HundredGigE 1/0/1.
<Sysname> display qos accounting policy interface hundredgige 1/0/1 inbound
  Direction: Inbound
  Accounting Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Accounting enable:
        0 (Packets)
# Display information about the mirroring-type QoS policy applied to the incoming traffic of HundredGigE 1/0/1.
<Sysname> display qos mirroring policy interface hundredgige 1/0/1 inbound
  Direction: Inbound
  Mirroring policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# Display information about the marking-type QoS policy applied to the incoming traffic of HundredGigE 1/0/1.
<Sysname> display qos remarking policy interface hundredgige 1/0/1 inbound
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# Display the QoS policies applied to all interfaces.
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: HundredGigE1/0/2
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: HundredGigE1/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
        Green packets : 0(Packets)
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: HundredGigE1/0/4
        Green action  : pass
Table 10 Command output
Direction
Accounting policy
Mirroring policy
Marking policy
Matched
Number of matching packets.
Forwarded
Average rate of successfully forwarded matching packets in a statistics collection period.
Dropped
Average rate of dropped matching packets in a statistics collection period.
Green packets
Traffic statistics for green packets.
Yellow packets
Traffic statistics for yellow packets.
Red packets
Traffic statistics for red packets.
Use display qos policy l2vpn-ac to display the QoS policies applied to Ethernet service instances.
display qos policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound | outbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays QoS policies applied to all Ethernet service instances on an interface.
inbound: Specifies the QoS policies applied to incoming traffic.
outbound: Specifies the QoS policies applied to outgoing traffic.
If you do not specify a direction, this command displays both QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to the incoming traffic of Ethernet service instance 1 on HundredGigE 1/0/1.
<Sysname> display qos policy l2vpn-ac interface hundredgige 1/0/1 service-instance 1 inbound
Interface: HundredGigE1/0/1    Service instance ID: 1
  Direction: Inbound
  Policy: p
   Classifier: c
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
        Green action  : pass
For the description of fields, see Table 1 and Table 4.
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
inbound: Displays QoS policies applied to incoming traffic.
outbound: Displays QoS policies applied to outgoing traffic.
If you do not specify a direction, this command displays QoS policies applied to VLANs in both the inbound and outbound directions.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 11 Command output
Direction
Green packets
Yellow packets
Red packets
Use qos apply policy to apply a QoS policy to an Ethernet service instance, interface, or control plane.
Use undo qos apply policy to remove an applied QoS policy.
qos apply [ accounting | mirroring | remarking ] policy policy-name { inbound | outbound } [ share-mode ]
undo qos apply [ accounting | mirroring | remarking ] policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view
Interface view
accounting: Specifies an accounting-type QoS policy. This keyword is supported only in interface view.
mirroring: Specifies a mirroring-type QoS policy. This keyword is supported only in interface view.
remarking: Specifies a marking-type QoS policy. This keyword is supported only in interface view.
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic. This keyword is not supported in control plane view.
share-mode: Applies the QoS policy in sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all interfaces on the device with the same QoS policy applied in one direction share one QoS and ACL resource.
The display qos policy interface command output for an interface also contains packet statistics for all interfaces that share the QoS and ACL resource with the interface.
A maximum of four QoS policies (one generic, one accounting-type, one mirroring-type, and one marking-type) can be applied to one direction of an interface. Different actions can be taken on the same traffic class if QoS policies of different types are applied to an interface.
If you specify the share-mode keyword when applying a QoS policy to an interface, follow these restrictions and guidelines:
·     All interfaces on an interface module with the QoS policy applied in one direction share one QoS and ACL resource.
If the share-mode keyword is not specified, each interface uses one QoS and ACL resource in one direction.
·     You cannot specify the share-mode keyword when applying an ACL to the same direction of the interface. For more information about applying an ACL to an interface, see the packet-filter (interface view) command in ACL commands.
You cannot change the sharing mode dynamically after a QoS policy is applied to an interface. To change the sharing mode for an applied QoS policy, perform the following tasks:
1.     Remove the QoS policy from the interface.
2.     Reapply the QoS policy with or without the share-mode keyword specified.
To apply a QoS policy to the control plane to limit the rate of protocol packets, match the traffic class against control plane protocol type instead of protocol packet information as a best practice.
Only the S9855 switch series supports applying a QoS policy to a VSI interface.
# Apply generic QoS policy USER1 to the outgoing traffic of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply policy USER1 outbound
# Apply accounting-type QoS policy USER2 to the outgoing traffic of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply accounting policy USER2 outbound
# Apply mirroring-type QoS policy USER3 to the outgoing traffic of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply mirroring policy USER3 outbound
# Apply marking-type QoS policy USER4 to the outgoing traffic of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply remarking policy USER4 outbound
# Apply generic QoS policy USER5 to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot1] qos apply policy USER5 inbound
# Apply generic QoS policy TEST9 to the incoming traffic of Ethernet service instance 200.
[Sysname-HundredGigE1/0/1] service-instance 200
[Sysname-HundredGigE1/0/1-srv200] qos apply policy TEST9 inbound
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply [ accounting | mirroring | remarking ] policy policy-name global { inbound | outbound }
undo qos apply [ accounting | mirroring | remarking ] policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy to the incoming packets on all interfaces.
outbound: Applies the QoS policy to the outgoing packets on all interfaces.
A global QoS policy takes effect on all incoming or outgoing traffic depending on the direction in which the QoS policy is applied.
A maximum of four QoS policies (one generic, one accounting-type, one mirroring-type, and one marking-type) can be applied to one direction globally.
If you do not specify the accounting, mirroring, or remarking keyword, this command applies a generic QoS policy globally.
# Globally apply generic QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
# Globally apply mirroring-type QoS policy user2 to the incoming traffic.
[Sysname] qos apply mirroring policy user2 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos [ accounting | mirroring | remarking ] policy policy-name
undo qos [ accounting | mirroring | remarking ] policy policy-name
No QoS policies exist.
accounting: Identifies the QoS policy as an accounting-type QoS policy.
mirroring: Identifies the QoS policy as a mirroring-type QoS policy.
remarking: Identifies the QoS policy as a marking-type QoS policy.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
If you do not specify the accounting, mirroring, or remarking keyword when creating a QoS policy, a generic QoS policy is created.
QoS policies of different types cannot use the same policy name.
Do not use the accounting, mirroring, or remarking word or the first letters of any one of them as a policy name. If you do so, no information is displayed when you execute the display qos policy user-defined policy-name command, because the system will recognize such a policy name as command keyword.
A generic QoS policy can be applied to all supported destinations and can contain all actions. An accounting-type QoS policy can be applied to only interfaces or globally and can contain only class-based accounting actions. A mirroring-type QoS policy can be applied to only interfaces or globally and can contain only mirroring actions. A marking-type QoS policy can be applied to only interfaces or globally and can contain only marking actions.
In the outbound direction of an interface on an S9855 switch, if a packet matches both an accounting-type QoS policy and a packet filter with the counting function enabled, it is counted only by the packet filter. For more information about packet filter, see Security Configuration Guide.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a generic QoS policy named user1.
# Create an accounting-type QoS policy named user2.
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# Create a marking-type QoS policy named user3.
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# Create a mirroring-type QoS policy named user4.
[Sysname] qos mirroring policy user4
[Sysname-qospolicy-user4]
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
# Clear the statistics of the QoS policy applied to the control plane of slot 1.
<Sysname> reset qos policy control-plane slot 1
Use reset qos policy global to clear the statistics of a global QoS policy.
reset qos [ accounting | mirroring | remarking ] policy global [ inbound | outbound ]
inbound: Clears the statistics of the global QoS policy applied to incoming traffic globally.
outbound: Clears the statistics of the global QoS policy applied to outgoing traffic globally.
If you do not specify the accounting, mirroring, or remarking keyword, this command clears statistics for generic QoS policies.
If you do not specify a direction, this command clears the statistics of the global QoS policies in both directions.
# Clear the statistics of the generic QoS policy applied to the incoming traffic globally.
<Sysname> reset qos policy global inbound
# Clear statistics for the mirroring-type QoS policy applied to the inbound direction globally.
<Sysname> reset qos mirroring policy global inbound
Use reset qos vlan-policy to clear the statistics of the QoS policy applied in a certain direction of a VLAN.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
inbound: Clears the statistics of the QoS policy applied to the incoming traffic of the specified VLAN.
outbound: Clears the statistics of the QoS policy applied to the incoming traffic of the specified VLAN.
If you do not specify a direction, this command clears the statistics of the QoS policies in both directions of the VLAN.
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Use display qos-acl resource to display QoS and ACL resource usage.
display qos-acl resource [ advance ] [ slot slot-number ]
advance: Displays the QoS and ACL resource usage in advanced mode. If you do not specify this keyword, this command displays the QoS and ACL resource usage in common mode.
# Display QoS and ACL resource usage in common mode.
<Sysname> display qos-acl resource
Interfaces: HGE1/0/1 to HGE1/0/16, HGE1/0/33
            HGE1/0/35, HGE1/0/37
            HGE1/0/39, HGE1/0/41
            HGE1/0/43, HGE1/0/45
            HGE1/0/47, 400GE1/0/50
            400GE1/0/51, 400GE1/0/52
            400GE1/0/54 (slot 1)
 Type             Total      Reserved   Configured Remaining  Usage
 VFP ACL          2048       0          0          2048       0%
 IFP ACL          16384      4096       2          12286      25%
 IFP Meter        512        0          84         428        16%
 IFP Counter      81920      8192       1          73727      10%
 EFP ACL          2048       0          0          2048       0%
 EFP Meter        128        0          0          128        0%
 EFP Counter      8192       0          0          8192       0%
Interfaces: HGE1/0/17 to HGE1/0/32, HGE1/0/34
            HGE1/0/36, HGE1/0/38
            HGE1/0/40, HGE1/0/42
            HGE1/0/44, HGE1/0/46
            HGE1/0/48, 400GE1/0/49
            400GE1/0/53, 400GE1/0/55
            400GE1/0/56 (slot 1)
 IFP ACL          16384      4096       1          12287      25%
Table 12 Command output
Interfaces
Interface range for the resources.
Resource type.
·     VFP ACL—ACL resource usage for marking local QoS IDs before Layer 2 forwarding.
·     IFP ACL—Ingress ACL resources.
·     IFP Meter—Ingress traffic policing resources.
·     IFP Counter—Ingress traffic accounting resources.
·     EFP ACL—Egress ACL resources.
·     EFP Meter—Egress traffic policing resources.
·     EFP Counter—Egress traffic accounting resources.
Total
Total number of resources.
Reserved
Number of reserved resources.
Configured
Number of resources that have been applied.
Remaining
Number of resources that you can apply.
Usage
Configured and reserved resources as a percentage of total resources. If the percentage is not an integer, this field displays the integer part. For example, if the actual usage is 50.8%, this field displays 50%.
# Display QoS and ACL resource usage in advanced mode.
<Sysname> display qos-acl resource advance
Interfaces:  HGE1/0/1 to HGE1/0/16, HGE1/0/33, HGE1/0/35, HGE1/0/37, HGE1/0/39, HGE1/0/41, HGE1/0/43, HGE1/0/45, HGE1/0/47, 400GE1/0
/50, 400GE1/0/51, 400GE1/0/52, 400GE1/0/54 (slot 1)
 Stage    Slice    Total    Configured   Remaining    Usage
 IFP       0        2048      1            2047        0%
 IFP       1        2048      1            2047        0%
 IFP       2        2048      0            2048        0%
 IFP       3        2048      0            2048        0%
 IFP       4        1024      43           981         4%
 IFP       5        1024      43           981         4%
 IFP       6        1024      43           981         4%
 IFP       7        1024      39           985         3%
 IFP       8        1024      0            1024        0%
 IFP       9        1024      0            1024        0%
 IFP       10       1024      0            1024        0%
 IFP       11       1024      0            1024        0%
 EFP       0        512       0            512         0%
 EFP       1        512       0            512         0%
 EFP       2        512       0            512         0%
 EFP       3        512       0            512         0%
 VFP       0        512       0            512         0%
 VFP       1        512       0            512         0%
 VFP       2        512       0            512         0%
 VFP       3        512       0            512         0%
Interfaces:  HGE1/0/17 to HGE1/0/32, HGE1/0/34, HGE1/0/36, HGE1/0/38, HGE1/0/40, HGE1/0/42, HGE1/0/44, HGE1/0/46, HGE1/0/48, 400GE1/
0/49, 400GE1/0/53, 400GE1/0/55, 400GE1/0/56 (slot 1)
 IFP       1        2048      0            2048        0%
 EFP       0        512       0            512         0%
 EFP       1        512       0            512         0%
 EFP       2        512       0            512         0%
 EFP       3        512       0            512         0%
 VFP       0        512       0            512         0%
 VFP       1        512       0            512         0%
 VFP       2        512       0            512         0%
 VFP       3        512       0            512         0%
Table 13 Command output
Interfaces
Stage
Processing stage:
·     VFP—Layer 2 forwarding stage.
·     IFP—Receiving stage.
·     EFP—Sending stage.
Slice
Slice index of the ACL resource.
Total
Configured
Remaining
Usage
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p | lp-dot1p ]
The device provides the following types of priority map.
Table 14 Priority maps
Priority mapping
dot1p-dp
802.1p-drop priority map.
dot1p-dscp
802.1p-DSCP priority map.
dot1p-lp
802.1p-local priority map.
dscp-dot1p
DSCP-802.1p priority map.
lp-dot1p
Local-802.1p priority map.
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 15 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p | lp-dot1p }
For the description of the keywords, see Table 14.
# Enter the 802.1p-local priority map view.
import
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of HundredGigE 1/0/1.
<Sysname> display qos trust interface hundredgige 1/0/1
 Port priority information
  Port priority: 0
  Port dscp priority: -
  Port priority trust type: dscp,  Override: disable
Table 16 Command output
Interface type and interface number.
Port priority
Port priority set for the interface.
Port dscp priority
DSCP value rewritten for packets. If you have not rewritten the DSCP value of packets, this field displays a hyphen (-).
Priority trust mode on the interface:
·     dot1p—Uses the 802.1p priority of received packets for mapping.
·     dscp—Uses the DSCP precedence of received IP packets for mapping.
·     none—Trusts no packet priority.
Override
Indicates whether the precedence derived through priority mapping overwrites the original precedence carried in the packet.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp } [ override ]
undo qos trust
An interface trusts the port priority. If the device has both Layer 2 and Layer 3 interfaces, Layer 2 packets trust their 802.1p priority, and Layer 3 packets trust the port priority.
Interface view
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
override: Uses the priority derived through priority mapping to overwrite the original priority carried in the packet. This keyword is optional. By default, this feature is disabled.
As a best practice, do not execute both the qos priority and qos trust commands on the same interface. If you execute both of them, the qos priority command does not take effect on packets with VLAN tags.
Only S9825 switch series support this command on tunnel interfaces. For this command to take effect, you must execute it on the physical interface associated with the tunnel interface.
# Set the priority trust mode to 802.1p priority on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos trust dot1p
qos trust (system view)
Use qos trust to configure the global priority trust mode for VXLAN packets.
qos trust tunnel-dscp
undo qos trust tunnel-dscp
The global priority trust mode for VXLAN packets is not configured.
tunnel-dscp: Trusts the DSCP value in the outer IP header of VXLAN packets for priority mapping.
For a VXLAN tunnel interface to trust the DSCP priority in the outer IP header of VXLAN packets, you must also configure the qos trust dscp command on its physical interface.
# Configure the switch to trust the DSCP priority in the outer IP header of VXLAN packets.
[Sysname] qos trust tunnel-dscp
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
The port priority is 0.
Interface view
priority-value: Specifies a priority value. If the dscp keyword is not specified, this argument specifies the port priority in the range of 0 to 7. If the dscp keyword is specified, this argument specifies the DSCP value to be set for packets, in the range of 0 to 63.
When no priority trust mode is configured for an interface, the interface uses the port priority as the 802.1p priority for priority mapping. If the qos priority dscp priority-value command is executed, the interface modifies the DSCP value of Layer 3 packets in addition to performing priority mapping.
# Set the port priority of HundredGigE 1/0/1 to 2.
[Sysname-HundredGigE1/0/1] qos priority 2
Global priority commands
qos mirroring local-precedence
Use qos mirroring local-precedence to set the local precedence of mirrored packets.
Use undo qos mirroring local-precedence to restore the default.
qos mirroring local-precedence local-precedence-value
The local precedence of a mirrored packet is 0.
local-precedence-value: Specifies a local precedence value in the range of 0 to 3. The greater the value, the higher the priority.
On the mirroring source device, both mirrored packets and service packets might exist on the egress port. To schedule service packets preferentially, execute this command to set the local precedence of mirrored packets to a smaller value, for example, 0. In this case, when congestion occurs, less service packets will be dropped.
This command takes effect on packets mirrored by both port mirroring and flow mirroring.
# Set the local precedence of mirrored packets to 2.
[Sysname] qos mirroring local-precedence 2
Traffic policing, GTS, and rate limit commands
Traffic policing commands
display qos overhead compensation-length
Use display qos overhead compensation-length to display the packet compensation length configuration for QoS rate limiting and statistics.
display qos overhead compensation-length [ interface [ interface-type interface-number ] ]
interface: Displays the packet compensation length configuration for QoS rate limiting and statistics on interfaces. If you do not specify this keyword, this command displays the global packet compensation length configuration and the packet compensation length configuration for each interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the packet compensation length configuration for each interface.
# Display the global packet compensation length configuration and the packet compensation length configuration for each interface.
<Sysname> display qos overhead compensation-length
Overhead compensation length:
Global
  Inbound  : 20
  Outbound : 20
Interface  : HundredGigE1/0/1
  Inbound  : 20
  Outbound : 20
Use qos overhead compensation-length to set the packet compensation length for QoS rate limiting and statistics.
Use undo qos overhead compensation-length restore the default.
qos overhead compensation-length length
The device does not include the IFG, preamble, and start frame delimiter by default when performing QoS rate limiting and statistics.
Interface view
length: Specifies the packet compensation length in the range of 0 to 31 bytes.
Operating mechanism
At the data link layer, Ethernet standards require the interframe gap (IFG), preamble, and start frame delimiter to exist between frames to allow the receiving device to prepare for the next frame. The minimum total length of the three parts is 20 bytes.
When the device performs QoS rate limiting (including rate limit, GTS, and traffic policing) and statistics on traffic, it calculates the packet rate and limit the rate based on the size of traffic passing through the interface per unit time. When the traffic size in the network is small, for example, when the average packet length is less than 100 bytes, the IFG significantly affects rate statistics. In this case, you must consider the IFG, preamble, and start frame delimiter when performing QoS rate limiting based on the calculated packet rate.
If the device does not include the IFG, preamble, and start frame delimiter when performing QoS rate limiting and statistics by default, you can set the compensation length to 20 bytes to obtain accurate rate limiting and statistics.
If you configure the packet compensation length in both system view and interface view, the configuration in interface view takes effect.
# Set the global packet compensation length for QoS rate limiting and statistics to 20 bytes.
[Sysname] qos overhead compensation-length 20
# Set the packet compensation length on HundredGigE 1/0/1 for QoS rate limiting and statistics to 20 bytes.
[Sysname-HundredGigE1/0/1] qos overhead compensation-length 20
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration for all interfaces.
# Display the GTS configuration for all interfaces.
 Rule: If-match queue 2
  CIR 512 (kbps), CBS 51200 (Bytes)
Table 17 Command output
Interface name, including the interface type and interface number.
Rule
Match criteria.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured on an interface.
Interface view
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 100000000 for 100-GE interfaces and 8 to 400000000 for 400-GE interfaces. The specified value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 16000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 16000000 is converted to 16000000.
When specifying an ACL, follow these restrictions and guidelines:
·     If the specified ACL does not exist or does not have any rules, the ACL will not be referenced.
·     In the specified ACL, if a rule has the vpn-instance keyword specified, the rule takes effect only on VPN packets. If a rule does not have the vpn-instance keyword specified, the rule takes effect only on packets in the public network.
Set the CIR in this command to be greater than or equal to the minimum guaranteed bandwidth in the qos bandwidth queue command.
# Shape the packets of queue 1 on GigabitEthernet 1/0/1 (CIR 6400 kbps and CBS 51200 bytes).
[Sysname-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
display qos lr interface
Use display qos lr interface to display the rate limit configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration for all interfaces.
# Display the rate limit configuration and statistics for all interfaces.
 Direction: Outbound
  CIR 2000 (kbps), CBS 20480 (Bytes)
Table 18 Command output
Direction
Direction in which the rate limit configuration is applied.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration.
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
No rate limit is configured on an interface.
Interface view
outbound: Limits the rate of outgoing packets.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 32 to 100000000 for 100-GE interfaces and 32 to 400000000 for 400-GE interfaces. The specified value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in the range of 512 to 128000000 bytes. The default is the product of 62.5 and the CIR and must be a multiple of 512. When the product is not a multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 128000000 is converted to 128000000.
# Limit the rate of outgoing packets on HundredGigE 1/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-HundredGigE1/0/1] qos lr outbound cir 256 cbs 51200
Congestion management commands
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of HundredGigE 1/0/1.
<Sysname> display qos queue sp interface hundredgige 1/0/1
 Output queue: Strict Priority queuing
Table 19 Command output
Output queue
Type of the current output queue.
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses SP queuing.
Interface view
# Enable SP queuing on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos sp
WRR commands
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of HundredGigE 1/0/1.
<Sysname> display qos queue wrr interface hundredgige 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Queue name      Group           Weight
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
Table 20 Command output
Output queue
Group
ID of the group a queue is assigned to.
Weight
Packet-count queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
Byte count
Byte-count scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
qos wrr
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
Interface view
byte-count: Allocates bandwidth to queues in bytes.
weight: Allocates bandwidth to queues in packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-count WRR queuing on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wrr weight
# Enable byte-count WRR queuing on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
qos wrr queue-id group 1 { byte-count | weight } schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
Interface view
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7 or keywords in Table 21.
Table 21 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group 1: Specifies WRR group 1. Only WRR group 1 is supported in the current software version.
schedule-value: Specifies a scheduling weight. The value range for this argument is 1 to 127.
# Enable byte-count WRR queuing on HundredGigE 1/0/1, assign queue 0 to WRR group 1, and specify scheduling weight 10 for queue 0.
[Sysname-HundredGigE1/0/1] qos wrr 0 group 1 byte-count 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues on a WRR-enabled interface are in WRR group 1.
Interface view
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on HundredGigE 1/0/1, and assign queue 0 to the SP group.
[Sysname-HundredGigE1/0/1] qos wrr 0 group sp
qos wrr
WFQ commands
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of HundredGigE 1/0/1.
<Sysname> display qos wfq interface hundredgige 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               64
 1               af1             1               1               64
 2               af2             1               1               64
 3               af3             1               1               64
 4               af4             1               1               64
 5               ef              1               1               64
 6               cs6             1               1               64
 7               cs7             1               1               64
Table 22 Command output
Output queue
Group
ID of the group that holds the queue.
Byte-count
Byte-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
Weight
Packet-count queue scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
Min Bandwidth
Minimum guaranteed bandwidth for the queue.
qos wrr
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth for a queue is 64 kbps.
Interface view
min bandwidth-value: Sets the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 100000000 for 100-GE interfaces and 8 to 400000000 for 400-GE interfaces.
The minimum guaranteed bandwidth is the amount of bandwidth guaranteed for a queue when the interface is congested.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wfq weight
[Sysname-HundredGigE1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to restore the default.
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
Interface view
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable packet-count WFQ on HundredGigE 1/0/1.
# Enable byte-count WFQ on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
All queues on a WFQ-enabled interface are in WFQ group 1 and have a weight of 1.
Interface view
group 1: Specifies WFQ group 1. Only WFQ group 1 is supported in the current software version.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on HundredGigE 1/0/1, assign queue 0 to WFQ group 1, and specify scheduling weight 10 for queue 0.
[Sysname-HundredGigE1/0/1] qos wfq 0 group 1 byte-count 10
qos bandwidth queue
qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to remove a queue from the SP group.
qos wfq queue-id group sp
All queues on a WFQ-enabled interface are in WFQ group 1.
Interface view
This command is available only on a WFQ-enabled interface. Queues in the SP group are scheduled with SP, instead of WFQ. The SP group has higher scheduling priority than the WFQ groups.
# Enable WFQ on HundredGigE 1/0/1, and assign queue 0 to the SP group.
[Sysname-HundredGigE1/0/1] qos wfq 0 group sp
qos bandwidth queue
qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to set the minimum guaranteed bandwidth for a queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
Queue scheduling profile view
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7.
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 100000000.
You must configure a queue as a WFQ queue before you set the minimum guaranteed bandwidth for the queue.
# Configure queue 0 as a WFQ queue, and set the minimum guaranteed bandwidth to 100 kbps for queue 0.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue scheduling profile: myprofile (ID 1)
 Queue ID  Type  Group   Schedule   Schedule  Min         Max
                         unit       value     bandwidth   bandwidth
 be        SP    N/A     N/A        N/A       N/A         N/A
 af1       SP    N/A     N/A        N/A       N/A         N/A
 af2       SP    N/A     N/A        N/A       N/A         N/A
 af3       SP    N/A     N/A        N/A       N/A         N/A
 af4       SP    N/A     N/A        N/A       N/A         N/A
 ef        SP    N/A     N/A        N/A       N/A         N/A
 cs6       SP    N/A     N/A        N/A       N/A         N/A
 cs7       SP    N/A     N/A        N/A       N/A         N/A
Table 23 Command output
Queue management profile
Queue scheduling profile name.
Queue scheduling type:
·     SP.
·     WRR.
·     WFQ.
Group
Priority group to which the queue belongs.
N/A indicates this field is ignored.
Schedule unit
Scheduling unit: weight or byte-count.
N/A indicates that this field is ignored.
Schedule value
This field indicates:
·     Number of packets for the weight scheduling unit.
·     Number of bytes for the byte-count scheduling unit.
Min bandwidth
Minimum guaranteed bandwidth for the queue. N/A indicates that this field is ignored.
Max bandwidth
Maximum allowed bandwidth for the queue. N/A indicates that this field is ignored.
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to HundredGigE 1/0/1.
<Sysname> display qos qmprofile interface hundredgige 1/0/1
Direction: Outbound
Table 24 Command output
Direction
Direction in which the queue scheduling profile is applied.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
Interface view
You can apply only one queue scheduling profile to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id{ sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
All queues in a queue scheduling profile are SP queues.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID. The group ID can only be 1.
schedule-value: Specifies the scheduling weight. The value range for this argument is 1 to 127.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
·     The WRR queuing is used.
·     The WRR group is group 1.
·     The scheduling weight is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
qos qmprofile
Congestion avoidance commands
WRED commands
ai-ecn
Use ai-ecn to enter AI ECN view.
ai-ecn
AI service view
To enable AI ECN, first enter AI service view and then enter AI ECN view.
# Enter AI ECN view.
[Sysname] ai-service
[Sysname-ai-service] ai-ecn
[Sysname-ai-service-ai-ecn ]
ai ai-ecn enable
Use ai ai-ecn enable to enable AI ECN and set the AI ECN mode.
Use undo ai ai-ecn enable to restore the default.
ai ai-ecn enable mode { centralized | distributed }
AI ECN is disabled.
AI service view
centralized: Specifies that the analyzer calculates the ECN triggering threshold and communicates it to devices.
distributed: Specifies that the device itself intelligently sets the optimal ECN triggering threshold.
This function enables the device to collect and send traffic characteristics to the AI service component on an analyzer or the local AI service component. The AI service component dynamically sets the optimal ECN triggering threshold for a queue to achieve low delay and high throughput.
After the device is rebooted, the ECN triggering thresholds set by the analyzer or AI service component are cleared.
# Enable AI ECN and set the AI ECN mode to centralized.
[Sysname-ai-service] ai ai-ecn enable mode centralized
queue (AI ECN view)
ai-service
Use ai-service to enter AI service view.
ai-service
# Enter AI service view.
display qos wred ecn interface
Use display qos wred ecn interface to display the ECN configuration of an interface.
display qos wred ecn interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the ECN configurations of all interfaces.
# Display the ECN configurations of all interfaces.
<Sysname> display qos wred ecn interface
 Queue ID: 0
   WRED ECN    : Enabled
   Delay ECN   : Enabled
     Threshold : 100               Queue length    : lt high-limit
   Dynamic ECN : Enabled
     Offset    : 100               Threshold floor : 200
 Queue ID: 1
   WRED ECN    : Enabled
    Delay ECN  : Enabled
 Queue ID: 7
   WRED ECN    : Enabled
    Delay ECN  : Enabled
Table 25 Command output
WRED ECN
ECN configuration in the qos wred queue command. If ECN is not enabled, this field displays a hyphen (-).
Delay ECN
Delay ECN configuration. If delay ECN is not configured, this field displays a hyphen (-).
Dynamic ECN
Dynamic ECN configuration. If dynamic ECN is not configured, this field displays a hyphen (-).
Threshold
Delay threshold for delay ECN.
Queue length
Queue length range for delay-based ECN. For the meaning of this field, see the operator limit1 [ limit2 ] parameter in the qos wred delay-ecn queue-length command.
Offset
Offset of the maximum available queue length for dynamic ECN.
Threshold floor
Minimum threshold for the queue length in dynamic ECN.
qos wred queue
qos wred queue delay-ecn
qos wred queue dynamic-ecn
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: q1
Table type: Queue based WRED
QID gmin     gmax     gpro ymin     ymax     ypro rmin     rmax     rpro exp ECN
0   100      1000     10   100      1000     10   100      1000     10   9   N
1   100      1000     10   100      1000     10   100      1000     10   9   N
2   100      1000     10   100      1000     10   100      1000     10   9   N
3   100      1000     10   100      1000     10   100      1000     10   9   N
4   100      1000     10   100      1000     10   100      1000     10   9   N
5   100      1000     10   100      1000     10   100      1000     10   9   N
6   100      1000     10   100      1000     10   100      1000     10   9   N
7   100      1000     10   100      1000     10   100      1000     10   9   N
Table 26 Command output
Table type
Type of a WRED table.
QID
Queue ID.
gmin
Lower limit for green packets.
gmax
Upper limit for green packets.
gprob
Drop probability for green packets.
ymin
Lower limit for yellow packets.
ymax
Upper limit for yellow packets.
yprob
Drop probability for yellow packets.
rmin
Lower limit for red packets.
rmax
Upper limit for red packets.
rprob
Drop probability for red packets.
exp
Exponent for average queue length calculation.
ECN
Indicates whether ECN is enabled for the queue:
·     Y—Enabled.
·     N—Disabled.
qos wred apply
display qos wred table
Use display qos wred table to display the WRED table configuration.
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
0   250      1000     10   250      1000     10   250      1000     10   9   N
1   250      1000     10   250      1000     10   250      1000     10   9   N
2   250      1000     10   250      1000     10   250      1000     10   9   N
3   250      1000     10   250      1000     10   250      1000     10   9   N
4   250      1000     10   250      1000     10   250      1000     10   9   N
5   250      1000     10   250      1000     10   250      1000     10   9   N
6   250      1000     10   250      1000     10   250      1000     10   9   N
7   250      1000     10   250      1000     10   250      1000     10   9   N
Table 27 Command output
Table name
Name of a WRED table.
Table type
QID
Queue ID.
gmin
gmax
gpro
ymin
ymax
ypro
rmin
rmax
rpro
exp
ECN
·     Y—Enabled.
·     N—Disabled.
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
Interface view
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wred apply table1
qos wred queue table
qos wred queue
Use qos wred queue to configure the WRED parameters for a queue.
Use undo qos wred queue to restore the default.
qos wred queue queue-id low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ ecn ] [ weighting-constant exponent ]
qos wred queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo qos wred queue { queue-id [ drop-level drop-level ] | all }
No WRED parameters are configured.
Interface view
low-limit low-limit: Specifies the lower limit for the average queue length. The value range for low-limit is 0 to 257862.
high-limit high-limit: Specifies the upper limit for the average queue length. The upper limit must be greater than the lower limit. The value range for high-limit is 0 to 257862.
discard-probability discard-prob: Specifies the denominator for drop probability calculation. The greater the denominator, the greater the calculated drop probability. The value range for discard-prob is 0 to 100.
ecn: Enables ECN.
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation. The value range for exponent is 0 to 15.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
all: Specifies all queues.
When the average queue size is smaller than or equal to the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size is equal to the upper threshold, the packets are dropped according to the configured drop probability. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
If you specify the high-limit high-limit and low-limit low-limit options and do not specify the discard-probability discard-prob option, the default drop probability is 10%.
Specifying the ecn keyword in this command has the same effect as executing the qos wred queue ecn command.
Specifying the weighting-constant exponent keyword in this command has the same effect as executing the qos wred queue weighting-constant command.
This command and the qos wred apply command are mutually exclusive.
# Configure the following WRED parameters for queue 1 on HundredGigE 1/0/1:
·     The drop level is 1.
·     The lower limit for the average queue length is 10.
·     The upper limit for the average queue length is 20.
·     The drop probability is 30%.
[Sysname-HundredGigE1/0/1] qos wred queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
qos wred queue ecn
qos wred queue ecn
Use qos wred queue ecn to enable ECN for a queue.
Use undo qos wred queue ecn to restore the default.
qos wred queue queue-id ecn
undo qos wred queue queue-id ecn
ECN is disabled for a queue.
Interface view
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
Executing this command has the same effect as specifying the ecn keyword in the qos wred queue command.
# Enable ECN for queue 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wred queue 1 ecn
qos wred queue
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
table table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
You can use the display qos wred table command to display the default WRED table, which cannot be modified or deleted.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
Use qos wred queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo qos wred queue weighting-constant to restore the default.
qos wred queue queue-id weighting-constant exponent
undo qos wred queue queue-id weighting-constant
The exponent for average queue length calculation is 9 for a queue.
Interface view
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
Executing this command has the same effect as specifying the weighting-constant exponent option in the qos wred queue command.
# Set the exponent for average queue length calculation to 12 for queue 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] qos wred queue 1 weighting-constant 12
qos wred queue
queue (AI ECN view)
Use queue to enable AI ECN for a queue.
Use undo queue to restore the default.
queue queue-id enable
undo queue queue-id
AI ECN is disabled for a queue.
AI ECN view
This function is mutually exclusive with the following settings:
·     Applying a WRED table to an interface.
·     Configuring WRED parameters for a queue.
·     Setting the WRED exponent for average queue size calculation.
·     Enabling ECN for a queue.
After the device is rebooted, the ECN triggering thresholds set by the AI service component are cleared.
# Enable AI ECN for a queue 1.
[Sysname-ai-service-ai-ecn] queue 1 enable
qos wred apply
qos wred queue
qos wred queue ecn
queue (WRED table view)
queue ecn
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
undo queue { queue-id [ drop-level drop-level ] | all }
The lower limit is 100, the upper limit is 1000, and the drop probability denominator is 10.
WRED table view
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
To use tail drop for a queue, set the lower limit and upper limit to the same value.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
WRED table view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
When the average queue size is above the upper threshold:
·     If the ECN field is 00, the packet comes from an ECN-incapable endpoint, and the congestion point drops the packet.
·     If the ECN field is 01 or 10, the packet comes from an ECN-capable endpoint, and the congestion point determines whether to modify the ECN field according to the drop probability and then forwards the packet. All packets will not be dropped.
·     If the ECN field is 11, the packet has experienced congestion along the transmission path, and the congestion point forwards the packet without modifying the ECN field.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
Traffic Matrix commands
display traffic-matrix
Use display traffic-matrix to display the flow tables of Traffic Matrix.
display traffic-matrix [ ip | ipv6 ] [ slot slot-number ]
ip: Specifies the IPv4 flow table. If you do not specify this keyword and the ipv6 keyword, the command displays both IPv4 and IPv6 flow tables.
ipv6: Specifies the IPv6 flow table. If you do not specify this keyword and the ip keyword, the command displays both IPv4 and IPv6 flow tables.
# Display all statically configured flow entries.
<Sysname> display traffic-matrix
Slot : 0
Protocol    : 17
SPort       : 4791               SIP     : 1.1.1.1
DPort       : 4791               DIP     : 2.2.2.2
Traffic path: GE1/0/1            Next hop: 1.1.1.2
Status      : Active             Reason  : -
Protocol    : 17
SPort       : -                  SIP     : 1.1.1.1
DPort       : -                  DIP     : 2.2.2.2
Status      : Inactive           Reason  : Interface down
Protocol    : -
Status      : Inactive           Reason  : Destination unreachable
Slot : 1
Protocol    : 17
Protocol    : 17
Status      : Inactive           Reason  : ARP/ND unreachable
Protocol    : -
Status      : Inactive           Reason  : Remote path failure
Table 28 Command output
Protocol
Protocol number,
SPort
Source port number.
SIP
Source IP address.
DPort
Destination port number.
DIP
Destination IP address.
Traffic path
Output interface to which traffic is redirected.
Next hop
Next-hop address to which traffic is redirected.
Status
Effective state of a flow entry:
·     Active—The flow entry is effective.
·     Inactive—The flow entry is ineffective.
Reason
Reason why a flow entry fails to take effect:
·     Interface down—The output interface is down.
·     Destination Unreachable—The next-hop address is unreachable.
·     ARP/ND unreachable—The ARP or ND entry is unavailable.
·     Remote path failure—BGP detects a remote path failure.
·     Resource not enough—Resources are insufficient.
·     Not ready—The device driver is not ready. The device driver might be ready after a moment. You can execute the command later.
·     -—The flow entry takes effect.
ip source destination
ipv6 source destination
Use ip source destination to configure an IPv4 flow entry for Traffic Matrix.
Use undo ip source destination to delete an IPv4 flow entry for Traffic Matrix.
ip [ protocol protocol ] source source-address destination dest-address [ source-port port destination-port port ] traffic-path interface interface-type interface-number next-hop ip-address
undo ip [ protocol protocol ] source source-address destination dest-address [ source-port port destination-port port ]
Traffic Matrix does not have an IPv4 flow entry.
Traffic Matrix View
protocol protocol: Specify a protocol type by its number in the range of 0 to 255. If you do not specify a protocol type, any protocol type can be matched.
source source-address: Specifies a source IPv4 address.
destination dest-address: Specifies a destination IPv4 address.
source-port port: Specifies a source port in the range of 0 to 65535. If you do not specify a source port, any source port can be matched.
destination-port port: Specifies a destination port in the range of 0 to 65535. If you do not specify a destination port, any destination port can be matched.
traffic-path interface interface-type interface-number: Redirect matching traffic to the specified interface for forwarding.
next-hop ip-address: Redirects matching traffic to the specified next-hop IP address. The next-hop IP address can be an IPv4 address or an IPv6 address.
Operating mechanism
Use this command to redirect traffic to the specified output interface and next hop for forwarding. The redirected traffic must match the source address, destination address, source port number, destination port number, and protocol type specified in this command.
Multiple IPv4 flow entries can be configured for Traffic Matrix. If you configure multiple IPv4 flow entries with the same 5-tuple, the most recent configuration takes effect.
In the Traffic Matrix feature, the source address, destination address, and next-hop address of an IPv4 flow entry must all be valid unicast addresses.
The Traffic Matrix feature regularly queries the routing table to identify whether the next-hop address specified in the ip source destination command is reachable in the routing table. If the next-hop address is unreachable, the ip source destination command will no longer be effective.
If the same flow can match multiple IPv4 flow entries in the Traffic Matrix feature, the priority order for IPv4 flow entries is as follows:
1.     The IPv4 flow entry that is configured with the 5-tuple has the highest priority.
2.     Other IPv4 flow entries are matched in their order of configuration. When a match is found, the matching process stops.
As a best practice to prevent the same flow from being forwarded through different paths before and after the device reboots or the interface flaps, do not configure two flow entries with the same source address and destination address and other overlapping match items. Suppose you configure one flow entry with a protocol, a source address, and a destination address, and the other flow entry with the same source address and destination address but without a protocol. The flow that can match the two entries might match different flow entries and is forwarded through different paths before and after the device reboots or the interface flaps.
# Configure an IPv4 flow entry.
[Sysname] traffic-matrix
[Sysname-traffic-matrix] ip protocol 80 source 1.1.1.1 destination 2.2.2.2 source-port 8080 destination-port 8080 traffic-path interface gigabitethernet 1/0/1 next-hop 3.3.3.3
Use ipv6 source destination to configure an IPv6 flow entry for Traffic Matrix.
Use undo ipv6 source destination to delete an IPv6 flow entry.
ipv6 [ protocol protocol ] source source-address destination dest-address [ source-port port destination-port port ] traffic-path interface interface-type interface-number next-hop ip-address
undo ipv6 [ protocol protocol ] source source-address destination dest-address [ source-port port destination-port port ]
Traffic Matrix does not have an IPv6 flow entry.
Traffic Matrix view
protocol protocol: Specifies a protocol type by its number in the range of 0 to 255. If you do not specify a protocol type, any protocol type can be matched.
source source-address: Specifies a source IPv6 address.
destination dest-address: Specifies a destination IPv6 address.
traffic-path interface interface-type interface-number: Redirects matching traffic to the specified interface for forwarding.
Operating mechanism
Multiple IPv6 flow entries can be configured for Traffic Matrix. If you configure multiple IPv6 flow entries with the same 5-tuple, the most recent configuration takes effect.
In the Traffic Matrix feature, the source address, destination address, and next-hop address in an IPv6 flow entry must all be valid unicast addresses.
The Traffic Matrix feature regularly queries the routing table to identify whether the next-hop address specified in the ipv6 source destination command is reachable in the routing table. If the next-hop address is unreachable, the ipv6 source destination command will no longer be effective.
If the same flow can match multiple IPv6 flow entries in the Traffic Matrix feature, the priority order for IPv6 flow entries is as follows:
1.     The IPv6 flow entry that is configured with the 5-tuple has the highest priority.
2.     Other IPv6 flow entries are matched in their order of configuration. When a match is found, the matching process stops.
# Configure an IPv6 flow entry.
[Sysname-traffic-matrix] ipv6 protocol 80 source 1::1 destination 2::2 source-port 8080 destination-port 8080 traffic-path interface gigabitethernet 1/0/1 next-hop 3::3
traffic-matrix
Use traffic-matrix to enable the Traffic Matrix feature and enter Traffic Matrix view.
Use undo traffic-matrix to disable the Traffic Matrix feature and delete all its flow tables.
traffic-matrix
undo traffic-matrix
The Traffic Matrix feature is disabled.
Application scenarios
In scenarios where AI model training occurs in data center networks or intelligent lossless networks, there are fewer traffic flows, but each flow has long transmission time and large data volumes. When traffic load sharing is conducted using the hash algorithm through equal-cost multi-path (ECMP), load imbalance can easily occur. To address uneven traffic load, enable the Traffic Matrix feature. The controller, based on the 5-tuple, deploys flow entries to leaf or spine devices to redirect traffic. Traffic is redirected to the specified path for forwarding, thus achieving manually controlled load sharing.
Operating mechanism
Traffic Matrix flow entries can be statically configured or dynamically generated.
·     Static configuration—You can use the ipv6 source destination or ip source destination command to generate a Traffic Matrix flow entry. A flow that matches a flow entry is forwarded according to the specified output interface and next hop.
·     Dynamic generation—In adaptive routing scenarios, the device automatically collects network node congestion data and dynamically generates Traffic Matrix flow entries.
Statically configured Traffic Matrix flow entries have higher priority than dynamically generated ones.
The device forwards traffic first according to the path defined in the flow table. If the defined path is invalid (for example, the output interface fails or the next hop is unreachable), the traffic is then forwarded by looking up the routing table.
# Enable the Traffic Matrix feature and enter Traffic Matrix view.
Elephant and mice flows distinguishing commands
elephant-flow action
Use elephant-flow action to configure an action to take on elephant flows.
Use undo elephant-flow action to restore the default.
elephant-flow action { drop-precedence drop-precedence-value | dot1p dot1p-value | local-precedence local-precedence-value | none }
No action is configured.
Elephant/mice flow view
drop-precedence drop-precedence-value: Specifies a drop precedence value in the range of 0 to 2.
dot1p dot1p-value: Specifies an 802.1p priority value in the range of 0 to 7.
local-precedence local-precedence-value: Specifies a local precedence value in the range of 0 to 7.
none: Takes no action.
# Specify drop precedence 2 for elephant flows.
[Sysname] qos mice-elephant-flow
[Sysname-mice-elephant-flow] elephant-flow action drop-precedence 2
elephant-flow rate
elephant-flow rate
Use elephant-flow rate to configure the traffic thresholds to identify elephant flows.
Use undo elephant-flow rate to remove traffic threshold settings.
elephant-flow rate rate [ gbps | kbps | mbps ] [ size size [ bytes | kbytes | mbytes ] ]
No traffic thresholds are configured.
rate [ gbps | kbps | mbps ]: Specifies the traffic rate threshold in Gbps, kbps, or Mbps. The default unit is kbps. The value range for the rate argument is 1 to 1000.
size size [ bytes | kbytes | mbytes ]: Specifies the traffic size threshold in bytes, KB, or MB. The default unit is byte. The value range for the rate argument is 1 to 1000.
The device assigns the drop precedence value specified the elephant-flow action command to the identified elephant flows and keeps the drop precedence of mice flows unchanged. When congestion occurs, packets with a lower or no drop precedence are preferentially forwarded.
# Specify the traffic thresholds as 20 kbps and 100 KB for identifying elephant flows.
[Sysname-mice-elephant-flow] elephant-flow rate 20 kbps size 100 kbytes
agile-buffer enable
Use agile-buffer enable to enable the flexible buffer for elephant and mice flows.
Use undo agile-buffer enable to disable the flexible buffer for elephant and mice flows.
agile-buffer enable
The flexible buffer for elephant and mice flows is disabled.
For the flexible buffer for elephant and mice flows to take effect, you must configure the following features:
·     Enable the feature of distinguishing elephant and mice flows as follows:
a.     Execute the elephant-flow rate command to configure the parameters for identifying elephant flows.
b.     Execute the elephant-flow action command with the local-precedence keyword specified to configure the local precedence of elephant flows.
·     Create a flow group in mice-elephant-flow mode or apply a predefined flow group in mice-elephant-flow mode. For more information about flow groups in mice-elephant-flow mode, see flow group commands in Telemetry Command Reference
The feature of distinguishing and scheduling elephant flows and mice flows statically configures parameters (for example, flow rate and size) to identify elephant flows in network traffic. Additionally, this feature specifies a lower drop priority, local priority, or 802.1p priority to these elephant flows. In the event of congestion, the device preferentially drops elephant flows based on the assigned priority to ensure fast forwarding of mice flows. The feature of distinguishing elephant and mice flows can partially resolve the issue that mice flows are blocked by elephant flows. However, in scenarios where the vast majority of traffic in the network contains mice flows or in scenarios of bursty traffic, the optimization effect of the elephant and mice flow distinguishing feature, which identifies flows through statically configured parameters, is not ideal. For example, in data center networks, where the majority of traffic contains mice flows that are more sensitive to delay. In the preceding scenarios, you can enable the flexible buffer for elephant and mice flows.
Operating mechanism
On the device, mice flow queues and elephant flow queues share a buffer space to schedule packets. This feature dynamically adjusts the size of the shared buffer space occupied by the mice flow queues and the elephant flow queues. When the network is congested and packets are dropped, the system dynamically reduces the upper limit of the shared buffer space available for elephant flow queues while ensuring high throughput of the elephant flows. In this case, the upper limit of the shared buffer space available for mice flow queues is increased, allowing the shared buffer space to accommodate as much mice flow traffic as possible, avoiding packet loss and reducing delay for mice flows. The device operates as follows after the flexible buffer for elephant and mice flows is enabled:
1.     By default, both the elephant flow queues and the mice flow queues use the tail-drop method to drop packets. In this case, when the length of either elephant flow queues or mice flow queues occupies the entire buffer space, all new packets entering the buffer space will be dropped.
2.     When the network is congested and packet loss occurs in the mice flow queues, the system triggers the flexible buffer feature for the elephant flows. In this case, the elephant flows use the WRED drop threshold. The system reduces the drop threshold of the elephant flow queues and uses the WRED method to drop elephant flow packets with a certain probability. As a result, the space for mice flow packets in the shared buffer increases.
3.     If the device still detects packet loss for mice flows after a certain detection period, this feature further lowers the WRED drop threshold for the elephant flow queues to increase the space for mice flow packets in the shared buffer.
4.     If no packet loss occurs in the mice flows during a detection period, this feature gradually restores the drop threshold of the elephant flow queues to the default tail drop method of the system.
With this feature enabled, the system will dynamically set the WRED drop threshold (the lower limit of the queue length) for the elephant flow queues. Therefore, this feature conflicts with the statically configured WRED parameters or a WRED table applied on an interface. If you both configure this feature and configure static WRED parameters or apply a WRED table, the static WRED parameters or applied WRED table takes precedence.
# Enable the flexible buffer for elephant and mice flows.
[Sysname-mice-elephant-flow] agile-buffer enable
elephant-flow rate
Use qos mice-elephant-flow to enter elephant/mice flow view.
# Enter elephant/mice flow view.
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics of HundredGigE 1/0/1.
<Sysname> display qos queue-statistics interface hundredgige 1/0/1 outbound
Interface: HundredGigE1/0/1
 Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Dropped: 1 packets, 1 bytes
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Dropped: 0 packets, 0 bytes
  Current queue length: 0 packets
 Queue 7
Table 29 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
Counts forwarded traffic both in packets and in bytes.
Dropped
Counts dropped traffic both in packets and in bytes.
Current number of packets in the queue.
reset counters interface (Interface Command Reference)
reset qos queue-statistics interface outbound
Use reset qos queue-statistics interface outbound to clear outgoing queue-based traffic statistics for an interface.
reset qos queue-statistics interface [ interface-type interface-number ] outbound
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears the outgoing queue-based traffic statistics for all interfaces.
# Clear the outgoing queue-based traffic statistics for all interfaces.
<Sysname> reset qos queue-statistics interface outbound
# Clear the outgoing queue-based traffic statistics for HundredGigE 1/0/1.
<Sysname> reset qos queue-statistics interface hundredgige 1/0/1 outbound
